06-VPN命令参考
05-ADVPN命令
本章节下载: 05-ADVPN命令  (543.70 KB)
05-ADVPN命令
1 ADVPN
1.1 VAM Server配置命令
1.1.1 authentication-algorithm
1.1.2 authentication-method
1.1.3 display vam server address-map
1.1.4 display vam server ipv6 address-map
1.1.5 display vam server ipv6 private-network
1.1.6 display vam server private-network
1.1.7 display vam server statistics
1.1.8 encryption-algorithm
1.1.9 hub-group
1.1.10 hub ipv6 private-address
1.1.11 hub private-address
1.1.12 keepalive
1.1.13 pre-shared-key (ADVPN domain view)
1.1.14 retry interval
1.1.15 reset vam server address-map
1.1.16 reset vam server ipv6 address-map
1.1.17 reset vam server statistics
1.1.18 server enable
1.1.19 shortcut interest
1.1.20 shortcut ipv6 interest
1.1.21 spoke ipv6 private-address
1.1.22 spoke private-address
1.1.23 vam server advpn-domain
1.1.24 vam server enable
1.1.25 vam server listen-port
1.2 VAM Client配置命令
1.2.1 advpn-domain
1.2.2 client enable
1.2.3 display vam client fsm
1.2.4 display vam client shortcut interest
1.2.5 display vam client shortcut ipv6 interest
1.2.6 display vam client statistics
1.2.7 dumb-time
1.2.8 pre-shared-key (VAM Client view)
1.2.9 reset vam client fsm
1.2.10 reset vam client ipv6 fsm
1.2.11 reset vam client statistics
1.2.12 retry
1.2.13 server primary
1.2.14 server secondary
1.2.15 user
1.2.16 vam client enable
1.2.17 vam client name
1.3 ADVPN隧道配置命令
1.3.1 advpn group
1.3.2 advpn ipv6 network
1.3.3 advpn logging enable
1.3.4 advpn map group
1.3.5 advpn network
1.3.6 advpn session dumb-time
1.3.7 advpn session idle-time
1.3.8 advpn source-port
1.3.9 display advpn ipv6 session
1.3.10 display advpn group-qos-map
1.3.11 display advpn session
1.3.12 display advpn session count
1.3.13 keepalive
1.3.14 reset advpn ipv6 session
1.3.15 reset advpn ipv6 session statistics
1.3.16 reset advpn session
1.3.17 reset advpn session statistics
1.3.18 vam client
1.3.19 vam ipv6 client
1 ADVPN
1.1  VAM Server配置命令
authentication-algorithm命令用来设置VAM协议报文的验证算法。
undo authentication-algorithm命令用来恢复缺省情况。
authentication-algorithm { aes-xcbc-mac | md5 | none | sha-1 | sha-256 } *
VAM协议报文的验证算法为SHA-1。
ADVPN域视图
context-admin
aes-xcbc-mac:表示采用AES-XCBC-MAC验证算法。
md5:表示采用MD5验证算法。
none:表示不对VAM协议报文进行验证。
sha-1:表示采用SHA-1验证算法。
sha-256:表示采用SHA-256验证算法。
VAM Server与VAM Client固定使用SHA-1验证算法对连接初始化请求和响应报文进行完整性验证;使用协商出来的验证算法对其他VAM协议报文进行完整性验证。
验证算法在配置中的出现顺序决定其使用优先级。配置中越靠前的验证算法,其优先级越高。VAM Server在与VAM Client协商时,从VAM Client支持的验证算法列表中选择VAM Server上配置最靠前的算法作为协商结果。
修改本配置对已经注册的VAM Client没有影响,新注册的VAM Client将采用修改后的验证算法进行协商。
# 设置在ADVPN域1中使用的验证算法优先级从高到低依次为MD5、SHA-1和SHA-256。
[Sysname] vam server advpn-domain 1
[Sysname-vam-server-domain-1] authentication-algorithm md5 sha-1 sha-256
authentication-method命令用来配置VAM Server对VAM Client的身份认证方式。
undo authentication-method命令用来恢复缺省情况。
authentication-method { none | { chap | pap } [ domain isp-name ] }
VAM Server使用CHAP方式对VAM Client进行身份认证,认证使用的ISP域为用户配置的系统默认域。
ADVPN域视图
context-admin
none:表示不对VAM Client进行认证。
chap:表示使用CHAP认证方式。
pap:表示使用PAP认证方式。
domain isp-name:指定认证使用的ISP域。isp-name表示ISP域的名称,为1~24个字符的字符串,不区分大小写,不能包括“\”、“|”、“/”、“:”、“*”、“?”、“””、“<”、“>”以及“@”字符。如果未指定本参数,则认证使用的ISP域为用户配置的系统默认域。
如果指定的ISP域不存在,则VAM Server对VAM Client的身份认证会失败。
修改本配置对已经注册的VAM Client没有影响,新注册的VAM Client将按照修改后的认证方式进行身份认证。
# 配置ADVPN域1对VAM Client采用CHAP方式进行身份认证,认证使用的ISP域为用户配置的系统默认域。
[Sysname-vam-server-domain-1] authentication-method chap
display vam server address-map命令用来显示注册到VAM Server上的VAM Client的IPv4私网地址和公网地址映射信息。
display vam server address-map [ advpn-domain domain-name [ private-address private-ip-address ] ] [ verbose ]
context-admin
context-operator
advpn-domain domain-name:显示指定ADVPN域中注册的VAM Client的IPv4私网地址和公网地址映射信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则显示VAM Server上所有注册的VAM Client的IPv4私网地址和公网地址映射信息。
private-address private-ip-address:显示指定IPv4私网地址的映射信息。private-ip-address为VAM Client的IPv4私网地址。如果未指定本参数,则显示指定或所有ADVPN域中注册的VAM Client的IPv4私网地址和公网地址映射信息。
verbose:显示地址映射的详细信息。如果未指定本参数,则显示地址映射的摘要信息。
# 显示所有ADVPN域中的IPv4私网地址和公网地址映射信息。
<Sysname> display vam server address-map
ADVPN domain name: 1
Total private address mappings: 2
Group      Private address  Public address              Type   NAT  Holding time
1          10.0.0.1         2001::1                     Hub    No   0H 13M 34S
1          10.0.0.3         74.125.128.102              Spoke  Yes  0H 4M 21S
ADVPN domain name: 2
Total private address mappings: 0
ADVPN domain name: 3
Total private address mappings: 1
1          30.0.0.1         113.124.136.1               Hub    No   0H 0M 2S
ADVPN domain name: 4
1          40.0.0.1         4001::1                     Hub    No   1H 8M 22S
ADVPN domain name: 5
1          50.0.0.1         115.194.156.1               Hub    No   132H 41M 29S
# 显示ADVPN域1中的IPv4私网地址和公网地址映射信息。
<Sysname> display vam server address-map advpn-domain 1
# 显示ADVPN域1中私网地址10.0.0.1的地址映射信息。
<Sysname> display vam server address-map advpn-domain 1 private-address 10.0.0.1
表1-1 display vam server address-map命令显示信息描述表
ADVPN domain name
ADVPN域的名称
IPv4私网地址和公网地址映射总数
Group
VAM Client所属的Hub组
Private address
VAM Client向VAM Server注册的私网地址
Public address
VAM Client向VAM Server注册的公网地址
VAM Client类型,有Hub和Spoke两种类型
NAT
VAM Client是否穿越NAT
Holding time
VAM Client的存活时间,为x小时y分钟z秒(xH yM zS)
# 显示所有ADVPN域中的IPv4私网地址和公网地址映射的详细信息。
<Sysname> display vam server address-map verbose
ADVPN domain name : 1
Private address   : 10.0.0.1
Type              : Hub
Hub group         : 1
Holding time      : 0H 13M 34S
Link protocol     : UDP
Public address    : 2001::1
Public port       : 10018
Registered address: 2001::1
Registered port   : 10018
Behind NAT        : No
Private address   : 10.0.0.3
Type              : Spoke
Hub group         : 1
Holding time      : 0H 4M 21S
Link protocol     : UDP
Public address    : 74.125.128.102
Public port       : 11297
Registered address: 192.168.23.6
Registered port   : 2158
Behind NAT        : Yes
ADVPN domain name : 3
Private address   : 30.0.0.1
Type              : Hub
Hub group         : 1
Holding time      : 0H 0M 2S
Link protocol     : GRE
Public address    : 113.124.136.1
Registered address: 113.124.136.1
Behind NAT        : No
ADVPN domain name : 4
Private address   : 40.0.0.1
Hub group         : 1
Holding time      : 1H 8M 22S
Link protocol     : IPsec-UDP
Public address    : 4001::1
Registered address: 4001::1
Registered port   : 4072
Behind NAT        : No
ADVPN domain name : 5
Private address   : 50.0.0.1
Type              : Hub
Hub group         : 1
Holding time      : 132H 41M 29S
Link protocol     : IPsec-GRE
Public address    : 115.194.156.1
Registered address: 115.194.156.1
Behind NAT        : No
# 显示ADVPN域1中的IPv4私网地址和公网地址映射的详细信息。
<Sysname> display vam server address-map advpn-domain 1 verbose
Type              : Hub
Hub group         : 1
Link protocol     : UDP
Public port       : 10018
Behind NAT        : No
Type              : Spoke
Hub group         : 1
Link protocol     : UDP
Public port       : 11297
Behind NAT        : Yes
# 显示ADVPN域1中私网地址10.0.0.1的地址映射详细信息。
<Sysname> display vam server address-map advpn-domain 1 private-address 10.0.0.1 verbose
Type              : Hub
Hub group         : 1
Link protocol     : UDP
Public port       : 10018
Behind NAT        : No
表1-2 display vam server address-map verbose命令显示信息描述表
ADVPN domain name
ADVPN域的名称
Private address
Hub group
VAM Client所属的Hub组
Holding time
Link protocol
VAM Client建立ADVPN隧道使用的链路层协议,包括:
·     UDP
·     GRE
·     IPsec-UDP
·     IPsec-GRE
Public address
NAT转换后的VAM Client的公网地址
Public port
NAT转换后的VAM Client的ADVPN端口号
本字段仅在Link protocol为UDP或IPsec-UDP时显示
Registered address
Registered port
VAM Client向VAM Server注册的ADVPN端口号
IPsec address
建立IPsec隧道时,本VAM Client使用的IP地址
本字段仅在Link protocol为IPsec-UDP或IPsec-GRE时显示
IPsec port
建立IPsec隧道时,本VAM Client使用的UDP端口号
Behind NAT
VAM Client是否穿越NAT
·     reset vam server address-map
display vam server ipv6 address-map命令用来显示注册到VAM Server上的VAM Client的IPv6私网地址和公网地址映射信息。
display vam server ipv6 address-map [ advpn-domain domain-name [ private-address private-ipv6-address ] ] [ verbose ]
context-admin
context-operator
advpn-domain domain-name:显示指定ADVPN域中注册的VAM Client的IPv6私网地址和公网地址映射信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则显示VAM Server上所有注册的VAM Client的IPv6私网地址和公网地址映射信息。
private-address private-ipv6-address:显示指定IPv6私网地址的映射信息。private-ipv6-address为VAM Client的IPv6私网地址。如果未指定本参数,则显示指定或所有ADVPN域中注册的VAM Client的IPv6私网地址和公网地址映射信息。
# 显示所有ADVPN域中的IPv6私网地址和公网地址映射信息。
<Sysname> display vam server ipv6 address-map
