40-附录
本章节下载 (142.28 KB)
本命令索引包括手册中所出现的全部命令,按字母序排列,左边为命令行,右边为该命令所在的功能模块和页码。
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
abr-summary |
IPv4路由 |
3-1 |
abr-summary |
IPv6路由 |
3-1 |
access-limit |
AAA-RADIUS-HWTACACS |
1-1 |
accounting |
QoS |
2-5 |
accounting default |
1-1 |
accounting lan-access |
1-3 |
accounting login |
1-3 |
accounting optional |
1-4 |
accounting-on enable |
1-29 |
accounting-on enable interval |
1-29 |
accounting-on enable send |
1-30 |
acl |
登录以太网交换机 |
2-1 |
acl |
ACL |
1-4 |
acl copy |
ACL |
1-6 |
acl ipv6 |
ACL |
1-22 |
acl ipv6 copy |
ACL |
1-24 |
acl ipv6 name |
ACL |
1-25 |
acl name |
ACL |
1-7 |
activation-key |
登录以太网交换机 |
1-1 |
active region-configuration |
MSTP |
1-1 |
add-member |
集群管理 |
1-16 |
administrator-address |
集群管理 |
1-17 |
aggregate |
IPv4路由 |
5-1 |
aggregation-group |
IPv6配置 |
3-1 |
apply as-path |
IPv4路由 |
6-1 |
apply comm-list delete |
IPv4路由 |
6-2 |
apply community |
IPv4路由 |
6-2 |
apply cost |
IPv4路由 |
6-3 |
apply cost-type |
IPv4路由 |
6-4 |
apply extcommunity |
IPv4路由 |
6-5 |
apply ip-address next-hop |
IPv4路由 |
6-23 |
apply ipv6 next-hop |
IPv6路由 |
6-1 |
apply isis |
IPv4路由 |
6-6 |
apply local-preference |
IPv4路由 |
6-6 |
apply origin |
IPv4路由 |
6-7 |
apply preference |
IPv4路由 |
6-8 |
apply preferred-value |
IPv4路由 |
6-9 |
apply tag |
IPv4路由 |
6-9 |
area |
IPv4路由 |
3-2 |
area |
IPv6路由 |
3-2 |
area-authentication-mode |
IPv4路由 |
4-1 |
arp check enable |
ARP |
1-1 |
arp max-learning-num |
ARP |
1-1 |
arp source-suppression enable |
ARP |
1-9 |
arp source-suppression limit |
ARP |
1-10 |
arp static |
ARP |
1-2 |
arp timer aging |
ARP |
1-3 |
asbr-summary |
IPv4路由 |
3-3 |
ascii |
文件系统管理 |
2-5 |
attribute |
1-5 |
attribute |
PKI |
1-1 |
authentication default |
1-6 |
authentication lan-access |
1-7 |
authentication login |
1-8 |
登录以太网交换机 |
1-2 |
IPv4路由 |
3-4 |
authorization command |
1-9 |
authorization default |
1-10 |
authorization lan-access |
1-11 |
authorization login |
1-12 |
auto-build |
集群管理 |
1-18 |
auto-cost enable |
IPv4路由 |
4-2 |
auto-execute command |
登录以太网交换机 |
1-3 |
auto-rp enable |
组播协议 |
5-1 |
backup startup-configuration |
文件系统管理 |
1-11 |
balance |
IPv4路由 |
5-3 |
balance |
IPv6路由 |
5-1 |
bandwidth-reference |
IPv4路由 |
3-5 |
IPv4路由 |
4-3 |
bestroute as-path-neglect |
IPv4路由 |
5-3 |
IPv6路由 |
5-2 |
bestroute compare-med |
IPv4路由 |
5-4 |
IPv6路由 |
5-2 |
bestroute med-confederation |
IPv4路由 |
5-5 |
IPv6路由 |
5-3 |
bfd authentication-mode |
BFD-GR |
1-1 |
bfd detect-multiplier |
BFD-GR |
1-2 |
bfd echo-source-ip |
BFD-GR |
1-2 |
bfd min-echo-receive-interval |
BFD-GR |
1-3 |
bfd min-receive-interval |
BFD-GR |
1-4 |
bfd min-transmit-interval |
BFD-GR |
1-4 |
bfd session init-mode |
BFD-GR |
1-5 |
bgp |
IPv4路由 |
5-6 |
bims-server |
DHCP |
1-1 |
binary |
文件系统管理 |
2-5 |
black-list add-mac |
集群管理 |
1-19 |
black-list delete-mac |
集群管理 |
1-20 |
bootfile-name |
DHCP |
1-2 |
boot-loader |
系统维护与调试 |
3-1 |
bootrom |
系统维护与调试 |
3-1 |
bpdu-tunnel dot1q enable |
QinQ-BPDU TUNNEL |
2-2 |
bpdu-tunnel dot1q stp |
QinQ-BPDU TUNNEL |
2-1 |
bpdu-tunnel tunnel-dmac |
QinQ-BPDU TUNNEL |
2-3 |
broadcast-suppression |
端口相关配置 |
1-1 |
bsr-policy |
组播协议 |
5-1 |
build |
集群管理 |
1-20 |
burst-traffic |
QoS |
5-1 |
bye |
文件系统管理 |
2-6 |
bye |
SSH |
1-29 |
ca identifier |
PKI |
1-2 |
cache-sa-enable |
组播协议 |
6-1 |
car |
QoS |
2-6 |
car name |
QoS |
6-3 |
c-bsr |
组播协议 |
5-2 |
c-bsr admin-scope |
组播协议 |
5-3 |
c-bsr global |
组播协议 |
5-4 |
c-bsr group |
组播协议 |
5-4 |
c-bsr hash-length |
组播协议 |
5-5 |
c-bsr holdtime |
组播协议 |
5-6 |
c-bsr interval |
组播协议 |
5-6 |
c-bsr priority |
组播协议 |
5-7 |
cd |
文件系统管理 |
1-1 |
cd |
文件系统管理 |
2-6 |
cd |
SSH |
1-29 |
cdup |
文件系统管理 |
2-7 |
cdup |
SSH |
1-30 |
certificate request entity |
PKI |
1-3 |
certificate request from |
PKI |
1-3 |
certificate request mode |
PKI |
1-4 |
certificate request polling |
PKI |
1-5 |
certificate request url |
PKI |
1-5 |
check region-configuration |
MSTP |
1-1 |
checkzero |
IPv4路由 |
2-1 |
checkzero |
IPv6路由 |
2-1 |
ciphersuite |
SSL-HTTPS |
1-1 |
circuit-cost |
IPv4路由 |
4-4 |
classifier behavior |
QoS |
2-16 |
client-verify enable |
