09-设备管理命令
本章节下载: 09-设备管理命令 (910.68 KB)
1.1.2 clock delay-compensation
1.1.14 display cpu-usage configuration
1.1.15 display cpu-usage history
1.1.17 display device manuinfo
1.1.18 display device manuinfo fan
1.1.19 display device manuinfo power
1.1.20 display diagnostic-information
1.1.23 display hardware-resource switch-mode
1.1.26 display memory-threshold
1.1.27 display memory-threshold dma
1.1.29 display resource-monitor
1.1.31 display scheduler logfile
1.1.32 display scheduler reboot
1.1.33 display scheduler schedule
1.1.34 display system stable state
1.1.35 display system-working-mode
1.1.36 display transceiver alarm
1.1.37 display transceiver diagnosis
1.1.38 display transceiver eyediagram-diagnosis
1.1.39 display transceiver interface
1.1.40 display transceiver manuinfo
1.1.41 display transceiver power
1.1.43 display version-update-record
1.1.47 hardware-resource switch-mode
1.1.54 monitor cpu-usage enable
1.1.55 monitor cpu-usage interval
1.1.56 monitor cpu-usage logging interval
1.1.57 monitor cpu-usage threshold
1.1.58 monitor memory-usage logging interval
1.1.59 monitor resend cpu-usage
1.1.60 monitor resend memory-threshold
1.1.61 parity-error consistency-check log enable
1.1.62 parity-error consistency-check threshold
1.1.63 parity-error monitor log enable
1.1.64 parity-error monitor period
1.1.65 parity-error monitor threshold
1.1.66 parity-error unrecoverable log enable
1.1.67 parity-error unrecoverable period
1.1.68 parity-error unrecoverable reboot
1.1.69 parity-error unrecoverable threshold
1.1.70 password-recovery enable
1.1.73 reset scheduler logfile
1.1.74 reset version-update-record
1.1.75 resource-monitor minor resend enable
1.1.76 resource-monitor output
1.1.77 resource-monitor resource
1.1.78 restore factory-default
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
· clock protocol
· clock summer-time
· clock timezone
· display clock
clock delay-compensation命令用来配置获取时间的延时补偿时长。
undo clock delay-compensation命令用来恢复缺省情况。
clock delay-compensation { 1pps | gps } timer
undo delay-clock compensation { 1pps | gps }
获取时间的延时补偿时长为0。
1pps:表示通过1pps方式获取时间。当设备通过同轴线缆获取时间时,需设置此参数。
gps:表示通过GPS方式获取时间。当设备通过外接天线获取时间时,需设置此参数。
timer:表示延时补偿时长,取值范围为1~65535,单位为纳秒。延时补偿时长是由使用的同轴线缆或外接天线的长度决定的。
执行本命令时,用户需根据外接天线或同轴线缆的实际长度来确定延时补偿的时长。
# 配置通过GPS获取时间的延时补偿时长为5纳秒。
[Sysname] clock delay-compensation gps 5
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp }
undo clock protocol
通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
系统时间的获取方式有:
· 配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
· 配置clock protocol ntp命令后,通过NTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
· 直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
· 分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
· 直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
· clock datetime
· clock timezone
· display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
· clock datetime
· clock summer-time
· display clock
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口Twenty-FiveGigE1/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface twenty-fivegige 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
· scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2015-2022 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm命令用来显示设备的告警信息。
display alarm [ slot slot-number ]
slot slot-number:指定设备编号,取值只能为1。
# 显示设备的告警信息。
<Sysname> display alarm
Slot CPU Level Info
1 0 ERROR faulty
表1-1 display alarm命令显示信息描述表
Slot |
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上 |
CPU |
告警CPU的编号 |
Level |
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO |
Info |
告警的详细信息。取值为: · faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态) · Fan n is absent:风扇n当前不在位 · Power n is absent:电源n当前不在位 · Power n is faulty:电源n处于异常状态 · The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限 · The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限 |
display alarm active命令用来显示设备当前仍未恢复的告警信息。
display alarm active [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示告警项的概要信息。
当设备的电源、CPU、风扇等运行异常时,使用display alarm命令可以查看到相应的告警信息。对于过去发生的、已经恢复的告警可以使用display alarm history命令查看;对于过去发生的、当前仍未恢复的告警可以使用display alarm active命令查看。
# 显示设备当前仍未恢复的告警信息。
<Sysname> display alarm active
Seq Level Time Info
24 Warning 2020-01-11 12:40:00 CPU usage is in minor alarm state on slot 1.
23 Warning 2020-01-11 12:30:00 Memory minor threshold has been exceeded on slot 1.
22 Minor 2020-01-11 12:18:00 Board state changed to Fault on slot 1.
表1-2 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
告警的级别,级别由高到低依次为Critical、Major、Minor、Warning |
Time |
告警产生的时间 |
Info |
告警的详细信息,涉及风扇、电源、设备温度等硬件故障,主要取值包括: · Board state changed to Fault on slot xx:slot xx变成Fault状态(该slot可能正在启动,或者处于故障状态) · Slot xx fan xx is absent:Slot xx上风扇xx未插入 · Slot xx fan xx is failed:Slot xx上风扇xx处于异常状态 · Slot xx power xx is absent:Slot xx上电源xx未插入 · Slot xx power xx failed:Slot xx上电源xx处于异常状态 · Temperature is higher than the high-temperature alarming threshold on slot xx sensor inflow xx:slot xx上的传感器xx的温度高于高温门限 · Memory minor threshold has been exceeded on slot xx:slot xx的空闲内存高于minor门限 · CPU usage is in minor alarm state on slot xx:slot xx的CPU使用率高于minor门限 · Interface-name: RX power is high!:接口Interface-name光功率过高 · Interface-name:The bit error ratio exceeds the upper threshold:接口Interface-name误码率超过了上限 · SSH user username (IP: IP-Address) connected to the server successfully:SSH用户的用户名(IP:IP地址)成功登录服务器 · Member port xx of aggregation group xx changed to the inactive state, because xx.:聚合xx内成员接口xx因为xx原因非选中 · The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4):LDP会话状态变化 ¡ $1:LDP会话状态,取值包括:nonexistent,initialized,openrec,opensent,operational ¡ $2:LDP会话处于Operational状态的持续时间 ¡ $3:LDP会话收到未知信息的次数 ¡ $4:LDP会话收到未知TLV的次数 · The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量超过允许接收的最大路由数量 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 · BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.:从对等体学到的路由数量超过了允许的最大路由数量 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:允许从对等体接收的最大路由前缀数量 · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7):接收的路由数量占允许的最大路由数量的百分比达到了阈值 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7):从BGP对等体收到的路由数量超过告警阈值 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 |
# 显示设备当前仍未恢复的告警信息详细内容。
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
Info: Board state changed to Fault on slot 2.
