09-负载均衡命令参考
02-服务器负载均衡命令
本章节下载: 02-服务器负载均衡命令  (2.38 MB)
02-服务器负载均衡命令
1 服务器负载均衡
1.1 服务器负载均衡配置命令
1.1.1 abnormal-url threshold
1.1.2 activate
1.1.3 all-service-down action forward
1.1.4 application-mode enable
1.1.5 argument
1.1.6 arp-nd interface (SNAT address pool view)
1.1.7 arp-nd interface (virtual server view)
1.1.8 auto-shutdown recovery-time
1.1.9 busy-action
1.1.10 capability-exchange timeout
1.1.11 case-insensitive
1.1.12 check all-packet
1.1.13 check-url
1.1.14 class
1.1.15 close-connection enable
1.1.16 compression level
1.1.17 concurrent-streams-per-connection
1.1.18 connection close
1.1.19 connection idle-timeout
1.1.20 connection-limit max (real server view)
1.1.21 connection-limit max (server farm member view)
1.1.22 connection-limit max (virtual server view)
1.1.23 connection-sync enable
1.1.24 content (HTTP content sticky group view)
1.1.25 content (HTTP passive sticky group view)
1.1.26 content length-threshold
1.1.27 content maxparse-length
1.1.28 content request-max-length
1.1.29 content rewrite
1.1.30 cookie (protection policy view)
1.1.31 cookie (sticky group view)
1.1.32 cookie secondary name
1.1.33 customlog content
1.1.34 default server-farm
1.1.35 default-class action
1.1.36 description
1.1.37 destination-ip object-group
1.1.38 diameter-attribute code
1.1.39 display loadbalance action
1.1.40 display loadbalance alg
1.1.41 display loadbalance class
1.1.42 display loadbalance connections
1.1.43 display loadbalance diameter connections
1.1.44 display loadbalance dns-query
1.1.45 display loadbalance external-monitor log
1.1.46 display loadbalance hot-backup statistics
1.1.47 display loadbalance limit-policy
1.1.48 display loadbalance policy
1.1.49 display loadbalance probe failed-record
1.1.50 display loadbalance probe undetected
1.1.51 display loadbalance probe-template
1.1.52 display loadbalance process-limit
1.1.53 display loadbalance protection-policy
1.1.54 display loadbalance snat-address statistics
1.1.55 display loadbalance snat-global-policy
1.1.56 display loadbalance snat-pool
1.1.57 display loadbalance snat-pool reference
1.1.58 display loadbalance snat-pool statistics
1.1.59 display loadbalance total-count
1.1.60 display loadbalance virtual-server overall-total-statistics
1.1.61 display loadbalance virtual-server total-statistics
1.1.62 display parameter-profile
1.1.63 display real-server
1.1.64 display real-server statistics
1.1.65 display real-server overall-statistics
1.1.66 display server-farm
1.1.67 display sticky statistics
1.1.68 display sticky virtual-server
1.1.69 display sticky-group
1.1.70 display temporary-real-server
1.1.71 display virtual-server
1.1.72 display virtual-server statistics
1.1.73 display virtual-server overall-statistics
1.1.74 domain-name
1.1.75 encrypt-cookie
1.1.76 env-variables
1.1.77 exceed-mss
1.1.78 external-link inject-domain-suffix
1.1.79 external-link inject-uri
1.1.80 external-link proxy enable (LB action view)
1.1.81 external-link proxy enable (virtual sever view)
1.1.82 external-link snat-pool
1.1.83 external-link whitelist domain
1.1.84 external-script
1.1.85 fail-action
1.1.86 fallback-action close
1.1.87 fallback-action continue
1.1.88 fallback-action response raw-file
1.1.89 fin-wait1 timeout
1.1.90 fin-wait2 timeout
1.1.91 forward all
1.1.92 frame size
1.1.93 frequency
1.1.94 header (HTTP header sticky group view)
1.1.95 header (HTTP passive sticky group view)
1.1.96 header call-id
1.1.97 header delete
1.1.98 header delete request accept-encoding
1.1.99 header exceed-length
1.1.100 header insert
1.1.101 header insert response vary
1.1.102 header maxparse-length
1.1.103 header modify per-request
1.1.104 header rewrite
1.1.105 header rewrite request url
1.1.106 header-table size
1.1.107 host ip address
1.1.108 idle-time
1.1.109 inherit vpn-instance disable
1.1.110 insert-header-field
1.1.111 insert-xff enable
1.1.112 ip
1.1.113 ip address
1.1.114 ip range
1.1.115 ip source mask
1.1.116 ipv6
1.1.117 ipv6 address
1.1.118 ipv6 range
1.1.119 ipv6 source prefix
1.1.120 ishell
1.1.121 keepalive idle-timeout
1.1.122 keepalive l4 idle-timeout
1.1.123 keepalive retransmission interval
1.1.124 lb-limit-policy
1.1.125 lb-policy
1.1.126 limit
1.1.127 loadbalance action
1.1.128 loadbalance alg
1.1.129 loadbalance alg all-enable
1.1.130 loadbalance class
1.1.131 loadbalance limit-policy
1.1.132 loadbalance log enable base
1.1.133 loadbalance log enable nat
1.1.134 loadbalance policy
1.1.135 loadbalance probe failed-record enable
1.1.136 loadbalance probe failed-record max-number
1.1.137 loadbalance probe nqa-task-restrict disable
1.1.138 loadbalance probe-result synchronization enable
1.1.139 loadbalance probe-template
1.1.140 loadbalance process-limit
1.1.141 loadbalance protection-policy
1.1.142 loadbalance reload external-link file
1.1.143 loadbalance schedule-test ip
1.1.144 loadbalance schedule-test ipv6
1.1.145 loadbalance snat-global-policy
1.1.146 loadbalance snat-pool
1.1.147 loadbalance ssl performance-optimize cache-value
1.1.148 loadbalance tcp-timestamp-mode
1.1.149 loadbalance test pcre
1.1.150 loadbalance test rewrite
1.1.151 location rewrite
1.1.152 manual-recover enable (server farm member view)
1.1.153 manual-recover enable (server farm view)
1.1.154 match acl
1.1.155 match application-id
1.1.156 match class
1.1.157 match content
1.1.158 match cookie
1.1.159 match destination-realm
1.1.160 match header
1.1.161 match interface
1.1.162 match method
1.1.163 match payload
1.1.164 match radius-attribute
1.1.165 match source
1.1.166 match sql
1.1.167 match url
1.1.168 match user
1.1.169 match user-group
1.1.170 match version
1.1.171 match-across-service enable
1.1.172 match-across-virtual-server enable
1.1.173 match-buffer-end
1.1.174 match-buffer-size
1.1.175 match-buffer-time
1.1.176 max-reuse (parameter profile view)
1.1.177 memory-size
1.1.178 monitor-interval
1.1.179 node
1.1.180 origin-host
1.1.181 origin-realm
1.1.182 override-limit enable
1.1.183 parameter (LB action view)
1.1.184 parameter (virtual server view)
1.1.185 parameter-profile
1.1.186 payload (HTTP/UDP payload sticky-group view)
1.1.187 payload (UDP passive sticky-group view)
1.1.188 payload rewrite
1.1.189 pool-size
1.1.190 port (real server view)
1.1.191 port (virtual server view)
1.1.192 predictor
1.1.193 prefer-method
1.1.194 priority (real server view)
1.1.195 priority (server farm member view)
1.1.196 priority (SNAT global policy view)
1.1.197 probe (real server view)
1.1.198 probe (server farm member view)
1.1.199 probe (server farm view)
1.1.200 probe log enable (real server view)
1.1.201 probe log enable (server farm member view)
1.1.202 probe-template (real-server view)
1.1.203 probe-template (server-farm member view)
1.1.204 probe-template (server-farm view)
1.1.205 product-name
1.1.206 protect-action
1.1.207 protected-url
1.1.208 protection-action
1.1.209 protection-period
1.1.210 protection-policy
1.1.211 proximity enable
1.1.212 proxy-protocol enable
1.1.213 radius-attribute
1.1.214 rate-limit bandwidth (real server view)
1.1.215 rate-limit bandwidth (virtual server view)
1.1.216 rate-limit connection (real server view)
1.1.217 rate-limit connection (server farm member view)
1.1.218 rate-limit connection (virtual server view)
1.1.219 rate-limit http-request (real server view)
1.1.220 rate-limit http-request (server farm member view)
1.1.221 readwrite-separation
1.1.222 real-server (server farm view)
1.1.223 real-server (system view)
1.1.224 rebalance per-request
1.1.225 recover-to-active (real server view)
1.1.226 recover-to-active (server farm member view)
1.1.227 recv-window size
1.1.228 redirect relocation (LB action view)
1.1.229 redirect relocation (virtual server view)
1.1.230 redirect return-code (LB action view)
1.1.231 redirect return-code (virtual server view)
1.1.232 reload http-response
1.1.233 request-version all
1.1.234 reset loadbalance connections
1.1.235 reset loadbalance dns-cache
1.1.236 reset loadbalance hot-backup statistics
1.1.237 reset loadbalance probe failed-record
1.1.238 reset loadbalance snat-pool statistics
1.1.239 reset real-server statistics
1.1.240 reset sticky virtual-server
1.1.241 reset virtual-server statistics
1.1.242 response
1.1.243 retransmission enable
1.1.244 retransmission timeout
1.1.245 retransmission-timeout
1.1.246 route-advertisement enable
1.1.247 rst threshold
1.1.248 rule (parameter profile view)
1.1.249 rule (protection policy view)
1.1.250 secondary-cookie delimiters
1.1.251 secondary-cookie start
1.1.252 selected-server
1.1.253 server-connection reuse
1.1.254 service-down-action reset
1.1.255 server-farm (LB action view)
1.1.256 server-farm (real server view)
1.1.257 server-farm (system view)
1.1.258 service enable
1.1.259 service object-group
1.1.260 set ip tos (LB action view)
1.1.261 set ip tos (parameter profile view)
1.1.262 shutdown (real server view)
1.1.263 shutdown (server farm member view)
1.1.264 shutdown-real-servers ip
1.1.265 shutdown-real-servers ipv6
1.1.266 slow-attack protection enable
1.1.267 slow-attack request-header timeout
1.1.268 slow-offline enable (real server view)
1.1.269 slow-offline enable (server farm member view)
1.1.270 slow-online
1.1.271 slow-shutdown enable (real server view)
1.1.272 slow-shutdown enable (server farm member view)
1.1.273 snat enable
1.1.274 snat-mode
1.1.275 snat-pool
1.1.276 snmp-agent trap enable loadbalance
1.1.277 source-ip
1.1.278 source-ip object-group (parameter profile view)
1.1.279 source-ip object-group (SNAT global policy view)
1.1.280 src-addr-option
1.1.281 ssl session-id
1.1.282 ssl url rewrite
1.1.283 ssl-client-policy (LB action view)
1.1.284 ssl-client-policy (virtual server view)
1.1.285 ssl-server-policy
1.1.286 statistics-match url
1.1.287 status-code
1.1.288 sticky
1.1.289 sticky-group
1.1.290 sticky-over-busy enable
1.1.291 sticky-sync enable (virtual server view)
1.1.292 success-criteria (real server view)
1.1.293 success-criteria (server farm member view)
1.1.294 success-criteria (server farm view)
1.1.295 syn retransmission-timeout
1.1.296 syn-cookie threshold
1.1.297 tcp connection idle-timeout
1.1.298 tcp mss
1.1.299 tcp delayed-acks
1.1.300 tcp option preserve
1.1.301 tcp option insert
1.1.302 tcp option insert-mode
1.1.303 tcp option remove
1.1.304 tcp option rewrite
1.1.305 tcp window-size
1.1.306 tcp-close
1.1.307 payload (TCP payload sticky-group view)
1.1.308 timeout (LB probe template view)
1.1.309 timeout (sticky group view)
1.1.310 time-wait timeout
1.1.311 traffic-group (virtual server view)
1.1.312 traffic-group (snat pool view)
1.1.313 translation-mode
1.1.314 transparent enable
1.1.315 udp per-packet
1.1.316 username (virtual server view)
1.1.317 variable
1.1.318 vendor-id
1.1.319 version
1.1.320 virtual ip address
1.1.321 virtual ipv6 address
1.1.322 virtual-server (system view)
1.1.323 vpn-instance (real server view)
1.1.324 vpn-instance (SNAT address pool view)
1.1.325 vpn-instance (SNAT global policy view)
1.1.326 vpn-instance (virtual server view)
1.1.327 vrrp vrid (SNAT address pool view)
1.1.328 vrrp vrid (virtual server view)
1.1.329 weight (real server view)
1.1.330 weight (server farm member view)
1.1.331 window-size
1.1.332 zero-window threshold
1 服务器负载均衡
非缺省vSystem不支持本特性的部分命令,具体情况请见本文相关描述。有关vSystem的详细介绍请参见“虚拟化技术配置指导”中的“vSystem”。
1.1  服务器负载均衡配置命令
abnormal-url threshold命令用来配置URL异常次数的上限阈值。
undo abnormal-url threshold命令用来恢复缺省情况。
abnormal-url threshold number
URL异常次数的上限阈值为10000。
HTTP passive类型的负载均衡探测模板视图
context-admin
vsys-admin
number:URL异常次数的上限阈值,取值范围为1~4294967295。
当设备收到携带指定URL的HTTP请求报文后,会对其响应报文进行HTTP被动健康检测。若响应报文中携带的响应状态码为status-code命令配置的值或响应时间超过timeout命令配置的响应超时时间,则认为该URL为异常URL。在监控周期内,设备会对异常URL的次数进行统计。若异常URL的次数超过本命令配置的上限阈值,则自动关闭实服务器。
# 在HTTP passive类型的负载均衡探测模板下,配置异常URL次数的上限阈值为20。
[Sysname] loadbalance probe-template http-passive tplt
[Sysname-lbpt-http-passive-tplt] abnormal-url threshold 20
·     status-code
·     timeout
·     check-url
1.1.2  activate
activate命令用来配置实服务组的可用条件。
undo activate命令用来恢复缺省情况。
activate lower lower-percentage upper upper-percentage
undo activate
实服务组中只要有一个实服务器可用,该实服务组就被认为可用。
实服务组视图
context-admin
vsys-admin
lower lower-percentage:最小可用百分比,取值范围为1~99。当主用实服务组中可用的实服务器数量占实服务器总数量的百分比低于此值时,该实服务组将被认为不可用,从而切换到备用实服务组。
upper upper-percentage:最大可用百分比,取值范围为1~99,且必须大于等于最小可用百分比。当主用实服务组中可用的实服务器数量占实服务器总数量的百分比高于此值时,将从备用实服务组切换回主用实服务组。
当虚服务器上未配置备用实服务组时,本配置无效。
# 配置实服务组sf的最小可用百分比为20,最大可用百分比为80。
[Sysname] server-farm sf
[Sysname-sfarm-sf] activate lower 20 upper 80
·     default server-farm
all-service-down action forward命令用来配置查找所有可用实服务组成员失败时,将流量转发给最近一次选中的实服务组成员。
undo all-service-down action forward命令用来恢复缺省情况。
查找所有可用实服务组成员失败时丢弃报文。
实服务组视图
context-admin
工作机制
若未配置本命令,当实服务组中所有实服务组成员均不可用,负载均衡设备会直接丢弃报文。若配置了本命令,当所有实服务组成员均不可用时,不会直接丢弃报文,而是将报文继续转发至最近一次选中的实服务组成员。
注意事项
仅当实服务组被工作在七层的TCP类型虚服务器引用时,本命令才能生效。
# 配置查找所有可用实服务组成员失败时,将流量转发给最近一次选中的实服务组成员。
[Sysname-sfarm-sf] all-service-down action forward
application-mode enable命令用来配置TCP类型的虚服务器工作在七层。
undo application-mode enable命令用来恢复缺省情况。
TCP类型的虚服务器工作在四层。
TCP类型的虚服务器视图
context-admin
vsys-admin
如果TCP类型的虚服务器配置了工作在七层模式,则必须为虚服务器配置非0端口号,否则该模式不生效。
TCP类型的虚服务器工作在七层时,端口不允许配置超过200个。
# 在TCP类型的虚服务器视图下,配置TCP类型的虚服务器工作在七层。
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] application-mode enable
1.1.5  argument
argument命令用来配置自定义监控的用户自定义信息。
undo argument命令用来恢复缺省情况。
argument text
undo argument
未配置自定义监控的用户自定义信息。
自定义监控类型的负载均衡探测模板视图
context-admin
text:用户自定义信息,为1~255个字符的字符串,区分大小写,允许存在空格,不支持使用”号。
非缺省vSystem不支持本命令。
在执行自定义监控脚本文件时,设备进程会将通过本命令配置的用户自定义信息作为参数传递给脚本文件。
设备允许同时输入多个参数,参数之间用空格分隔。
# 在自定义类型的负载均衡探测模板test_external视图下,配置用户自定义信息为“abc 123 456”。
[Sysname] loadbalance probe-template external-monitor test_external
[Sysname-lbpt-external-monitor-test_external] argument abc 123 456
arp-nd interface命令用来指定发送免费ARP报文或者ND报文的接口。
undo arp-nd interface命令用来删除发送免费ARP报文或者ND报文的指定接口。
arp-nd interface interface-type interface-number
undo arp-nd interface interface-type interface-number
未指定发送免费ARP报文或者ND报文的接口,即所有接口均不能发送免费ARP报文或者ND报文。
SNAT地址池视图
context-admin
vsys-admin
interface-type interface-number:发送免费ARP报文或ND报文的接口类型和接口编号。
在同一SNAT地址池下,可以多次执行本命令,指定多个接口发送免费ARP报文或者ND报文。
若SNAT地址池中的IP地址与设备连接服务器端的接口IP地址在同一网段,则必须通过执行本命令指定发送免费ARP报文或ND报文的接口。否则,无需指定发送免费ARP报文或ND报文的接口。
# 在SNAT地址池lbsp中,指定发送免费ARP报文或ND报文的接口为GigabitEthernet1/0/1。
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] arp-nd interface gigabitethernet 1/0/1
arp-nd interface命令用来指定发送免费ARP报文或ND报文的接口。
undo arp-nd interface命令用来删除发送免费ARP报文或ND报文的指定接口。
虚服务器视图
context-admin
vsys-admin
在同一虚服务器下,可以多次执行本命令,指定多个接口发送免费ARP报文或者ND报文。
若虚服务器的IP地址与设备连接客户端的接口IP地址在同一网段,则必须进行以下配置:
·     配置虚服务器IP地址的IPv4掩码长度为32或IPv6前缀长度为128。
·     执行本命令指定发送免费ARP报文或ND报文的接口。
·     开启虚服务器IP地址发布功能。
反之,若虚服务器的IP地址与设备连接客户端的接口IP地址不在同一网段上,则无需进行上述设置。
# 在虚服务器vs3下,指定发送免费ARP报文或ND报文的接口为GigabitEthernet1/0/1。
<Sysname>system-view
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] arp-nd interface gigabitethernet 1/0/1
auto-shutdown recovery-time命令用来配置实服务器的智能监控自动恢复时间。
undo auto-shutdown recovery-time命令用来恢复缺省情况。
auto-shutdown recovery-time recovery-time
实服务组的智能监控自动恢复时间为0。
实服务组视图
context-admin
vsys-admin
recovery-time:实服务器自动恢复时间,取值范围为0~15300,单位分钟。0表示实服务器不能自动恢复。
应用场景
若用户希望实服务器在被智能监控关闭后还可以自动恢复,则需要通过本命令配置恢复时间。
工作机制
若没有配置健康检测,实服务器恢复后的状态置为Unknown状态。
若配置了健康检测且健康检测成功,实服务器恢复后的状态置为Active状态,如果健康检测失败,则置为Probe-failed状态。
# 配置实服务组sf的智能监控自动恢复时间为5分钟。
[Sysname-sfarm-sf] auto-shutdown recovery-time 5
1.1.9  busy-action
busy-action命令用来配置实服务组的繁忙处理方式。
undo busy-action命令用来恢复缺省情况。
busy-action { drop | enqueue length length timeout timeout-value | force }
undo busy-action
实服务组的繁忙处理方式为调度失败。
实服务组视图
context-admin
vsys-admin
drop:繁忙处理方式为调度失败,即设备停止向当前实服务组分发流量。
enqueue:繁忙处理方式为排队等待,即将新的请求报文加入等待队列。
length length:队列长度,取值范围为1~100000。当等待队列的长度超过配置的队列长度时,后续的请求报文被丢弃。
timeout timeout-value:队列老化时间,取值范围为1~60,单位为秒。
force:繁忙处理方式为强制调度,即所有实服务器均参与调度。
当繁忙处理方式为调度失败且实服务器组处于繁忙状态时,若配置负载均衡策略允许继续匹配下一条规则,则继续匹配下一条匹配规则,否则直接丢弃请求报文。
排队等待繁忙处理方式仅适用于七层虚服务器,对四层虚服务器不生效。
# 配置实服务组sf的繁忙处理方式为强制调度。
[Sysname-sfarm-sf] busy-action force
capability-exchange timeout命令用来配置Diameter协商超时时间。
undo capability-exchange timeout命令用来恢复缺省情况。
capability-exchange timeout timeout-value
Diameter协商超时时间为10秒。
Diameter-session类型参数模板视图
context-admin
vsys-admin
timeout-value:与对端协商超时时间,取值范围为1~4294967295,单位为秒,缺省值为10。
当设备与客户端或服务器端建立TCP连接后,首先会通过CER请求报文和CEA应答报文进行信息交换。如果在设置的Diameter协商超时时间到期时,设备和对端一直没有CER和CEA报文交互,设备将认为该TCP连接已失效,并直接断开该连接,从而避免系统资源被持续占用而造成的浪费。
# 在Diameter-session类型的参数模板dia下,配置Diameter协商超时时间为15秒。
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] capability-exchange timeout 15
·     parameter-profile
case-insensitive命令用来配置匹配字符串时对大小写不敏感。
undo case-insensitive命令用来恢复缺省情况。
case-insensitive
匹配字符串时对大小写敏感。
HTTP类型的参数模板视图
context-admin
vsys-admin
本命令将影响以下内容:
·     对于类匹配,影响HTTP首部的取值、HTTP Cookie的名称和取值、URL。
·     对于HTTP首部持续性方法,影响首部的取值、URL以及用于生成持续性表项的Key值。
·     对于Cookie截取持续性方法,影响Cookie的名称和取值的匹配以及用于生成持续性表项的Key值。
# 在HTTP类型的参数模板pp1中,配置匹配字符串时对大小写不敏感。
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] case-insensitive
check all-packet命令用来配置检查所有报文。
undo check all-packet命令用来恢复缺省情况。
check all-packet
不检查所有报文。
HTTP Cookie类型的持续性组视图
HTTP passive类型的持续性组视图
context-admin
vsys-admin
当持续性方法为Cookie截取时,本命令用来配置是否从所有HTTP应答报文中截取Cookie。如果未配置本命令,则在一次连接中只从首个应答报文中截取一次Set-Cookie信息,后续应答报文不再截取。
当持续性方法为Cookie重写时,本命令用来配置是否在所有HTTP应答报文中重写Cookie。如果未配置本命令,则在一次连接中只在首个应答报文中重写Set-Cookie信息,后续应答报文不再重写。
当持续性方法为Cookie插入时,本命令用来配置是否向所有HTTP应答报文中插入Cookie。如果未配置本命令,则在一次连接中只向首个应答报文中插入Set-Cookie信息,后续应答报文不再插入。
当持续性方法为HTTP passive时,本命令用来配置是否从所有HTTP应答报文生成持续性表项。如果未配置本命令,则在一次连接中只从首个应答报文生成持续性表项,后续应答报文不再生成持续性表项。
# 在HTTP Cookie类型的持续性组sg3中,配置检查所有报文。
[Sysname] sticky-group sg3 type http-cookie
[Sysname-sticky-http-cookie-sg3] check all-packet
1.1.13  check-url
check-url命令用来配置HTTP passive类型探测模板所要检查的URL。
undo check-url命令用来取消对指定URL进行HTTP被动健康检测。
check-url url
undo check-url url
未配置HTTP passive类型探测模板所要检查的URL。
context-admin
vsys-admin
url:需要检查的URL的正则表达式,为1~255个字符的字符串,不区分大小写,不支持正则元字符?。
工作机制
若实服务器收到的HTTP请求报文中携带本命令指定的URL,则对其响应报文进行HTTP被动健康检测。
注意事项
同一HTTP passive类型的负载均衡探测模板视图下,最多允许配置10个URL的正则表达式。
# 在HTTP passive类型的负载均衡探测模板下,配置HTTP被动健康检测所要检查的URL为www.example.com。
[Sysname-lbpt-http-passive-tplt] check-url www.example.com
1.1.14  class
class命令用来负载均衡类对应的负载均衡动作。
undo class命令用来删除指定的负载均衡类。
class class-name [ insert-before before-class-name | insert-after [ after-class-name ] ] action action-name
undo class class-name
未指定负载均衡类对应的负载均衡动作。
负载均衡策略视图
context-admin
vsys-admin
class-name:负载均衡类的名称,为1~255个字符的字符串,不区分大小写。
insert-before:表示插入到指定的负载均衡类之前(该负载均衡类必须已被当前负载均衡策略引用)。
before-class-name:表示用于参照的负载均衡类名称,为1~255个字符的字符串,不区分大小写。
insert-after:表示插入到指定的负载均衡类之后(该负载均衡类必须已被当前负载均衡策略引用)。
after-class-name:表示用于参照的负载均衡类名称,为1~255个字符的字符串,不区分大小写。若未配置本参数,则表示插入到所有负载均衡类之前。
action-name:负载均衡动作的名称,为1~255个字符的字符串,不区分大小写。
工作机制
通过本命令可以为匹配特定负载均衡类的报文指定其执行的负载均衡动作。
配置本命令时,若未指定insert-before和insert-after,则表示将新增负载均衡类插入到所有负载均衡类之后。
不同的负载均衡类可以与同一负载均衡动作组成匹配规则。
用户可以在一个负载均衡策略中指定多个负载均衡类,转发报文时会按照配置顺序来匹配负载均衡类,匹配成功则执行相应的负载均衡动作,不会继续匹配下一条负载均衡类,否则继续匹配下一条负载均衡类。因此,当负载均衡类之间存在包含关系时,建议将更精细的负载均衡类放在前面,宽泛的负载均衡类放在后面。如果所有负载均衡类均未匹配,则执行缺省负载均衡动作。
注意事项
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作;通用类型的负载均衡策略只能引用通用类型的负载均衡类和负载均衡动作;HTTP类型的负载均衡策略则无此限制。
# 服务器负载均衡场景下,在通用类型的负载均衡策略lbp1中,为负载均衡类lbc1指定负载均衡动作为lba1,并将lbc1插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1] class lbc1 insert-before lbc0 action lba1
# 出方向链路负载均衡场景下,在链路类型的负载均衡策略lbp2中,为负载均衡类lbc2指定负载均衡动作为lba2,并将lbc1插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp2 type link-generic
[Sysname-lbp-link-generic-lbp2] class lbc2 insert-before lbc0 action lba2
# DNS透明代理场景下,在DNS类型的负载均衡策略lbp3中,为负载均衡类lbc3指定负载均衡动作为lba3,并将lbc1插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp3 type dns
[Sysname-lbp-dns-lbp3] class lbc3 insert-before lbc0 action lba3
close-connection enable命令用来开启主动关闭设备与两侧连接功能。
undo close-connection enable命令用来关闭主动关闭设备与两侧连接功能。
主动关闭设备与两侧连接功能处于关闭状态。
HTTP类型参数模板
context-admin
vsys-admin
工作机制
开启主动关闭两侧连接功能后,当设备接收到HTTP请求或应答报文,其头部携带connection:close字段时(对于HTTP1.0协议的报文,只要头部未携带connection:keep-alive字段,则默认认为是携带了connection:close字段),设备将在完成应答发送后,主动发送FIN报文,分别断开与客户端侧以及与服务器侧的连接。
注意事项
当本功能和设备与服务器的连接复用功能同时启用时,本功能仅对设备与客户端侧的连接生效,设备与服务器侧的连接不受影响,仍会保持连接复用。
# 在HTTP类型的参数模板视图下,开启HTTP主动关闭两侧连接功能。
[Sysname] parameter-profile p1 type http
[Sysname-para-http-p1] close-connection enable
·     display parameter-profile
·     server-connection reuse
compression level命令用来设置应答报文的压缩级别。
undo compression level命令用来恢复缺省情况。
compression level level
应答报文的压缩级别为1。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
level:压缩级别,取值范围为1~9,数值越大表示压缩速度越慢、压缩比越高。
# 创建HTTP压缩类型的参数模板pa1,并配置压缩等级为6。
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] compression level 6
concurrent-streams-per-connection命令用来配置一条TCP连接的最大并发请求。
undo concurrent-streams-per-connection命令用来恢复缺省情况。
concurrent-streams-per-connection connection-number
一条TCP连接的最大并发请求为10。
HTTP2.0类型的参数模板视图
context-admin
vsys-admin
connection-number:一条TCP连接的并发请求数,取值范围为1~256。
实现机制
HTTP2.0协议支持在同一TCP连接上并发处理和响应多个HTTP2.0请求。本命令用来配置一条TCP连接所支持的最大并发请求数,当请求数到达上限后,就会断开HTTP2.0的TCP连接。如果配置的最大并发请求数过大,可能会导致客户端或服务器的头部表项积累过大,占用大量内存,影响客户端或服务器并发处理能力;如果配置的最大并发请求数过小,可能出现建立多次TCP连接传输报文,从而降低报文传输效率的情况。管理员可根据实际网络情况,合理配置HTTP2.0连接的并发请求数。
注意事项
本命令仅对HTTP2.0协议版本的请求报文生效。
多次执行本命令,最后一次执行的命令生效。
# 创建HTTP2.0类型的参数模板p1,配置一条TCP连接的最大并发请求为128。
[Sysname] parameter-profile p1 type http2
[Sysname-para-http2-p1] concurrent-streams-per-connection 128
·     header-table size
connection close命令用来配置关闭设备与实服务器TCP连接的方式。
undo connection close命令用来恢复缺省情况。
connection close { fin | rst }
关闭与实服务器的TCP连接方式为RST。
HTTP2.0类型的参数模板视图
context-admin
vsys-admin
fin:表示发送FIN报文方式关闭连接。
rst:表示发送RST报文方式关闭连接。
使用场景
当设备收到客户端发起的多条HTTP2.0版本的并发请求报文,由于设备和服务器仅支持HTTP1.1协议,设备需要与多个实服务器分别建立TCP连接并转发请求报文。
管理员可通过配置本命令,使实服务器每处理完一条请求报文后,便以指定方式断开与设备的TCP连接,从而避免实服务器长时间被占用。
注意事项
本命令只针对客户端发起HTTP2.0协议版本的请求报文,而设备与实服务器仅支持HTTP1.1协议的情况下生效。
# 创建HTTP2类型的参数模板p1,配置通过发送FIN报文方式关闭设备与实服务器TCP连接。
[Sysname-para-http2-p1] connection close fin
connection idle-timeout命令用来配置HTTP2.0请求报文TCP连接的空闲超时时间。
undo connection idle-timeout命令用来恢复缺省情况。
connection idle-timeout timeout-value
TCP连接的空闲超时时间为300秒。
HTTP2.0类型的参数模板视图
context-admin
vsys-admin
timeout-value:TCP连接空闲超时时间,取值范围为0~4294967295,单位为秒。
实现机制
通过本命令可以自定义设备与客户端以及服务器建立的TCP连接的空闲超时时间。若在TCP连接的空闲超时时间内没有应用数据传输,设备会主动断开与客户端或服务器的TCP连接。
注意事项
# 创建HTTP2.0类型的参数模板p1,配置TCP连接空闲超时时间为60s。
[Sysname-para-http2-p1] connection idle-timeout 60
connection-limit max命令用来配置实服务器所允许的最大连接数。
undo connection-limit max命令用来恢复缺省情况。
connection-limit max max-number
实服务器所允许的最大连接数为0,即不受限制。
实服务器视图
context-admin
vsys-admin
max-number:最大连接数,取值范围为0~4294967295,0表示实服务器所允许的最大连接数不受限制。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置实服务器rs所允许的最大连接数为10000。
[Sysname] real-server rs
[Sysname-rserver-rs] connection-limit max 10000
connection-limit max 命令用来配置实服务器组成员所允许的最大连接数。
undo connection-limit max 命令用来恢复缺省情况。
实服务器组成员所允许的最大连接数不受限制。
实服务器组成员视图
context-admin
vsys-admin
max-number:最大连接数,取值范围为0~4294967295,0表示实服务器组成员所允许的最大连接数不受限制。
# 配置实服务组成员rs1所允许的最大连接数为10000。
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname -sfarm-sf-#member#-rs1-port-80] connection-limit max 10000
connection-limit max 命令用来配置虚服务器所允许的最大连接数。
虚服务器所允许的最大连接数为0,即不受限制。
虚服务器视图
context-admin
vsys-admin
max-number:最大连接数,取值范围为0~4294967295,0表示虚服务器所允许的最大连接数不受限制。
# 配置IP类型的虚服务器vs3所允许的最大连接数为10000。
[Sysname-vs-ip-vs3] connection-limit max 10000
# 出方向链路负载均衡场景下,配置LINK-IP类型的虚服务器vs2所允许的最大连接数为10000。
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] connection-limit max 10000
connection-sync enable命令用来开启虚服务器的会话扩展信息备份功能。
undo connection-sync enable命令用来关闭虚服务器的会话扩展信息备份功能。
虚服务器的会话扩展信息备份功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
HTTP类型的虚服务器不支持本命令。
# 开启IP类型的虚服务器vs3的会话扩展信息备份功能。
[Sysname-vs-ip-vs3] connection-sync enable
# 在出方向链路负载均衡场景下,开启LINK-IP类型的虚服务器vs2的会话扩展信息备份功能。
[Sysname-vs-link-ip-vs2] connection-sync enable
content命令用来配置HTTP实体持续性方法。
undo content命令用来删除HTTP实体持续性方法。
content [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo content
不存在任何持续性方法。
HTTP实体类型的持续性组视图
context-admin
vsys-admin
offset offset:HTTP请求报文实体起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:实体开始标记的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,区分大小写,不支持正则元字符?。
end end-string:实体结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持正则元字符?。
length length:实体的长度,取值范围为0~1000,缺省值为0,单位为字节,表示所有长度。
工作机制
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP实体信息。start-string和end-string将不计入持续性表项信息中。
HTTP实体持续性只能对实体内的所有内容进行持续性处理,对于chunk及multipart形式的实体内容,HTTP实体持续性不能根据具体内容进行明确的持续性处理。
注意事项
快速HTTP类型的虚服务器不支持引用HTTP实体持续性方法。
# 在HTTP实体类型的持续性组sg2中,配置HTTP实体持续性方法为:从HTTP请求报文实体起始位置的第30个字节起,以abc为开始、长度为20个字节的HTTP实体来生成持续性表项。
[Sysname] sticky-group sg2 type http-content
[Sysname-sticky-http-content-sg2] content offset 30 start abc length 20
content命令用来配置HTTP实体被动持续性方法。
undo content命令用来删除HTTP实体被动持续性方法。
content { get | match } id start start-string { end end-string | length length }
undo content { get | match } id
未配置HTTP实体被动持续性方法。
context-admin
vsys-admin
get:表示获取HTTP应答报文实体中的指定字符串,用来生成HTTP实体被动持续性表项。
match:表示获取HTTP请求报文实体中的指定字符串,用来匹配HTTP实体被动持续性表项,
start start-string:HTTP实体开始标记的正则表达式,为1~127字符的字符串,区分大小写,不支持字符?。
end end-string:HTTP实体结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持字符?。
length length:HTTP实体的长度,取值范围为0~1000,缺省值为0,单位为字节,表示所有长度。
content get和content match命令获取的字符串内容不包含start-string和end-string。
HTTP实体被动持续性方法需要content get和content match命令的配合才能生成。
当设备收到HTTP请求报文后,根据content match命令的配置获取HTTP请求报文实体中的指定字符串。若该字符串匹配上由content get命令获取到的HTTP应答报文实体中的指定字符串,则根据HTTP应答报文实体中的指定字符串生成持续性表项。对于后续收到的HTTP请求报文,若匹配上持续性表项,则按照持续性表项转发。
content get和content match命令的配置遵循以下原则:
同一HTTP passive类型的持续性组视图下,最多允许通过配置4条content get命令在HTTP应答报文实体中获取4个指定字符串,最多允许通过配置4条content match命令在HTTP请求报文实体中获取4个指定字符串。
n条content get命令获取到的n个字符串,其中任意1~n个字符串又可以按照ID顺序组合成2n-1个字符串,若content match命令获取到字符串匹配上任意一个组合后的字符串,则认为匹配成功。
n条content match命令获取到的n个字符串按照ID顺序结合成一个字符串进行匹配。
假设,用户配置了ID为1、2、3的三条content get命令,使得设备可以获取到HTTP应答报文实体中的字符串a、b、c,组合成七个匹配字符串a、b、c、ab、ac、bc、abc。并生成七条持续性表项。同时用户配置了ID为2、3、4的三条content match命令。当设备收到HTTP请求报文后,若基于这三条规则获取到了字符串a、b、c,且它们组合成的字符串abc能够与通过content get命令获取到的字符串abc匹配成功,则认为HTTP请求报文与持续性表项匹配成功,按照持续性表项转发。
# 在HTTP passive类型的持续性组sg2中,配置获取HTTP请求报文实体中从字符串“abc”后开始、长度为20个字节的HTTP实体。若该字符串匹配上HTTP应答报文实体中从字符串“xxx”后开始、长度为20个字节的HTTP实体,则根据HTTP应答报文实体中的字符串生成持续性表项。
[Sysname] sticky-group sg2 type http-passive
[Sysname-sticky-http-passive-sg2] content get 1 start abclength 20
[Sysname-sticky-http-passive-sg2] content match 1 start xxx length 20
·     display sticky-group
·     header (HTTP passive sticky-group view)
content length-threshold命令用来设置进行压缩的应答报文体最小长度。
undo content length-threshold命令用来恢复缺省情况。
content length-threshold length
压缩的应答报文的报文体最小长度为1024字节。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
length:报文体长度值,取值范围为0~4294967295,单位为字节。
如果应答报文中携带Content-Length首部,则报文体的长度必须达到配置的最小长度才会进行压缩,否则不进行压缩。如果应答报文中不携带Content-Length首部,此配置不生效,即无论报文多大都会进行压缩。
# 创建HTTP压缩类型的参数模板http1,并设置进行压缩的应答报文体最小长度为2000字节。
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] content length-threshold 2000
content maxparse-length命令用来配置HTTP实体的最大解析长度。
undo content maxparse-length命令用来恢复缺省情况。
content maxparse-length length
HTTP实体的最大解析长度为4096。
HTTP类型的参数模板视图
context-admin
vsys-admin
length:HTTP实体的最大解析长度,取值范围为1~65535,单位为字节。
快速HTTP类型的虚服务器不支持本功能。
# 在HTTP类型的参数模板pp1中,配置HTTP实体的最大解析长度为8192。
[Sysname-para-http-pp1] content maxparse-length 8192
content request-max-length命令用来配置允许通过的请求报文实体的最大长度。
undo content request-max-length命令用来恢复缺省情况。
content request-max-length length
允许通过的请求报文实体的最大长度不受限制。
HTTP类型的参数模板视图
context-admin
vsys-admin
length:HTTP请求报文实体的最大长度,取值范围为1~4294967295,单位为字节。
若HTTP请求报文实体的长度超出配置的最大长度,设备会丢弃报文。
# 在HTTP类型的参数模板h1中,配置请求报文实体的最大长度为1000字节。
[Sysname] parameter h1 type http
[Sysname-para-http-h1] content request-max-length 1000
content rewrite命令用来设置对HTTP应答报文体中的指定内容进行替换。
undo content rewrite命令用来恢复缺省情况。
content rewrite value value replace replace-string
不替换HTTP应答报文体中指定内容。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
value value:要被替换的HTTP报文体的内容,为1~127个字符的字符串,区分大小写,不支持字符?。
replace replace-string:替换后的内容,为1~127个字符的字符串,区分大小写。
此配置只对HTTP应答报文格式是text/* 的报文进行替换修改。
若执行替换操作时,达到了以下长度限制,则替换操作不生效:
·     当使用正则表达式匹配时,待匹配的报文内容长度超过4096字节。
·     替换后的内容长度超过4096字节。
替换的内容串支持配置%[1-9],表示按照value中匹配上的内容替换成%[1-9]中对应()中的内容。例如:执行命令content rewrite value (Wel)(co)(me) replace %2操作后,将把Welcome字符串替换为第2个括号"(co)"中的内容。
# 在HTTP类型的负载均衡动作replace中,将HTTP应答报文体中的内容2000::1替换为2.3.4.5。
[Sysname] loadbalance action replace type http
[Sysname- lba-http-replace] content rewrite value 2000::1 replace 2.3.4.5
cookie命令用来配置基于Cookie的防护阈值。
undo cookie命令用来恢复缺省情况。
cookie cookie-name request-threshold threshold
undo cookie
未配置基于Cookie的防护阈值。
防护规则视图
context-admin
vsys-admin
cookie-name:HTTP报文的Cookie名称,为1~63个字符的字符串,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
request-threshold threshold:请求报文数阈值,取值范围为1~4294967295。
在统计周期内,若同一用户访问指定URL的次数超过请求报文数阈值,则执行防护动作。设备支持基于以下两种特征来判断请求报文是否来自同一用户:
·     基于Cookie:若请求报文中对应于指定Cookie名称的Cookie值相同,则认为请求报文来自同一用户。Cookie名称由本命令指定。
·     基于源IP地址:若请求报文的源IP地址相同,则认为请求报文来自同一用户。
若同时配置基于Cookie的防护阈值和基于源IP地址的防护阈值,则当携带相同Cookie值或者相同源IP的报文达到配置的阈值时,执行相应的动作。
在同一防护规则视图下,多次执行本命令,最后一次执行的命令生效。
# 在编号为5的防护规则视图下,配置基于Cookie的防护阈值。指定HTTP报文的Cookie名称为jsessionid,请求报文数阈值为2。
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] cookie jsessionid request-threshold 2
·     protected-url
·     protection-action
·     protection-period
·     source-ip
cookie命令用来配置HTTP Cookie持续性方法。
cookie { get name cookie-name [ offset offset ] [ start start-string] [ end end-string | length length ] | { insert [ name cookie-name ] [ domain domain-name ] [ path path ] [ httponly ] [ secure ] | rewrite [ name cookie-name ] [ httponly ] [ secure ] }
undo cookie { get | insert | rewrite }
未配置任何HTTP Cookie持续性方法。
context-admin
vsys-admin
get:表示持续性方法为Cookie截取,即在服务器发送的HTTP应答报文中截取Set-Cookie字段用于持续性处理。
cookie-name:HTTP Cookie的名称,为1~63个字符的字符串,区分大小写。
offset offset:Cookie基于Cookie值起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:Cookie开始标记的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,区分大小写,不支持正则元字符?。
end end-string:Cookie结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持正则元字符?。
length length:Cookie的长度,取值范围为0~1000,缺省值为0,单位为字节。
insert:表示持续性方法为Cookie插入,即在服务器发送的HTTP应答报文中插入Set-Cookie字段用于持续性处理。
rewrite:表示持续性方法为Cookie重写,即改写服务器发送的HTTP应答报文所携带的Set-Cookie字段用于持续性处理。
name cookie-name:HTTP Cookie的名称,为1~63个字符的字符串,区分大小写,缺省值为X-LB。
domain domain-name:Cookie作用域域名,为1~255个字符的字符串,区分大小写,若未指定本参数,则表示Cookie作用域域名为创建Cookie的域名。
path path:Cookie作用路径,为1~255个字符的字符串,区分大小写,若未指定本参数,则表示Cookie作用路径为根目录“/”。
httponly:HTTPOnly属性。表示指定的Cookie不允许通过客户端脚本访问。若未配置本参数,则表示可以通过客户端脚本访问Cookie。
secure:安全属性。表示指定的Cookie只允许通过HTTPS连接进行传递。若未指定本参数,则表示所有连接都允许传递Cookie。
cookie get命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP Cookie信息。start-string和end-string将不计入持续性表项信息中。
当持续性方法为Cookie重写时,需要与HTTP服务器配合,即服务器发送的HTTP应答报文中应携带指定名称Cookie的Set-Cookie首部信息;此外,系统仅修改Set-Cookie中Cookie的值,不会修改其它属性(如Expires等)。
当持续性方法为Cookie插入或Cookie重写时,所配置的持续性老化时间不为会话老化(持续性表项的超时时间为0时),会在对应插入或重写的Value值后加入Expires字段。如果服务器发送的HTTP应答报文也携带此属性,负载均衡模块不会修改服务器所携带的该属性,而是在Value值后新增用户配置的Expires信息。因此在与服务器配合设置Cookie重写持续性方法时,建议服务器对于被负载均衡模块重写的Set-Cookie首部不要携带任何表征超时的属性。
Cookie作用域域名属性用来指定Cookie会被发送到的主机范围。例如,客户端可以访问域名example.com,www.example.com和www.corp.example.com的主机。如果配置Cookie作用域域名为“example.com”,客户端会在向域名为example.com,www.example.com和www.corp.example.com的主机发送的HTTP请求中携带Cookie信息。如果配置Cookie作用域域名为“www.corp.example.com”,客户端仅会在向域名为www.corp.example.com的主机发送的HTTP请求中携带Cookie信息。
Cookie作用路径属性用来限制Cookie的适用范围。例如。客户端可以访问主机的文件夹www.example.com/a和www.example.com/b。如果配置Cookie作用域域名为www.example.com,Cookie的作用路径为/a,客户端会在向www.example.com/a发送的HTTP请求中携带Cookie信息,而不会在向www.example.com/b发送的HTTP请求中携带Cookie信息,
HttpOnly属性用来指定Cookie是否可通过客户端脚本访问。若会话Cookie缺少HTTPOnly属性攻击者可以通过程序(例如JS脚本)等获取到用户的Cookie信息,造成用户Cookie信息泄露。
安全属性标识Cookie会被以安全的形式向服务器传输,也就是说Cookie只能在HTTPS连接中被浏览器传递到服务器端进行会话验证,如果是HTTP连接则不会传递Cookie信息。
# 在HTTP Cookie类型的持续性组sg3中,配置持续性方法为Cookie截取,即:截取从HTTP报文起始位置的第10个字节起,长度为32个字节的名为user的HTTP Cookie来生成持续性表项。
[Sysname-sticky-http-cookie-sg3] cookie get name user offset 10 length 32
# 在HTTP Cookie类型的持续性组sg3中,配置持续性方法为Cookie插入。
[Sysname-sticky-http-cookie-sg3] cookie insert
cookie secondary name命令用来指定需在URI中查找的Secondary Cookie名称。
undo cookie secondary name命令用来恢复缺省情况。
cookie secondary name value
未指定需在URI中查找的Secondary Cookie名称。
context-admin
vsys-admin
value:Secondary Cookie的名称,为1~63个Token字符,区分大小写,不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码小于或等于31,大于或等于127的字符。
本命令只对Cookie截取持续性方法生效。当配置了Cookie截取持续性方法时,如果也配置了本命令,此时系统如果未能在HTTP请求报文首部找到指定名称的Cookie,便会查找出现在URI中的Secondary Cookie。
# 在HTTP Cookie类型的持续性组sg3中,指定需在URI中查找的Secondary Cookie名称为sid。
[Sysname-sticky-http-cookie-sg3] cookie secondary name sid
customlog content命令用来配置快速日志输出的内容。
undo customlog content命令用来恢复缺省情况。
customlog content content-value
无快速日志输出。
IP/TCP/UDP/HTTP类型的虚服务器
context-admin
vsys-admin
content-value:指定快速日志输出内容,为1~3071个字符的字符串,当输入多个变量时,变量之间用分号分隔。
·     IP、TCP和UDP类型的虚服务器视图下支持配置以下变量:
¡     %{is}:客户端侧的源IP地址。
¡     %{ps}:客户端侧的源端口号。
¡     %{id}:客户端侧的目的IP地址。
¡     %{pd}:客户端侧的目的端口号。
¡     %{sis}:服务端侧的源IP地址。
¡     %{sps}:服务端侧的源端口号。
¡     %{sid}:服务端侧的目的IP地址。
¡     %{spd}:服务端侧的目的端口号。
¡     %{vsn}:虚服务器的名称。
¡     %{sfn}:实服务组的名称。
¡     %{protocol}:流量的协议类型。
¡     %{tmfirst}:当前流首包时间,采用GMT时间格式。
¡     %{tmlast}:当前流尾包时间,采用GMT时间格式。
¡     %{tmduration}:当前流持续时间(首包到尾包之间的时间)。
¡     %{cbytes_recv}:从客户端接收的总数据大小(统计整个会话)。
¡     %{cbytes_sent}:向客户端发送的总数据大小(统计整个会话)。
¡     %{sbytes_recv}:从服务端接收的总数据大小(统计整个会话)。
¡     %{sbytes_sent}:向服务端发送的总数据大小(统计整个会话)。
·     HTTP类型的虚服务器视图下支持配置以下变量(变量未找到或未实现,快速日志中显示为短横线“-”):
¡     %{is}:客户端侧的源IP地址。
¡     %{ps}:客户端侧的源端口号。
¡     %{pd}:客户端侧的目的端口号。
¡     %{sps}:服务端侧的源端口号。
¡     %{vsn}:虚服务器的名称。
¡     %{sfn}:实服务组的名称。
¡     %{reqtmstamp}:HTTP访问请求时间,采用GMT时间格式。
¡     %{reqtime}:HTTP访问请求时间,采用CST时区时间格式。
¡     %{uri}:HTTP URI。
¡     %{ver}:HTTP协议的版本号。
¡     %{args}:HTTP访问参数。
¡     %{method}:HTTP请求方法。
¡     %{xff}:XFF(X-Forwarded-For)的IP地址。
¡     %{ctype}:HTTP请求报文Content-Type字段。
¡     %{clen}:HTTP请求报文的Content-Length字段。
¡     %{ref}:HTTP请求报文的Referer首部字段。
¡     %{ua}:HTTP请求报文的User-Agent字段。
¡     %{host}:HTTP请求报文Host首部字段。
¡     %{path}:HTTP请求报文的Path。
¡     %{reqsz}:HTTP请求报文的大小,单位为字节。
¡     %{reqtm}:HTTP访问的请求时长,单位为毫秒,从设备收到客户端请求报文开始计时,收到服务器端响应报文计时结束。
¡     %{reqtm_s}:HTTP访问的请求时长,单位为秒,从设备收到客户端请求报文开始计时,收到服务器端响应报文计时结束。
¡     %{conntm_s}:HTTP访问的连接时长,单位为秒,从设备与客户端建立连接开始计时,发送完响应报文计时结束。
¡     %{repstatus}:HTTP应答报文状态码。
¡     %{rspclen}:HTTP响应报文Content-Length字段。
¡     %{rspsz}:HTTP响应报文的大小,单位为字节。
¡     %{rsptm}:HTTP访问响应时长,单位为毫秒,从设备收到服务器端响应报文开始计时,发送完响应报文计时结束。
¡     %{stscode}:HTTP响应状态码。
¡     %{reqbsz}:HTTP请求报文的Body大小,单位为字节。
¡     %{rspbsz}:服务器应答设备的HTTP响应报文的Body大小,单位为字节。
¡     %{rspsntbsz}:设备应答客户端的HTTP响应报文的Body大小,单位为字节。
¡     %{rspctype}:HTTP响应报文Content-Type字段。
¡     %{x509v}:证书版本。
¡     %{x509sigalgo}:证书算法。
¡     %{x509issuer}:证书颁发者。
¡     %{x509before}:在此之前无效。
¡     %{x509after}:在此之后无效。
¡     %{x509sub}:主题。
¡     %{dnc}:国家。
¡     %{dns}:州、省。
¡     %{dnl}:城市。
¡     %{dno}:公司。
¡     %{dncn}:通用名Common Name。
¡     %{cookie_cookie-name}:HTTP访问的Cookie,cookie-name表示Cookie名称,如%{cookie_cookie1}。Cookie名称中不能包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符,区分大小写。设备允许配置多个不同名称的Cookie。
¡     %{reqhdr_header-name}:HTTP请求报文的自定义头部名称,如%{reqhdr_Host}。头部名称中不能包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符,不区分大小写。设备允许配置多个头部名称,如%{reqhdr_Host};%{reqhdr_Connection}。
¡     %{rsphdr_header-name}:HTTP应答报文的自定义头部名称,如%{rsphdr_Content-Length}。头部名称中不能包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符,不区分大小写。设备允许配置多个头部名称,如%{rsphdr_Host};%{rsphdr_Connection}。
¡     %{reqbody_content-type_size}:HTTP请求报文的Body信息。
Body信息支持定制不同的Content-type和最大长度size。size取值范围为1~131072,单位为字节,若未指定size,则表示默认最大长度为512字节。当报文实际Body长度超过size配置的最大长度,则只截取size大小的Body信息输出日志。例如,实际报文的Body大小是1024个字节,配置%{reqbody_content-type_512};%{reqbody_content-type_2048},那么最终输出为xxxxx(512个字节);yyyy(1024个字节)。
支持的报文标准头Content-Type以及对应命令行中的输入格式,包括如下:
表1-1 报文标准头Content-Type对应输入格式参考表
报文标准头Content-Type
命令行中输入格式
application/x-www-form-urlencoded
axwfu
application/json
ajson
application/cloudevents+json
acejson
application/cloudevents-batch+json
acebjson
application/yaml
ayaml
application/xml
axml
application/soap+xml
asxml
multipart/form-data
multiformdata
multipart/related
multirelated
text/plain
tplain
text/csv
tcsv
text/xml
txml
text/html
thtml
application/xhtml+xml
axhtmlxml
输入多个Content-Type时,使用“|”分隔,如:%{reqbody_axwfu|ajson|multirelated_512}。
¡     %{rspbody_content-type_size}:HTTP应答报文的Body信息。Body信息支持定制不同的Content-type和最大长度size。content-type和size配置情况与%{reqbody_content-type_size}参数相同,此处不再赘述。
工作机制
配置本命令后,设备将采用用户配置的格式将指定内容的日志信息发往日志主机。
注意事项
在配置本命令时,请确保通过快速日志输出功能v2配置了快速日志主机(customlog host v2)且已配置了负载均衡模块输出参数(module loadbalance);或者通过快速日志输出功能v1开启了负载均衡模块的快速日志输出功能(customlog format),并配置了快速日志输出参数(customlog host)。
# 在HTTP类型的虚服务器vs视图下,配置快速日志输出的内容包括客户端源IP地址和源端口号。
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] customlog content %{is};%{ps}
·     customlog format(网络管理与监控命令参考/快速日志输出)
·     customlog host(网络管理与监控命令参考/快速日志输出)
·     customlog host v2(网络管理与监控命令参考/快速日志输出)
·     module loadbalance(网络管理与监控命令参考/快速日志输出)
default server-farm命令用来指定缺省的实服务组。
undo default server-farm命令用来恢复缺省情况。
default server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name [ backup backup-sticky-name ] ]
未指定缺省的实服务组。
IP/TCP/UDP/HTTP/快速HTTP类型的虚服务器视图
context-admin
vsys-admin
server-farm-name:主用实服务组的名称,为1~255个字符的字符串,不区分大小写。
backup backup-server-farm-name:备用实服务组的名称,为1~255个字符的字符串,不区分大小写。
sticky sticky-name:主用持续性组的名称,为1~255个字符的字符串,不区分大小写。
backup backup-sticky-name:备用持续性组的名称,为1~255个字符的字符串,不区分大小写。仅HTTP和RADIUS类型的虚服务器支持配置本参数。
工作机制
当主用实服务组可用(该实服务组存在且有可用的实服务器)时,虚服务器通过主用实服务组进行转发;当主用实服务组不可用而备用实服务组可用时,虚服务器通过备用实服务组进行转发。
如果用户既配置了主用持续性组,也配置了备用持续性组,则会根据两个持续性组同时生成主用持续性表项和备用持续性表项。当有新的流量匹配已生成持续性表项时,如果未能匹配到主用持续性表项,则进行备用持续性表项匹配。
注意事项
若配置了备用持续性组,只有如下三种组合才会生成备用持续性表项,否则配置不生效:
·     主用持续性组为RADIUS类型,备用持续性组为地址端口类型;
·     主用持续性组为HTTP Cookie类型,备用持续性组为地址端口类型;
·     主用持续性组为HTTP Cookie类型,备用持续性组为HTTP passive类型。
# 为IP类型的虚服务器vs3指定缺省的主用实服务组为sf,备用实服务组为sfb,持续性组名称为sg1。
[Sysname-vs-ip-vs3] default server-farm sf backup sfb sticky sg1
default-class action命令用来配置缺省的负载均衡动作。
undo default-class命令用来恢复缺省情况。
default-class action action-name
undo default-class
未配置缺省的负载均衡动作。
负载均衡策略视图
context-admin
vsys-admin
工作机制
通过本命令可以为未匹配任何负载均衡类的报文指定其执行的缺省动作。
注意事项
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作作为其缺省负载均衡动作;通用类型的负载均衡策略只能用通用类型的负载均衡动作作为其缺省的负载均衡动作;HTTP类型的负载均衡策略则无此限制。
# 服务器负载均衡场景下,在通用类型的负载均衡策略lbp1中,配置缺省的负载均衡动作为lba1。
[Sysname-lbp-generic-lbp1] default-class action lba1
# 出方向链路负载均衡场景下,在链路类型的负载均衡策略lbp2中,配置缺省的负载均衡动作为lba2。
[Sysname-lbp-link-generic-lbp2] default-class action lba2
# DNS透明代理场景下,在DNS类型的负载均衡策略lbp3中,配置缺省的负载均衡动作为lba3。
[Sysname-lbp-dns-lbp3] default-class action lba3
1.1.36  description
description命令用来配置描述信息。
undo description命令用来恢复缺省情况。
未配置描述信息。
实服务器视图/实服务组成员视图/实服务组视图
虚服务器视图
负载均衡动作视图/负载均衡类视图/负载均衡策略视图
负载均衡探测模板视图
SNAT地址池视图/SNAT全局策略视图
参数模板视图/持续性组视图/负载均衡限制策略视图/防护策略视图
统计节点视图
链路视图/链路组成员视图/链路组视图
ISP视图
DNS服务器视图/DNS服务器池成员视图/DNS服务器池视图
context-admin
vsys-admin
text:描述信息,为1~127个字符的字符串,区分大小写。
# 配置通用类型的负载均衡动作lba1的描述信息为“LB action LBA1”。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] description LB action LBA1
destination-ip object-group命令用来配置进行SNAT地址转换的目的IP地址对象组。
undo destination-ip object-group命令用来恢复缺省情况。
destination-ip object-group object-group-name
对所有匹配虚服务器的流量都进行SNAT地址转换。
SNAT全局策略视图
context-admin
vsys-admin
object-group-name:IP地址对象组的名称,为1~63个字符的字符串,不区分大小写。
若在SNAT全局策略视图下,配置了进行SNAT地址转换的目的IP地址对象组,则仅对匹配指定目的IP地址的流量进行SNAT地址转换。有关IP地址对象组的配置请参见“安全配置指导”中的“对象组”。
# 在SNAT全局策略sn1视图下,配置进行SNAT地址转换的目的IP地址对象组为obj1。
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] destination-ip object-group obj1
·     object-group(安全命令参考/对象组)
diameter-attribute code命令用来配置Diameter属性持续性方法。
undo diameter-attribute命令用来删除Diameter属性持续性方法。
diameter-attribute { code attribute-code [ index index-value ] } &<1-4>
不存在Diameter属性持续性方法。
Diameter类型的持续性组视图
context-admin
vsys-admin
code attribute-code:指定Diameter属性类型的编号,取值范围为0~4294967295。
index index-value:指定Diameter属性在AVP序列中的索引值,取值范围为0~32。当AVP的数据类型为Grouped时,指定属性编号attribute-code后,需要通过指定该属性编号所在AVP序列的索引值。若不指定本参数,则AVP序列索引值为0,表示该Diameter属性在AVP序列中的索引不受限制。
&<1-4>:表示前面的参数最多可以输入4次。
工作机制
