04-DPI深度安全命令参考
04-防病毒命令
本章节下载 04-防病毒命令  (504.60 KB)
04-防病毒命令
  录
1 防病毒
1.1 防病毒配置命令
1.1.1 anti-virus apply policy
1.1.2 anti-virus cache min-time
1.1.3 anti-virus cache size
1.1.4 anti-virus parameter-profile
1.1.5 anti-virus policy
1.1.6 anti-virus signature auto-update
1.1.7 anti-virus signature auto-update-now
1.1.8 anti-virus signature rollback
1.1.9 anti-virus signature update
1.1.10 cloud-query enable
1.1.11 description
1.1.12 display anti-virus cache
1.1.13 display anti-virus signature
1.1.14 display anti-virus signature family-info
1.1.15 display anti-virus signature library
1.1.16 display anti-virus statistics
1.1.17 display enhanced-inspect anti-virus file-engine statistics
1.1.18 display enhanced-inspect anti-virus file-engine status
1.1.19 display enhanced-inspect anti-virus signature library
1.1.20 enhanced-inspect anti-virus cache-file-size
1.1.21 enhanced-inspect anti-virus enable
1.1.22 enhanced-inspect anti-virus file-engine cache-file-size
1.1.23 enhanced-inspect anti-virus file-engine enable
1.1.24 enhanced-inspect anti-virus file-engine log enable
1.1.25 enhanced-inspect anti-virus file-engine install
1.1.26 enhanced-inspect anti-virus file-engine uninstall
1.1.27 enhanced-inspect anti-virus file-type
1.1.28 enhanced-inspect anti-virus signature auto-update-now
1.1.29 enhanced-inspect anti-virus signature auto-update
1.1.30 enhanced-inspect anti-virus signature rollback factory
1.1.31 enhanced-inspect anti-virus signature update
1.1.32 exception application
1.1.33 exception md5
1.1.34 exception signature
1.1.35 inspect
1.1.36 reset enhanced-inspect anti-virus cache type
1.1.37 reset enhanced-inspect anti-virus file-engine statistics
1.1.38 signature severity enable
1.1.39 update schedule
1.1.40 update schedule(enhancedinspect-av-autoupdate)
1.1.41 warning parameter-profile
1 防病毒
1.1  防病毒配置命令
anti-virus apply policy命令用来在DPI应用profile中引用防病毒策略。
undo anti-virus apply policy命令用来删除引用的防病毒策略。
anti-virus apply policy policy-name mode { alert | protect }
DPI应用profile中未引用防病毒策略。
DPI应用profile视图
context-admin
policy-name:表示防病毒策略名称,为1~63个字符的字符串,不区分大小写。
mode:表示防病毒策略的模式。
alert:告警模式,表示报文匹配上该防病毒策略中的特征后,仅可以生成日志,但其他动作均不生效。
protect:保护模式,表示报文匹配上该防病毒策略中的特征后,设备按照特征的动作对该报文进行处理。
防病毒策略仅在被DPI应用profile引用后生效。一个DPI应用profile视图下只能引用一个防病毒策略。多次执行本命令,最后一次执行的命令生效。
# 在名称为sec的DPI应用profile下引用防病毒策略abc。
[Sysname] app-profile sec
[Sysname-app-profile-sec] anti-virus apply policy abc mode protect
anti-virus cache min-time命令用来配置防病毒缓存条目的最短保留时间。
undo anti-virus cache min-time命令用来恢复缺省情况。
anti-virus cache min-time value
防病毒缓存条目的最短保留时间为10分钟。
context-admin
value:指定防病毒缓存条目的最短保留时间,取值范围为10~720,单位为分钟。
当设备需要进行云端查询时,若当前已缓存的MD5值条目达到配置的防病毒缓存条目的上限时,将进行如下处理:
·     若已缓存的最老的条目未超过最短保留时间,则不删除缓存的条目,不进行云端查询;
·     若已缓存的最老的条目已超过最短保留时间,则删除最老的条目以保存新条目,并进行云端查询。
但是,当用户修改防病毒缓存参数时,配置的MD5缓存条数小于当前已缓存的数目,设备将从防病毒缓存中删除最老的MD5缓存,即使该MD5缓存未达到最短保留时间,也将被删除。
# 配置防病毒缓存的最短保留时间为36分钟。
[Sysname] anti-virus cache min-time 36
·     anti-virus cache size
anti-virus cache size命令用来配置防病毒缓存条目的上限。
undo anti-virus cache size命令用来恢复缺省情况。
anti-virus cache size cache-size
防病毒缓存条目的上限为10万条。
context-admin
cache-size:指定防病毒缓存条目的上限,取值范围为100000~200000条。
云端服务器返回的查询结果将被缓存在防病毒缓存中用于后续报文进行本地匹配,查询结果包含了MD5值并确认其是否为病毒。
当用户修改防病毒缓存参数时,配置的MD5缓存条数小于当前已缓存的数目,设备将从防病毒缓存中删除缓存时间最老的MD5缓存,即使该MD5缓存未达到最短保留时间,也将被删除。
# 配置防病毒缓存条目的上限为200000条。
[Sysname] anti-virus cache size 200000
·     anti-virus cache min-time
anti-virus parameter-profile命令用来配置防病毒动作引用应用层检测引擎动作参数profile。
undo anti-virus parameter-profile命令用来取消配置防病毒动作引用应用层检测引擎动作参数profile。
anti-virus { email | logging | redirect } parameter-profile profile-name
undo anti-virus { email | logging | redirect } parameter-profile
防病毒动作未引用应用层检测引擎动作参数profile。
context-admin
email:表示设置防病毒邮件动作的参数。
logging:表示设置防病毒日志动作的参数。
redirect:表示设置防病毒重定向动作的参数。
parameter-profile profile-name:表示防病毒动作引用的应用层检测引擎动作参数profile。profile-name表示动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