SSL-HTTPS |
1-2 |
clock datetime |
系统维护与调试 |
1-1 |
clock summer-time one-off |
系统维护与调试 |
1-2 |
clock summer-time repeating |
系统维护与调试 |
1-3 |
clock timezone |
系统维护与调试 |
1-4 |
close |
文件系统管理 |
2-7 |
close-mode wait |
SSL-HTTPS |
1-2 |
cluster |
集群管理 |
1-21 |
cluster enable |
集群管理 |
1-22 |
cluster switch-to |
集群管理 |
1-23 |
cluster-mac |
集群管理 |
1-24 |
cluster-mac syn-interval |
集群管理 |
1-25 |
command-privilege |
系统维护与调试 |
1-5 |
common-name |
PKI |
1-6 |
compare-different-as-med |
IPv4路由 |
5-7 |
IPv6路由 |
5-4 |
confederation id |
IPv4路由 |
5-7 |
confederation nonstandard |
IPv4路由 |
5-8 |
confederation peer-as |
IPv4路由 |
5-9 |
control-vlan |
RRPP |
1-1 |
copy |
文件系统管理 |
1-2 |
cost-style |
IPv4路由 |
4-5 |
count |
NQA |
1-1 |
country |
PKI |
1-7 |
crl check |
PKI |
1-7 |
crl update-period |
PKI |
1-8 |
crl url |
PKI |
1-9 |
c-rp |
组播协议 |
5-8 |
c-rp advertisement-interval |
组播协议 |
5-9 |
c-rp holdtime |
组播协议 |
5-10 |
crp-policy |
组播协议 |
5-10 |
cut connection |
1-13 |
dampening |
IPv4路由 |
5-10 |
dampening |
IPv6路由 |
5-4 |
databits |
登录以太网交换机 |
1-4 |
datafill |
NQA |
1-1 |
data-flow-format |
1-31 |
data-flow-format |
1-58 |
datasize |
NQA |
1-2 |
debugging |
系统维护与调试 |
2-6 |
default |
IPv4路由 |
3-5 |
default cost |
IPv4路由 |
2-2 |
default cost |
IPv6路由 |
2-2 |
default cost |
IPv6路由 |
3-2 |
default ipv4-unicast |
IPv4路由 |
5-11 |
default local-preference |
IPv4路由 |
5-12 |
IPv6路由 |
5-5 |
default med |
IPv4路由 |
5-13 |
default med |
IPv6路由 |
5-6 |
default-cost |
IPv4路由 |
3-6 |
default-cost |
IPv6路由 |
3-3 |
default-route imported |
IPv4路由 |
5-13 |
IPv6路由 |
5-7 |
default-route originate |
IPv4路由 |
2-2 |
default-route-advertise |
IPv4路由 |
3-7 |
IPv4路由 |
4-6 |
delete |
文件系统管理 |
1-2 |
delete |
文件系统管理 |
2-8 |
delete |
SSH |
1-30 |
delete ipv6 static-routes all |
IPv6路由 |
1-1 |
delete static-routes all |
IPv4路由 |
1-1 |
delete-member |
集群管理 |
1-26 |
description |
VLAN |
1-1 |
description |
端口相关配置 |
1-2 |
description |
IPv4路由 |
3-8 |
description |
NQA |
1-3 |
description |
MCE |
1-1 |
description (for IPv4) |
ACL |
1-7 |
description (for IPv6) |
ACL |
1-26 |
destination |
IPv6配置 |
3-2 |
destination-ip |
NQA |
1-4 |
destination-port |
NQA |
1-4 |
dhcp enable |
DHCP |
1-2 |
dhcp enable |
DHCP |
2-1 |
dhcp relay address-check |
DHCP |
2-2 |
dhcp relay information enable |
DHCP |
2-2 |
dhcp relay information format |
DHCP |
2-3 |
dhcp relay information strategy |
DHCP |
2-4 |
dhcp relay release ip |
DHCP |
2-5 |
dhcp relay security static |
DHCP |
2-5 |
dhcp relay security tracker |
DHCP |
2-6 |
dhcp relay server-detect |
DHCP |
2-7 |
dhcp relay server-group |
DHCP |
2-7 |
dhcp relay server-select |
DHCP |
2-8 |
dhcp select relay |
DHCP |
2-9 |
dhcp select server global-pool |
DHCP |
1-3 |
dhcp server detect |
DHCP |
1-4 |
dhcp server forbidden-ip |
DHCP |
1-4 |
dhcp server ip-pool |
DHCP |
1-5 |
dhcp server ping packets |
DHCP |
1-6 |
dhcp server ping timeout |
DHCP |
1-6 |
dhcp server relay information enable |
DHCP |
1-7 |
dhcp-snooping |
DHCP |
4-1 |
dhcp-snooping information enable |
DHCP |
4-2 |
dhcp-snooping information format |
DHCP |
4-2 |
dhcp-snooping information strategy |
DHCP |
4-3 |
dhcp-snooping trust |
DHCP |
4-4 |
dir |
文件系统管理 |
1-3 |
dir |
文件系统管理 |
2-8 |
dir |
SSH |
1-31 |
disconnect |
文件系统管理 |
2-9 |
display acl |
ACL |
1-8 |
display acl ipv6 |
ACL |
1-26 |
display arp |
ARP |
1-4 |
display arp ip-address |
ARP |
1-5 |
display arp source-suppression |
ARP |
1-10 |
display arp timer aging |
ARP |
1-6 |
display arp vpn-instance |
ARP |
1-6 |
display bfd interface |
BFD-GR |
1-6 |
display bfd paf |
BFD-GR |
1-7 |
display bfd session |
BFD-GR |
1-8 |
display bgp group |
IPv4路由 |
5-14 |
display bgp ipv6 group |
IPv6路由 |
5-8 |
display bgp ipv6 network |
IPv6路由 |
5-9 |
display bgp ipv6 paths |
IPv6路由 |
5-10 |
display bgp ipv6 peer |
IPv6路由 |
5-11 |
display bgp ipv6 routing-table |
IPv6路由 |
5-12 |
display bgp ipv6 routing-table as-path-acl |
IPv6路由 |
5-14 |
display bgp ipv6 routing-table community |
IPv6路由 |
5-15 |
display bgp ipv6 routing-table community-list |
IPv6路由 |
5-16 |
display bgp ipv6 routing-table dampened |
IPv6路由 |
5-17 |
