04-WLAN定位命令
本章节下载: 04-WLAN定位命令 (226.42 KB)
1.1.1 display wlan ap all feature location-aware
1.1.2 display wlan rfid-tracking radio
1.1.4 rfid-tracking aeroscout aggregate-report interval
1.1.5 rfid-tracking aeroscout engine-address
1.1.6 rfid-tracking aeroscout engine-detection
1.1.7 rfid-tracking aeroscout report-mode
1.1.8 rfid-tracking aeroscout tag-multicast-address
1.1.9 rfid-tracking aeroscout timestamp
1.1.10 rfid-tracking aeroscout vendor-port
1.1.11 rfid-tracking client rate-limit
1.1.12 rfid-tracking client rate-limit cir
1.1.14 rfid-tracking dilution factor
1.1.15 rfid-tracking fingerprint
1.1.16 rfid-tracking fingerprint engine-address
1.1.17 rfid-tracking fingerprint mu-report
1.1.18 rfid-tracking fingerprint raw-frame-report
1.1.19 rfid-tracking fingerprint report-format
1.1.20 rfid-tracking fingerprint report-mode
1.1.21 rfid-tracking fingerprint tag-multicast-address
1.1.22 rfid-tracking fingerprint vendor-port
1.1.23 rfid-tracking ignore ap-frame
1.1.24 rfid-tracking ignore beacon
1.1.25 rfid-tracking keepalive
1.1.28 rfid-tracking rate-limit
1.1.29 rfid-tracking rate-limit cir
1.1.31 rfid-tracking rssi threshold
1.1.32 snmp-agent trap enable wlan location-aware
display wlan ap all feature location-aware命令用来显示WLAN定位功能的开关状态。
# 显示WLAN定位功能的开关状态。
<Sysname> display wlan ap all feature location-aware
AP name AeroScout BLE CUPID Fingerprint IoT
ap1 Disabled Disabled Disabled Disabled Disabled
表1-1 display wlan ap all feature location-aware命令显示信息描述表
AP name |
AP的名称 |
AeroScout |
AeroScout定位当前状态: · Enabled:开启 · Disabled:关闭 |
BLE |
BLE定位当前状态: · Enabled:开启 · Disabled:关闭 |
CUPID |
CUPID定位当前状态: · Enabled:开启 · Disabled:关闭 |
Fingerprint |
Fingerprinting定位类型的状态: · Enabled:开启 · Disabled:关闭 |
IoT |
IoT定位当前状态: · Enabled:开启 · Disabled:关闭 |
display wlan rfid-tracking radio命令用来查看定位的射频信息。
display wlan rfid-tracking radio [ ap ap-name ]
ap ap-pname:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。如果不指定本参数,则显示所有AP的定位射频信息。
# 显示定位的射频信息。
<Sysname> display wlan rfid-tracking radio
Wireless Locating
AP name Radio ID Type
ap1 1 MU/Tag
ap2 1 MU
ap3 2 Tag
ap4 1 N/A
表1-2 display wlan rfid-tracking radio命令显示信息描述表
AP name |
AP名称 |
Radio ID |
射频ID |
Type |
定位模式: · MU/Tag:兼容MU和Tag两种模式 · MU:MU模式 · Tag:Tag模式 · N/A:未配置定位模式 |
rfid-tracking aeroscout enable命令用来开启AeroScout定位功能。
rfid-tracking aeroscout disable命令用来关闭AeroScout定位功能。
undo rfid-tracking aeroscout命令用来恢复缺省情况。
rfid-tracking aeroscout { disable | enable }
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
全局配置视图:AeroScout定位功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启AeroScout无线定位功能将触发AP对所有支持的信道进行扫描,并将捕获到的无线报文封装成定位报文发送给AeroScout定位服务器。如果无需定位所有信道上的设备,且不影响其它业务的情况下,可以配置信道扫描黑名单或信道扫描白名单让AP仅对特定信道进行扫描。有关信道扫描黑白名单的详细介绍请参见“射频资源管理配置指导”中的“信道扫描”。
只有同时开启了AeroScout定位功能和Radio定位功能后,AP才会将Radio接口收到的无线报文封装成定位报文发送给定位服务器。
# 开启AeroScout定位功能。(AP视图)
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout enable
# 开启AeroScout定位功能。(AP组视图)
[Sysname] wlan ap-group 10
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout enable
