01-基础配置命令参考
05-设备管理命令
本章节下载: 05-设备管理命令  (570.83 KB)
05-设备管理命令
1 设备管理
1.1 设备管理配置命令
1.1.1 clock datetime
1.1.2 clock protocol
1.1.3 clock summer-time
1.1.4 clock timezone
1.1.5 command
1.1.6 copyright-info enable
1.1.7 display alarm
1.1.8 display clock
1.1.9 display copyright
1.1.10 display cpu-usage
1.1.11 display cpu-usage configuration
1.1.12 display cpu-usage history
1.1.13 display device
1.1.14 display device manuinfo
1.1.15 display diagnostic-information
1.1.16 display environment
1.1.17 display fan
1.1.18 display memory
1.1.19 display memory-threshold
1.1.20 display power
1.1.21 display scheduler job
1.1.22 display scheduler logfile
1.1.23 display scheduler reboot
1.1.24 display scheduler schedule
1.1.25 display system stable state
1.1.26 display transceiver alarm
1.1.27 display transceiver diagnosis
1.1.28 display transceiver interface
1.1.29 display transceiver manuinfo
1.1.30 display version
1.1.31 display version-update-record
1.1.32 header
1.1.33 job
1.1.34 locator blink
1.1.35 memory-threshold
1.1.36 memory-threshold usage
1.1.37 monitor cpu-usage enable
1.1.38 monitor cpu-usage interval
1.1.39 monitor cpu-usage threshold
1.1.40 monitor resource-usage { bridge-aggregation | route-aggregation } threshold
1.1.41 monitor resource-usage bandwidth inbound threshold
1.1.42 monitor resource-usage blade-controller-team context
1.1.43 monitor resource-usage context threshold
1.1.44 monitor resource-usage nat threshold
1.1.45 monitor resource-usage security-policy threshold
1.1.46 monitor resource-usage session-count threshold
1.1.47 monitor resource-usage session-rate threshold
1.1.48 password-recovery enable
1.1.49 reboot
1.1.50 reset scheduler logfile
1.1.51 reset version-update-record
1.1.52 restore factory-default
1.1.53 scheduler job
1.1.54 scheduler logfile size
1.1.55 scheduler reboot at
1.1.56 scheduler reboot delay
1.1.57 scheduler schedule
1.1.58 shutdown-interval
1.1.59 sysname
1.1.60 temperature-limit
1.1.61 time at
1.1.62 time once
1.1.63 time repeating
1.1.64 usb disable
1.1.65 user-role
1 设备管理
1.1  设备管理配置命令
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
仅缺省Context支持本命令。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
# 配置设备的系统时间为2019年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2019
# 配置设备的系统时间为2019年1月1日8时10分。
<Sysname> clock datetime 8:10 2019/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp context context-id }
undo clock protocol
从缺省Context通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
context context-id:表示时钟的来源Context编号。context-id表示Context的编号,关于context的取值范围及相关介绍,请参见“虚拟化技术命令参考”中的“Context”。
仅缺省Context支持本命令。
系统时间的获取方式有:
·     配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
·     配置clock protocol ntp命令后,通过NTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
所有Context的系统时间相同。当设备从某个Context获取时钟后,会同步给其它Context。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省Context支持本命令。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省Context支持本命令。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.5  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
context-admin
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口GigabitEthernet1/2/5/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/2/5/1
[Sysname-job-shutdownGE] command 3 shutdown
·     scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
context-admin
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
1.1.7  display alarm
display alarm命令用来显示设备的告警信息。
display alarm [ chassis chassis-number slot slot-number ]
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。
仅缺省Context支持本命令。
# 显示设备的告警信息。
<Sysname> display alarm
Chassis Slot   CPU   Level   Info
1       2      0     ERROR   Power 1 is absent
表1-1 display alarm命令显示信息描述表
Chassis Slot CPU
成员设备的编号、成员设备上单板所在的槽位号、单板上CPU的编号
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息。取值为:
·     Fan n is absent:风扇n当前不在位
·     Power n is absent:电源n当前不在位
·     The board in slot n is faulty:n号槽位上的单板处于faulty状态(该单板可能正在启动,或者当前处于故障状态)
·     The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限
·     The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限
1.1.8  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
context-admin
context-operator
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/15/2019
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/15/2019
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/15/2019
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
context-admin
context-operator
# 显示设备的版权信息。
<Sysname> display copyright
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
control-plane:显示控制平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
登录Context后执行该命令,会显示该Context可使用的CPU的利用率统计信息。
# 以段的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage
Chassis 1 Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
Chassis 1 Slot 2 CPU 0 CPU usage:
       0% in last 5 seconds
       0% in last 1 minute
       0% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。
<Sysname> display cpu-usage summary
Chassis Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1       1    0          1%                1%                1%
