06-接口管理命令参考
02-以太网接口命令
本章节下载 02-以太网接口命令  (796.97 KB)
02-以太网接口命令
  录
1 以太网接口
1.1 以太网接口通用配置命令
1.1.1 bandwidth
1.1.2 broadcast-suppression
1.1.3 dampening
1.1.4 default
1.1.5 description
1.1.6 display counters
1.1.7 display counters rate
1.1.8 display ethernet statistics
1.1.9 display ifmonitor interface statistics
1.1.10 display interface
1.1.11 display interface link-info
1.1.12 display interface main
1.1.13 display packet-drop
1.1.14 duplex
1.1.15 eee enable
1.1.16 flow-control
1.1.17 flow-control receive enable
1.1.18 flow-interval
1.1.19 ifmonitor crc-error
1.1.20 ifmonitor input-error
1.1.21 ifmonitor input-usage
1.1.22 ifmonitor interface statistics
1.1.23 ifmonitor output-error
1.1.24 ifmonitor output-usage
1.1.25 ifmonitor rx-pause
1.1.26 ifmonitor sdh-b1-error
1.1.27 ifmonitor sdh-b2-error
1.1.28 ifmonitor sdh-error
1.1.29 ifmonitor tx-pause
1.1.30 interface
1.1.31 jumboframe enable
1.1.32 loopback
1.1.33 multicast-suppression
1.1.34 port auto-power-down
1.1.35 port ifmonitor crc-error
1.1.36 port ifmonitor input-error
1.1.37 port ifmonitor input-usage
1.1.38 port ifmonitor output-error
1.1.39 port ifmonitor output-usage
1.1.40 port ifmonitor rx-pause
1.1.41 port ifmonitor sdh-b1-error
1.1.42 port ifmonitor sdh-b2-error
1.1.43 port ifmonitor sdh-error
1.1.44 port ifmonitor tx-pause
1.1.45 port link-mode
1.1.46 reset counters interface
1.1.47 reset counters mib interface
1.1.48 reset ethernet statistics
1.1.49 reset packet-drop interface
1.1.50 shutdown
1.1.51 shutdown all-physical-interfaces
1.1.52 snmp-agent trap enable ifmonitor
1.1.53 speed
1.1.54 sub-interface rate-statistic
1.1.55 unicast-suppression
1.2 二层以太网接口的配置命令
1.2.1 display storm-constrain
1.2.2 mdix-mode
1.2.3 storm-constrain
1.2.4 storm-constrain control
1.2.5 storm-constrain enable log
1.2.6 storm-constrain enable trap
1.2.7 storm-constrain interval
1.3 三层以太网接口/子接口的配置命令
1.3.1 mac-address
1.3.2 mtu
1.3.3 traffic-statistic enable
1 以太网接口
1.1  以太网接口通用配置命令
1.1.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
以太网接口视图
以太网子接口视图
context-admin
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口GigabitEthernet1/0/1的期望带宽为1000kbps。
[Sysname-GigabitEthernet1/0/1] bandwidth 1000
# 设置以太网子接口GigabitEthernet1/0/1.1的期望带宽为1000kbps。
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] bandwidth 1000
·     Speed
broadcast-suppression命令用来开启端口广播风暴抑制功能,并设置广播风暴抑制阈值。
undo broadcast-suppression命令用来关闭端口广播风暴抑制功能。
所有接口不对广播流量进行抑制。
以太网接口视图
context-admin
ratio:指定以太网接口允许通过的最大广播流量占该接口带宽的百分比,取值范围为0~100。数值越小,允许通过的广播流量也越小。
pps max-pps:指定以太网接口每秒允许转发的最大广播包数,单位为pps(packets per second,每秒转发的报文数),取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒允许转发的最大广播流量,单位为kbps(kilobits per second,每秒转发的千比特数),取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大广播报文流量。当接口上的广播流量超过用户设置的值后,系统将丢弃超出广播流量限制的报文,从而使接口广播流量所占的比例控制在限定的范围内,以便保证业务的正常运行。
执行broadcast-suppressionstorm-constrain命令都能开启端口的广播风暴抑制功能,storm-constrain命令通过软件对广播报文进行抑制,对设备性能有一定影响,broadcast-suppression通过芯片物理上对广播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置broadcast-suppressionstorm-constrain命令,以免配置冲突,导致抑制效果不确定。
当风暴抑制阈值配置为ppskbps时,设备可能会根据芯片支持的步长,将配置值转换成步长的倍数。所以,端口下配置的抑制阈值可能与实际生效抑制阈值不一致,请注意查看设备的提示信息。
# 在以太网接口GigabitEthernet1/0/1上,每秒最多允许10000kbps广播报文通过,对超出该范围的广播报文进行抑制。
[Sysname-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
·     multicast-suppression
·     unicast-suppression
1.1.3  dampening
dampening命令用来开启接口的dampening功能。
undo dampening命令用来恢复缺省情况。
undo dampening
接口的dampening功能处于关闭状态。
以太网接口视图
context-admin
half-life:半衰期,取值范围为1~120,单位为秒,缺省值为54。
reuse:启用值,取值范围为200~20000,缺省值为750,必须要小于suppress的值。
suppress:抑制门限,取值范围为200~20000,缺省值为2000。
max-suppress-time:最大抑制时间,取值范围为1~255,单位为秒,缺省值为半衰期的3倍,即162。
配置本命令时,各参数之间应满足以下关系,请根据该关系来选择参数的取值:
·     最大惩罚值=2(最大抑制时间/半衰期)×启用值,其中最大惩罚值不可配。
·     抑制值的配置值≤最大惩罚值≤抑制值可配的最大值
本命令对使用shutdown命令手动关闭的接口无效。手工shutdown接口时,dampening的惩罚值恢复为初始值0。
接口在抑制期发生up事件,通过display interface命令、MIB网管或Web网管等方式查看时,该接口的状态仍然为down。
# 按照缺省值开启接口GigabitEthernet1/0/1的dampening功能。
[Sysname-GigabitEthernet1/0/1] dampening
# 开启接口GigabitEthernet1/0/1的dampening功能,配置半衰期为2秒,启用值为800,抑制门限为3000,最大抑制时间为5秒。
[Sysname-GigabitEthernet1/0/1] dampening 2 800 3000 5
·     display interface
1.1.4  default
default命令用来恢复当前接口的缺省配置。
default
以太网接口视图
以太网子接口视图
context-admin
# 将以太网接口GigabitEthernet1/0/1恢复为缺省配置。
[Sysname-GigabitEthernet1/0/1] default
This command will restore the default settings. Continue? [Y/N]:y
# 将以太网子接口GigabitEthernet1/0/1.1恢复为缺省配置。
[Sysname-GigabitEthernet1/0/1.1] default
1.1.5  description
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“接口名 Interface”,例如:GigabitEthernet1/0/1 Interface。
以太网接口视图
以太网子接口视图
context-admin
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 设置以太网接口GigabitEthernet1/0/1的描述信息为“lan-interface”。
[Sysname-GigabitEthernet1/0/1] description lan-interface
# 设置以太网子接口GigabitEthernet1/0/1.1的描述信息为“subinterface1/0/1.1”。
[Sysname-GigabitEthernet1/0/1.1] description subinterface1/0/1.1
display counters命令用来显示接口的流量统计信息。
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
context-admin
context-operator
inbound:显示输入报文的流量统计信息。
outbound:显示输出报文的流量统计信息。
interface-type:指定接口类型。
interface-number:指定接口编号。
interface-number.subnumber:指定子接口。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
可通过命令reset counters interface清除以太网接口的统计信息。
如果不指定接口类型,则显示所有可统计的接口的流量统计信息。
如果指定接口类型而不指定接口编号,则显示该类型下所有接口的流量统计信息。
如果同时指定接口类型和接口编号,则显示指定接口/子接口的报文流量统计信息。
# 显示接口的报文输入流量统计信息。
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE1/0/1                       100                 100                   0           0
GE1/0/2                  Overflow            Overflow            Overflow    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
表1-1 display counters命令显示信息描述表
接口名称缩写
Total (pkts)
接口接收或发送报文的总数(单位为包)
Broadcast (pkts)
接口接收或发送广播报文的总数(单位为包)
Multicast (pkts)
接口接收或发送组播报文的总数(单位为包)
Err (pkts)
接口接收或发送错误报文的总数(单位为包)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围:
·     对于Err项,Overflow表示数据的长度超过了7位十进制数
·     对于其它项,Overflow表示数据的长度超过了14位十进制数
--: Not supported.
