22-EVPN命令参考
01-EVPN命令
本章节下载: 01-EVPN命令  (871.33 KB)
01-EVPN命令
1 EVPN
1.1 EVPN配置命令
1.1.1 ac interface
1.1.2 address-family evpn (public instance view)
1.1.3 address-family evpn (VPN instance view)
1.1.4 address-family ipv4 (public instance view)
1.1.5 address-family l2vpn evpn (BGP instance view)
1.1.6 advertise evpn route
1.1.7 advertise l2vpn evpn
1.1.8 advertise l3vpn route
1.1.9 arp mac-learning disable
1.1.10 arp-advertising disable
1.1.11 dci enable
1.1.12 display bgp l2vpn evpn
1.1.13 display bgp l2vpn evpn inlabel
1.1.14 display evpn auto-discovery
1.1.15 display evpn df-election
1.1.16 display evpn es
1.1.17 display evpn instance
1.1.18 display evpn ipv6 auto-discovery
1.1.19 display evpn route arp
1.1.20 display evpn route arp suppression
1.1.21 display evpn route mac
1.1.22 display evpn routing-table
1.1.23 display evpn route xconnect-group
1.1.24 display l2vpn forwarding evpn
1.1.25 display l2vpn forwarding evpn split-horizon
1.1.26 e-tree enable
1.1.27 esi
1.1.28 evpn df-election algorithm (interface view)
1.1.29 evpn df-election algorithm (system view)
1.1.30 evpn df-election preference
1.1.31 evpn df-election preference non-revertive
1.1.32 evpn edge group
1.1.33 evpn encapsulation
1.1.34 evpn frr local (cross-connect group EVPN instance view)
1.1.35 evpn frr local (EVPN instance view/VSI EVPN instance view)
1.1.36 evpn frr remote
1.1.37 evpn irb asymmetric
1.1.38 evpn local-service-id remote-service-id
1.1.39 evpn mpls routing-enable
1.1.40 evpn multihoming advertise disable
1.1.41 evpn multihoming advertise ignore-ethernet-tag
1.1.42 evpn multihoming vpls-frr local
1.1.43 evpn multihoming vpws-frr local
1.1.44 evpn multihoming re-originated mac
1.1.45 evpn multihoming timer df-delay
1.1.46 evpn redundancy-mode
1.1.47 evpn timer ad-delay
1.1.48 evpn timer es-delay
1.1.49 evpn track peer
1.1.50 evpn vpws-frr remote
1.1.51 export route-policy
1.1.52 ignore-ac-state
1.1.53 import evpn mac-ip
1.1.54 import route-policy
1.1.55 ip public-instance
1.1.56 l2vpn ignore-ac-state
1.1.57 l3-vni
1.1.58 mac-advertising disable
1.1.59 mapping vni
1.1.60 nexthop recursive-lookup default-route ignore
1.1.61 peer advertise encap-type mpls
1.1.62 peer advertise original-route
1.1.63 peer re-originated
1.1.64 peer router-mac-local
1.1.65 peer suppress re-originated
1.1.66 policy vpn-target
1.1.67 pw-class
1.1.68 route-distinguisher (EVPN instance view)
1.1.69 route-distinguisher (public instance view)
1.1.70 rr-filter
1.1.71 tracert evpn vsi
1.1.72 tunnel-policy
1.1.73 vpn-route cross multipath
1.1.74 vpn-target
1 EVPN
本特性的支持情况与设备型号有关,请以设备的实际情况为准。
型号
MSR610
不支持
支持
MSR810-LMS、MSR810-LUS
不支持
MSR810-SI、MSR810-LM-SI
不支持
MSR810-LMS-EA、MSR810-LME
支持
MSR1004S-5G、MSR1004S-5G-CN
支持
支持
支持
MSR2600-10-X1
支持
MSR2630-G-X1
支持
MSR2630
支持
MSR3600-28、MSR3600-51
支持
MSR3600-28-SI、MSR3600-51-SI
不支持
支持
支持
支持
支持
MSR-iMC
支持
支持
MSR3610、MSR3620、MSR3620-DP、MSR3640、MSR3660
支持
MSR3610-G、MSR3620-G
支持
MSR3640-G
支持
MSR3640-X1-HI
支持
型号
支持
MSR830-4LM-WiNet
支持
支持
支持
MSR2600-6-WiNet
支持
MSR2600-10-X1-WiNet
支持
MSR2630-WiNet
不支持
MSR3600-28-WiNet
不支持
MSR3610-X1-WiNet
支持
MSR3620-X1-WiNet
支持
支持
型号
MSR860-6EI-XS
支持
MSR860-6HI-XS
支持
MSR2630-XS
支持
MSR3600-28-XS
支持
MSR3610-XS
支持
MSR3620-XS
支持
MSR3610-I-XS
支持
MSR3610-IE-XS
支持
MSR3620-X1-XS
支持
MSR3640-XS
支持
MSR3660-XS
支持
型号
MSR810-LM-GL
支持
MSR810-W-LM-GL
支持
MSR830-6EI-GL
支持
MSR830-10EI-GL
支持
MSR830-6HI-GL
支持
MSR830-10HI-GL
支持
MSR1004S-5G-GL
支持
MSR2600-6-X1-GL
支持
MSR3600-28-SI-GL
不支持
1.1  EVPN配置命令
1.1.1  ac interface
ac interface命令用来指定交叉连接关联的接口。
undo ac interface命令用来取消接口与交叉连接的关联。
ac interface interface-type interface-number [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo ac interface interface-type interface-number
交叉连接未关联接口。
交叉连接视图
access-mode:指定接入模式。
·     当AC为三层接口或三层子接口时,缺省接入模式如下:
¡     对于VLAN接口,缺省接入模式为VLAN;对于其他三层接口,缺省接入模式为Ethernet。
¡     对于三层子接口,缺省接入模式为VLAN。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
track track-entry-number&<1-3>:配置AC(三层接口)与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在交叉连接视图/自动发现交叉连接视图下执行本命令后,从关联接口接收到的所有报文,将通过与该交叉连接关联的PW或另一条AC转发。
接入模式是PE对从CE收到的以太网帧携带的外层VLAN Tag的理解方式,以及PE向CE发送以太网帧的方式。接入模式分为两种:
·     VLAN接入模式:CE发送给PE的以太网帧头需要带有一个VLAN Tag,该Tag被称为P-Tag,即服务提供商网络为了区分用户而添加的“服务定界符”。PE发送以太网帧给CE时,也需要携带P-Tag。
·     Ethernet接入模式:CE发送给PE的以太网帧头中如果带有VLAN Tag,则该Tag被称为U-Tag,即用户网络的内部VLAN Tag,对于PE设备没有意义。PE发送以太网帧给CE时,不需要携带P-Tag。
# 在交叉连接组vpna的交叉连接aaa中关联接口GigabitEthernet1/0/1,使该接口接收到的所有报文都通过与该交叉连接关联的PW或另一条AC转发。
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] connection aaa
[Sysname-xcg-vpna-aaa] ac interface gigabitethernet 1/0/1
·     connection(MPLS命令参考/MPLS L2VPN)
·     display l2vpn interface(MPLS命令参考/MPLS L2VPN)
·     display l2vpn service-instance(MPLS命令参考/MPLS L2VPN)
·     pw-type(MPLS命令参考/MPLS L2VPN)
address-family evpn命令用来进入公网实例EVPN视图。
undo address-family evpn命令用来删除公网实例EVPN视图下的所有配置。
address-family evpn
公网实例视图
在公网实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入公网实例EVPN视图。
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
address-family evpn命令用来进入VPN实例EVPN视图。
undo address-family evpn命令用来删除VPN实例EVPN视图下的所有配置。
address-family evpn
VPN实例视图
在VPN实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入VPN实例EVPN视图。
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
address-family ipv4命令用来进入公网实例IPv4地址族视图。
undo address-family ipv4命令用来删除公网实例IPv4地址族视图下的所有配置。
address-family ipv4
公网实例视图
# 进入公网实例IPv4地址族视图。
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn命令用来创建BGP EVPN地址族,并进入BGP EVPN地址族视图。如果BGP EVPN地址族已经存在,直接进入BGP EVPN地址族视图。
undo address-family l2vpn evpn命令用来删除BGP EVPN地址族,及相应地址族视图下的所有配置。
不存在BGP EVPN地址族。
BGP实例视图
BGP EVPN地址族视图下的配置,只对公网BGP EVPN地址族的路由和对等体生效。
# 创建BGP EVPN地址族,并进入BGP EVPN地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise evpn route命令用来配置允许BGP EVPN路由通过VPNv4地址族发布给邻居。
undo advertise evpn route命令用来禁止BGP EVPN路由通过VPNv4地址族发布给邻居。
advertise evpn route [ replace-rt ] [ replace-sid ] [ advertise-policy policy-name ]
BGP EVPN路由不会通过VPNv4地址族向外发送。
BGP VPNv4地址族视图
replace-rt:指定将BGP EVPN路由的RT修改为VPNv4路由的RT。如果不指定本参数,则不修改BGP EVPN路由的RT。
replace-sid:删除原始BGP EVPN路由携带的SRv6 SID,并在与BGP EVPN路由RT匹配的VPN实例中为生成的BGP VPNv4/VPNv6路由重新申请SRv6 SID。如果不指定本参数,则生成的BGP VPNv4/VPNv6路由仍携带BGP EVPN路由的SRv6 SID。
advertise-policy policy-name:指定仅将通过路由策略过滤的BGP EVPN路由发布给VPNv4邻居。policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则所有BGP EVPN路由都可以发布给VPNv4邻居。
不同的数据中心之间通过MPLS L3VPN网络互联时,需要在ED上配置BGP EVPN和BGP VPNv4路由相互引入以实现数据中心之间的互通。
在EVPN L3VPN over SRv6网络与IP L3VPN over SRv6网络互通场景中,需要配置本命令并指定replace-sid参数,才能实现站点的私网路由信息穿越两个网络到达对端站点。
执行本命令后,设备会将EVPN的IP前缀路由、携带主机路由信息的MAC/IP发布路由通过VPNv4地址族发布给邻居。
# 配置允许BGP EVPN路由通过VPNv4地址族发布给邻居。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] advertise evpn route
advertise l2vpn evpn命令用来配置允许对外发布 BGP EVPN路由。
undo advertise l2vpn evpn命令用来禁止对外发布 BGP EVPN路由。
允许对外发布BGP EVPN路由。
BGP-VPN IPv4单播地址族视图
配置允许对外发布 BGP EVPN路由后,设备接收到BGP EVPN路由,并将其添加到某个VPN实例路由表后,会将该路由(私网路由)发布到本地站点。
# 配置允许BGP VPN实例vpn1对外发布BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
advertise l3vpn route命令用来配置允许BGP VPNv4路由通过EVPN地址族发布给邻居。
undo advertise l3vpn route命令用来禁止BGP VPNv4路由通过EVPN地址族发布给邻居。
advertise l3vpn route [ replace-rt ] [ replace-sid ] [ advertise-policy policy-name ]
BGP VPNv4路由不会通过EVPN地址族向外发送。
BGP EVPN地址族视图
replace-rt:指定将BGP VPNv4路由的RT修改为EVPN路由的RT。如果不指定本参数,则不修改BGP VPNv4路由的RT。
replace-sid:删除原始BGP VPNv4/VPNv6路由携带的SRv6 SID,并在与BGP VPNv4/VPNv6路由RT匹配的VPN实例中为生成的BGP EVPN路由重新申请SRv6 SID。如果不指定本参数,则生成的BGP EVPN路由仍携带BGP VPNv4/VPNv6路由的SRv6 SID。
advertise-policy policy-name:指定仅将通过路由策略过滤的BGP VPNv4路由发布给BGP EVPN邻居。policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则所有BGP VPNv4路由均可以发布给BGP EVPN邻居。
执行本命令后,BGP VPNv4路由将作为EVPN的IP前缀路由发布给邻居。
# 配置允许BGP VPNv4路由通过EVPN地址族发布给邻居。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] advertise l3vpn route
arp mac-learning disable命令用来配置禁止EVPN从ARP信息中学习MAC地址表项。
undo arp mac-learning disable命令用来恢复缺省情况。
EVPN可以从ARP信息中学习MAC地址表项。
VSI实例下的EVPN实例视图
VTEP可能会同时接收到远端VTEP通告的MAC地址信息和ARP信息。其中,ARP信息中包含MAC地址信息。为了避免重复,可以在VTEP上执行本命令禁止EVPN从ARP信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ARP信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp-advertising disable命令用来配置禁止通告ARP信息,并撤销已经通告的ARP信息。
undo arp-advertising disable命令用来恢复缺省情况。
允许通告ARP信息。
VSI实例下的EVPN实例视图
在EVPN分布式网关组网中,如果同一个VXLAN内的所有用户终端都部署在同一台EVPN网关下,则EVPN不需要通告该VXLAN的ARP信息(同时携带MAC和IP地址的MAC/IP发布路由),只需通告IP前缀路由,其他VXLAN内的用户终端通过IP前缀路由即可访问该VXLAN。此时,可以配置本命令禁止EVPN通告ARP信息,以减少占用的设备和网络资源。执行本命令后,设备还会撤销已经发布的ARP信息。
# 配置EVPN实例禁止通告ARP信息,并撤销已经通告的ARP信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
1.1.11  dci enable
dci enable命令用来在接口上开启DCI功能。
undo dci enable命令用来关闭接口的DCI功能。
dci enable
undo dci enable
接口上DCI功能处于关闭状态。
EVPN数据中心互联组网中,需要在ED间互连的三层接口上开启DCI功能。
# 在接口GigabitEthernet1/0/1上开启DCI功能。
[Sysname-GigabitEthernet1/0/1] dci enable
display bgp l2vpn evpn命令用来显示BGP EVPN路由信息。
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | route-distinguisher route-distinguisher [ route-type { auto-discovery | es | imet | ip-prefix | mac-ip } ] [ { evpn-route route-length | evpn-prefix } [ advertise-info ] ] | route-type { auto-discovery | es | imet | ip-prefix | mac-ip } | statistics ]
peer { ipv4-address | ipv6-address }:显示向指定对等体发布或者从指定对等体收到的BGP EVPN路由。ipv4-address表示对等体的IPv4地址;ipv6-address为对等体的IPv6地址。
advertised-routes:显示向指定对等体发布的BGP EVPN路由信息。
received-routes:显示从指定对等体接收到的BGP EVPN路由信息。
statistics:显示BGP EVPN路由的统计信息。
route-distinguisher route-distinguisher:显示指定路由标识符的BGP EVPN路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
route-type:显示指定类型的BGP EVPN路由。
auto-discovery:显示以太网自动发现路由(Ethernet auto-discovery route)。
es:显示以太网段路由(Ethernet segment route)。
imet:显示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)。
ip-prefix:显示IP前缀路由(IP prefix advertisement route)。
mac-ip:显示MAC/IP发布路由(MAC/IP advertisement route)。
evpn-route:显示指定BGP EVPN路由的详细信息。evpn-route表示EVPN路由信息,为1~512个字符的字符串,不区分大小写。
route-length:BGP EVPN路由信息的长度,取值范围为0~65535,单位为比特。
evpn-prefix:显示指定BGP EVPN路由的详细信息。evpn-prefix包含EVPN路由信息和路由信息长度,组成格式为evpn-route/route-length,为1~512个字符的字符串,不区分大小写。
advertise-info:显示BGP EVPN路由的通告信息。
如果未指定任何参数,则显示所有BGP EVPN路由的简要信息。
# 显示所有BGP EVPN路由的简要信息。
<Sysname> display bgp l2vpn evpn
 BGP local router ID is 8.8.8.8
               a – additional-path
 Total number of routes from all PEs: 3
 Route distinguisher: 1:1
 Total number of routes: 2
* >i [2][0][48][7010-0000-0001][0][0.0.0.0]/104
                        7.7.7.7         0          100        0       i
*  i                    7.7.7.7         0          100        0       i
