01-基础配置命令参考
10-设备管理命令
本章节下载: 10-设备管理命令  (1.13 MB)
10-设备管理命令
1 设备管理
1.1 设备管理配置命令
1.1.1 clock datetime
1.1.2 clock protocol
1.1.3 clock summer-time
1.1.4 clock timezone
1.1.5 command
1.1.6 copyright-info enable
1.1.7 display alarm
1.1.8 display asset-info
1.1.9 display clock
1.1.10 display copyright
1.1.11 display cpu-usage
1.1.12 display cpu-usage configuration
1.1.13 display cpu-usage history
1.1.14 display device
1.1.15 display device manuinfo
1.1.16 display device manuinfo chassis-only
1.1.17 display device manuinfo fan
1.1.18 display device manuinfo power
1.1.19 display device uptime
1.1.20 display diagnostic-information
1.1.21 display environment
1.1.22 display fabric multicast-forwarding mode
1.1.23 display fan
1.1.24 display hardware-failure-detection
1.1.25 display memory
1.1.26 display memory-threshold
1.1.27 display power
1.1.28 display power-supply
1.1.29 display resource-monitor
1.1.30 display scheduler job
1.1.31 display scheduler logfile
1.1.32 display scheduler reboot
1.1.33 display scheduler schedule
1.1.34 display switch-mode status
1.1.35 display system health
1.1.36 display system health history
1.1.37 display system stable state
1.1.38 display system-working-mode
1.1.39 display transceiver active-control
1.1.40 display transceiver advertising
1.1.41 display transceiver alarm
1.1.42 display transceiver application
1.1.43 display transceiver diagnosis
1.1.44 display transceiver health
1.1.45 display transceiver interface
1.1.46 display transceiver manuinfo
1.1.47 display transceiver status
1.1.48 display version
1.1.49 display version-update-record
1.1.50 fabric load-sharing mode
1.1.51 fabric multicast-forwarding mode
1.1.52 forward-path-detection enable
1.1.53 hardware-failure-detection
1.1.54 header
1.1.55 job
1.1.56 memory-threshold
1.1.57 memory-threshold usage
1.1.58 monitor cpu-usage enable
1.1.59 monitor cpu-usage interval
1.1.60 monitor cpu-usage logging interval
1.1.61 monitor cpu-usage threshold
1.1.62 monitor handshake-timeout disable-port
1.1.63 monitor memory-usage logging interval
1.1.64 monitor resend cpu-usage
1.1.65 monitor resend memory-threshold
1.1.66 parity-error consistency-check log enable
1.1.67 parity-error consistency-check period
1.1.68 parity-error consistency-check threshold
1.1.69 parity-error monitor log enable
1.1.70 parity-error monitor period
1.1.71 parity-error monitor threshold
1.1.72 parity-error unrecoverable log enable
1.1.73 parity-error unrecoverable period
1.1.74 parity-error unrecoverable reboot
1.1.75 parity-error unrecoverable threshold
1.1.76 password-recovery enable
1.1.77 power-supply off
1.1.78 power-supply on
1.1.79 power-supply policy enable
1.1.80 power-supply policy priority
1.1.81 power-supply policy redundant
1.1.82 reboot
1.1.83 reset asset-info
1.1.84 reset scheduler logfile
1.1.85 reset transceiver interface
1.1.86 reset version-update-record
1.1.87 resource-monitor minor resend enable
1.1.88 resource-monitor output
1.1.89 resource-monitor resource
1.1.90 restart standby
1.1.91 restore factory-default
1.1.92 scheduler job
1.1.93 scheduler logfile size
1.1.94 scheduler reboot at
1.1.95 scheduler reboot delay
1.1.96 scheduler schedule
1.1.97 set asset-info
1.1.98 shutdown-interval
1.1.99 switch-fabric isolate
1.1.100 switch-mode
1.1.101 sysname
1.1.102 system handshake timeout
1.1.103 system switchover
1.1.104 system-working-mode
1.1.105 temperature-limit
1.1.106 time at
1.1.107 time once
1.1.108 time repeating
1.1.109 transceiver health check enable
1.1.110 transceiver health weight
1.1.111 transceiver lane enable
1.1.112 transceiver lane equalization
1.1.113 transceiver monitor enable
1.1.114 transceiver monitor interval
1.1.115 transceiver power-mode
1.1.116 transceiver working-mode
1.1.117 user-role
1 设备管理
设备仅在独立运行模式下支持MDC。关于MDC的详细介绍,请参见“虚拟化技术配置指导”中的“MDC”。
1.1  设备管理配置命令
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
仅缺省MDC支持本命令。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
设备断电重启后,该命令会恢复到缺省情况,需要重新配置。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
从缺省MDC通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ptp:表示通过PTP(Precision Time Protocol,精确时间协议)协议获取时间。关于PTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“PTP”。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号,取值范围为1~5。
仅缺省MDC支持本命令。
系统时间的获取方式有:
·     配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
·     配置clock protocol { ntp | ptp }命令后,通过NTP/PTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
所有MDC的系统时间相同。当设备从某个MDC获取时钟后,会同步给其它MDC。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省MDC支持本命令。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省MDC支持本命令。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.5  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口Ten-GigabitEthernet3/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 3/0/1
[Sysname-job-shutdownGE] command 3 shutdown
·     scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
1.1.7  display alarm
display alarm命令用来显示设备的告警信息。
(独立运行模式)
display alarm [ slot slot-number ]
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
仅缺省MDC支持本命令。
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
表1-1 display alarm命令显示信息描述表
Slot
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上
CPU
告警CPU的编号
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息。取值为:
·     faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态)
·     Fan n is absent:风扇n当前不在位
·     Fan n is faulty:风扇n处于异常状态
·     Power n is absent:电源n当前不在位
·     Power n is faulty:电源n处于异常状态
·     Slot n temperature is too low, below the low limit:单板温度过低,低于低温告警门限(独立运行模式)
·     Chassis n slot m temperature is too low, below the low limit:单板温度过低,低于低温告警门限(IRF模式)
·     Slot n temperature is too high, above the warning/high/shutdown limit:单板温度过高,高于一般级/严重级/关闭级高温告警门限(独立运行模式)
·     Chassis n slot m temperature is too high, above the warning/high/shutdown limit:单板温度过高,高于一般级/严重级/关闭级高温告警门限(IRF模式)
display asset-info命令用来显示设备的用户资产信息。使用该命令,可以显示设备机箱、单板、风扇框或电源模块的资产信息。
(独立运行模式)
display asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
display asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
chassis:显示设备机箱的用户资产信息。
fan fan-id:显示指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号。
power power-id:显示指定电源模块的用户资产信息。power-id表示设备上电源模块的编号。
slot slot-number:显示指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:显示资产编号信息。
custom:显示用户自定义的资产信息。
department:显示资产的归属部门信息。
description:显示资产的描述信息。
service-date:显示资产的启用时间信息。
state:显示资产的使用状态信息。
chassis chassis-number:显示指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
【描述】
当用户希望显示设备机箱、单板的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,显示的是该设备机箱、单板的所有用户资产信息。
使用该命令显示设备机框、单板、风扇框或电源模块没有经过设置的具体信息项目时,该信息项目的内容显示为空。
使用该命令显示指定风扇框或者电源模块的资产信息时,如果设备上无对应编号的风扇框或者电源模块,将返回风扇框或者电源模块不支持该操作的提示信息。
# 显示机箱的资产编号信息(该显示信息与用户的当前配置有关)。(独立运行模式)
<Sysname> display asset-info chassis csn
Type        : Chassis
csn         : 123456789
<Sysname> display asset-info chassis 1 chassis
Type : Chassis
csn : 123456789
description : frameA
service-date:
department :MKT
state :Normal
custom :1:789
表1-2 display asset-info命令显示信息描述表
资产类型,内容为指定的设备机箱、单板
csn
资产编号信息,内容为空表示用户没有进行设置
description
资产描述信息,内容为空表示用户没有进行设置
location
资产位置信息,内容为空表示用户没有进行设置
service-date
资产启用时间信息,内容为空表示用户没有进行设置
department
资产归属部门信息,内容为空表示用户没有进行设置
state
资产使用状态信息,内容为空表示用户没有进行设置
custom
用户自定义的资产信息,内容为空表示用户没有进行设置
·     reset asset-info
·     set asset-info
1.1.9  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/16/2015
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
# 显示设备的版权信息。
<Sysname> display copyright
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
(独立运行模式)
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ]
control-plane:显示控制平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
登录MDC后执行该命令,会显示该MDC可使用的CPU的利用率统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
表1-3 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU或CPU核的平均利用率。该字段显示的是最近一个5秒统计周期内CPU或CPU核的平均利用率
Last 5 sec
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU或CPU核的平均利用率
Last 1 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU或CPU核的平均利用率
Last 5 min
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
(独立运行模式)
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。
登录MDC后执行该命令,会显示该MDC可使用的CPU的对应信息。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
表1-4 display cpu-usage configuration命令显示信息描述表
CPU利用率历史记录功能处于开启状态
CPU利用率历史记录的采样周期为60秒
CPU以及CPU核利用率的告警门限为90%
CPU低级别告警门限为80%
CPU恢复门限为40%
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
(独立运行模式)
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。(独立运行模式)
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
(独立运行模式)
display device[ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
display device[ flash | usb ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
flash:显示Flash的信息。
usb:显示USB接口的信息。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:取值固定为0,无实际意义。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不指定flash和usb参数时,显示单板的信息。
在缺省MDC和非缺省MDC下执行该命令,显示信息相同,且均显示物理设备的对应信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
……显示信息略……
表1-5 display device命令显示信息描述表
Slot Id.
