08-MPLS命令参考
08-MPLS L3VPN命令
本章节下载: 08-MPLS L3VPN命令  (362.55 KB)
08-MPLS L3VPN命令
1 MPLS L3VPN
1.1 MPLS L3VPN配置命令
1.1.1 address-family ipv4 (VPN instance view)
1.1.2 address-family vpnv4
1.1.3 description (VPN instance view)
1.1.4 display bgp routing-table ipv4 unicast inlabel
1.1.5 display bgp routing-table ipv4 unicast outlabel
1.1.6 display bgp routing-table vpnv4
1.1.7 display bgp routing-table vpnv4 inlabel
1.1.8 display bgp routing-table vpnv4 outlabel
1.1.9 display ip vpn-instance
1.1.10 display ospf sham-link
1.1.11 domain-id (OSPF view)
1.1.12 export route-policy
1.1.13 ext-community-type (OSPF view)
1.1.14 import route-policy
1.1.15 ip binding vpn-instance
1.1.16 ip vpn-instance (System view)
1.1.17 peer next-hop-invariable
1.1.18 policy vpn-target
1.1.19 route-distinguisher (VPN instance view)
1.1.20 route-replicate
1.1.21 route-tag (OSPF view)
1.1.22 routing-table limit
1.1.23 rr-filter (BGP VPNv4 address family view)
1.1.24 sham-link (OSPF area view)
1.1.25 snmp context-name
1.1.26 snmp-agent trap enable l3vpn
1.1.27 tnl-policy
1.1.28 vpn popgo
1.1.29 vpn-id
1.1.30 vpn-route cross multipath
1.1.31 vpn-target
2 IPv6 MPLS L3VPN
2.1 IPv6 MPLS L3VPN配置命令
2.1.1 address-family ipv6 (VPN instance view)
2.1.2 address-family vpnv6
2.1.3 disable-dn-bit-check
2.1.4 disable-dn-bit-set
2.1.5 display bgp routing-table vpnv6
2.1.6 display bgp routing-table vpnv6 inlabel
2.1.7 display bgp routing-table vpnv6 outlabel
2.1.8 display ospfv3 sham-link
2.1.9 domain-id (OSPFv3 view)
2.1.10 ext-community-type (OSPFv3 view)
2.1.11 policy vpn-target
2.1.12 route-tag (OSPFv3 view)
2.1.13 route-tag-check enable
2.1.14 rr-filter (BGP VPNv6 address family view)
2.1.15 sham-link (OSPFv3 area view)
1 MPLS L3VPN
1.1  MPLS L3VPN配置命令
address-family ipv4命令用来进入VPN实例IPv4 VPN视图。
undo address-family ipv4命令用来删除VPN实例IPv4 VPN视图下的所有配置。
address-family ipv4
VPN实例视图
在VPN实例IPv4 VPN视图下可以配置IPv4 VPN的参数,如IPv4 VPN应用的出方向路由策略、入方向路由策略等。
# 进入VPN实例IPv4 VPN视图。
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1]
·     address-family ipv6 (VPN instance view)
address-family vpnv4命令用来创建BGP VPNv4地址族或BGP-VPN VPNv4地址族,并进入相应地址族视图。如果BGP VPNv4地址族或BGP-VPN VPNv4地址族已经存在,则直接进入BGP VPNv4地址族或BGP-VPN VPNv4地址族视图。
undo address-family vpnv4命令用来删除BGP VPNv4地址族或BGP-VPN VPNv4地址族,及相应地址族视图下的所有配置。
不存在BGP VPNv4地址族和BGP-VPN VPNv4地址族。
BGP实例视图
BGP-VPN实例视图
VPNv4地址是指在IPv4地址前缀前增加RD后,形成的地址。VPNv4路由是指携带VPNv4地址的路由信息。
在PE设备上,进入BGP VPNv4地址族视图或BGP-VPN VPNv4地址族视图,在该视图下通过peer enable命令使能BGP对等体后,PE才能与该对等体交换BGP VPNv4路由。
在BGP VPNv4地址族视图下,还可以配置BGP-VPNv4路由的属性,例如为从对等体/对等体组接收的BGP-VPNv4路由分配的首选值、是否允许本地AS号在接收的BGP-VPNv4路由的AS_PATH属性中出现等。
BGP VPNv4地址族视图下的配置用来控制PE设备之间交互的VPNv4路由。
BGP-VPN VPNv4地址族视图下的配置用来控制嵌套VPN组网中,运营商PE和运营商CE之间交互的VPNv4路由。
# 在BGP实例视图下,创建BGP VPNv4地址族,并进入BGP VPNv4地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4]
description命令用来配置VPN实例的描述信息。
undo description命令用来恢复缺省情况。
未配置VPN实例的描述信息。
VPN实例视图
text:VPN实例的描述信息,为1~79个字符的字符串,区分大小写。
# 配置名为vpn1的VPN实例的描述信息为“This is vpn1”。
[Sysname-vpn-instance-vpn1] description This is vpn1
display bgp routing-table ipv4 unicast inlabel命令用来显示BGP IPv4单播路由的入标签信息。
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的入标签信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网BGP IPv4单播路由的入标签信息。
执行本命令时指定unicast参数和不指定unicast参数的效果相同。
# 显示公网内所有BGP IPv4单播路由的入标签信息。
<Sysname> display bgp routing-table ipv4 inlabel
 Total number of routes: 1
 BGP local router ID is 3.3.3.9
     Network            NextHop         OutLabel        InLabel
* >  2.2.2.9/32         1.1.1.2         1151            1279
表1-1 display bgp routing-table ipv4 unicast inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? – incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对等体为IPv4路由分配的标签
InLabel
入标签值,即本地为IPv4路由分配的标签
display bgp routing-table ipv4 unicast outlabel命令用来显示BGP IPv4单播路由的出标签信息。
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的出标签信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网BGP IPv4单播路由的出标签信息。
# 显示公网所有BGP IPv4单播路由的出标签信息。
<Sysname> display bgp routing-table ipv4 outlabel
表1-2 display bgp routing-table ipv4 unicast outlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
display bgp routing-table vpnv4命令用来显示BGP VPNv4路由信息。
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv4路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
ipv4-address:目的网段的IPv4地址。
mask-length:掩码长度,取值范围为0~32。
mask:网络掩码,为点分十进制格式。
longest-match:指定根据如下方法判断显示哪条BGP VPNv4路由信息:
(1)     将用户输入的网络地址和路由的掩码进行与操作;
(2)     计算结果与路由的网段地址相同,且掩码小于等于用户输入子网掩码的路由中,子网掩码最长的路由将被显示出来。
advertise-info:显示BGP VPNv4路由的通告信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP VPNv4路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
communit-list:显示匹配指定BGP团体列表的BGP VPNv4路由信息。
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表与指定的团体属性列表完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表中包含指定的团体属性列表,就显示该路由的信息。
adv-community-list-number:高级团体列表号,取值范围为100~199。
vpn-instance vpn-instance-name:显示向指定对等体发布或者从指定对等体收到的指定VPN实例内BGP VPNv4路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示向指定对等体发布或者从指定对等体收到的公网内BGP VPNv4路由信息。
peer:显示向指定对等体发布或者从指定对等体收到的BGP VPNv4路由信息。
ipv4-address:对等体的IPv4地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
statistics:显示BGP VPNv4路由的统计信息。
如果未指定任何参数,则显示所有BGP VPNv4路由的简要信息。
如果指定了ipv4-address mask或ipv4-address mask-length参数,则显示与指定目的网段IP地址和网络掩码(或掩码长度)精确匹配的BGP VPNv4路由的详细信息。
如果只指定了ipv4-address参数,未指定mask和mask-length参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的详细信息。
# 显示所有BGP VPNv4路由的简要信息。
<Sysname> display bgp routing-table vpnv4
 BGP local router ID is 1.1.1.9
 Total number of routes from all PEs: 8
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 6
* >  10.1.1.0/24        10.1.1.2        0                     32768   ?
*  e                    10.1.1.1        0                     0       65410?
