04-DPI深度安全命令参考
02-IPS命令
本章节下载: 02-IPS命令  (214.89 KB)
02-IPS命令
1 IPS
1.1  IPS配置命令
1.1.1  display ips policy
display ips policy命令用来显示IPS策略信息。
display ips policy policy-name
context-admin
context-operator
policy-name:表示IPS策略名称,为1~63个字符的字符串,不区分大小写。
# 显示IPS策略aa的策略信息。
<Sysname> display ips policy aa
Total signatures        :474       failed:0
 Pre-defined  signatures:474       failed:0
 User-defined signatures:0         failed:0
Flag:
  B: Block-source  D: Drop  P: Permit  Rs: Reset  Rd: Redirect  C: Capture  L: L
ogging
  Pre: predefined  User: user-defined
Type RuleID    Target      SubTarget       Severity Category    Status  Action
Pre  1         OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  2         OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  3         Browser     Browser/Interne High     Vulnerabili Enable  RsCL
Pre  4         OfficeSoftw OfficeSoftware/ High     Vulnerabili Enable  RsL
Pre  5         OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  6         OperationSy OperationSystem High     Vulnerabili Disable PL
Pre  7         Browser     Browser/Interne High     Vulnerabili Disable PL
Pre  8         Application ApplicationSoft High     Vulnerabili Enable  RsL
Pre  9         Application ApplicationSoft High     Vulnerabili Enable  RsL
Pre  10        OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  11        Browser     Browser/Interne High     Vulnerabili Enable  RsL
Pre  12        OfficeSoftw OfficeSoftware/ Critical Vulnerabili Disable RsL
Pre  13        OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  14        Application ApplicationSoft High     Vulnerabili Enable  RsL
Pre  15        Browser     Browser/Interne High     Vulnerabili Enable  RsL
Pre  16        OperationSy OperationSystem Critical Vulnerabili Enable  RsL
Pre  17        Browser     Browser/Interne High     Vulnerabili Enable  RsL
Pre  18        OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  19        OfficeSoftw OfficeSoftware/ Critical Vulnerabili Disable RsL
Pre  20        OfficeSoftw OfficeSoftware/ Critical Vulnerabili Enable  RsL
Pre  21        Application ApplicationSoft Critical Vulnerabili Enable  RsL
Pre  23        OperationSy OperationSystem High     Vulnerabili Enable  RsL
Pre  24        Browser     Browser/Interne High     Vulnerabili Disable PL
Pre  25        NetworkDevi NetworkDevice/D High     Vulnerabili Enable  PL
Pre  26        Browser     Browser/Interne High     Vulnerabili Enable  RsL
---- More ----
表1-1 display ips policy命令显示信息描述表
Total signatures
IPS特征总数
预定义IPS特征数目
用户自定义IPS特征数目
IPS特征的类型,包括如下取值:
·          Pre:表示预定义特征
·          User:表示自定义特征
RuleID
IPS特征编号
Target
攻击对象
SubTarget
攻击子对象
Severity
