11-网络管理和监控命令参考
19-信息中心命令
本章节下载 19-信息中心命令  (480.82 KB)
19-信息中心命令
1 信息中心
1.1 信息中心配置命令
1.1.1 diagnostic-logfile save
1.1.2 display diagnostic-logfile summary
1.1.3 display info-center
1.1.4 display info-center filter
1.1.5 display logbuffer
1.1.6 display logbuffer summary
1.1.7 display logfile buffer
1.1.8 display logfile summary
1.1.9 display security-logfile buffer
1.1.10 display security-logfile summary
1.1.11 enable log updown
1.1.12 info-center diagnostic-logfile directory
1.1.13 info-center diagnostic-logfile enable
1.1.14 info-center diagnostic-logfile frequency
1.1.15 info-center diagnostic-logfile quota
1.1.16 info-center enable
1.1.17 info-center filter
1.1.18 info-center format
1.1.19 info-center logbuffer
1.1.20 info-center logbuffer size
1.1.21 info-center logfile alarm-threshold
1.1.22 info-center logfile directory
1.1.23 info-center logfile enable
1.1.24 info-center logfile frequency
1.1.25 info-center logfile size-quota
1.1.26 info-center logging suppress duplicates
1.1.27 info-center logging suppress module
1.1.28 info-center loghost
1.1.29 info-center loghost locate-info with-sn
1.1.30 info-center loghost source
1.1.31 info-center security-logfile alarm-threshold
1.1.32 info-center security-logfile directory
1.1.33 info-center security-logfile enable
1.1.34 info-center security-logfile frequency
1.1.35 info-center security-logfile size-quota
1.1.36 info-center source
1.1.37 info-center synchronous
1.1.38 info-center syslog min-age
1.1.39 info-center syslog trap buffersize
1.1.40 info-center timestamp
1.1.41 info-center timestamp loghost
1.1.42 info-center trace-logfile quota
1.1.43 logfile save
1.1.44 reset logbuffer
1.1.45 security-logfile save
1.1.46 snmp-agent trap enable syslog
1.1.47 terminal debugging
1.1.48 terminal logging level
1.1.49 terminal monitor
1 信息中心
1.1  信息中心配置命令
设备运行于FIPS模式时,本特性部分配置相于非FIPS模式有所变化,具体差异请见本文相描述。有关FIPS模式的详细绍请“安全配置指导”中的“FIPS”。
diagnostic-logfile save命令用来手动将诊断日志文件缓冲区中的内容全部保存到诊断日志文件。
诊断日志文件的保存路径可以通过info-center diagnostic-logfile directory命令配置。
诊断日志文件保存成功后,诊断日志文件缓冲区中的内容会被清空。
如果执行本命令时,诊断日志文件缓冲区中没有日志,本命令会执行成功,但不会创建或更新已有诊断日志文件。
# 手动将诊断日志文件缓冲区中的内容保存到诊断日志文件。
<Sysname> diagnostic-logfile save
The contents in the diagnostic log file buffer have been saved to the file flash:/diagfile/diagfile.log.
·     info-center diagnostic-logfile enable
·     info-center diagnostic-logfile directory
display diagnostic-logfile summary命令用来显示诊断日志文件的配置。
# 显示诊断日志文件配置。
<Sysname> display diagnostic-logfile summary
  Diagnostic log file: Enabled.
  Diagnostic log file size quota: 10 MB
  Diagnostic log file directory: flash:/diagfile
  Writing frequency: 24 hour 0 min 0 sec
表1-1 display logfile summary命令显示信息描述表
Diagnostic log file
诊断日志文件当前的状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
单个诊断日志文件最大能占用的存储空间的大小,单位为MB
诊断日志文件存储的路径
Writing frequency
系统自动保存诊断日志文件的频率
display info-center命令用来显示各个输出方向的信息。
display info-center
# 显示各个输出方向的信息。
<Sysname> display info-center
Information Center: Enabled
Console: Enabled
Monitor: Enabled
Log host: Enabled
    192.168.0.1, log output filter: loghost1,
    port number: 5000, host facility: local7
Log buffer: Enabled
    Max buffer size 1024, current buffer size 512,
    Current messages 0, dropped messages 0, overwritten messages 0
Log file: Enabled
Security log file: Enabled
Information timestamp format:
    Log host: Date
    Other output destination: Date
表1-2 display info-center命令显示信息描述表
Information Center
信息中心当前的状态:
·     Enabled:表示允许输出日志
·     Disabled:表示禁止输出日志
Console
控制台方向当前的状态:
·     Enabled:表示允许向控制台输出日志
·     Disabled:表示禁止向控制台输出日志
Monitor
监视终端方向当前的状态:
·     Enabled:表示允许向监视终端输出日志
·     Disabled:表示禁止向监视终端输出日志
Log host: Enabled
日志主机方向的信息:
·     Enabled:表示允许向日志主机输出日志。允许向日志主机输出日志后,根据用户的配置,还可能显示以下信息:
¡     日志主机的IP地址
¡     关联的日志输出规则名称
¡     日志主机接收日志信息的端口
¡     日志主机的记录工具
·     Disabled:表示禁止向日志主机输出日志
Log buffer: Enabled
日志缓冲区方向的信息,包括开启状态、最大容量、当前容量、当前信息数、已丢弃的信息数、被覆盖的信息数
Log file
日志文件方向当前的状态:
·     Enabled:表示允许向日志文件输出日志