1       2    0          0%                0%                0%
表1-2 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
Last 5 sec
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
Last 1 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Last 5 min
display cpu-usage configuration命令用来显示CPU利用率历史信息记录功能的相关配置。
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。
cpu cpu-number:表示CPU的编号。
登录Context后执行该命令,会显示该Context可使用的CPU的对应信息。
# 显示CPU利用率历史信息记录功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 90%.
Current monitor recovery threshold is 40%.
表1-3 display cpu-usage configuration命令显示信息描述表
CPU利用率历史记录功能处于开启状态
CPU利用率采样周期为60秒
CPU利用率阈值
CPU利用率的恢复阈值
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Chassis 1 slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Chassis 1 slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
display device [ harddisk | usb ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
context-admin
context-operator
harddisk:显示硬盘的信息。
usb:显示USB接口的信息。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
不指定harddisk和usb参数时,显示单板的信息。
在缺省Context和非缺省Context下执行该命令,显示信息相同,且均显示物理设备的对应信息。
# 显示设备信息。
<Sysname> display device
Chassis  Slot   Cpu   Type          State      Subslot  Sft Ver        Patch Ver
1        0      0     NONE          Absent     0        None           None
1        1      0     NSQM1MPULA    Master     0        F5030D-9608P03 None
1        2      0     NSQ1MPBHA     Normal     0        F5030D-9608P03 None
表1-4 display device命令显示信息描述表
单板的硬件类型
单板状态:
·     Standby表示该板是备用主控板
·     Master表示该板是主用主控板
·     Absent表示该槽位没有插入单板
·     Fault表示该槽位单板出错,不能正常启动
·     Normal表示该槽位单板是接口板并处于正常工作状态
Soft Ver
当前单板上运行的软件版本
Patch Ver
当前单板上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁
若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级”
display device manuinfo命令用来显示设备的电子标签信息。
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
context-admin
context-operator
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
本命令仅缺省Context支持。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
Chassis 1:
 Slot 1 CPU 0:
 DEVICE_NAME          : NSQM1MPULA
 DEVICE_SERIAL_NUMBER : 210231A5XTH179000004
 MAC_ADDRESS          : 38AD-BE35-6DF9
 MANUFACTURING_DATE   : 2017-09-09
 VENDOR_NAME          : H3C
 Slot 2 CPU 0:
 DEVICE_NAME          : F5030-D
 DEVICE_SERIAL_NUMBER : 210235A2B3H179000029
 MAC_ADDRESS          : 38AD-BE8E-A2DC
 MANUFACTURING_DATE   : 2017-10-09
 VENDOR_NAME          : H3C
表1-5 display device manuinfo命令信息显示描述表
DEVICE_NAME
表示设备的名称
表示设备的序列号
MAC_ADDRESS
表示设备出厂MAC地址
MANUFACTURING_DATE
表示设备的调测日期
VENDOR_NAME
表示设备制造商的名称
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ context context-name ] [ key-info ] [ filename ]
context-admin
context-operator
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
context context-name:收集指定Context的诊断信息。context-name表示Context的名称,为1~15个字符的字符串,区分大小写。不指定该参数时,收集缺省Context的诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1)     使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2)     使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3)     使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20190101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行display diagnostic-information命令前,请使用display cpu-usage、display memory命令查看CPU、内存使用率。如果CPU使用率为100%,或者内存使用率超过90%,请暂时不要执行display diagnostic-information命令,等CPU和内存使用率回落后再执行。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2019
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20190101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20190101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     gunzip(基础配置命令参考/文件系统管理)
·     more(基础配置命令参考/文件系统管理)
·     tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
display environment [ chassis chassis-number [ slot slot-number ] ]
context-admin
context-operator
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示的是指定成员设备上所有温度传感器的温度信息。
本命令仅缺省Context支持。
# 显示设备上所有温度传感器的温度信息。
<Sysname> display environment
 System Temperature information (degree centigrade):