防病毒动作的具体执行参数(例如,邮件服务器的地址、输出日志的方式和对报文重定向的URL)由应用层检测引擎各动作参数profile来定义,可通过引用各动作参数proflle为防病毒动作提供执行参数。有关应用层检测引擎动作参数proflle的具体配置,请参见“DPI深度安全配置指导”中的“应用层检测引擎”。
如果防病毒动作没有引用应用层检测引擎动作参数profile,或者引用的动作参数profile不存在,则使用系统中各动作参数的缺省值。
# 创建名称为av1的应用层检测引擎邮件动作参数profile,配置登录邮件服务器的明文密码为abc123。
[Sysname] inspect email parameter-profile av1
[Sysname-inspect-email-av1] password simple abc123
[Sysname-inspect-logging-av1] quit
# 配置防病毒邮件动作引用名称为av1的应用层检查引擎邮件动作参数profile。
[Sysname] anti-virus email parameter-profile av1
·     inspect email parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·     inspect logging parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·     inspect redirect parameter-profile(DPI深度安全命令参考/应用层检测引擎)
anti-virus policy命令用来创建防病毒策略,并进入防病毒策略视图。如果指定的防病毒策略已经存在,则直接进入防病毒策略视图。
undo anti-virus policy命令用来删除指定的防病毒策略。
anti-virus policy policy-name
undo anti-virus policy policy-name
存在一个缺省防病毒策略,名称为default。
context-admin
policy-name:表示防病毒策略的名称,为1~63个字符的字符串,不区分大小写。
缺省防病毒策略和自定义防病毒策略都使用当前系统中的所有病毒特征。
缺省防病毒策略不能被修改和删除。
# 创建一个名称为abc的防病毒策略,并进入防病毒策略视图。
[Sysname] anti-virus policy abc
[Sysname-anti-virus-policy-abc]
anti-virus signature auto-update命令用来开启定期自动在线升级病毒特征库功能,并进入自动升级配置视图。
undo anti-virus signature auto-update命令用来关闭定期自动在线升级病毒特征库功能。
定期自动在线升级病毒特征库功能处于关闭状态。
context-admin
如果设备可以访问H3C官方网站,可以采用定期自动在线升级方式来对设备上的病毒特征库进行升级。
# 开启定期自动在线升级病毒特征库功能,并进入自动升级配置视图。
[Sysname] anti-virus signature auto-update
[Sysname-anti-virus-autoupdate]
·     update schedule
anti-virus signature auto-update-now命令用来立即自动在线升级病毒特征库。
context-admin
执行此命令后,将立即自动升级设备上的病毒特征库,且会备份当前的病毒特征库文件。此命令的生效与否,与是否开启了定期自动升级病毒特征库功能无关。
当管理员发现H3C官方网站上的特征库服务专区中的病毒特征库有更新时,可以选择立即自动在线升级方式来及时升级病毒特征库版本。
# 立即自动在线升级病毒特征库版本。
[Sysname] anti-virus signature auto-update-now
anti-virus signature rollback命令用来回滚病毒特征库。
context-admin
factory:表示病毒特征库的出厂版本。
如果管理员发现设备当前病毒特征库版本在检测和防御网络攻击时,误报率较高或出现异常情况,则可以对当前病毒特征库版本进行回滚。目前支持将设备中的病毒特征库版本回滚到出厂版本。
# 配置病毒特征库回滚到出厂版本。
[Sysname] anti-virus signature rollback factory
anti-virus signature update命令用来手动离线升级病毒特征库。
anti-virus signature update file-path [ vpn-instance vpn-instance-name ] [ source { ip | ipv6 } { ip-address | interface interface-type interface-number } ]
context-admin
file-path:指定病毒特征库文件的路径,为1~255个字符的字符串。
vpn-instance vpn-instance-name:表示TFTP、FTP服务器所属的VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则表示TFTP、FTP服务器位于公网中。
source:指定手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IP地址。如果不指定该参数,则表示使用系统根据路由表项查找到的出接口的地址。
ip ip-address:指定手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IPv4地址。
ipv6 ip-address:指定手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IPv6地址。
interface interface-type interface-number:指定该接口的主IPv4地址或接口上最小的IPv6地址为源IP地址。
H3C官方网站上的特征库服务专区根据设备的内存大小以及软件版本为用户提供了不同的特征库。管理员需要根据设备实际情况获取相应的特征库,如果为小内存设备(8GB以下)升级了适用于大内存设备(8GB以上)的特征库,可能会导致设备异常,请谨慎操作。
如果设备不能访问H3C官方网站上的特征库服务专区,管理员可以采用如下几种方式手动离线升级病毒特征库版本。
·     本地升级:使用本地保存的特征库文件升级系统上的病毒特征库版本。
·     FTP/TFTP升级:通过FTP或TFTP方式下载远程服务器上保存的特征库文件,并升级系统上的病毒特征库版本。
使用本地升级方式离线升级特征库版本时,特征库文件只能存储在当前主用设备上,否则设备升级特征库会失败。‌
参数file-path的取值与手动离线升级的操作方式有关。本地升级时参数file-path取值请参见表1-1;FTP/TFTP升级时参数file-path取值请参见表1-2
表1-1 本地升级时参数file-path取值说明表
升级场景
参数file-path取值
特征库文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
有关pwd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
特征库文件的存储位置与当前工作路径不一致,且在相同存储介质上
filename
需要先执行cd命令将工作路径切换至特征库文件所在目录下
有关cd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
特征库文件的存储位置与当前工作路径不在相同存储介质上
path/ filename
需要先执行cd命令将工作路径切换至特征库文件所在存储介质的根目录下,再指定特征库文件的相对路径
表1-2 FTP/TFTP升级时参数file-path取值说明表
升级场景
参数file-path取值
特征库文件存储在开启FTP服务的远程服务器上
ftp://username:password@server/filename
username为登录FTP服务器的用户名,password为登录FTP服务器的密码,server为FTP服务器的IP地址或主机名
当FTP的用户名和密码中使用了“:”、“@”和“/”三种特殊字符时,需要将这三种特殊字符替换为其对应的转义字符。“:”、“@”和“/”三种特殊字符对应的转义字符分别为“%3A或%3a”、“%40”和“%2F或%2f”
特征库文件存储在开启TFTP服务的远程服务器上
tftp://server/filename
server为TFTP服务器的IP地址或主机名
当采用FTP/TFTP方式升级特征库时,如果指定的是服务器的主机名,则需要确保设备能通过静态或动态域名解析方式获得FTP/TFTP服务器的IP地址,并与之路由可达。否则设备升级特征库会失败。有关域名解析功能的详细配置,请参见“三层技术-IP业务配置指导”中的“域名解析”。