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011-0022-0033][32][11.22.33.55]/136
                        30.30.1.2       0                     0       100i
表1-1 display bgp l2vpn evpn命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - stale:过期路由
·     a – additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? - incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
来自所有PE设备且符合命令行过滤条件的BGP EVPN路由总数
Route distinguisher
路由标识符
公网实例的路由标识符
路由标识符为指定值的BGP EVPN路由总数
Network
BGP EVPN路由/路由长度,例如,Network取值为[2][0][48][1485-247c-0506][32][10.1.2.20]/136时,[2][0][48][1485-247c-0506][32][10.1.2.20]为BGP EVPN路由,136表示该路由的长度为136比特
BGP EVPN路由取值包括:
·     [1][ESI][EthernetTagID]:
¡     1:表示以太网自动发现路由(Ethernet auto-discovery route)
¡     ESI:以太网段标识
¡     EthernetTagID:以太网标签
·     [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress]
¡     2:表示MAC/IP发布路由(MAC/IP advertisement route)
¡     MACLength:MAC地址长度
¡     MAC:MAC地址
¡     IPAddressLength:IP地址长度
¡     IPAddress:IP地址
·     [3][EthernetTagID][IPAddressLength][IPAddress]
¡     3:表示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)
¡     IPAddress:始发路由器的IP地址
·     [4][ESI][IPAddressLength][IPAddress]
¡     4:表示以太网段路由(Ethernet segment route)
¡     ESI:以太网段标识
·     [5][EthernetTagID][IPAddressLength][IPAddress]
¡     5:表示IP前缀路由(IP prefix advertisement route)
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[1][00:00:00:00:00:00:00:00:00:00][5]/120的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][00:00:00:00:00:00:00:00:00:00][5] 120
 BGP local router ID: 172.16.250.133
 Local AS number: 100
 Route distinguisher: 1.1.1.1:100
 Paths:   1 available, 1 best
 BGP routing table information of [1][00:00:00:00:00:00:00:00:00:00][5]/120:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 10.1.1.2
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
                   Label 1>, <EVPN DF Election: Alg Preference, Cap DP, Preference 123>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet auto-discovery route
 ESI             : 00:00:00:00:00:00:00:00:00:00
 Ethernet tag ID : 5
 MPLS label      : 10
表1-2 display bgp l2vpn evpn命令中Ethernet auto-discovery route详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
From
发布该路由的BGP对等体的IP地址
Rely nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Encapsulation Type:封装类型
·     ESI Label:ESI标签
·     EVPN DF Election:DF选举属性
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     localredist:从本地其他VPN实例引入到当前VPN实例的路由
·     bgp-rib-only:表示该路由禁止下发到IP路由表
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
路由的Qos-Local-ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
EVPN route type
BGP EVPN路由类型,取值为Ethernet auto-discovery route,表示以太网自动发现路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MPLS label
MPLS标签,目前此字段无意义
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[2][5][48][0001-0203-0405][32][4.5.5.5]/136的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
 BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
                   >, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
                   >, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 State           : valid, external, best, bgp-rib-only
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : MAC/IP advertisement route
 Ethernet tag ID : 5
 MAC address     : 0001-0203-0405
 IP address      : 5.5.5.5/32
 MPLS label1     : 10
 MPLS label2     : 0
表1-3 display bgp l2vpn evpn命令中MAC/IP advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Router's Mac:路由器MAC
·     MAC Mobility:MAC迁移属性。Flags表示是否为固定MAC地址,1为固定不可移动MAC,0为可以移动MAC;SeqNum用来标识最新的一次迁移
·     Default GateWay:默认网关路由
EVPN route type
BGP EVPN路由类型,取值为MAC/IP advertisement route,表示MAC/IP发布路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MAC address
MAC地址
IP address
IP地址
MPLS label1
用于二层转发的VXLAN ID
MPLS label2
用于三层转发的VXLAN ID,即L3VNI
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[3][0][32][5.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
 BGP routing table information of [3][0][32][4.5.5.5]/80:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>
 PMSI tunnel     : Flag 0, TunnelType 6, Label 10, EndPointAddress 10.1.1.2
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0,pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Inclusive multicast Ethernet tag route
 Ethernet tag ID : 0
 Origin address  : 5.5.5.5/32
表1-4 display bgp l2vpn evpn命令中Inclusive multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
PMSI tunnel
运营商组播服务接口的隧道信息,包括:
·     Flag:标志位,目前取值只能为0
·     TunnelType:隧道类型,目前取值只能为6,表示头端复制隧道
·     Label:VXLAN ID
·     EndPointAddress:隧道目的端地址
EVPN route type
BGP EVPN路由类型,取值为Inclusive multicast Ethernet tag route,表示包含性组播以太网标签路由
Ethernet tag ID
以太网标签
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5]/128的详细信息。
<Sysname>  display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5] 128
 BGP routing table information of [4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5]/128:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet segment route
 Origin address  : 4.5.5.5/32
表1-5 display bgp l2vpn evpn命令中Ethernet segment route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ES-Import RT:ES-Import Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Ethernet segment route,表示以太网段路由
ESI
以太网段标识
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[5][10][32][4.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
 BGP routing table information of [5][10][32][4.5.5.5]/80:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
                   0006-0708-0910>, <Priority-Color: (1:10:10)>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 Ethernet tag ID : 10
 IP address      : 4.5.5.5/32
 Gateway address : 0.0.0.0
 MPLS Label      : 1
表1-6 display bgp l2vpn evpn命令中IP prefix advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Priority-Color:Priority-Color扩展团体属性
EVPN route type
BGP EVPN路由类型,取值为IP prefix advertisement route,表示IP前缀路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
IP address
IP网络前缀
Gateway address
网关地址
MPLS Label
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5]/128的通告信息。
<Sysname> display bgp l2vpn  evpn  route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:00] [32][4.5.5.5] 128 advertise-info
 Paths:   1 best
    10.2.1.2
表1-7 display bgp l2vpn evpn advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
到达指定目的网络的优选路由数目
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:00] [32] [4.5.5.5]/128
BGP EVPN路由[4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5]/128的通告信息
该路由已经向哪些BGP EVPN对等体发送,以及对等体的数目
display bgp l2vpn evpn inlabel命令用来显示BGP EVPN的IP前缀路由的入标签信息。
display bgp [ instance instance-name ] l2vpn evpn inlabel
可通过本命令显示本地PE为EVPN的IP前缀路由分配的私网标签。
# 显示BGP EVPN IP前缀路由的入标签信息。
<Sysname> display bgp l2vpn evpn inlabel
               a - additional-path
       Origin: i - IGP, e - EGP, ? – incomplete
 Total number of routes from all PEs: 1
 Route distinguisher: 100:2
     Network            NextHop         OutLabel        InLabel
* >e [5][0][24][192.168.1.0]/80
                        192.168.1.10    NULL            1151
表1-8 display bgp l2vpn evpn inlabel命令显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     S - Stale:过期路由
·     i - internal:内部路由
·     e - external:外部路由
·     a - additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
Route distinguisher
路由标识符
公网实例的路由标识符
Network
BGP EVPN路由/路由长度,BGP EVPN路由取值为[5][EthernetTagID][IPAddressLength][IPAddress]
·     5:表示IP前缀路由(IP prefix advertisement route)
·     EthernetTagID:以太网标签
·     IPAddressLength:IP地址长度
·     IPAddress:始发路由器的IP地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为EVPN路由分配的私网标签,取值为NULL表示空标签
InLabel
入标签值,即本地PE为EVPN路由分配的私网标签
·     evpn mpls routing-enable
·     peer advertise encap-type mpls
display evpn auto-discovery命令用来显示EVPN通过BGP自动发现的邻居信息。
display evpn auto-discovery { { imet | mac-ip } [ mpls | srv6 | vxlan ] [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的邻居信息。
mac-ip:显示通过MAC/IP发布路由发现的邻居。
mpls:显示EVPN VPLS组网中通过BGP自动发现的邻居信息。
srv6:显示EVPN VPLS over SRv6组网中通过BGP自动发现的邻居信息。
vxlan:显示EVPN VXLAN组网中通过BGP自动发现的邻居信息。
peer ip-address:显示指定邻居的自动发现相关信息。ip-address为邻居的IP地址。如果未指定本参数,则显示自动发现的所有邻居的信息。
vsi vsi-name:显示指定VSI内自动发现的邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的邻居信息。
macip-prefix:显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。如果未指定本参数,则显示从所有路由下一跳学习到的邻居信息。
count:显示自动发现的邻居数目。如果未指定本参数,则显示邻居的具体信息。
如果执行本命令时,没有指定mpls、vxlan和srv6参数,则同时显示EVPN VPLS组网、EVPN VPLS over SRv6组网和EVPN VXLAN组网中的信息。
# EVPN VXLAN组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet vxlan
Total number of automatically discovered peers: 2
VSI name: vpna
RD                    PE_address      Tunnel_address  Tunnel mode VXLAN ID
1:10                  2.2.2.2         2.2.2.2         VXLAN       10
2:100                 3.3.3.3         3.3.3.3         VXLAN       10
# EVPN VPLS组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet mpls
Total number of automatically discovered peers: 1
VSI name: vpna
RD                    PE_address      In/Out label    Tunnel mode
1:1                   1.1.1.1         1151/1151       PW
# EVPN VPLS over SRv6组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet srv6
VSI name: vpnc
RD         : 1:1                 Tunnel mode      :  SRv6
PE_address : 1::1
In SID     : 100::10::0
Out SID    : 200::20::0
表1-9 display evpn auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
RD
路由标识符
PE_address
远端VTEP在VSI内的标识
Tunnel_address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     VXLAN-DCI:表示VXLAN数据中心互联隧道
·     PW:表示PW
·     SRv6:表示SRv6隧道
VXLAN ID
VXLAN编号
In SID
入SID
Out SID
出SID
# EVPN VXLAN组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip vxlan
VSI name: vpna
Destination IP  Source IP       VXLAN ID    Tunnel mode     Tunnel name
6.6.6.6         1.1.1.9         100         VXLAN           Tunnel1
# EVPN VPLS组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip mpls
VSI name: vpnb
Destination IP  In/Out label    Tunnel Mode
7.7.7.7         1420/1419       PW
<Sysname> display evpn auto-discovery mac-ip srv6
VSI name: vpnb
Destination IP : 1::1
In SID         : 100::10::0
表1-10 display evpn auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
VXLAN隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     PW:表示PW
·     SRv6:表示SRv6隧道
Tunnel name
隧道名称
In/Out label
PW的入标签和出标签,当标签无效时显示为“-”
In SID
入SID
Out SID
出SID
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