                                                       Warn    Alarm   ShutDown
Chass-Slot-Cpu-Sub  Type      Index  CurTemp  LowLmt   UpLmt   UpLmt   UpLmt
    1-1-0-0         inflow    1      35       0        60      70      NA
    1-1-0-0         hotspot   1      57       0        80      92      NA
    1-2-0-0         inflow    1      38       0        60      70      NA
    1-2-0-0         inflow    2      32       0        60      70      NA
    1-2-0-0         outflow   1      35       0        60      70      NA
    1-2-0-0         hotspot   1      59       0        80      92      NA
    1-2-0-2         hotspot   1      25       0        70      80      NA
    1-2-0-5         hotspot   1      26       0        70      80      NA
表1-6 display environment命令显示信息描述表
系统温度信息,单位为摄氏度
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Index
温度传感器的编号
Chass-Slot-Cpu-Sub
表示指定成员设备指定单板上温度传感器的温度信息
CurTemp
当前温度
LowLmt
低温告警门限。当显示为NA时,表示不支持该门限
WarnUpLmt
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限
AlarmUpLmt
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限
ShutDownUpLmt
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限
1.1.17  display fan
display fan命令用来显示风扇的工作状态。
display fan [ chassis chassis-number ]
context-admin
context-operator
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。
本命令仅缺省Context支持。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Chassis   Slot   Cpu   Index   Status      Speed
1         0      0     0       NoSupport
1         1      0     0       NoSupport
1         2      0     0       Normal      8823
1         2      0     1       Normal      8823
1         2      0     2       Normal      9090
1         2      0     3       Normal      9090
表1-7 display fan命令显示信息描述表
Chassis Slot Cpu
Index
设备上风扇的编号
Status
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Faulty:风扇故障
·     NoSupport:不支持风扇
·     FanDirectionFault:用户期望的风道方向与风扇框的实际风道方向不一致
Speed
风扇速率
display memory命令用来显示内存使用情况。
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。
cpu cpu-number:表示CPU编号。
登录Context后执行该命令,会显示该Context可使用的内存的使用情况。
# 显示设备的内存使用情况的详细信息。
<Sysname> display memory
Memory statistics are measured in KB:
Chassis 1 Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       4071128    826136   3244992         0      2344    232856       79.9%
-/+ Buffers/Cache:    590936   3480192
Swap:           0         0         0
Chassis 1 Slot 2:
Mem:      16413016   4746196  11666820         0      3776    231692       71.1%
-/+ Buffers/Cache:   4510728  11902288
Swap:
# 显示设备的内存使用情况的简要信息。
<Sysname> display memory summary
Chassis Slot CPU   Total      Used      Free      Buffers  Caches    FreeRatio
1       0    0     512252     334312    177940    2436     145540    34.7%
1       1    0     253636     146076    107560    8        30332     42.4%
表1-8 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值
Buffers
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值
Cached
高速缓冲寄存器已使用的内存大小。取值为“--”时,表示不支持统计该参数的值
Caches
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。
仅缺省Context支持本命令。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 224M
    Severe: 128M
    Critical: 96M
    Normal: 256M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-9 display memory-threshold命令显示信息描述表
内存利用率阈值
Free-memory thresholds
    Minor
    Severe
    Critical
    Normal
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
Current free-memory state
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
Free-memory event statistics:
门限事件统计信息,事件分为:
·     Back to normal state:内存恢复到正常状态
·     Entered minor alarm state:进入一级告警门限状态
·     Back to minor alarm state:恢复到一级告警前的状态
·     Entered severe alarm state:进入二级告警门限状态
·     Back to severe alarm state:恢复到二级告警前的状态
·     Entered critical alarm state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display power命令用来显示设备电源的信息。
display power [ chassis chassis-number  ]
context-admin
context-operator
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。
本命令仅缺省Context支持。