如果管理员希望手动离线升级特征库时发送给TFTP、FTP服务器的请求报文的源IP地址是一个特定的地址时,可配置source参数。例如,当组网环境中设备发出的报文需要经过NAT地址转换后才能访问TFTP、FTP服务器时,则需要管理员通过source参数指定一个符合NAT地址转换规则的源IP地址(其中,如果设备需要经过一台独立的NAT设备进行地址转换时,本命令指定的IP地址必须可以与NAT设备三层路由可达),使设备发出的报文可以进行NAT地址转换等处理,正常访问TFTP、FTP服务器。
当同时配置了sourcevpn-instance参数时,需要保证source中指定的源IP地址或接口所属VPN实例与vpn-instance中配置的VPN实例相同。
# 配置手动离线升级病毒特征库,且采用TFTP方式,病毒特征库文件的远程路径为tftp://192.168.0.10/av-1.0.2-en.dat。
[Sysname] anti-virus signature update tftp://192.168.0.10/av-1.0.2-en.dat
# 配置手动离线升级病毒特征库,且采用FTP方式,病毒特征库文件的远程路径为ftp://192.168.0.10/av-1.0.2-en.dat,用户名为user:123,密码为user@abc/123。
[Sysname] anti-virus signature update ftp://user%3A123:user%40abc%[email protected]/av-1.0.2-en.dat
# 配置手动离线升级病毒特征库,且采用本地方式,病毒特征库文件的本地路径为cfa0:/av-1.0.23-en.dat,且当前工作路径为cfa0:。
[Sysname] anti-virus signature update av-1.0.23-en.dat
# 配置手动离线升级病毒特征库,且采用本地方式,病毒特征库文件的本地路径为cfa0:/dpi/av-1.0.23-en.dat,且当前工作路径为cfa0:。
<Sysname> cd dpi
# 配置手动离线升级病毒特征库,且采用本地方式,病毒特征库文件的本地路径为cfb0:/dpi/av-1.0.23-en.dat,当前工作路径为cfa0:。
<Sysname> cd cfb0:/
[Sysname] anti-virus signature update dpi/av-1.0.23-en.dat
cloud-query enable命令用来开启防病毒MD5值云端查询功能。
undo cloud-query enable命令用来关闭防病毒MD5值云端查询功能。
cloud-query enable
防病毒MD5值云端查询功能处于关闭状态。
防病毒策略视图
context-admin
开启防病毒MD5值云端查询功能后,如果流经设备传输的文件的MD5值与特征库中的MD5规则匹配失败,设备会将文件的MD5值发往云端服务器进行查询。云端服务器响应该请求,并向设备发送查询结果,该结果中包含了MD5值并确认其是否为病毒,设备根据该结果执行相应的处理动作。
# 在名为news的防病毒策略中,开启防病毒云端查询功能。
[Sysname] anti-virus policy news
[Sysname-anti-virus-policy-news] cloud-query enable
1.1.11  description
description命令用来配置防病毒策略描述信息。
undo description命令用来恢复缺省情况。
未配置防病毒策略描述信息。
防病毒策略视图
context-admin
text:防病毒策略的描述信息,为1~255个字符的字符串,可以包含空格,区分大小写。
描述信息便于管理员快速理解和识别本防病毒策略的作用,有利于后期维护。
# 配置防病毒策略abc的描述信息为"RD Department anti-virus policy"。
[Sysname-anti-virus-policy-abc] description "RD Department anti-virus policy"
display anti-virus cache命令用来显示防病毒缓存中的信息。
display anti-virus cache [ slot slot-number ]
context-admin
context-operator
slot slot-number:显示指定成员设备上的防病毒缓存中的信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。‌‌
本命令仅在开启云端查询功能后生效。
当设备无法通过病毒特征和MD5规则识别出病毒时,会将未识别出的MD5值发往云端服务器进行查询,并将查询结果缓存到防病毒缓存中。
可通过本命令查看防病毒缓存的信息以及云端查询功能相关信息。其中,防病毒缓存包含命中列表和非命中列表。命中列表表示查询成功的病毒列表,非命中列表表示云端未查询到该MD5值,或查询结果为非病毒的列表。
# 显示防病毒缓存中的信息。
<Sysname> display anti-virus cache
Slot 1:
Anti-virus cache information:
 Cloud-query state: Disabled
 Total cached non-hit entries: 0
 Total cached hit entries: 0
 Non-hit list min update interval: 0 seconds
 Non-hit list max update interval: 0 seconds
 Hit list min update interval: 0 seconds
 Hit list max update interval: 0 seconds
 Last query message sent: 0 seconds ago
 Last query result received: 0 seconds ago
表1-3 display anti-virus cache命令显示信息描述表
防病毒缓存信息
Cloud-query state
云端查询功能状态,取值包括:
·     Enabled:表示云端查询功能处于开启状态
·     Disabled:表示云端查询功能处于关闭状态
非命中列表中节点的总数目
命中列表中节点的总数目
非命中列表表项中,距离上一次刷新时间最短的时间间隔,单位为秒
非命中列表表项中,距离上一次刷新时间最长的时间间隔,单位为秒
最近一次发送查询消息的时间与当前时间的间隔,单位为秒
最近一次接收到查询返回的结果的时间与当前时间的间隔,单位为秒
·     cloud-query enable
display anti-virus signature命令用来显示病毒特征信息。
display anti-virus signature [ [ signature-id ] | [ severity { critical | high | low | medium } ] ]
context-admin
context-operator
signature-id:表示病毒特征的ID号,取值范围为1~4294967294。若不指定该参数,则显示病毒特征的总数。
severity:指定病毒特征攻击的严重级别。
critical:表示严重级别最高。
high:表示严重级别比较高。
low:表示严重级别最低。
medium:表示严重级别中等。
可以通过本命令了解病毒特征的严重级别,便于更加合理的使用signature severity enable来使相应级别的病毒特征生效。
# 显示编号为10000001的病毒特征信息。
<Sysname> display anti-virus signature 10000001
Signature ID: 10000001
Name        : Trojan [Downloader].VBS.Agent
Severity    : Medium
表1-4 display anti-virus signature命令显示信息描述表
Signature ID
病毒特征编号
Name
病毒特征的名称或家族名称
Severity
病毒特征的攻击严重级别属性,取值包括:
·     Low
·     Medium
·     High
·     Critical
# 显示病毒特征总数。
 Total count:9206
 failed:0
表1-5 display anti-virus signature命令显示信息描述表
Total count
病毒特征的总数
Failed
从病毒特征库下发应用层检测引擎失败病毒特征的个数
display anti-virus signature family-info命令用来显示病毒特征家族信息。
