H3C S3200系列以太网 PON OLT交换机 命令参考-6W101
02-端口配置命令
本章节下载: 02-端口配置命令  (236.93 KB)
02-端口配置命令
1 端口配置命令
1.1 以太网端口配置命令
1.1.1 clear interface
1.1.2 description
1.1.3 duplex
1.1.4 flow-control
1.1.5 ingress acceptable-frame
1.1.6 ingress filtering
1.1.7 priority
1.1.8 display description
1.1.9 display interface
1.1.10 display statistics interface
1.1.11 shutdown
1.1.12 port-control mode
1.1.13 display port-control mode
1.1.14 speed
1.1.15 bandwidth-control
1.1.16 display bandwidth-control
1.1.17 port hybrid pvid vlan
1.1.18 port link-type
1.1.19 port trunk permit vlan
1.1.20 port hybrid vlan untagged
1.1.21 port hybrid vlan  tagged
1.1.22 display statistics dynamic interface
1.1.23 display utilization interface
1.2 端口镜像配置命令
1.2.1 mirror destination-interface
1.2.2 mirror source-interface
1.2.3 display mirror
1.2.4 undo mirror all
1.3 端口CAR配置命令
1.3.1 port-car
1.3.2 port-car-rate
1.3.3 display port-car
1.4 端口LACP汇聚配置命令
1.4.1 channel-group
1.4.2 channel-group mode
1.4.3 channel-group load-balance
1.4.4 lacp system-priority
1.4.5 lacp port-priority
1.4.6 display lacp sys-id
1.4.7 display lacp internal
1.4.8 display lacp neighbor
1.4.9 display statistics channel-group
1.4.10 clear channel-group
1.4.11 display statistics dynamic channel-group
1.4.12 display utilization channel-group
1.5 端口利用率告警配置命令
1.5.1 alarm all-packets
1.5.2 alarm all-packets threshold
1.5.3 display alarm all-packets
1.5.4 display alarm all-packets interface
1.6 端口shutdown-control配置命令
1.6.1 shutdown-control
1.6.2 shutdown-control-recover
1.6.3 display shutdown-control
1.6.4 undo shutdown-control-recover
1 端口配置命令
1.1  以太网端口配置命令
以太网端口配置命令包括:
·     clear interface
·     description
·     duplex
·     flow-control
·     ingress acceptable-frame
·     link-aggregation
·     priority
·     display description
·     display interface
·     display statistics interface
·     shutdown
·     port-control mode
·     display port-control mode
·     speed
·     port  hybrid pvid vlan
·     port  link-type
·     port  trunk  permit  vlan
·     port  hybrid    vlan untagged
·     port  hybrid    vlan tagged
·     display statistics dynamic interface
·     display utilization interface
clear interface [ interface-num | slot-num ]
系统视图/端口视图
【缺省级别】
2:系统级
interface-num:表示以太网端口,由端口类型 + 端口号组成,端口类型是gigabitethernet,端口号的表示形式为slot_num/board_num/port-num,slot_num是槽位号,取值为1,board_num是板卡号,取值为0,port-num是板卡上的端口号,取值范围是1~8。