IPS特征的攻击严重程度属性,从低到高分为四级:Low、Medium、High、Critical
Category
IPS特征的攻击类别名称
Status
IPS特征的状态,包括如下取值:
·          Enabled:表示此特征已生效
·          Disabled:表示此特征未生效
Action
对报文的处理动作,包括如下取值:
·          Block-source:表示阻断符合特征的报文
·          Drop:表示丢弃符合特征的报文
·          Permit:表示允许符合特征的报文通过
·          Reset:表示发送TCP的reset报文或UDP的ICMP端口不可达报文使TCP或UDP连接断开
·          Redirect:表示重定向符合特征的报文
·          Capture:表示捕获符合特征的报文
·          Logging:表示对符合特征的报文生成日志
·              ips policy
1.1.2  display ips signature
display ips signature命令用来显示IPS特征信息。
display ips signature [ pre-defined | user-defined ] [ direction { any | to-client | to-server } ] [ category category-name | fidelity { high | low | medium } | protocol { icmp | ip | tcp | udp } | severity { critical | high | low | medium } ] *
context-admin
context-operator
pre-defined:显示预定义IPS特征。
user-defined:显示自定义IPS特征。
direction { any | to-client | to-server }:显示符合指定方向属性的IPS特征。如果未指定此参数,则显示所有方向上的IPS特征。
·              to-server:表示一个会话的客户端到服务器的方向。
·              to-client:表示一个会话的服务器到客户端的方向。
·              any:表示一个会话的两个方向。
category category-name:显示符合指定攻击类别属性的IPS特征,category-name是攻击类型的名称。如果未指定此参数,则显示所有攻击类型的IPS特征。
fidelity { high | low | medium }:显示符合指定可信度属性的IPS特征。如果未指定此参数,则显示所有可信度的IPS特征。可信度是指此IPS特征识别攻击行为准确度,且从低到高分为如下三个级别:
·              low:可信度比较低。
·              medium:可信度中等。
·              high:可信度比较高。
protocol { icmp | ip | tcp | udp }:显示符合指定协议属性的IPS特征,协议ICMP、IP、TCP和UDP协议。如果未指定此参数,则显示所有协议的IPS特征。
severity { critical | high | low | medium }:显示符合指定攻击严重程度属性的IPS特征。如果未指定此参数,则显示所有攻击严重程度的IPS特征。攻击严重程度是指匹配此IPS特征的网络攻击造成的危害的严重程度,且从低到高分为四个级别:
·              low:攻击严重程度比较低。
·              medium:攻击严重程度中等。
·              high:攻击严重程度比较高。
·              critical:攻击严重程度非常高。
若不指定任何参数,则显示所有IPS特征。
# 显示可信度为中等的所有TCP协议的预定义IPS特征。
<Sysname> display ips signature pre-defined protocol tcp fidelity medium
Pre-defined  signatures:465       failed:0
Flag:
Type Sig-ID    Direction Severity Fidelity Category      Protocol
Pre  1         To-server High     Medium   Vulnerability TCP
Pre  2         To-server High     Medium   Vulnerability TCP
Pre  3         To-client High     Medium   Vulnerability TCP
Pre  4         To-client High     Medium   Vulnerability TCP
Pre  5         To-client High     Medium   Vulnerability TCP
Pre  6         To-client High     Medium   Vulnerability TCP
Pre  7         To-client High     Medium   Vulnerability TCP
Pre  8         To-client High     Medium   Vulnerability TCP
Pre  10        To-server High     Medium   Vulnerability TCP
Pre  11        To-client High     Medium   Vulnerability TCP
Pre  12        To-client Critical Medium   Vulnerability TCP
Pre  13        To-client High     Medium   Vulnerability TCP
Pre  14        To-server High     Medium   Vulnerability TCP
