13-TRILL命令参考
01-TRILL命令
本章节下载: 01-TRILL命令  (439.96 KB)
01-TRILL命令
1 TRILL
1.1 TRILL配置命令
1.1.1 auto-cost enable
1.1.2 display trill adjacent-table
1.1.3 display trill brief
1.1.4 display trill fib
1.1.5 display trill graceful-restart status
1.1.6 display trill ingress-route
1.1.7 display trill interface
1.1.8 display trill l3-forwarding active-vlan
1.1.9 display trill l3-forwarding adjacent-table
1.1.10 display trill l3-forwarding fib
1.1.11 display trill l3-forwarding interface
1.1.12 display trill l3-forwarding neighbor-table
1.1.13 display trill l3-forwarding unicast-route
1.1.14 display trill lsdb
1.1.15 display trill mfib ingress
1.1.16 display trill mfib transit
1.1.17 display trill multicast-route
1.1.18 display trill neighbor-table
1.1.19 display trill peer
1.1.20 display trill rpf-table
1.1.21 display trill topology
1.1.22 display trill unicast-route
1.1.23 flash-flood
1.1.24 flush-policy difference
1.1.25 graceful-restart
1.1.26 graceful-restart interval
1.1.27 graceful-restart suppress-sa
1.1.28 ingress assign-delay
1.1.29 ingress assign-rule load-balancing
1.1.30 l3-forwarding enable
1.1.31 l3-forwarding vlan
1.1.32 log-peer-change enable
1.1.33 lsp-length originate
1.1.34 lsp-length receive
1.1.35 max-unicast-load-balancing
1.1.36 multicast multi-thread enable
1.1.37 multicast-ecmp enable
1.1.38 nickname
1.1.39 ping trill
1.1.40 reset trill
1.1.41 set ingress-load-balancing
1.1.42 set overload(Release 1138P01及以上)
1.1.43 set-overload(Release 1135)
1.1.44 snmp context-name
1.1.45 snmp-agent trap enable trill
1.1.46 system-id
1.1.47 timer lsp-generation
1.1.48 timer lsp-max-age
1.1.49 timer lsp-refresh
1.1.50 timer spf
1.1.51 tracert trill
1.1.52 tree-root priority
1.1.53 trees calculate
1.1.54 trill
1.1.55 trill announcing-vlan
1.1.56 trill bypass-pseudonode enable
1.1.57 trill cost
1.1.58 trill designated-vlan
1.1.59 trill drb-priority
1.1.60 trill enable
1.1.61 trill link-type
1.1.62 trill timer avf-inhibited
1.1.63 trill timer csnp
1.1.64 trill timer hello
1.1.65 trill timer holding-multiplier
1.1.66 trill timer lsp
1 TRILL
提示
TRILL需要安装License才能使用。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
1.1  TRILL配置命令
auto-cost enable命令用来开启TRILL端口链路开销值的自动计算功能。
undo auto-cost enable命令用来关闭TRILL端口链路开销值的自动计算功能。
auto-cost enable
TRILL端口链路开销值的自动计算功能处于开启状态。
TRILL视图
TRILL端口的链路开销可以由系统自动计算或用户手工配置,其中手工配置优先,即:只要进行了手工配置,就取手工配置值;如果没有进行手工配置,若开启了自动计算功能则取自动计算值,若关闭了自动计算功能则取缺省值2000。
TRILL端口链路开销值自动计算的公式如下:链路开销值=20000000000000÷端口波特率。
# 关闭TRILL端口链路开销值的自动计算功能。
[Sysname] trill
[Sysname-trill] undo auto-cost enable
·            trill cost
display trill adjacent-table命令用来显示TRILL邻接表信息。
display trill adjacent-table [ count | nickname nickname interface interface-type interface-number ]
count:显示表项的数量。
nickname nickname interface interface-type interface-number:显示指定RB指定端口上的信息。nickname表示RB的Nickname,为0x1~0xFFFE的十六进制数;interface-type interface-number为端口类型和端口编号。如果未指定本参数,将显示所有RB所有端口上的信息。
# 显示TRILL邻接表所有表项的信息。
<Sysname> display trill adjacent-table
NextHop     MAC address       Interface
0x899b      00e0-fc58-123a    XGE1/0/1
# 显示TRILL邻接表的表项数量。
<Sysname> display trill adjacent-table count
Total number of TRILL ADJ entries: 1
表1-1 display trill adjacent-table命令显示信息描述表
NextHop
报文转发的下一跳RB的Nickname
MAC address
报文转发的下一跳RB的MAC地址
报文的出端口
TRILL邻接表的表项数量
display trill brief命令用来显示TRILL摘要信息。
display trill brief
# 显示TRILL摘要信息。
<Sysname> display trill brief
Network entity: 00.00a0.fc00.5806.00
Nickname: 0xfa1b
Nickname priority: 64
Tree-root priority: 32768
L3-nickname: 0x5de1
L3-nickname priority: 64
L3-tree-root priority: 1
Cost style: Wide
Maximum allowed LSP received: 1492
Maximum allowed LSP originated: 1458
Maximum unicast load-balancing: 8
Overload status: None
Overload remaining time: N/A
Device role: Normal
Timers:
  LSP-max-age: 1200s
  LSP-refresh: 900s
  Interval between SPFs: 10s  10ms  20ms
表1-2 display trill brief命令显示信息描述表
Network entity
网络实体的名称
Nickname
RB的二层Nickname,用于二层报文解封装。即如果报文的目的MAC是本设备,Egress Nickname是本设备的二层Nickname,则查找MAC地址表进行二层转发
没有使能三层转发功能的VLAN封装TRILL报文时使用二层Nickname作为Ingress Nickname
使用nickname命令配置的为二层Nickname
Nickname priority
RB拥有Nickname的优先级
Tree-root priority
设备作为TRILL分发树根桥的优先级
L3-nickname
RB的三层Nickname,用于三层报文解封装。即如果报文的目的MAC是本设备,Egress Nickname是本设备的三层Nickname,则查找路由表或ARP表进行三层转发
使能三层转发功能的VLAN封装TRILL报文时使用三层Nickname作为Ingress Nickname
三层Nickname由系统自动生成,暂不支持配置
仅当设备配置三层转发功能时显示
RB拥有三层Nickname的优先级
仅当设备配置三层转发功能时显示
三层Nickname作为TRILL分发树根桥的优先级
仅当设备配置三层转发功能时显示
Cost style
开销类型,仅支持Wide类型
可接收的LSP最大长度
可生成的LSP最大长度
TRILL单播等价多路径的最大路径数
Overload status
过载标志位的置位原因:
·         Config:表示配置过载标志位置位
·         GR:表示在平滑重启中过载标志位置位
·         GR/Config:表示在Start类型的平滑重启中配置过载标志位置位
·         None:表示未配置过载标志位置位
Device role
设备角色:
·         Normal:表示普通RB
·         Access:表示二层接入设备
过载标志位保持置位状态的时间,单位为秒。N/A表示未配置此时间或此时间已超时
Timers
TRILL定时器
LSP-max-age
LSP的最大生存时间,单位为秒
LSP-refresh
LSP的刷新周期,单位为秒
依次为使用SPF(Shortest Path First,最短路径优先)算法进行路由计算的最大时间间隔(单位为秒)、最小时间间隔(单位为毫秒)和时间间隔惩罚增量(单位为毫秒)
display trill fib命令用来显示TRILL单播转发表信息。
display trill fib [ count | nickname nickname ]
count:显示表项的数量。
nickname nickname:显示指定RB的信息。nickname表示RB的Nickname,为0x1~0xFFFE的十六进制数。如果未指定本参数,将显示所有RB的信息。
# 显示TRILL单播转发表所有表项的信息。
<Sysname> display trill fib
Flags: T-Transit, E-Egress
Destination   HopCount   NextHop   Interface                 Flags
0xfa1b        63         N/A       N/A                       E
0x899b        63         0x2a5c    XGE1/0/1                   T
# 显示TRILL单播转发表的表项数量。
<Sysname> display trill fib count
Total number of TRILL FIB destinations: 1
Total number of TRILL FIB entries: 2
表1-3 display trill fib命令显示信息描述表
Destination
目的RB的Nickname
HopCount
到达目的RB的跳数
NextHop
下一跳RB的Nickname
报文的出端口
Flags
标志:
·         T:表示转发
·         E:表示出隧道
TRILL单播转发表中目的RB的数量
TRILL单播转发表的表项数量
display trill graceful-restart status命令用来显示TRILL的GR(Graceful Restart,平滑重启)状态信息。
# 显示TRILL的GR状态信息。
<Sysname> display trill graceful-restart status
Restart status: RESTARTING
Restart phase: LSDB synchronization
Restart interval: 300s
T3 remaining time: 140s
Total number of interfaces: 1
Number of waiting LSPs: 3
T2 remaining time: 55s
    T1 remaining time: 2s
    RA received: Y
    CSNP received: N
    T1 expiration number: 1
表1-4 display trill graceful-restart status显示信息描述表
Restart status
重启状态:
·         COMPLETE:表示平滑重启已完成
·         RESTARTING:表示正进行Restart类型的平滑重启
·         STARTING:表示正进行Start类型的平滑重启
Restart phase
重启阶段:
·         Finish:表示平滑重启已完成
·         LSDB synchronization:表示T2同步阶段