【描述】
clear interface命令用于清除端口统计信息。
# 清除所有端口的统计信息。
[H3C]clear interface
# 两种视图下清除以太网端口5的统计信息。
[H3C]clear interface gigabitethernet 1/0/5
[H3C-GigabitEthernet 1/0/5]clear interface
1.1.2  description
description description-list
以太网端口视图
【缺省级别】
2:系统级
description-list:端口描述字符串,长度为1~128个字符。
【描述】
description命令用来配置端口的描述,此命令的undo形式用来取消端口描述。
# 配置以太网端口3的描述为green。
[H3C-GigabitEthernet 1/0/3]description green
# 清除以太网端口3的描述。
[H3C-GigabitEthernet 1/0/3]undo description
1.1.3  duplex
duplex { half | full | auto }
undo duplex
二层以太网端口视图/端口组视图
【缺省级别】
2:系统级
half:端口半双工属性。
full:端口全双工属性。
auto:端口双工状态处于自协商状态。
缺省auto。
【描述】
duplex命令用来设置以太网端口的全双工/半双工属性,此命令的undo形式用来将端口的双工状态恢复成缺省的自协商状态。
设置端口的传输特性时,当希望在发送数据包的同时可以接收数据包,可以将端口设置为全双工属性;当希望端口同一时刻只能发送数据包或接收数据包时,可以将端口设置为半双工属性;当设置端口为auto 状态时,端口的双工状态由本端口和对端端口双方自动协商而定。
千兆光口支持full和auto两种模式,百兆光口只支持full模式。
# 设置当前以太网端口5的双工属性为全双工。
[H3C-GigabitEthernet 1/0/5]duplex full
1.1.4  flow-control
flow-control
undo flow-control
二层以太网端口视图/端口组视图
【缺省级别】
2:系统级
无
【描述】
该命令用来开启以太网端口的流量控制特性,此命令的undo形式用来关闭以太网端口的流量控制特性。
缺省为关闭所有端口的流量控制特性。
如果端口的流量比较大,需要对其进行控制,以避免造成网络拥塞,丢失数据包。此时可以使用该命令对端口流量进行控制。
# 打开以太网端口5的流量控制功能。
[H3C-GigabitEthernet 1/0/5]flow-control
# 关闭以太网端口5的流量控制功能。
[H3C-GigabitEthernet 1/0/5]undo flow-control
ingress acceptable-frame { all | tagged }
undo ingress acceptable-frame
端口视图
【缺省级别】
2:系统级
无
【描述】
该命令用来配置允许端口接收的帧类型,此命令的undo形式用来恢复默认的允许端口接收的帧类型。
缺省为允许端口接收所有类型的帧。
当开启了端口的接收帧类型功能时,端口在接收到非该类型帧时将丢弃该帧;当端口的接收帧类型功能被关闭时,接收所有帧。
# 配置以太网端口5只接收tagged类型的帧。
[H3C-GigabitEthernet 1/0/5]ingress acceptable-frame tagged
# 恢复以太网端口5默认的接收帧类型。
[H3C-GigabitEthernet 1/0/5]undo ingress acceptable-frame
ingress filtering
undo ingress filtering
端口视图
【缺省级别】
2:系统级
无
【描述】
该命令用来开启端口的输入过滤功能,此命令的undo形式用来关闭端口的输入过滤功能。
缺省为打开端口的输入过滤功能。
当开启了端口的输入过滤功能时,端口在接收到VLAN ID不等于端口所在VLAN 的ID的帧时将丢弃该帧;当端口的输入过滤功能被关闭时,则不丢弃帧。
# 打开以太网端口5的输入过滤功能。
[H3C-GigabitEthernet 1/0/5]ingress filtering
# 关闭以太网端口5的输入过滤功能。
[H3C-GigabitEthernet 1/0/5]undo ingress filtering
1.1.7  priority
priority priority-value
undo priority
端口视图
【缺省级别】
2:系统级
priority-value:端口的优先级,取值范围为0~7。
【描述】
该命令用来确定指定端口的优先级,此命令的undo形式用来恢复端口优先级为缺省值。
缺省的端口优先级为0。
端口优先级值越大优先级越高。
# 配置以太网端口3优先级为1。
[H3C-GigabitEthernet 1/0/3]priority 1
display description interface [ interface-list ]
【缺省级别】
2:系统级