·     Disabled:表示禁止向日志文件输出日志
Security log file
安全日志文件方向当前的状态:
·     Enabled:表示允许向安全日志文件输出日志
·     Disabled:表示禁止向安全日志文件输出日志
    Loghost: Date
信息时间戳配置,包括日志主机输出方向和非日志主机输出方向日志信息的时间戳类型,分为boot、date、iso、none和no-year-date五种
display info-center filter命令用来显示用户创建的日志输出规则。
display info-center filter [ filter-name ]
filter-name:显示指定日志输出规则。filter-name表示日志信息输出规则的名称,必须为设备上已创建的日志输出规则。不指定该参数时,显示所有日志输出规则。
# 显示用户创建的日志输出规则loghost1。
<Sysname> display info-center filter loghost1
 Log output filter: loghost1
 Module                  Mnemonic                          Rule
 ARP                     AA                                Deny
 Default                                                   Informational
表1-3 display info-center filter命令显示信息描述表
Log output filter:
日志输出规则名
Module
输出规则中的模块
Mnemonic
日志助记符的完整内容
Rule
模块对应的输出规则
·     info-center filter
display logbuffer命令用来显示日志缓冲区的状态和日志缓冲区记录的日志信息。
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] * [ last-mins mins ]
reverse:指定日志的显示顺序为从新到旧。如果不指定该参数,将先显示旧日志,最后显示最新的日志。
level severity:显示日志缓存中指定级别日志的信息,severity表示信息级别,取值范围为0~7。不带该参数时将显示系统日志缓冲区内所有级别的日志信息。
表1-4 信息级别列表
数值
信息级别
0
emergency
表示设备不可用的信息,如系统授权已到期
1
alert
表示设备出现重大故障,需要立刻做出反应的信息,如流量超出接口上限
2
critical
表示严重信息,如设备温度已经超过预警值,设备电源、风扇出现故障等
3
error
表示错误信息,如接口链路状态变化等
4
warning
表示警告信息,如接口连接断开,内存耗尽告警等
5
notification
表示正常出现但是重要的信息,如通过终端登录设备,设备重启等
6
informational
表示需要记录的通知信息,如通过命令行输入命令的记录信息,执行ping命令的日志信息等
7
debugging
表示调试过程产生的信息
size buffersize:显示日志缓冲区中指定条数的最新日志。buffersize表示要显示的日志缓冲区中最新的日志信息的条数,取值范围为1~1024。不带该参数时将显示系统日志缓冲区内所有的日志信息。
slot slot-number:显示指定成员设备的日志缓冲区状态及日志缓冲区中记录的日志信息。slot-number表示设备在IRF中的成员编号。如不指定该参数,将显示所有成员设备的日志缓冲区状态及日志缓冲区中记录的日志信息。
last-mins mins:指定显示最近一段时间日志缓冲区状态及日志缓冲区中记录的日志信息,取值范围为1~43200,单位为分钟。不指定该参数时,不对显示信息进行时间过滤。
# 显示系统日志缓冲区的状态和缓冲区记录的日志信息。
<Sysname> display logbuffer
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 718
Current messages: 512
%Jun 17 15:57:09:578 2019 Sysname SYSLOG/7/SYS_RESTART:System restarted --
# 显示最近5分钟的日志缓冲区状态及日志缓冲区中记录的日志信息。
<Sysname> display logbuffer last-mins 5
Log buffer: Enabled
Dropped messages: 0
Overwritten messages: 0
Current messages: 191
%Jan  1 01:00:06:784 2019 Sysname SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.1.242-User=**; Command is display current-configuration
%Jan  1 01:03:19:691 2019 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.33.
%Jan  1 01:03:21:269 2019 Sysname SHELL/6/SHELL_CMD: -Line=vty1-IPAddr=192.168.1.33-User=**; Command is display logbuffer last-mins 5
表1-5 display logbuffer命令显示信息描述表
Log buffer
是否允许输出到日志缓冲区方向:
·     Enabled:表示允许
·     Disabled:表示不允许
Max buffer size
系统允许日志缓冲区可存储的最大信息条数‌
Actual buffer size
当前配置的日志缓冲区可存储的最大信息条数
Dropped messages
被丢弃的信息数(内存分配失败或分配日志缓冲区过小时丢失的信息数)
被覆盖的信息数(如果缓冲区存储空间不足,最早收到的信息数会被新的信息覆盖掉)
Current messages
当前记录的信息数
Failed to obtain  the specified data. The following tries to display all data in the log  buffer.
(和设备内部数据库信息交互异常)获取显示信息失败,下面将尝试显示日志缓冲区中的所有数据
·     info-center logbuffer
·     reset logbuffer
display logbuffer summary命令用来显示系统日志缓冲区的概要信息。
display logbuffer summary [ level severity | slot slot-number ] *
level severity:显示日志缓存中指定级别日志的概要信息,severity表示信息级别,取值范围为0~7,具体内容请参见表1-4。不带该参数时,将显示系统日志缓冲区内所有级别的日志概要信息。
slot slot-number:显示指定成员设备的日志缓冲区的概要信息。slot-number表示设备在IRF中的成员编号。如不指定该参数,将显示所有成员设备上的日志缓冲区概要信息。
# 显示系统日志缓冲区的概要信息。
<Sysname> display logbuffer summary
  Slot EMERG ALERT  CRIT ERROR  WARN NOTIF  INFO DEBUG
     1     0     0     0     7     0    34    38     0
表1-6 display logbuffer summary命令显示信息描述表
EMERG
emergency级别的信息数,请参见表1-4
ALERT
alert级别的信息数,请参见表1-4
CRIT
critical级别的信息数,请参见表1-4
ERROR
error级别的信息数,请参见表1-4
WARN
warning级别的信息数,请参见表1-4
NOTIF
notification级别的信息数,请参见表1-4
INFO
informational级别的信息数,请参见表1-4
DEBUG
debugging级别的信息数,请参见表1-4
display logfile buffer命令用来显示日志文件缓冲区的内容。
日志在保存到日志文件前,会先暂时缓存到日志文件缓冲区。当自动或者手动触发日志保存操作,系统才会将日志文件缓冲区中的内容保存到日志文件。保存成功后,日志文件缓冲区中的内容会被清空。
# 显示日志文件缓冲区的内容。
<Sysname> display logfile buffer
%@356%Dec 13 16:53:45:495 2019 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is logfile save.
