03-二层技术-以太网交换命令参考
12-LLDP命令
本章节下载: 12-LLDP命令  (262.97 KB)
12-LLDP命令
1 LLDP
三层以太网接口是指在以太网接口视图下通过port link-mode route命令切换为三层模式的以太网接口,有关以太网接口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网接口配置”。
1.1  LLDP配置命令
1.1.1  display lldp local-information
display lldp local-information命令用来显示LLDP本地信息,这些信息将将根据端口TLV使能情况被组织成TLV发送给邻居设备。
global:显示全局LLDP本地信息。
interface interface-type interface-number:显示指定接口上的LLDP本地信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将显示所有LLDP本地信息,包括全局LLDP信息以及所有使能了LLDP功能且状态为up的接口上的LLDP信息。
# 显示所有LLDP本地信息(假设DCBX的版本为标准版)。
<Sysname> display lldp local-information
 Chassis ID          : 000c-1000-1111
 System name         : H3C
 System description  : H3C Comware Platform Software, Software Version 7.1.045,
                       Feature 2110L06
                       H3C S10504
                       Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All
                       rights reserved.
 System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
 System capabilities enabled   : Bridge, Router, Customer Bridge
 MED information:
 Device class               : Connectivity device
 MED inventory information of master board:
 HardwareRev                : VER.A
 FirmwareRev                : 121
 SoftwareRev                : S10500-CMW71045-2110L06
 SerialNum                  : Unknown
 Manufacturer name          : H3C
 Model name                 : H3C S10504
 Asset tracking identifier  : Unknown
LLDP local-information of port 52[Ten-GigabitEthernet1/0/3]:
 Port ID type       : Interface name
 Port ID            : Ten-GigabitEthernet1/0/3
 Port description   : Ten-GigabitEthernet1/0/3 Interface
 LLDP agent nearest-bridge management address:
 Management address type           : IPv4
 Management address                : 192.168.80.60
 Management address interface ID   : Unknown
 Management address OID            : 0
 LLDP agent nearest-nontpmr management address:
 Management address                : 192.168.80.61
 LLDP agent nearest-customer management address:
 Management address                : 192.168.80.62
 DCBX Control info:
 Oper version       : Standard
 DCBX ETS configuration info:
  CBS                : False
  Max TCs            : 8
  CoS     Local Priority      Percentage        TSA
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
 DCBX ETS recommendation info:
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
 DCBX PFC info:
  P0-0     P1-1     P2-1     P3-1     P4-0     P5-0     P6-0     P7-0
  Number of traffic classes supported: 8
  Value of MBC: 0
 DCBX APP info:
  Selected Field  Protocol ID  Priority
  UDP/DCCP        100          0x3
  TCP/SCTP        200          0x3
  Ethertype       0x1234       0x3
  Ethertype       0x8906       0x3
 Port VLAN ID(PVID): 1
 Port and protocol VLAN ID(PPVID) : 0
 Port and protocol VLAN supported : No
 Port and protocol VLAN enabled   : No
 VLAN name of VLAN 12: VLAN 0012
 Management VLAN ID  : 5
 Link aggregation enabled   : No
 Aggregation port ID        : 0
 Auto-negotiation enabled   : Yes
 OperMau                    : Speed(10000)/Duplex(Full)
 Power port class           : PSE
 PSE power supported        : No
 PSE power enabled          : No
 PSE pairs control ability  : No
 Power pairs                : Signal
 Port power classification  : Class 0
 Maximum frame size         : 9216
表1-1 display lldp local-information命令显示信息描述表
本设备的全局LLDP本地信息
Chassis ID
Chassis ID值,为本设备的桥MAC地址
System name
系统名称
System description
系统描述
系统所支持的功能:
·     Bridge:表示支持交换功能
·     Router:表示支持路由功能
·     DocsisCableDevice:表示支持电缆设备功能
·     StationOnly:表示支持只作站点功能
·     Customer Bridge:表示支持客户桥功能
·     Service Bridge:表示支持服务桥功能
·     TPMR:表示支持双端口MAC中继功能
·     Other:表示支持不在上述列表的其它功能
系统已使能的功能:
·     Bridge:表示交换功能已使能
·     Router:表示路由功能已使能
·     DocsisCableDevice:表示电缆设备功能已使能
·     StationOnly:表示只作站点功能已使能
·     Customer Bridge:表示客户桥功能已使能
·     Service Bridge:表示服务桥功能已使能
·     TPMR:表示双端口MAC中继功能已使能
·     Other:表示不在上述列表的其它功能已使能
MED information
MED设备相关信息
Device class
MED设备类型:
·     Connectivity device:表示网络设备
·     Class I:表示一般终端设备,即所有需要LLDP发现服务的终端设备
·     Class II:表示媒体终端设备,即具备媒体能力的终端设备,其能力包含了一般终端设备的能力。该类设备支持媒体流