<Sysname> display evpn auto-discovery macip-prefix
Destination IP  Source IP       L3VNI           Tunnel mode Outgoing interface
1.1.1.1         3.3.3.3         200             VXLAN       Vsi-interface3
2.2.2.2         3.3.3.3         200             VXLAN       Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居总数。
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
表1-11 display evpn auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
Outgoing interface
出接口,即与L3VNI关联的VSI虚接口
邻接表项的总数
display evpn df-election命令用来显示DF选举的信息。
display evpn df-election [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ]
vsi vsi-name:显示指定VSI的DF选举信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组的DF选举信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
esi esi-id:显示指定ESI的DF选举信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示所有ESI的DF选举信息。
执行本命令时,如果未指定vsi vsi-name和xconnect-group group-name参数,则显示所有VSI和交叉连接组的DF选举信息。
# 显示所有VSI和交叉连接组的DF选举信息。
<Sysname> display evpn df-election
VSI name: 1
  ESI : 0021.1001.1001.1001.1002
  Interface : GigabitEthernet1/0/1
  Service instance ID : 1000
  Link ID             : 1
  Ethernet tag ID     : 12
  DF state            : DF
  FSM                 : DF_DONE
  Number of member devices : 2
    Originating IP   DF state   Algorithm   Preference Capability
    100.100.100.100  DF         Preference  65535      DP
    100.100.100.200  BDF        Preference  200        DP
  ESI : 0002.0002.0002.0002.0002
  Interface : GigabitEthernet1/0/2
  Link ID             : 0
  Ethernet tag ID     : -
  DF state            : -
  FSM                 : DF_CALC
    1.1.1.1          -          Preference  32767      -
    2.2.2.2          -          Preference  32767      -
Xconnect-group name : 1
 Connection name : 1
  ESI : 0001.0001.0001.0001.0001
  Interface : GigabitEthernet1/0/3
  Link ID             : 1
  Ethernet tag ID     : -
  DF state            : -
  FSM                 : DF_CALC
  Number of member devices : 1
表1-12 display evpn df-election命令显示信息描述表
VSI name
VSI名称
ESI
ES标识符
接口名称
Service instance ID
以太网服务实例的ID
Link ID
AC在VSI内的链路标识符
Ethernet tag ID
以太网标签
DF state
当前设备的DF(Designated Forwarder)选举结果,取值包括:
·     BDF:选举设备作为BDF(Backup DF)角色
·     DF:选举设备作为DF角色
·     -:未选举出结果
FSM
DF选举状态机的状态,取值包括:
·     INIT:初始化状态
·     DF_WAIT:DF选举等待状态,即在启动DF选举定时器后,定时器超时前的状态
·     DF_CALC:正在进行DF选举
·     DF_DONE:DF选举完成状态
参与DF选举的成员设备的数目
Originating IP
参与DF选举的成员设备的IP地址
DF state
Originating IP所代表的设备的DF选举结果,取值包括:
·     DF:选举设备作为DF角色
·     -:未选举出结果
Algorithm
DF选举使用的算法,取值包括:
·     modulus:基于VALN Tag的DF选举算法
·     Preference:基于优先级的DF选举算法
Preference
DF选举优先级
Capability
支持的DF选举能力,取值包括:
·     DP:表示DF选举不回切能力
·     -:表示不支持任何DF选举能力
display evpn es命令用来显示EVPN的ES信息。
display evpn es { local [ count | [ vsi vsi-name  | xconnect-group group-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name  | xconnect-group group-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
local:显示本地多归属成员ES信息。
count:显示本地多归属成员ES的数目。
vsi vsi-name:显示指定VSI的ES信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ES信息。
xconnect-group group-name:显示指定交叉连接组内EVPN的本地ES信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组内EVPN的本地ES信息。
esi esi-id:显示指定ESI的ES信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示VSI的所有ES信息。
verbose:显示ES的详细信息。如果不指定本参数,则显示ES的简要信息。
remote:显示远端多归属成员ES信息。
nexthop next-hop:显示从指定路由下一跳接收到的ES信息。next-hop为路由下一跳的IPv地址或IPv6地址。如果不指定本参数,则显示从所有路由下一跳收到的ES信息。
# 显示本地ES的数目。
<Sysname> display evpn es local count
 Total number of ES entries: 1
# EVPN VPLS组网中显示VSI实例vpna的本地ES简要信息。
<Sysname> display evpn es local vsi vpna
Redundacy mode: A – All-active, S – Single-active
VSI name : vpna
EVPN instance: -
ESI                         Tag ID      DF address      Mode  State ESI label
0001.0002.0002.0002.0002    -           1.1.1.1         A     Up    1000
0001.0002.0003.0004.0005    -           1.1.1.1         A     Up    1001
0003.0003.0003.0003.0003    2           2.2.2.2         A     Up    1002
# EVPN VPLS over SRv6组网中显示VSI实例vpna的本地ES简要信息。
VSI name : vpna
EVPN instance: -
 Tag ID     : -
 DF address : 1.1.1.1
 Mode       : A
 State      : Down
 Argument   : ::1
# EVPN VPWS组网中显示交叉连接组vpna的本地ES简要信息。
<Sysname> display evpn es local xconnect-group vpna
Redundancy mode: A – All-active, S – Single-active
Xconnect group name: vpna
0001.0002.0002.0002.0002    -           1.1.1.1         A     Up    -
0001.0002.0003.0004.0005    -           1.1.1.1         A     Up    -
0003.0003.0003.0003.0003    2           2.2.2.2         A     Up    -
# EVPN VPWS over SRv6组网中显示交叉连接组vpna的本地ES简要信息。
Xconnect-group name : vpna
 Tag ID     : -
 Mode       : A
 State      : Up
 Argument   : -
表1-13 display evpn es local命令显示信息描述表
VSI name
VSI名称
EVPN instance
EVPN实例名称。显示为“-”时,表示VSI实例下创建的EVPN实例
Xconnect group name
交叉连接组名称
ESI
ES标识符
Tag ID
以太网标签ID
DF address
被选为DF的VTEP或PE的Router ID
Mode
ES的冗余备份模式,取值包括:
·     A:表示ES的冗余备份模式为all-active模式
·     S:表示ES的冗余备份模式为single-active模式
当前ES的状态,取值包括Up和Down
ESI label
ESI标签;在EVPN VPWS和EVPN VXLAN组网中ESI label无效,显示为“-”
Argument
标识Leaf AC的Argument值,在EVPN VPLS over SRv6的E-Tree组网中用于实现Leaf AC间的流量隔离
当无Argument时显示为“-”
# 显示所有VSI内本地ES的详细信息。
<Sysname> display evpn es local verbose
VSI name : v1
EVPN instance: -
  ESI                      : 0003.0003.0003.0003.0003
  Redundancy mode          : All-active
  State                    : Up
  AD-delay remaining time  : 10
  ACs                      :
    Link ID     Service instance ID   Tag ID      DF address        ESI label
    0           1                     1           1.1.1.1           1001
    1           3                     3           3.3.3.3           1002
    2           10                    10          2.2.2.2           1003
VSI name : v2
EVPN instance: -
  ESI                      : 0004.0004.0004.0004.0004
  Interface                : -
  State                    : Up
  UPWs                     :
    Link ID     Tag ID      DF address        ESI label
    0           1           1.1.1.1           1004
VSI name : vpna
EVPN instance: -
  ESI                      : 0001.0002.0002.0002.0002
  State                    : Up
  ACs                      :
    1           -                     -           1.1.1.1           -
VSI name : vpnb
EVPN instance: -
  Interface                : GE1/0/3
  State                    : Down
  ACs                      :
    Link ID                : 0
    Service instance ID    : -
    Tag ID                 : -
    Argument               : ::1
Xconnect group name : vpna
 Connection name           : aa
  AC                       : GE1/0/5 srv1
  State                    : Up
  Link ID                  : 0
  Tag ID                   : 10
Xconnect group name : vpnd
 Connection name           : dd
  ESI                      : 0006.0006.0006.0006.0006
  State                    : Up
  UPW Link ID              : 0
  Tag ID                   : 10
表1-14 display evpn es local verbose命令显示信息描述表
VSI name
VSI名称
EVPN instance
Xconnect group name
交叉连接组名称
Connection name
交叉连接名称
ESI
ES标识符
接口名称
AC
与交叉连接关联的接入电路,取值为:
·     三层接口名称:表示交叉连接关联三层接口
Redundancy mode
ES的冗余备份模式,取值包括:
当前ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI
以太网自动发现路由延迟发布定时器的剩余时间,单位为秒
ACs
VSI在当前ES下的AC列表
UPWs
VSI在当前ES下的UPW列表
Link ID
AC在VSI内的链路ID
Service instance ID
以太网服务实例ID
Tag ID
以太网标签ID
DF address
被选为DF的VTEP或PE的Router ID,取值为“-”表示当前设备未被选举为该AC的DF
ESI label
Argument
当无Argument时显示为“-”
UPW link ID
UPW在VSI内的链路标识符
# 显示远端ES的简要信息。
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : vpna
EVPN instance: -
  ESI                     : 0001.0000.0000.0000.0001
  Ethernet segment routes :
    1.1.1.1
    3.3.3.3
  A-D per ES routes       :
    Peer IP             Remote Redundancy mode
    1.1.1.1             All-active
    3.3.3.3             All-active
  A-D per EVI routes      :
    Tag ID      Peer IP
    -           1.1.1.1
    -           3.3.3.3
  ESI                     : 0001.0002.0003.0004.0005
    1.1.1.1
  A-D per ES routes       :
    1.1.1.1             All-active
    Tag ID      Peer IP
    -           1.1.1.1
Xconnect group name : a
    123.123.123.123
    3.3.3.3
  A-D per ES routes       :
    123.123.123.123     All-active
    3.3.3.3             All-active
    Tag ID      Peer IP          Control Flags
    2           3.3.3.3          P
    4           123.123.123.123  PC
# 显示远端ES的详细信息。
VSI name : vpna
EVPN instance: -
  A-D per ES routes       :
    Peer IP               : 2::2
    Remote Redundancy mode: All-active
    Argument              : ::1
    Tag ID                : 1
    Peer IP               : 2::2
    2::2
  A-D per ES routes       :
    Peer IP               : 2::2
    Tag ID                : 1
    Control Flags         : P
    Peer IP               : 2::2
# 显示VSI实例vpna内,从下一跳3.3.3.3接收到的远端ES的信息。
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
EVPN instance: -
    3.3.3.3
  A-D per ES routes       :
    3.3.3.3
    Tag ID      Peer IP
    -           3.3.3.3
表1-15 display evpn es remote命令显示信息描述表
VSI name
VSI名称
EVPN instance
Xconnect group name
交叉连接组名称
ESI
ES标识符
Redundancy mode
ES的冗余备份模式,取值包括:
·     All-active:表示ES的冗余备份模式为多活模式
·     Single-active:表示ES的冗余备份模式为单活模式
Argument
当无Argument时显示为“-”
与该ES关联的以太网段路由
A-D per Ethernet segment routes
与该ES关联的A-D per ES路由
A-D per EVI routes
与该ES关联的A-D per EVI路由
Tag ID
以太网标签ID
Peer IP
远端设备的IP地址
远端ES的冗余备份模式,取值包括:
Control Flags
远端路由二层属性控制标识,取值包括:
·     P:接收到的路由携带了Primary标识
·     B:接收到的路由携带了Backup标识
·     C:接收到的路由携带了Control word标识
display evpn instance命令用来显示EVPN实例的相关信息。
display evpn instance [ vsi vsi-name | xconnect-group group-name ] [ verbose ]
vsi vsi-name:显示指定VSI对应EVPN实例的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组对应EVPN实例的信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
verbose:显示EVPN实例的详细信息。如果不指定本参数,则显示EVPN实例的简要信息。
执行本命令时,如果没有指定vsi vsi-name和xconnect-group group-name参数,则显示所有EVPN实例的信息。
# 显示所有EVPN实例的简要信息。
<Sysname> disp evpn instance
Total number of EVPN instances: 4
EVPN name                       EVPN index
a                               0x0
aaa                             0x1
bbb                             0x2
ccc                             0x3
表1-16 display evpn instance命令显示信息描述表
EVPN实例的总数
EVPN name
EVPN实例的名称
EVPN index
EVPN实例的索引值
# 显示所有EVPN实例的信息。
<Sysname> display evpn instance verbose
VSI Name: aaa
  EVPN index             : 0x1
  Encapsulation          : VXLAN
  Route distinguisher    : -
  Export VPN targets     : -
  Import VPN targets     : -
  MAC advertisement      : Enabled