interface-list:选择的端口列表,表示多个以太网端口。
【描述】
该命令用来显示端口的描述。
在显示端口描述时,如果不指定端口列表,则显示所有的端口描述;如果指定端口列表,则显示指定的端口描述。
# 显示以太网端口3的端口描述。
[H3C]display description interface gigabitethernet 1/0/3
display interface [ interface-num ]
【缺省级别】
2:系统级
interface-num:指定端口的端口编号。由端口类型 + 端口号组成,端口类型是gigabitethernet,端口号的表示形式为slot-num/broad-num/port-num,slot-num取值为1,broad-num是槽号,取值为0,port-num是槽中的端口号,取值范围是1~8。
【描述】
该命令用来显示端口的配置信息。
在显示端口信息时,如果不指定端口类型和端口号,则显示所有端口的信息;如果指定端口类型和端口号,则显示指定端口的信息。
# 显示以太网端口1的配置信息。
[H3C]display interface gigabitethernet 1/0/1
Gigabit Ethernet e1/0/1 current state: enabled, port link is up
 Time duration of linkup is 12 minute 56 second
 Hardware address is 000a-5a21-ff3c
 SetSpeed is auto, ActualSpeed is full-1000, porttype is 10/100/1000M
 Combo port's medium working mode is copper
 Priority is 0
 SFP module not exist
 Flow control is disabled
 Broadcast storm control target rate is 2048Kbps
 PVID is 1
 Port mode: hybrid
 Tagged   VLAN ID:
 Untagged VLAN ID: all
 Input : 0 packets, 0 bytes
         0 broadcasts, 0 multicasts, 0 unicasts
 Output: 21041729 packets, 1360768808 bytes
         3999 broadcasts, 2802 multicasts, 21034928 unicasts
display statistics interface [ interface-num ]
所有命令视图
【缺省级别】
2:系统级
【描述】
该命令用来显示指定端口或所有端口的统计信息。
在显示端口统计信息时,如果不指定端口类型和端口号,则显示所有端口的统计信息;如果指定端口类型和端口号,则显示指定端口的统计信息。
# 显示以太网端口1的统计信息。
<H3C>display statistics interface gigabitethernet 1/0/1
1.1.11  shutdown
shutdown
端口视图
【缺省级别】
2:系统级
无
【描述】
该命令用来关闭以太网端口,此命令的undo形式用来打开以太网端口。
缺省情况下,开启以太网端口。
当端口的相关参数及协议配置好之后可以使用undo shutdown命令启动端口; 或者当端口出现故障时可以将端口先关闭然后再启动,这样有可能使端口恢复正常。
# 关闭端口后再启动端口。
[H3C-GigabitEthernet 1/0/1]shutdown
[H3C-GigabitEthernet 1/0/1]undo shutdown
port-control mode { master | slave }
undo port-control mode
端口视图
【缺省级别】
2:系统级
master:主控。
slave:从属。
【描述】
该命令用来配置扩展千兆电口速率控制模式,此命令的undo形式用来恢复端口速率控制模式为默认的auto master/slave转换模式。
缺省情况下,默认为auto master/slave转换模式。
当两扩展千兆电口相连接且速率被设置为强制模式时,配置相连的两端口分别在master和slave模式下,使端口对接成功。
# 配置以太网端口1为master模式后再恢复为auto master/slave转换模式。
[H3C-GigabitEthernet 1/0/1] port-control mode master
[H3C-GigabitEthernet 1/0/1] undo port-control mode
【缺省级别】
2:系统级
无
【描述】
该命令用来显示所有扩展千兆电口的速率控制模式信息。
因只有扩展千兆电口需要进行端口速率控制模式master/slave的配置,因此也只显示千兆电口的速率控制模式信息。
# 显示扩展千兆电口的速率控制模式信息。
[H3C] display port-control mode
1.1.14  speed
speed { 10 | 10auto | 100 | 100auto | 1000 | 1000auto | auto }
undo speed
端口视图
