07-MPLS命令参考
08-MPLS L3VPN命令
本章节下载: 08-MPLS L3VPN命令  (383.26 KB)
08-MPLS L3VPN命令
1 MPLS L3VPN
1.1 MPLS L3VPN配置命令
1.1.1 address-family ipv4 (VPN instance view)
1.1.2 address-family vpnv4
1.1.3 description (VPN instance view)
1.1.4 display bgp group vpnv4
1.1.5 display bgp peer vpnv4
1.1.6 display bgp routing-table ipv4 unicast inlabel
1.1.7 display bgp routing-table ipv4 unicast outlabel
1.1.8 display bgp routing-table vpnv4
1.1.9 display bgp routing-table vpnv4 advertise-info
1.1.10 display bgp routing-table vpnv4 as-path-acl
1.1.11 display bgp routing-table vpnv4 community-list
1.1.12 display bgp routing-table vpnv4 inlabel
1.1.13 display bgp routing-table vpnv4 outlabel
1.1.14 display bgp routing-table vpnv4 peer
1.1.15 display bgp routing-table vpnv4 statistics
1.1.16 display bgp update-group vpnv4
1.1.17 display ospf sham-link
1.1.18 display ip vpn-instance
1.1.19 domain-id
1.1.20 export route-policy
1.1.21 ext-community-type
1.1.22 import route-policy
1.1.23 ip binding vpn-instance
1.1.24 ip vpn-instance (System view)
1.1.25 nesting-vpn
1.1.26 peer next-hop-invariable
1.1.27 peer upe
1.1.28 peer upe route-policy
1.1.29 policy vpn-target
1.1.30 refresh bgp vpnv4
1.1.31 reset bgp vpnv4
1.1.32 route-distinguisher (VPN instance view)
1.1.33 route-tag
1.1.34 routing-table limit
1.1.35 rr-filter
1.1.36 sham-link
1.1.37 snmp-agent trap enable l3vpn
1.1.38 tnl-policy (VPN instance view/IPv4 VPN view/IPv6 VPN view)
1.1.39 vpn popgo
1.1.40 vpn-id
1.1.41 vpn-target (VPN Instance view/IPv4 VPN view/IPv6 VPN view)
2 IPv6 MPLS L3VPN
2.1 IPv6 MPLS L3VPN配置命令
2.1.1 address-family ipv6 (VPN instance view)
2.1.2 address-family vpnv6
2.1.3 display bgp group vpnv6
2.1.4 display bgp peer vpnv6
2.1.5 display bgp routing-table vpnv6
2.1.6 display bgp routing-table vpnv6 advertise-info
2.1.7 display bgp routing-table vpnv6 as-path-acl
2.1.8 display bgp routing-table vpnv6 community-list
2.1.9 display bgp routing-table vpnv6 inlabel
2.1.10 display bgp routing-table vpnv6 outlabel
2.1.11 display bgp routing-table vpnv6 peer
2.1.12 display bgp routing-table vpnv6 statistics
2.1.13 display bgp update-group vpnv6
2.1.14 policy vpn-target
2.1.15 refresh bgp vpnv6
2.1.16 reset bgp vpnv6
2.1.17 rr-filter
1 MPLS L3VPN
1.1  MPLS L3VPN配置命令
address-family ipv4命令用来进入IPv4 VPN视图。
undo address-family ipv4命令用来删除IPv4 VPN视图下的所有配置。
address-family ipv4
VPN实例视图
在IPv4 VPN视图下可以配置IPv4 VPN的参数,如IPv4 VPN应用的出方向路由策略、入方向路由策略等。
# 进入IPv4 VPN视图。
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1]
·     address-family ipv6 (VPN instance view)
address-family vpnv4命令用来进入BGP VPNv4地址族视图或BGP-VPN VPNv4地址族视图。
undo address-family vpnv4命令用来删除BGP VPNv4地址族视图或BGP-VPN VPNv4地址族视图下的所有配置。
BGP视图/BGP-VPN实例视图
VPNv4地址是指在IPv4地址前缀前增加RD后,形成的地址。VPNv4路由是指携带VPNv4地址的路由信息。
在PE设备上,进入BGP VPNv4地址族视图或BGP-VPN VPNv4地址族视图,在该视图下通过peer enable命令使能BGP对等体后,PE才能与该对等体交换BGP VPNv4路由。
在BGP VPNv4地址族视图下,还可以配置BGP-VPNv4路由的属性,例如为从对等体/对等体组接收的BGP-VPNv4路由分配的首选值、是否允许本地AS号在接收的BGP-VPNv4路由的AS_PATH属性中出现等。
BGP VPNv4地址族视图下的配置用来控制PE设备之间交互的VPNv4路由。
BGP-VPN VPNv4地址族视图下的配置用来控制嵌套VPN组网中,运营商PE和运营商CE之间交互的VPNv4路由。
# 进入BGP VPNv4地址族视图。
[Sysname] bgp 100
[Sysname-bgp] address-family vpnv4
[Sysname-bgp-vpnv4]
# 进入BGP-VPN VPNv4地址族视图。
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-vpn1] address-family vpnv4
[Sysname-bgp-vpnv4-vpn1]
description命令用来配置当前VPN实例的描述信息。
undo description命令用来删除当前VPN实例的描述信息。
未配置VPN实例的描述信息。
VPN实例视图
text:VPN实例的描述信息,为1~79个字符的字符串,区分大小写。
如果多次执行本命令,则新的配置会覆盖原有配置。
# 配置名为vpn1的VPN实例的描述信息为“This is vpn1”。
[Sysname-vpn-instance-vpn1] description This is vpn1
display bgp group vpnv4命令用来显示BGP VPNv4对等体组的信息。
display bgp group vpnv4 [ vpn-instance vpn-instance-name ] [ group-name ]
vpn-instance vpn-instance-name:显示指定VPN实例内BGP VPNv4对等体组的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网内BGP VPNv4对等体组的信息。
group-name:显示指定BGP VPNv4对等体组的信息,group-name为BGP VPNv4对等体组的名称,为1~47个字符的字符串,区分大小写。如果没有指定本参数,则显示所有BGP VPNv4对等体组的信息。
# 显示公网内所有BGP VPNv4对等体组的信息。
<Sysname> display bgp group vpnv4
 BGP peer group: group1
 Remote AS number: not specified
 Type: external
  Members:
  10.1.1.1
# 显示名为group1的BGP VPNv4对等体组的信息。
<Sysname> display bgp group vpnv4 group1
 Remote AS: 600
 Type: external
 Maximum number of prefixes allowed: 4294967295
 Threshold: 75%
 Configured hold time: 180 seconds
 Keepalive time: 60 seconds
 Minimum time between advertisements: 30 seconds
 Peer preferred value: 0
 Routing policy configured:
 Members:
  2.2.2.2                600        0        0    0       0 00:00:05 Idle
表1-1 display bgp group vpnv4命令输出信息描述表
BGP peer group
BGP对等体组名称
Remote AS
对等体组的AS号
对等体组类型,取值包括:
·     external:表示EBGP对等体组
·     internal:表示IBGP对等体组
允许从对等体学习的最大路由数
Threshold
路由器产生提示信息的阈值,即从对等体接收的路由前缀数量与允许的最大路由数的百分比达到此值时,路由器将产生提示信息
配置的保持时间间隔,单位为秒
Keepalive time
存活时间间隔,单位为秒
路由发布的最小时间间隔,单位为秒
为来自对等体的路由指定的首选值
为对等体组指定的路由策略
如果未指定路由策略,则显示为No routing policy is configured
Members
对等体组包括的对等体信息
Peer
对等体的IPv4地址
AS
对等体所在的自治系统号
MsgRcvd
从该对等体收到的消息数目
MsgSent
向该对等体发送的消息数目
OutQ
等待发往该对等体的消息数目
PrefRcv
从该对等体收到的前缀数目
Up/Down
BGP会话处于当前状态的时长
该对等体的状态
display bgp peer vpnv4命令用来显示BGP VPNv4对等体的信息。
display bgp peer vpnv4 [ vpn-instance vpn-instance-name ] [ group-name log-info | ip-address { log-info | verbose } | verbose ]
vpn-instance vpn-instance-name:显示指定VPN实例的BGP VPNv4对等体或对等体组的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP VPNv4对等体或对等体组的信息。
group-name:显示指定对等体组内对等体的信息。group-name为对等体组的名称,为1~47个字符的字符串,区分大小写。
ip-address:显示指定BGP VPNv4对等体的信息。ip-address为对等体的IP地址。
log-info:显示BGP VPNv4对等体或对等体组的日志信息。
verbose:显示BGP VPNv4对等体的详细信息。如果指定了ip-address参数,则显示指定BGP对等体的详细信息;如果没有指定ip-address参数,则显示所有BGP VPNv4对等体的详细信息。
执行本命令时,如果没有指定任何参数,则显示所有BGP VPNv4对等体的简要信息。
# 显示公网内所有BGP VPNv4对等体的简要信息。
<Sysname> display bgp peer vpnv4
 BGP local router ID: 1.1.1.9
 Local AS number: 100
 Total number of peers: 2                  Peers in established state: 1
  3.3.3.9                100       50       51    0       2 00:37:19 Established
表1-2 display bgp peer vpnv4命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
对等体的总数
处于Established状态的对等体总数
Peer
对等体的IP地址
AS
对等体所在的自治系统号
MsgRcvd
从该对等体收到的消息数目
MsgSent
向该对等体发送的消息数目
OutQ
等待发往该对等体的消息数目
PrefRcv
从该对等体收到的前缀数目
Up/Down
BGP会话处于当前状态的时长
本地路由器与该对等体之间BGP会话的当前状态
# 显示地址为10.1.1.1的BGP VPNv4对等体的详细信息。
<Sysname> display bgp peer vpnv4 10.1.1.1 verbose
         Peer: 10.1.1.1  Local: 192.168.1.136
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.135
         BGP current state: Established, Up for 00h01m25s
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 1049
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer support BGP multi-protocol extended
         Peer support BGP route refresh capability
         Peer support BGP route AS4 capability
         Address family IPv4 Unicast: received
         Address family VPNv4: advertised and received
 Received: Total 4 messages, Update messages 1
 Sent: Total 17 messages, Update messages 1
 Threshold: 75%
 Optional capabilities:
 Connect-interface has been configured
 Peer Preferred Value: 0
 BFD: Enabled
表1-3 display bgp peer vpnv4 verbose命令显示信息描述表
Peer
对等体的IP地址
Local
本地路由器的IP地址
本地路由器与该对等体之间的BGP连接类型,取值包括:
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
BGP version
对等体使用的BGP版本
remote router ID
对等体的路由器ID
BGP current state
Up for
BGP会话建立的持续时间
BGP current event
本地路由器与该对等体之间BGP会话的当前事件
BGP last state
BGP会话的上一个状态
Port
建立TCP连接时本地(Local)和对等体(Remote)使用的端口号
Configured
本地配置的定时器值,包括会话保持时间间隔(Active Hold Time)和存活时间间隔(Keepalive Time),单位为秒
Received
收到的定时器值,即对等体上配置的定时器值,包括会话保持时间间隔(Active Hold Time),单位为秒
Negotiated
协商后的定时器值,包括会话保持时间间隔(Active Hold Time)和存活时间间隔(Keepalive Time),单位为秒
对等体支持的可选扩展能力
Peer support bgp multi-protocol extended
对等体支持BGP多协议扩展能力
Peer support bgp route refresh capability
对等体支持BGP路由刷新能力
Peer support bgp route AS4 capability
对等体支持四字节AS号能力
IPv4单播地址族能力,可以接收(received)和发送(advertised)该地址族的路由
VPNv4地址族能力能力:可以接收和发送该地址族的路由
Received
从对等体接收的消息总数及Update消息数目
Sent
向对等体发送的消息总数及Update消息数目
允许从对等体学习的最大路由数
Threshold
路由器产生提示信息的阈值,即对等体接收的路由前缀数量与允许的最大路由数的百分比达到此值时,路由器将产生提示信息
路由发布最小时间间隔,单位为秒
本端支持的可选扩展能力
本端支持BGP多协议扩展能力
本端支持BGP路由刷新能力
配置了TCP连接的源接口
为来自对等体的路由配置的首选值
BFD
是否配置通过BFD检测本地路由器和指定BGP对等体之间的链路
为对等体指定的路由策略
# 显示地址为10.1.1.1的BGP VPNv4对等体的日志信息。
<Sysname> display bgp peer vpnv4 10.1.1.1 log-info
 Peer: 10.1.1.1
     Date      Time    State Notification
                             Error/SubError
  21-Nov-2011 12:36:58 Up
  21-Nov-2011 12:22:29 Down  Send notification with error 6/6