  ARP-based MAC learning : Enabled
  VXLAN ID               : -
VSI Name: bbb
  EVPN index             : 0x2
  Encapsulation          : SRv6
  Dt2u SID               : -
  Dt2ul SID              : -
  Dt2m SID               : -
  Dt2uLocatorName        : -
  Dt2ulLocatorName       : -
  Dt2mLocatorName        : -
  E-Tree                 : Disabled
  Best-Effort            : Disabled
  Traffic-Engineering    : Disabled
  Import Route Policy    : -
  Export Route Policy    : -
VSI Name: vpna
  EVPN index             : 0x0
  Encapsulation          : MPLS
  Route distinguisher    : 1:1
  Export VPN targets     : 1:1
  Import VPN targets     : 1:1
  MPLS label             : 24128
  IMET MPLS label        : 24127
  Tunnel policy          : -
  PW class               : -
  Control Word           : Disabled
  E-Tree                 : Disabled
  PW type                : VLAN
  Sequencing             : -
表1-17 display evpn instance verbose命令显示信息描述表
VSI Name
VSI名称
EVPN index
EVPN实例的索引值
Encapsulation
EVPN的封装类型,取值包括:
·     VXLAN:表示EVPN的封装类型为VXLAN
·     MPLS:表示EVPN的封装类型为MPLS
·     SRv6:表示EVPN的封装类型为SRv6
Route distinguisher
EVPN实例的RD
Export VPN targets
EVPN实例的Export Target
Import VPN targets
EVPN实例的Import Target
MAC advertisement
是否允许通告MAC地址信息,取值包括:
·     Enabled:允许通告MAC地址信息
·     Disabled:禁止通告MAC地址信息
是否允许EVPN从ARP信息中学习MAC地址表项,取值包括:
·     Enabled:允许EVPN从ARP信息中学习MAC地址表项
·     Disabled:禁止EVPN从ARP信息中学习MAC地址表项
MPLS label
MAC/IP发布路由携带的MPLS标签
IMET MPLS label
IMET路由携带的MPLS标签
Tunnel policy
EVPN实例引用的隧道策略
PW class
EVPN实例引用的PW模板
Control word
是否开启控制字功能,取值包括:
·     Enabled:PW开启控制字功能
·     Disabled:PW关闭控制字功能
E-Tree
是否开启EVPN E-Tree功能,取值包括:
·     Enabled:开启EVPN E-Tree功能
·     Disabled:关闭EVPN E-Tree功能
PW type
PW类型,取值包括:
·     Ethernet:以太网类型
·     VLAN:VLAN类型
Sequencing
PW的排序处理,取值包括:
·     Both:表示对PW收发两个方向的报文均进行排序处理
·     -:表示未配置PW的排序处理,即不对PW上传输的报文进行排序
VXLAN ID
VXLAN编号
Flow label
流标签能力,取值包括:
·     Both:具有发送和接收能力
·     Send:具有发送能力
·     Recv:具有接收能力
·     -:未开启流标签能力
Dt2u SID
EVPN VPLS over SRv6组网中,用于转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128
Dt2ul SID
EVPN VPLS over SRv6多归属站点组网中,用于在冗余备份组成员设备间的Bypass隧道上转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128
Dt2m SID
EVPN VPLS over SRv6组网中,用于转发组播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128
Dt2uLocatorName
用于申请DT2U SID的Locator段名称
若禁止动态分配SID,则显示auto-sid-disable;否则,不显示
Dt2ulLocatorName
用于申请DT2UL SID的Locator段名称
Dt2mLocatorName
用于申请DT2M SID的Locator段名称
Best-Effort
是否根据SRv6 SID进行SR-BE路由迭代,取值包括:
·     Enabled:根据SRv6 SID进行SR-BE路由迭代
·     Disabled:不会根据SRv6 SID进行SR-BE路由迭代
Traffic-Engineering
是否根据下一跳地址进行SR-TE路由迭代,取值包括:
·     Enabled:根据下一跳地址进行SR-TE路由迭代
·     Disabled:不会根据下一跳地址进行SR-TE路由迭代
Import routing policy
EVPN实例引用的入方向路由策略,如果未引用入方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段
Export routing policy
EVPN实例引用的出方向路由策略,如果未引用出方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段
·     evpn encapsulation
·     vsi
display evpn ipv6 auto-discovery命令用来显示EVPN通过BGP自动发现的IPv6邻居信息。
display evpn ipv6 auto-discovery { { imet | mac-ip } [ srv6 | vxlan ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的IPv6邻居信息。
mac-ip:显示通过MAC/IP发布路由(MAC/IP Advertisement route)发现的IPv6邻居信息。
srv6:显示EVPN VPLS over SRv6组网中通过BGP自动发现的邻居信息。EVPN VPLS over SRv6组网的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
peer ipv6-address:显示指定IPv6邻居的自动发现相关信息。ipv6-address为邻居的IPv6地址。如果未指定本参数,则显示所有IPv6邻居的自动发现相关信息。
vsi vsi-name:显示指定VSI内自动发现的IPv6邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的IPv6邻居信息。
macip-prefix:显示通过携带L3VNI的MAC/IP发布路由或IP前缀路由发现的IPv6邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。如果未指定本参数,则显示从所有路由下一跳学习到的IPv6邻居信息。
count:显示自动发现的IPv6邻居数目。如果未指定本参数,则显示IPv6邻居的具体信息。
# EVPN VXLAN组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet
VSI name: vpna
EVPN instance  : -
RD             : 1:10
PE address     : 11::8
Tunnel address : 11::8
Tunnel mode    : VXLAN
VXLAN ID       : 10
RD             : 2:100
PE address     : 12::8
Tunnel address : 12::8
Tunnel mode    : VXLAN
VXLAN ID       : 10
# EVPN VPLS over SRv6组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet srv6
VSI name: vpnc
 PE_address  : 3::3
 In SID      : 111::1
 Out SID     : 333::1
表1-18 display evpn ipv6 auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
EVPN实例名称,如果未创建则显示“-”
RD
路由标识符
PE address
远端VTEP在VSI内的标识
Tunnel address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     SRv6:表示SRv6隧道
VXLAN ID
VXLAN编号
In SID
SRv6隧道的入SID
Out SID
SRv6隧道的出SID
# EVPN VXLAN组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip
VSI name: vpna
Destination IP : 6:6::6:8
Source IP      : 1:1::1:7
VXLAN ID       : 100
Tunnel mode    : VXLAN
Tunnel name    : Tunnel1
# EVPN VPLS over SRv6组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip srv6
VSI name: vpnc
Tunnel mode    :  SRv6
In SID         : 100::10::0
表1-19 display evpn ipv6 auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
隧道模式,取值包括:
·     VXLAN,表示VXLAN隧道
·     SRv6:表示SRv6隧道
Tunnel name
隧道名称
In SID
SRv6隧道的入SID
Out SID
SRv6隧道的出SID
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI              : 100
Tunnel mode        : VXLAN
OutInterface       : Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居总数。
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 1
表1-20 display evpn ipv6 auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
OutInterface
邻接表项的总数
display evpn route arp命令用来显示EVPN的ARP信息。
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local:显示本地ARP信息。
remote:显示远端ARP信息。
public-instance:显示公网实例的ARP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP信息。vpn-instance-name表示 MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示ARP表项的数目。如果不指定本参数,则显示ARP表项的具体信息。
执行本命令时,如果没有指定local和remote参数,则显示EVPN的本地和远端ARP信息。
执行本命令时,如果没有指定public-instance和vpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ARP信息。
# 显示所有EVPN的ARP信息。
<Sysname> display evpn route arp
Flags: D - Dynamic   B - BGP   G - Gateway   L - Local active   M - Mapping
VPN instance:vpn1                            Interface:Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  a0ce-7e40-0400  0           GL
10.1.1.11       0001-0001-0001  a0ce-7e40-0400  0           DL
10.1.1.12       0001-0001-0011  a0ce-7e41-0401  0           B
10.1.1.13       0001-0001-0021  a0ce-7e42-0402  0           B
Public instance                              Interface:Vsi-interface2
11.1.1.1        0033-0033-0033  a0ce-7e40-0400  0           GL
11.1.1.11       0011-0011-0011  a0ce-7e40-0400  0           DL
# 显示EVPN的ARP表项总数。
<Sysname> display evpn route arp count
Total number of entries: 6
表1-21 display evpn route arp命令显示信息描述表
VPN instance
VPN实例名称
Public instance
公网实例
VSI虚接口
IP address
IP地址
MAC address
MAC地址
Router MAC
设备的Router MAC
VSI index
VSI索引
Flags
ARP表项类型,取值包括:
·     D:表示动态学习的ARP表项
·     B:表示通过BGP EVPN路由学习的ARP表项
·     G:表示网关的ARP表项
·     L:表示本地ARP表项
·     M:表示来自映射的远端VXLAN的ARP表项
ARP表项的总数
display evpn route arp suppression命令用来显示EVPN的ARP泛洪抑制信息。
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ count ]
local:显示本地ARP泛洪抑制信息。
remote:显示远端ARP泛洪抑制信息。
vsi vsi-name:显示指定VSI的ARP泛洪抑制信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ARP泛洪抑制信息。
count:显示ARP泛洪抑制表项的数目。如果不指定本参数,则显示ARP泛洪抑制表项的具体信息。
执行本命令时,如果没有指定local和remote参数,则显示EVPN的本地和远端的ARP泛洪抑制信息。
# 显示所有EVPN的ARP泛洪抑制信息。
<Sysname> display evpn route arp suppression
VSI name: vpna
IP address      MAC address       Flags
10.1.1.12       0002-0002-0002    B
# 显示EVPN的ARP泛洪抑制表项总数。
<Sysname> display evpn route arp suppression count
表1-22 display evpn route arp suppression命令显示信息描述表
VSI name
VSI名称
IP address
IP地址
MAC address
MAC地址
Flags
ARP泛洪抑制表项类型,取值包括:
·     D:表示动态学习的ARP泛洪抑制表项
·     B:表示通过BGP EVPN路由学习的ARP泛洪抑制表项
·     G:表示网关的ARP泛洪抑制表项
·     L:表示本地ARP泛洪抑制表项
·     M:表示来自映射的远端VXLAN的ARP泛洪抑制表项
ARP泛洪抑制表项的总数
display evpn route mac命令用来显示EVPN的MAC地址信息。
display evpn route mac [ mpls | srv6 | vxlan ] [ local | remote ] [ vsi vsi-name ] [ count ]
mpls:显示EVPN VPLS组网中的MAC地址信息。
srv6:显示EVPN VPLS over SRv6组网中的MAC地址信息。
vxlan:显示EVPN VXLAN组网中的MAC地址信息。
local:显示本地MAC地址信息。
remote:显示远端MAC地址信息。
vsi vsi-name:显示指定VSI的MAC地址信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的MAC地址信息。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址的具体信息。
执行本命令时,如果没有指定mpls、srv6和vxlan参数,则显示所有组网环境下的MAC地址信息;如果没有指定local和remote参数,则显示EVPN的本地和远端MAC地址信息。
# EVPN VXLAN组网中显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac vxlan
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping        I - Invalid
       E - Multihoming ES sync    F - Leaf
VSI name: vpna
 MAC address    : 622a-c56d-0402
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : VXLAN
  Next hop      : -
# EVPN VPLS over SRv6组网中显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac srv6
VSI name: vpnb
EVPN instance: -
 MAC address    : 68ba-0573-0606
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : SRv6
  Next hop      : -
  Color         : -
 MAC address    : 68ba-0b4f-0706
  Link ID/Name  : 0x9000000
  Flags         : B
  Encap         : SRv6
  Next hop      : 2::2
  Color         : -
# 显示EVPN的MAC地址表项数目。
<Sysname> display evpn route mac count
Total number of entries: 5
表1-23 display evpn route mac命令显示信息描述表
VSI name
VSI名称
MAC address
MAC地址
Link ID/Name
Link ID表示路由表项的出链路标识符,即AC或SRv6隧道在VSI内的链路标识符
Name表示VXLAN隧道的Tunnel接口名称
Flags
表项类型,取值包括:
·     D:表示动态学习的MAC地址表项
·     B:表示通过BGP EVPN路由学习的MAC地址表项
·     G:表示网关的MAC地址表项
·     I:表示该MAC地址表项无效,原因如下:
¡     通过shutdown命令手工关闭VSI
¡     出方向Tunnel接口不存在
·     L:表示本地MAC地址表项
·     M:表示来自映射的远端VXLAN的MAC地址表项
·     S:表示生效的MAC地址表项是静态配置的MAC地址表项
·     E:表示多归属成员同步的MAC地址表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的MAC地址表项
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
·     VXLAN:报文封装类型为VXLAN
·     SRv6:报文封装类型为SRv6
Nexthop
远端VTEP的地址,取值为“-”表示本地MAC
Color
MAC地址的Color属性值,如果MAC地址无Color属性,则显示为“-”
MAC地址表项的总数
display evpn routing-table命令用来显示EVPN的路由表信息。
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6:显示EVPN的IPv6路由表信息。如果不指定本参数,则显示EVPN的IPv4路由表信息。
public-instance:显示公网实例的路由信息。
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示路由表项的数目。如果不指定本参数,则显示路由表项的具体信息。
# 显示VPN实例vpn1对应EVPN的IPv4路由信息。
<Sysname> display evpn routing-table vpn-instance vpn1
VPN instance name: vpn1                             Local L3VNI: 7
IP address         Nexthop            Outgoing interface       NibID
10.1.1.11          1.1.1.1            Vsi-interface3           0x18000000
10.1.1.12          2.2.2.2            Vsi-interface3           0x18000001
# 显示公网实例的EVPN IPv4路由信息。
<Sysname> display evpn routing-table public-instance