1          1000::1:0:0:1         2001::1                Hub    No   0H 13M 34S
2          1000::2:0:0:1         220.181.111.85         Spoke  Yes  0H 4M 21S
1          1003::1:0:0:1         3001::1                Hub    No   0H 0M 2S
1          1004::1:0:0:1         202.108.231.125        Hub    No   1H 8M 22S
1          1005::1:0:0:1         5001::1                Hub    No   132H 41M 29S
# 显示ADVPN域1中的IPv6私网地址和公网地址映射信息。
<Sysname> display vam server ipv6 address-map advpn-domain 1
# 显示ADVPN域1中私网地址1000::1:0:0:1的地址映射信息。
<Sysname> display vam server ipv6 address-map advpn-domain 1 private-address 1000::1:0:0:1
表1-3 display vam server ipv6 address-map命令显示信息描述表
ADVPN domain name
ADVPN域的名称
IPv6私网地址和公网地址映射总数
Group
VAM Client所属的Hub组
Private address
Public address
NAT
VAM Client是否穿越NAT
Holding time
# 显示所有ADVPN域中IPv6私网地址和公网地址映射的详细信息。
<Sysname> display vam server ipv6 address-map verbose
Private address   : 1000::1:0:0:1
Link local address: FE80::50:4
Type              : Hub
Hub group         : 1
Link protocol     : UDP
Public port       : 2098
Registered port   : 2098
Behind NAT        : No
Private address   : 1000::2:0:0:1
Link local address: FE80::60:4
Type              : Spoke
Hub group         : 2
Link protocol     : UDP
Public address    : 220.181.111.85
Public port       : 10018
Registered address: 10.158.26.14
Registered port   : 2694
Behind NAT        : Yes
Private address   : 1003::1:0:0:1
Link local address: FE80::70:4
Type              : Hub
Hub group         : 1
Link protocol     : GRE
Public address    : 3001::1
Registered address: 3001::1
Behind NAT        : No
Private address   : 1004::1:0:0:1
Link local address: FE80::80:4
Hub group         : 1
Public address    : 202.108.231.125
Registered address: 202.108.231.125
Behind NAT        : No
Private address   : 1005::1:0:0:1
Link local address: FE80::90:4
Type              : Hub
Hub group         : 1
Public address    : 5001::1
Registered address: 5001::1
Behind NAT        : No
# 显示ADVPN域1中的IPv6私网地址和公网地址映射的详细信息。
<Sysname> display vam server ipv6 address-map advpn-domain 1 verbose
Type              : Hub
Hub group         : 1
Link protocol     : UDP
Public port       : 2098
Behind NAT        : No
Type              : Spoke
Hub group         : 2
Link protocol     : UDP
Public port       : 10018
Behind NAT        : Yes
# 显示ADVPN域1中私网地址1000::1:0:0:1的地址映射详细信息。
<Sysname> display vam server ipv6 address-map advpn-domain 1 ipv6 private-address 1000::1:0:0:1 verbose
Type              : Hub
Hub group         : 1
Link protocol     : UDP
Public port       : 2098
Behind NAT        : No
表1-4 display vam server ipv6 address-map verbose命令显示信息描述表
ADVPN domain name
ADVPN域的名称
Private address
Link local address
VAM Client向VAM Server注册的私网链路本地地址
Hub group
VAM Client所属的Hub组
Holding time
Link protocol
·     UDP
·     GRE
·     IPsec-UDP
·     IPsec-GRE
Public address
VAM Client的真实公网地址
Public port
VAM Client的真实ADVPN端口号
Registered address
Registered port
IPsec address
IPsec链路使用的IP地址
IPsec port
IPsec链路使用的UDP端口号
Behind NAT
VAM Client是否穿越NAT
·     reset vam server ipv6 address-map
display vam server ipv6 private-network命令用来显示注册到VAM Server上的VAM Client的IPv6私网信息。
display vam server ipv6 private-network [ advpn-domain domain-name [ private-address private-ipv6-address ] ]
context-admin
context-operator
advpn-domain domain-name:显示指定ADVPN域中VAM Client的IPv6私网信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则显示VAM Server上所有注册的VAM Client的IPv6私网信息。
private-address private-ipv6-address:显示指定IPv6私网地址的私网信息。private-ipv6-address为VAM Client的IPv6私网地址。如果未指定本参数,则显示指定或所有ADVPN域中注册的VAM Client的IPv6私网信息。
# 显示所有ADVPN域中VAM Client的IPv6私网信息。
<Sysname> display vam server ipv6 private-network
Total private networks: 5
Network/Prefix                     Private address                    Preference
1000::1:0:0:0/96                   1000::1:0:0:2                      80
1000::1:0:0:0/100                  1000::1:0:0:1                      80
1000::1:1:0:0/96                   1000::1:0:0:1                      80
1000::2:0:0:0/96                   1000::1:0:0:2                      80
1000::2:0:0:0/96                   1000::2:0:0:2                      80
Total private networks: 0
Total private networks: 1
1001::1:0:0:0/100                  1001::1:0:0:1                      80
# 显示ADVPN域1中的IPv6私网信息。
<Sysname> display vam server ipv6 private-network advpn-domain 1
# 显示ADVPN域1中私网地址1000::1:0:0:1的私网信息。
<Sysname> display vam server ipv6 private-network advpn-domain 1 private-address 1000::1:0:0:1
Total private networks: 2
表1-5 display vam server ipv6 address-map命令显示信息描述表
ADVPN domain name
ADVPN域的名称
IPv6私网总数
Network/Prefix
Tunnel接口下配置的ADVPN隧道的私网网络地址/前缀长度
Private address
Preference
VAM Client向VAM Server注册的私网路由优先级
display vam server private-network命令用来显示注册到VAM Server上的VAM Client的IPv4私网信息。
display vam server private-network [ advpn-domain domain-name [ private-address private-ip-address ] ]
context-admin
context-operator
advpn-domain domain-name:显示指定ADVPN域中VAM Client的IPv4私网信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则显示VAM Server上所有注册VAM Client的IPv4私网信息。
private-address private-ip-address:显示指定IPv4私网地址的私网信息。private-ip-address为VAM Client的IPv4私网地址。如果未指定本参数,则显示指定或所有ADVPN域中注册的VAM Client的IPv4私网信息。
# 显示所有ADVPN域中VAM Client的IPv4私网信息。
<Sysname> display vam server private-network
Network/Mask              Private address        Preference
192.168.0.0/24            10.0.0.2               80
192.168.0.0/28            10.0.0.1               80
192.168.1.0/24            10.0.0.1               80
192.168.100.0/24          10.0.0.2               80
192.168.100.0/24          10.0.0.3               80
192.168.200.0/24          20.0.0.1               80
# 显示ADVPN域1中的IPv4私网信息。
<Sysname> display vam server private-network advpn-domain 1
# 显示ADVPN域1中私网地址10.0.0.1的私网信息。
<Sysname> display vam server private-network advpn-domain 1 private-address 10.0.0.1
表1-6 display vam server address-map命令显示信息描述表
ADVPN domain name
ADVPN域的名称
Total private network number
IPv4私网总数
Network/Mask
Tunnel接口下配置的ADVPN隧道的私网网络地址/子网掩码长度
Private address
Preference
display vam server statistic命令用来显示VAM Server上ADVPN域的统计信息。
display vam server statistics [ advpn-domain domain-name ]
context-admin
context-operator
advpn-domain domain-name:显示指定ADVPN域的统计信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则显示VAM Server上所有ADVPN域的统计信息。
# 显示VAM Server上所有ADVPN域的统计信息。
<Sysname> display vam server statistics
Total ADVPN number: 3
Total spoke number: 121
Total hub number  : 3
Server status          : Enabled
Holding time           : 0H 1M 47S
Registered spoke number: 98
Registered hub number  : 2
Packets received:
  Initialization request        : 100
  Initialization complete       : 100
  Register request              : 100
  Authentication information    : 100
  Address resolution request    : 203
  Network registration request  : 59
  Update request                : 196
  Logout request                : 0
  Hub information response      : 2
  Data flow information response: 0
  Keepalive                     : 642
  Error notification            : 0
  Unknown                       : 0
Packets sent:
  Initialization response      : 100
  Authentication request       : 100
  Register response            : 100
  Address resolution response  : 203
  Network registration response: 59
  Update response              : 196
  Hub information request      : 2
  Data flow information request: 0
  Logout response              : 0
  Keepalive                    : 642
ADVPN domain name      : 2
Server status          : Disabled
Holding time           : 0H 33M 53S
Registered spoke number: 23
Registered hub number  : 1
Packets received:
  Initialization request        : 24
  Initialization complete       : 24
  Register request              : 24
  Authentication information    : 24
  Address resolution request    : 23
  Network registration request  : 0
  Update request                : 5
  Logout request                : 0
  Keepalive                     : 362
  Unknown                       : 0
Packets sent:
  Initialization response      : 24
  Authentication request       : 24
  Register response            : 24
  Address resolution response  : 23
  Network registration response: 0
  Update response              : 0
  Logout response              : 0
  Keepalive                    : 362
# 显示VAM Server上ADVPN域1的统计信息。
<Sysname> display vam server statistics advpn-domain 1