配置Diameter属性的持续性方法后,设备会根据请求报文中的指定属性,生成持续性表项。对于后续收到的所有Diameter类型请求报文,根据请求报文中的指定属性,若匹配上持续性表项,则按照持续性表项转发。一个持续性组中只能配置1条Diameter属性持续性方法。重复配置时,新的配置会覆盖原有配置。
常用的Diameter属性类型对应的编号包括:
·     编号为258表示Diameter属性类型为Auth-Application-Id。
·     编号为259表示Diameter属性类型为Acct-Application-Id。
·     编号为263表示Diameter属性类型为Session-Id。
·     编号为264表示Diameter属性类型为Origin-Host。
·     编号为283表示Diameter属性类型为Destination-Realm。
·     编号为293表示Diameter属性类型为Destination-Host。
·     编号为296表示Diameter属性类型为Origin-Realm。
·     编号为443表示Diameter属性类型为Subscription-Id。
·     编号为444表示Diameter属性类型为Subscription-Id-Data。
注意事项
Diameter属性的持续性方法仅对Diameter报文有效。
# 在持续性组s1中,配置Diameter属性类型为Session-Id的持续性方法。
[Sysname] sticky-group s1 type diameter
[Sysname-sticky-diameter-s1] diameter-attribute code 263
·     sticky-group
display loadbalance action命令用来显示负载均衡动作的信息。
display loadbalance action [ name action-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name action-name:显示指定负载均衡动作的信息。action-name为负载均衡动作的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡动作的信息。
# 显示所有负载均衡动作的信息。
<Sysname> display loadbalance action
LB action: lba1
  Description:
  Type: Generic
  State: Inactive
  Forward type: Drop
  IP ToS:
  Fallback-action: Disabled
  Busy-action: Force
  TCP payload rewrite:
    Value: QMGR.S01
    Replacement: QMGR.S01%[variable]
    Direction: Request
    Value: QMGR.S01_1
    Replacement: QMGR.S01_2
    Direction: Response
    Value: QMGR.S02_2
    Direction: Response
  Reference count: 1
LB action: lba2
  Description:
  Type: HTTP
  State: Active
  Forward type: Server farm
  Server farm: sf (in use)
  Backup server farm: sfb
  Sticky: sg3
  Backup sticky: sg4
  IP ToS: 20
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation:
  Redirect return-code: 302
    URL rewrite:
      Value:
      Replacement:
  Header delete:
    Direction: Request
  Header insert:
    Value: 1234567890123456789012345678901234567890123456789012345678901234567890
    Direction: Both
  Header insert:
    Value: dd
    Direction: Request
  Header rewrite:
    Value: dd
    Replacement: ff
    Direction: Response
  SSL URL rewrite:
    Value: 12
    Clear port: 12
    SSL port: 123
  Location header rewrite:
    Target string: (http://www.example.com): 9080
    Replacement string: %1:80
  Reference count: 1
LB action: lba3
  Description: sina
  Type: Link-generic
  State: Active
  Forward type: link group
  Link group: lg1 (in use)
  Backup link group: lg2
  Sticky:
  IP ToS:
  Fallback-action: None
  Reference count: 1
LB action: lba4
  Description: xx
  Type: DNS
  State: Active
  Forward type: DNS server pool
  DNS server pool: dsp1
  Sticky: st
  IP ToS:
  Busy-action: Force
  Reference count: 1
LB action: lba5
  Description:
  Type: HTTP
  State: Active
  Forward type: Redirect
  IP ToS:
  Fallback-action: Continue
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation: www.example.com
    URL rewrite:
      Value:
      Replacement:
  Reference count: 1
LB action: lba6
  Description:
  Type: HTTP
  State: Active
  Forward type: Response
  IP ToS:
  Fallback-action: Response
    Raw file name: 301.raw
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
    URL rewrite:
      Value: group
      Replacement: csp
  Response file:
    File: index.html
    URL: /index/css
  Response file:
    File name: subsys_intf.js
    URL: /index/subsys
  Response file:
    File name: subsys.js
    URL: /subsys.js
  Response zip file:
    Zip file name: subsys.zip
    Working path: /
  Reference count: 1
LB action: lba7
  Description:
  Type: Diameter
  State: Active
  Backup server farm:
  Sticky: sg3
  SSL client policy:
  TCP parameter profile (client-side): tcp
  Diameter-session parameter profile: dia1
  Reference count: 1
表1-2 display loadbalance action命令显示信息描述表
LB action
负载均衡动作的名称
负载均衡动作的描述信息
负载均衡动作的类型,包括:
·     DNS:表示DNS类型
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
·     Link-generic:表示链路类型
·     RADIUS:表示RADIUS类型
·     Diameter:表示Diameter类型
负载均衡动作的状态,包括:
·     Active:可用
·     Inactive:不可用
Forward type
负载均衡动作中的报文转发模式,包括:
·     Drop:丢弃
·     Drop(FIN-close):通过FIN方式关闭连接(通用\HTTP\Diameter类型的负载均衡动作)
·     Drop(RST-close):通过RST方式关闭连接(通用\HTTP\Diameter类型的负载均衡动作)
·     Forward:正常转发
·     Server farm:通过实服务组指导转发(通用\HTTP\Radius\Diameter类型的负载均衡动作)
·     Link group:链路组(链路类型的负载均衡动作)
·     DNS server pool:通过DNS服务器池指导转发(DNS类型的负载均衡动作)
·     Skip current DNS proxy:跳过当前DNS透明代理(DNS类型的负载均衡动作)
·     Redirect:重定向类型
·     Response:代答
Server farm
指导转发的主用实服务组名称,(in use)表示该实服务组正被使用。只有当报文转发模式为server farm时才会显示本字段
Backup server farm
指导转发的备用实服务组名称,(in use)表示该实服务组正被使用。只有当报文转发模式为server farm时才会显示本字段
Link group
缺省的链路组,如果包含(in use)代表链路组是当前正在使用
Backup link group
备份的链路组,如果包含(in use)代表实链路组是当前正在使用
Sticky
指导转发的主用持续性组名称,只有当报文转发模式为server farm和DNS server pool时才会显示本字段
Backup sticky
备用持续性组名称,只有当报文转发模式为server farm且负载均衡动作类型为HTTP或RADIUS时才会显示本字段
IP ToS
IP报文的ToS字段值
Fallback-action
负载均衡处理失败时进行的操作,包括:
·     None:不做任何操作
·     Continue:继续匹配下一条引用规则
·     Response:用指定文件进行代答操作(DNS\通用\HTTP\链路\Radius类型的负载均衡动作)
·     FIN-close:FIN方式关闭连接(通用和HTTP类型的负载均衡动作)
·     RST-close:RST方式关闭连接(通用和HTTP类型的负载均衡动作)
Busy-action
负载均衡动作中的繁忙处理方式,包括:
·     Continue:继续匹配策略中的下一条引用规则
·     Force:强制调度
SSL client policy
SSL客户端策略的名称,只有HTTP\Diameter类型的负载均衡动作才会显示本字段
Content rewrite
重写HTTP实体的配置,其中:
·     Value:要被重写的HTTP实体的内容
·     Replacement:重写后的内容
只有HTTP类型的负载均衡动作才会显示本字段
Redirect relocation
重定向的URL
URL rewrite
重写Location首部,其中:
·     Value:要被重写的Location首部的正则表达式
重定向报文中的状态码,只有HTTP类型的负载均衡动作才会显示本字段
Header delete
删除HTTP首部的配置,其中:
·     Name:HTTP报文首部的名称
·     Direction:HTTP报文的方向,包括Both、Request和Response
只有配置了header delete命令才会显示本字段
Header insert
插入HTTP首部的配置,其中:
·     Name:要插入HTTP报文中的首部名称
·     Value:要插入HTTP报文中的首部内容
只有配置了header insert命令才会显示本字段
Header rewrite
重写HTTP首部的配置,其中:
·     Name:HTTP报文首部的名称
·     Value:要被重写的HTTP报文首部的内容
只有配置了header rewrite命令才会显示本字段
SSL URL rewrite
重写服务器发送的HTTP应答报文Location首部的URL的配置,其中:
·     Value:Location首部URL的正则表达式
·     Clear port:原HTTP端口号
·     SSL port:重写后的SSL端口号
只有配置了ssl url rewrite命令才会显示本字段
重写服务器发送的HTTP应答报文Location内容,其中:
·     Target string:要被重写Location首部的正则表达式
·     Replacement string:重写后的Location首部
只有配置了location rewrite replace命令才会显示本字段
DNS server pool
指导转发的DNS服务器池名称,只有当报文转发模式为DNS server pool时才会显示本字段
Response file
用非压缩文件对指定URL的客户端请求进行代答
File name
对客户端请求进行代答的非压缩文件名
URL
用压缩文件对指定URL的客户端请求进行代答,缺省为/filename
Response zip file
对指定URL的客户端请求进行代答
Zip file name
对客户端请求进行代答的压缩文件名
Working path
工作路径,用于匹配URL,缺省为根路径/
Raw file name
负载均衡处理失败时的代答文件
TCP payload rewrite
重写TCP载荷的配置,其中:
·     Value:要被重写的TCP报文载荷的内容
·     Direction:TCP报文的方向,包括Both、Request和Response
只有配置了payload rewrite命令才会显示本字段
Diameter类型负载均衡动作引用的客户端侧TCP类型参数模板,只有配置了客户端侧TCP类型的参数模板才会显示本字段
Diameter类型负载均衡动作引用的Diameter-session类型参数模板,只有引用了Diameter类型的参数模板才会显示本字段
Reference count
被引用次数
display loadbalance alg用来显示所有协议的负载均衡ALG状态。
context-admin
context-operator
vsys-admin
vsys-operator
当虚服务器配置的端口号为非知名端口号时,即使已开启相应协议的负载均衡ALG功能,设备也不会进行负载均衡ALG处理。可通过以下任一方式解决:
·     修改虚服务器端口号为该协议自身的知名端口号。
·     使用port-mapping命令,将虚服务器中配置的端口号与指定协议建立端口映射关系。关于port-mapping命令的详细介绍,请参见“安全命令参考”中的“APR”。
# 显示所有协议的负载均衡ALG状态。
<Sysname> display loadbalance alg
LB ALG:
  DNS         : Enable
  FTP         : Enable
  H323        : Disabled
  ICMP-ERROR  : Enable
  ILS         : Disabled
  MGCP        : Disabled
  NBT         : Disabled
  PPTP        : Enable
  RSH         : Disabled
  RTSP        : Enable
  SCCP        : Disabled
  SIP         : Disabled
  SQLNET      : Disabled
  TFTP        : Disabled
  XDMCP       : Disabled
display loadbalance class命令用来显示负载均衡类的信息。
display loadbalance class [ name class-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name class-name:显示指定负载均衡类的信息。class-name为负载均衡类的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡类的信息。
# 显示所有负载均衡类的信息。
<Sysname> display loadbalance class
LB class: lbc1
  Description:
  Type: HTTP
  Match type: Match-all
  Match rule:
    match 1 source ip address 1.2.3.0 24
    match 2 source ipv6 address 1::2
    match 3 cookie abc value 123
    match 4 header def value 12
    match 5 method ext xde
    match 6 method rfc CONNECT
    match 7 class cla2
    match 8 url 2q3
    match 9 acl ipv4 number 2000
    match 10 acl ipv6 number 2001
    match 11 acl ipv4 name aaa
    match 12 acl ipv6 name bbb
    match 13 isp name isp1
  Reference count: 1
LB class: lbc2
  Description:
  Type: Generic
  Match type: Match-any
  Match rule:
    match 1 class cla2
    match 2 source ip address 1.2.23.0 24
    match 3 source ipv6 address 1::12
    match 4 acl ipv4 number 3000
    match 5 acl ipv6 number 3001
    match 6 acl ipv4 name ccc
    match 7 acl ipv6 name ddd
    match 8 isp name isp2
    match 9 payload orcl
  Reference count: 1
LB class: lbc3
  Description:
  Type: Link-generic
  Match rule:
    match 1 class cla3
    match 2 source ip address 1.2.3.0 24
    match 4 acl ipv4 number 3002
    match 5 acl ipv6 number 3003
    match 9 user u1
    match 10 user-group lb-group
    match 11 interface GE1/0/1
  Reference count: 1
LB class: lbc4
  Description:
  Type: DNS
  Match rule:
    match 1 class cla2
    match 8 destination ip address 1.2.3.0 24
    match 9 destination ipv6 address 1::12
    match 10 domain-name www.example.com
  Reference count: 1
LB class: lbc5
  Description:
  Type: MySQL
  Match rule:
    match 1 class cla2
    match 8 sql select
  Reference count: 1
LB class: lbc6
  Description:
  Type: Diameter
  Match rule:
    match 1 class cla2
    match 2 application-id 5
    match 3 destinaton-realm a.example.com
  Reference count: 1
表1-3 display loadbalance class命令显示信息描述表
LB class
负载均衡类的名称
负载均衡类的描述信息
负载均衡类的类型,包括:
·     DNS:表示DNS类型
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
·     MySQL:表示MySQL类型
·     RADIUS:表示RADIUS类型
Match type
负载均衡类的匹配类型,包括:
·     Match-all:表示需要匹配所有规则才算匹配该类
·     Match-any:表示只需匹配任一规则就算匹配该类
Match rule
负载均衡类包含的匹配规则
Reference count
被引用次数
display loadbalance connections命令用来显示七层负载均衡的TCP连接信息。
display loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ slot slot-number ] [ verbose ]
任意视图。
context-admin
context-operator
vsys-admin
vsys-operator
client-side:显示客户端的负载均衡连接信息。
server-side:显示服务器端的负载均衡连接信息。
ipv4:IPv4连接。
ipv6:IPv6连接。
cs-client-ip ip-address:显示指定客户端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
cs-client-port port-number:显示指定客户端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
ss-client-ip ip-address:显示指定客户端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
ss-client-port port-number:显示指定客户端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
cs-server-ip ip-address:显示指定服务器端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
cs-server-port port-number:显示指定服务器端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
ss-server-ip ip-address:显示指定服务器端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
ss-server-port port-number:显示指定服务器端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。‌‌
state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait }:显示指定TCP连接状态的负载均衡连接信息。若未指定本参数,则显示所有TCP连接状态的负载均衡连接信息。
verbose:显示负载均衡TCP连接的详细信息。若未指定本参数,则显示负载均衡TCP连接的简要信息。
如果不指定任何参数,则显示所有七层负载均衡的TCP连接信息。
# 显示七层负载均衡的TCP连接简要信息。
<Sysname> display loadbalance connections
Client side:                       State        Server side:                     State  Cookie
192.168.56.1    <--> 8.8.8.8/80    ESTAB        192.168.56.1   <--> 2.2.2.2/80   ESTB   X-LB=2.3.ab37423e.50
/50168                                          /1026
Any             <-->Any            CLOSED       192.168.56.1   <--> 2.2.2.2/80   TIMEWT   X-LB=2.3.ab37423e.50
                                                /1027
Total sessions: 3
# 显示七层负载均衡的TCP连接详细信息。
<Sysname> display loadbalance connections verbose
Slot 1:
                 Client side                     Server side
Client address   12.12.12.12/3032                12.12.12.12/54649
Server address   4.4.44.4/80                     5.5.5.5/80
State            ESTABLISHED                     ESTABLISHED
VPN name         --                              --
Cookie           X-LB=2.3.ab37423e.50
Idle time        0 sec
Idle timeout     20 sec
Start time       2018-05-30 16:54:13
Session Duration 2
Cipher Suite     TLS_RSA_WITH_AES_128_GCM_SHA256  --
Client address   12.12.12.12/2996                Any
Server address   4.4.44.4/80                     Any
State            TIME_WAIT                       N/A
VPN name         --                              --
Idle time        1 sec
Idle timeout     20 sec
Start time       2018-05-30 16:54:12
Session Duration 2
Cipher Suite     TLS_RSA_WITH_AES_128_GCM_SHA256  TLS_RSA_WITH_AES_256_CBC_SHA
Client address   12.12.12.12/3251                12.12.12.12/54341
VPN name         --                              --
Idle time        0 sec
Idle timeout     20 sec
Start time       2018-05-30 16:54:14
Session Duration 2
Total sessions: 3
表1-4 display loadbalance connections命令显示信息描述表
Client side
客户端侧TCP连接信息
Server side
服务器测TCP连接信息
Client address
客户端侧地址
Server address
服务器侧地址
TCP连接的状态,包括:
·     CLOSED:CLOSED状态
·     LISTEN、LISTENING:LISTENING状态
·     SYNSNT、SYN_SENT:SYN_SENT状态
·     SYNRCV、SYN_RECEIVED:SYN_RECEIVED状态
·     ESTAB、ESTABLISHED: ESTABLISHED状态
·     CLOWAT、CLOSE_WAIT:CLOSE_WAIT状态
·     FINWT1、FIN_WAIT_1:FIN_WAIT_1状态
·     CLOSING:CLOSING状态
·     LASACK、LAST_ACK:LAST_ACK状态
·     FINWT2、FIN_WAIT_2:FIN_WAIT_2状态
·     TIMEWT、TIME_WAIT:TIME_WAIT状态
·     有关TCP连接状态的详细介绍,可参见RFC793.
VPN name
VPN实例名称
Cookie
持续性方法插入的Cookie名称和值
Idle time
TCP连接已空闲的时间,单位为秒
Idle timeout
TCP连接的空闲超时时间,单位为秒
Start time
开始建立TCP连接的时间
Session Duration
会话持续时间
Cipher Suite
证书的加密套件
Total sessions
总会话数量
display loadbalance diameter connections命令用来显示七层负载均衡的Diameter连接信息。
display loadbalance diameter connections [ slot slot-number ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
verbose:显示负载均衡Diameter连接的详细信息。若未指定本参数,则显示负载均衡TCP连接的简要信息。
# 显示七层负载均衡的Diameter连接简要信息。
<Sysname> display loadbalance diameter connections
1.1.1.1/50159    <--> 2.2.2.1/3868 ESTAB  12.12.12.1/1028 <--> 13.13.13.2/3868 ESTB
                                            12.12.12.1/1029 <--> 13.13.13.3/3868 ESTB
                                            12.12.12.1/1030 <--> 13.13.13.4/3868 ESTB
11.11.11.11/5009 <--> 22.2.22.1/3868 ESTAB  14.14.14.1/1028 <--> 15.15.15.2/3868 ESTB
                                            14.14.14.1/1029 <--> 15.15.15.3/3868 ESTB
# 显示七层负载均衡的Diameter连接详细信息。
<Sysname> display loadbalance diameter connections verbose
Slot 1:
                Client side
Role            Address            Origin-Host       Origin-Realm
Client          1.1.1.1/50169      dcca.example.com  example.com
Server          2.2.2.1/3868       host.h3c.com      h3c.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
Start time      2023-05-30 16:54:13
                Server side
Client          12.12.12.1/1028      host1.h3c.com    h3c.com
Server          13.13.13.2/3868      ide.example.com  example.com
State           ESTABLISHED
VPN name        --                              .
Idle time       0 sec
Idle timeout    20 sec
Start time      2023-05-30 16:54:14
Client          12.12.12.1/1029      host1.h3c.com   h3c.com
Server          13.13.13.3/3868      ide.example.com example.lb.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
Client          12.1.12.12/1030      host1.h3c.com   h3c.com
Server          13.13.13.4/3868      ide.example.com example.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
Start time      2023-05-30 16:54:15
                Client side
Client          1.1.1.2/50169        dc1.example.com example1.com
Server          2.2.2.2/3868         host2.h3c.com   h3c2.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
                Server side
Client          12.12.12.2/1028      host2.h3c.com    h3c2.com
Server          13.13.13.3/3868      ide2.example.com example3.com
State           ESTABLISHED
VPN name        --                              .
Idle time       0 sec
Idle timeout    20 sec
表1-5 display loadbalance diameter connections命令显示信息描述表
Client side
客户端侧连接信息
Server side
服务器测连接信息
Address
地址
Origin-Host
源主机名
Origin-Realm
源域名
TCP连接的状态,包括:
·     CLOSED:CLOSED状态
·     CLOSING:CLOSING状态
·     有关Diameter连接状态的详细介绍,可参见RFC793.
VPN name
VPN实例名称
Idle time
TCP连接已空闲的时间,单位为秒
Idle timeout
TCP连接的空闲超时时间,单位为秒
Start time
开始建立连接的时间
display loadbalance dns-query命令用来显示外链代理正在查询的域名信息。
display loadbalance dns-query [ vpn-instance vpn-instance-name ] [ slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网实例中的域名查询信息。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 显示外链代理正在查询的所有域名信息。
<Sysname> display loadbalance dns-query
Slot 1:
VPN instance:
  Domain name      DNS server
  www.a.example.com        1.2.3.4
  www.b.example.com        2.2.3.4
Slot 2:
VPN instance:
  www.c.example.com        3.2.3.4
  www.d.example.com        4.2.3.4
表1-6 display loadbalance dns-query命令显示信息描述表
Domain name
正在查询的域名
DNS server
查询域名的DNS服务器IP地址
VPN instance
VPN实例
display loadbalance external-monitor log命令用来显示自定义监控的日志信息。
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示自定义监控的日志信息。
<Sysname> display loadbalance external-monitor log
The external monitor probe state of (server farm sf, real server rs, port: 3306) template mysql-template changed to successful.
The external monitor probe state of (server farm sf2, real server rs2, port: 3306) template mysql-template changed to failed.
display loadbalance hot-backup statistics命令用来显示负载均衡热备份的统计信息。
display loadbalance hot-backup statistics [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
# 显示负载均衡热备份的统计信息。
<Sysname> display loadbalance hot-backup statistics
Slot 2:
               TryAdd    TryDel    AckDel    AckOK     AckNO     NotSpt
  StiSnd       1         0         0         0         0         0
  StiRcv       0         0         0         0         0         0
  StiSndFail   0         0         0         0         0         0
  StiRcvFail   0         0         0         0         0         0
  MsgSnd       1         0         0         0         0         0
  MsgRcv       0         0         0         0         0         0
  MsgSndFail   0         0         0         0         0         0
  MsgRcvFail   0         0         0         0         0         0
  MAllocFail   0         0         0         0         0         0
  SesBkTotal : 0
  SesBkFail  : 0
  SesResTotal: 0
  SesResFail : 0
  SesUpdate  : 0
表1-7 display loadbalance hotbackup statistics命令显示信息描述表
TryAdd
持续性表项添加消息
TryDel
持续性表项删除消息
AckDel
持续性表项确认删除消息
AckOK
持续性表项可以删除消息
AckNO
持续性表项不能删除消息
NotSpt
不支持的持续性表项消息
StiSnd
发送条数
StiRcv
接收条数
StiSndFail
发送失败条数
StiRcvFail
接收失败条数
MsgSnd
报文发送次数
MsgRcv
报文接收次数
MsgSndFail
报文发送失败次数
MsgRcvFail
报文发送失败次数
MAllocFail
内存申请失败次数
SesBkTotal
会话备份次数
SesBkFail
会话备份失败次数
SesResTotal
会话恢复次数
SesResFail
会话恢复失败次数
SesUpdate
会话更新次数
display loadbalance limit-policy命令用来显示负载均衡连接数限制策略配置信息。
display loadbalance limit-policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
policy-name:连接数限制策略的名称,为1~255个字符的字符串,不区分大小写。
# 显示限制策略名称为lptest的配置。
<Sysname> display loadbalance limit-policy name lptest
Limit-policy: lptest
  Description:
  Limit rule:
limit lptest acl 3000 amount 10 10
Reference count: 1
表1-8 display loadbalance limit-policy命令显示信息描述表
Limit-Policy
限制策略名称
限制策略的描述信息
Limit rule
限制规则
Reference count
被引用次数
display loadbalance policy命令用来显示负载均衡策略的信息。
display loadbalance policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name policy-name:显示指定负载均衡策略的信息。policy-name为负载均衡策略的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡策略的信息。
# 显示所有负载均衡策略的信息。
<Sysname> display loadbalance policy
LB policy: lbp1
  Description:
  Type: Generic
  Class: lbc1
   Action: lba1
  Default action: lba0
  Reference count: 1
LB policy: lbp2
  Description:
  Type: HTTP
  Default action:
  Reference count: 1
LB policy: lbp3
  Description:
  Type: Link-generic
  Class: lbc3
  Action: lba3
  Default action: lba3
  Reference count: 1
LB policy: lbp4
  Description:
  Type: DNS
  Class: lbc4
  Action: lba4
  Default action: lba4
LB policy: lbp5
  Description:
  Type: MySQL
  Class: lbc5
  Action: lba5
  Default action: lba5
  Reference count: 1
LB policy: lbp6
  Description:
  Type: Diameter
  Class: lbc6
   Action: lba6
  Default class action: lbc1
  Reference count: 1
表1-9 display loadbalance policy命令显示信息描述表
LB policy
负载均衡策略的名称
负载均衡策略的描述信息
负载均衡策略的类型,包括:
·     DNS:表示DNS类型
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
·     MySQL:表示MySQL类型
·     RADIUS:表示RADIUS类型
Class
负载均衡策略包含的负载均衡类
Action
负载均衡类对应的负载均衡动作
缺省的负载均衡动作
Reference count
被引用次数
display loadbalance probe failed-record命令用来显示健康检测失败的历史记录。
display loadbalance probe failed-record { real-server | link } [ name name ]
context-admin
context-operator
vsys-admin
vsys-operator
real-server:显示实服务器的健康检测失败记录。
link:显示链路的健康检测失败记录。
name name:显示指定名称实服务器或链路的健康检测失败历史记录。为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器或链路的健康检测失败的历史记录。
查看实服务器健康检测失败的历史记录前,需要通过loadbalance probe failed-record enable命令开启健康检测失败信息的记录功能。
# 显示所有实服务器的健康检测失败信息。
<Sysname> display loadbalance probe failed-record real-server
Template               Server farm    Real server          Address family   Port   Template type   Reason        Failure time
t1                     sf2            rs                   IPv4              30     arp            TimeOut       2023-06-25 17:14:39
t1                     sf1            rs                   IPv6              20     arp           TimeOut        2023-06-25 17:14:39
t1                     -              rs                   IPv4              -      arp            TimeOut       2023-06-25 17:14:38
t1                     -              rs                   IPv6              10     arp            TimeOut       2023-06-25 17:14:37
# 显示所有链路的健康检测失败信息。
<Sysname> display loadbalance probe failed-record link
Template               Link group    Link                 Address family    Template type     Reason         Failure time
t1                     lg            lk                   IPv4              arp               TimeOut        2023-06-25 17:14:39
t1                     lg            lk                   IPv6              arp               TimeOut        2023-06-25 17:14:39
t1                     -             lk                   IPv4              arp               TimeOut        2023-06-25 17:14:38
t1                     -             lk                   IPv6              arp               TimeOut        2023-06-25 17:14:37
表1-10 display virtual-server命令显示信息描述表
Template
健康检测模板的名称
Server farm
健康检测失败的实服务组名称,如果是实服务器,显示为“-”
Real server
实服务器或实服务组成员的名称
Link group
健康检测失败的链路组名称,如果是链路,显示为“-”
Link
链路或链路组成员的名称
Address family
实服务器或链路所属地址族类型,包括IPv4和IPv6,负载均衡自定义探测模板不区分址族类型,显示为” - ”
Port
实服务器的端口号,” - ”表示使用NQA的端口号
Template type
健康检测模板的类型
Reason
健康检测失败的原因,包括:
·     Timeout:请求超时导致检测失败
·     No Route:没有路由导致检测失败
·     Internal error:内部错误导致检测失败
·     Verify error:校验错误导致检测失败
·     Disconnect:对方强制断开连接导致检测失败
·     No connection:和对方建立连接失败
·     Expect Status error:预期状态错误导致检测失败
·     Other errors:其他错误导致检测失败
Failure time
健康检测失败的时间,按由近到远排序
·     loadbalance probe failed-record enable
·     loadbalance probe failed-record max-number
·     reset loadbalance probe failed-record
1.1.50  display loadbalance probe undetected
display loadbalance probe undetected显示由于NQA健康检测速率限制而未启动的健康检测任务信息。
display loadbalance probe undetected { dns-server | link | real-server }
context-admin
vsys-admin
dns-server:显示DNS服务器下未启动的NQA健康检测任务信息。
link:显示链路下未启动的NQA健康检测任务信息。
real-server:显示实服务器下未启动的NQA健康检测任务信息。
仅在开启NQA健康检测速率限制功能的情况下,存在因超出速率限制而未能启动的NQA健康检测任务时,系统才会显示相关内容。
# 显示实服务器下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected real-server
Real server: rs
Port: 20
Server farm: sf1
NQA template: t1
Probe type: IPv6
Record time: 2023-06-25 17:14:39
Real server: rs
Port: 20
Server farm: -
NQA template: t2
Probe type: IPv4
Record time: 2023-06-25 17:14:40
# 显示链路下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected link
Link: LK1Link group: lg
NQA template: t3
Probe type: IPv4
Record time: 2023-06-25 17:14:41
Link: LK2
Link group: -
NQA template: t
Probe type: IPv4
Record time: 2023-06-25 17:14:46
# 显示DNS服务器下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected dns-server
DNS server: dns1
Port:2
DNS server pool: dnspool1
NQA template: t
Probe type:IPv4
Record time: 2023-06-25 17:14:42
DNS server: dns2
Port: -
DNS server pool: -
NQA template: t7
Probe type: IPv4
Record time: 2023-06-25 17:14:43
表1-11 display loadbalance probe undetected命令显示信息描述表
Real server
实服务器或实服务组成员的名称
Server farm
未启动NQA健康检测的实服务组名称,如果是实服务器,显示为“-”
Link group
未启动NQA健康检测的链路组名称,如果是链路,显示为“-”
Link
链路或链路组成员的名称
DNS server
DNS服务器或DNS服务池成员的名称
DNS server pool
未启动NQA健康检测的DNS服务池的名称,如果是DNS服务器,显示为“-”
Port
NQA探测任务使用的探测端口,“-”表示使用探测模板配置的端口号探测
NQA template
NQA健康检测模板的名称
Probe type
健康检测类型,包括IPv4、IPv6、Interface
Record time
加入等待启动队列的时间
1.1.51  display loadbalance probe-template
display loadbalance probe-template命令用来显示负载均衡探测模板的信息。
display loadbalance probe-template [ name template-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name template-name:显示指定负载均衡探测模板的信息。template-name为负载均衡探测模板的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡探测模板的信息。
# 显示所有负载均衡探测模板的信息。
<Sysname> display loadbalance probe-template
Load balancing probe template: rst1
  Description:
  Type: tcp-rst
  Monitoring interval: 20 sec
  RST threshold: 10
  Protection action: auto-shutdown
  Reference count: 1
Load balancing probe template: zero2
  Description:
  Type: tcp-zero-window
  Monitoring interval: 30 sec
  Zero-window threshold: 20
  Protection action: busy
    Probe interval: 30 sec
    Probe times: 3
  Reference count: 1
Load balancing probe template: icmp1
  Description:
  Type: icmp
  Timeout: 3 sec
  Frequency: 300
  Reference count: 1
  Load balancing probe template: http1
  Description:
  Type: http-passive
  Monitoring interval: 1 sec
  Abnormal-url threshold: 10000
  Timeout: 30 sec
  URL list:
    aaa
  Status code list:
    404
  Reference count: 1
Load balancing probe template: test_external
  Description:
  Type: external-monitor
  External script: http.sh
  Monitoring interval: 5 sec
  Timeout: 6 sec
  Argument: 192.168.1.123
  Environment variable list:
    Name               Value
    Test3              /opt/lib
    Test4              /usr/bin
  Reference count: 1
表1-12 display loadbalance probe-template命令显示信息描述表
负载均衡探测模板的名称
负载均衡探测模板的描述信息
负载均衡探测模板的类型,包括:
·     external-monitor:表示自定义监控类型负载均衡探测模板
·     http-passive:表示HTTP passive类型负载均衡探测模板
·     icmp:表示ICMP类型负载均衡探测模板
·     tcp-rst:表示TCP RST类型负载均衡探测模板
·     tcp-zero-window:表示TCP zero-window类型负载均衡探测模板
·     database (AntDB):表示AntDB数据库类型的负载均衡探测模板(暂不支持)
·     database (MySQL):表示MySQL数据库类型的负载均衡探测模板(暂不支持)
·     database (Oracle):表示Oracle数据库类型的负载均衡探测模板(暂不支持)
Monitoring interval
负载均衡探测模板的监控时间
ICMP类型的负载均衡探测模板不会显示本字段
RST threshold
负载均衡探测模板RST报文上限阈值
只有TCP RST类型的负载均衡探测模板才会显示本字段
负载均衡探测模板零窗口报文上限阈值
只有TCP zero-window类型的负载均衡探测模板才会显示本字段
Protection action
负载均衡探测模板达到阈值后执行的保护动作,包括:
·     Auto-shutdown:实服务器关闭
·     Busy:实服务器繁忙
只有TCP RST类型或TCP zero-window类型的负载均衡探测模板才会显示本字段
Probe interval
实服务器的繁忙保护时间
只有TCP RST类型和TCP zero-window类型的负载均衡探测模板才会显示本字段
Probe times
实服务器的繁忙保护次数,超过该值实服务器自动关闭
Timeout
探测报文、HTTP报文或自定义监控报文的应答超时时间
TCP RST类型和TCP zero-window类型的负载均衡探测模板不会显示本字段
Frequency
探测报文的时间间隔
只有ICMP类型和HTTP passive类型的负载均衡探测模板才会显示本字段
异常URL的上限阈值
只有HTTP passive类型的负载均衡探测模板才会显示本字段
URL list
HTTP passive类型探测模板的URL列表
Status code list
HTTP passive类型探测模板的响应状态码列表
External script
自定义监控类型探测模板引用的自定义脚本名称
只有自定义监控类型的负载均衡探测模板才会显示本字段
Argument
自定义监控类型探测模板的用户自定义信息
Environment variables list
自定义监控类型探测模板的环境变量列表
Name
自定义监控类型探测模板的环境变量名
Value
自定义监控类型探测模板的环境变量值
Sent statement
登录数据库后,执行的数据库语句
只有数据库类型的负载均衡探测模板才会显示本字段
Max reuse times
设备与数据库的最大连接复用次数
Reference count
被引用次数
·     loadbalance probe-template
1.1.52  display loadbalance process-limit
display loadbalance process-limit命令用来显示设备允许启动的自定义监控进程个数。
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示设备允许启动的自定义监控进程个数。
<Sysname> display loadbalance process-limit
Loadbalance process-limit: 2
表1-13 display loadbalance process-limit命令显示信息描述表
设备允许启动的自定义进程个数
1.1.53  display loadbalance protection-policy
display loadbalance protection-policy命令用来显示防护策略的配置信息。
display loadbalance protection-policy [ name policy-name ]
context-admin
context-operator
name policy-name:显示指定防护策略的配置信息。policy-name为防护策略的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有防护策略的配置信息。
非缺省vSystem不支持本命令。
# 显示所有防护策略的配置信息。
<Sysname> display loadbalance protection-policy
Policy name: p1
  Description:
  Type: HTTP
  Protection action: warning
  Rule ID: 3
    URL: /index.php
    Protection period: 2
    Method                     Threshold
    Cookie (Jsessionid)        20
    Source IP                  10
  Rule ID: 5
    URL: /test.php
    Protection period: 20
    Method                     Threshold
    Cookie (A1B2C3D4)          20
  Reference count: 1
  Slow-attack protection state: Enabled
  Slow-attack request-header timeout: 10 seconds
表1-14 display loadbalance protection-policy命令显示信息描述表
Policy name
防护策略的名称
防护策略的类型,包括:
·     HTTP:表示HTTP类型
Protection action
防护动作,包括:
·     warning:告警
·     drop:丢弃报文
·     verify (insert header):通过插入HTTP首部的方式对客户端请求报文进行客户端验证
·     verify (js):通过注入JS脚本的方式对客户端请求报文进行验证
Rule ID
防护规则编号
URL
防护URL
Protection period
防护周期
Method
防护阈值的类型,包括:
·     Cookie (xxx):基于Cookie的防护阈值(Cookie名称)
·     Source IP:基于源IP地址的防护阈值
Threshold
HTTP请求数阈值
Reference count
被引用次数
HTTP慢速攻击防护功能是否开启,包括:
·     Enabled:开启
·     Disabled:关闭
HTTP慢速攻击防护请求Header接收超时时间
1.1.54  display loadbalance snat-address statistics
display loadbalance snat-address statistics命令用来显示SNAT IP地址的统计信息。
display loadbalance snat-address statistics { ip ip-address | ipv6 ipv6-address } [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
ip ip-address:指定一个IPv4地址。
ipv6 ipv6-address:指定一个IPv6地址。
slot slot-number:显示指定成员设备上的SNAT地址统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。‌‌
# 显示SNAT地址的统计信息。
<Sysname> display loadbalance snat-address statistics ip 10.10.10.79
Slot 1:
SNAT address: 10.10.10.79
  Inbound throughput            772.2Kbps
  Outbound throughput           376.7Kbps
  Received packets              2300
  Sent packets                  1100
  Current connections           0
  Peak connections              1
  Total connections             1
表1-15 display loadbalance snat-address statistics命令显示信息描述表
SNAT address
SNAT IP地址
Inbound throughput
报文的入吞吐量
Outbound throughput
报文的出吞吐量
Received packets
收到的报文数目
Sent packets
发出的报文数目
Current connections
当前并发连接数
Peak connections
历史最大并发连接数
Total connections
历史总连接数
1.1.55  display loadbalance snat-global-policy
display loadbalance snat-global-policy命令用来显示SNAT全局策略的信息。
display loadbalance snat-global-policy [ name policy-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name policy-name:显示指定SNAT全局策略的信息。snat-global-name为SNAT全局策略的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SNAT全局策略的信息。
# 显示所有SNAT全局策略的信息。
<Sysname> display loadbalance snat-global-policy
Policy name: lbsnat1
  Description:
  State: Active
  Priority: 0
  VPN instance:
  Source IP object group: src-obj
  Destination IP object group: dst-obj
  Service object group: proto-obj
  Translation mode: snat-pool sp
Policy name: lbsnat2
  Description:
  State: Inactive(disable)
  Priority: 0
  VPN instance:
  Translation mode: auto-map
表1-16 display loadbalance snat命令显示信息描述表
Policy name
SNAT全局策略的名称
SNAT全局策略的描述信息
SNAT全局策略的状态,包括:
·     Active:可用
·     Inactive:不可用(已开启SNAT功能,仍不可用)
·     Inactive (disabled):不可用(由于未开启SNAT功能)
Priority
SNAT全局策略的优先级
VPN instance
SNAT全局策略所属的VPN实例
进行SNAT地址转换的源IP地址对象组
进行SNAT地址转换的服务对象组
Translation mode
SNAT地址转换方式
1.1.56  display loadbalance snat-pool
display loadbalance snat-pool命令用来显示SNAT地址池的信息。
display loadbalance snat-pool [ name pool-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name pool-name:显示指定SNAT地址池的信息。pool-name为SNAT地址池的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SNAT地址池的信息。
# 显示所有SNAT地址池的信息。
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
  Description:
  VPN instance:
  Traffic group: 1
  VRRP IPv4 info:
    VRRP IPv4 VRID: 1
  VRRP IPv6 info:
    VRRP IPv6 VRID: 3
  IPv4 range:
    Start address                       End address
    202.110.10.5                        202.110.10.10
    202.110.20.10                       202.110.20.15
  IPv6 range:
    2002::2                             2002::100
    2002::200                           2002::300
  ARP/ND interfaces:
    GigabitEthernet1/0/3
  Reference count: 1
SNAT pool: lbsp2
  Description:
  VPN instance:
  Traffic group: 1
  VRRP IPv4 info:
    VRRP IPv4 VRID: 1
  VRRP IPv6 info:
    VRRP IPv6 VRID: 3
  IPv4 range:
    203.110.10.10                       203.110.10.15
  IPv6 range:
    2003::2                             2003::100
  ARP/ND interfaces:
    GigabitEthernet1/0/2
  Reference count: 1
表1-17 display loadbalance snat-pool命令显示信息描述表
SNAT pool
SNAT地址池的名称
SNAT地址池的描述信息
VPN instance
SNAT地址池所属VPN实例
Traffic group
SNAT地址池关联的集群流量组的编号
IPv4 range
IPv4地址段
IPv6 range
IPv6地址段
Start address
起始地址
End address
结束地址
ARP/ND interfaces
发送免费ARP报文或者ND报文的接口
VRRP IPv4 VRID
SNAT地址池绑定的VRRP IPv4备份组号
SNAT地址池绑定的VRRP备份组的接口
VRRP IPv6 VRID
SNAT地址池绑定的VRRP IPv6备份组号
Reference count
被引用次数
1.1.57  display loadbalance snat-pool reference
display loadbalance snat-pool reference命令用来查询SNAT地址池被引用的信息。
display loadbalance snat-pool reference [ brief | name pool-name ]
context-admin
context-operator
vsys-admin
vsys-operator
brief:显示所有SNAT地址池被引用的简要信息。如果未指定本参数,将显示SNAT地址池被引用的详细信息。
name pool-name:显示指定SNAT地址池被引用的详细信息。pool-name为SNAT地址池的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SNAT地址池被引用的信息。
# 显示所有SNAT地址池被引用的简要信息。
<Sysname> display loadbalance snat-pool reference brief
SNAT pool    Type                        Server farms         SNAT global policies
lbsp1        Address-based split         3                    2
lbsp2        Port-based split            0                    1
lbsp3        Failover-group-based split  2                    2
# 显示SNAT地址池lbsp1被引用的详细情况。
<Sysname> display loadbalance snat-pool reference name lbsp1
SNAT pool: lbsp1
  Type: Port-based split
  Server farms: sf1
                sf3
                sf4
  SNAT global policies: lbsnat1
                        lbsnat3
# 显示所有SNAT地址池被引用的详细信息。
SNAT pool: lbsp1
  Server farms: sf1
                sf3
                sf4
                        lbsnat3
SNAT pool: lbsp2
  Type: Address split
  Server farms: sf2
                sf5
  SNAT global policies: lbsnat2
                        Lbsnat4
表1-1 display loadbalance snat-pool reference命令显示信息描述表
SNAT pool
SNAT地址池的名称
SNAT地址池的类型,包括:
·     Address-based split:地址拆分类型
·     Failover-group-based spit:指定备份组类型
·     Port-based split:端口拆分类型
Server farms
引用该SNAT地址池的实服务组
引用该SNAT地址池的SNAT全局策略
·     snat-pool (server farm view)
·     translation-mode
1.1.58  display loadbalance snat-pool statistics
display loadbalance snat-pool statistics命令用来显示SNAT地址池的统计信息。
display loadbalance snat-pool statistics [ name pool-name ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
name pool-name:显示指定SNAT地址池的统计信息。pool-name为SNAT地址池的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SNAT地址池的统计信息。
slot slot-number:显示指定成员设备上的SNAT地址池统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。‌‌
# 显示SNAT地址池spool的统计信息。
<Sysname> display loadbalance snat-pool statistics name spool
Slot 1:
SNAT pool: spool
    Sent packets                                1100
    Current connections                         1
    Peak connections                            1
Total connections                           1
  SNAT address: 10.10.10.80
    Inbound throughput                          854.6Kbps
    Outbound throughput                         417.0Kbps
    Received packets                            2600
    Sent packets                                1300
    Peak connections                            1
Total connections                           1
  Total:
    Inbound throughput                          1.6Mbps
    Outbound throughput                         793.7Kbps
    Received packets                            4900
    Sent packets                                2400
    Current connections                         2
    Peak connections                            2
    Total connections                           2
表1-18 display loadbalance snat-pool statistics命令显示信息描述表
SNAT pool
SNAT地址池名称
SNAT address
SNAT地址池的IP地址成员
Inbound throughput
报文的入吞吐量
Outbound throughput
报文的出吞吐量
Received packets
收到的报文数目
Sent packets
发出的报文数目
Current connections
当前并发连接数
Peak connections
历史最大并发连接数
Total connections
历史总连接数
1.1.59  display loadbalance total-count
display loadbalance total-count命令用来显示负载均衡各项的配置总数。
context-admin
context-operator
非缺省vSystem不支持本命令。
# 显示负载均衡各项的配置总数。
<Sysname> display loadbalance total-count
Total number of virtual-server:0
Total number of real-server:0
Total number of server-farm:0
Total number of server-farm member:0
表1-19 display loadbalance total-count命令显示信息描述表
虚服务器的总数
实服务器的总数
实服务组的总数
实服务组成员的总数
1.1.60  display loadbalance virtual-server overall-total-statistics
display loadbalance virtual-server overall-total-statistics命令用来显示设备整机所有虚服务器的统计信息。
context-admin
context-operator
vsys-admin
vsys-operator
本命令用来显示设备整机所有虚服务器连接数的统计信息以及SSL卸载能力的统计信息。
# 显示设备整机所有虚服务器的统计信息。
<Sysname> display loadbalance virtual-server overall-total-statistics
  Total connections: 1048341
  Active connections: 0
  Connections per second: 0
  Active SSL connections: 1
  SSL connections per second: 300
  SSL inbound bandwidth: 208800 bps
  SSL outbound bandwidth: 1704864 bps
表1-20 display loadbalance virtual-server overall-total-statistics命令显示信息描述表
Total connections
虚服务器总连接数
Active connections
所有虚服务器当前活动的连接数
所有虚服务器的每秒连接数
当前SSL卸载活动的连接数
SSL卸载的每秒连接数
SSL卸载的入方向带宽
SSL卸载的出方向带宽
·     display loadbalance virtual-server total-statistics
1.1.61  display loadbalance virtual-server total-statistics
display loadbalance virtual-server total-statistics命令用来显示所有虚服务器的累加统计信息。
display loadbalance virtual-server total-statistics [ slot slot-number ]
context-admin
context-operator
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
工作机制
通过配置本命令可以显示所有虚服务器的总连接数。当通过命令reset virtual-server statistics清除某一虚服务的统计信息时,本命令的统计结果会受到影响。
注意事项
非缺省vSystem不支持本命令。
# 显示所有虚服务器的叠加统计信息。
<Sysname> display loadbalance virtual-server total-statistics
Slot 1:
  Total connections: 0
  Active SSL connections: 0
  SSL connections per second: 0
Slot 2:
表1-21 display loadbalance virtual-server total-statistics命令显示信息描述表
Total connections
总连接数
Active connections
当前活动的连接数
每秒连接数
当前活动的SSL连接数
每秒SSL连接数
1.1.62  display parameter-profile
display parameter-profile命令用来显示参数模板的信息。
display parameter-profile [ name parameter-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name parameter-name:显示指定参数模板的信息。parameter-name为参数模板的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有参数模板的信息。
# 显示所有参数模板的信息。
<Sysname> display parameter-profile
Parameter profile: pp1
  Description:
  Type: IP
  IP ToS: 20
  Reference count: 0
Parameter profile: pp2
  Description:
  Type: TCP
  Exceed MSS: Allow
  TCP window size: 65535
  TCP delayed acks: 2
  TCP connection idle-timeout: 10
  Time-wait timeout: 5
  Keepalive idle-timeout: 300
  Keepalive retransmission interval: 3
  Keepalive retransmission count: 5
  Keepalive l4 idle-timeout: 0
  Syn retransmission-timeout: 5
  Syn cookie threshold: 10
  Retransmission-timeout: 120
  Fin-wait1 timeout: 6
  Fin-wait2 timeout: 10
  Src-addr-option:
    Option kind number: 29 (TCP-AO)
    Encoding: string
  TCP option remove:
    Option kind number: 3 (WSopt)
  TCP option remove:
    Option kind number: 5 (SACK)
  TCP option insert-mode: data-packet
  TCP option insert:
    Option kind number:28 (UTO)
    Value: src-ip
    Encoding: string
  TCP option preserve:
    Option kind number: 8 (TSopt)
  TCP Timestamps option: Preserve
  Reference count: 1
Parameter profile: pp3
  Description:
  Type: HTTP
  Rebalance per request: Enabled
  Server connection reuse: Enabled
  Case insensitive: Enabled
  Header modify per request: Enabled
  Content maximum parse length: 8192
  Header maximum parse length: 8192
  Secondary cookie delimiters: !@#$
  Secondary cookie start: ?