* >  10.1.1.2/32        127.0.0.1       0                     32768   ?
* >i 10.3.1.0/24        3.3.3.9         0          100        0       ?
* >e 192.168.1.0        10.1.1.1        0                     0       65410?
*  i                    3.3.3.9         0          100        0       65420?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i 192.168.1.0        3.3.3.9         0          100        0       65420?
# 显示路由标识符为100:1的所有BGP VPNv4路由的简要信息。
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1
# 显示匹配AS路径过滤列表1的BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 as-path-acl 1
# 显示匹配BGP团体列表100的BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 community-list 100
# 显示向对等体3.3.3.9发布的所有公网BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes
     Network            NextHop         MED        LocPrf             Path/Ogn
* >  10.1.1.0/24        10.1.1.2        0                             ?
* >e 192.168.1.0        10.1.1.1        0                             65410?
# 显示从对等体3.3.3.9收到的所有公网BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes
表1-3 display bgp routing-table vpnv4命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的VPNv4路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv4路由总数
Network
目的网络地址
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性
# 显示网段10.3.1.0/24的BGP VPNv4路由的详细信息。
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24
 BGP local router ID: 1.1.1.9
 Local AS number: 100
 Paths:   1 available, 1 best
 Rely nexthop    : 172.1.1.2
 Original nexthop: 3.3.3.9
 OutLabel        : 1279
 Ext-Community   : <RT: 111:1>
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# 显示路由标识符为100:1、目的网络地址为10.3.1.0/24的BGP VPNv4路由的详细信息。
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1 10.3.1.0 24
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
表1-4 display bgp routing-table vpnv4命令详细显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
Route distinguisher
路由标识符
路由总数
Paths
路由数信息
·     available:有效路由条数
·     best:最佳路由条数
到达目的网络10.3.1.0/24的BGP路由表项信息
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
IP precedence
路由的IP优先级,取值范围是0~7,N/A表示无效值
QoS local ID
路由的QoS本地ID属性,取值范围是1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围是1~64,N/A表示无效值
# 显示到达目的网段10.1.1.0/24的BGP VPNv4路由的通告信息。
<Sysname> display bgp routing-table vpnv4 10.1.1.0 24 advertise-info
 Paths:   1 best
 BGP routing table information of 10.1.1.0/24:
    3.3.3.9
 Inlabel         : 1279
表1-5 display bgp routing-table vpnv4 advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
路由总数
Paths
到达指定目的网络的优选路由数目
到达目的网络10.1.1.0/24的BGP路由的通告信息
该路由已经向哪些VPNv4对等体发送,以及对等体的数目
Inlabel
路由的入标签
# 显示向对等体3.3.3.9发布的公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes statistics
 Advertised routes total: 2
# 显示从对等体3.3.3.9收到的公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes statistic
 Received routes total: 2
表1-6 display bgp routing-table vpnv4 peer statistic命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 statistics
表1-7 display bgp routing-table vpnv4 statistics命令显示信息描述表
来自所有PE设备的VPNv4路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv4路由总数
·     ip as-path(三层技术-IP路由命令参考/路由策略)
display bgp routing-table vpnv4 inlabel命令用来显示所有BGP VPNv4路由的入标签信息。
display bgp [ instance instance-name ] routing-table vpnv4 inlabel
# 显示所有BGP VPNv4路由的入标签信息。
<Sysname> display bgp routing-table vpnv4 inlabel
* >  10.1.1.0/24        10.1.1.2        NULL            1279
* >e 192.168.1.0        10.1.1.1        NULL            1278
表1-8 display bgp routing-table vpnv4 inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为VPNv4路由分配的私网标签,取值为NULL表示空标签
InLabel
入标签值,即本地PE为VPNv4路由分配的私网标签
display bgp routing-table vpnv4 outlabel命令用来显示所有BGP VPNv4路由的出标签信息。
display bgp [ instance instance-name ] routing-table vpnv4 outlabel
# 显示所有BGP VPNv4路由的出标签信息。
<Sysname> display bgp routing-table vpnv4 outlabel
 Total number of routes from all PEs: 4
* >i 10.3.1.0/24        3.3.3.9         1279
*  i 192.168.1.0        3.3.3.9         1278
* >i 192.168.1.0        3.3.3.9         1278
表1-9 display bgp routing-table vpnv4 outlabel命令输出信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的路由数
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
display ip vpn-instance命令用来显示VPN实例的信息。
display ip vpn-instance [ instance-name vpn-instance-name ]
instance-name vpn-instance-name:显示指定VPN实例的详细信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示创建的所有VPN实例的简要信息。
# 显示所有VPN实例的简要信息。
<Sysname> display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  abc                             1:1                    2011/05/18 10:48:17
表1-10 display ip vpn-instance命令显示信息描述表
VPN-Instance Name
VPN实例名称
RD
VPN实例的路由标识符
Create time
VPN实例创建的时间
# 显示名为vpn1的VPN实例的详细信息。
<Sysname> display ip vpn-instance instance-name vpn1
  VPN-Instance Name and Index : vpn1, 2
  Route Distinguisher : 100:1
  VPN ID : 1:1
  Description : vpn1
  Interfaces : Vlan-interface2
  Address-family IPv4:
   Export VPN Targets :
       2:2
   Import VPN Targets :
       3:3
   Export Route Policy : outpolicy
   Import Route Policy : inpolicy
   Tunnel Policy : tunnel1
   Maximum Routes Limit : 500
   Threshold Value(%): 50
  Address-family IPv6:
       2:2
       3:3
   Maximum Routes Limit :500
表1-11 display ip vpn-instance instance-name命令显示信息描述表
VPN实例名称和索引
Route Distinguisher
VPN实例的路由标识符值
VPN ID
VPN实例的ID,即VPN实例的全局唯一标识
VPN实例的描述信息
Interfaces
关联该VPN实例的接口
Address-family IPv4
IPv4 VPN的信息
Address-family IPv6
IPv6 VPN的信息
Export VPN Targets
出方向扩展团体属性
Import VPN Targets
入方向扩展团体属性
Export Route Policy
出方向路由策略
Import Route Policy
入方向路由策略
Tunnel Policy
隧道策略
路由最大条数
Threshold Value(%)
激活路由条数的告警门限值
display ospf sham-link命令用来显示OSPF伪连接信息。
display ospf [ process-id ] sham-link [ area area-id ]
process-id:显示指定OSPF进程内的伪连接信息。process-id为OSPF进程号,取值范围为1~65535。如果未指定本参数,则显示所有OSPF进程的伪连接信息。
area area-id:显示指定OSPF区域内的伪连接信息。area-id为OSPF区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。如果未指定本参数,则显示所有OSPF区域的伪连接信息。
如果未指定进程号和区域号,则显示所有的OSPF伪连接信息。
# 显示所有OSPF伪连接信息。
<Sysname> display ospf sham-link
          OSPF Process 1 with Router ID 125.1.1.1
                  Sham link
 Area            Neighbor ID     Source IP       Destination IP  State  Cost
 0.0.0.0         95.1.1.1        125.2.1.1       95.2.1.1        P-2-P  1
表1-12 display ospf sham-link命令显示信息描述表
Area
伪连接所属的OSPF区域
Neighbor ID
伪连接邻居的Router ID
Source IP
伪连接的源IP地址
Destination IP
伪连接的目的IP地址
伪连接的接口状态,取值包括Down和P-2-P
Cost
伪连接的开销
# 显示OSPF区域1内的OSPF伪连接信息。
<Sysname> display ospf sham-link area 1
          OSPF Process 100 with Router ID 100.1.1.2
 Sham link: 3.3.3.3 --> 5.5.5.5
 Neighbor ID: 120.1.1.2        State: Full
 Area: 0.0.0.1
 Cost: 1  State: P-2-P  Type: Sham
 Request list: 0  Retransmit list: 0
 GTSM: Enabled, maximum number of hops: 2
 MD5 authentication enabled.
    The last key is 3.
    The rollover is in progress, 1 neighbor(s) left.