当某个统计信息的值为“--”时,表示设备不支持该项数据的统计
·     reset counters interface
display counters rate命令用来显示最近一个统计周期内处于up状态的接口的报文速率统计信息。
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
context-admin
context-operator
inbound显示报文接收速率统计信息。
outbound显示报文发送速率统计信息。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
如果不指定interface-typeinterface-number,则显示所有可统计的接口类型中最近一个统计周期内处于up状态的接口的报文速率统计信息。
如果指定interface-type而不指定interface-number,则显示该类型下最近一个统计周期内处于up状态接口的报文速率统计信息。
如果同时指定interface-typeinterface-number,则显示指定接口在最近一个统计周期内报文速率统计信息。如果该接口在最近一个统计周期内一直处于down状态,则提示接口不支持该操作。
统计周期可以通过flow-interval命令来配置。
# 显示接口的报文接收速率统计信息。
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
GE1/0/1                     0             0                --               --
 Overflow: More than 14 digits.
       --: Not supported.
表1-2 display counters rate命令显示信息描述表
接口名称缩写
Usage (%)
在最近一个统计周期内,接口的带宽利用率(单位为百分比)
分为两种计算方式:
·     普通组网中,接口的带宽利用率计算公式为:本地物理接口带宽/本端所有选中接口带宽总和
·     M-LAG组网中,接口的带宽利用率计算公式为:本端物理接口带宽/(本端所有选中接口带宽+对端所有选中接口带宽)
Total (pps)
在最近一个统计周期内,接口接收或发送所有类型报文的平均速率(单位为包/秒)
Broadcast (pps)
在最近一个统计周期内,接口接收或发送广播报文的平均速率(单位为包/秒)
Multicast (pps)
在最近一个统计周期内,接口接收或发送组播报文的平均速率(单位为包/秒)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了14位十进制数
--: Not supported.
当某个统计信息的值为“--”时,则表示设备不支持该项数据的统计
·     flow-interval
display ethernet statistics命令用来显示以太网软件模块收发报文的统计信息。
display ethernet statistics slot slot-number
context-admin
context-operator
slot slot-number:显示指定成员设备的统计信息,slot-number表示设备在IRF中的成员编号。对于本产品,slot-number只能为固定取值,表示整台设备。‌‌
# 显示指定slot上的以太网软件模块收发报文的统计信息。‌‌
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
表1-3 display ethernet statistics命令显示信息描述表
以太网软件模块接收到的以太网报文的统计信息:
·     Totalnum:接收报文的总个数
·     ETHIINum:接收的ETHII封装格式报文个数
·     SNAPNum:接收的SNAP封装格式报文个数
·     RAWNum:接收的RAW封装格式报文个数
·     ISISNum:接收的ISIS封装格式报文个数‌
·     LLCNum:接收的LLC封装格式报文个数
·     UnknowNum:接收的未知封装格式报文个数
·     ForwardNum:二层转发或上送CPU的报文个数
·     ARP:接收的ARP报文个数
·     MPLS:接收的MPLS报文个数(暂不支持)‌
·     ISIS:接收的ISIS报文个数‌
·     ISIS2:接收的ISIS2报文个数‌
·     IP:接收的IP报文个数
·     IPv6:接收的IPv6报文个数
以太网软件模块接收错误的以太网报文的统计信息(可能是包本身包含错误或者是接收动作出错了):
·     NullPoint:接收报文时指针为空的报文的个数
·     ErrIfindex:接收报文时接口索引错误的报文个数
·     ErrIfcb:接收报文时接口控制块错误的报文个数
·     IfShut:接收报文时接口shutdown的报文个数
·     ErrAnalyse:接收报文时报文解析错误的报文个数
·     ErrSrcMAC:接收的包含源MAC地址错误的报文个数
·     ErrHdrLen:接收的包含报文头长度错误的报文个数
以太网软件模块发送的以太网报文的统计信息:
·     L3OutNum:通过三层以太网接口发送的报文总个数‌
·     VLANOutNum:通过VLAN接口发送的报文总个数‌
·     FastOutNum:快速发送的报文总个数
·     L2OutNum:通过二层以太网接口发送的报文总个数
以太网软件模块发送的错误以太网报文的统计信息:
·     MbufRelayNum:透传发送的报文总个数
·     NullMbuf:发送报文时空指针错误的报文个数
·     ErrAdjFwd:发送报文时邻接表错误的报文个数
·     ErrPrepend:发送报文时扩展错误的报文个数
·     ErrHdrLen:发送的包含报文头长度错误的报文个数
·     ErrPad:发送报文时填充错误的报文个数
·     ErrVLANTrs:发送报文时VLAN发送失败的报文个数
·     ErrEncap:发送报文时封装链路头失败的报文个数
·     ErrTagVLAN:发送报文时封装VLAN TAG失败的报文个数
·     IfShut:发送报文时端口shutdown的报文个数
·     IfErr:发送报文时出接口错误的报文个数
·     reset ethernet statistics
display ifmonitor interface statistics命令用来显示物理接口的流量统计信息。
display ifmonitor interface statistics interface-type interface-number [ history ]
context-admin
context-operator
interface interface-type interface-number:显示指定接口的流量统计信息。interface-type interface-number表示接口类型和接口编号。
history:显示最近7×24小时内接口的历史流量统计信息。如果未指定本参数,则只显示最近24小时内接口的历史流量统计信息。
使用本命令查看接口历史流量统计信息时,请先在系统视图下配置ifmonitor interface statistics命令全局开启物理接口流量统计功能。
# 显示三层以太网接口GigabitEthernet1/0/1的流量统计信息。
<Sysname> display ifmonitor interface statistics gigabitethernet 1/0/1
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Peak input rate: 0 bytes/sec, at 2013-07-07 16:07:11
Peak output rate: 0 bytes/sec, at 2013-07-07 16:07:11
Last one hour input: 0 packets/sec 0 bytes/sec 0%
Last one hour output: 0 packets/sec 0 bytes/sec 0%
IPv4 traffic statistics:
 Last one hour input rate: 0 packets/sec, 0 bytes/sec
 Last one hour seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 0 packets, 0 bytes
 Output: 0 packets, 0 bytes
IPv6 traffic statistics:
 Last one hour output rate: 0 packets/sec, 0 bytes/sec
Input (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
Input  (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
 Top 10 peak input bit rates: 30000 bits/sec at 2020-08-20 09:18:27
                              29000 bits/sec at 2020-08-20 08:16:24
                              28000 bits/sec at 2020-08-20 07:14:21
                               27000 bits/sec at 2020-08-20 06:12:18
                               26000 bits/sec at 2020-08-20 05:10:15
                               25000 bits/sec at 2020-08-20 04:08:12
                               24000 bits/sec at 2020-08-20 03:06:09
                               23000 bits/sec at 2020-08-20 02:04:06
                               22000 bits/sec at 2020-08-20 01:02:03
                               21000 bits/sec at 2020-08-20 00:00:00
 Top 10 peak input packet rates: 90000 packets/sec at 2020-08-20 09:18:27
                                 87000 packets/sec at 2020-08-20 08:16:24
                                 84000 packets/sec at 2020-08-20 07:14:21
                                 81000 packets/sec at 2020-08-20 06:12:18
                                 78000 packets/sec at 2020-08-20 05:10:15
                                 75000 packets/sec at 2020-08-20 04:08:12
                                 72000 packets/sec at 2020-08-20 03:06:09
                                 69000 packets/sec at 2020-08-20 02:04:06
                                 66000 packets/sec at 2020-08-20 01:02:03
                                 63000 packets/sec at 2020-08-20 00:00:00
 Top 10 peak output bit rates: 60000 bits/sec at 2020-08-20 09:18:27
                               58000 bits/sec at 2020-08-20 08:16:24
                               56000 bits/sec at 2020-08-20 07:14:21
                               54000 bits/sec at 2020-08-20 06:12:18
                               52000 bits/sec at 2020-08-20 05:10:15
                               50000 bits/sec at 2020-08-20 04:08:12
                               48000 bits/sec at 2020-08-20 03:06:09
                               46000 bits/sec at 2020-08-20 02:04:06
                               44000 bits/sec at 2020-08-20 01:02:03
                               42000 bits/sec at 2020-08-20 00:00:00
 Top 10 peak output packet rates: 120000 packets/sec at 2020-08-20 09:18:27
                                  116000 packets/sec at 2020-08-20 08:16:24
                                  112000 packets/sec at 2020-08-20 07:14:21
                                  108000 packets/sec at 2020-08-20 06:12:18
                                  104000 packets/sec at 2020-08-20 05:10:15
                                  100000 packets/sec at 2020-08-20 04:08:12
                                  96000 packets/sec at 2020-08-20 03:06:09
                                  92000 packets/sec at 2020-08-20 02:04:06
                                  88000 packets/sec at 2020-08-20 01:02:03
                                  84000 packets/sec at 2020-08-20 00:00:00
# 查看二层以太网接口GigabitEthernet1/0/1的流量统计信息。
Bandwidth: 100000 kbps
Maximum frame length: 9216
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Last one hour input: 0 packets/sec 0 bytes/sec -%
 Last one hour second output: 0 packets/sec 0 bytes/sec -%
