11-设备管理命令
本章节下载: 11-设备管理命令 (1.23 MB)
1.1.12 display cpu-usage configuration
1.1.13 display cpu-usage history
1.1.15 display device manuinfo
1.1.16 display device manuinfo chassis-only
1.1.17 display device manuinfo fan
1.1.18 display device manuinfo power
1.1.19 display diagnostic-information
1.1.22 display hardware-failure-detection
1.1.23 display hardware-resource board-mixed
1.1.24 display hardware-resource multicast-vlan
1.1.25 display hardware-resource parser
1.1.26 display hardware-resource route-async
1.1.27 display hardware-resource tcam
1.1.28 display hardware-resource uni
1.1.30 display memory-threshold
1.1.31 display memory-threshold dma
1.1.33 display resource-monitor
1.1.35 display scheduler logfile
1.1.36 display scheduler reboot
1.1.37 display scheduler schedule
1.1.39 display system health history
1.1.40 display system stable state
1.1.41 display system-working-mode
1.1.42 display transceiver alarm
1.1.43 display transceiver diagnosis
1.1.44 display transceiver interface
1.1.45 display transceiver itu-channel
1.1.46 display transceiver manuinfo
1.1.47 display transceiver status
1.1.49 display version-update-record
1.1.50 hardware-failure-detection
1.1.51 hardware-failure-protection aggregation
1.1.52 hardware-resource board-mixed
1.1.53 hardware-resource multicast-vlan
1.1.54 hardware-resource parser
1.1.55 hardware-resource route-async
1.1.64 monitor cpu-usage enable
1.1.65 monitor cpu-usage interval
1.1.66 monitor cpu-usage threshold
1.1.68 monitor resend cpu-usage
1.1.69 monitor resend memory-threshold
1.1.70 parity-error consistency-check log enable
1.1.71 parity-error consistency-check threshold
1.1.72 parity-error monitor log enable
1.1.73 parity-error monitor period
1.1.74 parity-error monitor threshold
1.1.75 parity-error unrecoverable log enable
1.1.76 parity-error unrecoverable period
1.1.77 parity-error unrecoverable reboot
1.1.78 parity-error unrecoverable threshold
1.1.79 password-recovery enable
1.1.80 power-exception-monitor
1.1.84 power-supply policy enable
1.1.85 power-supply policy redundant
1.1.86 power-supply surplus-power enable
1.1.89 reset scheduler logfile
1.1.90 reset transceiver interface
1.1.91 reset version-update-record
1.1.92 resource-monitor minor resend enable
1.1.93 resource-monitor output
1.1.94 resource-monitor resource
1.1.96 restore factory-default
1.1.100 scheduler reboot delay
1.1.105 switch-fabric removal-signal-suppression
1.1.106 switch-linecard isolate
1.1.109 system handshake timeout
1.1.116 transceiver lane enable
1.1.117 transceiver monitor enable
1.1.118 transceiver monitor interval
1.1.119 transceiver power-mode
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
仅缺省MDC支持本命令。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
· clock protocol
· clock summer-time
· clock timezone
· display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
从缺省MDC通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ptp:表示通过PTP(Precision Time Protocol,精确时间协议)协议获取时间。关于PTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“PTP”。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号,取值范围为1~16。
仅缺省MDC支持本命令。
系统时间的获取方式有:
· 配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
· 配置clock protocol { ntp | ptp }命令后,通过NTP/PTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
所有MDC的系统时间相同。当设备从某个MDC获取时钟后,会同步给其它MDC。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
· 直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
· 分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
· 直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省MDC支持本命令。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
· clock datetime
· clock timezone
· display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省MDC支持本命令。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
· clock datetime
· clock summer-time
· display clock
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口FortyGigE1/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface fortygige 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
· scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm命令用来显示设备的告警信息。
(独立运行模式)
display alarm [ slot slot-number ]
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
仅缺省MDC支持本命令。
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot CPU Level Info
- - ERROR Power 2 is faulty.
- - INFO Power 3 is absent.
- - INFO Power 4 is absent.
表1-1 display alarm命令显示信息描述表
Slot |
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上 |
CPU |
告警CPU的编号 |
Level |
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO |
Info |
告警的详细信息。取值为: · Board is faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态) · Fan n is absent:风扇n当前不在位 · Fan n is faulty:风扇n处于异常状态 · Power n is absent:电源n当前不在位 · Power n is faulty:电源n处于异常状态 · Slot n temperature is too high, above the shutdown limit:单板n温度过高,高于下电温度门限 · Slot n temperature is too high, above the high limit:单板n温度过高,高于高温门限 · Slot n temperature is too high, above the warning limit:单板n温度过高,高于告警门限 · Slot n temperature is too low, below the low limit:单板n温度过低,低于低温门限 |
display asset-info命令用来显示设备的用户资产信息。使用该命令,可以显示设备机框、单板、风扇框或电源模块的资产信息。
display asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
display asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
fan fan-id:显示指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号,取值范围为1~6。
power power-id:显示指定电源模块的用户资产信息。power-id表示设备上电源模块的编号,取值范围为1~16。
slot slot-number:显示指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
chassis chassis-number:显示指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
当用户希望显示设备机框、单板或风扇框的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,显示的是该设备机框、单板或风扇框的所有用户资产信息。
使用该命令显示设备机框、单板、风扇框或电源模块没有经过设置的具体信息项目时,该信息项目的内容显示为空。
使用该命令显示指定风扇框或者电源模块的资产信息时,如果设备上无对应编号的风扇框或者电源模块,将返回风扇框或者电源模块不在位的提示信息。
# 显示设备上1号风扇框的资产编号信息(该显示信息与用户的当前配置有关)。(独立运行模式)
[Sysname] display asset-info fan 1 csn
# 显示设备上1号风扇框的资产信息(该显示信息与用户的当前配置有关)。(独立运行模式)
表1-2 display asset-info命令显示信息描述表
Type |
资产类型,内容为指定的设备机框、单板、风扇框或电源模块 |
csn |
资产编号信息,内容为空表示用户没有进行设置 |
description |
资产描述信息,内容为空表示用户没有进行设置 |
location |
资产位置信息,内容为空表示用户没有进行设置 |
service-date |
资产启用时间信息,内容为空表示用户没有进行设置 |
department |
资产归属部门信息,内容为空表示用户没有进行设置 |
state |
资产使用状态信息,内容为空表示用户没有进行设置 |
custom |
用户自定义的资产信息,内容为空表示用户没有进行设置 |
· reset asset-info
· set asset-info
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/16/2015
· clock datetime
· clock timezone
· clock summer-time
display copyright命令用来显示设备的版权信息。
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
(独立运行模式)
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ]
control-plane:显示控制平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
登录MDC后执行该命令,会显示该MDC可使用的CPU的利用率统计信息。
当最近5秒、最近1分钟和最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
表1-3 display cpu-usage命令显示信息描述表
1% in last 5 seconds |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU或CPU核的平均利用率。该字段显示的是最近一个5秒统计周期内CPU或CPU核的平均利用率 |
Last 5 sec |
1% in last 1 minute |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU或CPU核的平均利用率 |
Last 1 min |
1% in last 5 minutes |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU或CPU核的平均利用率 |
Last 5 min |
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
(独立运行模式)
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。
登录MDC后执行该命令,会显示该MDC可使用的CPU的对应信息。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
表1-4 display cpu-usage configuration命令显示信息描述表
CPU usage monitor is enabled. |
CPU利用率历史记录功能处于开启状态 |
Current monitor interval is 60 seconds. |
CPU利用率采样周期为60秒 |
Current severe alarm threshold is 90%. |
CPU利用率高级别告警门限为90% |
Current minor alarm threshold is 80%. |
CPU利用率低级别告警门限为80% |
Current recovery-threshold is 40%. |
CPU利用率恢复门限为40% |
· monitor cpu-usage enable
· monitor cpu-usage interval
· monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
(独立运行模式)
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
· 纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
· 横坐标表示时间,时间越靠左表示距离当前时间越近。
· 用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。(独立运行模式)
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
(独立运行模式)
display device[ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
display device[ flash | usb ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
flash:显示Flash的信息。
usb:显示USB接口的信息。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
不指定flash和usb参数时,显示单板的信息。
在缺省MDC和非缺省MDC下执行该命令,显示信息相同,且均显示物理设备的对应信息。
仅LSXM1TGS24QGMODHB1单板支持显示子卡信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
Slot Type State Subslot Soft Ver Patch Ver
0 LSXM1SUPB1 Master 0 S12508X-AF-0502 None
1 LSXM1SUPB1 Standby 0 S12508X-AF-0502 None
2 NONE Absent 0 NONE None
3 LSXM1TGS48C2HB1 Normal 0 S12508X-AF-0502 None
4 NONE Absent 0 NONE None
5 NONE Absent 0 NONE None
6 NONE Absent 0 NONE None
7 NONE Absent 0 NONE None
8 NONE Absent 0 NONE None
9 NONE Absent 0 NONE None
10 NONE Absent 0 NONE None
11 NONE Absent 0 NONE None
12 NONE Absent 0 NONE None
13 NONE Absent 0 NONE None
14 NONE Absent 0 NONE None
15 LSXM1SFH08D1 Normal 0 S12508X-AF-0502 None
表1-5 display device命令显示信息描述表
Type |
单板的硬件类型 |
Status |
单板状态: · Standby表示该板是备用主控板 · Master表示该板是主用主控板 · Absent表示该槽位没有插入单板 · Fault表示该槽位单板正在启动、单板被下电或者单板出错,不能正常启动 · Normal表示该槽位单板是接口板并处于正常工作状态 · Offline表示该槽位网板处于隔离状态 |
Soft Ver |
当前单板上运行的软件版本 |
Patch Ver |
当前单板上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁 若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级” |
display device manuinfo命令用来显示设备的电子标签信息。
(独立运行模式)
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
display device manuinfo [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
本命令仅缺省MDC支持。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
(独立运行模式)
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
本命令仅缺省MDC支持。
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
显示信息略……。
display device manuinfo fan命令用来显示风扇的电子标签信息。
(独立运行模式)
display device manuinfo fan fan-id
display device manuinfo chassis chassis-number fan fan-id
fan-id:表示设备上风扇的ID编号。
本命令仅缺省MDC支持。
# 显示指定风扇的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo fan 1
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
(独立运行模式)
display device manuinfo power power-id
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号。
本命令仅缺省MDC支持。
# 显示指定电源的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 1
显示信息略……。
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1) 使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2) 使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3) 使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行display diagnostic-information命令前,请使用display cpu-usage、display memory命令查看CPU、内存使用率。如果CPU使用率为100%,或者内存使用率超过90%,请暂时不要执行display diagnostic-information命令,等CPU和内存使用率回落后再执行。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
· gunzip(基础配置命令参考/文件系统管理)
· more(基础配置命令参考/文件系统管理)
· tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
(独立运行模式)
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定slot和vent参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot和vent参数时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
本命令仅缺省MDC支持。
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
1 hotspot 1 38 10 40 50 100
1 hotspot 2 42 10 50 80 100
表1-6 display environment命令显示信息描述表
System Temperature information (degree centigrade) |
系统温度信息,单位为摄氏度 |
sensor |
温度传感器 · hotspot:表示热点温度传感器 · inflow:表示入风口温度传感器 |
Slot |
当显示数字时表示指定slot上温度传感器的温度信息 |
Temperature |
当前温度 |
Lower |
低温告警门限。当显示为NA时,表示不支持该门限 |
Warning |
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限 |
Alarm |
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限 |
Shutdown |
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限 |
display fan命令用来显示风扇的工作状态。
(独立运行模式)
display fan [ fan-id ]
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。(IRF模式)
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
本命令仅缺省MDC支持。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan-tray 1:
Status : Normal
Fan Type : LSXM110FAN
Fan number: 5
Fan mode : Auto
Airflow Direction: Fan-Panel-Exhaust
Fan Speed(rpm)
1 5673
2 3871
3 3883
4 1653
5 1639
表1-7 display fan命令显示信息描述表
Fan-tray 1: |
风扇模块1 |
Status |
风扇的状态,取值为: · Normal表示正常 · Faulty表示异常 · Absent表示没有插入风扇模块 |
Fan Type |
风扇模块的型号 |
Fan number |
风扇模块中风扇的个数 |
Fan mode |
风扇的调速模式 |
Airflow Direction |
风扇模块的实际风道方向: · Fan-Panel-Exhaust:风扇面板侧出风 · Fan-Panel-Intake:风扇面板侧进风 |
Fan Speed(rpm) |
风扇的编号和转速 |
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(独立运行模式)
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(IRF模式)
仅缺省MDC支持本命令。
# 查看设备的硬件故障检测和故障修复信息。(独立运行模式)
<Sysname> display hardware-failure-detection
Current level:
chip : isolate
board : isolate
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
There is no record.
