02-Password Control命令
本章节下载: 02-Password Control命令 (263.19 KB)
1.1.1 display password-control
1.1.2 display password-control blacklist
1.1.3 password-control { aging | composition | history | length } enable
1.1.5 password-control alert-before-expire
1.1.6 password-control complexity
1.1.7 password-control composition
1.1.9 password-control expired-user-login
1.1.10 password-control history
1.1.11 password-control length
1.1.12 password-control login idle-time
1.1.13 password-control login-attempt
1.1.14 password-control super aging
1.1.15 password-control super composition
1.1.16 password-control super length
1.1.17 password-control update-interval
1.1.18 reset password-control blacklist
1.1.19 reset password-control history-record
display password-control命令用来显示密码管理的配置信息。
display password-control [ super ]
super:显示super密码管理的配置信息。如果不指定该参数,将显示全局密码管理的配置信息。
# 显示全局密码管理的配置信息。
Password control: Disabled
Password aging: Enabled (90 days)
Password length: Enabled (10 characters)
Password composition: Enabled (1 types, 1 characters per type)
Password history: Enabled (max history records:4)
Early notice on password expiration: 7 days
Maximum login attempts: 3
Action for exceeding login attempts: Lock user for 1 minutes
Minimum interval between two updates: 24 hours
User account idle time: 90 days
Logins with aged password: 3 times in 30 days
Password complexity: Disabled (username checking)
Disabled (repeated characters checking)
# 显示super密码管理的配置信息。
表1-1 display password-control命令显示信息描述表
Global password control configurations |
全局密码管理配置 |
Super password control configurations |
Super密码管理配置 |
Password control |
全局密码管理功能的开启状态 |
Password aging |
密码老化功能的开启状态(密码的老化时间) |
Password length |
密码最小长度功能的开启状态(密码的最小长度) |
Password composition |
密码组合策略的开启状态(密码元素的组合类型、至少要包含每种元素的个数) |
Password history |
密码历史记录检测功能的开启状态(密码历史记录的最大条数) |
Early notice on password expiration |
密码过期前的提醒时间 |
Maximum login attempts |
用户最大登录尝试次数 |
Action for exceeding login attempts |
登录尝试次数达到设定次数后的用户帐户锁定行为 |
Minimum interval between two updates |
密码更新的最小时间间隔 |
User account idle time |
用户帐号闲置时间 |
Logins with aged password |
密码过期后允许用户登录的次数和时间 |
Password complexity |
密码复杂度检查功能的开启状态(检查是否包含用户名或者颠倒的用户名;检查是否包含三个或以上相同字符) |
display password-control blacklist命令用来显示用户认证失败后,被加入密码管理黑名单中的用户信息。
display password-control blacklist [ user-name user-name | ip ipv4-address | ipv6 ipv6-address ]
user-name user-name:显示密码管理黑名单中指定用户名的用户信息。其中,user-name表示用户名,为1~55个字符的字符串,区分大小写。
ip ipv4-address:显示密码管理黑名单中指定IPv4地址的用户信息。
ipv6 ipv6-address:显示密码管理黑名单中指定IPv6地址的用户信息。
如果不指定任何参数,则显示密码管理黑名单中的所有用户信息。
用户在认证失败后,其IP地址和用户名会被加入密码管理的黑名单。通过本命令可以查看被加入密码管理黑名单中的FTP用户和通过VTY方式访问设备的用户。
通过Console口连接到设备的用户,由于系统无法获得其IP地址,且这类访问设备的用户已经具备了一定的权限和安全性,所以认证失败后不会被加入密码管理的黑名单。
# 显示用户认证失败后,被加入密码管理黑名单中的用户信息。
<Sysname> display password-control blacklist
Blacklist items matched: 2.