display bgp ipv6 routing-table dampening parameter |
IPv6路由 |
5-18 |
display bgp ipv6 routing-table different-origin-as |
IPv6路由 |
5-18 |
display bgp ipv6 routing-table flap-info |
IPv6路由 |
5-19 |
display bgp ipv6 routing-table peer |
IPv6路由 |
5-20 |
display bgp ipv6 routing-table regular-expression |
IPv6路由 |
5-21 |
display bgp ipv6 routing-table statistic |
IPv6路由 |
5-22 |
display bgp network |
IPv4路由 |
5-16 |
display bgp paths |
IPv4路由 |
5-17 |
display bgp peer |
IPv4路由 |
5-18 |
display bgp routing-table |
IPv4路由 |
5-20 |
display bgp routing-table as-path-acl |
IPv4路由 |
5-22 |
display bgp routing-table cidr |
IPv4路由 |
5-22 |
display bgp routing-table community |
IPv4路由 |
5-23 |
display bgp routing-table community-list |
IPv4路由 |
5-24 |
display bgp routing-table dampened |
IPv4路由 |
5-25 |
display bgp routing-table dampening parameter |
IPv4路由 |
5-26 |
display bgp routing-table different-origin-as |
IPv4路由 |
5-26 |
display bgp routing-table flap-info |
IPv4路由 |
5-27 |
display bgp routing-table peer |
IPv4路由 |
5-28 |
display bgp routing-table regular-expression |
IPv4路由 |
5-29 |
display bgp routing-table statistic |
IPv4路由 |
5-30 |
display bgp vpnv4 route-distinguisher routing-table |
MCE |
1-11 |
display bgp vpnv4 vpn-instance group |
MCE |
1-1 |
display bgp vpnv4 vpn-instance network |
MCE |
1-3 |
display bgp vpnv4 vpn-instance paths |
MCE |
1-4 |
display bgp vpnv4 vpn-instance peer |
MCE |
1-5 |
display bgp vpnv4 vpn-instance routing-table |
MCE |
1-8 |
display bgp vpnv4 vpn-instance routing-table label |
MCE |
1-10 |
display boot-loader |
系统维护与调试 |
3-4 |
display bootp client |
DHCP |
5-1 |
display brief interface |
端口相关配置 |
1-2 |
display burst-traffic interface |
QoS |
5-2 |
display channel |
信息中心 |
1-1 |
display clipboard |
系统维护与调试 |
1-6 |
display clock |
系统维护与调试 |
1-7 |
display cluster |
集群管理 |
1-27 |
display cluster base-topology |
集群管理 |
1-28 |
display cluster black-list |
集群管理 |
1-29 |
display cluster candidates |
集群管理 |
1-30 |
display cluster current-topology |
集群管理 |
1-32 |
display cluster members |
集群管理 |
1-33 |
display connection |
1-14 |
display cpu-usage |
系统维护与调试 |
3-2 |
display current-configuration |
系统维护与调试 |
1-8 |
display debugging |
系统维护与调试 |
2-7 |
display debugging ospfv3 |
IPv6路由 |
3-4 |
display device |
系统维护与调试 |
3-5 |
display device manuinfo |
系统维护与调试 |
3-6 |
display dhcp client |
DHCP |
3-1 |
display dhcp relay |
DHCP |
2-9 |
display dhcp relay security |
DHCP |
2-10 |
display dhcp relay security statistics |
DHCP |
2-11 |
display dhcp relay security tracker |
DHCP |
2-12 |
display dhcp relay server-group |
DHCP |
2-12 |
display dhcp relay statistics |
DHCP |
2-13 |
display dhcp server conflict |
DHCP |
1-8 |
display dhcp server expired |
DHCP |
1-8 |
display dhcp server forbidden-ip |
DHCP |
1-10 |
display dhcp server free-ip |
DHCP |
1-9 |
display dhcp server ip-in-use |
DHCP |
1-10 |
display dhcp server statistics |
DHCP |
1-12 |
display dhcp server tree |
DHCP |
1-13 |
display dhcp-snooping |
DHCP |
4-5 |
display dhcp-snooping trust |
DHCP |
4-6 |
display diagnostic-information |
系统维护与调试 |
1-9 |
display dldp |
DLDP |
1-1 |
display dldp statistics |
DLDP |
1-3 |
display dns domain |
域名解析 |
1-1 |
display dns dynamic-host |
域名解析 |
1-2 |
display dns ipv6 dynamic-host |
IPv6配置 |
1-1 |
display dns ipv6 server |
IPv6配置 |
1-2 |
display dns server |
域名解析 |
1-3 |
display domain |
1-16 |
display dot1x |
802.1x-HABP-MAC地址认证 |
1-1 |
display environment |
系统维护与调试 |
3-6 |
display fan |
系统维护与调试 |
3-7 |
display fib |
IP地址-IP性能 |
2-1 |
display fib ip-address |
IP地址-IP性能 |
2-3 |
display fib statistics |
IP地址-IP性能 |
2-4 |
display fib vpn-instance |
IP地址-IP性能 |
2-5 |
display flow-template interface |
ACL |
1-37 |
display flow-template user-defined |
ACL |
1-36 |
display ftp client configuration |
文件系统管理 |
2-10 |
display ftp-server |
文件系统管理 |
2-1 |
display ftp-user |
文件系统管理 |
2-1 |
display garp statistics |
VLAN |
3-1 |
display garp timer |
VLAN |
3-2 |
display gvrp local-vlan interface |
VLAN |
3-6 |
display gvrp state |
VLAN |
3-7 |
display gvrp statistics |
VLAN |
3-7 |
display gvrp status |
VLAN |
3-9 |