  Encrypted cookie name: cookie1
  Header exceed length: Drop
  Reference count: 1
Parameter profile: compress
  Description:
  Type: HTTP compression
  Compression level: 1
  Prefer method: Gzip
  Content length threshold: 1024
  Memory size: 8KB
  Window size: 16KB
  Header Insert: Enabled
  Header Delete: Enabled
  Request version all: Disabled
  Rule 1: Permit url abc
  Reference count: 1
Parameter profile: urlstat
  Description:
  Type: HTTP-statistics
  Node: bank1
    Description:
    rule 1 url url1
    rule 2 url url2
  Node: bank2
    Description:
    rule 1 url url3
    rule 2 url url4
  Object group name:
    ObjGrp1
    ObjGrp2
  Reference count: 1
Parameter profile: pp4
  Description:
  Type: OneConnect
  Max reuse times: 1000
  Idle time: 10000
  IPv4 source mask length: 24
  IPv6 source prefix length: 120
  Reference count: 1
Parameter profile: pp5
  Description:
  Type: TCP-application
  Match-buffer-time: 5
  Match-buffer-size: 4096
  Match-buffer-end: YY
  Reference count: 1
Parameter profile: pp6
  Description:
  Type: MySQL
  Pool size: 2000
  Idle time: 10000 sec
  Reference count: 1
  Description:
  Type: HTTP2
  Concurrent-streams-per-connection: 123
  Recv-window size: 32
  Connection idle-timeout: 300
  Frame size: 1531
  Header-table size: 53241
  Insert-header-field: hx
  Connection close fin
  Reference count: 1
Parameter profile: pp7
  Description:
  Type: Diameter-session
  Origin host: host.example.com
  Origin realm: example.com
  Vendor Id: 25506
  Product name: L5080
  Host ip: 20.0.0.2
  Retransmission: Enabled
  Retransmission timeout: 5
  CE timeout: 20
  Reference count: 1
表1-22 display parameter-profile命令显示信息描述表
Parameter profile
参数模板的名称
参数模板的描述信息
参数模板的类型,包括:
·     IP:表示IP类型
·     HTTP:表示HTTP类型
·     HTTP compression:表示HTTP压缩类型
·     HTTP-statistics:表示HTTP统计类型
·     MySQL:表示MySQL类型
·     OneConnect:表示OneConnect类型
·     TCP:表示TCP类型
·     TCP-application:表示TCP-application类型
·     HTTP2:表示HTTP2.0类型
·     Diameter-session:表示Diameter-session类型
IP ToS
发往服务器的IP报文中的ToS字段
Reference count
被引用次数
Exceed MSS
对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式,包括:
·     Allow:表示允许超出MSS的数据段
·     Drop:表示丢弃超出MSS的数据段
是否开启对每个HTTP请求报文都进行负载均衡的功能,包括:
·     Disabled:关闭
·     Enabled:开启
Pool size
MySQL连接池的大小
是否开启允许负载均衡设备与服务器的连接复用的功能,包括:
·     Disabled:关闭
·     Enabled:开启
是否开启对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作的功能,包括:
·     Disabled:关闭
·     Enabled:开启
Case insensitive
是否开启匹配字符串时对大小写不敏感的功能,包括:
·     Disabled:关闭
·     Enabled:开启
HTTP实体的最大解析长度
HTTP首部的最大解析长度
URL中分隔Secondary Cookie的字符
URL中Secondary Cookie的起始位置标示字符
开启了Cookie加密功能的Cookie名称
当HTTP请求或应答报文首部超出最大长度时的处理方式,包括:
·     Continue:表示继续执行负载均衡操作
·     Drop:表示停止执行负载均衡操作,丢弃该报文并关闭连接
TCP window size
TCP连接中的本地最大窗口值
TCP delayed acks
TCP延迟ACK的接收数据包数量
TCP连接的空闲超时时间,单位为秒
Time-wait timeout
TCP TIME-WAIT状态的超时时间,单位为秒
七层模式下TCP保活定时器的空闲超时时间,单位为秒
七层模式下TCP保活报文的重传时间间隔,单位为秒
七层模式下TCP保活报文的重传次数
四层模式下TCP连接保活定时器的空闲超时时间,单位为秒,0表示未开启四层模式下的TCP保活功能
TCP SYN报文的重传超时时间,单位为秒
触发SYN Cookie保护功能的门限值,0表示不会触发
TCP连接中数据报文重传的总超时时间
Fin-wait1 timeout
TCP FIN-WAIT-1状态的超时时间,单位为秒
Fin-wait2 timeout
TCP FIN-WAIT-2状态的超时时间,单位为秒
Node
统计节点的名称及统计节点视图下配置的所有URL统计匹配规则
Object group name
HTTP统计类型的参数模板引用的IP地址对象组
Max reuse times
TCP连接的最大复用数目
Idle time
TCP连接的空闲超时时间,单位为秒
TCP连接复用客户端的IPv4源地址掩码长度
TCP连接复用客户端的IPv6源地址前缀长度
Match-buffer-time
TCP载荷匹配的缓冲时间,单位为秒
Match-buffer-size
TCP载荷匹配的缓冲数据大小
Match-buffer-end
TCP载荷匹配的缓冲结束符
Src-addr-option
进行SNAT地址转换的TCP Option
Option kind number
TCP选项类型编号
Encoding
TCP Option的编码方式,包括:
·     binary:二进制编码
·     string:字符串编码
TCP选项插入模式,包括:
·     per-packet:插入数据报文以及握手阶段的报文
·     data-packet:只插入数据报文
TCP option insert
在TCP选项中插入内容
Value
插入TCP选项的内容
TCP option remove
清除TCP选项
一条TCP连接的最大并发请求
Recv-window size
HTTP2.0报文使用的接收窗口大小
HTTP2.0请求报文TCP连接的空闲超时时间
Frame size
HTTP2.0报文连接帧大小
Header-table size
HTTP2.0报文头部表大小
Insert-header-field
HTTP2.0请求报文中插入的头部字段
Connection close fin/Connection close rst
关闭设备与实服务器TCP连接方式,包括:
·     fin:表示发送FIN报文方式关闭连接
·     rst:表示发送RST报文方式关闭连接
TCP option preserve
保持TCP选项
TCP option rewrite
重写TCP选项
全局TCP时间戳生效动作,包括:
·     Preserve:保持
·     Rewrite:重写
·     Remove:删除
当动作后有(*)时,表示全局TCP时间戳选项的配置生效,否则表示参数模板下配置的TCP时间戳选项生效
Origin host
源主机名
Origin realm
源域名
Vendor Id
厂商ID
Product name
产品名称
Host ip/Host ipv6
主机IPv4地址或IPv6地址
Retransmission
是否开启Diameter数据报文重传功能,包括:
·     Disabled:关闭
·     Enabled:开启
Diameter数据报文重传超时时间
CE timeout
Diameter协商超时时间
1.1.63  display real-server
display real-server命令用来显示实服务器或实服务组成员的信息。
display real-server [ brief | name real-server-name ]
display real-server server-farm server-farm-name [ name real-server-name port port-number ]
context-admin
context-operator
vsys-admin
vsys-operator
brief:显示实服务器的简要信息。如果未指定本参数,将显示实服务器的详细信息。
name real-server-name:显示指定实服务器的信息。real-server-name为实服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器的信息。
server-farm server-farm-name:显示指定实服务组下实服务器组成员的信息。server-farm-name为实服务组的名称,为1~255个字符的字符串,不区分大小写。
name real-server-name port port-number:显示指定名称及端口的实服务组成员的信息。real-server-name表示实服务组成员的名称,为1~255个字符的字符串,不区分大小写。port-number表示实服务组成员的端口,取值范围为0~65535。如果未指定本参数,将显示指定实服务组下的所有实服务组成员的信息。
# 显示所有实服务器的简要信息。
<Sysname> display real-server brief
Real server      Address/domain              Port  State     VPN instance     Server farm
rs1              192.168.1.1                 0     Active                    sf
rs2              192.168.1.2                 0     Busy                      sf
rs3              192.168.1.3                 0     Active                    sf
rs4              www.example.com             0     Active                    sf
# 显示实服务器rs的详细信息。
<Sysname> display real-server name rs
Real server: rs
  Description: Real server RS
  State: Active
  Domain name:
  VPN instance:
  Inherit VPN: Disabled
  IPv4 address: 1.1.1.1
  IPv6 address: 1001::1
  Port: 0 (port number in original packet)
  Server farm: sf
  Weight: 150
  Priority: 3
  Cost: 100
  Slow shutdown: Enabled
  Slow offline: Disabled
  Connection limit: 10000
  Rate limit:
    Connections: 10000
    Bandwidth: 10000 kbps
    Inbound bandwidth: 5000 kbps
    Outbound bandwidth: 5000 kbps
  Bandwidth busy:
    Max bandwidth: 10000 kbps
    Max inbound bandwidth: 5000 kbps
    Max outbound bandwidth: 5000 kbps
    Busy rate: 80
    Inbound busy rate: 70
    Outbound busy rate: 60
    Busy recovery rate: 60
    Inbound busy recovery rate: 60
    Outbound busy recovery rate: 60
  Probe log: Enabled
  Probe information:
    Dynamic weight: 1
    SNMPDCA busy state: Normal
    Probe success criteria: All
    Probe method                    State
    t4                              Succeeded
    External-monitor method         State
    test_external                   Succeeded
    test_external2                  Succeeded
    Database Probe method              State
    ora1(database)                     Succeeded
  Reference count: 1
# 显示实服务器组sf下所有实服务器组成员的信息。
<Sysname> display real-server server-farm sf
Server farm: sf
  Real server: rs1
    Description: real server 1
    Parent state: Inactive
    State: Inactive
    Port: 2
    Weight: 2
    Priority: 2
    Slow shutdown: Disabled
    Manual recover: Disabled
    Connection limit: --
    Connection rate limit: --
    Probe log: Enabled
    Probe information:
      Dynamic weight: --
      SNMPDCA busy state: --
      Probe method                       State
      icmp                               Failed
      ora1                               Invalid
    Probe template information:
      TCP RST probe template: rst
        Probe result: Normal
      TCP zero-window probe template:
      HTTP passive probe template:
  Real server: rs2
    Description: real server 2
    State: Inactive
    Port: 80
    Weight: 100
    Priority: 4
    Probe log: Enabled
    Probe information:
      Dynamic weight: 1
      Probe method                       State
      tcp                                Failed
      TCP zero-window probe template: zero
    Variable information:
      Variable name: variable
      Variable value: 2
表1-23 display real-server命令显示信息描述表
Real server
实服务器的名称
Address/domain
实服务器的IPv4地址、IPv6地址或者域名
Port
实服务器的端口号,0表示继续使用原报文携带的端口号
Domain name
实服务器配置的域名
Parent state/State
Parent state表示实服务器的状态,State表示实服务组成员状态,包括:
·     Active:可用
·     Busy:繁忙(当实服务器处于Active或Ramp状态,且开启接口获取带宽功能和繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·     Inactive:不可用(由于配置不完全、未被引用或虚服务器尚未开启)
·     Probe-failed:健康检测失败
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
·     Unknown:未配置健康检测
·     Auto shutdown:自动关闭(当实服务组引用负载均衡探测模板,探测结果达到配置的阈值或超过繁忙保护次数时,实服务组成员状态显示自动关闭)
·     Slowoffline:平滑退出状态,实服务器/实服务组成员开启平滑退出功能,且实服务器/实服务器组/实服务组成员下未引用任何健康检测
·     Shutdown (Probe-success):无活动连接的平滑退出状态,健康检测成功(实服务器/实服务组成员开启平滑退出功能,当暂无任何连接,其健康检测结果为成功时,显示该状态)
·     Shutdown (Probe-failed):无活动连接的平滑退出状态,健康检测失败(实服务器/实服务组成员开启平滑退出功能,当暂无任何连接,其健康检测结果为失败时,显示该状态)
·     Slowoffline (Probe-success):有活动连接平滑退出状态,健康检测成功(实服务器/实服务组成员开启平滑退出功能,当建立了连接,其健康检测结果为成功时,显示该状态)
·     Slowoffline (Probe-failed):有活动连接平滑退出状态,健康检测失败(实服务器/实服务组成员开启平滑退出功能,当建立了连接,其健康检测结果为失败时,显示该状态)
VPN instance
实服务器所属的VPN实例名称
Inherit VPN
实服务器所属VPN实例继承功能的状态,包括:
·     Enabled:开启
·     Disabled:关闭
Server farm
实服务器所属的实服务组
实服务器的描述信息
IPv4 address
实服务器的IPv4地址
IPv6 address
实服务器的IPv6地址
Weight
实服务器的权值
Priority
实服务器的调用优先级
Cost
就近性计算的成本
Slow shutdown
实服务器慢宕功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Slow offline
实服务器平滑退出功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Connection limit
实服务器所允许的最大连接数
实服务器所允许的最大连接速率
Rate limit
实服务器的速率限制
Connections
实服务器所允许的最大连接速率
Bandwidth
实服务器所允许的最大总带宽,单位为kbps
Inbound bandwidth
实服务器所允许的最大上行带宽,单位为kbps
Outbound bandwidth
实服务器所允许的最大下行带宽,单位为kbps
Max bandwidth
实服务器繁忙所允许的最大总带宽,单位为kbps
实服务器繁忙所允许的最大上行带宽,单位为kbps
实服务器繁忙所允许的最大下行带宽,单位为kbps
Busy rate
实服务器所允许的总带宽繁忙比
Inbound busy rate
实服务器所允许的上行带宽繁忙比
Outbound busy rate
实服务器所允许的下行带宽繁忙比
Busy recovery rate
实服务器所允许的总带宽繁忙恢复比
实服务器所允许的上行带宽繁忙恢复比
实服务器所允许的下行带宽繁忙恢复比
Dynamic weight
动态反馈算法所计算的动态权值,只有动态反馈算法生效后该值有效,否则显示“--”
SNMPDCA busy state
动态反馈算法所获取的实服务器的繁忙状态,只有动态反馈算法生效后该值有效,否则显示“--”,包括:
·     Normal:实服务器处于正常状态
·     Busy:实服务器处于繁忙状态
Probe log
实服务器健康检测日志的状态,包括:
·     Disabled:关闭
·     Enabled:开启
实服务器健康检测的成功条件:
·     All:只有全部方法都通过检测才认为健康检测成功
·     At least X:健康检测成功所需通过检测的最少方法数为X
Probe method
健康检测方法所使用的NQA模板名称
自定义监控和NQA健康检测方法的状态,包括:
·     Failed:健康检测失败
·     In progress:正在进行健康检测
·     Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者实服务器不可用
·     Succeeded:健康检测成功
·     Undetected:由于NQA健康检测速率限制,NQA健康检测未启动
自定义监控方法
(暂不支持)数据库类型探测模板
TCP RST类型的负载均衡探测模板名称
TCP zero-window类型的负载均衡探测模板名称
HTTP passive类型的负载均衡探测模板名称
Probe result
TCP RST类型、TCP zero-window类型和HTTP passive类型负载均衡探测模板的探测结果,包括:
·     Normal:实服务组成员处于正常状态
·     Busy:实服务组成员处于繁忙状态
·     Slowdown:实服务组成员处于慢宕状态
Manual recover
实服务器组中成员的健康检测手动恢复功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
实服务组成员关联的变量信息
Variable name
变量名称
Variable value
变量的值
Reference count
被引用次数
1.1.64  display real-server statistics
display real-server statistics命令用来显示实服务器或实服务器组成员的统计信息。
display real-server statistics [ name real-server-name ] [ slot slot-number ]
display real-server statistics server-farm server-farm-name [ name real-server-name port port-number ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
name real-server-name:显示指定实服务器的统计信息。real-server-name为实服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器的统计信息。
server-farm server-farm-name:显示指定实服务器组下实服务器组成员的统计信息。server-farm-name表示实服务器组的名称,为1~255个字符的字符串,不区分大小写。
name real-server-name port port-number:显示指定名称及端口的实服务器组成员的统计信息。real-server-name表示实服务器组成员的名称,为1~255个字符的字符串,不区分大小写。port-number表示实服务器组成员的端口,取值范围为0~65535。如果未指定本参数,将显示指定实服务器组下所有实服务器组成员的统计信息。
# 显示实服务器rs的统计信息。
<Sysname> display real-server statistics name rs
Real server: rs
  Total connections: 1798
  Active connections: 788
  Max connections: 803
    recorded at 11:02:49 on Tue May 21 2019
  Connections per second: 157
  Max connections per second: 163
  Server input: 333332 bytes
  Server output: 472054 bytes
  Throughput: 4396 bps
  Inbound throughput: 1214 bps
  Outbound throughput: 3128 bps
  Max throughput: 4564 bps
  Max inbound throughput: 1214 bps
  Max outbound throughput: 3320 bps
  Received packets: 1798
  Sent packets: 0
  Dropped packets: 0
  Received packets per second: 0
  Sent packets per second: 0
  Received requests: 0
  Dropped requests: 0
  Sent responses: 0
  Dropped responses: 0
  Connection failures: 1
  Busy state: Busy
# 显示实服务器组sf下所有实服务器组成员的统计信息。
<Sysname> display real-server statistics server-farm sf
Server farm: sf
  Real server: rs1
    Max connections: 0
    Max connections per second: 0
    Server input: 0 bytes
    Server output: 0 bytes
    Throughput: 0 bps
    Inbound throughput: 0 bps
    Outbound throughput: 0 bps
    Max throughput: 0 bps
    Max inbound throughput: 0 bps
    Max outbound throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
    Dropped requests: 0
    Sent responses: 0
    Connection failures: 0
    RST packets: 50
    Max RST packets: 5000
    RST probe protection times: 3
    Max RST probe protection times: 9
    Zero-window packet percentage: 10
    Max zero-window packet percentage: 50
    Zero-window probe protection times: 2
    Max zero-window probe protection times: 8
    Abnormal url times: 10
    Max abnormal url times: 20
  Real server: rs2
    Max connections: 0
    Throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
    Dropped requests: 0
    Sent responses: 0
    RST packets: 50
表1-24 display real-server statistics命令显示信息描述表
Real server
实服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Server input
服务器收到的流量,单位为字节
Server output
服务器发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
Received packets
收到的报文数
Sent packets
发出的报文数
Dropped packets
丢弃的报文数
每秒收到的报文数
每秒发出的报文数(虚服务器发给客户端的)
Received requests
接收的HTTP请求报文数量,只有七层实服务器才会显示本字段
Dropped requests
丢弃的HTTP请求报文数量,只有七层实服务器才会显示本字段
Sent responses
发出的HTTP应答报文数量,只有七层实服务器才会显示本字段
Dropped responses
丢弃的HTTP应答报文数量,只有七层实服务器才会显示本字段
Connection failures
建立连接失败
Busy state
实服务器的状态,包括:
·     --:健康检测失败或未进行有效关联
·     Normal:正常
·     Busy:繁忙
RST packets
监控周期内,实服务器发出的RST报文的总数
Max RST packets
监控周期内,实服务器发出的RST报文的历史最大数目
RST类型负载均衡探测模板的繁忙保护次数
RST类型负载均衡探测模板的最大繁忙保护次数
监控周期内,实服务器发出的零窗口报文的百分比
监控周期内,实服务器发出的零窗口报文的历史最大百分比
zero-window类型负载均衡探测模板的繁忙保护次数
zero-window类型负载均衡探测模板的最大繁忙保护次数
Abnormal url times
监控周期内,URL异常的总次数
监控周期内,URL异常的历史最大次数
·     reset real-server statistics
1.1.65  display real-server overall-statistics
display real-server overall-statistics命令用来显示设备整机实服务器或实服务器组成员的统计信息。
display real-server overall-statistics [ name real-server-name ] [ slot slot-number [ cpu cpu-number ] ]
display real-server overall-statistics server-farm server-farm-name [ name real-server-name port port-number ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
vsys-admin
vsys-operator
name real-server-name:显示指定实服务器的统计信息。real-server-name为实服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器的统计信息。
cpu cpu-number:显示指定CPU上的信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
# 显示实服务器rs的统计信息
<Sysname> display real-server overall-statistics name rs
Real server: rs
  Total connections: 356578
  Max connections: 37,
    recorded at: 08:46:22 on Wed Apr 13 2022
  Max connections per second: 6759,
    recorded at: 08:46:04 on Wed Apr 13 2022
  Server input: 88075301 bytes
  Server output: 115531472 bytes
  Throughput: 0 bps
  Max throughput: 28337024 bps,
    recorded at: 08:46:19 on Wed Apr 13 2022
  Max inbound throughput: 13176880 bps,
    recorded at: 08:46:05 on Wed Apr 13 2022
  Max outbound throughput: 17375712 bps,
  Received packets: 1426317
  Sent packets: 713161
  Dropped packets: 0
  Received requests: 356578
  Dropped requests: 0
  Sent responses: 356578
  Busy state: --
# 显示实服务组sf下所有实服务器组成员的统计信息
<Sysname> display real-server overall-statistics server-farm sf
Server farm: sf
  Real server (port: 443): rs
    Max connections: 0
    Throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
    Dropped requests: 0
    Sent responses: 0
    RST packets: 50
表1-25 display real-server overall-statistics命令显示信息描述表
Real server
实服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Server input
服务器收到的流量,单位为字节
Server output
服务器发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
Received packets
收到的报文数
Sent packets
发出的报文数
Dropped packets
丢弃的报文数
每秒收到的报文数
Received requests
Dropped requests
Sent responses
Dropped responses
Connection failures
建立连接失败
Busy state
实服务器的状态,包括:
·     --:不可用
·     Normal:正常
·     Busy:繁忙
RST packets
Max RST packets
Abnormal url times
监控周期内,URL异常的总次数
监控周期内,URL异常的历史最大次数
·     display real-server statistics
1.1.66  display server-farm
display server-farm命令用来显示实服务组的信息。
display server-farm [ brief | name server-farm-name ]
context-admin
context-operator
vsys-admin
vsys-operator
brief:显示实服务组的简要信息。如果未指定本参数,将显示实服务组的详细信息。
name server-farm-name:显示指定实服务组的信息。server-farm-name为实服务组的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务组的信息。
# 显示所有实服务组的简要信息。
<Sysname> display server-farm brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           LCM - Least connection member,
           BW – Bandwidth, MBW – Max bandwidth,
           IBW – Inbound bandwidth, OBW – Outbound bandwidth,
           MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port
           LT - Least time, LTM - Least time member,
           DRR - Dynamic round robin
           CARP(SIP) - CARP address source IP
           CARP(DIP) - CARP address destination IP
           CARP(SIP-PORT) - CARP address source IP-port
           CARP(HTTP) - CARP HTTP payload
           HASH(HTTP) - Hash HTTP payload
           OM – Observed member, PM – Predictive member
NAT/SNAT: Y - Enabled, N - Disabled
Server farm       Predictor       NAT  SNAT  Total  Active
sf                RR              Y    N     3      3
# 显示所有实服务组的详细信息。
Server farm: sf1
  Description:
  Predictor: Hash address
  Proximity: Disabled
  NAT: Enabled
  SNAT mode: snat-pool sp
  Failed action: Keep
  Active threshold: Enabled
    Lower: 80
    Upper: 90
  Slow-online: Enabled
  Standby time: 5s
  Ramp-up time: 10s
  Selected server: Enabled
    Min server: 100
    Max server: 600
  Busy action: Enqueue
    Queue length: 11
    Queue timeout: 12
  Probe information:
    Probe method:
    aaa
    bbb
    ccc
    External-monitor method:
    Database Probe method:
  TCP RST probe template: aaa
  TCP zero-window probe template: bbb
  HTTP passive probe template: ccc
  Auto-shutdown recovery time: 30
  All-service-down action: Forward
    Forwarded to member: rs1
  Total real server: 1
  Active real server: 1
  Reference count: 1
  Real server list: (* : waiting for manual recover)
  Name      State         VPN instance     Address/Domain name    Port  Weight Priority  LT-weight
  rs1     Inactive                   1.2.3.4              0    100    4        50
  rs2     Auto shutdown              1.2.3.4              0    100    4        50
  rs3     Active                     www.example.com      0    100    4        50
  Temporary real server list : (* : waiting for manual recover)
  Name         State         Address              Port  Real server  Domain name
  auto_1.1.1.1 Active        1.1.1.1                    rs1          www.example1.com
  auto_2.2.2.2 Inactive      2.2.2.2                    rs2          www.example2.com
表1-26 display server-farm命令显示信息描述表
Server farm
实服务组的名称
Predictor
实服务组的调度算法,包括:
·     RR:加权轮转算法
·     RD:随机算法
·     LC:加权最小连接算法
·     LCM:基于实服务器组成员的加权最小连接算法
·     BW:总带宽算法
·     IBW:入方向带宽算法
·     OBW:出方向带宽算法
·     MBW:最大总带宽算法
·     MIBW:最大入方向带宽算法
·     MOBW:最大出方向带宽算法
·     HASH(SIP):根据源IP地址进行的哈希算法
·     HASH(DIP):根据目的IP地址进行的哈希算法
·     HASH(SIP-PORT):根据源IP地址和端口号进行的哈希算法
·     LT:最快响应算法
·     LTM:基于实服务组成员的最快响应算法
·     DRR:动态反馈算法
·     CARP(SIP):根据源IP地址进行的CARP哈希算法
·     CARP(DIP):根据目的IP地址进行的CARP哈希算法
·     CARP(SIP-PORT):根据源IP地址和端口号进行的CARP哈希算法
·     CARP(HTTP):基于HTTP载荷进行的CARP哈希算法
·     HASH(HTTP):基于HTTP载荷进行的哈希算法
·     OM:流量观察算法
·     PM:流量预测算法
Manual recover
实服务器组中健康检测手动恢复功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
NAT
实服务组中NAT功能的状态,Y表示开启,N表示关闭
SNAT
实服务组中SNAT功能的状态,Y表示开启,N表示关闭
Total
包含的实服务器数量
Active
活跃的实服务器数量
实服务组的描述信息
Predictor
实服务组的调度算法,包括:
·     Round robin:加权轮转算法
·     Random:随机算法
·     Least connection:加权最小连接算法
·     Least connection member:基于实服务器组成员的加权最小连接算法
·     Bandwidth:总带宽算法
·     Inbound bandwidth:入方向带宽算法
·     Outbound bandwidth:出方向带宽算法
·     Max bandwidth:最大总带宽算法
·     Max inbound bandwidth:最大入方向带宽算法
·     Max outbound bandwidth:最大出方向带宽算法
·     Hash address source IP:根据源IP地址进行的哈希算法
·     Hash address source IP-port:根据源IP地址和端口号进行的哈希算法
·     Hash address destination IP:根据目的IP地址进行的哈希算法
·     Least time:最快响应算法
·     Least time member:基于实服务组成员的最快响应算法
·     Dynamic round robin:动态反馈算法
·     CARP address source IP:根据源IP地址进行的CARP哈希算法
·     CARP address source IP-port:根据源IP地址和端口号进行的CARP哈希算法
·     CARP address destination IP:根据目的IP地址进行的CARP哈希算法
·     CARP HTTP:基于HTTP载荷进行的CARP哈希算法
·     Hash HTTP:基于HTTP载荷进行的哈希算法
·     Observed member:流量观察算法
·     Predictive member:流量预测算法
Proximity
实服务器组中就近性功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
NAT
实服务组中NAT功能的状态,包括:
·     Disabled:关闭(未配置NAT功能)
·     Enabled:开启
·     Disabled (no license):因缺少License,NAT功能未使能
SNAT mode
SNAT地址转换方式,包括:
·     auto-map:自动映射方式
·     tcp-option:TCP Option方式
·     snat-pool pool-name:SNAT地址池方式,将报文的源地址转换为SNAT地址池pool-name中的地址
Failed action
实服务组的故障处理方式,包括:
·     Keep:保持已有连接
·     Reschedule:重定向连接
·     Reset:断开已有连接
Active threshold
实服务组可用条件的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Lower:最小可用百分比
·     Upper:最大可用百分比
Slow-online
实服务组中实服务器温暖上线功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Standby time:准备时间
·     Ramp-up time:爬升时间
Selected server
实服务组中可被调度算法调用的实服务器数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Min server:可被调度算法调用的实服务器最小数量
·     Max server:可被调度算法调用的实服务器最大数量
Busy action
实服务器组的繁忙处理方式,包括:
·     Drop:调度失败
·     Enqueue:排队等待
·     Force:强制调度
Queue length
队列长度
只有繁忙处理方式为排队等待时才会显示本字段
Queue timeout
队列老化时间,单位为秒
实服务器健康检测的成功条件:
·     At least x:健康检测成功所需通过检测的最少方法数为x
Probe method
健康检测方法所使用的NQA模板名称
自定义监控探测模板名称
(暂不支持)数据库类型的负载均衡探测模板名称
查找所有可用实服务组成员失败时的处理方式,包括:
·     --:缺省方式,即丢弃报文
·     Forward:将流量转发给最近一次选中的实服务组成员
Forwarded to member
查找所有可用实服务组成员失败时,将流量转发给指定名称的实服务组成员
Total real server
包含的实服务器数量
Active real server
活跃的实服务器数量
Reference count
被引用次数
Real server list
实服务器列表
Name
实服务器的名称
实服务器的状态,包括:
·     Active:可用
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
·     Unknown:未知(未配置健康检测)
Address/Domain name
实服务器的IPv4、IPv6地址或者域名
Port
实服务器的端口号
Weight
实服务器的权值
Priority
实服务器的调用优先级
LT-weight
最快响应算法计算的权值,仅当调度算法为最快响应算法时生效,无效时显示”--”
临时实服务器列表
Real server
临时实服务器所属的实服务器名称
Domain name
临时实服务器所属的域名
实服务组引用的TCP RST类型的负载均衡探测模板
只有引用了TCP RST类型的负载均衡探测模板才会显示本字段
实服务组引用的TCP zero-window类型的负载均衡探测模板
只有引用了TCP zero-window类型的负载均衡探测模板才会显示本字段
实服务组引用的HTTP passive类型的负载均衡探测模板
只有引用了HTTP passive类型的负载均衡探测模板才会显示本字段
实服务组的智能监控自动恢复时间,单位为分钟
1.1.67  display sticky statistics
display sticky statistics命令用来显示持续性表项的统计信息。
display sticky statistics [ dns-proxy | virtual-server ] [ slot slot-number ]
context-admin
context-operator
dns-proxy:显示DNS透明代理的持续性表项统计信息。
virtual-server:显示虚服务器的持续性表项统计信息。
若未指定dns-proxy和virtual-server参数,则显示所有持续性表项的统计信息。
# 显示虚服务器的持续性表项统计信息。
<Sysname> display sticky statistics virtual-server
Virtual server:
Total sticky entries for all sticky types: 27000
  Sticky type     Sticky method     Total sticky entries     Synced sticky entries
  Address-port                      12000                    120
                  Src IP            100                      10
                  Src IPv6          100                      10
                  Dst IP            100                      10
                  Dst IPv6          100                      10
                  Both IP           100                      10
                  Both IPv6         100                      10
                  Src IP port       100                      10
                  Src IPv6 port     100                      10
                  Dst IP port       100                      10
                  Dst IPv6 port     100                      10
                  Both IP port      100                      10
                  Both IPv6 port    100                      10
  HTTP header                       5000                     50
                  HTTP version      100                      10
                  HTTP URL          100                      10
                  HTTP method       100                      10
                  HTTP host         100                      10
                  Header name       100                      10
  HTTP cookie     Cookie get        100                      10
  HTTP content    HTTP content      100                      10
  Payload         Payload           100                      10
  SSL             SSL session       100                      10
  RADIUS          Attribute ID      200                      20
  SIP             SIP Call-ID       100                      10
  HTTP passive    HTTP Passive      100                      10
  UDP passive     Payload Passive   100                      10
  TCP payload     TCP Payload       100                      10
  Diameter        Attribute ID      100                      10
# 显示DNS透明代理的持续性表项统计信息。
<Sysname> display sticky statistics dns-proxy
DNS proxy:
Total sticky entries for all sticky types: 12000
                  Src IP            100                      10
                  Src IPv6          100                      10
                  Dst IP            100                      10
                  Dst IPv6          100                      10
                  Both IP           100                      10
                  Both IPv6         100                      10
                  Src IP port       100                      10
                  Dst IP port       100                      10
                  Both IP port      100                      10
表1-27 display sticky statistics命令显示信息描述表
Sticky type
持续性组的类型,包括:
·     Address-port:表示地址端口类型
·     HTTP content:表示HTTP实体类型
·     HTTP cookie:表示HTTP Cookie类型
·     HTTP header:表示HTTP首部类型
·     HTTP passive:表示HTTP Passive类型
·     Payload:表示HTTP载荷或UDP载荷类型
·     RADIUS:表示RADIUS类型
·     SIP:表示SIP类型
·     SSL:表示SSL类型
·     TCP payload:表示TCP载荷类型
·     UDP passive:表示UDP Passive类型
Sticky method
该持续性表项对应的持续性方法,包括:
·     Src IP:源IPv4地址持续性方法
·     Src IPv6:源IPv6地址持续性方法
·     Src IP port:源IPv4地址+源端口持续性方法
·     Src IPv6 port:源IPv6地址+源端口持续性方法
·     Dst IP:目的IPv4地址持续性方法
·     Dst IPv6:目的IPv6地址持续性方法
·     Dst IP port:目的IPv4地址+目的端口持续性方法
·     Dst IPv6 port:目的IPv6地址+目的端口持续性方法
·     Both IP:源IPv4地址+目的IPv4地址持续性方法
·     Both IPv6:源IPv6地址+目的IPv6地址持续性方法
·     Both IP port:源IPv4地址+源端口+目的IPv4地址+目的端口持续性方法
·     Both IPv6 port:源IPv6地址+源端口+目的IPv6地址+目的端口持续性方法
·     HTTP URL:基于HTTP URL的持续性方法
·     Header name:基于HTTP首部名称的持续性方法
·     HTTP version:基于HTTP版本的持续性方法
·     HTTP host:基于HTTP主机的持续性方法
·     HTTP method:基于HTTP Request-Method的持续性方法
·     HTTP content:HTTP实体持续性方法
·     Cookie get:HTTP Cookie截取持续性方法
·     Payload:HTTP载荷或UDP载荷持续性方法
·     HTTP passive:HTTP被动持续性方法
·     Payload passive:UDP载荷被动持续性方法
·     TCP payload:TCP载荷持续性方法
·     RADIUS IP:基于RADIUS报文Framed-IP-Address属性的持续性方法
·     RADIUS ID:基于RADIUS报文中指定属性的持续性方法
·     SIP Call-ID:基于SIP信令报文Call ID的持续性方法
·     SSL session ID:SSL持续性方法为基于SSL会话ID
·     Attribute ID:基于Diameter报文中指定属性的持续性方法
持续性表项总数
同步自其他设备或本设备其他板卡的持续性表项数量
1.1.68  display sticky virtual-server
display sticky virtual-server命令用来显示虚服务器的持续性表项信息。
display sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | client-port port-number | sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ traffic-group traffic-group-id ] [ brief ] [ slot slot-number ]
context-admin
context-operator
virtual-server-name virtual-server-name:显示指定虚服务器的持续性表项信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定virtual-server-name,将显示所有虚服务器的持续性表项信息。
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }:显示指定链路的持续性表项信息。ip ipv4-address表示链路的IPv4地址,ipv6 ipv6-address表示链路的IPv6地址,interface interface-type interface-number表示链路对应的出接口,interface-type为接口类型,interface-number为接口编号,interface-name为接口名称。
link-group link-group-name:显示指定链路组的持续性表项信息。link-group-name为链路组的名称,为1~255个字符的字符串,不区分大小写。
real-server-addr { ipv4-address | ipv6-address }:显示指定实服务器地址的持续性表项信息。ipv4-address表示实服务器的IPv4地址,ipv6-address表示实服务器的IPv6地址。
real-server-port port-number:显示指定实服务器端口的持续性表项信息。port-number为实服务器的端口号,取值范围0~65535。
server-farm server-farm-name:显示指定实服务组的持续性表项信息。server-farm-name为实服务组的名称,为1~255个字符的字符串,不区分大小写。
text text:显示指定匹配内容的持续性表项信息。text为持续性表项的匹配内容,为1~63个字符的字符串,区分大小写。
class { class-name | default-class }:显示指定负载均衡类的持续性表项信息。class-name为负载均衡类的名称,为1~255个字符的字符串,不区分大小写。default-class
表示缺省负载均衡类。
client-addr { ipv4-address | ipv6-address }:显示指定客户端地址的持续性表项信息。ipv4-address表示客户端的IPv4地址,ipv6-address表示客户端的IPv6地址。
client-port port-number:显示指定客户端端口的持续性表项信息。port-number为客户端的端口号,取值范围0~65535。
sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }:显示指定类型持续性组的持续性表项信息,包括Diameter、地址端口、HTTP实体、HTTP Cookie、HTTP首部、HTTP passive、HTTP/UDP载荷、RADIUS、SIP、SSL、TCP载荷和UDP passive。
key sticky-key:显示指定Key值的持续性表项。sticky-key为持续性表项的Key值,为1~127个字符的字符串,区分大小写。若未指定本参数,则表示显示所有Key值的持续性表项。
traffic-group traffic-group-id:显示指定集群流量组的持续性表项。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示显示所有集群流量组的持续性表项。
brief:显示虚服务器持续性表项的简要信息。如果未指定本参数,将显示虚服务器持续性表项的详细信息。
# 显示所有虚服务器持续性表项的详细信息。
<Sysname> display sticky virtual-server
  Virtual server name: vs
  Cluster traffic group: 1
  Server farm name: sf
  Class: cla
  Sticky type: Address-port
  Sticky method: Source IP
  Sticky key: 3.0.0.13
  Virtual server addr: 33.44.1.1:80
  Real server addr: 7.0.0.7:80
  Client addr: 3.0.0.13
  Timeout: 100 sec
  Expiration time: 58 sec
  Matching sessions: 1
  Virtual server name: vs1
  Server farm name: sf_http
  Class: Default Class
  Sticky type: HTTP header
  Sticky method: HTTP header name
  Sticky key: cb3bae31bb1c443fbf3db8889055f2fe
  Text: a1b2c3d4e5
  Virtual server addr: 33.44.1.2:80
  Timeout: 100 sec
  Virtual server name: vs2
  Link group name: lg
  Class: cl2
  Sticky key: 3.0.0.15
  Virtual server addr: 0.0.0.0:0
  link: 20.1.1.1
  Client addr: 3.0.0.15
  Timeout: 100 sec
# 显示所有虚服务器持续性表项的简要信息。
<Sysname> display sticky virtual-server brief
Sticky type    Sticky method    Sticky key      Virtual server      Real-server/link
Address-port   Src IP           3.0.0.13        vs                  7.0.0.7:80
Address-port   Src IP           3.0.0.15        vs2                 20.1.1.1
表1-28 display sticky virtual-server命令显示信息描述表
Virtual server name
虚服务器名称
集群流量组的编号
Server farm name
实服务组名称
Sticky group name
生成该持续性表项的持续性组名称
Sticky type
持续性组的类型,包括:
·     RADIUS:表示RADIUS类型
·     SIP:表示SIP类型
·     SSL:表示SSL类型
Sticky method
该持续性表项对应的持续性方法,包括:
·     Framed-IP-Address:基于RADIUS报文Framed-IP-Address属性的持续性方法
·     User-Name:基于RADIUS报文中User-Name属性的持续性方法
·     Code=attribute-code:基于RADIUS报文中指定属性的持续性方法,属性编号为attribute-code
Sticky key
持续性表项的Key值
Text
持续性表项的匹配内容
Virtual server addr
虚服务器地址端口
Real server addr
实服务器地址端口
Server farm name
实服务组名称
link
链路下一跳或出接口
Link group name
链路组名称
Class
负载均衡类,包括:
·     负载均衡类名称
·     Default Class:缺省负载均衡类
Client addr
客户端地址
Timeout
持续性表项的超时时间,单位为秒,indefinite表示不老化
Expiration time
持续性表项的老化剩余时间,单位为秒
Matching sessions
匹配该持续性表项的会话数量
HTTP Cookie插入和重写持续性方法对应的持续性表项不显示本字段
1.1.69  display sticky-group
display sticky-group命令用来显示持续性组的信息。
display sticky-group [ name group-name ]
context-admin
context-operator
vsys-admin
vsys-operator
name group-name:显示指定持续性组的信息。group-name为持续性组的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有持续性组的信息。
# 显示所有持续性组的信息。
<Sysname> display sticky-group
Sticky group: sg1
  Description:
  Timeout: 60
  Override limit: Disabled
  Stickiness-over-busyness: Enabled
  Matching across services: Enabled
  Matching across virtual servers: Enabled
  Sticky group type: Address-port
    Method: Both IP and port
      Mask: 32
  Reference count: 1
Sticky group: sg2
  Description:
  Timeout: 60
  Sticky group type: HTTP header
    Method: HTTP header name
      Offset: 4
      Start: gzip
      Length: 10
  Reference count: 1
Sticky group: sg3
  Description:
  Timeout: 60
  Sticky group type: RADIUS
    Method: User-Name
  Reference count: 1
Sticky group: sg4
  Description:
  Timeout: 86400
  Stickiness-over-busyness: Disabled
  Sticky group type: HTTP cookie
    Method: HTTP cookie insert
      Domain: example.com
      Path: /test1
      HttpOnly: Enabled
      Secure: Enabled
  Check all packets: Disabled
  Reference count: 1
Sticky group: sg5
  Description:
  Timeout: 60
  Sticky group type: Diameter
    Method: attribute-code
      Code: 263, Index: 0
      Code: 283, Index: 0
  Reference count: 1
表1-29 display sticky-group命令显示信息描述表
Sticky group
持续性组的名称
持续性组的描述信息
Timeout
持续性表项的超时时间,单位为秒。Indefinite表示持续性表项不老化
Override limit
匹配持续性表项的会话不受连接数限制功能的状态,包括:
·     Disabled:关闭,即匹配持续性表项的会话受连接数限制
·     Enabled:开启,即匹配持续性表项的会话不受连接数限制
持续性处理优先于繁忙功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
跨服务匹配持续性表项功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
跨虚服务器匹配持续性表项功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Sticky group type
持续性组的类型,包括:
·     HTTP passive:表示HTTP passive类型
·     RADIUS:表示RADIUS类型
·     SIP:表示SIP类型
·     SSL:表示SSL类型
·     UDP passive:表示UDP passive类型
·     Diameter:表示Diameter类型
各类型持续性组的具体内容,请参见表1-30
Reference count
被引用次数
表1-30 各类型持续性组的具体内容
持续性组类型
Address-port
·     Method:持续性方法,包括:
¡     Source IP:源IPv4地址持续性方法
¡     Source IPv6:源IPv6地址持续性方法
¡     Source IP and port:源IPv4地址+源端口持续性方法
¡     Source IPv6 and port:源IPv6地址+源端口持续性方法
¡     Destination IP:目的IPv4地址持续性方法
¡     Destination IPv6:目的IPv6地址持续性方法
¡     Destination IP and port:目的IPv4地址+目的端口持续性方法
¡     Destination IPv6 and port:目的IPv6地址+目的端口持续性方法
¡     Both IP:源IPv4地址+目的IPv4地址持续性方法
¡     Both IPv6:源IPv6地址+目的IPv6地址持续性方法
¡     Both IP and port:源IPv4地址+源端口+目的IPv4地址+目的端口持续性方法
¡     Both IPv6 and port:源IPv6地址+源端口+目的IPv6地址+目的端口持续性方法
·     Mask:持续性方法的掩码长度,只有IPv4持续性方法才会显示本字段
·     Prefix:持续性方法的前缀长度,只有IPv6持续性方法才会显示本字段
HTTP content
·     Offset:实体基于HTTP报文起始位置的偏移量
·     Start:实体开始标记的正则表达式
·     End:实体结束标记的正则表达式,不会与Length字段同时显示
·     Length:实体的长度,不会与End字段同时显示
HTTP cookie
·     Method:持续性方法,包括:
¡     HTTP cookie insert:Cookie截取持续性方法
¡     HTTP cookie rewrite:Cookie重写持续性方法
¡     HTTP cookie get:Cookie插入持续性方法
·     Name:HTTP cookie的名称。只有指定了HTTP Cookie持续性方法才会显示本字段
·     Domain:HTTP Cookie的作用域域名。只有指定了Cookie插入持续性方法才会显示本字段。
·     Path:HTTP Cookie的作用路径。只有指定了Cookie插入持续性方法才会显示本字段。
·     Offset:Cookie基于Cookie值起始位置的偏移量。只有指定了Cookie插入持续性方法才会显示本字段
·     Start:Cookie开始标记的正则表达式。只有指定了Cookie插入持续性方法才会显示本字段
·     End:Cookie结束标记的正则表达式,不会与Length字段同时显示。只有指定了Cookie插入持续性方法才会显示本字段
·     Length:Cookie的长度,不会与End字段同时显示。只有指定了Cookie插入持续性方法才会显示本字段
·     Cookie secondary name:需在URI中查找的Secondary Cookie名称。只有指定了Cookie插入持续性方法才会显示本字段
·     HttpOnly:是否配置HttpOnly功能,只有指定了Cookie插入或重写持续性方法才会显示本字段
¡     Disabled:关闭
¡     Enabled:开启
·     Secure:是否配置Secure功能,只有指定了Cookie插入或重写持续性方法才会显示本字段
¡     Disabled:关闭
¡     Enabled:开启
·     Check all packets:是否开启检查所有报文的功能,包括:
¡     Disabled:关闭
¡     Enabled:开启
HTTP header
·     Method:持续性方法,包括:
¡     HTTP host:基于HTTP主机的持续性方法
¡     HTTP header name:基于HTTP首部名称的持续性方法
¡     HTTP method:基于HTTP Request-Method的持续性方法
¡     HTTP URL:基于HTTP URL的持续性方法
¡     HTTP version:基于HTTP版本的持续性方法
·     Name:HTTP首部的名称。只有指定了基于HTTP首部名称的持续性方法才会显示本字段
·     Offset:HTTP首部基于HTTP报文起始位置的偏移量。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
·     Start:HTTP首部开始标记的正则表达式。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