表1-3 display alarm active verbose命令显示信息描述表
Seq |
告警序列号,告警发生时由系统自动分配 |
Alarm name |
告警的名称 |
Alarm source |
告警对象所在位置 |
Level |
Start time |
告警发生时间 |
Info |
告警的详细信息 |
· display alarm
· display alarm history
display alarm history命令用来显示已经恢复的告警信息。
display alarm history [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示概要信息。
本命令最多可显示的信息条数与设备的型号有关,请以设备的实际情况为准。
# 显示设备告警历史信息。
<Sysname> display alarm history
Seq Time Info
23 2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
本命令显示信息描述表请参见表1-2。
# 显示设备告警历史信息详细内容。
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
表1-4 display alarm history verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
AlarmPosition |
告警对象所在位置 |
Start time |
告警发生时间 |
Level |
Recovery time |
告警恢复时间 |
Info |
告警的详细信息,取值主要包括: · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7):从BGP对等体收到的路由数量降低到告警阈值以下 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:允许从对等体接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).:从BGP对等体收到的路由数量降低到告警阈值以下 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量降低到允许接收的最大路由数量以下 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 · BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6.:从对等体学到的路由数量降低到了允许的最大路由数量以下 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 |
· display alarm
· display alarm active
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/16/2015
· clock datetime
· clock timezone
· clock summer-time
display copyright命令用来显示设备的版权信息。
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
表1-5 display cpu-usage命令显示信息描述表
1% in last 5 seconds |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU或CPU核的平均利用率。该字段显示的是最近一个5秒统计周期内CPU或CPU核的平均利用率 |
Last 5 sec |
1% in last 1 minute |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU或CPU核的平均利用率 |
Last 1 min |
1% in last 5 minutes |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU或CPU核的平均利用率 |
Last 5 min |
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
cpu cpu-number:表示CPU的编号。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 95%.
Current recovery threshold is 60%.
表1-6 display cpu-usage configuration命令显示信息描述表
CPU usage monitor is enabled. |
CPU利用率历史记录功能处于开启状态 |
Current monitor interval is 60 seconds. |
CPU利用率历史记录的采样周期为60秒 |
Current severe alarm threshold is 99%. |
CPU利用率高级别告警门限为99% |
Current minor alarm threshold is 95%. |
CPU利用率低级别告警门限为95% |
Current recovery-threshold is 60%. |
CPU利用率恢复门限为60% |
· monitor cpu-usage enable
· monitor cpu-usage interval
· monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
· 纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
· 横坐标表示时间,时间越靠左表示距离当前时间越近。
· 用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
display device[ flash | usb ] [ slot slot-number | verbose ]
flash:显示Flash的信息。
usb:显示USB接口的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不指定flash和usb参数时,显示设备的信息。
# 显示设备信息。
<Sysname> display device
Slot Type State Subslot Soft Ver Patch Ver
1 S6826-48Y8C Master 0 6601006 None
表1-7 display device命令显示信息描述表
Type |
设备类型 |
State |
设备的角色,取值为: Master:表示本设备 |
Soft Ver |
设备上运行的软件版本 |
Patch Ver |
当前设备上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁 若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级” |
display device manuinfo命令用来显示设备的电子标签信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo fan命令用来显示风扇的电子标签信息。
display device manuinfo slot slot-number fan fan-id
fan-id:表示设备上风扇的ID编号。
# 显示指定风扇的电子标签信息。
<Sysname> display device manuinfo slot 1 fan 1
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
display device manuinfo slot slot-number power power-id
power-id:表示设备上电源的ID编号。
# 显示指定电源的电子标签信息。
<Sysname> display device manuinfo slot 1 power 1
显示信息略……。
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ equipment | hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
equipment:收集装备相关的诊断命令信息。
hardware:收集硬件相关的诊断信息。
ifmgr:收集IFMGR模块相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1) 使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2) 使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3) 使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定equipment、hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
· gunzip(基础配置命令参考/文件系统管理)
· more(基础配置命令参考/文件系统管理)
· tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
# 显示设备上所有温度传感器的温度信息。
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
1 hotspot 1 27 0 57 62 NA
1 hotspot 2 36 0 67 72 NA
1 hotspot 3 46 0 100 117 NA
1 hotspot 4 42 0 88 102 107
1 hotspot 5 30 NA NA NA NA
表1-8 display environment命令显示信息描述表
System Temperature information (degree centigrade) |
系统温度信息,单位为摄氏度 |
sensor |
温度传感器 · outflow:表示出风口温度传感器 · hotspot 1:主板电源风扇侧,板温 · hotspot 2:MAC芯片附近,板温 · hotspot 3:主板前面板侧,板温 · hotspot 4:MAC温度,读取MAC芯片内部寄存器 · hotspot 5:CPU温度,读取CPU芯片内部寄存器 |
Slot |
当显示数字时表示指定slot上温度传感器的温度信息 |
Temperature |
当前温度 |
Lower |
低温告警门限。当显示为NA时,表示不支持该门限 |
Warning |
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限 |
Alarm |
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限 |
Shutdown |
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限 |
display fan命令用来显示风扇的工作状态。
display fan [ slot slot-number [ fan-id ] ]
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Slot 1:
Fan 1:
State : Normal
Airflow Direction: Port-to-power
Prefer Airflow Direction: Port-to-power
Fan 2:
State : Normal
Fan 3:
State : Normal
Fan 4:
State : Normal
Fan 5:
State : Normal
表1-9 display fan命令显示信息描述表
Slot 1 |
设备的成员编号 |
Fan 1 |
设备上风扇的编号 |
State |
风扇状态: · Absent:风扇不在位 · Normal:风扇正常工作 · Fault:风扇故障 · FanDirectionFault:用户期望的风道方向与风扇框的实际风道方向不一致 |
Airflow Direction |
风扇模块的实际风道方向: · Port-to-power:风扇从端口侧向电源侧抽风,即风向从前向后 · Power-to-port:风扇从电源侧向端口侧吹风,即风向从后向前 |
Prefer Airflow Direction |
用户期望的风扇模块的风道方向: · Port-to-power:风扇从端口侧向电源侧抽风,即风向从前向后 · Power-to-port:风扇从电源侧向端口侧吹风,即风向从后向前 |
display hardware-resource switch-mode命令用来显示MAC地址表、ARP表/ND表、路由表的硬件资源模式。
display hardware-resource [ switch-mode ]
不指定switch-mode参数时,表示显示所有硬件资源的运行模式。
# 显示MAC地址表、ARP表/ND表、路由表的硬件资源模式。
<H3C> display hardware-resource switch-mode