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
表1-4 display interface命令显示信息描述表
接口GigabitEthernet1/0/1的相关信息
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
输出队列中——紧急队列的信息:队列中当前缓存的报文的个数/队列最多可缓存的报文个数/队列已丢弃的报文的个数
输出队列中——协议队列的信息:队列中当前缓存的报文的个数/队列最多可缓存的报文个数/队列已丢弃的报文的个数
输出队列中——FIFO队列的信息:队列中当前缓存的报文的个数/队列最多可缓存的报文个数/队列已丢弃的报文的个数
Last clearing of counters
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
端口在最近一小时接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比
如果值显示为“-”,则表示不支持该统计项
Input(total):  0 packets, 0 bytes
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
Input(normal):  0 packets, 0 bytes
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧
giants
接收到的超大帧的数量
超大帧是指有效长度大于端口允许通过最大报文长度的帧:
·     对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧
·     对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧
throttles
接收到的长度为非整数字节的帧的个数
CRC
接收到的CRC校验错误、长度正常的帧的数量
frame
接收到的CRC校验错误、且长度不是整字节数的帧的数量
overruns
当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃
aborts
接收到的非法报文总数,非法报文包括:
·     报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧
·     jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧
·     符号错误帧:报文中至少包含1个错误的符号
·     操作码未知帧:报文是MAC控制帧,但不是Pause帧
·     长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配
ignored
由于端口接收缓冲区不足等原因而丢弃的报文数量
parity errors
接收到的奇偶校验错误的帧的数量
Output(total): 0 packets, 0 bytes
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
Output(normal): 0 packets, 0 bytes
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
output errors
各种发送错误的报文总数
underruns
当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败
deferred
延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
collisions
冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
late collisions
延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
lost carrier
(暂不支持)载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
no carrier
(暂不支持)无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
Peak input rate
接口输入流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
Peak output rate
接口输出流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
Top n peak input bit rates
接口输入流量的最大速率的前n个值(单位为bits/sec)以及产生的时间
Top n peak output bit rates
接口输出流量的最大速率的前n个值(单位为bits/sec)以及产生的时间
Top n peak input packet rates
接口输入包的最大速率的前n个值(单位为packets/sec)以及产生的时间
Top n peak output packet rates
接口输出包的最大速率的前n个值(单位为packets/sec)以及产生的时间
IPv4报文统计信息
IPv6报文统计信息
端口在最近300秒接收报文的平均速率,单位分别为数据包/秒和字节/秒
端口在最近300秒发送报文的平均速率,单位分别为数据包/秒和字节/秒
端口接收报文的统计值,包括报文数、字节数
端口发送报文的统计值,包括报文数、字节数
·     ifmonitor interface statistics
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
context-admin
context-operator
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示。
如果不指定接口类型和接口编号,则显示所有接口的信息。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看三层以太网接口GigabitEthernet1/0/1的运行状态和相关信息。
<Sysname> display interface gigabitethernet 1/0/1
Line protocol state: DOWN
Allow jumbo frames to pass
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Media type is twisted pair, loopback not set, promiscuous mode set
Speed Negotiation, Duplex Negotiation, link type is autonegotiation
Output flow-control is disabled, input flow-control is disabled
Last link flapping: Never
Current system time:2078-11-09 17:58:38
Last time when physical state changed to up:-
Last time when physical state changed to down:2078-11-01 21:21:23
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
 Last 300 second input: 0 packets/sec 0 bytes/sec -%
 Last 300 second output: 0 packets/sec 0 bytes/sec -%
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 ignored, - parity errors
 Output: 0 output errors, 0 underruns, - buffer failures
IPv4 trafficstatistics:
Last 300 seconds input rate: 300 packets/sec, 230000 bytes/sec
Last 300 seconds output rate: 200 packets/sec, 220000 bytes/sec
Input: 12 packets, 1968 bytes
 Last 300 seconds input rate: 300 packets/sec, 230000bytes/sec
 Last 300 seconds output rate: 200 packets/sec,220000 bytes/sec
# 查看二层以太网接口GigabitEthernet1/0/1的运行状态和相关信息。
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Flow-control is not enabled
Allow jumbo frame to pass
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Last link flapping: 6 hours 39 minutes 25 seconds
Last hardware down reason: PHY line side is down
Last clearing of counters:  14:34:09 Tue 11/01/2011
Current system time:2017-12-09 10:59:08
Last time when physical state changed to down:2017-12-09 10:59:07
表1-5 display interface命令显示信息描述表
Current state
接口的物理状态,状态可能为:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭
·     DOWN ( Tunnel-Bundle administratively down ):表示该接口所属的Tunnel-Bundle接口已经通过shutdown命令被关闭
·     DOWN ( Monitor-Link uplink down ):Monitor Link联动而导致接口被关闭
·     ETH-rddc Shutdown:表示该接口被冗余组模块关闭,即接口状态为冗余关闭
·     mac-address moving down:由于MAC地址迁移抑制导致接口被关闭
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为MAD ShutDown
·     Storm-Constrain:表示端口上因为组播或广播报文中某类报文的流量大于其上限阈值而被关闭
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
·     DOWN:表示数据链路层协议状态为关闭
·     DOWN(protocols):表示接口的数据链路层被一个或者多个协议模块关闭。protocols为LAGG等的任意组合:
¡     LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层
The peer line protocol state is DOWN(Bit-error down)
远端接口发生误码故障,其链路层协议状态置为关闭
本端接口收到远端接口误码故障消息时显示本字段
Link quality grade
链路质量等级:
·     GOOD:链路质量优。误码率未达到高误码率门限或者误码率从大于等于高误码率门限回落到小于低误码率门限时,显示为GOOD
·     LOW:链路质量差。误码率达到高误码率门门限时,链路质量显示为LOW
未配置link-quality crc-error bit-error-ratio命令时,不显示本字段
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     Unnumbered:借用其他接口的IP地址
·     MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术配置指导”中的“IRF”
Type的取值情况与接口类型有关,请以实际情况为准
IPv4报文发送帧格式
hardware address
接口的MAC地址
IPv6报文发送帧格式
Media type is
接口的介质类型
Port hardware type is
接口的硬件类型
FEC mode
FEC模式,该显示信息与用户的配置有关
Port priority
接口优先级
Loopback is set internal
以太网接口正在进行对内环回测试,该显示信息与用户的配置有关
Loopback is set external
对以太网接口进行对外环回测试,该显示信息与用户的配置有关
Loopback is not set
接口上未配置环回测试,该显示信息与用户的配置有关
10Mbps-speed mode
接口速率为10Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
100Mbps-speed mode
接口速率为100Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
1000Mbps-speed mode
接口速率为1000Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
2.5Gbps-speed mode
接口速率为2.5Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
5Gbps-speed mode
接口速率为5Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
10Gbps-speed mode
接口速率为10Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
40Gbps-speed mode
接口速率为40Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
Unknown-speed mode
速率未知,可能因为速率协商失败或者接口物理未连通
half-duplex mode
接口工作在半双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
full-duplex mode
接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
unknown-duplex mode
未知双工模式,可能因为双工模式协商失败或者接口物理未连通
当用户配置了speed auto时显示该信息
Link speed type is force link
当用户使用speed命令配置了具体的速率时显示该信息,例如1000M等
当用户配置了duplex auto时显示该信息
link duplex type is force link
当用户使用duplex命令配置了具体的双工模式时显示该信息,例如half或者full
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关‌
接口允许通过的最大以太网帧长度
允许长帧通过
Broadcast max-
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Multicast max-
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Unicast max-
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
PVID
接口所在的缺省VLAN ID
MDI type