# 开启AeroScout定位功能。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] rfid-tracking aeroscout enable
· rfid-tracking radio
rfid-tracking aeroscout aggregate-report interval命令用来配置MU定位组装报文的上报时间间隔。
undo rfid-tracking aeroscout aggregate-report interval命令用来恢复缺省情况。
rfid-tracking aeroscout aggregate-report interval interval
AP组视图:继承全局配置。
全局配置视图:未配置MU定位组装报文的上报时间间隔,AP直接上报MU定位报文,不进行MU定位报文组装。
AP视图
AP组视图
全局配置视图
interval:指定MU定位组装报文的上报时间间隔,取值范围为100~600000,单位为毫秒。
AP每收到一个MU定位报文都会立即上报给AeroScout定位服务器,导致占用过多的网络资源。配置本功能后,当AP收到MU定位报文时,会对MU定位报文进行组装。当组装的定位报文长度达到1400字节或者到达配置的时间间隔时,AP就会将组装的MU定位报文发送给AeroScout定位服务器,从而有效地节约网络资源。
在AeroScout定位方式为静态定位时,可以配置MU定位组装报文的上报时间间隔。在AeroScout定位方式为动态定位时,此配置不生效。
# 配置MU定位组装报文的上报时间间隔为100毫秒。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout aggregate-report interval 100
# 配置MU定位组装报文的上报时间间隔为100毫秒。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout aggregate-report interval 100
# 配置MU定位组装报文的上报时间间隔为100毫秒。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout aggregate-report interval 100
· rfid-tracking aeroscout
rfid-tracking aeroscout engine-address命令用来配置AeroScout定位服务器的IPv4地址和端口号。
undo rfid-tracking aeroscout engine-address命令用来恢复缺省情况。
rfid-tracking aeroscout engine-address engine-address engine-port engine-port
undo rfid-tracking aeroscout ble engine-address
AP组视图:继承全局配置。
全局配置视图:未配置AeroScout定位服务器的IPv4地址和端口号。
AP视图
AP组视图
全局配置视图
engine-address engine-address:AeroScout定位服务器的IPv4地址。
engine-port engine-port:AeroScout定位服务器的端口号,取值范围为1~65535。
在AeroScout定位方式为静态定位时必须执行本配置,动态定位时无需配置,且不生效。
# 配置AeroScout定位服务器的IPv4地址为192.168.10.10,端口号为3000。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout engine-address 192.168.10.10 engine-port 3000
# 配置AeroScout定位服务器的IPv4地址为192.168.10.10,端口号为3000。(AP组视图)
[Sysname-wlan-ap-group10] rfid-tracking aeroscout engine-address 192.168.10.10 engine-port 3000
# 配置AeroScout定位服务器的IPv4地址为192.168.10.10,端口号为3000。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout engine-address 192.168.10.10 engine-port 3000
· rfid-tracking aeroscout engine-detection
rfid-tracking aeroscout engine-detection命令用来配置AeroScout无线定位方式。
undo rfid-tracking aeroscout engine-detection命令用来恢复缺省情况。
rfid-tracking aeroscout engine-detection { dynamic | static }
AP组视图:继承全局配置。
全局配置视图:AeroScout无线定位方式为静态方式。
AP视图
AP组视图
全局配置视图
dynamic:动态方式。
static:静态方式。
AeroScout定位分为动态定位和静态定位,需要根据使用的AeroScout定位服务器是否支持向AP发起动态协商来选择定位方式。
· 动态定位:该方式下,AP支持与AeroScout定位服务器进行动态协商,定位服务器在协商过程中获取AP支持的AeroScout定位版本、AP的设备和状态信息;AP也将从定位服务器获取定位参数,包括Tag设备发送报文的目的MAC地址、报文稀释参数、定位服务器的IP地址和端口号。完成上述协商过程后,定位服务器会向AP发送定位信息收集通知,AP收到通知后才会将收集的定位信息发送给定位服务器。
· 静态定位:当使用的定位服务器不支持与AP进行动态协商时,需要选择该方式。该方式下,AP仅接收来自AC的定位参数,因此需要在AC上配置AP进行定位所需的相关参数。静态定位方式下,只要AP获取到定位服务器的IP地址和端口号,就可以向定位服务器发送定位报文。当使用的定位服务器不支持与AP进行动态协商时,需要选择定位方式为静态定位。
# 配置AeroScout无线定位方式为动态方式。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout engine-detection dynamic
# 配置AeroScout无线定位方式为动态方式。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout engine-detection dynamic
# 配置AeroScout无线定位方式为动态方式。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout engine-detection dynamic
rfid-tracking aeroscout report-mode命令用来配置AeroScout定位报文上报模式。