·     info-center logfile frequency
·     logfile save
display logfile summary命令用来显示日志文件的配置。
# 显示日志文件配置。
<Sysname> display logfile summary
  Log file: Enabled.
  Log file size quota: 2 MB
  Log file directory: flash:/logfile
  Writing frequency: 24 hour 0 min 10 sec
表1-7 display logfile summary命令显示信息描述表
Log file
是否允许输出到日志文件方向:
·     Enabled:表示已开启
·     Disabled:表示未开启
Log file size quota
单个日志文件最大能占用的存储空间的大小,单位为MB
Log file directory
日志文件存储的路径
Writing frequency
系统自动保存日志文件的频率
display security-logfile buffer命令用来显示安全日志文件缓冲区的内容。
security-audit
安全日志在保存到安全日志文件前,会先暂时缓存到安全日志缓冲区。当自动或者手动触发安全日志保存操作,系统才会将安全日志缓冲区中的内容保存到安全日志文件。保存成功后,安全日志缓冲区中的内容会被清空。
只有具有安全日志管理员角色的本地用户才能使用本命令。安全日志管理员的配置请参见“安全命令参考”中的“AAA”。
# 显示安全日志文件缓冲区的内容。
<Sysname> display security-logfile buffer
%@1%Sep 17 11:13:16:609 2019 Sysname SHELL/5/SHELL_LOGIN: Console logged in from con0.
·     info-center security-logfile frequency
·     security-logfile save
display security-logfile summary命令用来显示安全日志文件的概要信息。
security-audit
# 显示安全日志文件概要信息。
<Sysname> display security-logfile summary
  Security log file size quota: 10 MB
  Security log file directory: flash:/seclog
  Alarm threshold: 80%
  Current usage: 30%
表1-8 display security-logfile summary命令显示信息描述表
Security log file
安全日志文件当前的状态:
·     Enabled:表示已开启
·     Disabled:表示未开启
单个安全日志文件最大能占用的存储空间的大小
安全日志文件存储的路径
Alarm threshold
安全日志文件使用率告警门限
Current usage
当前的安全日志文件使用率
Writing frequency
系统自动保存安全日志文件的频率
·     authorization-attribute(安全命令参考/AAA)
enable log updown命令用来允许端口在状态发生改变时生成Link up和Link down的日志信息。
undo enable log updown命令用来禁止端口在状态发生改变时生成Link up和Link down的日志信息。
enable log updown
允许所有端口在状态发生改变时生成端口Link up和Link down的日志信息。
# 禁止端口Ten-GigabitEthernet1/0/1在状态发生改变时生成Link up和Link down的日志信息。
[Sysname-Ten-GigabitEthernet1/0/1] undo enable log updown
info-center diagnostic-logfile directory命令用来修改存储诊断日志文件的路径。
存储诊断日志文件路径为flash:/diagfile。
dir-name:诊断日志文件存储的路径,为1~64个字符的字符串。
在执行该配置前,存储诊断日志文件的文件夹必须为当前已创建的目录。
本命令会在IRF重启或主设备和从设备主从倒换后失效。
# 配置存放诊断日志文件的目录为flash:/test。
<Sysname> mkdir test
[Sysname] info-center diagnostic-logfile directory flash:/test
info-center diagnostic-logfile enable命令用来开启诊断日志同步保存功能。
undo info-center diagose-logfile enable命令用来关闭诊断日志同步保存功能。
undo info-center diagnostic-logfile enable
诊断日志同步保存功能处于开启状态。
开启诊断日志同步保存功能后,系统将诊断日志进行集中处理:当生成的诊断日志时,系统会将诊断日志信息同步保存到诊断日志文件。这样既实现了诊断日志的集中管理,又有利于用户随时快捷地查看诊断日志,了解设备状态。
# 开启诊断日志同步保存功能。
[Sysname] info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency命令用来配置设备自动保存诊断日志文件的频率。
undo info-center diagnostic-logfile frequency命令用来恢复缺省情况。
设备自动保存诊断日志文件的频率为86400秒。
freq-sec:系统自动保存诊断日志文件的频率,取值范围为10~86400,单位为秒。
配置设备自动保存诊断日志文件的频率后,诊断日志会先被输出到诊断日志文件缓冲区(diagnostic-logfile buffer),系统会按照配置中指定的频率将诊断日志文件缓冲区的内容写入诊断日志文件。
# 配置诊断日志自动保存到文件的频率为600秒。
[Sysname] info-center diagnostic-logfile frequency 600
info-center diagnostic-logfile quota命令用来配置单个诊断日志文件最大可占用的存储空间的大小。
undo info-center diagnostic-logfile quota命令用来恢复缺省情况。
单个诊断日志文件最大能占用的存储空间为10MB。
# 配置单个诊断日志文件最大能占用的存储空间的大小为6MB。
[Sysname] info-center diagnostic-logfile quota 6
info-center enable命令用来开启信息中心功能。
undo info-center enable命令用来关闭信息中心功能。
info-center enable
信息中心处于开启状态。
# 开启信息中心功能。
[Sysname] info-center enable
info-center filter命令用来创建日志输出规则。
info-center filter filter-name { module-name [ mnemonic mnemonic-value ] | default } { deny | level severity }
undo info-center filter filter-name [ module-name [ mnemonic mnemonic-value ] | default ]
未创建日志输出规则。
filter-name:日志信息输出规则的名称,为1~8个字符的字符串,不区分大小写。
module-name:为指定模块配置日志输出规则,该参数的取值可通过在系统视图下输入info-center filter filter-name 来获取。