--------------------------Slot 0 trapped records:-----------------------------
There is no record.
表1-8 display hardware-failure-detection命令显示信息描述表
Current level |
当前故障检测对应的修复操作 |
chip : |
器件类故障对应的修复操作 |
board : |
单板类故障对应的修复操作 |
forwarding : |
转发类故障对应的修复操作 |
Recent record: |
最近记录 |
Slot n executed records: |
主控板n上记录的各个单板的历史操作记录(独立运行模式) |
Chassis n, Slot m executed records: |
成员设备n主控板m上记录的各个单板的历史操作记录(IRF模式) |
Slot n trapped records: |
主控板n上记录的各个单板的trap告警信息(独立运行模式) |
Chassis n, Slot m trapped records: |
成员设备n主控板m上记录的各个单板的trap告警信息(IRF模式) |
display hardware-resource board-mixed命令用来显示HA单板和非HA单板混合工作模式的状态
display hardware-resource [ board-mixed ]
board-mixed:显示HA单板和非HA单板混合工作模式的状态。
执行本命令时,如果不指定board-mixed参数,则显示所有类型的硬件资源模式。
# 显示HA单板和非HA单板混合工作模式的状态。
<Sysname> display hardware-resource board-mixed
Board mixed(board-mixed), all supported modes:
disable Disable mixed mode
enable Enable mixed mode
Default Current Next
disable disable enable
表1-9 display hardware-resource board-mixed命令显示信息描述表
Board mixed(board-mixed), all supported modes |
设备支持的HA单板和非HA单板混合工作模式 |
Default |
HA单板和非HA单板的缺省工作模式 |
Current |
HA单板和非HA单板当前的工作模式 |
Next |
最新配置的HA单板和非HA单板的工作模式 |
display hardware-resource multicast-vlan命令用来查看当前VLAN组播匹配模式的状态。
# 查看当前VLAN组播匹配模式的状态。
<Sysname> display hardware-resource multicast-vlan
multicast vlan only(multicast-vlan), all supported modes:
disable The disable mode: ignore-vlan
enable The enable mode: vlan-based
表1-10 display hardware-resource multicast-vlan命令显示信息描述表
multicast vlan only(multicast-vlan), all supported modes |
设备支持的VLAN组播匹配模式 |
Default |
VLAN组播匹配模式的缺省工作模式 |
Current |
VLAN组播匹配模式的当前工作模式 |
Next |
VLAN组播匹配模式的下个工作模式 |
display hardware-resource parser命令用来显示设备对报文解析的处理模式
display hardware-resource [ parser ]
不指定parser参数时,表示显示所有硬件资源的运行模式。
# 显示设备对报文解析的处理模式。
<Sysname> display hardware-resource parser
Network tap resource(parser), all supported modes:
normal The normal mode
network-tap The network tap mode
normal normal normal
表1-11 display hardware-resource parser命令显示信息描述表
Network tap resource(parser), all supported modes |
设备对报文解析的处理模式,取值为: · normal:普通模式 · network-tap:分流器模式 |
Default |
缺省处理模式 |
Current |
当前处理模式 |
Next |
最新配置的处理模式 |
· hardware-resource parser
display hardware-resource route-async命令用来查看当前路由异步任务的状态。
仅Release 2825及以上版本支持本命令。
# 查看当前路由异步任务的状态。
<Sysname> display hardware-resource route-async
route-async(route-async), all supported modes:
enable enable enable
表1-12 display hardware-resource route-async命令显示信息描述表
route-async(route-async), all supported modes |
设备支持的路由异步任务的工作模式 |
Default |
路由异步任务的缺省工作模式 |
Current |
路由异步任务的当前工作模式 |
Next |
最新配置的路由异步任务的工作模式 |
display hardware-resource tcam命令用来显示TCAM(Ternary Content Addressable Memory,三态内容寻址存储器)硬件资源的运行模式。
display hardware-resource [ tcam ]
仅缺省MDC支持本命令。
不指定tcam参数时,表示显示所有硬件资源的运行模式。
# 显示TCAM硬件资源的运行模式。
<Sysname> display hardware-resource tcam
Tcam resource(tcam), all supported modes:
routing The routing mode:LPM 4M, ACL 9k(F Series)/18K (H Series)
normal The normal mode:LPM 256K, ACL 9k(F Series)/18K (H Series)
acl The acl mode:LPM 256K, ACL 16k(F Series)/1M(H Series)
ipv6 The ipv6 mode:LPM 4M, ACL 9k(F Series)/18K (H Series)
mix The mix mode:LPM 4M/2M, ACL 32K(F Series)/256K(H Series)
routing routing routing
表1-13 display hardware-resource tcam命令显示信息描述表
Tcam resource(tcam), all supported modes |
设备支持的TCAM的运行模式,取值为: · routing:路由模式 · normal:普通模式 · acl:ACL模式 · ipv6:IPv6模式 · mix:MIX模式 |
Default |
TCAM的缺省运行模式 |
Current |
TCAM的当前运行模式 |
Next |
最新配置的TCAM的运行模式 |
· hardware-resource tcam
display hardware-resource uni命令用来显示UNI的工作模式。
仅缺省MDC支持本命令。
# 显示UNI的运行模式。
<Sysname> display hardware-resource uni
uni(uni), all supported modes:
enhance-uni The uni enhance mode
ultra-uni The uni ultra mode
表1-14 display hardware-resource命令显示信息描述表
uni(uni), all supported modes |
设备支持的UNI的运行模式 |
Default |
UNI的缺省运行模式 |
Current |
UNI的当前运行模式 |
Next |
最新配置的UNI的运行模式 |
display memory命令用来显示内存使用情况。
(独立运行模式)
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。(IRF模式)
cpu cpu-number:表示CPU编号。
登录MDC后执行该命令,会显示该MDC可使用的内存的使用情况。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。(独立运行模式)
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 8149596 2351256 5798340 0 20 275784 71.1%
-/+ Buffers/Cache: 2075452 6074144
Swap: 0 0 0
Slot 1:
Mem: 8149596 2180788 5968808 0 20 162472 73.2%
-/+ Buffers/Cache: 2018296 6131300
Swap: 0 0 0
Slot 3:
Mem: 7128860 2463148 4665712 0 80 16312 65.4%
-/+ Buffers/Cache: 2446756 4682104
Swap: 0 0 0
Slot 15:
Mem: 4044620 1253264 2791356 0 16 108084 69.0%
-/+ Buffers/Cache: 1145164 2899456
Swap: 0 0 0
# 显示设备的内存使用情况的简要信息。(独立运行模式)
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 498284 293884 204400 1316 76332 41.0%
表1-15 display memory命令显示信息描述表
Memory statistics are measured in KB: |
系统内存使用情况,以下统计信息均以KB为单位 |
Mem |
内存使用信息 |
Total |
系统可分配的物理内存的大小 设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小 |
Used |
整个系统已用的物理内存大小 |
Free |
整个系统可用的物理内存大小 |
Shared |
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值 |
Buffers |
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值 |
Cached |
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用。取值为“--”时,表示不支持统计该参数的值 |
Caches |
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用 |
FreeRatio |
整个系统物理内存的空闲率。包含当前剩余空闲内存以及高速缓冲寄存器中当前正在使用但是内存告警状态下可主动释放的内存 |
-/+ buffers/cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小 -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小 |
Swap |
交换分区的使用信息 |
display memory-threshold命令用来显示内存告警门限相关信息。
(独立运行模式)
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
仅缺省MDC支持本命令。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
Minor: 96M
Severe: 64M
Critical: 48M
Normal: 128M
Early-warning: 256M
Secure: 304M
Current free-memory state: Normal (secure)
Free-memory event statistics:
[Back to secure state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Entered early-warning state]
First notification at: 0.0
Latest notification at: 0.0
[Back to normal state]
[Entered minor alarm state]
[Back to minor alarm state]
[Entered severe alarm state]
[Back to severe alarm state]
[Entered critical alarm state]
表1-16 display memory-threshold命令显示信息描述表
Memory usage threshold |
内存利用率阈值 |
Free-memory thresholds Minor Severe Critical Normal Early-warning Secure |
剩余内存门限阈值: · Minor:一级告警门限,单位为MB · Severe:二级告警门限,单位为MB · Critical:三级告警门限,单位为MB · Normal:恢复到正常状态的阈值,单位为MB · Early-warning:预警门限,单位为MB · Secure:恢复预警门限状态的阈值,单位为MB |
Current free-memory state |
