04-系统管理命令参考
07-系统维护命令
本章节下载: 07-系统维护命令  (118.27 KB)
07-系统维护命令
1 系统维护命令参考
1.1  系统诊断配置命令
1.1.1  Ping
ping检查网络是否连通,可以很好地帮助我们分析和判定网络故障。
Ping   -I,-c,-I,-s,-t-vrf-WORD
缺省情况下,ping不带参数。
-I    Set source address     带源IP ping
  -c    Stop after sending count ECHO_REQUEST packets  设置发包个数(1-10000)
  -i    Set the interval of every packet      探测数目(1-10)
  -s    Specifies the number of data bytes to be sent  所发送数据包的报文大小(64-65500)
  -t    Set the IP Time to Live  指定数据包探测条数(1-255)
  -vrf  Select VPN routing instance   ping vrf里地址,需带vrf名称
  WORD  Ping destination address or hostname    直接ping 域名或者目的IP,使用默认参数
# 使用本机ip 访问114
host#  ping -I 192.168.2.73 114.114.114.114
PING 114.114.114.114 (114.114.114.114) from 192.168.2.73 : 56(84) bytes of data.
      seq       ttl     time(ms)
        1        75     24.540
        2        70     24.923
        3        70     25.317
        4        84     24.465
        5        88     24.156
--- 114.114.114.114 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 24.156/24.680/25.317/0.413 msdisplay user-policy app-local-cache
# 设备ping一个报文到114
host# ping -c  1 114.114.114.114
PING 114.114.114.114 (114.114.114.114) 56(84) bytes of data.
      seq       ttl     time(ms)
        1        90     14.201
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 14.201/14.201/14.201/0.000 ms
# 设备2秒ping一个报文到114
host# ping -i 2 114.114.114.114
      seq       ttl     time(ms)
        1        80     14.508
        2        86     14.238
        3        65     14.001
        4        80     14.311
        5        80     14.186
5 packets transmitted, 5 received, 0% packet loss, time 8009ms
rtt min/avg/max/mdev = 14.001/14.248/14.508/0.223 ms
# 设备ping一个1000字节报文到114
host# ping -s 1000 114.114.114.114
PING 114.114.114.114 (114.114.114.114) 1000(1028) bytes of data.
      seq       ttl     time(ms)
        1        54     14.805
        2        54     14.931
        3        54     14.417
        4        54     14.766
        5        54     14.727
5 packets transmitted, 5 received, 0% packet loss, time 4003ms
rtt min/avg/max/mdev = 14.417/14.729/14.931/0.186 ms
1.2  Traceroute
1.2.1  Traceroute
Traceroute用来追踪设备所经过的跳数
traceroute (-i imcp) (-s source address) (-u udp)name
缺省情况下,默认使用udp探测追踪路由。
#视图
-i    Use ICMP ECHO instead of UDP datagrams   icmp探测
 -s    Chooses an alternative source address    带源地址探测
  -u    Udp port detect                       udp探测
  WORD  Trace route to destination address or hostname   探测目标域名或者ip
需要设备网络连通。
# 带源地址探测到114的跳数
host# traceroute -s 192.168.2.73 114.114.114.114
traceroute to 114.114.114.114 (114.114.114.114) from 192.168.2.73, 30 hops max, 46 byte packets
 1  192.168.2.1 (192.168.2.1)  3.225 ms  9.781 ms  9.923 ms
 2  192.168.77.1 (192.168.77.1)  9.910 ms  9.897 ms  220.249.52.177 (220.249.52.177)  9.941 ms
 3  165.165.202.1.static.bjtelecom.net (1.202.165.165)  19.803 ms  9.765 ms  9.934 ms
 4  245.235.120.106.static.bjtelecom.net (106.120.235.245)  9.917 ms  9.816 ms  9.932 ms
 5  bj141-135-162.bjtelecom.net (219.141.135.162)  9.925 ms  9.830 ms  *
 6  124.65.194.173 (124.65.194.173)  14.803 ms  202.97.85.6 (202.97.85.6)  39.923 ms  123.126.0.233 (123.126.0.233)  19.874 ms
 7  218.2.182.30 (218.2.182.30)  39.897 ms  29.802 ms  39.934 ms
 8  *  60.217.43.14 (60.217.43.14)  23.572 ms  19.821 ms
 9  *  *  *
Traceroute  WORD
1.3  tcpsyn
tcpsyn命令用来目标开放的端口
Tcpsyn (-c Set packet count option ) (-w Set packet timeout option) hostname
#视图
-c        Set packet count option   数据包计数选项(1.1000)默认3
  -w        Set packet timeout option 数据包超时选项(1-1000)默认1
  HOSTNAME  Destination domain 探测域名或者地址后面跟端口范围(0-65535)
配置探测目标
# tcp探测百度是否开放80端口
host# tcpsyn www.baidu.com 80
tcpsyn to 115.239.211.112:80
 1  TCP ACK from 115.239.211.112:80
 2  TCP ACK from 115.239.211.112:80
 3  TCP ACK from 115.239.211.112:80!