·     End:HTTP首部结束标记的正则表达式,不会与Length字段同时显示。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
·     Length:HTTP首部的长度,不会与End字段同时显示。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
Payload
·     Offset:HTTP载荷或UDP载荷基于报文起始位置的偏移量
·     Start:HTTP载荷或UDP载荷开始标记的正则表达式
·     End:HTTP载荷或UDP载荷结束标记的正则表达式,不会与Length字段同时显示
·     Length:HTTP载荷或UDP载荷的长度,不会与End字段同时显示
RADIUS
·     Method:持续性方法,包括:
¡     Framed-IP-Address:基于RADIUS报文中Framed-IP-Address属性的持续性方法
¡     User-Name:基于RADIUS报文中User-Name属性的持续性方法
¡     Code=attribute-code:基于RADIUS报文中指定属性的持续性方法,属性编号为attribute-code
SIP
·     Method:持续性方法,包括:
¡     SIP Call-ID:基于SIP信令报文Call ID的持续性方法
SSL
·     Method:持续性方法,包括:
¡     SSL session ID:基于SSL session ID的SSL持续性方法
HTTP passive
·     Method:持续性方法,包括:
¡     HTTP header name:基于HTTP首部名称的被动持续性方法
¡     HTTP URL:基于HTTP URL的被动持续性方法
¡     HTTP content:基于HTTP实体被动持续性方法
·     Get:获取HTTP应答报文中的指定字符串
·     Match:获取HTTP请求报文中的指定字符串
UDP passive
·     Get:获取UDP应答报文中的指定字符串
·     Match:获取UDP请求报文中的指定字符串
·     Start:UDP载荷开始标记的正则表达式
·     End:UDP载荷结束标记的正则表达式,不会与Length字段同时显示
·     Length:UDP载荷的长度,不会与End字段同时显示
TCP payload
·     Offset:TCP载荷基于TCP报文起始位置的偏移量
·     Start:TCP载荷开始标记的正则表达式
·     End:TCP载荷结束标记的正则表达式,不会与Length字段同时显示
·     Length:TCP载荷的长度,不会与End字段同时显示
Diameter
·     Method:持续性方法,当前持续性方法仅有attribute-code:基于Diameter报文中指定属性的持续性方法
·     Code:Diameter报文中属性编号
·     Index:AVP序列索引
1.1.70  display temporary-real-server
display temporary-real-server命令用来显示临时生成的临时实服务器信息。
display temporary-real-server [ brief | name temporary-real-server-name ]
display temporary-real-server server-farm server-farm-name [ name temporary-real-server-name port port-number ]
context-admin
context-operator
brief:显示临时实服务器的简要信息。如果未指定本参数,将显示临时实服务器的详细信息。
name temporary-real-server-name:显示指定临时实服务器的信息。temporary-real-server-name为临时实服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有临时实服务器的信息。
server-farm server-farm-name:显示指定实服务组下临时实服务器组成员的信息。server-farm-name为实服务组的名称,为1~255个字符的字符串,不区分大小写。
name temporary-real-server-name port port-number:显示指定名称及端口的临时实服务组成员的信息。temporary-real-server-name表示临时实服务组成员的名称,为1~255个字符的字符串,不区分大小写。port-number表示临时实服务组成员的端口,取值范围为0~65535。如果未指定本参数,将显示指定实服务组下的所有临时实服务组成员的信息。
非缺省vSystem不支持本命令。
# 显示所有临时实服务器的简要信息。
<Sysname> display temporary-real-server brief
Temporary real server   Address          Real server  Domain name      State
auto_1.1.1.1            1.1.1.1          rs           www.h3c.com      Active
auto_2.2.2.2            2.2.2.2          rs1          www.example.com  Busy
# 显示临时实服务器auto_1.1.1.1的详细信息。
<Sysname> display temporary-real-server name auto_1.1.1.1
Temporary real server: auto_1.1.1.1
  Description: auto_1.1.1.1
  State: Active
  Belong domain name: www.h3c.com
  Belong real server: rs
  VPN instance:
  IPv6 address:
  Server farm: sf
  Weight: 150
  Priority: 3
  Cost: 100
  Rate limit:
    Connections: 10000
    HTTP requests: --
  Bandwidth busy:
    Busy rate: 80
  Probe log: Enabled
  Probe information:
    Dynamic weight: 1
    Probe method                    State
    t4                              Succeeded
  Reference count: 1
# 显示实服务器组sf下所有临时实服务器组成员的信息。
<Sysname> display temporary-real-server server-farm sf
Server farm: sf
  Real server: auto_1.1.1.1
    State: Inactive
    Port: 2 (port number in orginal packet)
    Weight: 2
    Priority: 2
    Rate limit: --
      Connections: --
      HTTP requests: --
    Probe log: Enabled
    Probe information:
      Dynamic weight: --
      Probe method                       State
      icmp                               Failed
      ora1                               Invalid
表1-1 display temporary-real-server命令显示信息描述表
临时实服务器的名称
Real server
临时实服务器所属的实服务器名称
Domain name
临时实服务器所属的域名
Address
临时实服务器的IPv4地址
Port
临时实服务器的端口号,0表示继续使用原报文携带的端口号
State表示临时实服务器/实服务组成员状态,包括:
·     Active:可用
·     Busy:繁忙(当临时实服务器处于Active或Ramp状态,且开启接口获取带宽功能和繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·     Ramp:温暖上线的爬升阶段
·     Shutdown:关闭
·     Standby:温暖上线的准备阶段
·     Unknown:未配置健康检测
Belong domain name
临时实服务器所属的域名
Belong real server
临时实服务器所属的实服务器名称
VPN instance
临时实服务器所属的VPN实例名称
Inherit VPN
临时实服务器所属VPN实例继承功能的状态,包括:
·     Enabled:开启
·     Disabled:关闭
Server farm
临时实服务器所属的实服务组
临时实服务器的描述信息
IPv4 address
临时实服务器的IPv4地址
IPv6 address
临时实服务器的IPv6地址
Weight
临时实服务器的权值
Priority
临时实服务器的调用优先级
Cost
就近性计算的成本
Slow shutdown
临时实服务器慢宕功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Slow offline
临时实服务器平滑退出功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Connection limit
临时实服务器所允许的最大连接数
临时实服务器所允许的最大连接速率
Rate limit
临时实服务器的速率限制
Connections
临时实服务器所允许的最大连接速率
HTTP requests
临时实服务器每秒HTTP请求数
Bandwidth
临时实服务器所允许的最大总带宽,单位为kbps
Inbound bandwidth
临时实服务器所允许的最大上行带宽,单位为kbps
Outbound bandwidth
临时实服务器所允许的最大下行带宽,单位为kbps
Max bandwidth
临时实服务器繁忙所允许的最大总带宽,单位为kbps
临时实服务器繁忙所允许的最大上行带宽,单位为kbps
临时实服务器繁忙所允许的最大下行带宽,单位为kbps
Busy rate
临时实服务器所允许的总带宽繁忙比
Inbound busy rate
临时实服务器所允许的上行带宽繁忙比
Outbound busy rate
临时实服务器所允许的下行带宽繁忙比
Busy recovery rate
临时实服务器所允许的总带宽繁忙恢复比
临时实服务器所允许的上行带宽繁忙恢复比
临时实服务器所允许的下行带宽繁忙恢复比
Dynamic weight
SNMPDCA busy state
动态反馈算法所获取的临时实服务器的繁忙状态,只有动态反馈算法生效后该值有效,否则显示“--”,包括:
·     Normal:临时实服务器处于正常状态
·     Busy:临时实服务器处于繁忙状态
Probe log
临时实服务器健康检测日志的状态,包括:
·     Disabled:关闭
·     Enabled:开启
临时实服务器健康检测的成功条件:
Probe method
健康检测方法所使用的NQA模板名称
自定义监控、数据库探测和NQA健康检测方法的状态,包括:
·     Failed:健康检测失败
·     Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者临时实服务器不可用
·     Succeeded:健康检测成功
自定义监控方法
(暂不支持)数据库类型探测模板
Manual recover
·     Disabled:关闭
·     Enabled:开启
TCP RST类型的负载均衡探测模板
Probe result
·     Busy:实服务组成员处于繁忙状态
实服务组成员关联的变量信息
Variable name
变量名称
Variable value
变量的值
Reference count
被引用次数
1.1.71  display virtual-server
display virtual-server命令用来显示虚服务器的信息。
display virtual-server [ brief | name virtual-server-name ]
context-admin
context-operator
vsys-admin
vsys-operator
brief:显示虚服务器的简要信息。如果未指定本参数,将显示虚服务器的详细信息。
name virtual-server-name:显示指定虚服务器的信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的信息。
# 显示所有虚服务器的简要信息。
<Sysname> display virtual-server brief
Virtual server   State    Type      VPN instance     Virtual address     Port
vs1              Inactive IP                         192.168.21.148/32   80
                                    vpn2             192.168.21.149/32   80
                                                     1111:2222:3333:4444
                                                     :5555:6666:7777:888
vs2              Active   HTTP                       61.159.4.100/32     8080
vs3              Active   LINK-IP                    51.139.4.100/32     0
vs4              Active   MySQL                      12.139.5.132/32     3306
vs5              Active   Diameter                   13.139.5.132/32     3868
# 显示所有虚服务器的详细信息。
Virtual server: vs
  Description: Virtual server VS
  Type: HTTP
  State: Active
  VPN instance: vpn1
  Virtual IPv4 address: 1.1.1.1/32
                        1.1.1.2/32(vpn2)
  Virtual IPv6 address: 1001::1/128(vpn3)
                        1001::2/128(vpn4)
  Port: 0 (any port)
  Traffic group: 1
  Primary server farm: sf (in use)
  Backup server farm: sfb
  Primary sticky: sg3
  Backup sticky: sg4  LB limit-policy:
  TCP parameter profile (client-side): ptc
  TCP parameter profile (server-side): pts
  HTTP parameter profile: pp1
  HTTP2 parameter profile (client-side): h1
  HTTP2 parameter profile (server-side): h2
  HTTP-statistics parameter profile: 1
  OneConnect parameter profile:one
  DPI application profile: profile1
  UDP per-packet: Enabled
  Rate limit:
    Connections: 10000
  SSL server policies with SNI list:
      Server name indication: www.example.com
  SSL server policy: ssl-server
  SSL client policy: ssl-client
  Redirect relocation:
  Redirect return-code: 302
  VRRP Info:
    VRRP VRID: 1
  Sticky: test
  Sticky synchronization: Disabled
  Bandwidth busy protection: Disabled
  Interface bandwidth statistics: Disabled
  Route advertisement: Enabled
  ARP/ND interfaces:
  Customlog content: %{is};%{ps}
  Cache policy:
  HTTP protection policy: p1  Insert xff: Enabled
  External-link proxy: Enabled
  External-link inject URI: proxy
  External-link inject domain suffix: c.example.com
  External-link SNAT pool: spool1
  External-link domain name whitelist:
    a.example.com
    b.example.com
  LB policy: lbp2
    Type: HTTP
Virtual server: vstcp
  Type: TCP
  State: Active
  VPN instance:
  Port: 8080
  Traffic group: 1
  Primary sticky: sg3
  Backup sticky: sg4
  LB limit-policy:
  TCP-Application parameter profile:ptapp
  Rate limit:
    Connections: 10000
  Connection synchronization: Disabled
  Application-Mode: Enabled
  Proxy protocol: Enabled
  Proxy protocol version:V1
  ARP/ND interfaces:
  LB policy: lbp2
    Type: Generic
# 显示出方向链路负载均衡中配置的虚服务器lk的详细信息。
<Sysname> display virtual-server name lk
Virtual server: lk
  Description:
  Type: Link-IP
  State: Active
  VPN instance:
  Port: 0
  Traffic group: 1
  Primary link group: lg1 (in use)
  Backup link group: lg2
  Sticky: sg3
  LB limit-policy:
  Rate limit:
    Connections: 10000
  Route advertisement: Disabled
  ARP/ND interfaces:
  LB policy: lbp2
    Type: Generic
# 显示虚服务器vs4的详细信息。
<Sysname> display virtual-server name vs4
Virtual server: vs4
  Description: Virtual server VS4
  Type: MySQL
  State: Active
  VPN instance:
  Port: 3306
  Traffic group: 1
  Sticky: sg3  LB limit-policy:
  MySQL parameter profile: my
  Rate limit:
    Connections: 10000
  ARP/ND interfaces:
  Version: 5.6
  User list:
    Username: wangping
    Username: liqiang
  Read server farm: rd
  Read sticky group: rsg
  Write server farm: wr
  Write sticky group: wsg
  LB policy: lbp2
    Type: Generic
# 显示虚服务器vs5的详细信息。
<Sysname> display virtual-server name vs5
Virtual server: vs5
  Description: Virtual server VS5
  Type: Diameter
  State: Active
  VPN instance: vpn1
  Port: 3868
  Traffic group: 1
  Sticky: dia-sg  LB limit-policy:
  Rate limit:
    Connections: --
  SSL server policy: ssp
  Diameter-session parameter profile: Dia-para
  LB policy: dia-lbp
    Type: Diameter
表1-31 display virtual-server命令显示信息描述表
Virtual server
虚服务器的名称
虚服务器的状态,包括:
·     Active:可用
·     Inactive:不可用(已安装License并开启了虚服务器功能,仍不可用)
·     Inactive (no license):不可用(由于缺少License)
·     Inactive (disabled):不可用(由于未开启虚服务器功能)
虚服务器的类型,包括Fast HTTP、HTTP、IP、MySQL、RADIUS、TCP、UDP、Link-IP和Diameter
VPN instance
虚服务器所属的VPN实例名称
Virtual address
虚服务器的IPv4地址和掩码
Port
虚服务器的端口号,0表示任意端口号
Traffic group
虚服务器关联的集群流量组的编号
虚服务器的描述信息
虚服务器的IPv4地址和掩码,()中的信息表示此地址所属的VPN实例名称,未指定IPv4地址所属的VPN实例时,此处不显示()以及()内的信息
虚服务器的IPv6地址和前缀,()中的信息表示此地址所属的VPN实例名称,未指定IPv6地址所属的VPN实例时,此处不显示()以及()内的信息
Primary server farm
缺省的主用实服务组名称,(in use)表示该实服务组正被使用
Backup server farm
缺省的备用实服务组名称,(in use)表示该实服务组正被使用
Primary link group
缺省的主用链路组名称,(in use)表示该链路组正被使用
Backup link group
缺省的备用链路组名称,(in use)表示该链路组正被使用
Primary sticky
缺省的主用持续性组名称
Backup sticky
备用持续性组名称,只有HTTP和RADIUS类型的虚服务器才会显示本字段
LB policy
虚服务器引用的负载均衡策略
虚服务器引用的HTTP类型参数模板,只有配置了HTTP类型的参数模板才会显示本字段
IP parameter profile
虚服务器引用的IP类型参数模板,只有配置了IP类型的参数模板才会显示本字段
虚服务器引用的TCP类型参数模板,只有配置了TCP类型的参数模板才会显示本字段
虚服务器引用的客户端侧TCP类型参数模板,只有配置了客户端侧TCP类型的参数模板才会显示本字段
虚服务器引用的服务器侧TCP类型参数模板,只有配置了服务器测TCP类型的参数模板才会显示本字段
虚服务器引用的OneConnect类型参数模板,只有引用了OneConnect类型的参数模板才会显示本字段
虚服务器引用的HTTP统计类型参数模板,只有配置了HTTP统计类型的参数模板才会显示本字段
虚服务器引用的TCP-Application类型参数模板,只有配置了TCP-Application类型参数模板才会显示本字段
虚服务器引用的MySQL类型参数模板,只有引用了MySQL类型的参数模板才会显示本字段
虚服务器引用的客户端侧HTTP2.0类型参数模板,只有配置了HTTP2.0类型的参数模板才会显示本字段
虚服务器引用的服务器侧HTTP2.0类型参数模板,只有配置了HTTP2.0类型的参数模板才会显示本字段
Diameter parameter profile
虚服务器引用的Diameter-session类型参数模板,只有引用了Diameter类型的参数模板才会显示本字段
虚服务器引用的DPI应用profile,只用引用了DPI应用profile才会显示本字段
UDP per-packet
虚服务器UDP强制负载均衡功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
只有UDP类型的虚服务器才会显示本字段
Connection limit
虚服务器所允许的最大连接数
Rate limit
虚服务器的速率限制
Connections
虚服务器所允许的最大连接速率
Bandwidth
虚服务器所允许的最大总带宽,单位为kbps
Inbound bandwidth
虚服务器所允许的最大入带宽,单位为kbps
Outbound bandwidth
虚服务器所允许的最大出带宽,单位为kbps
SSL服务器端策略的SNI列表,只有TCP和HTTP类型的虚服务器才会显示本字段
SSL服务器名称指示,只有TCP和HTTP类型的虚服务器才会显示本字段
SSL server policy
SSL服务器端策略的名称,只有HTTP和Diameter类型的虚服务器才会显示本字段
SSL client policy
SSL客户端策略的名称,只有HTTP类型的虚服务器才会显示本字段
Redirect relocation
重定向的URL,只有HTTP类型的虚服务器才会显示本字段
重定向报文中的状态码,只有HTTP类型的虚服务器才会显示本字段
VRRP VRID
虚服务器绑定的VRRP备份组号
VRRP interface
虚服务器绑定的VRRP备份组的接口
Sticky
虚服务引用的持续性组,只有HTTP类型的虚服务器才会显示本字段
虚服务器会话扩展信息备份功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
HTTP类型的虚服务器不会显示本字段
虚服务器持续性表项备份功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
链路的带宽繁忙保护功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
链路的接口带宽统计功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Route advertisement
虚服务器IP地址下发功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
Application-Mode
是否开启TCP类型的虚服务器工作在七层,包括:
·     Disabled:关闭
·     Enabled:开启
只有TCP类型的虚服务器才会显示本字段
Proxy protocol
虚服务器的代理协议功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
只有TCP类型虚服务器才会显示本字段
虚服务器的代理协议版本,包括:
·     V1:代理协议版本号为v1
·     V2:代理协议版本号为v2
只有虚服务器的代理协议功能才会显示本字段
ARP/ND interfaces
发送免费ARP报文或者ND报文的接口
Version
MySQL数据库的版本号,只有MySQL类型的虚服务器才会显示本字段
User list
MySQL数据库的登录用户列表,只有MySQL类型的虚服务器才会显示本字段
Username
MySQL数据库的登录用户名,只有MySQL类型的虚服务器才会显示本字段
Read server farm
MySQL虚服务器引用的读实服务组名称,只有MySQL类型的虚服务器才会显示本字段
Read sticky group
读实服务组对应的持续性组名称,只有MySQL类型的虚服务器才会显示本字段
Write server farm
MySQL虚服务器引用的写实服务组名称,只有MySQL类型的虚服务器才会显示本字段
Write sticky group
写实服务组对应的持续性组名称,只有MySQL类型的虚服务器才会显示本字段
Customlog content
快速日志输出的内容,只有HTTP类型的虚服务器才会显示本字段
Insert xff
配置发往服务器侧报文插入X-Forwarded-for字段
·     Disabled:关闭
·     Enabled:开启
虚服务器引用的HTTP防护策略
External-link proxy
外链代理功能的状态,包括:
·     Disabled:关闭
·     Enabled:开启
外链代理的URI标识
外链代理的域名后缀
外链代理的SNAT地址池
外链代理的白名单
1.1.72  display virtual-server statistics
display virtual-server statistics命令用来显示虚服务器的统计信息。
display virtual-server statistics [ name virtual-server-name ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
name virtual-server-name:显示指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的统计信息。
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
虚服务器的统计时间间隔为200毫秒,不支持配置。
# 显示虚服务器vs的统计信息。
<Sysname> display virtual-server statistics name vs
Virtual server: vs
  Total connections: 979
  Active connections: 618
  Half Open connections: 0
  Max connections: 661
  Connections per second: 146
  Max connections per second: 156
  Client input: 333332 bytes
  Client output: 472054 bytes
  Throughput: 4088 bps
  Outbound throughput: 2874 bps
  Max throughput: 4368 bps
  Max outbound throughput: 3154 bps
  Received packets: 979
  Sent packets: 0
  Dropped packets: 0
  Authentication permitted requests: 0
  Authentication denied requests: 0
  Redirected requests for login: 4
  Redirected requests for re-authentication: 0
表1-32 display virtual-server staistics命令显示信息描述表
Virtual server
虚服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
半开连接数,只有TCP类型的虚服务器才会显示本字段
Max connections
最大连接数
每秒连接数
最大每秒连接数
Client input
从客户端收到的流量,单位为字节
Client output
向客户端发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
Max oubound throughput
报文的最大出吞吐量,单位为bps
当前活动的SSL连接数
每秒SSL连接数
Received packets
收到的报文数
Sent packets
发出的报文数(虚服务器发给客户端的)
Dropped packets
丢弃的报文数
每秒收到的报文数
Received requests
收到的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
Dropped requests
丢弃的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
Sent responses
发出的HTTP应答报文数量,只有HTTP类型的虚服务器才会显示本字段
Dropped responses
丢弃的HTTP应答报文数量,只有HTTP类型的虚服务器才会显示本字段
鉴权结果为通过的请求数量
鉴权结果为拒绝的请求数量
重定向至登录页面的请求数量
重定向至二次认证页面的请求数量
·     reset virtual-server statistics
1.1.73  display virtual-server overall-statistics
display virtual-server overall-statistics命令用来显示整机虚服务器统计信息。
display virtual-server overall-statistics [ name virtual-server-name ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
vsys-admin
vsys-operator
虚服务器的统计时间间隔为200毫秒。
# 显示虚服务器vs的统计信息。
<Sysname> display virtual-server overall-statistics name vs
Virtual server: vs
  Max connections: 245,
    recorded at: 17:32:04 on Tue Jul 24 2074
  Max connections per second: 18912,
    recorded at: 17:31:55 on Tue Jul 24 2074
  Client input: 242167623 bytes
  Client output: 339667596 bytes
  Throughput: 0 bps
  Max throughput: 79507672 bps,
    recorded at: 17:31:59 on Tue Jul 24 2074
  Max inbound throughput: 35814280 bps,
    recorded at: 17:32:01 on Tue Jul 24 2074
  Max outbound throughput: 46758144 bps,
    recorded at: 17:32:00 on Tue Jul 24 2074
  Received packets: 4193385
  Sent packets: 2096703
  Dropped packets: 0
  Received requests: 1048341
  Dropped requests: 0
  Sent responses: 1048341
  Redirect requests for login: 0
  Redirect requests for re-authentication: 0
表1-33 display virtual-server overall-staistics命令显示信息描述表
Virtual server
虚服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Client input
从客户端收到的流量,单位为字节
Client output
向客户端发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为bps
Inbound throughput
报文的入吞吐量,单位为bps
Outbound throughput
报文的出吞吐量,单位为bps
Max throughput
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
当前活动的SSL连接数
每秒SSL连接数
Received packets
收到的报文数
Sent packets
发出的报文数(虚服务器发给客户端的)
Dropped packets
丢弃的报文数
每秒收到的报文数
Received requests
Dropped requests
Sent responses
Dropped responses
鉴权结果为通过的请求数量
鉴权结果为拒绝的请求数量
重定向至登录页面的请求数量
重定向至二次认证页面的请求数量
·     display virtual-server statistics
1.1.74  domain-name
domain-name命令用来配置实服务器的域名。
undo domain-name命令用来恢复缺省情况。
domain-name domain-name
undo domain-name
未配置实服务器的域名。
实服务器视图
context-admin
domain-name:域名,由“.”分隔的字符串组成(如example.com),每个字符串的长度不超过253个字符,包括“.”在内的总长度不超过253个字符。不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”。
工作机制
配置域名后,设备会立刻向DNS服务器发送域名查询请求,并依据查询结果创建名称为auto_ip-address,IP地址为ip-address的实服务器。若实服务器的域名解析为多个IP地址,设备会自动创建多个实服务器。
若管理员通过执行本命令配置了实服务器的域名,则必须通过执行dns server命令指定进行域名解析的DNS服务器,有关dns server命令的详细介绍,请参见“三层技术-IP业务命令参考”的“域名解析”。
DNS服务器返回的域名查询结果中会携带TTL超时时间,当TTL超时后,设备会自动进行下一次域名查询。如域名解析IP变化,则删除基于旧的解析IP生成的临时实服务器,并基于新的解析IP生成临时实服务器。
注意事项
在同一实服务器视图下,本命令与ip address (real server view)命令互斥,最后一次执行的命令生效。
不同的实服务器不可以配置相同的域名。
非缺省vSystem不支持本命令。
# 实服务器视图中,配置实服务器的域名。
[Sysname] real-server rs
[Sysname-rserver-rs] domain-name www.example.com
·     dns server(三层技术-IP业务命令参考/域名解析)
·     ip address
·     display temporary-real-server
1.1.75  encrypt-cookie
encrypt-cookie命令用来配置Cookie加密功能。
undo encrypt-cookie命令用来取消对指定Cookie进行加密。
encrypt-cookie name cookie-name key { cipher | simple } string
undo encrypt-cookie name cookie-name
不对任何Cookie进行加密。
HTTP类型的参数模板视图
context-admin
vsys-admin
name cookie-name:Cookie名称,为1~63个字符的字符串,区分大小写。
key:指定Cookie加密的密钥。
cipher:表示以密文方式设置密钥。
simple:表示以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~31个字符的字符串;密文密钥为1~73个字符的字符串。
配置本命令后,设备会将服务器发送的HTTP响应报文中Set-Cookie字段加密后发往客户端,以防止保存在Cookie中的用户关键信息泄露。客户端携带加密后的Cookie值访问服务器时,设备会将Cookie字段解密后再发往服务器。
# 在HTTP类型的参数模板p1视图下,为cookie1配置Cookie加密功能,加密密钥为123456。
[Sysname] parameter-profile p1 type http
[Sysname-para-http-p1] encrypt-cookie name cookie1 key simple 123456
1.1.76  env-variables
env-variables命令用来配置自定义监控的环境变量。
undo env-variables命令用来删除指定的自定义监控环境变量。
env-variables variable-name value variable-value
undo env-variables variable-name
未配置自定义监控的环境变量。
自定义监控类型的负载均衡探测模板视图
context-admin
variable-name:环境变量名称,为1~63个字符的字符串,区分大小写,允许存在空格。
value variable-value:环境变量值,为1~255个字符的字符串,区分大小写,支持空格,不支持”号。
工作机制
用户可以通过配置自定义监控的环境变量,指定自定义脚本的执行环境。
设备最多允许配置16个环境变量。
注意事项
非缺省vSystem不支持本命令。
# 在自定义类型的负载均衡探测模板test_external视图下,配置自定义监控的环境变量名称为env,值为/var/tmp。
[Sysname] loadbalance probe-template external-monitor test_external
[Sysname-lbpt-external-monitor-test_external] env-variables env value /var/tmp
1.1.77  exceed-mss
exceed-mss命令用来配置对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式。
undo exceed-mss命令用来恢复缺省情况。
exceed-mss { allow | drop }
undo exceed-mss
对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式为允许超出MSS的数据段。
TCP类型的参数模板视图
context-admin
vsys-admin
allow:允许超出MSS的数据段。
drop:丢弃超出MSS的数据段。
# 在TCP类型的参数模板pp3中,配置对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式为丢弃超出MSS的数据段。
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] exceed-mss drop
1.1.78  external-link inject-domain-suffix
external-link inject-domain-suffix命令用来配置外链代理的域名后缀。
undo external-link inject-domain-suffix命令用来删除指定的外链代理域名后缀。
external-link inject-domain-suffix domain-suffix
虚服务器未配置外链代理的域名后缀。
HTTP类型的虚服务器视图
context-admin
domain-suffix:外链改写后的域名后缀,由“.”分隔的字符串组成(如example.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符。不区分大小写,字符串中可以包含字母、数字、连字符“-”、下划线“_”或英文句号“.”。
工作机制
若DNS选路由入方向链路负载均衡完成,则DNS映射的域名后缀应与外链代理的域名后缀相同。多次配置本命令,最后一次配置的命令生效。
注意事项
非缺省vSystem不支持本命令。
#  在HTTP类型的虚服务器vs视图下,配置外链代理的域名后缀为b.example.com。
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] external-link inject-domain-suffix b.example.com
·     external-link inject-uri
·     external-link proxy enable
1.1.79  external-link inject-uri
external-link inject-uri命令用来配置外链代理的URI标识。
undo external-link inject-uri命令用来删除指定的外链代理URI标识。
external-link inject-uri string
未配置外链代理的URI标识。
HTTP类型的虚服务器视图
context-admin
string:外链代理的URI标识,为1~63个字符的字符串,不区分大小写,字符串中可以包含字母、数字、连字符“-”、下划线“_”,不能为英文句号“.”。
工作机制
外链代理的URI标识用来标识经过设备改写后的外链。当负载均衡设备收到IPv6站点服务器返回的应答报文时,设备会对应答报文中包含的IPv4外链域名进行改写,在原始的外链域名后添加指定的URI标识、域名后缀和虚服务器端口号。假设原始的IPv4外链域名为http://www.example1.com,若配置URI标识为proxy,域名后缀为example2.com,虚服务器端口号为8080,则改写后的外链域名为http://www.example1.com.proxy.example2.com:8080。当设备收到请求改写后外链域名的DNS请求报文后,设备会提取出原始的外链域名并代替IPv6客户端请求IPv4外链资源,并将获得的资源返回给客户端。
注意事项
非缺省vSystem不支持本命令。
#  在HTTP类型的虚服务器vs视图下,配置外链代理的URI标识为proxy。
[Sysname-vs-http-vs] external-link inject-uri proxy
·     external-link inject-domain-suffix
1.1.80  external-link proxy enable (LB action view)
external-link proxy enable命令用来开启外链代理功能。
undo external-link proxy enable命令用来关闭外链代理功能。
外链代理功能处于关闭状态。
HTTP类型的负载均衡动作视图
context-admin
工作机制
在HTTP类型的负载均衡动作视图下,开启了外链功能后,要使外链代理功能生效,还需要在虚服务器视图下配置外链代理相关参数。
缺省情况下,设备不会对匹配负载均衡动作的外链请求进行代理。只有在HTTP类型的负载均衡动作视图,开启了外链代理功能后,才会对匹配该负载均衡动作的外链请求进行代理。
若开启了外链代理功能且配置了以下负载均衡动作时,外链代理功能优先生效。
·     转发类动作
·     HTTP重定向功能
·     对指定的HTTP请求进行代答
·     负载均衡处理失败时的代答文件
注意事项
非缺省vSystem不支持本命令。
# 在HTTP类型的负载均衡动作视图下,开启外链代理功能。
[Sysname] loadbalance action a1 type http
[Sysname-lba-http-a1] external-link proxy enable
·     display loabalance action
1.1.81  external-link proxy enable (virtual sever view)
外链代理功能处于关闭状态。
HTTP类型的虚服务器视图
context-admin
工作机制
为了解决IPv6天窗问题,可以在负载均衡设备上开启外链代理功能,对指定外链进行代理。开启外链代理功能后,若IPv6客户端访问的IPv6站点页面中包含IPv4外链,当负载均衡设备收到IPv6站点服务器返回的应答报文时,会同时向客户端返回外链改写的脚本文件。客户端浏览器执行该脚本文件,对IPv4外链域名进行改写。当设备收到请求改写后外链域名的DNS请求报文后,会提取出原始的外链域名并代替IPv6客户端请求IPv4外链资源,并将获得的资源返回给客户端。
注意事项
非缺省vSystem不支持本命令。
#  在HTTP类型的虚服务器vs视图下,开启外链代理功能。
[Sysname-vs-http-vs] external-link proxy enable
1.1.82  external-link snat-pool
external-link snat-pool命令用来指定外链代理的SNAT地址池。
undo external-link snat-pool命令用来恢复缺省情况。
external-link snat-pool pool-name
未配置外链代理的SNAT地址池。
HTTP类型的虚服务器视图
context-admin
pool-name:SNAT地址池的名称,为1~255个字符的字符串,不区分大小写。
工作机制
当设备收到包含改写后外链域名的DNS请求报文后,设备会提取出原始的外链域名并使用外链代理SNAT地址池中的地址作为客户端IP地址,代替客户端请求IPv4外链资源。
若未指定外链代理的SNAT地址池,则会将设备通往服务器的出接口IP地址作为客户端IP地址。
注意事项
非缺省vSystem不支持本命令。
# 在HTTP类型的虚服务器vs视图下,指定外链代理的SNAT地址池为spool1。
[Sysname-vs-http-vs] external-link snat-pool spool1
·     loadbalance snat-pool
1.1.83  external-link whitelist domain
external-link whitelist domain命令用来添加外链代理的白名单表项。
undo external-link whitelist domain命令用来删除指定的外链代理白名单表项。
external-link whitelist domain domain-name
undo external-link whitelist domain domain-name
不存在外链代理的白名单表项。
HTTP类型的虚服务器视图
context-admin
domain-name:加入外链代理白名单的域名,由“.”分隔的字符串组成(如example.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符。不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”。
工作机制
通过本命令可将指定域名添加到外链代理白名单中,设备不会对加入白名单中的外链进行代理,即不改写白名单中外链。
在配置外链代理功能时,管理员需要将不希望进行外链代理的域名加入白名单列表。比如,IPv6站点中的IPv6外链域名。
注意事项
非缺省vSystem不支持本命令。
#  在HTTP类型的虚服务器vs视图下,向外链代理白名单中添加域名a.example.com。
[Sysname-vs-http-vs] external-link whitelist domain a.example.com
1.1.84  external-script
external-script命令用来配置负载均衡探测模板引用的脚本文件。
undo external-script命令用来恢复缺省情况。
external-script file-name
未配置负载均衡探测模板引用的脚本文件。
自定义监控类型的负载均衡探测模板视图
context-admin
file-name:自定义脚本文件名称,为1~255个字符的字符串,不区分大小写。
工作机制
通过在自定义监控类型的负载均衡探测模板视图下配置自定义脚本文件,可根据脚本文件定义的检测内容完成对实服务器状态的检测。
多次执行本命令,最后一次执行的命令生效。
注意事项
非缺省vSystem不支持本命令。
在引用脚本文件之前,请先将文件上传到设备上。
设备目前仅支持引用后缀名为.py的脚本文件。
# 在自定义监控类型的负载均衡探测模板test-external视图下,配置模板引用的自定义脚本文件为test.py。
[Sysname] loadbalance probe-template external-monitor test-external
[Sysname-lbpt-external-monitor-test-external] external-script test.py
1.1.85  fail-action
fail-action命令用来配置实服务器的故障处理方式。
undo fail-action命令用来恢复缺省情况。
fail-action { keep | reschedule | reset }
undo fail-action
实服务器的故障处理方式为保持已有连接。
实服务组视图
context-admin
vsys-admin
keep:保持已有连接,即不主动断开与故障实服务器的连接,连接继续保持还是断开将由协议自身的超时机制决定。
reschedule:重定向连接,即把连接重定向到实服务组中其它可用的实服务器上。
reset:断开已有连接,即主动断开与故障实服务器的连接。对于TCP报文,将发送RST报文;对于其它类型的报文,将发送ICMP不可达报文。
当处理报文的实服务器发生故障的时,负载均衡设备根据配置的故障处理方式来决定报文的处理方式。
# 配置实服务器sf的故障处理方式为重定向连接。
[Sysname] server-farm sf
[Sysname-sfarm-sf] fail-action reschedule
1.1.86  fallback-action close
fallback-action close命令用来配置查找可用实服务器失败时关闭TCP连接。
undo fallback-action命令用来恢复缺省情况。
fallback-action close { fin | rst }
查找可用实服务器失败时直接丢弃报文。
通用/HTTP负载均衡动作视图
context-admin
vsys-admin
fin:发送FIN报文关闭TCP连接。
rst:发送RST报文关闭TCP连接。
当配置该命令的动作在负载均衡策略中被引用时,在转发中根据该配置判断当前动作查找可用实服务器失败时,系统向客户端直接发送FIN报文或RST报文关闭TCP连接。
# 在HTTP类型的负载均衡动作a1中,开启根据当前动作查找可用实服务器失败时发送RST报文关闭TCP连接。
[Sysname-lba-http-a1] fallback-action rst-close
1.1.87  fallback-action continue
fallback-action continue命令用来配置查找可用服务器失败时继续匹配下一条引用规则。
根据当前动作查找可用服务器失败时直接丢弃报文。
负载均衡动作视图
context-admin
vsys-admin
工作机制
当配置该命令的动作在负载均衡策略中被引用时,在转发中根据该配置判断当前动作查找可用服务器失败时,可继续顺序匹配策略中的下一条引用规则。
注意事项
本命令对于SIP类型的虚服务不生效。
# 在HTTP类型的负载均衡动作a1中,开启根据当前动作查找可用实服务器失败时继续匹配策略中的下一条规则功能。
[Sysname-lba-http-a1] fallback-action continue
# DNS透明代理场景下,在DNS类型的负载均衡动作a2中,开启根据当前动作查找可用DNS服务器失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作a3中,开启根据当前动作查找可用链路失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a3 type link-generic
[Sysname-lba-link-generic-a3] fallback-action continue
1.1.88  fallback-action response raw-file
fallback-action response raw-file命令用来配置负载均衡处理失败时的代答文件。
fallback-action response raw-file raw-filename
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
raw-filename:处理失败时的代答文件名称,为1~255个字符的字符串,不区分大小写。
兼容性说明
本命令与fallback-action continue命令互斥。
工作机制
通过配置本命令,可在查找可用实服务器失败或按照response命令查找代答文件失败时,使用指定文件对客户端进行代答。指定的文件必须包含完整的HTTP报文,不能只包含报文体的内容。
# 配置负载均衡处理失败时的代答文件为301.raw。
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] fallback-action response raw-file 301.raw
·     display loadbalance action
·     fallback-action continue
1.1.89  fin-wait1 timeout
fin-wait1 timeout命令用来配置TCP连接FIN-WAIT-1状态的超时时间。
undo fin-wait1 timeout命令用来缺省默认情况。
fin-wait1 timeout timeout-value
TCP连接FIN-WAIT-1状态的超时时间为5秒。
TCP类型的参数模板视图
context-admin
vsys-admin
timeout-value:TCP连接FIN-WAIT-1状态的超时时间,取值范围为1~65535,单位为秒。
最多支持创建3个包含非缺省TIME-WAIT、FIN-WAIT-1、FIN-WAIT-2或SYN报文重传超时时间的TCP参数模板。
# 在TCP类型的参数模板profile下,配置TCP连接FIN-WAIT-1状态的超时时间为10秒。
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] fin-wait1 timeout 10
·     display parameter-profile
1.1.90  fin-wait2 timeout
fin-wait2 timeout命令用来配置TCP连接FIN-WAIT-2状态的超时时间。
undo fin-wait2 timeout命令用来恢复缺省情况。
fin-wait2 timeout timeout-value
TCP连接FIN-WAIT-2状态的超时时间为5秒。
TCP类型的参数模板视图
context-admin
vsys-admin
timeout-value:TCP连接FIN-WAIT-2状态的超时时间,取值范围为1~65535,单位为秒。
# 在TCP类型的参数模板profile下,配置TCP连接FIN-WAIT-2状态的超时时间为10秒。
[Sysname-para-tcp-profile] fin-wait2 timeout 10
1.1.91  forward all
forward all命令用来配置报文的转发模式为转发。
undo forward命令用来恢复缺省情况。
forward all
undo forward
报文的转发模式为丢弃。
通用/DNS/链路类型的负载均衡动作视图
context-admin
vsys-admin
兼容性说明
在DNS类型的负载均衡动作视图下,本命令与dns-server-pool和skip current-dns-proxy命令互斥;在通用类型的负载均衡动作视图下,本命令与server-farm命令互斥;在链路类型的负载均衡动作视图下,本命令与link-group命令互斥。当配置了其中一条后,另一条的配置将被自动取消。
注意事项
本命令对于SIP类型的虚服务不生效。
# 服务器负载均衡场景下,在通用类型的负载均衡动作lba1中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] forward all
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作lba2中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba2 type link-generic
[Sysname-lba-link-generic-lba2] forward all
# DNS透明代理场景下,在DNS类型的负载均衡动作lba3中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba3 type dns
[Sysname-lba-dns-lba3] forward all
·     server-farm (LB action view)
·     link-group (LB action view)
·     dns-server-pool
1.1.92  frame size
frame size命令用来配置HTTP2.0报文的数据帧大小。
undo frame size命令用来恢复缺省情况。
frame size size
undo frame size
HTTP2.0报文的数据帧大小为16384。
HTTP2.0类型的参数模板视图
context-admin
实现机制
HTTP2.0报文的最小单位是帧,一条HTTP2.0报文可以由多个帧构成。通过本命令,可以调整HTTP2.0报文中数据帧的最大值,若一条报文的某个数据帧超过指定大小,则会将该帧的数据部分按照指定数据帧大小进行分装。
本命令仅对HTTP2.0协议版本的请求报文生效。
注意事项
非缺省vSystem不支持本命令。
# 创建HTTP2.0类型的参数模板p1,配置HTTP2.0报文数据帧大小为1024。
[Sysname] parameter-profile p1 type http2
[Sysname-para-http2-p1] frame size 1024
1.1.93  frequency
frequency命令用来配置探测周期。
undo frequency命令用来恢复缺省情况。
frequency interval
undo frequency
探测周期为300秒。
负载均衡探测模板视图
context-admin
interval:探测周期,取值范围为5~604800,单位为秒。
工作机制
通过配置本命令可以指定负载均衡设备发送探测报文的时间间隔。
注意事项
非缺省vSystem不支持本命令。
# 在ICMP类型的探测模板icmptplt下,配置探测周期为3600秒。
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lb-pt-icmp-icmptplt] frequency 3600
1.1.94  header (HTTP header sticky group view)
header命令用来配置HTTP首部持续性方法。
undo header命令用来恢复缺省情况。
header { { { host | name header-name | url } [ offset offset ] [ start start-string] [ end end-string | length length ] } | request-method | version }
undo header
未配置任何HTTP首部持续性方法。
HTTP首部类型的持续性组视图
context-admin
vsys-admin
host:基于HTTP主机的持续性方法。
name header-name:基于HTTP首部名称的持续性方法,为1~63个字符的字符串,不区分大小写。
url:基于HTTP URL的持续性方法。
offset offset:HTTP首部基于HTTP报文起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:HTTP首部开始标记的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,区分大小写,不支持正则元字符?。
end end-string:HTTP首部结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持正则元字符?。
length length:HTTP首部的长度,取值范围为0~1000,缺省值为0,单位为字节。
request-method:基于HTTP Request-Method的持续性方法。
version:基于HTTP版本的持续性方法。
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP首部信息。start-string和end-string将不计入持续性表项信息中。
# 在HTTP首部类型的持续性组sg4中,配置HTTP首部持续性方法为:基于HTTP主机来生成持续性表项。
[Sysname] sticky-group sg4 type http-header
[Sysname-sticky-http-header-sg4] header host
1.1.95  header (HTTP passive sticky group view)
header命令用来配置HTTP首部被动持续性方法。
undo header命令用来删除HTTP首部被动持续性方法。
header { get id name header-name | match id { name header-name | url } } start start-string { end end-string | length length }
undo { get | match } id
未配置任何HTTP首部被动持续性方法。
HTTP passive类型的持续性组视图
context-admin
vsys-admin
get:表示获取HTTP应答报文首部中的指定字符串,用来生成HTTP首部被动持续性表项。
match:表示获取HTTP请求报文首部中的指定字符串,用来匹配HTTP首部被动持续性表项,
name header-name:基于HTTP首部名称进行匹配。header-name表示HTTP首部名称,为1~63个字符的字符串,不区分大小写。
url:基于URL进行匹配。
start start-string:HTTP首部或URL开始标记的正则表达式,为1~127字符的字符串,区分大小写,不支持字符?。
end end-string:HTTP首部或URL结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持字符?。
length length:HTTP首部或URL的长度,取值范围为0~1000,缺省值为0,0表示所有长度,单位为字节。
header get和header match命令获取的字符串内容不包含start-string和end-string将不计入持续性表项信息中。
HTTP首部被动持续性方法需要header get和header match命令的配合才能生成。
当设备收到HTTP请求报文后,根据header match命令的配置获取HTTP请求报文首部或URL中的指定字符串。若该字符串匹配上由header get命令获取到的HTTP应答报文首部中的指定字符串,则根据HTTP应答报文首部中的指定字符串生成持续性表项。对于后续收到的HTTP请求报文,若匹配上持续性表项,则按照持续性表项转发。
header get和header match命令的配置遵循以下原则:
同一HTTP passive类型的持续性组视图下,最多允许通过配置4条header get命令在HTTP应答报文首部或URL中获取4个指定字符串,最多允许通过配置4条header match命令在HTTP请求报文首部中获取4个指定字符串。
n条header get命令获取到的n个字符串,其中任意1~n个字符串又可以按照ID顺序组合成2n-1个字符串,若header match命令获取到字符串匹配上任意一个组合后的字符串,则认为匹配成功。
n条header match命令获取到的n个字符串按照ID顺序结合成一个字符串进行匹配。
假设,用户配置了ID为1、2、3的三条header get命令,使得设备可以获取到HTTP应答报文首部中的字符串a、b、c,组合成七个匹配字符串a、b、c、ab、ac、bc、abc,并生成七条持续性表项。同时用户配置了ID为2、3、4的三条header match命令,当设备收到HTTP请求报文后,若基于这三条规则获取到了字符串a、b、c,且它们组合成的字符串abc能够与通过header get命令获取到的字符串abc匹配成功,则认为HTTP请求报文与持续性表项匹配成功,按照持续性表项转发。
# 在HTTP passive类型的持续性组sg4中,配置获取HTTP请求报文URL中“callid”和“&”之间的字符串。若该字符串匹配上HTTP应答报文中名称为“x-forward-callid”的HTTP首部中“phone-number”和“&”之间的字符串,则根据HTTP应答报文首部中的字符串生成持续性表项。
[Sysname] sticky-group sg4 type http-passive
[Sysname-sticky-http-passive-sg4] header get 1 name x-forward-callid start phone-number end &
[Sysname-sticky-http-passive-sg4] header match 1 url start callid end &
·     content (HTTP passive sticky-group view)
·     display sticky-group
1.1.96  header call-id
header call-id命令用来配置基于SIP信令报文Call ID的持续性方法。
undo header call-id命令用来恢复缺省情况。
header call-id
undo header call-id
不存在任何持续性方法。
SIP类型的持续性组视图
context-admin
vsys-admin
配置基于SIP信令报文Call ID的持续性方法后,负载均衡会根据SIP信令报文首部的call-id字段生成持续性表项,将具有相同SIP会话ID的报文都分配给同一台实服务器处理。
# 在SIP类型的持续性组sg6中,配置基于SIP信令报文Call ID的持续性方法。
[Sysname] sticky-group sg6 type sip
[Sysname-sticky-sip-sg6] header call-id
1.1.97  header delete
header delete命令用来删除HTTP首部。
undo header delete命令用来保留HTTP首部。
header delete { both | request | response } name header-name
undo header delete { both | request | response } name header-name
保留HTTP首部。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
both:请求和应答两个方向的HTTP报文。
request:请求方向的HTTP报文。
response:应答方向的HTTP报文。
name header-name:HTTP报文首部的名称,包括标准和自定义的首部,需要与报文中的首部完全匹配。为1~63个字符的字符串,不区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符,首部名称可使用?联想,具体含义请参见RFC 4229。
配置了本命令后,如果指定方向的HTTP报文中携带有指定名称的首部,系统会将该首部从报文中删除。
# 在HTTP类型的负载均衡动作lba2中,删除HTTP请求报文中名为host的首部。
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] header delete request name host
1.1.98  header delete request accept-encoding
header delete request accept-encoding命令配置删除请求中的Accept-Encoding首部。
undo header delete request accept-encoding命令用来保留请求中的Accept-Encoding首部。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
当客户端发送的请求报文中携带Accept-Encoding首部,并开启该功能后,由负载均衡设备发往服务器的报文会删除Accpet-Encoding首部。由服务器发往负载均衡设备的应答报文不会进行压缩,而由负载均衡设备发往客户端的应答报文在符合匹配规则的情况下进行了压缩。如果客户端发送的请求报文不携带Accept-Encoding首部,无论是否使能该功能,负载均衡设备都不会对应答报文进行压缩。
缺省情况下,负载均衡设备不会对请求报文做任何修改。如果服务器发往负载均衡设备的应答报文是压缩的,则负载均衡设备会直接转发给客户端;如果服务器发往负载均衡设备的报文是未经过压缩的,则负载均衡设备会把符合匹配规则的报文进行压缩再发往客户端。
# 创建HTTP压缩类型的参数模板http1,并删除请求报文的Accept-Encoding首部。
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] header delete request accept-encoding
1.1.99  header exceed-length
header exceed-length命令用来配置当HTTP请求或应答报文首部超出最大长度时的处理方式。
undo header exceed-length命令用来恢复缺省情况。
header exceed-length { continue | drop }
当HTTP请求或应答报文首部超出最大长度时,继续执行负载均衡操作。
HTTP类型的参数模板视图
context-admin
vsys-admin
continue:继续执行负载均衡操作。
drop:停止执行负载均衡操作,丢弃该报文并关闭连接。
工作机制
当HTTP报文首部的长度超过负载均衡的处理能力时,系统将无条件使用drop方式处理该报文。
注意事项
快速HTTP类型的虚服务器不支持本功能。
# 在HTTP类型的参数模板pp1中,配置当HTTP请求或应答报文首部超出最大长度时的处理方式为:停止执行负载均衡操作,丢弃该报文并关闭连接。
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] header exceed-length drop
1.1.100  header insert
header insert命令用来插入HTTP首部。
undo header insert命令用来取消插入HTTP首部的配置。
header insert { both | request | response } name header-name value value [ encode { base64 | url } ]
undo header insert { both | request | response } name header-name
不插入HTTP首部。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
name header-name:要插入HTTP报文中的首部名称,包括标准和自定义的首部。为1~63个字符的字符串,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符,首部名称可使用?联想,具体含义请参见RFC 4229。
value value:要插入HTTP报文中的首部内容,为1~255个字符的字符串,支持以下改写变量:
·     %is:客户端侧的源IP地址。
·     %ps:客户端侧的源端口号。
·     %id:客户端侧的目的IP地址。
·     %pd:客户端侧的目的端口号。
·     %sps:服务器侧的源端口号。
·     %spd:服务器侧的目的端口号。
·     %sis:服务器侧的源IP地址。
·     %sid:服务器侧的目的IP地址。
·     %{x509v}:证书的版本。
·     %{x509snum}:证书的序列号。
·     %{x509sigalgo}:证书的签名算法。
·     %{x509issuer}:证书的签发者。
·     %{x509before}:证书的有效起始时间(在此时间之前无效)。
·     %{x509after}:证书的有效截止时间(在此时间之后无效)。
·     %{x509sub}:证书的主题。
·     %{x509spktype}:证书的主题的公钥类型。
·     %{x509spk}:证书的主题的公钥。
·     %{x509spkRSA}:证书的主题的RSA公钥的长度(仅当公钥为RSA类型才会存在该字段)。
·     %{x509hash}:客户端证书的MD5散列值(指纹)。
·     %{x509cipher}:证书的加密套件。
·     %{x509whole}:证书的全部内容。配置此变量时,必须选择Base64编码方式。
·     %{dncn}:颁发对象。
·     %{dne}:电子邮件。
·     %{dno}:公司/机构。
·     %{dnou}:部门。
·     %{dnc}:国家。
·     %{dns}:州/省份。
·     %{dnl}:城市。
encode { base64 | url }:对改写变量进行编码的方式。base64表示对改写变量进行Base64编码;url表示对改写变量进行URL编码。若未指定本参数,则不对改写变量进行编码。
实现机制
配置了本命令后,系统将在指定方向的HTTP报文中插入指定名称和内容的首部。
注意事项
URL编码方式只会对改写变量中的特殊字符进行编码,比如IPv6地址中的冒号等。Base64编码方式会对整个改写变量编码。