系统当前内存使用状态: · Normal:正常状态 · Minor:一级告警门限状态 · Severe:二级告警门限状态 · Critical:三级告警门限状态 · Normal (early-warning):预告警状态 · Normal (secure):安全状态 |
Free-memory event statistics: |
门限事件统计信息,事件分为: · Back to secure state:恢复到预警前的状态 · Entered early-warning state:进入预告警门限状态 · Back to normal state:内存恢复到正常状态 · Entered minor alarm state:进入一级告警门限状态 · Back to minor alarm state:恢复到一级告警前的状态 · Entered severe alarm state:进入二级告警门限状态 · Back to severe alarm state:恢复到二级告警前的状态 · Entered critical alarm state:进入三级告警门限状态 |
First notification at |
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification at |
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notification send |
事件发生的总次数 |
display memory-threshold dma命令用来显示DMA内存告警相关信息。
(独立运行模式)
display memory dma [ slot slot-number [ cpu cpu-number ] ]
display memory dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
# 显示DMA内存告警相关信息。(独立运行模式)
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Current DMA memory state: Normal
表1-17 display memory-threshold dma 命令显示信息描述表
Free DMA memory thresholds: Critical: |
DMA内存告警阈值(单位为KB): · Critical:告警阈值 · Normal:告警恢复阈值 |
Current DMA memory state |
DMA内存的当前状态: · Critical:告警状态 · Normal:正常状态 |
display power命令用来显示设备电源的信息。
(独立运行模式)
display power [ power-id | verbose ]
display power [ chassis chassis-number [ power-id | verbose ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。(IRF模式)
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
本命令仅缺省MDC支持。
# 显示设备电源的状况。
<Sysname> display power
Power supply policy : Enabled
Surplus sleeping : Disabled
Power modules installed : 2
Power modules usable : 2
Total power : 4000W
Redundant power : 0W
Sleeping power : 0W
Available power : 4000W
Out power : 108W
Allocated power : 2375W
Remaining power : 1625W
PowerID State InPower(W) Current(A) Voltage(V) OutPower(W) Type
1 Normal 2000 5.80 54.00 313.20 CP2000AC
2 Absent -- -- -- -- ---
3 Normal 2000 4.40 54.00 237.60 CP2000AC
4 Absent -- -- -- -- ---
5 Absent -- -- -- -- ---
6 Absent -- -- -- -- ---
7 Absent -- -- -- -- ---
8 Absent -- -- -- -- ---
Information about reserved power:
Slot Status Power(W) Remarks
7 Normal 275 Powered on
10 Normal 170 Powered on
11 Fault 450 Powered on
12 Normal 170 Powered on
16 Normal 50 Reserved for MPU
17 Absent 50 Reserved for MPU
Power information for fans:
Fan[2]: 1200W
表1-18 display power命令显示信息描述表
Power supply policy |
电源管理功能的状态,取值为: · Enabled:表示电源管理功能处于开启状态 · Disabled:表示电源管理功能处于关闭状态 |
Surplus sleeping |
电源睡眠功能的状态,取值为: · Enabled:表示电源睡眠功能处于开启状态 · Disabled:表示电源睡眠功能处于关闭状态 |
Power modules installed |
设备已安装电源模块的数量 |
Power modules usable |
设备已使用电源模块的数量:处于Normal和Sleeping状态的电源模块数量 |
Total power |
电源模块总功率,单位为瓦 |
Redundant power |
冗余电源功率,单位为瓦 |
Sleeping power |
睡眠电源功率,单位为瓦 |
Available power |
设备可用的电源功率,单位为瓦 |
Out power |
设备当前输出的电源功率,单位为瓦 |
Allocated power |
设备已使用的电源功率,单位为瓦 |
Remaining power |
设备剩余的电源功率,单位为瓦 |
PowerID |
设备上的电源模块编号 |
State |
电源模块的状态 · Absent:电源不在位 · Normal:电源正常工作 · Fault:电源故障 · Sleeping:电源处于睡眠状态 |
InPower(W) |
电源输入功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
Current(A) |
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息 |
Voltage(V) |
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息 |
OutPower(W) |
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
Type |
电源模块型号,显示为“--”表示设备暂不支持统计该信息 |
Information about reserved power |
单板预留的功率信息 |
Slot |
设备单板的槽位编号 |
Status |
单板的状态 · Absent:表示单板不在位 · Normal:表示单板已正常启动 · Fault:表示单板状态异常,可能是还没有启动或者故障 |
Power(W) |
单板预留的功率,单位为瓦 |
Remarks |
单板预留功率的描述,取值为: · Reserved for MPU:表示为主控板预留 · Powered on:表示正常上电 · Not enough power to power it on:表示没有足够的功率给单板预留 · Reserved for a non-MPU card:表示为单板预留 · Powered off:表示单板被强制下电 |
Power information for fans |
设备风扇预留的功率信息 |
Fan[x] |
设备风扇编号 |
display resource-monitor命令用来显示资源监控功能的相关信息。
(独立运行模式)
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见“设备可监测的资源描述表”。
slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。(独立运行模式)
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource Minor Severe Free/Total
(%) (%) (absolute)
arp 50 20 90095/90098
表1-19 display resource-monitor命令显示信息描述表
Minor alarms resending |
周期发送低级别资源告警通知功能的开启状态: · Enabled:表示该功能已开启 · Disabled:表示该功能未开启 |
Resource |
监控资源的名称 |
Minor (%) |
低级别告警门限,单位为百分比 |
Severe (%) |
高级别门限,单位为百分比 |
Free/Total (absolute) |
剩余资源的数量/该资源的总数,用绝对值形式表示 |
· resource-monitor minor resend enable
· resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang fortygige 1/0/1 to fortygige 1/0/3
[Sysname-if-range]shutdown
表1-20 display scheduler logfile命令显示信息描述表
Logfile Size |
Schedule日志文件的大小,单位为字节 |
Job name |
Job的名称 |
Schedule name |
Schedule的名称 |
Execution time |
开始执行Job的时间 |
Completion time |
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息) |
Job output |
Job中的命令执行时的输出信息 |
· reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
· scheduler reboot at
· scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2015
Last execution time : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts : 1
Job name Last execution status
shutdown Successful
表1-21 display scheduler schedule命令显示信息描述表
Schedule name |
Schedule的名称 |
Schedule type |
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息 |
Start time |
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Last execution time |
Schedule上一开始执行的时间 · 如果没有为Schedule配置执行时间,则不会显示该信息 · 如果还没有执行,则显示Yet to be executed |
Last completion time |
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Execution counts |
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息 |
Job name |
Schedule下关联的Job的名称 |
Last execution status |
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看) · Successful:表示执行成功 · Failed:表示执行失败 · Waiting:表示正在等待被执行 · In process:表示正在执行 · -NA-:表示还没有到执行时间 |
display system health命令用来显示设备的健康状态。
(独立运行模式)
display system health [ chassis chassis-number ]
chassis chassis-number :表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。(IRF模式)
设备会定期执行一系列检查,以便了解设备是否处于健康状态。检查项在设备出厂时已固定,检查结果可供设备内部业务模块(例如IRF、M-LAG等)使用,也可通过本命令供用户查看。
# 显示设备健康状态。
<Sysname> display system health
显示信息略
· display system health history
display system health history命令用来显示系统健康状态变化的历史信息。
(独立运行模式)
display system health history[ chassis chassis-number ]
# 显示系统健康状态变化的历史信息。
<Sysname> display system health history
Health: Normal
表1-22 display system health history命令显示信息描述表
Health: Normal(0) |
系统当前的健康状态。取值为: · Normal(0):表示系统健康 · Faulty(n):表示系统不健康,n表示健康值,取值越大越不健康 |
display system stable state命令用来显示系统的稳定状态。