mnemonic mnemonic-value:按照日志助记符对日志进行过滤。mnemonic-value表示助记符的全部内容,为1~32个字符的字符串,不区分大小写。如果输入的是助记符的部分内容,将过滤失败。不指定该参数时,表示仅按照模块名对日志进行过滤。
default:配置所有应用模块日志信息的缺省输出规则。
deny:禁止输出日志信息。
level severity:指定允许输出的日志信息的最低级别,取值为alertcriticaldebuggingemergencyerrorinformationalnotificationwarning,各参数的含义请参见表1-4。例如,本参数配置为warning,则表示配置对emergencyalertcriticalerrorwarning级别的日志均生效。
多次执行本命令可以创建多个输出规则,将输出规则和日志主机绑定,可以为不同的日志主机指定不同的输出规则。
info-center filter命令和info-center source命令都用来配置日志输出规则,两者区别在于:info-center filter命令配置的输出规则目前只支持应用到日志主机输出方向,info-center source命令配置的日志输出规则适用于所有输出方向。对于日志主机输出方向,info-center filter命令配置的输出规则优先于info-center source命令配置的输出规则。
用户可以使用module-name参数为应用模块单独配置输出规则,对于未单独配置应用模块则使用default参数配置的缺省输出规则,这两种配置可以同时存在。
给应用模块单独配置输出规则后,必须使用module-name参数来修改或删除该规则。
如果配置了带module-name参数的命令,未配置带default参数的命令行,则未单独配置输出规则的应用模块允许alert~informational级别的日志输出。
多次使用module-name参数为同一应用模块配置输出规则时,最后一次执行的命令生效;多次使用default参数配置缺省输出规则时,最后一次执行的命令生效。
# 配置名称为loghost1的输出规则,用来允许ARP模块alert~notification级别的日志信息输出,SNMP模块alert~warning级别的日志信息输出,其他模块的日志信息禁止输出。
[Sysname] info-center filter loghost1 arp level notification
[Sysname] info-center filter loghost1 snmp level warning
[Sysname] info-center filter loghost1 default deny
·     display info-center filter
·     info-center loghost
·     info-center source
info-center format命令用来配置发往日志主机的日志信息的输出格式。
undo info-center format命令用来恢复缺省情况。
info-center format { cmcc | rfc5424 | unicom }
发往日志主机的日志信息的格式为非定制格式。
cmcc:配置发往日志主机的日志信息的输出格式为中国移动格式。
rfc5424:配置发往日志主机的日志信息的输出格式为RFC 5424格式。
unicom:配置发往日志主机的日志信息的输出格式为中国联通格式。
发往日志主机的日志信息有以下格式:非定制格式、中国联通格式和中国移动格式。有关日志信息格式的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
# 配置发往日志主机的日志信息的格式为RFC 5424格式。
[Sysname] info-center format rfc5424
info-center logbuffer命令用来允许日志信息输出到日志缓冲区。
undo info-center logbuffer命令用来禁止日志信息输出日志缓冲区。
允许日志信息输出到日志缓冲区。
配置本命令后,设备会将业务模块生成的日志保存到日志缓冲区。其中,设备会为一些业务模块(例如会话等)创建单独的日志缓冲区,用来分别存储这些业务模块的日志,其它业务模块的日志会统一存储到通用日志缓冲区中。用户可使用display logbuffer命令查看这些日志缓冲区的内容或者使用info-center logbuffer size命令配置这些日志缓冲区的大小。
# 配置允许日志信息输出到日志缓冲区。
[Sysname] info-center logbuffer
·     display logbuffer
·     info-center enable
info-center logbuffer size命令用来配置日志缓冲区可存储的信息条数。
undo info-center logbuffer size命令用来恢复缺省情况。
日志缓冲区可存储512条信息。
buffersize:日志缓冲区可存储的信息条数,取值范围为0~1024,缺省值为512。
# 配置日志缓冲区可存储的信息条数为50。
[Sysname] info-center logbuffer size 50
# 恢复日志缓冲区可存储的信息条数为512。
[Sysname] undo info-center logbuffer size
·     display logbuffer
info-center logfile alarm-threshold命令用来配置单个日志文件使用率的告警门限。
undo info-center logfile alarm-threshold命令用来恢复缺省情况。
info-center logfile alarm-threshold usage
单个日志文件使用率的告警门限是80。即当单个日志文件使用率达到80%时,系统会提醒用户。
usage:表示日志文件使用率的告警门限,取值范围为0~100。取值为0时,表示关闭日志文件使用率告警功能。
用户可以使用本命令配置单个日志文件使用率的告警门限。当设备正在操作的日志文件的使用率超过告警门限时,系统会生成日志提醒用户,此时,用户可以将该日志文件进行备份,以防历史数据丢失。
# 当通用模块的日志文件使用率达到90%时进行告警。
[Sysname] info-center logfile alarm-threshold 90
info-center logfile directory命令用来配置存放日志文件的目录。
存放日志文件的目录为flash:/logfile
dir-name:存放日志文件的路径,为1~64个字符的字符串。
在执行该配置前,存放日志文件的目录必须为当前已创建的目录。
生成的日志文件的后缀名为.log。
# 配置存放日志文件的目录为flash:/test。
[Sysname] info-center logfile directory flash:/test
·     info-center logfile enable
info-center logfile enable命令用来允许日志信息输出到日志文件。
undo info-center logfile enable命令用来禁止日志信息输出到日志文件。
允许日志信息输出到日志文件。
# 配置允许日志信息输出到日志文件。
[Sysname] info-center logfile enable
info-center logfile frequency命令用来配置系统自动保存日志文件的频率。
undo info-center logfile frequency命令用来恢复缺省情况。
设备自动保存日志文件的频率为86400秒。
freq-sec:系统自动保存日志文件的频率,取值范围为1~86400,单位为秒。
配置系统自动保存日志文件的频率后,系统会按照指定的频率将日志文件缓冲区的内容写入日志文件。
# 配置设备自动保存日志文件的频率为60000秒。
[Sysname] info-center logfile frequency 60000
info-center logfile size-quota命令用来配置单个日志文件最大能占用的存储空间的大小。