·         LSP generation:表示LSP生成阶段
·         MCS synchronization:表示二层组播数据同步阶段
·         SPF:表示路由计算阶段
Restart interval
重启间隔,单位为秒
T3 remaining time
T3定时器的超时剩余时间,单位为秒。初始值为65535秒,后续会根据RA报文中的剩余时间来更新
进程下的所有端口数
等待的LSP数量
T2 remaining time
T2定时器的超时剩余时间,单位为秒。对于Restart类型的GR,初始值固定为60秒;对于Start类型的GR,初始值为graceful-restart interval命令的配置值(缺省为300秒)
端口名称
T1 remaining time
T1定时器的超时剩余时间,单位为秒。初始值为3秒
RA received
RA接收标记位:
·         Y:表示置位
·         N:表示未置位
CSNP received
CSNP接收标记位:
·         Y:表示置位
·         N:表示未置位
T1定时器的超时次数。最大值为10次
仅Release 1138P01及以上版本支持本命令。
display trill ingress-route命令用来显示TRILL入流量的转发信息。
display trill ingress-route [ vlan vlan-list ]
vlan vlan-list:显示指定VLAN的信息。vlan-list为VLAN列表,表示多个VLAN。表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果未指定本参数,将显示所有VLAN的信息。
通过本命令可以显示流量进入TRILL网络的本地入端口,以及流量转发所使用的树根和出端口信息。
# 显示所有VLAN的TRILL入流量的转发信息。
<Sysname> display trill ingress-route
Total number of VLANs: 1
VLAN ID:
  1
List of local ports(in total: 1):
  XGE1/0/1
VLAN ID:
  1
Root nickname:
  0x5801
List of remote ports(in total: 2):
  XGE1/0/3
  XGE1/0/4
表1-5 display trill ingress-route命令显示信息描述表
VLAN总数
VLAN ID
VLAN的编号
流量进入TRILL网络的本地入端口及其总数
Root nickname
本VLAN转发组播流量所使用的TRILL分发树树根的Nickname
报文经TRILL封装后的转发出端口及其总数
display trill interface命令用来显示TRILL端口信息。
display trill interface [ interface-type interface-number | verbose ]
interface-type interface-number:显示指定端口的信息,interface-type interface-number为端口类型和端口编号。如果未指定本参数,将显示所有端口的信息。
verbose:显示详细信息。如果未指定本参数,将显示摘要信息。
# 显示所有TRILL端口的摘要信息。
<Sysname> display trill interface
Interface                   Protocol state   DRB  Cost      Link type
Ten-GigabitEthernet1/0/1        UP               Yes  2000      Access
# 显示所有TRILL端口的详细信息。
<Sysname> display trill interface verbose
Circuit ID: 0x01
Protocol state: UP
Nickname: 0xfa1b
MTU: 1470
DRB: Yes
Designated VLAN: 1
Link type: Access
CSNP timer: 10s
Hello timer: 10s
Hello multiplier: 3
LSP timer: 10ms
LSP transmit-throttle count: 5
Cost: 2000
AVF inhibited timer: 30s
Priority: 64
Track index: None
Track state: NotReady
Active AVF:
  1-3, 5, 58
Inhibited AVF: None
表1-6 display trill interface命令显示信息描述表
端口名称
Circuit ID
端口标识
Protocol state
TRILL协议的状态,包括UP和DOWN
Nickname
RB的Nickname
MTU
链路的MTU值,单位为字节
DRB
是否被选举为DRB:
·         Yes:表示已被选举为DRB
·         No:表示未被选举为DRB
·         Down:表示端口状态为down,不参与DRB的选举
Designated VLAN
当前生效的指定VLAN。如果显示为65535,表示端口down或端口下没有使能VLAN
Link type
TRILL端口的类型:
·         Access:表示Access类型
·         Hybrid:表示Hybrid类型
·         Trunk:表示Trunk类型
CSNP timer
CSNP报文的发送间隔,单位为秒
Hello timer
Hello报文发送间隔,单位为秒
Hello multiplier
Hello报文的失效数目
LSP timer
LSP的最小发送间隔,单位为毫秒
一次发送LSP的最大数目
Cost
端口的链路开销值
AVF inhibited timer
环路避免的抑制时间,单位为秒
Priority
DRB优先级
Track index
TRILL监测的Track项,None表示没有
本系列交换机暂不支持TRILL监测Track项
Track state
TRILL监测的Track项状态:
·         NotReady:表示没有监测任何Track项或未连接Track模块
·         Positive:表示状态正常
·         Negative:表示状态异常
Active AVF
当前端口上被DRB分配为AVF的VLAN,None表示没有
Inhibited AVF
当前端口上暂时被抑制的AVF的VLAN,None表示没有
display trill l3-forwarding active-vlan命令用来显示所有TRILL三层转发功能处于Active状态的VLAN。
只有满足下面条件的VLAN的TRILL三层转发状态为Active:
·            VLAN的TRILL三层转发功能处于开启状态;
·            VLAN接口状态为UP;
# 显示所有三层转发功能处于Active状态的VLAN。
<Sysname> display trill l3-forwarding active-vlan
Active VLANs:
1, 3, 5, 10-20
表1-7 display trill l3-forwarding active-vlan命令显示信息描述表
Active VLANs
display trill l3-forwarding adjacent-table命令用来显示TRILL三层转发邻接表信息。
display trill l3-forwarding adjacent-table [ count | nickname nickname interface interface-type interface-number mac mac-address ]
count:统计表项的数量。
nickname nickname interface interface-type interface-number mac mac-address:指定RB和出接口直连RB对应MAC的三层转发邻接表信息。nickname:表示RB的Nickname,为0x1~0xFFFE的十六进制数;interface-type interface-number:为端口类型和端口编号;mac-address:和出接口直连RB对应的MAC地址。
如果未指定任何可选参数,将显示所有TRILL三层转发邻接表信息。
# 显示TRILL三层转发邻接表的所有表项信息。
<Sysname> display trill l3-forwarding adjacent-table
# 显示TRILL三层转发邻接表的指定下一跳指定接口的表项信息。
<Sysname> display trill l3-forwarding adjacent-table nickname 0x899b interface Ten-GigabitEthernet 1/0/1 mac 00e0-fc58-123a
# 显示TRILL三层转发邻接表的表项数量
<Sysname> display trill l3-forwarding adjacent-table count
Total number of TRILL L3 ADJ entries: 3
表1-8 display trill l3-forwarding adjacent-table命令显示信息描述表
NextHop
报文转发的下一跳RB的Nickname,分为直连下一跳或远端下一跳,远端下一跳是和当前设备中间隔着其他RB
MAC address
报文转发的出接口直连RB的MAC地址
报文三层转发的出接口
TRILL三层转发邻接表的表项数量
display trill l3-forwarding fib命令用来显示TRILL三层单播转发表信息。
display trill l3-forwarding fib [ count | nickname nickname ]
count:显示表项的数量。
如果未指定任何可选参数,将显示所有TRILL三层单播转发表信息。
# 显示TRILL三层单播转发表所有表项的信息。
<Sysname> display trill l3-forwarding fib
0xfa1b        63         N/A       N/A                      E
# 显示TRILL三层单播转发表的表项数量。
<Sysname> display trill l3-forwarding fib count
Total number of TRILL L3 FIB destinations: 1
Total number of TRILL L3 FIB entries: 2
表1-9 display trill l3-forwarding fib命令显示信息描述表
Destination
目的RB的Nickname
HopCount
到达目的RB的跳数
NextHop
下一跳RB的Nickname,N/A表示目的地址是本机
报文的出接口,N/A表示目的地址是本机
Flags
标志:
·         T:表示转发
·         E:表示解封装后出TRILL隧道转发
TRILL三层单播转发表中目的RB的数量
TRILL三层单播转发表的表项数量
display trill l3-forwarding interface命令用来显示VLAN接口的TRILL三层转发状态信息。
display trill l3-forwarding interface [ vlan-interface interface-number ]
vlan-interface interface-number:显示指定VLAN接口的TRILL三层转发状态信息,其中interface-number表示VLAN接口的编号,取值范围为1~4094。如果不指定本参数,则显示所有开启了TRILL三层转发功能的VLAN接口信息。
仅当VLAN接口状态为UP时,对应VLAN的三层转发状态才为Active。
# 显示所有开启了TRILL三层转发功能的VLAN接口信息。
<Sysname> display trill l3-forwarding interface
Total number of Vlan-interfaces: 5
Interface           Protocol   Track ID   Track state   Flag   Forwarding
Vlan-interface1     UP         None       None          True   Active
Vlan-interface2     UP         1          NotReady      True   Active
Vlan-interface3     UP         512        Positive      False  Inactive
Vlan-interface4     DOWN       1024       Negative      True   Inactive
Vlan-interface1024  DOWN       1024       Positive      True   Inactive
表1-10 display trill l3-forwarding interface命令显示信息描述表
开启了TRILL三层转发功能的VLAN接口个数
接口名称
Protocol
VLAN接口的状态:
·         UP:表示VLAN接口的协议状态是连通的
·         DOWN:表示VLAN接口的协议状态不通
Track ID
Track项的序号
Track state
Track项的状态:
·         NotReady:表示无效值
·         Positive:表示状态正常
·         Negative:表示状态异常
·         None:表示未配置Track项
Flag
对应VLAN是否开启了TRILL三层转发功能:
·         True:表示开启
·         False:表示未开启
Forwarding
对应VLAN的三层转发状态:
·         Active:表示VLAN的三层转发状态处于激活状态
·         Inactive:表示VLAN的三层转发状态处于未激活状态
display trill l3-forwarding neighbor-table命令用来显示TRILL三层邻居表信息。