通过本命令,在请求方向的HTTP报文首部X-Forwarded-For字段插入客户端侧的源IP地址,则不需要再使用insert-xff enable命令在虚服务器下开启X-Forwarded-For字段源IP地址插入功能。若同时配置了这两个功能,则后者的配置优先级较高。
插入证书的相关信息时,SSL服务器端策略需要开启客户端身份验证功能。SSL服务器端策略的详细介绍,请参见“安全配置指导”中的“SSL”。
# 在HTTP类型的负载均衡动作lba2中,将名为source、内容为源IP和源端口号的首部插入到HTTP请求报文中。
[Sysname-lba-http-lba2] header insert request name source value %is:%ps
·     insert-xff enable
1.1.101  header insert response vary
header insert命令用来设置在应答报文中插入Vary首部。
undo header insert命令用来取消在应答报文中插入Vary首部的配置。
undo header insert response vary
在应答报文中插入Vary首部。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
配置该功能后,无论应答本身是否携带Vary首部或应答未进行压缩处理都会在应答头插入Vary首部,内容为Accept-Encoding再发往客户侧。
# 创建HTTP压缩类型的参数模板http1,并在应答报文中插入一个Vary首部。
[Sysname-para-http-compression-http1] header insert response vary
1.1.102  header maxparse-length
header maxparse-length命令用来设置HTTP首部的最大解析长度。
undo header maxparse-length命令用来恢复缺省情况。
header maxparse-length length
HTTP首部的最大解析长度为4096。
HTTP类型的参数模板视图
context-admin
vsys-admin
length:HTTP首部的最大解析长度,取值范围为1~1048576,单位为字节。
# 在HTTP类型的参数模板pp1中,配置HTTP首部的最大解析长度为8192。
[Sysname-para-http-pp1] header maxparse-length 8192
1.1.103  header modify per-request
header modify per-request命令用来配置对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作。
undo header modify per-request命令用来恢复缺省情况。
只对每个连接的第一个HTTP请求或应答报文的首部执行插入、删除或修改操作。
HTTP类型的参数模板视图
context-admin
vsys-admin
# 在HTTP类型的参数模板pp1中,配置对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作。
[Sysname-para-http-pp1] header modify per-request
1.1.104  header rewrite
header rewrite命令用来重写HTTP首部。
undo header rewrite命令用来取消重写HTTP首部的配置。
header rewrite { both | request | response } name header-name value value replace replace [ encode { base64 | url } ]
undo header rewrite { both | request | response } name header-name
不重写HTTP首部。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
value value:要被重写的HTTP报文首部的内容,为1~127个字符的字符串,区分大小写,不支持字符?。
replace replace:重写后的内容,为1~127个字符的字符串,区分大小写。支持以下改写变量:
·     %is:客户端侧的源IP地址。
·     %ps:客户端侧的源端口号。
·     %id:客户端侧的目的IP地址。
·     %pd:客户端侧的目的端口号。
·     %sps:服务器侧的源端口号。
·      %spd:服务器侧的目的端口号。
·      %sis:服务器侧的源IP地址。
·      %sid:服务器侧的目的IP地址。
·     %{x509v}:证书的版本。
·     %{x509sub}:证书的主题。
·     %{dncn}:颁发对象。
·     %{dne}:电子邮件。
·     %{dno}:公司/机构。
·     %{dnou}:部门。
·     %{dnc}:国家。
·     %{dns}:州/省份。
·     %{dnl}:城市。
配置了本命令后,如果指定方向的HTTP报文中携带有指定名称的首部,系统会将该首部中的内容value重写为replace。
# 在HTTP类型的负载均衡动作lba2中,将HTTP请求报文名中为host的首部中的内容,由www.hello.example.com重写为www.he.example.com.cn。
[Sysname-lba-http-lba2] header rewrite request name host value www\.(he)(llo)\.example.com replace www.%1.example.com.cn encode url
1.1.105  header rewrite request url
header rewrite request url命令用来重写HTTP请求报文中的URL。
undo header rewrite request url命令用来恢复缺省情况。
header rewrite request url value value replace replace [ encode { base64 | url } ]
不对HTTP请求报文中的URL进行重写。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
value value:要被重写的HTTP报文中URL的内容,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
replace replace:重写后的内容,为1~127个字符的字符串,区分大小写。支持如下改写变量:
·     %is:客户端侧的源IP地址。
·     %ps:客户端侧的源端口号。
·     %id:客户端侧的目的IP地址。
·     %pd:客户端侧的目的端口号。
·     %sps:服务器侧的源端口号。
·     %spd:服务器侧的目的端口号。
·     %sis:服务器侧的源IP地址。
·     %sid:服务器侧的目的IP地址。
·     %{x509v}:证书的版本。
·     %{x509sub}:证书的主题。
·     %{dncn}:颁发对象。
·     %{dne}:电子邮件。
·     %{dno}:公司/机构。
·     %{dnou}:部门。
·     %{dnc}:国家。
·     %{dns}:州/省份。
·     %{dnl}:城市。
encode { base64 | url }:对改写变量进行编码的方式。base64表示对改写变量进行Base64编码; url表示对改写变量进行URL编码。若未指定本参数,则不对改写变量进行编码。
配置了本命令后,如果HTTP请求报文中的URL中包含内容value,系统会将该首部URL中的内容value重写为replace。
# 在HTTP类型的负载均衡动作lba2中,将HTTP请求报文中URL的内容,由www.hello.example.com重写为www.he.example.com.cn。
[Sysname-lba-http-lba2] header rewrite request url value www\.(he)(llo)\.example.com replace www.%1.example.com.cn encode url
1.1.106  header-table size
header-table size命令用来配置HTTP2.0报文头部表大小。
undo header-table size命令用来恢复缺省情况。
header-table size size
HTTP2.0报文的头部表大小为4096。
HTTP2.0类型的参数模板视图
context-admin
vsys-admin
应用场景
HTTP2.0协议为重复出现在报文头部的字符串和字段建立了一张头部表,用长度较小的索引号表示重复的字符串,用Huffman编码压缩头部数据,实现了大量并发请求和响应报文的头部压缩。
随着在同一TCP连接上发送的HTTP2.0报文数量越来越多,且头部字符串重复少的情况下,客户端和服务器双方的头部表项就会积累得越来越大,占用的内存也就越来越多,直接影响了设备或服务器并发处理能力。
实现机制
管理员通过本命令可以限制HTTP2.0报文头部表大小,当头部表大小到达上限后,就会关闭该TCP连接并释放内存,避免头部表无限增大,而降低设备或服务器性能。也可以通过配置concurrent-streams-per-connection限制一条TCP连接的最大并发请求数量,避免头部表过大问题。
注意事项
# 创建HTTP2.0类型的参数模板p1,配置HTTP2.0报文头部表大小为1024。
[Sysname-para-http2-p1] header-table size 1024
·     concurrent-streams-per-connection
1.1.107  host ip address
host { ip | ipv6 } address命令用来配置主机IP地址。
undo host { ip | ipv6 } address命令用来恢复缺省情况。
host { ip | ipv6 } address ip-address
未配置主机IP地址。
Diameter-session类型参数模板视图
context-admin
vsys-admin
ip-address:IPv4或IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址。
通过本命令指定的IP地址必须为设备接口上已配置的地址且接口处于可用状态,当设备与对端进行Diameter协商时,设备将配置的IP地址作为本机地址通过协商报文发送给对端。
# 在Diameter-session类型的参数模板dia下,配置主机IP地址为22.2.2.6。
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] host ip address 22.2.2.6
·     parameter-profile
1.1.108  idle-time
idle-time命令用来配置负载均衡设备与服务器之间TCP连接的空闲超时时间。
undo idle-time命令用来恢复缺省情况。
idle-time idle-time
undo idle-time
负载均衡设备与服务器之间TCP连接的空闲超时时间为86400秒。
OneConnect类型的参数模板视图
MySQL类型的参数模板视图
context-admin
vsys-admin
idle-time:TCP连接的空闲超时时间,取值范围为1~4294967295,单位为秒。
当负载均衡设备与服务器之间TCP连接的空闲时间达到空闲超时时间时,此TCP连接将会被断开,后续客户端发起的连接请求将触发建立新的TCP连接。
# 在OneConnect类型的参数模板ocp中,配置负载均衡设备与服务器之间TCP连接的空闲超时时间为10000秒。
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] idle-time 10000
1.1.109  inherit vpn-instance disable
inherit vpn-instance disable命令用来关闭实服务器所属VPN实例的继承功能。
undo inherit vpn-instance disable命令用来开启实服务器所属VPN实例的继承功能。
实服务器所属VPN实例的继承功能处于开启状态。
实服务器视图
context-admin
工作机制
若在实服务器视图下执行vpn-instance命令指定了实服务器所属的VPN实例,则实服务器属于该VPN实例。若未指定实服务器所属的VPN实例,当实服务器所属VPN实例的继承功能处于开启状态,实服务器所属的VPN实例与虚服务器所属的VPN实例一致;当该功能处于关闭状态时,实服务器服务于公网。
推荐配置
若需要指定实服务器属于某私有网络,建议通过执行实服务器视图下的vpn-instance命令进行配置。
注意事项
非缺省vSystem不支持本命令。
# 关闭实服务器rs所属VPN实例的继承功能。
[Sysname-rserver-rs] inherit vpn-instance disable
·     vpn-instance (real server view)
·     vpn-instance (virtual server view)
1.1.110  insert-header-field
insert-header-field命令用来配置向HTTP2.0请求报文中插入头部字段。
undo insert-header-field命令用来恢复缺省情况。
insert-header-field field-name
未插入任何头部字段。
HTTP2.0类型的参数模板视图
context-admin
vsys-admin
field-name:向HTTP请求报文中插入头部字段的名称,为1~63个字符的字符串,不区分大小写。
通过本命令向HTTP2.0版本的请求报文插入头部字段,便于实服务器识别HTTP2.0版本的请求报文。
# 创建HTTP2.0类型的参数模板p1,并指定向HTTP请求报文中插入头部字段为aaa。
[Sysname-para-http2-p1] insert-header-field aaa
1.1.111  insert-xff enable
insert-xff enable命令用来开启X-Forwarded-For字段源IP地址插入功能。
undo insert-xff enable命令用来关闭X-Forwarded-For字段源IP地址插入功能。
insert-xff enable
X-Forwarded-For字段源IP地址插入功能处于关闭状态。
HTTP类型的虚服务器视图
context-admin
vsys-admin
开启本功能后,当设备收到客户端的请求报文后,会在HTTP报文拓展头的X-Forwarded-For字段插入客户端的源IP地址。
# 在HTTP类型的虚服务器vs3中,开启X-Forwarded-For字段源IP地址插入功能。
[Sysname] virtual-server vs3 type http
[Sysname-vs-http-vs3] insert-xff enable
1.1.112  ip
ip命令用来配置IPv4持续性方法。
undo ip命令用来恢复缺省情况。
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
未配置IPv4持续性方法。
持续性组视图
context-admin
vsys-admin
port:表示持续性方法为IPv4地址+端口。如果未指定本参数,表示持续性方法为IPv4地址。
both:当未指定port参数时,表示持续性方法为源IPv4地址+目的IPv4地址;当指定了port参数时,表示持续性方法为源IPv4地址+源端口+目的IPv4地址+目的端口。
destination:当未指定port参数时,表示持续性方法为目的IPv4地址;当指定了port参数时,表示持续性方法为目的IPv4地址+目的端口。
source:当未指定port参数时,表示持续性方法为源IPv4地址;当指定了port参数时,表示持续性方法为源IPv4地址+源端口。
mask mask-length:持续性方法的掩码长度。
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv4地址。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv4地址+源端口。
[Sysname-sticky-address-port-sg1] ip port source
·     sticky-group
1.1.113  ip address
ip address命令用来配置实服务器的IPv4地址。
undo ip address命令用来恢复缺省情况。
ip address ipv4-address
undo ip address
未配置实服务器的IPv4地址。
实服务器视图
context-admin
vsys-admin
ipv4-address:实服务器的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
# 配置实服务器rs的IPv4地址为1.1.1.1。
[Sysname-rserver-rs] ip address 1.1.1.1
1.1.114  ip range
ip range命令用来添加SNAT地址池的IPv4地址成员。
undo ip range命令用来删除SNAT地址池的指定IPv4地址成员。
ip range start start-ipv4-address end end-ipv4-address
undo ip range start start-ipv4-address end end-ipv4-address
未配置SNAT地址池的IPv4地址成员。
SNAT地址池视图
context-admin
vsys-admin
start start-ipv4-address:起始IPv4地址。
end end-ipv4-address:结束IPv4地址,必须大于等于起始IPv4地址。
工作机制
可多次执行本命令,配置多个IPv4地址成员。每个地址成员最多包含256个IPv4地址。
注意事项
不同的SNAT地址池和同一SNAT地址池的不同地址成员中,不允许包含相同的IPv4地址。
若SNAT地址池中的IP地址与设备连接服务器端的接口IP地址在同一网段,则必须通过执行arp-nd interface (SNAT address pool view)命令指定发送免费ARP报文或ND报文的接口。否则,无需指定发送免费ARP报文或ND报文的接口。
# 在SNAT地址池lbsp中,添加IPv4地址成员为1.1.1.1~1.1.1.100。
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
·     arp-nd interface (SNAT address pool view)
1.1.115  ip source mask
ip source mask命令用来配置连接复用的IPv4网络掩码。
undo ip source mask命令用来恢复缺省情况。
ip source mask { mask-length | mask }
undo ip source mask
连接复用的IPv4网络掩码为自然掩码。
OneConnect类型的参数模板视图
MySQL类型的参数模板视图
context-admin
vsys-admin
mask-length:连接复用的IPv4掩码长度,取值范围为0~32,其中0表示自然掩码。
mask:连接复用的IPv4掩码。
通过配置连接复用的IPv4网络掩码,可对负载均衡设备与服务器之间连接复用的客户端网段进行限制。当负载均衡设备收到客户端的连接请求时,若客户端网段与已建立的TCP空闲连接的网段相同,则复用已建立的空闲连接。否则,触发建立新的TCP连接。
# 在OneConnect类型的参数模板ocp中,配置负载均衡设备与服务器之间连接复用IPv4掩码长度为24。
[Sysname-para-oneconnect-ocp] ip source mask 24
1.1.116  ipv6
ipv6命令用来配置IPv6持续性方法。
undo ipv6命令用来恢复缺省情况。
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
未配置IPv6持续性方法。
持续性组视图
context-admin
vsys-admin
port:表示持续性方法为IPv6地址+端口。如果未指定本参数,表示持续性方法为IPv6地址。
both:表示持续性方法为源IPv6地址+目的IPv6地址(未指定port参数时),或源IPv6地址+源端口+目的IPv6地址+目的端口(指定port参数时)。
destination:表示持续性方法为目的IPv6地址(未指定port参数时),或目的IPv6地址+目的端口(指定port参数时)。
source:表示持续性方法为源IPv6地址(未指定port参数时),或源IPv6地址+源端口(指定port参数时)。
prefix prefix-length:持续性方法的前缀长度。
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv6地址。
[Sysname-sticky-address-port-sg1] ipv6 source
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv6地址+源端口。
[Sysname-sticky-address-port-sg1] ipv6 port source
·     sticky-group
1.1.117  ipv6 address
ipv6 address命令用来配置实服务器的IPv6地址。
undo ipv6 address命令用来恢复缺省情况。
ipv6 address ipv6-address
undo ipv6 address
未配置实服务器的IPv6地址。
实服务器视图
context-admin
vsys-admin
ipv6-address:实服务器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址。
# 配置实服务器rs的IPv6地址为1001::1。
[Sysname-rserver-rs] ipv6 address 1001::1
1.1.118  ipv6 range
ipv6 range命令用来添加SNAT地址池的IPv6地址成员。
undo ipv6 range命令用来删除SNAT地址池的指定IPv6地址成员。
未配置SNAT地址池的IPv6地址成员。
SNAT地址池视图
context-admin
vsys-admin
start start-ipv6-address:起始IPv6地址。
end end-ipv6-address:结束IPv6地址,必须大于等于起始IPv6地址。
工作机制
可多次执行本命令,配置多个IPv6地址成员。每个地址成员最多包含10000个IPv6地址。
注意事项
不同的SNAT地址池和同一SNAT地址池的不同地址成员中,不允许包含相同的IPv6地址。
# 在SNAT地址池lbsp中,添加IPv6成员为1001::1~1001::100。
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
1.1.119  ipv6 source prefix
ipv6 source prefix命令用来配置连接复用的IPv6前缀长度。
undo ipv6 source prefix命令用来恢复缺省情况。
ipv6 source prefix prefix-length
连接复用的IPv6前缀长度为0。
OneConnect类型的参数模板视图
MySQL类型的参数模板视图
context-admin
vsys-admin
prefix-length:连接复用的IPv6前缀长度,取值范围为0~128。
通过配置连接复用的IPv6前缀长度,可对负载均衡设备与服务器之间连接复用的客户端网段进行限制。当负载均衡设备收到客户端的连接请求时,若客户端网段与已建立的TCP空闲连接的网段相同,则复用已建立的空闲连接。否则,触发建立新的TCP连接。
# 在OneConnect类型的参数模板ocp中,配置负载均衡设备与服务器之间连接复用IPv6前缀长度为24。
[Sysname-para-oneconnect-ocp] ipv6 source prefix 24
1.1.120  ishell
ishell命令用来引用脚本文件。
undo ishell命令用来取消引用脚本文件。
ishell filename
undo ishell
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-AI-160-G、F5000-AI-130-G、F5000-AI-120-G、F5000-AI-110-G、F5000-E-G、F5000-E-G2、F5000-AI160、F5000-CN160-G、F5000-CN160、F5000-CN-G55
不支持
F5000-S-G2、F5000-M-G2、F5000-A-G2
支持
F1000系列
F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G
支持
F1000-AI-90、F1000-AK9130、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-15、F1000-AI-10、F1000-AI-03-E、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AK1180-G、F1000-AK1080-G、F1000-AK1050-G
不支持
插卡
LSEM1FWESD0
不支持
未引用脚本文件。
HTTP/TCP/UDP类型的虚服务器视图
context-admin
file-name:脚本文件名称,为1~255个字符的字符串,不区分大小写。
工作机制
iShell是一种可扩展的脚本编程接口,通过在负载均衡业务处理过程中嵌入该接口,可以利用编程脚本实现对负载均衡业务的灵活控制。iShell采用Lua脚本语言,通过在虚服务器视图下引用Lua脚本文件,可对匹配虚服务器的业务处理进行控制。
在引用脚本文件之前,请先将Lua脚本文件上传到设备上。
注意事项
非缺省vSystem不支持本命令。
# 在TCP类型的虚服务器视图中,引用的脚本文件lb.lua。
[Sysname] virtual-server vs1 type tcp
[Sysname-vs-tcp-vs1] ishell lb.lua
1.1.121  keepalive idle-timeout
keepalive idle-timeout命令用来配置TCP连接保活定时器的空闲超时时间。
undo keepalive idle-timeout命令用来恢复缺省情况。
keepalive idle-timeout timeout-value
TCP连接保活定时器的空闲超时时间为1800秒。
TCP类型的参数模板视图
context-admin
vsys-admin
timeout-value:TCP连接保活定时器的空闲超时时间,取值范围为1~65535,单位为秒。
# 在TCP类型的参数模板profile下,配置TCP连接保活定时器的空闲超时时间为5秒。
[Sysname-para-tcp-profile] keepalive idle-timeout 5
1.1.122  keepalive l4 idle-timeout
keepalive l4 idle-timeout命令用来配置四层模式下TCP连接保活定时器的空闲超时时间。
undo keepalive l4 idle-timeout命令用来恢复缺省情况。
keepalive l4 idle-timeout timeout-value
四层模式下TCP连接保活定时器的空闲超时时间为0秒,表示未开启四层模式下的TCP保活功能。
TCP类型的参数模板视图
context-admin
vsys-admin
timeout-value:TCP连接保活定时器的空闲超时时间,取值范围为0~65535,单位为秒。0表示不发送保活报文。
工作机制
本命令用来配置四层虚服务器与客户端或服务器端的TCP连接保活定时器的空闲超时时间。TCP连接在一段时间没有数据传输后,会发送TCP保活报文,空闲超时时间用来约定多久发送一次TCP保活报文。
注意事项
仅当TCP参数模板被四层虚服务器引用时,本配置才生效。
keepalive idle-timeout命令仅对TCP参数模板被HTTP或HTTPS类型的虚服务器引用时,配置才生效。
# 在TCP类型的参数模板p1下,配置四层模式下TCP连接保活定时器的空闲超时时间为10秒。
[Sysname] parameter-profile p1 type tcp
[Sysname-para-tcp-p1]keepalive l4 idle-timeout 10
·     keepalive idle-timeout
1.1.123  keepalive retransmission interval
keepalive retransmission interval命令用来配置TCP保活报文的重传时间间隔与重传次数。
undo keepalive retransmission命令用来恢复缺省情况。
keepalive retransmission interval interval count count
TCP保活报文的重传时间间隔为10秒,重传次数为3次。
TCP类型的参数模板视图
context-admin
vsys-admin
interval:TCP保活报文的重传时间间隔,取值范围为1~65535,单位为秒。
count:TCP保活报文的重传次数,取值范围为1~65535。
# 在TCP类型的参数模板profile下,配置TCP保活报文的重传时间间隔为5秒,重传次数为10次。
[Sysname-para-tcp-profile] keepalive retransmission interval 5 count 10
1.1.124  lb-limit-policy
lb-limit-policy命令用来指定虚服务器引用的负载均衡连接数限制策略。
undo lb-limit-policy命令用来恢复缺省情况。
lb-limit-policy policy-name
虚服务器未引用任何负载均衡连接数限制策略。
虚服务器视图
context-admin
vsys-admin
policy-name:负载均衡连接数限制策略的名称,为1~255个字符的字符串,不区分大小写。
配置虚服务器引用限制策略,达到对客户流量的分类限速处理。
负载均衡连接数限制策略只在新建会话时生效,对已经存在的会话不生效。
# 指定HTTP类型的虚服务器vs引用的负载均衡策略为llp。
[Sysname-vs-http-vs]lb-limit-policy llp
·     loadbalance limit-policy
1.1.125  lb-policy
lb-policy命令用来指定虚服务器引用的负载均衡策略。
undo lb-poilcy命令用来恢复缺省情况。
lb-policy policy-name
undo lb-poilcy
虚服务器未引用任何负载均衡策略。
虚服务器视图
context-admin
vsys-admin
policy-name:负载均衡策略的名称,为1~255个字符的字符串,不区分大小写。
工作机制
虚服务器引用负载均衡策略,能够细化虚服务器负载均衡的粒度。根据策略中的匹配规则,使命中虚服务器的报文根据不同的报文内容进行不同的负载均衡处理,从而有效地丰富了负载均衡的负载功能。
注意事项
虚服务器只能引用与自身类型相关的策略模板,如:快速HTTP和HTTP类型的虚服务器,可以引用通用或HTTP类型的策略模板;IP、SIP、TCP和UDP类型的虚服务器,只能引用通用类型的策略模板。
# 指定IP类型的虚服务器vs3引用的负载均衡策略为lbp1。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] lb-policy lbp1
1.1.126  limit
limit命令用来配置负载均衡连接数限制规则。
undo limit命令用来删除指定的负载均衡连接数限制规则。
limit limit-id acl [ ipv6 ] { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
负载均衡连接数限制策略中不存在任何限制规则。
负载均衡限制策略视图
context-admin
vsys-admin
limit-id:连接数限制规则编号,取值范围为1~65535。
acl:指定用于匹配用户范围的ACL。该连接限制规则仅对匹配ACL规则的用户连接数进行统计和限制。
ipv6:表示引用IPv6 ACL。若不指定该参数,则表示引用IPv4 ACL。
acl-number:ACL的编号,取值范围为2000~3999。
name acl-name:引用的ACL名称
per-destination:按目的IP地址进行统计和限制。一个目的IP地址的连接数目将受到指定阈值的限制。
per-service:按服务统计和限制,即同一种服务(具有相同传输层协议和服务端口)的连接数目受限将受到指定阈值的限制。
per-source:按源地址统计和限制,即同一个源IP地址发起的连接数目受限将受到指定阈值的限制。
max-amount:指定的连接数上限,取值范围为1~4294967295。某范围或某种类型的连接数值超过此值时,用户将不能建立新的连接。
min-amount:指定的连接数下限,取值范围为1~4294967295,不能大于max-amount的取值。连接数的统计值降到此值之下时,允许用户建立新的连接。
工作机制
每个连接数限制策略中可以定义多个规则,每个规则中需要指定引用的ACL、规则的类型以及统计的上下门限值。对于per-destination、per-source、per-service类型,可以在一条规则中单独指定其中之一或指定它们的组合。例如,同时指定per-destination和per-source,就表示同时按照连接的报文源地址和目的地址进行统计和限制,具有相同源和目的的连接属于同一类连接,该类连接的数目将受到指定的阈值的限制。
如果per-destination、per-service、per-source三个参数都不指定,则表示与本规则引用的ACL相匹配的所有连接将整体受到指定的阈值限制。
对设备上建立的连接与某连接数限制策略进行匹配时,将按照规则编号从小到大的顺序依次遍历该策略中的所有规则,直到找到一条匹配的规则为止。
当引用的ACL内容发生改变时,设备将按照新的连接数限制策略重新对已有连接进行统计和限制。
注意事项
同一个连接数限制策略中的不同规则必须引用不同的ACL。
# 在负载均衡连接数限制策略1中创建一条规则,规则编号为1,引用ACL 3000,对匹配ACL 3000的连接同时按照报文的源地址和目的地址进行统计和限制,连接数的上限值为2000、下限值为1800。该规则用于限制192.168.0.0/24网段的每台主机最多只能同时向外网的同一个目的IP地址发起2000条连接,超过2000条时,需要等待连接数下降到1800以下之后,才允许新建连接。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
[Sysname] loadbalance limit-policy 1
[Sysname-lb-limit-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800
1.1.127  loadbalance action
loadbalance action命令用来创建负载均衡动作,并进入负载均衡动作视图。如果指定的负载均衡动作已经存在,则直接进入负载均衡动作视图。
undo loadbalance action命令用来删除指定的负载均衡动作。
loadbalance action action-name [ type { diameter | dns | generic | http | link-generic | radius } ]
undo loadbalance action action-name
不存在任何负载均衡动作。
context-admin
vsys-admin
action-name:负载均衡动作的名称,为1~255个字符的字符串,不区分大小写。
type { diameter | dns | generic | http | link-generic | radius }:负载均衡动作的类型,其中:
·     diameter:表示Diameter负载均衡动作类型。
·     dns:表示DNS负载均衡动作类型。非缺省vSystem不支持本参数。
·     generic:表示通用负载均衡动作类型。
·     http:表示HTTP负载均衡动作类型。
·     link-generic:表示链路负载均衡动作类型。非缺省vSystem不支持本参数。
·     radius:表示RADIUS负载均衡动作类型。
配置准备
Diameter、通用、HTTP和RADIUS类型的负载均衡动作需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
注意事项
创建负载均衡动作时必须指定类型参数;而在进入已创建的负载均衡动作视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建通用类型的负载均衡动作lba1,并进入负载均衡动作视图。
1.1.128  loadbalance alg
loadbalance alg命令用来开启指定协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
undo loadbalance alg命令用来关闭指定协议的负载均衡ALG功能。
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
DNS、FTP、PPTP、ICMP-ERROR和RTSP协议的负载均衡ALG功能均处于开启状态。
context-admin
vsys-admin
dns:DNS协议。
ftp:FTP协议。
h323:H323协议。
icmp-error:ICMP-ERROR协议。
ils:ILS(Internet Locator Service,互联网定位服务)协议。
mgcp:MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议。
nbt:NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议。
pptp:PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议。
rsh:RSH(Remote Shell,远程外壳)协议。
rtsp:RTSP(Real Time Streaming Protocol,实时流协议)协议。
sccp:SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议。
sip:SIP(Session Iniation Protocol,会话初始协议)协议。
sqlnet:SQLNET协议。
tftp:TFTP协议。
xdmcp:XDMCP(X Display Manager Control Protocol,X显示监控)协议。
工作机制
负载均衡ALG功能用于将父、子会话分发到同一条链路上。
注意事项
SIP分片报文不支持负载均衡ALG功能。
当虚服务器配置的端口号为非知名端口号时,即使已开启相应协议的负载均衡ALG功能,设备也不会进行负载均衡ALG处理。可通过以下任一方式解决:
·     修改虚服务器端口号为该协议自身的知名端口号。
·     使用port-mapping命令,将虚服务器中配置的端口号与指定协议建立端口映射关系。关于port-mapping命令的详细介绍,请参见“安全命令参考”中的“APR”。
# 开启TFTP协议的负载均衡ALG功能。
[Sysname] loadbalance alg tftp
1.1.129  loadbalance alg all-enable
loadbalance alg all-enable命令用来开启支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
loadbalance alg all-disable命令用来关闭支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
context-admin
vsys-admin
# 开启所有协议的负载均衡ALG功能。
[Sysname] loadbalance alg all-enable
1.1.130  loadbalance class
loadbalance class命令用来创建负载均衡类,并进入负载均衡类视图。如果指定的负载均衡类已经存在,则直接进入负载均衡类视图。
undo loadbalance class命令用来删除指定的负载均衡类。
loadbalance class class-name [ type { diameter | dns | generic | http | link-generic | mysql | radius } [ match-all | match-any ] ]
undo loadbalance class class-name
不存在任何负载均衡类。
context-admin
vsys-admin
class-name:负载均衡类的名称,为1~255个字符的字符串,不区分大小写。
type { diameter | dns | generic | http | link-generic | mysql | radius }:负载均衡类的类型,其中:
·     diameter表示Diameter负载均衡类型。
·     dns:表示DNS负载均衡类型。非缺省vSystem不支持本参数。
·     generic:表示通用负载均衡类型。
·     http:表示HTTP负载均衡类型。
·     link-generic:表示链路负载均衡类型。非缺省vSystem不支持本参数。
·     mysql:表示MySQL负载均衡类型。
·     radius:表示RADIUS负载均衡类型。
[ match-all | match-any ]:match-all表示需要匹配所有规则才算匹配该类,match-any表示只需匹配任一规则就算匹配该类。缺省值为match-all。
配置准备
Diameter、通用、HTTP、MySQL和RADIUS类型的负载均衡类需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
注意事项
创建负载均衡类时必须指定类型参数;而在进入已创建的负载均衡类视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建通用类型的负载均衡类lbc1,并进入负载均衡类视图。
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1]
1.1.131  loadbalance limit-policy
loadbalance limit-policy命令用来创建连接数限制策略,并进入连接数限制策略视图。如果指定的连接数限制策略已经存在,则直接进入连接数限制策略视图。
undo loadbalance limit-policy命令用来删除指定的连接数限制策略。
loadbalance limit-policy policy-name
undo loadbalance limit-policy policy-name
不存在任何负载均衡连接数限制策略。
context-admin
vsys-admin
policy-name:限制策略的名称,为1~255个字符的字符串,不区分大小写。
工作机制
通过引用负载均衡连接数限制,可以对设备上建立的连接数进行统计和限制,能够有效解决因某些用户在短时间内经过设备向内部网络发起大量连接,导致设备系统或服务器资源迅速消耗,其它用户无法正常使用网络资源的问题,实现保护内部网络资源(主机或服务器)以及合理分配设备系统资源的目的。
注意事项
非缺省vSystem不支持本命令。
# 创建名称为llp的负载均衡限制策略,并进入负载均衡限制策略视图。
[Sysname] loadbalance limit-policy llp
[Sysname-lb-limit-policy-llp]
1.1.132  loadbalance log enable base
loadbalance log enable base命令用来开启负载均衡基本日志功能。
undo loadbalance log enable base命令用来关闭负载均衡基本日志功能。
负载均衡基本日志功能处于开启状态。
context-admin
vsys-admin
通过开启负载均衡基本日志功能,可实现在以下几种情况下输出日志信息:
·     实服务器、实服务组、链路或链路组的状态变化。
·     实服务器或链路的健康检测结果发生变化。
·     实服务器、虚服务器或链路的连接数达到上限或者恢复到正常范围内。
·     实服务器、虚服务器或链路的连接速率达到上限或者恢复到正常范围内。
·     虚服务器引用的缺省实服务器组主备切换。
·     虚服务器引用的缺省链路组主备切换。
·     负载均衡动作引用的实服务器组主备切换。
·     负载均衡动作引用的链路组主备切换。
若链路、实服务器或虚服务器的实际带宽超过配置的最大带宽(命令rate-limit bandwidth)时,不会输出负载均衡基本日志。
# 开启负载均衡基本日志功能。
[Sysname] loadbalance log enable base
·     rate-limit bandwidth (link view)
·     rate-limit bandwidth (real server view)
·     rate-limit bandwidth (virtual server view)
1.1.133  loadbalance log enable nat
loadbalance log enable nat命令用来开启负载均衡NAT日志功能。
undo loadbalance log enable nat命令用来关闭负载均衡NAT日志功能。
负载均衡NAT日志功能处于关闭状态。
context-admin
vsys-admin
工作机制
通过开启负载均衡NAT日志功能,可以实现对源或目的地址进行过NAT转换的连接信息进行记录,包括IP地址及端口的转换信息、用户的访问信息等。
注意事项
负载均衡NAT日志通过Flow日志方式进行输出。开启负载均衡NAT日志功能后,必须配置Flow日志的相关功能才能输出负载均衡NAT日志信息。有关Flow日志的详细介绍,请参见“网络管理和监控配置指导”中的“Flow日志”。
# 开启负载均衡NAT日志功能。
[Sysname] loadbalance log enable nat
1.1.134  loadbalance policy
loadbalance policy命令用来创建负载均衡策略,并进入负载均衡策略视图。如果指定的负载均衡策略已经存在,则直接进入负载均衡策略视图。
undo loadbalance policy命令用来删除指定的负载均衡策略。
loadbalance policy policy-name [ type { diameter | dns | generic | http | link-generic | mysql | radius } ]
undo loadbalance policy policy-name
不存在任何负载均衡策略。
context-admin
vsys-admin
type { diameter | dns | generic | http | link-generic | mysql | radius }:负载均衡策略的类型,其中:
·      diameter:表示Diameter负载均衡策略类型。
·     dns:表示DNS负载均衡策略类型。非缺省vSystem不支持本参数。
·     generic:表示通用负载均衡策略类型。
·     http:表示HTTP负载均衡策略类型。
·     link-generic:表示链路负载均衡策略类型。非缺省vSystem不支持本参数。
·     radius:表示RADIUS负载均衡策略类型。
配置准备
Diameter、通用、HTTP、MySQL和RADIUS类型的负载均衡策略需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
注意事项
创建负载均衡策略时必须指定类型参数;而在进入已创建的负载均衡策略视图时可以不指定,但若要指定,则必须与创建时的类型一致。
# 创建通用类型的负载均衡策略lbp1,并进入负载均衡策略视图。
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1]
1.1.135  loadbalance probe failed-record enable
loadbalance probe failed-record enable命令用来开启健康检测失败信息的记录功能。
undo loadbalance probe failed-record enable命令用来恢复缺省情况。
健康检测失败信息的记录功能处于关闭状态。
context-admin
vsys-admin
配置本命令后,设备开始记录实服务器和链路健康检测失败的信息。通过执行display loadbalance probe failed-record命令,可查看健康检测失败的历史记录。
# 开启健康检测失败信息的记录功能。
[Sysname] loadbalance probe failed-record enable
·     display loadbalance probe failed-record
·     loadbalance probe failed-record max-number
1.1.136  loadbalance probe failed-record max-number
loadbalance probe failed-record max-number命令用来配置可记录的健康检测失败信息的最大条数。
undo loadbalance probe failed-record max-number命令用来恢复缺省情况。
loadbalance probe failed-record max-number max-number
可记录的健康检测失败信息的最大条数为50000条。
context-admin
vsys-admin
max-number:可记录的健康检测失败信息的最大条数,取值范围为100~50000。
# 配置可记录的健康检测失败信息的最大条数为10000条。
[Sysname] loadbalance probe failed-record max-number 10000
·     loadbalance probe failed-record enable
1.1.137  loadbalance probe nqa-task-restrict disable
loadbalance probe nqa-task-restrict disable命令用来关闭NQA健康检测速率限制功能。
undo loadbalance probe nqa-task-restrict disable命令用来开启NQA健康检测速率限制功能。
NQA健康检测速率限制功能处于开启状态。
context-admin
工作机制
开启本功能后,设备将对每秒可执行的NQA健康检测任务数进行限制。当新增NQA健康检测任务时,系统会结合当前已启动的所有任务计算设备NQA健康检测速率,并判断是否会超过最大NQA健康检测速率:若未超过,则启动任务;否则,将该任务加入等待队列。
等待队列的任务按以下从高到低的优先级启动(按名称的字典序):
(1)     DNS服务器名称
(2)     链路名称
(3)     实服务器名称
(4)     DNS服务器池成员名称
(5)     链路组成员名称
(6)     实服务组成员名称
而停止任务时则按从低到高的优先级执行。
若设备当前NQA健康检测任务启动速率已经超过最大NQA健康检测速率时,可通过延长健康检测模板的测试间隔或减少检测任务释放出一些资源。
通常情况下,建议开启NQA健康检测速率限制功能,防止任务数过多导致设备资源紧张。而在小型网络或故障排查等无需担心资源争用的场景下,可关闭本功能,以提升健康检测效率。
注意事项
非缺省vSystem不支持本命令。
修改NQA模板的测试间隔时,将首先影响关联该模板的任务启停。
每次启停本功能时,系统都会按照上述原则重新调整所有任务的队列。因此,反复操作可能导致任务队列的顺序变化。
最大NQA健康检测速率与设备型号有关,可以在Probe视图下执行display system internal loadbalance statistics probe命令查看。
# 开启NQA健康检测速率限制功能。
[Sysname] undo loadbalance probe nqa-task-restrict disable
1.1.138  loadbalance probe-result synchronization enable
loadbalance probe-result synchronization enable命令用来开启主备NQA健康检测结果同步。
undo loadbalance probe-result synchronization enable命令用来恢复缺省情况。
主备NQA健康检测结果同步功能处于关闭状态。
context-admin
vsys-admin
【配置指导】
工作机制
在RBM双机热备主备模式的组网环境,缺省情况下,业务主和业务备均启动NQA健康检测,各自使用自己的探测结果,主备探测结果不同步。开启本功能,只有业务主启动健康检测,业务备不启动健康检测,主设备将后台实服务器的健康检测结果同步到备设备。
配置推荐
本功能仅适用于以下两种组网场景:
·     HA联动虚拟地址。
·     HA联动VRRP主备模式。
在其他高可靠性组网场景下配置不生效。关于HA联动虚拟地址和HA联动VRRP的详细介绍,请参见“高可靠性配置指导”中的“双机热备(RBM)”。
在以上组网环境下,业务主和业务备均启动NQA健康检测,此时,可能会出现业务备探测的后台服务器结果全是失败。如果主备切换发生时,就会导致部分流量丢失。为了避免这种情况,建议开启本功能。
# 开启主备NQA健康检测结果同步。
[Sysname] loadbalance probe-result synchronization enable
1.1.139  loadbalance probe-template
loadbalance probe-template命令用来创建负载均衡探测模板,并进入负载均衡探测模板视图。如果指定的负载均衡探测模板已存在,则直接进入负载均衡探测模板视图。
undo loadbalance probe-template命令用来删除指定的负载均衡探测模板。
loadbalance probe-template { external-monitor | http-passive | icmp | tcp-rst | tcp-zero-window } template-name
undo loadbalance probe-template { external-monitor | http-passive | icmp | tcp-rst | tcp-zero-window } template-name
不存在负载均衡探测模板。
context-admin
vsys-admin
external-monitor:负载均衡探测模板的类型为自定义监控类型。非缺省vSystem不支持本参数。
http-passive:负载均衡探测模板的类型为HTTP passive类型。
icmp:负载均衡探测模板的类型为ICMP类型。非缺省vSystem不支持本参数。
tcp-rst:负载均衡探测模板的类型为TCP RST类型。
tcp-zero-window:负载均衡探测模板的类型为TCP zero-window类型。
template-name:负载均衡探测模板的名称,为1~255个字符的字符串,不区分大小写。
实服务组、实服务组成员、实服务器可通过引用自定义监控类型的负载均衡探测模板来实现对每个实服务器进行健康检测。
实服务组可通过引用HTTP passive类型的负载均衡探测模板来实现对每个实服务器进行HTTP被动健康检测。
就近性方法可通过引用ICMP类型的负载均衡模板来启动ICMP测试,并根据是否接收到ICMP应答报文判断目的主机的可达性。
实服务组可通过引用TCP RST类型的负载均衡探测模板来统计实服务组中每个实服务器RST报文的个数。
实服务组可通过引用TCP Zero-Window类型的负载均衡探测模板来统计实服务组中每个实服务器零窗口报文的个数。
# 服务器负载均衡场景下,创建名称为rsttplt的负载均衡探测模板,并进入负载均衡探测模板视图。
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt]
# 出方向链路负载均衡场景下,创建名称为icmptplt的负载均衡探测模板,并进入负载均衡探测模板视图。
[Sysname-lbpt-icmp-icmptplt]
1.1.140  loadbalance process-limit
loadbalance process-limit命令用来配置设备允许启动的自定义监控进程个数。
undo loadbalance process-limit命令用来恢复缺省情况。
loadbalance process-limit number
设备允许启动的自定义监控进程个数为1个。
context-admin
number:自定义监控进程个数,取值范围为1~16。
非缺省vSystem不支持本命令。
# 配置设备允许启动的自定义监控进程个数为2。
[Sysname] loadbalance process-limit 2
·     display loadbalance process-limit
1.1.141  loadbalance protection-policy
loadbalance protection-policy命令用来创建防护策略,并进入防护策略视图。如果指定的防护策略已经存在,则直接进入防护策略视图。
undo loadbalance protection-policy命令用来删除指定的防护策略。
loadbalance protection-policy policy-name [ type http ]
undo loadbalance protection-policy policy-name
不存在防护策略。
context-admin
policy-name:防护策略名称,为1~255个字符的字符串,不区分大小写。
type http:防护策略的类型为HTTP类型。创建防护策略时必须指定此参数。进入已创建的防护策略视图可以不指定此参数,若要指定此参数,则必须与创建时的类型一致。
非缺省vSystem不支持本命令。
# 创建HTTP类型的防护策略,并进入HTTP防护策略视图。
[Sysname] loadbalance protection-policy p1 type http
[Sysname-lbpp-http-p1]
1.1.142  loadbalance reload external-link file
loadbalance reload external-link file命令用来加载外链改写文件。
undo loadbalance reload external-link file命令用来取消使用指定的外链改写文件。
loadbalance reload external-link file filename
不使用外链改写文件。
context-admin
filename:外链改写文件的完整路径,为1~256个字符的字符串,不区分大小写。
工作机制
通过执行本命令可以加载指定的外链改写文件。若文件内容发生变化,需要再次执行本命令重新加载,否则文件无法生效。
推荐配置
外链改写文件需要配置为客户端浏览器能够识别的格式,推荐配置为JS脚本文件。
注意事项
非缺省vSystem不支持本命令。
外链改写文件名称不允许与HTTP代答文件名称一致。
# 重新加载外链改写文件/sub_lb_sw.js。
[Sysname] loadbalance reload external-link file /sub_lb_sw.js
·     external-link whitelist domain
1.1.143  loadbalance schedule-test ip
loadbalance schedule-test ip命令用来测试IPv4负载均衡的效果。
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示公网实例。
application:测试的应用。
http:应用的类型为HTTP。
message-file file-name:指定HTTP报文内容所在的文件。file-name为文件名,为1~255字符的字符串,不区分大小写。HTTP报文内容所在文件的大小不能大于5000字节。
method:HTTP协议的请求方法。
get:HTTP协议的请求方法为GET。
post:HTTP协议的请求方法为POST。
url url:HTTP报文的URL,为1~255个字符的字符串,区分大小写,可以包含字母、数字、“-”“_”及“.”,不能出现连续“.”,不支持字符“?”。
[ header header ]&<1-10>:HTTP报文首部,为1~127个字符的字符串,区分大小写,不支持字符“?”。&<1-10>表示前面的参数最多可以重复输入10次。
content content-value:HTTP报文体的内容,为1~255个字符的字符串,区分大小写,不支持字符“?”。
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMP(1)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv4地址。
destination-port destination-port:目的端口号,取值范围为0~65535。并非所有协议都支持本参数。
source source-address:源IPv4地址。
source-port source-port:源端口号,取值范围为0~65535。并非所有协议都支持本参数。
slot slot-number:测试指定成员设备,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将测试所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 测试TCP协议IPv4负载均衡的效果。
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
    Matched virtual server: vs2
    Matched default server farm: sf
    Forward type: Forwarding to real server
    Selected real server: rs2
        Scheduling algorithm: Predictor
    Matched default link group: lg
    Forward type: Forwarding to link
    Selected link: link2
表1-34 loadbalance schedule-test ip命令显示信息描述表
匹配的虚服务器名称
No matched virtual servers.
未匹配任何虚服务器
Matched class
匹配的负载均衡类名称
Matched the default class.
匹配了缺省负载均衡动作
匹配的缺省实服务组名称
匹配的缺省链路组名称
Forward type
转发类型,包括:
·     The destination address is not supported. Load balancing is not performed:不支持此目的地址,不进行负载均衡
·     Matching HTTP virtual server is not supported:匹配了HTTP类型的虚服务器,不支持负载均衡
·     Forward all:转发报文
·     Forwarding to real server:将报文转发给实服务器
·     Forwarding to link:将报文转发给链路
·     Drop:丢弃报文
·     Redirect:重定向
·     Waiting:排队等待
Drop reason
丢弃报文的原因,包括:
·     Number of connections or bandwidth for the virtual server exceeded the limit:虚服务器连接数或带宽受限
·     No class matched and no valid default server/link group farm configured:输入的五元组未匹配任何负载均衡类,且未配置有效的缺省实服务器组/链路组
·     No valid real server/link in the server farm/link group:选择的实服务器组/链路组中没有可用的实服务器/链路
·     Action is drop:负载均衡动作为丢弃报文
·     A sticky entry was matched but the number of connections or bandwidth for the real server/link exceeded the limit:匹配的持续性表项所对应的实服务器/链路连接数或带宽受限
·     A class was matched but no valid server farm/link group exists in the action of the class:匹配的负载均衡类所对应的负载均衡动作中没有可用的实服务组/链路组
·     The HTTP message is not valid:HTTP报文的内容不合法
·     The HTTP request line is not valid:HTTP报文请求行不合法
·     The HTTP header is not valid:HTTP报文首部不合法
·     The chunk HTTP content is not valid:HTTP报文体的chunk编码不合法
·     The server farm is busy:实服务器组繁忙
·     Queue overflow:排队等待的队列长度超出限制
选择的实服务器名称
Selected link
选择的链路名称
选择该实服务器的依据,包括:
·     Predictor:根据调度算法选择了该实服务器/链路
·     Sticky method:根据持续性方法选择了该实服务器/链路
·     Proximity:根据就近性方法选择了该链路
1.1.144  loadbalance schedule-test ipv6
loadbalance schedule-test ipv6命令用来测试IPv6负载均衡效果。
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
context-admin
application:测试的应用。
http:应用的类型为HTTP。
message-file file-name:指定HTTP报文内容所在的文件。file-name为1~255字符的字符串,不区分大小写。HTTP报文内容所在文件的大小不能大于5000字节。
method:HTTP协议的请求方法。
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMPv6(58)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv6地址。
source source-address:源IPv6地址。
非缺省vSystem不支持本命令。
# 测试ICMPv6协议IPv6负载均衡的效果。
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
表1-35 loadbalance schedule-test ipv6命令显示信息描述表
匹配的虚服务器名称
未匹配任何虚服务器
Matched class
匹配的负载均衡类名称
匹配了缺省负载均衡动作
匹配的缺省实服务组名称
匹配的缺省链路组名称
Forward type
转发类型,包括:
·     Forward all:转发报文
·     Forwarding to real server/link:将报文转发给实服务器/链路
·     Drop:丢弃报文
·     Redirect:重定向
·     Waiting:排队等待
Drop reason
丢弃报文的原因,包括:
·     No class matched and no valid default server farm/link group configured:输入的五元组未匹配任何负载均衡类,且未配置有效的缺省实服务器组/链路组
Selected real server/link
选择的实服务器/链路名称
选择该实服务器/链路的依据,包括:
1.1.145  loadbalance snat-global-policy
loadbalance snat-global-policy命令用来创建SNAT全局策略,并进入SNAT全局策略视图。如果指定的SNAT全局策略已经存在,则直接进入SNAT全局策略视图。
undo loadbalance snat-global-policy命令用来删除指定的SNAT全局策略。
loadbalance snat-global-policy policy-name
undo loadbalance snat-global-policy policy-name
不存在SNAT全局策略。
context-admin
vsys-admin
policy-name:SNAT全局策略的名称,为1~255个字符的字符串,不区分大小写。
# 创建SNAT全局策略,并进入SNAT全局策略视图。
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1]
·     snat-mode
·     snat-pool (server farm view)
1.1.146  loadbalance snat-pool
loadbalance snat-pool命令用来创建SNAT地址池,并进入SNAT地址池视图。如果指定的SNAT地址池已经存在,则直接进入SNAT地址池视图。
undo loadbalance snat-pool命令用来删除指定的SNAT地址池。
loadbalance snat-pool pool-name
undo loadbalance snat-pool pool-name
不存在任何SNAT地址池。
context-admin
vsys-admin
# 创建SNAT地址池lbsp,并进入SNAT地址池视图。
1.1.147  loadbalance ssl performance-optimize cache-value
loadbalance ssl performance-optimize cache-value命令用来配置SSL性能优化的缓存值。
undo loadbalance ssl performance-optimize cache-value命令用来恢复缺省情况。
loadbalance ssl performance-optimize cache-value cache-value
SSL性能优化的缓存值为0KB。
cache-value:SSL性能优化的缓存值,取值范围为0~15,单位为KB。当取值为0时,表示缓存大小不受限制。
非缺省vSystem不支持配置本命令。
通过配置本命令,指定SSL性能优化的缓存值大小,当SSL缓存达到配置的阈值时,将统一发送至服务器。
# 配置性能优化的缓存值为12KB。
[Sysname] loadbalance ssl performance-optimize cache-value 12
1.1.148  loadbalance tcp-timestamp-mode
loadbalance tcp-timestamp-mode命令用来配置全局TCP时间戳选项的动作。
undo loadbalance tcp-timestamp-mode命令用来恢复缺省情况。
loadbalance tcp-timestamp-mode { preserve | rewrite | remove }
全局TCP时间戳选项的动作为保持。
context-admin
preserve:保持TCP报文头中的时间戳选项。
rewrite:重写TCP报文头中的时间戳选项。
remove:清除TCP报文头中的时间戳选项。
工作机制
本命令用来对负载均衡设备发送给服务器的TCP报文头中的时间戳选项进行保持、重写或清除操作。
·     保持TCP时间戳:保持TCP报文头中的时间戳选项字段的值不变。
·     重写TCP时间戳:修改TCP报文头中的时间戳选项字段的值为设备当前时间戳值。
·     清除TCP时间戳:去除TCP报文头中的时间戳选项字段。在某些网络环境下,不需要时间戳机制,去除时间戳可以减少数据包的大小,提高网络传输性能。此外,当后台实服务器不支持时间戳机制时,也可以通过本功能清除TCP报文头中的时间戳选项。
注意事项
通过本功能配置全局TCP时间戳选项时,对TCP、HTTP、Diameter和Mysql类型的虚服务器生效;而通过在TCP类型参数模板视图下执行tcp option preserve、tcp option rewrite或tcp option remove命令来配置TCP时间戳选项时,则对引用该参数模板的虚服务器生效,后者的配置优先级较高。
# 配置全局TCP时间戳选项的动作为保持。
[Sysname] loadbalance tcp-timestamp-mode preserve
·     tcp option preserve
·     tcp option remove
·     tcp option rewrite
1.1.149  loadbalance test pcre
loadbalance test pcre命令用来测试PCRE正则表达式的匹配效果,并显示匹配结果。
loadbalance test pcre value value { string string | file file-name } [ offset offset ] [ case-insensitive ]
context-admin
value value:PCRE正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符“?”。
string string:待测试的字符串,为1~255个字符,区分大小写。
file file-name:待测试的文件名,为1~255字符的字符串,不区分大小写。待测试的文件大小不能大于5000字节。
offset offset:基于待测试内容的偏移量,取值范围为0~255,单位为字节,缺省值为0。
case-insensitive:表示匹配正则表达式时对大小写不敏感。若未指定本参数,则匹配正则表达式时区分大小写。
工作机制
当待测试的字符串或文件多次匹配输入的正则表达式时,只会显示出第一次匹配该正则表达式的内容。
当待测试内容为输入的字符串时,执行结果以字符串的形式显示出来;当待测试内容为指定文件中的内容时,匹配结果将以十六进制数和字符串的形式同时打印出来,其中,无法显示的字符用“.”来表示。
注意事项
非缺省vSystem不支持本命令。
# 测试字符串内容的PCRE正则表达式匹配结果,匹配正则表达式时对大小写不敏感。
<Sysname> loadbalance test pcre value aaa string ABCDAAaefg case-insensitive
Matched string content: AAa
# 测试文件内容的PCRE正则表达式匹配结果。
<Sysname> loadbalance test pcre value dzckgjlfdsfdsfsdnfsdkjgnf file 123.txt
Matched file content:
64 7a 63 6b 67 6a 6c 66 64  73 66 64 73 66 73 64   dzckgjlf dsfdsfsd
6e 66 73 64 6b 6a 67 6e 66  64                     nfsdkjgn f
表1-36 loadbalance test pcre命令显示信息描述表
匹配PCRE正则表达式的字符串
匹配PCRE正则表达式的文件内容
1.1.150  loadbalance test rewrite
loadbalance test rewrite命令用来测试根据正则表达式重写的效果,并显示重写结果。
loadbalance test rewrite value value replace replace-string { string string | file file-name } [ offset offset ] [ case-insensitive ]
context-admin
value value:用于匹配待重写内容的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符“?”。也可以使用以下特定含义的字符串:%is表示源IP地址;%ps表示源端口号;%id表示目的IP地址;%pd表示目的端口号。
replace replace-string:重写后的内容,为1~255个字符的字符串,区分大小写。
offset offset:基于待处理内容的偏移量,取值范围为0~255,单位为字节,缺省值为0。
工作机制
当待处理的字符串或文件匹配输入的正则表达式时,本命令将匹配成功的内容替换为重写后的内容。
当待处理的字符串或文件多次匹配输入的正则表达式时,只会显示出第一次匹配该正则表达式的字符串被替换后的内容。
当待处理内容以字符串的形式输入时,处理结果以字符串的形式显示出来,当待处理内容以文件的形式输入时,处理结果以十六进制数和字符串的形式同时显示印出来,其中,无法显示的字符用“.”来表示。
注意事项
非缺省vSystem不支持本命令。
# 测试字符串内容重写的效果,匹配待重写内容的正则表达式时对大小写不敏感。
<Sysname> loadbalance test rewrite value %id replace ip:%id,port:%pd string ABCDAAaefg case-insensitive
Rewritten string content: ABCD172.0.0.1fg
# 测试文件内容重写的效果。
<Sysname> loadbalance test rewrite value dzckgjlfdsfdsfsdnfsdkjgnf replace ip:%id,port:%pd file 123.txt
Rewritten file content:
66 67 73 2d 61 47 76 61 73  64 64 73 61 67 76 62   fgs-aGva sddsagvb
64 6a 63 78 6b 6c 63 78 76  0d 0a 0d 0a 0d 0a 0d   djcxklcx v.......