Username IP address Login failures Lock flag
abcd 169::168:34:1 4 lock
admin 192.168.34.1 1 unlock
表1-2 display password-control blacklist命令显示信息描述表
Blacklist items matched |
匹配的黑名单表项数目 |
Username |
用户名 |
IP address |
用户的IP地址 |
Login failures |
用户登录失败的次数 |
Lock flag |
该用户是否被锁定 · unlock:表示未锁定,允许用户再次尝试登录 · lock:表示锁定,暂时或永久禁止用户尝试登录(具体由password-control login-attempt命令的配置情况决定) |
password-control { aging | composition | history | length } enable命令用来使能指定的密码管理功能。
undo password-control { aging | composition | history | length } enable命令用来关闭指定的密码管理功能。
各密码管理功能均处于使能状态。
aging:使能密码老化管理功能。
composition:使能密码的组合检测管理功能。
history:使能密码历史记录检测管理功能。
length:使能密码最小长度管理功能。
要使指定的密码管理功能生效,首先必须保证全局密码管理功能处于使能状态,其次要保证对应的密码管理功能处于使能状态。例如,若全局密码管理功能或密码最小长度管理功能处于未使能状态,则password-control length命令配置的具体长度限制就不会生效。
密码历史记录检测管理功能关闭后,系统将不再检测新密码是否与所有历史密码不同,但历史密码记录功能不会关闭,当记录的某用户的历史密码条数达到password-control history max-record-number命令设置的最大值后,该用户的后续新密码历史记录将覆盖最老的一条密码历史记录。
使能了全局密码管理功能:非FIPS模式下,密码的最小长度为4个字符,且至少要有四个字符不同;FIPS模式下,密码的最小长度为15个字符,且至少要有四个字符不同。
# 使能全局密码管理功能。
# 使能密码组合检测管理功能。
[Sysname] password-control composition enable
# 使能密码老化功能。
[Sysname] password-control aging enable
# 使能密码最小长度功能。
[Sysname] password-control length enable
# 使能密码历史记录检测功能。
[Sysname] password-control history enable
· display password-control
· password-control enable
password-control aging命令用来配置密码的老化时间。
undo password-control aging命令用来恢复缺省情况。
全局的密码老化时间为90天;用户组的密码老化时间为全局配置的密码老化时间;本地用户的密码老化时间为所属用户组的密码老化时间。
用户组视图
本地用户视图
aging-time:密码的老化时间,取值范围为1~365,单位为天。
系统视图下配置具有全局性,对所有用户组有效,用户组视图下的配置对用户组内所有本地用户有效,本地用户视图下的配置只对当前本地用户有效。
该配置的生效优先级顺序由高到低依次为本地用户视图、用户组视图、全局视图。即,系统优先采用本地用户视图下的配置,若本地用户视图下未配置,则采用用户组视图下的配置,若用户组视图下也未配置,则采用全局视图下的配置。
# 配置全局的密码老化时间为80天。
[Sysname] password-control aging 80
# 配置用户组test的密码老化时间为90天。
[Sysname] user-group test
[Sysname-ugroup-test] password-control aging 90
[Sysname-ugroup-test] quit
# 配置设备管理类本地用户abc的密码老化时间为100天。
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] password-control aging 100
· display local-user(安全命令参考/AAA)
· display user-group(安全命令参考/AAA)
· password-control aging enable
password-control alert-before-expire命令用来配置密码过期前的提醒时间。
undo password-control alert-before-expire命令用来恢复缺省情况。
密码过期前的提醒时间为7天,表示在密码过期之前7天内,系统会在用户登录时提醒其密码即将过期。
alert-time:密码过期前的提醒时间,取值范围为1~30,单位为天。
不允许FTP用户更改密码,只能由管理员修改FTP用户的密码,因此本命令配置的过期提醒时间仅对非FTP类型的Login用户有效。
# 设定密码过期前的提醒时间为10天。
[Sysname] password-control alert-before-expire 10