网线类型,取值为automdix、mdi或mdix,与用户的配置有关
Port link-type
链路类型,取值为access、trunk或hybrid,与用户的配置有关
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
VLAN Passing
该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN)
VLAN permitted
接口允许通过的VLAN报文
Trunk port encapsulation
Trunk接口的封装格式
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
接口最近一次硬件down的原因:
·     PHY line side is down:PHY线路侧down
·     PHY system side is down:PHY系统侧down
·     No optical signal has been received at the optical port:光口未收到光信号
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,时间显示格式为YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS
最近一次接口物理状态变为UP的时刻
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
Last 300 second input:  0 packets/sec 0 bytes/sec 0%
Last 300 second output:  0 packets/sec 0 bytes/sec 0%
端口在最近300秒接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
giants
接收到的超大帧的数量
throttles
接收到的长度为非整数字节的帧的个数
CRC
frame
overruns
aborts
接收到的非法报文总数,非法报文包括:
ignored
parity errors
接收到的奇偶校验错误的帧的数量
output errors
各种发送错误的报文总数
underruns
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
deferred
collisions
late collisions
lost carrier
no carrier
Peak input rate
Peak output rate
IPv4报文统计信息
IPv6报文统计信息
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
# 显示所有接口的概要信息。
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
GE1/0/1              DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   UP       --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
GE1/0/2              DOWN auto    A      A    1
GE1/0/3              UP   1G(a)   F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示接口GigabitEthernet1/0/1的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface gigabitethernet 1/0/1 brief description
Speed: (a) - auto
GE1/0/1              UP   1G(a)   F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示当前物理状态为down的接口的信息以及down的原因。
GE1/0/1              DOWN Not connected
Vlan2                DOWN Not connected
GE1/0/2              DOWN Not connected
表1-6 display interface brief命令显示信息描述表
三层模式下(route)接口的概要信息,即三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
Protocol: (s) - spoofing
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
接口名称缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层协议状态为开启
·     DOWN:表示接口的数据链路层协议状态为关闭
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会取该值
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Brief information of interfaces in bridge mode:
二层模式下(bridge)的接口概要信息,即二层接口的概要信息
Speed: (a) - auto
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始
如果某接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
当显示为“A”时表示该接口的Duplex属性是通过自动协商获取的,但协商还未开始
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
Speed
接口的速率,单位为bps
Duplex
接口的双工模式,取值为:
·     A:表示双工模式由自动协商结果决定
·     F:表示全双工
·     F(a):表示自由协商的结果为全双工
·     H:表示半双工
·     H(a):表示自由协商的结果为半双工
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     DOWN ( Link-Aggregation interface down ):聚合接口被关闭后,该聚合接口的所有成员端口的状态会显示为DOWN,down的原因会显示为DOWN ( Link-Aggregation interface down )
·     DOWN (Loopback detection down):由于环路检测模块检测到环路而自动关闭接口
·     DOWN ( Monitor-Link uplink down ):由于Monitor Link模块检测到上行链路down而自动关闭接口
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为DOWN,down的原因会显示为MAD ShutDown
·     Not connected:表示没有物理连接(可能没有插网线或者网线故障)
·     Standby:表示接口处于备份状态
display interface link-info命令用来显示接口的状态和报文统计等信息。
display interface link-info [ main ] [ verbose ]
context-admin
context-operator
down:显示当前物理状态为down的接口的信息。不指定该参数时,将不会根据接口物理状态过滤显示信息。
up:显示当前物理状态为up的接口的信息。不指定该参数时,将不会根据接口物理状态过滤显示信息。
main:显示除子接口外的所有接口的状态和报文统计等信息。不指定该参数,显示所有接口的状态和报文统计等信息。
verbose:显示详细信息。如果不指定该参数,则显示简要信息。
# 显示所有接口的状态和报文统计等信息。
<Sysname> display interface link-info
Interface                         Link Pro   InUsage OutUsage   InErrs  OutErrs Description
GE1/0/1                         UP   UP      0.05%    0.05%     3000     3000
NULL0                           UP   UP(s)      -%       -%        0        0
BAGG11                          ADM  DOWN       --       --       --       --
GE1/0/2                         DOWN DOWN       --       --       --       --
RAGG11                          ADM  DOWN       --       --       --       --
GE1/0/3                         DOWN DOWN       --       --       --       --
 Overflow: More than 7 digits.
       --: Not supported.
# 显示所有接口的状态和报文统计等详细信息。
<Sysname> display interface link-info verbose
Interface                         Link Pro   InUsage OutUsage   InTotal(pps)  Ou
tTotal(pps)  InTotal(pkt) OutTotal(pkt)   InErrs  OutErrs Description
表1-7 display interface link-info命令显示信息描述表
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会具有该属性
接口名简称
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
Pro
接口数据链路层协议状态,取值为:
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会取该值
InUsage
接收方向最近一个统计周期的带宽利用率。接口接收方向最近一个统计周期内的带宽利用率=接口接收方向最近一个统计周期内平均速率/接口带宽。不足0.01%且有流量时显示0.01%。统计周期可以通过flow-interval命令进行设置
OutUsage
发送方向最近一个统计周期的带宽利用率。接口发送方向最近一个统计周期内的带宽利用率=接口发送方向最近一个统计周期内平均速率/接口带宽。不足0.01%且有流量时显示0.01%。统计周期可以通过flow-interval命令进行设置
InTotal(pps)
在最近一个统计周期内,接口接收所有类型报文的平均速率(单位为包/秒)
OutTotal(pps)
在最近一个统计周期内,接口发送所有类型报文的平均速率(单位为包/秒)
InTotal(pkt)
接口接收的报文总数(单位为包)
OutTotal(pkt)
接口发送的报文总数(单位为包)
InErrs
接口接收的错误报文总数(单位为包)
OutErrs
接口发送的错误报文总数(单位为包)
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围,Overflow表示数据的长度超过了7位十进制数
--: Not supported.
·     flow-interval
display interface main命令用来显示除子接口以外的接口的运行状态和相关信息。
display interface [ interface-type ] [ brief [ description | down ] ] main
context-admin
context-operator
interface-type:指定接口类型。如果不指定本参数,则显示所有类型接口的信息。
# 查看除子接口以外的接口的运行状态和相关信息。
<Sysname> display interface main
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 487a-da93-a93f
Loopback is not set
PVID: 1
MDI type: Automdix
 Tagged VLANs:   None
 Untagged VLANs: 1
Current system time:2020-12-09 13:35:28
Last time when physical state changed to down:2020-12-09 09:24:04
GigabitEthernet1/0/2
Current state: DOWN
Description: GigabitEthernet1/0/2 Interface
Dampening enabled:
 Penalty: 0 (not suppressed)
 Ceiling: 4525
 Reuse: 800
 Suppress: 3000
 Half-life: 2 seconds
 Max-suppress-time: 5 seconds
 Flap count: 0
IP packet frame type: Ethernet II, hardware address: 487a-da93-a940
IPv6 packet frame type: Ethernet II, hardware address: 487a-da93-a940
Media type is twisted pair, loopback not set, promiscuous mode not set
Last time when physical state changed to down:2020-12-08 15:14:18
# 显示除子接口以外所有接口的概要信息。
<Sysname> display interface brief main
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Speed: (a) - auto
# 显示除子接口以外的接口的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface  brief description main
Speed: (a) - auto
GE1/0/3              UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示除子接口以外当前物理状态为down的接口的信息以及down的原因。
<Sysname> display interface brief down main
显示信息描述请参见display interface命令。
display packet-drop命令用来显示接口丢弃的报文的信息。
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
context-admin
context-operator
summary:将所有接口丢弃报文的统计信息累计后再显示。
如果不指定接口类型和接口编号,显示所有接口丢弃的报文的信息。
如果仅指定接口类型,显示该类型所有接口丢弃的报文的信息。
# 显示接口GigabitEthernet1/0/1丢弃报文的信息。
<Sysname> display packet-drop interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Fast Filter Processor (FFP): 261
Packets dropped due to rate-limit: 143