Switch-mode resource(switch-mode), all supported modes:
0 MAC table:8K, ARP and ND tables:8K, routing table:16K
Default Current Next
0 0 0
表1-10 display hardware-resource命令显示信息描述表
Switch-mode resource(switch-mode), all supported modes |
MAC地址表、ARP表/ND表、路由表支持的硬件资源模式 |
Default |
MAC地址表、ARP表/ND表、路由表的硬件资源的缺省运行模式 |
Current |
MAC地址表、ARP表/ND表、路由表的硬件资源的当前运行模式 |
Next |
最新配置的MAC地址表、ARP表/ND表、路由表的硬件资源模式 |
· hardware-resource switch-mode
display memory命令用来显示内存使用情况。
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
cpu cpu-number:表示CPU编号。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 3607728 1660120 1947608 0 112 679464 54.7%
-/+ Buffers/Cache: 980544 2627184
Swap: 0 0 0
LowMem: 1789104 638072 1151032 -- -- -- 64.3%
HighMem: 1818624 1022048 796576 -- -- -- 43.8%
# 显示设备的内存使用情况的简要信息。
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 3607728 1660796 1946932 112 679464 54.6%
Low memory statistics are measured in KB:
1 0 1789104 638624 1150480 -- -- 64.3%
High memory statistics are measured in KB:
1 0 1818624 1022172 796452 -- -- 43.8%
表1-11 display memory命令显示信息描述表
Memory statistics are measured in KB: |
系统内存使用情况,以下统计信息均以KB为单位 |
Mem |
内存使用信息 |
Total |
系统可分配的物理内存的大小 设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小 |
Used |
整个系统已用的物理内存大小 |
Free |
整个系统可用的物理内存大小 |
Shared |
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值 |
Buffers |
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值 |
Cached |
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用。取值为“--”时,表示不支持统计该参数的值 |
Caches |
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用 |
FreeRatio |
整个系统物理内存的空闲率。包含当前剩余空闲内存以及高速缓冲寄存器中当前正在使用但是内存告警状态下可主动释放的内存 |
-/+ buffers/cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小 -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小 |
Swap |
交换分区的使用信息 |
LowMem |
低端内存使用信息 |
HighMem |
高端内存使用信息 |
display memory dma命令用来显示DMA内存的使用情况。
display memory dma [ slot slot-number [ cpu cpu-number ] ]
# 显示slot1的DMA内存使用相关信息。
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total Used Free FreeRatio
16384 6140 10244 63%
表1-12 display memory dma 命令显示信息描述表
DMA memory statistics measured in KB |
系统使用DMA内存情况,单位为KB |
Total |
内存分片的总个数,为Free和Used之和 |
Used |
系统已使用的DMA内存大小 |
Free |
系统可使用的DMA内存大小 |
FreeRatio |
Free与Total的比率,可以反映系统DMA内存的空闲率 |
display memory-threshold命令用来显示内存告警门限相关信息。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
Minor: 96M
Severe: 64M
Critical: 48M
Normal: 128M
Early-warning: 256M
Secure: 304M
Current free-memory state: Normal (secure)
Free-memory event statistics:
[Back to secure state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Entered early-warning state]
First notification at: 0.0
Latest notification at: 0.0
[Back to normal state]
[Entered minor alarm state]
[Back to minor alarm state]
[Entered severe alarm state]
[Back to severe alarm state]
[Entered critical alarm state]
表1-13 display memory-threshold命令显示信息描述表
Memory usage threshold |
内存利用率阈值 |
Free-memory thresholds Minor Severe Critical Normal Early-warning Secure |
剩余内存门限阈值: · Minor:一级告警门限,单位为MB · Severe:二级告警门限,单位为MB · Critical:三级告警门限,单位为MB · Normal:恢复到正常状态的阈值,单位为MB · Early-warning:预告警门限,单位为MB · Secure:恢复预告警门限状态的阈值,单位为MB |
Current free-memory state |
系统当前内存使用状态: · Normal:正常状态 · Minor:一级告警门限状态 · Severe:二级告警门限状态 · Critical:三级告警门限状态 · Normal (early-warning):预告警状态 · Normal (secure):安全状态 |
Free-memory event statistics: |
门限事件统计信息,事件分为: · Back to secure state:恢复到预告警前的状态 · Entered early-warning state:进入预告警门限状态 · Back to normal state:内存恢复到正常状态 · Entered minor alarm state:进入一级告警门限状态 · Back to minor alarm state:恢复到一级告警前的状态 · Entered severe alarm state:进入二级告警门限状态 · Back to severe alarm state:恢复到二级告警前的状态 · Entered critical alarm state:进入三级告警门限状态 |
First notification at |
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification at |
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notification send |
事件发生的总次数 |
display memory-threshold dma命令用来显示DMA内存告警相关信息。
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
[Entered to critcal state]
表1-14 display memory-threshold dma 命令显示信息描述表
Free DMA memory thresholds: Critical: Normal: |
DMA内存告警阈值(单位为KB): · Critical:告警阈值 · Normal:告警恢复阈值 |
Current DMA memory state |
DMA内存的当前状态: · Critical:告警状态 · Normal:正常状态 |
Free memory event statistics: |
告警事件统计信息,事件分为: · Back to normal state:内存恢复到正常状态 · Entered to critcal state:进入告警状态 |
First notification |
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification |
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications sent |
告警事件发生的总次数 |
display power命令用来显示设备电源的信息。
display power [ slot slot-number [ power-id | verbose ] ]
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
# 显示设备电源的简要信息。
<Sysname> display power
Slot 1:
Input Power: 99(W)
PowerID State Mode Current(A) Voltage(V) Power(W) FanDirection
1 Normal AC 5.40 12.35 66 PowerToPort
2 Normal AC 2.85 10.00 33 PortToPower
表1-15 display power命令显示信息描述表
Input Power |
设备的额定功率 |
PowerID |
设备上的电源模块编号 |
State |
电源模块的状态 · Absent:电源不在位 · Normal:电源正常工作 · Fault:电源故障 |
Mode |
电源模块的类型,取值为: · AC:表示交流电源 · DC:表示直流电源 |
Current(A) |
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息 |
Voltage(V) |
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息 |
Power(W) |
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
FanDirection |
电源模块内风扇的吹风方向,取值为: · PowerToPort:电源侧进风、端口侧出风 · PortToPower:端口侧进风、电源侧出风 |
# 显示电源的详细信息。
<Sysname> display power slot 1 verbose
Slot 1:
Input Power: 98(W)
1 Normal AC 8.18 12.07 98 PowerToPort
2 Absent -- -- -- -- --
表1-16 display power verbose命令显示信息描述表
Input Power |
设备的额定功率 |
PowerID |
设备上的电源模块编号(对于仅支持单电源供电的设备,不存在编号为2的电源,用户只需关注编号为1的电源工作状态) |
State |
电源模块的状态 · Absent:可插拔电源模块电源不在位 · Normal:电源正常工作 · Fault:电源故障或无供电输入 |
Mode |
Current(A) |
Voltage(V) |
Power(W) |
FanDirection |
display resource-monitor命令用来显示资源监控功能的相关信息。
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见“设备可监测的资源描述表”。
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource Minor Severe Free/Total