0a 69 70 3a 31 37 32 2e 30  2e 30 2e 31 2c 70 6f   .ip:172. 0.0.1,po
72 74 3a 38 30 09 6a 6b 64  67 6e 66 64 6a 6b 67   rt:80.jk dgnfdjkg
6e 66 64 6b 6a 67 6e 66 64  6b 6e 67 76 73 64 66   nfdkjgnf dkngvsdf
6c 0d 0a 0d 0a 0d 0a 0d 0a  66 67 73 2b 61 67 76   l....... .fgs+agv
61 73 64 64 73 61 67 76 62  64 6a 63 78 6b 6c 63   asddsagv bdjcxklc
78 76 0d 0a 66 67 73 64 61  67 76 61 73 64 64 73   xv..fgsd agvasdds
61 67 76 62 64 6a 63 78 6b  6c 63 78 76            agvbdjcx klcxv
表1-37 loadbalance test rewrite命令显示信息描述表
重写后的字符串内容
重写后的文件内容
1.1.151  location rewrite
location rewrite命令用来重写服务器发送的HTTP应答报文Location首部的内容。
undo location rewrite命令用来恢复缺省情况。
location rewrite match regex match-pattern replace replace-string
undo location rewrite match regex match-pattern replace replace-string
未对服务器发送的HTTP应答报文Location首部的内容进行重写。
HTTP类型负载均衡动作视图
context-admin
vsys-admin
match:表示用来匹配待重写的Location首部的内容。
regex match-pattern:表示待重写的Location首部的正则表达式内容,为1~127个字符的字符串,区分大小写,支持正则元字符?。
replace replace-string:表示重写后的Location首部的内容,为1~127个字符的字符串,区分大小写。
实现机制
配置本命令后,如果HTTP应答报文包含302重定向且匹配了指定的match-pattern,系统会将Location首部的内容按照匹配的match-pattern重写为replace-string。
可通过多次配置本命令,定义多条重写规则。若通过多次配置本命令对相同内容的Location首部进行重写,则最后一次配置生效。
注意事项
在同一HTTP类型的负载均衡动作视图下,建议配置不超过16条。
Location首部的重定向会在SSL URL重定向改写之后执行,匹配SSL URL改写后的结果再进行Location首部内容的改写。
# 在HTTP类型的负载均衡动作lba2中,将服务器发送的HTTP应答报文Location首部,由http://www.example.com:9080重写为http://www.example.com:80。
[Sysname-lba-http-lba2] location rewrite match regex (http://www.example.com):9080 replace %1:80
·     ssl url rewrite location
1.1.152  manual-recover enable (server farm member view)
manual-recover enable命令用来开启健康检测手动恢复功能。
undo manual-recover enable命令用来关闭健康检测手动恢复功能。
健康检测手动恢复功能处于关闭状态。
实服务组成员视图
context-admin
vsys-admin
缺省情况下,健康检测手动恢复功能处于关闭状态,当实服务组成员健康检测成功后,设备会自动将其恢复为可用状态。若开启健康检测手动恢复功能,当实服务组成员健康检测成功后,需要在实服务组成员视图下执行recover-to-active命令手动恢复其为可用状态。
# 开启实服务组成员rs1的健康检测手动恢复功能。
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] manual-recover enable
·     recover-to-active (server farm member view)
1.1.153  manual-recover enable (server farm view)
健康检测手动恢复功能处于关闭状态。
实服务组视图
context-admin
vsys-admin
# 开启实服务组sf的健康检测手动恢复功能。
[Sysname-sfarm-sf] manual-recover enable
1.1.154  match acl
match acl命令用来创建ACL类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match命令用来删除指定的匹配规则。
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
不存在匹配规则。
负载均衡类视图
context-admin
vsys-admin
match-id:匹配规则的编号,取值范围为1~65535。若未指定本参数,系统将自动分配一个可用的最小编号。
ipv6:表示IPv6 ACL类型。若未指定本参数,表示IPv4 ACL类型。
name acl-name:ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
如果指定编号或名称的ACL不存在,此匹配规则将不参与匹配。
一个负载均衡类中最多允许创建65535条匹配规则。
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc1中,创建ACL类型的匹配规则。
[Sysname-lbc-generic-lbc1] match acl 2000
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc2中,创建ACL类型的匹配规则。
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match acl 2000
# DNS透明代理场景下,在DNS类型的负载均衡类lbc3中,创建ACL类型的匹配规则。
[Sysname] loadbalance class lbc3 type dns
[Sysname-lbc-dns-lbc3] match acl 2000
1.1.155  match application-id
match application-id命令用来创建应用ID类型的匹配规则。如果匹配规则已经存在,则直接对其进行修改。
match [ match-id ] application-id [ application-id | all ]
undo match match-id
负载均衡类中不存在匹配规则。
Diameter类型的负载均衡类视图
context-admin
vsys-admin
application-id:应用识别号,取值范围为1~4294967295。
all:表示与所有应用都可进行匹配。
指定的应用ID应为Diameter基础协议和扩展协议中定义的应用识别号,如果指定的应用ID不存在,此匹配规则将不参与匹配。
# 在Diameter类型的负载均衡类lbc1中,创建基于应用ID的匹配规则。
[Sysname] loadbalance class lbc1 type diameter
[Sysname-lbc-diameter-lbc1] match application-id 3
·     loadbalance class
1.1.156  match class
match class命令用来创建嵌套类的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] class class-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
vsys-admin
class-name:要嵌套的负载均衡类名称,为1~255个字符的字符串,不区分大小写。不允许嵌套当前的负载均衡类。
在创建嵌套类的匹配规则时,最多只能嵌套一层。即本命令不能引用已嵌套的负载均衡类。
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc1中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname-lbc-generic-lbc1] match class lbc2
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc3中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname] loadbalance class lbc3 type link-generic
[Sysname-lbc-link-generic-lbc3] match class lbc2
# DNS透明代理场景下,在DNS类型的负载均衡类lbc4中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname] loadbalance class lbc4 type dns
[Sysname-lbc-dns-lbc4] match class lbc2
1.1.157  match content
match content命令用来创建HTTP实体类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] content content [ offset offset ]
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
vsys-admin
content content:HTTP实体的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符?。
offset offset:HTTP实体基于HTTP报文起始位置的偏移量,取值范围为0~1000,单位为字节,缺省值为0。
配置了本命令后,如果HTTP报文的实体部分在偏移了offset后能够匹配指定的正则表达式,便认为此报文匹配了该规则。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP实体类型的匹配规则为:HTTP报文的实体部分偏移了10之后,包含字符串abc。
[Sysname] loadbalance class lbc2 type http
[Sysname-lbc-http-lbc2] match content abc.* offset 10
1.1.158  match cookie
match cookie命令用来创建HTTP Cookie类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] cookie cookie-name value value
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
vsys-admin
cookie cookie-name:HTTP报文的Cookie名称,为1~63个字符的字符串,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
value value:Cookie值的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符?。
配置了本命令后,如果HTTP报文中携带有指定名称的Cookie,且Cookie值匹配了指定的正则表达式,便认为此报文匹配了该规则。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP Cookie类型的匹配规则为:名为JSession-id的Cookie,其值中包含字符串abc。
[Sysname-lbc-http-lbc2] match cookie JSeesion-id value abc.*
1.1.159  match destination-realm
match destination-realm命令用来创建目的域类型的匹配规则。如果匹配规则已经存在,则直接对其进行修改。
undo match命令用来删除指定匹配规则。
match [ match-id ] destination-realm realm-name
undo match  match-id
负载均衡类中不存在匹配规则。
Diameter类型的负载均衡类视图
context-admin
vsys-admin
realm-name:目的域名,为1~127个字符的字符串,区分大小写。流量特征匹配时是精确匹配。
当在Diameter类型的负载均衡类中配置了目的域类型的匹配规则,则流量匹配上指定的目的域名之后,执行相应的负载均衡动作。如果指定的域名不存在,此匹配规则将不参与匹配。
# 在Diameter类型的负载均衡类lbc1中,创建基于目的域的匹配规则。
[Sysname-lbc-diameter-lbc1] match destination-realm example.com
·     loadbalance class
1.1.160  match header
match header命令用来创建HTTP首部类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] header header-name { value regex-value | value-string string }
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
vsys-admin
header header-name:HTTP报文首部的名称,为1~63个字符的字符串,不区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
value value:首部值的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符?。
value-string string:首部值的普通字符串,为1~255个字符的字符串,区分大小写。
配置了本命令后,如果HTTP报文中携带有指定名称的首部,且首部值匹配了指定的正则表达式或普通字符串,便认为此报文匹配了该规则。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP首部类型的匹配规则为:名为user-agent的HTTP报文首部,其值为abcd。
[Sysname-lbc-http-lbc2] match header user-agent value abcd
1.1.161  match interface
match interface命令用来创建基于入接口的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] interface interface-type interface-number
undo match match-id
负载均衡类中不存在匹配规则。
通用/链路/HTTP类型的负载均衡类视图
context-admin
interface-type interface-number:指定接口类型和接口编号。接口类型包括三层以太网接口、三层聚合接口。
非缺省vSystem不支持本命令。
如果匹配规则中指定的接口不存在,则此规则不生效
# 出方向链路负载均衡场景下,在链路负载均衡类lbc1中,创建基于入接口的匹配规则。
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1] match interface gigabitethernet 1/0/0
# 服务器负载均衡场景下,在通用负载均衡类lbc2中,创建基于入接口的匹配规则。
[Sysname] loadbalance class lbc2 type generic
[Sysname-lbc-generic-lbc2] match interface gigabitethernet 1/0/0
1.1.162  match method
match method命令用来创建HTTP方法类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] method { ext ext-type | rfc rfc-type }
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
vsys-admin
ext ext-type:扩展类型,即用户可以输入指定的字符串作为方法名。ext-type为1~63个字符,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
rfc rfc-type:RFC类型,即对HTTP请求报文中URI所标识资源的执行方法。rfc-type包括:
·     CONNECET:保留。
·     DELETE:请求删除URI所标识的资源。
·     GET:请求获取URI所标识的资源。
·     HEAD:请求获取URI所标识资源的响应消息首部。
·     OPTIONS:请求查询服务器支持的功能,即查询与URI所标识资源相关的选项和需求。
·     POST:在URI所标识的资源后附加新数据。
·     PUT:请求服务器存储一个资源,并用URI作为其标识。
·     TRACE:请求服务器回送收到的请求消息,主要用于测试或诊断。
# 在HTTP类型的负载均衡类lbc2中,创建匹配报文方法类型的匹配规则为扩展类型的user。
[Sysname-lbc-http-lbc2] match method ext user
# 在HTTP类型的负载均衡类lbc2中创建匹配报文方法类型的匹配规则为RFC类型的CONNECT。
[Sysname-lbc-http-lbc2] match method rfc CONNECT
1.1.163  match payload
match payload命令用来创建TCP载荷类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
undo match命令用来在删除指定的匹配规则。
match [ match-id ] payload payload [ case-insensitive ] [ not ]
undo match match-id
负载均衡类中不存在匹配规则。
通用类型的负载均衡类视图
context-admin
vsys-admin
payload:匹配TCP载荷的正则表达式,为1~255个字符的字符串,区分大小写。
not:表示匹配条件取反。若未指定本参数,则匹配上指定的正则表达式之后,执行相应的负载均衡动作。
当在通用类型的负载均衡类中配置了TCP载荷类型的匹配规则,则TCP流量匹配上指定的正则表达式之后,执行相应的负载均衡动作。若在配置TCP载荷类型的匹配规则时,指定了not参数,则在TCP流量未匹配指定的正则表达式时,执行相应的负载均衡动作。
# 在通用类型的负载均衡类c1中,创建TCP载荷类型的匹配规则为:完全匹配hello。
[Sysname] loadbalance class c1 type generic
[Sysname-lbc-generic-c1] match payload hello
1.1.164  match radius-attribute
match radius-attribute命令用来创建RADIUS属性的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
undo match命令用来删除指定的RADIUS属性匹配规则。
match [ match-id ] radius-attribute { code attribute-code | user-name } value attribute-value
undo match match-id
负载均衡类中不存在RADIUS属性的匹配规则。
RADIUS类型的负载均衡类视图
context-admin
vsys-admin
code attribute-code:指定RADIUS属性类型的编号,取值范围为1~255。
user-name:指定RADIUS属性类型为User-Name(编号为1)。
value attribute-value:匹配RADIUS属性值的正则表达式,为1~255个字符的字符串,区分大小写。
# 在RADIUS类型的负载均衡类lbc1中,创建RADIUS属性类型为User-Name的匹配规则:属性值中包含字符串aaa。
[Sysname] loadbalance class lbc1 type radius
[Sysname-lbc-radius- lbc1] match radius-attribute user-name value aaa*
1.1.165  match source
match source命令用来创建源IP地址类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
vsys-admin
ip address ipv4-address:IPv4地址。
mask-lengh:子网掩码长度,取值范围为0~32,缺省值为32。
mask:子网掩码,缺省值为255.255.255.255。
ipv6 address ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为0~128,缺省值为128。
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc1中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-generic-lbc1] match source ip address 1.1.1.1
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc2中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-link-generic-lbc2] match source ip address 1.1.1.1
# DNS透明代理场景下,在DNS类型的负载均衡类lbc3中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-dns-lbc3] match source ip address 1.1.1.1
1.1.166  match sql
match sql命令用来创建MySQL语句类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] sql sql [ case-insensitive ] [ not ]
undo match match-id
负载均衡类中不存在匹配规则。
MySQL类型的负载均衡类视图
context-admin
vsys-admin
sql:匹配MySQL语句的正则表达式,为1~255个字符的字符串,区分大小写。
not:表示在未匹配指定的正则表达式时,执行相应的负载均衡动作。若未指定本参数,则匹配上指定的正则表达式之后,执行相应的负载均衡动作。
# 在MySQL类型的负载均衡类c1中,创建MySQL语句类型的匹配规则为:完全匹配select。
[Sysname] loadbalance class c1 type mysql
[Sysname-lbc-mysql-lbc1] match sql select
1.1.167  match url
match url命令用来创建HTTP URL类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] url url
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
vsys-admin
url url:URL的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符?。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP URL类型的匹配规则为:.*.html。
[Sysname-lbc-http-lbc2] match url .*.html
1.1.168  match user
match user命令用来创建基于用户的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] [ identity-domain domain-name ] user user-name
undo match match-id
负载均衡类中不存在任何匹配规则。
context-admin
vsys-admin
identity-domain domain-name:表示在指定的身份识别域中匹配此用户。domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括字符“?”。若未指定本参数,则表示在不属于任何身份识别域的用户中匹配此用户。
user-name:用户名,为1~55个字符的字符串,区分大小写。
如果匹配规则中指定的用户不存在,则此规则不生效。
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc1中,创建基于用户的匹配规则为:匹配属于身份识别域domain1的用户u1。
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user u1
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc2中,创建基于用户的匹配规则为:匹配属于身份识别域domain1的用户u1。
[Sysname-lbc-generic-lbc2] match identity-domain domain1 user u1
·     display loadbalance class
1.1.169  match user-group
match user-group命令用来创建基于用户组的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] [ identity-domain domain-name ] user-group user-group-name
undo match match-id
负载均衡类中不存在匹配规则。
context-admin
vsys-admin
user-group-name:用户组名称,为1~200个字符的字符串,不区分大小写。
如果匹配规则中指定的用户组不存在,则此规则不生效。
# 出方向链路负载均衡场景下,在链路类型的负载均衡类lbc1中,创建基于用户组的匹配规则为:匹配属于身份识别域domain1用户组lb-group。
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user-group lb-group
# 服务器负载均衡场景下,在通用类型的负载均衡类lbc2中,创建基于用户组的匹配规则为:匹配属于身份识别域domain1用户组lb-group。
[Sysname-lbc-generic-lbc2] match identity-domain domain1 user-group lb-group
1.1.170  match version
match version命令用来创建HTTP版本类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] version { 1.0| 1.1 | 2.0 }
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
vsys-admin
1.0:HTTP 1.0版本。
1.1:HTTP 1.1版本。
2.0:HTTP 2.0版本。
# 在HTTP类型的负载均衡类lbc1中,创建HTTP版本类型的匹配规则为:匹配HTTP版本为1.0。
[Sysname] loadbalance class lbc1 type http
[Sysname-lbc-dns-lbc1] match version 1.0
1.1.171  match-across-service enable
match-across-service enable命令用来开启跨服务匹配持续性表项功能。
undo match-across-service enable命令用来关闭跨服务匹配持续性表项功能。
跨服务匹配持续性表项功能处于关闭状态。
地址端口类型的持续性组视图
RADIUS类型的持续性组视图
Diameter类型的持续性组视图
context-admin
若持续性组中开启了跨服务匹配持续性表项功能,则同一客户端请求相同虚服务器地址的不同服务时,始终分配给同一个实服务组成员处理。
开启本功能后,在持续性表项匹配时,若流量未匹配到当前虚服务器生成的持续性表项,则会继续匹配与当前虚服务器地址相同的其它虚服务器生成的持续性表项。
# 在地址端口类型的持续性组sg1中,开启跨服务匹配持续性表项功能。
[Sysname-sticky-address-port-sg1] match-across-service enable
1.1.172  match-across-virtual-server enable
match-across-virtual-server enable命令用来开启跨虚服务器匹配持续性表项功能。
undo match-across-virtual-server enable命令用来关闭跨虚服务器匹配持续性表项功能。
跨虚服务器匹配持续性表项功能处于关闭状态。
地址端口类型的持续性组视图
RADIUS类型的持续性组视图
Diameter类型的持续性组视图
context-admin
若持续性组中开启了跨虚服务器匹配持续性表项功能,则同一客户端请求不同虚服务器时,始终分配给同一个实服务组成员处理。
开启本功能后,在持续性表项匹配时,若流量未匹配到当前虚服务器生成的持续性表项,则会继续匹配其它虚服务器生成的持续性表项。
# 在地址端口类型的持续性组sg1中,开启跨虚服务器匹配持续性表项功能。
[Sysname-sticky-address-port-sg1] match-across-virtual-server enable
1.1.173  match-buffer-end
match-buffer-end命令用来配置TCP载荷匹配的缓冲结束符。
undo match-buffer-end命令用来恢复缺省情况。
match-buffer-end string
未指定TCP载荷匹配的缓冲结束符。
TCP-application类型的参数模板
context-admin
vsys-admin
string:缓冲结束符,为1~31个字符的字符串,不区分大小写。
当基于TCP载荷类型的匹配规则生效后,在TCP载荷匹配的缓冲时间内,设备会缓冲客户端发给虚服务器的流量进行TCP载荷匹配。直到出现以下几种情况才结束缓冲:
·     收到缓冲结束字符。
·     缓冲数据长度超过配置的TCP缓冲数据大小。
·     缓冲数据已经与匹配规则匹配。
通过配置本命令可以指定设备缓冲客户端发给虚服务器TCP流量的缓冲结束符。
# 在TCP-application类型的参数模板p1中,配置TCP载荷匹配的缓冲结束符为over。
[Sysname] parameter-profile p1 type tcp-application
[Sysname-para-tcp-application-p1] match-buffer-end over
·     match payload
·     match-buffer-size
·     match-buffer-end
1.1.174  match-buffer-size
match-buffer-size命令用来配置TCP载荷匹配的缓冲数据大小。
undo match-buffer-size命令用来恢复缺省情况。
match-buffer-size size
TCP载荷匹配的缓冲数据大小为4096字节。
TCP-application类型的参数模板视图
context-admin
vsys-admin
·     收到缓冲结束字符。
·     缓冲数据已经与匹配规则匹配。
通过配置本命令可以指定设备缓冲客户端发给虚服务器TCP数据的大小。
# 在TCP-application类型的参数模板p1中,配置TCP载荷匹配的缓冲数据大小为2048字节。
[Sysname-para-tcp-application-p1] match-buffer-size 2048
·     match payload
·     match-buffer-size
·     match-buffer-end
1.1.175  match-buffer-time
match-buffer-time命令用来配置TCP载荷匹配的缓冲时间。
undo match-buffer-time命令用来恢复缺省情况。
match-buffer-time time
TCP载荷匹配的缓冲时间为3秒。
context-admin
vsys-admin
time:缓冲时间,取值范围为1~5,单位为秒。
·     收到缓冲结束字符。
·     缓冲数据已经与匹配规则匹配。
通过配置本命令可以指定设备缓冲客户端发给虚服务器TCP流量的时长。
# 在TCP-application类型的参数模板p1中,配置TCP载荷匹配的缓冲时间。
[Sysname-para-tcp-application-p1] match-buffer-time 3
·     match payload
·     match-buffer-size
·     match-buffer-end
1.1.176  max-reuse (parameter profile view)
max-reuse命令用来配置负载均衡设备与服务器之间TCP连接的最大复用次数。
undo max-reuse命令用来恢复缺省情况。
max-reuse reuse-number
undo max-reuse
负载均衡设备与服务器之间TCP连接的最大复用次数为1000。
OneConnect类型的参数模板视图
MySQL类型的参数模板视图
context-admin
reuse-number:TCP连接的最大复用次数,取值范围为1~4294967295,数值不包含首次新建。
工作机制
开启了负载均衡设备与服务器的连接复用功能后,在负载均衡设备与服务器之间TCP连接的复用次数达到最大次数之前,连接将始终保持。当负载均衡设备与服务器TCP连接的复用次数达到最大次数时,此TCP连接将会被断开,后续客户端发起的连接请求将触发建立新的TCP连接。
注意事项
非缺省vSystem不支持本命令。
# 在OneConnect类型的参数模板ocp中,配置负载均衡设备与服务器之间TCP连接的最大复用次数为10000。
[Sysname-para-oneconnect-ocp] max-reuse 10000
1.1.177  memory-size
memory-size命令用来设置对应答报文压缩所占用的内存大小。
undo memory-size命令用来恢复缺省情况。
memory-size size
undo memory-size
应答报文压缩所占用的内存大小为8KB。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
# 创建HTTP压缩类型的参数模板pa1,并指定压缩使用的内存大小为32KB。
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] memory-size 32
1.1.178  monitor-interval
monitor-interval命令用来配置负载均衡探测模板的监控周期。
undo monitor-interval命令用来恢复缺省情况。
monitor-interval interval-time
TCP RST类型和TCP zero-window类型负载均衡探测模板的监控周期为10秒,HTTP passive类型负载均衡探测模板的监控周期为1秒,自定义监控类型负载均衡探测模板的监控周期为5秒。
HTTP passive类型的负载均衡探测模板视图
TCP RST类型的负载均衡探测模板视图
TCP zero-window类型的负载均衡探测模板视图
自定义监控类型的负载均衡探测模板视图
context-admin
vsys-admin
interval-time:监控周期,TCP RST类型和TCP zero-window类型的取值范围为5~255,HTTP passive类型的取值范围为1~5,自定义监控类型的取值范围为1~86400,单位为秒。
当TCP RST类型或TCP zero-window类型的负载均衡探测模板被引用后,在监控周期内,系统会对实服务组中每个实服务器成员发送的TCP RST报文和TCP零窗口报文的个数进行统计。
当HTTP passive类型的负载均衡探测模板被引用后,若设备收到携带指定URL的HTTP请求报文,则会对其响应报文进行HTTP被动健康检测。在监控周期内,设备会对异常URL的次数进行统计。
当自定义监控类型的负载均衡探测模板被引用后,系统会在每个监控周期到来时执行一次自定义监控脚本文件(通过命令external-script配置)。
# 在TCP RST类型的负载均衡探测模板下,配置监控时间为60秒。
[Sysname-lbpt-tcp-rst-rsttplt] monitor-interval 60
·     external-script
1.1.179  node
node命令用来创建统计节点,并进入统计节点视图。如果指定的统计节点已经存在,则直接进入统计节点视图。
undo node命令用来删除指定的统计节点。
node node-name
undo node node-name
不存在统计节点。
HTTP统计类型的参数模板视图
context-admin
node-name:统计节点的名称,为1~255个字符的字符串,不区分大小写。
非缺省vSystem不支持本命令。
一个HTTP统计类型的参数模板视图下,最多允许配置256个统计节点。
# 在HTTP统计类型的参数模板http1视图下,创建统计节点node1,并进入统计节点视图。
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] node node1
[Sysname-para-http-statistics-http1-node-node1]
1.1.180  origin-host
origin-host命令用来配置源主机名。
undo origin-host命令用来恢复缺省情况。
origin-host host-name
undo origin-host
源主机名为host.h3c.com。
context-admin
vsys-admin
host-name:表示源主机名称,为1~127个字符的字符串,区分大小写。
工作机制
设备与对端进行Diameter协商时,会通过CER和CEA协商报文进行信息交换,交换的信息包括:源主机名、源域名、厂商ID及产品名称等。通过本命令指定设备的源主机名,当设备与对端进行Diameter协商时,设备将配置的源主机名作为本端设备主机名发送给对端。
推荐配置
配置的源主机名应为FQDN(Fully Qualified Domain Name,完全合格域名)形式,即同时带有主机名和源域名的名称,源域名通过origin-realm进行配置。例如:主机名为host1,源域名为example.com,则源主机名应配置为host1.example.com。
# 在Diameter-session类型的参数模板dia下,配置源主机名为rd.example.com。
[Sysname-para-diameter-session-dia] origin-host rd.example.com
·     origin-realm
·     parameter-profile
1.1.181  origin-realm
origin-realm命令用来配置源域名。
undo origin-realm命令用来恢复缺省情况。
origin-realm realm-name
undo origin-realm
源域名为h3c.com。
context-admin
vsys-admin
realm-name:表示域名,为1~127个字符的字符串,区分大小写。
设备与对端进行Diameter协商时,会通过CER和CEA协商报文进行信息交换,交换的信息包括:源主机名、源域名、厂商ID及产品名称等。通过本命令指定设备的源域名,当设备与对端进行Diameter协商时,设备将配置的域名作为本机域名发送给对端。
# 在Diameter-session类型的参数模板dia下,配置源域名为example.com。
[Sysname-para-diameter-session-dia] origin-realm example.com
·     origin-host
·     parameter-profile
1.1.182  override-limit enable
override-limit enable命令用来开启匹配持续性表项的会话不受连接数限制。
undo override-limit enable命令用来关闭匹配持续性表项的会话不受连接数限制。
匹配持续性表项的会话受连接数限制配置的影响。
持续性组视图
context-admin
vsys-admin
开启该功能后,如果该连接匹配了已有的持续性表项,将不受实服务器/链路上带宽和连接参数的影响,不受实服务器/链路的带宽繁忙比与最大期望带宽的影响,也不受虚服务器上引用的负载均衡策略连接数限制的影响。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置持续性组st使其对匹配了该持续性组生成的持续性表项的会话不受连接数限制影响。
[Sysname] sticky-group st type address-port
[Sysname-sticky-address-port-st] override-limit enable
1.1.183  parameter (LB action view)
parameter命令用来指定Diameter类型负载均衡动作引用的参数模板。
undo parameter命令用来恢复缺省情况。
parameter { diameter-session | tcp } profile-name [ server-side ]
undo parameter { diameter-session | tcp }
Diameter类型负载均衡动作未引用任何参数模板。
Diameter类型负载均衡动作视图
context-admin
vsys-admin
diameter-session:Diameter-session类型参数模板。
tcp:TCP类型参数模板。
profile-name:参数模板的名称,为1~255个字符的字符串,不区分大小写。
server-side:服务器侧的TCP类型参数模板。
引用Diameter-Session类型参数模板,用来对负载均衡动作为转发到服务器组的流量根据该参数模板进行相应的处理;引用TCP类型的参数模板,用来对设备与服务器之间建立的TCP连接根据该参数模板进行处理和优化。
# 指定Diameter类型的负载均衡动作act引用Diameter-session类型的参数模板pp2。
[Sysname] loadbalance action act type diameter
[Sysname-lba-diameter-act] parameter diameter-session pp2
·     loadbalance action
1.1.184  parameter (virtual server view)
parameter命令用来指定虚服务器引用的参数模板。
parameter { diameter-session | http | http-compression | http-statistics | http2 [ client-side | server-side ] | ip | mysql | oneconnect | tcp | tcp-application } profile-name [ client-side | server-side ]
undo parameter { diameter-session | http | http-compression | http-statistics | http2 [ client-side | server-side ] | ip | mysql | oneconnect | tcp | tcp-application } [ client-side | server-side ]
虚服务器未引用任何参数模板。
虚服务器视图
context-admin
vsys-admin
{ diameter-session | http | http-compression | http-statistics | http2 | ip | mysql | oneconnect | tcp | tcp-application }:参数模板的类型,包括HTTP、HTTP压缩、HTTP统计、HTTP2.0、IP、OneConnect、TCP和TCP-application类型。其中,diameter-session参数只在Diameter类型的虚服务器视图下支持,http只在快速HTTP和HTTP类型的虚服务器视图下支持,http-compression、http-statistics、http2和oneconnect参数只在HTTP类型的虚服务器视图下支持,mysql参数只在MySQL类型的虚服器视图下支持,客户端侧tcp参数仅在Diameter、快速HTTP、HTTP和MySQL类型的虚服务视图下支持,服务端侧tcp参数仅在快速HTTP、HTTP和MySQL类型的虚服务视图下支持,tcp-application参数只在工作在七层的TCP类型的虚服务器视图下支持。
client-side:客户端侧参数模板。
server-side:服务器侧参数模板。
工作机制
参数模板用来对虚服务器上的流量进行比较深入的解析、处理和优化。虚服务器引用了参数模板后,就要根据该参数模板的配置对匹配流量进行相应的处理。若配置了虚服务器引用客户端侧TCP类型的参数模板,则系统对客户端与设备之间建立的TCP连接进行优化和处理;若配置了虚服务器引用服务器侧TCP类型参数模板,则系统对设备与实服务器之间建立的TCP连接进行优化和处理。只有TCP类型参数模板才支持客户端侧与服务器侧分别配置。
若仅配置了虚服务器引用客户端侧的HTTP2.0参数模板,则系统对客户端发起的2.0版本的HTTP报文进行深入的解析、处理和优化,但转发给实服务器的报文为HTTP1.0或1.1版本。若同时配置了虚服务器引用客户端侧和服务器侧的HTTP2.0参数模板,则系统对客户端发起的2.0版本的HTTP报文进行处理和优化,并转发实服务器HTTP2.0版本报文。若管理员只在虚服务器引用服务器侧的HTTP2.0参数模板,则该参数模板不生效;若管理员只在虚服务器引用HTTP类型的参数模板,则只能处理和转发1.0和1.1版本的HTTP报文。
注意事项
RADIUS类型的虚服务器只能引用IP类型的参数模板。
# 指定IP类型的虚服务器vs3引用IP类型的参数模板pp2。
[Sysname-vs-ip-vs3] parameter ip pp2
1.1.185  parameter-profile
parameter-profile命令用来创建参数模板,并进入参数模板视图。如果指定的参数模板已经存在,则直接进入参数模板视图。
undo parameter-profile命令用来删除指定的参数模板。
parameter-profile profile-name [ type { diameter-session | http | http-compression | http-statistics | http2 | ip | mysql | oneconnect | tcp | tcp-application } ]
undo parameter-profile profile-name
不存在任何参数模板。
context-admin
vsys-admin
type { diameter-session | http | http-compression | http-statistics | http2 | ip | mysql | oneconnect | tcp | tcp-application }:参数模板的类型。创建参数模板时必须指定本参数;而在进入已创建的参数模板视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。其中:
·     diameter-session:表示Diameter-session类型。
·     http:表示HTTP类型。
·     http-compression:表示HTTP压缩类型。
·     http-statistics:表示HTTP统计类型。非缺省vSystem不支持本参数。
·     http2:表示HTTP2.0类型。
·     ip:表示IP类型。
·     mysql:表示MySQL类型。
·     oneconnect:表示OneConnect类型。
·     tcp:表示TCP类型。
·     tcp-application:表示TCP-application类型。
工作机制
通过配置参数模板可以进行一些高级参数的配置。这样,当参数模板被虚服务器引用之后,可以对虚服务器的业务流量进行更深入的解析、处理和优化。
配置准备
Diameter-session、HTTP、HTTP2.0、HTTP压缩、MySQL、HTTP统计、OneConnect和TCP-application类型的参数模板需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
# 创建IP类型的参数模板pp2,并进入参数模板视图。
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
1.1.186  payload (HTTP/UDP payload sticky-group view)
payload命令用于配置HTTP或UDP载荷持续性方法。
undo payload命令用来删除HTTP或UDP载荷持续性方法。
payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload
不存在任何持续性方法。
HTTP/UDP载荷类型的持续性组视图
context-admin
vsys-admin
offset offset:HTTP或UDP载荷基于HTTP或UDP报文起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:HTT或UDPP载荷开始标记的正则表达式,即从offset起到本标记为开始,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
end end-string:HTTP或UDP载荷结束标记的正则表达式,即从start-string起到本标记为结束,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
length length:HTTP或UDP载荷的长度,取值范围为0~1000,缺省值为0,单位为字节。
工作机制
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP或UDP载荷信息。start-string和end-string将不计入持续性表项信息中。
注意事项
快速HTTP类型的虚服务器不支持引用HTTP或UDP载荷持续性方法。
# 在HTTP载荷类型的持续性组sg5中,配置HTTP载荷持续性方法为:从HTTP报文起始位置的第10个字节起,长度为20个字节的HTTP载荷来生成持续性表项。
[Sysname] sticky-group sg5 type payload
[Sysname-sticky-payload-sg5] payload offset 10 length 20
# 在UDP载荷类型的持续性组sg6中,配置UDP载荷持续性方法为:从UDP报文起始位置的第28个字节起,长度为6个字节的UDP载荷来生成持续性表项。
[Sysname] sticky-group sg6 type payload
[Sysname-sticky-payload-sg6] payload offset 28 length 6
1.1.187  payload (UDP passive sticky-group view)
payload命令用来配置UDP载荷被动持续性方法。
undo payload命令用来删除UDP载荷被动持续性方法。
payload { get | match } [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload { get | match }
未配置UDP载荷被动持续性方法。
UDP passive类型的持续性组视图
context-admin
vsys-admin
get:表示获取UDP应答报文中的载荷信息,用来生成UDP载荷被动持续性表项。
match:表示获取UDP请求报文中的载荷信息,用来匹配UDP载荷被动持续性表项。
offset offset:UDP载荷基于UDP报文起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:UDP载荷开始标记的正则表达式,即从offset起到本标记为开始,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
end end-string:UDP载荷结束标记的正则表达式,即从start-string起到本标记为结束,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
length length:UDP载荷的长度,取值范围为0~1000,缺省值为0,单位为字节,表示所有长度。
payload get命令用来根据start-string、end-string及length获取UDP应答报文的载荷信息。payload match命令用来根据start-string、end-string及length获取UDP请求报文的载荷信息。
UDP载荷被动持续性方法需要payload get和payload match命令的配合才能生成。
当设备收到UDP请求报文后,根据payload match命令的配置获取到指定的请求报文的载荷信息。若该载荷信息匹配上由payload get命令获取到的UDP应答报文的载荷信息,则根据UDP应答报文的载荷信息生成持续性表项。对于后续收到的UDP请求报文,若匹配上持续性表项,则按照持续性表项转发。
# 在UDP passive类型的持续性组sg5中,配置UDP载荷被动持续性方法为:获取UDP应答报文中字符串“id”后,长度为20个字节的UDP载荷来生成持续性表项。获取UDP请求报文中字符串“id”后,长度为20个字节的UDP载荷来匹配持续性表项。
[Sysname] sticky-group sg5 type udp-passive
[Sysname-sticky-udp-passive-sg5] payload get start id length 20
[Sysname-sticky-udp-passive-sg5] payload match start id length 20
1.1.188  payload rewrite
payload rewrite命令用来重写TCP载荷。
undo payload rewrite命令用来取消重写TCP载荷的配置。
payload rewrite { both | request | response } value value replace replace-string
undo payload rewrite { both | request | response } value value
未对TCP载荷进行重写。
通用类型的负载均衡动作视图
context-admin
vsys-admin
both:请求和应答两个方向的TCP报文。
request:请求方向的TCP报文。
response:应答方向的TCP报文。
value value:要被重写的TCP报文载荷的内容,为1~127个字符的字符串,区分大小写。
replace replace-string:重写后的报文内容,为1~127个字符的字符串,区分大小写,支持携带以下变量:
·     %[variable],为实服务组成员关联的变量,其中,variable该变量的名称。
·     %[1-9],表示按照value中匹配上的内容替换成%[1-9]中对应()中的内容。例如:执行命令payload rewrite value (Wel)(co)(me) replace %2后,将把Welcome字符串替换为第2个括号中的内容co。
设备支持通过配置改写变量%[variable]将TCP报文载荷的指定内容替换为实服务组成员关联的变量值。例如:在实服务组成员视图下执行命令variable var1 value _1,再执行命令payload rewrite request value “QMGR.S01” replace QMGR.S01%[var1]操作后,将把TCP请求报文中的字符串QMGR.S01替换为QMGR.S0_1。
# 在通用类型的负载均衡动作lba1中,将TCP请求报文中的QMGR.S01重写为QMGR.S01%[var1],其中var1为实服务组成员关联的变量名称。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] payload rewrite request value QMGR.S01 replace QMGR.S01%[var1]
·     variable
1.1.189  pool-size
pool-size命令用来配置MySQL连接池的大小。
undo pool-size命令用来恢复缺省情况。
pool-size pool-size
undo pool-size
MySQL连接池的默认大小为1024。
MySQL类型的参数模板视图
context-admin
vsys-admin
pool-size:MySQL连接池的大小,取值范围为1~64000。
当MySQL数据传输完成后,不立即断开TCP连接,而是将TCP连接保存在MySQL连接池中。当需要建立新的连接时,优先从MySQL连接池中获取可用连接,而不是重新建立一个新连接。
MySQL连接池的大小用来限制MySQL连接池可存储的TCP连接的个数。
# 在MySQL类型的参数模板p1中,配置MySQL连接池的大小为2000。
[Sysname] parameter-profile p1 type mysql
[Sysname-para-mysql-p1] pool-size 2000
1.1.190  port (real server view)
port命令用来配置实服务器的端口号。
undo port命令用来恢复缺省情况。
port port-number
undo port
实服务器的端口号为0(表示继续使用原报文携带的端口号)。
实服务器视图
context-admin
vsys-admin
port-number:端口号,取值范围为0~65535,0表示继续使用原报文携带的端口号。
只有当实服务组开启了NAT功能后,本配置才有效。
# 配置实服务器rs的端口号为8080。
[Sysname] real-server rs
[Sysname-rserver-rs] port 8080
·     transparent enable(server farm view)
1.1.191  port (virtual server view)
port命令用来配置虚服务器的端口号。
port { port-number [ to port-number ] } &<1-n>
undo port
IP/RADIUS/TCP/UDP类型虚服务器的端口号为0(表示任意端口号),快速HTTP/HTTP类型虚服务器的端口号为80,SIP类型虚服务的端口号为5060。
虚服务器视图
context-admin
vsys-admin
{ port-number [ to port-number ] } &<1-n>:表示一个或多个端口号。其中,port-number为端口号,对于IP/RADIUS/TCP/UDP类型的虚服务器,取值范围为0~65535,0表示任意端口号;对于快速HTTP/HTTP/SIP类型的虚服务器,取值范围为1~65535。&<1-n>表示前面的参数最多可以输入n次,对于IP/RADIUS/TCP/UDP类型的虚服务器,n的取值范围为1~32;对于快速HTTP/HTTP/SIP类型的虚服务器,n的取值只能为1。
如果虚服务器引用了SSL策略,则必须为其配置一个非缺省端口号(通常用443)。
TCP类型的虚服务器工作在七层时,端口不允许配置超过200个。
# 配置IP类型的虚服务器vs3的端口号为8080。
[Sysname-vs-ip-vs3] port 8080
·     ssl-server-policy
1.1.192  predictor
predictor命令用来配置实服务组的调度算法。
undo predictor命令用来恢复缺省情况。
基于实服务器:
predictor { dync-round-robin | least-connection | least-time | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
基于实服务组成员:
predictor hash [ carp ] address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor hash [ carp ] http [ offset offset ] [ start start-string ] [ [ end end-string ] | [ length length ] ]
predictor { least-connection member [ slow-online ] | least-time member | observed member | predictive member | random | round-robin }
undo predictor
实服务组的调度算法为加权轮转算法。
实服务组视图
context-admin
vsys-admin
hash address:根据IP地址进行的哈希算法。
carp:CARP(Cache Array Routing Protocol,缓存阵列路由协议)算法。当可用的实服务器数量发生变化时,采用CARP哈希算法,可使当前所有可用实服务器负载分担变动最小。
destination:根据目的IP地址进行的哈希算法。
source:根据源IP地址进行的哈希算法。
source-ip-port:根据源IP地址和端口号进行的哈希算法。
mask mask-length:IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
prefix prefix-length:IPv6地址的前缀长度,取值范围为0~128,缺省值为128。
http:根据HTTP载荷进行的哈希算法。
offset offset:基于HTTP载荷起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:HTTP载荷起始位置的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,区分大小写,不支持正则元字符?。
end end-string:HTTP载荷结束位置的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持正则元字符?。
length length:参与运算的HTTP载荷的长度,取值范围为0~1000,缺省值为0。
dync-round-robin:动态反馈算法,即根据实服务器的内存使用率、CPU使用率和磁盘使用率等信息计算出当前的负载能力权值。负载越小,权值越大,分配到的新连接越多。
least-connection:基于实服务器的加权最小连接算法,即总是把新连接分发给加权活动连接数(当前实服务器在所有实服务组中的活动连接总数/权值)最小的实服务。该算法中使用的权值为实服务器视图下配置的权值。
least-connection member:基于实服务器组成员的加权最小连接算法,即总是把新连接分发给加权活动连接数(实服务组成员在指定实服务组中的活动连接数/权值)最小的实服务组成员。该算法中使用的权值为实服务器组成员视图下配置的权值。
slow-online:用于优化使用加权最小连接算法的实服务组成员的温暖上线。若希望通过指定本参数优化实服务组成员的温暖上线,请先在实服务组中开启实服务器温暖上线功能。
least-time:基于实服务器的最快响应算法,即根据实服务器的响应时间计算出当前负载能力的权值。响应时间越短,权值越大,分配到的新连接越多。
least-time member:基于实服务组成员的最快响应算法,即根据实服务组成员的响应时间计算出当前负载能力的权值。响应时间越短,权值越大,分配到的新连接越多。
observed member:基于实服务组成员的流量观察算法,观察实服务组成员当前及过去一段时间内的连接数情况,通过计算这些观察数据,判断出当前连接负载最小的实服务组成员,并将新到达的客户端连接分配给该成员。
predictive member:基于实服务组成员的流量预测算法,观察实服务组成员当前及过去一段时间内的连接数情况,并且分析过去一段时间内的负载变化趋势,判断成员的性能是提升还是下降。优先将新连接分配给性能排名高且当前性能正在提升的实服务组成员。
random:随机算法,即把新连接随机分发给每个实服务器。
round-robin:加权轮转算法,即根据实服务权值的大小把新连接依次分发给每个实服务器,权值越大,分配的新连接越多。该算法中使用的权值为实服务器组成员视图下配置的权值。
bandwidth:带宽算法,即报文根据实服务器的权值与剩余带宽乘积后的比例分发到各实服务器上。该算法中使用的权值为实服务器视图下配置的权值。例如,对于实服务器rs1和实服务器rs2,如果其剩余带宽分别为150kbps和250kbps,而权值分别为5和6,最终rs1和rs2的请求流量分配比例为150×5:250×6,即1:2。
max-bandwidth:最大带宽算法,即总是将报文分发给处于空闲状态且剩余带宽最大的实服务器。该算法中使用的权值为实服务器视图下配置的权值。例如,对于实服务器rs1和实服务器rs2,如果其剩余带宽分别为150kbps和250kbps,两条实服务器带宽差值为100kbps,此时,当请求流量少于100kbps时,则流量都将分配给rs2;当请求流量大于100kbps时,如130kbps,其中100kbps分配给rs2,其余30kbps流量将平均分配给两台实服务器。
inbound:根据入方向带宽选择实服务器。
outbound:根据出方向带宽选择实服务器。
动态反馈算法只有在引用了SNMP-DCA类型的NQA探测模板的情况下才会生效。若未引用SNMP-DCA类型的NQA探测模板,则使用非加权的轮转算法进行调度。有关NQA模板的配置请参见“网络管理与监控配置指导”中的“NQA”。
如果未指定inbound和outbound关键字,将根据总带宽来选择实服务器。
CARP哈希算法是在普通哈希算法的基础上进行了改进。相比于普通哈希算法,采用CARP哈希算法,能使当前所有可用实服务器负载分担变动最小,更好地保持流量调度的持续性。例如,当某台实服务器故障时,若采用了普通哈希算法会重新分配所有请求,影响用户体验;而采用CARP哈希算法,仅会重新分配故障实服务器的请求,不会影响其他实服务器。
在带宽算法和最大带宽算法中,权值为实服务器视图下配置的权值;剩余带宽为实服务器视图下配置的最大期望带宽(max-bandwidth)与当前带宽的差值。若未配置最大期望带宽,剩余带宽为实服务器视图下配置的所允许的最大带宽(rate-limit bandwidth)与当前带宽的差值。
# 配置实服务组sf的调度算法为随机算法。
[Sysname] server-farm sf
[Sysname-sfarm-sf] predictor random
·     max-bandwidth (real server view)
1.1.193  prefer-method
prefer-method命令用来配置应答报文首选的压缩算法。
undo prefer-method命令用来恢复缺省情况。
prefer-method { deflate | gzip }
undo prefer-method
应答报文首选的压缩算法为gzip。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
deflate:deflate压缩算法。
gzip:缺省的gzip压缩算法。
如果客户端的请求支持配置的压缩算法,则用配置的算法进行压缩,否则采用请求中携带的算法。
# 创建HTTP压缩类型的参数模板http1,并配置首选压缩算法为deflate。
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] prefer-method deflate
1.1.194  priority (real server view)
priority命令用来配置实服务器的调用优先级。
undo priority命令用来恢复缺省情况。
priority priority
undo priority
实服务器的调用优先级为4。
实服务器视图
context-admin
vsys-admin
priority:实服务器调用优先级,取值范围为1~8。数值越大,越被优先调用。
通常使用负载分担时,优先使用高优先级的实服务器处理流量。如果最高优先级实服务器的个数少于配置的参与调度的最少个数,则在次高优先级中选择实服务器,达到配置的最少个数。
# 配置实服务器rs的调用优先级为3。
[Sysname-rserver-rs] priority 3
·     selected-server
1.1.195  priority (server farm member view)
priority命令用来配置实服务组成员的调用优先级。
priority priority
undo priority
实服务组成员的调度优先级为4。
实服务组成员视图
context-admin
vsys-admin
priority:实服务组成员调用优先级,取值范围为1~8。数值越大,越被优先调用。
在实服务组范围内,优先级最高的实服务组成员参与调度,如果可用实服务组成员数量未到达预设的最低门限,则将次高优先级的实服务组成员均加入调度,依次类推,直至达到预设的最小参与调度个数或没有可用实服务组成员为止。若将某一个优先级的实服务组成员均加入调度后,超出了预设的最大参与调度个数,则只加入部分此优先级的实服器组成员,此时最终参与调度的可用实服务组成员个数将为预设的最大参与调度个数。
本命令与实服务组成员视图下的selected-server命令配合使用。
# 配置实服务组成员rs1的调用优先级为3。
[Sysname-sfarm-sf-#member#-rs1-port-80] priority 3
·     selected-server (server farm view)
1.1.196  priority (SNAT global policy view)
priority命令用来配置SNAT全局策略的优先级。
priority priority
undo priority
SNAT全局策略的优先级为0。
SNAT全局策略视图
context-admin
priority:SNAT全局策略的优先级。取值范围为0~65535,数值越大,优先级越高。
若同时配置多个SNAT全局策略,则优先级越大的SNAT全局策略,越优先匹配。
# 在SNAT全局策略sn1视图下,配置SNAT全局策略的优先级为100。
[Sysname-lb-snat-gp-sn1] priority 100
1.1.197  probe (real server view)
probe命令用来指定实服务器的健康检测方法。
undo probe命令用来恢复缺省情况。
probe template-name [ nqa-template-port ]
undo probe template-name
未指定实服务器的健康检测方法。
实服务器视图
context-admin
vsys-admin
template-name:健康检测方法所使用的NQA模板名称,为1~255个字符的字符串,不区分大小写。
nqa-template-port:健康检测方法使用NQA模板测试操作的目的端口进行检测,如果未指定该参数则使用实服务器的端口进行检测。
请使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对实服务器进行检测,保证其能够提供有效的服务。
用户可在实服务组视图下对组内的所有实服务组成员进行配置,也可在实服务组成员视图下只对当前实服务组成员进行配置,或者在实服务器视图下只对当前实服务器进行配置,后两者的配置优先级相同,且高于实服务组视图下的健康检测配置。建议优先在实服务组视图下配置健康检测。
实服务器的健康检测结果影响实服务器组成员的使用,实服务器组成员的健康检测结果不影响实服务器的使用。
# 创建ICMP类型的NQA模板t4,并将其指定为实服务器rs的健康检测方法。
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-rserver-rs] probe t4
·     nqa template(网络管理和监控命令参考/NQA)
·     success-criteria (real server view)
1.1.198  probe (server farm member view)
probe命令用来指定实服务组成员的健康检测方法。
未指定实服务组成员的健康检测方法。
实服务组成员视图
context-admin
vsys-admin
nqa-template-port:健康检测方法使用NQA模板默认端口进行检测,如果未指定该参数则使用实服务组成员的端口进行检测。
请使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对实服务组成员进行检测,保证其能够提供有效的服务。
用户可在实服务组视图下对组内的所有实服务组成员进行配置,也可在实服务组成员视图下只对当前实服务组成员进行配置,或者在实服务器视图下只对当前实服务器进行配置,后两者的配置优先级相同且高于实服务组视图下的健康检测配置。建议优先在实服务组视图下配置健康检测。
# 创建ICMP类型的NQA模板t4,并将其指定为实服务组成员rs1的健康检测方法。
[Sysname-sfarm-sf-#member#-rs1-port-80] probe t4
·     success-criteria (server farm member view)
1.1.199  probe (server farm view)
probe命令用来指定实服务组的健康检测方法。
undo probe命令用来删除指定实服务组的健康检测方法。
未指定实服务组的健康检测方法。
实服务组视图
context-admin
vsys-admin
nqa-template-port:健康检测方法使用NQA模板默认端口进行检测,如果未指定该参数则使用实服务器的端口进行检测。
# 创建ICMP类型的NQA模板t4,并将其指定为实服务组sf的健康检测方法。
<Sysname>system-view
[Sysname-sfarm-sf] probe t4
·     success-criteria (server farm view)
1.1.200  probe log enable (real server view)
probe log enable命令用来开启实服务器健康检测日志功能。
undo probe log enable命令用来关闭实服务器健康检测日志功能。
probe log enable
实服务器健康检测日志功能处于开启状态。
实服务器视图
context-admin
工作机制
通过开启负载均衡基本日志功能,可实现在实服务器的健康状态发生变化时输出日志信息。
注意事项
非缺省vSystem不支持本命令。
# 开启实服务器rs的健康检测日志功能。
[Sysname-rserver-rs] probe log enable
1.1.201  probe log enable (server farm member view)
probe log enable命令用来开启实服务组成员健康检测日志功能。
undo probe log enable命令用来关闭实服务组成员健康检测日志功能。
probe log enable
实服务组成员健康检测日志功能处于开启状态。
实服务组成员视图
context-admin
工作机制
通过开启负载均衡基本日志功能,可实现在实服务组成员的健康状态发生变化时输出日志信息。
注意事项
非缺省vSystem不支持本命令。
# 开启实服务组成员rs1的健康检测日志功能。
[Sysname-sfarm-sf-#member#-rs1-port-80] probe log enable
1.1.202  probe-template (real-server view)
probe-template命令用来指定实服务器引用的负载均衡探测模板。
undo probe-template命令用来取消实服务器对指定负载均衡探测模板的引用。
probe-template  external-monitor template-name
undo probe-template  external-monitor template-name
实服务器未引用任何类型的负载均衡探测模板。
实服务器视图
context-admin
external-monitor:自定义监控类型的负载均衡探测模板。
工作机制
本命令通过引用自定义监控类型的负载均衡探测模板,实现对当前实服务器进行监控。
实服务器的探测结果影响实服务器组成员的使用,实服务器组成员的探测结果不影响实服务器的使用。
注意事项
非缺省vSystem不支持本命令。
配置域名的实服务器不支持引用自定义监控类型的负载均衡探测模板。
# 指定实服务器rs引用的自定义监控类型的负载均衡探测模板名称为test_external。
[Sysname-rserver-rs] probe-template external-monitor test_external
·     loadbalance probe-template
1.1.203  probe-template (server-farm member view)
probe-template命令用来指定实服务组成员引用的负载均衡探测模板。
undo probe-template命令用来取消实服务器成员对指定负载均衡探测模板的引用。
实服务组成员未引用任何类型的负载均衡探测模板。
实服务组成员视图
context-admin
工作机制
本命令通过引用自定义监控类型的负载均衡探测模板,实现对当前实服务组成员进行监控。
用户既可在实服务组视图下对组内的所有实服务组成员进行配置,也可在实服务组成员视图下只对当前实服务组成员进行配置,后者的配置优先级高。
注意事项
非缺省vSystem不支持本命令。
配置域名的实服务组成员不支持引用自定义监控类型的负载均衡探测模板。
# 指定实服务组成员rs引用的自定义监控类型的负载均衡探测模板名称为test_external。
[Sysname-sfarm-sf-#member#-rs1-port-80] probe-template external-monitor test_external
1.1.204  probe-template (server-farm view)
probe-template命令用来指定实服务组引用的负载均衡探测模板。
undo probe-template命令用来删除实服务组引用的负载均衡探测模板。
probe-template { external-monitor | http-passive | tcp-rst | tcp-zero-window } template-name
undo probe-template { external-monitor | http-passive | tcp-rst | tcp-zero-window }
未指定实服务组引用的负载均衡探测模板。
实服务组视图
context-admin
vsys-admin
http-passive:HTTP passive类型的负载均衡探测模板。
tcp-rst:TCP RST类型的负载均衡探测模板。
tcp-zero-window:TCP zero-window类型的负载均衡探测模板。
本命令通过引用自定义监控类型、HTTP passive类型、TCP RST类型或TCP zero-window类型的负载均衡探测模板,实现对实服务组内所有实服务组成员进行监控。
实服务组只能同时引用一个HTTP passive类型的负载均衡探测模板、一个TCP RST类型的负载均衡探测模版和一个TCP zero-window类型的负载均衡探测模版。
允许在实服务组中同时引用多个自定义监控类型的负载均衡探测模板。引用自定义监控类型探测模板对实服务组内配置域名的实服务组成员不生效。
# 指定实服务组sf引用名称为r1的TCP RST类型的负载均衡探测模版。
[Sysname-sfarm-sf] probe-template tcp-rst r1
1.1.205  product-name
product-name命令用来配置产品的名称。
undo product-name命令用来恢复缺省情况。
product-name product-name
undo product-name
产品名称为管理员配置的设备名称,若管理员未修改过设备名称,则产品名称为H3C。
Diameter-session类型参数模板视图
context-admin
vsys-admin
product-name:厂商指定的产品名称,区分大小写,为1~127个字符的字符串。
设备与对端进行Diameter协商时,会通过CER和CEA协商报文进行信息交换,交换的信息包括:源主机名、源域名、厂商ID及产品名称等。通过本命令指定设备的产品名称,当设备与对端进行Diameter协商时,设备将配置的名称作为本机名称发送给对端。
管理员可以通过sysname命令配置设备缺省情况下的产品名称。关于sysname命令的详细介绍请参见“基础配置命令参考”中的“设备管理”。
# 在Diameter-session类型的参数模板dia下,配置产品名称为L5080。
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] product-name L5080
·     parameter-profile
·     sysname(基础配置命令参考/设备管理)
1.1.206  protect-action
protect-action命令用来配置负载均衡探测模板的保护动作。
undo protect-action命令用来恢复缺省情况。
protect-action { auto-shutdown | busy [ probe-interval interval ] [ probe-times times ] }
undo protect-action
负载均衡探测模板的保护动作为设置实服务器为繁忙状态。
context-admin
vsys-admin
auto-shutdown:关闭实服务器。
busy:设置实服务器为繁忙状态。
probe-interval interval:实服务器的繁忙保护时间,取值范围为5~3600,缺省为30,单位秒。
probe-times times:实服务器的繁忙保护次数,取值范围为0~255,缺省为0。0表示实服务器的繁忙保护次数不受限制。
若配置负载均衡探测模板的保护动作为设置实服务器为繁忙状态,则当实服务器发送的RST报文或零窗口报文达到配置的阈值时,系统会将实服务器的状态标记为繁忙,然后以繁忙保护时间为间隔再次对实服务器进行检查。若实服务器在繁忙保护时间内发送的RST报文或零窗口报文未达到配置的阈值,则实服务器恢复正常状态。否则继续以繁忙保护时间为间隔检查实服务器,直到达到实服务器的繁忙保护次数为止。达到繁忙保护次数后,系统会自动关闭实服务器。
在因为达到阈值或达到繁忙保护次数导致实服务器关闭的情况下,若删除实服务组引用负载均衡探测模板,则实服务组的状态会立即恢复为正常。
在因为达到阈值或达到繁忙保护次数导致实服务器关闭的情况下,可以通过执行auto-shutdown recovery-time命令使实服务器在达到指定恢复时间后自动恢复为正常状态;或者通过执行recover-from-auto-shutdown (real server view)命令使实服务器立即恢复为正常状态。
# 在TCP RST类型的负载均衡探测模板下,配置负载均衡探测模板保护动作为设置实服务器为繁忙状态,实服务器的繁忙保护时间30秒,实服务器的繁忙保护次数3次。
[Sysname-lbpt-tcp-rst-rsttplt] protect-action busy probe-interval 30 probe-times 3
·     auto-shutdown recovery-time
·     recover-from-auto-shutdown (real server view)
1.1.207  protected-url
protected-url命令用来配置防护URL。
undo protected-url命令用来删除防护URL。
protected-url url
undo protected-url
不存在防护URL。
防护规则视图
context-admin
vsys-admin
通过配置本命令可以指定需要限制用户请求次数的URL。在统计周期内,若同一用户访问指定URL的次数超过配置的阈值,则执行防护动作。
设备进行匹配时,不会对HTTP报文URL中的参数部分进行匹配。即仅匹配URL中“?”之前的内容。
在同一防护规则视图下,多次执行本命令,最后一次执行的命令生效。
# 在编号为5的防护规则视图下,配置防护URL为www.example.com/index.html。
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] protected-url www.example.com/index.html
·     cookie (protection policy view)
·     protection-action
·     protection-period
·     source-ip
1.1.208  protection-action
protection-action命令用来配置防护动作。
undo protection-action命令用来恢复缺省情况。
protection-action { warning | { drop | verify { insert-header | js } } } *
未配置防护动作.
