09-负载均衡命令参考
04-入方向链路负载均衡命令
本章节下载: 04-入方向链路负载均衡命令  (622.57 KB)
04-入方向链路负载均衡命令
1 入方向链路负载均衡
1.1 入方向链路负载均衡配置命令
1.1.1 bandwidth busy-protection enable (virtual server pool view)
1.1.2 bandwidth busy-rate
1.1.3 display loadbalance dns-listener
1.1.4 display loadbalance dns-listener statistics
1.1.5 display loadbalance dns-map
1.1.6 display loadbalance dns-map statistics
1.1.7 display loadbalance isp
1.1.8 display loadbalance link
1.1.9 display loadbalance local-dns-server parse-fail-record
1.1.10 display loadbalance reverse-zone
1.1.11 display loadbalance virtual-server-pool
1.1.12 display loadbalance zone
1.1.13 domain-name
1.1.14 expire
1.1.15 fallback
1.1.16 ip address
1.1.17 ipv6 address
1.1.18 isp
1.1.19 loadbalance dns-listener
1.1.20 loadbalance dns-map
1.1.21 loadbalance link
1.1.22 loadbalance local-dns-server parse-faill-record type
1.1.23 loadbalance local-dns-server parse-fail-record max-number
1.1.24 loadbalance local-dns-server schedule-test ip
1.1.25 loadbalance local-dns-server schedule-test ipv6
1.1.26 loadbalance log enable bandwidth-busy
1.1.27 loadbalance region
1.1.28 loadbalance reverse-zone
1.1.29 loadbalance virtual-server-pool
1.1.30 loadbalance zone
1.1.31 max-bandwidth
1.1.32 min-ttl
1.1.33 predictor (virtual server pool view)
1.1.34 primary-nameserver
1.1.35 probe (link view)
1.1.36 record
1.1.37 record ptr
1.1.38 refresh
1.1.39 reset loadbalance dns-listener statistics
1.1.40 reset loadbalance dns-map statistics
1.1.41 reset loadbalance local-dns-server parse-fail-record
1.1.42 responsible-mail
1.1.43 retry
1.1.44 router ip
1.1.45 serial
1.1.46 service enable (DNS listener view)
1.1.47 service enable (DNS mapping view)
1.1.48 soa
1.1.49 success-criteria (link view)
1.1.50 topology region
1.1.51 ttl (DNS forward zone view)
1.1.52 ttl (DNS mapping view)
1.1.53 virtual-ip
1.1.54 virtual-ipv6
1.1.55 virtual-server
1.1.56 virtual-server-pool
1.1.57 vpn-instance
1 入方向链路负载均衡
非缺省vSystem不支持本特性的部分命令,具体情况请见本文相关描述。有关vSystem的详细介绍请参见“虚拟化技术配置指导”中的“vSystem”。
1.1  入方向链路负载均衡配置命令
bandwidth busy-protection enable命令用来开启虚服务器池的繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭虚服务器池的繁忙保护功能。
虚服务器池繁忙保护功能处于关闭状态。
虚服务器池视图
context-admin
工作机制
开启繁忙保护功能后,虚服务器池根据用户配置的调度方式选择虚服务器成员时,会查看所选取的虚服务器成员对应的链路是否超过配置的繁忙比例,如果超出则不选择该虚服务器成员。
注意事项
非缺省vSystem不支持本命令。
# 开启虚服务器池local-pool的繁忙保护功能。
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] bandwidth busy-protection enable
·     bandwidth busy-rate(link view)
bandwidth busy-rate命令用来配置链路的带宽繁忙比。
undo bandwidth busy-rate命令用来恢复缺省情况。
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
带宽繁忙比例为70。
链路视图
context-admin
inbound:表示入方向的带宽繁忙比。
outbound:表示出方向的带宽繁忙比。
busy-rate-number:链路的带宽繁忙比例,取值范围为1~100。
recovery recovery-rate-number:链路带宽繁忙恢复比例,取值范围为1~100。缺省情况下,当带宽繁忙比例大于10时,带宽繁忙恢复比例为带宽繁忙比例减去10;当带宽繁忙比例小于等于10时,带宽繁忙恢复比例等于带宽繁忙比例。
工作机制
当链路的带宽超过该链路的带宽繁忙比例与最大期望带宽的乘积时,链路进入繁忙状态,不再参与调度。当链路的带宽低于带宽繁忙恢复比例与最大期望带宽的乘积时,链路解除繁忙状态,重新参与调度。
若未指定inbound或outbound关键字,则表示设置链路的总带宽繁忙比例。
带宽繁忙比例为当前链路实际带宽与用户配置最大带宽的百分比值,若最大带宽设置为不受限,则使用其可设置的最大值进行计算。
注意事项
非缺省vSystem不支持本命令。
同一链路的带宽繁忙恢复比例必须小于等于带宽繁忙比例。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置链路lk1的总带宽繁忙比例为90,带宽繁忙恢复比例为85。
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
·     display loadbalance link
·     max-bandwidth(link view)
display loadbalance dns-listener命令用来显示DNS监听器的信息。
display loadbalance dns-listener [ name listener-name ]
context-admin
context-operator
name listener-name:指定DNS监听器的信息。listener-name为DNS监听器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS监听器的信息。
工作机制
使用本命令可以查看系统的DNS监听器信息,主要包含服务状态、IPv4、监听端口号及监听到不存在域名的处理方式。
注意事项
非缺省vSystem不支持本命令。
# 显示DNS监听器listener1的信息。
<Sysname> display loadbalance dns-listener name listener1
DNS listener name:listener1
  Service state:Enabled
  IPv4 address: 1.1.1.2
  Port: 53
  IPv6 address: --
  IPv6 Port: 53
  Fallback: Reject
  VPN instance:
表1-1 display loadbalance dns-listener命令显示信息描述
DNS listener name
DNS监听器名称
Service state
DNS监听器是否开启:
·     Enabled:表示DNS监听器处于开启状态
·     Disabled:表示DNS监听器处于关闭状态
IPv4 address
DNS监听器的IPv4地址信息
Port
DNS监听器的监听端口号
IPv6 address
DNS监听器的IPv6地址信息
IPv6 Port
DNS监听器的IPv6监听端口号
Fallback
DNS监听器无法找到响应DNS请求的服务器时的处理方式:
·     dns-proxy:通过DNS代理回应请求报文
·     No-response:不回应DNS请求
·     Reject:回应一个DNS拒绝报文
VPN instance
DNS监听器所属的VPN实例名称
display loadbalance dns-listener statistics命令用来显示DNS监听器的统计信息。
display loadbalance dns-listener statistics [ name dns-listener-name ] [ slot slot-number ]
context-admin
context-operator
name dns-listener-name:指定一个DNS监听器的名称,dns-listener-name表示DNS监听器的名称,为1~255个字符的字符串,不区分大小写。若不指定该参数,则表示显示所有的DNS监听器的统计信息。
slot slot-num:显示指定成员设备上的DNS监听器统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 显示DNS监听器dl的统计信息。
<Sysname> display loadbalance dns-listener statistics name dl
DNS listener: dl
Total:
  Received requests: 100
  Received valid requests: 70
  Unresponded requests: 10
  Rejected requests: 20
  Proxy requests: 0
  RCVR - Received requests, RVR - Received valid requests,
  UR - Unresponded requests, RJTR - Rejected requests, PR - Proxy requests
  Type        RCVR        RVR       UR          RJTR         PR
  A           50          50        0           0            0
  AAAA        0           0         0           0            0
  MX          10          5         5           0            0
  NS          20          5         5           10           0
  CNAME       10          5         0           5            0
  SOA         10          5         0           5            0
  PTR         0           0         0           0            0
  TXT         10          5         0           5            0
  SRV         0           0         0           0            0
表1-2 display loadbalance dns-listener statistics命令显示信息描述表格内容
DNS listener
DNS监听器的名称
Received requests
DNS监听器接收到的DNS请求报文数
DNS监听器接收到的DNS正常请求数
DNS监听器未应答DNS请求报文数
Rejected requests
DNS监听器拒绝的DNS请求报文数
Proxy requests
DNS监听器通过DNS代理回应请求报文的数目
请求报文类型,包括:
·     A:IPv4主机记录类型
·     AAAA:IPv6主机记录类型
·     CNAME:别名类型
·     MX:邮件交换类型
·     NS:名字服务器类型
·     PTR:指针记录类型
·     SOA:原始权威服务器类型
·     SRV:服务类型
·     TXT:文本类型
display loadbalance dns-map命令用来显示DNS映射的配置信息。
display loadbalance dns-map [ name dns-map-name ]
context-admin
context-operator
dns-map-name:DNS映射名,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS映射的配置信息。
工作机制
使用本命令可以查看系统的DNS映射配置信息,主要包含服务状态、映射的域名、引用虚服务器池。
注意事项
非缺省vSystem不支持本命令。
# 显示指定DNS映射dm1的配置信息。
<Sysname> display loadbalance dns-map name dm1
DNS mapping name: dm1
  Service state: Enabled
  TTL: 3600s
  Domain name list: www.example.domain.com
  Virtual server pool: pool1
表1-3 display loabalance dns-map命令显示信息描述表
DNS mapping name
DNS映射的名称
Service state
DNS映射服务是否开启:
·     Enabled:表示映射服务处于开启状态
·     Disabled:表示映射服务处理关闭状态
TTL
DNS应答报文所填充的域名记录的缓存时间,单位为秒
Domain name list
DNS映射的DNS域名
Virtual server pool
DNS映射引用的虚服务器池名称
display loadbalance dns-map statistics命令用来显示DNS映射的统计信息。
display loadbalance dns-map statistics [ name dns-map-name ] [ slot slot-number ]
context-admin
context-operator
name dns-map-name:指定一个DNS映射的名称,为1~255个字符的字符串,不区分大小写。如果不指定该参数,将显示所有DNS映射的统计信息。
slot slot-number:显示指定成员设备上的DNS映射统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 显示DNS映射名dm的统计信息。
<Sysname> display loadbalance dns-map statistics name dm
DNS map: dm
Matched DNS requests: 100
表1-4 display loadbalance dns-map statistics命令显示信息描述表
DNS map
DNS映射名称
DNS映射匹配的DNS请求数
display loadbalance isp命令用来显示ISP的信息。
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
context-admin
context-operator
ip ipv4-address:显示指定IPv4地址所对应ISP的信息。