(%) (%) (absolute)
arp 50 20 90095/90098
表1-17 display resource-monitor命令显示信息描述表
Minor alarms resending |
周期发送低级别资源告警通知功能的开启状态: · Enabled:表示该功能已开启 · Disabled:表示该功能未开启 |
Resource |
监控资源的名称 |
Minor (%) |
低级别告警门限,单位为百分比 |
Severe (%) |
高级别门限,单位为百分比 |
Free/Total (absolute) |
剩余资源的数量/该资源的总数,用绝对值形式表示 |
· resource-monitor minor resend enable
· resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang twenty-fivegige 1/0/1 to twenty-fivegige 1/0/3
[Sysname-if-range]shutdown
表1-18 display scheduler logfile命令显示信息描述表
Logfile Size |
Schedule日志文件的大小,单位为字节 |
Job name |
Job的名称 |
Schedule name |
Schedule的名称 |
Execution time |
开始执行Job的时间 |
Completion time |
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息) |
Job output |
Job中的命令执行时的输出信息 |
· reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
· scheduler reboot at
· scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2015
Last execution time : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts : 1
Job name Last execution status
shutdown Successful
表1-19 display scheduler schedule命令显示信息描述表
Schedule name |
Schedule的名称 |
Schedule type |
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息 |
Start time |
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Last execution time |
Schedule上一开始执行的时间 · 如果没有为Schedule配置执行时间,则不会显示该信息 · 如果还没有执行,则显示Yet to be executed |
Last completion time |
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Execution counts |
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息 |
Job name |
Schedule下关联的Job的名称 |
Last execution status |
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看) · Successful:表示执行成功 · Failed:表示执行失败 · Waiting:表示正在等待被执行 · In process:表示正在执行 · -NA-:表示还没有到执行时间 |
display system stable state命令用来显示系统的稳定状态。
display system stable state [ summary ]
summary:显示系统稳定状态的汇总信息。不指定该参数时,显示CPU的运行状态以及CPU运行状态的详细信息。
设备启动需要一定的时间,才能达到Stable状态。如果设备长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
· 通过display device命令查看设备是否处于故障状态。
· 通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
· 通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统稳定状态的汇总信息。
<Sysname> display system stable state summary
System state : Stable
Redundancy state : No redundancy
NSR state : No standby
# 显示系统的稳定状态。
Redundancy state: No redundancy
Slot CPU Role State
1 0 Active Stable
表1-20 display system stable state命令显示信息描述表
System state |
设备运行状态的汇总: Stable:稳定运行,表示设备处于稳定运行状态 · Not ready:未稳定 |
Redundancy state |
主备状态: · Stable:主备状态稳定,可以倒换 · No redundancy:系统无冗余,不能倒换 · Not ready:未稳定,不可以倒换 |
NSR state |
各模块NSR(Nonstop Routing,不间断路由)状态的汇总,取值为: · Ready:稳定状态,表示所有开启的NSR功能均能正常工作 · Not ready:未稳定状态,此时不能进行进程倒换或者主备倒换 · No standby:没有备设备 · Not configured:未开启NSR功能 |
Role |
设备在系统中的身份: Active:该设备 |
State |
(暂不支持)成员设备状态: · Stable:成员设备稳定运行 · Board inserted:成员设备加入 · Kernel initiating:成员设备内核初始化 · Service starting:成员设备上的服务正在启动 · Service stopping:成员设备上的服务正在关闭 · HA Batch backup:HA批量备份中 · Interface data batch backup:接口管理批量备份未完成 |
当前对象处于未稳定状态 |
· display device
display system-working-mode命令用来显示设备的工作模式。
# 显示设备的工作模式。
<Sysname> display system-working-mode
The current system working mode is expert.
The system working mode for next startup is expert.
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-21 SFP/SFP28/SFP+的display transceiver alarm命令输出信息描述表
RX signal loss |
接收信号丢失 |
RX power high alarm |
接收光功率高告警 |
RX power high warning |
接收光功率高预警 |
RX power low alarm |
接收光功率低告警 |
RX power low warning |
接收光功率低预警 |
TX fault |
发送错误 |
TX bias high alarm |
偏置电流高告警 |
TX bias high warning |
偏置电流高预警 |
TX bias low alarm |
偏置电流低告警 |
TX bias low warning |
偏置电流低预警 |
TX power high alarm |
发送光功率高告警 |
TX power high warning |
发送光功率高预警 |
TX power low alarm |
发送光功率低告警 |
TX power low warning |
发送光功率低预警 |
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
Voltage high alarm |
电压高告警 |
Voltage high warning |
电压高预警 |
Voltage low alarm |
电压低告警 |
Voltage low warning |
电压低预警 |
Transceiver info I/O error |
模块信息读写错误 |
Transceiver info checksum error |
模块信息校验和错误 |
Transceiver type and port configuration mismatch |
模块类型和端口配置不匹配 |
Transceiver type not supported by port hardware |
端口不支持该模块类型 |
RX CDR loss of lock |
接收侧CDR失锁,表示信号不好 |
TX CDR loss of lock |
发送侧CDR失锁,表示信号不好 |
表1-22 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
电压高告警 |
电压高预警 |
Voltage low alarm |
电压低告警 |
电压低预警 |
RX loss of signal(channel x) |
通道x接收到的信号丢失 |
TX fault(channel x) |
通道x发送报文时出错 |
TX loss of signal(channel x) |
通道x发送的信号丢失 |
RX power high(channel x) |
通道x接收到的光的功率太高 |
RX power low(channel x) |
通道x接收到的光的功率太低 |
TX power high alarm(channel x) |
通道x发送光功率高告警 |
TX power high warning(channel x) |
通道x发送光功率高预警 |
TX power low alarm(channel x) |
通道x发送光功率低告警 |
TX power low warning(channel x) |
通道x发送光功率低预警 |
TX bias high(channel x) |
通道x的偏置电流高 |
TX bias low(channel x) |
通道x的偏置电流低 |
模块读写错误 |
模块信息校验和错误 |
Transceiver type and port configuration mismatched |
模块类型和端口配置不匹配 |
Transceiver type not supported |
端口不支持该类型的模块 |
表1-23 QSFP-DD光模块的display transceiver alarm命令输出信息描述表
Data path firmware fault |
数据通道固件错误 |
Module firmware fault |
模块固件错误 |
Module state changed |
模块状态改变 |
Data path state changed in channel x |
通道x的数据路径状态改变 |
TX loss in channel x |
通道x的发送信号丢失 |
TX CDR LOL in channel x |
通道x的TX 时钟和数据恢复失锁 |
TX input eq fault in channel x |
通道x的TX输入均衡错误 |
RX CDR LOL in channel x |
通道x的RX 时钟和数据恢复失锁 |
Loss of reference clock |
基准时钟丢失 |
L-Host Pattern Generator LOL in channel x |
通道x的主机端码型发生器失锁 |
L-Media Pattern Generator LOL in channel x |
通道x的媒体端模式发生器失锁 |
L-Host Pattern Checker LOL in channel x |
通道x的主机端码型检查器失锁 |
L-Media Pattern Checker LOL in channel x |
通道x的媒体端模式检查器失锁 |
# 显示接口Twenty-FiveGigE1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1 transceiver current alarm information:
RX signal loss
RX power low
表1-24 display transceiver alarm显示信息描述表
transceiver current alarm information |
接口光模块当前故障告警信息 |
RX signal loss |
接收信号丢失 |
RX power low |
接收光功率低告警 |