HTTP类型防护策略视图
context-admin
warning:表示输出告警日志。
drop:表示丢弃报文。
verify:表示对客户端请求报文进行客户端验证。
insert-header:通过插入HTTP首部方式对客户端请求报文进行验证。
js:通过注入JS脚本方式对客户端请求报文进行验证。
工作机制
用户可以在HTTP类型的防护策略中配置HTTP慢速攻击防护,设备在转发报文时会对报文进行慢速攻击检查,当检测存在慢速攻击时,执行丢弃的防护动作。也可以在HTTP类型的防护策略中配置防护规则,当匹配防护规则时,执行相应的防护动作。设备支持以下防护动作:
·     输出告警日志:生成告警信息并发送到信息中心。对匹配上HTTP慢速攻击防护的流量不生效。
·     丢弃报文:丢弃请求报文。
·     客户端验证:设备检测到请求报文个数达到阈值限制时,向客户端返回携带指定Cookie的响应报文。若客户端后续请求报文中携带的Cookie值与设备返回的Cookie值相同,则认为客户端请求报文通过验证。若请求报文中未携带Cookie值或携带的Cookie值与设备返回值不同,则认为客户端请求报文未通过验证,直接丢弃报文。对于攻击者无法在请求报文中插入Cookie值的场景,可以通过配置防护动作为客户端验证过滤攻击报文。设备支持通过插入HTTP首部和响应JS脚本的方式向客户端返回Cookie值。对匹配上HTTP慢速攻击防护的流量不生效。
推荐配置
在一条防护策略中,可同时配置HTTP慢速攻击防护和URL防护。如果需要对HTTP慢速攻击防护和URL防护指定各自的防护动作,建议配置成多条防护策略。
注意事项
非缺省vSystem不支持本命令。
配置HTTP慢速攻击防护后需指定防护动作为丢弃报文,否则HTTP慢速攻击防护功能不生效。
在同一HTTP类型的防护策略视图下,多次执行本命令,最后一次执行的命令生效。
# 在HTTP类型防护策略p1视图下,配置防护动作为输出告警日志和插入HTTP首部方式对客户端请求报文进行客户端验证。
[Sysname-lbpp-http-p1] protection-action warning verify insert-header
1.1.209  protection-period
protection-period命令用来配置防护周期。
undo protection-period命令用来恢复缺省情况。
protection-period period
防护周期为120秒。
防护规则视图
context-admin
vsys-admin
period:防护周期,取值范围为1~900,单位为秒。
在防护周期内,若同一用户访问指定URL的次数超过配置的阈值,则执行防护动作。
# 在编号为5的防护规则视图下,配置防护周期为5秒。
[Sysname-lbpp-http-p1-rule-5] protection-period 5
·     protection-action
·     protected-url
1.1.210  protection-policy
protection-policy命令用来指定虚服务器引用防护策略。
undo protection-policy命令用来恢复缺省情况。
protection-policy http policy-name
undo protection-policy http
虚服务器未引用任何防护策略。
HTTP类型的虚服务器视图
context-admin
vsys-admin
policy-name:防护策略的名称,为1~255个字符的字符串,不区分大小写。
配置虚服务器引用防护策略,对匹配指定虚服务器的流量进行防护。
# 在指定HTTP类型的虚服务器vs视图下,指定虚服务器引用的防护策略为p1。
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs]protection-policy http p1
·     loadbalance protection-policy
1.1.211  proximity enable
proximity enable命令用来在实服务组中开启就近性功能。
undo proximity enable命令用来在实服务组中关闭就近性功能。
proximity enable
实服务器组中的就近性功能处于关闭状态。
实服务组视图
context-admin
工作机制
在实服务器组中开启就近性功能后,负载均衡设备首先按照就近性选择组内的实服务器,就近性选择失败后再按照调度算法选择实服务器。
注意事项
非缺省vSystem不支持本命令。
# 在实服务组sf中开启就近性功能。
[Sysname-sfarm-sf] proximity enable
1.1.212  proxy-protocol enable
proxy-protocol enable命令用来开启TCP类型虚服务器的代理协议功能。
undo proxy-protocol enable命令用来恢复缺省情况。
proxy-protocol enable [ v1 | v2 ]
TCP类型虚服务器的代理协议功能处于关闭状态。
TCP类型的虚服务器视图
context-admin
vsys-admin
v1:表示代理协议版本号为v1。
v2:表示代理协议版本号为v2。
配置本命令后,设备通过代理协议来透传真实的源IP地址信息到后端实服务器。
若配置本命令时未指定代理协议版本,则默认为v1版本。配置本命令之前,请确保后端实服务器支持指定版本的代理协议,否则将导致设备与实服务器之间的新建连接失败。
仅工作在七层的TCP类型虚服务器配置本命令才生效。
# 在TCP类型的虚服务器视图下,开启TCP类型虚服务器的代理协议功能。
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] proxy-protocol enable
·     application-mode enable
1.1.213  radius-attribute
radius-attribute命令用来配置RADIUS属性持续性方法。
undo radius-attribute命令用来删除RADIUS属性持续性方法。
radius-attribute { code attribute-code | framed-ip-address | user-name }
不存在RADIUS属性持续性方法。
RADIUS类型的持续性组视图
context-admin
vsys-admin
framed-ip-address:指定RADIUS属性类型为Framed-IP-Address(编号为8)。
RADIUS属性的持续性方法仅对RADIUS报文有效。
# 在持续性组s1中,配置RADIUS属性类型为User-Name的持续性方法。
[Sysname] sticky-group s1 type radius
[Sysname-sticky-radius-s1] radius-attribute user-name
1.1.214  rate-limit bandwidth (real server view)
rate-limit bandwidth命令用来配置实服务器所允许的最大带宽。
undo rate-limit bandwidth命令用来恢复缺省情况。
rate-limit bandwidth [ inbound | outbound ] bandwidth-value kbps
undo rate-limit bandwidth [ inbound | outbound ]
实服务器所允许的最大带宽不受限制。
实服务器视图
context-admin
vsys-admin
inbound:配置最大入带宽。
outbound:配置最大出带宽。
bandwidth-value:最大带宽值,取值范围为0~4294967295,单位为kbps,0表示最大带宽不受限制。
kbps:最大带宽值的单位为kbps。
如果未指定inbound和outbound参数,则配置最大总带宽,总带宽等于入带宽与出带宽之和。
本命令不仅在新建会话时生效,对已经存在的会话也生效。
# 配置实服务器rs所允许的最大总带宽为1kbps。
[Sysname-rserver-rs] rate-limit bandwidth 1 kbps
# 配置实服务器rs所允许的最大入带宽为1kbps。
[Sysname-rserver-rs] rate-limit bandwidth inbound 1 kbps
# 配置实服务器rs所允许的最大出带宽为1kbps。
[Sysname-rserver-rs] rate-limit bandwidth outbound 1 kbps
1.1.215  rate-limit bandwidth (virtual server view)
rate-limit bandwidth命令用来配置虚服务器所允许的最大带宽。
虚服务器所允许的最大带宽不受限制。
虚服务器视图
context-admin
vsys-admin
inbound:最大入带宽。
outbound:最大出带宽。
kbps:最大带宽值的单位为kbps。
# 配置IP类型的虚服务器vs3所允许的最大总带宽为1kbps。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] rate-limit bandwidth 1 kbps
# 出方向链路负载均衡场景下,配置LINK-IP类型的虚服务器vs3所允许的最大入带宽为1kbps。
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] rate-limit bandwidth inbound 1 kbps
1.1.216  rate-limit connection (real server view)
rate-limit connection命令用来配置实服务器所允许的最大连接速率。
undo rate-limit connection命令用来恢复缺省情况。
rate-limit connection connection-number
实服务器所允许的最大连接速率为0。
实服务器视图
context-admin
vsys-admin
connection-number:实服务器所允许的最大连接速率,取值范围为0~4294967295,0表示实服务器所允许的最大连接速率不受限制。
# 配置实服务器rs所允许的最大连接速率为10000。
[Sysname-rserver-rs] rate-limit connection 10000
1.1.217  rate-limit connection (server farm member view)
rate-limit connection命令用来配置实服务组成员所允许的最大连接速率。
实服务器组成员所允许的最大连接速率为0。
实服务器组成员视图
context-admin
vsys-admin
connection-number:最大连接速率,取值范围为0~4294967295,单位为个/秒,0表示实服务组成员所允许的最大连接速率不受限制。
# 配置实服务器组成员rs1所允许的最大连接速率为1000个/秒。
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit connection 1000
1.1.218  rate-limit connection (virtual server view)
rate-limit connection命令用来配置虚服务器所允许的最大连接速率。
虚服务器所允许的最大连接速率为0。
虚服务器视图
context-admin
vsys-admin
connection-number:虚服务器所允许的最大连接速率,取值范围为0~4294967295,0表示虚服务器所允许的最大连接速率不受限制。
# 配置IP类型的虚服务器vs3所允许的最大连接速率为10000。
[Sysname-vs-ip-vs3] rate-limit connection 10000
# 出方向链路负载均衡场景下,配置LINK-IP类型的虚服务器vs2所允许的最大连接速率为10000。
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] rate-limit connection 10000
1.1.219  rate-limit http-request (real server view)
rate-limit http-request命令用来配置实服务器所允许的最大HTTP请求速率。
undo rate-limit http-request命令用来恢复缺省情况。
rate-limit http-request request-number
实服务器所允许的最大HTTP请求速率不受限制。
实服务器视图
context-admin
vsys-admin
request-number:实服务器所允许的最大HTTP请求速率,取值范围为0~4294967295,0表示实服务器所允许的最大HTTP请求速率不受限制。
实服务器所允许的最大HTTP请求速率为判断实服务器是否繁忙的依据之一。若实服务器每秒收到的HTTP请求报文数超过配置的值,则认为该实服务器处于繁忙状态。
# 配置实服务器rs所允许的最大HTTP请求速率为10000。
[Sysname-rserver-rs] rate-limit http-request 10000
1.1.220  rate-limit http-request (server farm member view)
rate-limit http-request命令用来配置实服务组成员所允许的最大HTTP请求速率。
实服务组成员所允许的最大HTTP请求速率不受限制。
实服务器组成员视图
context-admin
vsys-admin
request-number:实服务组成员所允许的最大HTTP请求速率,取值范围为0~4294967295,0表示实服务组成员所允许的最大HTTP请求速率不受限制。
实服务组成员所允许的最大HTTP请求速率为判断实服务组成员是否繁忙的依据之一。若实服务组成员器每秒收到的HTTP请求报文数超过配置的值,则认为该实服务组成员处于繁忙状态。
# 配置实服务组成员rs所允许的最大HTTP请求速率为10000。
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit http-request 10000
1.1.221  readwrite-separation
readwrite-separation命令用来开启MySQL数据库读写分离功能。
undo readwrite-separation命令用来关闭MySQL数据库读写分离功能。
readwirte-separation read-server-farm read-server-farm-name [ read-sticky-group read-sticky-group-name ] write-server-farm write-sever-farm-name [ write-sticky-group write-sticky-group-name ]
MySQL数据库读写分离功能处于关闭状态。
MySQL类型的虚服务器视图
context-admin
vsys-admin
read-server-farm read-server-farm-name:读实服务组名称,为1~63个字符的字符串,不区分大小写。
read-sticky read-sticky-group-name:读实服务组所对应的持续性组名称,为1~63个字符的字符串,不区分大小写。
write-server-farm write-server-farm-name:写实服务组名称,为1~63个字符的字符串,不区分大小写。
write-sticky write-sticky-group-name:写实服务组所对应的持续性组名称,为1~63个字符的字符串,不区分大小写。
开启MySQL虚服务器的读写分离功能后,读SQL命令和写SQL命令将分别由读实服务组和写实服务组执行,一定程度上缓解读写并发时对数据库性能的影响。
# 在MySQL类型的虚服务器vs1视图下,开启MySQL数据库读写分离功能,并指定读实服务组为rd,写实服务组为wr。
[Sysname] virtual-server vs1 type mysql
[Sysname-vs-mysql-vs1] readwrite-separation read-server-farm rd write-server-farm wr
1.1.222  real-server (server farm view)
real-server命令用来创建并添加实服务组成员,并进入实服务组成员视图。如果指定的实服务组成员已经存在,则直接进入实服务组成员视图。
undo real-server命令用来删除指定的实服务组成员。
real-server real-server-name port port-number
undo real-server real-server-name port port-number
不存在实服务组成员。
实服务组视图
context-admin
vsys-admin
real-server-name:实服务组成员的名称,为1~255个字符的字符串,不区分大小写。
port-number:实服务组成员的端口号,取值范围为0~65535。
设备支持通过两种方式向实服务组中添加成员:
·     通过本命令创建实服务组成员或添加已存在的实服务器,推荐使用此种方式进行配置。
·     通过server-farm (real server view)命令指定实服务器所属的实服务组。
设备不支持同时通过两种方式配置名称和端口均相同的实服务组成员。
如果在real-server (system view)中配置了域名,且收到了域名解析结果,实服务组在引用该实服务器后,会自动引用对应域名解析结果的临时实服务器组成员,临时成员的名称为“auto_IP地址”的形式,如“auto_1.1.1.1”。
# 添加实服务组成员rs1,并进入实服务器组成员视图。
·     server-farm (real server view)
1.1.223  real-server (system view)
real-server命令用来创建实服务器,并进入实服务器视图。如果指定的实服务器已经存在,则直接进入实服务器视图。
undo real-server命令用来删除指定的实服务器。
不存在实服务器。
context-admin
vsys-admin
real-server-name:实服务器的名称,为1~255个字符的字符串,不区分大小写。
本命令需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
# 创建实服务器rs,并进入实服务器视图。
1.1.224  rebalance per-request
rebalance per-request命令用来配置对每个HTTP请求报文都进行负载均衡。
undo rebalance per-request命令用来恢复缺省情况。
只对一条连接的第一个HTTP请求报文进行负载均衡,其余请求报文的处理方式与第一个相同。
HTTP类型的参数模板视图
context-admin
vsys-admin
# 在HTTP类型的参数模板pp1中,配置对每个HTTP请求报文都进行负载均衡。
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] rebalance per-request
1.1.225  recover-to-active (real server view)
recover-to-active命令用来手动恢复实服务器的状态。
recover-to-active
实服务器视图
context-admin
vsys-admin
若没有配置健康检测,实服务器恢复后的状态置为Unknown状态。
若配置了健康检测且健康检测成功,实服务器恢复后的状态置为Active状态,如果健康检测失败,则置为Probe-failed状态。
# 手动恢复实服务器rs的状态。
[Sysname-rserver-rs] server-farm sf
[Sysname-rserver-rs] recover-to-active
1.1.226  recover-to-active (server farm member view)
recover-to-active命令用来手动恢复实服务组成员的状态。
recover-to-active
实服务组成员视图
context-admin
vsys-admin
若没有配置健康检测,实服务组成员恢复后的状态置为Unknown状态。
若配置了健康检测且健康检测成功,实服务组成员恢复后的状态置为Active状态,如果健康检测失败,则置为Probe-failed状态。
# 手动恢复实服务组成员sf-rs1-80的状态。
[Sysname-sfarm-sf-#member#-rs1-port-80] recover-to-active
1.1.227  recv-window size
recv-window size命令用来配置HTTP2.0最大接收窗口值。
undo recv-window size命令用来恢复缺省情况。
recv-window size size
HTTP2.0最大接收窗口值为32KB。
HTTP2.0类型的参数模板视图
context-admin
vsys-admin
当设备或服务器通过一条TCP连接并发处理和响应多个请求时,若并发请求过大,则容易影响设备或服务器的并发处理能力。管理员可通过配置一条TCP连接所支持的最大并发请求数进行控制,也可以通过配置HTTP2.0最大接收窗口值,当并发请求报文超过最大接收窗口大小时,则将并发请求按接收窗口大小分多次接收处理。
本命令仅对HTTP2.0协议版本的请求报文生效。
# 创建HTTP2.0类型的参数模板p1,配置HTTP2.0最大接收窗口值为128Kb。
[Sysname] parameter-profile p1 type http2
[Sysname-para-http2-p1] recv-window size 128
·     concurrent-streams-per-connection
1.1.228  redirect relocation (LB action view)
redirect relocation命令用来开启动作的重定向功能并指定重定向URL。
undo redirect relocation命令用来关闭动作的重定向功能。
redirect relocation relocation [ replace match-pattern replace-string ]
动作的重定向功能处于关闭状态。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
relocation:重定向URL,为1~255个字符的字符串,区分大小写,也可以使用?和以下特定含义的字符串(各自只允许使用一次):
·     %h:表示客户端请求报文中的主机名和端口号。
·     %{host}:表示客户端请求报文中的主机名。
·     %{port}:表示客户端请求报文中的端口号。
·     %p:表示客户端请求报文中的URL资源路径。
replace:表示重写Location首部内容。
match-pattern:表示匹配待重写的Location首部的正则表达式内容,为1~127个字符的字符串,区分大小写,支持正则元字符?。
兼容性说明
本命令与server-farm命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
工作机制
在HTTP类型的负载均衡动作视图下开启了重定向功能后,所有匹配对应负载均衡类的HTTP请求报文都将被重定向到该URL。
# 在HTTP类型的负载均衡动作视图下开启重定向功能,并将请求重定向为HTTPS。
[Sysname] loadbalance action lba1 type http
[Sysname-lba-http-lba1] redirect relocation https://%h%p
1.1.229  redirect relocation (virtual server view)
redirect relocation命令用来开启虚服务器的重定向功能并指定重定向URL。
undo redirect relocation命令用来关闭虚服务器的重定向功能。
虚服务器的重定向功能处于关闭状态。
HTTP类型的虚服务器视图
context-admin
vsys-admin
relocation:指定重定向URL,开启了虚服务器的重定向功能后,所有匹配该虚服务器的请求报文都将被重定向到该URL。为1~255个字符的字符串,区分大小写。也可以使用?和以下特定含义的字符串(各自只允许使用一次):
·     %h:使用客户端请求报文中的主机名和端口号。
·     %p:使用客户端请求报文中的URL资源路径。
# 开启HTTP类型的虚服务器vs2的重定向功能,并将请求重定向为HTTPS。
[Sysname] virtual-server vs2 type http
[Sysname-vs-http-vs2] redirect relocation https://%h%p
1.1.230  redirect return-code (LB action view)
redirect return-code命令用来配置负载均衡设备返回给客户端的重定向报文中的状态码。
undo redirect return-code命令用来恢复缺省情况。
redirect return-code { 301 | 302 | 307 }
负载均衡设备返回给客户端的重定向报文中的状态码为302。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
301:状态码为301,表示永久删除被请求的资源。
302:状态码为302,表示临时删除被请求的资源。
307:状态码为307,表示临时将请求重定向到Location首部的URL上。
只有HTTP类型的负载均衡动作视图开启了重定向功能后,本命令才生效。
# 在HTTP类型的动作lba1上,配置负载均衡设备返回给客户端的重定向报文中的状态码为301。
[Sysname-lba-http-lba1] redirect return-code 301
·     redirect relocation
1.1.231  redirect return-code (virtual server view)
HTTP类型的虚服务器视图
context-admin
vsys-admin
本命令只有在开启了虚服务器的重定向功能后才会生效。
# 在HTTP类型的虚服务器vs2上,配置负载均衡设备返回给客户端的重定向报文中的状态码为301。
[Sysname-vs-http-vs2] redirect return-code 301
1.1.232  reload http-response
reload http-response该命令用来重新加载代答文件。
reload http-response { file filename }
context-admin
vsys-admin
file filename:代答文件的完整路径,为1~255个字符的字符串,不区分大小写。
当指定的代答文件发生变化后,需要通过配置本命令进行重新加载,否则代答文件无法生效。
# 重新加载代答文件subsys_intf.js。
[Sysname] reload http-response /index/subsys_intf.js
·     fallback-action response raw-file
·     response
1.1.233  request-version all
request-version all命令用来配置对HTTP1.0的请求报文的应答进行压缩处理。
undo request-version all命令用来恢复缺省情况。
request-version all
不对HTTP1.0的报文进行压缩。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
# 创建HTTP压缩类型的参数模板http1,并使其对HTTP1.0的请求的应答进行压缩。
[Sysname-para-http-compression-http1] request-version all
1.1.234  reset loadbalance connections
reset loadbalance connections命令用来清除负载均衡的应用层连接。
reset loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ slot slot-number ]
context-admin
vsys-admin
client-side:清除客户端的负载均衡连接信息。
server-side:清除服务器端的负载均衡连接信息。
ipv4:IPv4连接。
ipv6:IPv6连接。
cs-client-ip ip-address:指定客户端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
cs-client-port port-number:指定客户端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
ss-client-ip ip-address:指定客户端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
ss-client-port port-number:指定客户端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
cs-server-ip ip-address:指定服务器端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
cs-server-port port-number:指定服务器端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
ss-server-ip ip-address:指定服务器端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
ss-server-port port-number:指定服务器端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
slot slot-number:指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除所有成员设备上的信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait }:指定TCP连接状态的负载均衡连接信息。若未指定本参数,则清除所有TCP连接状态的负载均衡连接信息。
此命令会将当前所有负载均衡的应用层连接清除,包括连接复用中的空闲连接。
# 清除负载均衡应用层链接。
<Sysname> reset loadbalance connection
1.1.235  reset loadbalance dns-cache
reset loadbalance dns-cache命令用来清除DNS缓存信息。
reset loadbalance dns-cache[ vpn-instance vpn-instance-name ] [ domain-name domain-name ] [ traffic-group traffic-group-id ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网实例中的DNS缓存的信息。
domain-name domain-name:清除指定域名的DNS缓存信息,domain-name为1~253个字符的字符串,不区分大小写。如果未指定本参数,将清除所有域名的DNS缓存信息。
traffic-group traffic-group-id:清除指定集群流量组的DNS缓存信息。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示清除所有集群流量组的DNS缓存信息。
非缺省vSystem不支持本命令。
# 清除所有DNS缓存信息。
<Sysname> reset loadbalance dns-cache
1.1.236  reset loadbalance hot-backup statistics
reset loadbalance hot-backup statistics命令用来清除负载均衡热备份的统计信息。
context-admin
vsys-admin
# 清除负载均衡热备份的统计信息。
<Sysname> reset loadbalance hot-backup statistics
1.1.237  reset loadbalance probe failed-record
reset loadbalance probe failed-record命令用来清除健康检测失败的历史记录。
reset loadbalance probe failed-record { real-server | link } [ name name ]
context-admin
vsys-admin
real-server:清除实服务器的健康检测失败记录。
link:清除链路的健康检测失败记录。
name name:清除指定名称实服务器或链路的健康检测失败历史记录。为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除所有实服务器或链路的健康检测失败的历史记录。
# 清除所有实服务器记录的健康检测失败信息。
<Sysname> reset loadbalance probe failed-record real-server
·     display loadbalance probe failed-record
1.1.238  reset loadbalance snat-pool statistics
reset loadbalance snat-pool statistics命令用来清除SNAT地址池的统计信息。
reset loadbalance snat-pool statistics [ pool-name ]
context-admin
vsys-admin
pool-name:SNAT地址池的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将清除所有SNAT地址池的统计信息。
# 清除所有SNAT地址池及其对应的SNAT IP地址的统计信息。
<Sysname> reset loadbalance snat-pool statistics
# 清除SNAT地址池sp及sp成员的统计信息。
<Sysname> reset loadbalance snat-pool statistics sp
1.1.239  reset real-server statistics
reset real-server statistics命令用来清除实服务器或实服务器组成员的统计信息。
reset real-server statistics [ real-server-name ]
reset real-server statistics server-farm server-farm-name [ name real-server-name port port-number ]
context-admin
vsys-admin
real-server-name:清除指定实服务器的统计信息。real-server-name为实服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除所有实服务器的统计信息。
server-farm server-farm-name:清除指定实服务器组下实服务器组成员的统计信息。server-farm-name为实服务器组的名称,为1~255个字符的字符串,不区分大小写。
name real-server-name port port-number:清除指定名称及端口的实服务器组成员的统计信息。real-server-name表示实服务器组成员的名称,为1~255个字符的字符串,不区分大小写。port-number表示实服务组成员的端口,取值范围为0~65535。如果未指定本参数,将清除指定实服务器组下所有实服务器组成员的统计信息。
# 清除所有实服务器的统计信息。
<Sysname> reset real-server statistics
# 清除实服务器组sf下所有实服务器组成员的统计信息。
<Sysname> reset real-server statistics server-farm sf
·     display real-server statistics
1.1.240  reset sticky virtual-server
reset sticky virtual-server命令用来清除虚服务器的持续性表项信息。
reset sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | client-port port-number | sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ traffic-group traffic-group-id ] [ slot slot-number ]
context-admin
vsys-admin
virtual-server-name virtual-server-name:清除指定虚服务器的持续性表项信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定virtual-server-name,将清除所有虚服务器的持续性表项信息。
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }:清除指定链路的持续性表项信息。ip ipv4-address表示链路的IPv4地址,ipv6 ipv6-address表示链路的IPv6地址,interface interface-type interface-number表示链路对应的出接口,interface-type为接口类型,interface-number为接口编号,interface-name为接口名称。
link-group link-group-name:清除指定链路组的持续性表项信息。link-group-name为链路组的名称,为1~255个字符的字符串,不区分大小写。
real-server-addr { ipv4-address | ipv6-address }:清除指定实服务器地址的持续性表项信息。ipv4-address表示实服务器的IPv4地址,ipv6-address表示实服务器的IPv6地址。
real-server-port port-number:清除指定实服务器端口的持续性表项信息。port-number为实服务器的端口号,取值范围0~65535。
server-farm server-farm-name:清除指定实服务组的持续性表项信息。server-farm-name为实服务组的名称,为1~255个字符的字符串,不区分大小写。
text text:清除指定匹配内容的持续性表项信息。text为持续性表项的匹配内容。
class { class-name | default-class }:清除指定负载均衡类的持续性表项信息。class-name为负载均衡类的名称,为1~255个字符的字符串,不区分大小写。default-class表示缺省负载均衡类。
client-addr { ipv4-address | ipv6-address }:清除指定客户端地址的持续性表项信息。ipv4-address表示客户端的IPv4地址,ipv6-address表示客户端的IPv6地址。
client-port port-number:清除指定客户端端口的持续性表项信息。port-number为客户端的端口号,取值范围0~65535。
sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }:清除指定类型持续性组的持续性表项信息,包括Diameter、地址端口、HTTP实体、HTTP Cookie、HTTP首部、HTTP passive、HTTP/UDP载荷、RADIUS、SIP、SSL、TCP载荷和UDP passive。
key sticky-key:清除指定Key值的持续性表项。sticky-key为持续性表项的Key值,为1~127个字符的字符串,区分大小写。若未指定本参数,则表示清除所有Key值的持续性表项。
traffic-group traffic-group-id:清除指定集群流量组的持续性表项。traffic-group-id为集群流量组编号,取值范围为1~255。若未指定本参数,则表示清除所有集群流量组的持续性表项。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 清除客户端地址为3.0.0.1的虚服务器vs的持续性表项信息。
<Sysname> reset sticky virtual-server virtual-server-name vs client-addr 3.0.0.1
1.1.241  reset virtual-server statistics
reset virtual-server statistics命令用来清除虚服务器的统计信息。
reset virtual-server statistics [ virtual-server-name ]
context-admin
vsys-admin
virtual-server-name:清除指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将清除所有虚服务器的统计信息。
# 清除所有虚服务器的统计信息。
<Sysname> reset virtual-server statistics
·     display virtual-server statistics
1.1.242  response
response命令用来配置对指定的HTTP请求进行代答。
undo response命令用来恢复缺省情况。
response { url url file filename | workpath workpath zip-file zip-filename }
undo response { url url | workpath workpath }
未配置对指定的HTTP请求进行代答。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
url url:URL资源路径,用来匹配HTTP请求。为1~255个字符的字符串,区分大小写。该路径必须以/开始。
file filename:非压缩文件名称,为1~255个字符的字符串,不区分大小写。
workpath workpath:工作路径,用来匹配HTTP请求URL。为1~255个字符的字符串,区分大小写。该参数可以配置为/,如果不是则要求该路径必须以/开始,不能以/结束。
zip-file zip-filename:压缩文件名称,为1~255个字符的字符串,不区分大小写,必须为.zip格式的压缩文件。ZIP压缩包内相对路径用来匹配HTTP请求的URL。
兼容性说明
该命令与server-farm (LB action view)和redirect relocation (LB action view)命令两两互斥。
工作机制
通过配置本命令,可用指定文件对HTTP请求进行代答。具体代答情况如下:
·     如果客户端请求URL中的资源路径匹配配置的url,则用配置的filename文件内容作为代答内容。
·     如果客户端请求URL中的资源路径匹配配置的workpath+ZIP压缩包内相对路径,则使用ZIP压缩包内的文件答复客户端。例如:用户通过配置response workpath /index zip-file flash:/za/zb/test.zip对指定的HTTP请求进行代答,test.zip中存在如下压缩目录关系/css/col.css,则实际匹配的URL资源路径为/index/css/col.css,代答文件为col.css。
URL匹配时不支持URL编码。
若同时配置用压缩文件和非压缩文件对HTTP请求进行代答。且压缩文件和非压缩文件匹配的URL资源路径相同,则使用非压缩文件进行代答。
配置本命令时,要求设备上已存在命令行配置的路径。
相同HTTP类型的负载均衡动作视图下,无论URL资源路径是否相同,多次配置压缩文件,最后一次配置生效。
相同HTTP类型的负载均衡动作视图下,对于同一URL只允许用一个非压缩文件进行代答。同一个非压缩文件可以代答不同的URL。
# 配置HTTP请求URL为/index/subsys/subsys_intf.js时,代答文件为subsys.js。
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] response url /index/subsys/subsys_intf.js file subsys.js
·     display loadbalance action
·     redirect relocation (LB action view)
·     server-farm (LB action view)
1.1.243  retransmission enable
retransmission enable命令用来配置Diameter数据报文重传功能。
undo retransmission enable命令用来关闭Diameter数据重传功能。
Diameter数据报文重传功能处于关闭状态。
context-admin
vsys-admin
当设备向服务器发送Diameter数据报文一段时间后,还没有得到服务器的响应,则有必要重传Diameter数据报文,以保证用户尽可能地获得相应的服务。
开启Diameter数据重传功能后,当设备向实服务器发送数据报文时,在数据重传超时时间内没有收到实服务器的应答报文,将选择同一实服务组内另一台实服务器重新发送该数据报文,并重新开始计时,若在重传超时时间到期时依旧没有收到应答,则认为该Diameter数据发送失败,通知客户端不可达。
设备仅支持对数据报文重传一次。
# 在Diameter-session类型的参数模板dia下,配置开启数据重传功能。
[Sysname-para-diameter-session-dia] retransmission enable
·     parameter-profile
·     retransmission timeout
1.1.244  retransmission timeout
retransmission timeout命令用来配置Diameter数据报文重传超时时间。
undo retransmission命令用来恢复缺省情况。
retransmission timeout timeout-value
undo retransmission timeout
Diameter数据报文重传超时时间为5秒。
context-admin
vsys-admin
timeout-value:重传超时时间,取值范围为1~4294967295,单位为秒。
配置本命令前,请先通过retransmission enable开启Diameter数据报文重传功能。
在开启Diameter数据报文重传功能情况下,设备向实服务器发送数据报文后,如果在数据重传超时时间内没有收到实服务器应答,则选择同一实服务组内另一台实服务器重新发送该数据报文,并重新开始计时,若在重传超时时间到期时依旧没有收到应答,则认为该Diameter数据发送失败,通知客户端不可达。
设备仅支持对数据报文重传一次。
管理员可通过本配置灵活、合理地设置Diameter数据报文重传的超时时间,避免设置超时时间较长,导致资源释放过慢,造成浪费;或设置超时时间过短,而导致服务器来不及处理而无法完成用户请求。
# 在Diameter会话类型的参数模板dia下,配置Diameter数据报文重传超时时间为15秒。
[Sysname-para-diameter-session-dia] retransmission timeout 15
·     parameter-profile
·     retransmission enable
1.1.245  retransmission-timeout
retransmission-timeout命令用来配置TCP连接中数据报文重传的总超时时间。
undo retransmission-timeout命令用来恢复缺省情况。
retransmission-timeout timeout-value
TCP连接中数据报文重传的总超时时间为120秒。
TCP类型参数模板视图
context-admin
vsys-admin
timeout-value:报文重传的总超时时间,取值范围为0~1000,单位为秒。当取值为0时,表示报文重传的总超时时间不受限制,但当重传次数超过13次时,将自动断开TCP连接。
配置本命令后,若TCP连接中数据包发生重传,当重传总时间超出配置的超时时间时,设备将直接关闭TCP连接。如果超时时间配置为0,则表示报文重传的总超时时间不受限制,但当重传次数超过13次时,将自动断开TCP连接。
# 在TCP类型的参数模板视图下,配置TCP连接的报文重传总超时时间为180秒。
[Sysname] parameter-profile tcppara type tcp
[Sysname-para-tcp-tcppara] retransmission-timeout 180
1.1.246  route-advertisement enable
route-advertisement enable命令用来开启虚服务器IP地址发布功能。
undo route-advertisement enable命令用来关闭虚服务器IP地址发布功能。
虚服务器IP地址发布功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
开启虚服务器IP地址发布功能后,设备会将虚服务器的IP地址发布给OSPF模块参与路由计算,当数据中心进行切换的时候,保证访问虚服务器的流量也可以自动切换,从而提高负载均衡服务的可靠性。有关OSPF的配置请参见“三层技术-IP路由”中的“OSPF”。
# 开启虚服务器IP地址发布功能。
[Sysname] virtual-server vs type ip
[Sysname-vs-ip-vs] route-advertisement enable
1.1.247  rst threshold
rst threshold命令用来配置RST报文的上限阈值。
undo rst threshold命令用来恢复缺省情况。
rst threshold number
undo rst threshold
RST报文的上限阈值为1000000。
context-admin
vsys-admin
number:RST报文数,取值范围为1~4294967295。
若实服务器发送的RST报文达到RST报文的上限阈值,则执行由protect-action命令指定的负载均衡探测模板保护动作。
# 在TCP RST类型的负载均衡探测模板下,配置RST报文的上限阈值为20。
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] rst threshold 20
·     protect-action
1.1.248  rule (parameter profile view)
rule命令用来配置进行压缩的过滤条件。
undo rule命令用来恢复缺省情况。
rule [ rule-id ] { deny | permit } { content-type | url } expression
undo rule rule-id
未配置任何过滤条件。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
rule-id:规则的编号,取值范围为1~65535。如果指定编号的规则不存在,则创建一条新的规则;如果指定编号的规则已存在,则对其进行修改。如果未指定本参数,系统将自动分配一个可用的最小编号。
deny:对符合匹配规则的报文不进行压缩。
permit:符合匹配规则的报文进行压缩。
content-type:匹配范围限于content-type首部中携带的报文体类型。
url:匹配范围限于报文携带的URL。
expression:正则表达式,为1~255的字符串,不支持正则元字符?,表示匹配的内容,区分大小写。
# 创建HTTP压缩类型的参数模板http1,并配置对url中包含image的应答报文不进行压缩。
[Sysname-para-http-compression-http1] rule deny url image
1.1.249  rule (protection policy view)
rule命令用来创建防护规则,并进入防护规则视图。如果指定编号的防护规则已经存在,则直接进入防护规则视图。
undo rule命令用来删除指定的防护规则。
rule rule-id
undo rule rule-id
不存在防护规则。
HTTP类型的防护策略视图
context-admin
rule-id:防护规则编号,取值范围为1~65535。
工作机制
同一类型的HTTP防护规则视图下,允许创建多条防护规则。转发报文时会按照配置的防护规则ID顺序匹配防护规则。若用户访问的URL与某防护规则下的URL匹配成功且访问指定URL的次数超过请求报文数阈值,则执行相应的防护动作;若与某防护规则下的URL匹配不成功,则继续匹配下一条防护规则。
注意事项
非缺省vSystem不支持本命令。
# 在HTTP类型防护策略p1视图下,创建编号为5的防护规则,并进入防护规则视图。
[Sysname] loadbalance protection-policy p1
1.1.250  secondary-cookie delimiters
secondary-cookie delimiters命令用来配置URL中分隔Secondary Cookie的字符。
undo secondary-cookie delimiters命令用来恢复缺省情况。
secondary-cookie delimiters text
URL中分隔Secondary Cookie的字符为“/”、“&”、“#”或“+”。
HTTP类型的参数模板视图
context-admin
vsys-admin
text:分隔字符,为1~4个字符的字符串,包括:!、"、#、;、<、>、?、[、\、]、^、`、|、:、@、&、$、+、*、'、(、)、,、/。该字符串中的每个字符都被认为是分隔字符。
# 在HTTP类型的参数模板pp1中,配置URL中分隔Secondary Cookie的字符为“/”、“@”、“#”或“$”。
[Sysname-para-http-pp1] secondary-cookie delimiters /@#$
1.1.251  secondary-cookie start
secondary-cookie start命令用来配置URL中Secondary Cookie的起始位置标示字符。
undo secondary-cookie start命令用来恢复缺省情况。
secondary-cookie start text
URL中Secondary Cookie的起始位置标示字符为“?”。
HTTP类型的参数模板视图
context-admin
vsys-admin
text:标示字符,为1~2个字符的字符串,包括:!、"、#、;、<、>、?、[、\、]、^、`、|。
# 在HTTP类型的参数模板pp1中,配置URL中Secondary Cookie的起始位置标示字符为“?”或“!”。
[Sysname-para-http-pp1] secondary-cookie start ?!
1.1.252  selected-server
selected-server命令用来配置实服务组中可被调度算法调用的实服务器数量限制。
undo selected-server命令用来恢复缺省情况。
selected-server min min-number max max-number
实服务组中调用优先级最高的实服务器全部被调度算法调用。
实服务组视图
context-admin
vsys-admin
min min-number:可被调度算法调用的实服务器最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的实服务器最大数量,取值范围1~1000,且必须大于等于min-number。
用户通过本命令可以限制可被调度算法调用的实服务器数量:
·     如果调用优先级最高的可用实服务器数量大于max-number时,则只选用max-number个实服务器。
·     如果调用优先级最高的可用实服务器数量小于min-number时,除了调用全部优先级最高的可用实服务器外,还会调用优先级次高的可用实服务器,直至调用的可用实服务器数量达到min-number,或者没有可用的实服务器可调用为止。
# 配置实服务组sf中可被调度算法调用的实服务器最小数量为20,最大数量为30。
[Sysname-sfarm-sf] selected-server min 20 max 30
·     predictor(server farm view)
·     priority(real server view)
1.1.253  server-connection reuse
server-connection reuse命令用来开启负载均衡设备与服务器的连接复用功能。
undo server-connection reuse命令用来关闭负载均衡设备与服务器的连接复用功能。
负载均衡设备与服务器的连接复用功能处于关闭状态。
HTTP类型的参数模板视图
MySQL类型的参数模板视图
context-admin
vsys-admin
工作机制
通过开启负载均衡设备与服务器的连接复用功能,在负载均衡设备与服务器之间建立连接,使多个客户端复用同一条与服务器的连接,以减少客户端与服务器之间打开的连接数。
注意事项
快速HTTP类型的虚服务器不支持本功能。
# 在HTTP类型的参数模板pp1中,开启负载均衡设备与服务器的连接复用功能。
[Sysname-para-http-pp1] server-connection reuse
1.1.254  service-down-action reset
service-down-action reset命令用来开启虚服务不可用时立即断开TCP连接功能。
undo service-down-action reset命令用来关闭虚服务不可用时立即断开TCP连接功能。
虚服务不可用时立即断开TCP连接功能处于关闭状态。
TCP/HTTP/快速HTTP/MySQL/SIP-TCP类型的虚服务器视图
context-admin
vsys-admin
若开启虚服务不可用时立即断开TCP连接功能,当虚服务不可用后,收到客户端的SYN报文时会立即应答RST报文
# 在TCP类型的虚服务器视图下,开启虚服务不可用时立即断开TCP连接功能。
[Sysname-vs-tcp-vs] service-down-action reset
1.1.255  server-farm (LB action view)
server-farm命令用来指定指导转发的实服务组。
undo server-farm命令用来恢复缺省情况。
server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name [ backup backup-sticky-name ] ]
undo server-farm
未指定指导转发的实服务组。
负载均衡动作视图
context-admin
vsys-admin
server-farm-name:主用实服务组的名称,为1~255个字符的字符串,不区分大小写。
backup backup-server-farm-name:备用实服务组的名称,为1~255个字符的字符串,不区分大小写。
sticky sticky-name:实服务组所对应主用持续性组的名称,为1~255个字符的字符串,不区分大小写。
backup backup-sticky-name:实服务组所对应的备用持续性组的名称,为1~255个字符的字符串,不区分大小写。仅HTTP和RADIUS类型的负载均衡动作支持配置本参数。
兼容性说明
本命令与forward all和redirect relocation命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
工作机制
当主用实服务组可用(该实服务组存在且有可用的实服务器)时,使用主用实服务组指导转发;当主用实服务组不可用而备用实服务组可用时,使用备用实服务组指导转发。
如果用户既配置了主用持续性组,也配置了备用持续性组,则会根据两个持续性组同时生成主用持续性表项和备用持续性表项。当有新的流量匹配已生成持续性表项时,如果未能匹配到主用持续性表项,则进行备用持续性表项匹配。
注意事项
若配置了备用持续性组,只有如下三种组合才会生成备用持续性表项,否则配置不生效:
·     主用持续性组为RADIUS类型,备用持续性组为地址端口类型;
·     主用持续性组为HTTP Cookie类型,备用持续性组为地址端口类型;
·     主用持续性组为HTTP Cookie类型,备用持续性组为HTTP passive类型。
# 在通用类型的负载均衡动作lba1中,指定指导转发的主用实服务组为sf,备用实服务组为sfb,持续性组为sg1。
[Sysname-lba-generic-lba1] server-farm sf backup sfb sticky sg1
·     forward all
1.1.256  server-farm (real server view)
server-farm命令用来指定实服务器所属的实服务组。
undo server-farm [ server-farm-name ]
实服务器不属于任何实服务组。
实服务器视图
context-admin
vsys-admin
server-farm-name:实服务组的名称,为1~255个字符的字符串,不区分大小写。
指定实服务组名称时,可以是尚未创建的实服务组。
不推荐使用本功能指定实服务器所属的实服务组,请进入实服务组视图通过real-server命令添加实服务器。
# 指定实服务器rs属于实服务组sf。
·     real-server (server farm view)
1.1.257  server-farm (system view)
server-farm命令用来创建实服务组,并进入实服务组视图。如果指定的实服务组已经存在,则直接进入实服务组视图。
undo server-farm命令用来删除指定的实服务组。
undo server-farm server-farm-name
不存在任何实服务组。
context-admin
vsys-admin
工作机制
为了便于对多台服务器进行管理,可以依据这些服务器的共有属性划分成不同的组,称为实服务组。比如,可按存储内容的不同划分为歌曲服务器组、视频服务器组或图片服务器组等。
配置准备
# 创建实服务组sf,并进入实服务组视图。
[Sysname-sfarm-sf]
1.1.258  service enable
service enable命令用来开启虚服务器。
undo service enable命令用来关闭虚服务器。
service enable
undo service enable
虚服务器处于关闭状态。
虚服务器视图
context-admin
vsys-admin
# 开启IP类型的虚服务器vs3。
[Sysname-vs-ip-vs3] service enable
# 出方向链路负载均衡场景下,开启LINK-IP类型的虚服务器vs2。
[Sysname-vs-link-ip-vs2] service enable
1.1.259  service object-group
service object-group命令用来配置进行SNAT地址转换的服务对象组。
undo service object-group命令用来恢复缺省情况。
service object-group object-group-name
对匹配虚服务器的所有服务类型的流量都进行SNAT地址转换。
SNAT全局策略视图
context-admin
vsys-admin
object-group-name:服务对象组的名称,为1~63个字符的字符串,不区分大小写。
若在SNAT全局策略视图下,配置了进行SNAT地址转换的服务对象组,则仅对匹配指定服务的流量进行SNAT地址转换。有关服务对象组的配置请参见“安全配置指导”中的“对象组”。
# 在SNAT全局策略sn1视图下,配置进行SNAT地址转换的服务对象组为obj1。
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] service object-group obj1
·     object-group(安全命令参考/对象组)
1.1.260  set ip tos (LB action view)
set ip tos命令用来配置发往服务器的IP报文中的ToS字段。
undo set ip tos命令用来恢复缺省情况。
set ip tos tos-number
undo set ip tos
不改变发往服务器的IP报文中的ToS字段。
负载均衡动作视图
context-admin
vsys-admin
tos-number:ToS字段值,取值范围为0~255。
# 在通用类型的负载均衡动作lba1中,配置发往服务器的IP报文中的ToS字段值为20。
[Sysname-lba-generic-lba1] set ip tos 20
# 出方向链路负载均衡场景下,在链路类型的负载均衡动作lba2中,配置发往服务器的IP报文中的ToS字段值为20。
[Sysname] loadbalance action lba2 type link-generic
[Sysname-lba-link-generic-lba2] set ip tos 20
# DNS透明代理场景下,在DNS类型的负载均衡动作lba3中,配置发往DNS服务器的IP报文中的ToS字段值为20。
[Sysname] loadbalance action lba3 type dns
[Sysname-lba-dns-lba3] set ip tos 20
1.1.261  set ip tos (parameter profile view)
set ip tos命令用来配置发往客户端的IP报文中的ToS字段。
undo set ip tos
不改变发往客户端的IP报文中的ToS字段。
参数模板视图
context-admin
vsys-admin
tos-number:ToS字段值,取值范围0~255。
本命令只在IP类型的参数模板视图下支持。
# 在IP类型的参数模板pp2中,配置发往客户端的IP报文中的ToS字段值为20。
[Sysname-para-ip-pp2] set ip tos 20
1.1.262  shutdown (real server view)
shutdown命令用来关闭实服务器。
undo shutdown命令用来开启实服务器。
shutdown
实服务器处于开启状态。
实服务器视图
context-admin
vsys-admin
# 关闭实服务器rs。
[Sysname-rserver-rs] shutdown
1.1.263  shutdown (server farm member view)
shutdown命令用来关闭实服务组成员。
undo shutdown命令用来开启实服务组成员。
shutdown
实服务组成员处于开启状态。
实服务组成员视图
context-admin
vsys-admin
# 关闭实服务组成员rs1。
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] shutdown
1.1.264  shutdown-real-servers ip
shutdown-real-servers ip命令用来关闭指定IPv4地址的实服务器。
undo shutdown real-servers ip命令用来恢复缺省情况。
shutdown-real-servers ip ip-address  [ vpn-instance vpn-instance-name ]
undo shutdown-real-servers ip ip-address [ vpn-instance vpn-instance-name ]
指定IPv4地址的实服务器处于开启状态。
context-admin
vsys-admin
ip ip-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
vpn-instance vpn-instance-name:指定实服务器所属VPN实例。vpn-instance-name为MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示关闭公网的实服务器。
工作机制
系统中可能存在多个相同IPv4地址的实服务器,当管理员需要将这些实服务器都关闭时,则可以通过此命令批量关闭这些实服务器。
应用场景
在网络中,当一台物理服务器支持多种服务时,管理员可以在设备上配置多个相同IP地址的实服务器或实服务组成员,使其承担不同的业务。当后台物理服务器出现故障,需要立即关闭设备上对应的实服务器时,可以通过本功能批量关闭该IP地址的所有实服务器,以节省人工查找和逐个关闭实服务器的时间,提高网络运维的效率。
注意事项
当一个实服务器下同时配置了IPv4地址和IPv6地址,通过本命令关闭任意一个地址时,该实服务器都将处于关闭状态。
# 关闭地址为1.2.3.4的实服务器。
[Sysname] shutdown-real-servers ip 1.2.3.4
1.1.265  shutdown-real-servers ipv6
shutdown-real-servers ipv6命令用来关闭指定IPv6地址的实服务器。
undo shutdown real-servers ipv6命令用来恢复缺省情况。
shutdown-real-servers ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
undo shutdown-real-servers ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
指定IPv6地址的实服务器处于开启状态。
context-admin
vsys-admin
ipv6 ipv6-address:IPv6地址,不能为环回地址、组播地址、广播地址及全零地址。
工作机制
系统中可能存在多个相同IPv6地址的实服务器,当管理员需要将这些实服务器都关闭时,则可以通过此命令批量关闭这些实服务器。
应用场景
注意事项
# 关闭地址为1::4的实服务器。
[Sysname] shutdown-real-servers ipv6 1::4
1.1.266  slow-attack protection enable
slow-attack protection enable命令用来在HTTP类型防护策略下开启HTTP慢速攻击防护功能。
undo slow-attack protection enable命令用来关闭HTTP类型防护策略下HTTP慢速攻击防护功能。
HTTP类型防护策略下HTTP慢速攻击防护功能处于关闭状态。
HTTP防护策略视图
context-admin
工作机制
用户可以在HTTP类型的防护策略中配置HTTP慢速攻击防护,设备会对收到的HTTP请求报文进行分析。将根据Slow headers的超时时间来判断是否受到慢速攻击,如果受到慢速攻击则执行防护动作。
当客户端发送一个HTTP请求报文,在Slow headers攻击的超时时间到达时,设备没有接收到完整的HTTP首部,则认为受到了Slow headers攻击。
注意事项
非缺省vSystem不支持本命令。
配置HTTP慢速攻击防护功能后需指定防护动作为丢弃报文,即protection-action  drop,否则HTTP慢速攻击防护功能不生效。
# 在HTTP类型的防护策略视图下,开启HTTP慢速攻击防护功能。
[Sysname-lbpp-http-p1] slow-attack protection enable
·     display loadbalance protection-policy
·     protection-action
1.1.267  slow-attack request-header timeout
slow-attack request-header timeout命令用来配置Slow headers攻击的超时时间。
undo slow-attack request-header timeout命令用来关闭Slow headers攻击检查。
slow-attack request-header timeout timeout-value
Slow headers攻击检查处于关闭状态。开启HTTP慢速攻击防护功能后,Slow headers攻击的超时时间为10秒。
HTTP防护策略视图
context-admin
timeout-value:客户端发送完整HTTP请求报文Header的超时时间,取值范围为1~65535,缺省值为10,单位为秒。
工作机制
注意事项
非缺省vSystem不支持本命令。
开启HTTP慢速攻击防护功能后,Slow headers攻击的超时时间配置才会生效。
当通过本命令开启Slow headers攻击防护时,仅对修改后新建的流量生效,对已有的流量不生效。
# 在HTTP类型的防护策略视图下,配置Slow headers攻击的超时时间。
[Sysname-lbpp-http-p1] slow-attack request-header timeout 10
·     slow-attack protection enable
1.1.268  slow-offline enable (real server view)
slow-offline enable命令用来开启实服务器的平滑退出功能。
undo slow-offline enable命令用来关闭实服务器的平滑退出功能。
slow-offline enable
实服务器的平滑退出功能处于关闭状态。
实服务器视图
context-admin
vsys-admin
工作机制
通过shutdown命令可以立即中断实服务器的已有连接,而平滑退出则不会立即中断实服务器的已有连接。开启平滑退出功能后,实服务器只处理已建立连接的流量信息,以及属于现有持续性表项的流量信息,并且一直保持对实服务器的健康监测。
应用场景
当需要暂时移除实服务器,并希望能够随时重新启用时,可以选择平滑退出功能,确保管理员可以实时监控移除的实服务器健康状态。
配置准备
本命令需要与shutdown命令配合使用。
本命令与slow-shutdown enable命令互斥,后开启的命令生效。
# 开启实服务器rs的平滑退出功能。
[Sysname-rserver-rs] slow-offline enable
·     shutdown(real server view)
·     slow-shutdown enable(real server view)
1.1.269  slow-offline enable (server farm member view)
slow-offline enable命令用来在实服务组中开启实服务组成员的平滑退出功能。
undo slow-offline enable命令用来在实服务组中关闭实服务组成员的平滑退出功能。
slow-offline enable
实服务器组成员的平滑退出功能处于关闭状态。
实服务器组成员视图
context-admin
vsys-admin
工作机制
通过shutdown命令可以立即中断实服务器组成员的已有连接,而平滑退出则不会立即中断实服务器的已有连接。开启平滑退出功能后,实服务组成员只处理已建立连接的流量信息,以及属于现有持续性表项的流量信息,直到所有持续性表项老化后,才关闭实服务器,但仍然保持对实服务组成员的健康监测。
应用场景
当需要暂时移除实服务组成员,并希望能够随时重新启用时,可以选择平滑退出功能,确保管理员可以实时监控移除的实服务组成员健康状态。
配置准备
# 开启实服务器组sf下rs成员的平滑退出功能。
[Sysname-sfarm-sf] real-server rs port 0
[Sysname-sfarm-sf-#member#-rs-port-0] slow-offline enable
[Sysname-sfarm-sf-#member#-rs-port-0] shutdown
·     shutdown(server farm member view)
·     slow-shutdown enable(server farm member view)
1.1.270  slow-online
slow-online命令用来在实服务组中开启实服务器温暖上线功能。
undo slow-online命令用来在实服务组中关闭实服务器温暖上线功能。
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
实服务组中的实服务器温暖上线功能处于关闭状态。
实服务组视图
context-admin
vsys-admin
standby-time standby-time:准备时间,取值范围为0~600,单位为秒,缺省为5秒。
ramp-up-time ramp-up-time:爬升时间,取值范围为3~600,单位为秒,缺省为5秒。
可以通过开启温暖上线功能,解决实服务组中新增实服务器无法立即承担大量业务的问题。当实服务组中新增一个可用实服务器后,在准备时间内,负载均衡设备不会向其分配任何业务;准备时间超时后,负载均衡设备在爬升时间内会逐步增加向其分配的业务量;爬升时间超时后,负载均衡设备开始向其正常分配业务。
# 在实服务组sf中开启实服务器温暖上线功能。
[Sysname-sfarm-sf] slow-online
1.1.271  slow-shutdown enable (real server view)
slow-shutdown enable命令用来开启实服务器的慢宕功能。
undo slow-shutdown enable命令用来关闭实服务器的慢宕功能。
实服务器的慢宕功能处于关闭状态。
实服务器视图
context-admin
vsys-admin
工作机制
通过shutdown命令可以立即中断实服务器的已有连接,而慢宕则不会立即中断实服务器的已有连接,而是让其自然老化,并且不再建立新的连接。
应用场景
当实服务器需要进行维护或升级时,为了避免突然中断连接导致用户体验下降,可以选择启用慢宕功能。
配置准备
本命令需要与shutdown命令配合使用。必须开启了慢宕功能之后再关闭实服务器,该实服务器才会开始慢宕。如果先关闭实服务器,再开启慢宕功能,则慢宕功能不生效,实服务器处于关闭状态。
本命令与slow-offline enable命令互斥,后开启的命令生效。
# 开启实服务器rs的慢宕功能。
[Sysname-rserver-rs] slow-shutdown enable
·     slow-offline enable(real server view)
1.1.272  slow-shutdown enable (server farm member view)
slow-shutdown enable命令用来开启实服务组成员的慢宕功能。
undo slow-shutdown enable命令用来关闭实服务组成员的慢宕功能。
实服务组成员的慢宕功能处于关闭状态。
实服务组成员视图
context-admin
vsys-admin
工作机制
通过shutdown命令可以立即中断实服务组成员的已有连接,而慢宕则不会立即中断实服务组成员的已有连接,而是让其自然老化,并且不再建立新的连接。
应用场景