display system stable state[ mdc { mdc-id | all } ]
mdc { mdc-id | all }:显示指定或所有MDC的系统稳定状态。mdc-id表示MDC的编号,取值范围为1~16。
不指定mdc参数时,显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/单板/MDC启动需要一定的时间,才能达到Stable状态。如果设备/单板/MDC长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板/MDC,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
· 通过display device命令查看设备是否处于故障状态。
· 通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
· 通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。(独立运行模式)
<Sysname> display system stable state
System state : Stable
Redundancy state : Stable
Slot CPU Role State
0 0 Active Stable
1 0 Standby Stable
3 0 Other Stable
15 0 Other Stable
表1-23 display system stable state命令显示信息描述表
System state |
系统状态: · Stable:稳定运行 · Not ready:未稳定,此时不能进行ISSU升级 |
Redundancy state |
主备状态: · Stable:主备状态稳定,可以倒换 · No redundance:系统无冗余,不能倒换 · Not ready:未稳定,不可以倒换 |
Role |
单板在系统中的身份: · Active:主用主控板 · Standby:备用主控板,提供冗余备份 · Other:业务板 |
State |
单板状态: · Stable:单板稳定运行 · Board inserted:单板插入 · Kernel initiating:单板内核初始化 · Service starting:单板上的服务正在启动 · Service stopping:单板上的服务正在关闭 · HA Batch backup:HA批量备份中 · Interface data batch backup:接口管理批量备份未完成 · MDC starting:MDC正在启动 · MDC stopping:MDC正在关闭 · Automatic configuration:MDC正在进行自动配置(本字段的支持情况与设备的型号有关,请以设备的实际情况为准) |
当前对象处于未稳定状态 |
· display device
· display ha service-group(可靠性命令参考/进程分布优化)
· display mdc(虚拟化技术命令参考/MDC)
display system-working-mode命令用来显示设备的工作模式。
仅缺省MDC支持本命令。
# 显示设备的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-24 SFP/SFP+的display transceiver alarm命令输出信息描述表
RX loss of signal |
接收信号丢失 |
RX power high alarm |
接收光功率高告警 |
RX power high warning |
接收光功率高预警 |
RX power low alarm |
接收光功率低告警 |
RX power low warning |
接收光功率低预警 |
TX fault |
发送错误 |
TX bias high alarm |
偏置电流高告警 |
TX bias high warning |
偏置电流高预警 |
TX bias low alarm |
偏置电流低告警 |
TX bias low warning |
偏置电流低预警 |
TX power high alarm |
发送光功率高告警 |
TX power high warning |
发送光功率高预警 |
TX power low alarm |
发送光功率低告警 |
TX power low warning |
发送光功率低预警 |
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
Voltage high alarm |
电压高告警 |
Voltage high warning |
电压高预警 |
Voltage low alarm |
电压低告警 |
Voltage low warning |
电压低预警 |
Transceiver info I/O error |
模块信息读写错误 |
Transceiver info checksum error |
模块信息校验和错误 |
Transceiver type and port configuration mismatch |
模块类型和端口配置不匹配 |
Transceiver type not supported by port hardware |
端口不支持该模块类型 |
TEC fault |
TEC(Thermoelectric Cooler,热点冷却器)错误。仅SFP-XG-LH80-Tunable光模块支持显示该信息 |
Wavelength unlocked |
光信号波长失锁。仅SFP-XG-LH80-Tunable光模块支持显示该信息 |
Tx is not ready due to tunning |
光信号波长改变时发射端处于准备过程状态告警。仅SFP-XG-LH80-Tunable光模块支持显示该信息 |
RX CDR loss of lock |
接收侧CDR失锁,表示信号不好 |
TX CDR loss of lock |
发送侧CDR失锁,表示信号不好 |
表1-25 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
电压高告警 |
电压高预警 |
Voltage low alarm |
电压低告警 |
电压低预警 |
RX loss of signal(channel x) |
通道x接收到的信号丢失 |
TX fault(channel x) |
通道x发送报文时出错 |
TX loss of signal(channel x) |
通道x发送的信号丢失 |
RX power high(channel x) |
通道x接收到的光的功率太高 |
RX power low(channel x) |
通道x接收到的光的功率太低 |
TX power high alarm(channel x) |
通道x发送光功率高告警 |
TX power high warning(channel x) |
通道x发送光功率高预警 |
TX power low alarm(channel x) |
通道x发送光功率低告警 |
TX power low warning(channel x) |
通道x发送光功率低预警 |
TX bias high(channel x) |
通道x的偏置电流高 |
TX bias low(channel x) |
通道x的偏置电流低 |
模块读写错误 |
模块信息校验和错误 |
Transceiver type and port configuration mismatched |
模块类型和端口配置不匹配 |
Transceiver type not supported |
端口不支持该类型的模块 |
表1-26 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked |
发送Jitter PLL失锁 |
TX CMU unlocked |
发送CMU失锁 |
Overloaded |
负载过大 |
Loss of REFCLK input |
缺乏参考时钟 |
Channel signals out of alignment |
主机通道信号不对齐 |
PLD or flash initialization error |
初始化错误 |
Power supply fault |
电源错误 |
CFP checksum error |
校验和错误 |
TX bias high |
偏置电流高 |
TX bias low |
偏置电流低 |
Temp high |
温度高 |
Temp low |
温度低 |
Voltage high |
电压高 |
Voltage low |
电压低 |
RX signal loss in channel x |
通道x接收到的信号丢失 |
RX IC unlocked in channel x |
通道x接收到的IC时钟失锁 |
RX FIFO error in channel x |
通道x接收到FIFO错误 |
TX signal loss in channel x |
通道x发送的信号丢失 |
TX IC unlocked in channel x |
通道x发送的IC时钟失锁 |
TX FIFO error in channel x |
主机通道x的发送FIFO出错 |
主机通道x发送的IC时钟失锁 |
APD supply fault in channel x |
通道x出现APD错误 |
TEC fault in channel x |
通道x出现TEC错误 |
Wavelength unlocked in channel x |
通道x的光信号波长失锁 |
RX power high in lane x |
通道x接收到的光的功率太高 |
RX power low in lane x |
通道x接收到的光的功率太低 |
TX power high in lane x |
通道x发送的光的功率太高 |
TX power low in lane x |
通道x发送的光的功率太低 |
TX bias high in lane x |
通道x的偏置电流高 |
TX bias low in lane x |
通道x的偏置电流低 |
Temp high in lane x |
通道x的温度高 |
Temp low in lane x |
通道x的温度低 |
模块读写错误 |
模块信息校验和错误 |
模块类型和端口配置不匹配 |
端口不支持该类型的模块 |
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface fortygige 1/0/1
FortyGigE1/0/1 transceiver current alarm information:
RX loss of signal
RX power low
表1-27 display transceiver alarm显示信息描述表
transceiver current alarm information |
接口光模块当前故障告警信息 |
RX loss of signal |
接收信号丢失 |
RX power low |
接收光功率低告警 |
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
对于插入非H3C光模块的接口,将无法通过该命令显示光模块的数字诊断参数的当前测量值。
# 显示接口FortyGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface fortygige 1/0/1
FortyGigE1/0/1 transceiver diagnostic information:
Temp.(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp.(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Warning thresholds:
Temp(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 45 3.25 1.25 -15.00 4.00
Low 25 2.85 0.85 -25.00 1.00
# 显示接口HundredGigE1/0/49上插入的QSFP28可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface hundredgige 1/0/49
HundredGigE1/0/49 transceiver diagnostic information:
[module] Temp.(C) Voltage(V) Total RX power(dBm) Total TX power(dBm)
38 3.32 8.35 7.68
[channel] Bias(mA) RX power(dBm) TX power(dBm)
1 41.32 2.35 1.90
2 40.54 1.85 1.85
3 40.85 2.23 1.22
4 40.90 2.85 1.65
Alarm thresholds:
High 75 3.63 55.00 5.50 7.50
Low -5 2.97 25.00 -9.60 -8.30
Warning thresholds:
High 70 3.47 50.00 4.50 4.50
Low 0 3.13 30.00 -8.60 -4.30
表1-28 display transceiver diagnosis显示信息描述表
transceiver diagnostic information |
接口插入的光模块的数字诊断信息 |
Current diagnostic parameters |
当前的诊断参数 |
Wave.er(nm) |
波长偏移,单位为nm,精确到0.001nm。仅SFP-XG-LH80-Tunable光模块支持显示该字段 |
Freq.er(GHz) |
频率偏移,单位为GHZ,精确到0.1GHZ。仅SFP-XG-LH80-Tunable光模块支持显示该字段 |
Temp.(C) |
数字诊断参数——温度,单位为°C,精确到1°C |
Voltage(V) |
数字诊断参数——电压,单位为V,精确到0.01V |
Bias(mA) |
数字诊断参数——偏置电流,单位为mA,精确到0.01mA |
Total RX power(dBm) |
数字诊断参数——总接收光功率,单位为dBm,精确到0.01dBm |