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Twenty-FiveGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1 transceiver diagnostic information:
Temp.(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Warning thresholds:
Temp(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 45 3.25 1.25 -15.00 4.00
Low 25 2.85 0.85 -25.00 1.00
# 显示接口HundredGigE1/0/1上插入的QSFP28可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface hundredgige 1/0/49
HundredGigE1/0/49 transceiver diagnostic information:
[module] Temp.(C) Voltage(V)
29 3.33
[channel] Bias(mA) RX power(dBm) TX power(dBm)
1 0.00 -36.96 -36.96
2 0.00 -36.96 -36.96
3 0.00 -36.96 -36.96
4 0.00 -36.96 -36.96
Alarm thresholds:
High 75 3.47 13.00 3.40 5.00
Low -5 3.13 3.00 -14.00 -10.00
Warning thresholds:
High 70 3.45 11.00 2.40 3.00
Low 0 3.15 5.00 -11.00 -8.00
Total average launch power(dBm): 5.90
表1-25 display transceiver diagnosis显示信息描述表
transceiver diagnostic information |
接口插入的光模块的数字诊断信息 |
Current diagnostic parameters |
当前的诊断参数 |
Temp.(C) |
数字诊断参数——温度,单位为°C,精确到1°C |
Voltage(V) |
数字诊断参数——电压,单位为V,精确到0.01V |
TEC Curr. (%) |
数字诊断参数——制冷器工作电流/制冷器的额定电流,单位为%,精确到0.01% |
Laser Temp.(C) |
数字诊断参数——激光器温度,单位为°C,精确到0.01°C |
Bias(mA) |
数字诊断参数——偏置电流,单位为mA,精确到0.01mA |
Total RX power(dBm) |
数字诊断参数——总接收光功率,单位为dBm,精确到0.01dBm |
Total TX power(dBm) |
数字诊断参数——总发送光功率,单位为dBm,精确到0.01dBm |
RX power(dBm) |
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm |
TX power(dBm) |
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm |
Alarm thresholds |
告警门限 |
High |
高告警门限或高预警门限 |
Low |
低告警门限或低预警门限 |
Warning threshold |
预警门限 |
Total average launch power(dBm) |
针对多通道光模块的各通道发射总功率,单位为mBM,精确到0.01dBm |
display transceiver eyediagram-diagnosis命令用来诊断可插拔光模块,并以眼图的形式显示诊断信息。
display transceiver eyediagram-diagnosis interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:诊断接口上插入的可插拔光模块,并以眼图的形式显示诊断信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
本命令是用于模仿专业检测仪器测试数据传输的质量,通过获取芯片上接收数据的采样值,以眼图的形式输出可插拔光模块的诊断结果,方便用户分析和评估可插拔光模块的数据传输质量。
通过眼图分析可插拔光模块的数据传输质量的简要方法:
· 眼睛区域越大,眼睛形状越清晰,表明数据传输信号越稳定,质量越好。眼睛区域是位于中心线(即0mV线)上下的空白区域。
· 眼睛区域中没有数字,表明数据传输质量好;眼睛区域中存在数字,表明数据传输质量不好。
# 诊断接口Twenty-FiveGigE1/0/1上插入的可插拔光模块,并以眼图的形式输出诊断结果。
<Sysname> display transceiver eyediagram-diagnosis interface twenty-fivegige 1/0/1
This operation might consume a large amount of system resources. It might cause unknown risks and might take several minutes. Continue?[Y/N]:y
| EYESCAN Phy: 0x0e1 lane_mask: 0x01 |
Each character N represents approximate error rate 1e-N at that location
UI/64 : -30 -25 -20 -15 -10 -5 0 5 10 15 20 25 30
128mV : 111111111111111111111111112222322222222211111111111111111111111
124mV : 111111111111111111111111122233332222222221111111111111111111111
120mV : 111111111111111111111111222333333332222222211111111111111111111
115mV : 111111111111111111111112223334443333222222221111111111111111111
111mV : 111111111111111111111122233344444333322222222111111111111111111
107mV : 111111111111111111111122233445544433332222222211111111111111111
103mV : 111111111111111111111222334456655544333332222222111111111111111
99mV : 111111111111111111112223344566665544433333222222211111111111111
95mV : 11111111111111111111222344556776655443333322222221111111111111
91mV : 11111111111111111112223345567 :766554443333222222111111111111
86mV : 11111111111111111122233455677 : 76655444333322222211111111111
82mV : 111111111111111111223344567----+---7665544433322222221111111111
78mV : 111111111111111112223345667 : :76655444333222222111111111
74mV : 11111111111111112223345677: : :77665544333322222111111111
70mV : 1111111111111111223344567 7 : : 76655443332222211111111
66mV : 1111111111111112223345677 : : : 7665444333222221111111
62mV : 111111111111112223345667--+----+----+----+776554433322222111111
57mV : 111111111111112223445677 : : : :76655443332222111111
53mV : 1111111111111222334566 : : : : 7765544333222211111
49mV : 1111111111112223345567 : : : : 76554333222221111
45mV : 111111111111222334567: : : : : :7655443322222111
41mV : 111111111112223345677+----+----+----+----+----+7765544332222211
37mV : 11111111112223344567 : : : : : :776544333222211
33mV : 11111111112223345667 : : : : : : 7654433322221
28mV : 1111111112223344567 : : : : : : 7765443322222
24mV : 111111111222334567 : : : : : : 765543332222
20mV : 111111112223345567---+----+----+----+----+----+----+76544333222
16mV : 11111112222344567 : : : : : : :7654433222
12mV : 1111111222334567: : : : : : : :77655433322
8mV : 1111112223344567: : : : : : : : 765543322
4mV : 111111222334566 : : : : : : : : 776544332
0mV : 111111222344567-+----+----+----+----+----+----+----+----6554332
-4mV : 111111222344567 : : : : : : : : 76544332
-8mV : 111111222334567 : : : : : : : : 765443332
-12mV : 1111112223344567: : : : : : : :7655433322
-16mV : 1111111222334567: : : : : : : :7654433222
-20mV : 11111112222344567----+----+----+----+----+----+----776544333222
-24mV : 111111112223345677 : : : : : : 765543332222
-28mV : 111111111222334567 : : : : : : 7665443332222
-33mV : 1111111111222344567 : : : : : : 77654433322221
-37mV : 1111111111222334567 : : : : : :766544333222211
-41mV : 11111111111223344567-+----+----+----+----+----+7765544332222211
-45mV : 11111111111222334566 : : : : : 77655443332222111
-49mV : 1111111111112223345677 : : : : 76554433322221111
-53mV : 1111111111111222344567 : : : : 7765544333222221111
-57mV :1111111111111222334567 : : : :77655443332222211111
-62mV : 111111111111112223445677--+----+----+----+776654433332222211111
-66mV : 111111111111111223345567 : : : 7765544333222222111111
-70mV : 1111111111111112223345667 : : : 7655443333222221111111
-74mV :11111111111111112223345667 : : : 766554433322222211111111
-78mV :111111111111111112233445677 : : 776554433322222211111111
-82mV : 111111111111111112223345567----+----766554443332222221111111111
-86mV : 1111111111111111112223345567 : 765544433322222221111111111
-91mV : 11111111111111111112233445667 : 7665444333322222211111111111