Packets dropped due to broadcast-suppression: 301
Packets dropped due to unicast-suppression: 215
Packets dropped due to multicast-suppression: 241
Packets dropped due to Tx packet aging: 246
# 将所有接口丢弃报文的统计信息累计后再显示。
<Sysname> display packet-drop summary
All interfaces:
表1-8 display packet-drop命令显示信息描述表
由于芯片缓存满或者带宽不够导致的丢包数
由于数据包被过滤所导致的丢包数
由于速率限制导致的丢包数
由于广播抑制导致的丢包数
由于未知单播抑制导致的丢包数
由于组播抑制导致的丢包数
由于出方向报文超时导致的丢包数
1.1.14  duplex
duplex命令用来设置以太网接口的双工模式。
undo duplex命令用来恢复缺省情况。
duplex { auto | full | half }
undo duplex
以太网接口的双工模式为auto(自协商)状态。
以太网接口视图
context-admin
auto:接口与对端接口自动协商双工状态。
full:全双工状态,接口在发送数据包的同时可以接收数据包。
half:半双工状态,接口同一时刻只能发送数据包或接收数据包。
# 将以太网接口GigabitEthernet1/0/1接口设置为全双工状态。
[Sysname-GigabitEthernet1/0/1] duplex full
1.1.15  eee enable
eee enable命令用来开启EEE(Energy Efficient Ethernet)节能功能。
undo eee enable命令用来关闭EEE节能功能。
eee enable
undo eee enable
EEE节能功能处于关闭状态。
以太网接口视图
context-admin
接口开启EEE节能功能后,如果在连续一段时间(由芯片规格决定,不能通过命令行配置)内接口状态始终为up且没有收发任何报文,则接口自动进入低功耗模式;当接口需要收发报文时,接口又自动恢复到正常工作模式,从而达到节能的效果。
# 在GigabitEthernet1/0/1下开启EEE节能功能。
[Sysname-GigabitEthernet1/0/1] eee enable
1.1.16  flow-control
flow-control命令用来开启以太网接口的流量控制功能。
undo flow-control命令用来关闭以太网接口流量控制功能。
flow-control
undo flow-control
以太网接口的流量控制功能处于关闭状态。
以太网接口视图
context-admin
配置flow-control命令后,设备具有发送和接收流量控制报文的能力:
·     当本端发生拥塞时,设备会向对端发送流量控制报文。
·     当本端收到对端的流量控制报文后,会停止报文发送。
只有本端和对端设备都开启了流量控制功能,才能实现对本端以太网接口的流量控制。
# 开启以太网接口GigabitEthernet1/0/1的流量控制功能。
[Sysname-GigabitEthernet1/0/1] flow-control
flow-control receive enable命令用来开启以太网接口的接收流量控制功能。
undo flow-control命令用来关闭以太网接口的接收流量控制功能。
undo flow-control
以太网接口的接收流量控制功能处于关闭状态。
以太网接口视图
context-admin
配置flow-control receive enable命令后,设备具有接收流量控制报文的能力,但不具有发送流量控制报文的能力。
开启以太网接口的接收流量控制功能后:
·     当设备收到对端的流量控制报文,会停止向对端发送报文。
·     当本端发生拥塞时,设备不能向对端发送流量控制报文。
如果要应对单向网络拥塞的情况,可以在一端配置flow-control receive enable,在对端配置flow-control;如果要求本端和对端网络拥塞都能处理,则两端都必须配置flow-control
# 使能以太网接口GigabitEthernet1/0/1的接收流量控制功能。
[Sysname-GigabitEthernet1/0/1] flow-control receive enable
【相关配置】
·     flow-control
flow-interval命令用来配置接口统计报文信息的时间间隔。
undo flow-interval命令用来恢复缺省情况。
flow-interval interval
undo flow-interval
接口统计报文信息的时间间隔为300秒。
以太网接口视图
context-admin
interval:接口统计信息的时间间隔值,取值范围为5~300,单位为秒,步长为5(即取值必须为5的整数倍)。
Context中的共享接口不支持该命令。
# 设置以太网接口GigabitEthernet1/0/1的统计信息时间间隔为100秒。
[Sysname-GigabitEthernet1/0/1] flow-interval 100
ifmonitor crc-error命令用来全局配置CRC错误报文告警参数。
undo ifmonitor crc-error命令用来恢复缺省情况。
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
CRC错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定CRC错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定CRC错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的CRC错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因CRC错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的CRC错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
slot slot-number:配置指定成员设备的参数。slot-number为设备在IRF中的成员编号。对于本产品,slot-number只能为固定取值,表示整台设备。‌‌
开启CRC错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的CRC错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的CRC错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置CRC错误报文告警参数。
·     系统视图下的配置对所有接口有效,接口视图下的配置只对当前接口有效。(不支持指定slot的设备)
·     系统视图下的配置对指定slot的所有接口有效,接口视图下的配置只对当前接口有效。(支持指定slot的设备)
·     对于接口来说,优先采用接口视图下的配置,当该接口未进行配置时,才采用系统视图下的配置。
多次执行本命令,最后一次执行的命令生效。
# 配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
·     snmp-agent trap enable ifmonitor
ifmonitor input-error命令用来全局配置入方向错误报文告警参数。
undo ifmonitor input-error命令用来恢复缺省情况。
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
入方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定接口入方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口入方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口入方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口入方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启入方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内入方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内入方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向错误报文告警参数。
# 配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage命令用来全局配置入方向带宽利用率的告警参数。
undo ifmonitor input-usage命令用来恢复缺省情况。
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
入方向带宽利用率告警的上限阈值为90,下限阈值为80。
context-admin
high-threshold high-value:指定入方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内入方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内入方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
关于统计周期的值,分为以下几种情况:
·     不支持flow-interval命令的设备,统计周期固定为5分钟。
·     对于支持flow-interval命令的设备,统计周期可以通过flow-interval命令来配置。
用户可在系统视图和接口视图下配置入方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启入方向带宽利用率告警功能后才能生效。
# 配置全局入方向带宽利用率告警上限阈值为95,入方向带宽利用率告警下限阈值为80。
[Sysname] ifmonitor input-usage high-threshold 95 low-threshold 80
·     flow-interval
ifmonitor interface statistics命令用来开启物理接口流量统计功能。
undo ifmonitor interface statistics
物理接口流量统计功能处于开启状态。
context-admin
开启本功能后,设备每一小时对设备上的所有物理接口进行一次流量统计,设备上可以保存最近7天的统计信息,当统计信息超过7天后就会被新的统计信息覆盖。
# 开启物理接口流量统计功能。
[sysname] ifmonitor interface statistics
·     display ifmonitor interface statistics
ifmonitor output-error命令用来全局配置出方向错误报文告警参数。
undo ifmonitor output-error命令用来恢复缺省情况。
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
出方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定接口出方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口出方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口出方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口出方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启出方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内出方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内出方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向错误报文告警参数。
# 配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage命令用来全局配置出方向带宽利用率的告警参数。
undo ifmonitor output-usage命令用来恢复缺省情况。
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
出方向的带宽利用率告警的上限阈值为90,下限阈值为80。
context-admin
high-threshold high-value:指定出方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定出方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内出方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内出方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
关于统计周期的值,分为以下几种情况:
用户可在系统视图和接口视图下配置出方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启出方向带宽利用率告警功能后才能生效。
# 配置全局出方向带宽利用率告警上限阈值为80,出方向带宽利用率告警下限阈值为60。
[Sysname] ifmonitor output-usage high-threshold 80 low-threshold 60
·     flow-interval
ifmonitor rx-pause命令用来全局配置接收PAUSE帧告警参数。
undo ifmonitor rx-pause命令用来恢复缺省情况。
ifmonitor rx-pause  slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
接收PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定接收PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接收PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内接收PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置接收PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启接收PAUSE帧告警功能后才能生效。
# 配置接收PAUSE帧告警上限阈值为30,接收PAUSE帧告警下限阈值为20,接收PAUSE帧数据收集和比较时间间隔为4秒。
[Sysname] ifmonitor rx-pause high-threshold 30 low-threshold 20 interval 4
ifmonitor sdh-b1-error命令用来全局配置SDH-B1错误报文告警参数。
undo ifmonitor sdh-b1-error命令用来恢复缺省情况。
ifmonitor sdh-b1-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-b1-error slot slot-number