Total TX power(dBm) |
数字诊断参数——总发送光功率,单位为dBm,精确到0.01dBm |
RX power(dBm) |
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm |
TX power(dBm) |
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm |
Alarm thresholds |
告警门限 |
High |
高告警门限或高预警门限 |
Low |
低告警门限或高预警门限 |
Warning threshold |
预警门限 |
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface fortygige 1/0/1
显示信息略……。
display transceiver itu-channel命令用来显示光模块的ITU通道信息。
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface:显示接口上插入的光模块当前使用的ITU通道的信息。
interface-type interface-number:显示指定光模块当前使用的ITU通道的信息。interface-type interface-number表示接口类型和接口编号。不指定该参数时,表示所有接口上光模块当前使用的ITU通道的信息。
supported-channel:仅显示接口支持配置的ITU通道的信息。不指定该参数时,仅显示光模块当前使用的ITU通道的信息。
本命令仅SFP-XG-LH80-Tunable光模块支持。
# 显示GigabitEthernet1/0/1上插入的光模块当前使用的ITU通道的信息。
<Sysname> display transceiver itu-channel interface gigabitethernet 1/0/1
Interface Channel WaveLength(nm) Frequency(THz)
GE1/0/1 1 1566.72 191.35
# 显示GigabitEthernet1/0/1上插入的光模块支持配置的ITU通道的信息。
<Sysname> display transceiver itu-channel interface gigabitethernet 1/0/1 supported-channel
ITU channel settings supported on Ten-GigabitEthernet1/0/1 :
1 1566.72 191.35
2 1566.31 191.40
3 1565.90 191.45
4 1565.50 191.50
5 1565.09 191.55
6 1564.68 191.60
7 1564.27 191.65
8 1563.86 191.70
其它显示信息略……。
表1-29 display transceiver itu-channel interface命令显示信息描述表
光模块所在接口的简称 |
Channel |
ITU通道编号 |
WaveLength(nm) |
通道编号对应的波长,单位为nm,精确到0.01nm。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有: · 该接口上未插入光模块 · 该接口上光模块不支持配置ITU通道编号 · 光模块获取ITU通道信息失败 · 设备不支持光模块上当前存储的ITU通道编号 |
Frequency(THz) |
通道编号对应的频率,单位为THZ,精确到0.01THZ。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有: · 该接口上未插入光模块 · 该接口上光模块不支持配置ITU通道编号 · 光模块获取ITU通道信息失败 · 设备不支持光模块上当前存储的ITU通道编号 |
· itu-channel
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface fortygige 1/0/1 1/0/1
显示信息略……。
display transceiver status命令用来显示可插拔光模块的状态信息。
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的状态信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
当设备端口上的可插拔模块出异常时,可使用本命令查看光模块的状态信息,例如光模块是否发生过复位、光模块的功耗模式、光模块当前各通道的发光情况等。
仅可插拔SFP和QSFP系列光模块支持本命令。
# 显示接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块的状态信息。
<Sysname> display transceiver status interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver status information:
Initialization Complete Flag : Finish
Power Mode : High
Lane Tx Disable Tx CDR Rx CDR
Lane1 Yes ON OFF
Lane2 Yes ON OFF
Lane3 Yes ON OFF
Lane4 Yes ON OFF
表1-30 QSFP系列光模块display transceiver status命令显示信息描述表
interface-name transceiver status information |
接口interface-name上插入的可插拔QSFP光模块的状态信息 |
Initialization Complete Flag |
光模块是否完成初始化,取值为: · Finish:表示已完成初始化 · Unkown:表示未检测到初始化状态 |
Power Mode |
光模块当前处于的功耗模式,取值为: · High:表示模块当前处于高功耗模式 · Low:表示模块当前处于低功耗模式 |
Tx Disable |
是否允许光模块的光通道发送报文,取值为: · Yes:表示处于关闭状态 · No:表示处于开启状态 |
Tx CDR |
光模块发送侧时钟和数据恢复功能开启/关闭状态,取值为: · On:表示开启CDR功能 · Off:表示关闭CDR功能 |
Rx CDR |
光模块接收侧时钟和数据恢复功能开启/关闭状态,取值为: · On:表示开启CDR功能 · Off:表示关闭CDR功能 |
Lane |
光通道的编号 |
# 显示接口Ten-FortyGigE1/0/1上插入的可插拔SFP系列模块的状态信息。
<Sysname> display transceiver status interface ten-fortygige 1/0/1
Ten-FortyGigE1/0/1 transceiver status information:
Hardware Tx Disable : YES
表1-31 SFP系列模块display transceiver status 命令显示信息描述表
接口interface-name上插入的可插拔SFP光模块的状态信息 |
Hardware Tx Disable |
通过硬件管脚设置是否允许光模块的光通道发送报文,取值为: · Yes:表示处于关闭状态 · No:表示处于开启状态 |
· reset transceiver interface
· transceiver cdr
· transceiver lane enable
· transceiver power-mode
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
H3C Comware Software, Version 7.1.070, Alpha 7021
H3C S12510-X uptime is 0 weeks, 1 day, 8 hours, 46 minutes
Last reboot reason : Cold reboot
Boot image: flash:/s12500x-cmw710-boot-a7021.bin
Boot image version: 7.1.070P21, Alpha 7021
Compiled Jun 15 2017 16:00:00
System image: flash:/s12500x-cmw710-system-a7021.bin
System image version: 7.1.070, Alpha 7021
显示信息略……。
表1-32 display version命令显示信息描述表
H3C Comware Software, Version 7.1.070, Alpha 7021 |
表示设备使用的软件版本 |
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved. |
表示设备的版权申明 |
H3C S12510-X uptime is 0 weeks, 1 day, 8 hours, 46 minutes |
表示设备的型号以及本次启动后的持续运行时间 |
Last reboot reason |
表示设备上次重启的原因,主要取值有: · User reboot:表示用户通过命令行、SNMP等方式重启设备 · Cold reboot:表示断电导致的重启 · Kernel abnormality reboot:表示内核异常导致的重启 · DeadLoop reboot:表示内核死循环导致的重启 · DEV HandShake reboot:表示设备管理握手失败导致的重启 · SlaveSwitch reboot:表示主备倒换导致的重启 · IRF Merge reboot:表示IRF合并重启本设备 · Auto Update reboot:表示版本自动升级导致的重启 · Memory exhaust reboot:表示单板内存耗尽导致的重启 |
Boot image: flash:/s12500x-cmw710-boot-a7021.bin Boot image version: 7.1.070P21, Alpha 7021 Compiled Jun 15 2017 16:00:00 |
表示设备当前运行过程中使用的Boot包以及该软件包的版本、编译时间 |
display version-update-record命令用来显示启动软件包版本更新操作的记录。
仅缺省MDC支持本命令。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2015 at 06:23:54):
*Name : boot-test.bin
Version : 7.1.070 Test 0001
Compile time: Mar 25 2015 15:52:43
*Name : system-test.bin
表1-33 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54) |
最近的第n次更新的时间,Record 1为最新的一次更新 |
*Name |
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化 |
Version |
软件包的版本号 |
Compile time |
版本编译时间 |
· reset version-update-record
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
当系统检测到器件(chip)、单板(board)和转发(forwarding)的硬件故障时,修复操作均为reset。
board:对单板故障进行在线检测,包括控制通道检测和单板状态快速检测。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动关闭端口、隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,不会修复故障。
仅缺省MDC支持本命令。
设备启动后,系统会持续自动检测器件、单板和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
hardware-failure-protection aggregation命令用来开启针对聚合组的硬件故障保护功能。
undo hardware-failure-protection aggregation命令用来关闭针对聚合组的硬件故障保护功能。
针对聚合组的硬件故障保护功能处于关闭状态。
只有配置hardware-failure-detection forwarding isolate命令后,该命令才生效。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对聚合组中的该成员端口失效:
· 端口下配置了以太网接口环回测试功能,即loopback { external | internal }命令;
· 端口下配置了以太网接口的强制开启功能,即port up-mode命令;
· 该端口配置为IRF物理端口。
仅缺省MDC支持本命令。
# 开启针对聚合组的硬件故障保护功能。
[Sysname] hardware-failure-protection aggregation
· hardware-failure-detection
hardware-resource board-mixed命令用来开启或关闭HA单板和非HA单板混合工作模式。
hardware-resource board-mixed { enable | disable }
HA单板和非HA单板混合工作模式处于关闭状态。
enable:开启HA单板和非HA单板混合工作模式。
disable:关闭HA单板和非HA单板混合工作模式。
如果设备上安装了HA单板和非HA单板,那么它们只能在开启HA单板和非HA单板混合工作模式的情况下,才能正常工作。
配置该命令后需要保存配置并重启才能生效。
# 开启HA单板和非HA单板混合工作模式。
[Sysname] hardware-resource board-mixed enable
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and reboot the system to make it effective.