·     Class III:表示通讯终端设备,即直接支持目标用户IP通讯系统的终端设备,其能力包含了一般终端设备和媒体终端设备的所有能力。该类设备直接被目标用户所使用
主控板MED资产信息
HardwareRev
产品的硬件版本
FirmwareRev
产品的固件版本
SoftwareRev
产品的软件版本
SerialNum
序列号
Manufacturer name
制造厂商
Model name
模块名称
资产跟踪ID
LLDP local-information of port 1
端口1上LLDP本地信息
Port ID type
端口ID类型:
·     MAC address:表示MAC地址
·     Interface name:表示接口名称
Port ID
端口ID值,根据本设备的Port ID type取相应类型的值
Port description
端口描述
LLDP缺省代理,即最近桥代理的管理地址
LLDP最近客户桥代理的管理地址
LLDP最近非TPMR桥代理的管理地址
管理地址类型
Management address
管理地址
管理地址所在接口的编码方式
管理地址接口索引
管理地址对象标识符
DCBX control info
显示DCBX控制TLV的信息,在标准DCBX中显示版本信息
Oper version
DCBX版本号
Sequence number
DCBX TLV内容改变的次数
Acknowledge number
对端设备同步配置的次数
DCBX ETS info
CoS与本地优先级的映射关系及对应的带宽分配情况
CoS
CoS值
Local Priority
本地优先级
Percentage
对应的带宽分配
P0-     P1-     P2-     P3-     P4-     P5-     P6-     P7-
本端的no-drop标记值对应的支持的优先级数
PFC支持的能力集,只在1.01版本中显示该项
DCBX APP info
显示APP TLV信息
Selected Field
选择域
Priority
802.1p优先级
Protocol ID
应用协议号
CoS map
应用协议与CoS的映射关系
显示ETS配置TLV信息
CBS
是否支持CBS,表示本端是否支持令牌桶限速算法:
·     False:表示不支持令牌桶限速算法
·     True:表示支持令牌桶限速算法
Max TCs
支持的最大优先级数目
TSA
传输选择算法
显示ETS推荐TLV信息
DCBX PFC info
显示PFC TLV信息
Value of MBC
支持的MBC状态(MBC表示报文避开MACsec的能力,占1个bit,取值为0表示MACsec去使能时,报文可以避开MACsec,取值为1表示MACsec去使能时,报文不可以避开MACsec)
Port VLAN ID(PVID)
端口VLAN ID
端口协议VLAN ID
是否支持端口协议VLAN
是否已使能端口协议VLAN
VLAN 12的名称
Management VLAN ID
管理VLAN ID
端口是否支持自协商
端口是否已使能自协商
OperMau
端口自适应的速率和双工状态
Power port class
PoE类型:
·     PSE(Power Sourcing Equipment,供电设备)
·     PD(Powered Device,受电设备)
PSE power supported
是否支持PSE供电
PSE power enabled
是否已使能PSE供电
供电方式是否可控
Power pairs
PoE端口的远程供电模式:
·     Signal:表示信号线供电模式
·     Spare:表示空闲线供电模式
PD的端口控制级别:
·     Class 0:表示级别0
·     Class 1:表示级别1
·     Class 2:表示级别2
·     Class 3:表示级别3
·     Class 4:表示级别4
端口是否支持链路聚合
端口是否已使能链路聚合
Aggregation port ID
聚合组中该成员端口的编号,未使能链路聚合功能时为0
Maximum frame size
端口支持的最大帧长度
1.1.2  display lldp neighbor-information
display lldp neighbor-information命令用来显示由邻居设备发来的LLDP信息,这些信息是由邻居设备组织成TLV并发送给本设备的。
interface interface-type interface-number:显示指定接口收到的由邻居设备发来的LLDP信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口收到的由邻居设备发来的LLDP信息。
agent:显示指定类型LLDP代理收到的由邻居设备发来的LLDP信息。如果未指定该参数,将显示所有类型LLDP代理收到的由邻居设备发来的LLDP信息。
nearest-bridge:表示最近桥代理。
nearest-customer:表示最近客户桥代理。
nearest-nontpmr:表示最近非TPMR桥代理。
verbose:显示由邻居设备发来的LLDP详细信息。如果未指定该参数,将显示由邻居设备发来的LLDP概要信息。
list:按列表显示由邻居设备发来的LLDP信息。
system-name system-name:按列表显示由指定邻居设备发来的LLDP信息。system-name表示邻居设备的系统名称,为1~255个字符的字符串。如果未指定该参数,将按列表显示由所有邻居设备发来的LLDP信息。
# 显示所有接口最近桥代理收到的由邻居设备发来的LLDP详细信息(假设DCBX的版本为标准版)。
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[Ten-GigabitEthernet1/0/1]:
LLDP agent nearest-bridge:
 LLDP Neighbor index : 1
 Update time         : 0 days, 0 hours, 1 minutes, 1 seconds
 LLDP mac type       : Nearest Bridge
 Chassis type        : MAC address
 Chassis ID          : 000f-0055-0002
 Port ID             : Ten-GigabitEthernet1/0/1
 Time to live        : 120
 Port description    : Ten-GigabitEthernet1/0/1 Interface
 System name         : Sysname
 Management address                : 192.168.1.55
 DCBX Control info:
  CBS                : False
  Max TCs            : 8
  CoS     Local priority      Percentage        TSA
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
 DCBX PFC info:
  Value of MBC: 0
 DCBX APP info:
  UDP/ DCCP                   100         0x3
  TCP/SCTP                    200         0x3
 Port and protocol VLAN ID(PPVID) : 12
 Port and protocol VLAN supported : Yes
 Port and protocol VLAN enabled   : Yes
 MED information:
 Media policy type          : Unknown
 Unknown policy             : No
 VLAN tagged                : No
 Media policy VLAN ID       : 1000
 Media policy L2 priority   : 6
 Media policy DSCP          : 10
 Location format       : Civic Address LCI
 Location information  :
  What(1)  Country(CN)
  CA type  CA value
  0        Chinese
  1        Zhejiang
  2        Hangzhou
 MED port information:
  Unknown policy             : No
  VLAN tagged                : No
  Media policy VLANID        : 1000
 PoE PSE power source       : Primary
 Port PSE priority          : Low
 Port available power value : 2.2(w)