表1-13 display ospf sham-link area命令显示信息描述表
Sham link
伪连接,从源IP地址到目的IP地址
Neighbor ID
伪连接邻居的Router ID
伪连接的邻居状态,取值包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Area
伪连接所属的OSPF区域
Cost
伪连接的开销
伪连接的状态,取值包括Down和P-2-P
伪连接的类型,取值为Sham
Timers
伪连接的定时器,包括Hello,Dead,Retransmit和Transmit Delay定时器,单位为秒
Request list
请求列表个数
Retransmit list
重传列表个数
开启OSPF报文的GTSM安全检测功能,本例中允许接收到的报文所经过的路由器的最大跳数为2跳
如果未开启OSPF报文的GTSM安全检测功能,则显示为GTSM:Disabled
使能了MD5认证功能
The last key
最新的MD5验证密钥
正在进行MD5验证平滑迁移,尚未完成MD5验证平滑迁移的邻居个数为1
domain-id命令用来配置OSPF域标识符。
undo domain-id命令用来删除OSPF域标识符。
undo domain-id [ domain-id ]
OSPF域标识符为0。
OSPF视图
domain-id:OSPF域标识符,可以采用以下三种形式。
·     整数形式,取值范围为0~4294967295,例如:1。
·     点分十进制形式,例如:0.0.0.1。
·     点分十进制形式:16位用户自定义数,取值范围0~65535,例如:0.0.0.1:512。
secondary:配置的域标识符作为从标识符。如果未指定本参数,表示配置主标识符。
如果通过domain-id命令配置了OSPF域标识符,则PE将OSPF路由引入到BGP时,主域标识符被附加到BGP VPNv4路由上,作为BGP的扩展团体属性传递给对端PE。对端PE接收到BGP路由后,将本地配置的OSPF主域标识符、从域标识符和路由中携带的OSPF域标识符进行比较:如果主域标识符或从域标识符与其相同,且为区域内或区域间路由,则将路由重新引入到OSPF时,该路由作为Network Summary LSA(即Type-3 LSA)发布给CE;否则,该路由将作为AS External LSA(即Type-5 LSA)或NSSA External LSA(即Type-7 LSA)发布给CE。
执行undo domain-id命令时,如果未指定任何参数,将恢复缺省情况。
# 配置OSPF域标识符为234。
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
export route-policy命令用来配置VPN实例应用出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
VPN实例未应用出方向路由策略,不对发布的路由进行过滤。
VPN实例视图
VPN实例IPv4 VPN视图
VPN实例IPv6 VPN视图
route-policy:VPN实例的出方向路由策略名,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了VPN实例应用的出方向路由策略,则该VPN实例在向其他VPN实例发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制VPN实例之间路由的发布。
多次执行本命令,最后一次执行的命令生效。
VPN实例视图下的配置,既可以用于IPv4 VPN,也可以用于IPv6 VPN;VPN实例IPv4 VPN视图下的配置只能用于IPv4 VPN;VPN实例IPv6 VPN视图下的配置只能用于IPv6 VPN。
VPN实例IPv4 VPN视图下的配置优先级高于VPN实例视图下的配置,即如果同时在VPN实例IPv4 VPN视图和VPN实例视图下进行了配置,则IPv4 VPN采用VPN实例IPv4 VPN视图下的配置。
VPN实例IPv6 VPN视图下的配置优先级高于VPN实例视图下的配置,即如果同时在VPN实例IPv6 VPN视图和VPN实例视图下进行了配置,则IPv6 VPN采用VPN实例IPv6 VPN视图下的配置。
# 对名为vpn1的VPN实例应用出方向路由策略poly-1。
[Sysname-vpn-instance-vpn1] export route-policy poly-1
·     import route-policy
·     route-policy(三层技术-IP路由命令参考/路由策略)
ext-community-type命令用来配置OSPF扩展团体属性的类型编码。
undo ext-community-type命令用来将指定OSPF扩展团体属性的类型编码恢复为缺省值。
undo ext-community-type [ domain-id | router-id | route-type ]
OSPF扩展团体属性Domain ID的类型编码是0x0005,Router ID的类型编码是0x0107,Route Type的类型编码是0x0306。
OSPF视图
domain-id type-code1:指定OSPF扩展团体属性Domain ID的类型编码。type-code1取值可以为十六进制数值0005、0105、0205和8005。
router-id type-code2:指定OSPF扩展团体属性Router ID的类型编码。type-code2取值可以为十六进制数值0107和8001。
router-type type-code3:指定OSPF扩展团体属性Route Type的类型编码。type-code3取值可以为十六进制数值0306和8000。
# 为OSPF进程100配置OSPF扩展团体属性Domain ID的类型编码为0x8005,Router ID的类型编码为0x8001,Route Type的类型编码为0x8000。
[Sysname] ospf 100
[Sysname-ospf-100] ext-community-type domain-id 8005
[Sysname-ospf-100] ext-community-type router-id 8001
[Sysname-ospf-100] ext-community-type route-type 8000
import route-policy命令用来配置VPN实例应用入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
VPN实例未应用入方向路由策略。如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
VPN实例视图
VPN实例IPv4 VPN视图
VPN实例IPv6 VPN视图
route-policy:VPN实例的入方向路由策略名,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了VPN实例应用的入方向路由策略,则该VPN实例在接收其他VPN实例的路由后,将利用指定的路由策略对接收的路由进行过滤、改变接收路由的属性等。使用本命令可以更加精确、灵活地控制VPN实例之间路由的接收。
# 对名为vpn1的VPN实例应用入方向路由策略poly-1。
[Sysname-vpn-instance-vpn1] import route-policy poly-1
·     export route-policy
ip binding vpn-instance命令用来配置接口与指定VPN实例关联。
undo ip binding vpn-instance命令用来恢复缺省情况。
接口未关联VPN实例,接口属于公网。
vpn-instance-name:接口关联的VPN实例名称,为1~31个字符的字符串,区分大小写。
本命令用于在PE设备上将连接CE的接口与该CE所属的VPN实例关联。
配置或取消接口与VPN实例关联后,该接口上的IP地址、路由协议等配置将被删除。
接口关联的VPN实例,必须已经通过系统视图下的ip vpn-instance命令创建。
不能通过重复执行本命令修改接口关联的VPN实例。如需修改接口关联的VPN实例,请先通过undo ip binding vpn-instance命令取消关联的VPN实例后,再执行ip binding vpn-instance命令关联新的VPN实例。
# 将接口Vlan-interface2与名为vpn1的VPN实例关联。
[Sysname-Vlan-interface2] ip binding vpn-instance vpn1
·     ip vpn-instance (System view)
ip vpn-instance命令用来创建VPN实例,并进入VPN实例视图。如果指定的VPN实例已经存在,则直接进入VPN实例视图。
undo ip vpn-instance命令用来删除指定的VPN实例。
不存在VPN实例。
vpn-instance-name:VPN实例的名称,为1~31个字符的字符串,区分大小写。
# 创建一个名为vpn1的VPN实例,并进入VPN实例视图。
·     route-distinguisher
peer next-hop-invariable命令用来配置向指定对等体/对等体组发布路由时不改变下一跳。
undo peer next-hop-invariable命令用来配置向对等体/对等体组发布路由时会将下一跳改为自己的地址。
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
BGP VPNv4地址族视图
group-name:对等体组的名称,为1~47个字符的字符串,区分大小写。
ipv4-address:对等体的IP地址。
如果在跨域VPN OptionC组网中使用路由反射器RR(Route Reflector)通告VPNv4路由,则需要在路由反射器上通过本命令配置向BGP邻居和反射客户通告VPNv4路由时,不改变路由的下一跳,以保证私网路由下一跳不会被修改。
本命令与peer next-hop-local命令互斥。
# 在BGP VPNv4地址族视图下,配置向对等体1.1.1.1发布路由时不改变下一跳。
[Sysname] bgp 100
[Sysname-bgp-default-af-vpnv4] peer 1.1.1.1 next-hop-invariable
·     peer next-hop-local(三层技术-IP路由命令参考/BGP)
policy vpn-target命令用来配置对接收到的VPNv4路由进行VPN-Target过滤,即只将Export Route Target属性与本地Import Route Target属性匹配的VPNv4路由加入到路由表。
undo policy vpn-target命令用来配置对接收到的VPNv4路由不进行VPN-Target过滤,即接收所有VPNv4路由。
policy vpn-target
对接收到的VPNv4路由进行VPN-Target过滤。
BGP VPNv4地址族视图
在跨域VPN OptionB组网中,ASBR需要保存所有VPNv4路由信息,以通告给对端ASBR。这种情况下,ASBR上需执行undo policy vpn-target命令接收所有的VPNv4路由信息,不对它们进行VPN-Target过滤。