ipv6 ipv6-address:显示指定IPv6地址所对应ISP的信息。
name isp-name:显示指定名称的ISP的信息,isp-name为1~255个字符的字符串,不区分大小写。
工作机制
如果未指定任何可选参数,将显示所有ISP的信息。
注意事项
非缺省vSystem不支持本命令。
# 显示所有ISP的信息。
<Sysname> display loadbalance isp
(*) - User-defined object
Last successful auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update result: Successful
  ISP update count: 1
LB ISP: isp1
    Description: ISP1
    Whois maintainer object name:
        MAINT-CHINANET
    IPv4 address/Mask length: --
    IPv6 address/Prefix length: --
  Reference count: 1
LB ISP: isp2(*)
    Description:
        1.2.3.0/32(*)           1.2.3.4/32              3.3.3.6/32(*)
        192.168.6.131/32(*)     192.168.195.189/32(*)
        1::2/128
        FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
  Reference count: 1
# 显示IPv4地址1.2.3.0所对应ISP的信息。
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name            Source                   IPv4 address/Mask length
isp2                user-set                 1.2.3.0/28
isp2                user-set                 1.2.3.0/29
isp2                user-set                 1.2.3.0/30
isp2                file-load                1.2.3.0/31
                    auto-update
isp2                user-set                 1.2.3.0/32
                    file-load
# 显示IPv6地址1::1234所对应ISP的信息。
<Sysname> display loadbalance isp ipv6 1::1234
ISP name            Source                   IPv6 address/Prefix length
isp2                user-set                 1::1234/126
isp2                user-set                 1::1234/127
isp2                file-load                1::1234/128
表1-5 display loadbalance isp命令显示信息描述表
(*)表示该ISP信息仅由用户手动配置而来。如果ISP信息既是手工配置又是文件导入时,不显示(*)
最近一次成功更新的时间
最近一次更新的时间
最近一次更新的状态,包括:
·     Successful:成功
·     Failed to connect to WHOIS server:连接WHOIS服务器失败
·     Connection failed:连接异常
·     Failed to query DNS:发送DNS请求失败
ISP update count
最近一次更新ISP的个数
LB ISP
ISP的名称
ISP的描述信息
WHOIS服务器管理标识
ISP的IPv4地址和掩码长度
ISP的IPv6地址和前缀长度
ISP name
ISP的名称
Source
ISP的来源,包括:
·     user-set:表示由用户手工配置
·     file-load:表示由文件导入
·     auto-update:表示来源于自动更新
Reference count
被引用次数
display loadbalance link命令用来显示链路的信息。
display loadbalance link [ brief | name link-name ]
context-admin
context-operator
brief:显示所有链路的简要信息。如果未指定本参数,将显示链路的详细信息。
name link-name:显示指定链路的详细信息。link-name为链路的名称,为1~255个字符的字符串,不区分大小写。
工作机制
如果未指定任何参数,则表示显示所有链路的详细信息。
注意事项
非缺省vSystem不支持本命令。
# 显示所有链路的简要信息。
<Sysname> display loadbalance link brief
Link         Router IP/Interface    State        VPN instance     Link group
Lk1          192.168.1.1            Busy         --               lg
Lk2          192.168.2.1            Active       --               lg
Lk3          Dialer0                Inactive     --               lg
# 显示链路lk的详细信息。
<Sysname> display loadbalance link name lk
Link: lk
  Description: lk
  State: Busy
  VPN instance: --
  Inherit VPN: Disabled
  Router IP: 1.2.3.4
  Router IPv6: --
  Link-group: lg
  Weight: 100
  Priority: 4
  Cost: 0
  Slow-shutdown: Disabled
  Bandwidth detection upon link probe failure: Enabled
  Bandwidth threshold: 100 kbps
  Connection limit: 0
  Rate limit:
    Connections: 10000
    Bandwidth: 10000 kbps
    Inbound bandwidth: 5000 kbps
    Outbound bandwidth: 5000 kbps
  Bandwidth busy:
    Max bandwidth: 10000 kbps
    Max inbound bandwidth: 5000 kbps
    Max outbound bandwidth: 5000 kbps
    Busy rate: 80
    Inbound busy rate: 70
    Outbound busy rate: 60
    Busy recovery rate: 60
    Inbound busy recovery rate: 60
    Outbound busy recovery rate: 60
  Probe information:
    Probe success criteria: All
    Probe method                    State
    t4                              Inactive
  Reference count: 1
Link: lk2
  Description: link2
  State: Inactive
  VPN instance: --
  IPv4 address state: Active
  IPv6 address state: Inactive
  Router interface:Dialer0
  Link group: lg
  Weight: 150
  Priority: 3
  Cost: 100
  Slow shutdown: Enabled
  Bandwidth threshold: --
  Connection limit: 10000
  Rate limit:
    Connections: 10000
  Bandwidth busy:
    Busy rate: 80
Probe information:
  Probe method      State
  t4                Inactive
  Reference count: 1
表1-6 display loadbalance link命令显示信息描述表
Link
链路的名称
Router IP/Interface
链路的网关IP地址/链路对应的出接口
Parent state/State
Parent state表示链路的状态,包括:
·     Active:可用
·     Busy:繁忙
·     Inactive:不可用(由于配置不完全、未被引用或虚服务器尚未开启)
·     Probe-failed:健康检测失败
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
·     Unknown:未配置健康检测
VPN instance
链路所属VPN实例的来源,包括
·     Config:手动配置
·     Inherit:继承
Link group
链路所属链路组的名称
链路的描述信息
Inherit VPN
链路所属VPN实例继承功能的状态,包括:
·     Enabled:开启
·     Disabled:关闭
IPv4 address state
链路的IPv4地址状态,包括:
·     Active:可用,即链路对应的出接口已获取到可用的IPv4地址
·     Inactive:不可用,即链路对应的出接口未获取到可用的IPv4地址
仅当配置了链路对应的出接口时,才会显示本字段
IPv6 address state
链路的IPv6地址状态,包括:
·     Active:可用,即链路对应的出接口已获取到可用的IPv6地址
·     Inactive:不可用,即链路对应的出接口未获取到可用的IPv6地址
·     仅当配置了链路对应的出接口时,才会显示本字段
Router IP
链路的网关IPv4地址
Router IPv6
链路的网关IPv6地址
Router interface
链路对应的出接口
Weight
链路的权值
Priority
链路在所属链路组内的优先级
Cost
就近性计算的链路成本
Slow shutdown
链路的慢宕的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Connection limit
链路所允许的最大连接数
Connection rate limit
链路所允许的最大连接速率
Rate limit
链路的速率限制
Connections
链路所允许的最大连接速率
Bandwidth
链路所允许的最大总带宽,单位为kbps
Inbound bandwidth
链路所允许的最大入带宽,单位为kbps
Outbound bandwidth
链路所允许的最大出带宽,单位为kbps
Bandwidth busy
带宽繁忙比例
Max bandwidth
带宽繁忙阈值所允许的最大总带宽,单位为kbps
带宽繁忙阈值所允许的最大入带宽,单位为kbps
带宽繁忙阈值所允许的最大出带宽,单位为kbps
Busy rate
链路的总带宽繁忙比例
Inbound busy rate
链路的入带宽繁忙比例
Outbound busy rate
链路的出带宽繁忙比例
Busy recovery rate
链路的总带宽繁忙恢复比例
入方向链路带宽繁忙恢复比例
出方向链路带宽繁忙恢复比例
Probe information
链路健康检测的详细信息
链路健康检测的成功条件:
·     All:只有全部方法都通过检测才认为健康检测成功
·     At-least:健康检测成功所需通过检测的最少方法数
Probe method
健康检测方法所使用的NQA模板名称
链路健康检测失败后触发带宽检测功能状态,包括:
·     Disabled:关闭
·     Enabled:开启
Bandwidth threshold
触发带宽检测的阈值,单位为kbps
健康检测方法的状态,包括:
·     Failed:健康检测失败
·     In progress:正在进行健康检测
·     Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者实服务器不可用
·     Succeeded:健康检测成功
Reference count
被引用次数
display loadbalance local-dns-server parse-fail-record命令用来显示解析失败的DNS请求报文的信息。
display loadbalance local-dns-server parse-fail-record [ type { a | aaaa | cname | mx | ns | soa | srv | txt } ] [ domain domain-name ] | ptr [ ip address { ipv4-address | ipv6-address } ] ] [ vpn-instance vpn-instance-name ] [ slot slot-number ]
context-admin
context-operator
type { a | aaaa | cname | mx | ns | ptr | soa | srv | txt }:显示指定类型的解析失败的DNS请求报文信息,包括A、AAAA、CNAME、MX、NS、PTR、SOA、SRV和TXT九种类型。若未指定本参数,则显示所有类型的解析失败的DNS请求。
domain domain-name:显示指定域名的解析失败的DNS请求报文信息,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,如果该域名为绝对域名,则包括“.”在内的总长度不超过254个字符,如果该域名为非绝对域名,则总长度不超过253个字符。若未指定本参数,则显示所有域名的解析失败的DNS请求报文信息。
ip address { ipv4-address | ipv6-address }:显示指定IP地址的解析失败的DNS请求报文信息。该地址为PTR类型DNS请求报文中用于反向解析的IP地址。若未指定本参数,则显示所有IP地址的解析失败的DNS请求报文信息。
vpn-instance vpn-instance-name:显示指定VPN实例中解析失败的DNS请求报文信息。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网中解析失败的DNS请求报文信息。
slot slot-number:显示指定成员设备上解析失败的DNS请求报文的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上解析失败的DNS请求报文的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 显示所有解析失败的DNS请求报文的信息。
<Sysname> display loadbalance local-dns-server parse-fail-record
Slot 0:
  ID Time        Type  SIP/Port  DIP/Port   VPN instance Domain       Failure cause
  1  03 Nov 2016 A     1.2.3.4/1 2.2.2.2/53 --           www.example.com  No matched virtual
     19:09:52                                                         server member.