# 显示设备电源的简要信息。
<Sysname> display power
1         0      0     0       NoSupport
1         1      0     0       NoSupport
1         2      0     0       Normal
1         2      0     1       Absent
表1-10 display power命令显示信息描述表
Chassis   Slot   Cpu
Index
设备上的电源模块编号
Status
电源模块的状态
·     Absent:电源不在位
·     Normal:电源正常工作
·     Faulty:电源故障
·     NoSupport:不支持电源
display scheduler job命令用来显示Job的配置信息。
context-admin
context-operator
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
context-admin
context-operator
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Sun May 27 10:44:42 2018
Completion time : Sun May 27 10:44:47 2018
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/2/5/1 to gigabitethernet 1/2/5/3
[Sysname-if-range]shutdown
表1-11 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
context-admin
context-operator
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2018 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
context-admin
context-operator
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Sun May 27 10:44:42 2018
Last execution time  : Sun May 27 10:44:42 2018
Last completion time : Sun May 27 10:44:47 2018
Execution counts     : 1
shutdown                                          Successful
表1-12 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display system stable state命令用来显示系统的稳定状态。
display system stable state [ context { context-id | all } ]
context-admin
context-operator
context { context-id | all }:显示指定或所有Context的系统稳定状态。context-id表示Context的编号,关于context的取值范围及相关介绍,请参见“虚拟化技术命令参考”中的“Context”。
不指定context参数时,显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/Context启动需要一定的时间,才能达到Stable状态。如果设备/Context长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/Context,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。
<Sysname> display system stable state
System state     : Stable
Redundancy state : No redundance
  Chassis    Slot    CPU    Role       State
  1          1       0      Active     Stable
  1          2       0      Other      Stable
表1-13 display system stable state命令显示信息描述表
System state
系统状态:
·     Stable:稳定运行
·     Not ready:未稳定,此时不能进行ISSU升级
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No redundance:系统无冗余,不能倒换
·     Not ready:未稳定,不可以倒换
Role
单板在系统中的身份:
·     Active:主用主控板
·     Standby:备用主控板,提供冗余备份
·     Other:业务板
单板状态:
·     Stable:单板稳定运行
·     Board inserted:单板插入
·     Kernel initiating:单板内核初始化
·     Service starting:单板上的服务正在启动
·     Service stopping:单板上的服务正在关闭
·     HA Batch backup:HA批量备份中
·     Interface data batch backup:接口管理批量备份未完成
·     Context starting:Context正在启动
·     Context stopping:Context正在关闭
当前对象处于未稳定状态
·     display context(虚拟化技术命令参考/Context)
·     display device
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
context-admin
context-operator
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-14 SFP/SFP+的display transceiver alarm命令输出信息描述表
RX loss of signal
接收信号丢失
RX power high
接收光功率高
RX power low
接收光功率低
TX fault
发送错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
# 显示接口GigabitEthernet1/2/5/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 1/2/5/1
GigabitEthernet1/2/5/1 transceiver current alarm information:
  RX loss of signal
  RX power low
表1-15 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX loss of signal
接收信号丢失
RX power low
接收光功率低告警
context-admin
context-operator
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/2/5/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 1/2/5/1
GigabitEthernet1/2/5/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(℃)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
表1-16 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
context-admin
context-operator
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/2/5/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 1/2/5/1
GigabitEthernet1/2/5/1 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),270(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : SFP-GE-SX-MM850
表1-17 display transceiver interface显示信息中光学参数统计信息描述表