context-admin
context-operator
可以通过本命令帮助用户了解防病毒特征库中包含的病毒特征家族信息。
# 显示病毒特征家族信息。
<Sysname> display anti-virus signature family-info
Anti-Virus signature family information:
 Total count : 18844
 FamilyID  FamilyName
 1         Trojan[Downloader].VBS.Agent
 2         Trojan[Downloader].MSOffice.Donoff
 3         Trojan[Downloader].MSWord.Agent
 4         Trojan[SMS].Android.Opfake
 5         GrayWare[AdWare].Android.Ewind
 6         RiskWare[RiskTool].Android.Hamad
 7         Trojan[Backdoor].Android.TigerBot
 8         Trojan[Dropper].VBS.Agent
 9         Trojan[SMS].Android.FakeInst
表1-6 display anti-virus signature family-info命令显示信息描述表
Total count
病毒特征家族的总数
Family ID
病毒特征家族的编号
Family name
病毒特征家族的名称
display anti-virus signature library命令用来显示病毒特征库信息。
context-admin
context-operator
# 显示病毒特征库信息。
<Sysname> display anti-virus signature library
Anti-Virus signature library information:
Type      SigVersion         ReleaseTime               Size
Current   1.0.9              Wed Apr 22 09:51:13 2015  976432
Factory   1.0.0              Fri Dec 31 16:00:00 1999  20016
表1-7 display anti-virus signature library命令显示信息描述表
病毒特征库版本,包括如下取值:
·     Current:当前版本
·     Factory:出厂版本
SigVersion
病毒特征库版本号
ReleaseTime
病毒特征库发布时间
Size
病毒特征库大小,单位是Bytes
display anti-virus statistics命令用来显示防病毒统计信息。
display anti-virus statistics [ policy policy-name ] [ slot slot-number ]
context-admin
context-operator
policy policy-name:表示防病毒策略名称,为1~63个字符的字符串,不区分大小写。若不指定此参数,则显示所有防病毒策略的统计信息。
slot slot-number:显示指定成员设备上的防病毒统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上的防病毒统计信息。‌‌
# 显示指定slot上的防病毒统计信息。‌‌
<Sysname> display anti-virus statistics slot 4 cpu 1
CPU 1 on slot 4:
Total Block:    0
Total Redirect: 0
Total Alert:    0
Type           http      ftp       smtp      pop3      imap
Block           0         0         0         0         0
Redirect        0         0         0         0         0
Alert+Permit    0         0         0         0         0
表1-8 display anti-virus statisic命令显示信息描述表
Total Block
执行阻断动作的总数
Total Redirect
执行重定向动作的总数
Total Alert
执行告警动作的总数
动作类型,包括如下取值:
·     Block:表示阻断报文并生成日志。
·     Redirect:表示将HTTP连接重定向到指定的URL并生成日志。
·     Alert+Permit:表示仅对报文进行告警,即允许报文通过并生成日志。
http
对HTTP协议类型数据处理的动作计数
ftp
对FTP协议类型数据处理的动作计数
smtp
对SMTP协议类型数据处理的动作计数
pop3
对POP3协议类型数据处理的动作计数
imap
对IMAP协议类型数据处理的动作计数
display enhanced-inspect anti-virus file-engine statistics命令用来显示防病毒文件引擎增强检测统计信息。
display enhanced-inspect anti-virus file-engine statistics [ slot slot-number ]
slot slot-number:显示指定成员设备上的防病毒文件引擎增强检测统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。‌‌
非缺省vSystem不支持本命令。
当设备启用了基于文件引擎的增强检测功能时,可以通过本命令查看文件引擎增强检测统计信息,包括待检测文件总数、已检测文件总数以及检测为病毒文件的总数等数据,从而全面了解文件检测的情况。
# 显示防病毒文件引擎增强检测统计信息。‌
<Sysname> display enhanced-inspect anti-virus file-engine statistics
Slot 1:
  TaskNum: 27
  DetectionNum: 14
  VirusNum: 3
  FileType     DetectNum    VirusNum
  pe           5            2
  zip          2            0
  doc          7            1
  jpg          0            0
  png          0            0
  bmp          0            0
  psd          0            0
  xml,msc     0            0
  html         0            0
  pdf          0            0
  rar          0            0
  elf          0            0
  xls          0            0
  ppt          0            0
  office_2003  0            0
  js           0            0
  php          0            0
  py           0            0
  pl           0            0
  docx         0            0
  xlsx         0            0
  pptx         0            0
  office_2007  0            0
  wav          0            0
  avi          0            0
  ram          0            0
  rmvb         0            0
  mov          0            0
  gif          0            0
  swf          0            0
  tgz,tar.gz   0            0
  vsd          0            0
  vsdx         0            0
  msg          0            0