                             Cease/Other Configuration Change
  21-Nov-2011 12:07:09 Up
表1-4 display bgp peer vpnv4 log-info命令显示信息描述表
Peer
对等体的IP地址
Date
发送或接收到Notification消息的日期
Time
发送或接收到Notification消息的时间
本地与对等体之间BGP会话的状态,取值包括:
·     Up:表示BGP会话处于Established状态
·     Down:表示BGP会话断开
Notification                             Error/SubError
Notification消息中的错误码,表明了BGP会话处于Down状态的原因
Error表示Notification消息差错码,指定错误类型;SubError表示Notification消息差错子码,指定错误类型的详细信息
display bgp routing-table ipv4 unicast inlabel命令用来显示BGP IPv4单播路由的入标签信息。
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的入标签信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv4单播路由的入标签信息。
执行本命令时指定unicast参数和不指定unicast参数的效果相同。
# 显示公网内所有BGP IPv4单播路由的入标签信息。
<Sysname> display bgp routing-table ipv4 inlabel
 Total number of routes: 1
 BGP local router ID is 3.3.3.9
     Network            NextHop         OutLabel        InLabel
* >  2.2.2.9/32         1.1.1.2         1151            1279
表1-5 display bgp routing-table ipv4 unicast inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-7
Origin
路由起源代码,请参见表1-7
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对等体为IPv4路由分配的标签
InLabel
入标签值,即本地为IPv4路由分配的标签
display bgp routing-table ipv4 unicast outlabel命令用来显示BGP IPv4单播路由的出标签信息。
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的出标签信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv4单播路由的出标签信息。
# 显示公网所有BGP IPv4单播路由的出标签信息。
<Sysname> display bgp routing-table ipv4 outlabel
表1-6 display bgp routing-table ipv4 unicast outlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-7
Origin
路由起源代码,请参见表1-7
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
display bgp routing-table vpnv4命令用来显示BGP VPNv4路由信息。
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ network-address [ { mask | mask-length } [ longest-match ] ] ]
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv4路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
network-address:目的网段的IP地址。
mask:网络掩码,为点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
longest-match:指定根据如下方法判断显示哪条BGP VPNv4路由信息:
(1)     将用户输入的网络地址和路由的掩码进行与操作;
(2)     计算结果与路由的网段地址相同,且掩码小于等于用户输入子网掩码的路由中,子网掩码最长的路由将被显示出来。
·     如果没有指定network-address、mask和mask-length参数,则显示所有BGP VPNv4路由的简要信息。
·     如果指定了network-address mask或network-address mask-length参数,则显示与指定目的网段IP地址和网络掩码(或掩码长度)精确匹配的BGP VPNv4路由的详细信息。
·     如果只指定了network-address参数,则显示与指定目的网段IP地址和自然掩码精确匹配的BGP VPNv4路由的详细信息。
# 显示所有BGP VPNv4路由的简要信息。
<Sysname> display bgp routing-table vpnv4
 BGP local router ID is 1.1.1.9
 Total number of routes from all PEs: 2
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 6
* >  10.1.1.0/24        10.1.1.2        0                     32768   ?
*  e                    10.1.1.1        0                     0       65410?
* >  10.1.1.2/32        127.0.0.1       0                     32768   ?
* >i 10.3.1.0/24        3.3.3.9         0          100        0       ?
* >e 192.168.1.0        10.1.1.1        0                     0       65410?
*  i                    3.3.3.9         0          100        0       65420?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i 192.168.1.0        3.3.3.9         0          100        0       65420?
# 显示路由标识符为100:1的所有BGP VPNv4路由的简要信息。
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1
表1-7 display bgp routing-table vpnv4命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。聚合路由和通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     ? – incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
来自所有PE设备的VPNv4路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv4路由总数
Network
目的网络地址
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性,其中:
·     AS_PATH属性记录了此路由经过的所有AS,可以避免路由环路的出现
·     ORIGIN属性标记了此BGP路由如何生成的
# 显示网段10.3.1.0/24的BGP VPNv4路由的详细信息。
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24
 Paths:   1 available, 1 best
 Relay nexthop   : 172.1.1.2
 Original nexthop: 3.3.3.9
 OutLabel        : 1279
 Ext-Community   : <RT: 111:1>
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best,
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
# 显示路由标识符为100:1、目的网络地址为10.3.1.0/24的BGP VPNv4路由的详细信息。
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1 10.3.1.0 24
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
表1-8 display bgp routing-table vpnv4命令详细显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
Route distinguisher
路由标识符
路由总数
Paths
路由数信息
·     available:有效路由条数
·     best:最佳路由条数
到达目的网络10.3.1.0/24的BGP路由表项信息
From
发布该路由的BGP对等体的IP地址
Relay Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。聚合路由和通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
display bgp routing-table vpnv4 advertise-info命令用来显示BGP VPNv4路由的通告信息。
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] network-address [ mask | mask-length ] advertise-info
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv4路由通告信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
network-address:目的网络的IP地址。
mask:网络掩码,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
·     如果没有指定mask和mask-length参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的通告信息。
·     如果指定了mask或mask-length参数,则显示与指定目的网络IP地址和网络掩码(或掩码长度)精确匹配的BGP IPv4单播路由的通告信息。
# 显示到达目的网段10.1.1.0/24的BGP VPNv4路由的通告信息。
<Sysname> display bgp routing-table vpnv4 10.1.1.0 24 advertise-info
 Paths:   1 best
 BGP routing table information of 10.1.1.0/24:
    3.3.3.9
 Inlabel         : 1279
表1-9 display bgp routing-table vpnv4 advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
路由总数
Paths
到达指定目的网络的优选路由数目
到达目的网络10.1.1.0/24的BGP路由的通告信息
该路由已经向哪些VPNv4对等体发送,以及对等体的数目
Inlabel
路由的入标签
display bgp routing-table vpnv4 as-path-acl命令用来显示匹配指定AS路径过滤列表的BGP VPNv4路由信息。
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] as-path-acl as-path-acl-number
as-path-acl-number:AS路径过滤列表号,取值范围为1~256。
# 显示匹配AS路径过滤列表1的BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 as-path-acl 1
以上显示信息的说明请参见表1-7。
·     ip as-path(三层技术-IP路由命令参考/路由策略)
display bgp routing-table vpnv4 communit-list命令用来显示匹配指定BGP团体列表的BGP VPNv4路由信息。
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表与指定的团体属性列表完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表中包含指定的团体属性列表,就显示该路由的信息。
adv-community-list-number:高级团体列表号,取值范围为100~199。
# 显示匹配BGP团体列表100的BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 community-list 100
以上显示信息的说明请参见表1-7。
display bgp routing-table vpnv4 inlabel命令用来显示所有BGP VPNv4路由的入标签信息。
# 显示所有BGP VPNv4路由的入标签信息。
<Sysname> display bgp routing-table vpnv4 inlabel
* >  10.1.1.0/24        10.1.1.2        NULL            1279
* >e 192.168.1.0        10.1.1.1        NULL            1278
表1-10 display bgp routing-table vpnv4 inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-7
Origin
路由起源代码,请参见表1-7
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为VPNv4路由分配的私网标签
取值为exp-null表示为显式空标签
InLabel
入标签值,即本地PE为VPNv4路由分配的私网标签
display bgp routing-table vpnv4 outlabel命令用来显示所有BGP VPNv4路由的出标签信息。
# 显示所有BGP VPNv4路由的出标签信息。
<Sysname> display bgp routing-table vpnv4 outlabel
* >i 10.3.1.0/24        3.3.3.9         1279
*  i 192.168.1.0        3.3.3.9         1278
* >i 192.168.1.0        3.3.3.9         1278
表1-11 display bgp routing-table vpnv4 outlabel命令输出信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-7
Origin
路由起源代码,请参见表1-7
来自所有PE设备的路由数
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
取值为exp-null表示为显式空标签
display bgp routing-table vpnv4 peer命令用来显示向指定对等体发布或者从指定对等体收到的BGP VPNv4路由信息。
display bgp routing-table vpnv4 [ vpn-instance vpn-instance-name ] peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistics ]
vpn-instance vpn-instance-name:显示向指定对等体发布或者从指定对等体收到的指定VPN实例内BGP VPNv4路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示向指定对等体发布或者从指定对等体收到的公网内BGP VPNv4路由信息。
ip-address:对等体的地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
mask:目的网络的掩码,点分十进制格式。
mask-length:目的网络的掩码长度,取值范围为0~32。
statistics:显示路由的统计信息。
·     如果没有指定network-address、mask和mask-length参数,则显示向指定对等体发布或者从指定对等体收到的所有BGP VPNv4路由信息。
·     如果指定了network-address参数,没有指定mask和mask-length参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的信息。
·     如果指定了network-address mask或network-address mask-length参数,则显示与指定目的网络IP地址和网络掩码(或掩码长度)精确匹配的路由信息。
# 显示向对等体3.3.3.9发布的所有公网BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes
     Network            NextHop         MED        LocPrf             Path/Ogn
* >  10.1.1.0/24        10.1.1.2        0                             ?