单板的槽位号
单板的硬件类型
Brd Status
单板状态:
·     Standby表示该板是备用主控板
·     Master表示该板是主用主控板
·     Absent表示该槽位没有插入单板
·     Fault表示该槽位单板正在启动、单板被下电或者单板出错,不能正常启动
·     Normal表示该槽位单板是接口板并处于正常工作状态
·     Offline表示该槽位网板处于隔离状态
Subslot
单板支持接口子卡的最大个数
Sft Ver
当前单板上运行的软件版本
Patch Ver
当前单板上运行的热补丁版本
display device manuinfo命令用来显示设备的电子标签信息。
(独立运行模式)
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
本命令仅缺省MDC支持。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
(独立运行模式)
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
本命令仅缺省MDC支持。
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
显示信息略……。
display device manuinfo fan命令用来显示风扇的电子标签信息。
(独立运行模式)
display device manuinfo fan fan-id
display device manuinfo chassis chassis-number fan fan-id
fan-id:表示设备上风扇的ID编号。
本命令仅缺省MDC支持。
# 显示指定风扇的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo fan 1
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
(独立运行模式)
display device manuinfo power power-id
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号。
本命令仅缺省MDC支持。
# 显示指定电源的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 1
显示信息略……。
display device uptime命令用来显示单板最近一次启动后的运行时长。
# 显示单板最近一次启动后的运行时长。(独立运行模式)
<Sysname> display device uptime
Slot No. Brd Type             Brd Status  Subslot  UP time(DD:HH:MM)
 0       LSXM1SUPS2           Master      0        0000:13:54
 1       NONE                 Absent      0        None
 2       LSXM3GT24GPSE2       Normal      0        0000:13:53
 3       LSXM3GT24GPSE2       Normal      0        0000:02:14
 4       NONE                 Absent      0        None
# 显示单板最近一次启动后的运行时长。(IRF模式)
Slot   Type                  State    Subslot  UP time(DD:HH:MM)
1/0    LSXM1SUPS2            Master   0        0000:01:43
1/1    NONE                  Standby  0        None
1/2    LSXM3GT24GPSE2        Normal   0        0000:01:41
1/3    NONE                  Absent   0        None
1/4    NONE                  Absent   0        None
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
ifmgr:收集IFMGR模块相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1)     使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2)     使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3)     使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行display diagnostic-information命令前,请使用display cpu-usage、display memory命令查看CPU、内存使用率。如果CPU使用率为100%,或者内存使用率超过90%,请暂时不要执行display diagnostic-information命令,等CPU和内存使用率回落后再执行。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     gunzip(基础配置命令参考/文件系统管理)
·     more(基础配置命令参考/文件系统管理)
·     tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
(独立运行模式)
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
本命令仅缺省MDC支持。
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
 System temperature information (degree centigrade):
 Slot  Sensor       Temperature  Lower       Warning       Alarm       Shutdown
 1     hotspot 1    38           10          40            50          100
 1     hotspot 2    42           10          50            80          100
表1-6 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息,单位为摄氏度
sensor
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Slot
当显示数字时表示指定slot上温度传感器的温度信息
Temperature
当前温度。当显示为Failed时,表示温度传感器故障
Lower
低温告警门限。当显示为NA时,表示不支持该门限
Warning
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限
Alarm
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限
Shutdown
关断级(Shutdown)高温告警门限,当风扇故障或不在位时,并且温度传感器的温度大于该门限超过10S时,设备会自动关闭。当显示为NA时,表示不支持该门限
display fabric multicast-forwarding mode命令用来显示组播的转发模式。
对于S12500CR系列交换机,不支持本命令。
对于S12500G-AF系列交换机,仅SE系列接口板支持本命令。
# 显示组播的转发模式。
<Sysname> display fabric multicast-forwarding mode
The current mode is standard.
The mode at the next startup is standard.
1.1.23  display fan
display fan命令用来显示风扇的工作状态。
(独立运行模式)
display fan [ verbose ]
display fan [ chassis chassis-number ] [ verbose ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。(IRF模式)
verbose:显示设备内置风扇的详细信息。不指定该参数时,显示设备内置风扇的简要信息。
本命令仅缺省MDC支持。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
  Fan 1 State: Normal
  Fan 2 State: Normal
表1-7 display fan命令显示信息描述表
Fan 1
设备上风扇的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Faulty:风扇故障
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(独立运行模式)
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(IRF模式)
仅缺省MDC支持本命令。
# 查看设备的硬件故障检测和故障修复信息。(独立运行模式)
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    board      : isolate
    forwarding : warning
Recent record:
--------------------------Slot  0 executed records:-----------------------------
                 There is no record.
--------------------------Slot  0 trapped records:-----------------------------
                 There is no record.
表1-8 display hardware-failure-detection命令显示信息描述表
Current level
当前故障检测对应的修复操作
chip       :
器件类故障对应的修复操作
board      :
单板类故障对应的修复操作
forwarding :
转发类故障对应的修复操作
Recent record:
最近记录
Slot  n executed records:
主控板n上记录的各个单板的历史操作记录(独立运行模式)
Chassis n, Slot m executed records:
成员设备n主控板m上记录的各个单板的历史操作记录(IRF模式)
Slot  n trapped records:
主控板n上记录的各个单板的trap告警信息(独立运行模式)
Chassis n, Slot m trapped records:
成员设备n主控板m上记录的各个单板的trap告警信息(IRF模式)
display memory命令用来显示内存使用情况。
(独立运行模式)
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。(IRF模式)
cpu cpu-number:表示CPU编号。
登录MDC后执行该命令,会显示该MDC可使用的内存的使用情况。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。(独立运行模式)
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       1993104   1010464    982640         0      2544    576384       51.8%
-/+ Buffers/Cache:    431536   1561568
Swap:            0         0         0
Slot 3:
Mem:       1993104    417824   1575280         0        96    133136       79.1%
-/+ Buffers/Cache:    284592   1708512
Swap:            0         0         0
# 显示设备的内存使用情况的简要信息。(独立运行模式)
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0      1993104   1010576    982528     2544    576368     51.8%
   3   0      1993104    417824   1575280       96    133136     79.1%
表1-9 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值
Buffers
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值
Cached
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用。取值为“--”时,表示不支持统计该参数的值
Caches
FreeRatio
整个系统物理内存的空闲率。包含当前剩余空闲内存以及高速缓冲寄存器中当前正在使用但是内存告警状态下可主动释放的内存
-/+ buffers/cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
(独立运行模式)
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
仅缺省MDC支持本命令。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
    Minor: 194M
    Severe: 136M
    Critical: 77M
    Normal: 252M
    Early-warning: 311M
    Secure: 350M
Current free-memory state: Normal (secure)
Free-memory event statistics:
 [Back to secure state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered early-warning state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to normal state]
 [Entered minor alarm state]
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
表1-10 display memory-threshold命令显示信息描述表
内存利用率阈值
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
·     Early-warning:预告警门限,单位为MB
·     Secure:恢复预告警门限状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
·     Normal (early-warning):预告警状态
·     Normal (secure):安全状态
门限事件统计信息,事件分为:
·     Back to secure state:恢复到预告警前的状态
·     Entered early-warning state:进入预告警门限状态
·     Back to normal state:内存恢复到正常状态
·     Entered minor alarm state:进入一级告警门限状态
·     Back to minor alarm state:恢复到一级告警前的状态
·     Entered severe alarm state:进入二级告警门限状态
·     Back to severe alarm state:恢复到二级告警前的状态
·     Entered critical alarm state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display power命令用来显示设备电源的信息。
(独立运行模式)
display power [ power-id | verbose ]
display power [ chassis chassis-number [ power-id | verbose ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。(IRF模式)
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
本命令仅缺省MDC支持。
# 显示设备电源的简要信息。
<Sysname> display power
Input Power: 1600.0 W
 PowerID  State  Mode   Current(A)  Voltage(V)  Power(W) FanDirection
 1        Absent --     --          --          --       --
 2        Absent --     --          --          --       --
 3        Absent --     --          --          --       --
 4        Absent --     --          --          --       --
 5        Normal AC     13.5        54.7        738.2    --
 6        Absent --     --          --          --       --
 7        Absent --     --          --          --       --
 8        Absent --     --          --          --       --
表1-11 display power命令显示信息描述表
Input Power
设备的额定功率
PowerID
设备上的电源模块编号
电源模块的状态
·     Absent:电源不在位
·     Normal:电源正常工作
·     Fault:电源故障
Mode
电源模块的类型,取值为:
·     AC:表示交流电源
·     DC:表示直流电源
Current(A)
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息
Voltage(V)
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息
Power(W)
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息
FanDirection
电源模块内风扇的吹风方向,取值为:
·     PowerToPort:电源侧进风、端口侧出风