SDH-B1错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定SDH-B1错误报文告警上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定SDH-B1错误报文告警下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定SDH-B1错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B1错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B1错误而被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B1错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH-B1错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH-B1错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH-B1错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH-B1错误报文告警功能后才能生效。
# 配置SDH-B1错误报文告警上限阈值为65,SDH-B1错误报文告警下限阈值为25,SDH-B1错误报文数据收集和比较时间间隔为20秒。
[Sysname] ifmonitor sdh-b1-error high-threshold 65 low-threshold 25 interval 20
ifmonitor sdh-b2-error命令用来全局配置SDH-B2错误报文告警参数。
undo ifmonitor sdh-b2-error命令用来恢复缺省情况。
ifmonitor sdh-b2-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-b2-error slot slot-number
SDH-B2错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定接口SDH-B2错误报文告警上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B2错误报文告警下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH-B2错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B2错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B2错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B2错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH-B2错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH-b2错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH-B2错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH-B2错误报文告警功能后才能生效。
# 配置SDH-B2错误报文告警上限阈值为6,SDH-B2错误报文告警下限阈值为5,SDH-B2错误报文数据收集和比较时间间隔为2秒。
[Sysname] ifmonitor sdh-b2-error high-threshold 6 low-threshold 5 interval 2
ifmonitor sdh-error命令用来全局配置SDH错误报文告警参数。
undo ifmonitor sdh-error命令用来恢复缺省情况。
ifmonitor sdh-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-error slot slot-number
SDH错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定SDH错误报文告警上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定SDH错误报文告警下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定SDH错误报文数据收集和比较时间间隔,取值范围为1~65535,单位为秒。
shutdown:表示当接口接收到SDH错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH错误报文达到上限告警阈值,不会关闭该接口,同时该接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH错误报文告警功能后才能生效。
# 配置SDH错误报文告警上限阈值为35,SDH错误报文告警下限阈值为20,SDH错误报文数据收集和比较时间间隔为8秒。
[Sysname] ifmonitor sdh-error high-threshold 35 low-threshold 20 interval 8
ifmonitor tx-pause命令用来全局配置发送PAUSE帧告警参数。
undo ifmonitor tx-pause命令用来恢复缺省情况。
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor tx-pause slot slot-number
发送PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
context-admin
high-threshold high-value:指定发送PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定发送PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内发送PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内发送PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置发送PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启发送PAUSE帧告警功能后才能生效。
# 配置发送PAUSE帧告警上限阈值为20,发送PAUSE帧告警下限阈值为10,发送PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname] ifmonitor tx-pause high-threshold 20 low-threshold 10 interval 5
1.1.30  interface
interface命令用来进入接口视图或创建子接口并进入子接口视图。如果指定的子接口已经存在,则直接进入子接口视图。
context-admin
# 进入以太网接口GigabitEthernet1/0/1视图。
# 创建以太网子接口GigabitEthernet1/0/1.1并进入该子接口的视图。
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
以太网接口上允许通过的超长帧的最大长度为9216字节。
二层以太网接口视图
三层以太网接口视图
context-admin
# 允许超长帧通过以太网接口GigabitEthernet1/0/1。
[Sysname-GigabitEthernet1/0/1] jumboframe enable
1.1.32  loopback
开启环回功能后,接口将不能正常转发数据包,请按需配置。
loopback命令用来开启以太网接口的环回功能。
undo loopback命令用来关闭以太网接口的环回功能。
undo loopback
以太网接口的环回功能处于关闭状态。
以太网接口视图
context-admin
external:开启以太网接口的外部环回功能。
internal:开启以太网接口的内部环回功能。
开启环回功能后,接口将自动切换到全双工模式,关闭环回功能后会自动恢复原有双工模式。
shutdownloopback命令互斥,后配置的失败。
# 开启以太网接口GigabitEthernet1/0/1的内部环回功能。
[Sysname-GigabitEthernet1/0/1] loopback internal
multicast-suppression命令用来开启端口组播风暴抑制功能,并设置组播风暴抑制阈值。
undo multicast-suppression命令用来关闭端口组播风暴抑制功能。
所有接口不对组播流量进行抑制。
以太网接口视图
context-admin
ratio:指定以太网接口允许通过的最大组播流量占该接口带宽的百分比。取值范围为0~100。数值越小,则允许通过的组播流量也越小。
pps max-pps:指定以太网接口每秒最多通过的组播包包数,取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒最多通过的组播流量,单位为kbps,取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大组播报文流量。当接口上的组播流量超过用户设置的值后,系统将丢弃超出组播流量限制的报文,从而使接口组播流量所占的比例控制在限定的范围内,以便保证业务的正常运行。
执行multicast-suppressionstorm-constrain命令都能开启端口的组播风暴抑制功能,storm-constrain命令通过软件对组播报文进行抑制,对设备性能有一定影响,multicast-suppression通过芯片物理上对组播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置multicast-suppressionstorm-constrain命令,以免配置冲突,导致抑制效果不确定。
# 在以太网接口GigabitEthernet1/0/1上,每秒最多允许10000kbps组播报文通过,对超出该范围的组播报文进行抑制。
[Sysname-GigabitEthernet1/0/1] multicast-suppression kbps 10000
·     broadcast-suppression
port auto-power-down命令用来开启down状态接口节能功能。
undo port auto-power-down命令用来关闭down状态接口节能功能。
down状态接口节能功能处于关闭状态。
context-admin
配置该命令后,如果在连续一段时间(由芯片规格决定,不能通过命令行配置)内接口状态始终为down,则系统会自动停止对该接口供电,接口自动进入节能模式;当接口状态变为up时,系统会自动恢复对该接口供电,接口自动进入正常模式,从而达到节能的效果。
# 开启以太网接口GigabitEthernet1/0/1的down状态节能功能。
[Sysname-GigabitEthernet1/0/1] port auto-power-down
port ifmonitor crc-error命令用来配置CRC错误报文告警参数。
undo port ifmonitor crc-error命令用来恢复缺省情况。
接口采用的CRC错误报文告警参数与全局采用的CRC错误报文告警参数一致。
以太网接口视图
context-admin
ratio:表示以百分比形式配置告警阈值。不指定该参数时,表示配置的是告警阈值的大小。
high-threshold high-value:指定CRC错误报文告警上限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
# 在接口GigabitEthernet1/0/1上配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-error命令用来配置入方向错误报文告警参数。
undo port ifmonitor input-error命令用来恢复缺省情况。
接口采用的入方向错误报文告警参数与全局采用的入方向错误报文告警参数一致。
以太网接口视图
context-admin
# 在接口GigabitEthernet1/0/1上配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage命令用来配置入方向带宽利用率的告警参数。
undo port ifmonitor input-usage命令用来恢复缺省情况。
接口采用的入方向带宽利用率告警参数与全局采用的入方向带宽利用率告警参数一致。
context-admin
high-threshold high-value:指定入方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
关于统计周期的值,分为以下几种情况:
# 在接口GigabitEthernet1/0/1上配置入方向带宽利用率告警上限阈值为80,入方向带宽利用率告警下限阈值为60。
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-usage high-threshold 80 low-threshold 60
·     flow-interval
port ifmonitor output-error命令用来配置出方向错误报文告警参数。
undo port ifmonitor output-error命令用来恢复缺省情况。
接口采用的出方向错误报文告警参数与全局采用的出方向错误报文告警参数一致。
以太网接口视图
context-admin
# 在接口GigabitEthernet1/0/1上配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage命令用来配置出方向带宽利用率的告警参数。
undo port ifmonitor output-usage命令用来恢复缺省情况。
接口采用的出方向带宽利用率告警参数与全局采用的出方向带宽利用率告警参数一致。
context-admin
high-threshold high-value:指定接口出方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
high-threshold high-value:指定接口出方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
关于统计周期的值,分为以下几种情况:
# 在接口GigabitEthernet1/0/1上配置出方向带宽利用率告警上限阈值为9,出方向带宽利用率告警下限阈值为7。
[Sysname-GigabitEthernet1/0/1]port ifmonitor output-usage high-threshold 9 low-threshold 7
·     flow-interval
port ifmonitor rx-pause命令用来配置接口接收PAUSE帧告警参数。
undo port ifmonitor rx-pause命令用来恢复缺省情况。
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的接收PAUSE帧告警参数与全局采用的接收PAUSE帧告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口接收PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口接收PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口GigabitEthernet1/0/1上配置接收PAUSE帧告警上限阈值为90,接收PAUSE帧告警下限阈值为50,接收PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor sdh-b1-error命令用来配置接口SDH-B1错误报文告警参数。
undo port ifmonitor sdh-b1-error命令用来恢复缺省情况。