Public instance                                     Local L3VNI: 3900
# 显示VPN实例vpn1对应的EVPN的IPv4路由表项总数。
<Sysname> display evpn routing-table vpn-instance vpn1 count
# EVPN分布式网关组网中,显示VPN实例vpna对应的EVPN的IPv6路由信息。
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
Flags: E - with valid ESI   A – A-D ready   L - Local ES exists
VPN instance: vpna                              Local L3VNI: 7
IPv6 address        :      BC10:0300:1000:0020:0200:0300:0100:0034
Outgoing interface  :      Vsi-interface3
Next hop            :      1.1.1.1
NibID               :      0x18000000
Flags               :      E
IPv6 address        :      BC10:0300:1000:0020:0200:0300:0100:0035
Next hop            :      2.2.2.2
NibID               :      0x18000001
Flags               :      E
表1-24 display evpn routing-table命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
Local L3VNI
与VPN实例或公网实例关联的L3VNI
IP address
目的IPv4地址
IPv6 address
目的IPv6地址
Nexthop
下一跳地址
Outgoing interface
出接口
NibID
下一跳ID
路由表项的总数
display evpn route xconnect-group命令用来显示交叉连接的EVPN相关信息。
display evpn route xconnect-group [ name group-name [ connection connection-name ] ] [ count ]
name group-name:显示指定交叉连接组的EVPN相关信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组的EVPN相关信息。
connection connection-name:显示交叉连接组内指定交叉连接的EVPN相关信息。交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。如果未指定本参数,则显示指定交叉连接组内所有交叉连接的EVPN相关信息。
count:显示EVPN交叉连接的总数。如果不指定本参数,则显示交叉连接的EVPN的具体信息。
# 显示所有交叉连接的EVPN相关信息。
<Sysname> display evpn route xconnect-group
Ctrl Flags: P - Primary, B - Backup, C - Control word
Xconnect group name: aa
 Connection name: aaa
  Local service ID    : 16777215
  Remote service ID   : 16777214
  Control word        : Enabled
  In label            : 502
  Local MTU           : 1500
  AC state            : Up
  Tunnel policy       : -
  PW class            : -
  PW type             : VLAN
    Nexthop          ESI                       Out label  Flags  MTU    State
    192.123.123.123  0001.0002.0002.0002.0001  1299       PC     1500   Up
    192.1.1.1        0001.0002.0002.0002.0001  1026       B      1500   Down
 Connection name: aab
  ESI                 : 0000.0000.0000.0000.0000
  Remote service ID   : 2
  Control word        : Disabled
  In label            : 323
  Local MTU           : 1500
  AC state            : Up
  Tunnel policy       : -
  PW class            : -
  PW type             : VLAN
    192.1.1.1        0002.0002.0002.0002.0001  1234       P      1500   Up
    192.2.1.2        0002.0002.0002.0002.0001  603        P      1500   Up
 Connection name: aac
  Local service ID    : 3
  Remote service ID   : 4
  In label            : -
  Local MTU           : 1500
  AC state            : Up
  Tunnel policy       : -
  PW class            : -
  PW type             : Ethernet
    192.1.1.3        0000.0000.0000.0000.0000  555        P      1500   Idle
 Connection name: pw1
  In SID[DX2]         : 100::1
  In SID[DX2L]        : -
  Local MTU           : 1500
  AC State            : Up
  Tunnel policy       : -
  PW class            : -
  PW type             : Ethernet
  SRv6 Tunnel:
    Next Hop          : 2::2
    Out SID           : 200::1
    Flags             : P
    MTU               : 1500
    State             : Up
# 显示EVPN交叉连接的总数。
<Sysname> display evpn route xconnect-group count
表1-25 display evpn route xconnect-group命令显示信息描述表
Xconnect group name
交叉连接组名称
Connection name
交叉连接名称
Encapsulation
EVPN的封装类型,取值包括:
ESI
ES标识符
Local service ID
本地服务ID
Remote service ID
远端服务ID
Control word
是否开启控制字功能取值包括:
·     Enabled:PW开启控制字功能
In label
PW的入标签
Local MTU
本地配置的最大传输单元,单位为字节
AC state
当前AC的状态,取值包括Up、Down和“-”。其中,“-”表示未配置AC
Tunnel policy
引用的隧道策略
PW class
引用的PW模板
PW type
PW的数据封装类型,取值包括Ethernet和VLAN
Nexthop
远端PE的地址
Out label
PW的出标签
Flags
PW属性标记,取值包括:
·     P:接收到的路由携带了Primary标识,需要建立主PW
·     B:接收到的路由携带了Backup标识,需要建立备份PW
·     C:接收到的路由中携带控制字标识,表示对端开启控制字功能,若本地使能控制字功能,则使EVPN PW处于UP状态,否则EVPN PW无法UP
MTU
接收到的路由中携带的最大传输单元,单位为字节
EVPN PW的状态,取值包括:
·     Up:表示协议状态Up
·     Down:表示协议状态Down
·     Idle:表示入或出标签不可用
In SID[DX2]
End.DX2类型的入SID
In SID[DX2L]
End.DX2L类型的入SID
SRv6 Tunnel
SRv6隧道信息
Out SID
出SID
EVPN PW和SRv6隧道的总数
display l2vpn forwarding evpn命令用来显示EVPN VPLS/VPWS和EVPN VPLS/VPWS over SRv6的转发信息。
(独立运行模式)
display l2vpn forwarding evpn [ vsi [ name vsi-name ] [ verbose ] ]
display l2vpn forwarding evpn [ vsi [ name vsi-name ] [ verbose ] ] slot slot-number
vsi:显示指定VSI下的EVPN的转发信息。不指定本参数时,显示所有关联EVPN的VSI和交叉连接的转发信息。
name vsi-name:显示指定VSI下的EVPN的转发信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI下的EVPN的信息。
verbose:显示指定VSI下的EVPN的详细信息。如果不指定本参数,则显示VSI下的EVPN的简要信息。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。(IRF模式)
# 显示EVPN VPLS组网中所有EVPN的简要转发信息。(独立运行模式)
<Sysname> display l2vpn forwarding evpn vsi
Total number of VSIs: 2
VSI name                       VSI index
vpls1                          0
# 显示EVPN VPLS组网中slot 1上所有EVPN的简要转发信息。(IRF模式)
<Sysname> display l2vpn forwarding evpn vsi slot 1
VSI name                       VSI index
vpls1                          0
表1-26 display l2vpn forwarding evpn命令显示信息描述表
VSI的总数
VSI name
VSI名称
VSI index
VSI索引
# 显示EVPN VPLS组网中所有EVPN的详细转发信息。(独立运行模式)
<Sysname> display l2vpn forwarding evpn vsi verbose
VSI name: vpls1
  VSI index                         : 0
  MPLS label                        : 1150
  IMET MPLS label                   : 1149
  Control word                      : enabled
  PW type                           : Ethernet
  Sequencing                        : Both
  Flow label                        : Both
# 显示EVPN VPLS组网中slot 1上所有EVPN的详细转发信息。(IRF模式)
<Sysname> display l2vpn forwarding evpn vsi verbose slot 1
VSI name: vpls1
  VSI index                         : 0
  MPLS label                        : 1150
  PW type                           : Ethernet
  Sequencing                        : Both
  Flow label                        : Both
表1-27 display l2vpn forwarding evpn verbose命令显示信息描述表
VSI name
VSI名称
VSI index
VSI索引
Encapsulation
封装类型,取值包括:
·     MPLS:表示MPLS封装
·     SRv6:表示SRv6封装
MPLS label
MAC/IP发布路由携带的MPLS标签
IMET MPLS label
IMET路由携带的MPLS标签
Control word
是否开启控制字功能,取值包括:
·     enabled:PW开启控制字功能
·     disabled:PW关闭控制字功能
PW type
PW类型,取值包括:
·     Ethernet:以太网类型
·     VLAN:VLAN类型
Sequencing
PW的排序处理,取值包括:
Flow label
流标签能力,取值包括:
·     Both:具有发送和接收能力
·     Send:具有发送能力
·     Recv:具有接收能力
·     -:未开启流标签能力
Dt2u SID
用于转发单播报文的SRv6 SID
Dt2ul SID
Dt2m SID
用于转发组播报文的SRv6 SID
·     vsi
display l2vpn forwarding evpn split-horizon命令用来显示EVPN多归属组网中满足水平分割原则的接口信息。
(独立运行模式)
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number | upw vsi vsi-name }
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number | upw vsi vsi-name } [ slot slot-number ]
ac interface interface-type interface-number:显示EVPN VPLS多归属组网中AC接口的水平分割信息,即从指定AC收到的泛洪流量不会转发到哪些AC。interface-type interface-number为三层接口的接口类型和接口编号。
ac interface interface-type interface-number service-instance instance-id:显示EVPN VPLS多归属组网中AC接口的水平分割信息,即从指定AC收到的泛洪流量不会转发到哪些AC。interface-type interface-number为二层接口的接口类型和接口编号;service-instance instance-id为二层接口下配置的以太网服务实例,instance-id为以太网服务实例的编号,取值范围为1~4096。
tunnel tunnel-number:显示EVPN VXLAN组网中VXLAN隧道的水平分割信息,即从指定VXLAN隧道接收到的泛洪流量不会转发到哪些AC。tunnel-number为VXLAN隧道接口的编号。如果未指定本参数,则显示EVPN多归属组网中所有满足水平分割原则的接口信息。
upw vsi vsi-name:显示EVPN VPLS over SRv6/EVPN VPLS组网中用来关联SRv6 PW/EVPN PW的LDP PW或静态PW的水平分割信息,即从指定VSI的LDP PW或静态PW收到的泛洪流量不会转发到哪些SRv6 PW或者EVPN PW。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定Master设备。(IRF模式)
# 显示从Tunnel 0上收到的泛洪流量中满足水平分割原则的接口信息。
<Sysname> display l2vpn forwarding evpn split-horizon tunnel 0
Tunnel name: 0
  Total number of filtered interfaces: 2
  Filtered interfaces:
    GE1/0/1
    GE1/0/2
# EVPN VPLS组网中显示AC接口GigabitEthernet1/0/1的水平分割信息。
<Sysname> display l2vpn forwarding evpn split-horizon ac interface gigabitethernet 1/0/1
Interface name  : GigabitEthernet1/0/1
AC link ID              : 0
PW count                : 2
VSI name        PW link ID         ESI label
vpna            8                  775128
vpna            9                  775128
# EVPN VPLS over SRv6组网中显示AC接口GigabitEthernet1/0/1的水平分割信息。
AC link ID              : 0
SRv6 tunnel count       : 2
VSI name        SRv6 link ID       Argument
vpna            0x8                ::1
vpna            0x9                ::1
# EVPN VPLS组网中显示VSI实例vpna的LDP PW或静态PW水平分割信息。
<Sysname> display l2vpn forwarding evpn split-horizon upw vsi vpna
UPW link ID             : 0
PW count                : 2
VSI name        PW link ID       Argument
vpna            0x8              ::1
vpna            0x9              ::1
# EVPN VPLS over SRv6组网中显示VSI实例vpna的LDP PW或静态PW水平分割信息。
UPW link ID             : 0
vpna            0x8                ::1
vpna            0x9                ::1
表1-28 display l2vpn forwarding evpn split-horizon命令显示信息描述表
Tunnel name
VXLAN隧道接口名称
Filtered interfaces
从指定VXLAN隧道接收到的泛洪流量在该设备上不能转发的接口
Interface name
接口名称
AC link ID
AC的链路标识符
Service instance ID
以太网服务实例编号
PW count
PW的数量
SRv6 tunnel count
SRv6隧道的数量
VSI name
VSI名称
PW link ID
PW的链路标识符
SRv6 link ID
SRv6隧道的链路标识符
ESI label
ESI标签
Argument
当无Argument时显示为“-”
UPW link ID
UPW的链路标识符
e-tree enable命令用来开启本地AC与远端AC的EVPN E-Tree功能。
undo e-tree enable命令用来关闭本地AC与远端AC的EVPN E-Tree功能。
e-tree enable
undo e-tree enable
本地AC与远端AC的EVPN E-Tree功能处于关闭状态。
VSI实例下的EVPN实例视图
在EVPN VPLS和EVPN VPLS over SRv6组网中,属于同一个EVPN实例的所有AC均可以互相访问。EVPN承载接入用户的网络中,为了提高用户的安全性,减少用户之间的相互影响,通常需要控制AC侧用户之间的相互访问。EVPN E-Tree功能通过将AC分为Root和Leaf角色,实现了同一EVPN实例内AC之间流量的隔离。
本命令用于开启本地AC与远端AC的EVPN E-Tree功能,若仅需要控制本地AC之间的访问,则无需配置本命令。
EVPN VPLS和EVPN VPLS over SRv6组网中,不能同时配置本功能。
# 开启EVPN E-Tree功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation mpls
[Sysname-vsi-aaa-evpn-mpls] e-tree enable
1.1.27  esi
esi命令用来配置接口或UPW的ESI(Ethernet Segment Identifier,以太网段标识)。
undo esi命令用来恢复缺省情况。
esi esi-id
undo esi
未配置接口和UPW的ESI。
交叉连接PW视图
VSI LDP PW视图
VSI静态PW视图
esi-id:以太网链路网段标识符。格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。
ESI是ES的唯一标识,ESI相同的接口(或UPW)对应的链路属于同一个ES,报文可以在这些链路之间进行负载分担。
主接口及其子接口上均可以配置ESI:
·     若主接口及其子接口上都配置了ESI,或仅在子接口上配置了ESI,则子接口的ESI以该子接口上的配置为准,子接口的ES相关配置(evpn redundancy-mode、evpn df-election algorithm、evpn df-election preference、evpn df-election preference non-revertive和evpn timer es-delay命令)也以该子接口上的配置为准。
·     若仅在主接口上配置了ESI,则子接口继承主接口的ESI和ES相关配置。即使 子接口上执行了ES相关配置,也不会生效。
只有VSI LDP PW和VSI静态PW不采用水平分割方式转发报文(执行peer命令时指定no-split-horizon参数)时,才允许在该VSI LDP PW或VSI静态PW的视图下执行本命令。
不能通过重复执行esi命令修改接口(或UPW)的ESI属性值。如需修改,请先通过undo esi命令删除接口(或UPW)的ESI属性值,再执行esi命令配置新的ESI属性值。