  2  03 Nov 2016 AAAA  1.2.3.4/2 2.2.2.2/53 --      www.lb.example.com No matched.
     19:09:43                                                         DNS mapping
  3  03 Nov 2016 MX    1.2.3.5/3 2.2.2.2/53 --           mail.example.com  No matched record.
     20:09:41
  4  04 Nov 2016 NS    1.2.3.4/4 2.2.2.2/53 --           ns.example.com   No matched record.
     11:15:40
  5  05 Nov 2016 CNAME 1.2.3.4/5 2.2.2.2/53 --        www.example.com  No matched DNS
     11:16:35                                                         zone.
  6  05 Nov 2016 SOA   1.2.3.4/6 2.2.2.2/53 --        www.example.com  No matched DNS
     12:16:25                                                         zone.
  7  05 Dec 2016 PTR   1.2.3.4/7 2.2.2.2/53 --           1.2.3.4      No matched record.
     15:19:16
表1-7 display loadbalance local-dns-server parse-fail-record命令显示信息描述表
ID
记录序号
Time
接收到DNS请求报文的时间
资源记录的类型,包括:
·     A:IPv4主机记录类型
·     AAAA:IPv6主机记录类型
·     CNAME:别名类型
·     MX:邮件交换类型
·     NS:名字服务器类型
·     PTR:指针记录类型
·     SOA:原始权威服务器类型
·     SRV:服务类型
·     TXT:文本类型
SIP/Port
源IP地址/端口号
DIP/Port
目的IP地址/端口号
VPN instance
VPN实例
Domain
域名
Failure cause
调度失败原因,包括:
·     --:成功
·     No matched DNS listener:无匹配的DNS监听器
·     No matched DNS mapping:无匹配的DNS映射
·     No matched virtual server pool:无匹配的DNS虚服务池
·     No matched DNS zone:无匹配的DNS区域
·     Failed to get buffer:压缩缓冲区无效
·     No matched record:无匹配的DNS资源记录
·     No enough memory resource:无充足的可申请内存
·     Failed to parse domain:域名解析失败
·     Failed to find DNS listener by ID:通过ID无法匹配DNS监听器
·     No scheduling content:调度算法无调度内容
·     Scheduling failed:调度内容存在,调度失败
·     No matched virtual server member:无匹配的虚服务
display loadbalance reverse-zone命令用来显示DNS反向区域的信息。
display loadbalance reverse-zone { ip [ ipv4-address mask-length ] | ipv6 [ ipv6-address prefix-length ] }
context-admin
context-operator
ip:显示IPv4 DNS反向区域的信息。
ipv4-address mask-length:显示指定IPv4地址的DNS反向区域信息。ipv4-address表示IPv4地址;mask-length表示IPv4地址的掩码长度,取值范围为0~32。若未指定本参数,则显示所有IPv4 DNS反向区域的信息。
ipv6:显示IPv6 DNS反向区域的信息。
ipv6-address prefix-length:显示指定IPv6地址的DNS反向区域信息。Ipv6-address表示IPv6地址;prefix-length表示IPv6地址的前缀长度,取值范围为0~128。若未指定本参数,则显示所有IPv6 DNS反向区域的信息。
非缺省vSystem不支持本命令。
# 显示所有IPv4 DNS反向区域的信息。
<Sysname> display loadbalance reverse-zone ip
Reverse zone: 10.1.1.0/24
Record list:
Type      TTL      RDATA
PTR       3600     1.1.1.2  a.mail.example.com
PTR       2700     1.1.1.3  b.mail.example.com
# 显示所有IPv6 DNS反向区域的信息。
<Sysname> display loadbalance reverse-zone ipv6
Reverse zone: 1::/64
Record list:
Type      TTL     RDATA
PTR       3600    1::1  a.mail.example.com
PTR       2700    1::2  b.mail.example.com
表1-8 display loadbalance reverse-zone命令显示信息描述表
Reverse zone
DNS反向区域的IP地址及掩码/前缀长度
Record list
资源记录列表
资源记录类型(目前仅支持PTR类型的资源记录)
TTL
资源记录的缓存时间,单位为秒
RDATA
资源数据
display loadbalance virtual-server-pool命令用来显示虚服务器池的信息。
display loadbalance virtual-server-pool [ brief | name pool-name ]
context-admin
context-operator
brief:显示所有虚服务器池的简要信息。
name pool-name:显示指定虚服务器池的详细信息。
工作机制
如果未指定任何参数,则表示显示所有虚服务器池的详细信息。
注意事项
非缺省vSystem不支持本命令。
# 显示所有虚服务器池的简要信息。
<Sysname> display loadbalance virtual-server-pool brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           TOP - Topology, PRO – Proximity
           BW - Bandwidth, MBW - Max bandwidth,
           IBW - Inbound bandwidth, OBW - Outbound bandwidth,
           MIBW - Max inbound bandwidth, MOBW - Max outbound bandwidth,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port
VSpool           Pre    Alt    Fbk    BWP     Total    Active
vsp           .. RR     LC            Enabled  0        0
vpp              RR                   Enabled  0        0
vsp1             RD     TOP           Enabled  3        0
# 显示虚服务器池local-pool的详细信息。
<Sysname> display loadbalance virtual-server-pool name local-pool
Virtual-server pool: local-pool
  Predictor:
   Preferred RD
   Alternate TOP
   Fallback  --
Bandwidth busy-protection:Disabled
Total virtual servers: 3
Active virtual servers: 0
Virtual server list:
Name      State     Address       Port     Weight  Link
vs1       Active    192.168.1.1   0        150     ct-link1
vs2       Active    192.167.1.1   0        120     ct-link2
vs3       Active    192.169.1.1   0        80      cnc-link
Virtual IP address list:
Address        State      Weight  Link
10.0.1.1       Active     150     ct-link1
10.1.1.1       Active     120     ct-link2
10.2.1.1       Active     80      cnc-link
Virtual IPv6 address list:
9::5           Active     150     ct-link1
9::6           Active     120     ct-link2
9::7           Active     80      cnc-link
表1-9 display loadbalance virtual-server-pool命令显示信息描述表
Virtual-server pool
虚服务器池的名称
Predictor
虚服务器池的调度算法
虚服务器池中繁忙保护功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
包含的虚服务器数量
活跃的虚服务器数量
Virtual server list
虚服务器列表
虚IPv4地址列表
虚IPv6地址列表
Name
虚服务器的名称
虚服务器的状态,包括:
·     Active:可用
·     Busy:繁忙(当链路处于Active,且开启繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·     Inactive:不可用(由于配置不完全或关联link状态不可用)
Address
虚服务器地址或虚IP地址
Port
虚服务器的端口号
Weight
虚服务器或虚IP的权值
Link
引用的链路的名称
display loadbalance zone命令用来显示DNS正向区域的信息。
display loadbalance zone [ name domain-name ]
context-admin
context-operator
name domain-name:显示指定DNS正向区域的信息。domain-name为DNS正向区域的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”或“.”。如果未指定本参数,将显示所有DNS正向区域的信息。
非缺省vSystem不支持本命令。
# 显示所有DNS正向区域的信息。
<Sysname> display loadbalance zone
Zone: example.com
  TTL: 3600s
  SOA:
    Primary name server: ns1.example.com
    Responsible mail: root.ns1.example.com
    Serial: 11812
    Retry: 14400s
    Expire: 604800s
    Min TTL: 86400s
  Record list:
    Type    TTL        RDATA
    NS      3600s      ns1.example.com
    NS      4200s      ns2.example.com
    NS      4200s      a.example.com       ns2.example.com
    MX      3600s      a.mail.example.com  10
    MX      2700s      b.mail.example.com  20
    CNAME   5000s      a.test.example.com  abc1.example.com