password-control complexity命令用来配置用户密码的复杂度检查策略。
undo password-control complexity命令用来取消指定的密码复杂度检查策略。
undo password-control complexity { same-character | user-name } check
全局的密码复杂度检查策略为:不对用户密码进行复杂度检查,允许密码中包含用户名或者字符顺序颠倒的用户名,也允许包含连续三个或以上的相同字符;用户组的密码复杂度检查策略为全局的密码复杂度检查策略;本地用户的密码复杂度检查策略为所属用户组的密码复杂度检查策略。
用户组视图
本地用户视图
same-character:指定检查密码中是否包含连续三个或以上相同的字符。例如,密码aaabc就不符合该项复杂度检查。
user-name:指定检查密码中是否包含用户名或者字符顺序颠倒的用户名。例如,用户名为123,则密码abc123、321df就不符合该项复杂度检查。
可以通过多次执行本命令同时打开用户名检查以及连续字符检查功能。
# 配置密码复杂度检测策略为,检查配置的密码中是否包含用户名或者字符顺序颠倒的用户名。
password-control composition命令用来配置用户密码的组合策略。
undo password-control composition命令用来恢复缺省情况。
非FIPS模式下:
全局的密码元素的最少组合类型为1种,至少要包含每种元素的个数为1个;用户组的密码组合策略为全局配置的密码组合策略;本地用户的密码组合策略为所属用户组的密码组合策略。
FIPS模式下:
全局的密码元素的最少组合类型为4种,至少要包含每种元素的个数为1个;用户组的密码组合策略为全局配置的密码组合策略;本地用户的密码组合策略为所属用户组的密码组合策略。
用户组视图
本地用户视图
type-number type-number:密码元素的最少组合类型。其中,type-number表示组合类型的个数,非FIPS模式下,取值范围为1~4;FIPS模式下,取值为4。
type-length type-length:密码中至少要包含每种元素的个数。其中,type-length表示元素个数,非FIPS模式下,取值范围为1~63;FIPS模式下,取值范围为1~15。
密码元素的最少组合类型数以及每种元素的最小个数的乘积应该小于允许的最大密码长度。
# 配置全局的密码元素的最少组合类型为4种,至少要包含每种元素的个数为5个。
[Sysname] password-control composition type-number 4 type-length 5
# 配置用户组test的密码元素的最少组合类型为4种,至少要包含每种元素的个数为5个。
[Sysname-ugroup-test] password-control composition type-number 4 type-length 5
# 配置设备管理类本地用户abc的密码元素的最少组合类型为4种,至少要包含每种元素的个数为5个。
[Sysname-luser-manage-abc] password-control composition type-number 4 type-length 5
· password-control composition enable
password-control enable命令用来使能全局密码管理功能。
undo password-control enable命令用来关闭全局密码管理功能。
非FIPS模式下:
全局密码管理功能处于关闭状态。
FIPS模式下:
全局密码管理功能处于开启状态,且不能关闭。
只有在使能了全局密码管理功能的情况下,其它指定的密码管理功能才能生效。
使能全局密码管理功能后,设备管理类本地用户密码以及super密码的配置将不被显示,即无法通过相应的display命令查看到设备管理类本地用户密码以及super密码的配置。网络接入类本地用户密码不受密码管理功能控制,其配置显示也不受影响。
使能全局密码管理功能后,首次设置的设备管理类本地用户密码必须至少由四个不同的字符组成。
# 使能全局密码管理功能。
· password-control { aging | composition | history | length } enable
password-control expired-user-login命令用来配置密码过期后允许用户登录的时间和次数。
undo password-control expired-user-login命令用来恢复缺省情况。
密码过期后允许登录的时间为30天,允许登录的次数为3次,即密码过期后系统还允许用户在30天内使用老密码登录3次,超过30天或登录次数超过3次后,系统提示用户设置新密码。
delay delay:密码过期后允许用户登录的时长,取值范围为1~90,单位为天。
times times:密码过期后允许用户登录的最大次数,取值范围为0~10。0表示密码过期后系统直接提示用户设置新密码。
该配置仅对非FTP类型的Login用户生效。对于FTP用户,密码过期后,系统不允许其继续登录。
# 设定允许用户在密码过期之后的60天内登录5次。
password-control history命令用来配置每个用户密码历史记录的最大条数。
undo password-control history命令用来恢复缺省情况。
每个用户密码历史记录的最大条数为4条。