* >e 192.168.1.0        10.1.1.1        0                             65410?
# 显示从对等体3.3.3.9收到的所有公网BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes
以上显示信息的说明请参见表1-7。
# 显示向对等体3.3.3.9发布的公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes statistics
 Advertised routes total: 2
# 显示从对等体3.3.3.9收到的公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes statistic
 Received routes total: 2
表1-12 display bgp routing-table vpnv4 peer statistic命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
display bgp routing-table vpnv4 statistics命令用来显示BGP VPNv4路由的统计信息。
# 显示公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 statistics
表1-13 display bgp routing-table vpnv4 statistics命令显示信息描述表
来自所有PE设备的VPNv4路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv4路由总数
display bgp update-group vpnv4命令用来显示BGP VPNv4地址族下打包组的相关信息。
display bgp update-group vpnv4 [ vpn-instance vpn-instance-name ] [ ip-address ]
vpn-instance vpn-instance-name:显示指定VPN实例内BGP VPNv4地址族的打包组相关信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP VPNv4地址族的所有打包组相关信息。
ip-address:显示指定对等体所在打包组的信息。ip-address为对等体的IP地址。
执行本命令时,如果没有指定任何参数,则显示公网BGP VPNv4地址族的所有打包组信息。
# 显示BGP VPNv4地址族的所有打包组信息。
<Sysname> display bgp update-group vpnv4
  Update-group ID: 0
  Type: EBGP link
  4-byte AS number: Supported
  OutQ: 0
  Members: 1
    99.1.1.1
# 显示VPN实例vpn1内BGP VPNv4对等体1.1.1.2所在打包组的信息。
<Sysname> display bgp update-group vpnv4 vpn-instance vpn1 1.1.1.2
  Update-group ID: 0
  Type: EBGP link
  Nesting-vpn: vpn1
  OutQ: 0
  Members: 2
    1.1.1.2
    1.1.1.3
# 显示VPN实例vpn1内BGP VPNv4所有打包组的信息。
  Update-group ID: 0
  Type: EBGP link
  Nesting-vpn: vpn1
  OutQ: 0
  Members: 1
    1.1.1.2
  Update-group ID: 1
  Type: EBGP link
  Nesting-vpn: vpn1
  Minimum time between advertisements: 10 seconds
  OutQ: 0
  Members: 1
    1.1.1.3
表1-14 display bgp update-group vpnv4命令显示信息描述表
Update-group ID
打包组ID
打包组中对等体的BGP连接类型,取值包括:
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
·     Confed IBGP link:联盟IBGP连接
·     Confed EBGP link:联盟EBGP连接
Label capability: Supported
打包组中的对等体具有交换带标签路由的能力
打包组中的对等体支持4字节AS号
4-byte AS number: Suppressed
打包组中的对等体抑制4字节AS号
Nesting-vpn
打包组中的对等体使能了嵌套VPN功能
Fake AS: number
为打包组中的对等体配置了虚拟的本地自治系统号number
Public-AS-Only: Yes
向打包组中的对等体发送BGP更新消息时只携带公有AS号,不携带私有AS号
Substitute-AS: Yes
用本地AS号替换AS_PATH属性里打包组中对等体的AS号
Minimum time between advertisements: number seconds
向打包组中对等体发布同一路由的最小时间间隔,单位为秒
Nexthop invariable: Yes
向打包组中的对等体发布路由时不改变下一跳
Advertising community: Yes
向打包组中的对等体发布团体属性
Route-reflect client: Yes
打包组中的对等体是路由反射器的客户机
UPE: Yes
打包组中的对等体为UPE
Advertising extended community: Yes
向打包组中的对等体发布扩展团体属性
Export AS-path-ACL: as-path-acl-number
为打包组中的对等体设置了基于AS路径过滤列表的BGP路由出方向过滤策略
Export prefix list: prefix-list-name
为打包组中的对等体设置了基于地址前缀列表的BGP路由出方向过滤策略
Export route policy: route-policy-name
对发布给打包组中对等体的路由应用了路由策略
Export filter-policy: ACL acl-number
为打包组中的对等体设置了基于ACL的BGP路由出方向过滤策略
UPE export route policy
为打包组中的UPE对等体应用了出方向路由策略
OutQ
等待发往打包组中对等体的前缀数目
Members
打包组中对等体的数目及对等体的地址
display ospf sham-link命令用来显示OSPF伪连接信息。
独立运行模式:
display ospf [ process-id ] sham-link [ area area-id ] [ standby slot slot-number ]
IRF模式:
display ospf [ process-id ] sham-link [ area area-id ] [ standby chassis chassis-number slot slot-number ]
process-id:显示指定OSPF进程内的伪连接信息。process-id为OSPF进程号,取值范围为1~65535。如果不指定本参数,则显示所有OSPF进程的伪连接信息。
area area-id:显示指定OSPF区域内的伪连接信息。area-id为OSPF区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。如果不指定本参数,则显示所有OSPF区域的伪连接信息。
standby:显示指定OSPF备进程的信息。如果不指定本参数,则显示OSPF主进程的信息。
slot slot-number:指定备进程所在的单板。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定备进程所在的成员设备和单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
执行本命令时,如果不指定进程号和区域号,则显示所有的OSPF伪连接信息。
开启OSPF NSR功能后,OSPF主进程将OSPF邻居和路由等信息备份到备进程。执行本命令时,如果指定了standby参数,则显示备份到指定备进程的信息。如果没有开启OSPF NSR功能,则指定standby参数时,不会显示任何信息。
# 显示所有OSPF伪连接信息。
<Sysname> display ospf sham-link
          OSPF Process 1 with Router ID 125.1.1.1
                  Sham link
 Area            Neighbor ID     Source IP       Destination IP  State  Cost
 0.0.0.0         95.1.1.1        125.2.1.1       95.2.1.1        P-2-P  1
表1-15 display ospf sham-link命令显示信息描述表
Area
伪连接所属的OSPF区域
Neighbor ID
伪连接邻居的Router ID
Source IP
伪连接的源IP地址
Destination IP
伪连接的目的IP地址
伪连接的接口状态,取值包括Down和P-2-P
Cost
伪连接的开销
# 显示OSPF区域1内的OSPF伪连接信息。
<Sysname> display ospf sham-link area 1
 Sham link: 125.2.1.1 --> 95.2.1.1
 Neighbor ID: 95.1.1.1         State: Full
 Area: 0.0.0.0
 Cost: 1  State: P-2-P  Type: Sham
 Timers: Hello 10s, Dead 40s, Retransmit 5s, Transmit Delay 1s
 Request list: 0  Retransmit list: 0
 MD5 authentication enabled.
    The last key is 3.
    The rollover is in progress, 1 neighbor(s) left.