 Unknown basic TLV:
  TLV type           : 23
  TLV information    : 0x00140014
 Unknown organizationally-defined TLV:
  TLV OUI            : 00-12-bb
  TLV subtype        : 21
  Index              : 1
  TLV information    : 0x556e6b6e 6f776e
CDP neighbor-information of port 1[Ten-GigabitEthernet1/0/1]:
  CDP neighbor index : 2
  Chassis ID         : Switch
  Address            : 2.0.0.2
  Port ID            : GigabitEthernet1/0/3
  Software version   : Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9
-M), Version 12.2(25)SED1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 22-Nov-05 23:37 by yenanh
  Platform           : cisco WS-C3750G-48TS
  Duplex             : Full
# 显示所有接口所有类型LLDP代理收到的由邻居设备发来的LLDP详细信息(假设DCBX的版本为标准版)。
<Sysname> display lldp neighbor-information verbose
 Time to live        : 120
 DCBX control info:
  CBS                : False
  Max TCs            : 8
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
 DCBX PFC info:
  Value of MBC: 0
 DCBX APP info:
  UDP/DCCP        100          0x3
  TCP/SCTP        200          0x3
 HardwareRev               : Unknown
 FirmwareRev               : Unknown
 SoftwareRev               : Unknown
 SerialNum                 : Unknown
 Manufacturer name         : Unknown
 Model name                : Unknown
  What(1)  Country(CN)
  CA type  CA value
  0        Chinese
  1        Zhejiang
  2        Hangzhou
  Unknown policy             : No
  VLAN tagged                : No
 Unknown basic TLV:
  TLV type           : 23
  TLV OUI            : 00-12-bb
  TLV subtype        : 21
  Index              : 1
 CDP neighbor index  : 4
 Chassis ID         : Switch
 Address            : 2.0.0.2
 Duplex             : Full
LLDP agent nearest-nontpmr:
 Time to live        : 120
 SerialNum                 : Unknown
  What(1)  Country(CN)
  CA type  CA value
  0        Chinese
  1        Zhejiang
  2        Hangzhou
  Unknown policy             : No
  VLAN tagged                : No
Port available power value: 2.2(w)
Unknown basic TLV:
  TLV type           : 23
  TLV OUI            : 00-12-bb
  TLV subtype        : 21
  Index              : 1
# 显示所有接口所有类型LLDP代理收到的由邻居设备发来的LLDP概要信息。
LLDP neighbor-information of port 52[Ten-GigabitEthernet1/0/3]:
 LLDP neighbor index : 3
 ChassisID/subtype   : 0011-2233-4400/MAC address
 PortID/subtype      : 000c-29f5-c71f/MAC address
 Capabilities        : Bridge, Router, Customer Bridge
 LLDP neighbor index : 6
 PortID/subtype      : 000c-29f5-c715/MAC address
 Capabilities        : None
CDP neighbor-information of port 52[Ten-GigabitEthernet1/0/3]:
 Chassis ID          : SEP00260B5C0548
 Port ID             : Port 1
 CDP neighbor index  : 5
 Chassis ID          : 0011-2233-4400
 Port ID             : Ten-GigabitEthernet1/0/4
 Capabilities        : None
# 按列表显示类型LLDP代理所有邻居设备发来的LLDP信息。
Chassis ID : * -- --Nearest nontpmr bridge neighbor
             # -- --Nearest customer bridge neighbor
             Default -- -- Nearest bridge neighbor
System Name          Local Interface   Chassis ID       Port ID
System1              XGE1/0/1          000f-e25d-ee91   Ten-GigabitEthernet1/0/5
System2              XGE1/0/2          000f-e25d-ee92*  Ten-GigabitEthernet1/0/6
System3              XGE1/0/3          000f-e25d-ee93#  Ten-GigabitEthernet1/0/7
表1-2 display lldp neighbor-information命令显示信息描述表
LLDP缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
端口1上收到的LLDP邻居信息
LLDP Neighbor index
邻居索引
Update time
邻居信息最新更新时间
LLDP mac type
邻居MAC地址类型:
·     Nearest brige:最近桥代理
·     Nearest customer bridge:最近客户桥代理
·     Nearest non-tpmr bridge:最近非TPMR桥代理
Chassis type
Chassis ID类型:
·     Chassis component:表示底架组件
·     Interface alias:表示接口化名
·     Port component:表示端口组件
·     Network address(ipv4):表示网络地址(括号里表示地址类型)
·     Locally assigned:表示邻居自定义
Chassis ID
Chassis ID值,根据邻居设备的Chassis type取相应类型的值
Port ID type
端口ID类型:
·     Network Address(ipv4):表示网络地址(括号里表示地址类型)
·     Agent circuit ID:表示代理巡回标识
Port ID
端口ID值,根据邻居设备的Port ID type取相应类型的值
Time to live
邻居信息在本地的存活时间
Port description
端口描述
System name
系统名称
System description
系统描述
系统所支持的功能:
·     Repeater:表示支持信号中继功能