# 在BGP VPNv4地址族视图下,配置对接收到的VPNv4路由不进行VPN-Target过滤。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] undo policy vpn-target
route-distinguisher命令用来配置VPN实例的RD(Route Distinguisher,路由标识)。
undo route-distinguisher命令用来恢复缺省情况。
未配置VPN实例的RD。
VPN实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
RD用于解决不同VPN之间地址空间重叠的问题。将RD添加到一个IPv4前缀之前,使之成为全局唯一的VPN-IPv4地址前缀。
为了保证VPN-IPv4地址全球唯一,建议不要将自治系统号/IP地址设置为私有AS号/私有IP地址。
不能通过重复执行route-distinguisher命令修改VPN实例的RD值。如需修改VPN实例的RD值,请先通过undo route-distinguisher命令删除VPN实例的RD值,再执行route-distinguisher命令配置新的RD值。
# 配置VPN实例vpn1的RD为22:1。
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
route-replicate命令用来将公网或其他VPN实例的路由信息引入到指定VPN实例中。
undo route-replicate命令用来取消该配置。
route-replicate from { public | vpn-instance vpn-instance-name } protocol bgp as-number [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol { direct | static | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
undo route-replicate from { public | vpn-instance vpn-instance-name } protocol { direct | static | bgp as-number | { isis | ospf | rip } process-id }
公网或其他VPN实例的路由信息不能引入到指定VPN实例中。
VPN实例IPv4 VPN视图
public:从公网引入路由。
vpn-instance vpn-instance-name:从指定的VPN引入路由。vpn-instance-name表示VPN实例的名称,为1~31个字符的字符串,区分大小写。
protocol:引入指定路由协议的路由。
bgp:BGP协议。
as-number:本地AS号,取值范围为1~4294967295。
direct:直连路由。
static:静态路由。
isis:IS-IS协议。
ospf:OSPF协议。
rip:RIP协议。
process-id:路由协议的进程号,取值范围为1~65535。
advertise:允许发布引入的路由。如果未指定本参数,则表示引入的路由不允许发布。
route-policy route-policy-name:对引入的路由应用路由策略。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
在BGP/MPLS L3VPN组网中,只有Route target属性匹配的VPN实例之间才可以通信。通过配置本功能可以将公网或其他VPN实例的路由信息引入到指定VPN实例中,从而使指定VPN用户可以获取访问公网或其他VPN的路由。
在流量智能调控场景中,不同租户的流量被划分到不同的VPN中。为了使租户流量可以流向公网,则需要配置本功能将公网的路由信息引入到指定VPN实例中。
# 引入公网OSPF的有效路由到VPN实例vpn1中。
[Sysname]ip vpn-instance vpn1
[Sysname-vpn-ipv4-vpn1] route-replicate from public protocol ospf 1
route-tag命令用来配置VPN引入路由的外部路由标记值。
undo route-tag命令用来恢复缺省情况。
route-tag tag-value
undo route-tag
若MPLS骨干网上配置了BGP路由协议,并且BGP的AS号不大于65535,则外部路由标记值的前面两个字节固定为0xD000,后面的两个字节为本端BGP的AS号;否则,外部路由标记值为0。例如,本端BGP AS号为100时,外部路由标记的缺省值为十进制值3489661028,即0xD0000000对应的十进制值(3489660928)+100。
OSPF视图
tag-value:VPN引入路由的外部路由标记值,取值范围为0~4294967295。
在CE双归属(CE连接两个PE)、且PE和CE之间采用OSPF协议交互私网路由的组网中,外部路由标记可以用来避免路由环路。CE连接的一台PE将从对端PE接收到的BGP路由引入OSPF,并通过Type-5或Type-7 LSA发布给CE时,为该Type-5或Type-7 LSA添加本地的外部路由标记。另一台PE接收到CE发布的Type-5或Type-7 LSA后,将其中的外部路由标记值与本地的外部路由标记值进行比较。如果相同(包括接收路由的外部路由标记值和本地的值均为0),则在进行路由计算时忽略该LSA,从而避免路由环路。
外部路由标记值的配置方式及各种方式的优先级为:
(1)     import-route命令配置的tag值优先级最高;
(2)     route-tag、default tag命令配置的tag值优先级其次。其中,route-tag命令用于PE设备,default tag命令用于CE和MCE设备。
同一个区域的PE建议配置相同的外部路由标记值。
外部路由标记值不会在BGP的扩展团体属性中传递,它只在收到BGP路由并且产生OSPF Type-5或Type-7 LSA的PE路由器上起作用。
可以为不同的OSPF进程配置相同的外部路由标记值。
# 为OSPF进程100配置VPN引入路由的外部路由标记值为100。
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
·     import-route(三层技术-IP路由命令参考/OSPF)
·     default(三层技术-IP路由命令参考/OSPF)
routing-table limit命令用来限制VPN实例支持的最多激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
未限制VPN实例支持的最多激活路由前缀数。
VPN实例视图
VPN实例IPv4 VPN视图
VPN实例IPv6 VPN视图
number:指定一个VPN实例最多可以支持的激活路由前缀数。取值范围为1~262144。
warn-threshold:告警门限值,取值范围为1~100,单位为百分比。当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到告警门限值时,产生一条日志信息,但仍然允许激活路由前缀。当VPN实例中的激活路由前缀数达到最多支持激活路由前缀数目时,不再激活新的路由前缀。
simply-alert:指定当VPN实例的激活路由前缀数超过最多支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
通过本命令可以避免PE路由器引入太多的VPN激活路由前缀。
# 限制名为vpn1的VPN实例最多可支持1000条激活路由前缀,并且当激活路由前缀数超过最多支持激活路由前缀数时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
rr-filter命令用来创建路由反射器的反射策略。
undo rr-filter命令用来恢复缺省情况。
undo rr-filter
路由反射器不会对反射的路由进行过滤。
BGP VPNv4地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~199。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的VPNv4路由进行过滤:只有接收的VPNv4路由通过扩展团体属性列表过滤时,路由反射器才会反射该路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 在BGP VPNv4地址族视图下,配置路由反射器只反射通过扩展团体属性列表10过滤的VPNv4路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
sham-link命令用来创建一条OSPF伪连接。
undo sham-link命令用来删除一条已有的OSPF伪连接,或者将指定OSPF伪连接的参数恢复为缺省值。
sham-link source-ip-address destination-ip-address [ cost cost-value | dead dead-interval | hello hello-interval | { { hmac-md5 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit retrans-interval | trans-delay delay | ttl-security hops hop-count ] *
undo sham-link source-ip-address destination-ip-address [ cost | dead | hello | { { hmac-md5 | md5 } key-id | keychain | simple } | retransmit | trans-delay | ttl-security ] *
不存在OSPF伪连接。
OSPF区域视图
source-ip-address:OSPF伪连接的源IP地址。
destination-ip-address:OSPF伪连接的目的IP地址。
cost cost-value:伪连接开销,取值范围为1~65535,缺省值为1。
dead dead-interval:失效间隔,取值范围为1~32768,单位为秒,缺省值为40。建立伪连接的两个路由器上需要配置相同的dead-interval,且至少为hello-interval的4倍。
hello hello-interval:接口上发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10。建立伪连接的两个路由器上需要配置相同的hello-interval。
hmac-md5:HMAC-MD5验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:MD5/HMAC-MD5验证字标识符,取值范围为1~255。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。对于简单验证模式,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。对于MD5/HMAC-MD5验证模式,明文密钥为1~16个字符的字符串;密文密钥为33~53个字符的字符串。