# 显示TRILL三层转发的邻居表信息。
<Sysname> display trill l3-forwarding neighbor-table
Total number of neighbors: 1
Neighbor   MAC address       Interface
表1-11 display trill l3-forwarding neighbor-table 命令显示信息描述表
邻居的总数,包括直连邻居和非直连邻居
Neighbor
邻居的Nickname
MAC address
到达邻居的下一跳RB的MAC地址
出端口
display trill l3-forwarding unicast-route命令用来显示TRILL三层转发单播路由表信息。
display trill l3-forwarding unicast-route [ nickname nickname ]
nickname nickname:显示指定RB上的TRILL三层转发单播路由表信息。nickname表示RB的Nickname,为0x1~0xFFFE的十六进制数。如果未指定本参数,将显示所有RB上的TRILL三层转发单播路由表信息。
# 显示TRILL三层转发单播路由表所有表项的信息。
<Sysname> display trill l3-forwarding unicast-route
Destinations: 2        Unicast routes: 2
Destination   Neighbor ID     MAC address     Interface
0xfa1b        0x0000          N/A             N/A
0x899b        0x01F5          00e0-fc58-123a  XGE1/0/1
表1-12 display trill l3-forwarding unicast-route 命令显示信息描述表
Destinations
目的RB的数量
Unicast routes
单播路由的条数
Destination
目的RB的Nickname
Neighbor ID
下一跳关联的邻居编号
MAC address
下一跳的MAC地址,N/A表示目的地址是本机
出端口,N/A表示目的地址是本机
display trill lsdb命令用来显示TRILL链路状态数据库信息。
display trill lsdb [ local | lsp-id lsp-id | verbose ] *
local:显示本地生成的LSP的信息。
lsp-id lsp-id:显示指定LSP的信息。lsp-id为LSP标识,形式为SYSID.Pseudonode ID-fragment num,其中,SYSID是产生该LSP的结点或伪结点的System ID,fragment num是该LSP的分片号。如果未指定本参数,将显示所有LSP的信息。
# 显示TRILL链路状态数据库的摘要信息。
<Sysname> display trill lsdb
Flags: * - Self LSP
LSP ID                 Seq num     Checksum  Holdtime  Length    Overload
00a0.fc00.5806.00-00*  0x00000005  0xd315    361       78        0
# 显示TRILL链路状态数据库的详细信息。
<Sysname> display trill lsdb verbose
LSP ID: 00a0.fc00.5806.00-00*
Sequence number: 0x00000005
Checksum: 0xd315
Holdtime: 1145s
Length: 78
Overload: 0
Source: 00a0.fc00.5806.00
TRILL version: 0x00
Nickname:
  Nickname: 0xfa1b
  Priority: 64
Trees:
  Compute trees number: 1
  Max compute trees number: 15
  Used trees number: 1
Tree identifiers:
  0x899b
Trees used identifiers:
  0x899b
Interested VLANs:
  Start: 4, End: 4, M4: 0, M6: 0
  Start: 5, End: 6, M4: 1, M6: 0
Neighbor:
  ID: 00e0.fc58.123a.01, Cost: 2000
Group address:
  VLAN ID: 2
  Group MAC address: 0100-5e01-0101
表1-13 display trill lsdb命令显示信息描述表
LSP ID
LSP标识,*表示是本地生成的LSP
Seq num/Sequence number
LSP的序列号
Checksum
LSP的校验和
Holdtime
LSP的生存剩余时间,单位为秒
Length
LSP的长度
Overload
LSP中Overload位的置位情况:
·         0:表示未置位
·         1:表示已置位
Source
生成此LSP的RB的编号
TRILL version
生成此LSP的RB支持的最高版本
Nickname
生成此LSP的RB的Nickname信息:
·         Nickname:RB的Nickname
·         Priority:占有Nickname的优先级
·         Tree-root priority:作为TRILL分发树根桥的优先级
Trees
生成此LSP的RB的TRILL分发树计算信息:
·         Compute trees number:希望整网计算的TRILL分发树数量
·         Max compute trees number:最多可计算的TRILL分发树数量
·         Used trees number:作为Ingress RB时使用的TRILL分发树数量
Tree identifiers
生成此LSP的RB作为根桥优先级最高的RB时,要求其它RB计算的TRILL分发树
生成此LSP的RB作为Ingress RB时使用的TRILL分发树
Interested VLANs
以生成此LSP的RB为AVF的VLAN信息:
·         Start:起始VLAN的编号
·         End:结束VLAN的编号
·         M4:在此VLAN范围内是否存在IPv4组播路由器。0表示存在,1表示不存在
·         M6:在此VLAN范围内是否存在IPv6组播路由器。0表示存在,1表示不存在
Neighbor
生成此LSP的RB的邻居信息:
·         ID:邻居的编号
·         Cost:到达此邻居的开销值
Group address
生成此LSP的RB的组播MAC地址信息:
·         VLAN ID:组播MAC地址所属VLAN
·         Group MAC address:关注的组播MAC地址
display trill mfib ingress命令用来显示TRILL组播转发表的入表项信息。
display trill mfib ingress [ vlan vlan-id [ local-entry | remote-entry ] ]
vlan vlan-id:显示指定VLAN内的信息,vlan-id的取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
local-entry:显示本地的入表项信息。本地入表项是指从该表项中的端口发出的报文无需进行TRILL封装。
remote-entry:显示远端的入表项信息。远端入表项是指从该表项中的端口发出的报文需要进行TRILL封装。
【使用指南】
如果未指定local-entry和remote-entry参数,将同时显示本地和远端的入表项信息。
# 显示TRILL组播转发表所有入表项的信息。
<Sysname> display trill mfib ingress
Ingress type: Local entry
  VLAN ID: 1
  Ports:
    XGE1/0/1
Ingress type: Remote entry
  VLAN ID: 1
  RootNickName: 0x5092
  Ports:
    XGE1/0/2
表1-14 display trill mfib ingress命令显示信息描述表
Ingress type
入表项的类型:
·         Local entry:表示本地入表项
·         Remote entry:表示远端入表项
VLAN ID
表项对应VLAN的编号
RootNickName
表项对应RB的Nickname
Ports
表项对应的端口
display trill mfib transit命令用来显示TRILL组播转发表的出表项信息。
display trill mfib transit [ nickname nickname [ prune-entry | rpf-entry | vlan vlan-id [ mac mac-address ] ] ]
prune-entry:显示被剪枝掉的表项的信息。如果未指定本参数,将显示所有表项的信息。
rpf-entry:显示RPF表项的信息。如果未指定本参数,将显示所有表项的信息。
mac mac-address:显示指定MAC地址的信息,mac-address为MAC地址。如果未指定本参数,将显示所有MAC地址的信息。
# 显示TRILL组播转发表所有出表项的信息。
<Sysname> display trill mfib transit
Transit type: RPF entry
  InNickName: 0x5092
  Port: XGE1/0/1
Transit type: RB entry
  Flag: Egress/Transit
  Ports:
    XGE1/0/1
Transit type: VLAN RB entry
  VLAN ID: 1
  Ports:
    XGE1/0/1
表1-15 display trill mfib transit命令显示信息描述表
Transit type
出表项的类型:
·         RB entry:表示RB表项
·         RPF entry:表示RPF表项
·         VLAN RB entry:表示指定VLAN的RB表项
·         MAC VLAN RB entry:表示指定MAC地址和VLAN的RB表项
RootNickName
表项对应RB的Nickname
InNickName
表项入口RB的Nickname
VLAN ID
表项对应VLAN的编号
MAC address
表项对应的MAC地址
Flag
表项的类型:
·         Egress:表示Egress表项
·         Transit:表示Transit表项
·         Egress/Transit:表示既是Egress表项又是Transit表项
Port/Ports
表项对应的端口
display trill multicast-route命令用来显示TRILL组播路由表信息,即基于组播分发树的组播报文的下一跳出端口列表。
display trill multicast-route [ tree-root nickname [ vlan vlan-list [ mac-address mac-address ] ] ]
tree-root nickname:显示以指定RB为TRILL分发树根桥的TRILL组播路由表信息。nickname表示RB的Nickname,为0x1~0xFFFE的十六进制数。如果未指定本参数,将显示所有TRILL组播路由表信息。
vlan vlan-list:显示指定VLAN内的信息。vlan-list为VLAN列表,表示多个VLAN。表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果未指定本参数,将显示所有VLAN内的信息。
mac-address mac-address:显示指定MAC地址的信息,mac-address为MAC地址。如果未指定本参数,将显示所有MAC地址的信息。
# 显示TRILL组播路由表所有表项的信息。
<Sysname> display trill multicast-route
Root                          Flag
0x899b                        Valid
# 显示以指定RB(Nickname为0x899B)为TRILL分发树根桥的TRILL组播路由表信息。
<Sysname> display trill multicast-route tree-root 899b
Root: 0x899b
LocalRcvFlag: True
List of VLANs:
  1 to 10, 13, 40, 60 to 85, 200, 1001
List of outgoing ports (4 in total):
  XGE1/0/1
  XGE1/0/2
  XGE1/0/3
  XGE1/0/4
# 显示VLAN 1内以指定RB(Nickname为0x899B)为TRILL分发树根桥的TRILL组播路由表信息。
<Sysname> display trill multicast-route tree-root 899b vlan 1
Root: 0x899b
VLAN: 1
LocalRcvFlag: False
List of outgoing ports (3 in total):
  XGE1/0/1
  XGE1/0/2
  XGE1/0/3
List of IPv4 multicast-router ports (2 in total):
  XGE1/0/1
  XGE1/0/2
List of MAC addresses (4 in total):
  0000-1111-00ee
  00ff-1111-00ff
  00ef-1111-00ef
  0000-111f-00ff
# 显示VLAN 1内以指定RB(Nickname为0x899B)为TRILL分发树根桥的、指定MAC地址(0011-11FF-0022)上的TRILL组播路由表信息。
<Sysname> display trill multicast-route tree-root 899b vlan 1 mac-address 0011-11ff-0022