·     Bridge:表示支持交换功能
·     WlanAccessPoint:表示支持无线接入点功能
·     Router:表示支持路由功能
·     Telephone:表示支持电话功能
系统已使能的功能:
·     Repeater:表示信号中继功能已使能
·     Bridge:表示交换功能已使能
·     WlanAccessPoint:表示无线接入点功能已使能
·     Router:表示路由功能已使能
·     Telephone:表示电话功能已使能
管理地址类型
Management address
管理地址
管理地址接口类型
管理地址接口索引
管理地址对象标识符
DCBX control info:
Oper version
DCBX版本号
Sequence number
DCBX TLV内容改变的次数
Acknowledge number
对端设备同步配置的次数
DCBX ETS info
CoS
CoS值
Local Priority
本地优先级
Percentage
对应的带宽分配
PFC支持的能力集,在1.01版本和标准版本中显示该项
DCBX APP info
显示APP TLV信息
Protocol ID
应用协议号
CoS map
应用协议与CoS的映射关系
显示ETS配置TLV信息
CBS
·     True:表示支持令牌桶限速算法
Max TCs
显示支持的最大优先级数目
TSA
显示传输选择算法
显示ETS推荐TLV信息
DCBX PFC info
显示PFC TLV信息
Value of MBC
支持的MBC状态
Selected Field
选择域
Port VLAN ID
端口VLAN ID
端口协议VLAN ID
是否支持端口协议VLAN
是否使能端口协议VLAN
VLAN 12的名称
Management VLAN ID
管理VLAN ID
端口是否支持自协商
端口是否已使能自协商
OperMau
端口自适应的速率和双工状态
Power port class
PoE类型:
·     PSE:表示供电设备
·     PD:表示受电设备
PSE power supported
是否支持PSE供电
PSE power enabled
是否已使能PSE供电
供电方式是否可控
Power pairs
PoE端口的远程供电模式:
·     Signal:表示信号线供电模式
·     Spare:表示空闲线供电模式
PD的端口控制级别:
·     Class 0:表示级别0
·     Class 1:表示级别1
·     Class 2:表示级别2
·     Class 3:表示级别3
·     Class 4:表示级别4
端口是否支持链路聚合
端口是否已使能链路聚合
Maximum frame size
端口支持的最大帧长度
MED information
MED设备相关信息
Device class
MED设备类型:
Media policy type
媒体策略类型:
·     Unknown:表示类型未知
·     Voice:表示语音
·     VoiceSignaling:表示语音信号
·     GuestVoice:表示访客语音
·     GuestVoiceSignaling:表示访客语音信号
·     SoftPhoneVoice:表示软体电话语音
·     Videoconferencing:表示视频会议
·     StreamingVideo:表示流视频
·     VideoSignaling:表示视频信号
Unknown policy
媒体策略类型是否未知:
·     Yes:表示策略类型未知
·     No:表示策略类型已知
VLAN tagged
媒体VLAN是否带Tag
媒体VLAN的VLAN ID
二层优先级
Media policy DSCP
DSCP的值
Location format
位置信息格式:
·     Invalid:表示无效位置数据类型
·     Coordinate-based LCI:表示基于坐标的位置信息
·     Civic Address LCI:表示普通地址信息
·     ECS ELIN:表示紧急电话号码
位置信息
PSE所采用的电源类型:
·     Unknown:表示采用的电源类型未知
·     Primary:表示采用主用电源作为电源
·     Backup:表示采用备用电源作为电源
PoE PD power source
PD所采用的电源类型:
·     PSE:表示采用PSE作为电源
·     Local:表示采用本地电源作为电源
·     PSE and local:表示采用PSE和本地电源作为电源
PoE service type
PoE服务类型
Port PSE priority
PSE上端口的供电优先级:
·     Unknown:表示优先级未知
·     Critical:表示优先级为1级
·     High:表示优先级为2级
·     Low:表示优先级为3级
Port PD priority
PD上端口的受电优先级:
·     Unknown:表示优先级未知
·     Critical:表示优先级为1级
·     High:表示优先级为2级
·     Low:表示优先级为3级
PSE上端口可提供的功率,或PD上端口所需的功率(单位为瓦特)
HardwareRev
产品的硬件版本
FirmwareRev
产品的固件版本
SoftwareRev
产品的软件版本
SerialNum
序列号
Manufacturer name
制造厂商
Model name
模块名称
资产跟踪ID
Unknown basic TLV
未知的基本TLV
TLV type
未知的基本TLV类型
TLV information
未知的基本TLV的具体信息
未知组织定义TLV
TLV OUI
未知组织定义TLV的对象唯一标识
TLV subtype
未知的组织定义TLV类型
Index
未知组织的索引
端口1的CDP邻居信息
CDP neighbor index
CDP邻居索引
Chassis ID/subtype
Chassis ID值及Chassis ID类型
Port ID/subtype
Port ID值及PortID类型
Software version
邻居软件版本
Platform version
邻居平台版本
Duplex
双工状态
Capabilities
系统已使能的功能:
·     Repeater:表示使能信号中继功能
·     Bridge:表示使能交换功能
·     WlanAccessPoint:表示使能无线接入点功能
·     Router:表示使能路由功能
·     Telephone:表示使能电话功能
·     DocsisCableDevice:表示使能电缆设备功能
·     StationOnly:表示使能只作站点功能,与其他功能不能同时出现
·     Other:表示使能不在上述列表的其他功能
·     None:表示该邻居未发布该TLV
Local Interface
接收LLDP信息的本端端口
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
                    #-- -- Nearest customer bridge neighbor
·     *符号:表示该邻居是最近非TPMR桥代理类型邻居
#符号:表示该邻居是最近客户桥代理类型邻居
1.1.3  display lldp statistics
display lldp statistics命令用来显示LLDP的统计信息。
global:显示全局LLDP统计信息。
interface interface-type interface-number:显示指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。
agent:显示指定类型LLDP代理的统计信息。如果未指定该参数,将显示所有类型LLDP代理的统计信息。
如果未指定任何参数,将同时显示全局和接口上的LLDP统计信息。
# 显示全局和接口上的LLDP统计信息。
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics information of port 1 [Ten-GigabitEthernet1/0/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
LLDP agent nearest-customer:
# 显示接口Ten-GigabitEthernet1/0/1的最近客户桥代理上的LLDP统计信息。
<Sysname> display lldp statistics interface Ten-GigabitEthernet1/0/1 agent nearest-customer
表1-3 display lldp statistics命令显示信息描述表
LLDP缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
全局LLDP统计信息
邻居信息的最后更新时间
邻居信息的增加次数
邻居信息的删除次数
由于空间不足而导致丢弃邻居信息的次数
邻居信息的老化数量
LLDP statistics Information of port 1
端口1上的LLDP统计信息