Packets received:
  Logout request                : 0
  Keepalive                     : 642
  Unknown                       : 0
Packets sent:
  Logout response              : 0
  Keepalive                    : 642
表1-7 display vam server statistics命令显示信息描述表
Total ADVPN number
VAM Server上ADVPN域的数目
Total spoke number
VAM Server上所有ADVPN域中Spoke类型客户端数目
Total hub number
VAM Server上所有ADVPN域中Hub类型客户端数目
ADVPN domain name
ADVPN域的名称
Server status
ADVPN域中VAM Server功能的启用情况:
·     Enabled:表示开启VAM Server功能
·     Disabled:表示关闭VAM Server功能
Holding time
ADVPN域的存活时间,为x小时y分钟z秒(xH yM zS)
ADVPN域中注册的Spoke数目
ADVPN域中注册的Hub数目
Packets received
ADVPN域中接收的报文数目
ADVPN域中接收的初始化请求报文数目
ADVPN域中接收的初始化完成报文数目
Register request
ADVPN域中接收的注册请求报文数目
ADVPN域中接收的认证信息报文数目
ADVPN域中接收的地址解析请求报文数目
ADVPN域中接收的私网注册请求报文数目
Update request
ADVPN域中接收的节点更新请求报文数目
Logout request
ADVPN域中接收的清除请求报文数目
ADVPN域中接收的Hub信息响应报文数目
ADVPN域中接收的数据流信息响应报文数目
Keepalive
ADVPN域中接收的Keepalive报文数目
Error notification
ADVPN域中接收的错误通知报文数目
Unknown
ADVPN域中接收的未知报文或错误报文数目
Packets sent
ADVPN域中发送的报文数目
ADVPN域中发送的初始化响应报文数目
ADVPN域中发送的初始化完成报文数目
ADVPN域中发送的认证请求报文数目
Register response
ADVPN域中发送的注册响应报文数目
ADVPN域中发送的地址解析响应报文数目
ADVPN域中发送的子网注册响应报文数目
Update response
ADVPN域中发送的节点更新响应报文数目
ADVPN域中发送的Hub信息请求报文数目
ADVPN域中发送的数据流信息请求报文数目
Logout response
ADVPN域中发送的清除响应报文数目
Keepalive
ADVPN域中发送的Keepalive报文数目
Error notification
ADVPN域中发送的错误通知报文数目
·     reset vam server statistics
encryption-algorithm命令用来配置VAM协议报文的加密算法。
undo encryption-algorithm命令用来恢复缺省情况。
encryption-algorithm { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | aes-ctr-128 | aes-ctr-192 | aes-ctr-256 | des-cbc | none } *
按照优先级由高到低依次使用AES-CBC-256、AES-CBC-192、AES-CBC-128、AES-CTR-256、AES-CTR-192、AES-CTR-128、3DES-CBC、DES-CBC算法。
ADVPN域视图
context-admin
3des-cbc:表示采用3DES-CBC加密算法。
aes-cbc-128:表示采用AES-CBC加密算法,密钥长度128位。
aes-cbc-192:表示采用AES-CBC加密算法,密钥长度192位。
aes-cbc-256:表示采用AES-CBC加密算法,密钥长度256位。
aes-ctr-128:表示采用AES-CTR加密算法,密钥长度128位。
aes-ctr-192:表示采用AES-CTR加密算法,密钥长度192位。
aes-ctr-256:表示采用AES-CTR加密算法,密钥长度256位。
des-cbc:表示采用DES-CBC加密算法。
none:表示不对VAM协议报文进行加密。
VAM Server与VAM Client固定使用AES-CBC-128加密算法对连接初始化请求和响应报文进行加密;使用协商出来的加密算法对其他VAM协议报文进行加密。
加密算法在配置中的出现顺序决定其使用优先级。配置中越靠前的加密算法,其优先级越高。VAM Server在与VAM Client协商时,从VAM Client支持的加密算法列表中选择配置最靠前的算法作为协商结果。
修改本配置对已经注册的VAM Client没有影响,新注册的VAM Client将采用修改后的加密算法进行协商。
# 配置在ADVPN域1中按照优先级由高到低的顺序使用AES-CBC-128和3DES-CBC加密算法。
[Sysname-vam-server-domain-1] encryption-algorithm aes-cbc-128 3des-cbc
1.1.9  hub-group
hub-group命令用来创建Hub组,并进入Hub组视图。如果指定的Hub组已经存在,则直接进入Hub组视图。
undo hub-group命令用来删除指定Hub组。
hub-group group-name
undo hub-group group-name
不存在Hub组。
ADVPN域视图
context-admin
group-name:Hub组的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。
在大规模组网情况下,将ADVPN域划分为多个Hub组可以方便管理。创建Hub组后,可以按照Spoke的私网地址网段或地址范围,将Spoke划分到不同的Hub组中,并为每个Hub组指定一个或多个Hub。
当VAM Client向VAM Server注册时,VAM Server根据VAM Client的私网地址将VAM Client划分到对应的ADVPN域Hub组中:
(1)     根据Hub组名称字典序依次匹配各Hub组内配置的Hub私网地址。
(2)     如果匹配上,则VAM Client为Hub,并被划分到该Hub组;如果VAM Client不是Hub,再根据Hub组名称字典序依次匹配各Hub组内配置的Spoke私网地址范围。
(3)     如果匹配上,则VAM Client为Spoke,并被划分到该Hub组;否则,VAM Client既不是Hub也不是Spoke,注册失败。
VAM Server只向VAM Client下发其所属的Hub组内的Hub信息。VAM Client只与本Hub组内的Hub建立永久ADVPN隧道。
# 在ADVPN域1内创建Hub组1,并进入Hub组视图。
[Sysname-vam-server-domain-1] hub-group 1
[Sysname-vam-server-domain-1-hub-group-1]
hub ipv6 private-address命令用来添加Hub组内的Hub IPv6私网地址。
undo hub ipv6 private-address命令用来删除Hub组内的Hub IPv6私网地址。
hub ipv6 private-address private-ipv6-address [ public-address { public-ipv4-address | public-ipv6-address } [ advpn-port port-number ] ]
undo hub ipv6 private-address private-ipv6-address
Hub组内未配置Hub IPv6私网地址。
Hub组视图
context-admin
private-ipv6-address:Hub的IPv6私网地址,该地址必须是全球单播地址。
public-address:指定Hub的公网地址。如果未指定本参数,VAM Server使用该Hub注册的公网地址。
public-ip-address:Hub的IPv4公网地址,该地址必须是单播地址。
public-ipv6-address:Hub的IPv6公网地址,该地址必须是全球单播地址。
advpn-port port-number:Hub的ADVPN端口号,取值范围为1025~65535。如果未指定本参数,VAM Server使用该Hub注册的ADVPN端口号。
一般情况下,不需要指定Hub的公网地址和ADVPN端口号。只有当Hub要穿越NAT时,由于Hub注册的公网地址和ADVPN端口号是经过NAT转换前的,需要在NAT网关上为Hub配置一个固定的地址和端口号的转换关系。此时,需要指定Hub的公网地址和ADVPN端口号为NAT网关上配置的转换后的地址和端口号。
每个Hub组内可以配置多个IPv6私网地址不同的Hub。
如果指定IPv6私网地址的Hub已经存在,多次执行本命令,最后一次执行的命令生效。
# 向ADVPN域1的Hub组1中添加Hub,其IPv6私网地址为1000::1:0:0:1,公网地址为2001::1,ADVPN端口号为8000。
[Sysname-vam-server-domain-1-hub-group-1] hub ipv6 private-address 1000::1:0:0:1 public-address 2001::1 advpn-port 8000
hub private-address命令用来添加Hub组内的Hub IPv4私网地址。
undo hub private-address命令用来删除Hub组内的Hub IPv4私网地址。
hub private-address private-ip-address [ public-address { public-ipv4-address | public-ipv6-address } [ advpn-port port-number ] ]
undo hub private-address private-ip-address
Hub组内未配置Hub IPv4私网地址。
Hub组视图
context-admin
private-ip-address:Hub的IPv4私网地址,该地址必须是单播地址。
每个Hub组内可以配置多个IPv4私网地址不同的Hub。
如果指定IPv4私网地址的Hub已经存在,多次执行本命令,最后一次执行的命令生效。
# 向ADVPN域1的Hub组1中添加Hub,其IPv4私网地址为10.1.1.1,公网地址为123.0.0.1,ADVPN端口号为8000。
[Sysname-vam-server-domain-1-hub-group-1] hub private-address 10.1.1.1 public-address 123.0.0.1 advpn-port 8000
1.1.12  keepalive
keepalive命令用来配置VAM Client发送Keepalive报文的时间间隔和重发次数。
undo keepalive命令用来恢复缺省情况。
keepalive interval interval retry retries
undo keepalive
VAM Client发送Keepalive报文的时间间隔为180秒,重发次数为3次。
ADVPN域视图
context-admin
interval interval:VAM Client发送Keepalive报文的时间间隔,取值范围为5~65535,单位为秒。
retry retries:VAM Client发送Keepalive报文的重发次数,取值范围为1~6。
配置的时间间隔和重发次数值由VAM Server在注册响应报文中下发给VAM Client,同一个ADVPN域中所有VAM Client的Keepalive报文参数都是相同的。但是,如果VAM Server改变Keepalive报文参数,则修改后的参数只对新注册的VAM Client生效,已经注册的VAM Client不受影响。
VAM Client和VAM Server之间通过Keepalive报文保持联系。VAM Client按照VAM Server指定的时间间隔向VAM Server发送Keepalive报文,VAM Server收到Keepalive报文后回复响应报文。当Keepalive报文的重发次数达到指定的值仍没有收到VAM Server的响应时,VAM Client认为与VAM Server的连接中断,不再发送Keepalive报文。当VAM Server在时间间隔×重发次数的时间内没有收到VAM Client的Keepalive报文,则认为与VAM Client的连接中断,会删除该VAM Client的信息并将其下线。
如果VAM Server与VAM Client间存在配置了动态NAT的设备,则Keepalive报文的发送时间间隔应小于NAT表项的老化时间,从而保证NAT表项不会老化。
请根据实际组网情况,合理配置VAM Client发送Keepalive报文的时间间隔和重发次数。
# 配置ADVPN域1中VAM Client发送Keepalive报文的时间间隔为30秒,重发次数为5次。
[Sysname-vam-server-domain-1] keepalive interval 30 retry 5
pre-shared-key命令用来配置VAM Server的预共享密钥。
undo pre-shared-key命令用来删除配置的预共享密钥。
pre-shared-key { cipher | simple } string
undo pre-shared-key
未配置VAM Server的预共享密钥。
ADVPN域视图
context-admin
cipher:以密文方式设置预共享密钥。
simple:以明文方式设置预共享密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~31个字符的字符串,密文密钥为1~73个字符的字符串。
预共享密钥是VAM Server用来和VAM Client建立安全通道的公共密钥材料。在连接初始化阶段预共享密钥用来生成验证和加密连接请求、连接响应报文的初始密钥;如果选择对后续的报文进行加密和验证,则预共享密钥还用来生成验证和加密后续报文的连接密钥。
同一个ADVPN域内的VAM Client和VAM Server上配置的预共享密钥必须一致。
# 以明文方式配置ADVPN域1中VAM Server的预共享密钥为123。
[Sysname-vam-server-domain-1] pre-shared-key simple 123
·     pre-shared-key (VAM client view)
retry interval命令用来设置VAM Server重发请求报文的时间间隔。
undo retry interval命令用来恢复缺省情况。
retry interval interval
undo retry interval
VAM Server重发请求报文的时间间隔为5秒。
ADVPN域视图
context-admin
interval:VAM Server重发请求报文的时间间隔,取值范围为3~30,单位为秒。
VAM Server向VAM Client发送请求报文后,如果在指定的时间间隔内没有收到响应报文,VAM Server将重新发送请求报文,直到收到响应报文或者VAM Client Keepalive超时(即VAM Server在Keepalive报文发送时间间隔×重发次数的时间内没有收到VAM Client的Keepalive报文)为止。
# 设置ADVPN域1中VAM Server向VAM Client重发请求报文的时间间隔为20秒。
[Sysname-vam-server-domain-1] retry interval 20
reset vam server address-map命令用来清除注册到VAM Server上的IPv4私网地址和公网地址映射信息。
reset vam server address-map [ advpn-domain domain-name [ private-address private-ip-address ] ]
context-admin
advpn-domain domain-name:清除指定ADVPN域中注册的IPv4私网地址和公网地址映射信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则清除VAM Server上注册的所有IPv4私网地址和公网地址映射信息。
private-address private-ip-address:清除指定IPv4私网地址的映射信息。private-ip-address为VAM Client的IPv4私网地址。如果未指定本参数,则清除指定ADVPN域或所有ADVPN域中的IPv4私网地址和公网地址映射信息。
执行本命令清除注册到VAM Server上的IPv4私网地址和公网地址映射信息时,设备会向注册该IPv4私网地址的VAM Client发送错误通知报文,要求VAM Client下线。
执行本命令除了会清除VAM Server上注册的IPv4私网地址和公网地址映射信息外,还会清除该IPv4私网地址相关的私网信息。
# 清除VAM Server上注册的所有IPv4私网地址和公网地址映射信息。
<Sysname> reset vam server address-map
# 清除ADVPN域1中注册的所有IPv4私网地址和公网地址映射信息。
<Sysname> reset vam server address-map advpn-domain 1
# 清除ADVPN域1中私网地址10.0.0.1的地址映射信息。
<Sysname> reset vam server address-map advpn-domain 1 private-address 10.0.0.1
·     display vam server address-map
reset vam server ipv6 address-map命令用来清除注册到VAM Server上的IPv6私网地址和公网地址映射信息。
reset vam server ipv6 address-map [ advpn-domain domain-name [ private-address private-ipv6-address ] ]
context-admin
advpn-domain domain-name:清除指定ADVPN域中注册的IPv6私网地址和公网地址映射信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则清除VAM Server上注册的所有IPv6私网地址和公网地址映射信息。