Pre  15        To-client High     Medium   Vulnerability TCP
Pre  16        To-client Critical Medium   Vulnerability TCP
Pre  17        To-client High     Medium   Vulnerability TCP
Pre  18        To-client High     Medium   Vulnerability TCP
---- More ----
# 显示攻击严重程度为比较高的所有UDP协议的IPS特征。
<Sysname> display ips signature severity high protocol udp
Total signatures        :7         failed:0
 Pre-defined  signatures:7         failed:0
Flag:
Pre  9         To-server High     Medium   Vulnerability UDP
Pre  45        To-server High     Medium   Vulnerability UDP
Pre  187       Any       High     Medium   Vulnerability UDP
Pre  196       Any       High     Medium   Vulnerability UDP
Pre  223       To-server High     Medium   Vulnerability UDP
Pre  234       To-client High     Medium   Vulnerability UDP
Pre  338       To-client High     Medium   Vulnerability UDP
表1-2 display ips signature命令显示信息描述表
Total signatures
IPS特征总数
Pre-defined  count
预定义IPS特征数目
User-defined count
自定义IPS特征数目
IPS特征的类型,包括如下取值:
·          Pre:表示预定义特征
·          User:表示自定义特征
Sig-ID
IPS特征的编号
Direction
IPS特征的方向属性,包括如下取值:
·          any:表示一个会话的两个方向
·          To-server:一个会话的客户端到服务器方向
·          To-client:一个会话的服务器到客户端方向
Severity
IPS特征的攻击严重程度属性,严重程度从低到高分为四个级别:Low、Medium、High、Critical
Fidelity
IPS特征的可信度属性,可信度从低到高分为三个级别:Low、Medium、High
Category
IPS特征的攻击类别名称
Protocol
IPS特征的协议属性
1.1.3  display ips signature { pre-defined | user-defined }
display ips signature { pre-defined | user-defined }命令用来显示IPS特征的详细信息。
display ips signature { pre-defined | user-defined } signature-id
context-admin
context-operator
pre-defined:显示预定义IPS特征的详细信息。
user-defined:显示自定义IPS特征的详细信息。
signature-id:指定IPS特征的编号,取值范围为1~4294967295。
# 显示编号为1的预定义IPS特征的详细信息。
<Sysname> display ips signature pre-defined 1
 Type        : Pre-defined
 Signature ID: 1
 Status      : Enabled
 Action      : Reset & Logging
 Protocol    : TCP
 Severity    : High
 Fidelity    : Medium
 Direction   : To-server
 Category    : Vulnerability
 Reference   : CVE-2014-6271;
 Description : GNU Bash through 4.3 processes trailing strings after function definitions in the values of environment variables, which allows remote attackers to execute arbitrary code via a crafted environment, as demonstrated by vectors involving the ForceCommand feature in OpenSSH sshd, the mod_cgi and mod_cgid modules in the Apache HTTP Server, scripts executed by unspecified DHCP clients, and other situations in which setting the environment occurs across a privilege boundary from Bash execution, aka \"ShellShock.\" NOTE: the original fix for this issue was incorrect; CVE-2014-7169 has been assigned to cover the vulnerability that is still present after the incorrect fix.