发送的LLDP帧总数
收到的LLDP帧总数
丢弃的LLDP帧总数
收到的错误LLDP帧总数
丢弃的LLDP TLV总数
不可识别的LLDP TLV总数
老化的LLDP邻居信息总数
发送的CDP帧总数
收到的CDP帧总数
丢弃的CDP帧总数
收到的错误CDP帧总数
1.1.4  display lldp status
display lldp status命令用来显示LLDP的状态信息。
interface interface-type interface-number:显示指定接口上的LLDP状态信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有使能了LLDP功能的接口上的LLDP状态信息。
agent:显示指定类型LLDP代理的状态信息。如果未指定该参数,将显示所有类型LLDP代理的状态信息。
# 显示全局和所有接口上的LLDP状态信息。
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
Transmit interval              : 30s
Fast transmit interval         : 1s
Transmit max credit            : 5
Hold multiplier                : 4
Reinit delay                   : 2s
Trap interval                  : 5s
Fast start times               : 3
LLDP status information of port 1 [Ten-GigabitEthernet1/0/1]:
Port status of LLDP            : Enable
Admin status                   : Tx_Rx
Trap flag                      : No
MED trap flag                  : No
Polling interval               : 0s
Number of LLDP neighbors       : 5
Number of MED neighbors        : 2
Number of CDP neighbors        : 0
Number of sent optional TLV    : 12
Trap flag                      : No
Trap flag                      : No
表1-4 display lldp status命令显示信息描述表
Bridge mode of LLDP
LLDP桥模式:
·     service-bridge:表示服务桥模式
·     customer-bridge:表示客户桥模式
LLDP缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
LLDP功能是否已全局使能
当前设备的LLDP邻居总数
当前设备的CDP邻居总数
邻居信息的最后更新时间
Transmit interval
LLDP报文的发送间隔
Hold multiplier
TTL乘数
Reinit delay
端口初始化延迟时间
Transmit max credit
LLDP报文发包限速令牌桶的最大值
Trap interval
Trap信息的发送间隔
Fast start times
快速发送LLDP报文的个数
LLDP status infomation of port 1
端口1上的LLDP状态信息
Port status of LLDP
LLDP功能是否已在端口上使能
Admin status
端口LLDP工作模式:
·     Tx_Rx:表示既发送也接收LLDP报文
·     Rx_Only:表示只接收不发送LLDP报文
·     Tx_Only:表示只发送不接收LLDP报文
·     Disable:表示既不发送也不接收LLDP报文
Trap Flag
LLDP Trap功能是否已使能
MED trap flag
LLDP-MED Trap功能是否已使能
Polling interval
轮询间隔,0表示轮询功能处于关闭状态
Number of neighbors
端口LLDP邻居数量
端口MED邻居设备的数量
端口CDP邻居设备的数量
端口在一个LLDP报文中发送的可选TLV总数
端口在所有LLDP报文中收到的不能识别的TLV总数
1.1.5  display lldp tlv-config
display lldp tlv-config命令用来显示接口上可发送的可选TLV信息。
display lldp tlv-config [ interface interface-type interface-number ] [ agent { nearest-bridge | nearest-customer | nearest-nontpmr ] ]
interface interface-type interface-number:显示指定接口上可发送的可选TLV信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口上可发送的可选TLV信息。
agent:显示指定类型LLDP代理的可选TLV信息。如果未指定该参数,将显示所有类型LLDP代理的可选TLV信息。
# 显示接口Ten-GigabitEthernet1/0/1上可发送的可选TLV信息。
<Sysname> display lldp tlv-config interface ten-gigabitethernet 1/0/1
LLDP tlv-config of port 1[Ten-GigabitEthernet1/0/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       YES
 System Name TLV                  YES       YES
 System Description TLV           YES       YES
 System Capabilities TLV          YES       YES
 Management Address TLV           YES       YES
IEEE 802.1 extend TLV:
 Port VLAN ID TLV                 YES       YES
 Port And Protocol VLAN ID TLV    YES       YES
 VLAN Name TLV                    YES       YES
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
 Link Aggregation TLV             YES       YES
 Management VID TLV               YES       YES
IEEE 802.3 extend TLV:
 MAC-Physic TLV                   YES       YES
 Power via MDI TLV                YES       YES
 Maximum Frame Size TLV           YES       YES
LLDP-MED extend TLV:
 Network Policy TLV               YES        YES
 Location Identification TLV      NO         NO
 Extended Power via MDI TLV       YES        YES
 Inventory TLV                    YES        YES
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       NO
 System Name TLV                  YES       NO
 System Description TLV           YES       NO
 System Capabilities TLV          YES       NO
 Management Address TLV           YES       NO
 Port VLAN ID TLV                 YES       NO
 Port And Protocol VLAN ID TLV    YES       NO
 VLAN Name TLV                    YES       NO
 DCBX TLV                         NO        NO
 EVB TLV                          YES       YES
 Link Aggregation TLV             YES       NO
 Management VID TLV               NO        NO