·     PortToPower:端口侧进风、电源侧出风
·     --:表示暂不支持统计该信息
# 显示电源的详细信息。(独立运行模式)
<Sysname> display power verbose
System power information:
Power modules installed: 1
Power modules usable: 1
Rated power: 2000 W
Usable power: 1495 W
Used power: 139.60 W
Redundant power: 0 W
Total DC output : 2.8 A
PowerID    State   InVoltage(V) InPower(W)  OutVoltage(V) OutCurrent(A)  OutPower(W)
1          Normal  220          2000        50            2.8            140
Power information by slot:
Slot  Type   Current(A)   Power(W)  Status
1     None   5            10        Normal
表1-12 display power verbose命令显示信息描述表
设备上电源系统的相关信息
设备中已安装的电源模块数量
设备中可用的电源模块数量
Rated power
处于Normal状态的电源模块的额定功率之和,单位为瓦
Usable power
处于Normal状态的电源模块可分配的功率之和,单位为瓦
Used power
当前已分配的功率,单位为瓦
Redundant power
电源系统实际的冗余功率,单位为瓦
Total DC output
设备中所有电源模块输出电流值的和,单位为安
PowerID
设备上电源模块的编号
电源模块的状态,取值为:
·     Absent:表示未安装电源
·     Normal:表示电源正常工作
·     Faulty:表示电源故障
InVoltage(V)
电源模块的实际输入电压
InPower(W)
电源模块的实际输入功率
OutVoltage(V)
电源模块的实际输出电压
OutCurrent(A)
电源模块的实际输出电流
OutPower(W)
电源模块的实际输出功率
各slot对当前电源模块的使用情况
单板的类型
Current(A)
单板当前的输入电流,单位为安,显示为“--”表示设备暂不支持统计该信息
Power(W)
单板的额定功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息
Status
单板的状态:
·     Absent:表示单板不在位
·     Normal:表示单板正常
·     Faulty:表示单板故障
display power-supply命令用来显示电源管理功能的相关信息。
(独立运行模式)
display power-supply [ chassis chassis-number ]
chassis chassis-number:显示指定成员设备上电源管理功能的相关信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
仅缺省MDC支持本命令。
对于主控板、网板和IRF物理端口所在的单板,不支持显示供电优先级相关的信息。
# 显示电源管理功能的相关信息(独立运行模式)。
<Sysname> display power-supply
 Power supply policy:  Disable
 Power modules redundant (setting):  0
 Board power supply information:
 Slot   Type                  Priority        Status
 0      LSXM1SUPS2            --              Powered on
 1      None                  --              Reserved
 2      LSDM1GT24GPSE0        5               Powered on
 3      LSDM1GT24GPSE0        5               Powered on
 4      None                  5               Absent
表1-13 display power-supply命令显示信息描述表
Power supply policy
电源管理功能是否处于开启状态:
·     Disable:处于关闭状态
·     Enable:处于开启状态
配置的冗余电源模块数
单板电源管理信息
Priority
单板的供电优先级
Slot
单板所在槽位号
单板型号
Status
单板状态,取值为:
·     Powered on:表示单板处于上电状态
·     Powered off:表示单板电源功率不足未上电
·     Reserved:表示单板预留
·     Off(manual):表示单板被手动下电
·     Off(Temp):表示单板高温下电
·     Absent:表示单板不在位
·     --:表示单板功率状态获取失败
display resource-monitor命令用来显示资源监控功能的相关信息。
(独立运行模式)
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见“设备可监测的资源描述表”。
slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。(独立运行模式)
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
表1-14 display resource-monitor命令显示信息描述表
周期发送低级别资源告警通知功能的开启状态:
·     Enabled:表示该功能已开启
·     Disabled:表示该功能未开启
Resource
监控资源的名称
Minor
低级别告警门限,单位为百分比
Severe
高级别门限,单位为百分比
Free/Total
(absolute)
剩余资源的数量/该资源的总数,用绝对值形式表示
·     resource-monitor minor resend enable
·     resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/3
[Sysname-if-range]shutdown
表1-15 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
Job name                                          Last execution status
shutdown                                          Successful
表1-16 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display switch-mode status用于查看所有业务板当前的工作模式以及业务板配置的工作模式。
(独立运行模式)
display switch-mode status chassis chassis-number
chassis chassis-number:显示指定成员设备上所有业务板当前的工作模式和代理模式以及业务板配置的工作模式和代理模式。chassis-number表示设备在IRF中的成员编号。(IRF模式)
使用undo switch-mode命令将业务板的工作模式恢复到未配置状态(即config显示为NONE),保存配置并重启该设备后,业务板将以缺省工作模式启动。
# 查看交换机所有业务板当前的工作模式以及业务板配置的工作模式。
<Sysname> display switch-mode status
LPU switch mode:
Slot    Current             Config
 0      NORMAL              NONE
 2      NORMAL              NONE
 3      NORMAL              NONE
表1-17 display switch-mode status显示信息描述表
LPU switch mode
业务板的工作模式
Slot
业务板槽位号
Current
业务板当前的工作模式:
NONE:业务板不支持配置业务板的工作模式
NORMAL:业务板当前的工作模式为普通模式
BALANCE:业务板当前的工作模式为均衡模式
BRIDGING:业务板当前的工作模式为MAC扩展模式
ROUTING:业务板当前的工作模式为路由扩展模式
ENHANCE:业务板当前的工作模式为增强模式
EHC-BALANCE:业务板当前的工作模式为增强的均衡模式
EHC-BRIDGING:业务板当前的工作模式为增强的MAC扩展模式
EHC-ROUTING:业务板当前的工作模式为增强的路由扩展模式
Config
业务板配置的工作模式:
·     switch-mode
display system health命令用来显示设备的健康状态。
(独立运行模式)
display system health [ chassis chassis-number ]
chassis chassis-number :表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。(IRF模式)
设备会定期执行一系列检查,以便了解设备是否处于健康状态。检查项在设备出厂时已固定,检查结果可供设备内部业务模块(例如IRF、M-LAG等)使用,也可通过本命令供用户查看。
# 显示系统健康情况。(独立运行模式)
<Sysname> display system health
Health: Faulty(3)
    Memory: Normal(0)
    Communication: Normal(0)
    DBM monitor: Normal(0)
    Chip jam: Normal(0)
    CPU deadloop: Normal(0)
    Forwarding channel: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    LSW port: Normal(0)
    Board status: Faulty(3)
Fan status: Normal(0)
    Temperature: Normal(0)
# 显示系统健康情况。(IRF模式)
Chassis  1 health: Normal(0)
    Memory: Normal(0)
    Chip jam: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    LSW port: Normal(0)
    Board status: Normal(0)
Chassis  2 health: Normal(0)
    Memory: Normal(0)
    Chip jam: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    LSW port: Normal(0)
表1-18 display system health命令显示信息描述表
Health: Normal(0)
系统的健康状态。取值为:
·     Normal(0):表示系统健康
·     Faulty(n):表示系统不健康,n表示健康值,取值越大越不健康
Memory
内存检测
Communication
通信检测
DBM monitor
DBM进程异常检测
Chip jam
芯片堵死定时检测
CPU deadloop
CPU死循环检测
Forwarding channel
设备跨板业务检测
HG
单板间HG检测
LSW CPU
LSW CPU故障检测
LSW port
LSW端口检测
Board status
单板状态检测
Fan status
风扇状态检测
Temperature status
温度传感器状态检测
·     display system health history
display system health history命令用来显示系统健康状态变化的历史信息。
(独立运行模式)
display system health history[ chassis chassis-number ]
# 显示系统健康状态变化的历史信息。
<Sysname> display system health history
Health: Faulty(1)
  Chip jam:
    Faulty(1)  2019-10-10 18:00:00 on slot 1
    Normal(0)  2019-10-08 17:00:00 on slot 1
    Faulty(1)  2019-10-07 18:00:00 on slot 1
表1-19 display system health history命令显示信息描述表
Health: Normal(0)
系统当前的健康状态。取值为:
·     Normal(0):表示系统健康
Chip jam:
健康检测结果有变化的检测项的历史信息,设备支持的检测项请参见表1-18,每个测试项最多显示30条系统健康状态变化的历史信息
Faulty(1)  2019-10-10 18:00:00 on slot 1表示slot 1在2019-10-10 18:00:00状态变为Faulty(1)
display system stable state命令用来显示系统的稳定状态。
display system stable state [ mdc { mdc-id | all } ]  [ summary ]
mdc { mdc-id | all }:显示指定或所有MDC的系统稳定状态。mdc-id表示MDC的编号,MDC的取值范围为1~5。
summary:显示系统稳定状态的汇总信息,该信息包括CPU的运行状态、主备状态和NSR的稳定状态。不指定该参数时,显示CPU的运行状态、主备状态,以及CPU运行状态的详细信息。
不指定mdc参数时,显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/单板/MDC启动需要一定的时间,才能达到Stable状态。如果设备/单板/MDC长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板/MDC,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
·     通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统稳定状态的汇总信息。
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundancy
NSR     state     : No standby
# 显示系统的稳定状态。(独立运行模式)
Redundancy state : Stable
  Slot    CPU    Role       State
  0       0      Active     Stable
  1       0      Standby    Stable
  3       0      Other      Stable
  15      0      Other      Stable
表1-20 display system stable state命令显示信息描述表
System state
单板运行状态的汇总:
·     Stable:稳定运行,表示所有单板均处于稳定运行状态
·     Not ready:未稳定,此时不能进行ISSU升级
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No redundancy:系统无冗余,不能倒换
·     Not ready:未稳定,不可以倒换
NSR state
各模块NSR(Nonstop Routing,不间断路由)状态的汇总,取值为:
·     Ready:稳定状态,表示所有开启的NSR功能均能正常工作
·     Not ready:未稳定状态,此时不能进行进程倒换或者主备倒换、ISSU升级
·     No standby:没有备用主控板
·     Not configured:未开启NSR功能
Role
单板在系统中的身份:
·     Active:主用主控板
·     Standby:备用主控板,提供冗余备份
·     Other:业务板
单板的运行状态:
·     Stable:单板稳定运行
·     Board inserted:单板插入
·     Kernel initiating:单板内核初始化
·     Service starting:单板上的服务正在启动
·     Service stopping:单板上的服务正在关闭
·     HA Batch backup:HA批量备份中
·     Interface data batch backup:接口管理批量备份未完成
·     MDC starting:MDC正在启动
·     MDC stopping:MDC正在关闭
·     Automatic configuration:MDC正在进行自动配置
当前对象处于未稳定状态
·     display device
·     display ha service-group(可靠性命令参考/进程分布优化)
·     display mdc(虚拟化技术命令参考/MDC)
display system-working-mode命令用来显示设备的工作模式。
仅缺省MDC支持本命令。
# 显示设备的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
display transceiver active-control命令用于显示可插拔400G光模块的当前运行参数。
display transceiver active-control interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔400G光模块的当前运行参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FourHundredGigE1/0/1上插入的可插拔400G光模块的当前运行参数。
<Sysname> display transceiver active-control interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver active-control setting information:
Current working mode     : 400G-SR8
  Lane    LowestHostLane   RxPre-Cursor     RxPost-Cursor    RxAmplitude