表1-3 display ips signature { pre-defined | user-defined }命令显示信息描述表
IPS特征的类型,包括如下取值:
·          Pre:表示预定义特征
·          User:表示自定义特征
Signature ID
IPS特征的编号
Status
IPS特征的状态,包括如下取值:
·          Enabled:表示此特征已生效
·          Disabled:表示此特未生效
Action
对报文的处理动作,包括如下取值:
·          Drop:表示丢弃符合特征的报文
Name
IPS特征的名称
Protocol
IPS特征的协议属性
Severity
Fidelity
Direction
IPS特征的方向属性,包括如下取值:
·          any:表示一个会话的两个方向
Category
IPS特征的攻击类别名称
Reference
IPS特征的参考信息
IPS特征的描述信息
1.1.4  display ips signature information
display ips signature information命令用来显示IPS特征库信息。
context-admin
context-operator
# 显示IPS特征库版本信息。
<Sysname> display ips signature information
IPS signature library information:
Type     SigVersion         ReleaseTime               Size
Current  1.02               Fri Sep 13 09:05:35 2014  71594
Last     -                  -                         -
Factory  1.00               Fri Sep 11 09:05:35 2014  71394
表1-4 display ips signature information命令显示信息描述表
IPS特征库版本,包括如下取值:
·          Current:表示当前版本
·          Last:表示上一版本
·          Factory:表示出厂版本
SigVersion
IPS特征库版本号
ReleaseTime
IPS特征库发布时间
Size
IPS特征库文件大小,单位是Bytes
1.1.5  ips parameter-profile
ips { block-source | capture | email | logging | redirect } parameter-profile命令用来配置IPS引用应用层检查引擎动作参数profile。
undo ips { block-source | capture | email | logging | redirect } parameter-profile命令用来取消IPS引用的应用层检查引擎动作参数profile。
ips { block-source | capture | email | logging | redirect } parameter-profile parameter-name
IPS未引用应用层检查引擎动作参数profile。
context-admin
block-source:表示设置IPS阻断动作的参数。
capture:表示设置IPS捕获动作的参数。
email:表示设置IPS邮件动作的参数。
logging:表示设置IPS日志动作的参数。
redirect:表示设置IPS重定向动作的参数。
parameter-profile parameter-name:指定IPS动作引用的应用层检测引擎动作参数profile。parameter-name表示动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
每类IPS动作的具体执行参数由应用层检测引擎动作参数profile来定义,该profile的具体配置请参见“DPI深度安全命令参考”中的“应用层检测引擎”。
如果IPS引用的应用层检测引擎动作参数profile不存在或没有引用,则使用系统各类动作参数的缺省值。
# 创建名称为ips1的应用层检测引擎阻断动作参数profile,配置其阻断源IP地址的时长为1111秒。
[Sysname] inspect block-source parameter-profile ips1
[Sysname-inspect-block-source-ips1] block-period 1111
[Sysname-inspect-block-source-ips1] quit
# 配置IPS引用名称为ips1的应用层检查引擎阻断动作参数profile。
[Sysname] ips block-source parameter-profile ips1
·              inspect block-source parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·              inspect capture parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·              inspect logging parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·              inspect email parameter-profile(DPI深度安全命令参考/应用层检测引擎)
·              inspect redirect parameter-profile(DPI深度安全命令参考/应用层检测引擎)
1.1.6  ips apply policy
ips apply policy命令用来在DPI应用profile中引用IPS策略。
undo ips apply policy命令用来删除引用的IPS策略。