Root: 0x899b
VLAN: 1
MAC address: 0011-11ff-0022
LocalRcvFlag: True
List of outgoing ports (2 in total):
  XGE1/0/3
  XGE1/0/4
表1-16 display trill multicast-route命令显示信息描述表
Root
作为TRILL分发树根桥的RB的Nickname
VLAN
VLAN的编号
MAC address
MAC地址
Flag
根桥是否有效:
·         Invalid:表示无效
·         Valid:表示有效
LocalRcvFlag
本地接收标识,即是否需要进行本地转发:
·         False:表示不需要进行本地转发
·         True:表示需要进行本地转发
出端口列表及其总数,None表示没有
List of VLANs (2 in total)
VLAN列表及其总数,None表示没有
IPv4组播路由器的端口列表及其总数
MAC地址列表及其总数
display trill neighbor-table命令用来显示TRILL邻居表信息。
# 显示TRILL邻居表信息。
<Sysname> display trill neighbor-table
Total number of nexthops: 3
表1-17 display trill neighbor-table命令显示信息描述表
下一跳的总数
NextHop
下一跳的Nickname
MAC address
下一跳的MAC地址
出端口
display trill peer命令用来显示TRILL邻居统计信息。
display trill peer [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定端口上的信息,interface-type interface-number为端口类型和端口编号。如果未指定本参数,将显示所有端口上的信息。
# 显示端口Ten-GigabitEthernet1/0/1上的TRILL邻居统计信息。
<Sysname> display trill peer interface ten-gigabitethernet 1/0/1
System ID: 00e0.fc58.123a
Circuit ID: 00e0.fc58.123a.01
State: Up
Holdtime: 8s
DRB priority: 64
Nickname: 0x899b
Uptime: 00:38:15
表1-18 display trill peer命令显示信息描述表
System ID
邻居的System ID
与邻居直连的本地TRILL端口
Circuit ID
伪节点的LSP编号
邻居状态,包括Up和Down
Holdtime
邻接关系保持时间,单位为秒。如果在该时间内未收到邻居发来的Hello报文,则认为与该邻居的邻接关系已失效;如果收到了,则重置此时间
DRB priority
邻居端口的DRB优先级
Nickname
邻居的Nickname
Uptime
与该邻居的邻接关系已保持的时间
display trill rpf-table命令用来显示TRILL RPF检查表信息。
display trill rpf-table tree-root nickname
tree-root nickname:显示以指定RB为TRILL分发树根桥的信息。nickname表示RB的Nickname,为0x1~0xFFFE的十六进制数。
TRILL RPF(Reverse Path Forwarding,逆向路径转发)检查表用来检查组播报文的入端口是否合法。即根据报文中Egress RB(即该报文所属TRILL分发树的根桥)和Ingress RB的Nickname,检查报文的实际入端口与RPF表项中的入端口是否一致,如不一致则认为该报文非法并将其丢弃。
# 显示以指定RB(Nickname为0x899B)为TRILL分发树根桥的TRILL RPF检查表信息。
<Sysname> display trill rpf-table tree-root 899b
Ingress-nickname           Expected-rcv-ports
0x1fff                     XGE1/0/1
0x1ff0                     XGE1/0/2
0x0ffe                     XGE1/0/3
表1-19 display trill rpf-table命令显示信息描述表
Ingress-nickname
Ingress RB的Nickname
Expected-rcv-ports
期望的入端口
display trill topology命令用来显示TRILL网络的拓扑信息。
display trill topology [ verbose ]
# 显示TRILL网络拓扑的摘要信息。
<Sysname> display trill topology
                         TRILL topology information
    Flags: O-Node is overloaded          R-Node is directly reachable
           D-Node or link is to be deleted
SPF node          Node flag    SPF link               Link cost  Link flag
0011.2200.0201.00 -/-/-
                               -->0011.2200.0301.01   20000      -
0011.2200.0301.01 -/R/-
                               -->0011.2200.0201.00   0          -
                               -->0011.2200.0301.00   0          -
0011.2200.0301.00 -/-/-
# 显示TRILL网络拓扑的详细信息。
<Sysname> display trill topology verbose
SPF node: 0011.2200.0201.00
  Node flag: -/-/-
  SPF links count: 1
    Link cost: 20000
    Link flag: -
    Link sources: 1
     Link source 1
       Type: Adjacent       Interface: N/A
       Cost: 20000          NextHop: N/A
SPF node: 0011.2200.0301.01
  Node flag: -/R/-
  SPF links: 2
    Link cost: 0
    Link flag: -
    Link sources count: 1
     Link source 1
       Type: Remote         Interface: N/A
       Cost: 0              NextHop: N/A
    Link cost: 0
    Link flag: -
    Link sources: 1
     Link source 1
       Type: Remote         Interface: XGE1/0/1
       Cost: 0              NextHop: 0x0002
SPF node: 0011.2200.0301.00
  Node flag: -/-/-
  SPF links: 1
    Link cost: 20000
    Link flag: -
    Link sources: 1
     Link source 1
表1-20 display trill topology命令显示信息描述表
SPF node
拓扑节点的编号
Node flag
节点的状态标记:
·         O:OverLoad状态,表示节点当前不可用
·         R:表示节点是直连节点
·         D:表示节点待删除
SPF link
拓扑链路
SPF links
拓扑链路的个数
Link cost
拓扑链路的开销
Link flag
链路状态标记,D表示链路待删除
Link sources
链路发布源的个数
Link source 1
 链路发布源的相关信息
链路发布源的类型:
·         Adjacent:表示由本地邻居维护产生
·         Remote:表示由其它节点的LSP产生
Cost
链路发布源的开销
display trill unicast-route命令用来显示TRILL单播路由表信息。
display trill unicast-route [ nickname nickname ] [ verbose ]
# 显示TRILL单播路由表所有表项的摘要信息。
<Sysname> display trill unicast-route
Destination    Interface                 NextHop
0xfa1b         N/A                       N/A
0x899b         XGE1/0/1                  Direct
# 显示TRILL单播路由表所有表项的详细信息。
<Sysname> display trill unicast-route verbose
Destination: 0xfa1b
NextHop count: 0             Neighbor ID: 0x0000
Destination: 0x899b
NextHop count: 1              Neighbor ID: 0x0101
Interface: XGE1/0/1           NextHop: Direct
表1-21 display trill unicast-route命令显示信息描述表
Destinations
目的RB的数量
Unicast routes
单播路由的条数
Destination
目的RB的Nickname
出端口
NextHop
下一跳的Nickname
NextHop count
下一跳的数量
Neighbor ID
下一跳关联的邻居编号
1.1.23  flash-flood
flash-flood命令用来开启LSP快速扩散功能。
undo flash-flood命令用来关闭LSP快速扩散功能。
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval ] *
undo flash-flood
LSP快速扩散功能处于关闭状态。
TRILL视图
flood-count flooding-count:表示扩散次数,取值范围为1~15,缺省值为5。
max-timer-interval flooding-interval:表示开始进行扩散的延迟时间,取值范围为0~50000,单位为毫秒,缺省值为0(表示立即扩散)。
LSP的变化会导致重新计算SPF。开启本功能后,设备会将导致SPF重新计算的LSP快速扩散出去,从而有效缩短拓扑变化时全网设备上LSDB不一致的时间,提高全网的快速收敛性能。
多次执行本命令,最后一次执行的命令生效。
# 开启LSP快速扩散功能,并配置LSP快速扩散的个数为10个、延迟时间为10毫秒。
[Sysname] trill
[Sysname-trill] flash-flood flood-count 10 max-timer-interval 10
flush-policy difference命令用来配置TRILL组播路由采用差异化下刷策略。
undo flush-policy difference命令用来恢复缺省情况。
TRILL组播路由未采用差异化下刷策略。
TRILL视图
TRILL组播路由表项分为RB表项、RB+VLAN表项和RB+VLAN+MAC表项三级。在特定的组网和配置下,如果TRILL组播路由相关的下级表项与上一级表项完全相同,此时只需下刷上一级表项便可正确指导转发,这便是差异化下刷策略,即仅当下级表项与上一级表项不同时才下刷。
例如:若一棵TRILL分发树的RB表项、RB+VLAN 1表项和RB+VLAN 1+MAC表项均相同,则只需下刷RB表项即可,VLAN 1中的TRILL数据报文可以直接查找RB表项进行转发。
需要注意的是,本命令只能应用在RB表项、RB+VLAN表项和RB+VLAN+MAC表项的出端口和本地标识都相同的特殊组网中,否则将导致大量表项同一时间集中下刷而使性能下降。
# 配置TRILL组播路由采用差异化下刷策略。
[Sysname] trill
[Sysname-trill] flush-policy difference
graceful-restart命令用来使能TRILL的GR能力。
undo graceful-restart命令用来关闭TRILL的GR能力。
graceful-restart
TRILL的GR能力处于关闭状态。
TRILL视图
# 使能TRILL的GR能力。
[Sysname] trill
[Sysname-trill] graceful-restart
graceful-restart interval命令用来配置TRILL的GR重启间隔。
TRILL的GR重启间隔为300秒。
TRILL视图
interval:表示TRILL的GR重启间隔,取值范围为30~1800,单位为秒。
# 配置TRILL的GR重启间隔为120秒。
[Sysname] trill
[Sysname-trill] graceful-restart interval 120
graceful-restart suppress-sa命令用来配置TRILL GR重启时抑制SA(Suppress-Advertisement)位置位(表示不置位)。
undo graceful-restart suppress-sa命令用来恢复缺省情况。
TRILL GR重启时SA位将被置位。
TRILL视图