display gvrp vlan-operation interface |
VLAN |
3-9 |
display habp |
2-1 |
display habp table |
2-1 |
display habp traffic |
2-2 |
display history-command |
系统维护与调试 |
1-10 |
display hotkey |
系统维护与调试 |
1-11 |
display hwtacacs |
1-59 |
display icmp statistics |
IP地址-IP性能 |
2-6 |
display igmp group |
组播协议 |
4-1 |
display igmp group port-info |
组播协议 |
4-2 |
display igmp interface |
组播协议 |
4-4 |
display igmp routing-table |
组播协议 |
4-6 |
display igmp-snooping group |
组播协议 |
1-1 |
display igmp-snooping statistics |
组播协议 |
1-2 |
display info-center |
信息中心 |
1-2 |
display interface |
端口相关配置 |
1-5 |
display interface tunnel |
IPv6配置 |
3-3 |
display interface Vlan-interface |
VLAN |
1-2 |
display ip as-path |
IPv4路由 |
6-10 |
display ip check source |
IP Source Guard |
1-1 |
display ip community-list |
IPv4路由 |
6-11 |
display ip extcommunity-list |
IPv4路由 |
6-11 |
display ip host |
域名解析 |
1-4 |
display ip https |
SSL-HTTPS |
2-1 |
display ip interface |
IP地址-IP性能 |
1-1 |
display ip interface brief |
IP地址-IP性能 |
1-3 |
display ip ip-prefix |
IPv4路由 |
6-23 |
display ip ipv6-prefix |
IPv6路由 |
6-2 |
display ip routing-table |
路由概述 |
1-1 |
display ip routing-table acl |
路由概述 |
1-4 |
display ip routing-table ip-address |
路由概述 |
1-7 |
display ip routing-table ip-prefix |
路由概述 |
1-10 |
display ip routing-table protocol |
路由概述 |
1-12 |
display ip routing-table statistics |
路由概述 |
1-13 |
display ip routing-table vpn-instance |
MCE |
1-12 |
display ip socket |
IP地址-IP性能 |
2-7 |
display ip statistics |
IP地址-IP性能 |
2-9 |
display ip vpn-instance |
MCE |
1-13 |
display ip-subnet-vlan interface |
VLAN |
1-19 |
display ip-subnet-vlan vlan |
VLAN |
1-20 |
display ipv6 fib |
IPv6配置 |
1-2 |
display ipv6 fibcache |
IPv6配置 |
1-4 |
display ipv6 host |
IPv6配置 |
1-4 |
display ipv6 interface |
IPv6配置 |
1-5 |
display ipv6 interface tunnel |
IPv6配置 |
3-4 |
display ipv6 neighbors |
IPv6配置 |
1-7 |
display ipv6 neighbors count |
IPv6配置 |
1-8 |
display ipv6 pathmtu |
IPv6配置 |
1-9 |
display ipv6 routing-table |
路由概述 |
1-14 |
display ipv6 routing-table acl |
路由概述 |
1-15 |
display ipv6 routing-table ipv6-address |
路由概述 |
1-16 |
display ipv6 routing-table ipv6-address1 ipv6-address2 |
路由概述 |
1-17 |
display ipv6 routing-table ipv6-prefix |
路由概述 |
1-18 |
display ipv6 routing-table protocol |
路由概述 |
1-19 |
display ipv6 routing-table statistics |
路由概述 |
1-20 |
display ipv6 routing-table verbose |
路由概述 |
1-21 |
display ipv6 socket |
IPv6配置 |
1-10 |
display ipv6 statistics |
IPv6配置 |
1-11 |
display isis brief |
IPv4路由 |
4-7 |
display isis graceful-restart status |
IPv4路由 |
4-8 |
display isis interface |
IPv4路由 |
4-10 |
display isis license |
IPv4路由 |
4-12 |
display isis lsdb |
IPv4路由 |
4-14 |
display isis mesh-group |
IPv4路由 |
4-15 |
display isis name-table |
IPv4路由 |
4-16 |
display isis peer |
IPv4路由 |
4-17 |
display isis route |
IPv4路由 |
4-18 |
display isis route ipv6 |
IPv6路由 |
4-1 |
display isis spf-log |
IPv4路由 |
4-20 |
display isis statistics |
IPv4路由 |
4-21 |
display lacp system-id |
链路聚合 |
1-1 |
display link-aggregation interface |
链路聚合 |
1-1 |
display link-aggregation service-type |
链路聚合 |
1-3 |
display link-aggregation summary |
链路聚合 |
1-4 |
display link-aggregation verbose |
链路聚合 |
1-5 |
display local-proxy-arp |
ARP |
2-3 |
display local-user |
1-17 |
display logbuffer |
信息中心 |
1-4 |
display logbuffer summary |
信息中心 |
1-7 |
display loopback-detection |
端口相关配置 |
1-7 |
display mac-address |
MAC地址表管理 |
1-1 |
display mac-address aging-time |
MAC地址表管理 |
1-2 |
display mac-authentication |
3-1 |
display memory |
系统维护与调试 |
3-8 |
display mirroring-group |
端口镜像 |
1-1 |
display mld-snooping group |
组播协议 |
2-1 |
display mld-snooping statistics |
组播协议 |
2-2 |
display msdp brief |
组播协议 |
6-1 |
display msdp peer-status |
组播协议 |
6-3 |
display msdp sa-cache |
组播协议 |
6-5 |
display msdp sa-count |
组播协议 |
6-6 |
display multicast boundary |
组播协议 |
7-1 |
display multicast forwarding-table |
组播协议 |
7-2 |
display multicast routing-table |
组播协议 |
7-4 |
display multicast routing-table static |
组播协议 |
7-5 |
display multicast rpf-info |
组播协议 |
7-7 |
display multicast-vlan |
组播协议 |
3-1 |
display ndp |