private-address private-ipv6-address:清除指定IPv6私网地址的映射信息。private-ipv6-address为VAM Client的IPv6私网地址。如果未指定本参数,则清除指定ADVPN域或所有ADVPN域中的IPv6私网地址和公网地址映射信息。
执行本命令清除注册到VAM Server上的IPv6私网地址和公网地址映射信息时,设备会向注册该IPv6私网地址的VAM Client发送错误通知报文,要求VAM Client下线。
执行本命令除了会清除VAM Server上注册的IPv6私网地址和公网地址映射信息外,还会清除该IPv6私网地址相关的私网信息。
# 清除VAM Server上注册的所有IPv6私网地址和公网地址映射信息。
<Sysname> reset vam server ipv6 address-map
# 清除ADVPN域1中注册的所有IPv6私网地址和公网地址映射信息。
<Sysname> reset vam server ipv6 address-map advpn-domain 1
# 清除ADVPN域1中私网地址1000::1:0:0:1的地址映射信息。
<Sysname> reset vam server ipv6 address-map advpn-domain 1 private-address 1000::1:0:0:1
·     display vam server ipv6 address-map
reset vam server statistics命令用来清除VAM Server上ADVPN域的统计信息。
reset vam server statistics [ advpn-domain domain-name ]
context-admin
advpn-domain domain-name:清除VAM Server上指定ADVPN域的统计信息。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符为A~Z、a~z、0~9和“.”。如果未指定本参数,则清除VAM Server上所有ADVPN域的统计信息。
# 清除名为abc的ADVPN域的统计信息。
<Sysname> reset vam server statistics advpn-domain abc
# 清除所有ADVPN域的统计信息。
·     display vam server statistics
server enable命令用来开启ADVPN域的VAM Server功能。
undo server enable命令用来关闭ADVPN域的VAM Server功能。
server enable
undo server enable
ADVPN域的VAM Server功能处于关闭状态。
ADVPN域视图
context-admin
除了执行本命令外,还可以在系统视图下通过vam server enable命令来开启所有或指定ADVPN域的VAM Server功能。
# 开启ADVPN域1的VAM Server功能。
[Sysname-vam-server-domain-1] server enable
·     vam server enable
shortcut interest命令用来配置跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则。
undo shortcut interest命令用来恢复缺省情况。
shortcut interest { acl { acl-number | name acl-name } | all }
未配置跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则,不允许跨Hub组建立IPv4 Spoke-Spoke直连隧道。
Hub组视图
context-admin
acl:表示只允许匹配指定IPv4 ACL的Spoke之间建立跨Hub组的IPv4 Spoke-Spoke直连隧道。
acl-number:IPv4 ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:表示IPv4基本ACL。
·     3000~3999:表示IPv4高级ACL。
name acl-name:指定IPv4 ACL的名称。acl-name为ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
all:表示所有跨Hub组的Spoke之间均可建立IPv4 Spoke-Spoke直连隧道。
如果配置了跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则,则在Hub上线后,VAM Server将指定的规则下发到Hub。
·     如果规则指定为all,则Hub在转发任意跨Hub组的IPv4 Spoke-Spoke私网数据报文的同时,会向相应Spoke发送重定向报文。
·     如果规则指定为匹配ACL,则Hub在转发跨Hub组的IPv4 Spoke-Spoke私网数据报文的同时,会将报文与指定的ACL进行匹配。如果匹配成功,Hub会向相应的Spoke发送重定向报文;否则,不会发送重定向报文。
Spoke收到重定向报文后,将被重定向的数据报文的目的地址发送给VAM Server,向VAM Server查询连接该目的地址所在私网网段的Spoke节点的信息,并与该Spoke建立直连隧道。
跨Hub组Spoke-Spoke直连隧道建立前,数据报文仍由Hub进行转发。直连隧道建立后,数据报文将直接发送到直连路由下一跳所对应的Spoke,而不再经过Hub中转。
指定IPv4 ACL时,需要注意的是:
·     如果指定的ACL不存在,则配置不生效。任何私网数据报文都不会触发Hub向Spoke发送重定向报文。
·     如果指定的是IPv4基本ACL,本命令仅支持匹配源地址信息的规则。
·     如果指定的是IPv4高级ACL,仅支持匹配协议类型、源地址、目的地址、源端口和目的端口信息的规则,并且不支持排除某个源/目的端口号的规则。
·     如果本命令指定的ACL中包含不支持的规则,则该条ACL规则将不生效。
# 配置如果Spoke之间的报文匹配ACL 3000,则允许建立跨Hub组的IPv4 Spoke-Spoke直连隧道。
[Sysname-vam-server-domain-1-hub-group-1] shortcut interest acl 3000
shortcut ipv6 interest命令用来配置跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则。
undo shortcut ipv6 interest命令用来恢复缺省情况。
shortcut ipv6 interest { acl { ipv6-acl-number | name ipv6-acl-name } | all }
未配置跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则,不允许跨Hub组建立IPv6 Spoke-Spoke直连隧道。
Hub组视图
context-admin
acl:表示只允许匹配指定IPv6 ACL的Spoke之间建立跨Hub组的IPv6 Spoke-Spoke直连隧道。
ipv6-acl-number:IPv6 ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:表示IPv6基本ACL。
·     3000~3999:表示IPv6高级ACL。
name ipv6-acl-name:指定IPv6 ACL的名称。ipv6-acl-name为ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
all:表示所有跨Hub组的Spoke之间均可建立IPv6 Spoke-Spoke直连隧道。
配置了跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则,在Hub上线后,VAM Server通过数据流信息报文将指定的规则下发到Hub。
·     如果规则指定为all,则Hub在转发任意跨Hub组的IPv6 Spoke-Spoke私网数据报文的同时,会向相应Spoke发送重定向报文。
·     如果规则指定为匹配ACL,则Hub在转发跨Hub组的IPv6 Spoke-Spoke私网数据报文的同时,会将报文与指定的ACL进行匹配。如果匹配成功,Hub会向相应的Spoke发送重定向报文;否则,不会发送重定向报文。
指定IPv6 ACL时,需要注意的是:
·     如果指定的是IPv6基本ACL,本命令仅支持匹配源地址信息的规则。
·     如果指定的是IPv6高级ACL,仅支持匹配协议类型、源地址、目的地址、源端口和目的端口信息的规则,并且不支持排除某个源/目的端口号的规则。
# 配置如果Spoke之间的报文匹配IPv6 ACL 3000,则允许建立跨Hub组的IPv6 Spoke-Spoke直连隧道。
[Sysname-vam-server-domain-1-hub-group-1] shortcut ipv6 interest acl 3000
spoke ipv6 private-address命令用来配置Hub组内Spoke的IPv6私网地址范围。
undo spoke ipv6 private-address命令用来删除Hub组内Spoke的IPv6私网地址范围。
spoke ipv6 private-address { network prefix prefix-length | range start-ipv6-address end-ipv6-address }
undo spoke ipv6 private-address { network prefix prefix-length | range start-ipv6-address end-ipv6-address }
未配置Spoke的IPv6私网地址范围。
Hub组视图
context-admin
network prefix prefix-length:指定子网网段形式的IPv6私网地址范围。prefix为IPv6地址前缀,prefix-length为IPv6地址前缀长度,取值范围为0~128。
range start-ipv6-address end-ipv6-address:指定地址段形式的IPv6私网地址范围。start-ipv6-address为地址段的起始IPv6地址,end-ipv6-address为地址段的结束IPv6地址。
Hub组内Spoke的IPv6私网地址范围可以指定为地址段形式或子网网段形式。以子网网段形式指定的IPv6私网地址范围,系统会自动将其转换为地址段形式。
每个Hub组可以配置多个Spoke的IPv6私网地址范围,将按照地址从低到高的顺序排列。
删除的私网地址范围必须和配置时的一致。
# 指定Hub组1内Spoke的IPv6私网地址范围为1000::/64。
[Sysname-vam-server-domain-1-hub-group-1] spoke ipv6 private-address network 1000:: 64
spoke private-address命令用来配置Hub组内Spoke的IPv4私网地址范围。
undo spoke private-address命令用来删除Hub组内Spoke的IPv4私网地址范围。
spoke private-address { network ip-address { mask-length | mask } | range start-address end-address }
undo spoke private-address { network ip-address { mask-length | mask } | range start-address end-address }
未配置Spoke的IPv4私网地址范围。
Hub组视图
context-admin
network ip-address { mask-length | mask }:指定子网网段形式的IPv4私网地址范围。ip-address为子网网段IPv4地址;mask-length为子网掩码长度,取值范围为0~32;mask为子网掩码。
range start-address end-address:指定地址段形式的IPv4私网地址范围。start-address为地址段的起始IPv4地址,end-address为地址段的结束IPv4地址。
Hub组内Spoke的IPv4私网地址范围可以指定为地址段形式或子网网段形式。以子网网段形式指定的IPv4私网地址范围,系统会自动将其转换为地址段形式。
每个Hub组可以配置多个Spoke的IPv4私网地址范围,将按照地址从低到高的顺序排列。
删除的私网地址范围必须和配置时的一致。
# 指定Hub组1内Spoke的IPv4私网地址范围为1.1.1.0/24。
[Sysname-vam-server-domain-1-hub-group-1] spoke private-address network 1.1.1.0 255.255.255.0
vam server advpn-domain命令用来创建ADVPN域,并进入ADVPN域视图。如果指定的ADVPN域已经存在,则直接进入ADVPN域视图。
undo vam server advpn-domain命令用来删除指定的ADVPN域。
vam server advpn-domain domain-name [ id domain-id ]
undo vam server advpn-domain domain-name
不存在ADVPN域。
context-admin
domain-name:ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。
id domain-id:指定ADVPN域的ID。domain-id为ADVPN域的ID,取值范围为1~65535。
创建ADVPN域时必须指定ADVPN域的ID。若要进入已存在的ADVPN域的视图,可以不指定其域ID。
不同的ADVPN域必须使用不同的域ID。
# 创建ADVPN域1,ID为1,并进入其视图。
[Sysname] vam server advpn-domain 1 id 1
vam server enable命令用来开启ADVPN域的VAM Server功能。
undo vam server enable命令用来关闭所有或指定ADVPN域的VAM Server功能。
vam server enable [ advpn-domain domain-name ]
undo vam server enable [ advpn-domain domain-name ]
context-admin
advpn-domain domain-name:开启指定ADVPN域的VAM Server功能。domain-name为ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A~Z、a~z、0~9和“.”。如果未指定本参数,则开启所有ADVPN域的VAM Server功能。
除了执行本命令外,还可以在ADVPN域视图下通过server enable命令来开启相应ADVPN域的VAM Server功能。
# 开启所有ADVPN域的VAM Server功能。
[Sysname] vam server enable
[Sysname] vam server enable advpn-domain 1
·     server enable
vam server listen-port命令用来配置VAM Server的监听端口号。
undo vam server listen-port命令用来恢复缺省情况。
vam server listen-port port-number
VAM Server的监听端口号为18000。
context-admin
port-number:VAM Server监听的端口号,取值范围为1025~65535。
VAM Server的监听端口号与VAM Client上指定的VAM Server的端口号必须一致。
# 配置VAM Server的监听端口号为10000。
[Sysname] vam server listen-port 10000
·     server primary
·     server secondary
1.2  VAM Client配置命令
1.2.1  advpn-domain
advpn-domain命令用来配置VAM Client所属的ADVPN域。
undo advpn-domain命令用来删除VAM Client所属的ADVPN域。
undo advpn-domain
VAM Client不属于任何ADVPN域。
VAM Client视图
context-admin
domain-name:ADVPN域的名称,为1~31个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。
多个VAM Client可以属于同一个ADVPN域。
# 配置VAM Client abc属于ADVPN域100。
[Sysname] vam client name abc
[Sysname-vam-client-abc] advpn-domain 100
1.2.2  client enable
client enable命令用来开启VAM Client功能。
undo client enable命令用来关闭VAM Client功能。
client enable
undo client enable
VAM Client功能处于关闭状态。
VAM Client视图
context-admin
还可以在系统视图下通过vam client enable命令来开启所有或指定VAM Client的VAM Client功能。
# 开启VAM Client abc的VAM Client功能。
[Sysname-vam-client-abc] client enable
·     vam client enable
display vam client fsm命令用来显示VAM Client的状态机信息。
display vam client fsm [ name client-name ]
context-admin
context-operator
name client-name:显示指定VAM Client的状态机信息。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,则显示所有VAM Client的状态机信息。
一些未配置的命令参数,或者未能动态获取的信息将不会出现在本命令的显示信息中。
# 显示所有VAM Client的状态机信息。
<Sysname> display vam client fsm
Client name      : abc
Status           : Enabled
  Primary server: abc.com (28.1.1.23)
    Private address: 10.0.0.12
    Interface      : Tunnel1