【缺省级别】
2:系统级
10:表示端口速率为10Mbps。
100:表示端口速率为100Mbps。
1000:表示端口速率为1000Mbps。
10auto: 表示端口速率最大为10Mbps,并且双工模式处于自协商状态。
100auto: 表示端口速率最大为100Mbps,并且双工模式处于自协商状态。
1000auto: 表示端口速率最大为1000Mbps,并且双工模式处于自协商状态。
auto: 表示端口速率和双工模式为自协商状态。
【描述】
该命令用来设置端口的速率,此命令的undo形式用来恢复端口的速率为缺省值。
缺省情况下,默认为auto。
百兆电口卡支持10Mbps和100Mbps速率;百兆光口卡只支持100Mbps速率;千兆电口卡支持10Mbps、100Mbps和1000Mbps速率;千兆光口卡只支持1000Mbps速率;百兆电口卡及千兆电口卡支持全双工、半双工、自协商模式;百兆光口卡只支持全双工模式;千兆光口卡支持全双工和自协商模式。
# 设置以太网端口1的端口速率为100Mbps。
[H3C-GigabitEthernet 1/0/1]speed 100
bandwidth-control { ingress | egress } target-rate
undo bandwidth-control { ingress | egress }
端口视图
【缺省级别】
2:系统级
ingress:进口。
Egress:出口。
target-rate:对端口发送报文限制的总速率,取值范围为64~1024000,单位为Kbps。
【描述】
该命令用来进行端口限速,对端口收或发的报文的总速率进行限制,此命令的undo形式用来取消端口限速的配置。
使用本命令用来进行端口限速,对端口接收或发送报文的总速率进行限制。
# 下面的命令对快速以太网端口1 限速为10Mbps。
[H3C-GigabitEthernet 1/0/1] bandwidth-control ingress 10240
【缺省级别】
2:系统级
无
【描述】
该命令用来显示指定端口的带宽控制。
# 显示带宽控制。
[H3C]display bandwidth-control interface
port hybrid pvid vlan vlan-id
端口视图
【缺省级别】
2:系统级
vlan-id:表示VLAN的ID,取值范围为1~4094。
【描述】
此命令用于把当前端口加入到指定的VLAN中,并设置该端口默认vlan-id为此指定的VLAN。
此命令使用的条件是vlan-id所指的VLAN必须存在。
# 将以太网端口1的默认vlan-id配置为vlan 2。
[H3C-GigabitEthernet 1/0/1] port hybrid pvid vlan 2
undo port link-type
端口视图
【缺省级别】
2:系统级
access:设置端口为access端口,此端口只能属于一个VLAN,该VLAN即为该端口的缺省VLAN,并且在该VLAN中为untagged状态。
hybrid:设置端口为hybrid端口,在其所属的VLAN中可以为tagged状态,也可以为untagged状态。
trunk:设置端口为trunk端口,在其所属的VLAN中全部为tagged状态。
【描述】
可以使用该命令设置端口类型,此命令的undo形式用来恢复端口为缺省状态,即为hybrid端口。
端口缺省为hybrid端口。
使用port link-type命令把端口设为trunk端口、hybrid端口或access端口,设为trunk端口后,此端口在其所在VLAN中的状态也将由untagged变为tagged,同理,如果把一个端口从trunk端口设置为hybrid端口后, 那么此端口在其所在VLAN中状态也将由tagged变为untagged,如果把端口设置为access端口,那么只保留此端口缺省VLAN为untagged vlan,此端口从其他VLAN中全部删除。
# 将以太网端口1设置为trunk端口。
[H3C-GigabitEthernet 1/0/1]port link-type trunk
port trunk permit vlan { vlan-list | all }
undo port trunk  permit  vlan { vlan-list | all }
端口视图
【缺省级别】
2:系统级
vlan-list: vlan-list可以用离散的数字、连续一段数字、离散和连续混合的数字表示,其中离散的数字之间用逗号分隔,数字段用减号表示,如:2,5,8,10-20。下文中的vlan-list均以此格式表示。
all:将trunk端口加入到所有VLAN中。
【描述】
该命令用来将trunk端口加入到指定的VLAN,此命令的undo形式用来将trunk端口从指定的VLAN中删除。
该命令用来将trunk端口加入到指定的VLAN中。trunk端口可以属于多个VLAN。如果多次使用port trunk permit vlan命令,那么trunk端口上允许通过的VLAN是这些vlan-list的集合。
# 将trunk端口1加入到3、4、70~150 VLAN中。
[H3C-GigabitEthernet 1/0/1]port trunk permit vlan 3,4,70-150
port hybrid vlan { vlan-list | all } untagged