Transceiver Type
光模块的类型
Connector Type
光连接器的类型
Wavelength(nm)
·     对于光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔
·     对于电模块:显示为“N/A”
传输距离,对于单模模块,xx显示为km,其他模块xx显示为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
·     CX4:表示CX4电缆
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
Ordering Name
可插拔接口模块的对外型号
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
context-admin
context-operator
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/2/5/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 1/2/5/1
GigabitEthernet1/2/5/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2018-09-01
  Vendor Name          : H3C
表1-18 display transceiver manuinfo显示信息中光学参数统计信息描述表
Manu. Serial Number
光模块的序列号
Manufacturing Date
光模块的生产日期
Vendor Name
光模块定制厂商的名称
display version命令用来显示系统版本信息。
display version
context-admin
context-operator
# 查看系统版本信息。
<Sysname> display version
H3C Comware Software, Version 7.1.064, Ess 9608P06
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F5030-D uptime is 0 weeks, 0 days, 1 hour, 20 minutes
Last reboot reason: User reboot
Boot image: flash:/f5080mpu-cmw710-boot-E9608P06.bin
Boot image version: 7.1.064, Ess 9608P06
  Compiled Apr 11 2018 16:00:00
System image: flash:/f5080mpu-cmw710-system-E9608P06.bin
System image version: 7.1.064, Ess 9608P06
显示信息略……。
表1-19 display version命令显示信息描述表
表示设备使用的软件版本
表示设备的版权申明
H3C SecPath F5030-D uptime is 0 weeks, 0 days, 2 hours, 14 minutes
表示设备的型号以及本次启动后的持续运行时间
Last reboot reason
表示设备上次重启的原因,主要取值有:
·     User reboot:表示用户通过命令行、SNMP等方式重启设备
·     Cold reboot:表示断电导致的重启
·     Kernel abnormality reboot:表示内核异常导致的重启
·     DeadLoop reboot:表示内核死循环导致的重启
·     DEV HandShake reboot:表示设备管理握手失败导致的重启
·     SlaveSwitch reboot:表示主备倒换导致的重启
·     IRF Merge reboot:表示IRF合并重启本设备
·     Auto Update reboot:表示版本自动升级导致的重启
·     Memory exhaust reboot:表示单板内存耗尽导致的重启
Boot image version: 7.1.070, Ess 9608P06
表示设备当前运行过程中使用的Boot包以及该软件包的版本、编译时间
display version-update-record命令用来显示启动软件包版本更新操作的记录。
仅缺省Context支持本命令。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2018 at 06:23:54):
 *Name        : simware-cmw710-boot.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2018 15:52:43
 *Name        : simware-cmw710-system.bin
表1-20 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2018 at 06:23:54)
最近的第n次更新的时间,Record 1为最新的一次更新
*Name
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化
Version
软件包的版本号
Compile time
版本编译时间
·     reset version-update-record
1.1.32  header
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
未配置欢迎信息。
context-admin
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
1.1.33  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
context-admin
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
locator blink blink-time命令用来定位设备的位置。
locator blink stop命令用来停止定位。
locator [ chassis chassis-number ] blink blink-time
locator [ chassis chassis-number ] blink stop
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示对所有设备进行操作。
blink-time:闪烁的持续时间,取值范围为5~120,单位为秒。
stop:停止闪烁。
仅缺省Context支持本命令。
配置locator blink blink-time命令后,指定设备上用于定位的LED灯会以间隔快闪的方式闪烁,并持续指定的时间。用户可根据LED灯的指示来定位设备所在的位置。
blink-time时间到或者执行locator blink stop命令,则定位闪烁的LED灯会恢复正常点亮状态。
# 开始定位。
<Sysname> locator blink 30
# 结束定位。
<Sysname> locator blink stop
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
一级告警门限值为112MB,二级告警门限值为96MB,三级告警门限值为88MB,系统内存恢复正常状态时的内存大小为128MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
仅缺省Context支持本命令。
系统实时监控系统剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
·     display memory-threshold
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
仅缺省Context支持本命令。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大于等于用户配置的内存利用率阈值时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
context-admin
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
context-admin
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率告警门限为70%,CPU利用率恢复门限为30%。
context-admin
severe-threshold:CPU利用率高级别告警门限,取值范围为1~100,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 recovery-threshold 70