  pub          0            0
  mp3          0            0
  msi          0            0
  tif          0            0
  wmf          0            0
  xpm          0            0
  fig          0            0
  xcf          0            0
  gks          0            0
  rpm          0            0
  a            0            0
  cab          0            0
  bz2          0            0
  7z           0            0
  chm          0            0
  torrent      0            0
  dwg          0            0
  ods          0            0
  odt          0            0
  odp          0            0
  tar          0            0
  mp4          0            0
  h,c,cpp      0            0
  others       0            0
表1-9 display enhanced-inspect anti-virus file-engine statistics命令显示信息描述表
TaskNum
待检测文件的总数
DetectionNum
已检测文件的总数
VirusNum
检测为病毒文件的总数
FileType
检测文件的类型
·     reset enhanced-inspect anti-virus file-engine statistics
display enhanced-inspect anti-virus file-engine status命令用来显示防病毒文件引擎增强检测状态。
display enhanced-inspect anti-virus file-engine status [ slot slot-number ]
slot slot-number:显示指定成员设备上的防病毒文件引擎增强检测状态。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。‌‌
非缺省vSystem不支持本命令。
# 显示防病毒文件引擎增强检测状态。
<Sysname> display enhanced-inspect anti-virus file-engine status
Slot 1:
  Version: 1.0
  Initialization error code: 0
  Task queue num: 0
  Threshold status:Minor:
表1-10 display enhanced-inspect anti-virus file-engine status命令显示信息描述表
Version
当前防病毒文件引擎版本
其中‘-’表示未安装防病毒增强检测文件引擎软件或者防病毒增强检测文件引擎软件版本错误
防病毒文件引擎增强检测初始化失败的错误码
Task queue num
防病毒文件引擎增强检测任务数
Threshold status
防病毒文件引擎增强检测门限状态。取值包括:
·     Normal:正常状态
·     Minor:异常状态
·     Severe:严重状态
·     Critical:危急状态
display enhanced-inspect anti-virus signature library命令用来显示防病毒增强检测文件引擎特征库信息。
context-admin
context -operator
# 显示防病毒增强检测文件引擎特征库信息。
<Sysname> display enhanced-inspect anti-virus signature library
File-engine signature library information:
Current   1.0.0              Fri Dec 28 10:56:27 2018  20016
Factory   -                  -                         -
表1-11 display enhanced-inspect anti-virus signature library命令显示信息描述表
防病毒增强检测文件引擎特征库版本,包括如下取值:
·     Current:表示当前版本
·     Factory:表示出厂版本(暂不支持)
SigVersion
防病毒增强检测文件引擎特征库版本号
ReleaseTime
防病毒增强检测文件引擎特征库发布时间
Size
防病毒增强检测文件引擎特征库文件大小,单位是Bytes
enhanced-inspect anti-virus cache-file-size命令用来配置防病毒增强检测缓存文件大小上限。
undo enhanced-inspect anti-virus cache-file-size命令用来恢复缺省情况。
enhanced-inspect anti-virus cache-file-size file-size
防病毒增强检测缓存文件大小上限为1MB。
context-admin
file-size:表示每个缓存文件的大小上限,取值范围为1~10,单位为MB。
本命令仅在开启防病毒增强检测功能后生效。
开启防病毒增强检测功能后,设备会先将缓存的文件上送智能业务平台进行病毒检测,如果缓存文件超出缓存大小上限,则不将该文件上送平台检测。
文件上送平台检测后,设备将清空本地缓存。
# 配置防病毒增强检测缓存文件大小上限为5MB。
[Sysname] enhanced-inspect anti-virus cache-file-size 5
·     enhanced-inspect anti-virus enable
enhanced-inspect anti-virus enable命令用来开启防病毒增强检测功能。
undo enhanced-inspect anti-virus enable命令用来关闭防病毒增强检测功能。
防病毒增强检测功能处于关闭状态。
context-admin
开启本功能后,当防病毒业务未识别出病毒时,会将待检测文件发往智能业务平台继续进行病毒检测,从而提高病毒识别成功率
# 开启防病毒增强检测功能。
[Sysname] enhanced-inspect anti-virus enable
Enabling this feature will disable enhanced anti-virus file-engine inspection. Continue? [Y/N]
enhanced-inspect anti-virus file-engine cache-file-size命令用来配置防病毒文件引擎增强检测缓存文件大小上限。
undo enhanced-inspect anti-virus file-engine cache-file-size命令用来恢复缺省情况。
enhanced-inspect anti-virus file-engine cache-file-size file-size
防病毒文件引擎增强检测缓存文件大小上限为1MB。
context-admin
工作机制
开启防病毒文件引擎增强检测功能后,设备会将缓存的文件上送至增强检测文件引擎进行病毒检测,如果缓存文件超过缓存大小上限,则不将该文件上送增强检测文件引擎检测。
注意事项
本命令在开启防病毒文件引擎增强检测功能后生效。
文件上送增强检测文件引擎检测后,设备将清空本地缓存。
# 配置防病毒文件引擎增强检测缓存文件大小上限为5MB。
[Sysname] enhanced-inspect anti-virus file-engine cache-file-size 5
·     enhanced-inspect anti-virus file-engine enable
enhanced-inspect anti-virus file-engine enable命令用来开启防病毒文件引擎增强检测功能。
undo enhanced-inspect anti-virus file-engine enable命令用来关闭防病毒文件引擎增强检测功能。
防病毒文件引擎增强检测功能处于关闭状态。
context-admin
工作机制