undo port hybrid vlan { vlan-list | all }
端口视图
【缺省级别】
2:系统级
vlan-list:VLAN列表。
all:所有已经存在的VLAN。
【描述】
port hybrid vlan { vlan-list | all } untagged:用来将hybrid端口加入到指定的VLAN中,并且为untagged。
undo port hybrid vlan { vlan-list | all }:将hybrid端口从指定的VLAN中删除。
# 将hybrid端口1加入到3、4、70~150 VLAN中。
[H3C-GigabitEthernet 1/0/1]port hybrid vlan 3,4,70-150 untagged
port hybrid vlan { vlan-list | all } tagged
端口视图
【缺省级别】
2:系统级
vlan-list:VLAN列表。
all:所有已经存在的VLAN。
【描述】
该命令用来将hybrid端口加入到指定的VLAN中,并且为tagged。hybrid端口可以属于多个VLAN,如果多次使用该命令,那么hybrid端口上允许通过的tagged VLAN是这些vlan-list的集合。
[H3C-GigabitEthernet 1/0/1]port hybrid vlan 3,4,70-150 tagged
【缺省级别】
2:系统级
 无
【描述】
该命令用来实时显示所有端口的统计信息。
在显示端口统计信息时,端口统计信息每三秒钟自动刷新一次。
# 实时显示端口的统计信息。
<H3C>display statistics dynamic interface
【缺省级别】
2:系统级
无。
【描述】
该命令用来实时显示所有端口的使用情况,包括端口接收和发送的速率,端口带宽占用率等。
在显示端口使用情况时,端口接收和发送速率以及带宽占用率等信息每3秒钟刷新一次。
# 实时显示端口的使用信息。
[H3C]display utilization interface
1.2  端口镜像配置命令
端口镜像配置命令包括:
·     mirror destination-interface
·     mirror source-interface
·     display mirror
mirror destination-interface interface-num
undo mirror destination-interface interface-num
【缺省级别】
2:系统级
【描述】
该命令用来设置镜像端口,此命令undo形式用来删除镜像端口。
# 配置以太网端口1为镜像端口。
[H3C]mirror destination-interface  gigabitethernet  1/0/1
mirror source-interface { interface- num | cpu } { both | egress | ingress }
undo mirror source-interface { interface- num | cpu }
【缺省级别】
2:系统级
cpu:代表CPU端口。
both:代表对端口的出口和入口都镜像。
egress:代表对端口的出口镜像。
ingress:代表对端口的入口镜像。
【描述】
该命令用来设置被镜像的端口,此命令undo形式用来删除被镜像端口。
# 配置以太网端口2入方向为被镜像端口。
[H3C]mirror source-interface gigabitethernet 1/0/2 ingress
display mirror
【缺省级别】
2:系统级
无
【描述】
该命令可以查看系统当前镜像端口的设置内容,包括系统的镜像端口和被镜像端口列表。
# 显示镜像端口和被镜像端口列表信息。
[H3C]display mirror
Information about mirror port(s]
The monitor port            : e1/0/1
The mirrored egress ports   : e1/0/2
The mirrored ingress ports  : e1/0/2
undo mirror all
【缺省级别】
2:系统级
无
【描述】
该命令可以删除系统当前所有端口镜像和流镜像。
# 删除所有端口镜像和流镜像。
[H3C]undo mirror all
1.3  端口CAR配置命令
端口CAR配置命令包括:
·     port-car
·     port-car-rate
·     display port-car
1.3.1  port-car
port-car
undo port-car
系统视图/以太网端口视图
【缺省级别】
2:系统级
无
【描述】
该命令用来开启全局或端口的端口CAR,此命令的undo形式用来关闭全局或端口的端口CAR。
缺省为开启全局端口CAR。
# 打开全局端口CAR。
[H3C]port-car
# 打开以太网8端口的端口CAR。
[H3C-GigabitEthernet 1/0/8]port-car
1.3.2  port-car-rate
port-car-rate port-car-rate
undo port-car-rate
系统视图/端口视图