集群管理 |
1-1 |
display nqa |
NQA |
1-5 |
display ntdp |
集群管理 |
1-8 |
display ntdp device-list |
集群管理 |
1-9 |
display ntdp single-device mac-address |
集群管理 |
1-11 |
display ntp-service sessions |
NTP |
1-1 |
display ntp-service status |
NTP |
1-2 |
display ntp-service trace |
NTP |
1-4 |
display oam |
OAM |
1-1 |
display oam configuration |
OAM |
1-5 |
display oam critical-event |
OAM |
1-7 |
display oam link-event |
OAM |
1-8 |
display ospf abr-asbr |
IPv4路由 |
3-9 |
display ospf asbr-summary |
IPv4路由 |
3-10 |
display ospf brief |
IPv4路由 |
3-11 |
display ospf cumulative |
IPv4路由 |
3-14 |
display ospf error |
IPv4路由 |
3-16 |
display ospf interface |
IPv4路由 |
3-18 |
display ospf lsdb |
IPv4路由 |
3-19 |
display ospf nexthop |
IPv4路由 |
3-21 |
display ospf peer |
IPv4路由 |
3-22 |
display ospf peer statistics |
IPv4路由 |
3-25 |
display ospf request-queue |
IPv4路由 |
3-26 |
display ospf retrans-queue |
IPv4路由 |
3-27 |
display ospf routing |
IPv4路由 |
3-28 |
display ospf vlink |
IPv4路由 |
3-30 |
display ospfv3 |
IPv6路由 |
3-4 |
display ospfv3 interface |
IPv6路由 |
3-6 |
display ospfv3 lsdb |
IPv6路由 |
3-8 |
display ospfv3 lsdb statistic |
IPv6路由 |
3-11 |
display ospfv3 next-hop |
IPv6路由 |
3-12 |
display ospfv3 peer |
IPv6路由 |
3-13 |
display ospfv3 peer statistic |
IPv6路由 |
3-15 |
display ospfv3 request-list |
IPv6路由 |
3-16 |
display ospfv3 retrans-list |
IPv6路由 |
3-17 |
display ospfv3 routing |
IPv6路由 |
3-19 |
display ospfv3 statistic |
IPv6路由 |
3-20 |
display ospfv3 topology |
IPv6路由 |
3-21 |
display ospfv3 vlink |
IPv6路由 |
3-22 |
display pim bsr-info |
组播协议 |
5-11 |
display pim claimed-route |
组播协议 |
5-13 |
display pim control-message counters |
组播协议 |
5-14 |
display pim grafts |
组播协议 |
5-16 |
display pim interface |
组播协议 |
5-16 |
display pim join-prune |
组播协议 |
5-19 |
display pim neighbor |
组播协议 |
5-20 |
display pim routing-table |
组播协议 |
5-22 |
display pim rp-info |
组播协议 |
5-24 |
display pki certificate |
PKI |
1-9 |
display pki certificate access-control-policy |
PKI |
1-11 |
display pki certificate attribute-group |
PKI |
1-12 |
display pki crl domain |
PKI |
1-13 |
display port |
端口相关配置 |
1-8 |
display port combo |
端口相关配置 |
1-9 |
display port-group manual |
端口相关配置 |
1-10 |
display port-isolate group |
端口相关配置 |
2-1 |
display power |
系统维护与调试 |
3-9 |
display protocol-vlan interface |
VLAN |
1-14 |
display protocol-vlan vlan |
VLAN |
1-15 |
display proxy-arp |
ARP |
2-2 |
display public-key local |
SSH |
1-1 |
display public-key peer |
SSH |
1-2 |
display qos car interface |
QoS |
1-1 |
display qos car name |
QoS |
6-3 |
display qos gts interface |
QoS |
1-3 |
display qos map-table |
QoS |
4-1 |
display qos policy |
QoS |
2-17 |
display qos policy interface |
QoS |
2-18 |
display qos trust interface |
QoS |
4-4 |
display qos vlan-policy |
QoS |
7-1 |
display qos wred interface |
QoS |
5-2 |
display qos wrr interface |
QoS |
3-1 |
display radius scheme |
1-32 |
display radius statistics |
1-34 |
display reboot-type |
系统维护与调试 |
3-9 |
display rip |
IPv4路由 |
2-3 |
display rip database |
IPv4路由 |
2-5 |
display rip interface |
IPv4路由 |
2-6 |
display rip route |
IPv4路由 |
2-7 |
display ripng |
IPv6路由 |
2-2 |
display ripng database |
IPv6路由 |
2-3 |
display ripng interface |
IPv6路由 |
2-5 |
display ripng route |
IPv6路由 |
2-6 |
display rmon alarm |
SNMP-RMON |
2-1 |
display rmon event |
SNMP-RMON |
2-2 |
display rmon eventlog |
SNMP-RMON |
2-3 |
display rmon history |
SNMP-RMON |
2-4 |
display rmon prialarm |
SNMP-RMON |
2-5 |
display rmon statistics |
SNMP-RMON |
2-7 |
display route-policy |
IPv4路由 |
6-12 |
display rrpp brief |
RRPP |
1-2 |
display rrpp statistics |
RRPP |
1-3 |
display rrpp verbose |
RRPP |
1-6 |
display saved-configuration |
文件系统管理 |
1-12 |
display schedule reboot |
系统维护与调试 |
3-10 |
display sftp client source |
SSH |
1-3 |
display snmp-agent community |
SNMP-RMON |
1-1 |
display snmp-agent group |
SNMP-RMON |
1-2 |
display snmp-agent local-engineid |
SNMP-RMON |
1-3 |
display snmp-agent mib-view |
SNMP-RMON |
1-3 |
display snmp-agent statistics |
SNMP-RMON |
1-5 |
display snmp-agent sys-info |
SNMP-RMON |
1-7 |