开启本功能后,防火墙防病毒业务未检测出病毒时,会将待检测文件发往文件引擎继续进行病毒检测,文件引擎响应该请求并完成检测,并返回查询结果,会将检测结果发送给设备,设备会将检测结果保存到本地各业务的缓存中,便于后续报文直接在本地进行业务检测,而不必再上送文件引擎查询。
应用场景
在企业局域网内部署防病毒文件引擎功能,当下载或传输文件时,文件引擎增强检测功能能即时扫描并识别潜在威胁,如新型恶意软件、勒索软件或零日攻击,防范可能的安全漏洞。
注意事项
设备上不能同时配置本命令和enhanced-inspect anti-virus enable命令。若设备已配置enhanced-inspect anti-virus enable命令,则在启用本功能时会提示是否关闭防病毒增强检测功能。
配置本功能前,请确保已经导入文件引擎安装包或正确安装防病毒增强检测文件引擎特征库。
# 开启防病毒文件引擎增强检测功能。
[Sysname] enhanced-inspect anti-virus file-engine enable
Enabling this feature will disable enhanced anti-virus inspection. Continue? [Y/N]
·     enhanced-inspect anti-virus file-engine install
enhanced-inspect anti-virus file-engine log enable命令用来开启防病毒文件引擎增强检测日志功能。
undo enhanced-inspect anti-virus file-engine log enable命令用来关闭防病毒文件引擎增强检测日志功能。
防病毒文件引擎增强检测日志功能处于关闭状态。
应用场景
在企业环境中,当设备检测到可疑活动或潜在威胁时,详细的日志记录能够及时提供关键信息,帮助快速定位风险源头。通过深入分析日志,可以提前发现和修复潜在漏洞,保障企业敏感数据的安全,降低运营风险。
工作机制
开启本功能后,防病毒文件引擎增强检测会输出日志信息。开启防病毒文件引擎增强检测日志功能后,日志信息将被输出到缺省dpi/av/enhanced-inspectlog目录中,请不要删除该目录,以免影响日志存储。此文件最多存储5MB,当数据超过5MB时,系统将按照创建时间删除较早的日志文件。
非缺省vSystem不支持本命令。
# 打开防病毒文件引擎增强检测日志功能。
[Sysname] enhanced-inspect anti-virus file-engine log enable
enhanced-inspect anti-virus file-engine install命令用来安装防病毒增强检测文件引擎安装包。
enhanced-inspect anti-virus file-engine install type { all | module } file-path
未安装防病毒增强检测文件引擎安装包。
all:表示指定导入完整的防病毒增强检测文件引擎安装包。
module:表示指定只导入Module文件的防病毒增强检测文件引擎安装包。仅在设备上安装了防病毒增强检测文件引擎特征库或者完整的防病毒增强检测文件引擎安装包,才能单独导入防病毒增强检测Module文件。
file-path:表示指定防病毒增强检测文件引擎文件的路径,为1~255个字符串。
非缺省vSystem不支持本命令。
工作机制
本命令用于安装防病毒增强检测文件引擎安装包,以启用防病毒增强检测文件引擎增强检测功能。使用方式为从官网下载增强检测文件引擎安装包后,通过FTP等方式将该安装包上传至设备指定路径中(用户自行选择将安装包上传到设备的某个flash下),再使用本命令安装防病毒增强检测文件引擎安装包。
注意事项
防病毒增强检测文件引擎安装包大于300MB,请确保设备内存有足够的空间来存储和加载这些引擎
文件,并且要能够支持其解压加载操作。
# 安装防病毒增强检测文件引擎完整引擎安装包。
[Sysname] enhanced-inspect anti-virus file-engine install all avengine1-0-10.zip
enhanced-inspect anti-virus file-engine uninstall命令用来卸载防病毒增强检测文件引擎安装包。
非缺省vSystem不支持本命令。
应用场景
当安装多种安全防护软件时,可能会引发资源占用过高或软件冲突,导致系统性能下降。为了提升系统效率和稳定性,用户可能选择卸载部分防病毒引擎,特别是那些对日常使用影响较小的文件,从而确保设备在保持足够安全防护的同时,运行更加顺畅和高效。文件被卸载后,对应的防病毒文件引擎增强检测功能则无法使用。
注意事项
在执行本命令前,请先关闭防病毒文件引擎增强检测功能。
# 卸载防病毒文件引擎安装包。
[Sysname] enhanced-inspect anti-virus file-engine uninstall
enhanced-inspect anti-virus file-type命令用来配置防病毒增强检测的文件类型。
undo enhanced-inspect anti-virus file-type命令用来恢复缺省情况。
enhanced-inspect anti-virus file-type { all | name &<1-8> }
undo enhanced-inspect anti-virus file-type { all | name &<1-8> }
防病毒增强检测的文件类型为PE、ELF、OFFICE和压缩包文件。
context-admin
all:表示所有文件类型。
name &<1-8>:表示需要检测的文件类型名称,不区分大小写,可通过输入“?”获取支持的文件类型。&<1-8>表示前面的参数最多可以输入8次。
应用场景
在企业环境中,为有效预防和应对复杂的网络攻击,特别是在处理大量邮件附件、下载文件和共享文档时。它可以针对高风险文件类型(如.exe、.doc、.pdf等)进行深度扫描,全面提升安全性,防止病毒、木马、勒索软件等威胁。
工作机制
本命令用于配置防病毒增强检测的缓存文件类型,缺省情况下,防病毒增强检测的文件类型为PE、ELF、OFFICE和压缩包文件。通过配置缓存文件类型后,只传送指定的文件类型用于防病毒增强检测。
# 配置防病毒增强检测所有文件类型。
[Sysname] enhanced-inspect anti-virus  file-type all
enhanced-inspect anti-virus signature auto-update-now命令用来立即自动在线升级防病毒增强检测文件引擎特征库。
非缺省vSystem不支持本命令。
应用场景
当管理员发现官方网站上的特征库服务专区中的防病毒增强检测文件引擎特征库有更新时,可以选择立即自动在线升级方式来及时升级防病毒增强检测文件引擎特征库版本。
工作机制
执行本命令后,将立即自动升级设备上的防病毒增强检测文件引擎特征库,且会备份当前的防病毒增强检测文件引擎特征库文件。此命令的生效与否,与是否开启了定期自动升级防病毒增强检测文件引擎特征库功能无关。
# 立即自动在线升级防病毒增强检测文件引擎特征库。
[Sysname] enhanced-inspect anti-virus signature auto-update-now
enhanced-inspect anti-virus signature auto-update命令用来开启定期自动在线升级防病毒增强检测文件引擎特征库,并进入防病毒增强检测文件引擎自动升级配置视图。
undo enhanced-inspect anti-virus signature auto-update命令用来关闭定期自动在线防病毒增强检测文件引擎特征库。
定期自动在线升级防病毒增强检测文件引擎特征库功能处于关闭状态。
非缺省vSystem不支持本命令。
如果设备可以访问官方网站上的特征库服务专区,可以采用定期自动在线升级方式来对设备上的防病毒增强检测文件引擎特征库进行升级。
# 开启定期自动在线升级防病毒增强检测文件引擎特征库。
·     update schedule(enhancedinspect-av-autoupdate view)
enhanced-inspect anti-virus signature rollback factory命令用来删除防病毒增强检测文件引擎特征库。
非缺省vSystem不支持本命令。
如果管理员发现设备当前内存不足或不需要防病毒增强检测文件引擎特征库时,可以执行本命令对当前防病毒增强检测文件引擎特征库版本进行删除,以释放内存空间。
# 删除防病毒增强检测文件引擎特征库。
[Sysname] enhanced-inspect anti-virus signature rollback factory
enhanced-inspect anti-virus signature update命令用来手动离线升级防病毒增强检测文件引擎特征库。