      Current state           : Online (active)
      Client type             : Hub
      Holding time            : 9H 20M 30S
      Encryption algorithm    : AES-CBC-128
      Authentication algorithm: SHA1
      Keepalive               : 30 seconds, 3 times
      Number of hubs          : 1
    Private address: 1000::22
    Interface      : Tunnel2
      Client type             : Spoke
      Number of hubs          : 1
  Secondary server: 2811::24
    Interface      : Tunnel1
      Current state           : Offline
      Client type             : Unknown
      Holding time            : 0H 0M 0S
      Keepalive               : 0 seconds, 0 times
      Number of hubs          : 0
    Interface      : Tunnel2
      Number of hubs          : 0
Client name      : hub
Status           : Enabled
  Primary server: 202.159.36.24
    Interface      : Tunnel20
      Client type             : Hub
      Holding time            : 0H 0M 47S
      Number of hubs          : 1
Client name      : spoke
Status           : Disabled
ADVPN domain name:
表1-8 display vam client fsm命令显示信息描述表
Client name
VAM Client的名称
Status
VAM Client的状态,包括:
·     Enabled
·     Disabled
ADVPN domain name
该VAM Client所在的ADVPN域名
Primary server
主VAM Server的公网地址
Private address
VAM Client注册的私网地址
与该VAM Client绑定的ADVPN隧道接口
Current state
VAM Client当前状态,包括:
·     Offline:离线状态
·     Init:连接初始化阶段
·     Reg:注册阶段
·     Online:在线状态
·     Dumb:静默状态
Client type
VAM Client类型,包括:
·     Hub
·     Spoke
·     Unknown
Holding time
VAM Client维持当前状态的时间,为x小时y分z秒(xH yM zS)
协商使用的加密算法
协商使用的认证算法
Keepalive
VAM Server下发的Keepalive时间间隔(单位为秒)和重发次数
Number of hubs
VAM Server下发的Hub数量
Secondary server
备VAM Server的公网地址
·     reset vam client fsm
display vam client shortcut interest命令用来显示VAM Client收到的VAM Server下发的跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则。
display vam client shortcut interest [ name client-name ]
context-admin
context-operator
name client-name:显示指定VAM Client收到的规则。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,则显示所有VAM Client收到的规则。
VAM Server仅给Hub下发跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则。如果指定的VAM Client为Spoke,则下发的规则数为0。
# 显示所有VAM Client收到的跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则。
<Sysname> display vam client shortcut interest
Client name      : abc
Client type      : Spoke
ACL rules        : 0
Client name      : hub
Client type      : Hub
ACL rules        : 2
  Rule 1: Permit
    Protocol   : 6 (TCP)
    Source     : Address 0.0.0.0-255.255.255.255, port 0-65535
    Destination: Address 192.168.114.100-192.168.114.200, port 10000-20000
  Rule 2: Deny
    Protocol   : 0 (IP)
    Destination: Address 0.0.0.0-255.255.255.255, port 0-65535
Client name      : spoke
ACL rules        : 0
# 显示VAM Client abc收到的跨Hub组建立IPv4 Spoke-Spoke直连隧道的规则。
<Sysname> display vam client shortcut interest name abc
Client name      : abc
Client type      : Spoke
ACL rules        : 0
表1-9 display vam client shortcut interest命令显示信息描述表
Client name
VAM Client的名称
ADVPN domain name
Client type
VAM Client类型,包括:
·     Hub
·     Spoke
·     Unknown
ACL rules
VAM Client收到的匹配规则计数
Rule n: Operation
ACL规则的编号(n)和动作(Operation)。Operation包括:
·     Permit:允许建立跨Hub组IPv4 Spoke-Spoke直连隧道
·     Deny:不允许建立跨Hub组IPv4 Spoke-Spoke直连隧道
·     Discard:丢弃该报文
Protocol
匹配指定的协议类型
Source
匹配指定范围的源IP地址和源端口号
Destination
匹配指定范围的目的IP地址和目的端口号
display vam client shortcut ipv6 interest命令用来显示VAM Client收到VAM Server下发的跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则。
display vam client shortcut ipv6 interest [ name client-name ]
context-admin
context-operator
VAM Server仅给Hub下发跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则。如果指定的VAM Client为Spoke,则下发的规则数为0。
# 显示所有VAM Client收到的跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则。
<Sysname> display vam client shortcut ipv6 interest
Client name      : abc
Client type      : Spoke
ACL rules         : 0
Client name      : hub
Client type      : Hub
ACL rules        : 2
  Rule 1: Permit
    Protocol                 : TCP
    Start source address     : 0::0
    End source address       : FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF
    Start source port        : 0
    End source port          : 65535
    Start destination address: 2000::0
    End destination address  : 2000:1::0
    Start destination port   : 0
    End destination port     : 65535
  Rule 2: Deny
    Protocol                 : All
    Start destination address: 0::0
    End destination address  : FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF
Client name      : spoke
ADVPN domain name:
ACL rules        : 0
# 显示VAM Client abc收到的跨Hub组建立IPv6 Spoke-Spoke直连隧道的规则。
<Sysname> display vam client shortcut ipv6 interest name abc
Client name      : spoke
ADVPN domain name:
ACL rules        : 0
表1-10 display vam client shortcut ipv6 interest命令显示信息描述表
Client name
VAM Client的名称
ADVPN domain name
Client type
VAM Client类型,包括:
·     Hub
·     Spoke
·     Unknown
ACL rules
VAM Client收到的匹配规则计数
Rule n: operation
·     Permit:允许建立跨Hub组IPv6 Spoke-Spoke直连隧道
·     Deny:不允许建立跨Hub组IPv6 Spoke-Spoke直连隧道
·     Discard:丢弃该报文
Protocol
匹配指定的协议类型
匹配的源IPv6地址范围的起始地址
End source address
匹配的源IPv6地址范围的结束地址
Start source port
匹配的源端口范围的起始端口号
End source port
匹配的源端口范围的结束端口号
匹配的目的IPv6地址范围的起始地址
匹配的目的IPv6地址范围的结束地址
匹配的目的端口范围的起始端口号
匹配的目的端口范围的结束端口号
display vam client statistics命令用来显示VAM Client的统计信息。
display vam client statistics [ name client-name ]
context-admin
context-operator
name client-name:显示指定VAM Client的统计信息。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,则显示所有VAM Client的统计信息。
# 显示所有VAM Client的统计信息。
<Sysname> display vam client statistics
Client name: abc
 Status     : Enabled
    Packets sent:
      Address resolution request    : 9
      Update request                : 0
      Logout request                : 0
      Hub information response      : 0
      Keepalive                     : 35
    Packets received:
      Address resolution response  : 9
      Update response              : 0
      Hub information request      : 0
      Logout response              : 0
      Keepalive                    : 35
      Unknown                      : 0
  Secondary server: 28.1.1.24
    Packets sent:
      Initialization request        : 15
      Initialization complete       : 0
      Register request              : 0
      Authentication information    : 0
      Address resolution request    : 0
      Update request                : 0
      Logout request                : 0
      Keepalive                     : 0
    Packets received:
      Initialization response      : 0
      Register response            : 0
      Authentication request       : 0
      Address resolution response  : 0
      Update response              : 0
      Logout response              : 0
      Keepalive                    : 0
      Unknown                      : 0
Client name: hub
Status     : Disabled
Client name: spoke
Status     : Enabled
  Primary server: test.com
    Packets sent:
      Initialization request        : 3
      Initialization complete       : 3
      Register request              : 3
      Authentication information    : 3
      Update request                : 0
      Logout request                : 0
      Keepalive                     : 124
    Packets received:
      Initialization response      : 3
      Authentication request       : 3
      Register response            : 3
      Update response              : 0
      Logout response              : 0
      Keepalive                    : 114
      Unknown                      : 0
# 显示VAM Client abc的统计信息。
<Sysname> display vam client statistics name abc
Client name: abc
Status     : Enabled
    Packets sent:
      Update request                : 0
      Logout request                : 0
      Keepalive                     : 35
    Packets received:
      Update response              : 0
      Logout response              : 0
      Keepalive                    : 35
      Unknown                      : 0
    Packets sent:
      Update request                : 0
      Logout request                : 0
      Keepalive                     : 0
    Packets received:
      Update response              : 0
      Logout response              : 0
      Keepalive                    : 0
      Unknown                      : 0
表1-11 display vam client statistic命令显示信息描述表
Client name
VAM Client的名称
Status
VAM Client的状态,包括:
·     Enabled
·     Disabled
Primary server
主VAM Server的公网地址或域名