ips apply policy policy-name mode { alert | protect }
DPI应用profile中没有引用IPS策略。
DPI应用profile视图
context-admin
mode:表示IPS策略的模式。
alert:告警模式,表示报文匹配上该IPS策略中的特征后,仅可以生成日志或捕获报文,但其他动作均不能生效。
protect:保护模式,表示报文匹配上该IPS策略中的特征后,设备按照特征的动作对该报文进行处理。
一个DPI应用profile视图下只能引用一个IPS策略。多次执行本命令,最后一次执行的命令生效。
# 在名称为sec的DPI应用profile下引用IPS策略ips1,且配置IPS模式为保护模式。
[Sysname] app-profile sec
[Sysname-app-profile-sec] ips apply policy ips1 mode protect
·              app-profile(DPI深度安全命令参考/应用层检测引擎)
·              ips policy
1.1.7  ips policy
ips policy命令用来创建IPS策略,并进入IPS策略视图。如果指定的IPS策略已经存在,则直接进入IPS策略视图。
undo ips policy命令用来删除指定的IPS策略。
undo ips policy policy-name
存在一个缺省IPS策略,名称为default。
context-admin
设备上存在一个名称为default的缺省IPS策略,缺省IPS策略和自定义IPS策略都使用当前系统中的所有IPS特征,新增IPS特征会自动添加到所有策略下。但是缺省IPS策略中的IPS特征的动作属性和生效状态属性不能被修改。
# 创建一个名称为ips1的IPS策略,并进入IPS策略视图。
[Sysname] ips policy ips1
[Sysname-ips-policy-ips1]
1.1.8  ips signature auto-update
ips signature auto-update命令用来开启定期自动在线升级IPS特征库功能,并进入自动升级配置视图。
undo ips signature auto-update命令用来关闭定期自动在线升级IPS特征库功能。
定期自动在线升级IPS特征库功能处于关闭状态。
context-admin
如果设备可以访问H3C官方网站上的特征库服务专区,可以采用定期自动在线升级方式来对设备上的IPS特征库进行升级。
# 开启定期自动在线升级IPS特征库功能,并进入自动升级配置视图。
[Sysname] ips signature auto-update
[Sysname-ips-autoupdate]
·              update schedule
1.1.9  ips signature auto-update-now
ips signature auto-update-now命令用来立即自动在线升级IPS特征库。
context-admin
执行此命令后,将立即自动升级设备上的IPS特征库,且会备份当前的IPS特征库文件。此命令的生效与否,与是否开启了定期自动升级IPS特征库功能无关。
当管理员发现H3C官方网站上的特征库服务专区中的IPS特征库有更新时,可以选择立即自动在线升级方式来及时升级IPS特征库版本。
# 立即自动在线升级IPS特征库版本。
[Sysname] ips signature auto-update-now
1.1.10  ips signature import snort
ips signature import snort命令用来导入自定义IPS特征。
ips signature import snort file-path
不存在自定义IPS特征。
context-admin
file-path:自定义IPS特征库文件的URL,为1~255个字符的字符串。
当需要的IPS特征在设备当前IPS特征库中不存在时,可通过编辑Snort格式的IPS特征文件,并将其导入设备中来生成所需的IPS特征。导入的IPS特征文件内容会自动覆盖系统中所有的自定义IPS特征。
管理员可以采用如下几种方式导入自定义IPS特征库文件。
·              本地方式:使用本地保存的自定义IPS特征库文件导入。
·              FTP/TFTP方式:通过FTP或TFTP方式下载远程服务器上保存的自定义IPS特征库文件,并导入到系统中。
参数file-path的取值与自定义IPS特征库文件导入的操作方式有关。采用本地方式时参数file-path取值请参见表1-5;采用FTP/TFTP方式时参数file-path取值请参见表1-6。
表1-5 采用本地方式时参数file-path取值说明表
导入方式
参数file-path取值
自定义IPS特征库文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
有关pwd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
自定义IPS特征库文件的存储位置与当前工作路径不一致,且在相同存储介质上
path/ filename
自定义IPS特征库文件的存储位置与当前工作路径不在相同存储介质上
path/ filename
需要先执行cd命令将工作路径切换至自定义IPS特征库文件所在存储介质的根目录下,再指定自定义IPS特征库文件的相对路径
有关cd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
表1-6 采用FTP/TFTP方式时参数file-path取值说明表
升级场景
参数file-path取值
自定义IPS特征库文件存储在开启FTP服务的远程服务器上
ftp://username:password@server/filename
username为登录FTP服务器的用户名,password为登录FTP服务器的密码,server为FTP服务器的IP地址或主机名
当FTP用户名和密码中使用了“:”、“@”和“/”三种特殊字符时,需要将这三种特殊字符替换为其对应的转义字符。“:”、“@”和“/”三种特殊字符对应的转义字符分别为“%3A或%3a”、“%40”和“%2F或%2f”