    CNMAE   3600s      b.test.example.com  abc2.example.com
    TXT     5000s      v=spf1 include:spf.abcmail.example.com.cn -all
    SRV     --       _ http._tcp.example.com. www.example.com 5 10 80
表1-10 display loadbalance zone命令显示信息描述表
Zone
DNS正向区域的域名
TTL
DNS正向区域中资源记录的缓存时间,单位为秒
SOA
原始权威服务器的相关信息
Primary name server
主域名服务器的主机名
Responsible mail
管理员邮箱地址
Serial
序列号
Retry
重试时间,单位为秒
Expire
过期时间,单位为秒
Min TTL
最小生命周期,单位为秒
Record list
资源记录列表
资源记录类型,包括:
·     MX:邮件交换资源记录
·     CNAME:规范名称资源记录
·     NS:域名服务器资源记录
·     SRV:服务类型资源记录
·     TXT:文本类型资源记录
TTL
资源记录的缓存时间,单位为秒
RDATA
资源数据
1.1.13  domain-name
domain-name命令添加DNS映射的DNS域名。
undo domain-name命令删除DNS映射的DNS域名。
domain-name domain-name
undo domain-name domain-name
DNS映射不存在任何域名。
DNS映射视图
context-admin
domain-name:DNS域名,为1~253个字符的字符串,不区分大小写。
工作机制
DNS映射视图下可以配置多个DNS域名。域名支持通配符配置,允许使用的通配字符包括问号“?”和星号“*”,通配符使用规则如下:
·     域名中允许使用多个问号“?”,问号“?”用于代替域名中的单个字符,域名中的点“.”除外;
·     域名中允许使用多个星号“*”,星号“*”用于代替域名中的多个字符;
·     域名中允许同时使用问号“?”和星号“*”。
·     域名中以点“.”分隔的每个字符串最大长度为63个字符。
·     域名中起始字符与结束字符支持字母、数字、横线、下划线、通配符星号“*”与通配符问号“?”;中间字符支持字母、数字、横线、下划线、点号“.”、通配符星号“*”与通配符问号“?”。
注意事项
非缺省vSystem不支持本命令。
# 为DNS映射dm1添加两个DNS映射域名。
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] domain-name www.example.domain.com
[Sysname-lb-dm-dm1] domain-name ???.example.*.com
1.1.14  expire
expire命令用来配置过期时间。
undo expire命令用来恢复缺省情况。
expire expire-time
undo expire
过期时间为86400秒。
SOA视图
context-admin
expire-time:过期时间,取值范围为500~4294967295,单位为秒。
工作机制
过期时间是指当辅助域名服务器与主域名服务器失去联系后,辅助域名服务器可继续进行DNS解析的时长。
注意事项
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,指定SOA资源记录的过期时间为7天。
[Sysname] loadbalance zone example.com
[Sysname-lb-zone-example.com] soa
[Sysname-lb-zone-example.com-soa] expire 604800
·     display loadbalance zone
1.1.15  fallback
fallback命令用来指定DNS监听器查找DNS请求资源记录失败时的处理方式。
undo fallback命令用来恢复缺省情况。
fallback { dns-proxy | no-response | reject }
undo fallback
DNS监听器查找DNS请求资源记录失败时的处理方式为回应DNS拒绝报文。
DNS监听器视图
context-admin
dns-proxy:通过DNS代理回应请求报文。
no-response:不回应DNS请求。
reject:回应DNS拒绝报文。
非缺省vSystem不支持本命令。
# 指定DNS监听器查找DNS请求资源记录失败时的处理方式。
[Sysname] loadbalance dns-listener ct-listener
[Sysname-lb-dl-ct-listener] fallback no-response
1.1.16  ip address
ip address命令用来指定DNS监听器的IPv4地址和端口。
undo ip address命令用来恢复缺省情况。
ip address ipv4-address [ port port-number ]
undo ip address
未指定DNS监听器的IPv4地址和端口。
DNS监听器视图
context-admin
ipv4-address:DNS监听器的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
port-number:DNS监听端口号,取值范围为1~65535,缺省值为53。
工作机制
在同一DNS监听器视图下,多次执行本命令,最后一次执行的命令生效。
未配置IPv4地址的DNS监听器不处理IPv4 DNS请求报文。
注意事项
非缺省vSystem不支持本命令。
在同时配置入方向链路负载均衡功能和服务器负载均衡功能的情况下,为避免影响入方向链路负载均衡功能的正常使用,请不要将DNS监听器的IP地址与虚服务器的IP地址配置为同一地址。
# 配置DNS监听器的IPv4地址为1.2.3.4,端口号为8080。
[Sysname-lb-dl-ct-listener] ip address 1.2.3.4 port 8080
·     display loadbalance dns-listener
1.1.17  ipv6 address
ipv6 address命令用来指定DNS监听器的IPv6地址和端口。
undo ipv6 address命令用来恢复缺省情况。
ipv6 address ipv6-address [ port port-number ]
undo ipv6 address
未指定DNS监听器的IPv6地址和端口。
DNS监听器视图
context-admin
ipv6-address:DNS监听器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址。
port port-number:端口号,取值范围为1~65535,缺省值为53。
工作机制
每个DNS监听器只能配置一个IPv6地址。
未配置IPv6地址的DNS监听器不能处理IPv6 DNS请求报文。
注意事项
非缺省vSystem不支持本命令。
# 配置DNS监听器ct-listener的IPv6地址为1001::1,端口号为64。
[Sysname-lb-dl-ct-listener] ipv6 address 1001::1 port 64
1.1.18  isp
isp命令用来向区域中添加ISP信息。
undo isp命令用来删除区域中的指定ISP信息。
isp isp-name
undo isp isp-name
不存在任何ISP信息。
负载均衡区域视图
context-admin
isp-name:ISP信息的名称,为1~255个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
# 在区域region-ct中添加ISP信息为isp-ct。
[Sysname] loadbalance region region-ct
[Sysname-lb-region-region-ct] isp isp-ct
·     loadbalance region
loadbalance dns-listener命令用来创建DNS监听器,并进入DNS监听器视图。如果指定的DNS监听器已经存在,则直接进入DNS监听器视图。
undo loadbalance dns-listener命令用来删除指定的DNS监听器。
loadbalance dns-listener dns-listener-name
undo loadbalance dns-listener dns-listener-name
不存在DNS监听器。
context-admin
dns-listener-name:DNS监听器名称,为1~255个字符的字符串,不区分大小写。
工作机制
DNS监听器用于监听负载均衡设备上收到的DNS请求。
注意事项
非缺省vSystem不支持本命令。
# 创建名称为ct-istener的DNS监听器,并进入该DNS监听器视图。
loadbalance dns-map命令用来创建DNS映射,并进入DNS映射视图。如果指定的DNS映射已经存在,则直接进入DNS映射视图。
undo loadbalance dns-map命令用来删除指定的DNS映射。
loadbalance dns-map dns-map-name
undo loadbalance dns-map dns-map-name
不存在DNS映射。
context-admin
dns-map-name:DNS映射名称,为1~255个字符的字符串,不区分大小写。
工作机制
一个DNS映射定义了待解析域名和虚服务器池IP地址之间的映射关系。一个域名只能与一个服务器池映射。
注意事项
非缺省vSystem不支持本命令。
# 创建一个DNS映射dm1,并进入该DNS映射视图。
[Sysname-lb-dm-dm1]
loadbalance link命令用来创建链路,并进入链路视图。如果指定的链路已经存在,则直接进入链路视图。
undo loadbalance link命令用来删除链路。
loadbalance link link-name
undo loadbalance link link-name
不存在链路。
context-admin
link-name:链路的名称,为1~255个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
连接外部网络的每条物理链路对应一个链路。
# 创建链路lk1,并进入该链路视图。
[Sysname-lb-link-lk1]
loadbalance local-dns-server parse-fail-record type命令用来配置可记录的解析失败的DNS请求报文的类型。
undo loadbalance local-dns-server parse-fail-record type命令用来删除可记录的解析失败的DNS请求报文的类型。
loadbalance local-dns-server parse-fail-record type { a | aaaa | all-disable | all-enable | cname | mx | ns | ptr | soa | srv | txt }
undo loadbalance local-dns-server parse-fail-record type { a | aaaa | cname | mx | ns | ptr | soa | srv | txt }
可记录的解析失败的DNS请求报文的类型为全部类型。
context-admin
a:A(Host Address,主机地址)类型。
aaaa:AAAA类型。
all-disable:不记录任何类型。
all-enable:记录所有类型。
cname:CNAME(Canonical Name,规范名称)类型。
mx:MX(Mail Exchanger,邮件交换)类型。
ns:NS(Name Server,权威名称服务器)类型。
ptr:PTR(Pointer Record,指针记录)类型。
soa:SOA(Start of Authority,起始授权)类型。
srv:SRV(Service,服务)类型。
txt:TXT(Text,文本)类型。
非缺省vSystem不支持本命令。
# 配置可记录的解析失败的DNS请求报文的类型为A类型。
[Sysname] loadbalance local-dns-server parse-fail-record type a
loadbalance local-dns-server parse-fail-record max-number命令用来配置可记录的解析失败的DNS请求报文的最大数目。
undo loadbalance local-dns-server parse-fail-record max-number命令用来恢复缺省情况。
loadbalance local-dns-server parse-fail-record max-number max-number
可记录的解析失败的DNS请求报文的最大数目为10000条。
context-admin
max-number:可记录的解析失败的DNS请求报文的最大数目,取值范围为0~4294967295。