Secondary server
备VAM Server的公网地址或域名
Packets sent
向VAM Server发送的报文数目
向VAM Server发送的初始化请求报文数目
向VAM Server发送的初始化完成报文数目
Register request
向VAM Server发送的注册请求报文数目
向VAM Server发送的认证信息报文数目
向VAM Server发送的地址解析请求报文数目
向VAM Server发送的私网注册请求报文数目
Update request
向VAM Server发送的节点更新请求报文数目
Logout request
向VAM Server发送的清除请求报文数目
向VAM Server发送的Hub信息响应报文数目
向VAM Server发送的数据流信息响应报文数目
Keepalive
向VAM Server发送的Keepalive报文数目
Error notification
向VAM Server发送的错误通知报文数目
Unknown
向VAM Server发送的未知报文或错误报文数目
Packets received
从VAM Server接收的报文数目
从VAM Server接收的初始化响应报文数目
从VAM Server接收的初始化完成报文数目
从VAM Server接收的认证请求报文数目
Register response
从VAM Server接收的注册响应报文数目
从VAM Server接收的地址解析响应报文数目
从VAM Server接收的私网注册响应报文数目
Update response
从VAM Server接收的节点更新响应报文数目
从VAM Server接收的Hub信息请求报文数目
从VAM Server接收的数据流信息请求报文数目
Logout response
从VAM Server接收的清除响应报文数目
Keepalive
从VAM Server接收的Keepalive报文数目
Error notification
从VAM Server接收的错误通知报文数目
·     reset vam client statistics
1.2.7  dumb-time
dumb-time命令用来配置VAM Client连接超时的静默时间。
undo dumb-time命令用来恢复缺省情况。
dumb-time time-interval
undo dumb-time
VAM Client连接超时的静默时间为120秒。
VAM Client视图
context-admin
time-interval:VAM Client连接超时的静默时间,取值范围为10~600,单位为秒。
VAM Client在与VAM Server连接超时后,会进入静默状态,此时VAM Client不处理任何报文。当静默时间到达后,VAM Client将重新上线。
# 配置VAM Client的静默时间为100秒。
[Sysname-vam-client-abc] dumb-time 100
pre-shared-key命令用来配置VAM Client的预共享密钥。
undo pre-shared-key命令用来删除VAM Client的预共享密钥。
undo pre-shared-key
未配置VAM Client的预共享密钥。
VAM Client视图
context-admin
cipher cipher-string:以密文方式设置预共享密钥。
simple simple-string:以明文方式设置预共享密钥,该密钥将以密文形式存储。
# 以明文方式配置VAM Client的预共享密钥为123。
[Sysname-vam-client-abc] pre-shared-key simple 123
·     pre-shared-key (ADVPN domain view)
·     vam client name
reset vam client fsm命令用来重置VAM Client的状态机。
reset vam client fsm [ name client-name ]
name client-name:重置指定VAM Client的状态机。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写。只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,则重置所有VAM Client的状态机。
执行本命令重置VAM Client的状态机后,VAM Client会立刻尝试重新上线。
# 重置VAM Client abc的状态机。
<Sysname> reset vam client fsm name abc
# 重置所有VAM Client的状态机。
·     display vam client fsm
reset vam client ipv6 fsm命令用来重置IPv6 VAM Client的状态机。
reset vam client ipv6 fsm [ name client-name ]
name client-name:重置指定IPv6 VAM Client的状态机。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写。只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,则重置所有IPv6 VAM Client的状态机。
执行本命令重置IPv6 VAM Client的状态机后,IPv6 VAM Client会立刻尝试重新上线。
# 重置IPv6 VAM Client abc的状态机。
<Sysname> reset vam client ipv6 fsm name abc
# 重置所有IPv6 VAM Client的状态机。
reset vam client statistic命令用来清除VAM Client的统计信息。
reset vam client statistics [ name client-name ]
context-admin
name client-name:清除指定VAM Client的统计信息。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,则清除所有VAM Client的统计信息。
# 清除VAM Client abc的统计信息。
<Sysname> reset vam client statistics name abc
# 清除所有VAM Client的统计信息。
·     display vam client statistics
1.2.12  retry
retry命令用来设置VAM Client重发请求报文的时间间隔和重发次数。
undo retry命令用来恢复缺省情况。
retry interval interval count retries
undo retry
请求报文的重发时间间隔为5秒,重发次数为3次。
VAM Client视图
context-admin
interval interval:请求报文的重发时间间隔,取值范围为3~30,单位为秒。
count retries:请求报文的重发次数,取值范围为1~6。
VAM Client向VAM Server发送请求报文后,如果在指定的时间间隔内没有收到响应报文,VAM Client将重新发送请求报文。如果重新发送请求报文的次数超过指定的重发次数,则VAM Client认为VAM Server不可达。
私网注册请求报文和节点信息更新请求报文不受重发次数的限制,将会按照指定的时间间隔一直发送,直至VAM Client下线。
# 设置VAM Client重发请求报文的时间间隔为20秒,重发次数为4次。
[Sysname-vam-client-abc] retry interval 20 count 4
server primary命令用来配置主VAM Server的地址。
undo server primary命令用来恢复缺省情况。
server primary { ip-address ipv4-address | ipv6-address ipv6-address | name host-name } [ port port-number ]
undo server primary
未配置主VAM Server的地址。
VAM Client视图
context-admin
ip-address ipv4-address:主VAM Server的公网IPv4地址,该地址必须是单播地址。
ipv6-address ipv6-address:主VAM Server的公网IPv6地址,该地址必须是全球单播地址。
name host-name:主VAM Server的域名,由以“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符,不区分大小写,字符串中可以包含字母、数字、“-”及“_”。
port port-number:主VAM Server的端口号,取值范围为1025~65535,缺省值为18000。
VAM Client上指定的VAM Server的端口号,则必须和VAM Server上通过vam server listen-port命令配置的监听端口号一致。
如果主VAM Server和备VAM Server的地址相同(配置了相同的地址或通过域名解析到相同的地址),则只有主VAM Server有效。
# 指定主VAM Server的域名为abc.com,端口号为2000。
[Sysname-vam-client-abc] server primary name abc.com port 2000
# 指定主VAM Server的公网IP地址为1.1.1.1,端口号为2000。
[Sysname-vam-client-abc] server primary ip-address 1.1.1.1 port 2000
# 指定主VAM Server的公网IPv6地址为1001::1,端口号为2000。
[Sysname-vam-client-abc] server primary ipv6-address 1001::1 port 2000
·     server secondary
server secondary命令用来配置备VAM Server的地址。
undo server secondary命令用来恢复缺省情况。
server secondary { ip-address ipv4-address | ipv6-address ipv6-address | name host-name } [ port port-number ]
未配置备VAM Server的地址。
VAM Client视图
context-admin
ip-address ipv4-address:备VAM Server的公网IPv4地址,该地址必须是单播地址。
ipv6-address ipv6-address:备VAM Server的公网IPv6地址,该地址必须是全球单播地址。
name host-name:备VAM Server的域名,由以“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符,不区分大小写,字符串中可以包含字母、数字、“-”及“_”。
port port-number:备VAM Server的端口号,取值范围为1025~65535,缺省值为18000。
# 指定备VAM Server的域名为abc.com,端口号为2000。
[Sysname-vam-client-abc] server secondary name abc.com port 2000
# 指定备VAM Server的公网IP地址为1.1.1.2,端口号为3000。
[Sysname-vam-client-abc] server secondary ip-address 1.1.1.2 port 3000
# 指定备VAM Server的公网IPv6地址为1001::2,端口号为3000。
[Sysname-vam-client-abc] server secondary ipv6-address 1001::2 port 3000
·     server primary
1.2.15  user
user命令用来配置认证用户名和密码。
undo user命令用来恢复缺省情况。
user username password { cipher | simple } string
undo user
未配置认证用户名和密码。
VAM Client视图
context-admin
username:认证用户名,为1~253个字符的字符串,区分大小写,不能包括“/”、“\”、“:”、“*”、“?”、“<”、“>”、“””、“|”以及“@”字符。
password:设置用户密码。
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~63个字符的字符串,密文密钥为1~117个字符的字符串。
一个VAM Client下只允许配置一个认证用户。
# 设置VAM Client abc的认证用户名为user,以明文方式设置用户密码为user。
[Sysname-vam-client-abc] user user password simple user
vam client enable命令用来开启VAM Client的VAM Client功能。
undo vam client enable命令用来关闭所有或指定VAM Client的VAM Client功能。
vam client enable [ name client-name ]
undo vam client enable [ name client-name ]
VAM Client的VAM Client功能处于关闭状态。
context-admin
name client-name:开启指定VAM Client的VAM Client功能。client-name为VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。如果未指定本参数,开启所有VAM Client的VAM Client功能。
还可以在VAM Client视图下通过client enable命令来开启相应VAM Client的VAM Client功能。
# 开启所有VAM Client的VAM Client功能。
[Sysname] vam client enable
[Sysname] vam client enable name abc
·     client enable
vam client name命令用来创建VAM Client,并进入VAM Client视图。如果指定的VAM Client已经存在,则直接进入VAM Client视图。
undo vam client name命令用来删除指定的VAM Client。
vam client name client-name
undo vam client name client-name
不存在VAM Client。
context-admin
client-name:VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。
# 创建一个名为abc的VAM Client,并进入VAM Client视图。
1.3  ADVPN隧道配置命令
1.3.1  advpn group
advpn group命令用来配置ADVPN隧道的组名。
undo advpn group命令用来恢复缺省情况。
advpn group group-name
undo advpn group
未配置ADVPN隧道的组名。
Tunnel接口视图
context-admin
group-name:ADVPN隧道的组名,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。
在Spoke的隧道接口下配置ADVPN隧道组名。Spoke向Hub发送建立Hub-Spoke类型的隧道请求时,把配置的组名发送给Hub,Hub将根据组名匹配QoS策略,如果匹配成功则应用组名对应的QoS策略,如果匹配失败则不应用QoS策略。
在隧道已经建立的情况下,修改ADVPN隧道的组名,Spoke会向Hub发送配置更新报文,Hub根据新的组名进行QoS策略匹配。
不建议在隧道接口下既配置ADVPN隧道组名又应用QoS策略。
# 配置ADVPN隧道的组名为aaa。
[Sysname] interface tunnel1 mode advpn gre
[Sysname-Tunnel1] advpn group aaa
advpn ipv6 network命令用来添加ADVPN隧道的IPv6私网信息。
undo advpn ipv6 network命令用来删除ADVPN隧道的IPv6私网信息。
advpn ipv6 network prefix prefix-length [ preference preference-value ]
undo advpn ipv6 network prefix prefix-length
未配置ADVPN隧道的IPv6私网信息。
Tunnel接口视图
context-admin
prefix prefix-length:ADVPN隧道的私网IPv6地址前缀及前缀长度。prefix-length取值范围为0~128。
preference preference-value:ADVPN隧道私网路由优先级,取值范围为1~255,缺省值为8。
本命令只有在IPv6 ADVPN类型的Tunnel接口下才能配置。
VAM Client向VAM Server注册ADVPN隧道的私网信息。其他VAM Client向VAM Server解析私网报文目的地址时,如果解析的地址属于注册私网,则VAM Server将注册VAM Client的节点信息返回给查询方。
只有在Tunnel接口上配置了IPv6地址,并通过vam ipv6 client命令指定了接口引用的VAM Client后,本命令才会生效。
每个Tunnel接口下可以配置多个IPv6私网信息。
私网路由的优先级建议高于其他动态路由协议,且低于静态路由。优先级数值越大,优先级越低。
# 向接口Tunnel1增加IPv6私网信息1001::/64,私网路由优先级为20。
[Sysname] interface tunnel 1 mode advpn udp ipv6
[Sysname-Tunnel1] advpn ipv6 network 1001:: 64 preference 20
·     vam ipv6 client
advpn logging enable命令用来开启ADVPN日志功能。
undo advpn logging enable命令用来关闭ADVPN日志功能。
ADVPN日志功能处于关闭。
context-admin
设备生成的ADVPN日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启ADVPN日志功能。
[Sysname] advpn logging enable
advpn map group命令用来配置ADVPN隧道组名与QoS策略的对应关系。