SA表示抑制邻接标志位,将其置位的主要目的是避免出现路由黑洞,例如在启动或重启时没有保留本地转发表,此时如果GR Helper将报文送到设备来进行转发将造成严重的丢包现象。在这种情况下,GR Restarter发送的Hello报文中必须将SA位置位,而GR Helper收到这种SA位被置位的Hello报文后,将不会把发送该Hello报文的GR Restarter放入LSP中扩散出去。而对于启动速度要求较高的场景,则可以不配置TRILL GR重启时抑制SA位置位。
# 配置TRILL GR重启时抑制SA位置位。
[Sysname] trill
[Sysname-trill] graceful-restart suppress-sa
ingress assign-delay命令用来配置入流量分配给新TRILL分发树的延时时间。
undo ingress assign-delay命令用来恢复缺省情况。
ingress assign-delay delay
入流量分配给新TRILL分发树的延时时间为300秒。
TRILL视图
delay:入流量分配给新TRILL分发树的延时时间,取值范围为1~3600,单位为秒。
当入流量选择TRILL分发树的策略为负载均衡优先时,当新增一棵TRILL分发树时,为了让所有TRILL分发树来进行流量分担,Ingress RB需要将部分已分配给其它树的AVF VLAN重新分配给新树,以使新树分担本地流量的转发。但在其他RB尚未声明使用新树前,本地流量是无法使用新树进行转发的。因此,可以通过本命令来设置新树生效后,入流量分配给该树的延时时间。
# 配置入流量分配给新TRILL分发树的延时时间为600秒。
[Sysname] trill
[Sysname-trill] ingress assign-delay 600
·            ingress assign-rule load-balancing
ingress assign-rule load-balancing命令用来配置入流量选择TRILL分发树的策略为负载均衡优先。
undo ingress assign-rule命令用来恢复缺省情况。
入流量选择TRILL分发树的策略为稳定优先。
TRILL视图
入流量选择TRILL分发树的策略分为稳定优先(即尽量保持原分发树不变)和负载均衡优先(即入流量在全部分发树上进行负载分担)。
删除AVF VLAN时,在稳定优先策略下剩余AVF VLAN保持原分发树不变,在负载均衡优先策略下剩余AVF VLAN按负载均衡原则重新分配给各分发树。但添加、删除分发树、添加AVF VLAN时,不论在稳定优先策略还是负载均衡优先策略下,入流量都重新在全部分发树上进行负载均衡分配。因此本命令只影响减少AVF VLAN时对剩余AVF VLAN选择TRILL分发树的策略。
# 配置入表项选择TRILL分发树的策略为负载均衡优先。
[Sysname] trill
[Sysname-trill] ingress assign-rule load-balancing
·         仅FE、FX单板支持TRILL三层转发功能。
·         仅Release 1138P01及以上版本支持本命令。
l3-forwarding enable命令用来开启TRILL三层转发功能。
undo l3-forwarding enable命令用来恢复缺省情况。
TRILL三层转发功能处于关闭状态。
TRILL视图
设备上开启TRILL三层转发功能之后,可以转发本地网络中跨VLAN的、以及本地与外部网络之间的三层流量。
请在网关RB上开启本功能,接入层RB上不需要开启。
TRILL三层转发功能目前只支持IPv4类型的单播流量。
# 开启TRILL三层转发功能。
[Sysname] trill
[Sysname-trill] l3-forwarding enable
l3-forwarding vlan命令用来开启指定VLAN的TRILL三层转发功能。
undo l3-forwarding vlan命令用来关闭指定VLAN的TRILL三层转发功能。
l3-forwarding vlan { vlan-list | all }
undo l3-forwarding vlan { vlan-list | all  }
所有VLAN的TRILL三层转发功能均处于关闭状态。
TRILL视图
vlan-list:开启TRILL三层转发功能的VLAN列表。表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
all:表示开启所有VLAN的TRILL三层转发功能。
开启指定VLAN的三层转发功能之前,请为该VLAN创建VLAN接口并配置VLAN接口的IP地址。
设备和指定VLAN的TRILL三层转发功能均处于开启状态时,VLAN的三层转发功能才能生效。
# 开启VLAN 1~VLAN 100的TRILL三层转发功能。
[Sysname] trill
[Sysname-trill] l3-forwarding vlan 1 to 100
log-peer-change enable命令用来开启TRILL邻接状态输出开关。
undo log-peer-change enable命令用来关闭TRILL邻接状态输出开关。
邻接状态输出开关处于开启状态。
TRILL视图
开启邻接状态输出开关后,TRILL邻接状态的变化会输出到配置终端上。
# 关闭TRILL邻接状态输出开关。
[Sysname] trill
[Sysname-trill] undo log-peer-change enable
lsp-length originate命令用来配置RB可生成的LSP最大长度。
undo lsp-length originate命令用来恢复缺省情况。
lsp-length originate size
RB可生成的LSP最大长度为1458字节。
TRILL视图
LSP的实际最大长度将由本配置值、端口的MTU值和所有其它RB在LSP中携带的自身能生成的LSP最大长度这三者中的最小值来决定。
RB可生成的LSP最大长度不得大于RB可接收的LSP最大长度,否则系统将提示出错。
# 配置RB可生成的LSP最大长度为1024字节。
[Sysname] trill
[Sysname-trill] lsp-length originate 1024
·            lsp-length receive
lsp-length receive命令用来配置RB可接收的LSP最大长度。
undo lsp-length receive命令用来恢复缺省情况。
lsp-length receive size
RB可接收的LSP最大长度为1492字节。
TRILL视图
RB可接收的LSP最大长度不得小于RB可生成的LSP最大长度,否则系统将提示出错。
# 配置RB可接收的LSP最大长度为1024字节。
[Sysname] trill
[Sysname-trill] lsp-length receive 1024
·            lsp-length originate
max-unicast-load-balancing命令用来配置TRILL单播等价多路径的最大路径数。
undo max-unicast-load-balancing命令用来恢复缺省情况。
max-unicast-load-balancing number
TRILL单播等价多路径的最大路径数为32条。
TRILL视图
number:表示TRILL单播等价多路径的最大路径数,取值范围为1~32。取值为1表示不进行负载分担。
# 配置TRILL单播等价多路径的最大路径数为3条。
[Sysname] trill
[Sysname-trill] max-unicast-load-balancing 3
multicast multi-thread enable命令用来开启TRILL分发树计算支持多线程功能。
undo multicast multi-thread enable命令用来关闭TRILL分发树计算支持多线程功能。
TRILL分发树计算支持多线程功能处于关闭状态。
TRILL视图
在多核CPU设备上,可以开启TRILL分发树计算支持多线程功能,以提升TRILL分发树的计算效率。开启本功能后,每棵TRILL分发树将分别使用一个线程进行计算。
在单核CPU设备上开启本功能后,并不一定会带来效率的提升。
开启或关闭本功能,将会清除TRILL进程当前的动态运行数据。
# 开启TRILL分发树计算支持多线程功能。
[Sysname] trill
[Sysname-trill] multicast multi-thread enable
·            reset trill
multicast-ecmp enable命令用来开启TRILL组播等价多路径功能。
undo multicast-ecmp enable命令用来关闭TRILL组播等价多路径功能。
multicast-ecmp enable [ p2p-ignore ]
TRILL组播等价多路径功能处于关闭状态。
TRILL视图
p2p-ignore:表示在伪节点被旁路的等价路径上,只使用一条路径转发组播报文。如果未指定本参数,表示在伪节点被旁路的等价路径上,使用全部等价路径转发组播报文,这样可在最大程度上实现组播流量的负载分担。但当与第三方厂商的设备互通时,可能需要指定本参数以保证互通成功。仅Release 1138P01及以上版本支持本参数。
当TRILL组播等价多路径功能关闭时,由于根桥不同而使各分发树拓扑不同,从而可在一定程度上实现组播流量的负载分担,但并未利用开销相同的等价路径来分担流量;当开启该功能后,TRILL可将这些等价路径分给不同的分发树,从而实现更好的负载分担效果。
本功能的配置在TRILL网络中所有RB上应完全一致,否则可能导致组播流量不通。
# 开启TRILL组播等价多路径功能。
[Sysname] trill
[Sysname-trill] multicast-ecmp enable
1.1.38  nickname
nickname命令用来配置RB的Nickname。
undo nickname命令用来恢复缺省情况。
nickname nickname [ priority priority ]
undo nickname nickname
RB的Nickname由系统自动分配,其持有Nickname的优先级为64。
TRILL视图
nickname:表示RB的Nickname,为0x1~0xFFBF的十六进制数。
priority priority:表示RB持有Nickname的优先级,取值范围为129~255,缺省值为192。
Nickname是RB在TRILL网络中的地址。如果TRILL网络中不同RB拥有相同的Nickname,则优先级较高者保留此Nickname;如果优先级也相同,则System ID较大者保留此Nickname,其余RB再由系统为其自动分配一个新的Nickname。
# 配置RB的Nickname为0x0001,其持有Nickname的优先级为198。
[Sysname] trill
[Sysname-trill] nickname 0001 priority 198
1.1.39  ping trill
ping trill命令用来检查指定目的RB是否可达,并输出相应的统计信息。
ping trill [ -c count | -h ttl | -i interface-type interface-number | -m interval | -priority priority | -t timeout ] * nickname
-c count:指定发送Ping TRILL请求报文次数,取值范围为1~4294967295,缺省值为5。
-h ttl:指定Ping TRILL请求报文中的TTL值,取值范围为1~63,缺省值为63。
-i interface-type interface-number:指定发送Ping TRILL请求报文的接口的类型和编号。不指定本参数时,将使用TRILL单播路由表中的第一个出接口。
-m interval:指定发送Ping TRILL请求报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200毫秒。
-priority priority:指定Ping TRILL请求报文中内层以太网报文头的802.1p优先级,取值范围为0~7,缺省值为0。取值越大,802.1p优先级越高。
-t timeout:指定Ping TRILL应答报文的超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。发送Ping TRILL请求报文timeout时长后还没有收到应答报文,源端则认为应答报文超时。
nickname:指定目的端RB的Nickname,为0x1~0xFFBF的十六进制数。仅支持指定为目的端RB的二层Nickname(display trill brief命令显示信息的Nickname字段)。
在执行命令过程中,键入<Ctrl+C>可终止ping trill操作。
# 检查Nickname为0xbca3的目的RB是否可达。
<Sysname> ping trill bca3
Ping TRILL 0xbca3, press CTRL_C to break
reply from 0xbca3: seq=0 ttl=63 time=0.851 ms
reply from 0xbca3: seq=1 ttl=63 time=0.812 ms
reply from 0xbca3: seq=2 ttl=63 time=0.849 ms
reply from 0xbca3: seq=3 ttl=63 time=0.831 ms
reply from 0xbca3: seq=4 ttl=63 time=0.872 ms
--- Ping TRILL statistics for 0xbca3 ---
5 packet(s) transmitted, 5 packet(s) received, 0.00% packet loss
round-trip min/avg/max = 0.812/0.843/0.872 ms
表1-22 ping trill命令显示信息描述表
检查Nickname为0xbca3的目的RB设备是否可达,按组合键Ctrl+C可以终止本次Ping TRILL操作
收到Nickname为0xbca3的RB设备回复的响应报文,若应答报文时间超时仍没有收到响应报文,则输出Request time out
seq表示报文序号
ttl表示响应报文中的TTL值
time表示响应时间
Ping TRILL操作中收发数据的统计结果
发送的Ping TRILL请求报文数
收到的Ping TRILL响应报文数
0.00% packet loss
未响应请求报文占发送的总请求报文的百分比
响应时间的最小值、平均值和最大值,单位为毫秒
TRILL not configured.