 MAC-Physic TLV                   YES       NO
 Power via MDI TLV                YES       NO
 Maximum Frame Size TLV           YES       NO
 Network Policy TLV               YES        NO
 Extended Power via MDI TLV       YES        NO
 Inventory TLV                    YES        NO
NAME                              STATUS    DEFAULT
Basic optional TLV:
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
表1-5 display lldp tlv-config命令显示信息描述表
LLDP 缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
端口1上可发送的可选TLV类型
NAME
TLV类型
STATUS
端口是否配置发布指定类型TLV
DEFAULT
端口发布指定类型TLV的缺省情况
Basic optional TLV
端口可以发送的基本TLV类型
端口描述TLV
System Name TLV
系统名称TLV
系统描述TLV
系统能力集TLV
管理地址TLV
IEEE 802.1 extended TLV
端口可发送的IEEE 802.1组织定义的TLV类型
Port VLAN ID TLV
端口VLAN ID TLV
协议VLAN ID TLV
VLAN Name TLV
VLAN名称TLV
DCBX TLV
DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议) TLV。
EVB TLV
EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV。
Management VID TLV
管理VLAN TLV
IEEE 802.3 extended TLV
端口可发送的IEEE 802.3组织定义的TLV类型
MAC-Physic TLV
端口物理属性TLV
Power via MDI TLV
供电能力TLV
链路聚合TLV
最大帧长度TLV
LLDP-MED extend TLV
LLDP-MED TLV
Capabilities TLV
MED能力集TLV
Network Policy TLV
网络策略TLV
位置标识TLV
扩展供电能力TLV
Inventory TLV
资产信息TLV,包括以下几种:
·     Hardware Revision TLV:终端设备硬件版本
·     Firmware Revision TLV:终端设备固件版本
·     Software Revision TLV:终端设备软件版本
·     Serial Number TLV:终端设备序列号
·     Manufacturer Name TLV:终端设备的制造厂商名称
·     Model name TLV:终端设备的模块名称
·     Asset id TLV:终端设备的资产标识符,以便目录管理和资产跟踪
1.1.6  lldp admin-status
lldp admin-status命令用来配置LLDP的工作模式。
undo lldp admin-status命令用来恢复缺省情况。
在二层以太网接口视图/三层以太网接口视图下:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
LLDP最近桥代理的工作模式为TxRx,既发送也接收LLDP报文。其他类型的LLDP代理的工作模式为Disable,即不发送也不接收LLDP报文。
二层以太网接口视图/二层聚合接口视图/三层以太网接口视图
agent:配置指定类型LLDP代理的工作模式。在以太网接口视图下,未指定时表示配置最近桥代理的工作模式。
disable:表示工作模式为Disable,既不发送也不接收LLDP报文。
rx:表示工作模式为Rx,只接收不发送LLDP报文。
tx:表示工作模式为Tx,只发送不接收LLDP报文。
txrx:表示工作模式为TxRx,既发送也接收LLDP报文。
# 配置接口Ten-GigabitEthernet1/0/1上最近客户桥代理LLDP的工作模式为Rx。
[Sysname-Ten-GigabitEthernet1/0/1] lldp agent nearest-customer admin-status rx
1.1.7  lldp check-change-interval
lldp check-change-interval命令用来使能轮询功能并配置轮询间隔。
undo lldp check-change-interval命令用来关闭轮询功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
轮询功能处于关闭状态。
agent:配置指定类型LLDP代理的轮询功能。在以太网接口视图下,未指定时表示配置最近桥代理的轮询功能。
interval:表示轮询间隔,取值范围为1~30,单位为秒。
# 在接口Ten-GigabitEthernet1/0/1的最近客户桥代理上使能轮询功能,并配置轮询间隔为30秒。
[Sysname-Ten-GigabitEthernet1/0/1] lldp agent nearest-customer check-change-interval 30
1.1.8  lldp compliance admin-status cdp
lldp compliance admin-status cdp命令用来配置LLDP兼容CDP功能的工作模式。
undo lldp compliance admin-status cdp命令用来恢复缺省情况。
lldp compliance admin-status cdp { disable | txrx }
LLDP兼容CDP功能的工作模式为Disable,既不发送也不接收CDP报文。
二层以太网接口视图/三层以太网接口视图
disable:表示工作模式为Disable,既不发送也不接收CDP报文。
txrx:表示工作模式为TxRx,既发送也接收CDP报文。
欲使LLDP兼容CDP的功能生效,必须先使能LLDP兼容CDP功能,同时将LLDP兼容CDP功能的工作模式配置为TxRx。
# 使能LLDP兼容CDP功能,并在接口Ten-GigabitEthernet1/0/1上配置LLDP兼容CDP功能的工作模式为TxRx。
[Sysname] lldp compliance cdp
[Sysname-Ten-GigabitEthernet1/0/1] lldp compliance admin-status cdp txrx
·     lldp compliance cdp
1.1.9  lldp compliance cdp
lldp compliance cdp命令用来使能LLDP兼容CDP功能。
undo lldp compliance cdp命令用来恢复缺省情况。
lldp compliance cdp
LLDP兼容CDP功能处于关闭状态。
由于CDP报文所携Time To Live TLV中TTL的最大值为255,而CDP报文的发送间隔由LLDP报文的发送间隔控制,因此为保证LLDP兼容CDP功能的正常运行,建议配置LLDP报文的发送间隔值不大于实际TTL的1/3。
# 使能LLDP兼容CDP功能。
·     lldp hold-multiplier
·     lldp timer tx-interval
1.1.10  lldp enable
lldp enable命令用来在接口上使能LLDP功能。
undo lldp enable命令用来在接口上关闭LLDP功能。
lldp enable
undo lldp enable
接口上的LLDP功能处于使能状态。
只有当全局和接口上都使能了LLDP功能后,该功能才会生效。
# 在接口Ten-GigabitEthernet1/0/1上关闭LLDP功能。
[Sysname-Ten-GigabitEthernet1/0/1] undo lldp enable
·     lldp global enable
1.1.11  lldp encapsulation snap
lldp encapsulation snap命令用来配置LLDP报文的封装格式为SNAP格式。
undo lldp encapsulation命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
LLDP报文的封装格式为Ethernet II格式。
agent:配置指定类型LLDP代理的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的封装格式。
·     LLDP CDP报文的封装格式只能为SNAP格式,不能为Ethernet II格式。
·     携带EVB模块TLV的LLDP报文不能通过SNAP格式封装和发送。
# 配置接口Ten-GigabitEthernet1/0/1上发送的LLDP报文的封装格式为SNAP格式。
[Sysname-Ten-GigabitEthernet1/0/1] lldp encapsulation snap