port ifmonitor sdh-b1-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH-B1错误告警参数与全局采用的SDH-B1错误告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口SDH-B1错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B1错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH-B1错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B1错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B1错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B1错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
# 在接口GigabitEthernet1/0/1上配置SDH-B1错误报文告警上限阈值为20,SDH-B1错误报文告警下限阈值为10,SDH-B1错误报文数据收集和比较时间间隔为10秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor sdh-b1-error high-threshold 20 low-threshold 10 interval 10
port ifmonitor sdh-b2-error命令用来配置接口SDH-B2错误报文告警参数。
undo port ifmonitor sdh-b2-error命令用来恢复缺省情况。
port ifmonitor sdh-b2-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH-B2错误告警参数与全局采用的SDH-B2错误告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口SDH-B2错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B2错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
# 在接口GigabitEthernet1/0/1上配置SDH-B2错误报文告警上限阈值为10,SDH-B2错误报文告警下限阈值为8,SDH-B2错误报文数据收集和比较时间间隔为3秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor sdh-b2-error high-threshold 10 low-threshold 8 interval 3
port ifmonitor sdh-error命令用来配置接口下SDH错误报文告警参数。
undo port ifmonitor sdh-error命令用来恢复缺省情况。
port ifmonitor sdh-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH错误报文告警参数与全局采用的SDH错误报文告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口SDH错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH错误报文数据收集和比较时间间隔,取值范围为1~65535,单位为秒。
shutdown:表示当接口接收到的SDH错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
# 在接口GigabitEthernet1/0/1上配置SDH错误报文告警上限阈值为50,SDH错误报文告警下限阈值为30,SDH错误报文数据收集和比较时间间隔为10秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor sdh-error high-threshold 50 low-threshold 30 interval 10
port ifmonitor tx-pause命令用来配置接口发送PAUSE帧告警参数。
undo port ifmonitor tx-pause命令用来恢复缺省情况。
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的发送PAUSE帧告警参数与全局采用的发送PAUSE帧告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口发送PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口发送PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口GigabitEthernet1/0/1上配置发送PAUSE帧告警上限阈值为50,发送PAUSE帧告警下限阈值为40,发送PAUSE帧数据收集和比较时间间隔为8秒。
[Sysname-GigabitEthernet1/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
port link-mode命令用来切换以太网接口的工作模式。
undo port link-mode命令用来恢复缺省情况。
undo port link-mode
以太网接口工作在三层模式。
以太网接口视图
context-admin
bridge:工作在二层模式。
route:工作在三层模式。
接口模式切换后,除了shutdown命令,该以太网接口下的其它所有命令都将恢复到新模式下的缺省情况。
基于业务板的硬件构造,设备上的某些接口只能作为二层以太网接口;某些接口只能作为三层以太网接口;某些接口比较灵活,工作模式可以通过命令行设置。如果将工作模式设置为二层模式(bridge),则作为一个二层以太网接口使用,如果将工作模式设置为三层模式(route),则作为一个三层以太网接口使用。
# 使接口GigabitEthernet1/0/1工作在二层模式。
[Sysname-GigabitEthernet1/0/1] port link-mode bridge
The configuration of the interface will be restored to the default. Continue? [Y/N]:y
reset counters interface命令用来清除接口的统计信息。
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
context-admin
如果不指定interface-typeinterface-number,则清除所有接口的统计信息。
如果指定interface-type而不指定interface-number,则清除所有该类型接口的统计信息。
# 清除以太网接口GigabitEthernet1/0/1的统计信息。
<Sysname> reset counters interface gigabitethernet 1/0/1
·     display interface
·     display counters interface
·     display counters rate interface
reset counters mib interface命令用来清除MIB上接口的统计信息。
reset counters mib interface [ interface-type [ interface-number | interface-number.subnumber ] ]
context-admin
在某些情况下,需要在MIB中统计一定时间内某接口的流量,这就需要在统计开始前清除该接口原有的MIB统计信息,重新进行统计。
如果不指定interface-typeinterface-number,则清除除VA接口外所有接口的mib统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的mib统计信息。
# 清除MIB上以太网接口GigabitEthernet1/0/1的统计信息。
<Sysname> reset counters mib interface gigabitethernet 1/0/1
reset ethernet statistics命令用来清除以太网软件模块收发报文的统计信息。
reset ethernet statistics [ slot slot-number ]
context-admin
slot slot-number:清除指定成员设备的统计信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 清除指定slot上的以太网软件模块收发报文的统计信息。‌‌
<Sysname> reset ethernet statistics slot 1
·     display ethernet statistics
reset packet-drop interface命令用来清除接口丢弃报文的统计信息。
reset packet-drop interface [ interface-type [ interface-number ] ]
context-admin
如果不指定接口类型和接口编号,则清除所有接口丢弃的报文的信息。
如果仅指定接口类型,则清除所有该类型接口丢弃的报文的信息。
# 清除以太网接口GigabitEthernet1/0/1丢弃报文的统计信息。
<Sysname> reset packet-drop interface gigabitethernet 1/0/1
# 清除所有接口丢弃报文的统计信息。
·     display packet-drop
1.1.50  shutdown
shutdown命令用来关闭以太网接口/子接口。
undo shutdown命令用来打开以太网接口/子接口。
shutdown
以太网接口/子接口处于开启状态。
以太网接口视图
以太网子接口视图
context-admin
执行本命令会导致使用该接口建立的链路中断,不能通信,请谨慎使用。
在某些特殊情况下(例如修改接口的工作参数),接口相关配置不能立即生效,需要关闭再打开接口后,才能生效。
# 关闭以太网接口GigabitEthernet1/0/1后打开该接口。
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
# 关闭以太网子接口GigabitEthernet1/0/1.1后打开该接口。
[Sysname-GigabitEthernet1/0/1.1] shutdown
[Sysname-GigabitEthernet1/0/1.1] undo shutdown
shutdown all-physical-interfaces命令用来关闭全部物理接口。
undo shutdown all-physical-interfaces命令用来开启全部物理接口。
shutdown all-physical-interfaces [ include irf-physical-interface ]
物理接口处于开启状态。
context-admin
include irf-physical-interface:关闭全部物理接口时包括IRF物理接口。如果未指定本参数,则关闭全部物理接口时不包括IRF物理接口。
通过配置shutdown all-physical-interfaces命令,可以关闭和开启设备上除管理以太网接口和IRF物理接口外的所有物理接口,所有物理接口状态变为ADM。
在系统视图下执行shutdown all-physical-interfaces命令或在接口视图下执行shutdown命令,接口均会被关闭。
在系统视图下执行undo shutdown all-physical-interfaces命令和在接口视图下执行undo shutdown命令后,接口才会被开启。
多次执行本命令,如果携带include irf-physical-interface参数,则关闭设备上除管理以太网接口外的所有物理接口。
# 关闭全部物理接口。
[Sysname] shutdown all-physical-interfaces
·     shutdown
snmp-agent trap enable ifmonitor命令用来开启接口告警功能。
undo snmp-agent trap enable ifmonitor命令用来关闭接口告警功能。
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
接口告警功能处于开启状态。
context-admin
crc-error:开启接口CRC错误报文告警功能。
input-error:开启接口入方向错误报文告警功能。
input-usage:开启接口入方向带宽利用率告警功能。
output-error:开启接口出方向错误报文告警功能。
output-usage:开启接口出方向带宽利用率告警功能。
rx-pause:开启接口接收PAUSE帧告警功能。
sdh-b1-error:开启接口SDH-B1错误报文告警功能。
sdh-b2-error:开启接口SDH-B2错误报文告警功能。
sdh-error:开启接口SDH错误报文告警功能。
tx-pause:开启接口发送PAUSE帧告警功能。
# 开启接口CRC错误报文告警功能。
[Sysname] snmp-agent trap enable ifmonitor crc-error
1.1.53  speed
speed命令用来设置以太网接口的速率。
undo speed命令用来恢复缺省情况。
speed { 10 | 100 | 1000 | 2500 | 5000 | 10000 | 40000 | 100000 | auto }
undo speed
以太网接口速率处于自协商状态。
以太网接口视图
context-admin
10:表示接口速率为10Mbps。
100:表示接口速率为100Mbps。
1000:表示接口速率为1000Mbps。
2500:表示接口速率为2500Mbps。
5000:表示接口速率为5000Mbps。
10000:表示接口速率为10000Mbps。
40000:表示接口速率为40000Mbps。
本参数的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
T1000-AI系列
T1000-AI-70-G1、T1000-AI-65-G1、T1000-AI-55-G1
支持
T1000-AI-35-G1、T1000-AI-25-G1
不支持
50000:表示接口速率为50000Mbps
系列
型号
F5000系列
F5000-AI-160-G、F5000-AI-130-G、F5000-AI-110-G、F5000-AI160、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-CN160、F5000-CN160-G、F5000-E-G、F5000-E-G2、F5000-S-G2、F5000-M-G2、F5000-A-G2
支持
F5000-AI-120-G、F5000-CN-G55、F5080、F5030
不支持
F1000系列
F1000-AK9130、F1000-AI-90、F1000-AI-60、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-15、F1000-AI-10、F1000-AI-03-E、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-15-G、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AK1180-G、F1000-AK1080-G、F1000-AK1050-G
不支持
F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G
支持
插卡
LSEM1FWESD0
不支持
系列
型号
T1000-AI系列
支持
不支持
200000:表示接口速率为200000Mbps
400000:表示接口速率为400000Mbps
auto:表示接口速率处于自协商状态。