enhanced-inspect anti-virus signature update file-path [ vpn-instance vpn-instance-name ][ source { ip | ipv6 } { ip-address | interface interface-type interface-number }]
file-path:指定特征库文件的路径,为1~255个字符的字符串。
非缺省vSystem不支持本命令。
官方网站上的特征库服务专区根据设备的内存大小以及软件版本为用户提供了不同的特征库和特征库。管理员需要根据设备实际情况获取相应的特征库,如果为小内存设备(8GB以下)升级了适用于大内存设备(8GB以上)的特征库,可能会导致设备异常,请谨慎操作。
工作机制
如果设备不能访问官方网站上的特征库服务专区,管理员可以采用如下几种方式手动离线升级特征库版本。
·     文件升级:使用文件保存的病毒文件升级系统上的特征库版本。
·     FTP/TFTP升级:通过FTP或TFTP方式下载远程服务器上保存的特征库文件,并升级系统上的特征库版本。
使用文件升级方式离线升级特征库版本时,特征库文件只能存储在当前主用设备上,否则设备升级特征库会失败。‌
使用文件升级方式离线升级特征库版本时,特征库文件只能存储在当前主用主控板上,否则设备升级特征库会失败。‌
使用文件升级方式离线升级特征库版本时,特征库文件只能存储在当前全局主用主控板上,否则设备升级特征库会失败。‌
参数file-path的取值与手动离线升级的操作方式有关。文件升级时参数file-path取值请参见表1-12;FTP/TFTP升级时参数file-path取值请参见表1-13
表1-12 文件升级时参数file-path取值说明表
升级场景
参数file-path取值
特征库文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
filename
path/ filename
需要先执行cd命令将工作路径切换至病毒文件所在存储介质的根目录下,再指定特征库文件的相对路径
表1-13 FTP/TFTP升级时参数file-path取值说明表
升级场景
参数file-path取值
注意事项
# 手动离线升级防病毒增强检测文件引擎特征库且采用FTP方式,特征库文件的远程路径为ftp://192.168.0.10/enhance-antivirus-1.0.2-en.dat,用户名为example:123,密码为example@abc/123。
[Sysname] enhanced-inspect anti-virus signature update ftp://example%3A123:example%40abc%[email protected]/enhance-antivirus-1.0.2-en.dat
# 手动离线升级防病毒增强检测文件引擎特征库且采用TFTP方式,特征库文件的远程路径为tftp://192.168.0.10/enhance-antivirus-1.0.2-en.dat。
[Sysname] enhanced-inspect anti-virus signature update tftp://192.168.0.10/ enhance-antivirus-1.0.2-en.dat
# 手动离线升级防病毒增强检测文件引擎特征库且采用文件方式,特征库文件的文件路径为cfa0:/ enhance-antivirus-1.0.2-en.dat,且当前工作路径为cfa0:。
[Sysname] enhanced-inspect anti-virus signature update enhance-antivirus-1.0.2-en.dat
exception application命令用来配置应用例外并为其指定处理动作。
undo exception application命令用来删除指定的或所有的应用例外。
exception application application-name action { alert | block | permit }
undo exception application { application-name | all }
不存在应用例外。
防病毒策略视图
context-admin
application-name:例外应用的名称。
action:指定例外应用的动作。
all:表示所有的应用例外。
alert:表示仅对病毒报文进行告警,即允许其通过并生成病毒日志。
block:表示阻断病毒报文并生成病毒日志。
permit:表示允许病毒报文通过。
缺省情况下,设备基于应用层协议的防病毒动作对符合病毒特征的报文进行处理。当需要对某应用层协议上承载的某一具体应用采取不同的动作时,可以将此应用设置为应用例外。例如,对HTTP协议进行允许通过处理,但是需要对HTTP协议上承载的游戏类应用采取阻断动作,这时就可以把所有游戏类的应用设置为应用例外。
# 配置163Email应用为应用例外并为其指定处理动作为告警。
[Sysname-anti-virus-policy-abc] exception application 163Email action alert
exception md5命令用来配置例外MD5值。
undo exception md5命令用来删除例外MD5值。
exception md5 md5-value
undo exception md5 { md5-value | all }
不存在例外MD5值。
防病毒策略视图
context-admin
md5-value:表示例外MD5值。
all:表示所有的例外MD5值。
如果发现某类检测出病毒的报文被误报时,用户可以通过查看防病毒日志获取MD5值并执行此命令把该报文对应的MD5值设置为例外。当后续再有检测出符合该MD5值的报文通过时,设备将对其执行允许动作。
# 在名为abc的防病毒策略中,配置例外MD5值为2b9c5137769b613f0ea11bd51c324afc。
[Sysname-anti-virus-policy-abc] exception md5 2b9c5137769b613f0ea11bd51c324afc
exception signature命令用来配置病毒例外。
undo exception signature命令用来删除指定的或所有的病毒例外。
exception signature signature-id
undo exception signature { signature-id | all }
不存在病毒例外。
防病毒策略视图
context-admin
signature-id:表示病毒特征的ID号,取值范围为1~4294967292。
all:表示所有的病毒例外。
如果发现某类检测出病毒的报文被误报时,可以通过执行此命令把该报文对应的病毒特征设置为病毒例外。当后续再有检测出包含此病毒特征的报文通过时,设备将对其执行允许动作。
# 配置ID为101000的病毒特征为病毒例外。
[Sysname-anti-virus-policy-abc] exception signature 101000
·     display anti-virus signature
1.1.35  inspect
inspect命令用来配置病毒检测的应用层协议类型。
undo inspect命令用来取消对指定协议的报文进行病毒检测。
inspect { ftp | http | imap | nfs | pop3 | smb | smtp } direction { both | download | upload } [ cache-file-size file-size ] action { alert | block | redirect }
undo inspect { ftp | http | imap | nfs | pop3 | smb | smtp }
设备对FTP、HTTP、SMB、NFS和IMAP协议上传和下载方向传输的报文均进行病毒检测,对POP3协议下载方向传输的报文进行病毒检测,对SMTP协议上传方向传输的报文进行病毒检测。设备对FTP、HTTP、NFS和SMB协议报文的动作为阻断,对IMAP、SMTP和POP3协议报文的动作为告警,支持缓存的检测文件大小上限为1MB。
防病毒策略视图
context-admin
ftp:表示FTP协议。
http:表示HTTP协议。
imap:表示IMAP协议。
nfs:表示NFS协议,NFS协议仅支持NFSv3版本。
pop3:表示POP3协议。
smb:表示SMB协议,SMB协议支持SMBv1和SMBv2版本。
smtp:表示SMTP协议。
direction:表示对指定方向上的报文进行病毒检测。因为POP3协议只有下载方向,SMTP协议只支持上传方向,所以对这两种协议类型不支持配置方向属性。
both:表示会话的上传和下载方向。
download:表示会话的下载方向。
upload:表示会话的上传方向。