表1-16 display ospf sham-link area命令显示信息描述表
Sham link
伪连接,从源IP地址到目的IP地址
Neighbor ID
伪连接邻居的Router ID
伪连接的邻居状态,取值包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Area
伪连接所属的OSPF区域
Cost
伪连接的开销
伪连接的状态,,取值包括Down和P-2-P
伪连接的类型,取值为Sham
Timers
伪连接的定时器,包括Hello,Dead,Retransmit和Transmit Delay定时器
Request list
请求列表个数
Retransmit list
重传列表个数
使能了MD5认证功能
The last key
最新的MD5验证密钥
正在进行MD5验证平滑迁移,尚未完成MD5验证平滑迁移的邻居个数为1
display ip vpn-instance命令用来显示VPN实例的信息。
display ip vpn-instance [ instance-name vpn-instance-name ]
instance-name vpn-instance-name:显示指定VPN实例的详细信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示创建的所有VPN实例的简要信息。
# 显示所有VPN实例的简要信息。
<Sysname> display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  abc                             1:1                    2011/05/18 10:48:17
表1-17 display ip vpn-instance命令显示信息描述表
VPN-Instance Name
VPN实例名称
RD
VPN实例的路由标识符
Create time
VPN实例创建的时间
# 显示名为vpn1的VPN实例的详细信息。
<Sysname> display ip vpn-instance instance-name vpn1
  VPN-Instance Name and Index : vpn1, 2
  Route Distinguisher : 100:1
  VPN ID : 1:1
  Description : vpn1
  Interfaces : Vlan-interface17
  Address-family IPv4:
   Export VPN Targets :
       2:2
   Import VPN Targets :
       3:3
   Export Route Policy : outpolicy
   Import Route Policy : inpolicy
   Tunnel Policy : tunnel1
   Maximum Routes Limit : 5000
  Address-family IPv6:
       2:2
       3:3
表1-18 display ip vpn-instance instance-name命令显示信息描述表
VPN实例名称和索引
Route Distinguisher
VPN实例的路由标识符值
VPN ID
VPN实例的ID,即VPN实例的全局唯一标识
VPN实例的描述信息
Interfaces
关联该VPN实例的接口
Address-family IPv4
IPv4 VPN的信息
Address-family IPv6
IPv6 VPN的信息
Export VPN Targets
IPv4 VPN或IPv6 VPN的出方向扩展团体属性
Import VPN Targets
IPv4 VPN或IPv6 VPN的入方向扩展团体属性
Export Route Policy
IPv4 VPN或IPv6 VPN的出方向路由策略
Import Route Policy
IPv4 VPN或IPv6 VPN的入方向路由策略
Tunnel Policy
IPv4 VPN或IPv6 VPN的隧道策略
IPv4 VPN或IPv6 VPN的路由最大条数
1.1.19  domain-id
domain-id命令用来配置OSPF域标识符。
undo domain-id命令用来恢复缺省值。
undo domain-id [ domain-id ]
OSPF域标识符为0。
OSPF视图
domain-id:OSPF域标识符,可以采用以下三种形式。
·     采用整数形式,取值范围为0~4294967295,例如:1。
·     点分十进制形式,例如:0.0.0.1。
·     点分十进制形式:16位用户自定义数,取值范围0~65535,例如:0.0.0.1:512。
secondary:配置的域标识符作为从标识符。如果不配置,表示配置主标识符。
如果通过domain-id命令配置了OSPF域标识符,则将OSPF路由引入到BGP时,该域标识符被附加到BGP VPN路由上,作为BGP的扩展团体属性传递给对端,以便对端据此判断两端的站点是否属于同一个OSPF域。如果域标识符相同,且为区域内或区域间路由,则在对端将路由重新引入到OSPF时,该路由将作为Summary LSA(Type3)发布;如果域标识符相同,但不为区域内或区域间路由,则该路由将作为AS External LSA(Type5)或NSSA External LSA(Type7)发布;如果域标识符不同,则该路由将作为AS External LSA(Type5)或NSSA External LSA(Type7)发布。
执行undo domain-id命令时,如果不指定参数,将删除所有域标识符。
# 配置OSPF VPN扩展中的VPN域标识符。
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
export route-policy命令用来配置当前VPN实例应用出方向路由策略。
undo export route-policy命令用来取消当前VPN实例应用出方向路由策略。
VPN实例没有应用出方向路由策略,不对发布的路由进行过滤。
VPN实例视图/IPv4 VPN视图/IPv6 VPN视图
route-policy:VPN实例的出方向路由策略名,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了VPN实例应用的出方向路由策略,则设备在发布该VPN实例的路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制VPN实例路由的发布。
·     如果多次执行本命令,则新的配置会覆盖原有配置。
·     VPN实例视图下的配置,既可以用于IPv4 VPN,也可以用于IPv6 VPN;IPv4 VPN视图下的配置只能用于IPv4 VPN;IPv6 VPN视图下的配置只能用于IPv6 VPN。
·     IPv4 VPN视图、IPv6 VPN视图下的配置优先级高于VPN实例视图下的配置,即如果同时在IPv4 VPN视图(或IPv6 VPN视图)和VPN实例视图下进行了配置,则IPv4 VPN(或IPv6 VPN)采用IPv4 VPN视图(或IPv6 VPN视图)下的配置。
# 对名为vpn1的VPN实例应用出方向路由策略poly-1。
[Sysname-vpn-instance-vpn1] export route-policy poly-1
# 对名为vpn2的IPv4 VPN应用出方向路由策略poly-2。
[Sysname] ip vpn-instance vpn2
[Sysname-vpn-instance-vpn2] address-family ipv4
[Sysname-vpn-ipv4-vpn2] export route-policy poly-2
# 对名为vpn3的IPv6 VPN应用出方向路由策略poly-3。
[Sysname] ip vpn-instance vpn3
[Sysname-vpn-instance-vpn3] address-family ipv6
[Sysname-vpn-ipv6-vpn3] export route-policy poly-3
·     import route-policy
·     route-policy(三层技术-IP路由命令参考/路由策略)
ext-community-type命令用来配置OSPF扩展团体属性的类型编码。
undo ext-community-type命令用来恢复缺省情况。
undo ext-community-type [ domain-id | router-id | route-type ]
OSPF扩展团体属性Domain ID的类型编码是0x0005,Router ID的类型编码是0x0107,Route Type的类型编码是0x0306。
OSPF视图
domain-id type-code1:指定OSPF扩展团体属性Domain ID的类型编码。type-code1取值可以为0005,0105 ,0205和8005。
router-id type-code2:指定OSPF扩展团体属性Router ID的类型编码。type-code2取值可以为0107和8001。
router-type type-code3:指定OSPF扩展团体属性Route Type的类型编码。type-code3取值可以为0306和8000。
# 为OSPF进程100配置OSPF扩展团体属性Domain ID的类型编码为0x8005, Router ID的类型编码为0x8001,Route Type的类型编码为0x8000。
[Sysname] ospf 100
[Sysname-ospf-100] ext-community-type domain-id 8005
[Sysname-ospf-100] ext-community-type router-id 8001
[Sysname-ospf-100] ext-community-type route-type 8000
import route-policy命令用来配置当前VPN实例应用入方向路由策略。
undo import route-policy命令用来取消当前VPN实例应用入方向路由策略。
VPN实例没有应用入方向路由策略。如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
route-policy:VPN实例的入方向路由策略名,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了VPN实例应用的入方向路由策略,则设备接收到该VPN实例的路由后,将利用指定的路由策略对接收的路由进行过滤、改变接收路由的属性等。使用本命令可以更加精确、灵活地控制VPN实例路由的接收。
# 对名为vpn1的VPN实例应用入方向路由策略poly-1。
[Sysname-vpn-instance-vpn1] import route-policy poly-1
# 对名为vpn2的IPv4 VPN应用入方向路由策略poly-2。
[Sysname-vpn-ipv4-vpn2] import route-policy poly-2
# 对名为vpn3的IPv6 VPN应用入方向路由策略poly-3。
[Sysname-vpn-ipv6-vpn3] import route-policy poly-3
·     export route-policy
ip binding vpn-instance命令用来配置当前接口与指定VPN实例关联。
undo ip binding vpn-instance命令用来取消接口与VPN实例的关联。
接口不与任何VPN实例关联,接口属于公网。
vpn-instance-name:接口关联的VPN实例名称,为1~31个字符的字符串,区分大小写。
本命令用于在PE设备上将连接CE的接口与该CE所属的VPN实例关联。
·     配置或取消接口与VPN实例关联后,该接口上的IP地址、路由协议等配置将被删除。建议在接口视图下通过display this命令查看接口的当前配置,并根据需要重新配置IP地址、路由协议等。
·     接口关联的VPN实例,必须已经通过系统视图下的ip vpn-instance命令创建。
·     不能通过重复执行本命令修改接口关联的VPN实例。只能通过undo ip binding vpn-instance命令取消关联的VPN实例后,再通过ip binding vpn-instance命令关联新的VPN实例。
# 将接口Vlan-interface2与名为vpn1的VPN实例关联。
[Sysname-Vlan-interface2] ip binding vpn-instance vpn1
·     ip vpn-instance (System view)
ip vpn-instance命令用来创建VPN实例,并进入VPN实例视图。
undo ip vpn-instance命令用来删除指定的VPN实例。
设备上不存在任何VPN实例。
vpn-instance-name:VPN实例的名称,为1~31个字符的字符串,区分大小写。
# 创建一个名为vpn1的VPN实例,并进入VPN实例视图。
·     route-distinguisher
1.1.25  nesting-vpn
nesting-vpn命令用来使能嵌套VPN功能。