# 配置接口GigabitEthernet1/0/1上的ESI值为0000.0001.0002.0003.0004。
[Sysname-GigabitEthernet1/0/1] esi 0000.0001.0002.0003.0004
# 配置交叉连接PW的ESI值为0000.0001.0002.0003.0004。
[Sysname] xconnect-group 1
[Sysname-xcg-1] connection 1
[Sysname-xcg-1-1] peer 1.1.1.1 pw-id 34
[Sysname-xcg-1-1-1.1.1.1-34] esi 0000.0001.0002.0003.0004
# 配置VSI LDP PW的ESI值为0000.0001.0002.0003.0004。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling ldp
[Sysname-vsi-vpn1-ldp] peer 1.1.1.1 pw-id 23 no-split-horizon
[Sysname-vsi-vpn1-ldp-1.1.1.1-23] esi 0000.0001.0002.0003.0004
# 配置VSI静态PW的ESI值为0000.0001.0002.0003.0004。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling static
[Sysname-vsi-vpn1-static] peer 1.1.1.1 pw-id 23 in-label 100 out-label 200 no-split-horizon
[Sysname-vsi-vpn1-static-1.1.1.1-23] esi 0000.0001.0002.0003.0004
evpn df-election algorithm命令用来配置DF选举算法。
undo evpn df-election algorithm命令用来恢复缺省情况。
evpn df-election algorithm algorithm
以系统视图下配置的DF选举算法为准。
algorithm:指定DF选举算法。当前仅支持取值preference,表示基于优先级的DF选举算法。
在EVPN多归属组网中,如果用户希望通过更加灵活地方式控制DF选举,则可以配置本命令修改DF选举算法。
接口视图和系统视图下均可以配置DF选举算法。系统视图的配置对所有ES都有效,而接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置。
# 在接口GigabitEthernet1/0/1上配置基于优先级的DF选举算法。
[Sysname-GigabitEthernet1/0/1] evpn df-election algorithm preference
·     evpn df-election algorithm (system view)
·     evpn df-election preference
evpn df-election algorithm命令用来全局配置DF选举算法。
采用基于VLAN Tag的DF选举算法。
系统视图和接口视图下均可以配置DF选举算法。系统视图的配置对所有ES都有效,而接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置。
# 全局配置基于优先级的DF选举算法。
[Sysname] evpn df-election algorithm preference
·     evpn df-election algorithm (interface view)
evpn df-election preference命令用来配置DF选举优先级。
undo evpn df-election preference命令用来恢复缺省情况。
evpn df-election preference preference
DF选举优先级为32767。
preference:指定DF选举优先级,取值范围为0~65535。优先级数值越大则优先级越高。
在EVPN多归属组网中,若采用了基于优先级的DF选举算法,则可以通过本命令配置DF选举优先级来控制DF的选举。DF优先级最高的设备将选举为DF。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,本命令配置的优先级才会生效。
# 配置DF选举优先级为100。
[Sysname-GigabitEthernet1/0/1] evpn df-election preference 100
evpn df-election preference non-revertive命令用来开启基于优先级DF选举算法的不回切功能。
undo evpn df-election preference non-revertive命令用来关闭基于优先级DF选举算法的不回切功能。
基于优先级算法的DF选举不回切功能处于关闭状态。
配置基于优先级的DF选举算法后,优先级最高的设备被选举为DF进行流量转发。
如用户通过多归属接入VTEP 1和VTEP 2,VTEP 1的DF选举优先级为200,VTEP 2的DF选举优先级为100,则VTEP 1被选举为DF。若出现如下情况则会重新选举VTEP 2作为DF:
·     VTEP 1设备故障。
·     用户接入VTEP 1的链路故障。
·     在VTEP 2上配置了比VTEP 1更高的DF选举优先级。
若在VTEP 2被选举为DF后,VTEP 1故障恢复、用户接入VTEP 1的链路故障恢复或者VTEP 1上配置了高于VTEP 2上的DF选举优先级,则又会重新选举VTEP 1作为DF。如果此时将DF切换为VTEP 1,则会造成一些不必要的丢包。在VTEP 2上配置本功能,可以避免DF回切为VTEP 1,减少丢包。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,本命令才会生效。
# 开启基于优先级DF选举算法的不回切功能。
[Sysname-GigabitEthernet1/0/1] evpn df-election preference non-revertive
evpn edge group命令用来配置ED设备的虚拟IP地址。
undo evpn edge group命令用来恢复缺省情况。
evpn edge group group-ip
未指定ED设备的虚拟IP地址。
group-ip:ED设备的虚拟IP地址。
为了提高ED的可靠性,避免单点故障,在数据中心的边缘可以部署两台ED设备与其他数据中心互联。在这两台ED设备上执行本命令后,它们将虚拟成一台ED设备,采用虚拟IP地址与VTEP、远端ED建立隧道,以实现冗余保护和负载分担。
两台ED设备被虚拟成一台设备以后,ED设备不能在本地接入虚拟机,只能作为数据中心互联的边缘设备使用,且不能在单台ED设备上引入外部路由。
两台ED设备上配置的虚拟IP地址必须相同,该虚拟IP地址应为ED设备上某个LoopBack接口的IP地址,且该地址不能与BGP对等体的地址相同。
本命令仅用于EVPN VXLAN的数据中心互联组网。在EVPN L3VPN组网中配置本命令,本命令不会生效。
在设备上通过undo bgp命令关闭EVPN地址族所在的BGP实例,会导致该设备上的evpn edge group配置被删除,请谨慎使用。
# 配置ED设备的虚拟IP地址为1.2.3.4。
[Sysname] evpn edge group 1.2.3.4
evpn encapsulation命令用来创建EVPN实例,并进入EVPN实例视图。如果EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn encapsulation命令用来恢复缺省情况。
VSI视图:
evpn encapsulation { mpls | vxlan }
交叉连接组视图:
不存在EVPN实例。
VSI视图
交叉连接组视图
mpls:表示EVPN采用MPLS封装方式。
vxlan:表示EVPN采用VXLAN封装方式。
只有创建EVPN实例后,才能进行EVPN相关配置。
# 创建EVPN实例,并进入EVPN实例视图。
[Sysname] vsi aaa
evpn frr local enable命令用来开启指定EVPN实例的Bypass PW功能。
evpn frr local disable命令用来关闭指定EVPN实例的Bypass PW功能,同时删除已经建立的Bypass PW。
undo evpn frr local命令用来恢复缺省情况。
evpn frr local { disable | enable }
undo evpn frr local
EVPN实例的Bypass PW功能状态与EVPN VPWS全局Bypass PW功能状态保持一致。
交叉连接组EVPN实例视图
EVPN多归属站点组网中,CE 1双归属接入PE 1和PE 2,其中PE 1为DF。当PE 1侧的AC故障时,PE 1会向PE 2及远端PE通告本地不可达信息,使PE 1与远端PE间的PW无法转发流量,导致已经从远端PE发送到PE 1的数据报文被丢弃。为解决上述问题,可通过配置本命令在PE 1与PE 2间建立Bypass PW。PE 1侧的AC故障时,通过Bypass PW临时将流量转发到PE 2,以避免流量转发中断。
如果同时执行了本命令和evpn multihoming vpws-frr local命令,则当前EVPN实例的Bypass PW功能状态以本命令的配置为准。
本命令配置在冗余备份组成员PE上。
# 开启交叉连接组aa的EVPN实例的Bypass PW功能。
[Sysname] xconnect-group aa
[Sysname-xcg-1] evpn encapsulation mpls
[Sysname-xcg-1-evpn-mpls] evpn frr local enable
·     evpn multihoming vpws-frr local
evpn frr local enable命令用来开启指定EVPN实例的FRR功能。
evpn frr local disable令令用来关闭指定EVPN实例的FRR功能。
undo evpn frr local
EVPN实例的FRR功能状态与EVPN VPLS全局FRR功能状态保持一致。
VSI实例下的EVPN实例视图
EVPN VPLS多归属站点组网中,CE 1双归属接入PE 1和PE 2,其中PE 1为DF。当PE 1侧的AC故障时,PE 1会删除对应的MAC地址表项,并向PE 2及远端PE通告本地不可达信息撤销MAC地址,此时已经从远端PE发送到PE 1的数据报文由于没有出接口,会被丢弃。为解决上述问题,可通过本命令在PE 1上开启FRR功能,使PE 1侧的AC故障时,不删除对应的MAC地址表项,而是将出接口变更为PE 1与PE 2间建立的PW的索引,将数据报文转发至PE 2,再由PE 2转发至CE 1,从而减少AC故障导致的丢包。
如果同时执行了本命令和evpn multihoming vpls-frr local命令,则当前EVPN实例的FRR功能状态以本命令的配置为准。
本命令配置在冗余备份组成员PE上。
# 开启VSI实例vpna下的EVPN实例的FRR功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation mpls
[Sysname-vsi-vpna-evpn-mpls] evpn frr local enable
·     evpn multihoming vpls-frr local
evpn frr remote enable命令用来开启指定EVPN实例的主备PW功能。
evpn frr remote disable命令用来关闭指定EVPN实例的主备PW功能,同时删除已经建立的备PW。
undo evpn frr remote命令用来恢复缺省情况。
evpn frr remote [ disable | enable ]
EVPN实例的主备PW功能状态与EVPN VPWS全局主备PW功能状态保持一致。
交叉连接组EVPN实例视图
EVPN VPWS组网中,CE 1接入PE 1,PE 1分别通过RR 1和RR 2连接至PE 2,RR在PE间反射路由时修改下一跳属性并重新分配MPLS标签。RR上配置路由策略修改路由属性,PE 1根据RR反射路由中的路由属性,只会选择RR 1或RR 2其中一条最优路径与PE 2建立PW。为了提高网络可靠性,可在PE 1上配置主备PW功能,实现PE 1通过RR 1、RR 2分别与PE 2创建一主一备两条PW,其中最优路径为主PW,从而减小PE 1与RR 1或RR 2间链路故障对整个网络的影响。
目前,仅MPLS封装的交叉连接组EVPN实例支持本命令。
如果同时执行了本命令和evpn vpws-frr remote命令,则当前EVPN实例的主备PW功能状态以本命令的配置为准。
# 开启交叉连接组xcga的EVPN实例的主备PW功能。
[Sysname] xconnect-group xcga
[Sysname-xcg-xcga] evpn encapsulation mpls
[Sysname-xcg-xcga-evpn-mpls] evpn frr remote enable
·     evpn vpws-frr remote
evpn irb asymmetric命令用来配置EVPN VXLAN采用非对称IRB方式转发流量。
undo evpn irb asymmetric命令用来恢复缺省情况。
evpn irb asymmetric
EVPN VXLAN采用对称IRB方式转发流量。
EVPN VXLAN支持对称IRB和非对称IRB两种流量转发方式,通过本命令可以修改流量转发方式。
# 配置EVPN VXLAN采用非对称IRB方式转发流量。
[Sysname] evpn irb asymmetric
evpn local-service-id remote-service-id命令用来创建EVPN PW,并进入EVPN PW视图。如果指定的EVPN PW已经存在,则直接进入EVPN PW视图。
undo evpn local-service-id remote-service-id命令用来删除指定的EVPN PW。
evpn local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ] [ pw-class class-name ]
undo evpn local-service-id local-service-id remote-service-id remote-service-id
不存在EVPN PW。
交叉连接视图
local-service-id local-service-id:本端的service ID,取值范围为1~16777215。
remote-service-id remote-service-id:远端的service ID,取值范围为1~16777215。
tunnel-policy tunnel-policy-name:指定PW的隧道策略。tunnel-policy-name表示隧道策略名,为1~19个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道策略。
pw-class class-name:指定PW引用的PW模板。class-name表示PW模板名,为1~19个字符的字符串,区分大小写。PW模板中可以配置PW的数据封装类型、是否使用控制字等。如果不指定本参数,则PW数据封装类型由接口的链路类型决定,对于不强制要求使用控制字的PW数据封装类型,不支持控制字功能。
在同一交叉连接下执行两次evpn local-service-id remote-service-id命令将两条EVPN PW关联可以实现多段PW功能。
同一个交叉连接中不能通过重复执行evpn local-service-id remote-service-id修改已经创建的EVPN PW,如需修改已经创建的EVPN PW,请先通过undo evpn local-service-id remote-service-id命令删除已经创建的EVPN PW,再执行evpn local-service-id remote-service-id命令创建新的EVPN PW。
在多归属站点组网中,如果本端PE与冗余备份组中的各PE建立EVPN PW时,通过本命令引用的PW模板中配置了使用BFD检测PW的连通性:
·     若本端PE与冗余备份组中各PE建立的EVPN PW为主备EVPN PW,则仅为主EVPN PW建立动态BFD会话。
·     若本端PE与冗余备份组中各PE建立的EVPN PW为等价EVPN PW,则不建立动态BFD会话。
# 创建EVPN PW,指定PW的隧道策略为aaa并且指定引用的PW模板为bbb,并进入EVPN PW视图。
[Sysname] xconnect-group aaa
[Sysname-xcg-aaa] connection ac2pw
[Sysname-xcg-aaa-ac2pw] evpn local-service-id 2 remote-service-id 4 tunnel-policy aaa pw-class bbb
[Sysname-xcg-aaa-ac2pw-2-4]
1.1.39  evpn mpls routing-enable
evpn mpls routing-enable命令用来开启EVPN通告VPN路由功能。
undo evpn mpls routing-enable命令用来关闭EVPN通告VPN路由功能。
EVPN通告VPN路由功能处于关闭状态。
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
开启本功能后,VPN路由表中的VPN路由会作为EVPN的IP前缀路由发布给邻居;当收到邻居发送的MPLS封装的IP前缀路由时,会将其插入到相应的VPN路由表中。
本功能需要与向对等体/对等体组发布MPLS封装的IP前缀路由功能配合使用,即在配置本功能后还需要在BGP EVPN地址族视图下执行命令peer advertise encap-type mpls配置向对等体/对等体组发布MPLS封装的IP前缀路由功能。
# 在VPN实例vpna的IPv4地址族视图下使能EVPN通告VPN路由功能。
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn mpls routing-enable
1.1.40  evpn multihoming advertise disable
evpn multihoming advertise disable命令用来配置禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由。
undo evpn multihoming advertise disable命令用来恢复缺省情况。
允许通告EVPN以太网自动发现路由和以太网段路由。
在站点多归属组网中,用户需要重启其中一台VTEP或PE时,重启该VTEP或PE前,可以通过在该VTEP或PE上执行此命令,来禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由,以便其他VTEP或PE及时更新本地的EVPN路由表,确保VTEP或PE的重启不会影响报文转发。
# 配置禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由。
[Sysname] evpn multihoming advertise disable
1.1.41  evpn multihoming advertise ignore-ethernet-tag
evpn multihoming advertise ignore-ethernet-tag命令用来配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
undo evpn multihoming advertise ignore-ethernet-tag命令用来恢复缺省情况。
EVPN多归属组网中,PE发送以太网自动发现路由和MAC/IP发布路由时携带以太网标签。
本命令需要配置在冗余备份组成员PE上。
多归属站点组网中,为冗余备份组成员上的AC配置ESI后,冗余备份组成员发送以太网自动发现路由和MAC/IP发布路由时会携带AC的以太网标签。如果对端设备无法识别以太网标签,为了与该对端设备互通,需要在本端设备上配置本命令,使得本端设备将发送的以太网自动发现路由和MAC/IP发布路由中的以太网标签字段填为0。
执行本命令后,设备会撤销已经发布的以太网自动发现路由和MAC/IP发布路由,并重新发布以太网标签字段为0的以太网自动发现路由和MAC/IP发布路由。
执行本命令时,需要注意的是:
·     为三层主接口配置ESI后,如果该接口上的子接口未配置ESI,则子接口会继承主接口的ESI。此时,具有相同ESI的子接口不能关联相同的VSI。
# 配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
[Sysname] evpn multihoming advertise ignore-ethernet-tag
·     esi
1.1.42  evpn multihoming vpls-frr local
evpn multihoming vpls-frr local命令用来全局开启EVPN VPLS的FRR功能。
undo evpn multihoming vpls-frr local命令用来关闭全局EVPN VPLS的FRR功能。
EVPN VPLS的FRR功能处于关闭状态。
如果执行本命令的同时在指定EVPN实例下执行了evpn frr local命令,则指定EVPN实例的FRR功能状态以EVPN实例下的配置为准。
如果在指定EVPN实例下开启了EVPN的FRR功能,则执行undo evpn multihoming vpls-frr local命令不会关闭该EVPN实例下的FRR功能。
本命令配置在冗余备份组成员PE上。
# 开启EVPN VPLS全局FRR功能。
[Sysname] evpn multihoming vpls-frr local
·     evpn frr local (VSI EVPN instance view)
1.1.43  evpn multihoming vpws-frr local
evpn multihoming vpws-frr local命令用来开启全局EVPN VPWS的Bypass PW功能。
undo evpn multihoming vpws-frr local命令用来关闭全局EVPN VPWS的Bypass PW功能,并删除已经建立的Bypass PW。
EVPN VPWS的Bypass PW功能处于关闭状态。
如果执行本命令的同时在指定EVPN实例下执行了evpn frr local命令,则指定EVPN实例的Bypass PW功能状态以EVPN实例下的配置为准。
执行undo evpn multihoming vpws-frr local命令后,如果EVPN实例下配置了evpn frr local enable命令,则不删除该EVPN实例下的Bypass PW。
本命令配置在冗余备份组成员PE上。
# 开启全局EVPN VPWS的Bypass PW功能。
[Sysname] evpn multihoming vpws-frr local
·     evpn frr local (cross-connect group EVPN instance view)