hardware-resource multicast-vlan命令用来VLAN组播匹配模式的开启和关闭。
仅R2825及以上版本支持本命令。
hardware-resource multicast-vlan { enable | disable }
缺省情况下,VLAN组播匹配模式为关闭状态。
enabel:设置VLAN组播匹配模式为开启状态。
disable:设置VLAN组播匹配模式为关闭状态。
仅缺省MDC支持本命令。
基于VLAN的组播报文匹配模式开启后,系统会自动为每个开启IGMP侦听的VLAN创建一个内部ACL,导致ACL资源减少。正常情况下,建议关闭此模式。
#将VLAN组播匹配模式设置为关闭状态。
[Sysname] hardware-resource multicast-vlan disable
hardware-resource parser命令用来配置设备对报文解析的处理模式。
undo hardware-resource parser命令用来恢复缺省情况。
hardware-resource parser { normal | network-tap }
设备对报文解析的处理模式为普通模式。
normal:表示普通模式。
network-tap:表示分流器模式。
本命令配置后,请先保存当前配置,并重启设备,以确保修改后的模式生效。
配置报文解析的处理模式为分流器模式后,会影响原有聚合hash、ECMP hash、重定向、VLAN映射等功能,请用户谨慎使用。
# 配置设备进行报文解析的处理模式为分流器模式。
[Sysname] hardware-resource parser network-tap
· display hardware-resource parser
hardware-resource route-async命令用来控制路由异步任务的开启和关闭。
hardware-resource route-async { enable | disable }
缺省情况下,路由异步任务为开启状态。
enabel:设置路由异步任务为开启状态。
disable:设置路由异步任务为关闭状态。
仅缺省MDC支持本命令。
使用该命令修改路由异步任务的工作模式后,不需要重启设备,设备即可按最新配置的模式进行工作。
#将路由异步任务设置为关闭状态。
[Sysname] hardware-resource route-async disable
hardware-resource tcam命令用来配置TCAM的运行模式。
undo hardware-resource tcam命令用来恢复缺省情况。
hardware-resource tcam { acl | ipv6 | mix | normal | routing }
TCAM的运行模式为路由模式。
acl:表示ACL模式。
ipv6:表示IPv6模式。
mix:表示Mix模式。
normal:表示普通模式。
routing:表示路由模式。
仅缺省MDC支持本命令。
本命令仅对HF单板生效。
切换TCAM的运行模式后,请先将当前配置保存到下次启动配置文件,再删除下次启动配置文件对应的二进制文件(后缀为.mdb的文件),最后重启设备,以确保修改后的运行模式生效。
HF单板支持的TCAM模式请参见表1-34。
表1-34 HF单板TCAM模式对存储资源分配的说明
TCAM模式 |
HF单板 |
ACL模式(acl) |
系统将HF单板的TCAM仅分配给IPv4 ACL表项,可以扩大IPv4 ACL表项的规模 |
IPv6模式(ipv6) |
与routing模式相同,此时系统将HF单板的TCAM仅分配给ARP、ND、IPv4和IPv6路由表项,可以扩大ARP、ND、IPv4和IPv6路由表项的规模 |
MIX模式(mix) |
系统将HF单板的TCAM仅分配给IPv4 ACL、ARP、ND、IPv4和IPv6路由表项,可以扩大IPv4 ACL、ARP、ND、IPv4和IPv6路由表项的规模 |
普通模式(normal) |
系统不使用HF单板的TCAM |
路由模式(routing) |
# 将TCAM的运行模式配置为路由模式。
[Sysname] hardware-resource tcam routing
hardware-resource uni命令用来配置UNI的运行模式。
undo hardware-resource uni命令用来恢复缺省情况。
hardware-resource uni { normal | enhance-uni | ultra-uni }
UNI的运行模式为normal模式。
normal:普通模式,此时系统的UNI模式,MAC地址高44bit相同的IPv4 ARP表项共享一条硬件资源,MAC地址完全相同的IPv6 ND表项共享一条硬件资源。ARP和ND直接无资源共享。
enahnce-uni:增强模式,此时系统的UNI模式,MAC地址完全相同的IPv4 ARP表项共享一条硬件资源,MAC地址完全相同的IPv6 ND表项共享一条硬件资源,MAC地址完全相同的ARP和ND表项直接也能共享硬件资源。
ultra-uni:超强模式,只能在带外扩FPGA的HF单板使用,此时系统的UNI模式,MAC地址高44bit相同的IPv4 ARP表项共享一条硬件资源;MAC地址高44bit相同的IPv6 ND表项共享一条硬件资源;MAC地址高44bit相同的ARP和ND表项直接也能共享硬件资源。
本命令的超强模式仅对HF单板生效。
仅缺省MDC支持本命令。
命令下发立即生效,为避免重启后配置丢失,切换UNI的工作模式后,请先将当前配置保存到下次启动配置文件,再删除下次启动配置文件对应的二进制文件(后缀为.mdb的文件),最后重启设备,以确保修改后的运行模式生效。
# 将UNI的运行模式配置为增强模式。
[Sysname] hardware-resource uni enhance-uni
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
itu-channel命令用来配置光模块的ITU通道编号。
undo itu-channel命令用来恢复缺省情况。
itu-channel channel-number
undo itu-channel
光模块的ITU通道编号为1。
以太网接口视图
channel-number:表示光模块的ITU通道编号。
配置该命令后,设备会将ITU通道编号保存在光模块内部的寄存器中,不会保存到配置文件中。
# 将Ten-GigabitEthernet1/0/1上插入的光模块的ITU通道编号配置为2。
[Sysname-Ten-GigabitEthernet1/0/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
· display transceiver itu-channel
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
· scheduler job
· scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
一级告警门限为256MB,二级告警门限为192MB,三级告警门限为128MB,系统恢复到正常的内存门限为320MB,预告警门限为384MB,预告警解除门限为448MB。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
secure secure-value:预警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
仅缺省MDC支持本命令。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备监控的是系统内存中剩余空闲内存的大小,使用display memory命令可以查看系统内存的使用情况。
除了一级、二级、三级告警,设备还支持预警功能。预警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预警恢复门限用于解除预警。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
· display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
仅R2830及以上版本支持命令。
(独立运行模式)
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value
undo memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
DMA内存告警阈值为2048KB。
视图】
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB,取值范围0~3145728。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小:当DMA空闲内存小于或等于告警阈值,产生告警事件,表示DMA内存可能不足。
若配置的告警阈值大于前可用的空闲内存,业务板将重启,此时命令行设置实际生效,但会提示“Failed to set DMA memory threshold”,此为正常现象忽略即可。
# 配置Slot 1的DMA内存告警阈值为32KB(独立运行模式)
[Sysname] memory-threshold dma slot 1 critical 32
· display memory-threshold dma
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
仅缺省MDC支持本命令。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
(独立运行模式)
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
· display cpu-usage configuration
· display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
(独立运行模式)
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
(独立运行模式)
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | chassis chassis-number slot slot-number cpu cpu-number [ core core-id-list ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | chassis chassis-number slot slot-number cpu cpu-number [ core core-id-list ] }
CPU利用率高级别告警门限为99%,低级别告警门限为80%,恢复门限为60%。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
core core-id-list:表示CPU核的编号列表。表示方式为core-id-list = { core-id1 [ to core-id2 ] }&<1-10>,core-id2的值要大于或等于core-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,低级别告警门限为80%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor disable-port命令用于全局开启Port Down功能。
undo monitor disable-port命令用于全局关闭Port Down功能。
monitor { handshake-timeout | fab-absent } disable-port
undo monitor { handshake-timeout | fab-absent } disable-port
缺省情况下,Port Down功能处于开启状态。
handshake-timeout:检测主控板与业务板连接状态,当连接超时时关闭所有业务口。
fab-absent:检测网板状态,当网板不在位时关闭所有业务口。
本功能常用于以主备方式提供网络可靠性的双机环境中(例如VRRP)。开启本功能后,当主设备的主控板与业务板连接超时或网板不在位时,系统将立即关闭主设备上的所有业务口,使业务快速切换到备用设备上。
# 开启检测主控板与业务板连接状态的Port Down功能。
[Sysname] monitor handshake-timeout disable-port
Set successful!
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。(独立运行模式)
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
执行undo monitor resend memory-threshold命令并不指定critical-interval、early-warning-interval、minor-interval和severe-interval参数时,表示将这些参数均恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。(独立运行模式)
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查错误日志记录功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查错误日志记录功能。
对于Release 2825之前的版本,软硬件表项一致性检查错误日志记录功能处于关闭状态;
对于Release 2825及之后的版本,软硬件表项一致性检查错误日志记录功能处于开启状态。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,如果检测到这两个表项不一致,则可以生成日志提醒用户。
# 开启软硬件表项一致性检查错误日志记录功能。
[Sysname] parity-error consistency-check log enable
· parity-error consistency-check threshold
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查错误次数的告警门限。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查错误次数的告警门限为10次。
value:表示软硬件表项一致性检查错误次数的告警门限,取值范围为1~2147483647,单位为次数。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,如果设备在发送周期内产生软硬件表项一致性检查错误的次数达到配置的告警门限,则发送日志提醒用户。
# 配置软硬件表项一致性检查错误次数的告警门限为20次。
[Sysname] parity-error consistency-check threshold 20
· parity-error consistency-check log enable
parity-error monitor log enable命令用来开启奇偶校验错误日志功能。
undo parity-error monitor log enable命令用来关闭奇偶校验错误日志功能。
· 对于R2825之前的版本,奇偶校验错误日志功能处于关闭状态。
· 对于R2825及以上版本,奇偶校验错误日志功能处于开启状态。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,当设备奇偶校验错误时,设备可以生成日志记录奇偶校验错误的详细信息。
# 配置开启奇偶校验错误日志功能。
[Sysname] parity-error monitor log enable
· parity-error monitor period
· parity-error monitor threshold
parity-error monitor period命令用来配置奇偶校验错误的日志发送周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period value
对于Release 2825之前的版本,奇偶校验错误的日志发送周期为60秒;
对于Release 2825及之后的版本,奇偶校验错误的日志发送周期为600秒。
value:表示奇偶校验错误的日志发送周期,取值范围为1~86400,单位为秒。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,设备会按周期收集奇偶校验错误发生的次数。
# 配置奇偶校验错误的日志发送周期为120秒。
[Sysname] parity-error monitor period 120
· parity-error monitor log enable
parity-error monitor threshold命令用来配置奇偶校验错误次数的告警门限。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
· 对于R2825之前的版本,缺省情况下,奇奇偶校验错误次数的告警门限为5000次。
· 对于R2825及以上版本,缺省情况下,奇偶校验错误次数的告警门限为20000次。