  Lane1   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane2   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane3   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane4   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane5   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane6   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane7   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane8   Lane1            1.5 dB           1 dB             600-1200 mV
表1-21 display transceiver active-control命令显示信息描述表
interface-name transceiver active-control setting information
接口interface-name上插入的可插拔400G光模块的当前运行参数
光模块当前使用的工作模式
Lane
光模块当前使用的通道
LowestHostLane
光模块当前使用通道所在组中最小的通道号
RxPre-Cursor
本端作为接收端时的RxPre-Cursor参数
RxPost-Cursor
本端作为接收端时的RxPost-Cursor参数
RxAmplitude
本端作为接收端时的输出幅值参数
display transceiver advertising命令用来显示可插拔400G光模块支持的能力。
display transceiver advertising interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔400G光模块支持的能力。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FourHundredGigE1/0/1上插入的可插拔400G光模块支持的能力。
<Sysname> display transceiver advertising interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver advertising information:
  CMIS Revision                      : 3.0
  Versatile Diagnostic Monitoring    : YES
  Tx clock recovery capabilities     : Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups
  Max Tx Input Eq(dB)                : 9
  Max Rx Output Eq Pre-cursor(dB)    : 1.5
  Max Rx Output Eq Post-cursor(dB)   : 3
  Tx disable implemented             : YES
  Tx Force Squelch implemented       : YES
  Tx Squelch implemented             : NO
  Tunable transmitter                : YES
  Tx bypass CDR implemented          : YES
  Rx bypass CDR implemented          : YES
  Tx Input Eq Adaptive               : YES
  CDB implemented                    : NO
表1-22 display transceiver advertising命令显示信息描述表
interface-name transceiver advertising information
接口interface-name上插入的可插拔400G光模块的功能支持能力信息
CMIS Revision
QSFP-DD CMIS的版本,取值为3.0或者4.0
诊断监控能力,取值为:
·     YES:支持
·     NO:不支持
本端作为发送端时的时钟恢复能力,取值为:
·     All Tx input lanes to be in a single Tx synchronous group:表示所有Lane共用同一个时钟恢复
·     Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups:表示Lane 1~4和Lane 5~8各用同一个时钟恢复
·     Tx input lanes 1-2, 3-4, 5-6, 7-8 to be in separate Tx synchronous groups:表示Lane1和2、3和4、5和6、7和8各用一个时钟恢复
·     Each Tx input lane to be in a separate Tx synchronous group:表示每个Lane有一个时钟恢复
Max Tx Input Eq (dB)
本端作为发送端时的最大均衡能力
Max Rx Output Eq Pre-cursor (dB)
最大可支持的Rx Output Eq Pre-cursor
Max Rx Output Eq Post-cursor (dB)
最大可支持的Rx Output Eq Post-cursor
Tx disable功能,取值为:
·     YES:支持
·     NO:不支持
Tx强制Squelch功能,取值为:
·     YES:支持
·     NO:不支持
Tx Squelch功能,取值为:
·     No:不支持
·     OMA:基于OMA实现
·     Pave:基于平均光功率实现
·     Both:基于OMA实现和基于平均光功率实现都支持
Tunable transmitter
是否为可调谐模块,取值为:
·     YES:是
·     NO:否
本端作为发送端时的CDR旁路功能,取值为:
·     Yes:支持
·     NO:不支持
本端作为接收端时的CDR旁路功能,取值为:
·     YES:支持
·     NO:不支持
Tx input Eq Adaptive
本端作为发送端时的输入是否为自适应均衡,取值为:
·     YES:是
·     NO:否
CDB implemented
CDB功能,取值为:
·     NO:不支持
·     One instance of CDB implemented:支持一个CDB实例
·     Two instances of CDB implemented:支持两个CDB实例
·     UNKNOWN:未知状态
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-23 SFP/SFP28/SFP+/GBIC/SFF的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX power high
接收光功率高
RX power low
接收光功率低
TX fault
发送错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
表1-24 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
RX signal loss in channel x
通道x接收到的信号丢失
TX fault in channel x
通道x发送报文时出错
TX signal loss in channel x
通道x发送的信号丢失
RX power high in channel x
通道x接收到的光的功率太高
RX power low in channel x
通道x接收到的光的功率太低
TX bias high in channel x
通道x的偏置电流高
TX bias low in channel x
通道x的偏置电流低
模块读写错误
模块信息校验和错误
Transceiver type and port configuration mismatched
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-25 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked
发送Jitter PLL失锁
TX CMU unlocked
发送CMU失锁
Overloaded
负载过大
Loss of REFCLK input
缺乏参考时钟
Channel signals out of alignment
主机通道信号不对齐
PLD or flash initialization error
初始化错误
Power supply fault
电源错误
CFP checksum error
校验和错误
TX bias high
偏置电流高
TX bias low
偏置电流低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
通道x接收到的信号丢失
RX IC unlocked in channel x
通道x接收到的IC时钟失锁
RX FIFO error in channel x
通道x接收到FIFO错误
通道x发送的信号丢失
TX IC unlocked in channel x
通道x发送的IC时钟失锁
TX FIFO error in channel x
主机通道x的发送FIFO出错
主机通道x发送的IC时钟失锁
APD supply fault in channel x
通道x出现APD错误
TEC fault in channel x
通道x出现TEC错误
Wavelength unlocked in channel x
通道x的光信号波长失锁
RX power high in lane x
通道x接收到的光的功率太高
RX power low in lane x
通道x接收到的光的功率太低
TX power high in lane x
通道x发送的光的功率太高
TX power low in lane x
通道x发送的光的功率太低
TX bias high in lane x
通道x的偏置电流高
TX bias low in lane x
通道x的偏置电流低
Temp high in lane x
通道x的温度高
Temp low in lane x
通道x的温度低
模块读写错误
模块信息校验和错误
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-26 XFP的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX not ready
接收状态未就绪
RX CDR loss of lock
RX CDR时钟失锁
RX power high
接收光功率高
RX power low
接收光功率低
TX not ready
发送状态未就绪
TX fault
发送错误
TX CDR loss of lock
TX CDR时钟失锁
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Module not ready
模块状态未就绪
APD supply fault
APD(Avalanche Photo Diode,雪崩光电二极管)错误
TEC fault
TEC(Thermoelectric Cooler,热点冷却器)错误
Wavelength unlocked
光信号波长失锁
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
表1-27 XENPAK的display transceiver alarm命令输出信息描述表
WIS local fault
WIS(WAN Interface Sublayer)本地错误
Receive optical power fault
接收光功率错误
PMA/PMD receiver local fault
PMA/PMD(Physical Medium Attachment/Physical Medium Dependent)接收器本地错误
PCS receive local fault
PCS(Physical Coding Sublayer)接收本地错误
PHY XS receive local fault
PHY XS(PHY Extended Sublayer)接收本地错误
RX power high
接收光功率高
RX power low
接收光功率低
Laser bias current fault
激光器偏置电流错误
Laser temperature fault
激光器温度错误
Laser output power fault
激光器输出光功率错误
TX fault
发送器错误
PMA/PMD接收器本地错误
PCS接收本地错误
PHY XS接收本地错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
模块信息I/O错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
表1-28 QSFP-DD光模块的display transceiver alarm命令输出信息描述表
Data path firmware fault
数据通道固件错误
Module firmware fault
模块固件错误
Module state changed
模块状态改变
Data path state changed in channel x
通道x的数据路径状态改变
TX loss in channel x
通道x的发送信号丢失
TX CDR LOL in channel x
通道x的TX 时钟和数据恢复失锁
TX input eq fault in channel x
通道x的TX输入均衡错误
RX CDR LOL in channel x
通道x的RX 时钟和数据恢复失锁
Loss of reference clock
基准时钟丢失
L-Host Pattern Generator LOL in channel x
通道x的主机端码型发生器失锁
L-Media Pattern Generator LOL in channel x
通道x的媒体端模式发生器失锁
L-Host Pattern Checker LOL in channel x
通道x的主机端码型检查器失锁
L-Media Pattern Checker LOL in channel x
通道x的媒体端模式检查器失锁
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver current alarm information:
  RX signal loss
  RX power low
表1-29 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX signal loss
接收信号丢失
RX power low
接收光功率低告警
display transceiver application命令用来显示可插拔400G光模块支持的应用及相关信息。
display transceiver application interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔400G光模块支持的应用及相关信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FourHundredGigE1/0/1上插入的可插拔400G光模块支持的应用及相关信息。
<Sysname> display transceiver application interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver application information:
ApSel code:0001b
     Host Electrical Interface code     Module Media Interface Code
     400GAUI-8 C2M                      400G-SR8
     Host Lane Count                    Media Lane Count
     8                                  8
     The Lowest host Lane               The Lowest media lane
     1                                  1
ApSel Code: 0010b
     IB EDR                             Undefined
     8                                  8
     1                                  1
表1-30 display transceiver application命令显示信息描述表
interface-name transceiver application information:
接口interface-name上插入的可插拔400G光模块支持的应用及相关信息
ApSel Code
光模块的当前工作类型(用光模块支持的应用类型的代码表示)
主机侧电接口代码
光模块侧介质接口代码
Host Lane Count
主机侧支持的通道数
Media Lane Count
介质侧支持的通道数
该应用类型主机侧最低的通道编号。光模块工作在不同的应用类型下,支持的通道数不同,这些通道会按组划分,本参数显示每个组中最小的通道编号
该应用类型介质侧最低的通道编号
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver diagnostic information:
    Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36         3.31        6.13      -35.64          -5.19
  Alarm thresholds:
    High  50         3.55        1.44      -10.00         5.00
    Low   30         3.01        1.01      -30.00         0.00
# 显示接口FourHundredGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname>display transceiver diagnosis interface FourHundredGigE1/0/1
FourHundredGigE1/0/1 transceiver diagnostic information:
[Module]   Temp.(C)     Voltage(V)      TEC Curr. (%)   Laser Temp.(C)
           40           3.34            38              53
[Channel]   Bias(mA)     RX power(dBm)  TX power(dBm)
1           1.13         -20.43               -1.0
2           1.13         -20.43               -1.0
3           1.13         -20.43               -1.0