【缺省级别】
2:系统级
port-car-rate:全局CAR的值,取值范围为0~1000。
port-car-rate:端口CAR的值,取值范围为1~128。
【描述】
该命令用来设置全局或端口CAR 的值,此命令undo形式用来恢复全局或端口默认的CAR的值。
全局CAR的默认值为720 packet/second,端口CAR的缺省值为30 packet/second。
# 配置全局CAR的值为500 packet/second。
[H3C]port-car-rate 500
display port-car
【缺省级别】
2:系统级
无
【描述】
该命令用来显示端口CAR 的相关信息。
# 显示端口CAR信息。
[H3C]display port-car
Port CAR global status: enable
Port CAR rate(packet/second): 720
port     status     port-car-rate
p1/0/1   enable     30
p1/0/2   enable     30
p1/0/3   enable     30
p1/0/4   enable     30
p1/0/5   enable     30
p1/0/6   enable     30
p1/0/7   enable     30
p1/0/8   enable     30
e1/0/1   enable     30
e1/0/2   enable     30
e1/0/3   enable     30
e1/0/4   enable     30
e1/0/5   enable     30
e1/0/6   enable     30
e1/0/7   enable     30
e1/0/8   enable     30
1.4  端口LACP汇聚配置命令
端口LACP汇聚配置命令包括:
·     channel-group
·     channel-group mode
·     channel-group load-balance
·     lacp system-priority
·     lacp port-priority
·     display lacp sys-id
·     display lacp internal
·     display lacp neighbor
·     display statistics channel-group
·     clear channel-group
·     display statistics dynamic channel-group
·     display utilization channel-group
1.4.1  channel-group
channel-group channel-group-number
undo channel-group channel-group-number
【缺省级别】
2:系统级
channel-group-number:取值范围为0~7。
【描述】
该命令用来创建创建汇聚通道组,但通道内不包含任何成员。删除通道时,需要首先删除通道内所有成员。使用undo进行删除操作。
# 创建汇聚组通道1。
[H3C]channel-group 1
channel-group channel-group-number mode { active | passive | on }
端口视图
【缺省级别】
2:系统级
【描述】
该命令向汇聚通道中添加端口成员,并且指定成员的工作模式,使用undo命令就把成员从通道中删除。
# 添加以太网端口3到第三个通道中,并指定这个端口为active模式。
[H3C-GigabitEthernet 1/0/3]channel-group 3 mode active
# 添加以太网端口6~8到第二个通道中,并指定三个端口为on模式。
[H3C]interface range gigabitethernet 1/0/6 to gigabitethernet 1/0/8
[H3C-if-range]channel-group 2 mode on
channel-group load-balance { dst-ip | dst-mac | src-dst-ip | src-dst-mac | src-ip | src-mac }
【缺省级别】
2:系统级
dst-ip: 目的ip。
dst-mac:目的mac。
src-dst-ip:源、目的ip。
src-dst-mac:源、目的mac。
src-ip:源ip。
src-mac:源mac。
【描述】
该命令用来设置配置汇聚组的负载均衡策略,也就是报文发送时候具体物理链路选择策略。
缺省为源MAC方式。
# 指定负载均衡策略是目的MAC。
[H3C]channel-group load-balance dst-mac
lacp system-priority priority
undo lacp system-priority priority
端口视图
【缺省级别】
2:系统级
priority:取值范围为1~65535。
【描述】
该命令用来设置LACP的系统优先级。undo命令恢复系统的缺省优先级。
缺省值为32768。