undo rfid-tracking report-mode命令用来恢复缺省情况。
rfid-tracking aeroscout report-mode { central | local }
AP组视图:继承全局配置。
全局配置视图:AeroScout定位报文上报模式为本地上报。
AP视图
AP组视图
全局配置视图
central:集中上报模式,即AP将定位信息封装为定位报文后先发送给AC,再由AC将定位报文发送给定位服务器。
local:本地上报模式,即AP将定位信息封装为定位报文后直接发送给定位服务器。
# 配置AeroScout定位报文上报模式为集中上报模式。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout report-mode central
# 配置AeroScout定位报文上报模式为集中上报模式。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout report-mode central
# 配置AeroScout定位报文上报模式为集中上报模式。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout report-mode central
rfid-tracking aeroscout tag-multicast-address命令用来配置AeroScout定位方式下Tag设备的组播MAC地址。
undo rfid-tracking aeroscout tag-multicast-address命令用来恢复缺省情况。
rfid-tracking aeroscout tag-multicast-address mac-address
AP组视图:继承全局配置。
全局配置视图:未配置Tag设备的组播MAC地址。
AP视图
AP组视图
全局配置视图
mac-address:Tag设备的组播MAC地址,格式为H-H-H。
Tag设备发送报文的目的MAC地址为设备厂家指定的组播MAC地址,将其配置并下发给AP后,AP才能识别报文来自Tag设备或MU设备,并将报文中的定位信息封装为指定设备类型的定位报文后发送给定位服务器。
如果未配置Tag设备的组播MAC地址,AP会认为所接收的802.11报文全部来自MU设备。
仅在AeroScout定位方式为静态定位时才需要此配置,动态定位时无需配置,且不生效。
# 配置AeroScout定位方式下Tag设备的组播MAC地址为0134-ed66-8923。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout tag-multicast-address 0134-ed66-8923
# 配置AeroScout定位方式下Tag设备的组播MAC地址为0134-ed66-8923。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout tag-multicast-address 0134-ed66-8923
# 配置AeroScout定位方式下Tag设备的组播MAC地址为0134-ed66-8923。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout tag-multicast-address 0134-ed66-8923
rfid-tracking aeroscout timestamp命令用来配置AeroScout定位方式下封装MU客户端报文的时间戳类型。
undo rfid-tracking aeroscout timestamp命令用来恢复缺省情况。
rfid-tracking aeroscout timestamp { absolute | relative }
AP组视图:继承全局配置。
全局配置视图:封装MU客户端报文的时间戳类型为相对时间。
AP视图
AP组视图
全局配置视图
absolute:时间戳类型为绝对时间戳,即1970年以来到接收客户端报文的时间,单位为毫秒。
relative:时间戳类型为相对时间戳,即系统启动以来到接收客户端报文的时间,单位为毫秒。
对Tag报文仅支持封装相对时间戳,对于MU报文,当定位服务器为某特定厂商定位服务器时仅支持封装为绝对时间戳,否则只能封装为相对时间戳。
# 配置为MU客户端报文封装的时间戳类型为绝对时间。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout timestamp absolute
# 配置为MU客户端报文封装的时间戳类型为绝对时间。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout timestamp absolute
# 配置为MU客户端报文封装的时间戳类型为绝对时间。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout timestamp absolute
rfid-tracking aeroscout vendor-port命令用来配置AeroScout定位方式下AP需要监听的端口号。
undo rfid-tracking aeroscout vendor-port命令用来恢复缺省情况。
rfid-tracking aeroscout vendor-port vendor-port-number
AP组视图:继承全局配置。
全局配置视图:AeroScout定位方式下AP需要监听的端口号为1144。
AP视图
AP组视图
全局配置视图
vendor-port-number:AeroScout定位方式下AP需要监听的端口号,取值范围为1~65535。
定位服务器与AP进行报文交互的过程中,向AP的某个端口号发送报文,AP需要监听该端口号,才能进行响应。
在AeroScout定位方式为静态定位时,AP不对监听端口收到的报文进行响应。
# 配置AeroScout定位方式下AP需要监听的端口号为3000。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking aeroscout vendor-port 3000
# 配置AeroScout定位方式下AP需要监听的端口号为3000。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking aeroscout vendor-port 3000
# 配置AeroScout定位方式下AP需要监听的端口号为3000。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking aeroscout vendor-port 3000
rfid-tracking client rate-limit enable命令用来开启AP接收客户端报文的限制速率功能。