undo nesting-vpn命令用来禁止嵌套VPN功能。
nesting-vpn
undo nesting-vpn
嵌套VPN功能处于禁止状态。
BGP VPNv4地址族视图
嵌套VPN是指在运营商通过MPLS L3VPN骨干网为用户提供一个大的VPN的基础上,用户可以根据实际需要管理和划分自己的内部VPN,而这些内部VPN的划分对于运营商骨干网来说是透明的。嵌套VPN为用户提供了多样化的VPN组网方式,实现了用户对内部VPN以及多层VPN之间的互访权限控制管理,可以满足多种用户网络的需求。
需要注意的是,只有在BGP VPNv4地址族视图下使能了嵌套VPN功能后,BGP-VPN VPNv4地址族视图下通过peer enable命令激活的对等体之间才能成功协商VPNv4路由交换能力,才能接收和发布VPNv4路由。
# 使能嵌套VPN功能。
[Sysname] bgp 100
[Sysname-bgp-vpnv4] nesting-vpn
peer next-hop-invariable命令用来配置向EBGP对等体/对等体组发布路由时不改变下一跳。
undo peer next-hop-invariable命令用来恢复缺省情况。
peer { group-name | ip-address } next-hop-invariable
undo peer { group-name | ip-address } next-hop-invariable
向EBGP对等体/对等体组发布路由时会将下一跳改为自己的地址。
BGP VPNv4地址族视图
group-name:对等体组的名称,为1~47个字符的字符串,区分大小写。
ip-address:对等体的IP地址。
如果在跨域VPN OptionC组网中使用路由反射器RR(Route Reflector)通告VPNv4路由,则需要在路由反射器上通过本命令配置向EBGP邻居和反射客户通告VPNv4路由时,不改变路由的下一跳,以保证私网路由下一跳不会被修改。
需要注意的是,本命令与peer next-hop-local命令互斥。
# 在BGP VPNv4地址族视图下,配置向EBGP对等体1.1.1.1发布路由时不改变下一跳。
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 next-hop-invariable
·     peer next-hop-local(三层技术-IP路由命令参考/BGP)
1.1.27  peer upe
peer upe命令用来在BGP VPNv4地址族视图下,指定BGP对等体或对等体组作为HoVPN的UPE。
undo peer upe命令用来取消该配置。
peer { group-name | ip-address } upe
undo peer { group-name | ip-address } upe
BGP对等体或对等体组不是HoVPN的UPE。
BGP VPNv4地址族视图
ip-address:对等体的IP地址。指定的对等体必须已经创建。
UPE是一类特殊的VPNv4对等体,它可以接收SPE上每个相关VPN实例的一条缺省路由,也可以接收SPE上发送的通过路由策略过滤的路由信息。SPE是普通的VPN对等体。
# 指定对等体1.1.1.1作为UPE。
[Sysname] bgp 100
[Sysname-bgp-vpnv4] peer 1.1.1.1 upe
peer upe route-policy命令用来配置向指定的UPE发布经过路由策略过滤的路由信息。
undo peer upe route-policy命令用来恢复缺省情况。
peer { group-name | ip-address } upe route-policy route-policy-name export
undo peer { group-name | ip-address } upe route-policy export
不向对等体发布路由。
BGP VPNv4地址族视图
route-policy-name:路由策略的名称,为1~63个字符的字符串,区分大小写。
export:对发布的路由应用过滤策略。
本命令必须和peer upe命令配合使用。
# 在BGP VPNv4地址族视图下,配置对等体1.1.1.1为UPE,并向1.1.1.1发送通过路由策略hope过滤的路由信息。
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 200
[Sysname-bgp-vpnv4] peer 1.1.1.1 enable
[Sysname-bgp-vpnv4] peer 1.1.1.1 upe route-policy hope export
·     peer upe
policy vpn-target命令用来对接收到的VPNv4路由使能VPN-Target过滤功能,即只将Export Route Target属性与本地Import Route Target属性匹配的VPNv4路由加入到路由表。
undo policy vpn-target命令用来取消对VPNv4路由的VPN-Target过滤功能,即接收所有VPNv4路由。
policy vpn-target
对接收到的VPNv4路由使能VPN-Target过滤功能。
BGP VPNv4地址族视图
在跨域VPN OptionB组网中,ASBR-PE需要保存所有VPNv4路由信息,以通告给对端ASBR-PE。这种情况下,ASBR-PE上需执行undo policy vpn-target命令接收所有的VPNv4路由信息,不对它们进行Route Target过滤。
# 在BGP VPNv4地址族视图下,取消对VPNv4路由的Route Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-vpnv4] undo policy vpn-target
refresh bgp vpnv4命令用来手工对VPNv4地址族下的BGP会话进行软复位。
refresh bgp { ip-address | all | external | group group-name | internal } { export | import } vpnv4  [ vpn-instance vpn-instance-name ]
ip-address:软复位与指定对等体的BGP会话。ip-address为对等体的IP地址。
all:软复位VPNv4地址族下的所有BGP会话。
external:软复位VPNv4地址族下的所有EBGP会话。
group group-name:软复位与指定对等体组中对等体的BGP会话。group-name为对等体组的名称,为1~47个字符的字符串,区分大小写。
internal:软复位VPNv4地址族下的所有IBGP会话。
export:触发出方向的软复位,即采用新的配置对向对等体发布的VPNv4路由进行过滤。
import:触发入方向的软复位,即采用新的配置对从对等体接收的VPNv4路由进行过滤。
vpn-instance vpn-instance-name:软复位指定VPN实例的BGP会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则软复位公网的BGP会话。
软复位BGP会话是指在不断开BGP邻居关系的情况下,更新BGP VPNv4路由信息,使新的配置生效。
选路策略发生改变后,执行本命令时,如果指定了export参数,则会触发本地路由器根据新的路由发布策略过滤路由信息,并将通过过滤的路由信息发送给BGP对等体;执行本命令时,如果指定了import参数,则本地路由器会向BGP对等体发送Route-refresh消息,收到Route-refresh消息的对等体将其路由信息重新发给本地路由器,以便本地路由器根据新的路由策略对接收到的路由信息进行过滤。
·     执行本命令软复位BGP会话时,要求当前路由器和对等体都支持Route-refresh功能,否则本命令不会生效。
·     配置peer keep-all-routes命令后,执行refresh bgp vpnv4 import命令不会生效。
# 手工对VPNv4地址族下的所有BGP会话进行入方向的软复位。
<Sysname> refresh bgp all import vpnv4
·     peer capability-advertise route-refresh(三层技术-IP路由命令参考/BGP)
·     peer keep-all-routes(三层技术-IP路由命令参考/BGP)
reset bgp vpnv4命令用来复位VPNv4地址族下的BGP会话。
reset bgp { as-number | ip-address | all | external | group group-name | internal } vpnv4 [ vpn-instance vpn-instance-name ]
as-number:复位与指定自治系统内对等体的BGP会话。as-number为自治系统号,取值范围为1~4294967295。
ip-address:复位与指定对等体的BGP会话。ip-address为对等体的IP地址。
all:复位VPNv4地址族下的所有BGP会话。
external:复位VPNv4地址族下的所有EBGP会话。
group group-name:复位与指定对等体组中对等体的BGP会话。group-name为对等体组的名称,为1~47个字符的字符串,区分大小写。
internal:复位VPNv4地址族下的所有IBGP会话。
vpn-instance vpn-instance-name:复位指定VPN实例的BGP会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则复位公网的BGP会话。
BGP的选路策略改变后,为了使新的策略生效,可以复位BGP会话,即删除并重新建立BGP会话,以便重新发布BGP VPNv4路由信息,并应用新的策略对BGP VPNv4路由信息进行过滤。复位BGP会话时,会造成短暂的BGP会话中断。
# 复位公网内VPNv4地址族下的所有BGP会话。
<Sysname> reset bgp all vpnv4
route-distinguisher命令用来配置VPN实例的RD(Route Distinguisher,路由标识)。
undo route-distinguisher命令用来删除VPN实例的RD值。
没有指定VPN实例的RD。
VPN实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
RD用于解决不同VPN之间地址空间重叠的问题。如果在配置时保证了RD的全局唯一性,则将RD添加到一个IPv4前缀之前,就可以使之成为全局唯一的VPN IPv4前缀。这样,即使不同VPN使用了同样的IPv4地址空间,PE路由器也可以向各VPN发布不同VPN IPv4前缀的路由。
需要注意的是,不能通过重复执行route-distinguisher命令修改VPN实例的RD值。必须先通过undo route-distinguisher命令删除VPN实例的RD值,再通过route-distinguisher命令配置新的RD值。
# 配置VPN实例vpn1的RD为22:1。
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
1.1.33  route-tag
route-tag命令用来配置标识VPN引入路由的tag值。
undo route-tag命令用来恢复缺省值。
route-tag tag-value
undo route-tag
若AS号不大于65535,取缺省值时前面两个字节为固定的0xD000,后面的两个字节为本端BGP的AS号,否则tag缺省值为0。比如本端BGP AS号为100,则其缺省的tag十进制值为3489661028。
OSPF视图
tag-value:标识VPN引入路由的tag值,取值范围为0~4294967295。
PE上与OSPF实例相关的VPN实例会配置一个VPN Route Tag,该路由标记必须被包含在第5/7类的LSA中。同一个区域的PE建议配置相同的route-tag。route-tag不在BGP的扩展团体属性中传递,只是本地概念,只在收到BGP路由并且产生OSPF LSA的PE路由器上配置并起作用。不同OSPF进程可配置相同的route-tag。
通过route-tag命令设置的tag和其它命令设置的tag只有优先级的差别:
·     import-route命令配置的tag优先级最高;
·     route-tag命令配置的tag优先级其次;
·     default tag命令配置的tag优先级最低。
如果收到的type5、type7 LSA中包含的tag与自己的tag相同,则在进行路由计算时忽略该LSA。
# 为OSPF进程100配置route-tag为100。
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
·     import-route
routing-table limit命令用来限制当前VPN实例支持的最多激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
缺省情况下,没有配置VPN实例支持的最多路由数。