对于以太网电口来说,使用speed命令设置端口速率,目的是使其与对端进行速率匹配。不同类型的电口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前电口支持该速率。否则,当前电口不支持该速率。
对于光口来说,使用speed命令设置端口速率,目的是使其与可插拔光模块进行速率匹配。不同类型的光口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前光口支持该速率。否则,当前光口不支持该速率。同时需要根据所选用光模块类型,在光口下配置匹配的速率,以便正常使用光模块。如果光口所配置的速率光模块无法支持,则光模块无法使用。例如SFP+口插入SFP千兆光模块时配置speed 10000,或SFP+口插入万兆光模块时配置speed 1000,光模块都无法使用。
设备的固定SFP口插入SFP-GE-T或SFP-GE-T-D光模块后,端口支持的速率与设备型号有关,请以设备实际情况为准。
# 将以太网接口GigabitEthernet1/0/1的速率设置为自协商获得。
[Sysname-GigabitEthernet1/0/1] speed auto
sub-interface rate-statistic命令用来开启以太网接口/子接口的速率统计功能。
undo sub-interface rate-statistic命令用来关闭接口/子接口的速率统计功能。
以太网接口/子接口的速率统计功能处于关闭状态。
以太网接口视图
context-admin
开启本功能后可能需要耗费大量系统资源,请谨慎使用。
# 开启GigabitEthernet1/0/1接口的子接口速率统计功能。
[Sysname-GigabitEthernet1/0/1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
unicast-suppression命令用来开启端口未知单播风暴抑制功能,并设置未知单播风暴抑制阈值。
undo unicast-suppression命令用来关闭端口未知单播风暴抑制功能。
所有接口不对未知单播流量进行抑制。
以太网接口视图
context-admin
ratio:指定以太网接口最大未知单播流量占该接口带宽的百分比。取值范围为0~100。数值越小,则允许通过的未知单播流量也越小。
pps max-pps:指定以太网接口每秒最多通过的未知单播包包数,取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒通过的未知单播流量,单位为kbps,取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大未知单播报文流量。当接口上的未知单播流量超过用户设置的值后,系统将丢弃超出未知单播流量限制的报文,从而使接口未知单播流量所占的比例降低到限定的范围,保证网络业务的正常运行。
# 在以太网接口GigabitEthernet1/0/1上,每秒最多允许10000kbps未知单播报文通过,对超出该范围的未知单播报文进行抑制。
[Sysname-GigabitEthernet1/0/1] unicast-suppression kbps 10000
1.2  二层以太网接口的配置命令
display storm-constrain命令用来显示接口流量控制信息。
display storm-constrain [ broadcast | multicast ] [ interface interface-type interface-number ]
context-admin
context-operator
broadcast:只显示广播报文流量控制信息。
multicast:只显示组播报文流量控制信息。
interface interface-type interface-number显示指定接口的报文流量控制信息。interface-type interface-number指定接口类型和接口编号。不指定该参数时,显示所有接口报文的流量控制信息。
不指定broadcastmulticast参数时,则显示所有类型报文的流量控制信息。
# 显示系统当前所有接口的流量控制信息。
<Sysname> display storm-constrain
 Abbreviation: BC - broadcast; MC - multicast; UC - unicast;
               FW - forwarding
 Flow Statistic Interval: 5 (in seconds)
Port          Type Lower     Upper     Unit  Mode     Status   Trap Log StateChg
GE1/0/1       MC 100       200       kbps  shutdown shutdown off  on  10
表1-9 display storm-constrain命令显示信息描述表
流量统计的时间间隔,单位为秒
Port
接口名称缩写
进行流量阈值控制的报文类型:
·     BC:broadcast,表示广播报文
·     MC:multicast,表示组播报文
·     UC:unicast,表示未知单播报文(暂不支持)
Lower
用户配置的流量控制下限阈值或百分比
Upper
用户配置的流量控制上限阈值或百分比
Unit
用户配置的流量阈值的单位,为pps、kbps或百分比
Mode
用户配置的流量阈值超过上限的控制动作:
·     block表示阻塞方式
·     shutdown表示关闭方式
·     N/A表示未配置控制动作
Status
接口报文转发状态,取值为:
·     FW表示该端口处于正常转发状态
·     shutdown表示端口已被关闭
·     block表示该端口对该类报文直接丢弃
Trap
Trap信息输出开关:
·     on表示打开
·     off表示关闭
Log
Log信息输出开关:
·     on表示打开
·     off表示关闭
StateChg
接口报文转发状态切换次数
当StateChg达到65535次时,会自动跳转到0,重新计数
1.2.2  mdix-mode
光口不支持本命令。
mdix-mode命令用来设置以太网接口的MDIX模式。
undo mdix-mode命令用来恢复缺省情况。
mdix-mode { automdix | mdi| mdix }
undo mdix-mode
以太网接口的MDIX模式为automdix
二层以太网接口视图
context-admin
automdix:两端设备通过协商来决定引脚1和2是发送还是接收信号,引脚3和6是接收还是发送信号。
mdi:使用引脚1和2发送信号,使用引脚3和6接收信号。
mdix:使用引脚1和2接收信号,使用引脚3和6发送信号。
# 设置以太网接口GigabitEthernet1/0/1的MDIX模式为automdix
[Sysname-GigabitEthernet1/0/1] mdix-mode automdix
1.2.3  storm-constrain
storm-constrain命令用来开启端口流量阈值控制功能,并设置上限阈值与下限阈值。
undo storm-constrain命令用来关闭端口流量阈值控制功能。
storm-constrain { broadcast | multicast } pps upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast }
端口流量阈值控制功能处于关闭状态,即不对端口的报文流量进行抑制。
二层以太网接口视图
context-admin
all:取消端口所有类型(组播和广播)报文流量阈值配置。
broadcast:设置端口广播报文流量阈值。
multicast:设置端口组播报文流量阈值。
pps:以包每秒为单位统计流量。
upperlimit:端口报文流量的上限阈值。当和pps一起使用时,该参数的取值范围为0~1.4881×接口带宽。
lowerlimit:端口报文流量的下限阈值。当和pps一起使用时,该参数的取值范围为0~1.4881×接口带宽。
执行本命令后,设备就会周期性地对接口收到的指定类型的报文进行统计,如果流量超过上限阈值,则采取一定的措施。其中,通过storm-constrain interval命令可以配置统计周期,通过storm-constrain control命令可以配置流量超过上限阈值时采取的控制方式。
执行storm-constrainbroadcast-suppressionmulticast-suppressionunicast-suppression命令都能开启端口的风暴抑制功能。storm-constrain命令通过软件对报文流量进行抑制,对设备性能有一定影响,broadcast-suppressionmulticast-suppressionunicast-suppression通过芯片物理上对报文流量进行抑制,相对storm-constrain来说,对设备性能影响较小。对于某种类型的报文流量,请不要同时配置这两种方式,以免配置冲突,导致抑制效果不确定。
配置时,upperlimit值必须大于lowerlimit值,建议不要配成相等值。
# 对GigabitEthernet1/0/1端口配置广播报文流量阈值,上限阈值为200pps、下限阈值为150pps。
[Sysname-GigabitEthernet1/0/1] storm-constrain broadcast pps 200 150
·     storm-constrain control
·     storm-constrain interval
1.2.4  storm-constrain control
storm-constrain control命令用来设置端口组播或者广播流量超过上限阈值时采取的控制方式。
undo storm-constrain control命令用来恢复缺省情况。
不对端口流量进行控制。
二层以太网接口视图
context-admin
block:block方式,即:当端口上组播或广播报文中某类报文的流量大于其上限阈值时,端口将暂停转发该类报文(其它类型报文照常转发),端口处于阻塞状态,但仍会统计该类报文的流量。当该类报文的流量小于其下限阈值时,端口将自动恢复对此类报文的转发。
shutdown:shutdown方式,即:当端口上组播或广播报文中某类报文的流量大于其上限阈值时,端口将被关闭,系统停止转发所有报文。当该类报文的流量小于其下限阈值时,端口状态不会自动恢复,此时可通过执行undo shutdown命令或取消端口上流量阈值的配置来恢复。
# 配置GigabitEthernet1/0/1端口,当流量超过上限阈值时,采用block方式控制。
[Sysname-GigabitEthernet1/0/1] storm-constrain control block
·     storm-constrain
1.2.5  storm-constrain enable log
storm-constrain enable log命令用来配置端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
undo storm-constrain enable log命令用来禁止端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
二层以太网接口视图
context-admin
# 当GigabitEthernet1/0/1端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
[Sysname-GigabitEthernet1/0/1] storm-constrain enable log
1.2.6  storm-constrain enable trap
storm-constrain enable trap命令用来配置端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
undo storm-constrain enable trap命令用来禁止端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
二层以太网接口视图
context-admin
# 当GigabitEthernet1/0/1端口流量从小于等于上限阈值到大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
[Sysname-GigabitEthernet1/0/1] storm-constrain enable trap
1.2.7  storm-constrain interval
storm-constrain interval命令用来配置端口流量阈值控制模块流量统计的时间间隔。
undo storm-constrain interval命令用来恢复缺省情况。
storm-constrain interval interval
端口流量统计的时间间隔为10秒。
context-admin
interval:端口流量统计的时间间隔,取值范围为1~300,单位为秒。为了保持网络状态的稳定,建议设置的时间间隔不低于10秒。
本命令设置的时间间隔专门为storm-constrain命令服务的,不同于flow-interval命令设置的时间间隔。虽然同样是统计端口流量,但是功能是分开的。
# 配置端口流量统计时间间隔为60秒。
[Sysname] storm-constrain interval 60
·     storm-constrain
1.3  三层以太网接口/子接口的配置命令
1.3.1  mac-address
mac-address命令用来配置以太网接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
缺省情况下,三层以太网接口的MAC地址与设备的型号有关,请以设备的实际情况为准;三层以太网子接口的缺省MAC与主接口MAC相同。
三层以太网接口视图
三层以太网子接口视图
context-admin
mac-address:MAC地址,形式为H-H-H。
# 配置三层以太网接口GigabitEthernet1/0/1的MAC地址为0001-0001-0001。
[Sysname-GigabitEthernet1/0/1] mac-address 1-1-1
1.3.2  mtu
mtu命令用来设置三层以太网接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
三层以太网接口/子接口的MTU值为1500字节。
三层以太网接口视图
三层以太网子接口视图
context-admin
# 设置三层以太网接口GigabitEthernet1/0/1的最大传输单元为1430字节。
[Sysname-GigabitEthernet1/0/1] mtu 1430
# 设置三层以太网子接口GigabitEthernet1/0/1.1的最大传输单元为1430字节。
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] mtu 1430
1.3.3  traffic-statistic enable
traffic-statistic enable命令用来开启以太网子接口的报文统计功能。
undo traffic-statistic enable命令用来关闭以太网子接口的报文统计功能。
以太网子接口的报文统计功能处于关闭状态。
三层以太网子接口视图
context-admin
开启以太网子接口报文统计功能后会占用系统硬件资源,在大量以太网子接口下开启本功能或者flow-interval命令配置的时间间隔较小时会导致系统繁忙,CPU占用率升高。
配置本命令后,可以通过display interface命令的Input和Output字段或者display counters命令查看以太网子接口的统计信息。
# 开启三层以太网子接口GigabitEthernet1/0/1.1的报文统计功能。
[Sysname-GigabitEthernet1/0/1.1] traffic-statistic enable
·     display counters
·     display interface
·     flow-interval