keychain:使用keychain验证方式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
retransmit retrans-interval:接口上重传LSA报文的时间间隔,取值范围是1~3600,单位为秒,缺省值为5。
trans-delay delay:接口上延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1。
ttl-security hops hop-count:开启OSPF报文的GTSM(Generalized TTL Security Mechanism,通用TTL安全保护机制)安全检测功能,并指定允许接收来自OSPF伪连接邻居的报文所经过的路由器的最大跳数。hop-count表示最大跳数,取值范围为1~254。如果未指定本参数,GTSM安全检测功能处于关闭状态。
属于同一个VPN的两个Site之间存在一条区域内OSPF链路(backdoor链路)时,为了避免VPN流量总是通过backdoor链路转发而不走骨干网,可以在PE路由器之间建立OSPF伪连接,使经过MPLS VPN骨干网的路由也成为OSPF区域内路由,确保VPN流量通过骨干网转发。
可以使用MD5/HMAC-MD5验证或简单验证两种方式对OSPF伪连接进行验证,但不能同时使用两种验证方式。使用MD5/HMAC-MD5验证方式时,可配置多条MD5/HMAC-MD5验证命令,但同一key-id只能配置一个验证字。
修改伪连接的OSPF MD5/HMAC-MD5验证字的步骤如下:
(1)     为伪连接配置新的MD5/HMAC-MD5验证字。此时若邻居设备尚未配置新的MD5/HMAC-MD5验证字,便会触发MD5/HMAC-MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5验证字的多份报文,使得无论邻居设备上是否配置新验证字都能验证通过,保持邻居关系。
(2)     在邻居设备上也配置相同的新MD5/HMAC-MD5验证字。当本设备上收到邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5验证平滑迁移过程。
(3)     在本设备和邻居上都执行undo sham-link命令删除旧的MD5/HMAC-MD5验证字。建议不要为伪连接保留多个MD5/HMAC-MD5验证字,每次MD5/HMAC-MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在OSPF伪连接使用keychain验证方式时:
·     OSPF伪连接在发送报文前,会先从keychain获取当前的有效发送key,根据该key的key-id、认证算法和认证密钥进行报文验证,如果当前不存在有效发送key,或者该key的key-id大于255,OSPF伪连接不会发送报文。
·     OSPF伪连接在收到报文后,会根据报文携带的key-id从keychain获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验。如果报文校验失败,或者根据报文中携带的key-id无法从keychain中获取到有效接收key,则该报文将被丢弃。
·     OSPF仅支持MD5和HMAC-MD5认证算法, 仅支持标识符取值范围为0~255的key。
开启OSPF报文的GTSM安全检测功能后,当设备在伪连接上收到OSPF报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,则上送报文;如果不在,则直接丢弃报文。以使设备避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。执行本命令后,设备会将发送报文的初始TTL设置为255。
同一VPN实例的不同OSPF进程下,不能配置源地址、目的地址都相同的伪连接。
两端PE上配置的伪连接必须属于相同的OSPF区域,否则,无法建立OSPF邻居。
开启GTSM功能时,要求本设备和邻居设备上同时支持本特性,指定的hop-count值可以不同,只要能够通过安全检测即可。
# 创建一条OSPF伪连接,源地址为1.1.1.1,目的地址为2.2.2.2。
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] sham-link 1.1.1.1 2.2.2.2
·     display ospf sham-link
snmp context-name命令用来配置VPN实例的SNMP上下文。
未配置VPN实例的SNMP上下文。
VPN实例视图
context-name:SNMP上下文名称,为1~32个字符的字符串,区分大小写。
对于支持多VPN实例的功能(如AAA、NAT),通过MIB(Management Information Base,管理信息库)节点对这些功能进行管理时,这些功能无法获知被管理的节点属于哪个VPN实例。为不同的VPN实例配置不同的SNMP上下文可以解决上述问题。
·     对于SNMPv3报文:
¡     如果报文中不携带上下文,则功能模块对公网的MIB节点进行相应处理。
¡     如果报文中携带上下文,设备上存在对应的SNMP上下文(通过系统视图下的snmp-agent context命令创建),且该上下文与为某一个VPN实例配置的上下文相同,则功能模块对该VPN实例的MIB节点进行相应处理。
¡     其他情况下,不允许对任何MIB节点进行处理。
·     对于SNMPv1/v2c报文:
¡     如果设备上未通过系统视图下的snmp-agent community-map命令将报文中的团体名映射为SNMP上下文,则功能模块对公网的MIB节点进行相应处理。
¡     如果设备上将团体名映射为SNMP上下文,设备上存在对应的SNMP上下文,且该上下文与为某一个VPN实例配置的上下文相同,则功能模块对该VPN实例的MIB节点进行相应处理。
SNMP上下文和团体名的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
为不同VPN实例配置的SNMP上下文不能相同。
在同一个VPN实例下重复执行本命令,则新的配置将覆盖已有配置。
# 配置VPN实例vpna的SNMP上下文为vpna。
[Sysname] snmp-agent context vpna
[Sysname-vpn-instance-vpna] route-distinguisher 22:33
[Sysname-vpn-instance-vpna] snmp context-name vpna
·     snmp-agent community-map(网络管理和监控命令参考/SNMP)
·     snmp-agent context(网络管理和监控命令参考/SNMP)
snmp-agent trap enable l3vpn命令用来开启L3VPN模块的告警功能。
undo snmp-agent trap enable l3vpn命令用来关闭L3VPN模块的告警功能。
L3VPN模块的告警功能处于开启状态。
开启L3VPN模块的告警功能后,在VPN实例内的路由数达到告警门限等情况下,L3VPN模块会产生RFC 4382中规定的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启L3VPN模块的告警功能。
[Sysname] snmp-agent trap enable l3vpn
1.1.27  tnl-policy
tnl-policy命令用来配置VPN实例与指定的隧道策略关联。
undo tnl-policy命令用来恢复缺省情况。
tnl-policy tunnel-policy-name
undo tnl-policy
VPN实例未关联隧道策略。
VPN实例视图
VPN实例IPv4 VPN视图
VPN实例IPv6 VPN视图
tunnel-policy-name:VPN实例的隧道策略名称,为1~19个字符的字符串,区分大小写。
在设备上配置VPN实例与隧道策略关联后,设备将根据指定的隧道策略选择转发该VPN实例流量的隧道。
如果VPN实例未关联隧道策略或者关联的隧道策略尚未配置,则该VPN实例根据缺省选择策略来选择隧道。缺省选择策略为按照LSP隧道->GRE隧道->CR-LSP隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
# 将名为vpn1的VPN实例和隧道策略po1关联起来。
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname-vpn-instance-vpn1] route-distinguisher 22:33
[Sysname-vpn-instance-vpn1] tnl-policy po1
·     tunnel-policy(MPLS命令参考/隧道策略)
1.1.28  vpn popgo
vpn popgo命令用来将Egress PE上私网路由的标签操作方式配置为根据标签查找出接口转发。
undo vpn popgo命令用来恢复缺省情况。
vpn popgo
undo vpn popgo
Egress PE上私网路由的标签操作方式为根据标签查找FIB转发。
BGP实例视图
配置vpn popgo命令后,Egress PE会自动断开并重建与私网内BGP邻居之间的会话,重新学习私网路由。
配置vpn popgo命令后,Egress PE将报文转发给私网时,不支持在多个私网BGP邻居之间进行BGP负载分担。
# 在BGP实例视图下,将Egress PE上私网路由的标签操作方式定制为根据标签查找出接口转发。
[Sysname] bgp 100
[Sysname-bgp-default] vpn popgo
1.1.29  vpn-id
vpn-id命令用来配置VPN实例的ID。
undo vpn-id命令用来恢复缺省情况。
vpn-id vpn-id
undo vpn-id
未配置VPN实例的ID。
VPN实例视图
vpn-id:VPN实例的ID,取值形式为OUI:Index。其中,OUI(Organizationally Unique Identifier,全球统一标识符)的取值范围为十六进制数0~ffffff;Index的取值范围为十六进制数0~ffffff。
VPN ID是VPN实例的唯一标识,不同VPN实例的VPN ID不能相同。
VPN ID的取值不能为0:0。
# 配置VPN实例vpn1的ID为20:1。
[Sysname-vpn-instance-vpn1] vpn-id 20:1
·     display ip vpn-instance
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到VPN实例的路由表中。
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