非缺省vSystem不支持本命令。
# 配置可记录的解析失败的DNS请求报文的最大数目为600条。
[Sysname] loadbalance local-dns-server parse-fail-record max-number 600
loadbalance local-dns-server schedule-test ip命令用来测试IPv4入方向链路负载均衡的DNS解析结果。
loadbalance local-dns-server schedule-test ip [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address { ipv4-address | ipv6-address } } [ slot slot-number ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示公网。
destination destination-address:目的IPv4地址,即DNS监听器地址。
destination-port destination-port:目的端口号,取值范围为0~65535,缺省值为53。
source source-address:源IPv4地址。
source-port source-port:源端口号,取值范围为0~65535。
type:DNS请求报文的类型。
aaaa:AAAA类型。
txt:TXT(Text,文本)类型。
domain domain-name:待解析的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,如果该域名为绝对域名,则包括“.”在内的总长度不超过254个字符;如果该域名为非绝对域名,则总长度不超过253个字符。
ptr:PTR(Pointer Record,指针记录)类型,用来将IP地址解析为域名。
ip address { ipv4-address | ipv6-address }:待反向解析的IP地址。
slot slot-number:测试指定成员设备,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将测试所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 测试A类型DNS请求报文IPv4入方向链路负载均衡的DNS解析结果。
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type a domain www.example.com
Slot 0:
    Matched DNS listener: dl2
    Matched DNS mapping: dm2
    Matched virtual server pool: vsp2
    Preferred scheduling algorithm: Round robin
    Alternative scheduling algorithm: --
    Fallback scheduling algorithm: --
    Preferred algorithm failure cause: --
    Alternative algorithm failure cause: --
    Fallback algorithm failure cause: --
    Selected virtual server: vs2
    Response type: Send response
    Failure cause: --
# 测试MX类型DNS请求报文IPv4入方向链路负载均衡的DNS解析结果。
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type mx domain www.example.com
Slot 0:
    Matched zone: example.com
    Failure cause: --
# 测试PTR类型DNS请求报文IPv4入方向链路负载均衡的DNS解析结果。
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type ptr ip address 1.2.3.4
Slot 0:
    Matched zone: 1.2.3.0/24
    Failure cause: --
表1-11 loadbalance local-dns-server schedule-test ip命令显示信息描述表
匹配的DNS监听器名称
Matched zone
匹配的DNS区域(若DNS请求报文的类型为A、AAAA、CNAME、MX、NS、SOA、SRV或TXT类型,则该字段为DNS正向区域的域名;若DNS请求报文的类型为PTR类型,则该字段为DNS反向区域的IP地址)
Matched DNS mapping
匹配的DNS映射名称
匹配的虚服务池名称
虚服务器的首选调度算法,包括:
·     Round robin:加权轮转算法
·     Random:随机算法
·     Least connection:加权最小连接算法
·     Topology:静态就近性算法
·     Proximity:动态就近性算法
·     Bandwidth:总带宽算法
·     Inbound bandwidth:入方向带宽算法
·     Outbound bandwidth:出方向带宽算法
·     Max bandwidth:最大总带宽算法
·     Max inbound bandwidth:最大入方向带宽算法
·     Max outbound bandwidth:最大出方向带宽算法
·     Hash address source IP:根据源IP地址进行的哈希算法
·     Hash address destination IP:根据目的IP地址进行的哈希算法
·     Hash address source IP-port:根据源IP地址和端口号进行的哈希算法
虚服务器的次选调度算法,包括:
·     Random:随机算法
·     Topology:静态就近性算法
·     Proximity:动态就近性算法
·     Bandwidth:总带宽算法
·     --:未配置次选调度算法
虚服务器的备选调度算法,包括:
·     Random:随机算法
·     Topology:静态就近性算法
·     Proximity:动态就近性算法
·     Bandwidth:总带宽算法
·     --:未配置备选调度算法
首选调度失败原因,包括:
·     --:调度成功
·     No matched virtual server member:无匹配的虚服务器
次选调度算法失败原因,包括:
·     --:调度成功
备选调度算法失败原因,包括:
·     --:调度成功
选中的虚服务名称
Response type
请求报文的回应类型,包括:
·     Send response:发送DNS应答报文
·     Send reject:回应一个DNS拒绝报文
·     No response:不回应DNS请求
Failure cause
请求报文解析失败原因,包括
·     --:解析成功
loadbalance local-dns-server schedule-test ipv6命令用来测试IPv6入方向链路负载均衡的解析结果。
loadbalance local-dns-server schedule-test ipv6 [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address ipv4-address } [ slot slot-number ]
context-admin
destination destination-address:目的IPv6地址,即DNS监听器IPv6地址。
source source-address:源IPv6地址。
type:DNS请求报文的类型。
a:IPv4主机地址类型。
aaaa:IPv6主机地址类型。
txt:TXT(Text,文本)类型。
非缺省vSystem不支持本命令。
# 测试A类型DNS请求报文IPv6入方向链路负载均衡的解析结果。
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 source 1::5 source-port 5 type a domain www.example.com
Slot 0:
    Preferred algorithm failed cause: --
    Alternative algorithm failed cause: --
    Fallback algorithm failed cause: --
    Selected virtual server: vsa1
    Failure cause: --
# 测试MX类型DNS请求报文IPv6入方向链路负载均衡的解析结果。
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 destination-port 953 source 1::5 source-port 5 type mx domain www.example.com
Slot 0:
    Failure cause: --
# 测试PTR类型DNS请求报文IPv6入方向链路负载均衡的解析结果。
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 source 1::5 source-port 5 type ptr ip address 1.2.3.4
Slot 0:
    Failure cause: --
表1-12 loadbalance local-dns-server schedule-test ipv6命令显示信息描述表
匹配的DNS监听器名称
Matched zone
匹配的DNS区域(若DNS请求报文的类型为A、AAAA、CNAME、MX、NS、SOA、SRV或TXT类型,则该字段为DNS正向区域的域名;若DNS请求报文的类型为PTR类型,则该字段为DNS反向区域的IPv6地址)
Matched DNS mapping
匹配的DNS映射名称
匹配的虚服务池
虚服务器的首选调度算法,包括:
·     Random:随机算法
·     Topology:静态就近性算法
·     Proximity:动态就近性算法
·     Bandwidth:总带宽算法
虚服务器的次选调度算法,包括:
·     Random:随机算法
·     Topology:静态就近性算法
·     Proximity:动态就近性算法
·     Bandwidth:总带宽算法
·     --:未配置次选调度算法
虚服务器的备选调度算法,包括:
·     Random:随机算法
·     Topology:静态就近性算法
·     Proximity:动态就近性算法
·     Bandwidth:总带宽算法
·     --:未配置备选调度算法
首选调度失败原因,包括:
·     --:调度成功
次选调度算法失败原因,包括:
·     --:调度成功
备选调度算法失败原因,包括:
·     --:调度成功
选中的虚服务名称
Response type
请求报文的回应类型,包括:
Failure cause
请求报文解析失败原因,包括:
·     --:解析成功
·     Failed to get CONTEXT:获取CONTEXT失败
loadbalance log enable bandwidth-busy命令用来开启负载均衡链路带宽繁忙日志功能。
undo loadbalance log enable bandwidth-busy命令用来关闭负载均衡链路带宽繁忙日志功能。
负载均衡链路带宽繁忙日志功能处于关闭状态。
context-admin
工作机制
通过开启负载均衡链路带宽繁忙日志功能,实现对所有链路的繁忙状态进行记录。
注意事项
非缺省vSystem不支持本命令。
# 开启负载均衡链路带宽繁忙日志功能。
[Sysname] loadbalance log enable bandwidth-busy
loadbalance region命令用来创建区域对象,并进入区域对象视图。如果指定的区域对象已经存在,则直接进入区域对象视图。
undo loadbalance region命令用来删除指定的区域对象。
loadbalance region region-name
undo loadbalance region region-name
不存在任何区域对象。
context-admin
region-name:区域对象的名称,为1~255个字符的字符串,不区分大小写。
工作机制
区域对象中包含根据不同维度划分的地址段,目前仅支持按照运营商类别来划分地址段。
注意事项
非缺省vSystem不支持本命令。
# 创建区域对象isp-ct,并进入该区域对象视图。
[Sysname] loadbalance region isp-ct
[Sysname-lb-region-isp-ct]
loadbalance reverse-zone命令用来创建DNS反向区域,并进入DNS反向区域视图。如果指定的DNS反向区域已经存在,则直接进入DNS反向区域视图。