4           1.13         -20.43               -1.0
5           1.13         -20.43               -1.0
6           1.13         -20.43               -1.0
7           1.13         -20.43               -1.0
8           1.13         -20.43               -1.0
  Alarm thresholds:
    High  80         3.64        15.00     5.00           5.50
    Low   -10        2.97        4.50      -12.00         -3.50
表1-31 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
TEC Curr. (%)
数字诊断参数——制冷器工作电流/制冷器的额定电流,单位为%,精确到0.01%
Laser Temp.(C)
数字诊断参数——激光器温度,单位为°C,精确到0.01°C
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver health命令用来显示光模块的健康度信息。
display transceiver health interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔光模块的健康度信息。
[Sysname] display transceiver health interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver health information:
LinkStatus health: 10
Transceiver health:
  Temp.    Voltage    Bias    RX power    TX power   Total
  10       10         10      10          10         10
表1-32 display transceiver health显示信息描述表
Transceiver health
接口的光模块健康度信息
LinkStatus health
链路健康度,其计算方法与错包率健康度有关:
·     当错包率健康度为1时,则链路健康度=1
·     当错包率健康度为2~9时:链路健康度=(接收光功率健康度+丢包率健康度)/2
·     当错包率健康度为10时,则链路健康度=(接收光功率健康度+10)/2+0.5的值取整
Temp
温度健康度
Voltage
电压健康度
Bias
偏置电流健康度
RX power
接收光功率健康度
TX power
发送光功率健康度
Total
接口的光模块总体健康度,计算方式为下方每一个元素健康度乘以对应权重值之和
·     transceiver health check enable
·     transceiver health weight
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface ten-gigabitethernet 3/0/1
显示信息略……。
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 3/0/1
显示信息略……。
display transceiver status命令用来显示可插拔400G光模块的状态信息。
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔400G光模块的状态信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FourHundredGigE1/0/1上插入的可插拔400G光模块的状态信息。
<Sysname> display transceiver status interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver status information:
  Module state        : ModuleReady
  Interrupt           : YES
  Lane      Data Path State     Media Lane State
  Lane1     Activated           Enable
  Lane2     Activated           Enable
  Lane3     Activated           Enable
  Lane4     Activated           Enable
  Lane5     Activated           Enable
  Lane6     Activated           Enable
  Lane7     Activated           Enable
  Lane8     Activated           Enable
# 显示接口FourHundredGigE1/0/1上插入的可插拔400G ZR光模块的状态信息。(本举例仅QSFPDD-400G-ZR光模块支持)
  Interrupt           : YES
表1-33 display transceiver status命令显示信息描述表
interface-name transceiver status information
接口interface-name上插入的可插拔400G光模块的状态信息
Module state
光模块的状态,取值为:
·     ModuleLowPwr:表示低功率状态
·     ModulePwrUp:表示上电状态
·     ModuleReady:表示就绪状态
·     ModulePwrDn:表示断电状态
·     Fault state:表示故障状态
·     UNKONWN:表示未知状态
Interrupt
光模块当前是否存在中断告警,取值为:
·     YES:表示处于中断告警态
·     NO:表示未处于中断告警状态
Data Path State
数据路径的状态,取值为:
·     UNKNOWN:表示未知状态
·     Deactivated:表示未激活状态
·     Init:表示初始化状态
·     Deinit:表示未初始化状态
·     Activated:表示激活状态
·     TxTurnOn:表示Tx端打开状态
·     TxTurnOff:表示Tx端关闭状态
·     Initialized:表示初始化完成状态
Lane
数据通道
Media Lane State
光模块光通道的状态,取值为:
·     Enable:表示开启状态
·     Disable:表示关闭状态
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
显示信息略……。
display version-update-record命令用来显示启动软件包版本更新操作的记录。
仅缺省MDC支持本命令。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : system-test.bin
表1-34 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54)
最近的第n次更新的时间,Record 1为最新的一次更新
*Name
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化
Version
软件包的版本号
Compile time
版本编译时间
·     reset version-update-record
fabric load-sharing mode命令用来配置业务板的负载分担类型。
undo fabric load-sharing mode命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing mode { { { destination-ip | source-ip } * | { destination-mac| source-mac } * | flexible } slot slot-number
undo fabric load-sharing mode { { destination-ip | source-ip } * | { destination-mac| source-mac } * | flexibleslot slot-number
fabric load-sharing mode { { { destination-ip | source-ip } * | { destination-mac| source-mac } * | flexible } chassis chassis-number slot slot-number
undo fabric load-sharing mode { { destination-ip | source-ip } * | { destination-mac| source-mac } * | flexiblechassis chassis-number slot slot-number
缺省情况下,业务板的负载分担类型为flexible。
destination-ip:表示按报文的目的IP地址进行负载分担。
destination-mac:表示按报文的目的MAC地址进行负载分担。
source-ip:表示按报文的源IP地址进行负载分担。
source-mac:表示按报文的源MAC地址进行负载分担。
flexible:表示按报文类型(如二层、IPv4等)自动选择负载分担的类型。
slot slot-number:单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number为单板所在的槽位号。(IRF模式)
对于S12500G-AF系列交换机,仅SF系列接口板支持本命令。
如果多次执行本命令,最后一次执行的命令生效。
# 配置指定slot按照报文目的MAC地址进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing mode destination-mac slot 2
fabric multicast-forwarding mode命令用来配置组播转发模式。
undo fabric multicast-forwarding mode命令用来恢复缺省情况。
fabric multicast-forwarding mode { enhanced | standard }
组播转发模式为标准模式。
enhanced:配置组播转发模式为增强模式。
standard:配置组播转发模式为标准模式。
本功能需要保存配置并重启设备才能生效。
当跨单板转发的组播流量较大时,建议将设备的组播转发模式配置为enhanced模式。
对于S12500CR系列交换机,不支持enhanced模式。
对于S12500G-AF系列交换机,SF系列接口板不支持enhanced模式。
仅缺省MDC中支持配置组播转发模式。
在组成IRF的所有设备上,组播转发模式(通过fabric multicast-forwarding mode命令配置)配置必须相同,否则这些设备将无法组成IRF。关于IRF的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。
配置组播转发模式为enhanced模式前,请先确认:
·     设备上已配置聚合负载分担采用本地转发优先功能。关于聚合负载分担采用本地转发优先功能的详细介绍,请参见“二层技术-以太网交换配置指导”中的“以太网链路聚合”。
·     IRF链路两端的IRF物理端口所在单板丝印以及单板上端口号必须相同。关于IRF的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。
# 将组播转发模式配置为增强模式。
[Sysname] fabric multicast-forwarding mode enhanced
Are you sure you want to change the forwarding mode for multicast packets between internal interfaces? [Y/N]:y
Multicast forwarding mode changed. For the change to take effect, save the running configuration and reboot the device.
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
仅缺省MDC支持本命令。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
当系统检测到器件(chip)、单板(board)和转发(forwarding)的硬件故障时,修复操作均为reset。
board:对单板故障进行在线检测,包括控制通道检测和单板状态快速检测。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,若控制通道检查到单板故障,则会重启单板并尝试修复故障。
仅缺省MDC支持本命令。
设备启动后,系统会持续自动检测器件、单板和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
1.1.54  header
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
未配置欢迎信息。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
1.1.55  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
一级告警门限为194MB,二级告警门限为136MB,三级告警门限为77MB,系统恢复到正常的内存门限为252MB,预告警门限为311MB,预告警恢复门限为350MB。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
仅缺省MDC支持本命令。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备监控的是系统内存中剩余空闲内存的大小,使用display memory命令可以查看系统内存的使用情况。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
配置本命令后,当剩余空闲内存到达了告警门限,将无法创建微分段,无法进入微分段视图,但已配置的微分段功能可以正常使用。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
·     display memory-threshold
1.1.57  memory-threshold usage
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
仅缺省MDC支持本命令。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
1.1.58  monitor cpu-usage enable
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
(独立运行模式)
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
1.1.59  monitor cpu-usage interval
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
(独立运行模式)
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
1.1.60  monitor cpu-usage logging interval
monitor cpu-usage logging interval命令用来开启周期性输出CPU利用率日志功能。
undo monitor cpu-usage logging interval命令用来关闭周期性输出CPU利用率日志功能。
monitor cpu-usage logging interval interval-time
周期性输出CPU利用率日志功能处于关闭状态。
interval-time:周期性输出CPU利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出CPU利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor cpu-usage logging interval 60
1.1.61  monitor cpu-usage threshold
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
(独立运行模式)
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | chassis chassis-number slot slot-number cpu cpu-number [ core core-id-list ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | chassis chassis-number slot slot-number cpu cpu-number [ core core-id-list ] }
CPU利用率高级别告警门限为99%,CPU利用率低级别告警门限为80%,CPU利用率恢复门限为60%。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
core core-id-list:表示CPU核的编号列表。表示方式为core-id-list = { core-id1 [ to core-id2 ] }&<1-10>,core-id2的值要大于或等于core-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
系统每隔1分钟会对CPU以及CPU核的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,低级别告警门限为80%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
1.1.62  monitor handshake-timeout disable-port
monitor handshake-timeout disable-port命令用于全局开启Port Down功能。
undo monitor handshake-timeout disable-port命令用于全局关闭Port Down功能。
缺省情况下,Port Down功能处于开启状态。
【描述】
本功能常用于以主备方式提供网络可靠性的双机环境中(例如VRRP)。开启本功能后,当主设备的主控板被拔出或异常重启时,系统将立即关闭主设备上的所有业务口,使业务快速切换到备用设备上。
该功能配置成功后,只有当当前设备上已没有可用的主控板时才生效。
# 全局开启Port Down功能。
[Sysname] monitor handshake-timeout disable-port
Set successfully!