开启VPN引入等价路由功能后,BGP可以把前缀和RD均相同的多条路由全部引入到VPN实例的路由表中,以便在这些路由之间进行负载分担或MPLS L3VPN快速重路由。
# 在BGP-VPN IPv4单播地址族视图下开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] vpn-route cross multipath
1.1.31  vpn-target
vpn-target命令用来配置VPN实例的Route Target。
undo vpn-target命令用来删除VPN实例的Route Target。
未配置VPN实例的Route Target。
VPN实例视图
VPN实例IPv4 VPN视图
VPN实例IPv6 VPN视图
vpn-target&<1-8>:指定Route Target值。vpn-target为3~21个字符的字符串,取值为AS-number:nn或IP-address:nn。&<1-8>表示前面的参数最多可以输入8次。
Route Target有三种格式:
both:指定配置的Route Target值同时作为Import Target和Export Target。如果未指定both、export-extcommunity和import-extcommunity中的任何一个参数时,缺省值为both。
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
Route Target用来控制VPN路由的发布。PE在发布的VPN路由中添加Route Target扩展团体属性,该属性的值为配置的Export Target。对端PE接收到VPN路由后,将路由中携带的Route Target属性与本地配置的VPN实例的Import Target进行比较,如果二者中存在相同的值,则将该路由学习到该VPN实例的路由表中。
# 为名为vpn1的VPN实例配置Route Target。
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
2 IPv6 MPLS L3VPN
本章只介绍IPv6 MPLS L3VPN的相关命令,IPv4 MPLS L3VPN和IPv6 MPLS L3VPN的公共命令请参见“MPLS命令参考”中的“MPLS L3VPN”。
address-family ipv6命令用来进入VPN实例IPv6 VPN视图。
undo address-family ipv6命令用来删除VPN实例IPv6 VPN视图下的所有配置。
address-family ipv6
VPN实例视图
在VPN实例IPv6 VPN视图下可以配置IPv6 VPN的参数,如IPv6 VPN应用的出方向路由策略、入方向路由策略等。
# 进入VPN实例IPv6 VPN视图。
[Sysname-vpn-instance-vpn1] address-family ipv6
[Sysname-vpn-ipv6-vpn1]
·     address-family ipv4 (VPN instance view)
address-family vpnv6命令用来创建BGP VPNv6地址族,并进入BGP VPNv6地址族视图。如果BGP VPNv6地址族已经存在,则直接进入BGP VPNv6地址族视图
undo address-family vpnv6命令用来删除BGP VPNv6地址族及该视图下的所有配置。
不存在BGP VPNv6地址族。
BGP实例视图
VPN-IPv6地址是指在IPv6地址前缀前增加RD后,形成的地址。在IPv6 MPLS L3VPN组网中,PE设备之间需要交换VPN-IPv6地址族的路由信息(即BGP VPNv6路由)。
在PE设备上,进入BGP VPNv6地址族视图,在该视图下通过peer enable命令使能BGP对等体(通常为对端PE设备)后,PE才能与该对等体交换BGP VPNv6路由。
在BGP VPNv6地址族视图下,还可以配置BGP-VPNv6路由的属性,例如为从对等体/对等体组接收的BGP-VPNv6路由分配的首选值、是否允许本地AS号在接收的BGP-VPNv6路由的AS_PATH属性中出现等。
# 在BGP实例视图下,创建BGP VPNv6地址族,并进入BGP VPNv6地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family vpnv6
[Sysname-bgp-default-af-vpnv6]
disable-dn-bit-check命令用来忽略OSPFv3 LSA的DN位检查。
undo disable-dn-bit-check命令用来恢复缺省情况。
PE上需要检查OSPFv3 LSA的DN位。
OSPFv3视图
DN位用于防止路由环路。当PE设备将BGP路由引入OSPFv3,并生成OSPFv3 LSA时,PE为生成的LSA设置DN位。当其他PE设备收到DN位置位的LSA后,在计算路由时忽略该LSA,从而避免再次通过BGP协议发布该路由造成路由环路。
如果PE在路由计算时希望考虑其他PE发布的所有LSA,则可以配置disable-dn-bit-check命令,使得PE在计算路由时不检查LSA的DN位,DN位置位的LSA也参与路由计算。
执行disable-dn-bit-check命令,可能会导致路由环路,请谨慎使用本命令。
只有在未配置vpn-instance-capability simple命令的OSPFv3多实例进程下执行时,本命令才会生效。
# 配置OSPFv3多实例进程100不检查LSA的DN位。
[Sysname] ospfv3 100 vpn-instance vpn1
[Sysname-ospfv3-100] disable-dn-bit-check
·     disable-dn-bit-set
·     display ospfv3(三层技术-IP路由命令参考/OSPFv3)
disable-dn-bit-set命令用来禁止设置OSPFv3 LSA的DN位。
undo disable-dn-bit-set命令用来恢复缺省情况。
disable-dn-bit-set
PE上将BGP路由引入OSPFv3,并生成OSPFv3 LSA时,为生成的LSA设置DN位。
OSPFv3视图
如果PE希望其他的PE在路由计算时考虑本PE发布的所有LSA,则可以执行disable-dn-bit-set命令,使得本PE在发布LSA时不设置DN位。
执行disable-dn-bit-set命令,可能会导致路由环路,请谨慎使用本命令。
# 配置OSPFv3多实例进程100不设置LSA的DN位。
[Sysname-ospfv3-100] disable-dn-bit-set
·     disable-dn-bit-check
display bgp routing-table vpnv6命令用来显示BGP VPNv6路由信息。
display bgp [ instance instance-name ] routing-table vpnv6 [ [ route-distinguisher route-distinguisher ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv6路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
ipv6-address prefix-length:显示与指定目的网段地址及前缀长度精确匹配的BGP VPNv6路由的详细信息。ipv6-address为目的网段的IPv6地址;prefix-length为目的网段地址的前缀长度,取值范围为0~128。如果未指定本参数,则显示所有BGP VPNv6路由的简要信息。
advertise-info:显示BGP VPNv6路由的通告信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP VPNv6路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
communit-list:显示匹配指定BGP团体列表的BGP VPNv6路由信息。
peer:显示向指定对等体发布或者从指定对等体收到的BGP VPNv6路由信息。
statistics:显示BGP VPNv6路由的统计信息。
如果未指定任何参数,则显示所有BGP VPNv6路由的简要信息。
# 显示所有BGP VPNv6路由的简要信息。
<Sysname> display bgp routing-table vpnv6
 Total number of routes from all PEs: 1
 Total number of routes: 4
* >  Network : 2001:1::                                 PrefixLen : 96
     NextHop : ::                                       LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: ?
*  e Network : 2001:1::                                 PrefixLen : 96
     NextHop : 2001:1::1                                LocPrf    :
     MED     : 0
     Path/Ogn: 65410?
* >  Network : 2001:1::2                                PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
* >i Network : 2001:3::                                 PrefixLen : 96
     NextHop : ::FFFF:3.3.3.9                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# 显示匹配AS路径过滤列表1的BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 as-path-acl 1
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# 显示匹配BGP团体列表100的BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 community-list 100
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# 显示向对等体3.3.3.9发布的所有公网BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: ?
# 显示从对等体3.3.3.9收到的所有公网BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes
     MED     : 0
     Path/Ogn: ?