-95mV : 111111111111111111122233445667 :7766554433332222222111111111111
-99mV : 111111111111111111112223344566777665544333322222221111111111111
-103mV : 111111111111111111111223334556676655443333222222211111111111111
-107mV : 111111111111111111111222333445565544333322222222111111111111111
-111mV : 111111111111111111111122233444554443333222222221111111111111111
-115mV : 111111111111111111111112223334444433332222222211111111111111111
-120mV : 111111111111111111111111222333444333322222222111111111111111111
-124mV : 111111111111111111111111222233333332222222211111111111111111111
-128mV : 111111111111111111111111122223333322222222111111111111111111111
UI/64 :-30 -25 -20 -15 -10 -5 0 5 10 15 20 25 30
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
# 显示接口Twenty-FiveGigE1/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface twenty-fivegige 1/0/1
显示信息略……。
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Twenty-FiveGigE1/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface twenty-fivegige 1/0/1
显示信息略……。
display transceiver power命令用来显示可插拔光模块的功耗信息。
display transceiver power [ interface interface-type interface-number ]
interface interface-type interface-number:显示接口上插入的可插拔光模块的功耗信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示设备所有可插拔接口模块的功耗。
<Sysname> display transceiver power
Interface Transceiver type Current power(w) Max power(w)
WGE1/0/1 100G_BASE_SR4_QSFP28 2.30 3.50
WGE1/0/2 100G_BASE_LR4_QSFP28 2.50 4.00
WGE1/0/3 100G_BASE_ER4_QSFP28 3.51 5.00
WGE1/0/4 Absent -- --
WGE1/0/5 100G_BASE_SR4_QSFP28 -- --
WGE1/0/6 10G_BASE_LR_SFP -- 1.50
10G_BASE_LR_SFP 1.00 --
Current total power : 9.31w
Maximum total Power : 15.5w
# 显示接口Twenty-FiveGigE1/0/1上插入的可插拔接口模块的功耗。
<Sysname> display transceiver power interface twenty-fivegige 1/0/1
WGE1/0/1 10G_BASE_LR_SFP 1.00 1.50
表1-26 display transceiver power命令信息显示描述表
接口简称 |
Transceiver type |
模块类型 |
Current power(w) |
当前功耗,单位为w,精确到0.01w |
Max power(w) |
最大功耗,单位为w,精确到0.01w |
Current total power |
当前总功耗,单位为w,精确到0.01w |
Max total power |
最大总功耗,单位为w,精确到0.01w |
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
H3C Comware Software, Version 7.1.070, ESS 6713P01
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C S6826-48Y8C uptime is 0 weeks, 0 days, 10 hours, 0 minutes
Last reboot reason : Cold reboot
Boot image: flash:/s9826_6826-cmw710-boot-e6713p01.bin
Boot image version: 7.1.070, ESS 6713P01
Compiled Nov 13 2023 11:00:00
System image: flash:/s9826_6826-cmw710-system-e6713p01.bin
System image version: 7.1.070, ESS 6713P01
显示信息略……。
表1-27 display version命令显示信息描述表
H3C Comware Software, Version 7.1.070, ESS 6713P01 |
表示设备使用的软件版本 |
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved. |
表示设备的版权申明 |
H3C S6826-48Y8C uptime is 0 weeks, 0 days, 10 hours, 0 minutes |
表示设备的型号以及本次启动后的持续运行时间 |
Last reboot reason |
表示设备上次重启的原因,主要取值有: · User reboot:表示用户通过命令行、SNMP等方式重启设备 · Cold reboot:表示断电导致的重启。部分产品升级导致Bootware基本段版本变化时,也会显示本原因 · Kernel abnormality reboot:表示内核异常导致的重启 · DeadLoop reboot:表示内核死循环导致的重启 · DEV HandShake reboot:表示设备管理握手失败导致的重启 · SlaveSwitch reboot:表示主备倒换导致的重启 · IRF Merge reboot:表示IRF合并重启本设备 · Auto Update reboot:表示版本自动升级导致的重启 · Memory exhaust reboot:表示单板内存耗尽导致的重启 · Double Master Reboot:表示异常双主控导致的重启 |
Boot image: flash:/s9826_6826-cmw710-boot-e6713p01.bin Boot image version: 7.1.070, ESS 6713P01 Compiled Nov 13 2023 11:00:00 |
表示设备当前运行过程中使用的Boot包以及该软件包的版本、编译时间 |
display version-update-record命令用来显示启动软件包版本更新操作的记录。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2015 at 06:23:54):
*Name : boot-test.bin
Version : 7.1.070 Test 0001
Compile time: Mar 25 2015 15:52:43
*Name : system-test.bin
表1-28 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54) |
最近的第n次更新的时间,Record 1为最新的一次更新 |
*Name |
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化 |
Version |
软件包的版本号 |
Compile time |
版本编译时间 |
· reset version-update-record
download manuinfo fan命令用来配置风扇的序列号。
download manuinfo slot slot-number fan fan-id serial-num serial-number
设备未配置风扇的序列号。
fan fan-id:表示设备上风扇的ID编号。
serial-num serial-number:表示风扇的序列号。
未配置风扇序列号或配置的序列号不正确时,执行display device manuinfo和display device manuinfo fan命令行风扇序列号和生产日期显示为NONE。
风扇的序列号粘贴于风扇上,请将序列号配置给对应的风扇ID。
# 配置指定风扇的序列号。
[sysname] download manuinfo slot 1 fan 2 serial-num 21020000000000000000
fan prefer-direction命令用来配置设备期望的风扇模块的风道方向。
undo fan prefer-direction命令用来恢复缺省情况。
fan prefer-direction slot slot-number { port-to-power | power-to-port }
undo fan prefer-direction slot slot-number
缺省情况与下,用户期望的风道方向为port-to-power,即端口侧进风、电源侧出风。
port-to-power:表示风道方向为端口侧进风、电源侧出风。
power-to-port:表示风道方向为电源侧进风、端口侧出风。
本命令用于配置期望的风扇模块的风道方向,不是调整风道方向。当检测到风扇模块的风道方向与设备期望的风道方向不一致时,系统会打印Trap和Log信息提醒用户。此时,用户可根据提示信息进行相应的处理。
# 配置设备期望的风扇模块的风道方向为port-to-power。
[Sysname] fan prefer-direction slot 1 port-to-power
· display fan
hardware-alarm disable命令用来关闭硬件资源告警的发送功能。
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
undo hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
所有硬件资源告警的发送功能处于开启状态。
all:所有硬件资源告警信息的发送功能。
board:与单板相关的资源告警信息的发送功能。
bus:与总线相关的资源告警信息的发送功能。
chip-channel:与芯片通道相关的资源告警信息的发送功能。
chip-port:与芯片端口相关的资源告警信息的发送功能。
device:与设备相关的资源告警信息的发送功能。
disk:与磁盘相关的资源告警信息的发送功能。
fan:与风扇相关的资源告警信息的发送功能。
interface:与接口相关的资源告警信息的发送功能。
syslog:硬件资源告警日志信息的发送功能。
Subcard:与子卡相关的资源告警信息的发送功能。
transceiver:与光模块相关的资源告警信息的发送功能。
trap:硬件资源告警Trap信息的发送功能。
power:与电源相关的资源告警信息的发送功能。
voltage:与电压相关的资源告警信息的发送功能。
# 关闭所有硬件的资源告警Trap信息的发送功能。
<Sysname> system
[Sysname] hardware-alarm trap resource-type all disable
# 关闭与设备相关的资源告警日志信息的发送功能。
<Sysname> system
[Sysname] hardware-alarm syslog resource-type device disable
hardware-resource switch-mode命令用来配置MAC地址表、ARP表/ND表、路由表的硬件资源模式。
undo hardware-resource switch-mode命令用来恢复缺省情况。
hardware-resource switch-mode 0
MAC地址表、ARP表/ND表、路由表的硬件资源模式为0。
0:设备工作的表项模式为标准模式。
配置该命令后,须手工保存配置并重启设备才能生效。重启设备前请评估重启对网络造成的影响,做好相关准备工作。
# 设置设备的表项模式为标准模式。
[Sysname] hardware-resource switch-mode 0
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and
reboot the system to make it effective.