1.1.63  monitor memory-usage logging interval
monitor memory-usage logging interval命令用来开启周期性输出内存利用率日志功能。
undo monitor memory-usage logging命令用来关闭周期性输出内存利用率日志功能。
monitor memory-usage logging interval interval-time
undo monitor memory- usage logging interval
周期性输出内存利用率日志功能处于关闭状态。
interval-time:周期性输出内存利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出内存利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor memory-usage logging interval 60
1.1.64  monitor resend cpu-usage
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。(独立运行模式)
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
1.1.65  monitor resend memory-threshold
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
执行undo monitor resend memory-threshold命令并不指定critical-interval、early-warning-interval、minor-interval和severe-interval参数时,表示将这些参数均恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。(独立运行模式)
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
1.1.66  parity-error consistency-check log enable
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查日志信息功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查日志信息功能。
软硬件表项一致性检查日志信息功能处于关闭状态。
设备在运行过程中,会对单板转发芯片中的硬件表项和软件表项进行一致性检查。配置本命令后,在采样周期内,如果检查软硬件表项的不一致次数达到通过parity-error consistency-check threshold命令配置的错误次数阈值,则生成软硬件表项一致性检查日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启软硬件表项一致性检查日志信息功能。
[Sysname] parity-error consistency-check log enable
·     parity-error consistency-check threshold
·     parity-error consistency-check period
1.1.67  parity-error consistency-check period
parity-error consistency-check period命令用来配置软硬件表项一致性检查错误日志的发送周期。
undo parity-error consistency-check period命令用来恢复缺省情况
parity-error consistency-check period value
软硬件表项一致性检查错误日志的发送周期为3600秒。
value:表示软硬件表项一致性检查错误日志的发送周期,取值范围为600~31536000,单位为秒。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,设备会按周期收集单板软硬件表项一致性检查错误发生的次数。建议将周期设置为大于3600秒。
# 配置软硬件表项一致性检查错误的日志发送周期为600秒。
[Sysname] parity-error consistency-check period 600
·     parity-error consistency-check log enable
1.1.68  parity-error consistency-check threshold
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查的错误次数阈值。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查的错误次数阈值为10次。
value:表示软硬件表项一致性检查的错误次数阈值,取值范围为1~2147483647,单位为次数。
在开启软硬件表项一致性检查日志信息功能后,配置本命令后,设备在软硬件表项一致性检查错误次数的采样周期内,当检查到单板软硬件表项不一致的错误次数达到配置的阈值时,会生成软硬件表项一致性检查日志信息。
# 配置软硬件表项一致性检查的错误次数阈值为20次。
[Sysname] parity-error consistency-check threshold 20
1.1.69  parity-error monitor log enable
parity-error monitor log enable命令用来开启硬件表项奇偶校验和ECC校验日志信息功能。
undo parity-error monitor log enable命令用来关闭硬件表项奇偶校验和ECC校验日志信息功能。
硬件表项奇偶校验和ECC校验日志信息功能处于关闭状态。
设备在运行过程中,会自动对单板转发芯片中硬件表项进行奇偶校验和ECC校验,并记录错误次数。配置本命令后,在通过parity-error monitor period命令配置的采样周期内,如果硬件表项的奇偶校验和ECC校验的错误次数达到通过parity-error monitor threshold命令配置的错误次数阈值,则生成硬件表项奇偶校验和ECC校验日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启硬件表项奇偶校验和ECC校验日志信息功能。
[Sysname] parity-error monitor log enable
·     parity-error monitor period
·     parity-error monitor threshold
1.1.70  parity-error monitor period
parity-error monitor period命令用来配置硬件表项奇偶校验和ECC校验错误次数的采样周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period period
硬件表项奇偶校验和ECC校验错误次数的采样周期为60秒。
period:表示硬件表项奇偶校验和ECC校验错误次数的采样周期,取值范围为1~86400,单位为秒。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在配置的硬件表项内,当单板硬件表项奇偶校验和ECC校验的错误次数达到阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置奇偶校验和ECC校验错误次数的采样周期为120秒。
[Sysname] parity-error monitor period 120
·     parity-error monitor log enable
1.1.71  parity-error monitor threshold
parity-error monitor threshold命令用来配置硬件表项奇偶校验和ECC校验的错误次数阈值。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
硬件表项奇偶校验和ECC校验的错误次数阈值为5000次。
value:表示硬件表项奇偶校验和ECC校验的错误次数阈值,取值范围为1~1000000,单位为次数。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在硬件表项奇偶校验和ECC校验错误次数的采样周期内,当单板校验错误次数达到配置的阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置硬件表项奇偶校验和ECC校验的错误次数阈值为8000次。
[Sysname] parity-error monitor threshold 8000
1.1.72  parity-error unrecoverable log enable
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对单板转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果单板关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
·     parity-error unrecoverable period
·     parity-error unrecoverable reboot
·     parity-error unrecoverable threshold
1.1.73  parity-error unrecoverable period
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为60秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当单板关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
·     parity-error unrecoverable log enable
1.1.74  parity-error unrecoverable reboot
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启。
如果单板转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使单板通过重启来恢复关键硬件表项。
配置本命令后,当单板生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
# 开启生成关键硬件表项不可恢复日志信息后单板的自动重启功能。
[Sysname] parity-error unrecoverable reboot
1.1.75  parity-error unrecoverable threshold
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~1000000,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
1.1.76  password-recovery enable
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
仅缺省MDC支持本命令。
清除认证密码的操作必须在主用主控板的启动过程中进入BootWare菜单进行。(独立运行模式)(IRF模式)
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.77  power-supply off
power-supply off命令用来强制给单板断电。
(独立运行模式)
power-supply off slot slot-number
power-supply off chassis chassis-number slot slot-number
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
强制给单板下电后,单板将无法收发报文,请谨慎使用。
仅缺省MDC支持本命令。
如果设备电量不足,且某些接口板处于空闲状态或者连接的为非关键网络节点时,可以手工停止给这些接口板供电,以便节约电能保证给重要接口板供电。
请先开启电源管理功能,再配置本命令。否则,本命令配置失败。
在IRF中,当最后一个处于up状态的IRF物理端口都位于某接口板上时,不允许强制给该接口板断电,以免导致IRF分裂。(IRF模式)
# 强制给指定slot的单板断电。(独立运行模式)
<Sysname> power-supply off slot 2
·     power-supply policy enable
1.1.78  power-supply on
power-supply on命令用来手工给单板供电。
(独立运行模式)
power-supply on slot slot-number
power-supply on chassis chassis-number slot slot-number
仅缺省MDC支持本命令。
# 手工给指定slot的单板供电。(独立运行模式)
<Sysname> power-supply on slot 2
1.1.79  power-supply policy enable
power-supply policy enable命令用来开启电源管理功能。
undo power-supply policy enable命令用来关闭电源管理功能。
(独立运行模式)
power-supply policy chassis chassis-number enable
undo power-supply policy chassis chassis-number enable
电源管理功能处于关闭状态。
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
仅缺省MDC支持本命令。
# 启用电源管理功能。(独立运行模式)
[Sysname] power-supply policy enable
1.1.80  power-supply policy priority
power-supply policy priority命令用来配置单板的供电优先级。
undo power-supply policy priority命令用来恢复缺省情况。
(独立运行模式)
power-supply policy slot slot-number priority priority
undo power-supply policy slot slot-number priority
power-supply policy chassis chassis-number slot slot-number priority priority
undo power-supply policy chassis chassis-number slot slot-number priority
接口板的供电优先级为5。
priority:单板的供电优先级,取值范围为0~10。本参数值越小表示单板的供电优先级越高。
仅缺省MDC支持本命令。
仅业务板支持本命令。
请根据实际组网应用,将正在处理或将要处理重要业务的单板的优先级值减小,以便在系统供电不足或者电力恢复时,优先保证对该单板的供电。
系统会自动保证IRF物理接口所在的接口板的供电优先级:
·     将接口板上的接口和IRF端口绑定后,系统会自动提高该接口板的供电优先级,不再支持手工配置。
·     用户配置接口板的供电优先级,再将接口板上的接口和IRF端口绑定后,接口板的供电优先级配置会继续存在但不生效。
开启电源管理功能后,本命令才会生效。
# 配置指定slot的单板的供电优先级为10。(独立运行模式)
[Sysname] power-supply policy slot 2 priority 10
1.1.81  power-supply policy redundant
power-supply policy redundant命令用来配置冗余电源模块数。
undo power-supply policy redundant命令用来恢复缺省情况。
(独立运行模式)
power-supply policy redundant module-count
power-supply policy chassis chassis-number redundant module-count
undo power-supply policy chassis chassis-number redundant
配置的冗余电源模块数为0。