设备没有开启TRILL 功能
1.1.40  reset trill
reset trill命令用来清除TRILL进程当前的动态运行数据。
reset trill
# 清除TRILL进程当前的动态运行数据。
<Sysname> reset trill
set ingress-load-balancing命令用来对TRILL分发树转发的流量进行手工均衡。
TRILL视图
当入流量选择TRILL分发树的策略为稳定优先时,当VLAN在各TRILL分发树上分布不均衡时,可使用本命令对TRILL分发树转发的流量进行手工均衡。
执行本命令可能影响当前某些报文的转发。
# 对TRILL分发树转发的流量进行手工均衡。
[Sysname] trill
[Sysname-trill] set ingress-load-balancing
set overload命令用来将LSP的过载标志位置位并配置保持置位状态的时间。
undo set overload命令用来恢复缺省情况。
set overload [ timeout ]
undo set overload
LSP的过载标志位未置位。
TRILL视图
timeout:表示过载标志位保持置位状态的时间,取值范围为5~3600,单位为秒。缺省值为无穷大,即一直保持置位状态直至取消配置。
请不要在作为TRILL分发树根桥的RB上配置本命令,否则将导致使用该根桥的流量转发不通。
# 将LSP的过载标志位置位,并配置保持置位状态的时间为1200秒。
[Sysname] trill
[Sysname-trill] set overload 1200
set-overload命令用来将LSP的过载标志位置位并配置保持置位状态的时间。
undo set-overload命令用来恢复缺省情况。
set-overload [ timeout ]
undo set-overload
LSP的过载标志位未置位。
TRILL视图
[Sysname] trill
[Sysname-trill] set-overload 1200
snmp context-name命令用来配置管理TRILL的SNMP实体所使用的上下文名称。
未配置管理TRILL的SNMP实体所使用的上下文名称。
TRILL视图
context-name:上下文的名称,为1~32个字符的字符串,区分大小写。
TRILL使用IS-IS的MIB(Management Information Base,管理信息库)对NMS(Network Management System,网络管理系统)提供TRILL对象的管理,但标准IS-IS MIB中定义的MIB为单实例管理对象,无法同时对IS-IS和TRILL进行管理。因此,参考RFC 4750中对OSPF多实例的管理方法,为管理TRILL定义一个上下文名称,以区分来自NMS的SNMP请求是要对IS-IS还是TRILL进行管理。
由于上下文名称只是SNMPv3独有的概念,因此对于SNMPv1/v2c,会将团体名映射为上下文名称以对不同协议进行区分。
# 配置管理TRILL的SNMP实体所使用的上下文名称为trill。
[Sysname] trill
[Sysname-trill] snmp context-name trill
snmp-agent trap enable trill命令用来开启TRILL的告警功能。
undo snmp-agent trap enable trill命令用来关闭TRILL的告警功能。
snmp-agent trap enable trill [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-drb | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
undo snmp-agent trap enable trill [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-drb | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
TRILL的告警功能处于开启状态。
adjacency-state-change:表示TRILL邻接状态变化的告警信息。
area-mismatch:表示Hello报文区域地址不匹配的告警信息。
buffsize-mismatch:表示LSP长度与产生缓冲区大小不匹配的告警信息。
id-length-mismatch:表示TRILL报文中System ID长度不匹配的告警信息。
lsdboverload-state-change:表示LSDB过载状态变化的告警信息。
lsp-parse-error:表示LSP解析错误的告警信息。
lsp-size-exceeded:表示超大LSP导致泛洪失败的告警信息。
max-seq-exceeded:表示LSP序列号超过最大序列号的告警信息。
maxarea-mismatch:表示Hello报文最大区域地址不匹配的告警信息。
new-drb:表示成为新DRB的告警信息。
own-lsp-purge:表示尝试清除本地LSP的告警信息。
protocol-support:表示报文协议支持类型不匹配的告警信息。
rejected-adjacency:表示Hello报文邻接不匹配丢弃的告警信息。
skip-sequence-number:表示跳过已产生过的LSP序列号的告警信息。
topology-change:表示AVF状态变化的告警信息。
version-skew:表示Hello报文版本号不匹配的告警信息。
如果未指定任何可选参数,表示开启或关闭TRILL的全部告警功能。
开启了TRILL的告警功能之后,TRILL会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭TRILL的全部告警功能。
[Sysname] undo snmp-agent trap enable trill
1.1.46  system-id
system-id命令用来配置RB的System ID。
undo system-id命令用来恢复缺省情况。
system-id system-id
undo system-id
RB启动后会根据自己的MAC地址自动生成一个System ID。
TRILL视图
system-id:表示RB的System ID,格式为xxxx.xxxx.xxxx,x代表十六进制数。
如果用户为RB新配置的System ID与原有的不同,系统将重置TRILL进程。
# 配置RB的System ID为1010.1020.1030。
[Sysname] trill
[Sysname-trill] system-id 1010.1020.1030
timer lsp-generation命令用来配置LSP重新生成的时间间隔。
undo timer lsp-generation命令用来恢复缺省情况。
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ]
LSP重新生成的最大时间间隔为2秒,最小时间间隔为10毫秒,时间间隔惩罚增量为20毫秒。
TRILL视图
maximum-interval:表示LSP重新生成的最大时间间隔,取值范围为1~120,单位为秒。
minimum-interval:表示LSP重新生成的最小时间间隔,取值范围为10~60000,单位为毫秒,必须为10的整数倍。最小时间间隔必须小于最大时间间隔。
incremental-interval:表示LSP重新生成的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒,必须为10的整数倍。时间间隔惩罚增量必须小于最大时间间隔。
网络拓扑的变化会导致重新生成LSP,通过调节LSP重新生成的时间间隔,可以抑制网络频繁变化可能导致的对带宽资源和设备资源的过多占用。在网络变化不频繁的情况下,将LSP重新生成的时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval。
# 配置LSP重新生成的最大时间间隔为10秒,最小时间间隔为100毫秒,时间间隔惩罚增量为200毫秒。
[Sysname] trill
[Sysname-trill] timer lsp-generation 10 100 200
timer lsp-max-age命令用来配置LSP的最大生存时间。
undo timer lsp-max-age命令用来恢复缺省情况。
timer lsp-max-age time
LSP的最大生存时间为1200秒。
TRILL视图
time:表示LSP的最大生存时间,取值范围为3~65535,单位为秒。
当RB生成一个LSP时,会将该LSP的最大生存时间作为LSP中的剩余生存时间告知其他RB。当LSDB中一个LSP的剩余生存时间为0时,说明该LSP已失效,RB将从LSDB中删除该LSP的内容,只保留其摘要,并将该LSP的剩余生存时间置0后泛洪给其他RB以清除此LSP。
需要注意的是,由于LSP的实际刷新时间会受LSP的最小发送间隔和一次发送LSP的最大数目的影响,因此请合理配置LSP的最大生存时间和刷新周期,以免LSP被意外老化。
# 配置LSP的最大生存时间为1500秒。
[Sysname] trill
[Sysname-trill] timer lsp-max-age 1500
·            timer lsp-refresh
·            trill timer lsp
timer lsp-refresh命令用来配置LSP的刷新周期。
undo timer lsp-refresh命令用来恢复缺省情况。
timer lsp-refresh time
LSP的刷新周期为900秒。
TRILL视图
time:表示LSP的刷新周期,取值范围为1~65534,单位为秒。
对于一个本地生成的LSP,当其剩余生存时间≤(最大生存时间-刷新周期)时,即使该LSP中的内容没有任何改变,也要重新更新此LSP,这样可避免网络中的LSP老化太频繁,保证网络稳定性。
# 配置LSP的刷新周期为1000秒。
[Sysname] trill
[Sysname-trill] timer lsp-refresh 1000
·            timer lsp-max-age
·            trill timer lsp
1.1.50  timer spf
timer spf命令用来配置TRILL使用SPF算法进行路由计算的时间间隔。
undo timer spf命令用来恢复缺省情况。
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
undo timer spf
TRILL使用SPF算法进行路由计算的最大时间间隔为10秒,最小时间间隔为10毫秒,时间间隔惩罚增量为20毫秒。
TRILL视图
maximum-interval:表示最大时间间隔,取值范围为1~120,单位为秒。
minimum-interval:表示最小时间间隔,取值范围为10~60000,单位为毫秒,必须为10的整数倍。最小时间间隔必须小于最大时间间隔。
incremental-interval:表示时间间隔惩罚增量,取值范围为10~60000,单位为毫秒,必须为10的整数倍。时间间隔惩罚增量必须小于最大时间间隔。
根据本地维护的LSDB,RB通过SPF算法算出以自己为根的最短路径树,并根据此树决定到达目的网络的下一跳。通过调节SPF算法的时间间隔,可抑制由于网络频繁变化而导致的带宽资源和设备资源的过多占用。
系统在网络变化不频繁时将连续路由计算的时间间隔缩小至minimum-interval,而在网络变化频繁时进行相应的惩罚,即增加incremental-interval×2n-2(n为连续触发路由计算的次数),但最大不超过maximum-interval。