· display hardware-resource switch-mode
· hardware-resource routing-mode(三层技术-IP路由命令参考/IP路由基础)
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
· scheduler job
· scheduler schedule
locator blink blink-time命令用来定位设备的位置。
locator blink stop命令用来停止定位。
locator [ slot slot-number ] blink blink-time
locator [ slot slot-number ] blink stop
blink-time:闪烁的持续时间,取值范围为5~120,单位为秒。
stop:停止闪烁。
配置locator blink blink-time命令后,指定设备上用于定位的LED灯会以间隔快闪的方式闪烁,并持续指定的时间。用户可根据LED灯的指示来定位设备所在的位置。
blink-time时间到或者执行locator blink stop命令,则定位闪烁的LED灯会恢复正常点亮状态。
# 开始定位。
<Sysname> locator blink 30
# 结束定位。
<Sysname> locator blink stop
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
一级告警门限为128MB,二级告警门限为128MB,三级告警门限为128MB,系统恢复到正常的内存门限为128MB,预告警门限为256MB,预告警解除门限为304MB。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
配置本命令后,当剩余空闲内存到达了告警门限,将无法创建微分段,无法进入微分段视图,但已配置的微分段功能可以正常使用。
满足以下条件时,系统会重启设备。
· 产生三级告警后,剩余空闲内存值持续小于三级告警门限,其时长到达30秒,则系统会重启设备。
· 如果连续产生两次三级告警的时间间隔小于30秒,则系统会重启设备。
· 如果3分钟内产生三次三级告警,则系统会重启设备。
· 产生三级告警后,系统将会周期采样,预测剩余空闲内存是否会在30秒之内耗尽,如果预测结果为会在30秒之内耗尽,则系统会重启设备。
如果配置内存一级、二级、三级告警门限相同,当设备空闲内存达到一级、二级、三级告警门限时,设备会进行相应的告警通知,并在告警通知后自动重启。
系统监控到剩余空闲内存值达到一级、二级、三级告警门限以及预告警门限后,用户在Console或Telnet登录设备,以及执行每条命令时,都会显示当前内存使用情况。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
· display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
缺省情况下,DMA内存告警阈值为2048KB,告警恢复阈值为4096KB。
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB,取值范围为0~2097148。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。设备会根据critical-value的配置值自动调整normal-value的取值范围,请以设备的实际情况为准。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小,当DMA空闲内存小于或等于告警阈值,设备会自动重启。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
· display cpu-usage configuration
· display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage logging interval命令用来开启周期性输出CPU利用率日志功能。
undo monitor cpu-usage logging interval命令用来关闭周期性输出CPU利用率日志功能。
monitor cpu-usage logging interval interval-time
周期性输出CPU利用率日志功能处于关闭状态。
interval-time:周期性输出CPU利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出CPU利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor cpu-usage logging interval 60
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
缺省情况下,CPU利用率高级别告警门限为99%,低级别告警门限为95%,恢复门限为60%。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,低级别告警门限为80%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor memory-usage logging interval命令用来开启周期性输出内存利用率日志功能。
undo monitor memory-usage logging命令用来关闭周期性输出内存利用率日志功能。
monitor memory-usage logging interval interval-time
undo monitor memory- usage logging interval
周期性输出内存利用率日志功能处于关闭状态。
interval-time:周期性输出内存利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出内存利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor memory-usage logging interval 60
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
执行undo monitor resend memory-threshold命令并不指定critical-interval、early-warning-interval、minor-interval和severe-interval参数时,表示将这些参数均恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查错误日志记录功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查错误日志记录功能。
软硬件表项一致性检查错误日志记录功能处于开启状态。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,如果检测到这两个表项不一致,则可以生成日志提醒用户。
# 开启软硬件表项一致性检查错误日志记录功能。
[Sysname] parity-error consistency-check log enable
· parity-error consistency-check threshold
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查错误次数的告警门限。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查错误次数的告警门限为10次。
value:表示软硬件表项一致性检查错误次数的告警门限,取值范围为1~2147483647,单位为次数。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,如果设备在发送周期内产生软硬件表项一致性检查错误的次数达到配置的告警门限,则发送日志提醒用户。
# 配置软硬件表项一致性检查错误次数的告警门限为20次。
[Sysname] parity-error consistency-check threshold 20
· parity-error consistency-check log enable
parity-error monitor log enable命令用来开启奇偶校验错误日志功能。
undo parity-error monitor log enable命令用来关闭奇偶校验错误日志功能。
奇偶校验错误日志功能处于关闭状态。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,当设备奇偶校验错误时,设备可以生成日志记录奇偶校验错误的详细信息。
# 配置开启奇偶校验错误日志功能。
[Sysname] parity-error monitor log enable
· parity-error monitor period
· parity-error monitor threshold
parity-error monitor period命令用来配置奇偶校验错误的日志发送周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period value
奇偶校验错误的日志发送周期为600秒。
value:表示奇偶校验错误的日志发送周期,取值范围为1~86400,单位为秒。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,设备会按周期收集奇偶校验错误发生的次数。
# 配置奇偶校验错误的日志发送周期为120秒。
[Sysname] parity-error monitor period 120
· parity-error monitor log enable
parity-error monitor threshold命令用来配置奇偶校验错误次数的告警门限。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
奇偶校验错误次数的告警门限为5000次。
value:表示奇偶校验错误次数的告警门限,取值范围为1~1000000,单位为次数。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,如果设备在日志发送周期内发生奇偶校验错误的次数大于配置的告警门限,则发送日志提示用户。
# 配置奇偶校验错误次数的告警门限为8000次。
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
· parity-error unrecoverable period
· parity-error unrecoverable reboot
· parity-error unrecoverable threshold
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为600秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
· parity-error unrecoverable log enable
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启。
如果设备转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使设备通过重启来恢复关键硬件表项。
配置本命令后,当设备生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
# 开启生成关键硬件表项不可恢复日志信息后设备的自动重启功能。
[Sysname] parity-error unrecoverable reboot
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~1000000,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
reboot命令用来重启设备。
slot slot-number:指定设备编号,取值只能为1。
force:强制重启:
· 不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
· 指定该参数时,系统将不进行任何检查,直接执行重启操作。
· 重新启动可能会导致业务中断,请谨慎使用该命令。