max-record-number:每个用户密码历史记录的最大条数,取值范围为2~15。
开启全局密码管理功能后,系统会持续记录历史密码。当记录的某用户的历史密码条数达到最大值后,该用户的后续新密码历史记录将覆盖最老的一条密码历史记录。
只有当关闭全局密码管理功能(undo password-control enable)或手动清除历史密码记录时(reset password-control history-record),历史密码记录才会被清除掉。
# 配置每个用户密码历史记录的最大条数为10条。
[Sysname] password-control history 10
· password-control history enable
· reset password-control blacklist
password-control length命令用来配置密码的最小长度。
undo password-control length命令用来恢复缺省情况。
非FIPS模式下:
全局的密码最小长度为10个字符;用户组的密码最小长度为全局配置的密码最小长度;本地用户的密码最小长度为所属用户组的密码最小长度。
FIPS模式下:
全局的密码最小长度为15个字符;用户组的密码最小长度为全局配置的密码最小长度;本地用户的密码最小长度为所属用户组的密码最小长度。
用户组视图
本地用户视图
length:密码的最小长度,非FIPS模式下,取值范围为4~32;FIPS模式下,取值范围为15~32。
# 配置全局的密码最小长度为16个字符。
# 配置用户组test的密码最小长度为16个字符。
[Sysname-ugroup-test] password-control length 16
# 配置设备管理类本地用户abc的密码最小长度为16个字符。
[Sysname-luser-manage-abc] password-control length 16
· password-control length enable
password-control login idle-time命令用来配置用户帐号的闲置时间。
undo password-control login idle-time命令用来恢复缺省情况。
用户帐号的闲置时间为90天。
idle-time:用户帐号的闲置时间,取值范围为0~365,单位为天。0表示对用户帐号闲置时间无限制。
如果用户自最后一次成功登录后,在指定的闲置时间内再未成功登录过设备,那么该用户帐号将会失效。
用户最后一次登录设备成功后,若系统时间变化,也可能导致用户账号失效。
账号失效后,用户将无法正常登录设备。若不需要账号闲置时间检查功能,可将idle-time配置为0,表示Password Control功能对用户账号闲置时间无限制。
# 设定用户帐号的闲置时间为30天,表示自最后一次成功登录后,若用户在30天内再未成功登录过设备,那么该用户帐号将会失效。
password-control login-attempt命令用来配置允许用户登录的最大尝试次数以及登录尝试失败后的处理措施。
undo password-control login-attempt命令用来恢复缺省情况。
全局的用户登录尝试次数限制策略为:用户登录尝试的最大次数为3次。如果某用户登录尝试失败,则1分钟后再允许该用户重新登录;用户组的用户登录尝试次数限制策略为全局配置的用户登录尝试次数限制策略;本地用户的登录尝试次数限制策略为所属用户组的用户登录尝试次数限制策略。
用户组视图
本地用户视图
login-times:用户登录尝试的最大次数,取值范围为2~10。
exceed:对登录尝试失败次数超过最大值的用户所采取的处理措施。
lock:表示永久禁止该用户登录。
lock-time time:表示禁止该用户一段时间后,再允许该用户重新登录。其中,time为禁止该用户的时间,取值范围为1~360,单位为分钟。
unlock:表示不禁止该用户,允许其继续登录。
FTP用户或通过VTY方式访问设备的用户登录认证失败后,系统会将其用户名和IP地址加入密码管理的黑名单。当登录失败次数超过指定值后,系统将会根据此处配置的处理措施对其之后的登录行为进行相应的限制,并且该用户只能在满足相应的条件后才可重新登录:
· 对于被永久禁止登录的用户,只有管理员使用reset password-control blacklist命令把该用户从密码管理的黑名单中删除后,该用户才能重新登录。
· 对于被禁止一段时间内登录的用户,当配置的禁止时间超时或者管理员使用reset password-control blacklist命令将其从密码管理的黑名单中删除,该用户才可以重新登录。
· 对于不禁止登录的用户,只要用户登录成功后,该用户就会从该黑名单中删除。
本命令生效后,会立即影响密码管理黑名单中当前用户的锁定状态以及这些用户后续的登录。
# 管理员设定用户登录尝试次数为4次,并且永久禁止该用户登录。
[Sysname] password-control login-attempt 4 exceed lock
之后,若有用户连续尝试认证的失败累加次数达到4次,管理员可通过命令查看到被加入密码管理黑名单中的用户锁定状态由之前的unlock切换为lock,且该用户无法再次成功登录。
[Sysname] display password-control blacklist
Username: test
IP: 192.168.44.1 Login failures: 4 Lock flag: lock
Blacklist items matched: 1.