module-count:表示冗余电源模块数目,不同型号的设备支持的取值范围不同,用户可以通过帮助信息来获取设备支持的取值范围,但是该范围的上限是系统支持的最大冗余模块数,根据设备安插的接口板的数量和耗电量不同,用户实际能够配置的值会小于等于系统支持的最大冗余模块数。
仅缺省MDC支持本命令。
只有在开启电源管理功能后,冗余电源配置才会生效。
# 配置电源冗余模块数为1。(独立运行模式)
[Sysname] power-supply policy redundant 1
1.1.82  reboot
reboot命令用来重启设备。
(独立运行模式)
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启成员设备。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启整个设备。(独立运行模式)
force:强制重启:
·     不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(独立运行模式)
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。(独立运行模式)
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
·     display system stable state
1.1.83  reset asset-info
reset asset-info命令用来清除设备的用户资产信息。使用该命令,用户可以清除设备机箱、单板、电源或风扇框的资产信息。
(独立运行模式)
reset asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
reset asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
chassis:清除设备机箱的用户资产信息。
fan fan-id:设置指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号。
power power-id:设置指定电源模块的用户资产信息。power-id表示设备上电源模块的编号。
slot slot-number:清除指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:清除资产编号信息。
custom:清除用户自定义的资产信息。
department:清除资产的归属部门信息。
description:清除资产的描述信息。
service-date:清除资产的启用时间信息。
state:清除资产的使用状态信息。
chassis chassis-number:清除指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
当用户希望清除设备机箱、单板或风扇框的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,清除的是该设备机箱、单板或风扇框的所有用户资产信息。
使用该命令清除指定风扇框或者电源模块的资产信息时,如果设备上无对应编号的风扇框或者电源模块,将返回风扇框或者电源模块不支持该操作的提示信息。
# 清除设备上0号单板的资产编号信息。(独立运行模式)
[Sysname] reset asset-info slot 0 csn
·     display asset-info
·     set asset-info
1.1.84  reset scheduler logfile
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
仅缺省MDC支持本命令。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
1.1.85  reset transceiver interface
reset transceiver interface命令用来通过软件复位可插拔400G光模块。
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number:表示接口类型和接口编号。不指定该参数时,表示所有接口。
当光模块工作异常时,可以通过软件复位光模块来尝试修复光模块。正常情况下,不建议配置。
执行本命令会重启光模块,请谨慎使用。
# 通过软件复位接口FourHundredGigE1/0/1上插入的可插拔400G光模块。
<Sysname> reset transceiver interface fourhundredgige 1/0/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
1.1.86  reset version-update-record
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
仅缺省MDC支持本命令。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
1.1.87  resource-monitor minor resend enable
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
·     开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
·     关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
·     display resource-monitor
·     resource-monitor output
1.1.88  resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
·     NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
·     信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
·     SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
1.1.89  resource-monitor resource
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
(独立运行模式)
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
resource-monitor resource resource-name  chassis chassis-number slot slot-number cpu cpu-number by-percent minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见下表。
表1-35 设备可监测的资源描述表
取值
含义
ac
VXLAN服务实例资源
agg_group
聚合组资源
agg_member
聚合组成员端口数
arp
ARP表项资源
egs_acl
出方向ACL资源
egs_counter
出方向counter资源
igs_acl
入方向ACL资源
igs_counter
入方向counter资源
input_flowrate
入方向报文速率
ipmc
三层组播复制表资源
ipv6
IPv6路由表项资源
l2mc
VLAN内组播复制表资源
mac
MAC地址表项资源
meter
meter资源
mqcin
入方向MQC资源
mqcout
出方向MQC资源
nd
ND表项资源
nexthoppool1
Underlay下一跳资源池资源
nexthoppool2
Overlay下一跳资源池资源
openflow
OpenFlow资源
output_flowrate
出方向报文速率
pbr
PBR资源
pfilterin
入方向包过滤资源
pfilterout
出方向包过滤资源
port
二层以太网接口资源
route
路由表项资源
rport
三层以太网接口资源
stg
stp实例资源
vlaninterface
VLAN接口资源
vrf
VPN实例资源
vsi
VSI(Virtual Switch Instance,虚拟交换实例)资源
vsiintf
VSI接口资源
slot slot-number:表示监测指定单板上的资源。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示监测指定单板上的资源。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。(独立运行模式)
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent  minor-threshold 30 severe-threshold 10
1.1.90  restart standby
restart standby命令用来重启备用主控板。
restart standby
仅独立运行模式下支持本命令。
仅缺省MDC支持本命令。
执行本命令效果等同于执行reboot slot slot-number(slot-number指定为备用主控板所在的槽位号)。因为无需指定slot参数,所以,使用起来比reboot命令更加便捷。
# 重启备用主控板。
[Sysname] restart standby
Rebooting the standby MPU. Continue?[Y/N]:y
The standby MPU is rebooting. Please wait...
·     reboot
1.1.91  restore factory-default
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
仅缺省MDC支持本命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
1.1.92  scheduler job
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
·     command
1.1.93  scheduler logfile size
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
1.1.94  scheduler reboot at
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
·     配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
1.1.95  scheduler reboot delay
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
1.1.96  scheduler schedule
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule。
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
1.1.97  set asset-info
set asset-info命令用来设置设备的用户资产信息。使用该命令,用户可以根据自定义的规则为设备机箱、单板设置资产信息。
(独立运行模式)
set asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
set asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
chassis:设置设备机箱的用户资产信息。
slot slot-number:设置指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn csn-number:设置资产编号信息。csn-number表示用户设置的资产编号信息,为1~64字节的字符串。
custom name value:设置用户自定义的资产信息。name表示用户自定义的资产信息名称,value表示用户设置的资产信息内容。
department department:设置资产的归属部门信息。department表示用户设置的资产归属部门,为1~64字节的字符串。
description description:设置资产的描述信息。description表示用户设置的资产描述信息,为1~64字节的字符串。
location location:设置资产的位置信息。location表示用户设置的资产位置信息,为1~64字节的字符串。
service-date date:设置资产的启用时间信息。date表示用户设置的资产启用时间,为1~25字节的字符串。
state state:设置资产的使用状态信息。state表示用户设置的资产使用状态,为1~64字节的字符串。
chassis chassis-number:设置指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
使用该命令设置指定风扇框或者电源模块的资产信息时,如果设备上无对应编号的风扇框或者电源模块,将返回风扇框或者电源模块不支持该操作的提示信息。
# 设置设备上0号单板的资产编号为123456。(独立运行模式)
[Sysname] set asset-info slot 0 csn 123456
·     reset asset-info
1.1.98  shutdown-interval
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个检测端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
1.1.99  switch-fabric isolate
switch-fabric isolate命令用来将网板从转发平面隔离出去,所有数据流量都不经过指定网板。
undo switch-fabric isolate命令用来取消对网板的隔离。
(独立运行模式)
switch-fabric isolate slot slot-number [ channel channel-number ]
undo switch-fabric isolate slot slot-number [ channel channel-number ]
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
undo switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
网板处于转发平面,数据流量会经过网板进行转发。
slot slot-number:表示网板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定网板。(IRF模式)
channel channel-number:表示网板上数据通道的编号。不指定该参数时,表示隔离指定网板。
·     每块网板都有一定的转发带宽,隔离一块网板后会减少相应的转发带宽,使设备整体转发带宽降低。请根据需要配置。
·     当设备上仅存在一块网板时,请不要隔离该网板。
仅缺省MDC支持本命令。
该命令主要用于定位网板是否能够正常转发,以及更换网板前,为避免报文丢失,可配置本命令。网板隔离后仍能与主控板正常通信,控制平面上协议报文的解析与协议的计算等功能均不受影响,从而保证取消隔离后可以快速恢复网板的转发能力。
网板隔离期间不要重启设备。
网板隔离后,请使用undo switch-fabric isolate命令对该网板取消隔离,网板才能恢复正常转发功能。
# 将10号槽位的网板隔离。(独立运行模式)
[Sysname] switch-fabric isolate slot 10
The command will isolate the switch fabric from the system. Continue? [Y/N]y
1.1.100  switch-mode
switch-mode命令用于配置交换机业务板的工作模式。
undo switch-mode命令用于恢复业务板的工作模式为未配置状态。
(独立运行模式)
switch-mode slot slot-number { balance | bridging | enhance | enhance-balance | enhance-bridging | enhance-routing | normal | routing }
undo switch-mode slot slot-number
switch-mode chassis chassis-number slot slot-number { balance | bridging | enhance | enhance-balance | enhance-bridging | enhance-routing | normal | routing}