rfid-tracking client rate-limit disable命令用来关闭AP接收客户端报文的限制速率功能。
undo rfid-tracking client rate-limit命令用来恢复缺省情况。
rfid-tracking client rate-limit { disable | enable }
AP组视图:继承全局配置。
全局配置视图:AP接收客户端报文的限制速率功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启AP接收客户端报文的限制速率功能后,AP将按照令牌桶算法对从定位设备接收到的报文进行速率限制。当某个定位设备以高于承诺信息速率的速率发送无线报文,并且令牌桶中的令牌已用完时,AP不会对超出的报文做定位相关处理,即不进行定位报文的封装上报工作。使用本功能保障每个客户端的定位信息都能均等地发送至定位服务器,也可以避免AP处理过多报文,从而保障AP的定位功能正常运行。
如果同时开启本功能和报文稀释功能,将对稀释后的报文进行速率限制。
本命令仅在AeroScout定位方式和指纹定位方式下生效。
# 开启AP接收客户端报文的限制速率功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking client rate-limit enable
# 开启AP接收客户端报文的限制速率功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking client rate-limit enable
# 开启AP接收客户端报文的限制速率功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking client rate-limit enable
· rfid-tracking fingerprint
· rfid-tracking client rate-limit cir
rfid-tracking client rate-limit cir命令用来配置AP接收客户端报文的限制速率。
undo rfid-tracking client rate-limit cir命令用来恢复缺省情况。
rfid-tracking client rate-limit cir cir [ cbs cbs ]
AP组视图:继承全局配置。
全局配置视图:承诺信息速率和承诺突发尺寸为0,即AP不对接收客户端报文的速率进行限制。
AP视图
AP组视图
全局配置视图
cir cir:AP接收客户端报文的承诺信息速率,取值范围为1~1300000,单位为Kbps。
cbs cbs:AP接收客户端报文的承诺突发尺寸,取值范围为80~130000000,单位为bytes,缺省值为cir × 700。
开启AP接收客户端报文的限制速率后,配置的AP接收客户端报文的承诺信息速率和承诺突发尺寸才会生效。
# 配置AP接收客户端报文的承诺信息速率为200000Kbps,承诺突发尺寸为50000bytes。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking client rate-limit cir 200000 cbs 50000
# 配置AP接收客户端报文的承诺信息速率为200000Kbps,承诺突发尺寸为50000bytes。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking client rate-limit cir 200000 cbs 50000
# 配置AP接收客户端报文的承诺信息速率为200000Kbps,承诺突发尺寸为50000bytes。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking client rate-limit cir 200000 cbs 50000
rfid-tracking dilution enable命令用来开启报文稀释功能。
rfid-tracking dilution disable命令用来关闭报文稀释功能。
undo rfid-tracking dilution命令用来恢复缺省情况。
rfid-tracking dilution { disable | enable }
AP组视图:继承全局配置。
全局配置视图:报文稀释功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启报文稀释功能后,对于AeroScout定位和指纹定位的MU客户端报文,仅在满足稀释因子或稀释超时时间的情况下,AP才会将MU客户端报文封装为定位报文并发送给定位服务器。
本配置仅在以下定位场景下生效:
· AeroScout定位方式为静态方式时的MU客户端定位。
· 指纹定位方式时的MU客户端定位。
# 开启报文稀释功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking dilution enable
# 开启报文稀释功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking dilution enable
# 开启报文稀释功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking dilution enable
· rfid-tracking aeroscout engine-detection static
· rfid-tracking dilution factor
· rfid-tracking mode mu
rfid-tracking dilution factor命令用来配置报文稀释因子和稀释超时时间。
undo rfid-tracking dilution factor命令用来恢复缺省情况。
rfid-tracking dilution factor factor timeout timeout
AP组视图:继承全局配置。
全局配置视图:未配置报文稀释因子和稀释超时时间。
AP视图
AP组视图
全局配置视图
factor factor:稀释因子,取值范围为1~10000。
timeout timeout:稀释超时时间,取值范围为1~60,单位为秒。
稀释因子和稀释超时时间作为稀释功能的参数,仅对AeroScout/指纹定位的MU客户端定位生效。例如在稀释因子为10,稀释超时时间为5秒,AeroScout/指纹定位对于报文稀释功能的实现如下:
开启了AeroScout定位或指纹定位功能,并且配置了被定位客户端类型为MU的AP,在5秒的稀释超时时间内每收到10个来自同一MU客户端的无线报文(不包括管理报文和广播报文),会将第10个报文封装成定位报文发送给定位服务器。如果AP在5秒内收到的报文数量没有达到稀释因子数,则将超时时间内最后接收到的无线报文发送给定位服务器,避免报文收集周期过长,影响定位的准确性。
开启定位报文的稀释功能后,配置的稀释因子和稀释超时时间才会生效。