1.1.12  lldp fast-count
lldp fast-count命令用来配置快速发送LLDP报文的个数。
undo lldp fast-count命令用来恢复缺省情况。
lldp fast-count count
快速发送LLDP报文的个数为4个。
count:表示快速发送LLDP报文的个数,取值范围为1~8,单位为个。
# 配置快速发送LLDP报文的个数为5个。
[Sysname] lldp fast-count 5
1.1.13  lldp global enable
lldp global enable命令用来全局使能LLDP功能。
undo lldp global enable命令用来全局关闭LLDP功能。
lldp global enable
LLDP功能处于全局关闭状态。
# 全局关闭LLDP功能。
[Sysname] undo lldp global enable
·     lldp enable
1.1.14  lldp hold-multiplier
lldp hold-multiplier命令用来配置TTL乘数。
undo lldp hold-multiplier命令用来恢复缺省情况。
lldp hold-multiplier value
TTL乘数为4。
value:表示TTL乘数,取值范围为2~10。
LLDP报文所携Time To Live TLV中TTL的值用来设置邻居信息在本地设备上的老化时间,由于TTL=Min(65535,(TTL乘数×LLDP报文的发送间隔)),即取65535与(TTL乘数×LLDP报文的发送间隔)中的最小值,因此通过调整TTL乘数可以控制本设备信息在邻居设备上的老化时间。
# 配置TTL乘数为6。
1.1.15  lldp management-address-format string
lldp management-address-format string命令用来配置管理地址在TLV中的封装格式为字符串格式。
undo lldp management-address-format命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
管理地址在TLV中的封装格式为数字格式。
agent:配置指定LLDP代理类型管理地址在TLV中的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的管理地址在TLV中的封装格式。
如果邻居将管理地址以字符串格式封装在TLV中,用户可在本地设备上也将封装格式改为字符串,以保证与邻居设备的正常通信。
# 在接口Ten-GigabitEthernet1/0/1的最近客户桥代理上配置管理地址在TLV中的封装格式为字符串格式。
[Sysname-Ten-GigabitEthernet1/0/1] lldp agent nearest-customer management-address-format string
1.1.16  lldp max-credit
lldp max-credit命令用来配置限制发送报文速率的令牌桶大小。
undo lldp max-credit命令用来恢复缺省情况。
lldp max-credit credit-value
限制发送报文速率的令牌桶大小为5。
credit-value:表示LLDP发包限速的令牌桶大小,取值范围1~100。
# 配置LLDP发包限速的令牌桶大小为10。
[Sysname] lldp max-credit 10
1.1.17  lldp mode
lldp mode命令用来配置当前设备的LLDP桥模式。
undo lldp mode命令用来恢复缺省情况。
lldp mode service-bridge
undo lldp mode
设备的LLDP桥模式为客户桥模式。
service-bridge:表示服务桥模式。
LLDP的桥模式命令用于控制设备支持不同的LLDP代理。
·     工作于服务桥模式时,设备可支持最近桥代理和最近非TPMR桥代理,即对上述类型代理MAC的报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
·     工作于客户桥模式时,设备可支持最近桥代理、最近非TPMR桥代理及最近客户桥代理,即对上述类型代理MAC的报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
桥模式配置只在LLDP全局使能后才能生效,LLDP全局未使能时,只能作为客户桥对三种类型代理MAC的报文进行拦截。
# 配置LLDP桥模式为服务桥模式。
[Sysname] lldp mode service-bridge
1.1.18  lldp notification med-topology-change enable
lldp notification med-topology-change enable命令用来使能LLDP-MED Trap功能。
undo lldp notification med-topology-change enable命令用来关闭LLDP-MED Trap功能。
LLDP-MED Trap功能处于关闭状态。
二层以太网接口视图/三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上使能LLDP-MED Trap功能。
[Sysname-Ten-GigabitEthernet1/0/1] lldp notification med-topology-change enable
1.1.19  lldp notification remote-change enable
lldp notification remote-change enable命令用来使能LLDP Trap功能。
undo lldp notification remote-change enable命令用来关闭LLDP Trap功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP Trap功能处于关闭状态。
agent:使能指定类型LLDP代理的LLDP Trap功能。在以太网接口视图下,未指定时表示使能最近桥代理类型LLDP代理的LLDP Trap功能。
# 在接口Ten-GigabitEthernet1/0/1最近客户桥代理上使能LLDP Trap功能。
[Sysname-Ten-GigabitEthernet1/0/1] lldp agent nearest-customer notification remote-change enable
1.1.20  lldp timer fast-interval
lldp timer fast-interval命令用来配置LLDP快速发送报文的时间间隔。
undo lldp timer fast-interval命令用来恢复缺省情况。
LLDP快速发送报文的时间间隔为1秒。
interval:表示LLDP快速发送报文的时间间隔,取值范围为1~3600,单位为秒。
# 配置LLDP快速发送报文的时间间隔为2秒。
[Sysname] lldp timer fast-interval 2
1.1.21  lldp timer notification-interval
lldp timer notification-interval命令用来配置LLDP Trap和LLDP-MED Trap信息的发送间隔。
undo lldp timer notification-interval命令用来恢复缺省情况。
LLDP Trap和LLDP-MED Trap信息的发送间隔均为30秒。
interval:表示LLDP Trap和LLDP-MED Trap信息的发送间隔,取值范围为5~3600,单位为秒。
# 配置LLDP Trap和LLDP-MED Trap信息的发送间隔为8秒。
1.1.22  lldp timer reinit-delay
lldp timer reinit-delay命令用来配置接口初始化的延迟时间。
undo lldp timer reinit-delay命令用来恢复缺省情况。
lldp timer reinit-delay delay
接口初始化的延迟时间为2秒。
delay:接口初始化的延迟时间,取值范围为1~10,单位为秒。
# 配置接口初始化的延迟时间为4秒。
1.1.23  lldp timer tx-interval
lldp timer tx-interval命令用来配置LLDP报文的发送间隔。
undo lldp timer tx-interval命令用来恢复缺省情况。
LLDP报文的发送间隔为30秒。
interval:表示LLDP报文的发送间隔,取值范围为5~32768,单位为秒。
# 配置LLDP报文的发送间隔为20秒。
1.1.24  lldp tlv-enable
lldp tlv-enable命令用来配置接口上允许发布的TLV类型。
undo lldp tlv-enable命令用来配置接口上禁止发布的TLV类型。
在二层以太网接口视图下:
·     配置最近桥代理LLDP接口上允许发布的TLV类型