1.1.44  evpn multihoming re-originated mac
evpn multihoming re-originated mac命令用来配置本地重生成MAC/IP发布路由中的MAC地址。
undo evpn multihoming re-originated mac命令用来恢复缺省情况。
本地不会重生成MAC/IP发布路由中的MAC地址。
EVPN VPLS组网中,CE 1通过聚合口或S-trunk双归属接入PE 1和PE 2,PE 3为远端PE连接CE 2。CE 1选择PE 1侧发送流量至CE 2,CE 2通过PE 1和PE 2两侧均可将流量转发至CE 1。当PE 1侧AC故障时,PE 1会撤销发送至PE 2和PE 3的MAC/IP发布路由,此时PE 2需要重新从CE 1学习MAC地址并同步给PE 3,在此期间PE 3没有CE 1的MAC地址表项,导致断流。
为解决上述问题,可在PE 2上配置本命令,PE 2接收到PE 1同步的MAC/IP发布路由时,在本地重新生成CE 1的MAC地址表项并发布给PE 3,这样即使PE 1侧的AC故障导致PE 1撤销MAC/IP发布路由,PE 3仍有CE 1的MAC地址表项,避免断流。
配置本命令前,需要先开启EVPN VPLS的FRR功能。
# 配置本地重生成MAC/IP发布路由中的MAC地址。
[Sysname] evpn multihoming re-originated mac
1.1.45  evpn multihoming timer df-delay
evpn multihoming timer df-delay命令用来设置DF选举的延迟时间。
undo evpn multihoming timer df-delay命令用来恢复缺省情况。
evpn multihoming timer df-delay delay-value
DF选举的延迟时间为3秒。
delay-value:DF选举的延迟时间,取值范围为1~1200,单位为秒。
AC所在接口的状态、多归属成员设备数量或者接口下ESI值的频繁变化都会导致DF频繁选举,极大影响了网络的性能。通过配置evpn multihoming timer df-delay命令可以指定DF选举的时间间隔,避免频繁选举DF,保证网络的稳定性。
在多归属组网中,若希望DF故障时,能够快速选举出新的DF,以避免长时间存在多个BFD,导致流量转发中断,则建议通过本命令将DF选举延迟时间配置为0。
# 配置DF选举的延迟时间为5秒。
[Sysname] evpn multihoming timer df-delay 5
1.1.46  evpn redundancy-mode
evpn redundancy-mode命令用来配置接口或UPW的冗余备份模式。
undo evpn redundancy-mode命令用来恢复缺省情况。
evpn redundancy-mode { all-active | single-active }
冗余备份模式为多活冗余模式。
交叉连接PW视图
single-active:单活冗余模式。
all-active:多活冗余模式。
EVPN VPWS、EVPN VPLS、EVPN VPWS over SRv6、EVPN VPLS over SRv6多归属组网支持本配置。EVPN VXLAN多归属组网仅支持多活冗余模式,不支持本配置。
在多归属站点组网中,冗余备份组中的各PE分别与远端PE建立EVPN PW(或SRv6 PW),若需两条EVPN PW(或SRv6 PW)间形成主备关系,则使用单活冗余模式;若需EVPN PW(或SRv6 PW)间形成等价负载分担,则使用多活冗余模式。
建议为同一冗余备份组中各PE连接多归属站点的AC接口或UPW配置相同的冗余备份模式。
本功能需要与配置接口(或UPW)的ESI配合使用,即还需要执行esi命令配置ESI。
# 配置接口GigabitEthernet1/0/1的冗余备份模式为单活冗余模式。
[Sysname-GigabitEthernet1/0/1] evpn redundancy-mode single-active
# 配置交叉连接PW的冗余备份模式为单活冗余模式。
[Sysname-xcg-1-1-1.1.1.1-34] evpn redundancy-mode single-active
·     esi
1.1.47  evpn timer ad-delay
evpn timer ad-delay命令用来开启以太网自动发现路由延迟发布功能,并指定延迟发布时间。
undo evpn timer ad-delay命令用来关闭以太网自动发现路由延迟发布功能。
evpn timer ad-delay delay-time
以太网自动发现路由延迟发布功能处于关闭状态,即不延迟发布以太网自动发现路由。
delay-time:以太网自动发现路由延迟发布时间,取值范围3~1200,单位为秒。
EVPN VPLS组网中,CE 1通过聚合口或S-trunk双归属多活接入PE 1和PE 2,PE 3为远端PE连接CE 2。CE 1选择PE 1侧发送流量至CE 2,CE 2通过PE 1和PE 2两侧均可将流量转发至CE 1。PE 1重启后,在PE 2发送MAC/IP发布路由同步CE 1的MAC地址之前,PE 1先发送携带下一跳信息的以太网自动发现路由至PE 3,导致PE 3查找CE 1的MAC地址转发流量时会将流量转发给PE 1和PE 2,此时PE 1未学习到CE 1的MAC地址,报文会被丢弃。
为解决上述问题,可在PE 1的AC接口上配置本功能,延迟发布以太网自动发现路由,使PE 1先学习到CE 1的MAC地址,再发布以太网自动发现路由,减少丢包。
# 接口GigabitEthernet1/0/1下配置以太网自动发现路由发布的延迟时间为300秒。
[Sysname-GigabitEthernet1/0/1] evpn timer ad-delay 300
1.1.48  evpn timer es-delay
evpn timer es-delay命令用来开启以太网段路由延迟发布功能,并指定延迟发布时间。
undo evpn timer es-delay命令用来关闭以太网段路由延迟发布功能。
evpn timer es-delay delay-time
以太网段路由延迟发布功能处于关闭状态,即不延迟发布以太网段路由。
delay-time:以太网段路由延迟发布时间,取值范围3~1200,单位为秒。
本命令通常与evpn track peer命令配合使用。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。如果通过本命令开启了以太网段路由延迟发布功能,则当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对指定BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 接口GigabitEthernet1/0/1下配置以太网段路由发布的延迟时间为300秒。
[Sysname-GigabitEthernet1/0/1] evpn timer es-delay 300
·     evpn track peer
1.1.49  evpn track peer
evpn track peer命令用来在多归属组网中,配置冗余备份组中的成员设备监视其它VTEP/PE设备的BGP邻居状态。
undo evpn track peer命令用来取消监视其它VTEP/PE设备的BGP邻居状态。
evpn track peer peer-address
undo evpn track peer peer-address
在多归属组网中,冗余备份组中的成员设备不会监视其它设备的BGP邻居状态。
peer-address:VTEP/PE的IPv4地址。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。这样,当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对本命令指定的BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 在接口GigabitEthernet1/0/1上配置本地成员设备监视设备1.1.1.1的BGP邻居状态。
[Sysname-GigabitEthernet1/0/1] evpn track peer 1.1.1.1
·     evpn timer es-delay
1.1.50  evpn vpws-frr remote
evpn vpws-frr remote命令用来全局开启EVPN VPWS的主备PW功能。
undo evpn vpws-frr remote命令用来关闭全局EVPN VPWS的主备PW功能,并删除已经建立的备PW。
EVPN VPWS的主备PW功能处于关闭状态。
如果执行本命令的同时在指定EVPN实例下执行了evpn frr remote命令,则指定EVPN实例的主备PW功能状态以EVPN实例下的配置为准。
如果EVPN实例下配置了evpn frr remote enable命令,再执行undo evpn vpws-frr remote命令,则EVPN实例下的主备PW功能仍然处于开启状态且不删除该EVPN实例下的备PW。
# 全局开启EVPN VPWS主备PW功能。
[Sysname] evpn vpws-frr remote
·     evpn frr remote
1.1.51  export route-policy
export route-policy命令用来配置EVPN的出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
未配置EVPN的出方向路由策略,即不对发布的路由进行过滤。
VSI实例下的EVPN实例视图(非VXLAN封装)
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:出方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的出方向路由策略,则EVPN实例/VPN实例向BGP EVPN协议发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制路由的发布。
在同一视图下,多次执行本命令,最后一次执行的命令生效。
VSI实例下的EVPN实例视图(非VXLAN封装)、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的出方向路由策略均能用来过滤EVPN路由。其中:
·     VSI实例下的EVPN实例视图(非VXLAN封装)、交叉连接组EVPN实例视图下的配置用于EVPN二层转发场景。
·     VPN实例视图和VPN实例EVPN视图下的配置用于EVPN三层转发场景。如果同时配置二者,则EVPN采用VPN实例EVPN视图下的配置。
# 在VPN实例vpn1下配置EVPN的出方向路由策略为poly-1。
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.52  ignore-ac-state
ignore-ac-state enable命令用来开启当前VSI忽略AC状态的功能。
ignore-ac-state disable命令用来关闭当前VSI忽略AC状态的功能。
undo ignore-ac-state命令用来恢复缺省情况。
ignore-ac-s tate { enable | disable }
与全局VSI忽略AC功能状态的开关情况保持一致。
VSI视图
EVPN VPLS多归属单活组网中,CE 1采用S-Trunk方式双归属接入PE 1和PE 2,PE 1为主用设备,PE 2为备份设备,PE 2上AC状态为Down。当PE 1上AC故障时,PE 1会撤销以太网自动发现路由,同时PE 2上的AC状态为Up,并向远端PE发送以太网自动发现路由,远端PE需要收到PE 2发送的以太网自动发现路由,才能切换至备份路径,路径切换过程速度较慢,会导致报文丢失。为解决上述问题,可在PE 2上配置本命令,使PE 2忽略AC状态并向远端PE发送以太网自动发现路由,远端PE保存该路由。当PE 1的AC故障时,远端PE将流量快速切换至备份路径,减少丢包。
如果执行本命令的同时在全局执行了l2vpn ignore-ac-state命令,则该VSI的配置以ignore-ac-state命令为准。
本功能可以与本地重生成MAC/IP发布路由中的MAC地址功能配合使用。
# 开启VSI实例vpna忽略AC状态的功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna] ignore-ac-state enable
·     l2vpn ignore-ac-state
1.1.53  import evpn mac-ip
import evpn mac-ip命令用来配置将从对等体/对等体组收到的包含ARP信息的MAC/IP发布路由引入BGP单播路由表。
undo import evpn mac-ip命令用来禁止将从对等体/对等体组收到的包含ARP信息的MAC/IP发布路由引入BGP单播路由表。
import evpn mac-ip
BGP IPv4单播地址族视图
BGP-VPN IPv4单播地址族视图
在BGP IPv4单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP信息的MAC/IP发布路由后,会将其添加到公网实例路由表,并发布到本地站点。
在BGP-VPN IPv4单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP信息的MAC/IP发布路由后,会将其添加到VPN实例对应的BGP IPv4单播路由表,是否发布到本地站点取决于是否执行命令advertise l2vpn evpn配置允许向本地站点发布BGP EVPN路由。
# 配置将从对等体/对等体组收到的MAC/IP路由引入VPN实例vpna对应的BGP IPv4单播路由表。
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
1.1.54  import route-policy
import route-policy命令用来配置EVPN的入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
未配置EVPN的入方向路由策略,即如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:入方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的入方向路由策略,则将BGP EVPN协议的路由引入到EVPN实例或VPN实例时,会利用指定的路由策略对引入的路由进行过滤、改变引入路由的属性等。使用本命令可以更加精确、灵活地控制路由的引入。
VSI实例下的EVPN实例视图(非VXLAN封装)、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的入方向路由策略均能用来过滤EVPN路由。其中:
# 在VPN实例vpn1下配置EVPN的入方向路由策略为poly-1。
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
1.1.55  ip public-instance
ip public-instance命令用来创建公网实例,并进入公网实例视图。如果公网实例已经存在,则直接进入公网实例视图。
undo ip public-instance命令用来删除公网实例。
ip public-instance
不存在公网实例。
公网实例用来实现分布式EVPN网关转发公网的三层流量及公私网互通。公网实例可以看作是特殊的VPN实例,分布式EVPN网关对公网实例的处理与VPN实例完全相同。
# 创建公网实例,并进入公网实例视图。
[Sysname] ip public-instance
[Sysname-public-instance]
1.1.56  l2vpn ignore-ac-state
l2vpn ignore-ac-state命令用来全局开启VSI忽略AC状态的功能。
undo l2vpn ignore-ac-state命令用来全局关闭VSI忽略AC状态的功能。
VSI忽略AC状态的功能处于关闭状态。
EVPN VPLS多归属单活组网中,CE 1采用S-Trunk方式双归属接入PE 1和PE 2,PE 1为主用设备,PE 2为备份设备,PE 2上AC状态为Down。当PE 1上AC故障时,PE 1会撤销以太网自动发现路由,同时PE 2上的AC状态为Up,并向远端PE发送以太网自动发现路由,远端PE收到PE 2发送的以太网自动发现路由后,才能切换至备份路径,路径切换过程速度较慢,会导致报文丢失。为解决上述问题,可在PE 2上配置本命令,使PE 2忽略AC状态并向远端PE发送以太网自动发现路由,远端PE保存该路由。当PE 1的AC故障时,远端PE将流量快速切换至备份路径,减少丢包。
如果执行本命令的同时在VSI视图下执行了ignore-ac-state命令,则该VSI的配置以ignore-ac-state命令为准。
# 全局开启VSI忽略AC状态的功能。
[Sysname] l2vpn ignore-ac-state
·     ignore-ac-state
1.1.57  l3-vni
l3-vni命令用来配置L3VNI。
undo l3-vni用来取消配置的L3VNI。
l3-vni vxlan-id
undo l3-vni
未配置L3VNI。
VSI虚接口视图
公网实例视图
vxlan-id:L3VNI,取值范围为0~16777215。
分布式网关组网中,需要在网关上配置L3VNI。在网关之间通过VXLAN隧道转发流量时,属于同一路由域、能够进行三层互通的流量通过L3VNI来标识。
转发某个VPN的三层流量时,需要在与该VPN实例关联的VSI虚接口视图下执行本命令;转发公网的三层流量时,不仅需要在属于公网的VSI虚接口视图下执行本命令,还需要在公网实例视图下执行本命令配置与VSI虚接口相同的L3VNI。
在公网实例视图下,不能通过重复执行本命令修改公网实例的L3VNI。如需修改公网实例的L3VNI,请先通过undo l3-vni命令删除L3VNI,再执行l3-vni命令。
# 在VSI虚接口100上配置L3VNI为1000。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
1.1.58  mac-advertising disable
mac-advertising disable命令用来配置禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
undo mac-advertising disable命令用来恢复缺省情况。
允许通告MAC地址信息。
VSI实例下的EVPN实例视图
VTEP可能会同时向远端VTEP通告MAC地址信息和ARP信息。其中,ARP信息中已经包含MAC地址信息。为了避免重复,可以执行本命令来禁止本端VTEP向远端VTEP通告MAC地址信息。执行本命令后,本端VTEP还会撤销已经发布的MAC地址信息。
# 配置EVPN实例禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
1.1.59  mapping vni
mapping vni命令用来指定本地VXLAN映射的远端VXLAN。
undo mapping vni命令用来恢复缺省情况。
mapping vni vxlan-id
undo mapping vni
未指定本地VXLAN映射的远端VXLAN。
VSI实例下的EVPN实例视图
vxlan-id:映射的远端VXLAN ID,取值范围为0~16777215。
在不同的数据中心中,同一租户的相同子网可能使用不同的VXLAN。这些数据中心互联时,若要保证同一租户相同子网之间的流量进行二层转发,则ED设备上需要执行本命令,在不同的VXLAN之间建立映射关系。
可以通过以下方式建立映射关系:
·     将本地VXLAN直接映射为另一个数据中心中使用的VXLAN。采用此方式时,只需在一个数据中心的ED上指定映射的远端VXLAN。例如,数据中心1内使用VXLAN 10、数据中心2内使用VXLAN 20时,只需在数据中心1的ED上配置VXLAN 10映射为远端VXLAN 20。
·     将不同数据中心ED上的本地VXLAN映射为相同的VXLAN(称为中间VXLAN)。采用此方式时,需要在所有数据中心的ED上都指定映射的远端VXLAN为中间VXLAN。例如,数据中心1内使用VXLAN 10、数据中心2内使用VXLAN 20、数据中心3内使用VXLAN 30时,需要在三个数据中心的ED上均配置映射的远端VXLAN为中间VXLAN(如VXLAN 500)。当多个数据中心互联,且不同数据中心使用的VXLAN各不相同时,需要使用此方式。中间VXLAN只能用于VXLAN映射,不能用作普通VXLAN来处理VXLAN业务。
·     本地设备上需要创建映射的远端VXLAN,为其配置EVPN实例,并为该EVPN实例配置RD和Route Target属性。
# 配置本地VXLAN 100映射为远端VXLAN 200。
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] quit
[Sysname-vsi-aaa-evpn-vxlan] mapping vni 200
1.1.60  nexthop recursive-lookup default-route ignore
nexthop recursive-lookup default-route ignore命令用来配置下一跳路由迭代时不能迭代到缺省路由。
undo nexthop recursive-lookup default-route ignore命令用来恢复缺省情况。
nexthop recursive-lookup default-route ignore [ route-policy route-policy-name ]
BGP路由进行下一跳路由迭代时,可以迭代到缺省路由。
BGP EVPN地址族视图
route-policy route-policy-name:通过路由策略指定对哪些路由进行下一跳路由迭代时不查找缺省路由。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。未指定本参数或本参数指定的路由策略不存在时,所有从对等体接收到的BGP路由进行下一跳路由迭代时,都不查找缺省路由。指定的路由策略中,通过if-match interface命令配置的匹配条件不生效。
配置本命令后,可能会使得EVPN VXLAN网络中已经创建的VXLAN隧道重新建立,导致VXLAN流量的短暂丢失。建议您在配置本命令后,再使能BGP EVPN路由的交互能力。
缺省情况下,BGP路由在进行下一跳路由迭代时,若只能通过缺省路由到达BGP路由的下一跳,则BGP路由会迭代到缺省路由,即选择缺省路由作为BGP路由的下一跳的依赖路由。如果通过该缺省路由实际无法到达BGP路由的下一跳,则匹配该BGP路由的流量将转发失败。
为了解决上述问题,可以配置本命令,使得BGP路由进行下一跳路由迭代时,不迭代到缺省路由。配置本命令后,BGP路由在进行下一跳路由迭代时,若只能通过缺省路由到达BGP路由的下一跳,则路由迭代失败,该BGP路由成为失效路由,同一前缀的其他BGP路由可以被优选。
本功能可以应用在到达同一目的地址存在多条链路的组网场景中,在承载流量的链路发生故障时,原本迭代到该链路的BGP路由也不会因为迭代到缺省路由而保持继续生效,而是变为失效路由,使得下一跳指向其他链路的BGP路由能够优选,以实现链路的切换,避免长时间丢包。