# 配置稀释因子为10,稀释超时时间为10秒。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking dilution factor 10 timeout 10
# 配置稀释因子为10,稀释超时时间为10秒。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking dilution factor 10 timeout 10
# 配置稀释因子为10,稀释超时时间为10秒。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking dilution factor 10 timeout 10
· rfid-tracking dilution enable
rfid-tracking fingerprint enable命令用来开启指纹定位功能。
rfid-tracking fingerprint disable命令用来关闭指纹定位功能。
undo rfid-tracking fingerprint命令用来恢复缺省情况。
rfid-tracking fingerprint { disable | enable }
AP组视图:继承全局配置。
全局配置视图:指纹定位功能处于关闭状态。
AP视图
AP组视图
全局配置视图
只有同时开启了指纹定位功能和Radio无线定位功能后,AP才会将Radio接口收到的无线报文封装成定位报文发送给指纹定位服务器。
# 开启指纹定位功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint enable
# 开启指纹定位功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking fingerprint enable
# 开启指纹定位功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint enable
· rfid-tracking radio enable
rfid-tracking fingerprint engine-address命令用来配置指纹定位服务器的IPv4地址和端口号。
undo rfid-tracking fingerprint engine-address命令用来恢复缺省情况。
rfid-tracking fingerprint engine-address engine-address engine-port engine-port
AP组视图:继承全局配置。
全局配置视图:未配置指纹定位服务器的IPv4地址和端口号。
AP视图
AP组视图
全局配置视图
engine-address engine-address:指纹定位服务器的IPv4地址。
engine-port engine-port:指纹定位服务器的端口号,取值范围为1~65535。
配置指纹定位服务器的IPv4地址和端口号,用于AP主动探知指纹定位服务器,进行信息交互。
# 配置指纹定位服务器的IPv4地址为192.168.10.10,端口号为1145。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
# 配置指纹定位服务器的IPv4地址为192.168.10.10,端口号为1145。(AP组视图)
[Sysname-wlan-ap-group10] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
# 配置指纹定位服务器的IPv4地址为192.168.10.10,端口号为1145。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
rfid-tracking fingerprint mu-report enable命令用来开启指纹定位报文携带MU信息功能。
rfid-tracking fingerprint mu-report disable命令用来关闭指纹定位报文携带MU信息功能。
undo rfid-tracking fingerprint mu-report命令用来恢复缺省情况。
rfid-tracking fingerprint mu-report { disable | enable }
AP组视图:继承全局配置。
全局配置视图:指纹定位报文携带MU信息功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启定位报文携带MU(Mobile Unit,移动设备)信息功能后,AP会将包括MU的IP地址,发送速率等信息封装在定位报文中发送给定位服务器。
# 开启指纹定位报文携带MU信息功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint mu-report enable
# 开启指纹定位报文携带MU信息功能。(AP组视图)
[Sysname-wlan-ap-group10] rfid-tracking fingerprint mu-report enable
# 开启指纹定位报文携带MU信息功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint mu-report enable
rfid-tracking fingerprint raw-frame-report enable命令用来开启指纹定位报文携带原始报文功能。
rfid-tracking fingerprint raw-frame-report disable命令用来关闭指纹定位报文携带原始报文功能。
undo rfid-tracking fingerprint raw-frame-report命令用来恢复缺省情况。
rfid-tracking fingerprint raw-frame-report { disable | enable }
AP组视图:继承全局配置。
全局配置视图:指纹定位报文携带原始报文功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启定位报文携带原始报文功能后,AP会将接收到的无线报文和从报文中获取到的定位信息一同封装为定位报文发送给定位服务器。否则,AP仅将获取到的定位信息上送给定位服务器。
# 开启指纹定位报文携带原始报文功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint raw-frame-report enable
# 开启指纹定位报文携带原始报文功能。(AP组视图)
[Sysname-wlan-ap-group10] rfid-tracking fingerprint raw-frame-report enable