cache-file-size file-size:表示缓存的待检测文件大小,file-size表示文件大小,取值范围为1~24,单位为MB。仅HTTP协议支持配置此参数。
action:指定对报文的处理动作,IMAP协议只支持告警动作。
redirect:表示将携带病毒的HTTP连接重定向到指定的URL并生成病毒日志,仅对上传方向生效。
配置此命令后,设备可根据报文的应用层协议类型和传输方向来对其进行病毒检测,如果检测到病毒,则对此报文执行指定的动作。
当配置协议类型为HTTP,动作为block时,设备检测出病毒后,不仅会阻断病毒报文、生成病毒日志,还会向客户端浏览器返回提示窗口并显示告警信息。告警信息可通过导入告警文件的方式进行配置,即通过import block warning-file命令配置。有关告警文件的详细介绍,请参见“DPI深度安全配置指导”中的“应用层检测引擎”。
因为防病毒模块所支持协议的连接请求均由客户端发起,为了使连接可以成功建立并能对此连接上的报文进行病毒检测,需要管理员在配置安全策略或安全域间实例时确保客户端所在的安全域为源安全域、服务器所在的安全域为目的安全域。
# 配置对基于HTTP协议且是下载方向上的报文进行检测病毒,动作为告警。
[Sysname-anti-virus-policy-abc] inspect http direction download action alert
# 配置不对基于FTP协议的报文进行病毒检测。
[Sysname-anti-virus-policy-abc] undo inspect ftp
·     import block warning-file(DPI深度安全命令参考/应用层检测引擎)
reset enhanced-inspect anti-virus cache type命令用来清除防病毒增强检测缓存信息。
reset enhanced-inspect anti-virus cache type { all | hit | non-hit }
all:表示防病毒增强检测缓存的命中名单和非命中名单列表表项。
hit:表示防病毒增强检测缓存的命中名单列表表项。
non-hit:表示防病毒增强检测缓存的非命中名单列表表项。
非缺省vSystem不支持本命令。
# 清除防病毒增强检测缓存的命中名单表项。
<Sysname> reset enhanced-inspect anti-virus cache type hit
reset enhanced-inspect anti-virus file-engine statistics命令用来清除防病毒文件引擎增强检测统计信息。
reset enhanced-inspect anti-virus file-engine statistics [ slot slot-number ]
slot slot-number:清除指定成员设备上的防病毒文件引擎增强检测统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。‌‌
非缺省vSystem不支持本命令。
# 清除防病毒文件引擎增强检测统计信息。
<Sysname> reset enhanced-inspect anti-virus file-engine statistics
·     display enhanced-inspect anti-virus file-engine statistics
signature severity enable命令用来配置有效病毒特征的最低严重级别。
undo signature severity enable命令用来恢复缺省情况。
signature severity { critical | high | medium } enable
所有严重级别的病毒特征都处于生效状态。
防病毒策略视图
context-admin
critical:表示严重级别最高。
high:表示严重级别比较高。
medium:表示严重级别中等。
在仅需要对某类及其以上严重级别病毒进行防御的应用需求中,可通过配置此功能来实现此需求。配置此功能后防病毒策略中只有指定的及其以上严重级别的病毒特征会生效。
# 配置仅使High及其以上严重级别的病毒特征生效。
[Sysname-anti-virus-policy-abc] signature severity high enable
update schedule命令用来配置定期自动在线升级病毒特征库的时间。
undo update schedule命令用来恢复缺省情况。
设备在每天02:01:00至04:01:00之间自动在线升级病毒特征库。
自动升级配置视图
context-admin
daily:表示升级周期为每天。
weekly:表示以一周为周期,在指定一天进行自动升级。
fri:表示星期五。
mon:表示星期一。
sat:表示星期六。
sun:表示星期日。
thu:表示星期四。
tue:表示星期二。
wed:表示星期三。
start-time time:指定自动升级开始时间,time的格式为hh:mm:ss,取值范围为00:00:00~23:59:59。
tingle minutes:指定抖动时间,即实际自动升级开始时间的偏差范围,取值范围为0~120,单位为分钟。在start-time指定时间的前后各偏移抖动时间的一半作为自动升级的时间范围,例如,指定自动升级的开始时间为01:00:00,抖动时间为60分钟,则自动升级的时间范围为00:30:00至01:30:00。
# 配置病毒特征库的定期自动在线升级时间为每周一20:30:00,抖动时间为10分钟。
[Sysname-anti-virus-autoupdate] update schedule weekly mon start-time 20:30:00 tingle 10
·     anti-virus signature auto-update
update schedule命令用来配置定期自动在线升级防病毒增强检测文件引擎特征库的时间。
update schedule { weekly { fri | mon | sat | sun | thu | tue | wed } | daily } start-time time
设备在每天的02:00:00自动在线升级防病毒文件引擎特征库。
防病毒增强检测文件引擎自动升级配置视图
daily:表示自动升级周期为每天。
weekly:指表示以一周为周期,在指定的一天进行自动升级。
fri:表示星期五。
mon:表示星期一。
sat:表示星期六。
sun:表示星期日。
thu:表示星期四。
tue:表示星期二。
wed:表示星期三。
当管理员发现防病毒文件引擎特征库的定期自动在线升级时间不合理时,可以根据实际情况设置每日或每周的更新时间并指定开始时间。配置完成后,防病毒文件引擎特征库将在设定的时间开始自动升级。
# 配置防病毒文件引擎特征库的定期自动在线升级时间为每周一20:30:00。
[Sysname-enhancedinspect-av-autoupdate] update schedule weekly mon start-time 20:30:00
·     enhanced-inspect anti-virus signature auto-update
warning parameter-profile命令用来开启发送告警信息功能,并引用告警动作参数profile。
undo warning parameter-profile命令用来恢复缺省情况。
warning parameter-profile profile-name
未引用告警动作参数profile,设备不支持向客户端发送告警信息。
防病毒策略视图
context-admin
profile-name:引用的告警动作参数profile名称,为1~63个字符的字符串,不区分大小写,仅支持数字、字母和下划线。
当设备检测出病毒后,支持向客户端发送告警信息。告警信息的具体内容由应用层检测引擎告警动作参数profile来定义,可通过引用该动作参数profile为告警信息提供显示内容。有关应用层检测引擎动作参数profile的具体配置,请参见“DPI深度安全配置指导”中的“应用层检测引擎”。
在RBM双机热备的非对称组网环境中(即同一条流量的报文来回路径不一致),不支持发送告警信息功能,即使配置了本命令,其功能也不会生效。有关RBM双机热备的详细介绍,请参见“高可靠性配置指导”中的“双机热备(RBM)”。
配置本功能后,设备会对匹配防病毒策略的HTTP流量进行代理,将对设备性能产生较大影响,请根据实际情况判断是否需要配置本功能。
# 在名为abc的防病毒策略中开启发送告警信息功能,并引用名为av1的告警动作参数profile。
[Sysname-anti-virus-policy-abc] warning parameter-profile av1
·     inspect warning parameter-profile(DPI深度安全命令参考/应用层检测引擎)