· 使用force参数时,系统在重启时不会做任何保护性措施。重启后,可能导致文件系统损坏,请谨慎使用该参数。建议在系统故障或无法正常重启时,才使用该参数。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
# 重启设备,并保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
· display system stable state
reset alarm active命令用来清除设备当前仍未恢复的告警信息。
reset alarm active { all | sequence-number sequence-number }
未清除设备当前仍未恢复的告警信息。
all:清除设备当前仍未恢复的所有告警信息。
sequence-number sequence-number:清除指定序列号的未恢复的告警信息。sequence-number表示告警信息的序列号,取值范围为1~4294967295。
当系统中存在无法恢复的告警记录信息时,用户可使用该命令自主清除其告警记录信息。清除后,在显示告警信息时,系统不会再对用户展现这些告警信息。
# 清除序列号为1的未恢复告警信息。
[Sysname] reset alarm active sequence-number 1
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
· display scheduler logfile
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
· display version-update-record
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
· 开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
· 关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
· display resource-monitor
· resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
· NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
· 信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
· SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见下表。
表1-29 设备可监测的资源描述表
取值 |
含义 |
arp |
ARP表项资源 |
ecmpgroup |
等价路由组资源 |
ipv4l2mc |
IPv4二层组播资源 |
ipv4l3mc |
IPv4三层组播资源 |
ipv6_128 |
掩码长度为128位的IPv6路由表项资源 |
ipv6_64 |
掩码长度为0~64位的IPv6路由表项资源 |
ipv6l2mc |
IPv6二层组播资源 |
ipv6l3mc |
IPv6三层组播资源 |
mac |
MAC地址表项资源 |
mqcin |
入方向MQC资源 |
mqcin_c0_p0 |
chip0 pipe0的入方向MQC资源 |
mqcin_c0_p1 |
chip0 pipe1的入方向MQC资源 |
mqcin_c0_p2 |
chip0 pipe2的入方向MQC资源 |
mqcin_c0_p3 |
chip0 pipe3的入方向MQC资源 |
mqcout |
出方向MQC资源 |
mqcout_c0 |
chip0的出方向MQC资源 |
nd |
ND表项资源 |
nexthoppool1 |
Underlay下一跳资源池资源 |
pbr |
PBR资源 |
pbrin_c0_p0 |
chip0 pipe0的PBR资源 |
pbrin_c0_p1 |
chip0 pipe1的PBR资源 |
pbrin_c0_p2 |
chip0 pipe2的PBR资源 |
pbrin_c0_p3 |
chip0 pipe3的PBR资源 |
pfilterin |
入方向包过滤资源 |
pfilterin_c0_p0 |
chip0 pipe0的入方向包过滤资源 |
pfilterin_c0_p1 |
chip0 pipe1的入方向包过滤资源 |
pfilterin_c0_p2 |
chip0 pipe2的入方向包过滤资源 |
pfilterin_c0_p3 |
chip0 pipe3的入方向包过滤资源 |
pfilterout |
出方向包过滤资源 |
pfilterout_c0 |
chip0的出方向包过滤资源 |
route |
路由表项资源 |
vlan |
VLAN资源 |
vlaninterface |
VLAN接口资源 |
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
· reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
· command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· YYYY的取值范围为2000~2035;
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
· 配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
· 配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
· 使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1) 使用scheduler job命令创建Job。
(2) 在Job视图下,使用command命令配置需要执行的命令。
(3) 使用scheduler schedule命令创建Schedule。
(4) 在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5) 在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6) 在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
· job
· time at
· time once
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个检测端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
sysid命令用来配置设备的网元信息。
undo sysid命令用来恢复缺省情况。
sysid system-id
undo sysid
未配置设备的网元信息。
system-id:表示设备的网元信息,可用于表示设备的位置信息、功能信息、用户自定义的名字标记等。
# 配置网元信息为position-hall,表明设备位置在大厅。
[Sysname] sysid positon-hall
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
system-working-mode命令用来配置设备的工作模式。
system-working-mode { advance | expert }
设备工作在均衡延迟(L2/L3)模式。
advance:将设备的工作模式配置为低延迟(L2)模式。该模式仅支持二层转发,不支持三层转发,转发时延较均衡延迟(L2/L3)模式更低。
expert:将设备的工作模式配置为均衡延迟(L2/L3)模式。该模式同时支持二三层转发,可获得较低的转发延时,为设备的缺省工作模式。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,详细描述请参见“基础配置指导”中的“设备管理”。
要使修改的工作模式生效,必须重启设备。
# 将设备工作模式配置为低延迟(L2)模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
· display environment
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
· 使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
transceiver lane cdr命令用来配置可插拔QSFP系列光模块发送通道和接收通道的时钟和数据恢复功能。
undo transceiver lane cdr命令用来恢复缺省情况。
transceiver lane [ lane-number ] cdr { tx | rx } { on | off }
undo transceiver lane [ lane-number ] cdr { tx | rx }
光模块发送通道和接收通道的时钟和数据恢复功能处于开启状态。
以太网接口视图
lane-number:表示光通道的编号。取值范围为1~4,不指定该参数时,表示所有光通道。
tx:光模块的发送链路。
rx:光模块的接收链路。
on:开启光模块链路的时钟和数据恢复功能。
Off:关闭光模块链路的时钟和数据恢复功能。
使用本命令配置光模块时钟和数据恢复功能,减少信号抖动,会提高光模块传输性能;关闭光模块时钟和数据恢复功能会降低其传输性能。无论开启还是关闭操作,都可能引起设备端口状态震荡。
本命令的配置会保存在光模块内部的寄存器中,不会保存到配置文件中。
仅可插拔QSFP系列光模块支持本命令。
# 开启接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块的Tx CDR功能。
[Sysname-HundredGigE1/0/1] transceiver lane cdr tx on
This command will engage the internal retiming function of transceiver Tx route. Continue? [Y/N]:Y
# 关闭接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块的Rx CDR功能。
[Sysname-HundredGigE1/0/1] transceiver lane cdr rx off
This command will enable an internal bypassing mode of transceiver Rx route, which directs traffic around the internal CDR. Continue? [Y/N]:Y
· display transceiver status
transceiver power-mode命令用来配置可插拔光模块的功耗模式。
undo transceiver power-mode命令用来恢复缺省情况。
transceiver power-mode { high | low }
缺省情况下,光模块处于高功耗模式。
以太网接口视图
通常情况下,光模块处于高功耗工作模式。当光模块长时间不需要工作时,可将光模块切换到低功耗工作模式,节省能耗。低功耗模式下,光模块不能传输信号,如果有流量传输需求,需要手工将光模块调整到高功耗工作模式。
本配置会保存在光模块内部的寄存器中,不会保存到配置文件中。
仅可插拔QSFP系列光模块支持本命令。
# 将HundredGigE1/0/1上插入的QSFP28光模块设置为高功耗模式。
[Sysname-HundredGigE1/0/1] transceiver power-mode high
# 将HundredGigE1/0/1上插入的QSFP28光模块设置为低功耗模式。
[Sysname-HundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
usb disable命令用来关闭USB接口。
undo usb disable命令用来开启USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
用户可通过USB口进行文件的上传和下载。缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
# 打开USB接口。
[Sysname] undo usb disable
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
· command