undo info-center logfile size-quota命令用来恢复缺省情况。
单个日志文件最大能占用的存储空间为10MB。
# 配置单个日志文件最大能占用的存储空间的大小为2MB。
[Sysname] info-center logfile size-quota 2
info-center logging suppress duplicates命令用来开启抑制重复日志输出功能。
undo info-center logging suppress duplicates命令用关闭抑制重复日志输出功能。
抑制重复日志输出功能处于关闭状态。
当设备持续生成相同的日志,大量重复的信息会浪费设备资源和网络资源,并导致有用的信息被淹没,不利于设备的维护。为了避免此问题,可开启重复日志抑制功能。
# 开启抑制重复日志输出功能。
[Sysname] info-center logging suppress duplicates
info-center logging suppress module命令用来禁止指定模块日志的输出。
undo info-center logging suppress module命令用来取消对指定模块日志输出的限制。
undo info-center logging suppress module module-name mnemonic { all | mnemonic-value }
未禁止指定模块日志的输出。
module-name:指定需要被过滤的应用模块的名称,为1~8个字符的字符串,不区分大小写。执行info-center logging suppress module 命令,设备会自动显示可配置的模块名称。
mnemonic { all | mnemonic-value }:表示需要被过滤的应用模块的助记符。其中:
·     all:表示过滤该模块的所有日志。
·     mnemonic-value:表示助记符的全部内容,为1~32个字符的字符串,不区分大小写。如果输入的是助记符的部分内容,将不会禁止输出该助记符对应的日志。
当系统日志较多时,对于用户不关心的日志,可以使用该命令,禁止指定模块日志的输出,或者禁止指定模块特定助记符的日志输出。
# 禁止SHELL模块助记符为SHELL_LOGIN的日志输出。
[Sysname] info-center logging suppress module shell mnemonic shell_login
info-center loghost命令用来配置日志主机及相关参数。
undo info-center loghost命令用来取消日志主机及相关参数的配置。
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ dscp dscp-value ] [ facility local-number ] [ filter filter-name ] [ format rfc5424-json-v1 tcp [ end-with-length ] ssl-client-policy ssl-client-policy-name directory dir-name size-quota size ]
undo info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address }
未配置日志主机及相关参数。
vpn-instance vpn-instance-name:指定日志主机所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示日志主机位于公网中。
hostname:指定日志主机的名称,为1~253个字符的字符串,不区分大小写,字符串中只能包含字母、数字、“-”、“_”和“.”,且需满足以下要求:
·     主机名以“.”字符分割成多个字符串,单个字符串的长度不超过63个字符。
·     主机名不能以“.”字符开头或结尾。
·     主机名不能包含两个连续的“.”字符。
ipv4-address:指定日志主机的IPv4地址。
ipv6 ipv6-address:指定日志主机的IPv6地址。
port port-number:指定日志主机接收日志信息的端口号,取值范围为1~65535,缺省值为514。该参数的值需要和日志主机侧的配置一致,否则日志主机接收不到日志信息。
dscp dscp-value:指定日志消息的DSCP(Differentiated Services Code Point,差分服务代码点)优先级,取值范围为0~63,缺省值为0。值越大表示优先级越高。DSCP优先级封装在IP报文中的ToS字段,用来表示报文自身的优先级,设备可根据该优先级决定报文传输的优先程度。
facility local-number:配置日志主机的记录工具。取值为local0local1local2local3local4local5local6local7original-facility,缺省值为local7。该参数用于计算日志中携带的PRI字段(PRI=facility*8+level),其中,local0~local7分别对应取值16~23。如果将facility配置为local0~local7,则表示设备发往日志主机的所有日志的Facility均为指定的值;如果将facility配置为original-facility,则表示设备发往日志主机的日志的Facility为业务模块生成日志时定义的初始Facility,不同日志的初始Facility可能不同。
filter filter-name:指定日志主机关联的日志输出规则的名称,只有符合规则的日志才能输出到对应的日志主机。filter-name表示日志信息输出规则的名称,为1~8个字符的字符串,不区分大小写。不指定该参数时,则采用info-center source命令日志主机方向的配置作为日志输出规则。
format rfc5424-json-v1:配置发往指定日志主机的日志信息中使用的日志格式为rfc5424-json-v1。其中,日志的内容区段采用Json格式,日志的其它区段采用RFC5424格式。不指定该参数时,使用info-center format命令中配置的日志格式。
tcp:配置使用TCP协议发送日志。缺省使用UDP协议发送日志。
end-with-length:表示在日志中携带Length字段来表示一条日志的结束。不指定该参数时,表示使用“\n”换行符来表示一条日志的结束。
ssl-client-policy policy-name:配置使用基于TCP协议的SSL加密方式发送日志。policy-name表示SSL客户端策略名称,为1~31个字符的字符串,不区分大小写。
directory dir-name size-quota size:表示当设备和日志主机之间的TCP连接断开时,设备生成的需要发往日志主机的日志以文件形式保存到本地的指定路径。其中,dir-name表示保存日志文件的文件夹的绝对路径,为1~64个字符的字符串。日志文件的名称由设备使用本命令指定的IP地址或者日志主机的名称自动生成。size表示日志文件的大小,取值范围为1~70,单位为MB。当日志文件大小达到指定值时,设备会删除最旧的日志来存储新日志。
应用场景
使用本命令,用户可以将设备生成的日志发送给指定的日志主机。
工作机制
配置本命令时,用户可以指定:
·     日志过滤规则。只有符合过滤规则的日志才会发送给日志主机,以免用户不关心的日志发送给日志主机,占用网络带宽和日志主机上的资源。
·     日志发送格式。设备将按照用户指定的格式封装日志,以便日志主机按照指定的规则解析日志。
·     用TCP协议发送日志,提高日志传输的安全性。如果TCP链接断开,设备会将日志以文件的形式保存到本地,以便用户查询。
用户只有使用info-center enable命令开启了信息中心功能,配置info-center loghost命令才会生效。
多次执行本命令,最多可以指定20台不同主机同时接收设备产生的日志信息。
# 配置系统向IP地址为1.1.1.1的日志主机发送日志信息。
[Sysname] info-center loghost 1.1.1.1