# 开启指纹定位报文携带原始报文功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint raw-frame-report enable
rfid-tracking fingerprint report-format命令用来配置指纹定位方式下的定位报文上报格式。
undo rfid-tracking fingerprint report-format命令用来恢复缺省情况。
rfid-tracking fingerprint report-format { cupid-hybrid | general | light-weight }
AP组视图:继承全局配置。
全局配置视图:指纹定位方式下的定位报文上报格式为常规报文格式。
AP视图
AP组视图
全局配置视图
cupid-hybrid:定位报文使用CUPID混杂报文格式,即CUPID非关联终端报告的报文格式,仅上报客户端的MAC地址和RSSI,在定位服务器仅需要获取客户端的MAC地址和RSSI时使用。
general:定位报文上报格式为常规报文格式,适用于大部分场景,大部分第三方定位服务器仅支持该报文格式。
light-weight:定位报文上报格式为轻量级报文格式,适用于对流量敏感的场景。为了减少带宽占用,轻量级报文不仅压缩了报文内容,而且还减少了报文数量,AP会缓存一段时间后再将多个客户端信息放在同一个轻量级报文中进行上报。
# 配置指纹定位方式下的定位报文上报格式为轻量级报文格式。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint report-format light-weight
# 配置指纹定位方式下的定位报文上报格式为轻量级报文格式。(AP组视图)
[Sysname-wlan-ap-group10] rfid-tracking fingerprint report-format light-weight
# 配置指纹定位方式下的定位报文上报格式为轻量级报文格式。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint report-format light-weight
rfid-tracking fingerprint report-mode命令用来配置指纹定位方式下的定位报文上报模式。
undo rfid-tracking fingerprint report-mode命令用来恢复缺省情况。
rfid-tracking fingerprint report-mode { central | local }
AP组视图:继承全局配置。
全局配置视图:指纹定位方式下的定位报文上报模式为本地上报模式。
AP视图
AP组视图
全局配置视图
central:定位报文上报模式为集中上报模式,即AP将定位信息封装为定位报文后先发送给AC,再由AC将定位报文发送给定位服务器。
local:定位报文上报模式为本地上报模式,即AP将定位信息封装为定位报文后直接发送给定位服务器。
# 配置指纹定位方式下的定位报文上报模式为集中上报模式。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint report-mode central
# 配置指纹定位方式下的定位报文上报模式为集中上报模式。(AP组视图)
[Sysname-wlan-ap-group10] rfid-tracking fingerprint report-mode central
# 配置指纹定位方式下的定位报文上报模式为集中上报模式。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint report-mode central
rfid-tracking fingerprint tag-multicast-address命令用来配置指纹定位方式下Tag设备的组播MAC地址。
undo rfid-tracking fingerprint tag-multicast-address命令用来恢复缺省情况。
rfid-tracking fingerprint tag-multicast-address mac-address
AP组视图:继承全局配置。
AP视图
AP组视图
全局配置视图
# 配置指纹定位方式下Tag设备的组播MAC地址为01-34-ed-66-89-23。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint tag-multicast-address 0134-ed66-8923
# 配置指纹定位方式下Tag设备的组播MAC地址为01-34-ed-66-89-23。(AP组视图)
[Sysname-ap-group-10] rfid-tracking fingerprint tag-multicast-address 0134-ed66-8923
# 配置指纹定位方式下Tag设备的组播MAC地址为01-34-ed-66-89-23。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint tag-multicast-address 0134-ed66-8923
rfid-tracking fingerprint vendor-port命令用来配置指纹定位方式下AP需要监听的端口号。
undo rfid-tracking fingerprint vendor-port命令用来恢复缺省情况。
rfid-tracking fingerprint vendor-port vendor-port-number
AP组视图:继承全局配置。
全局配置视图:指纹定位方式下AP需要监听的端口号为1144。
AP视图
AP组视图
全局配置视图
vendor-port-number:指纹定位方式下AP需要监听的端口号,取值范围为1~65535。
AP和指纹定位服务器之间通过UDP报文通信。其中,定位服务器向AP的某个端口号发送查询信息和配置信息,AP需要监听该端口号才能响应查询、接收配置信息。
# 配置指纹定位方式下AP需要监听的端口号为3000。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint vendor-port 3000
# 配置指纹定位方式下AP需要监听的端口号为3000。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking fingerprint vendor-port 3000
# 配置指纹定位方式下AP需要监听的端口号为3000。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking fingerprint vendor-port 3000
rfid-tracking ignore ap-frame enable命令用来开启忽略AP帧功能。
rfid-tracking ignore ap-frame disable命令用来关闭忽略AP帧功能。
undo rfid-tracking ignore ap-frame命令用来恢复缺省情况。