undo loadbalance reverse-zone命令用来删除指定的DNS反向区域。
loadbalance reverse-zone { ip ipv4-address mask-length | ipv6 ipv6-address prefix-length }
undo loadbalance reverse-zone { ip ipv4-address mask-length | ipv6 ipv6-address prefix-length }
不存在DNS反向区域。
context-admin
ip ipv4-address mask-length:DNS反向区域的IPv4地址和掩码长度。ipv4-address为DNS反向区域的IPv4地址;mask-length为IPv4地址的掩码长度,取值范围为0~32。
ipv6 ipv6-address prefix-length:DNS反向区域的IPv6地址和前缀长度。ipv6-address为DNS反向区域的IPv6地址;prefix-length为IPv6地址的前缀长度,取值范围为0~128。
非缺省vSystem不支持本命令。
# 创建IPv4地址及掩码长度为10.11.2.0/24的DNS反向区域,并进入DNS反向区域视图。
[Sysname] loadbalance reverse-zone ip 10.11.2.0 24
[Sysname-lb-rzone-10.11.2.0/24]
# 创建IPv6地址及前缀长度为1001::0/64的DNS反向区域,并进入DNS反向区域视图。
[Sysname] loadbalance reverse-zone ipv6 1001::0 64
[Sysname-lb-rzone-1001::/64]
·     display loadbalance reverse-zone
loadbalance virtual-server-pool命令用来创建虚服务器池,并进入虚服务器池视图。如果指定的虚服务器池已经存在,则直接进入虚服务器池视图。
undo loadbalance virtual-server-pool命令用来删除指定的虚服务器池。
loadbalance virtual-server-pool pool-name
undo loadbalance virtual-server-pool pool-name
不存在任何虚服务器池。
context-admin
pool-name:虚服务器池的名称,为1~255个字符的字符串,不区分大小写。
工作机制
为了便于对多个虚服务器进行管理,可以依据这些虚服务器的共有属性划分成不同的池,称为虚服务器池。
注意事项
非缺省vSystem不支持本命令。
# 创建虚服务器池local-pool,并进入虚服务器池视图。
loadbalance zone命令用来创建DNS正向区域,并进入DNS正向区域视图。如果指定的DNS正向区域已经存在,则直接进入DNS正向区域视图。
undo loadbalance zone命令用来删除指定的DNS正向区域。
loadbalance zone domain-name
undo loadbalance zone domain-name
不存在DNS正向区域。
context-admin
domain-name:DNS正向区域的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”和“.”。
非缺省vSystem不支持本命令。
# 创建域名为example.com的DNS正向区域,并进入DNS正向区域视图。
max-bandwidth命令用来配置链路的最大期望带宽。
undo max-bandwidth命令用来恢复缺省情况。
max-bandwidth [ inbound | outbound ] bandwidth-value kbps
undo max-bandwidth [ inbound | outbound ]
链路的最大期望带宽不受限制。
链路视图
context-admin
inbound:配置最大上行期望带宽,即入方向带宽。
outbound:配置最大下行期望带宽,即出方向带宽。
bandwidth-value:最大带宽值,取值范围为1~4294967295,单位为kbps,0表示最大带宽不受限制。
kbps:最大带宽值的单位为kbps。
工作机制
如果未指定inbound和outbound参数,则最大总期望带宽,总带宽等于入带宽与出带宽之和。
通过本命令配置的最大期望带宽不仅用于带宽繁忙保护功能,还用于带宽算法、最大带宽算法和就近性中剩余带宽的计算。
注意事项
非缺省vSystem不支持本命令。
# 配置链路lk1的最大总期望带宽为1kbps。
[Sysname-lb-link-lk1] max-bandwidth 1 kbps
# 配置链路lk1的最大上行期望带宽为1kbps。
[Sysname-lb-link-lk1] max-bandwidth inbound 1 kbps
# 配置链路lk1的最大下行期望带宽为1kbps。
[Sysname-lb-link-lk1] max-bandwidth outbound 1 kbps
1.1.32  min-ttl
min-ttl命令用来配置最小生命周期。
undo min-ttl命令用来恢复缺省情况。
min-ttl ttl-value
undo min-ttl
最小生命周期为3600秒。
SOA视图
context-admin
ttl-value:最小生命周期,取值范围为0~4294967295,单位为秒。
工作机制
最小生命周期是主域名服务器上的资源记录在辅助域名服务器上被缓存的时间。
注意事项
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,配置最小生命周期为1天。
[Sysname-lb-zone-example.com-soa] min-ttl 86400
predictor命令用来配置虚服务器池的调度算法。
undo predictor命令用来恢复缺省情况。
predictor { alternate | fallback | preferred } { least-connection | proximity | random | round-robin | topology | { bandwidth | max-bandwidth } [ inbound | outbound ] | hash address { source | source-ip-port | destination } [ mask mask-length | prefix prefix-length ] }
undo predictor { alternate | fallback }
虚服务器池的首选调度算法为加权轮转算法,不存在次选和备选调度算法。
虚服务器池视图
context-admin
alternate:指定虚服务器池的次选调度算法。
fallback:指定虚服务器池的备选调度算法。
preferred:指定虚服务器池的首选调度算法。
least-connection:加权最小连接算法,即总是把DNS请求分发给加权活动连接数(当前活动连接数/权值)最小的虚服务器。
proximity:动态就近性算法,即根据动态就近性表项把DNS请求分发给虚服务。
random:随机算法,即把DNS请求随机分发给每个虚服务器。
round-robin:加权轮转算法,即根据虚服务器权值的大小把DNS请求依次分发给每个虚服务器,权值越大,分配的DNS请求越多。
topology:静态就近性算法,即根据静态就近性表项把DNS请求分发给虚服务器。
bandwidth:带宽算法,即根据虚服务器的权值与剩余带宽的比例把DNS请求分发给每个虚服务器。
max-bandwidth:最大带宽算法,即总是将DNS请求分发给处于空闲状态且剩余带宽最大的链路所对应的虚服务器。
inbound:根据入方向带宽选择虚服务器。
outbound:根据出方向带宽选择虚服务器。
hash address:根据IP地址进行的哈希算法。
source:根据源IP地址进行的哈希算法。
source-ip-port:根据源IP地址和端口号进行的哈希算法。
destination:根据目的IP地址进行的哈希算法。
mask mask-length:哈希算法中IPv4地址的掩码长度。其中,mask-length的取值范围为0~32,缺省值为32。
prefix prefix-length:哈希算法中IPv6地址的掩码长度。其中,prefix-length的取值范围为0~128,缺省值为128。
工作机制
选择带宽算法或最大带宽算法时,若未指定inbound和outbound关键字,则将根据总带宽来选择虚服务器。
在带宽算法和最大带宽算法中,剩余带宽为链路的最大期望带宽(max-bandwidth)与当前带宽的差值。若未配置最大期望带宽,剩余带宽为链路所允许的最大带宽(rate-limit bandwidth)与当前带宽的差值。
注意事项
非缺省vSystem不支持本命令。
# 配置虚服务器池local-pool的优选调度算法为随机算法,次选调度算法为最小连接数算法。
[Sysname-lb-vspool-local-pool] predictor preferred random
[Sysname-lb-vspool-local-pool] predictor alternate least-connection
·     max-bandwidth (link view)
·     rate-limit bandwidth (link view)
primary-nameserver命令用来配置主域名服务器的主机名。
undo primary-nameserver命令用来恢复缺省情况。
primary-nameserver host-name
未配置主域名服务器的主机名。
SOA视图
context-admin
host-name:主域名服务器的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
工作机制
主域名服务器的主机名可以是相对域名(不以“.”结束),也可以是绝对域名(以“.”结束)。当主机名为绝对域名时,不会自动扩充主机名,其长度不能大于254个字符;当主机名为相对域名时,会进行自动扩充,在用户配置的主机名后自动添加当前区域名。主机名加区域名长度总和不能大于254个字符。
注意事项
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,配置主域名服务器的主机名为ns1.example.com。
[Sysname-lb-zone-example.com-soa] primary-nameserver ns1.example.com
probe命令用来指定链路的健康检测方法。
undo probe命令用来恢复缺省情况。
probe template-name
undo probe template-name
未指定链路的健康检测方法。
链路视图
context-admin
template-name:健康检测方法所使用的NQA模板名称,为1~255个字符的字符串,不区分大小写。
工作机制
通过配置健康检测方法可以对链路进行检测,保证其能够提供有效的链路,健康检测方法所使用的NQA模板由nqa template命令配置。
同一个链路视图下,可以配置多个链路健康检测方法。系统缺省情况下,只有全部方法通过检测才认为健康检测成功,可通过success-criteria命令配置链路健康检测的成功条件。
注意事项
非缺省vSystem不支持本命令。
# 创建ICMP类型的NQA模板t4,并将其指定为链路lk1的健康检测方法。
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-link-lk1] probe t4
·     nqa template(网络管理和监控命令参考/NQA)
·     success-criteria (link view)
1.1.36  record
record命令用来配置指定类型的资源记录。
undo record命令用来删除指定的资源记录。
record { cname alias alias-name canonical canonical-name | mx [ host hostname ] exchanger exchanger-name preference preference | ns [ sub subname ] authority ns-name | srv [ service service-name ] host-offering-service hostname priority priority weight weight port  port-number | txt [ sub subname ] describe-txt description } [ ttl ttl-value ]
undo record { cname alias alias-name canonical canonical-name | mx [ host hostname ] exchanger exchanger-name | ns [ sub subname ] authority ns-name | srv [ service hostname ] host-offering-service hostname port port-number | txt [ sub subname ] describe-txt description }