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation | dcbx | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | port-vlan-id | link-aggregation | dcbx | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy | power-over-ethernet | location-id } }
·     配置最近非TPMR代理LLDP接口上允许发布的TLV类型
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | evb | port-vlan-id | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | evb | port-vlan-id | link-aggregation } }
·     配置最近客户桥代理LLDP接口上允许发布的TLV类型
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | port-vlan-id | link-aggregation } }
在三层以太网接口视图下:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | link-aggregation } }
在二层聚合接口视图下:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | evb | port-vlan-id } }
lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv | port-description | system-capability | system-description | system-name } | dot1-tlv { all | evb | port-vlan-id } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
二层以太网接口上:
·     最近桥代理允许发布除DCBX TLV、 Location-id TLV、Port And Protocol VLAN ID TLV、VLAN Name TLV和Management VLAN ID TLV之外所有类型的TLV;
·     最近非TPMR桥代理只允许发布EVB TLV;
·     最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV。
三层以太网接口上:
·     最近桥代理允许发布除Network Policy TLV之外所有类型的TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV;
·     最近非TPMR桥代理不发布任何TLV;
·     最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV。
二层聚合接口上:
·     不存在最近桥代理;
·     最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV。
agent:配置指定类型LLDP代理允许发布的TLV类型。在以太网接口视图下,未指定时表示配置最近桥代理允许发布的TLV类型。
all:在二层以太网接口视图/二层聚合接口视图/三层以太网接口视图下指定basic-tlv、dot1-tlv或dot3-tlv时,本参数表示该类型下所有的可选TLV;在上述任何视图下指定med-tlv时,本参数都表示该类型下除location-id以外所有的可选TLV。
basic-tlv:表示基本类型TLV。
management-address-tlv [ ip-address ]:表示Management Address TLV。其中,ip-address表示在LLDP报文中所要发布的管理地址,其缺省值在二层以太网接口视图/二层聚合接口视图下配置时若未指定ip-address,则发布的管理地址为该端口允许通过的、对应VLAN接口上配置有IP地址且处于up状态的最小VLAN的主IP地址(如果该端口允许通过的所有VLAN所对应的VLAN接口上都未配置IP地址或均处于down状态,则发布该接口的MAC地址),在三层以太网接口视图下配置时若未指定ip-address,则发布的管理地址为该接口的IP地址(如果该接口未配置IP地址,则发布该接口的MAC地址)。
port-description:表示Port Description TLV。
system-capability:表示System Capabilities TLV。
system-description:表示System Description TLV。
system-name:表示System Name TLV。
dot1-tlv:表示IEEE 802.1组织定义的TLV。
dcbx:表示Data Center Bridging Exchange Protocol TLV。
evb:表示EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV。
port-vlan-id:表示Port VLAN ID TLV。
protocol-vlan-id [ vlan-id ]:表示Port And Protocol VLAN ID TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
vlan-name [ vlan-id ]:表示VLAN Name TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
management-vid [ mvlan-id ]:表示Management VLAN ID TLV。mvlan-id指定要发布管理VLAN的VLAN ID,取值范围为1~4094。如果未指定该参数,则表示发布0,表示当前LLDP agent未配置管理VLAN。
link-aggregation:表示Link Aggregation TLV。
dot3-tlv:表示IEEE 802.3组织定义的TLV。
mac-physic:表示MAC/PHY Configuration/Status TLV。
max-frame-size:表示Maximum Frame Size TLV。
power:表示Power Via MDI TLV和Power Stateful Control TLV。
med-tlv:表示LLDP-MED TLV。
capability:表示LLDP-MED Capabilities TLV。
inventory:表示Hardware Revision TLV、Firmware Revision TLV、Software Revision TLV、Serial Number TLV、Manufacturer Name TLV、Model Name TLV和Asset ID TLV。
location-id:表示Location Identification TLV。
civic-address:表示Location Identification TLV封装网络设备的普通地址信息。
device-type:表示设备类型,取值范围为0~2。0表示设备类型为DHCP server,1表示设备类型为Switch,2表示设备类型为LLDP-MED Endpoint。
country-code:表示国家编码,取值范围请参考ISO 3166。
{ ca-type ca-value }&<1-10>:地址信息。ca-type表示地址信息类型,取值范围为0~255;ca-value表示地址信息,为1~250个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。
elin-address:Location Identification TLV封装紧急电话号码。
tel-number:表示紧急电话号码,为10~25个字符的字符串,只能包含数字。
network-policy:表示Network Policy TLV。
power-over-ethernet:表示Extended Power-via-MDI TLV。
·     在使用本命令时若不指定all参数,每次只能配置某类型下的一种可选TLV,此时可通过多次使用该命令来配置各类型下的多种可选TLV。
·     如果禁止发布802.3的组织定义的MAC/PHY Configuration/Status TLV,则LLDP-MED TLV将不会被发布,不论其是否被允许发布;如果禁止发布LLDP-MED Capabilities TLV,则其它LLDP-MED TLV将不会被发布,不论其是否被允许发布。
·     IEEE 802.1组织定义的TLV的Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV只能基于最近桥代理配置,但是其配置会被最近非TPMR桥代理和最近客户桥代理继承。
# 配置接口Ten-GigabitEthernet1/0/1上最近客户桥代理允许发布IEEE 802.1组织定义的Link Aggregation可选TLV。
[Sysname-Ten-GigabitEthernet1/0/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