monitor resource-usage { bridge-aggregation | route-aggregation } threshold命令用来配置聚合接口数的告警阈值。
undo monitor resource-usage { bridge-aggregation | route-aggregation } threshold命令用来恢复缺省情况。
monitor resource-usage { bridge-aggregation | route-aggregation } threshold threshold-value
未配置聚合接口的告警阈值,不会触发告警。
context-admin
bridge-aggregation:表示对可创建的二层聚合接口数设置告警阈值。
route-aggregation:表示对可创建的三层聚合接口数设置告警阈值。
threshold-value:表示可创建聚合接口数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上创建的二层聚合接口或三层聚合接口的数量达到告警阈值时,则输出告警信息。之后每3小时输出一次告警,直到设备上创建的二层聚合接口或三层聚合接口的数量低于告警阈值后,才停止输出告警。
# 配置二层聚合接口数的告警阈值为100。
[Sysname] monitor resource-usage bridge-aggregation threshold 100
# 配置三层聚合接口数的告警阈值为150。
[Sysname] monitor resource-usage route-aggregation threshold 150
monitor resource-usage bandwidth inbound threshold命令用来配置整机入方向带宽的告警阈值。
undo monitor resource-usage bandwidth inbound threshold命令用来恢复缺省情况。
monitor resource-usage bandwidth inbound threshold threshold-value [ duration duration-value ]
未配置整机入方向带宽的告警阈值,不会触发告警。
threshold-value:表示整机入方向带宽的告警阈值,取值范围为1~4294967295,单位为Mbps。
duration duration-value:表示整机入方向流量超过告警阈值的持续时间。duration-value是持续时间,取值范围为5~300,必须是5的倍数,单位为秒,缺省值为300秒。
当入方向流量在持续时间内一直大于或等于带宽告警阈值,则输出告警,且之后会每5秒输出一次告警;直到入方向流量低于带宽告警阈值后,才停止输出告警。
此命令仅缺省Context支持,非缺省Context不支持。
# 配置整机入方向带宽告警的阈值为1024Mbps,持续时间为60秒。
[Sysname] monitor resource-usage bandwidth inbound threshold 1024 duration 60
monitor resource-usage blade-controller-team context命令用来开启安全引擎组中Context个数告警功能。
undo monitor resource-usage blade-controller-team context命令用来关闭安全引擎组中Context个数告警功能。
安全引擎组中Context个数告警功能处于关闭状态。
开启此功能后,设备会按周期监测每个安全引擎组中的Context个数:
·     当某个安全引擎组中Context个数从小于变成大于等于一级告警阈值时,设备会立即输出该安全引擎组的一级告警并进入一级告警状态。若该安全引擎组一直处于一级告警状态,为避免告警频繁,后续一级告警会每6小时输出一次,直到该安全引擎组进入二级告警状态或者一级告警状态解除。
·     当某个安全引擎组中Context个数从小于变成大于等于二级告警阈值时,设备会立即输出该安全引擎组的二级告警并进入二级告警状态。若该安全引擎组一直处于二级告警状态,为避免告警频繁,后续二级告警会每6小时输出一次,直到该安全引擎组二级告警状态解除。
·     若某个安全引擎组处于二级告警状态,当Context个数降至二级阈值以下时,则解除二级告警状态,输出二级告警解除日志。
·     若某个安全引擎组处于一级告警状态,当Context个数降至一级阈值以下时,则解除一级告警状态,输出一级告警解除日志。
一级阈值和二级阈值在设备出厂时已固定,不支持修改,可从告警信息中查看。
# 开启安全引擎组中Context个数告警监控功能。
[Sysname] monitor resource-usage blade-controller-team context
monitor resource-usage context threshold命令用来配置Context个数的告警阈值。
undo monitor resource-usage context threshold命令用来恢复缺省情况。
monitor resource-usage context threshold threshold-value
未配置Context个数的告警阈值,不会触发告警。
threshold-value:表示可创建的Context个数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上新建Context的数量达到告警阈值时,则输出告警信息。之后每6小时输出一次告警,直到设备上新建Context的数量低于告警阈值后,才停止输出告警。
# 配置Context数的告警阈值为16。
[Sysname] monitor resource-usage context threshold 16
monitor resource-usage nat threshold命令用来配置NAT条目数的告警阈值。
undo monitor resource-usage nat threshold命令用来恢复缺省情况。
monitor resource-usage nat threshold threshold-value
未配置NAT条目数的告警阈值,不会触发告警。
context-admin
threshold-value:表示NAT条目数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上配置的NAT条目数达到告警阈值时,则输出告警信息。之后每3小时输出一次告警,直到设备上配置的NAT条目数低于告警阈值后,才停止输出告警。
目前,此功能仅统计配置的静态地址转换条目数和生效的NAT内部服务器地址转换条目数,可通过display nat server命令查看NAT内部服务器配置的生效状态。
# 配置NAT条目数的告警阈值为300。
[Sysname] monitor resource-usage nat threshold 300
·     display nat server(三层技术-IP业务/NAT)
monitor resource-usage security-policy { ip | ipv6 } threshold命令用来配置安全策略规则数的告警阈值。
undo monitor resource-usage security-policy { ip | ipv6 } threshold命令用来恢复缺省情况。
monitor resource-usage security-policy { ip | ipv6 } threshold threshold-value
未配置安全策略规则数的告警阈值,不会触发告警。
context-admin
ip:表示对可创建的IPv4类型安全策略规则设置告警阈值。
ipv6:表示对可创建的IPv6类型安全策略规则设置告警阈值。
threshold-value:表示可创建安全策略规则数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上创建的安全策略规则的数量达到告警阈值时,则输出告警信息。之后每6小时输出一次告警,直到设备上创建的安全策略规则的数量低于告警阈值后,才停止输出告警。
# 配置IPv4类型安全策略规则数的告警阈值为500。
[Sysname] monitor resource-usage security-policy ip threshold 500
# 配置IPv6类型安全策略规则数的告警阈值为500。
[Sysname] monitor resource-usage security-policy ipv6 threshold 500
monitor resource-usage session-count threshold命令用来配置会话连接数的告警阈值。
undo monitor resource-usage session-count threshold命令用来恢复缺省情况。
monitor resource-usage session-count [ chassis chassis-number slot slot-number ] threshold threshold-value