info-center loghost locate-info with-sn命令用来配置向日志主机方向发送日志时,在日志定位信息中携带设备序列号。
undo info-center loghost locate-info with-sn命令用来恢复缺省情况。
向日志主机方向发送日志时,日志定位信息中未携带设备序列号。
# 配置向日志主机方向发送日志时,在日志定位信息中携带设备序列号。
[Sysname] info-center loghost locate-info with-sn
info-center loghost source命令用来配置发送的日志信息的源IP地址。
undo info-center loghost source命令用来恢复缺省情况。
使用出接口的主IP地址作为发送的日志信息的源IP地址。
interface-type interface-number:指定发送日志信息的源IP地址对应的出接口的类型和编号。
配置日志信息的源IP地址后,不管实际使用哪个物理接口发送日志信息,日志信息的源IP地址均为指定接口的主IP地址。
用户只有使用info-center enable命令开启了信息中心功能,配置info-center loghost source命令才会生效。
# 配置使用Loopback0的IP地址作为发送的日志信息的源IP地址。
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] info-center loghost source loopback 0
info-center security-logfile alarm-threshold命令用来配置安全日志文件使用率的告警门限。
undo info-center security-logfile alarm-threshold命令用来恢复缺省情况。
安全日志文件使用率的告警门限是80(即当安全日志文件使用率达到80%时,系统会提醒用户)。
usage:安全日志文件使用率的告警门限,取值范围为1~100的整数。
当安全日志文件大小达到上限时,新的安全日志会覆盖旧的安全日志,从而导致安全日志丢失。为防止这种情况发生,用户可以使用本命令配置安全日志文件使用率的告警门限。当使用率超过此门限值时,系统会发出日志提醒用户,此时,用户可以将安全日志文件进行备份,以防重要历史数据丢失。
# 配置当安全日志文件使用率达到90%时进行告警。
[Sysname] info-center security-logfile alarm-threshold 90
·     info-center security-logfile size-quota
info-center security-logfile directory命令用来修改存储安全日志文件的路径。
存储安全日志文件路径为flash:/seclog。
security-audit
dir-name:安全日志文件存储的路径,为1~64个字符的字符串。
在执行该配置前,存储安全日志文件的文件夹必须为当前已创建的目录。
只有配置了安全日志管理员权限的本地用户才能使用本命令。安全日志管理员的配置请参见“安全命令参考”中的“AAA”。
# 配置存放安全日志文件的目录为flash:/test。
[Sysname] info-center security-logfile directory flash:/test
info-center security-logfile enable命令用来开启安全日志同步保存功能。
undo info-center security-logfile enable命令用来关闭安全日志同步保存功能。
安全日志同步保存功能处于关闭状态。
开启安全日志同步保存功能后,系统将安全日志进行集中处理:当生成的日志信息中有安全日志,在不影响日志信息现有输出规则的前提下,系统会将安全日志信息同步保存到专用的安全日志文件。这样既实现了安全日志的集中管理,又有利于用户随时快捷地查看安全日志,了解设备状态。
# 开启安全日志同步保存功能。
[Sysname] info-center security-logfile enable
info-center security-logfile frequency命令用来配置设备自动保存安全日志文件的频率。
undo info-center security-logfile frequency命令用来恢复缺省情况。
设备自动保存安全日志文件的频率为86400秒。
freq-sec:系统自动保存安全日志文件的频率,取值范围为10~86400,单位为秒。
配置设备自动保存安全日志文件的频率后,安全日志会先被输出到安全日志文件缓冲区(security-logfile buffer),系统会按照配置中指定的频率将安全日志文件缓冲区的内容写入安全日志文件。
# 配置安全日志自动保存到文件的频率为600秒。
[Sysname] info-center security-logfile frequency 600
·     info-center security-logfile enable
info-center security-logfile size-quota命令用来配置单个安全日志文件最大能占用的存储空间的大小。
undo info-center security-logfile size-quota命令用来恢复缺省情况。
单个安全日志文件最大能占用的存储空间的大小为10MB。
# 配置单个安全日志文件最大能占用的存储空间的大小为6MB。
[Sysname] info-center security-logfile size-quota 6
·     info-center security-logfile alarm-threshold
info-center source命令用来配置日志信息的输出规则。
undo info-center source命令用来恢复缺省情况。
info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor } { deny | level severity }
undo info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor }
日志信息的输出规则请参见表1-9
表1-9 日志信息的缺省输出规则
输出方向
日志信息来源
开关
等级
控制台
所有支持的模块
debugging
监视终端
所有支持的模块
debugging
日志主机
所有支持的模块
informational
日志缓冲区
所有支持的模块
informational
日志文件
所有支持的模块
informational
module-name:配置指定应用模块日志信息的输出规则。系统支持的来源模块可以通过在系统视图下输入info-center source ?进行查看。
console:输出到控制台。
logbuffer:输出到日志缓冲区。
logfile:输出到日志文件。
loghost:输出到日志主机。
monitor:输出到监视终端。
deny:禁止输出信息。
如果没有使用module-name参数为应用模块单独配置输出规则,则该模块使用default参数配置的输出规则。如果未使用default参数配置输出规则,则使用缺省输出规则。
给应用模块单独配置输出规则后,必须使用module-name参数来修改或删除该规则,使用default参数进行的新配置对该模块不生效。
多次使用module-name参数为同一应用模块配置输出规则,最后一次执行的命令生效;多次使用default参数配置缺省输出规则,最后一次执行的命令生效。
# 只允许VLAN模块的信息输出控制台,且输出信息的级别为emergency的日志信息。
[Sysname] info-center source default console deny
[Sysname] info-center source vlan console level emergency