number:指定一个VPN实例最多可以支持的激活路由前缀数。在VPN实例视图下的取值范围为1~65536;在IPv4 VPN视图下的取值范围为1~524288;在IPv6 VPN视图下的取值范围为1~65536。
warn-threshold:告警门限值,取值范围为1~100,单位为百分比。当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到告警门限值时,产生一条告警信息,但仍然允许激活路由前缀。当VPN实例中的激活路由前缀数达到最多支持激活路由前缀数目时,不再激活新的路由前缀。
simply-alert:指定当VPN实例的激活路由前缀数超过最多支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条系统日志Syslog信息。
通过本命令可以避免PE路由器引入太多的VPN激活路由前缀。
# 限制名为vpn1的VPN实例最多可支持1000条激活路由前缀,并且当激活路由前缀数超过最多支持激活路由前缀数时,可以继续激活新的路由前缀,但是会产生一条系统日志Syslog信息。
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
# 限制名为vpn2的IPv4 VPN最多可支持1000条激活路由前缀,并且当激活路由前缀数超过最多支持激活路由前缀数时,可以继续激活新的路由前缀,但是会产生一条系统日志Syslog信息。
[Sysname-vpn-instance-vpn2] route-distinguisher 100:2
[Sysname-vpn-ipv4-vpn2] routing-table limit 1000 simply-alert
# 限制名为vpn3的IPv6 VPN最多可支持1000条激活路由前缀,并且当激活路由前缀数超过最多支持激活路由前缀数时,可以继续激活新的路由前缀,但是会产生一条系统日志Syslog信息。
[Sysname-vpn-instance-vpn3] route-distinguisher 100:3
[Sysname-vpn-ipv4-vpn3] routing-table limit 1000 simply-alert
1.1.35  rr-filter
rr-filter命令用来创建路由反射器的反射策略:通过配置路由反射器支持的扩展团体属性号,对接收的路由信息进行过滤,只有接收的VPNv4路由包含指定的扩展团体属性号时,路由反射器才会反射该路由。
undo rr-filter命令用来恢复缺省情况。
rr-filter extended-community-number
undo rr-filter
路由反射器不会对反射的路由进行过滤。
BGP VPNv4地址族视图
extended-community-number:路由反射器支持的扩展团体属性号,取值范围1~199。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
# 在BGP VPNv4地址族视图下,配置路由反射器支持的扩展团体属性号为10,即该路由反射器只反射包含扩展团体属性10的VPNv4路由。
[Sysname] bgp 100
[Sysname-bgp-vpnv4] rr-filter 10
1.1.36  sham-link
sham-link命令用来创建一条OSPF伪连接。
undo sham-link命令用来删除一条已有的OSPF伪连接,或者将指定OSPF伪连接的参数恢复为缺省值。
sham-link source-ip-address destination-ip-address [ cost cost | dead dead-interval | hello hello-interval | { { hmac-md5 | md5 } key-id { cipher cipher-string | plain plain-string } | simple { cipher cipher-string | plain plain-string } } | retransmit retrans-interval | trans-delay delay ] *
undo sham-link source-ip-address destination-ip-address [ cost | dead | hello | { { hmac-md5 | md5 } key-id | simple } | retransmit | trans-delay ] *
设备上不存在任何OSPF伪连接。
OSPF区域视图
source-ip-address:OSPF伪连接的源IP地址。
destination-ip-address:OSPF伪连接的目的IP地址。
cost cost:伪连接开销,取值范围为1~65535,缺省值为1。
dead dead-interval:失效间隔,取值范围为1~32768,单位为秒,缺省值为40秒。建立伪连接的两个路由器上需要配置相同的dead seconds值,且至少为hello seconds值的4倍。
hello hello-interval:接口上发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10秒。建立伪连接的两个路由器上需要配置相同的hello seconds值。
hmac-md5:HMAC-MD5验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:MD5/HMAC-MD5验证字标识符,取值范围为1~255。
cipher:以密文形式设置密钥。
cipher-string:密文密钥,区分大小写。对于简单验证模式,为33~41个字符的字符串,对于MD5/HMAC-MD5验证模式,为33~53个字符的字符串。
plain:以明文形式设置密钥。
plain-string:明文密钥,区分大小写。对于简单验证模式,为1~8个字符的字符串,对于MD5/HMAC-MD5验证模式,为1~16个字符的字符串。
retransmit retrans-interval:接口上重传LSA报文的时间间隔,取值范围是1~3600,单位为秒,缺省值为5秒。
trans-delay delay:接口上延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1秒。
属于同一个VPN的两个Site之间存在一条区域内OSPF链路(backdoor链路)时,为了避免VPN流量总是通过backdoor链路转发而不走骨干网,可以在PE路由器之间建立OSPF伪连接(Sham-link),使经过MPLS VPN骨干网的路由也成为OSPF区域内路由,确保VPN流量通过骨干网转发。
可以使用MD5/HMAC-MD5验证或简单验证两种方式对OSPF伪连接进行验证,但不能同时使用两种验证方式。使用MD5/HMAC-MD5验证方式时,可配置多条MD5/HMAC-MD5验证命令,但同一key-id只能配置一个验证字。
修改伪连接的OSPF MD5/HMAC-MD5验证字的步骤如下:
(1)     为伪连接配置新的MD5/HMAC-MD5验证字。此时若邻居设备尚未配置新的MD5/HMAC-MD5验证字,便会触发MD5/HMAC-MD5验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5验证字的多份报文,使得无论邻居设备上是否配置新验证字都能验证通过,保持邻居关系。
(2)     在邻居设备上也配置相同的新MD5/HMAC-MD5验证字。当本设备上收到邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5验证平滑迁移过程。
(3)     在本设备和邻居上都执行undo sham-link命令删除旧的MD5/HMAC-MD5验证字。建议不要为伪连接保留多个MD5/HMAC-MD5验证字,每次MD5/HMAC-MD5验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
# 创建一条OSPF伪连接,源地址为1.1.1.1,目的地址为2.2.2.2。
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] sham-link 1.1.1.1 2.2.2.2
·     display ospf sham-link
snmp-agent trap enable l3vpn命令用来开启L3VPN模块的告警功能。
undo snmp-agent trap enable l3vpn命令用来关闭L3VPN模块的告警功能。
L3VPN模块的告警功能处于开启状态。
开启L3VPN模块的告警功能后,在VPN实例内的路由数达到告警门限等情况下,L3VPN模块会产生RFC 4382中规定的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启L3VPN模块的告警功能。
[Sysname] snmp-agent trap enable l3vpn
tnl-policy命令用来配置当前VPN实例与指定的隧道策略关联。
undo tnl-policy命令用来取消当前VPN实例与隧道策略的关联。
tnl-policy tunnel-policy-name
undo tnl-policy
VPN实例不与任何隧道策略关联。
tunnel-policy-name:VPN实例的隧道策略名称,为1~19个字符的字符串,不区分大小写。
在设备上配置VPN实例与隧道策略关联后,设备将根据指定的隧道策略选择转发该VPN实例流量的隧道。
如果VPN实例没有关联隧道策略或者关联的隧道策略尚未配置,则该VPN实例根据缺省选择策略来选择隧道。缺省选择策略为按照LSP隧道->CR-LSP隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
# 将名为vpn1的VPN实例和隧道策略po1关联起来。
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] tunnel select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname-vpn-instance-vpn1] route-distinguisher 22:33
[Sysname-vpn-instance-vpn1] tnl-policy po1
# 将名为vpn2的IPv4 VPN和隧道策略po1关联起来。
[Sysname-vpn-instance-vpn2] route-distinguisher 11:22
[Sysname-vpn-ipv4-vpn2] tnl-policy po1
[Sysname-vpn-ipv4-vpn2] quit
[Sysname-vpn-instance-vpn2] quit
# 将名为vpn3的IPv6 VPN和隧道策略po1关联起来。
[Sysname-vpn-instance-vpn3] route-distinguisher 11:33
[Sysname-vpn-ipv6-vpn3] tnl-policy po1
·     tunnel-policy(MPLS命令参考/隧道策略)
1.1.39  vpn popgo
vpn popgo命令用来将Egress PE上私网路由的标签操作方式配置为根据标签查找出接口转发。
undo vpn popgo命令用来将Egress PE上私网路由的标签操作方式恢复为根据标签查找FIB转发。
vpn popgo
undo vpn popgo
Egress PE上私网路由的标签操作方式为根据标签查找FIB转发。
BGP视图
配置vpn popgo命令后,Egress PE会自动断开并重建与私网内BGP邻居之间的会话,重新学习私网路由。
配置vpn popgo命令后,Egress PE将报文转发给私网时,不支持在多个私网BGP邻居之间进行BGP负载分担。
# 将Egress PE上私网路由的标签操作方式定制为根据标签查找出接口转发。
[Sysname] bgp 100
[Sysname-bgp] vpn popgo
# 将Egress PE上私网路由的标签操作方式定制为根据标签查找FIB转发。
[Sysname] bgp 100
[Sysname-bgp] undo vpn popgo
1.1.40  vpn-id
vpn-id命令用来配置VPN实例的ID。
undo vpn-id命令用来删除VPN实例的ID。
vpn-id vpn-id
undo vpn-id
没有指定VPN实例的ID。
VPN实例视图
vpn-id:VPN实例的ID,取值形式为OUI:Index,OUI和Index均为十六进制数。其中,OUI(Organizationally Unique Identifier,全球统一标识符)的取值范围为0~FFFFFF;Index的取值范围为0~FFFFFFFF。
VPN ID是VPN实例的唯一标识,不同VPN实例的VPN ID不能相同。
需要注意的是,VPN ID的取值不能为0:0。
# 配置VPN实例vpn1的ID为20:1。
[Sysname-vpn-instance-vpn1] vpn-id 20:1
·     display ip vpn-instance
vpn-target命令用来配置当前VPN实例的Route Target。
undo vpn-target命令用来删除当前VPN实例的Route Target。