# 管理员设定用户登录尝试次数为2次,并且限制该用户在3分钟后才能重新登录。
[Sysname] password-control login-attempt 2 exceed lock-time 3
之后,若有用户连续尝试认证的失败累加次数达到2次,管理员可通过命令查看到被加入密码管理黑名单中的用户锁定状态由之前的unlock切换为lock。
Username: test
IP: 192.168.44.1 Login failures: 2 Lock flag: lock
用户被禁止登录3分钟后,将被从密码管理黑名单中删除,且可以重新登录。
· display password-control blacklist
password-control super aging命令用来配置super密码的老化时间。
undo password-control super aging命令用来恢复缺省情况。
密码的老化时间为90天。
aging-time:super密码的老化时间,取值范围为1~365,单位为天。
# 设定super密码的老化时间为10天。
[Sysname] password-control super aging 10
password-control super composition命令用来配置super密码的组合策略。
undo password-control super composition命令用来恢复缺省情况。
非FIPS模式下:
super密码的最少组合类型为1种,每种类型至少包含1个字符。
FIPS模式下:
super密码的最少组合类型为4种,每种类型至少包含1个字符。
type-number type-number:super密码的最少组合类型。其中,type-number表示组合类型,非FIPS模式下,取值范围为1~4;FIPS模式下,取值为4。
type-length type-length:super密码中每种类型的最少字符个数。其中,type-length表示字符个数,非FIPS模式下,取值范围为1~63;FIPS模式下,取值范围为1~15。
密码元素的最少组合类型数以及每种元素的最小个数的乘积应该小于密码允许的最大长度。
# 配置super密码的最少组合类型为4种,每种类型的最少字符个数为5个。
password-control super length命令用来配置super密码的最小长度。
undo password-control super length命令用来恢复缺省情况。
非FIPS模式下:
super密码的最小长度为10个字符。
FIPS模式下:
super密码的最小长度为15个字符。
length:super密码的最小字符长度,非FIPS模式下,取值范围为4~63;FIPS模式下,取值范围为15~63。
# 设定super密码的最小长度为16个字符。
[Sysname] password-control super length 16
password-control update-interval命令用来配置密码更新的最小时间间隔。
undo password-control update-interval命令用来恢复缺省情况。
password-control update-interval interval
密码更新的最小时间间隔为24小时。
interval:密码更新的最小时间间隔,取值范围为0~168,单位为小时。0表示对密码更新的时间间隔无限制。
有两种情况下的密码更新并不受该功能的约束:用户首次登录设备时系统要求用户修改密码;密码老化后系统要求用户修改密码。
# 设定密码更新的最小时间间隔为36小时。
reset password-control blacklist命令用来清除密码管理黑名单中的用户。
reset password-control blacklist [ user-name user-name ]
user-name user-name:清除密码管理黑名单中指定的用户。其中,user-name表示用户名,为1~55个字符的字符串,区分大小写。
对于因为登录认证时密码尝试的失败次数超过最大值而被禁止登录的用户,管理员可以使用本命令将其从黑名单中删除,使其可以重新登录。
# 清除密码管理黑名单中的用户test。
<Sysname> reset password-control blacklist user-name test
Are you sure to delete the specified user in blacklist? [Y/N]:
reset password-control history-record命令用来清除用户的密码历史记录。
reset password-control history-record [ super [ role role-name ] | user-name user-name ]
super:删除super密码的历史记录。
role role-name:删除指定用户角色的用户密码历史记录。其中,role-name表示用户角色,为1~63个字符的字符串,区分大小写。如果不指定参数此参数,将删除所有super密码的历史记录。
user-name user-name:删除指定用户名的密码历史记录。其中,user-name表示用户名,为1~55个字符的字符串,区分大小写。
如果不指定任何参数,将删除所有本地用户的密码历史记录。
# 清除所有本地用户的密码历史记录。当用户输入Y,系统将删除所有本地用户的密码历史记录。
<Sysname> reset password-control history-record
Are you sure to delete all local user’s history records? [Y/N]:y