undo monitor resource-usage session-count [ chassis chassis-number slot slot-number ] threshold
未配置会话连接数的告警阈值,不会触发告警。
context-admin
threshold-value:表示会话连接数的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上的会话连接数达到告警阈值时,则输出告警信息。之后每10分钟输出一次告警,直到会话连接数低于告警阈值后,才停止输出告警。
不指定可选参数时,表示监控整机的会话连接数。
多次执行此命令,可以为不同的成员设备或单板配置会话连接数的告警阈值。
# 配置整机会话连接数的告警阈值为100000。
[Sysname] monitor resource-usage session-count threshold 100000
monitor resource-usage session-rate threshold命令用来配置会话新建速率的告警阈值。
undo monitor resource-usage session-rate threshold命令用来恢复缺省情况。
monitor resource-usage session-rate [ chassis chassis-number slot slot-number ] threshold threshold-value
undo monitor resource-usage session-rate [ chassis chassis-number slot slot-number ] threshold
未配置会话新建速率的告警阈值,不会触发告警。
context-admin
threshold-value:表示会话新建速率的告警阈值,取值范围为1~4294967295。
配置此功能后,当设备上的会话新建速率达到告警阈值时,则输出告警信息。之后每10分钟输出一次告警,直到会话新建速率低于告警阈值后,才停止输出告警。
多次执行此命令,可以为不同的成员设备或单板配置会话新建速率的告警阈值。
# 配置会话新建速率的告警阈值为500。
[Sysname] monitor resource-usage session-rate threshold 500
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
仅缺省Context支持本命令。
清除认证密码的操作必须在主用主控板的启动过程中进入BootWare菜单进行。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.49  reboot
reboot命令用来重启设备。
context-admin
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启成员设备。
force:强制重启:
·     不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
Now rebooting, please wait...
·     display system stable state
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
仅缺省Context支持本命令。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
仅缺省Context支持本命令。
执行本命令时,设备会自动强制重启,以便恢复到出厂状态,请谨慎使用该命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data, and forcibly reboot the system. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
The system is rebooting...
·     reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
context-admin
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
·     command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
context-admin
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
context-admin
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
·     配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2019年3月3日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 03/03/2019 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
context-admin
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2018年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2018(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
context-admin
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule。
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
context-admin
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示不进行定时检测。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
1.1.59  sysname
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
context-admin
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
context-admin
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
本命令仅缺省Context支持。
# 配置指定chassis上热点1号温度传感器,低温门限为0摄氏度,一般级高温门限为80摄氏度,严重级高温门限为90摄氏度。
[sysname] temperature-limit chassis 1 slot 1 hotspot 1 0 80 90
·     display environment
1.1.61  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
context-admin
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2018年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2018/05/11
1.1.62  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
context-admin
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
context-admin
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.64  usb disable
usb disable命令用来关闭USB接口。
undo usb disable命令用来开启USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
仅缺省Context支持本命令。
用户可通过USB口进行文件的上传和下载。缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
# 打开USB接口。
[Sysname] undo usb disable
1.1.65  user-role
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
context-admin
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、context-admin、context-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