value:表示奇偶校验错误次数的告警门限,取值范围为1~1000000,单位为次数。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,如果设备在日志发送周期内发生奇偶校验错误的次数大于配置的告警门限,则发送日志提示用户。
# 配置奇偶校验错误次数的告警门限为8000次。
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
· parity-error unrecoverable period
· parity-error unrecoverable reboot
· parity-error unrecoverable threshold
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为600秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
· parity-error unrecoverable log enable
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启。
如果单板转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使单板通过重启来恢复关键硬件表项。
配置本命令后,当单板生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
# 开启生成关键硬件表项不可恢复日志信息后单板的自动重启功能。
[Sysname] parity-error unrecoverable reboot
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~1000000,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
仅缺省MDC支持本命令。
清除认证密码的操作必须在主用主控板的启动过程中进入BootWare菜单进行。(独立运行模式)(IRF模式)
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
power-exception-monitor命令用来配置电源模块的监控模式。
power-exception-monitor { normal | enhanced }
电源模块的监控模式为normal模式。
normal:电源模块故障后,打印状态告警信息。
enhanced:持续对电源模块进行监控,一旦监控到温度、电压或电流等异常情况,即打印状态告警信息。
配置电源模块的监控模式为enhanced时,将会占用一定系统的资源。
# 配置电源模块的监控模式为normal模式。
[Sysname] power-exception-monitor normal
power-monitor enable命令用来开启单板上下电管理功能。
undo power-monitor enable命令用来关闭单板上下电管理功能。
(独立运行模式)
power-monitor enable chassis chassis-number
undo power-monitor enable chassis chassis-number
单板上下电管理功能处于开启状态。
单板上下电管理功能处于开启状态时,系统会对单板的上下电进行管理。例如:
· 通过检测系统总功率的大小,单板功率的分配情况等,判断是否上电单板。
· 通过检测单板的温度情况,风扇情况等,判断是否下电单板。
关闭单板上下电管理功能后,系统将不再对单板的上下电进行管理,默认使所有单板上电,同时无法控制单板下电。
关闭单板上下电管理功能将会带来不可预知的风险,请谨慎执行。
# 开启单板上下电管理功能。
[Sysname] power-monitor enable
power-supply off命令用来强制给单板断电。
(独立运行模式)
power-supply off slot slot-number
power-supply off chassis chassis-number slot slot-number
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
强制给单板下电后,单板将无法收发报文,请谨慎使用。
仅缺省MDC支持本命令。
如果设备电量不足,且某些接口板处于空闲状态或者连接的为非关键网络节点时,可以手工停止给这些接口板供电,以便节约电能保证给重要接口板供电。
请先开启电源管理功能,再配置本命令。否则,本命令配置失败。
在IRF中,当最后一个处于up状态的IRF物理端口都位于某接口板上时,不允许强制给该接口板断电,以免导致IRF分裂。(IRF模式)
# 强制给指定slot的单板断电。(独立运行模式)
<Sysname> power-supply off slot 2
· power-supply policy enable
power-supply on命令用来手工给单板供电。
(独立运行模式)
power-supply on slot slot-number
power-supply on chassis chassis-number slot slot-number
仅缺省MDC支持本命令。
# 手工给指定slot的单板供电。(独立运行模式)
<Sysname> power-supply on slot 2
power-supply policy enable命令用来开启电源管理功能。
undo power-supply policy enable命令用来关闭电源管理功能。
(独立运行模式)
power-supply policy chassis chassis-number enable
undo power-supply policy chassis chassis-number enable
电源管理功能处于开启状态。
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
仅缺省MDC支持本命令。
# 启用电源管理功能。(独立运行模式)
[Sysname] power-supply policy enable
power-supply policy redundant命令用来配置冗余电源模块数。
undo power-supply policy redundant命令用来恢复缺省情况。
(独立运行模式)
power-supply policy redundant module-count
power-supply policy chassis chassis-number redundant module-count
undo power-supply policy chassis chassis-number redundant
冗余电源模块数量的值为0。
module-count:表示冗余电源模块数目,不同型号的设备支持的取值范围不同,用户可以通过帮助信息来获取设备支持的取值范围,但是该范围的上限是系统支持的最大冗余模块数,根据设备安插的接口板的数量和耗电量不同,用户实际能够配置的值会小于等于系统支持的最大冗余模块数。
仅缺省MDC支持本命令。
只有在开启电源管理功能后,冗余电源配置才会生效。
# 配置电源冗余模块数为1。(独立运行模式)
[Sysname] power-supply policy redundant 1
power-supply surplus-power enable命令用来开启电源睡眠功能。
undo power-supply surplus-power enable命令用来关闭电源睡眠功能。
仅适配PSR2400-54A、PSR2400-54D或PSR3000-54A电源模块的交换机支持开启电源睡眠功能。
只有使用power-supply policy enable命令开启电源管理功能后,开启电源睡眠功能的配置才能生效。
处于睡眠状态的电源模块无法提供冗余备份功能,若正常工作的电源模块突然故障或被拔出,可能会影响设备正常运行。用户可通过display power命令查看电源模块的工作状态。
开启电源睡眠功能后,系统会根据设备当前的实际功耗,智能控制电源模块进入或者退出睡眠状态,降低能耗:
· 当系统剩余功率大于单个电源模块输入功率时,将其设置为睡眠模式并关断输出。
· 当系统剩余功率不足时,唤醒睡眠中的电源模块。
# 开启电源睡眠功能
[Sysname] power-supply surplus-power enable
reboot命令用来重启设备。
(独立运行模式)
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启成员设备。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启整个设备。(独立运行模式)
force:强制重启:
· 不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
· 指定该参数时,系统将不进行任何检查,直接执行重启操作。
· 重新启动可能会导致业务中断,请谨慎使用该命令。
· 使用force参数时,系统在重启时不会做任何保护性措施。重启后,可能导致文件系统损坏,请谨慎使用该参数。建议在系统故障或无法正常重启时,才使用该参数。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(独立运行模式)
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。(独立运行模式)
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
· display system stable state
reset asset-info命令用来清除设备的用户资产信息。使用该命令,用户可以清除设备机框、单板、风扇框或电源模块的资产信息。
(独立运行模式)
reset asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
reset asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
chassis:清除设备机框的用户资产信息。
fan fan-id:清除指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号,取值范围为1~6。
power power-id:清除指定电源模块的用户资产信息。power-id表示设备上电源模块的编号,取值范围为1~16。
slot slot-number:清除指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:清除资产编号信息。
custom:清除用户自定义的资产信息。
department:清除资产的归属部门信息。
description:清除资产的描述信息。
service-date:清除资产的启用时间信息。
state:清除资产的使用状态信息。
chassis chassis-number:清除指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
当用户希望清除设备机框、单板或风扇框的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,清除的是该设备机框、单板或风扇框的所有用户资产信息。
使用该命令清除指定风扇框或者电源模块的资产信息时,如果设备上无对应编号的风扇框或者电源模块,将返回风扇框或者电源模块不在位的提示信息。
# 清除设备上0号单板的资产编号信息。(独立运行模式)
[Sysname] reset asset-info slot 0 csn
· display asset-info
· set asset-info
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
仅缺省MDC支持本命令。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
· display scheduler logfile
reset transceiver interface命令用来通过软件复位可插拔QSFP系列光模块。
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number:表示接口类型和接口编号。不指定该参数时,表示所有接口。
当光模块工作异常时,可以通过软件复位光模块来尝试修复光模块。正常情况下,不建议配置。
执行本命令会重启光模块,请谨慎使用。
# 通过软件复位接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块。
<Sysname> reset transceiver interface hundredgige 1/0/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
仅缺省MDC支持本命令。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
· display version-update-record
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
仅缺省MDC支持本命令。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
· 开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
· 关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
· display resource-monitor
· resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
仅缺省MDC支持本命令。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
· NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
· 信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
· SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
(独立运行模式)
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number by-percent minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见下表。
表1-35 设备可监测的资源描述表
取值 |
含义 |
ac |
VXLAN服务实例资源 |
agg_group |
聚合组资源 |
arp |
ARP表项资源 |
arp_encap |
出方向封装表资源 |
ecmp_fec_1 |
一级ECMP FEC资源 |
ecmp_fec_2 |
级联的ECMP FEC资源 |
global_ecmp |
全局等价路由组资源 |
global_fec_1 |
一级全局转发等价类资源 |
global_fec_2 |
级联的二级全局转发等价类资源 |
lem |
精确匹配路由表项资源 |
local_ecmp |
本地等价路由组资源 |
local_fec_1 |
一级本地转发等价类资源 |
local_fec_2 |
级联的二级本地转发等价类资源 |
mac |
MAC地址表项资源 |
mc |
二层和三层组播资源 |
mqcin |
入方向MQC资源 |
mqcout |
出方向MQC资源 |
nd |
ND表项资源 |
openflow |
OpenFlow资源 |
pbr |
PBR资源 |
pfilterin |
入方向包过滤资源 |
pfilterout |
出方向包过滤资源 |
route |
路由表项资源 |
rport |
三层以太网接口资源 |
subrport |
三层以太网子接口资源 |
vlaninterface |
VLAN接口资源 |
vrf |
VPN实例资源 |
vsi |
VSI(Virtual Switch Instance,虚拟交换实例)资源 |
vsiintf |
VSI接口资源 |
slot slot-number:表示监测指定单板上的资源。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示监测指定单板上的资源。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
仅缺省MDC支持本命令。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。(独立运行模式)
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restart standby命令用来重启备用主控板。
restart standby
仅独立运行模式下支持本命令。
仅缺省MDC支持本命令。
执行本命令效果等同于执行reboot slot slot-number(slot-number指定为备用主控板所在的槽位号)。因为无需指定slot参数,所以,使用起来比reboot命令更加便捷。
# 重启备用主控板。
[Sysname] restart standby
Rebooting the standby MPU. Continue?[Y/N]:y
The standby MPU is rebooting. Please wait...