# 配置TRILL使用SPF算法进行路由计算的最大时间间隔为15秒,最小时间间隔为100毫秒,时间间隔惩罚增量为200毫秒。
[Sysname] trill
[Sysname-trill] timer spf 15 100 200
tracert trill命令用来查看TRILL数据报文从本设备(Ingress节点)到指定目的RB(Egress节点)所经过的转发路径。
tracert trill [ -f first-ttl | -i interface-type interface-number | -m max-ttl | -priority priority | -q packet-number | -t timeout | -v [ -name ] ] * nickname
-f first-ttl:指定一个初始TTL,即第一个报文所允许的最大跳数。取值范围为0~63,且小于或等于最大TTL,缺省值为0。
-i interface-type interface-number:指定发送Tracert TRILL请求报文的接口的类型和编号。不指定本参数时,将使用TRILL单播路由表中的第一个出接口。
-m max-ttl:指定一个最大TTL,即一个报文所允许的最大跳数。取值范围为0~63,且大于或等于初始TTL,缺省值为63。
-priority priority:指定Tracert TRILL请求报文中内层以太网报文头的802.1p优先级,取值范围为0~7,缺省值为0。取值越大,802.1p优先级越高。
-q packet-number:指定每次发送的探测报文个数,取值范围为1~10,缺省值为3。
-t timeout:指定Tracert TRILL应答报文的超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。发送Tracert TRILL请求报文timeout时长后还没有收到应答报文,源端则认为应答报文超时。
-v:显示TRILL数据报文从本设备到目的RB所经过的转发路径的详细信息。不指定本参数时,将显示转发路径的概要信息。
-name:显示TRILL报文从本设备到目的RB所经过的转发路径的详细信息时,ReceivingPort和OutputPort显示接口名称。不指定本参数时,ReceivingPort和OutputPort仅显示端口标识。
当用户使用ping trill命令发现网络出现故障后,可以用tracert trill命令分析出现故障的网络节点。
tracert trill命令的输出信息包括到达Egress RB所经过的所有RB的Nickname,如果某设备不能回应错误消息(如中间设备支持TRILL但不支持tracert trill,该设备会转发tracert trill报文),则输出“* * *”。
在执行命令过程中,键入<Ctrl+C>可终止此次tracert trill操作。
# 查看TRILL数据报文从本设备(0xa456)到目的RB(0x2222)所经过路径的概要信息。
<Sysname> tracert trill 2222
TRILL traceroute to 0x2222, 63 hops at most, press CTRL_C to break
TTL RBridge Time
    0xa456
 0  0xb123  4.969 ms 4.651 ms 5.245 ms
 1  0x2222  4.067 ms 3.725 ms 3.708 ms
# 查看TRILL数据报文从本设备(0xa456)到目的RB(0x2222)所经过路径的详细信息。
<Sysname> tracert trill -v 2222
TTL  RBridge  ReceivingPort   OutputPort   NextHop  Time
     0xa456   Ingress         0x0001       0xb123
 0   0xb123   0x0001          0x0002       0x2222   4.093 ms 3.603 ms 3.657 ms
 1   0x2222   0x0001          Egress       0x0000   3.558 ms 3.277 ms 3.115 ms
# 查看TRILL报文从本设备(0xa456)到目的RB(0x2222)所经过路径的详细信息。
<Sysname> tracert trill -v –name 2222
  RBridge: 0xa456
  ReceivingPort: Ingress
  OutputPort: 0x0001(XGE1/0/1)
  NextHop: 0xb123
TTL 0
  RBridge: 0xb123
  ReceivingPort: 0x0001(XGE1/0/1)
  OutputPort: 0x0002(XGE1/0/2)
  NextHop: 0x2222
  Time: 4.093 ms 3.603 ms 3.657 ms
TTL 1
  RBridge: 0x2222
  OutputPort: Egress
  NextHop: 0x0000
  Time: 3.558 ms 3.277 ms 3.115 ms
# 查看TRILL数据报文到本机(0xa456)的概要路径信息。
<Sysname> tracert trill a456
TRILL traceroute to 0xa456, 63 hops at most, press CTRL_C to break
TTL RBridge Time
    0xa456
 0  0xa456  0.903 ms 0.857 ms 0.803 ms
# 查看TRILL数据报文到本机(0xa456)的详细路径信息。
<Sysname> tracert trill -v a456
     0xa456   Ingress        InLoop      0x0000
 0   0xa456   InLoop         Egress      0x0000   0.953 ms 0.832 ms 0.857 ms
表1-23 tracert trill命令显示信息描述表
查看TRILL报文从当前设备传到指定Egress RB(0x2222)所经过的路径
63 hops at most
探测报文的最大跳数,可使用-m参数配置
在执行命令过程中,键入<Ctrl+C>可终止此次Tracert TRILL操作
TTL
跳数
RBridge
发送应答报文的RB设备的Nickname,若应答报文时间超时仍没有收到响应报文,则输出“* * *”
ReceivingPort
接收报文的端口标识,指定-name参数时同时显示接口名称。包含下面特殊情况:
·         当前RB发起Tracert TRILL请求,显示Ingress
·         目的RB是当前设备,从环回口收到应答报文,显示InLoop
·         接口名称显示为N/A时表示对端不支持显示接口名称
未指定-name参数时,在相应设备上执行display trill interface verbose命令,也可以查看端口标识具体对应哪个接口
OutputPort
转发报文的端口标识,指定-name参数时同时显示接口名称。包含下面特殊情况:
·         目的RB是当前设备 ,请求报文从环回口发出,显示InLoop
·         目的RB返回应答报文,显示Egress
·         下一跳有多条等价路径时,显示ECMP
未指定-name参数时,在相应设备上执行display trill interface verbose命令,也可以查看端口标识(Circuit ID字段)具体对应哪个接口
NextHop
下一跳RB的Nickname:
·         如果是目的RB,显示0x0000
·         如果下一跳有多条等价路径,显示ECMP
Time
接收到每个应答报文的往返时间,单位为毫秒
每次发送探测报文的个数可以通过-q参数设置,默认是三个
设备没有开启TRILL功能
tree-root priority命令用来配置RB作为TRILL分发树根桥的优先级。
undo tree-root priority命令用来恢复缺省情况。
tree-root priority priority
RB作为TRILL分发树的根桥优先级为32768。
TRILL视图
priority:表示RB作为TRILL分发树根桥的优先级,取值范围为1~65535,数值越大优先级越高。
# 配置RB作为TRILL分发树根桥的优先级为65535。
[Sysname] trill
[Sysname-trill] tree-root priority 65535
trees calculate命令用来配置RB希望整网计算的TRILL分发树数量。
undo trees calculate命令用来恢复缺省情况。
trees calculate count
RB希望整网计算的TRILL分发树数量为1棵。
TRILL视图
count:表示RB希望整网计算的TRILL分发树数量,取值范围为1~15。
# 配置RB希望整网计算的TRILL分发树数量为2棵。
[Sysname] trill
[Sysname-trill] trees calculate 2
1.1.54  trill
trill命令用来全局使能TRILL协议,并进入TRILL视图。
undo trill命令用来全局关闭TRILL协议。
trill
undo trill
TRILL协议处于全局关闭状态。
# 全局使能TRILL协议,并进入TRILL视图。
[Sysname] trill
[Sysname-trill]
trill announcing-vlan命令用来配置通告VLAN。
undo trill announcing-vlan命令用来取消配置的通告VLAN。
trill announcing-vlan { vlan-list | null }
undo trill announcing-vlan { vlan-list | null }
未配置通告VLAN,此时通告VLAN与使能VLAN的范围相同。
二层以太网接口视图/二层聚合接口视图
vlan-list:通告VLAN的列表,表示多个通告VLAN。表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
null:表示通告VLAN为空集,即不包含任何VLAN。
RB之间的Hello报文,是通过一个VLAN集合来交互的,具体来说:
·            DRB在以下VLAN集合中发送Hello报文:使能VLAN ∩(指定VLAN ∪ 通告VLAN)。
·            非DRB在以下VLAN集合中发送Hello报文:使能VLAN ∩(指定VLAN ∪(通告VLAN ∩ AVF VLAN))。
由于TRILL端口会在上述VLAN集合的每个VLAN内都发送Hello报文,这样当VLAN集合较大时,设备会因发送大量Hello报文而占用过多CPU资源,从而无法及时处理其它协议的报文。为了避免这种情况,可以通过减少通告VLAN的范围来缩小VLAN集合的范围。
二层以太网接口视图下的配置只对当前端口生效;二层聚合接口视图下的配置对当前接口及其成员端口均生效;聚合成员端口上的配置,只有当成员端口退出聚合组后才能生效。
# 配置通告VLAN为VLAN 10~20。
[Sysname-Ten-GigabitEthernet1/0/1] trill announcing-vlan 10 to 20
# 配置通告VLAN为空集。
[Sysname-Ten-GigabitEthernet1/0/1] trill announcing-vlan null
·            trill designated-vlan
trill bypass-pseudonode enable命令用来开启旁路伪节点功能。
undo trill bypass-pseudonode enable命令用来关闭旁路伪节点功能。