# 在前面例子基础上撤销控制台方向上VLAN模块的输出(即全部信息不在控制台显示)。
[Sysname] undo info-center source vlan console
info-center synchronous命令用来开启命令行输入回显功能。
undo info-center synchronous命令用来关闭命令行输入回显功能。
命令行输入回显功能处于关闭状态。
当用户进行命令行、参数或者Y/N确认信息输入时,如果被大量的日志信息打断,用户可能记不清已经输入了哪些字符串,还需要输入哪些字符串。使用命令行输入回显功能,能够协助用户配置。系统会在日志信息输出完毕后回显用户已有的输入或者Y/N确认信息,以便用户继续执行配置。
# 开启设备命令行输入回显功能,输入display current-configuration命令查看设备当前配置。
[Sysname] info-center synchronous
Info-center synchronous output is on
[Sysname] display current-
此时,收到日志报文,则系统在所有的日志报文显示完以后,附加显示用户的输入(此例为“display current-”)。
%May 21 14:33:19:425 2019 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.44
此时,用户可以继续输入configuration(完成命令display current-configuration的完整输入),回车,即可执行该命令。
# 开启设备命令行输入回显功能,保存当前配置(输入交互信息)。
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
此时,收到日志信息,则系统会在所有的日志报文显示完以后,附加显示[Y/N]:。
[Y/N]:
此时,用户可以输入Y或者N,继续日志信息输出前的操作。
info-center syslog min-age命令用来配置日志信息的最短保存时间。
undo info-center syslog min-age命令用来恢复缺省情况。
info-center syslog min-age min-age
未配置日志信息的最短保存时间。
min-age:表示日志信息的最短保存时间,取值范围为1~8760,单位为小时。
# 将日志信息的最短保存时间配置为168小时。
[Sysname] info-center syslog min-age 168
info-center syslog trap命令用来配置日志告警缓冲区的大小。
undo info-center syslog trap命令用来恢复缺省情况。
undo info-center syslog trap buffersize
日志告警缓冲区的大小为1024条。
buffersize:表示日志告警缓冲区的大小,取值范围为0~65535,单位为条。当取值为0时,表示不缓存日志告警。
配置snmp-agent trap enable syslog命令后,设备会将日志封装成告警信息,存储在日志告警缓冲区。用户通过访问“日志告警缓冲区对应的MIB节点”,就可以直接读取日志告警。
通常情况下,日志告警缓冲区的大小采用缺省值即可。当日志告警缓冲区内存储的信息达到上限,且还需要存储信息时,新信息会覆盖旧信息。
# 配置日志告警缓冲区的大小为2048条。
[Sysname] info-center syslog trap buffersize 2048
·     snmp-agent trap enable syslog
info-center timestamp命令用来配置发往控制台、监视终端、日志缓冲区和日志文件方向的日志信息的时间戳输出格式。
undo info-center timestamp命令用来恢复缺省情况。
时间戳输出格式为date格式。
boot:系统启动后经历的时间,格式为:xxx.yyy,其中xxx是系统自启动后经历时间的毫秒数高32位,yyy是低32位,形如0.21990989(等效于Jun 25 14:09:26:881 2019)。
date:系统当前的日期和时间,格式为“MMM DD hh:mm:ss:ms YYYY”,形如Dec  8 10:12:21:708 2019。
·     “MMM”为英语月份的缩写,具体取值如下:Jan,Feb,Mar,Apr,May,Jun,Jul,Aug,Sep,Oct,Nov,Dec。
·     “DD”表示日期,如果日期的值小于10,则格式为“空格+日期”,如“ 7”。
·     “hh:mm:ss:ms”表示本地时间,hh的取值范围为00~23,mm和ss的取值范围均为00~59,ms的取值范围为0~999。
·     “YYYY”表示年份。
none:不带时间信息。
# 配置日志信息时间戳输出格式为boot格式。
[Sysname] info-center timestamp boot
·     info-center timestamp loghost
info-center timestamp loghost命令用来配置发往日志主机的日志信息的时间戳输出格式。
undo info-center timestamp loghost命令用来恢复缺省情况。
info-center timestamp loghost { date [ with-milliseconds ] | iso [ with-milliseconds | with-timezone ] * | no-year-date | none }
发往日志主机的日志信息的时间戳输出格式为date格式。
date:配置时间戳输出格式为:MMM DD hh:mm:ss YYYY,形如Dec  8 10:12:21 2019,但最终显示格式由日志主机决定。
iso:配置时间戳输出格式为ISO 8601标准格式,形如:2019-09-21T15:32:55。
with-milliseconds:表示时间戳精确到毫秒,且毫秒用标准点号分割。对于date格式的时间戳,加毫秒后,形如:Dec 8 10:12:21.708 2019;对于iso格式的时间戳,加毫秒后,形如:2019-09-21T15:32:55.708。不指定该参数时,表示时间戳精确到秒。
with-timezone:在时间戳中携带时区信息,形如:2019-09-21T15:32:55+01:00。不指定该参数时,表示在时间戳中不带时区信息。
no-year-date:系统当前日期和时间,但不包含年份和毫秒信息。
none:不带时间信息。
# 配置发往日志主机的日志信息的时间戳为no-year-date格式。
[Sysname] info-center timestamp loghost no-year-date
info-center trace-logfile quota命令用来配置调试跟踪日志文件最大能占用的存储空间的大小。
undo info-center trace-logfile quota命令用来恢复缺省情况。
调试跟踪日志文件最大能占用的存储空间的大小为1MB。
本命令用来配置保存在存储介质上的单个调试跟踪日志文件最大可占用的存储空间的大小以及内存中调试跟踪日志文件最大可占用的存储空间的大小。
# 配置调试跟踪日志文件最大能占用的存储空间的大小为6MB。
[Sysname] info-center trace-logfile quota 6
1.1.43  logfile save
logfile save命令用来手动将日志文件缓冲区中的内容全部保存到日志文件。
logfile save
日志文件的保存路径可以通过info-center logfile directory命令配置。
日志文件保存成功后,日志文件缓冲区中的内容会被清空。
如果执行本命令时,日志文件缓冲区中没有日志,本命令会执行成功,但不会创建或更新已有日志文件。
# 手动将日志文件缓冲区中的内容保存到日志文件。
<Sysname> logfile save
The contents in the log file buffer have been saved to the file flash:/logfile/logfile.log.