· reboot
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
仅缺省MDC支持本命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
使用本命令可能会导致License文件丢失,即设备已安装授权不可用,请谨慎使用。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
· reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
· command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· YYYY的取值范围为2000~2035;
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
· 配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
· 配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
· 使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1) 使用scheduler job命令创建Job。
(2) 在Job视图下,使用command命令配置需要执行的命令。
(3) 使用scheduler schedule命令创建Schedule。
(4) 在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5) 在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6) 在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
· job
· time at
· time once
set asset-info命令用来设置设备的用户资产信息。使用该命令,用户可以根据自定义的规则为设备机框、单板、风扇框及电源模块设置资产信息。
(独立运行模式)
set asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
set asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
fan fan-id:设置指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号,取值范围为1~6。
power power-id:设置指定电源模块的用户资产信息。power-id表示设备上电源模块的编号,取值范围为1~16。
slot slot-number:设置指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn csn-number:设置资产编号信息。csn-number表示用户设置的资产编号信息,取值范围为1~62字节的字符串。
custom name value:设置用户自定义的资产信息。name表示用户自定义的资产信息名称,value表示用户设置的资产信息内容,为1~62字节的字符串。
department department:设置资产的归属部门信息。department表示用户设置的资产归属部门,为1~62字节的字符串。
description description:设置资产的描述信息。description表示用户设置的资产描述信息,为1~62字节的字符串。
location location:设置资产的位置信息。location表示用户设置的资产位置信息,为1~62字节的字符串。
service-date date:设置资产的启用时间信息。date表示用户设置的资产启用时间,为1~25字节的字符串。
state state:设置资产的使用状态信息。state表示用户设置的资产使用状态,为1~62字节的字符串。
chassis chassis-number:设置指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
使用该命令设置指定风扇框或者电源模块的资产信息时,如果设备上无对应编号的风扇框或者电源模块,将返回风扇框或者电源模块不在位的提示信息。
# 设置设备上0号单板的资产编号为123456。(独立运行模式)
[Sysname] set asset-info slot 0 csn 123456
· reset asset-info
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个检测端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
switch-fabric isolate命令用来将网板从转发平面隔离出去,所有数据流量都不经过指定网板。
undo switch-fabric isolate命令用来取消对网板的隔离。
(独立运行模式)
switch-fabric isolate slot slot-number [ channel channel-number ]
undo switch-fabric isolate slot slot-number [ channel channel-number ]
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
undo switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
网板处于转发平面,数据流量会经过网板进行转发。
slot slot-number:表示网板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定网板。(IRF模式)
channel channel-number:表示网板上数据通道的编号。不指定该参数时,表示隔离指定网板。
· 每块网板都有一定的转发带宽,隔离一块网板后会减少相应的转发带宽,使设备整体转发带宽降低。请根据需要配置。
· 当设备上仅存在一块网板时,请不要隔离该网板。
本命令不支持对主控板进行隔离。
该命令主要用于定位网板是否能够正常转发,以及更换网板前,为避免报文丢失,可配置本命令。网板隔离后仍能与主控板正常通信,控制平面上协议报文的解析与协议的计算等功能均不受影响,从而保证取消隔离后可以快速恢复网板的转发能力。
网板隔离期间不要重启设备。
网板隔离后,请使用undo switch-fabric isolate命令对该网板取消隔离,网板才能恢复正常转发功能。
# 将10号槽位的网板隔离。(独立运行模式)
[Sysname] switch-fabric isolate slot 10
The command will isolate the switch fabric from the system. Continue? [Y/N]y
switch-fabric removal-signal-suppression命令用来抑制上报网板中断信号。
undo switch-fabric removal-signal-suppression命令用来恢复缺省情况。
不抑制上报网板中断信号。
配置本命令后,网板拔出时可能会有流量丢包,导致业务中断,请谨慎使用。
正常情况下,网板拔出前,会触发一次中断信号。系统收到中断信号后会将网板的业务迁移到其他网板上,以便网板拔出的时候,不影响当前业务。当硬件故障或者受到信号干扰等异常情况下,网板可能频繁触发中断信号,导致设备需要不停处理该中断信号,甚至异常。为规避这种情况,可以使用本功能强制设备不处理网板中断信号,将影响减到最低。
# 抑制上报网板中断信号。
[Sysname] switch-fabric removal-signal-suppression
switch-linecard isolate命令用来隔离业务板。
(独立运行模式)
switch-linecard isolate slot slot-number
switch-linecard isolate chassis chassis-number slot slot-number
slot slot-number:表示业务板所在的槽位号。
chassis chassis-number :表示设备在IRF中的成员编号。(IRF模式)
重启设备/单板后,如需继续隔离业务版,请重新配置。
当业务板出现故障,需要定位原因,为降低故障影响范围,可先通过本功能隔离故障业务板。处于隔离状态的业务板无法转发数据,用户可通过display device命令查看业务板运行状态,Offline表示单板已处于隔离状态。重启被隔离的业务板即可取消隔离。
# 隔离slot编号为2的业务板。(独立运行模式)
[Sysname] switch-linecard isolate slot 2
display device
sysid命令用来配置设备的网元信息。
undo sysid命令用来恢复缺省情况。
sysid system-id
undo sysid
未配置设备的网元信息。
system-id:表示设备的网元信息,可用于表示设备的位置信息、功能信息、用户自定义的名字标记等。
# 配置网元信息为position-hall,表明设备位置在大厅。
[Sysname] sysid positon-hall
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
system handshake timeout命令用来配置主控板与接口板之间握手的超时时长。
undo system handshake timeout命令用来恢复缺省情况。
system handshake timeout timeout
缺省情况下,主控板与接口板之间握手的超时时长为26秒。
timeout:主控板与接口板之间一次握手的超时时长。取值范围为26~60,单位为秒。
接口板启动完成后,会主动向主控板注册,以便接受主控板的管理。在设备运行期间,主控板会定期向接口板发送握手报文,来确认接口板是否运行正常。如果接口板在本命令设置的握手超时时长内未回复报文,主控板将认为该接口板故障,则会重启该接口板。
在一些对此握手时间有要求的场景(比如板卡重启断流时间要求短的场景),可以通过本命令调整主控板与接口板之间握手的超时时长,实现缩短握手时间,尽早发现接口板故障。
# 配置主控板与接口板之间握手的超时时长为40秒。
[Sysname] system handshake timeout 40
system-working-mode命令用来配置设备的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | bridgee | standard }
设备工作在标准模式。
advance:将设备的工作模式配置为高级模式。
bridgee:将设备的工作模式配置为二层增强模式。
standard:将设备的工作模式配置为标准模式。
仅缺省MDC支持本命令。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,详细描述请参见“基础配置指导”中的“设备管理”。
要使修改的工作模式生效,必须重启设备。
# 将设备工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
(独立运行模式)
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow } sensor-number
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
本命令仅缺省MDC支持。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
· display environment
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
· 使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
transceiver lane cdr命令用来配置可插拔QSFP系列光模块发送通道和接收通道的时钟和数据恢复功能。
undo transceiver lane cdr命令用来恢复缺省情况。
仅Release 2825及以上版本支持本命令。
transceiver lane [ lane-number ] cdr { tx | rx } { on | off }
undo transceiver lane [ lane-number ] cdr { tx | rx }
光模块发送通道和接收通道的时钟和数据恢复功能处于开启状态。
以太网接口视图
lane-number:表示光通道的编号。取值范围为1~4,不指定该参数时,表示所有光通道。
tx:光模块的发送链路。
rx:光模块的接收链路。
on:开启光模块链路的时钟和数据恢复功能。
Off:关闭光模块链路的时钟和数据恢复功能。
使用本命令配置光模块时钟和数据恢复功能,减少信号抖动,会提高光模块传输性能;关闭光模块时钟和数据恢复功能会降低其传输性能。无论开启还是关闭操作,都可能引起设备端口状态震荡。
本命令的配置会保存在光模块内部的寄存器中,不会保存到配置文件中。
仅可插拔QSFP系列光模块支持本命令。
# 开启接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块的Tx CDR功能。
[Sysname-HundredGigE1/0/1] transceiver lane cdr tx on
This command will engage the internal retiming function of transceiver Tx route. Continue? [Y/N]:Y
# 关闭接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块的Rx CDR功能。
[Sysname-HundredGigE1/0/1] transceiver lane cdr rx off
This command will enable an internal bypassing mode of transceiver Rx route, which directs traffic around the internal CDR. Continue? [Y/N]:Y
· display transceiver status
transceiver lane enable命令用来开启可插拔SFP和QSFP系列光模块的光通道。
undo transceiver lane命令用来关闭可插拔SFP和QSFP系列光模块的光通道。
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
光模块的光通道处于开启状态。
以太网接口视图
lane-number:表示光通道的编号,对于SFP系列模块,取值为1;对于QSFP系列模块,取值范围为1~4,不指定该参数时,表示所有光通道。
本命令主要用于调测光模块的功能是否正常,正常情况下,不建议配置。
关闭光通道将导致光模块不能传输信号。
关闭某个光通道将导致该光通道所属的光接口不能传输信号。
# 开启HundredGigE1/0/1上插入的QSFP系列光模块的通道1。
[Sysname-HundredGigE1/0/1] transceiver lane 1 enable
transceiver monitor enable命令用来开启光模块监控功能。
undo transceiver monitor enable命令用来关闭光模块监控功能。
光模块监控功能处于关闭状态。
仅缺省MDC支持本命令。
开启光模块监控功能后,设备会按周期检查光模块的参数(例如光模块的输出功率、输入功率等),当参数的采样值达到软件设定的阈值时,会生成相应的日志提醒用户。
# 使能光模块监控功能。
[Sysname] transceiver monitor enable
· transceiver monitor interval
transceiver monitor interval命令用来配置光模块的监控周期。
undo transceiver monitor interval命令用来恢复缺省情况。
transceiver monitor interval interval
光模块的监控周期是600秒。
interval:表示光模块的监控周期,取值范围为300~3600,单位为秒。
仅缺省MDC支持本命令。
开启光模块监控功能后,本命令才生效。
# 配置光模块监控周期为500秒。
[Sysname] transceiver monitor interval 500
· transceiver monitor enable
transceiver power-mode命令用来配置可插拔QSFP系列光模块的功耗模式。
undo transceiver power-mode命令用来恢复缺省情况。
transceiver power-mode { high | low }
本命令的缺省情况与光模块的型号有关,请以光模块的实际情况为准。
以太网接口视图
通常情况下,光模块处于高功耗工作模式。当光模块长时间不需要工作时,可将光模块切换到低功耗工作模式,节省能耗。低功耗模式下,光模块不能传输信号,如果有流量传输需求,需要手工将光模块调整到高功耗工作模式。
仅可插拔QSFP系列光模块支持本命令。
# 将HundredGigE1/0/1上插入的QSFP系列光模块设置为高功耗模式。
[Sysname-HundredGigE1/0/1] transceiver power-mode high
# 将HundredGigE1/0/1上插入的QSFP系列光模块设置为低功耗模式。
[Sysname-HundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
usb disable命令用来关闭USB接口。
undo usb disable命令用来开启USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
仅缺省MDC支持本命令。
用户可通过USB口进行文件的上传和下载。缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
# 打开USB接口。
[Sysname] undo usb disable
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、mdc-admin、mdc-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
· command
x86-server reboot命令用来重启LSXM1X86SUPE1云主控的X86服务器单元。
(独立运行模式)
x86-server reboot slot slot-number
x86-server reboot chassis chassis-number slot slot-number
本命令仅用于重启LSXM1X86SUPE1云主控的X86服务器单元,如果用户需要重启LSXM1X86SUPE1云主控的交换控制单元需要通过reboot命令。
# 重启指定槽位LSXM1X86SUPE1云主控的X86服务器单元。
<Sysname> X86-server reboot slot 1
Successfully Reboot X86Server.
· reboot