LACP系统优先级和端口优先级对链路冗余影响的说明:LACP提供链路冗余机制,需要保证两台对接OLT冗余选择一致性,并且用户能够配置冗余链路,这是靠系统优先级和端口优先级来实现的。冗余选择步骤:
(1)     确定以哪台OLT为选择基准。通过LACP报文交互,两台OLT都相互知道对方的LACP系统优先级和系统MAC,先以本地的LACP系统优先级和对端的LACP系统优先级做比较,哪一台最小就以哪一台为准;如果相同,再比较MAC,哪个小就以哪台为准。
(2)     再以选择处理那台OLT的端口参数为准,选择冗余链路。先比较端口LACP优先级,优先级低的处于冗余状态,如果相同,则端口号大的处于冗余状态。
# 指定系统LACP优先级为40000。
[H3C]lacp system-priority 40000
lacp port-priority priority
端口视图
【缺省级别】
2:系统级
【描述】
该命令用来配置端口的LACP优先级,当通道组内端口存在备份时候,低优先级来处于备份状态。undo命令恢复端口的缺省LACP优先级。
缺省为128。
# 指定以太网2端口的LACP优先级为12345。
[H3C-GigabitEthernet 1/0/2]lacp port-priority 12345
display lacp sys-id
端口视图
【缺省级别】
2:系统级
无
【描述】
该命令用来显示系统LACP ID,由16位的系统优先级和32位的系统MAC地址组成。
# 显示系统LACP id。
[H3C]display lacp sys-id
display lacp internal [ channel-group-number ]
【缺省级别】
2:系统级
channel-group-number:通道索引为0~7。
【描述】
这条命令显示通道中的端口成员相关参数,如果不输入参数则是显示当前所有的通道。
# 显示当前所有的通道。
[H3C]display lacp internal
display lacp neighbor  [ channel-group-number ]
【缺省级别】
2:系统级
【描述】
这条命令显示通道中的邻接端口的信息,如果不输入参数则是显示当前所有的通道的邻接端口。
# 显示当前所有的通道的邻接端口。
[H3C]display lacp neighbor
display statistics channel-group [ channel-group-number ]
【缺省级别】
2:系统级
channel-group-number:通道索引是0~7。
【描述】
这条命令用来显示汇聚通道的统计信息,如果不输入参数则是显示当前所有的汇聚通道。
# 显示当前所有的汇聚通道。
[H3C]display statistics channel-group
clear channel-group  [ channel-group-number ]
【缺省级别】
2:系统级
【描述】
该命令用来清除汇聚通道的统计信息,如果不输入参数则是清除当前所有的汇聚通道。
# 清除当前所有的汇聚通道。
[H3C]clear channel-group
【缺省级别】
2:系统级
无
【描述】
该命令用来动态显示汇聚通道的统计信息。
# 动态显示汇聚通道的统计信息。
[H3C]display statistics dynamic channel-group
【缺省级别】
2:系统级
无
【描述】
该命令用来实时显示所有汇聚通道的使用情况,包括接收和发送数据包的速率,带宽占用率等信息。
# 实时显示所有汇聚通道的使用情况。
[H3C]display utilization channel-group
1.5  端口利用率告警配置命令
端口利用率配置命令包括:
·     alarm all-packets
·     alarm all-packets threshold
·     display alarm all-packets
alarm all-packets
undo alarm all-packets
系统视图/端口视图
【缺省级别】
2:系统级
无
【描述】
该命令用来开启全局或端口的端口利用率告警,此命令的undo形式用来关闭全局或端口的端口利用率告警。
缺省为开启全局端口利用率告警。
# 打开全局端口利用率告警。
[H3C]alarm all-packets
# 打开以太网8端口的端口利用率告警。
[H3C-GigabitEthernet 1/0/8]alarm all-packets
alarm all-packets threshold [ exceed exceed ] [ normal normal ]
端口视图
【缺省级别】
2:系统级
exceed:流量过大阈值,百兆口取值范围为1~100,千兆口取值范围为1~1000。
normal: 流量正常阈值,百兆口取值范围为1~1000, 千兆口取值范围为1~1000。
【描述】
该命令用来设置端口利用率告警的流量过大阈值和流量正常阈值。
百兆口流量过大阈值缺省值为85,流量正常阈值缺省值为60。
千兆口流量过大阈值缺省值为850,流量正常阈值缺省值为600。
必须满足exceed > normal。
# 配置端口利用率流量过大阈值为50,流量正常阈值为30。
[H3C-GigabitEthernet 1/0/1]alarm all-packets threshold exceed 50 normal 30