表2-1 display bgp routing-table vpnv6命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态值:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的VPNv6路由总数
Route distinguisher
路由标识符
路由的总数
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳的IPv6地址
LocPrf
本地优先级
PrefVal
路由首选值
OutLabel
路由的出标签值
MED
Path/Ogn
# 显示到达目的网段2::/64的BGP VPNv6路由的详细信息。
<Sysname> display bgp routing-table vpnv6 2:: 64
 Local AS number: 200
 Paths:   2 available, 1 best
 BGP routing table information of 2::/64:
 Rely nexthop    : ::FFFF:10.1.1.1
 Original nexthop: ::FFFF:10.1.1.1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Backup route.
 Rely nexthop    : 1::1
 Original nexthop: 1::1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
表2-2 display bgp routing-table vpnv6命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
到达目的网络2::/64的BGP路由表项信息
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
Imported route
该路由为引入的路由
Original nexthop
OutLabel
路由的出标签值
AS-path
Origin
路由信息的来源,取值包括:
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     best:最佳路由
IP precedence
QoS local ID
Traffic index
Backup route
该路由为备份的路由
# 显示到达目的网段2001:1::/96的BGP VPNv6路由的通告信息。
<Sysname> display bgp routing-table vpnv6 2001:1:: 96 advertise-info
 Paths:   1 best
 BGP routing table information of 2001:1::/96:
    3.3.3.9
 Inlabel         : 1279
表2-3 display bgp routing-table vpnv6 advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
路由总数
Paths
到达指定目的网络的优选路由数目
到达目的网络2001:1::/96的BGP路由的通告信息
该路由已经向哪些VPNv6对等体发送,以及对等体的数目
Inlabel
路由的入标签
# 显示向对等体3.3.3.9发布的公网BGP VPNv6路由的统计信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes statistics
# 显示从对等体3.3.3.9收到的公网BGP VPNv6路由的统计信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes statistic
表2-4 display bgp routing-table vpnv6 peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示公网BGP VPNv6路由的统计信息。
<Sysname> display bgp routing-table vpnv6 statistics
表2-5 display bgp routing-table vpnv6 statistics命令显示信息描述表
来自所有PE设备的VPNv6路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv6路由总数
display bgp routing-table vpnv6 inlabel命令用来显示所有BGP VPNv6路由的入标签信息。
display bgp [ instance instance-name ] routing-table vpnv6 inlabel
# 显示所有BGP VPNv6路由的入标签信息。
<Sysname> display bgp routing-table vpnv6 inlabel
     NextHop : ::                                       OutLabel  : NULL
     InLabel : 1279
表2-6 display bgp routing-table vpnv6 inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态值:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为VPNv6路由分配的私网标签,取值为NULL表示空标签
InLabel
入标签值,即本地PE为VPNv6路由分配的私网标签
display bgp routing-table vpnv6 outlabel命令用来显示所有BGP VPNv6路由的出标签信息。
display bgp [ instance instance-name ] routing-table vpnv6 outlabel
# 显示所有BGP VPNv6路由的出标签信息。
<Sysname> display bgp routing-table vpnv6 outlabel
     NextHop : ::FFFF:3.3.3.9                           OutLabel  : 1279
表2-7 display bgp routing-table vpnv6 outlabel命令输出信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态值:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的路由数
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IP地址
OutLabel
display ospfv3 sham-link命令用来显示OSPFv3伪连接信息。
display ospfv3 [ process-id ] [ area area-id ] sham-link [ verbose ]
process-id:显示指定OSPFv3进程内的伪连接信息。process-id为OSPFv3进程号,取值范围为1~65535。如果不指定本参数,则显示所有OSPFv3进程的伪连接信息。
area area-id:显示指定OSPFv3区域内的伪连接信息。area-id为OSPFv3区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。如果不指定本参数,则显示所有OSPFv3区域的伪连接信息。
verbose:显示伪连接的详细信息。如果不指定本参数,则显示伪连接的概要信息。
# 显示所有OSPFv3伪连接的概要信息。
<Sysname> display ospfv3 sham-link
               OSPFv3 Process 1 with Router ID 125.0.0.1
 Sham-link (Area: 0.0.0.1)
 Neighbor ID      State  Instance ID  Destination address
 0.0.0.0          Down   1            1:1::58
 95.0.0.1         P-2-P  1            1:1::95
表2-8 display ospfv3 sham-link命令显示信息描述表
Area
伪连接所属的OSPFv3区域
Neighbor ID
伪连接邻居的Router ID
Instance ID
伪连接的接口实例ID
Destination address
伪连接的目的地址
# 显示所有OSPFv3伪连接的详细信息。
<Sysname> display ospfv3 sham-link verbose
 Source      : 1:1::125
 Destination : 1:1::58
 Interface ID: 2147483649
 Neighbor ID : 0.0.0.0, Neighbor state: Down
 Cost: 1  State: Down  Type: Sham  Instance ID: 1
 Timers: Hello 10, Dead 40, Retransmit 5, Transmit delay 1
 Keychain authentication: Enabled (test), inherited
 Source      : 1:1::125
 Destination : 1:1::95
 Interface ID: 2147483650
 Neighbor ID : 95.0.0.1, Neighbor state: Full
 Cost: 1  State: P-2-P  Type: Sham  Instance ID: 1
表2-9 display ospf sham-link verbose命令显示信息描述表
Area
伪连接所属的OSPFv3区域
Source
伪连接的源地址
Destination
伪连接的目的地址
Interface ID
伪连接的接口索引
Neighbor ID
伪连接邻居的Router ID
Neighbor state
伪连接邻居状态,取值包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Cost
伪连接的开销
接口类型,取值固定为Sham,表示为伪连接
Instance ID
伪连接的接口实例ID
Timers
伪连接的定时器,单位为秒,包括Hello,Dead,Retransmit和Transmit Delay定时器
Request list
请求列表中LSA的个数
Retransmit list
重传列表中LSA的个数
IPsec profile name
伪连接引用的IPsec安全框架名
OSPFv3伪连接采用keychain验证模式,keychain名称为test,inherited表示伪连接继承的是其所属区域的keychain验证模式
domain-id命令用来配置OSPFv3域标识符。
domain-id { domain-id [ secondary ] | null }
undo domain-id [ domain-id | null ]
OSPFv3域标识符为0。
OSPFv3视图
domain-id:OSPFv3域标识符,可以采用以下三种形式:
·     整数形式,取值范围为0~4294967295,例如:1;
·     点分十进制形式,例如:0.0.0.1;
·     点分十进制:16位二进制数,例如:0.0.0.1:512。