undo advpn map group命令用来删除ADVPN隧道组名与QoS策略的对应关系。
advpn map group group-name qos-policy policy-name outbound
undo advpn map group group-name
未配置ADVPN隧道组名与QoS策略的对应关系。
Tunnel接口视图
context-admin
qos-policy policy-name:QoS策略名称,为1~31个字符的字符串,区分大小写。
outbound:对发送的报文应用QoS策略。
本命令在Hub上配置,Hub在ADVPN隧道接口上收到Spoke的隧道建立请求后,会解析其携带的ADVPN隧道组名,并根据组名查找配置的QoS策略对应关系。如果查找成功,则将会在该隧道接口上按照ADVPN隧道组名对应的QoS策略进行数据转发。
每个Tunnel接口下可以配置多条ADVPN隧道组名与QoS策略的对应关系。
多个ADVPN隧道组名可以对应同一个QoS策略,但一个ADVPN隧道组名只能对应一个QoS策略。
不建议在隧道接口下既配置ADVPN隧道组名与QoS策略的对应关系、又应用QoS策略。
# 在隧道口Tunnel1下配置组名aaa和QoS策略bbb的对应关系。
[Sysname] interface Tunnel1 mode advpn gre
[Sysname-Tunnel1] advpn map group aaa qos-policy bbb outbound
1.3.5  advpn network
advpn network命令用来添加ADVPN隧道的IPv4私网信息。
undo advpn network命令用来删除ADVPN隧道的IPv4私网信息。
advpn network ip-address { mask-length | mask } [ preference preference-value ]
undo advpn network ip-address { mask-length | mask }
未配置ADVPN隧道的IPv4私网信息。
Tunnel接口视图
context-admin
ip-address:ADVPN隧道的IPv4私网网段地址。
mask-length:ADVPN隧道的私网网段掩码长度,取值范围为0~32。
mask:ADVPN隧道的私网网段掩码。
preference preference-value:ADVPN隧道的私网路由优先级,取值范围为1~255,缺省值为8。
本命令只有在IPv4 ADVPN类型的Tunnel接口下才能配置。
只有在Tunnel接口上配置了IPv4地址,并通过vam client命令指定了接口引用的VAM Client后,本命令才会生效。
每个Tunnel接口下可以配置多个IPv4私网信息。
# 向接口Tunnel1增加IPv4私网信息10.0.5.0 255.255.255.0,私网路由优先级为20。
[Sysname-Tunnel1] advpn network 10.0.5.0 255.255.255.0 preference 20
·     vam client
advpn session dumb-time命令用来配置ADVPN隧道建立失败的静默时间。
undo advpn session dumb-time命令用来恢复缺省情况。
advpn session dumb-time time-interval
ADVPN隧道建立失败的静默时间为120秒。
Tunnel接口视图
context-admin
time-interval:ADVPN隧道建立失败的静默时间,取值范围为10~600,单位为秒。
本命令只有在ADVPN类型的Tunnel接口下才能配置。
修改此参数对已经建立的ADPVN隧道没有影响,之后建立的ADPVN隧道会使用修改后的参数值。
# 配置ADVPN隧道建立失败的静默时间为100秒。
[Sysname-Tunnel1] advpn session dumb-time 100
advpn session idle-time命令用来配置Spoke-Spoke类型ADVPN隧道的空闲超时时间。
undo advpn session idle-time命令用来恢复缺省情况。
advpn session idle-time time-interval
Spoke-Spoke类型ADVPN隧道的空闲超时时间为600秒。
Tunnel接口视图
context-admin
time-interval:Spoke-Spoke类型ADVPN隧道的空闲超时时间,取值范围为60~65535,单位为秒。
如果修改此参数,已经建立的Spoke-Spoke类型ADVPN隧道会使用修改后的参数值重新开始计时。
如果在空闲超时时间内,Spoke-Spoke类型ADVPN隧道上没有数据传输,则断开该隧道。
# 配置Spoke-Spoke类型ADVPN隧道的空闲超时时间为800秒。
[Sysname-tunnel1] advpn session idle-time 800
advpn source-port命令用来配置ADVPN报文的源UDP端口号。
undo advpn source-port命令用来恢复缺省情况。
advpn source-port port-number
undo advpn sourc-port
ADVPN报文的源UDP端口号为18001。
Tunnel接口视图
context-admin
port-number:端口号,取值范围为1025~65535。
本命令只有在UDP封装模式的ADVPN类型的Tunnel接口下才能配置。
如果Tunnel接口下通过vam client命令配置了compatible参数,则该Tunnel接口配置的源端口号不能和其他Tunnel接口的源端口号相同。
# 配置ADVPN报文的源UDP端口号为6000。
[Sysname-Tunnel1] advpn source-port 6000
·     vam client
display advpn ipv6 session命令用来显示IPv6 ADVPN隧道的信息。
display advpn ipv6 session [ interface tunnel number [ private-address private-ipv6-address ] ] [ verbose ]
context-admin
context-operator
interface tunnel number:显示指定IPv6 ADVPN类型Tunnel接口上的IPv6 ADVPN隧道信息。number为Tunnel接口的编号。如果未指定本参数,则显示所有IPv6 ADVPN隧道的信息。
private-address private-ipv6-address:显示指定对端IPv6私网地址的IPv6 ADVPN隧道信息。private-ipv6-address为隧道对端的IPv6私网地址。如果未指定本参数,则显示指定或所有IPv6 ADVPN隧道的信息。
verbose:显示IPv6 ADVPN隧道的详细信息。如果未指定本参数,则显示IPv6 ADVPN隧道的摘要信息。
# 显示所有IPv6 ADVPN隧道的摘要信息。
<Sysname> display advpn ipv6 session
Interface         : Tunnel1
Number of sessions: 2
Private address       Public address        Port  Type  State      Holding time
1001::3               2000::180:136         1139  H-S   Success    5H 38M 8S
1001::4               2000::180:137         3546  H-S   Dumb       0H 0M 27S
Interface         : Tunnel2
Number of sessions: 1
1002::4               202.0.180.137         --    S-H   Establish  0H 0M 2S
Interface         : Tunnel3
1003::4               2003::180:137         2057  S-S   Success    1H 12M 26S
Interface         : Tunnel4
1004::4               204.1.181:157         --    H-H   Success    10H 48M 19S
Interface         : Tunnel5
Number of sessions: 0
# 显示接口Tunnel1上IPv6 ADVPN隧道的摘要信息。
<Sysname> display advpn ipv6 session interface tunnel 1
Interface         : Tunnel1
# 显示接口Tunnel1上对端私网地址为1001::3的IPv6 ADVPN隧道的摘要信息。
<Sysname> display advpn ipv6 session interface tunnel 1 private-address 1001::3
表1-12 display advpn ipv6 session命令显示信息描述表
ADVPN隧道接口
Number of seesions
隧道接口下建立的ADVPN隧道总数
Private address
ADVPN隧道对端的私网地址
Public address
ADVPN隧道对端的公网地址
Port
ADVPN隧道对端的端口号
ADVPN隧道的类型,包括:
·     H-H:本端是Hub,对端也是Hub
·     H-S:本端是Hub,对端是Spoke
·     S-H:本端是Spoke,对端是Hub
·     S-S:本端是Spoke,对端也是Spoke
ADVPN隧道的状态,包括:
·     Success:表示隧道建立成功
·     Establishing:表示隧道正在建立中
·     Dumb:表示隧道建立失败后处于静默状态
Holding time
当前ADVPN隧道状态的持续时间,为x小时y分z秒(xH yM zS)
# 显示所有IPv6 ADVPN隧道的详细信息。
<Sysname> display advpn ipv6 session verbose
Interface         : Tunnel1
Client name       : vpn1
Link protocol     : UDP
  Private address: 1001::3
  Public address : 2000::180:136
  ADVPN port     : 1139
  Session type   : Hub-Spoke
  State          : Success
  Holding time   : 5H 38M 8S
  Input : 2201 packets, 2198 data packets, 3 control packets
          2191 multicasts, 0 errors
  Output: 2169 packets, 216 data packets, 1 control packets
          2163 multicasts, 0 errors
  Private address: 1001::4
  Public address : 2000::180:137
  ADVPN port     : 3546
  State          : Dumb
  Holding time   : 0H 0M 27S
  Input : 1 packets, 0 data packets, 1 control packets
          0 multicasts, 0 errors
  Output: 16 packets, 0 data packets, 16 control packets
Interface         : Tunnel2
Client name       : vpn2
Link protocol     : GRE
  Private address: 1002::4
  Public address : 202.0.180.137
  Session type   : Spoke-Hub
  State          : Establish
  Input:  0 packets, 0 data packets, 0 control packets
  Output: 1 packets, 0 data packets, 1 control packets
Interface         : Tunnel3
Client name       : vpn3
  Private address: 1003::4
  Public address : 2003::180:137
  ADVPN port     : 2057
  SA's SPI       :
    Inbound : 187199087 (0xb286e6f) [ESP]
    Outbound: 3562274487 (0xd453feb7) [ESP]
  Session type   : Spoke-Spoke
  State          : Establish
Interface         : Tunnel4
Client name       : vpn4
  Private address: 1004::4
  Public address : 204.1.181:157
  SA's SPI       :
    Inbound:  187199087 (0xb286e6f) [ESP]
  Session type   : Hub-Hub
  State          : Success
  Holding time   : 10H 48M 19S
  Output: 2169 packets, 2168 data packets, 1 control packets
Interface         : Tunnel5
Client name       : vpn5
Link protocol     : UDP
# 显示接口Tunnel1上IPv6 ADVPN隧道的详细信息。
<Sysname> display advpn ipv6 session interface tunnel 1 verbose
Interface         : Tunnel1
Client name       : vpn1
Link protocol     : UDP
  ADVPN port     : 1139
  State          : Success
  ADVPN port     : 3546
  State          : Dumb
# 显示接口Tunnel1上对端私网地址为1001::3的IPv6 ADVPN隧道的详细信息。
<Sysname> display advpn ipv6 session interface tunnel 1 private-address 1001::3 verbose
  ADVPN port     : 1139
  State          : Success
表1-13 display advpn ipv6 session verbose命令显示信息描述表
ADVPN隧道接口
Client name
隧道接口绑定的VAM Client名称
ADVPN domain name
ADVPN域的名称
Link protocol
ADVPN隧道使用的承载链路层协议:
·     UDP
·     GRE
·     IPsec-UDP
·     IPsec-GRE
Number of sessions
隧道接口下建立的ADVPN隧道总数
Private address
ADVPN隧道对端的私网地址
Public address
ADVPN隧道对端的公网地址
ADVPN port
ADVPN隧道使用的承载链路层协议为UDP或IPsec-UDP时,隧道的UDP端口号
SA's SPI
ADVPN隧道使用的承载链路层协议为IPsec-UDP或IPsec-GRE时,出方向和入方向的安全策略索引
Session type
ADVPN隧道的类型,包括:
·     Hub-Hub:本端是Hub,对端也是Hub
·     Hub-Spoke:本端是Hub,对端是Spoke
·     Spoke-Hub:本端是Spoke,对端是Hub
·     Spoke-Spoke:本端是Spoke,对端也是Spoke
ADVPN隧道的状态,包括:
·     Success:表示隧道建立成功
Holding time
当前隧道状态的持续时间,为x小时y分z秒(xH yM zS)
Input
接收的报文统计信息,包括:
·     packets:报文总个数
·     data packets:数据报文个数
·     control packets:控制报文个数
·     multicasts:组播报文个数
·     errors:错误报文个数
Output
发送的报文统计信息,包括:
·     packets:报文总个数
·     multicasts:组播报文个数
·     errors:错误报文个数
·     reset advpn ipv6 session
display advpn group-qos-map命令用来显示ADVPN隧道组名与QoS策略的对应关系。
display advpn group-qos-map [ interface tunnel number [ group group-name ] ]
context-admin
context-operator
interface tunnel number:显示指定ADVPN隧道接口上ADVPN隧道组名与QoS策略的对应关系。number为Tunnel接口的编号,取值范围为0~1023。如果未指定本参数,则显示所有ADVPN隧道接口上ADVPN隧道组名与QoS策略的对应关系。
group group-name:显示指定ADVPN隧道组名与QoS策略的对应关系。如果未指定本参数,则显示所有ADVPN隧道组名与QoS策略的对应关系。
# 显示所有IPv4 ADVPN隧道接口上ADVPN隧道组名与QoS策略的对应关系。
<Sysname> display advpn group-qos-map
Interface: Tunnel1
  ADVPN group: group1
  QoS policy: policy1
  Session list:
     10.0.0.3                 192.168.180.136
     10.0.1.4                 192.168.180.137
  ADVPN group: bb
  QoS policy: bb-policy
  No sessions match the ADVPN group-to-QoS policy mapping.