没有指定VPN实例的Route Target。
vpn-target&<1-8>:指定Route Target值。vpn-target为3~21个字符的字符串,取值为AS-number:nn或IP-address:nn。&<1-8>表示前面的参数最多可以输入8次。
Route Target有三种格式:
both:指定配置的Route Target值同时作为Import Target和Export Target。没有指定both、export-extcommunity和import-extcommunity中的任何一个参数时,缺省值为both。
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
Route Target用来控制VPN路由的发布。PE在发布的VPN路由中添加Route Target扩展团体属性,该属性的值为配置的Export Target。对端PE接收到VPN路由后,将路由中携带的Route Target属性与本地配置的VPN实例的Import Target进行比较,如果二者中存在相同的值,则将该路由学习到该VPN实例的路由表中。
# 为名为vpn1的VPN实例配置Route Target。
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
# 为名为vpn2的IPv4 VPN配置Route Target。
[Sysname-vpn-ipv4-vpn2] vpn-target 3:3 export-extcommunity
[Sysname-vpn-ipv4-vpn2] vpn-target 4:4 import-extcommunity
[Sysname-vpn-ipv4-vpn2] vpn-target 5:5 both
# 为名为vpn3的IPv6 VPN配置Route Target。
[Sysname-vpn-ipv6-vpn3] vpn-target 3:3 export-extcommunity
[Sysname-vpn-ipv6-vpn3] vpn-target 4:4 import-extcommunity
[Sysname-vpn-ipv6-vpn3] vpn-target 5:5 both
2 IPv6 MPLS L3VPN
本章只介绍IPv6 MPLS L3VPN的相关命令,IPv4 MPLS L3VPN和IPv6 MPLS L3VPN的公共命令请参见“MPLS命令参考”中的“MPLS L3VPN”。
address-family ipv6命令用来进入IPv6 VPN视图。
undo address-family ipv6命令用来删除IPv6 VPN视图下的所有配置。
address-family ipv6
VPN实例视图
在IPv6 VPN视图下可以配置IPv6 VPN的参数,如IPv6 VPN应用的出方向路由策略、入方向路由策略等。
# 进入IPv6 VPN视图。
[Sysname-vpn-instance-vpn1] address-family ipv6
[Sysname-vpn-ipv6-vpn1]
·     address-family ipv4 (VPN instance view)
address-family vpnv6命令用来进入BGP VPNv6地址族视图。
undo address-family vpnv6命令用来删除BGP VPNv6地址族视图下的所有配置。
BGP视图
VPN-IPv6地址是指在IPv6地址前缀前增加RD后,形成的地址。在IPv6 MPLS L3VPN组网中,PE设备之间需要交换VPN-IPv6地址族的路由信息(即BGP VPNv6路由)。
在PE设备上,进入BGP VPNv6地址族视图,在该视图下通过peer enable命令使能BGP对等体(通常为对端PE设备)后,PE才能与该对等体交换BGP VPNv6路由。
在BGP VPNv6地址族视图下,还可以配置BGP-VPNv6路由的属性,例如为从对等体/对等体组接收的BGP-VPNv6路由分配的首选值、是否允许本地AS号在接收的BGP-VPNv6路由的AS_PATH属性中出现等。
# 进入BGP VPNv6地址族视图。
[Sysname] bgp 100
[Sysname-bgp] address-family vpnv6
[Sysname-bgp-af-vpnv6]
display bgp group vpnv6命令用来显示BGP VPNv6对等体组的信息。
display bgp group vpnv6 [ group-name ]
group-name:显示指定BGP VPNv6对等体组的信息,group-name为BGP VPNv6对等体组的名称,为1~47个字符的字符串,区分大小写。如果没有指定本参数,则显示所有BGP VPNv6对等体组的信息。
# 显示公网内所有BGP VPNv6对等体组的信息。
<Sysname> display bgp group vpnv6
 Remote AS: 600
 Type: external
 Members:
  2.2.2.2
# 显示名为group1的BGP VPNv6对等体组的信息。
<Sysname> display bgp group vpnv6 group1
 Remote AS: 600
 Type: external
 Threshold: 75%
 Members:
  2.2.2.2                600        0        0    0       0 00:00:22 Idle
表2-1 display bgp group vpnv6命令输出信息描述表
BGP peer group
BGP对等体组名称
Remote AS
对等体组的AS号
对等体组类型,取值包括:
允许从对等体学习的最大路由数
Threshold
配置的保持时间间隔,单位为秒
Keepalive time
存活时间间隔,单位为秒
路由发布的最小时间间隔,单位为秒
为来自对等体的路由指定的首选值
为对等体组指定的路由策略
Members
对等体组包括的对等体信息
Peer
对等体的IPv4地址
AS
对等体所在的自治系统号
MsgRcvd
从该对等体收到的消息数目
MsgSent
向该对等体发送的消息数目
OutQ
等待发往该对等体的消息数目
PrefRcv
从该对等体收到的前缀数目
Up/Down
BGP会话处于当前状态的时长
该对等体的状态
display bgp peer vpnv6命令用来显示BGP VPNv6对等体的信息。
display bgp peer vpnv6 [ group-name log-info | ip-address { log-info | verbose } | verbose ]
ip-address:显示指定BGP VPNv6对等体的信息。ip-address为对等体的IPv4地址。如果没有指定本参数,则显示所有BGP VPNv6对等体的信息。
log-info:显示BGP VPNv6对等体或对等体组的日志信息。
verbose:显示BGP VPNv6对等体的详细信息。如果没有指定本参数,则显示BGP VPNv6对等体的简要信息。
执行本命令时,如果没有指定任何参数,则显示所有BGP VPNv6对等体的简要信息。
# 显示所有BGP VPNv6对等体的简要信息。
<Sysname> display bgp peer vpnv6
 Local AS number: 300
 Total number of peers: 1                  Peers in established state: 1
  10.1.1.2               100        6        7    0       0 00:01:57 Established
表2-2 display bgp peer vpnv6命令显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
对等体的总数
Peer
对等体的IP地址
AS
对等体所在的自治系统号
MsgRcvd
从该对等体收到的消息数目
MsgSent
向该对等体发送的消息数目
OutQ
等待发往该对等体的消息数目
PrefRcv
从该对等体收到的前缀数目
Up/Down
BGP会话处于当前状态的时长
该对等体的状态
# 显示地址为10.1.1.2的BGP VPNv6对等体的详细信息。
<Sysname> display bgp peer vpnv6 10.1.1.2 verbose
         Peer: 10.1.1.2  Local: 192.168.1.135
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.136
         BGP current state: Established, Up for 00h02m28s
         Port:  Local - 179      Remote - 63679
         Address family IPv4 Unicast: advertised
         Address family VPNv6: advertised and received
 Received: Total 6 messages, Update messages 2
 Sent: Total 7 messages, Update messages 2
 Threshold: 75%
 BFD: Enabled
表2-3 display bgp peer vpnv6 verbose命令显示信息描述表
Peer
对等体的IP地址
Local
本地的路由器ID
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
BGP version
对等体使用的BGP版本
remote router ID
对等体的路由器ID
BGP current state
Up for
BGP会话建立的持续时间
BGP current event
BGP last state
BGP会话的上一个状态
Port
Configured
Received
Negotiated
对等体支持的可选扩展能力
对等体支持BGP多协议扩展能力
对等体支持BGP路由刷新能力
对等体支持四字节AS号能力
IPv4单播地址族能力:可以接收和发送该地址族的路由
VPNv6地址族能力能力:可以接收和发送该地址族的路由
Received
Sent
允许从对等体学习的最大路由数
Threshold
路由发布最小时间间隔,单位为秒
本端支持的可选扩展能力
本端支持BGP多协议扩展能力
本端支持BGP路由刷新能力
配置了TCP连接的源接口
为来自对等体的路由配置的首选值
BFD
为对等体指定的路由策略
# 显示地址为10.1.1.2的BGP VPNv6对等体的日志信息。
<Sysname> display bgp peer vpnv6 10.1.1.2 log-info
 Peer: 10.1.1.2
                             Error/SubError
  21-Nov-2011 13:22:25 Up
  21-Nov-2011 13:21:53 Down  Receive notification with error 6/6
  21-Nov-2011 12:39:37 Up
  21-Nov-2011 12:25:08 Down  Receive notification with error 6/6
  21-Nov-2011 12:09:48 Up
表2-4 display bgp peer vpnv4 log-info命令显示信息描述表
Peer
对等体的IP地址
Date
Time
·     Down:表示BGP会话断开
display bgp routing-table vpnv6命令用来显示BGP VPNv6路由信息。
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] [ network-address prefix-length ]
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv6路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
network-address prefix-length:显示与指定目的网段地址及前缀长度精确匹配的BGP VPNv6路由信息。network-address为目的网段的IPv6地址;prefix-length为目的网段地址的前缀长度,取值范围为0~128。如果没有指定本参数,则显示所有BGP VPNv6路由信息。
# 显示所有BGP VPNv6路由的信息。
<Sysname> display bgp routing-table vpnv6
 Total number of routes from all PEs: 1
 Total number of routes: 4
* >  Network : 2001:1::                                 PrefixLen : 96
     NextHop : ::                                       LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: ?