自定义IPS特征库文件存储在开启TFTP服务的远程服务器上
tftp://server/filename
server为TFTP服务器的IP地址或主机名
需要注意的是,Snort文件需要遵循Snort公司的语法。
# 采用TFTP方式,将自定义Snort格式的IPS特征库文件导入设备生成自定义IPS特征,自定义Snort格式的IPS特征库文件的远程路径为tftp://192.168.0.1/snort.rules。
[Sysname] ips signature import snort tftp://192.168.0.1/snort.rules
1.1.11  ips signature rollback
ips signature rollback命令用来回滚IPS特征库。
ips signature rollback { factory | last }
context-admin
factory:表示IPS特征库的出厂版本。
last:表示IPS特征库的上一版本。
IPS特征库回滚是指将当前的IPS特征库版本回滚到指定的版本。如果管理员发现设备当前IPS特征库版本在检测和防御网络攻击时,误报率较高或出现异常情况,则可以对当前IPS特征库版本进行回滚。目前支持将设备中的IPS过滤特征库版本回滚到出厂版本和上一版本。
IPS特征库版本每次回滚前,设备都会备份当前版本。多次回滚上一版本的操作将会在当前版本和上一版本之间反复切换。例如当前IPS特征库是V2,上一版本是V1,第一次执行回滚到上一版本的操作后,特征库替换成V1版本,再执行回滚上一版本的操作则特征库重新变为V2版本。
# 配置IPS特征库回滚到上一版本。
[Sysname] ips signature rollback last
1.1.12  ips signature update
ips signature update命令用来手动离线升级IPS特征库。
ips signature update [ override-current ] file-path
context-admin
override-current:表示覆盖当前版本的特征库文件。如果不指定本参数,则表示当前特征库在升级之后作为备份特征库保存在设备上。
file-path:指定特征库文件的路径,为1~255个字符的字符串。
如果设备不能访问H3C官方网站上的特征库服务专区,管理员可以采用如下几种方式手动离线升级IPS特征库版本。
·              本地升级:使用本地保存的特征库文件升级系统上的IPS特征库版本。
¡  特征库文件只能存储在当前主用设备上,否则设备升级特征库会失败。(集中式IRF设备)
¡  特征库文件只能存储在当前主用主控板上,否则设备升级特征库会失败。(分布式设备-独立运行模式)
¡  特征库文件只能存储在当前全局主用主控板上,否则设备升级特征库会失败。(分布式设备-IRF模式)
·              FTP/TFTP升级:通过FTP或TFTP方式下载远程服务器上保存的特征库文件,并升级系统上的IPS特征库版本。
参数file-path的取值与手动离线升级的操作方式有关。本地升级时参数file-path取值请参见表1-7;FTP/TFTP升级时参数file-path取值请参见表1-8。
表1-7 本地升级时参数file-path取值说明表
升级场景
参数file-path取值
特征库文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
path/ filename
path/ filename
需要先执行cd命令将工作路径切换至特征库文件所在存储介质的根目录下,再指定特征库文件的相对路径
表1-8 FTP/TFTP升级时参数file-path取值说明表
升级场景
参数file-path取值
当FTP的用户名和密码中使用了“:”、“@”和“/”三种特殊字符时,需要将这三种特殊字符替换为其对应的转义字符。“:”、“@”和“/”三种特殊字符对应的转义字符分别为“%3A或%3a”、“%40”和“%2F或%2f”
当采用FTP/TFTP方式升级特征库时,如果指定的是服务器的主机名,则需要确保设备能通过静态或动态域名解析方式获得FTP/TFTP服务器的IP地址,并与之路由可达。否则设备升级特征库会失败。有关域名解析功能的详细配置请参见“三层技术-IP业务配置指导”中的“域名解析”。
# 配置手动离线升级IPS特征库,且采用TFTP方式,IPS特征库文件的远程路径为tftp://192.168.0.10/ips-1.0.2-en.dat。
[Sysname] ips signature update tftp://192.168.0.10/ips-1.0.2-en.dat
# 配置手动离线升级IPS特征库,且采用FTP方式,IPS特征库文件的远程路径为ftp://192.168.0.10/ips-1.0.2-en.dat,用户名为user:123,密码为user@abc/123。
[Sysname] ips signature update ftp://user%3A123:user%40abc%[email protected]/ips-1.0.2-en.dat
# 配置手动离线升级IPS特征库,且采用本地方式,IPS特征库文件的本地路径为cfa0:/ips-1.0.23-en.dat,且当前工作路径为cfa0:。
<Sysname> system
[Sysname] ips signature update ips-1.0.23-en.dat
# 配置手动离线升级IPS特征库,且采用本地方式,IPS特征库文件的本地路径为cfa0:/dpi/ips-1.0.23-en.dat,且当前工作路径为cfa0:。
<Sysname> system
[Sysname] ips signature update dpi/ips-1.0.23-en.dat
# 配置手动离线升级IPS特征库,且采用本地方式,IPS特征库文件的本地路径为cfb0:/dpi/ips-1.0.23-en.dat,当前工作路径为cfa0:。
<Sysname> cd cfb0:/
<Sysname> system
1.1.13  override-current