当实服务组成员需要进行维护或升级时,为了避免突然中断连接导致用户体验下降,可以选择启用慢宕功能。
配置准备
本命令需要与shutdown命令配合使用。必须开启了慢宕功能之后再关闭实服务组成员,该实服务组成员才会开始慢宕。如果先关闭实服务组成员,再开启慢宕功能,则慢宕功能不生效,实服务组成员处于关闭状态。
# 开启实服务组成员rs1的慢宕功能。
[Sysname-sfarm-sf-#member#-rs1-port-80] slow-shutdown enable
·     slow-offline enable(server farm member view)
1.1.273  snat enable
snat enable命令用来开启SNAT功能。
undo snat enable命令用来关闭SNAT功能。
snat enable
undo snat enable
SNAT功能处于关闭状态。
SNAT全局策略视图
context-admin
vsys-admin
# 在SNAT全局策略sn1视图下,开启SNAT功能。
[Sysname-lb-snat-gp-sn1] snat enable
1.1.274  snat-mode
snat-mode命令用来配置SNAT地址转换方式。
undo snat-mode命令用来恢复缺省情况。
snat-mode { auto-map | tcp-option }
undo snat-mode
未配置SNAT地址转换方式。
实服务组视图
context-admin
vsys-admin
auto-map:自动映射方式的SNAT地址转换。
tcp-option:TCP Option方式的SNAT地址转换。
兼容性说明
同一实服务组视图下,三种源地址转换方式互斥,后配置的生效。即本命令与snat-pool (server farm view)命令互斥。
工作机制
通过配置SNAT功能可将收到报文的源地址转换为指定地址,设备在实服务组视图下支持配置三种源地址转换方式:
·     Auto Map:采用设备与实服务器通信的接口地址进行源地址转换。
·     TCP Option:根据收到报文的TCP Option字段携带的地址进行源地址转换。
·     SNAT地址池:根据配置的SNAT地址池进行源地址转换。
当配置了SNAT全局策略时,若未在实服务组视图下配置SNAT功能,则采用SNAT全局策略进行源地址转换。
# 在实服务组sf视图下,配置SNAT地址转换方式为自动映射。
[Sysname-sfarm-sf] snat-mode auto-map
·     loadbalance snat-global-policy
·     snat-pool (server farm view)
1.1.275  snat-pool
snat-pool命令用来指定实服务组引用的SNAT地址池。
undo snat-pool命令用来恢复缺省情况。
snat-pool pool-name
undo snat-pool
实服务组未引用任何SNAT地址池。
实服务组视图
context-admin
vsys-admin
pool-name:SNAT地址池的名称,为1~255个字符的字符串,不区分大小写。
SNAT地址池是一个地址范围,它被实服务组引用之后,负载均衡设备将把收到报文的源地址修改为SNAT地址池中的地址后再转发出去。
# 指定实服务组sf引用的SNAT地址池为lbsp。
[Sysname-sfarm-sf] snat-pool lbsp
1.1.276  snmp-agent trap enable loadbalance
snmp-agent trap enable loadbalance命令用来开启负载均衡的告警功能。
undo snmp-agent trap enable loadbalance命令用来关闭负载均衡的告警功能。
负载均衡的告警功能处于开启状态。
context-admin
工作机制
开启了负载均衡的告警功能之后,负载均衡会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
注意事项
非缺省vSystem不支持本命令。
# 关闭负载均衡的告警功能。
[Sysname] undo snmp-agent trap enable loadbalance
1.1.277  source-ip
source-ip命令用来配置基于源IP地址的防护阈值。
undo source-ip命令用来恢复缺省情况。
source-ip request-threshold threshold
undo source-ip
未配置基于源IP地址的防护阈值。
防护规则视图
context-admin
vsys-admin
request-threshold threshold:请求报文数阈值,取值范围为1~4294967295。
在统计周期内,若同一用户访问指定URL的次数超过请求报文数阈值,则执行防护动作。设备支持基于以下两种特征来判断请求报文是否来自同一用户。
·     基于Cookie:若请求报文中对应于指定Cookie名称的Cookie值相同,则认为请求报文来自同一用户。Cookie名称由cookie (protection policy view)命令指定。
·     基于源IP地址:设备将来自相同源IP地址的请求报文判断为来自同一用户。
若同时配置基于Cookie的防护阈值和基于源IP地址的防护阈值,则当携带相同Cookie值或者相同源IP的报文达到配置的阈值时,执行相应的动作。
# 在编号为5的防护规则视图下,配置基于源IP地址的防护阈值为2。
[Sysname-lbpp-http-p1-rule-5] source-ip request-threshold 2
·     protection-action
·     protection-period
·     protected-url
1.1.278  source-ip object-group (parameter profile view)
source-ip object-group命令用来配置按照指定源IP地址对象组进行HTTP流量统计。
undo source-ip object-group命令用来删除进行HTTP流量统计的指定源IP地址对象组。
source-ip object-group object-group-name
undo source-ip object-group object-group-name
按照单个源IP地址进行HTTP流量统计。
HTTP统计类型的参数模板视图
context-admin
object-group-name:IP地址对象组的名称,为1~63个字符的字符串,不区分大小写。
工作机制
若HTTP流量匹配了指定URL,并且HTTP流量的源IP地址匹配了指定的源IP地址对象组,则按照源IP地址对象组进行流量统计。若未匹配指定的源IP地址对象组,则按照单个源IP地址进行流量统计。
一个HTTP统计类型的参数模板中最多允许指定1024个IP地址对象组。
注意事项
非缺省vSystem不支持本命令。
本命令只对IP地址对象(network命令)的host、subnet、range类型配置生效。有关IP地址对象的配置请参见“安全配置指导”中的“对象组”。
# 在HTTP统计类型的参数模板中,配置按照源IP地址对象组cnc进行HTTP流量统计。
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] source-ip object-group cnc
·     network(安全命令参考/对象组)
1.1.279  source-ip object-group (SNAT global policy view)
source-ip object-group命令用来配置进行SNAT地址转换的源IP地址对象组。
undo source-ip object-group命令用来恢复缺省情况。
对所有源IP地址的流量都进行SNAT地址转换。
SNAT全局策略视图
context-admin
vsys-admin
若在SNAT全局策略视图下,配置了进行SNAT地址转换的源IP地址对象组,则仅对匹配指定源IP地址的流量进行SNAT地址转换。有关IP地址对象组的配置请参见“安全配置指导”中的“对象组”。
# 在SNAT全局策略sn1视图下,配置进行SNAT地址转换的源IP地址对象组为obj1。
[Sysname-lb-snat-gp-sn1] source-ip object-group obj1
1.1.280  src-addr-option
src-addr-option命令用来配置进行SNAT地址转换的TCP Option。
undo src-addr-option命令用来恢复缺省情况。
src-addr-option option-number [ encode { binary | string } ]
未配置进行SNAT地址转换的TCP Option。
TCP类型的参数模板视图
context-admin
vsys-admin
option-number:TCP选项的类型编号,取值范围为6、7、9~18、22~254。
encode { binary | string }:TCP Option的编码方式。binary表示TCP Option的编码方式为二进制编码,string表示TCP Option的编码方式为字符串编码。若未配置本参数,则TCP Option的编码方式为二进制编码。
通过配置本命令,设备可以解析收到的报文中指定编号的TCP Option字段携带的IP地址,并配合snat-mode命令将解析处理后的地址进行源地址转换。
此命令在客户端侧的参数模板下生效。
在同一参数模板视图下,多次执行本命令,最后一次执行的命令生效。
# 在TCP类型的参数模板pp3视图下,配置进行SNAT地址转换的TCP Option编号为28,编码方式为二进制编码。
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] src-addr-option 28 encode binary
·     snat-mode
1.1.281  ssl session-id
ssl session-id命令用来配置SSL持续性方法为基于SSL会话ID。
undo ssl session-id命令用来恢复缺省情况。
ssl session-id
undo ssl session-id
不存在任何持续性方法。
SSL类型的持续性组视图
context-admin
工作机制
基于SSL会话ID的SSL持续性方法对HTTPS请求报文有效,并且需要指定虚服务器引用的SSL服务器端策略。
注意事项
非缺省vSystem不支持本命令。
# 在SSL类型的持续性组sg6中,指定SSL的持续性方法为基于SSL会话ID。
[Sysname] sticky-group sg6 type ssl
[Sysname-sticky-ssl-sg6] ssl session-id
1.1.282  ssl url rewrite
ssl url rewrite命令用来重写服务器发送的HTTP应答报文Location首部的URL。
undo ssl url rewrite命令用来取消该配置。
ssl url rewrite location location [ clearport clear-port ] [ sslport ssl-port ]
undo ssl url rewrite location location [ clearport clear-port ]
不重写服务器发送的HTTP应答报文Location首部的URL。
HTTP类型的负载均衡动作视图
context-admin
vsys-admin
location location:Location首部URL的正则表达式,为1~255个字符的字符串,区分大小写。
clearport clear-port:原HTTP端口号,取值范围为1~65535,缺省值为80。
sslport ssl-port:重写后的SSL端口号,取值范围为1~65535,缺省值为443。
配置了本命令后,如果HTTP应答报文Location首部匹配了指定的location和clear-port,系统会将Location首部的URL由HTTP重写为HTTPS,并将clear-port重写为ssl-port。
# 在HTTP类型的负载均衡动作lba2中,将服务器发送的HTTP应答报文Location首部的URL,由http://www.ss.example.com:8080重写为https://www.ss.example.com:443。
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] ssl url rewrite location www.ss.example.com clearport 8080 sslport 443
1.1.283  ssl-client-policy (LB action view)
ssl-client-policy命令用来引用SSL客户端策略,以便对负载均衡设备(作为SSL客户端)与SSL服务器之间传输的流量进行加密传输。
undo ssl-client-policy命令用来恢复缺省情况。
ssl-client-policy policy-name
undo ssl-client-policy policy-name
未引用任何SSL客户端策略。
HTTP/Diameter类型的负载均衡动作视图
context-admin
vsys-admin
policy-name:SSL客户端策略的名称,为1~255个字符的字符串,不区分大小写。
设备不支持引用加密套件为exp_rsa_des_cbc_sha、exp_rsa_rc2_md5、exp_rsa_rc4_md5、rsa_des_cbc_sha的SSL客户端策略。
# 在HTTP类型的负载均衡动作lba2中,引用SSL客户端策略scp。
[Sysname-lba-http-lba2] ssl-client-policy scp
1.1.284  ssl-client-policy (virtual server view)
ssl-client-policy命令用来指定虚服务器引用的SSL客户端策略,以便对负载均衡设备(作为SSL客户端)与SSL服务器之间传输的流量进行加密传输。
虚服务器未引用任何SSL客户端策略。
HTTP类型的虚服务器视图
context-admin
vsys-admin
# 在HTTP类型的虚服务器vs2上,引用SSL客户端策略scp。
[Sysname-vs-http-vs2] ssl-client-policy scp
1.1.285  ssl-server-policy
ssl-server-policy命令用来指定虚服务器引用的SSL服务器端策略,以便对负载均衡设备(作为SSL服务器)与SSL客户端之间传输的流量进行加密传输。
undo ssl-server-policy命令用来删除指定的SSL服务器端策略。
ssl-server-policy policy-name [ sni server-name ]
undo ssl-server-policy [ policy-name sni]
虚服务器未引用任何SSL服务器端策略。
TCP/HTTP/Diameter类型的虚服务器视图
context-admin
vsys-admin
sni server-name:SSL服务器名称指示,为1~253个字符的字符串,不区分大小写。
工作机制
当虚服务器引用多个SSL服务器端策略时,设备会选取不带SNI的SSL服务器端策略作为默认策略。如未配置不带SNI的SSL服务器端策略,则选取排序最后的带SNI的策略作为默认策略。策略排序规则为:相同策略,后添加的往前排;不同策略,按添加顺序往后排。
请确保设备选取的默认SSL服务器端策略配置正常有效。
在相同视图下,不允许配置多个相同的SSL服务器端策略。
在相同视图下,不允许配置SNI相同的多个SSL服务器端策略。
注意事项
设备不支持引用加密套件为exp_rsa_des_cbc_sha、exp_rsa_rc2_md5、exp_rsa_rc4_md5、rsa_des_cbc_sha的SSL服务器端策略。
# 在HTTP类型的虚服务器vs2上,引用SSL服务器端策略ssp。
[Sysname-vs-http-vs2] ssl-server-policy ssp
1.1.286  statistics-match url
statistics-match url命令用来配置URL类型的统计匹配规则。
undo statistics-match命令用来删除指定的统计匹配规则。
statistics-match [ rule-id ] url url
undo statistics-match rule-id
不存在统计匹配规则。
统计节点视图
context-admin
rule-id:统计匹配规则的编号,取值范围为1~256。若未指定本参数,系统将自动分配一个可用的最小编号。
url:URL的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符?。
非缺省vSystem不支持本命令。
一个统计节点视图中,最多允许配置256条统计匹配规则。
# 在统计节点bank视图下,配置URL类型的统计匹配规则为:匹配以.html结尾的所有URL。
[Sysname-para-http-statistics-http1] node bank
[Sysname-para-http-statistics-http1-node-bank] statistics-match url *.html
1.1.287  status-code
status-code命令用来配置HTTP passive类型探测模板所要检查的响应状态码。
undo status-code命令用来删除指定的HTTP passive类型探测模板所要检查的响应状态码。
status-code code
undo status-code code
未配置HTTP passive类型探测模板所要检查的响应状态码。
HTTP passive类型的负载均衡探测模板视图
context-admin
vsys-admin
code:响应状态码,取值范围为100~599。
当设备收到携带指定URL的HTTP请求报文后,会对其响应报文进行HTTP被动健康检测。本命令用来指定HTTP passive类型探测模板所要检查的响应状态码。若HTTP响应报文中携带的状态码为配置的值,则认为检测到一次异常URL。
同一HTTP类型的负载均衡探测模板视图下,最多允许配置10个响应状态码。
# 在HTTP passive类型的负载均衡探测模板下,配置HTTP passive类型探测模板所要检查的响应状态码为404。
[Sysname] loadbalance probe-template http-passive tplt
[Sysname-lbpt-http-passive-tplt] status-code 404
·     check-url
1.1.288  sticky
sticky命令用来指定虚服务器引用的持续性组。
undo sticky命令用来恢复缺省情况。
sticky sticky-name
undo sticky
未指定虚服务器引用的持续性组。
HTTP类型的虚服务器视图
context-admin
vsys-admin
sticky-name:持续性组名称,为1~255个字符的字符串,不区分大小写。
工作机制
设备支持通过执行default server-farm、server-farm (LB action view)命令和本命令引用持续性组。本命令引用的持续性组优先级最高。即在进行流量分配时,优先根据虚服务器引用的持续性组生成持续性表项。
注意事项
本命令仅支持引用HTTP Cookie类型的持续性组。
# 在HTTP类型虚服务器下,指定虚服务器引用的Cookie持续性组为test。
[Sysname-vs-http-vs] sticky test
·     default server-farm
·     sticky-group
1.1.289  sticky-group
sticky-group命令用来创建持续性组,并进入持续性组视图。如果指定的持续性组已经存在,则直接进入持续性组视图。
undo sticky-group命令用来删除指定的持续性组。
sticky-group group-name [ type { address-port | diameter | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } ]
undo sticky-group group-name
不存在持续性组。
context-admin
vsys-admin
group-name:持续性组的名称,为1~255个字符的字符串,不区分大小写。
type { address-port | diameter | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }:持续性组的类型,包括地址端口、Diameter、HTTP实体、HTTP Cookie、HTTP首部、HTTP passive、HTTP/UDP载荷、RADIUS、SIP、SSL、TCP载荷和UDP passive。创建持续性组时必须指定本参数;而在进入已创建的持续性组视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
工作机制
持续性组的作用是根据某种持续性方法将具有一定相关性的会话都分配给同一个实服务器/链路处理。在一个会话中,当其首包通过持续性方法选择了实服务器/链路之后,后续包都会沿用这个选择结果。
配置准备
Diameter、HTTP实体、HTTP Cookie、HTTP首部、HTTP passive、HTTP载荷、RADIUS、SIP、SSL、TCP载荷和UDP passive类型的持续性组需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
# 创建地址端口类型的持续性组sg1,并进入持续性组视图。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1]
1.1.290  sticky-over-busy enable
sticky-over-busy enable命令用来开启持续性处理优先于繁忙功能。
undo sticky-over-busy enable命令用来关闭持续性处理优先于繁忙功能。
持续性处理优先于繁忙功能处于关闭状态。
持续性组视图
context-admin
vsys-admin
若本功能处于开启状态,则在持续性表项老化之前,无论实服务器是否处于繁忙状态,设备都会依据持续性表项为其分配流量。
若本功能处于关闭状态,则在持续性表项老化之前,设备会依据持续性表项仅为处于正常状态的实服务器分配流量。
# 在地址端口类型的持续性组sg1中,开启持续性优先于繁忙功能。
[Sysname-sticky-address-port-sg1] sticky-over-busy enable
1.1.291  sticky-sync enable (virtual server view)
sticky-sync enable命令用来开启虚服务器的持续性表项备份功能。
undo sticky-sync enable命令用来关闭虚服务器的持续性表项备份功能。
sticky-sync enable [ global ]
虚服务器的持续性表项备份功能处于关闭状态。
虚服务器视图
context-admin
vsys-admin
global:开启持续性表项的全局备份功能。
工作机制
在开启虚服务器的持续性表项备份功能之前,请确保主用和备用设备上均不存在持续性表项。可以通过先开启持续性表项备份功能,再引用持续性组,保证备份前设备上不存在持续性表项。
推荐配置
在VRRP组网中,开启虚服务器的持续性表项备份功能时必须指定global参数,否则配置不生效。
若设备的配置发生以下变化,则设备会删除当前已有的持续性表项,后续流量将会重新触发生成新的持续性表项。
·     关闭持续性表项备份功能
·     持续性表项备份由组间备份切换为全局备份
·     持续性表项备份由全局备份切换为组间备份
# 开启IP类型的虚服务器vs3的持续性表项备份。
[Sysname-vs-ip-vs3] sticky-sync enable
# 在出方向链路负载均衡场景下,开启LINK-IP类型的虚服务器vs2的持续性表项备份。
[Sysname-vs-link-ip-vs2] sticky-sync enable
1.1.292  success-criteria (real server view)
success-criteria命令用来配置实服务器健康检测的成功条件。
undo success-criteria命令用来恢复缺省情况。
success-criteria { all | at-least min-number }
只有全部方法都通过检测才认为健康检测成功。
实服务器视图
context-admin
vsys-admin
all:只有全部方法都通过检测才认为健康检测成功。
at-least min-number:健康检测成功所需通过检测的最少方法数,取值范围为1~4294967295。
当用户指定的最少方法数大于设备上实际存在的方法数量时,系统也将认为健康检测成功。
用户既可在实服务组视图下对组内的所有实服务器进行配置,也可在实服务器视图下只对当前实服务器进行配置,后者的配置优先级较高。
# 配置实服务器rs的健康检测成功所需通过检测的最少方法数为2个。
[Sysname] real-server rs
[Sysname-rserver-rs] success-criteria at-least 2
1.1.293  success-criteria (server farm member view)
success-criteria命令用来配置实服务组成员健康检测的成功条件。
实服务组成员视图
context-admin
vsys-admin
用户既可在实服务组视图下对组内的所有实服务组成员进行配置,也可在实服务组成员视图下只对当前实服务组成员配置,后者的配置优先级高。
实服务器的健康检测结果影响实服务组成员的使用,实服务组成员的健康检测结果不影响实服务器的使用。
# 配置实服务组成员rs1的健康检测成功所需通过检测的最少方法数为2个。
[Sysname] server-farm sf
[Sysname-sfarm-sf-#member#-rs1-port-80] success-criteria at-least 2
1.1.294  success-criteria (server farm view)
success-criteria命令用来配置实服务组健康检测的成功条件。
实服务组视图
context-admin
vsys-admin
# 配置实服务组sf的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-sfarm-sf] success-criteria at-least 2
1.1.295  syn retransmission-timeout
syn retransmission-timeout命令用来配置TCP连接SYN报文的重传超时时间。
undo syn retransmission-timeout命令用来恢复缺省情况。
syn retransmission-timeout timeout-value
TCP连接SYN报文的重传超时时间为10秒。
TCP类型的参数模板视图
context-admin
vsys-admin
timeout-value:TCP连接SYN报文的重传超时时间,取值范围为1~75,单位为秒。
本命令用来配置设备等待SYN ACK的超时时间。若超过此时间未收到任何响应,则直接关闭TCP连接。
最多支持创建3个包含非缺省TIME-WAIT、FIN-WAIT-1、FIN-WAIT-2或SYN报文重传超时时间的TCP参数模板。
# 在TCP类型的参数模板profile下,配置TCP连接SYN报文的重传超时时间为5秒。
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] syn retransmission-timeout 5
·     display parameter-profile
1.1.296  syn-cookie threshold
syn-cookie threshold命令用来配置触发SYN Cookie保护功能的门限值。
undo syn-cookie threshold命令用来恢复缺省情况。
syn-cookie threshold threshold
触发SYN Cookie功能的门限值为0,即不会触发SYN Cookie功能。
TCP类型的参数模板视图
context-admin
vsys-admin
threshold:触发SYN Cookie功能的半开连接数门限值,取值范围为1~4294967295。若未指定本参数,则门限值为0,表示引用该参数模板的TCP类型的虚服务不会触发SYN Cookie保护功能。
应用场景
一般情况下,TCP连接的建立需要经过三次握手,一些恶意的攻击者利用TCP连接的建立过程进行SYN Flood攻击,从而达到耗费服务器资源,使服务器无法处理正常业务的目的。
管理员可配置本命令,当虚服务器与客户端之间的半开连接数达到配置的门限值时,就会触发SYN Cookie保护功能。通过这种方式,可以避免在设备上建立大量的半开连接,防止受到SYN Flood攻击。
半开连接,即客户端与虚服务器建立TCP连接过程中,虚服务器在收到TCP连接请求SYN报文之后到收到ACK报文之前,连接尚未建立的状态。
注意事项
仅当TCP类型参数模板被TCP类型虚服务器引用,且虚服务器配置了工作在四层模式时,本配置才生效。
# 在TCP类型的参数模板tcppara中,设置触发SYN Cookie保护功能的门限值为10。
[Sysname-para-tcp-tcppara] syn-cookie threshold 10
1.1.297  tcp connection idle-timeout
tcp connection idle-timeout命令用来配置TCP连接的空闲超时时间。
undo tcp connection idle-time命令用来恢复缺省情况。
tcp connection idle-timeout value
undo tcp connection idle-timeout
TCP连接的空闲超时时间为0,即不超时。
TCP类型的参数模板视图
context-admin
vsys-admin
value:TCP连接的空闲超时时间,取值范围为1~86400,单位为秒。
通过本命令可以自定义负载均衡设备与客户端以及服务器建立的TCP连接的空闲超时时间。若在TCP连接的空闲超时时间内没有应用数据传输,负载均衡设备会主动断开与客户端或服务器的TCP连接。
# 配置TCP连接的空闲超时时间为60秒。
[Sysname] parameter-profile pp1 type tcp
[Sysname-para-tcp-pp1] tcp connection idle-timeout 60
1.1.298  tcp mss
tcp mss命令用来配置负载均衡设备与对端建立TCP连接时的MSS值。
undo tcp mss命令用来恢复缺省情况。
tcp mss value
undo tcp mss
未配置负载均衡设备与对端建立TCP连接时的MSS值。
TCP类型的参数模板视图
context-admin
vsys-admin
value:MSS值,取值范围为128~1460,单位为字节。
工作机制
在客户端与负载均衡设备建立TCP连接时,客户端将MSS值通告给负载均衡设备,负载均衡设备会记录下这个MSS值,并将配置的MSS值发送给客户端,客户端与负载均衡设备将使用较小的MSS值作为双方通信的最大分段长度。
在负载均衡设备与服务器建立TCP连接时,负载均衡设备将配置的MSS值通告给服务器,服务器会记录下这个MSS值,并将自身的MSS值发送给负载均衡设备,负载均衡设备与服务器将使用较小的MSS值作为双方通信的最大分段长度。
注意事项
本命令仅当快速HTTP类型和HTTP类型的虚服务器引用了TCP类型的参数模板时才会生效。
# 配置负载均衡设备与对端建立TCP连接时的MSS值为1300。
[Sysname] parameter-profile tcp type tcp
[Sysname-para-tcp-tcp] tcp mss 1300
1.1.299  tcp delayed-acks
tcp delayed-acks命令用来配置TCP延迟ACK的接收数据包数量。
undo tcp delayed-acks命令用来恢复缺省情况。
tcp delayed-acks number
TCP延迟ACK的接收数据包数量为2。
TCP类型参数模板视图
context-admin
vsys-admin
number:TCP延迟ACK的接收数据包数量,取值范围为1~8。
工作机制
通过本命令配置TCP延迟ACK的接收数据包数量,当设备接收到指定数量的数据包后将统一发送ACK响应,以减少ACK报文的发送次数。
推荐配置
管理员需要根据实际网络环境合理设置延迟ACK的数据包数量。通常情况下,保持缺省情况即可。而在网络环境较差的情况下,建议将延迟ACK的数据包数量配置为1,以确保设备能够及时回复ACK响应,从而维持连接的稳定性,避免因网络延迟导致连接断开。
在网络环境良好的情况下,可以适量调高延迟ACK的数据包数量,以减少ACK报文的发送频率,提高网络传输效率。
# 在TCP类型的参数模板pp1中,配置TCP延迟ACK的接收数据包数量为2。
[Sysname-para-tcp-pp1] tcp delayed-acks 2
1.1.300  tcp option preserve
tcp option preserve命令用来配置TCP选项的保持功能。
undo tcp option preserve命令用来取消对指定TCP选项的保持功能的配置。
tcp option preserve option-number
undo tcp option preserve option-number
TCP类型的参数模板视图
未配置TCP选项的保持功能。TCP报文头中的时间戳选项使用loadbalance tcp-timestamp-mode命令的当前配置作为缺省情况。
context-admin
vsys-admin
option-number:TCP选项的类型编号,当前取值只能为8,表示TCP报文头中的时间戳选项。
工作机制
本命令用来保持负载均衡设备发送给服务器的TCP报文头中指定选项的不变。当前仅支持配置TCP时间戳选项的保持功能,即TCP选项编号为8。
注意事项
在通过本命令、tcp option remove或tcp option rewrite命令对TCP报文头中类型编号为8的TCP选项进行配置时,最后一次执行的命令生效。
当同时配置了系统视图下的loadbalance tcp-timestamp-mode命令和本命令时,则本命令优先级较高。
# 在TCP类型的参数模板pp1中,保持TCP报文头中的时间戳选项。
[Sysname-para-tcp-pp1] tcp option preserve 8
·     loadbalance tcp-timestamp-mode
·     parameter-profile
·     tcp option remove
·     tcp option rewrite
1.1.301  tcp option insert
tcp option insert命令用来在TCP选项中插入内容。
undo tcp option insert命令用来取消在指定TCP选项中插入内容的配置。
tcp option insert option-number { src-addr | value value } [ encode { binary | string } ]
undo tcp option insert option-number
未在TCP选项中插入内容。
TCP类型的参数模板视图
context-admin
vsys-admin
src-addr:在TCP选项中插入客户端真实源IP地址。
value value:要插入TCP选项中的内容,为1~255个字符的字符串,支持以下改写变量:
·     %{is}:客户端侧的源IP地址。
·     %{isl}:客户端侧的源IP地址长度,1字节。
·     %{ps}:客户端侧的源端口号。
·     %{psl}:客户端侧的源端口号长度,1字节。
工作机制
本命令用来在负载均衡设备发送给服务器的TCP报文头的指定选项中插入指定内容。
仅允许通过多次配置本命令插入5个TCP选项。
当TCP参数模板被工作在四层的TCP类型虚服务器引用时,指定内容只会在SYN、首个ACK以及首个PSH ACK报文中插入(包括重传的报文);而被工作在七层的TCP类型虚服务器引用时,则可以通过配置TCP选项插入模式,选择只在数据报文中插入,或在TCP协商报文和每个数据报文中都插入指定内容。
对同一TCP选项,多次执行本命令,最后一次执行的命令生效。
注意事项
本命令仅在以下几种类型的虚服务器引用TCP类型的参数模板时才会生效:
·     HTTP类型的虚服务器
·     TCP类型的虚服务器
·     MySQL类型的虚服务器
# 在TCP类型的参数模板para2中,在类型编号为28的TCP选项中插入客户端的源IP地址。
[Sysname] parameter-profile para2 type tcp
[Sysname-para-tcp-para2] tcp option insert 28 src-addr
·     parameter-profile
1.1.302  tcp option insert-mode
tcp option insert-mode命令用来配置TCP选项插入模式。
undo tcp option insert-mode命令用来恢复缺省情况。
tcp option insert-mode data-packet
插入模式为插入数据报文以及握手阶段报文。
TCP类型的参数模板视图
context-admin
vsys-admin
data-packet:指定TCP选项插入模式为只插入数据报文。
缺省情况下,TCP选项的插入模式为插入数据报文以及握手阶段报文,通过配置本命令,可指定在TCP选项中插入内容时的插入模式为只插入数据报文。
# 在TCP类型的参数模板para2中,指定TCP选项插入模式为只插入数据报文。
[Sysname-para-tcp-para2] tcp option insert-mode data-packet
1.1.303  tcp option remove
tcp option remove命令用来清除TCP报文头中的指定选项。
undo tcp option remove命令用来取消对指定TCP选项进行清除的配置。
tcp option remove option-number
undo tcp option remove option-number
未对TCP报文头中的指定选项进行清除。TCP报文头中的时间戳选项使用loadbalance tcp-timestamp-mode命令的当前配置作为缺省情况。
TCP类型的参数模板视图
context-admin
vsys-admin
option-number:TCP选项的类型编号,取值范围为3~254。
工作机制
本命令用来清除负载均衡设备发送给服务器的TCP报文头中的指定选项。
注意事项
在通过本命令、tcp option preserve或tcp option rewrite命令对TCP报文头中类型编号为8的TCP选项进行配置时,最后一次执行的命令生效。
当同时配置了系统视图下的loadbalance tcp-timestamp-mode命令以及本命令清除TCP报文头中类型编号为8的选项(即TCP时间戳选项)时,则本命令优先级较高。
仅允许通过多次配置本命令清除5个TCP选项。
# 在TCP类型的参数模板para2中,清除TCP报文头中类型编号为8的TCP选项。
[Sysname-para-tcp-para2] tcp option remove 8
·     parameter-profile
·     tcp option preserve
1.1.304  tcp option rewrite
tcp option rewrite命令用来配置TCP选项的重写功能。
undo tcp option rewrite命令用来取消对指定TCP选项的重写功能的配置。
tcp option rewrite option-number
undo tcp option rewrite option-number
TCP类型的参数模板视图
未配置TCP选项的重写功能。TCP报文头中的时间戳选项使用loadbalance tcp-timestamp-mode命令的当前配置作为缺省情况。
context-admin
vsys-admin
工作机制
本命令用来重写负载均衡设备发送给服务器的TCP报文头中的指定选项。当前仅支持配置TCP时间戳选项的重写功能,即TCP选项编号为8。通过本命令可以重写TCP报文头中的时间戳选项字段的值为设备当前时间值。
注意事项
在通过本命令、tcp option remove或tcp option preserve命令对TCP报文头中类型编号为8的TCP选项进行配置时,最后一次执行的命令生效。
# 在TCP类型的参数模板pp1中,重写TCP报文头中的时间戳选项。
[Sysname-para-tcp-pp1] tcp option rewrite 8
·     parameter-profile
·     tcp option remove
1.1.305  tcp window-size
tcp window-size命令用来配置TCP连接中的本地最大窗口值。
undo tcp window-size命令用来恢复缺省情况。
tcp window-size size
TCP连接中的本地最大窗口值为65535。
TCP类型的参数模板视图
context-admin
vsys-admin
# 在TCP类型的参数模板pp3中,配置TCP连接中的本地最大窗口值为8192。
[Sysname-para-tcp-pp3] tcp window-size 8192
1.1.306  tcp-close
tcp-close命令用来配置关闭TCP连接的方式。
undo tcp-close命令用来恢复缺省情况。
tcp-close { fin | rst }
undo tcp -close
关闭TCP连接的方式为发送TCP FIN报文。
通用/HTTP/Diameter类型的负载均衡动作视图
context-admin
vsys-admin
fin:FIN方式关闭连接。
rst:RST方式关闭连接。
# 在通用类型的负载均衡动作下,配置关闭TCP连接的方式为发送RST报文。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] tcp-close rst
1.1.307  payload (TCP payload sticky-group view)
payload命令用来配置TCP载荷类型的持续性方法。
undo payload命令用来删除TCP载荷持续性方法。
payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload
未配置TCP载荷类型的持续性方法。
TCP载荷类型的持续性组视图
context-admin
vsys-admin
offset offset:TCP载荷基于TCP报文起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:TCP载荷开始标记的正则表达式,即从offset起到本标记为开始,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
end end-string:TCP载荷结束标记的正则表达式,即从start-string起到本标记为结束,为1~127个字符的字符串,区分大小写,不支持正则元字符?。
length length:TCP载荷的长度,取值范围为0~1000,缺省值为0,表示所有长度。
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的TCP载荷信息。start-string和end-string将不计入持续性表项信息中。
若未配置任何参数,则表示TCP类型的持续性方法为依据完整的TCP报文生成持续性表项。
# 在TCP载荷类型的持续性组sg中,配置TCP载荷持续性方法为:依据完整的TCP报文生成持续性表项。
[Sysname] sticky-group sg type tcp-payload
[Sysname-sticky-payload-sg] payload
1.1.308  timeout (LB probe template view)
timeout命令用来配置探测报文的应答超时时间。
undo timeout命令用来恢复缺省情况。
undo timeout
ICMP和自定义监控类型探测报文的应答超时时间为3秒,HTTP passive类型探测报文的应答超时时间为5秒。
ICMP类型的负载均衡探测模板视图
自定义监控类型的负载均衡探测模板视图
context-admin
vsys-admin
timeout-value:探测报文的应答超时时间,ICMP类型的取值范围为1~60,HTTP passive类型的取值范围为1~255,自定义监控类型的取值范围为1~86400,单位为秒。
工作机制
当HTTP passive类型的负载均衡探测模板被引用后,若设备收到携带指定URL的HTTP请求报文后,会对其响应报文进行HTTP被动健康检测。本命令用来指定HTTP passive类型探测模板的响应超时时间。若HTTP报文的响应时间超过配置的响应超时时间,则认为检测到一次异常URL。
推荐配置
建议通过本命令配置的探测报文的应答超时时间小于监控周期(通过命令monitor-interval配置)。
# 在ICMP类型的探测模板icmptplt下,配置探测报文的应答超时时间为5秒。
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lbpt-icmp-icmptplt] timeout 5
·     check-url
·     monitor-interval
1.1.309  timeout (sticky group view)
timeout命令用来配置持续性表项的超时时间。
timeout { indefinite | timeout-value }
undo timeout
对于HTTP Cookie、HTTP passive和UDP passive类型的持续性组,持续性表项的超时时间为86400秒;对于Diameter类型的持续性组,持续性表项的超时时间为180秒;对于其它类型的持续性组,持续性表项的超时时间为60秒。
持续性组视图
context-admin
vsys-admin
indefinite:表示持续性表项不老化。HTTP Cookie、HTTP passive和UDP passive类型不支持配置本参数.
timeout-value:超时时间。对于HTTP Cookie类型的持续性组,取值范围为0~31536000,单位为秒;对于其它类型的持续性组,取值范围为10~604800,单位为秒。
对于HTTP Cookie类型的持续性组,当其持续性方法为Cookie插入或Cookie重写时,0表示该持续性为会话持续性;当其持续性方法为Cookie截取时,0表示此持续性表项的超时时间为0秒。
# 在地址端口类型的持续性组sg1中,配置持续性表项的超时时间为100秒。
[Sysname-sticky-address-port-sg1] timeout 100
1.1.310  time-wait timeout
time-wait timeout命令用来配置TCP连接TIME-WAIT状态的超时时间。
undo time-wait timeout命令用来恢复缺省情况。
time-wait timeout value
TCP连接TIME-WAIT状态的超时时间为2秒。
TCP类型参数模板视图
context-admin
vsys-admin
value:TCP连接TIME-WAIT状态的超时时间,取值范围为0~65535,单位为秒。当取值为0时,表示立即释放TCP连接。
TCP连接断开时,由于TCP协议的TIME-WAIT状态超时时间较长,导致TCP连接释放过慢,影响负载均衡业务处理效率。本命令用来灵活设置TIME-WAIT状态超时时间。
# 在TCP类型的参数模板pa1视图下,配置TCP连接TIME-WAIT状态的超时时间30秒。
[Sysname] parameter-profile pa1 type tcp
[Sysname-para-tcp-pa1] time-wait timeout 30
1.1.311  traffic-group (virtual server view)
traffic-group命令用来指定虚服务器引用的集群流量组。
undo traffic-group命令用来恢复缺省情况。
undo traffic-group
未指定虚服务器引用的集群流量组。
虚服务器视图
context-admin
traffic-group-id:表示集群流量组的编号,取值范围为1~255。
应用场景
在集群组网中,流量组是集群中处理业务的基本逻辑单元。配置虚服务器引用的集群流量组,可以将匹配虚服务器的报文提交给集群流量组进行处理。
虚服务器引用集群流量组时,需保证当前设备已经加入引用的流量组。
不同类型的虚服务器可以引用相同的集群流量组。
注意事项
非缺省vSystem不支持本命令。
# 指定虚服务器vs1引用ID为1的集群流量组。
[Sysname] virtual-server vs1 type http
[Sysname-vs-http-vs1] traffic-group 1
·     cluster traffic-group(高可靠性命令参考/集群(RBM))
1.1.312  traffic-group (snat pool view)
traffic-group命令用来指定SNAT地址池引用的集群流量组。
undo traffic-group
未指定SNAT地址池引用的集群流量组。
SNAT地址池视图
context-admin
应用场景
在集群组网中,流量组是集群中处理业务的基本逻辑单元。配置SNAT地址池引用的集群流量组,可以将匹配SNAT地址池的报文提交给集群流量组进行处理。
SNAT地址池引用集群流量组时,需保证当前设备已经加入引用的流量组。
注意事项
非缺省vSystem不支持本命令。
# 指定SNAT地址池sp引用ID为1的集群流量组。
[Sysname] loadbalance snat-pool sp
[Sysname-lbsnat-pool-addr-sp] traffic-group 1
1.1.313  translation-mode
translation-mode命令用来配置SNAT地址转换方式。
undo translation-mode命令用来恢复缺省情况。
translation-mode { auto-map | snat-pool pool-name }
不进行SNAT地址转换。
SNAT全局策略视图
context-admin
vsys-admin
snat-pool pool-name:SNAT地址池方式的SNAT地址转换。pool-name表示SNAT地址池的名称,为1~255个字符的字符串,不区分大小写。
工作机制
通过配置SNAT全局策略可将设备收到报文的源地址转换为指定地址,设备支持在SNAT全局策略视图下配置两种SNAT地址转换方式:
·     Auto Map:采用设备与实服务器通信的接口地址进行SNAT地址转换。
·     SNAT地址池:根据配置的SNAT地址池进行SNAT地址转换。设备将匹配报文的源地址修改为SNAT地址池中的地址后再转发出去。
注意事项
只有在实服务组视图下未配置SNAT功能时,SNAT全局策略才会生效。
# 在SNAT全局策略sn1视图下,配置SNAT地址转换方式为将报文的源地址转换为SNAT地址池sp中的地址。
[Sysname-lb-snat-gp-sn1] translation-mode snat-pool sp
1.1.314  transparent enable
transparent enable命令用来在实服务组中关闭NAT功能。
undo transparent enable命令用来在实服务组中开启NAT功能。
transparent enable
实服务组中的NAT功能处于开启状态。
实服务组视图
context-admin
vsys-admin
实服务组被HTTP类型的虚服务器引用时,即使关闭了NAT功能也将仍按照NAT模式处理。
# 在实服务组sf中关闭NAT功能。
[Sysname-sfarm-sf] transparent enable
1.1.315  udp per-packet
udp per-packet命令用来开启虚服务器的UDP强制负载均衡功能。
undo udp per-packet命令用来关闭虚服务器的UDP强制负载均衡功能。
udp per-packet
undo udp per-packet
虚服务器的UDP强制负载均衡功能处于关闭状态。
UDP类型的虚服务器视图
基于UDP的SIP类型的虚服务器视图
context-admin
vsys-admin
工作机制
当UDP强制负载均衡功能关闭时,匹配虚服务器的流量按照数据流来进行负载均衡,即一个应用的流量会被负载均衡到同一个实服务器上;而当UDP强制负载均衡功能开启后,匹配虚服务器的流量不再按照流来进行负载均衡,而是按照每报文来进行负载均衡。
注意事项
UDP强制负载均衡功能开启后,需要注意的是:
·     虚服务器以及实服务器上与连接数相关的数据将不会被统计。
·     如果引用的实服务组未开启NAT功能,虚服务器以及实服务器上的发出的报文数量将不会被统计。
·     以下配置项仍将生效:虚服务器所引用实服务组上配置的调度算法、虚服务器引用实服务组时所配置的持续性组中的持续性方法。例如,实服务组的调度算法为哈希算法或者持续性方法为源IP地址持续性时,由于同一会话的五元组相同,哈希计算结果和持续性表项匹配结果都是相同的实服务器,因此属于同一会话的UDP报文仍将被送至同一个实服务器进行处理,而无法按照每报文进行负载均衡。
# 开启UDP类型的虚服务器vs5的UDP强制负载均衡功能。
[Sysname] virtual-server vs5 type udp
[Sysname-vs-udp-vs5] udp per-packet
1.1.316  username (virtual server view)
username命令用来配置登录MySQL数据库时使用的用户名和密码。
undo username命令用来删除登录MySQL数据库时使用的用户名。
username username [ password { cipher | simple } string ]
undo username username
未配置登录MySQL数据库时使用的用户名和密码。
MySQL类型的虚服务器视图
context-admin
vsys-admin
username:用户名,为1~63个字符的字符串,区分大小写。
password:指定登录MySQL数据库的用户密码。若未指定该参数,则表示密码为空。
cipher:表示以密文方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~127个字符的字符串;密文密码为1~255个字符的字符串。
设备最多支持配置100个MySQL数据库的登录用户。
通过本命令配置的MySQL数据库使用的用户名和密码必须与真实的MySQL数据库保持一致。
# 在MySQL类型的虚服务器vs1视图下,配置MySQL数据库的登录用户root并设置其密码为123456。
[Sysname-vs-mysql-vs1] username root password simple 123456
1.1.317  variable
variable命令用来配置实服务组成员关联的变量。
undo variable命令用来删除实服务组成员关联的变量。
variable variable-name value value
undo variable variable-name
未配置实服务组成员关联的变量。
实服务组成员视图
context-admin
vsys-admin
variable-name:实服务组成员关联的变量名称,为1~63个字符的字符串,区分大小写。
value value:实服务组成员关联的变量值,为1~127个字符的字符串,区分大小写。
# 在实服务组成员rs视图下,配置实服务组关联的变量名称为var1,取值为_1。
[Sysname-sfarm-sf] real-server rs port 5001
[Sysname-sfarm-sf-#member#-rs-port-5001] variable var1 value _1
·     payload rewrite
1.1.318  vendor-id
vendor-id命令用来配置由IANA分配的厂商标识。
undo vendor-id命令用来恢复缺省情况。
vendor-id vendor-id
undo vendor-id
厂商ID为25506,表示厂商为H3C。
Diameter-session类型参数模板视图
context-admin
vsys-admin
vendor-id:表示厂商ID,取值范围为1~4294967295,缺省值为25506,表示厂商为H3C。
设备与对端进行Diameter协商时,会通过CER和CEA协商报文进行信息交换,交换的信息包括:源主机名、源域名、厂商ID及产品名称等。通过本命令指定设备的厂商ID,当设备与对端进行Diameter协商时,设备将配置的厂商ID发送给对端。
# 在Diameter-session类型的参数模板dia下,配置厂商ID为25506。
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] vendor-id 25506
·     parameter-profile
1.1.319  version
version命令用来配置MySQL数据库的版本。
undo version命令用来恢复缺省情况。
version { 5.0 | 5.1 | 5.5 | 5.6 | 5.7 }
undo version
MySQL数据库的版本为5.6。
MySQL类型的虚服务器视图
context-admin
vsys-admin
{ 5.0 | 5.1 | 5.5 | 5.6 | 5.7 }:MySQL数据库的版本号。
在MySQL类型的服务器负载均衡中,负载均衡设备会代替MySQL服务器对客户端进行认证。若通过本命令配置了MySQL数据库的版本,则设备会向客户端发送该版本的数据库初始化报文。
# 在MySQL类型的虚服务器vs1视图下,配置MySQL数据库的版本为5.7。
[Sysname] virtual-server vs1 type mysql
[Sysname-vs-mysql-vs1] version 5.7
1.1.320  virtual ip address
virtual ip address命令用来配置虚服务器的IPv4地址(即VSIP)。
undo virtual ip address命令用来删除指定的虚服务器IPv4地址。
virtual ip address ipv4-address [ mask-length | mask | vpn-instance vpn-instance-name ]
undo virtual ip address [ ipv4-address [ vpn-instance vpn-instance-name | all ] ]
未配置虚服务器的IPv4地址。
虚服务器视图
context-admin
vsys-admin
ipv4-address:虚服务器的IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X(如果掩码长度不是32,则可以配置0.X.X.X)。
mask-lengh:子网掩码长度,取值范围为0~32,缺省值为32。本参数在快速HTTP和HTTP类型的虚服务器视图下不支持。
mask:子网掩码,缺省值为255.255.255.255。本参数在快速HTTP和HTTP类型的虚服务器视图下不支持。
vpn-instance vpn-instance-name:指定虚服务器的IPv4地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示虚服务器的IPv4地址属于在虚服务器视图下通过执行vpn-instance命令配置的VPN实例。非缺省vSystem不支持配置本参数。
all:删除指定虚服务器下的IPv4地址及其所有VPN实例。
工作机制
通过本命令,管理员可选择为虚服务器配置一个IPv4地址网段或多个单个的IPv4地址。当配置IP地址网段时,多次执行本命令,最后一次执行的结果生效;当配置单个的IPv4地址时,则可以为该地址指定所属的VPN实例,最多可以配置256个单个的IPv4地址。需要注意的是,同一个虚服务器不支持同时配置IP地址网段和单个IP地址。
执行undo virtual ip address命令时:
·     如果不携带任何参数,则会删除虚服务器下所有的IPv4地址。
·     如果携带ipv4-address vpn-instance vpn-instance-name参数,则会删除虚服务器下指定VPN实例的IPv4地址。
·     如果携带ipv4-address all参数,则会删除虚服务器下IPv4地址及其所有VPN实例。
推荐配置
若在虚服务器下配置了单个的IP地址,并且为IP地址指定了VPN实例,那么实服务器无法直接继承对应虚服务器下配置的VPN实例。建议执行inherit vpn-instance disable命令关闭实服务器VPN实例的继承功能,或通过在实服务器视图下执行vpn-instance命令指定实服务器所属的VPN实例。
若虚服务器的IP地址与设备连接客户端的接口IP地址在同一网段,则必须配置虚服务器IPv4地址的掩码长度为32位,且必须通过执行arp-nd interface (virtual server view)命令指定发送免费ARP报文或ND报文的接口。否则,无需指定发送免费ARP报文或ND报文的接口。
注意事项
在虚服务器视图下执行vpn-instance命令指定虚服务器所属的VPN实例,对虚服务器下所有未指定VPN实例的虚服务器IP地址都生效;通过本命令指定虚服务器IPv4地址所属的VPN实例,只对当前IPv4地址生效,后者的配置优先级较高。
基于UDP的SIP类型和端口号为5060的UDP类型虚服务器,当通过udp per-packet命令开启UDP强制负载均衡功能,并通过loadbalance alg sip命令启用SIP协议类型的负载均衡ALG功能时,暂不支持处理多个IP地址,因此,建议只配置一条虚服务器IP地址。
# 配置IP类型的虚服务器vs3的IP地址为1.1.1.1/24。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] virtual ip address 1.1.1.1 24
# 配置IP类型的虚服务器vs1的IP地址,其中IPv4地址为1.1.1.1,所属VPN实例为vpn1;IPv4地址为1.1.1.2,所属VPN实例为vpn2。
[Sysname] virtual-server vs1 type ip
[Sysname-vs-ip-vs1] virtual ip address 1.1.1.1 vpn-instance vpn1
[Sysname-vs-ip-vs1] virtual ip address 1.1.1.2 vpn-instance vpn2
·     arp-nd interface (virtual server view)
·     inherit vpn-instance disable (real server view)
·     vpn-instance (real server view)
·     vpn-instance (virtual server view)
1.1.321  virtual ipv6 address
virtual ipv6 address命令用来配置虚服务器的IPv6地址(即VSIP)。
undo virtual ipv6 address命令用来删除指定的虚服务器IPv6地址。
virtual ipv6 address ipv6-address [ prefix-length | vpn-instance vpn-instance-name ]
undo virtual ipv6 address [ ipv6-address [ vpn-instance vpn-instance-name | all ] ]
未配置虚服务器的IPv6地址。
虚服务器视图
context-admin
vsys-admin
ipv6-address:虚服务器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址(如果前缀长度为0,则可以配置全0地址)。
prefix-length:前缀长度,取值范围为0~128,缺省值为128。本参数在快速HTTP和HTTP类型的虚服务器视图下不支持。
vpn-instance vpn-instance-name:指定虚服务器的IPv6地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示虚服务器的IPv6地址属于在虚服务器视图下通过执行vpn-instance命令配置的VPN实例。非缺省vSystem不支持配置本参数。
all:删除虚服务器下的IPv6地址及其所有VPN实例。
工作机制
通过本命令,管理员可选择为虚服务器配置一个IPv6地址网段或多个单个的IPv6地址。当配置IP地址网段时,多次执行本命令,最后一次执行的结果生效;当配置单个的IPv6地址时,则可以为该地址指定所属的VPN实例,最多可以配置256个单个的IPv6地址。需要注意的是,同一个虚服务器不支持同时配置IP地址网段和单个IP地址。
执行undo virtual ipv6 address命令时:
·     如果不携带任何参数,则会删除虚服务器所有的IPv6地址配置。
·     如果携带ipv6-address vpn-instance vpn-instance-name参数,则会删除虚服务器下指定VPN实例的IPv6地址。
·     如果携带ipv6-address all参数,则会删除虚服务器下的IPv6地址及其VPN实例。
推荐配置
若虚服务器的IP地址与设备连接客户端的接口IP地址在同一网段,则必须配置虚服务器IPv6地址的前缀长度为128位,且必须通过执行arp-nd interface (virtual server view)命令指定发送免费ARP报文或ND报文的接口。否则,无需指定发送免费ARP报文或ND报文的接口。
注意事项
在虚服务器视图下执行vpn-instance命令指定虚服务器所属的VPN实例,对虚服务器下所有未指定VPN实例的虚服务器IP地址都生效;通过本命令指定虚服务器IPv6地址所属的VPN实例,只对当前IPv6地址生效,后者的配置优先级较高。
# 配置IP类型的虚服务器vs3的IPv6地址为1001::1/64。
[Sysname-vs-ip-vs3] virtual ipv6 address 1001::1 64
# 配置IP类型的虚服务器vs1的IPv6地址,其中IPv6地址为1001::1,所属VPN实例为vpn1;IPv6地址为1001::2,所属VPN实例为vpn2。
[Sysname-vs-ip-vs1] virtual ipv6 address 1001::1 vpn-instance vpn1
[Sysname-vs-ip-vs1] virtual ipv6 address 1001::2 vpn-instance vpn2
1.1.322  virtual-server (system view)
virtual-server命令用来创建虚服务器,并进入虚服务器视图。如果指定的虚服务器已经存在,则直接进入虚服务器视图
undo virtual-server命令用来删除指定的虚服务器。
virtual-server virtual-server-name [ type { diameter | fast-http | http | ip | link-ip | mysql | sip-tcp | sip-udp | radius | tcp | udp } ]
undo virtual-server virtual-server-name
不存在任何虚服务器。
context-admin
vsys-admin
virtual-server-name:虚服务器的名称,为1~255个字符的字符串,不区分大小写。
type { diameter | fast-http | http | ip | link-ip | mysql | sip-tcp | sip-udp | radius | tcp | udp }:虚服务器的类型,包括Diameter、快速HTTP、HTTP、IP、LINK-IP、MySQL、RADIUS、基于TCP的SIP、基于UDP的SIP、TCP和UDP。创建虚服务器时必须指定本参数;进入已创建的虚服务器视图时可以不指定本参数,若要指定本参数,则必须与创建时的类型一致。
Diameter、快速HTTP、HTTP、MySQL、RADIUS、SIP、TCP和UDP类型的虚服务器需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
# 创建IP类型的虚服务器vs3,并进入虚服务器视图。
[Sysname-vs-ip-vs3]
1.1.323  vpn-instance (real server view)
vpn-instance命令用来指定实服务器所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
当实服务器所属VPN实例的继承功能处于开启状态时,实服务器所属的VPN实例与虚服务器所属的VPN实例一致;当实服务器所属VPN实例的继承功能处于关闭状态时,实服务器服务于公网。
实服务器视图
context-admin
vpn-instance-name:MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
非缺省vSystem不支持本命令。
# 指定实服务器rs所属的VPN实例为vpn1。
[Sysname-rserver-rs] vpn-instance vpn1
1.1.324  vpn-instance (SNAT address pool view)
vpn-instance命令用来指定SNAT地址池所属VPN实例。
undo vpn-instance
SNAT地址池属于公网。
SNAT地址池视图
context-admin
应用场景
当存在多个地址池地址资源出现重叠时,需要将各个地址池通过VPN实例进行配置隔离,否则在负载均衡设备上会认为配置冲突。
推荐配置
此VPN属性仅用于配置隔离使用。负载均衡设备在使用地址池地址进行转发时,建议将地址池对应的VPN属性与其对应的实服务器的VPN属性配置一致。
注意事项
非缺省vSystem不支持本命令。
# 在SNAT地址池sp1视图下,指定SNAT地址池所属的VPN实例为vpn1。
[Sysname] loadbalance snat-pool spl
[Sysname-lbsnat-pool-sp] vpn-instance vpn1
·     display loadbalance snat-pool
1.1.325  vpn-instance (SNAT global policy view)
vpn-instance命令用来指定SNAT全局策略所属的VPN实例。
undo vpn-instance命令来恢复缺省情况。
undo vpn-instance
SNAT全局策略属于公网。
SNAT全局策略视图
context-admin
vsys-admin
# 在SNAT全局策略sn1视图下,指定SNAT全局策略所属的VPN实例vpn1。
<Sysname>system-view
[Sysname-lb-snat-gp-sn1] vpn-instance vpn1
1.1.326  vpn-instance (virtual server view)
vpn-instance命令用来指定虚服务器所属的VPN。
undo vpn-instance
虚服务器属于公网。
虚服务器视图
context-admin
非缺省vSystem不支持本命令。
管理员可以在配置虚服务器IP地址时,为指定虚服务器IP配置所属的VPN实例;也可以通过本命令对未指定VPN实例的虚服务器IP批量配置所属的VPN实例,前者的优先级较高。
# 指定IP类型的虚服务器vs3所属的VPN为vpn1。
[Sysname-vs-ip-vs3] vpn-instance vpn1
# 出方向链路负载均衡场景下,指定LINK-IP类型的虚服务器vs3所属的VPN为vpn1。
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] vpn-instance vpn1
1.1.327  vrrp vrid (SNAT address pool view)
vrrp vrid命令用来配置SNAT地址池绑定的VRRP备份组。
undo vrrp命令用来删除SNAT地址池绑定的VRRP备份组。
vrrp [ ipv6 ] vrid virtual-router-id interface interface-type interface-number
undo [ ipv6 ] vrrp
SNAT地址池未绑定任何VRRP备份组。
SNAT地址池视图
context-admin
vsys-admin
ipv6:表示IPv6 VRRP备份组,若未配置本参数,则表示IPv4 VRRP备份组。
virtual-router-id:表示VRRP备份组号,取值范围为1~255。
interface interface-type interface-number:备份组号对应的接口类型和接口编号。
应用场景
在双主模式的高可靠性组网中,主管理设备上配置负载均衡功能时,可以通过配置本功能将SNAT地址池与VRRP备份组绑定,以保证该SNAT地址池的流量都上送到此VRRP备份组的Master设备上处理。关于高可靠性的详细介绍,请参见“高可靠性配置指导”中的“双机热备(RBM)”。
工作机制
在双机热备组网中SNAT地址池中的地址在发布ARP或ND报文时,会根据当前配置取合适的MAC地址来发布通告报文和回复ARP或ND请求,优先级从高到低为:
·     SNAT地址池绑定了VRRP备份组时,使用绑定的VRRP备份组的虚拟MAC地址;
·     SNAT地址池对应的虚服务器绑定了VRRP备份组时,使用接口下同组的VRRP备份组的虚拟MAC地址;
·     使用对应的接口的MAC地址。
同一个SNAT地址池最多只能绑定一个VRRP IPv4备份组和一个VRRP IPv6备份组。
# SNAT地址池sp1视图下,绑定编号为1的VRRP备份组。
[Sysname-lbsnat-pool-sp1] vrrp vrid 1 interface gigabitethernet 1/0/1
1.1.328  vrrp vrid (virtual server view)
vrrp vrid命令用来配置虚服务器绑定的VRRP备份组。
undo vrrp命令用来删除虚服务器绑定的VRRP备份组。
vrrp vrid virtual-router-id interface interface-type interface-number
undo vrrp
未绑定任何VRRP备份组。
虚服务器视图
context-admin
应用场景
在HA组网中,在HA的主管理设备上配置服务器负载均衡功能时,需要通过配置本命令,将虚服务器与VRRP备份组绑定,以保证正反向报文在同一台Master设备上处理。关于HA的详细介绍,请参见“高可靠性配置指导”中的“双机热备(RBM)”。
工作机制
对于绑定了不同VRRP备份组的多个虚服务器,不允许引用同一个SNAT地址池。
同一个虚服务器最多只能绑定一个VRRP IPv4备份组和一个VRRP IPv6备份组。VRRP IPv4备份组仅对IPv4类型的虚服务器地址生效,VRRP IPv6备份组仅对IPv6类型的虚服务器地址生效。
注意事项
非缺省vSystem不支持本命令。
# 在TCP类型的虚服务器视图下,绑定编号为1的VRRP备份组。
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] vrrp vrid 1 interface gigabitethernet 1/0/1
·     virtual-server
·     vrrp vrid(高可靠性命令参考/双机热备(RBM))
1.1.329  weight (real server view)
weight命令用来配置实服务器的权值。
undo weight命令用来恢复缺省情况。
weight weight-value
undo weight
实服务器的权值为100。
实服务器视图
context-admin
vsys-admin
weight-value:权值,取值范围为1~255。
通过本命令可以调整实服务器的调度算法所使用的权值,该数值越大,对应的实服务器越被优先调用。
# 配置实服务器rs的权值为150。
[Sysname-rserver-rs] weight 150
1.1.330  weight (server farm member view)
weight命令用来配置实服务组成员的权值。
weight weight-value
undo weight
实服务组成员的权值为100。
实服务组成员视图
context-admin
vsys-admin
weight-value:实服务组成员的权值,取值范围为1~255。
通过本命令可以调整实服务组成员的调度算法所使用的权值,该数值越大,对应的实服务组成员越被优先调用。
# 配置实服务组成员rs1的权值为150。
[Sysname-sfarm-sf-#member#-rs1-port-80] weight 150
1.1.331  window-size
window-size命令用来配置压缩使用的窗口大小。
undo window-size命令用来恢复缺省情况。
window-size size
undo window-size
压缩窗口大小为16KB。
HTTP压缩类型的参数模板视图
context-admin
vsys-admin
# 创建HTTP压缩类型的参数模板pa1,并指定压缩使用的窗口大小为32KB。
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compression-pa1] window-size 32
1.1.332  zero-window threshold
zero-window threshold命令用来配置零窗口报文的上限阈值。
undo zero-window threshold命令用来恢复缺省情况。
zero-window threshold percentage
undo packet-zero-window
零窗口报文的上限阈值为40%。
TCP zero-window类型的负载均衡探测模板视图
context-admin
vsys-admin
percentage:零窗口报文占报文总数的百分比,取值范围为1~100,单位为百分比。
本命令用来配置在负载均衡探测模板的监控时间内,实服务器发送的零窗口报文占报文总数的最大百分比。
若实服务器发送的零窗口报文达到负载均衡探测模板零窗口报文的上限阈值,则执行由protect-action命令指定的负载均衡探测模板保护动作。
# 在TCP zero-window类型的负载均衡探测模板下,配置零窗口报文的上限阈值为20%。
[Sysname] loadbalance probe-template tcp-zero-window zerotplt
[Sysname-lbpt-tcp-zwnd-zerotplt] zero-window threshold 20
·     protect-action