不存在任何资源记录。
正向区域视图
context-admin
cname:CNAME(Canonical Name,规范名称)类型的资源记录。
alias alias-name:别名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
canonical canonical-name:正规主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
mx:MX(Mail Exchanger,邮件交换)类型的资源记录。
host hostname:MX资源记录主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
exchanger exchanger-name:邮件服务器的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
preference preference:MX资源记录的优先级,取值范围为0~65535。该值越小,优先级越高。
ns:NS(Name Server,权威名称服务器)类型的资源记录。
sub subname:该区域的子域名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,如果该域名为绝对域名,则包括“.”在内的总长度不超过254个字符。如果该域名为非绝对域名,则总长度不超过253个字符。域名可以包含字母、数字、“-”、“_”或“.”。
authority ns-name:权威名称服务器的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
srv:SRV(Service,服务)类型的资源记录。
service service-name:服务名称,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,如果该服务名称为绝对域名,则包括“.”在内的总长度不超过254个字符。如果该域名为非绝对域名,则总长度不超过253个字符。域名可以包含字母、数字、“-”、“_”或“.”。为了与主机域名区分,应用名称和协议以下划线开始,例如:_ftp._tcp.movie.edu。若未指定本参数,则服务名称为DNS正向区域的域名。
host-offering-service host-name:提供此服务的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,如果该服务名称为绝对域名,则包括“.”在内的总长度不超过254个字符。如果该域名为非绝对域名,则总长度不超过253个字符。域名可以包含字母、数字、“-”、“_”或“.”。
priority priority:优先级,取值范围为0~100,数值越小优先级越高。
weight weight-value:权值,取值范围为0~100。
port port-number:服务端口号,取值范围0~65535。
txt:TXT(Text,文本)类型的资源记录。
describe-txt description:文本描述,为1~255个字符的字符串,区分大小写。
ttl ttl-value:资源记录的缓存时间,取值范围为0~4294967295,单位为秒,缺省值为3600。
工作机制
资源记录指定的主机名可以是相对域名(不以“.”结束),也可以是绝对域名(以“.”结束)。当主机名为绝对域名时,不会自动扩充主机名,其长度不能大于254个字符;当主机名为相对域名时,会进行自动扩充,在用户配置的主机名后自动添加当前区域名。主机名加区域名长度总和不能大于254个字符。
若相同的服务有多条SRV记录,设备会先尝试连接优先级最低的记录。若存在多条SRV记录并且优先级也相同,那么用户会先尝试连接权重高的记录。
若在本命令中指定了资源记录的缓存时间则优先使用该缓存时间,否则使用DNS正向区域视图下配置的缓存时间。
在同一DNS正向区域内,可以配置多条资源记录。
注意事项
非缺省vSystem不支持本命令。
# 在DNS正向区域example.com中,配置MX类型资源记录:指定邮件服务器的主机名mail.example.com,MX资源记录的优先级为10。
[Sysname-lb-zone-example.com] record mx exchanger mail.example.com preference 10
# 在DNS正向区域example.com中,配置CNAME类型资源记录:指定正规主机名aaa.example.com的别名为test.example.com。
[Sysname-lb-zone-example.com] record cname alias test.example.com canonical aaa.example.com
# 在DNS正向区域example.com中,配置NS类型资源记录:指定权威名称服务器的主机名为ns1.example.com。
[Sysname-lb-zone-example.com] record ns authority ns1.example.com
# 在DNS正向区域example.com中,配置TXT类型资源记录。
[Sysname-lb-zone-example.com] record txt sub hotline describe-txt v=spf1 include:spf.abcmail.example.com.cn -all
# 在DNS正向区域example.com中,配置SRV类型资源记录。
[Sysname-lb-zone-example.com] record srv service _http._tcp.example.com. host-offering-service www.example.com priority 5 weight 10 port 80
1.1.37  record ptr
record ptr命令用来配置PTR资源记录。
undo record ptr命令用来删除指定的PTR资源记录。
record ptr { ip ipv4-address | ipv6 ipv6-address } domain-name [ ttl ttl-value ]
undo record ptr { ip ipv4-address | ipv6 ipv6-address } domain-name
不存在PTR资源记录。
DNS反向区域视图
context-admin
ip ipv4-address:IPv4地址。
ipv6 ipv6-address:IPv6地址。
domain-name:域名,不区分大小写。由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”或“.”。
ttl ttl-value:资源记录的缓存时间。其中,ttl-value的取值范围为0~4294967295,缺省值为3600,单位为秒。
工作机制
用户可根据需求,对需要进行反向解析的IP地址配置PTR资源记录。
PTR资源记录中指定的IP地址应在其所属DNS反向区域的IP地址范围内。
同一DNS反向区域下,可配置多条PTR类型资源记录。
注意事项
非缺省vSystem不支持本命令。
# 在DNS反向区域10.1.1.0/24中,配置PTR类型的资源记录。
[Sysname] loadbalance reverse-zone ip 10.1.1.0 24
[Sysname-lb-rzone-10.1.1.0/24] record ptr ip 10.1.1.1 mail.example.com
1.1.38  refresh
refresh命令用来配置刷新间隔。
undo refresh命令用来恢复缺省情况。
refresh refresh-interval
undo refresh
刷新间隔为3600秒。
SOA视图
context-admin
refresh-interval:刷新间隔,取值范围为300~2419200,单位为秒。
工作机制
辅助域名服务器以刷新间隔为周期,从主域名服务器上获取SOA资源记录,然后和本地辅助域名服务器上的SOA资源记录相比较。
注意事项
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,指定刷新间隔为4小时。
[Sysname-lb-zone-example.com-soa] refresh 14400
reset loadbalance dns-listener statistics命令用来清除DNS监听器的统计信息。
reset loadbalance dns-listener statistics [ dns-listener-name ]
context-admin
dns-listener-name:DNS监听器名称,为1~255个字符的字符串,不区分大小写。如果未指定此参数,则清除所有DNS监听器的统计信息。
非缺省vSystem不支持本命令。
# 清除DNS监听器dl2的统计信息。
<Sysname> reset loadbalance dns-listener statistics dl2
# 清空所有DNS监听器的统计信息。
·     display loadbalance dns-listener statistics
reset loadbalance dns-map statistics命令用来清除DNS映射的统计信息。
reset loadbalance dns-map statistics [ dns-map-name ]
context-admin
dns-map-name:DNS映射名称,为1~255个字符的字符串,不区分大小写。如果未指定此参数,则清除所有DNS映射的统计信息。
非缺省vSystem不支持本命令。
# 清除DNS映射dm2的统计信息。
<Sysname> reset loadbalance dns-map statistics dm2
# 清除所有DNS映射的统计信息。
·     display loadbalance dns-map statistics
reset loadbalance local-dns-server parse-fail-record命令用来清除当前记录的解析失败的DNS请求报文的信息。
context-admin
非缺省vSystem不支持本命令。
# 清除当前记录的解析失败的DNS请求报文的信息。
<Sysname> reset loadbalance local-dns-server parse-fail-record
responsible-mail命令用来配置管理员的邮箱地址。
undo responsible-mail命令用来恢复缺省情况。
responsible-mail mail-address
未配置管理员的邮箱地址。
SOA视图
context-admin
mail-address:管理员的邮箱地址,区分大小写。由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符。字符串中可以包含字母、数字、“-”、“_”和“.”。
工作机制
管理员邮箱地址可以是相对域名(不以“.”结束),也可以是绝对域名(以“.”结束)。当管理员邮箱地址为绝对域名时,不会自动扩充主机名,其长度不能大于254个字符;当管理员邮箱地址为相对域名时,会进行自动扩充,在用户配置的管理员邮箱地址后自动添加当前区域名。管理员邮箱地址加区域名长度总和不能大于254个字符。
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,配置管理员的邮箱地址为root.ns1.example.com。
[Sysname-lb-zone-example.com-soa] responsible-mail root.ns1.example.com
1.1.43  retry
retry命令用来指定重试时间。
undo retry命令用来恢复缺省情况。
retry retry-interval
undo retry
重试时间为600秒。
SOA视图
context-admin
retry-interval:重试时间,取值范围为500~1209600,单位为秒。
工作机制
重试时间为辅助域名服务器进行区域复制失败后的等待时间。
注意事项
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,指定重试时间为30分钟。
[Sysname-lb-zone-example.com-soa] retry 1800
1.1.44  router ip
router ip命令用来指定链路通往外网方向的下一跳IPv4地址。
undo router ip命令用来恢复缺省情况。
router ip ipv4-address
undo router ip
未配置链路通往外网方向的下一跳IPv4地址。
链路视图
context-admin
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
非缺省vSystem不支持本命令。
一条链路只能配置一个通往外网方向的下一跳IPv4地址。
# 指定链路lk1通往外网方向的下一跳IPv4地址为1.2.3.4。
[Sysname-lb-link-lk1] router ip 1.2.3.4
1.1.45  serial
serial命令用来配置DNS正向区域的序列号。
undo serial命令用来恢复缺省情况。