override-current命令用来配置定期自动在线升级IPS特征库时覆盖当前的特征文件。
undo override-current命令用来恢复缺省情况。
override-current
定期自动在线升级IPS特征库时不会覆盖当前的特征库文件,而是同时备份当前的特征库文件。
自动升级配置视图
context-admin
可以通过开启此功能解决升级IPS特征库时设备内存不足的问题。在设备剩余内存充裕的情况下,不建议配置该功能,因为IPS特征库升级时,如果没有备份当前特征库文件,则不能回滚到上一版本。
# 配置定期自动在线升级IPS特征库时覆盖当前的特征文件。
[Sysname-ips-autoupdate] override-current
·              ips signature auto-update
1.1.14  signature override
signature override命令用来修改IPS特征的状态和动作。
undo signature override命令用来恢复指定IPS特征的缺省状态和动作。
signature override { pre-defined | user-defined } signature-id { { disable | enable } [ { block-source | drop | permit | redirect | reset } | capture | logging ] * }
undo signature override { pre-defined | user-defined } signature-id
预定义IPS特征使用系统预定义的状态和动作,自定义IPS特征的动作和状态在管理员导入的特征库文件中定义。
IPS策略视图
context-admin
pre-defined:表示预定义的IPS特征。
user-defined:表示自定义的IPS特征。
signature-id:IPS特征的编号,取值范围为1~4294967295。
disable:表示禁用此IPS特征。在某些网络环境中,如果一些IPS特征暂时不会被用到,而且又不想将其从IPS策略中删除时,可以使用disable参数来禁用这些规则。
enable:表示启用此IPS特征。
block-source:阻断符合特征的报文,并会将该报文的源IP地址加入IP黑名单。如果设备上同时开启了IP黑名单过滤功能,则一定时间内(由block-period命令指定)来自此IP地址的所有报文将被直接丢弃;否则,此IP黑名单不生效。有关IP黑名单过滤功能的详细介绍请参见“安全命令参考”中的“攻击检测与防范”,有关block-period命令的详细介绍请参见“DPI深度安全”中的“应用层检测引擎”。
drop:表示丢弃报文的动作。
permit:表示允许报文通过的动作。
redirect:表示重定向报文的动作,把符合特征的报文重定向到指定的Web页面上。
reset:表示通过发送TCP的reset报文使TCP连接断开。
capture:表示捕获报文的动作。
logging:表示生成报文日志的动作。
管理员可以根据实际的网络需求,通过配置IPS策略修改此IPS策略中已有IPS特征的动作属性和生效状态属性,但是缺省IPS策略中的IPS特征的动作属性和生效状态属性不能被修改。当IPS策略中的IPS特征被禁用后,此IPS特征对用户报文不生效。
在同一个IPS策略视图中对同一IPS特征多次执行此命令,最后一次执行的命令生效。
经过设备的报文与某个IPS特征匹配成功后,设备将根据此IPS特征的动作对该报文进行处理。如果报文未与任何IPS特征匹配成功,则设备直接允许此报文通过。
如果报文同时与多个IPS特征匹配成功,则根据这些动作中优先级最高的动作对此报文进行处理。但是,对于源阻断、生成日志和捕获三个动作只要匹配成功的特征中存在就会执行。动作优先级从高到低的顺序为:重置 > 重定向 > (源阻断/丢弃) > 允许,其中源阻断与丢弃的优先级相同。
# 在名称为ips1的IPS策略中,配置编号为2的预定义IPS特征的状态为开启,动作为丢弃和捕获报文,并生成日志信息。
[Sysname-ips-policy-ips1] signature override pre-defined 2 enable drop capture logging
·              blacklist enable (security zone view)(安全命令参考/攻击检测与防范)
·              blacklist global enable(安全命令参考/攻击检测与防范)
·              ips parameter-profile
·              ips policy
1.1.15  update schedule
update schedule命令用来配置定期自动在线升级IPS特征库的时间。
undo update schedule命令用来恢复缺省情况。
设备在每天01:00:00至03:00:00之间自动在线升级IPS特征库。
自动升级配置视图
context-admin
daily:表示自动升级周期为每天。
weekly:表示以一周为周期,在指定的一天进行自动升级。
fri:表示星期五。
mon:表示星期一。
sat:表示星期六。
sun:表示星期日。
thu:表示星期四。
tue:表示星期二。
wed:表示星期三。
start-time time:指定自动升级开始时间,time的格式为hh:mm:ss,取值范围为00:00:00~23:59:59。
tingle minutes:指定抖动时间,即实际自动升级开始时间的偏差范围,取值范围为0~120,单位为分钟。在start-time指定时间的前后各偏移抖动时间的一半作为自动升级的时间范围,例如,指定自动升级的开始时间为01:00:00,抖动时间为60分钟,则自动升级的时间范围为00:30:00至01:30:00。
# 配置IPS特征库的定期自动在线升级时间为每周一20:30:00,抖动时间为10分钟。
[Sysname-ips-autoupdate] update schedule weekly mon start-time 20:30:00 tingle 10