display snmp-agent trap-list |
SNMP-RMON |
1-7 |
display snmp-agent usm-user |
SNMP-RMON |
1-8 |
display ssh client source |
SSH |
1-4 |
display ssh server |
SSH |
1-5 |
display ssh server-info |
SSH |
1-6 |
display ssh user-information |
SSH |
1-7 |
display ssl client-policy |
SSL-HTTPS |
1-3 |
display ssl server-policy |
SSL-HTTPS |
1-4 |
display startup |
文件系统管理 |
1-15 |
display stop-accounting-buffer |
1-37 |
1-61 |
display stp |
MSTP |
1-3 |
display stp abnormal-port |
MSTP |
1-5 |
display stp down-port |
MSTP |
1-6 |
display stp history |
MSTP |
1-7 |
display stp region-configuration |
MSTP |
1-8 |
display stp root |
MSTP |
1-9 |
display stp tc |
MSTP |
1-9 |
display switch-mode |
IPv6配置 |
2-1 |
display tcp ipv6 statistics |
IPv6配置 |
1-14 |
display tcp ipv6 status |
IPv6配置 |
1-17 |
display tcp statistics |
IP地址-IP性能 |
2-11 |
display tcp status |
IP地址-IP性能 |
2-13 |
display telnet client configuration |
登录以太网交换机 |
1-5 |
display tftp client configuration |
文件系统管理 |
3-1 |
display this |
系统维护与调试 |
1-12 |
display time-range |
ACL |
1-1 |
display traffic behavior |
QoS |
2-7 |
display traffic classifier |
QoS |
2-1 |
display transceiver alarm interface |
系统维护与调试 |
3-10 |
display transceiver diagnosis interface |
系统维护与调试 |
3-13 |
display transceiver interface |
系统维护与调试 |
3-14 |
display transceiver manuinfo interface |
系统维护与调试 |
3-16 |
display trapbuffer |
信息中心 |
1-7 |
display udp ipv6 statistics |
IPv6配置 |
1-17 |
display udp statistics |
IP地址-IP性能 |
2-14 |
display udp-helper server |
UDP Helper |
1-1 |
display user-bind |
IP Source Guard |
1-2 |
display user-interface |
登录以太网交换机 |
1-6 |
display users |
登录以太网交换机 |
1-7 |
display version |
系统维护与调试 |
1-13 |
display vlan |
VLAN |
1-3 |
display voice vlan oui |
VLAN |
2-1 |
display voice vlan state |
VLAN |
2-2 |
display vrrp |
VRRP |
1-1 |
display vrrp ipv6 |
VRRP |
1-13 |
display vrrp ipv6 statistics |
VRRP |
1-15 |
display vrrp statistics |
VRRP |
1-3 |
display web users |
登录以太网交换机 |
1-8 |
dldp authentication-mode |
DLDP |
1-4 |
dldp delaydown-timer |
DLDP |
1-5 |
dldp enable |
DLDP |
1-6 |
dldp interval |
DLDP |
1-7 |
dldp reset |
DLDP |
1-8 |
dldp unidirectional-shutdown |
DLDP |
1-9 |
dldp work-mode |
DLDP |
1-9 |
dns domain |
域名解析 |
1-4 |
dns resolve |
域名解析 |
1-5 |
dns server |
域名解析 |
1-6 |
dns server ipv6 |
IPv6配置 |
1-18 |
dns-list |
DHCP |
1-14 |
domain |
1-19 |
domain default |
1-20 |
domain-authentication-mode |
IPv4路由 |
4-24 |
domain-id |
MCE |
1-14 |
domain-name |
DHCP |
1-15 |
dot1x |
1-4 |
dot1x authentication-method |
1-5 |
dot1x guest-vlan |
1-7 |
dot1x handshake |
1-8 |
dot1x max-user |
1-9 |
dot1x multicast-trigger |
1-10 |
dot1x port-control |
1-11 |
dot1x port-method |
1-12 |
dot1x quiet-period |
1-13 |
dot1x retry |
1-14 |
dot1x supp-proxy-check |
1-15 |
dot1x timer |
1-16 |
duplex |
端口相关配置 |
1-11 |
ebgp-interface-sensitive |
IPv4路由 |
5-31 |
enable link-local-signaling |
IPv4路由 |
3-31 |
enable log |
IPv4路由 |
3-32 |
enable out-of-band-resynchronization |
IPv4路由 |
3-32 |
enable snmp trap updown |
SNMP-RMON |
1-9 |
encap-data-enable |
组播协议 |
6-7 |
escape-key |
登录以太网交换机 |
1-9 |
execute |
文件系统管理 |
1-4 |
exit |
SSH |
1-32 |
expediting enable |
IPv6配置 |
3-6 |
expediting subnet |
IPv6配置 |
3-6 |
expired |
DHCP |
1-16 |
export route-policy |
MCE |
1-15 |
fast-leave |
组播协议 |
1-3 |
fast-leave |
组播协议 |
2-3 |
fast-leave |
组播协议 |
4-7 |
file prompt |
文件系统管理 |
1-5 |
filename |
NQA |
1-9 |
filter |
IPv4路由 |
3-33 |
filter |
QoS |
2-8 |
filter-policy export |
IPv4路由 |
2-9 |
IPv4路由 |
3-34 |
IPv4路由 |
4-25 |
IPv4路由 |
5-31 |
IPv6路由 |
2-7 |
IPv6路由 |
3-24 |
IPv6路由 |
5-23 |
MCE |
1-16 |
filter-policy import |
IPv4路由 |
2-10 |
IPv4路由 |
3-35 |
IPv4路由 |
4-26 |
IPv4路由 |
5-33 |
IPv6路由 |
2-8 |
IPv6路由 |
3-25 |
IPv6路由 |
5-24 |
MCE |
1-17 |
fixdisk |
文件系统管理 |
1-5 |
flash-flood |
IPv4路由 |
4-27 |
flow-control |
登录以太网交换机 |
1-10 |
flow-control |
端口相关配置 |
1-12 |
flow-interval |
端口相关配置 |
1-13 |
flow-template |
ACL |
1-38 |
flow-template basic |
ACL |
1-39 |
flow-template extend |
ACL |
1-42 |
format |
文件系统管理 |
1-6 |
fqdn |
PKI |
1-14 |
free ftp user |
文件系统管理 |
2-2 |
free user-interface |
登录以太网交换机 |