secondary:指定配置的域标识符作为从域标识符。如果不指定本参数,表示配置的域标识符为主域标识符。
null:指定无域标识符,即团体属性中不携带域标识符。
如果通过domain-id命令配置了OSPFv3域标识符,则PE将OSPFv3路由引入到BGP时,配置的主域标识符被附加到BGP VPNv6路由上作为BGP的扩展团体属性传递给对端PE。对端PE接收到BGP VPNv6路由后,将本地配置的OSPFv3主域标识符、从域标识符和路由中携带的OSPFv3域标识符进行比较:如果主域标识符或从域标识符与路由携带的域标识符相同,且为区域内或区域间路由,则将路由重新引入到OSPFv3时,该路由将作为Inter-Area-Prefix LSA(即Type-3 LSA)向外发布;否则,该路由将作为AS External LSA(即Type-5 LSA)或NSSA External LSA(即Type-7 LSA)向外发布。
如果一端PE的域标识符配置为null,另一端PE配置为0,则比较域标识符时,认为二者的域标识符相同。
主域标识符的值为0时,不能配置从域标识符。
执行undo domain-id命令时,如果不指定任何参数,将恢复缺省情况。
# 配置OSPFv3多实例进程100的主域标识符为1.1.1.1。
[Sysname-ospfv3-100] domain-id 1.1.1.1
ext-community-type命令用来配置OSPFv3扩展团体属性的类型编码。
undo ext-community-type命令用来将指定OSPFv3扩展团体属性的类型编码恢复为缺省值。
ext-community-type { domain-id type-code1 | route-type type-code2 | router-id type-code3 }
undo ext-community-type [ domain-id | route-type | router-id ]
OSPFv3扩展团体属性Domain ID的类型编码是0x0005,Route Type的类型编码是0x0306,Router ID的类型编码是0x0107。
OSPFv3视图
domain-id type-code1:指定OSPFv3扩展团体属性Domain ID的类型编码。type-code1取值可以为十六进制数值0005、0105、0205和8005。
route-type type-code2:指定OSPFv3扩展团体属性Route Type的类型编码。type-code2取值可以为十六进制数值0306和8000。
router-id type-code3:指定OSPFv3扩展团体属性Router ID的类型编码。type-code3取值可以为十六进制数值0107和8001。
# 配置OSPFv3多实例进程100扩展团体属性Domain ID的类型编码为0x8005,Route Type的类型编码为0x8000,Router ID的类型编码为0x8001。
[Sysname-ospfv3-100] ext-community-type domain-id 8005
[Sysname-ospfv3-100] ext-community-type route-type 8000
[Sysname-ospfv3-100] ext-community-type router-id 8001
policy vpn-target命令用来配置对接收到的VPNv6路由进行VPN-Target过滤,即只将Export Route Target属性与本地Import Route Target属性匹配的VPNv6路由加入到路由表。
undo policy vpn-target命令用来配置对接收到的VPNv6路由不进行VPN-Target过滤,即接收所有VPNv6路由。
policy vpn-target
对接收到的VPNv6路由进行VPN-Target过滤。
BGP VPNv6地址族视图
在跨域VPN OptionB组网中,ASBR需要保存所有VPNv6路由信息,以通告给对端ASBR。这种情况下,ASBR上需执行undo policy vpn-target命令接收所有的VPNv6路由信息,不对它们进行VPN-Target过滤。
# 在BGP VPNv6地址族视图下,配置对接收到的VPNv6路由不进行VPN-Target过滤。
[Sysname] bgp 100
[Sysname-bgp-default-af-vpnv6] undo policy vpn-target
route-tag tag-value
undo route-tag
OSPFv3视图
在CE双归属(CE连接两个PE)、且PE和CE之间采用OSPFv3协议交互私网路由的组网中,外部路由标记可以用来避免路由环路。CE连接的一台PE将从对端PE接收到的BGP VPNv6路由引入OSPFv3,并通过Type-5或Type-7 LSA发布给CE时,为该Type-5或Type-7 LSA添加本地配置的外部路由标记。另一台PE上如果通过route-tag-check enable命令使能了OSPFv3 LSA的tag标记检查,则PE接收到CE发布的Type-5或Type-7 LSA后,将其中的外部路由标记值与本地配置的值进行比较。如果相同,则在进行路由计算时忽略该LSA,从而避免路由环路。
(1)     import-route命令配置的tag值优先级最高。
(2)     route-tag、default tag命令配置的tag优先级其次。其中,route-tag命令用于PE设备,default tag命令用于CE和MCE设备。
外部路由标记值不会在BGP的扩展团体属性中传递,它只在收到BGP路由并且产生OSPFv3 Type-5或Type-7 LSA的PE路由器上起作用。
本命令只能在OSPFv3多实例进程下执行,并且只有在未配置vpn-instance-capability simple命令的OSPFv3多实例进程下执行时,本命令才会生效。
# 配置OSPFv3多实例进程100的VPN引入路由的外部路由标记值为100。
[Sysname-ospfv3-100] route-tag 100
·     default tag(三层技术-IP路由命令参考/OSPFv3)
·     import-route(三层技术-IP路由命令参考/OSPFv3)
·     route-tag-check enable
route-tag-check enable命令用来使能OSPFv3 LSA的外部路由标记检查功能。
undo route-tag-check enable命令用来关闭OSPFv3 LSA的外部路由标记检查功能。
OSPFv3 LSA的外部路由标记检查功能处于关闭状态。
OSPFv3视图
在CE双归属(CE连接两个PE)、且PE和CE之间采用OSPFv3协议交互私网路由的组网中,外部路由标记可以用来避免路由环路。CE连接的一台PE将从对端PE接收到的BGP VPNv6路由引入OSPFv3,并通过Type-5或Type-7 LSA发布给CE时,为该Type-5或Type-7 LSA添加本地配置的外部路由标记。另一台PE上如果通使能了OSPFv3 LSA的外部路由标记检查功能,则PE接收到CE发布的Type-5或Type-7 LSA后,将其中的外部路由标记值与本地配置的值进行比较。如果相同,则在进行路由计算时忽略该LSA,从而避免路由环路。
通常情况下,在上述组网中PE通过DN位来避免路由环路。LSA的外部路由标记检查只是为了兼容不支持DN位的设备。如果网络中不存在这类设备,建议不要配置本命令。
# 在OSPFv3多实例进程100下使能OSPFv3 LSA的外部路由标记检查功能。
[Sysname-ospfv3-100] route-tag-check enable
·     route-tag
undo rr-filter
路由反射器不会对反射的路由进行过滤。
BGP VPNv6地址族视图
执行本命令后,路由反射器将根据扩展团体属性列表对接收的VPNv6路由进行过滤:只有接收的VPNv6路由通过扩展团体属性列表过滤时,路由反射器才会反射该路由。
# 在BGP VPNv6地址族视图下,配置路由反射器只反射通过扩展团体属性列表10过滤的VPNv6路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv6] rr-filter 10
sham-link命令用来创建一条OSPFv3伪连接。
undo sham-link命令用来删除一条已有的OSPFv3伪连接,或者将指定OSPFv3伪连接的参数恢复为缺省值。
sham-link source-ipv6-address destination-ipv6-address [ cost cost-value | dead dead-interval | hello hello-interval | instance instance-id | ipsec-profile profile-name | keychain keychain-name | retransmit retrans-interval | trans-delay delay ] *
undo sham-link source-ipv6-address destination-ipv6-address [ cost | dead | hello | ipsec-profile | keychain | retransmit | trans-delay ] *
不存在OSPFv3伪连接。
OSPFv3区域视图
source-ipv6-address:OSPFv3伪连接的源IPv6地址。
destination-ipv6-address:OSPFv3伪连接的目的IPv6地址。
dead dead-interval:失效时间间隔,取值范围为1~32768,单位为秒,缺省值为hello-interval的4倍。建立伪连接的两个路由器上需要配置相同的dead-interval,且至少为hello-interval的4倍。
instance instance-id:伪连接的实例ID,取值范围为0~255,缺省值为0。
ipsec-profile profile-name:指定伪连接引用的IPsec安全框架。profile-name为IPsec安全框架名称,为1~63个字符的字符串,不区分大小写。
keychain:使用keychain验证模式。
属于同一个VPN的两个Site之间存在一条区域内OSPFv3链路(backdoor链路)时,为了避免VPN流量总是通过backdoor链路转发而不走骨干网,可以在PE设备之间建立OSPFv3伪连接,使经过MPLS VPN骨干网的路由也成为OSPFv3区域内路由,确保VPN流量通过骨干网转发。
在OSPFv3伪连接下配置的验证模式,其优先级高于在OSPFv3伪连接所属区域下配置的验证模式。只有在OSPFv3伪连接下未配置验证模式时,OSPFv3伪连接所属区域下配置的验证模式才会对该伪连接生效。
在OSPFv3伪连接使用keychain验证模式时,报文的收、发过程如下:
·     OSPFv3在发送报文前,会先从keychain获取当前的有效发送key,根据该key的标识符、认证算法和认证密钥进行报文验证。如果当前不存在有效发送key,OSPFv3不会发送报文。
·     OSPFv3在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPFv3的支持情况如下:
·     OSPFv3仅支持HMAC-SHA-256认证算法。
·     OSPFv3仅支持标识符取值范围为0~65535的key。
# 创建一条OSPFv3伪连接,源地址为1::1,目的地址为2::2。
[Sysname-ospfv3-100] area 0
[Sysname-ospfv3-100-area-0.0.0.0] sham-link 1::1 2::2
·     display ospfv3 sham-link