Interface: Tunnel2
  ADVPN group: group2
  QoS policy: policy2
  Session list:
    20.0.0.3                 200::3
表1-14 display advpn group-map命令显示信息描述表
ADVPN隧道接口
ADVPN group
ADVPN隧道的组名
QoS policy
QoS策略名
Session list
应用QoS策略的ADVPN隧道列表
Private address
ADVPN隧道对端的私网地址
Public address
ADVPN隧道对端的公网地址
ADVPN隧道上没有应用组名与QoS策略的对应关系
·     advpn group
·     advpn map group
display advpn session命令用来显示IPv4 ADVPN隧道的信息。
display advpn session [ interface tunnel number [ private-address private-ip-address ] ] [ verbose ]
context-admin
context-operator
interface tunnel number:显示指定IPv4 ADVPN类型Tunnel接口上的IPv4 ADVPN隧道信息。number为Tunnel接口的编号。如果未指定本参数,则显示所有IPv4 ADVPN隧道的信息。
private-address private-ip-address:显示指定对端IPv4私网地址的IPv4 ADVPN隧道信息。private-ip-address为对到对端的IPv4私网地址。如果未指定本参数,则显示指定或所有IPv4 ADVPN隧道的信息。
verbose:显示IPv4 ADVPN隧道的详细信息。如果未指定本参数,则显示IPv4 ADVPN隧道的摘要信息。
# 显示所有IPv4 ADVPN隧道的摘要信息。
<Sysname> display advpn session
Interface         : Tunnel1
10.0.0.3         192.168.180.136             1139  H-S   Success    5H 38M 8S
10.0.1.4         192.168.180.137             3546  H-S   Dumb       0H 0M 27S
Interface         : Tunnel2
20.0.0.3         200::3                      --     S-H   Establish  0H 0M 2S
Interface         : Tunnel3
30.0.0.3         192.168.200.22              2057  S-S   Success    1H 12M 26S
Interface         : Tunnel4
40.0.0.3         4::4                        --    H-H   Success    10H 48M 19S
Interface         : Tunnel5
# 显示接口Tunnel1上IPv4 ADVPN隧道的摘要信息。
<Sysname> display advpn session interface tunnel 1
Interface         : Tunnel1
# 显示接口Tunnel1上对端私网地址为10.0.1.3的IPv4 ADVPN隧道的摘要信息。
<Sysname> display advpn session interface tunnel 1 private-address 10.0.1.3
表1-15 display advpn session命令显示信息描述表
ADVPN隧道接口
ADVPN domain name
ADVPN域的名称
Number of sessions
隧道接口下建立的ADVPN隧道总数
Private address
ADVPN隧道对端的私网地址
Public address
ADVPN隧道对端的公网地址
Port
ADVPN隧道对端的端口号
ADVPN隧道的类型,包括:
ADVPN隧道的状态,包括:
·     Success:表示隧道建立成功
Holding time
# 显示所有IPv4 ADVPN隧道的详细信息。
<Sysname> display advpn session verbose
Interface         : Tunnel1
Client name       : vpn1
Link Protocol     : UDP
  Private address: 10.0.1.3
  Public address : 192.168.180.136
  ADVPN Port     : 1139
  Behind NAT     : No
  State          : Success
  Input : 2201 packets, 218 data packets, 3 control packets
  Private address: 10.0.1.4
  Public address : 192.168.180.137
  ADVPN port     : 3546
  Behind NAT     : No
  State          : Dumb
  ADVPN group      : group1
  Outbound QoS policy: policy1
Interface         : Tunnel2
Client name       : vpn2
Link protocol     : GRE
  Private address: 20.0.0.3
  Public address : 200::3
  Behind NAT     : No
  State          : Establish
Interface         : Tunnel3
Client name       : vpn3
Link Protocol     : IPsec-UDP
  Private address: 30.0.0.3
  Public address : 192.168.200.32
  ADVPN port     : 2057
  SA's SPI       :
  Behind NAT     : No
  State          : Establish
Interface         : Tunnel4
Client name       : vpn4
  Private address: 40.0.0.3
  Public address : 4::4
  SA's SPI       :
  Behind NAT     : No
  State          : Success
Interface         : Tunnel5
Client name       : vpn5
Link protocol     : UDP
# 显示接口Tunnel1上IPv4 ADVPN隧道的详细信息。
<Sysname> display advpn session interface tunnel 1 verbose
Interface         : Tunnel1
Client name       : vpn1
Link Protocol     : UDP
  ADVPN Port     : 1139
  Behind NAT     : No
  State          : Success
  ADVPN port     : 3546
  Behind NAT     : No
  State          : Dumb
# 显示接口Tunnel1上对端私网地址为10.0.1.3的IPv4 ADVPN隧道的详细信息。
<Sysname> display advpn session verbose interface tunnel 1 private-address 10.0.1.3
  ADVPN Port     : 1139
  Behind NAT     : No
  State          : Success
表1-16 display advpn session verbose命令显示信息描述表
ADVPN隧道接口
Client name
隧道接口绑定的VAM Client名称
ADVPN domain name
ADVPN域的名称
Link protocol
ADVPN隧道使用的承载链路层协议:
·     UDP
·     GRE
·     IPsec-UDP
·     IPsec-GRE
Number of sessions
隧道接口下建立的ADVPN隧道总数
Private address
ADVPN隧道对端的私网地址
Public address
ADVPN隧道对端的公网地址
ADVPN port
SA's SPI
Behind NAT
ADVPN隧道对端是否穿越NAT
Session type
ADVPN隧道的类型,包括:
ADVPN隧道的状态,包括:
·     Success:表示隧道建立成功
Holding time
ADVPN group
ADVPN隧道组名。
Outbound QoS policy
ADVPN隧道的组名对应的QoS策略名
Input
接收的报文统计信息,包括:
·     packets:报文总个数
·     multicasts:组播报文个数
·     errors:错误报文个数
Output
发送的报文统计信息,包括:
·     packets:报文总个数
·     data packets;数据报文个数
·     multicasts:组播报文个数
·     errors:错误报文个数
·     reset advpn session
display advpn session count命令用来显示不同状态下ADVPN会话的个数。
context-admin
context-operator
# 显示不同状态下ADVPN会话的个数。
<Sysname> display advpn session count
Total ADVPN sessions: 7
IPv4 sessions: 3
  Success: 3
  Establishing: 0
  Dumb: 0
IPv6 sessions: 4
  Success: 4
  Establishing: 0
  Dumb: 0
表1-17 display advpn session count命令显示信息描述表
ADVPN会话的总个数
IPv4 sessions:
IPv4私网ADVPN会话个数
IPv6 sessions:
IPv6私网ADVPN会话 个数
Success
成功状态下ADVPN会话个数
Establishing
正在建立的ADVPN会话个数
Dumb
静默状态下的ADVPN会话个数
1.3.13  keepalive
keepalive命令用来配置ADVPN隧道的Keepalive报文发送周期及最大发送次数。
undo keepalive
ADVPN隧道的Keepalive报文发送周期为180秒,最大发送次数为3次。
Tunnel接口视图
context-admin
interval interval:Keepalive报文的发送周期,取值范围为1~32767,单位为秒。
retry retries:Keepalive报文的最大发送次数,取值范围为1~255。
本命令只有在ADVPN隧道类型的Tunnel接口下才能配置。
如果在Keepalive报文发送周期×最大发送次数时间内没有收到Keepalive报文,则断开该隧道。
在同一个ADVPN域中,所有Tunnel接口的Keepalive报文发送周期及最大发送次数必须一致。
本命令配置之后,ADVPN隧道的Keepalive定时器并不立即启动,直到ADVPN隧道建立成功之后才启动。
# 配置ADVPN隧道的Keepalive报文发送周期为20秒,最大发送次数为5次。
[Sysname-Tunnel1] keepalive interval 20 retry 5
1.3.14  reset advpn ipv6 session
reset advpn ipv6 session命令用来删除IPv6 ADVPN隧道。
reset advpn ipv6 session [ interface tunnel number [ private-address private-ipv6-address ] ]
context-admin
interface tunnel number:拆除指定IPv6 ADVPN类型Tunnel接口上的IPv6 ADVPN隧道。number为Tunnel接口的编号。如果未指定本参数,则拆除所有IPv6 ADVPN隧道。
private-address private-ipv6-address:拆除指定对端IPv6私网地址的IPv6 ADVPN隧道。private-ipv6-address为隧道对端的IPv6私网地址。如未指定本参数,则拆除指定或所有Tunnel接口上的所有ADVPN隧道。
如果隧道对端是Hub,且与本端在同一个Hub组内,隧道拆除后将重新建立隧道。
# 拆除所有IPv6 ADVPN隧道。
<Sysname> reset advpn ipv6 session
# 拆除接口Tunnel1上的所有IPv6 ADVPN隧道。
<Sysname> reset advpn ipv6 session interface tunnel 1
# 拆除接口Tunnel1上对端私网地址为1000::1的IPv6 ADVPN隧道。
<Sysname> reset advpn ipv6 session interface tunnel 1 private-address 1000::1
·     display advpn ipv6 session
1.3.15  reset advpn ipv6 session statistics
reset advpn ipv6 session statistic命令用来清除IPv6 ADVPN隧道的统计信息。
reset advpn ipv6 session statistics [ interface tunnel number [ private-address private-ipv6-address ] ]
context-admin
interface tunnel number:清除指定IPv6 ADVPN类型Tunnel接口上IPv6 ADVPN隧道的统计信息。number为Tunnel接口的编号。如果未指定本参数,则清除所有IPv6 ADVPN隧道的统计信息。
private-address private-ipv6-address:清除指定对端IPv6私网地址的IPv6 ADVPN隧道的统计信息。private-ipv6-address为隧道对端的IPv6私网地址。如果未指定本参数,则清除指定或所有Tunnel接口上所有IPv6 ADVPN隧道的统计信息。
# 清除所有IPv6 ADVPN隧道的统计信息。
<Sysname> reset advpn ipv6 session statistics
# 清除接口Tunnel1上所有IPv6 ADVPN隧道的统计信息。
<Sysname> reset advpn ipv6 session statistics interface tunnel 1
# 清除接口Tunnel1上对端私网地址为1::1的IPv6 ADVPN隧道的统计信息。
<Sysname> reset advpn ipv6 session statistics interface tunnel 1 private-address 1::1
1.3.16  reset advpn session
reset advpn session命令用来删除IPv4 ADVPN隧道。
reset advpn session [ interface tunnel number [ private-address private-ip-address ] ]
context-admin
interface tunnel number:删除指定IPv4 ADVPN类型Tunnel接口上的IPv4 ADVPN隧道。number为Tunnel接口的编号。如果未指定本参数,则删除所有IPv4 ADVPN隧道。
private-address private-ip-address:删除指定对端IPv4私网地址的IPv4 ADVPN隧道。private-ip-address为隧道对端的IPv4私网地址。如果未指定本参数,则删除指定或所有Tunnel接口上的所有IPv4 ADVPN隧道。
如果隧道对端是Hub,且与本端在同一个Hub组内,隧道删除后将重新建立。
# 删除所有IPv4 ADVPN隧道。
<Sysname> reset advpn session
# 删除接口Tunnel1上所有IPv4 ADVPN隧道。
<Sysname> reset advpn session interface tunnel 1
# 删除接口Tunnel1上对端私网地址为169.254.0.1的IPv4 ADVPN隧道。
<Sysname> reset advpn session interface tunnel 1 private-address 169.254.0.1
·     display advpn session
1.3.17  reset advpn session statistics
reset advpn session statistic命令用来清除IPv4 ADVPN隧道的统计信息。
reset advpn session statistics [ interface tunnel number [ private-address private-ip-address ] ]
context-admin
interface tunnel number:清除指定IPv4 ADVPN类型Tunnel接口上IPv4 ADVPN隧道的统计信息。number为Tunnel接口的编号。如果未指定本参数,则清除所有IPv4 ADVPN隧道的统计信息。
private-address private-ip-address:清除指定对端IPv4私网地址的IPv4 ADVPN隧道的统计信息。private-ip-address为隧道对端的IPv4私网地址。如果未指定本参数,则清除指定或所有Tunnel接口上所有IPv4 ADVPN隧道的统计信息。
# 清除所有IPv4 ADVPN隧道的统计信息。
<Sysname> reset advpn session statistics
# 清除接口Tunnel1上所有IPv4 ADVPN隧道的统计信息。
<Sysname> reset advpn session statistics interface tunnel 1
# 清除接口Tunnel1上对端私网地址为169.254.0.1的IPv4 ADVPN隧道的统计信息。
<Sysname> reset advpn session statistics interface tunnel 1 private-address 169.254.0.1
1.3.18  vam client
vam client命令用来配置IPv4 ADVPN隧道接口绑定的VAM Client。
undo vam client命令用来取消IPv4 ADVPN隧道接口绑定的VAM Client。
vam client client-name [ compatible advpn0 ]
undo vam client
IPv4 ADVPN隧道接口未绑定任何VAM Client。
Tunnel接口视图
context-admin
client-name:绑定的VAM Client的名称,为1~63个字符的字符串,不区分大小写,只能包含字符A-Z、a-z、0-9和“.”。
compatible advpn0:兼容ADVPN V0版本报文格式。如果未指定本参数,则不兼容ADVPN V0版本报文格式。
对于IPv4 ADVPN隧道,需要配置此命令将隧道接口与VAM Client绑定。绑定后,VAM Client会向VAM Server注册相应隧道接口的IPv4私网信息。
一个VAM Client只能与一个IPv4 ADVPN类型的Tunnel接口绑定。
如果Tunnel接口绑定的VAM Client所在的Hub组内中有仅支持ADVPN V0版本报文格式的设备,则必须配置compatible参数。配置了compatible参数后,Tunnel接口上配置的ADVPN报文源UDP端口号必须和其他Tunnel接口不同。
# 配置IPv4 ADVPN隧道接口Tunnel1与VAM Client abc绑定。
[Sysname-Tunnel1] vam client abc
·     advpn source-port
·     vam ipv6 client
1.3.19  vam ipv6 client
vam ipv6 client命令用来配置IPv6 ADVPN隧道接口绑定的VAM Client。
undo vam ipv6 client命令用来取消IPv6 ADVPN隧道接口绑定的VAM Client。
vam ipv6 client client-name
IPv6 ADVPN隧道接口未绑定任何VAM Client。
Tunnel接口视图
context-admin
对于IPv6 ADVPN隧道,需要配置此命令将隧道接口与VAM Client绑定。绑定之后, VAM Client会向VAM Server注册相应隧道接口的IPv6私网信息。
一个VAM Client只能与一个IPv6 ADVPN类型的Tunnel接口绑定。
# 配置IPv6 ADVPN隧道接口Tunnel1与VAM Client abc绑定。
[Sysname-Tunnel1] vam ipv6 client abc
·     vam client