旁路伪节点功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
开启本功能后,如果当前端口为DRB且只有一个邻居,则不再生成伪节点的LSP,以减少网络中LSP的数量。
# 在端口Ten-GigabitEthernet1/0/1上开启旁路伪节点功能。
[Sysname-Ten-GigabitEthernet1/0/1] trill bypass-pseudonode enable
1.1.57  trill cost
trill cost命令用来配置TRILL端口的链路开销值。
undo trill cost命令用来恢复缺省情况。
trill cost cost-value
undo trill cost
TRILL端口的链路开销值为2000。
二层以太网接口视图/二层聚合接口视图
cost-value:表示链路开销值,取值范围为1~16777214。
对于TRILL端口的链路开销值来说:如果进行了手工配置,则取配置值;如果没有手工配置且自动计算功能处于开启状态,则取自动计算值;如果没有手工配置且自动计算功能处于关闭状态,则取缺省值2000。
手工配置时,请确保本端和对端TRILL端口的链路开销值相同。
# 配置TRILL端口Ten-GigabitEthernet1/0/1的链路开销值为20000。
[Sysname-Ten-GigabitEthernet1/0/1] trill cost 20000
·            auto-cost enable
trill designated-vlan命令用来配置指定VLAN。
undo trill designated-vlan命令用来恢复缺省情况。
trill designated-vlan vlan-id
未配置指定VLAN,此时指定VLAN由系统从使能VLAN中自动选出。
二层以太网接口视图/二层聚合接口视图
vlan-id:表示指定VLAN,取值范围为1~4094。
而除Hello报文外的其它TRILL协议报文和本地数据报文,则全部通过指定VLAN来交互。因此,请确保所配置的指定VLAN处于使能VLAN的范围内,否则可能导致TRILL邻居无法建立或TRILL数据报文无法转发。
# 配置指定VLAN为VLAN 2。
[Sysname-Ten-GigabitEthernet1/0/1] trill designated-vlan 2
·            trill announcing-vlan
trill drb-priority命令用来配置TRILL端口的DRB优先级。
undo trill drb-priority命令用来恢复缺省情况。
trill drb-priority priority
TRILL端口的DRB优先级为64。
二层以太网接口视图/二层聚合接口视图
priority:表示TRILL端口的DRB优先级,取值范围为0~127,数值越大优先级越高。
当网络类型为广播网时,TRILL需要选举DRB:DRB优先级较高的RB优先被选中为DRB;若两个RB的DRB优先级相同,则MAC地址最大者会被选为DRB。
# 配置TRILL端口Ten-GigabitEthernet1/0/1的DRB优先级为2。
[Sysname-Ten-GigabitEthernet1/0/1] trill drb-priority 2
1.1.60  trill enable
trill enable命令用来在端口上使能TRILL协议。
undo trill enable命令用来在端口上关闭TRILL协议。
trill enable
undo trill enable
端口上的TRILL协议处于关闭状态。
二层以太网接口视图/二层聚合接口视图
·            在端口上使能TRILL协议之前,必须先全局使能TRILL协议。
·            组网和配置时请避免同一VLAN的成员端口中既有TRILL端口又有非TRILL端口。
·            在端口上使能TRILL协议之前,请先关闭端口(使用shutdown命令),使能端口的TRILL协议并配置好端口所属VLAN后再开启端口(使用undo shutdown命令),以避免配置未完成前形成环路。
·            TRILL端口上不允许使能生成树协议。由于所有端口上的生成树协议在缺省情况下均处于使能状态,全局使能生成树协议后,端口上的生成树协议立即生效,因此,全局使能生成树协议后,请在TRILL端口上手动关闭生成树协议。有关生成树的详细介绍,请参见“二层技术-以太网交换配置指导”中的“生成树”。
·            二层以太网接口视图下的配置只对当前端口生效;二层聚合接口视图下的配置对当前接口及其成员端口均生效;聚合成员端口上的配置,只有当成员端口退出聚合组后才能生效。
# 全局使能TRILL协议,并在端口Ten-GigabitEthernet1/0/1上使能TRILL协议。
[Sysname] trill
[Sysname-trill] quit
[Sysname-Ten-GigabitEthernet1/0/1] trill enable
·            trill
trill link-type命令用来配置TRILL端口的类型。
undo trill link-type命令用来恢复缺省情况。
trill link-type { access [ alone ] | hybrid | trunk }
TRILL端口的类型为Access类型(非Alone属性)。
二层以太网接口视图/二层聚合接口视图
access [ alone ]:表示Access类型。如果未指定alone参数,表示非Alone属性的Access端口,此类端口只能处理本地数据报文和Hello报文;如果指定了alone参数,表示Alone属性的Access端口,此类端口不会收、发Hello报文,不参与DRB选举和AVF协商。
hybrid:表示Hybrid类型。该类型的端口同时具有Access和Trunk的属性,能够处理本地数据报文和过路数据报文。
trunk:表示Trunk类型。该类型的端口能够处理过路数据报文和部分二层协议报文(如LLDP报文),不能处理本地数据报文。
# 配置TRILL端口Ten-GigabitEthernet1/0/1的类型为Trunk类型。
[Sysname-Ten-GigabitEthernet1/0/1] trill link-type trunk
trill timer avf-inhibited命令用来配置环路避免的抑制时间。
undo trill timer avf-inhibited命令用来恢复缺省情况。
trill timer avf-inhibited time
环路避免的抑制时间为30秒。
二层以太网接口视图/二层聚合接口视图
time:表示环路避免的抑制时间,取值范围为0~30,单位为秒。
AVF的存在保证了在一条链路上与一个VLAN相关的报文,只会有唯一的出口或入口,其他RB收到与该VLAN相关的报文时将不做任何处理。然而,当RB发现链路上的根桥发生了变化,或其他RB宣称的AVF与本RB的AVF发生冲突时,会将相关的AVF抑制一段时间以避免环路的产生。抑制时间超时后,如果本RB仍是该VLAN的AVF,则重新履行AVF的职能。
#在端口Ten-GigabitEthernet1/0/1上配置环路避免的抑制时间为20秒。
[Sysname-Ten-GigabitEthernet1/0/1] trill timer avf-inhibited 20
trill timer csnp命令用来配置CSNP报文的发送间隔。
undo trill timer csnp命令用来恢复缺省情况。
trill timer csnp interval
CSNP报文的发送间隔为10秒。
二层以太网接口视图/二层聚合接口视图
interval:表示CSNP报文的发送间隔,取值范围为1~600,单位为秒。
当网络类型为广播网时,DRB定期发送CSNP报文进行全网的LSDB同步。CSNP报文记录了本地LSDB中的所有LSP摘要,当一个RB收到一个CSNP报文时,就会与本地的LSDB进行比较,检查其中的LSP是否有老化和缺失。如果CSNP报文中有某个LSP摘要而本地LSDB中没有,RB将发送PSNP报文以请求获取该LSP的信息。
# 在端口Ten-GigabitEthernet1/0/1上配置CSNP报文的发送间隔为15秒。
[Sysname-Ten-GigabitEthernet1/0/1] trill timer csnp 15
trill timer hello命令用来配置Hello报文的发送间隔。
undo trill timer hello命令用来恢复缺省情况。
trill timer hello interval
Hello报文的发送间隔为10秒。
二层以太网接口视图/二层聚合接口视图
interval:表示Hello报文的发送间隔,在Release 1135版本上取值范围为3~255,在Release 1138P01及以上版本上取值范围为1~255,单位为秒。
RB定期发送Hello报文以维持邻接关系。Hello报文的发送间隔越短,网络收敛越快,但也会占用更多的系统资源。
Hello报文的发送间隔与失效数目的乘积为邻接关系保持时间,即RB监测到链路失效并进行路由重计算的时间。RB通过Hello报文将邻接关系保持时间通知给其邻居,若该邻居在邻接关系保持时间内未收到此报文,便宣告邻接关系失效。
本命令用来配置RB发送Hello报文的时间间隔,而DRB发送Hello报文的时间间隔则为RB的1/3,以保证DRB失效后可被快速检测到。
Hello报文的发送间隔与失效数目的乘积不允许超过65535。
# 在端口Ten-GigabitEthernet1/0/1上配置Hello报文的发送间隔为20秒。
[Sysname-Ten-GigabitEthernet1/0/1] trill timer hello 20
·            trill timer holding-multiplier
trill timer holding-multiplier命令用来配置Hello报文的失效数目。
undo trill timer holding-multiplier命令用来恢复缺省情况。
trill timer holding-multiplier count
undo trill holding-multiplier
Hello报文的失效数目为3个。
二层以太网接口视图/二层聚合接口视图
count:表示Hello报文的失效数目,在Release 1135版本上取值范围为3~1000,在Release 1138P01及以上版本上取值范围为2~1000。
# 在端口Ten-GigabitEthernet1/0/1上配置Hello报文的失效数目为6。
[Sysname-Ten-GigabitEthernet1/0/1] trill timer holding-multiplier 6
·            trill timer hello
trill timer lsp命令用来配置LSP的最小发送间隔和一次发送的最大数目。
undo trill timer lsp命令用来恢复缺省情况。
trill timer lsp interval [ count count ]
LSP的最小发送间隔为10毫秒,一次发送LSP的最大数目为5个。
二层以太网接口视图/二层聚合接口视图
interval:表示LSP的最小发送间隔,取值范围为10~1000,步长为10,单位为毫秒。
count:表示一次发送LSP的最大数目,取值范围为1~1000。
为了避免网络中的LSP老化太频繁,RB需要定期发送LSP,以使全网RB上的LSDB和路由计算保持稳定有效。
# 在端口Ten-GigabitEthernet1/0/1上配置LSP的最小发送间隔为500毫秒,一次发送LSP的最大数目为10个。
[Sysname-Ten-GigabitEthernet1/0/1] trill timer lsp 500 count 10