rfid-tracking ignore ap-frame { disable | enable }
AP组视图:继承全局配置。
全局配置视图:忽略AP帧功能处于关闭状态。
AP视图
AP组视图
全局配置视图
AP帧即本AP收到的其它AP发送的802.11帧。若不需要对无线环境中的AP进行定位和监测,可以开启忽略AP帧的功能,AP不会把从AP帧中获取到的定位信息上报给定位服务器。
# 开启忽略AP帧功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking ignore ap-frame enable
# 开启忽略AP帧功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking ignore ap-frame enable
# 开启忽略AP帧功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking ignore ap-frame enable
rfid-tracking ignore beacon enable命令用来开启忽略Beacon帧功能。
rfid-tracking ignore beacon disable命令用来关闭忽略Beacon帧功能。
undo rfid-tracking ignore beacon命令用来恢复缺省情况。
rfid-tracking ignore beacon { disable | enable }
AP组视图:继承全局配置。
全局配置视图:忽略Beacon帧功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启忽略Beacon帧功能后,AP不会将接收到的Beacon帧上报给定位服务器,避免无线环境中大量的Beacon帧对定位服务器造成冲击,影响定位服务器的性能。
# 开启忽略Beacon帧功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking ignore beacon enable
# 开启忽略Beacon帧功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking ignore beacon enable
# 开启忽略Beacon帧功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking ignore beacon enable
rfid-tracking keepalive enable命令用来开启定位保活功能。
rfid-tracking keepalive disable命令用来关闭定位保活功能。
undo rfid-tracking keepalive命令用来恢复缺省情况。
rfid-tracking keepalive { disable | enable }
定位保活功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启本功能后,AP会每隔15秒发送Hello报文给定位服务器,用于定位服务器确认AP是否在线。如果定位服务器超过30秒没有收到来自AP的Hello消息或其它任何消息,则认为AP已失去连接,并采取相应的处理。
如果定位服务器不支持处理Hello报文,避免无效报文占用带宽资源,则建议关闭本功能;如果定位服务器支持处理Hello报文,则根据定位服务器的要求开启本功能。
本命令仅在指纹定位方式下生效。
# 开启定位保活功能。(AP视图)
[Sysname] wlan ap ap1 WA4320i-ACN
[Sysname-wlan-ap-ap1] rfid-tracking keepalive enable
# 开启定位保活功能。(AP组视图)
[Sysname-ap-group10] rfid-tracking keepalive enable
# 开启定位保活功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking keepalive enable
· rfid-tracking ble
· rfid-tracking cupid
rfid-tracking mode命令用来配置待定位客户端类型。
undo rfid-tracking mode命令用来取消待定位客户端类型的配置。
rfid-tracking mode { mu | tag }
undo rfid-tracking mode { mu | tag }
Radio视图:继承AP组Radio配置。
AP组Radio视图:未配置待定位客户端类型。
Radio视图
AP组Radio视图
mu:配置待定位客户端类型为MU。
tag:配置待定位客户端类型为Tag。
配置待定位客户端类型后,AP才会将指定类型的客户端发送的无线报文发送给定位服务器。
本命令仅在AeroScout定位功能或指纹定位功能处于开启的情况下才会生效。
通过重复配置本命令指定不同参数,可配置不同类型的待定位客户端。
# 配置待定位客户端为类型MU。(Radio视图)
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rfid-tracking mode mu
# 配置待定位客户端为类型MU。(AP组Radio视图)
[Sysname-wlan-ap-group-10] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-10-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-10-ap-model-WA4320i-ACN-radio-1] rfid-tracking mode mu
rfid-tracking radio enable命令用来开启Radio定位功能。
rfid-tracking radio disable命令用来关闭Radio定位功能。
undo rfid-tracking radio命令用来恢复缺省情况。
rfid-tracking radio { disable | enable }
AP组Radio视图:Radio定位功能处于关闭状态。
Radio视图
AP组Radio视图
只有配置AP的定位方式为AeroScout定位和指纹定位时,才需要配置本命令。
同时开启了AP的AeroScout/指纹定位功能和Radio定位功能后,AP才会将Radio接口收到的无线报文封装成定位报文发送给定位服务器。
# 开启Radio定位功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] rfid-tracking radio enable
# 开启Radio定位功能。(AP组Radio视图)
[Sysname-wlan-ap-group-10-ap-model-WA4320i-ACN-radio-1] rfid-tracking radio enable