·     info-center logfile directory
reset logbuffer命令用来清除日志缓冲区中的信息。
reset logbuffer
# 清除日志缓冲区中的信息。
<Sysname> reset logbuffer
·     display logbuffer
security-logfile save命令用来手动将安全日志文件缓冲区中的内容全部保存到安全日志文件。
security-audit
安全日志文件保存成功后,安全日志文件缓冲区中的内容会被立即清空。
需要注意的是,只有具有安全日志管理员角色的本地用户才能使用本命令。安全日志管理员的配置请参见“安全命令参考”中的“AAA”。
如果执行本命令时,安全日志文件缓冲区中没有日志,本命令会执行成功,但不会创建或更新已有安全日志文件。
# 手动将安全日志缓冲区中的内容保存到安全日志文件。
<Sysname> security-logfile save
The contents in the security log file buffer have been saved to the file flash:/seclog/seclog.log.
·     info-center security-logfile directory
snmp-agent trap enable syslog命令用来将系统日志封装成告警信息发送。
undo snmp-agent trap enable syslog命令用来恢复缺省情况。
系统日志不会封装成告警信息发送。
配置该命令后,设备除了根据输出规则将日志输出到各方向外,还会将日志信息封装成告警信息,发送到SNMP模块和日志告警缓冲区。
·     发送到SNMP模块后,是否输出到目的主机,以Trap还是Inform形式发送,由SNMP模块的配置决定,关于告警信息以及SNMP配置的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
·     发送到日志告警缓冲区后,用户可通过“日志告警缓冲区对应的MIB节点”来直接读取日志信息封装成的告警信息。用户还可通过info-center syslog trap buffersize命令来配置日志告警缓冲区的大小。
# 将系统日志封装成告警信息发送。
[Sysname] snmp-agent trap enable syslog
·     info-center syslog trap buffersize
terminal debugging命令用来开启当前终端对调试信息的显示功能。
undo terminal debugging命令用来关闭当前终端对调试信息的显示功能。
terminal debugging
当前终端对调试信息的显示功能处于关闭状态。
如果需要在控制台显示调试信息,请先配置terminal debugging命令,再使能信息中心功能(信息中心功能缺省处于使能状态),最后使用debugging命令打开功能模块的调试信息开关。
如果需要在监视终端上显示调试信息,请先配置terminal monitorterminal debugging命令,再使能信息中心功能(信息中心功能缺省处于使能状态),最后使用debugging命令打开功能模块的调试信息开关。
需要注意的是,本命令只对当前连接有效。当终端与设备重新建立连接后,本命令会恢复到缺省情况。
执行terminal logging level 7命令或terminal debugging命令,都可以开启当前终端对调试信息的显示功能,但两条命令有如下区别:
·     执行terminal logging level 7命令,当前终端允许输出级别为0~7的所有日志。
·     执行terminal debugging命令,当前终端仅输出terminal logging level命令配置的日志信息和级别为7的调试信息。
# 允许debugging日志信息输出到当前终端。
<Sysname> terminal debugging
The current terminal is enabled to display debugging logs.
·     terminal logging level
·     terminal monitor
terminal logging level命令用来配置当前终端允许输出的日志信息的最低级别。
undo terminal logging level命令用来恢复缺省情况。
当前终端允许输出的日志信息的最低级别均为6(Informational)。
severity:当前终端允许输出的日志信息的最低级别,取值为0~7的整数或者alert、critical、debugging、emergency、error、informational、notification、warning。
在配置了当前终端允许输出的日志信息的最低级别后,当系统输出信息时,所有信息等级高于或等于配置等级的信息都会被输出。例如,当配置的允许输出的日志信息的最低级别6(informational)时,等级0~6的信息均会被输出。
本命令配置的显示属性只对当前连接有效,当终端与设备的连接超时、重新建立连接后,显示属性将恢复到缺省情况。
# 配置当前终端监控的最低日志级别为debugging。
<Sysname> terminal logging level 7
terminal monitor命令用来允许日志信息输出到当前终端。
undo terminal monitor命令用来禁止日志信息输出到当前终端。
terminal monitor
允许日志信息输出到控制台,不允许日志信息输出到监视终端。
# 允许日志信息输出到当前终端。
<Sysname> terminal monitor
本站点使用Cookies,继续浏览表示您同意我们使用Cookies。 Cookies和隐私政策>