undo switch-mode chassis chassis-number slot slot-number
业务板的工作模式为normal。
balance:业务板工作模式为均衡模式。
bridging:业务板工作模式为MAC扩展模式。
enhance:业务板工作模式为增强模式。
enhance-balance:业务板工作模式为增强的均衡模式。
enhance-bridging:业务板工作模式为增强的MAC扩展模式。
enhance-routing:业务板工作模式为增强的路由扩展模式。
normal:业务板工作模式为普通模式。
routing:业务板工作模式为路由扩展模式。
slot slot-number:业务板所在槽位号。
chassis chassis-number:表示IRF中设备的成员编号。(IRF模式)
业务板工作模式配置完毕后需保存配置并重启该业务板,所做配置才会生效。
对于S12500CR系列交换机,不支持增强的工作模式。
对于S12500G-AF系列交换机,SF系列接口板不支持增强的工作模式。
# 配置设备2号槽位接口板的工作模式为MAC扩展模式(bridging)。(独立运行模式)
[Sysname] switch-mode bridging slot 2
·     display switch-mode status
1.1.101  sysname
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
1.1.102  system handshake timeout
system handshake timeout命令用来配置主控板与接口板之间握手的超时时长。
undo system handshake timeout命令用来恢复缺省情况。
system handshake timeout timeout
缺省情况下,设备主控板与接口板之间握手的超时时长为60秒。
timeout:主控板与接口板之间一次握手的超时时长。取值范围为10~60,单位为秒。
仅独立运行模式下支持本命令。
接口板启动完成后,会主动向主控板注册,以便接受主控板的管理。在设备运行期间,主控板会定期向接口板发送握手报文,来确认接口板是否运行正常。如果接口板在本命令设置的握手超时时长内未回复报文,主控板将认为该接口板故障,则会重启该接口板。
在一些对此握手时间有要求的场景(比如板卡重启断流时间要求短的场景),可以通过本命令调整主控板与接口板之间握手的超时时长,实现缩短握手时间,尽早发现接口板故障。
# 配置主控板与接口板之间握手的超时时长为40秒。
[Sysname] system handshake timeout 40
1.1.103  system switchover
system switchover命令用来手工触发主用主控板和备用主控板的主备倒换。
system switchover
仅独立运行模式下支持本命令。
仅缺省MDC支持本命令。
手工触发主备倒换时,原主用主控板会自动重启,所以,在执行本命令前,建议先保存当前配置。
# 当前配置跟启动配置文件比较无变化时,手工触发主用主控板和备用主控板的主备倒换。
[Sysname] system switchover
Switching to the standby MPU. Continue? [Y/N]:y
This command will perform a switchover. Continue? [Y/N]:y
# 当前配置跟启动配置文件比较有变化时,手工触发主用主控板和备用主控板的主备倒换。
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Please input the file name(*.cfg)[flash:/mqc.cfg]
flash:/mqc.cfg exists, overwrite? [Y/N]:y
1.1.104  system-working-mode
system-working-mode命令用来配置设备的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | expert | standard }
设备工作在专家模式。
advance:将设备的工作模式配置为高级模式。
expert:将设备的工作模式配置为专家模式。
standard:将设备的工作模式配置为标准模式。
仅缺省MDC支持本命令。
仅S12500G-AF S系列交换机支持本命令。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,详细描述请参见“基础配置指导”中的“设备管理”。
要使修改的工作模式生效,必须重启设备。
# 将设备工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
1.1.105  temperature-limit
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
(独立运行模式)
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number{ hotspot | inflow | outflow } sensor-number
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
本命令仅缺省MDC支持。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
·     display environment
1.1.106  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
1.1.107  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
1.1.108  time repeating
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.109  transceiver health check enable
transceiver health check enable命令用来开启光模块健康度检测功能。
undo transceiver health check enable命令用来关闭光模块健康度检测功能。
光模块健康度检测功能处于关闭状态。
# 开启光模块健康度检测功能。
[Sysname] transceiver health check enable
·     display transceiver health
1.1.110  transceiver health weight
transceiver health weight命令用来配置光模块健康度的计算权重。
undo transceiver health命令用来恢复缺省情况。
transceiver health weight temp temp-weight voltage volage-weight bias bias-weight rxpower rxpower-weight txpower txpower-weight
undo transceiver health weight
光模块健康度的计算权重如下:temp权重值为15,voltage权重值为5,bias权重值为30,rxpower权重值为10,txpower权重值为40。
temp temp-weight:表示光模块的温度在健康度中的计算权重,取值范围为1~96。
voltage volage-weight:表示光模块的电压在健康度中的计算权重,取值范围为1~96。
bias bias-weight:表示光模块的偏置电流在健康度中的计算权重,取值范围为1~96。
rxpower rxpower-weight:表示光模块的发送光功率健康度在健康度中的计算权重,取值范围为1~96。
txpower txpower-weight:表示光模块的接收光功率健康度在健康度中的计算权重,取值范围为1~96。
本命令可配置用于光模块健康度检测计算的5个诊断参数的计算权重。诊断参数分别为temp、voltage、bias、rxpower和txpower。
光模块健康度的各个诊断参数的计算权重值之和必须为100。
# 配置光模块健康度的计算权重,temp、voltage、bias、rxpower和txpower的计算权重值均为20。
[Sysname] transceiver health weight temp 20 voltage 20 bias 20 rxpower 20 txpower 20
1.1.111  transceiver lane enable
transceiver lane enable命令用来打开400G光模块的光通道。
undo transceiver lane命令用来关闭400G光模块的光通道。
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
光模块的光通道处于开启状态。
以太网接口视图
lane-number:表示光通道的编号,取值范围为1~8。不指定该参数时,表示所有光通道。
本命令主要用于调测光模块的功能是否正常,正常情况下,不建议配置。
关闭光通道将导致光模块不能传输信号。
关闭某个光通道将导致该光通道所属的光接口不能传输信号。
本配置会保存在光模块内部的寄存器中,不会保存到配置文件中。
# 开启FourHundredGigE1/0/1上插入的400G光模块的通道1。
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] transceiver lane 1 enable
·     display transceiver status
1.1.112  transceiver lane equalization
transceiver lane equalization命令用来配置400G光模块接收通道的平衡因子和功率幅值。
undo transceiver lane equalization命令用来恢复缺省情况。
transceiver lane [ lane-number ] equalization { precursor precursor-value | postcursor postcursor-value | amplitude amplitude-value }
undo transceiver lane [ lane-number ] equalization { precursor | postcursor | amplitude }
本命令的缺省情况与光模块的型号有关,请以光模块的实际情况为准。
FourHGE以太网接口及其拆分口的接口视图
lane-number:光通道的编号,取值范围为1~8。不指定该参数时,表示所有光通道。
precursor-value:设置光模块接收通道precursor的编码。取值为:
·     level0:表示No Equalization。
·     level1:表示0.5dB。
·     level2:表示1dB。
·     level3:表示1.5dB。
·     level4:表示2dB。
·     level5:表示2.5dB。
·     level6:表示3dB。
·     level7:表示3.5dB。
postcursor-value:设置光模块接收通道postcursor的编码。取值为:
·     level1:表示1dB。
·     level2:表示2dB。
·     level3:表示3dB。
·     level4:表示4dB。
·     level5:表示5dB。
·     level6:表示6dB。
·     level7:表示7dB。
amplitude-value:设置光模块接收通道功率幅值的编码。取值为:
·     range0:表示100-400 mV。
·     range1:表示300-600 mV。
·     range2:表示400-800 mV。
·     range3:表示600-1200 mV。
本命令用来来调测和优化高速信号,达到最优的链路状态。通常情况下,建议使用缺省情况。如果确实需要调整,请在专业人士指导下进行,以免光模块工作异常。
当接口在传输业务流量时,建议不要执行本命令。因为执行本命令,设备会自动关闭、开启光模块一次,影响流量的传输。
# 为FourHundredGigE1/0/1上插入的400G光模块接收通道配置平衡因子和功率幅值。
[Sysname-FourHundredGigE1/0/1] transceiver lane 1 equalization pre-cursor 1 post-cursor 8 amplitude 3
This operation will shut down and then bring up the transceiver module, affecting data transmission. Continue? [Y/N]:Y
·     display transceiver active-control
1.1.113  transceiver monitor enable
transceiver monitor enable命令用来开启光模块监控功能。
undo transceiver monitor enable命令用来关闭光模块监控功能。
光模块监控功能处于关闭状态。
仅缺省MDC支持本命令。
开启光模块监控功能后,设备会按周期检查光模块的参数(例如光模块的输出功率、输入功率等),当参数的采样值达到软件设定的阈值时,会生成相应的日志提醒用户。
# 使能光模块监控功能。
[Sysname] transceiver monitor enable
·     transceiver monitor interval
1.1.114  transceiver monitor interval
transceiver monitor interval命令用来配置光模块的监控周期。
undo transceiver monitor interval命令用来恢复缺省情况。
transceiver monitor interval interval
光模块的监控周期是600秒。
interval:表示光模块的监控周期,取值范围为300~3600,单位为秒。
仅缺省MDC支持本命令。
开启光模块监控功能后,本命令才生效。
# 配置光模块监控周期为500秒。
[Sysname] transceiver monitor interval 500
·     transceiver monitor enable
1.1.115  transceiver power-mode
transceiver power-mode命令用来配置400G光模块的功耗模式。
undo transceiver power-mode命令用来恢复缺省情况。
transceiver power-mode { high | low }
以太网接口视图
通常情况下,光模块处于高功耗工作模式。当光模块长时间不需要工作时,可将光模块切换到低功耗工作模式,节省能耗。低功耗模式下,光模块不能传输信号,如果有流量传输需求,需要手工将光模块调整到高功耗工作模式。
# 将FourHundredGigE1/0/1上插入的400G光模块设置为高功耗模式。
[Sysname-FourHundredGigE1/0/1] transceiver power-mode high
# 将FourHundredGigE1/0/1上插入的400G光模块设置为低功耗模式。
[Sysname-FourHundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
1.1.116  transceiver working-mode
transceiver working-mode命令用来配置400G光模块的工作模式。
undo transceiver working-mode命令用来恢复缺省情况。
transceiver working-mode working-mode
本命令的缺省情况与光模块的型号有关,请以设备的实际情况为准。
working-mode:400G光模块的工作模式,比如400G-SR8、200G-SR4,不区分大小写。
两个直连的光模块工作模式必须相同,否则,不能通信。
# 将FourHundredGigE1/0/1上插入的400G光模块设置为400G-SR8工作模式。
[Sysname-FourHundredGigE1/0/1] transceiver working-mode 400G-SR8
1.1.117  user-role
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、mdc-admin、mdc-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