rfid-tracking rate-limit enable命令用来开启AP发送定位报文的限制速率功能。
rfid-tracking rate-limit disable命令用来关闭AP发送定位报文的限制速率功能。
undo rfid-tracking rate-limit命令用来恢复缺省情况。
rfid-tracking rate-limit { disable | enable }
AP组视图:继承全局配置。
全局配置视图:AP发送定位报文的限制速率功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启AP发送定位报文的限制速率功能后,AP将按照令牌桶算法对发送的定位报文进行速率限制。当AP以高于承诺信息速率的速率发送定位报文,并且令牌桶中的令牌已用完时,AP将直接丢弃该定位报文。使用本功能可以避免定位报文流量过大对定位服务器造成流量冲击,影响定位服务器的性能。
# 开启AP发送定位报文的限制速率功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking rate-limit enable
# 开启AP发送定位报文的限制速率功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking rate-limit enable
# 开启AP发送定位报文的限制速率功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking rate-limit enable
· rfid-tracking rate-limit cir
rfid-tracking rate-limit cir命令用来配置AP发送定位报文的限制速率。
undo rfid-tracking rate-limit cir命令用来恢复缺省情况。
rfid-tracking rate-limit cir cir [ cbs cbs ]
AP组视图:继承全局配置。
全局配置视图:承诺信息速率和承诺突发尺寸为0,即AP不对发送定位报文的速率进行限制。
AP视图
AP组视图
全局配置视图
cir cir:AP发送定位报文的承诺信息速率,取值范围为8~1300000,单位为Kbps。
cbs cbs:AP发送定位报文的承诺突发尺寸,取值范围为500~130000000,单位为bytes,缺省值为cir × 700。
开启AP发送定位报文的限制速率功能后,配置的AP发送定位报文的承诺信息速率和承诺突发尺寸才会生效。
# 配置AP发送定位报文的承诺信息速率为800000Kbps,承诺突发尺寸为50000bytes。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking rate-limit cir 800000 cbs 50000
# 配置AP发送定位报文的承诺信息速率为800000Kbps,承诺突发尺寸为50000bytes。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking rate-limit cir 800000 cbs 50000
# 配置AP发送定位报文的承诺信息速率为800000Kbps,承诺突发尺寸为50000bytes。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking rate-limit cir 800000 cbs 50000
· rfid-tracking rate-limit enable
rfid-tracking rssi enable命令用来开启报文RSSI过滤功能。
rfid-tracking rssi disable命令用来关闭报文RSSI过滤功能。
undo rfid-tracking rssi命令用来恢复缺省情况。
rfid-tracking rssi { disable | enable }
AP组视图:继承全局配置。
全局配置视图:报文RSSI过滤功能处于关闭状态。
AP视图
AP组视图
全局配置视图
开启报文RSSI过滤功能后,当AP接收到无线报文的RSSI值小于设定的RSSI门限值时,将不对其做定位报文的封装上报工作。
# 开启报文RSSI过滤功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking rssi enable
# 开启报文RSSI过滤功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking rssi enable
# 开启报文RSSI过滤功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking rssi enable
· rfid-tracking rssi threshold
rfid-tracking rssi threshold命令用来配置报文RSSI过滤门限值。
undo rfid-tracking rssi threshold命令用来恢复缺省情况。
rfid-tracking rssi threshold rssi-threshold
AP组视图:继承全局配置。
全局配置视图:报文RSSI过滤门限值为5,即-123dBm。
AP视图
AP组视图
全局配置视图
threshold rssi-threshold:RSSI门限值,取值范围为5~100,代表功率范围为-123~-28dBm,取值越大,所代表的功率越大。当AP收到的无线报文的RSSI低于配置的门限值时,将不对其做定位报文的封装上报工作。
该命令仅在RSSI过滤功能处于开启的情况下才会生效。
# 配置报文RSSI过滤门限值为50。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking rssi threshold 50
# 配置报文RSSI过滤门限值为50。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking rssi threshold 50
# 配置报文RSSI过滤门限值为50。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking rssi threshold 50
snmp-agent trap enable wlan location-aware命令用来开启WLOC的告警功能。
undo snmp-agent trap enable wlan location-aware命令用来恢复缺省情况。
WLOC的告警功能处于关闭状态。
开启了告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 开启WLOC的告警功能。
[Sysname] snmp-agent trap enable wlan location-aware