serial number
undo serial
DNS正向区域的序列号为1。
SOA视图
context-admin
number:序列号,取值范围为1~4294967295。
工作机制
序列号标识该区域配置的新旧,区域越新,序列号越大。
辅助域名服务器会周期性地查询主域名服务器上DNS正向区域的序列号,然后和本地的DNS正向区域序列号相比较。
注意事项
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,配置DNS正向区域的序列号为123。
[Sysname-lb-zone-example.com-soa] serial 123
service enable命令用来开启DNS监听功能。
undo service enable命令用来关闭DNS监听功能。
service enable
undo service enable
DNS监听功能处于关闭状态。
DNS监听器视图
context-admin
非缺省vSystem不支持本命令。
# 在名称为ct-listener的DNS监听器视图下,开启DNS监听功能。
[Sysname-lb-dl-ct-listener] service enable
service enable命令用来开启DNS映射。
undo service enable命令关闭DNS映射。
service enable
undo service enable
DNS映射处于关闭状态。
DNS映射视图
context-admin
非缺省vSystem不支持本命令。
# 在名称为dm1的DNS映射视图下,开启DNS映射服务。
[Sysname-lb-dm-dm1] service enable
1.1.48  soa
soa命令用来创建SOA类型的资源记录,并进入SOA视图。如果SOA类型的资源记录已经存在,则直接进入SOA视图。
undo soa命令用来删除SOA类型的资源记录与该记录下的所有配置。
soa
undo soa
不存在SOA类型的资源记录。
DNS正向区域视图
context-admin
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,创建SOA类型的资源记录,并进入SOA视图。
success-criteria命令用来配置链路健康检测的成功条件。
undo success-criteria命令用来恢复缺省情况。
success-criteria { all | at-least min-number }
只有全部方法通过检测才认为健康检测成功。
链路视图
context-admin
all:要求链路通过所有方式的健康检测。
at-least min-number:要求链路至少通过指定方式数目的健康检测,取值范围为1~4294967295。
工作机制
当用户指定的最少方法数大于设备上实际存在的方法数量时,只要实际存在的全部方法通过检测,系统就认为健康检测成功。
注意事项
非缺省vSystem不支持本命令。
# 配置链路健康检测的成功条件至少为2个。
[Sysname-lb-link-lk1] success-criteria at-least 2
·     success-criteria(link group view)
topology region命令用来配置Topology。
undo topology region命令用来恢复缺省情况。
topology region region-name { ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address prefix-length } [ priority priority ]
undo topology region region-name [ ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address [ prefix-length ] ]
Topology(区域特征与IP网段的对应关系)不存在。
context-admin
region-name:区域名,为1~255个字符的字符串,不区分大小写。
ip ipv4-address:虚服务器的IPv4地址。
mask-length:IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
mask:IPv4掩码,缺省值为255.255.255.255。
ipv6 ipv6-address:虚服务器的IPv6地址。
prefix-length:IPv6地址的前缀长度,取值范围为1~128,缺省值为128。
priority priority:优先级,取值范围为1~255,缺省值为100。
工作机制
Topology定义了LDNS(本地DNS服务器)源地址区域特征与虚服务器所在IP网段的对应关系。
当虚服务器池中通过predictor命令指定调度算法为静态就近性调度算法时,需要配置此命令。
当DNS请求匹配多个Topology记录时,优先选择优先级值高的记录。
通过多次执行本命令,可以为一个区域特征配置多个不同的IP网段。
注意事项
非缺省vSystem不支持本命令。
若删除Topology时仅指定区域特征,则该区域特征对应的所有Topology均会被删除。
# 配置指定的源地址区域特征与IP网段的对应关系。
[Sysname] topology region region-ct ip 1.2.3.4 24 priority 200
·     predictor(virtual-server-pool view)
ttl命令用来配置资源记录的全局缓存时间。
undo ttl命令用来恢复缺省情况。
ttl ttl-value
undo ttl
资源记录的缓存时间为3600秒。
DNS正向区域视图
context-admin
ttl-value:资源记录的全局缓存时间,取值范围为0~4294967295,单位为秒。
非缺省vSystem不支持本命令。
# 对DNS正向区域example.com,配置资源记录的全局缓存时间为1天。
[Sysname-lb-zone-example.com] ttl 86400
ttl命令用来配置缓存DNS域名解析记录的缓存时间。
undo ttl命令用来恢复缺省情况。
ttl ttl-value
undo ttl
域名解析记录的缓存时间缺省值为3600秒。
DNS映射视图
context-admin
ttl-value:缓存时间,取值范围为0~4294967295,单位为秒。
工作机制
该命令指定DNS请求客户端本地保存域名解析记录的时间,当负载均衡策略变化、虚服务器配置变化时,用户可以通过配置小一些的缓存时间(比如60秒),使DNS请求客户端尽快获得新的解析记录;而在网络稳定的环境下,用户可将缓存时间设置为更大的值(比如86400秒),提高域名的解析稳定性及速度。
注意事项
非缺省vSystem不支持本命令。
# 在名称为dm1的DNS映射视图下,配置缓存DNS域名解析记录的缓存时间为4000秒。
[Sysname-lb-dm-dm1] ttl 4000
1.1.53  virtual-ip
virtual-ip命令用来向虚服务器池中添加虚IP地址。
undo virtual-ip命令用来从虚服务器池中删除指定的虚IP地址。
virtual-ip ipv4-address link link-name [ weight weight-value ]
undo virtual-ip ipv4-address
虚服务器池未添加任何虚IP地址。
虚服务器池视图
context-admin
ipv4-address:虚IPv4地址。
link link-name:虚IP地址关联的链路的名称,为1~63个字符的字符串,不区分大小写。
weight weight-value:虚IP地址的权值。其中,weight-value的取值范围为1~255,缺省值为100。
应用场景
在无需配置服务器负载均衡的场景下,可以不配置虚服务器,而直接配置虚IP地址简化配置。
工作机制
在加权轮转调度算法中,虚IP地址的权值越大,越被优先调度。
虚服务器池中允许添加多个虚IPv4地址,同一虚IPv4地址只能关联一条链路。若虚IPv4地址相同,多次执行本命令,最后一次执行的命令生效。
注意事项
非缺省vSystem不支持本命令。
# 在名称为local-pool的虚服务器池视图下,中添加虚IP地址10.0.0.1,关联的链路为link1。
[Sysname-lb-vspool-local-pool] virtual-ip 10.0.0.1 link link1
·     loadbalance link
·     loadbalance virtual-server-pool
1.1.54  virtual-ipv6
virtual-ipv6命令用来向虚服务器池中添加虚IPv6地址。
undo virtual-ipv6命令用来从虚服务器池中删除指定的虚IPv6地址。
virtual-ipv6 ipv6-address link link-name [ weight weight-value ]
undo virtual-ipv6 ipv6-address
虚服务器池未添加任何虚IPv6地址。
虚服务器池视图
context-admin
ipv6-address:虚IPv6地址。
link link-name:虚IPv6地址关联的链路的名称,为1~63个字符的字符串,不区分大小写。
weight weight-value:虚IPv6地址的调用权值。其中,weight-value的取值范围为1~255,缺省值为100。
应用场景
在无需配置服务器负载均衡的场景下,可以不配置虚服务器,而直接配置虚IPv6地址简化配置。
工作机制
在加权轮转调度算法中,虚IPv6地址的权值越大,越被优先调度。
虚服务器池中允许添加多个虚IPv6地址,同一虚IPv6地址只能关联一条链路。若虚IPv6地址相同,多次执行本命令,最后一次执行的命令生效。
注意事项
非缺省vSystem不支持本命令。
# 在名称为local-pool的虚服务器池视图下,添加虚IPv6地址10::1,关联的链路为link1。
[Sysname-lb-vspool-local-pool] virtual-ip 10::1 link link1
·     loadbalance link
virtual-server命令用来向虚服务器池中添加虚服务器。
undo virtual-server命令用来从虚服务器池中删除指定的虚服务器。
virtual-server virtual-server-name link link-name [ weight weight-value ]
undo virtual-server virtual-server-name
虚服务器池未添加任何虚服务器。
虚服务器池视图
context-admin
virtual-server-name:添加的虚服务器名称,为1~255个字符的字符串,不区分大小写。
link link-name:虚服务器关联的链路的名称,为1~255个字符的字符串,不区分大小写。
weight weight-value:虚服务器的调用权值。其中,weight-value的取值范围为1~255,缺省值为100。在加权轮转调度算法中,该数值越大,虚服务器的调用优先级越高。如果不指定此参数,添加的虚服务器的调用权值为其缺省值100。
非缺省vSystem不支持本命令。
虚服务器池中允许添加多个虚服务器。
如果同时配置入方向链路负载均衡功能和服务器负载均衡功能,请避免配置虚服务器的IP地址与DNS监听器地址为同一地址,以免影响入方向链路负载均衡功能的正常使用。
配置入方向链路负载均衡使用的虚服务器的IP地址时,要求配置32位掩码,且为非全0的单播地址。
# 向虚服务器池local-pool中添加虚服务器vs1,关联链路为link1。
[Sysname-lb-vspool-local-pool] virtual-server vs1 link link1
·     loadbalance link
virtual-server-pool命令用来指定DNS映射使用的虚服务器池。
undo virtual-server-pool命令用来恢复缺省情况。
undo virtual-server-pool pool-name
未指定DNS映射使用的虚服务器池。
DNS映射视图
context-admin
pool-name:虚服务器池名称,为1~255个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
目前一个DNS映射视图中仅支持配置一个虚服务器池。
# 在名称为dm1的DNS映射视图下,使用的虚服务器池为pool1。
[Sysname-lb-dm-dm1] virtual-server-pool pool1
1.1.57  vpn-instance
vpn-instance命令用来指定DNS监听器所属的VPN实例。
undo vpn-instance命令来恢复缺省情况。
undo vpn-instance
DNS监听器属于公网。
DNS监听器视图
context-admin
vpn-instance-name:MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
非缺省vSystem不支持本命令。
# 指定DNS监听器ct-listener所属的VPN实例为vpn1。
[Sysname-lb-dl-ct-listener] vpn-instance vpn1