1-11 |
free web-users |
登录以太网交换机 |
2-2 |
frequency |
NQA |
1-10 |
ftp |
文件系统管理 |
2-10 |
ftp client source |
文件系统管理 |
2-12 |
ftp ipv6 |
文件系统管理 |
2-13 |
ftp server enable |
文件系统管理 |
2-3 |
ftp timeout |
文件系统管理 |
2-3 |
ftp update |
文件系统管理 |
2-4 |
ftp-operation |
NQA |
1-10 |
ftp-server |
集群管理 |
1-35 |
garp timer |
VLAN |
3-3 |
garp timer leaveall |
VLAN |
3-4 |
gateway-list |
DHCP |
1-16 |
get |
文件系统管理 |
2-14 |
get |
SSH |
1-32 |
graceful-restart |
IPv4路由 |
3-35 |
graceful-restart |
IPv4路由 |
4-28 |
graceful-restart (BGP view) |
IPv4路由 |
5-33 |
graceful-restart help |
IPv4路由 |
3-37 |
graceful-restart interval |
IPv4路由 |
3-37 |
IPv4路由 |
4-28 |
graceful-restart suppress-sa |
IPv4路由 |
4-29 |
graceful-restart timer restart |
IPv4路由 |
5-34 |
graceful-restart timer wait-for-rib |
IPv4路由 |
5-35 |
gratuitous-arp-learning enable |
ARP |
1-9 |
gratuitous-arp-sending enable |
ARP |
1-8 |
group |
IPv4路由 |
5-35 |
group |
IPv6路由 |
5-24 |
group-member |
端口相关配置 |
1-13 |
group-policy |
组播协议 |
1-4 |
group-policy |
组播协议 |
2-4 |
gvrp |
VLAN |
3-10 |
gvrp registration |
VLAN |
3-11 |
habp enable |
2-3 |
habp server vlan |
2-4 |
habp timer |
2-4 |
handshake timeout |
SSL-HTTPS |
1-5 |
header |
系统维护与调试 |
1-14 |
hello-option dr-priority |
组播协议 |
5-25 |
hello-option holdtime |
组播协议 |
5-26 |
hello-option lan-delay |
组播协议 |
5-27 |
hello-option neighbor-tracking |
组播协议 |
5-27 |
hello-option override-interval |
组播协议 |
5-28 |
help |
SSH |
1-33 |
history-command max-size |
登录以太网交换机 |
1-12 |
history-records |
NQA |
1-11 |
holdtime |
集群管理 |
1-36 |
holdtime assert |
组播协议 |
5-29 |
holdtime join-prune |
组播协议 |
5-29 |
host-advertise |
IPv4路由 |
3-38 |
host-aging-time |
组播协议 |
1-5 |
host-aging-time |
组播协议 |
2-5 |
host-route |
IPv4路由 |
2-11 |
hotkey |
系统维护与调试 |
1-16 |
http-operation |
NQA |
1-12 |
http-string |
NQA |
1-12 |
hwtacacs nas-ip |
1-61 |
hwtacacs scheme |
1-62 |
idle-cut |
1-20 |
idle-timeout |
登录以太网交换机 |
1-13 |
if-match |
QoS |
2-2 |
if-match acl |
IPv4路由 |
6-24 |
if-match as-path |
IPv4路由 |
6-13 |
if-match community |
IPv4路由 |
6-14 |
if-match cost |
IPv4路由 |
6-15 |
if-match extcommunity |
IPv4路由 |
6-15 |
if-match interface |
IPv4路由 |
6-16 |
if-match ip |
IPv4路由 |
6-25 |
if-match ip-prefix |
IPv4路由 |
6-26 |
if-match ipv6 |
IPv6路由 |
6-3 |
if-match route-type |
IPv4路由 |
6-17 |
if-match tag |
IPv4路由 |
6-18 |
igmp |
组播协议 |
4-8 |
igmp enable |
组播协议 |
4-8 |
igmp fast-leave |
组播协议 |
4-9 |
igmp group-policy |
组播协议 |
4-10 |
igmp last-member-query-interval |
组播协议 |
4-11 |
igmp max-response-time |
组播协议 |
4-12 |
igmp require-router-alert |
组播协议 |
4-12 |
igmp robust-count |
组播协议 |
4-13 |
igmp send-router-alert |
组播协议 |
4-14 |
igmp static-group |
组播协议 |
4-14 |
igmp timer other-querier-present |
组播协议 |
4-15 |
igmp timer query |
组播协议 |
4-16 |
igmp version |
组播协议 |
4-17 |
igmp-snooping |
组播协议 |
1-6 |
igmp-snooping drop-unknown |
组播协议 |
1-7 |
igmp-snooping enable |
组播协议 |
1-7 |
igmp-snooping fast-leave |
组播协议 |
1-8 |
igmp-snooping general-query source-ip |
组播协议 |
1-9 |
igmp-snooping group-limit |
组播协议 |
1-10 |
igmp-snooping group-policy |
组播协议 |
1-11 |
igmp-snooping host-aging-time |
组播协议 |
1-12 |
igmp-snooping host-join |
组播协议 |
1-13 |
igmp-snooping last-member-query-interval |
组播协议 |
1-14 |
igmp-snooping max-response-time |
组播协议 |
1-15 |
igmp-snooping overflow-replace |
组播协议 |
1-15 |
igmp-snooping querier |
组播协议 |
1-16 |
igmp-snooping query-interval |
组播协议 |
1-17 |
igmp-snooping router-aging-time |
组播协议 |
1-18 |
igmp-snooping special-query source-ip |
组播协议 |
1-18 |
igmp-snooping static-group |
组播协议 |
1-19 |
igmp-snooping static-router-port |
组播协议 |
1-20 |
igmp-snooping version |
组播协议 |
1-21 |
import |
QoS |
4-3 |
import route-policy |
MCE |
1-17 |
import-route |
IPv4路由 |
2-12 |
import-route |
IPv4路由 |
3-39 |
import-route |
IPv4路由 |
4-30 |
import-route |
IPv4路由 |
5-36 |
import-route |
IPv6路由 |
2-9 |
import-route |
IPv6路由 |
3-26 |
import-route |
IPv6路由 |
5-25 |
import-route isis level-2 into level-1 |
IPv4路由 |
4-31 |
import-source |
组播协议 |
6-8 |
info-center channel name |
信息中心 |
1-9 |
info-center console channel |
信息中心 |
1-9 |
info-center enable |
信息中心 |
1-10 |