# 配置通过路由策略policy1过滤的BGP EVPN路由进行下一跳路由迭代时,不查找缺省路由。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] nexthop recursive-lookup default-route ignore route-policy policy1
·     if-match interface(三层技术-IP路由命令参考/路由策略)
1.1.61  peer advertise encap-type mpls
peer advertise encap-type mpls命令用来配置向对等体/对等体组发布MPLS封装的EVPN路由。
undo peer advertise encap-type mpls命令用来删除向对等体/对等体组发布MPLS封装的EVPN路由的配置。
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
向对等体/对等体组发布VXLAN封装的EVPN路由。
BGP EVPN地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
ipv6-address:对等体的IPv6地址。指定的对等体必须已经创建。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
在EVPN L3VPN网络中,需要执行本命令配置向邻居发布MPLS封装的EVPN路由。
EVPN L3VPN组网中,本功能通常配置在EVPN承载的L3VPN网络的边缘节点和RR(Route Reflector,路由反射器)设备上。在边缘节点上,本功能需要与EVPN通告VPN路由功能配合使用,即在VPN实例IPv4地址族视图/VPN实例IPv6地址族视图下执行命令evpn mpls routing-enable开启EVPN通告VPN路由功能。
# 配置向对等体1.1.1.1发布MPLS封装的EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
1.1.62  peer advertise original-route
peer advertise original-route命令用来配置向对等体/对等体组发布源EVPN路由。
undo peer advertise original-route命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } advertise original-route
undo peer { group-name | ipv4-address [ mask-length ] } advertise original-route
执行peer re-originated命令后,设备不向对等体/对等体组发布源EVPN路由。
BGP EVPN地址族视图
使用本功能前必须在ED上配置peer re-originated命令,否则本功能不生效。
EVPN数据中心互联组网中,ED上配置peer re-originated命令后,该ED仅向对等体/对等体组发布修改路由信息后的路由,不会发布源EVPN路由。此时若有对等体/对等体组希望从该ED接收未经修改的源EVPN路由,则可在ED上执行本命令,向指定对等体/对等体组同时发送源EVPN路由和修改路由信息后的路由。
# 在BGP EVPN地址族视图下,配置向对等体1.1.1.1发送源EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise original-route
·     peer re-originated
·     peer suppress re-originated
1.1.63  peer re-originated
peer re-originated命令用来配置从对等体/对等体组接收到BGP EVPN路由后,修改路由中的信息。
undo peer re-originated命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } re-originated [ ip-prefix | mac-ip ] [ replace-rt ]
undo peer { group-name | ipv4-address [ mask-length ] } re-originated [ ip-prefix | mac-ip ]
不修改从对等体/对等体组接收到的EVPN路由的信息。
BGP EVPN地址族视图
ip-prefix:指定修改IP前缀路由的信息。
mac-ip:指定修改MAC/IP发布路由的信息。
replace-rt:指定将IP前缀路由或MAC/IP发布路由的L3VNI、RD和RT修改为本地VPN实例的L3VNI、RD和RT。如果不指定本参数,则仅修改L3VNI、RD,不修改RT。
EVPN数据中心互联组网中,在ED上执行本命令后,ED从VTEP或远端ED接收到EVPN路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则将路由中的信息修改为本地VPN实例的信息,并将修改后的路由发布给远端ED或VTEP。
通常在以下情况下,可以执行本命令:
·     不同数据中心使用的L3VNI不同,通过本配置修改L3VNI,以实现数据中心之间的互通。
·     不同数据中心互通,需要RT值匹配。当数据中心组网规模较大时,数据中心之间的RT配置比较复杂。配置本命令后,ED可直接修改EVPN路由的RT值,数据中心之间发布EVPN路由使用统一的RT值即可,无需进行复杂的RT配置。
·     用户不希望泄露本地数据中心使用的L3VNI时,可以执行本配置将本地所有L3VNI均替换为ED上的L3VNI,对外仅体现ED上的L3VNI。
执行本命令后,ED仅向对等体/对等体组发布修改路由信息后的路由,不会向对等体/对等体组发布源EVPN路由。
如果ED上本地VPN实例的RD与接收到的EVPN路由的RD相同,则不会修改该路由的L3VNI和RT,也不会重生成路由,导致该BGP EVPN路由无法向对等体/对等体组发布。因此,执行本命令时,建议在不同设备上为VPN实例配置不同的RD。
执行本命令时,如果未指定ip-prefix和mac-ip参数,则表示修改IP前缀路由的信息。
# 在BGP EVPN地址族视图下,配置修改从BGP对等体1.1.1.1收到的IP前缀路由的L3VNI、RD和RT。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated ip-prefix replace-rt
·     peer advertise original-route
1.1.64  peer router-mac-local
peer router-mac-local命令用来配置向对等体/对等体组发布路由、将从对等体/对等体组接收到的路由发布给其他对等体时,将路由的Router MAC修改为自身的Router MAC地址。
undo peer router-mac-local命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } router-mac-local
undo peer { group-name | ipv4-address [ mask-length ] } router-mac-local
不会修改路由的Router MAC。
BGP EVPN地址族视图
数据中心网络的ED设备上需要执行本命令,以便该设备将从数据中心内的对等体/对等体组学到的路由通告给其他数据中心网络的ED设备,或将从其他数据中心网络的ED设备学到的路由通告给数据中心内的对等体/对等体组时,将路由的Router MAC修改为本地的Router MAC。
# 在BGP EVPN地址族视图下,配置向对等体1.1.1.1发布路由、将从对等体1.1.1.1接收到的路由发布给其他对等体时,将路由的Router MAC修改为自身的Router MAC。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 router-mac-local
1.1.65  peer suppress re-originated
peer suppress re-originated命令用来抑制向对等体/对等体组发送修改路由信息后的EVPN路由。
undo peer suppress re-originated命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } suppress re-originated { ip-prefix | mac-ip }
undo peer { group-name | ipv4-address [ mask-length ] } suppress re-originated { ip-prefix | mac-ip }
执行peer re-originated命令后,设备仅向对等体/对等体组发送修改路由信息后的EVPN路由。
BGP EVPN地址族视图
ip-prefix:抑制向对等体/对等体组发送修改路由信息后的IP前缀路由。
mac-ip:抑制向对等体/对等体组发送修改路由信息后的MAC/IP发布路由。
如果ED上同时配置了peer re-originated和peer advertise original-route命令,则该ED会向指定对等体/对等体组发送源EVPN路由和修改路由信息后的EVPN路由。此时若该对等体/对等体组仅希望接收源EVPN路由,则可在ED上配置本命令,抑制向对等体/对等体组发送修改路由信息后的EVPN路由,减少该对等体/对等体组上的EVPN路由条目。
# 在BGP EVPN地址族视图下,抑制向对等体1.1.1.1发送修改路由信息后的IP前缀路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 suppress re-originated ip-prefix
1.1.66  policy vpn-target
policy vpn-target命令用来开启BGP EVPN路由的VPN-Target过滤功能。
undo policy vpn-target命令用来关闭BGP EVPN路由的VPN-Target过滤功能。
policy vpn-target
BGP EVPN路由的VPN-Target过滤功能处于开启状态。
BGP EVPN地址族视图
开启BGP EVPN路由的VPN-Target过滤功能后,设备只将Export Route Target属性与本地Import Route Target属性匹配的BGP EVPN路由加入到BGP EVPN路由表。设备上如需保存所有BGP EVPN路由,则需执行undo policy vpn-target命令,不对BGP EVPN路由进行VPN-Target过滤。
# 关闭BGP EVPN路由的VPN-Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
1.1.67  pw-class
pw-class命令用来指定引用的PW模板。
undo pw-class命令用来恢复缺省情况。
pw-class class-name
undo pw-class
未引用PW模板。
VSI实例下的EVPN实例视图
class-name:PW模板名,为1~19个字符的字符串,区分大小写。
仅采用MPLS封装方式的EVPN实例支持本命令。
在VSI实例下的EVPN实例视图下执行本命令指定引用PW模板后,该PW模板将应用于该视图下建立的所有PW。
多次执行本命令,则最后一次执行的命令生效。
# 在VSI实例下的EVPN实例视图下指定引用的PW模板为pw100。
[Sysname] vsi vpna
[Sysname-vsi-vpna-evpn-mpls] pw-class pw100
1.1.68  route-distinguisher (EVPN instance view)
route-distinguisher命令用来配置EVPN实例的RD(Route Distinguisher,路由标识符)。
undo route-distinguisher命令用来恢复缺省情况。
route-distinguisher { route-distinguisher | auto }
未指定EVPN实例的RD。
VSI实例下的EVPN实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串(不允许为全0)。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1
auto:表示自动生成RD。自动生成的RD取值为“N:VXLAN ID”,N为从1开始的整数;如果“N:VXLAN索引”已被使用,则RD取值改为“(N+1):VXLAN ID”,如此反复,直到找到未被使用的RD。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告。本命令指定的RD,携带在MP-BGP协议发布的邻居、MAC地址、主机路由信息中,以标识不同EVPN实例的邻居、MAC地址、主机路由信息。
# 配置EVPN的RD为22:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
1.1.69  route-distinguisher (public instance view)
route-distinguisher命令用来配置公网实例的RD。
未配置公网实例的RD。
公网实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
不能通过重复执行route-distinguisher命令修改公网实例的RD值。如需修改公网实例的RD值,请先通过undo route-distinguisher命令删除公网实例的RD值,再执行route-distinguisher命令配置新的RD值。
# 配置公网实例的RD为22:1。
[Sysname-public-instance] route-distinguisher 22:1
1.1.70  rr-filter
rr-filter命令用来配置路由反射器对反射的EVPN路由进行过滤。
undo rr-filter命令用来恢复缺省情况。
undo rr-filter
路由反射器不会对反射的EVPN路由进行过滤。
BGP EVPN地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~65535。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的EVPN路由进行过滤:只有接收的BGP EVPN路由通过扩展团体属性列表过滤时,路由反射器才会反射该EVPN路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置路由反射器只反射通过扩展团体属性列表10过滤的BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
1.1.71  tracert evpn vsi
tracert evpn vsi命令用来查看EVPN VPLS组网或EVPN VPLS over SRv6中本端PE到指定主机连接的远端PE间PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vsi vsi-name mac mac-address [ -a source-ipv4 | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out ] *
vsi vsi-name:检测指定VSI内PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
mac mac-address:检测到指定主机连接的远端PE的PW连通性。mac-address表示MAC地址,形式为H-H-H,不能配置为全0、广播MAC地址和组播MAC地址。
-a source-ipv4:指定发送的MPLS echo request报文的源地址。source-ipv4为源IPv4地址。如果未指定本参数,则MPLS echo request报文的源IPv4地址为报文出接口的主IPv4地址。本参数仅适用于EVPN VPLS组网。
-exp exp-value:MPLS echo request报文中标签的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。本参数仅适用于EVPN VPLS组网。
-h ttl-value:指定MPLS echo request报文中TTL的最大值,ttl-value为TTL值,取值范围为1~255,缺省值为255。
-r reply-mode:指定接收者对MPLS echo request报文的应答模式。reply-mode为应答模式,取值为2、4,缺省值为2。2表示根据目的IP地址查找IP转发表转发应答报文。在EVPN VPLS组网中,4表示根据VSI关联的PW转发应答报文;在EVPN VPLS over SRv6组网中,4表示根据请求报文的源IPv6地址在目的节点上查找IPv6路由表,封装SRH信息转发应答报文。
-rtos tos-value:指定MPLS echo reply报文IP头的ToS值。tos-value为ToS值,取值范围为0~7,缺省值为6。本参数仅适用于EVPN VPLS组网。
-t time-out:指定发送MPLS echo request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000。
EVPN VPLS组网和EVPN VPLS over SRv6组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到指定主机连接的远端PE间PW所经过的路径,并根据应答信息对错误点进行定位。
# 在EVPN VPLS组网中,查看本端PE到MAC地址为1-1-1的主机连接的远端PE之间PW所经过的路径,并根据应答信息对错误点进行定位。
<Sysname> tracert evpn vsi vpna mac 1-1-1
Trace route to a remote PE in VSI vpna by reaching remote-MAC 0001-0001-0001.
Press CTRL+C to break.
  TTL   Replier            Time    Type
  0                                Ingress
  1     11.1.1.2           1 ms    Transit
  2     12.1.1.1           1 ms    Egress
表1-29 tracert evpn vsi命令显示信息描述表
查看VSI vpna内从当前设备到MAC地址为0001-0001-0001的主机连接的远端PE间PW所经过的路径
按组合键Ctrl+C可以终止tracert操作
TTL
跳数
Replier
节点的IP地址
Time
RTT(Roud-Trip Time,往返时间)值,单位为毫秒
路径经过的节点类型,取值包括:
·     Ingress:入节点
·     Transit:中间节点
·     Egress:出节点
Request time out
请求超时,若在等待响应的超时时间内没有收到应答报文,则显示本字段
1.1.72  tunnel-policy
tunnel-policy命令用来指定引用的隧道策略。
undo tunnel-policy命令用来恢复缺省情况。
undo tunnel-policy
未引用隧道策略。
VSI实例下的EVPN实例视图
tunnel-policy-name:隧道策略名称,为1~19个字符的字符串,区分大小写。
在VSI实例下的EVPN实例视图下执行本命令指定引用的隧道策略后,与该VSI关联的PW将引用该隧道策略,即根据指定的隧道策略选择承载PW的公网隧道。
如果未引用隧道策略或者引用的隧道策略尚未配置,则PW根据缺省选择策略来选择公网隧道。缺省选择策略为按照LSP隧道->GRE隧道->CRLSP->SRLSP隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
多次执行本命令,则仅最后一次执行的生效。
# 在VSI实例下的EVPN实例视图下指定引用的隧道策略为policy1。
[Sysname] vsi aa
[Sysname-vsi-aa] evpn encapsulation mpls
[Sysname-vsi-aa-evpn-mpls] tunnel-policy policy1
1.1.73  vpn-route cross multipath
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到BGP EVPN路由表中。
BGP EVPN地址族视图
开启VPN引入等价路由功能后,BGP将前缀和RD均相同的多条路由全部引入到BGP EVPN路由表中。
# 开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
1.1.74  vpn-target
vpn-target命令用来配置EVPN的Route Target属性。
undo vpn-target命令用来删除指定的Route Target属性。
VSI实例下的EVPN实例视图:
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN实例EVPN视图/公网实例IPv4地址族视图/公网实例EVPN视图:
未指定EVPN的Route Target属性。
VSI实例下的EVPN实例视图
VPN实例EVPN视图
公网实例IPv4地址族视图
公网实例EVPN视图
vpn-target&<1-8>:Route Target属性值,vpn-target为3~21个字符的字符串。&<1-8>表示前面的参数最多可以输入8次。Route Target有三种格式:
auto:表示自动生成RT。自动生成的RT取值为“BGP AS:VXLAN ID”。
both:指定配置的Route Target值同时作为Import Target和Export Target。没有指定both、export-extcommunity和import-extcommunity中的任何一个参数时,缺省值为both。
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告等。本地设备在通过MP-BGP的Update消息将BGP EVPN路由发送给远端设备时,将Update消息中携带的VPN target属性设置为Export target。远端设备接收到BGP EVPN路由后,将该路由中携带的Export Target属性与本地配置的Import Target进行比较,如果二者中存在相同的值,则接收该信息。
重复执行本命令,Route Target值为多次配置结果的集合。
在EVPN VPLS组网中,请为同一PE上的不同EVPN实例配置不同的RT值,否则会使EVPN实例接收错误的路由,导致创建PW时使用错误的MPLS标签。
# 配置EVPN的Import Target为10:1、100:1和1000:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