【缺省级别】
2:系统级
无
【描述】
该命令用来显示全局端口利用率告警的相关信息。
# 显示全局端口利用率告警信息。
[H3C]display alarm all-packets
Port alarm global status : enable
Port alarm exceed port
display alarm all-packets interface [ interface-list ]
【缺省级别】
2:系统级
interface-list:选择显示的端口列表,表示多个以太网端口,interface-list由端口类型 + 端口号组成,端口类型是gigabitethernet,端口号的表示形式device-num/slot-num/port-num,device-num是设备编号,取值为1,slot-num是槽号,取值为0,port-num是槽中的端口号,取值范围是1~8,连续的同类端口可以用“to”连接,但紧跟“to”前面的端口号一定要小于紧跟“to”后面的端口号,这种形式最多允许重复3次。
【描述】
该命令用来显示端口的端口利用率告警的相关信息。
参数interface-list是可选的,如果没选,则显示所有以太网端口的端口利用率告警信息,否则显示指定端口的端口利用率告警信息。
# 显示端口gigabitethernet  1/0/1的端口利用率告警信息。
[H3C]display alarm all-packets interface gigabitethernet  1/0/1
e1/0/1 port alarm information
Port alarm status                 : enable
Port alarm exceed threshold(Mbps] : 85
Port alarm undormal threshold(Mbps] : 60
Total entries: 1.
端口shutdown-control配置命令包括:
·     shutdown-control
·     shutdown-control-recover
·     display shutdown-control
·     undo shutdown-control-recover
shutdown-control [ broadcast | multicast | unicast ] target-rate
undo shutdown-control [ broadcast | multicast | unicast ]
端口视图
【缺省级别】
2:系统级
broadcast:配置广播关闭控制。
multicast:配置多播关闭控制。
unicast:配置单播关闭控制。
target-rate:关闭控制限制目标速率。
【描述】
该命令用来配置以太网端口的shutdown-control功能。
# 打开以太网8端口对广播报文的shutdown-control,速率限制为100pps。
[H3C-GigabitEthernet 1/0/8]shutdown-control broadcast 100
shutdown-control-recover  mode { manual | automatic }
shutdown-control-recover automatic-open-time open-time
【缺省级别】
2:系统级
manual:手工恢复方式,只有执行命令undo shutdown才可以恢复。
automatic:自动恢复方式,端口异常后过段时间可以自动打开端口。
open-time:在自动恢复方式下,被端口shutdown-control关闭的端口重新打开的时间,取值范围为1~3600秒,默认值为480秒。
【描述】
shutdown-control-recover  mode { manual | automatic } :
该命令设置被端口shutdown-control关闭的端口恢复正常的方式。
shutdown-control-recover automatic-open-time open-time:
该命令用来设置被端口shutdown-control关闭的端口恢复正常的时间。
被端口shutdown-control关闭的端口恢复缺省方式为manual。
# 配置被端口shutdown-control关闭的端口恢复方式为自动,且重新打开的时间为10秒。
[H3C]shutdown-control-recover mode automatic
[H3C]shutdown-control-recover automatic-open-time 10
【缺省级别】
2:系统级
无
【描述】
该命令用来显示端口shutdown-control 的相关信息。
# 显示端口shutdown-control信息。
[H3C]display shutdown-control
undo shutdown-control-recover { mode | automatic-open-time }
【缺省级别】
2:系统级
无
【描述】
该命令用来恢复端口shutdown-control 为默认配置。
# 恢复端口shutdown-control的恢复模式为默认的manual方式。
[H3C] undo shutdown-control-recover mode