*  e Network : 2001:1::                                 PrefixLen : 96
     NextHop : 2001:1::1                                LocPrf    :
     MED     : 0
     Path/Ogn: 65410?
* >  Network : 2001:1::2                                PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
* >i Network : 2001:3::                                 PrefixLen : 96
     NextHop : ::FFFF:3.3.3.9                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
表2-5 display bgp routing-table vpnv6命令显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态值:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的VPNv6路由总数
Route distinguisher
路由标识符
路由的总数
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳的IPv6地址
LocPrf
本地优先级
PrefVal
路由首选值
OutLabel
路由的出标签值
MED
Path/Ogn
display bgp routing-table vpnv6 advertise-info命令用来显示BGP VPNv6路由的通告信息。
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] network-address prefix-length advertise-info
network-address prefix-length:显示与指定目的网段地址及前缀长度精确匹配的BGP VPNv6路由的通告信息。network-address为目的网段的IPv6地址;prefix-length为目的网段地址的前缀长度,取值范围为0~128。
# 显示到达目的网段2001:1::/96的BGP VPNv6路由的通告信息。
<Sysname> display bgp routing-table vpnv6 2001:1:: 96 advertise-info
 Paths:   1 best
 BGP routing table information of 2001:1::/96:
    3.3.3.9
 Inlabel         : 1279
表2-6 display bgp routing-table vpnv6 advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
路由总数
Paths
到达指定目的网络的优选路由数目
到达目的网络2001:1::/96的BGP路由的通告信息
该路由已经向哪些VPNv6对等体发送,以及对等体的数目
Inlabel
路由的入标签
display bgp routing-table vpnv6 as-path-acl命令用来显示匹配指定AS路径过滤列表的BGP VPNv6路由信息。
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] as-path-acl as-path-acl-number
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv6路由通告信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
# 显示匹配AS路径过滤列表1的BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 as-path-acl 1
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
以上显示信息的说明请参见表2-5。
display bgp routing-table vpnv6 communit-list命令用来显示匹配指定BGP团体列表的BGP VPNv6路由信息。
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
# 显示匹配BGP团体列表100的BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 community-list 100
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
以上显示信息的说明请参见表2-5。
display bgp routing-table vpnv6 inlabel命令用来显示所有BGP VPNv6路由的入标签信息。
# 显示所有BGP VPNv6路由的入标签信息。
<Sysname> display bgp routing-table vpnv6 inlabel
     NextHop : ::                                       OutLabel  : NULL
     InLabel : 1279
表2-7 display bgp routing-table vpnv6 inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-7
Origin
路由起源代码,请参见表1-7
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为VPNv6路由分配的私网标签
取值为exp-null表示为显式空标签
InLabel
入标签值,即本地PE为VPNv6路由分配的私网标签
display bgp routing-table vpnv6 outlabel命令用来显示所有BGP VPNv6路由的出标签信息。
# 显示所有BGP VPNv6路由的出标签信息。
<Sysname> display bgp routing-table vpnv6 outlabel
     NextHop : ::FFFF:3.3.3.9                           OutLabel  : 1279
表2-8 display bgp routing-table vpnv6 outlabel命令输出信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码,请参见表1-7
Origin
路由起源代码,请参见表1-7
来自所有PE设备的路由数
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
PrefixLen
目的网络地址的前缀长度
NextHop
下一跳IP地址
OutLabel
取值为exp-null表示为显式空标签
display bgp routing-table vpnv6 peer命令用来显示向指定对等体发布或者从指定对等体收到的BGP VPNv6路由信息。
display bgp routing-table vpnv6 peer ip-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
ip-address:对等体的IPv4地址。
# 显示向对等体3.3.3.9发布的所有公网BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: ?
# 显示从对等体3.3.3.9收到的所有公网BGP VPNv6路由信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes
     MED     : 0
     Path/Ogn: ?
以上显示信息的说明请参见表2-5。
# 显示向对等体3.3.3.9发布的公网BGP VPNv6路由的统计信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes statistics
# 显示从对等体3.3.3.9收到的公网BGP VPNv6路由的统计信息。
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes statistic
表2-9 display bgp routing-table vpnv6 peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
display bgp routing-table vpnv6 statistics命令用来显示BGP VPNv6路由的统计信息。
# 显示公网BGP VPNv6路由的统计信息。
<Sysname> display bgp routing-table vpnv6 statistics
表2-10 display bgp routing-table vpnv6 statistics命令显示信息描述表
来自所有PE设备的VPNv6路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv6路由总数
display bgp update-group vpnv6命令用来显示BGP VPNv6地址族下打包组的相关信息。
display bgp update-group vpnv6 [ ip-address ]
ip-address:显示指定对等体所在打包组的信息。ip-address为对等体的IP地址。如果不指定本参数,则显示BGP VPNv6地址族的所有打包组信息。
# 显示BGP VPNv6地址族的所有打包组信息。
<Sysname> display bgp update-group vpnv6
  Update-group ID: 0
  Type: EBGP link
  OutQ: 0
  Members: 1
    99::1
# 显示BGP VPNv6对等体1.1.1.2所在打包组的信息。
<Sysname> display bgp update-group vpnv6 1.1.1.2
  Update-group ID: 0
  Type: EBGP link
  OutQ: 0
  Members: 2
    1.1.1.2
    1.1.1.3
表2-11 display bgp update-group vpnv6命令显示信息描述表
Update-group ID
打包组ID
·     IBGP link:IBGP连接
·     EBGP link:EBGP连接
打包组中的对等体支持4字节AS号
打包组中的对等体抑制4字节AS号
Fake AS: number
Public-AS-Only: Yes
Substitute-AS: Yes
向打包组中的对等体发布团体属性
打包组中的对等体是路由反射器的客户机
向打包组中的对等体发布扩展团体属性
Export prefix list: ipv6-prefix-name
Export filter-policy: ACL acl6-number
OutQ
等待发往打包组中对等体的前缀数目
Members
打包组中对等体的数目及对等体的地址
policy vpn-target命令用来对接收到的VPNv6路由使能VPN-Target过滤功能,即只将Export Route Target属性与本地Import Route Target属性匹配的VPNv6路由加入到路由表。
undo policy vpn-target命令用来取消对VPNv6路由的VPN-Target过滤功能,即接收所有VPNv6路由。
policy vpn-target
对接收到的VPNv6路由使能VPN-Target过滤功能。
BGP VPNv6地址族视图
在跨域VPN OptionB组网中,ASBR-PE需要保存所有VPNv6路由信息,以通告给对端ASBR-PE。这种情况下,ASBR-PE上需执行undo policy vpn-target命令接收所有的VPNv6路由信息,不对它们进行Route Target过滤。
# 在BGP VPNv6地址族视图下,取消对VPNv6路由的Route Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-af-vpnv6] undo policy vpn-target
refresh bgp vpnv6命令用来手工对VPNv6地址族下的BGP会话进行软复位。
refresh bgp { ip-address | all | external | group group-name | internal } { export | import } vpnv6
all:软复位VPNv6地址族下的所有BGP会话。
external:软复位VPNv6地址族下的所有EBGP会话。
internal:软复位VPNv6地址族下的所有IBGP会话。
export:触发出方向的软复位,即采用新的配置对向对等体发布的VPNv6路由进行过滤。
import:触发入方向的软复位,即采用新的配置对从对等体接收的VPNv6路由进行过滤。
软复位BGP会话是指在不断开BGP邻居关系的情况下,更新BGP VPNv6路由信息,使新的配置生效。
·     配置peer keep-all-routes命令后,执行refresh bgp vpnv6 import命令不会生效。
# 手工对VPNv6地址族下的所有BGP会话进行入方向的软复位。
<Sysname> refresh bgp all import vpnv6
reset bgp vpnv6命令用来复位VPNv6地址族下的BGP会话。
reset bgp { as-number | ip-address | all | external | group group-name | internal } vpnv6
all:复位VPNv6地址族下的所有BGP会话。
external:复位VPNv6地址族下的所有EBGP会话。
internal:复位VPNv6地址族下的所有IBGP会话。
BGP的选路策略改变后,为了使新的策略生效,可以复位BGP会话,即删除并重新建立BGP会话,以便重新发布BGP VPNv6路由信息,并应用新的策略对BGP VPNv6路由信息进行过滤。复位BGP会话时,会造成短暂的BGP会话中断。
# 复位VPNv6地址族下的所有BGP会话。
<Sysname> reset bgp all vpnv6
2.1.17  rr-filter
rr-filter命令用来创建路由反射器的反射策略:通过配置路由反射器支持的扩展团体属性号,对接收的路由信息进行过滤,只有接收的VPNv6路由包含指定的扩展团体属性号时,路由反射器才会反射该路由。
undo rr-filter
路由反射器不会对反射的路由进行过滤。
BGP VPNv6地址族视图
extended-community-number:路由反射器支持的扩展团体属性号,取值范围为1~199。
# 在BGP VPNv6地址族视图下,配置路由反射器支持的扩展团体属性号为10,即该路由反射器只反射包含扩展团体属性10的VPNv6路由。
[Sysname] bgp 100
[Sysname-bgp-vpnv6] rr-filter 10