info-center logbuffer |
信息中心 |
1-11 |
info-center loghost |
信息中心 |
1-11 |
info-center loghost source |
信息中心 |
1-12 |
info-center monitor channel |
信息中心 |
1-13 |
info-center snmp channel |
信息中心 |
1-14 |
info-center source |
信息中心 |
1-15 |
info-center synchronous |
信息中心 |
1-16 |
info-center timestamp |
信息中心 |
1-17 |
info-center timestamp loghost |
信息中心 |
1-18 |
info-center trapbuffer |
信息中心 |
1-19 |
instance |
MSTP |
1-10 |
interface |
端口相关配置 |
1-14 |
interface tunnel |
IPv6配置 |
3-7 |
VLAN |
1-4 |
ip (Pki Entity view) |
PKI |
1-15 |
ip address |
VLAN |
1-5 |
ip address |
IP地址-IP性能 |
1-4 |
ip address bootp-alloc |
DHCP |
5-2 |
ip address dhcp-alloc |
DHCP |
3-3 |
ip as-path |
IPv4路由 |
6-18 |
ip binding vpn-instance |
MCE |
1-18 |
ip check source |
IP Source Guard |
1-3 |
ip community-list |
IPv4路由 |
6-20 |
IPv4路由 |
6-21 |
ip forward-broadcast (Interface view) |
IP地址-IP性能 |
2-15 |
ip forward-broadcast (System view) |
IP地址-IP性能 |
2-16 |
ip host |
域名解析 |
1-6 |
ip http acl |
登录以太网交换机 |
2-2 |
ip http enable |
登录以太网交换机 |
1-13 |
ip https acl |
SSL-HTTPS |
2-2 |
ip https certificate access-control-policy |
SSL-HTTPS |
2-2 |
ip https enable |
SSL-HTTPS |
2-3 |
ip https ssl-server-policy |
SSL-HTTPS |
2-4 |
ip ip-prefix |
IPv4路由 |
6-27 |
ip ipv6-prefix |
IPv6路由 |
6-4 |
ip redirects enable |
IP地址-IP性能 |
2-16 |
ip route-static |
IPv4路由 |
1-2 |
ip route-static default-preference |
IPv4路由 |
1-4 |
ip rpf-route-static |
组播协议 |
7-8 |
ip ttl-expires enable |
IP地址-IP性能 |
2-17 |
ip unreachables enable |
IP地址-IP性能 |
2-18 |
ip vpn-instance |
MCE |
1-19 |
ip-pool |
集群管理 |
1-37 |
ip-subnet-vlan |
VLAN |
1-21 |
ipv4-family vpn-instance |
MCE |
1-19 |
ipv6 |
IPv6配置 |
1-19 |
ipv6 |
IPv6配置 |
2-1 |
ipv6 address |
IPv6配置 |
1-20 |
ipv6 address |
IPv6配置 |
2-2 |
ipv6 address auto link-local |
IPv6配置 |
1-20 |
IPv6配置 |
2-2 |
ipv6 address eui-64 |
IPv6配置 |
1-21 |
IPv6配置 |
2-3 |
ipv6 address link-local |
IPv6配置 |
1-22 |
IPv6配置 |
2-4 |
ipv6 default-route-advertise |
IPv6路由 |
4-4 |
ipv6 enable |
IPv6路由 |
4-5 |
ipv6 fibcache |
IPv6配置 |
1-22 |
ipv6 fib-loadbalance-type hash-based |
IPv6配置 |
1-23 |
ipv6 filter-policy export |
IPv6路由 |
4-5 |
ipv6 filter-policy import |
IPv6路由 |
4-6 |
ipv6 host |
IPv6配置 |
1-23 |
ipv6 icmp-error |
IPv6配置 |
1-24 |
ipv6 icmpv6 multicast-echo-reply enable |
IPv6配置 |
1-25 |
ipv6 import-route |
IPv6路由 |
4-7 |
ipv6 import-route isisv6 level-2 into level-1 |
IPv6路由 |
4-8 |
ipv6 maximum load-balancing |
IPv6路由 |
4-9 |
ipv6 nd autoconfig managed-address-flag |
IPv6配置 |
1-25 |
ipv6 nd autoconfig other-flag |
IPv6配置 |
1-26 |
ipv6 nd dad attempts |
IPv6配置 |
1-26 |
ipv6 nd hop-limit |
IPv6配置 |
1-27 |
ipv6 nd ns retrans-timer |
IPv6配置 |
1-28 |
ipv6 nd nud reachable-time |
IPv6配置 |
1-28 |
ipv6 nd ra halt |
IPv6配置 |
1-29 |
ipv6 nd ra interval |
IPv6配置 |
1-30 |
ipv6 nd ra prefix |
IPv6配置 |
1-30 |
ipv6 nd ra router-lifetime |
IPv6配置 |
1-31 |
ipv6 neighbor |
IPv6配置 |
1-32 |
ipv6 neighbors max-learning-num |
IPv6配置 |
1-33 |
ipv6 pathmtu |
IPv6配置 |
1-34 |
ipv6 pathmtu age |
IPv6配置 |
1-34 |
ipv6 preference |
IPv6路由 |
4-10 |
ipv6 route-static |
IPv6路由 |
1-2 |
ipv6 summary |
IPv6路由 |
4-11 |
ipv6-family |
IPv6路由 |
5-26 |
isis |
IPv4路由 |
4-32 |
isis authentication-mode |
IPv4路由 |
4-33 |
isis circuit-level |
IPv4路由 |
4-34 |
isis circuit-type |
IPv4路由 |
4-35 |
isis cost |
IPv4路由 |
4-36 |
isis dis-name |
IPv4路由 |
4-37 |
isis dis-priority |
IPv4路由 |
4-37 |
isis enable |
IPv4路由 |
4-38 |
isis ipv6 enable |
IPv6路由 |
4-12 |
isis mesh-group |
IPv4路由 |
4-39 |
isis silent |
IPv4路由 |
4-40 |
isis small-hello |
IPv4路由 |
4-41 |
isis timer csnp |
IPv4路由 |
4-41 |
isis timer hello |
IPv4路由 |
4-42 |
isis timer holding-multiplier |
IPv4路由 |
4-43 |
isis timer lsp |
IPv4路由 |
4-44 |
isis timer retransmit |
IPv4路由 |
4-45 |
is-level |
IPv4路由 |
4-46 |
is-name |
IPv4路由 |
4-46 |
is-name map |
IPv4路由 |
4-47 |
is-snmp-traps enable |
IPv4路由 |
4-48 |
jitter-interval |
NQA |
1-15 |
jitter-packetnum |
NQA |
1-15 |
jp-pkt-size |
组播协议 |
5-30 |
jp-queue-size |
组播协议 |
5-31 |
jumboframe enable |
端口相关配置 |
1-14 |
key |
1-38 |
key |
1-63 |
lacp port-priority |
链路聚合 |
1-7 |
lacp system-priority |
链路聚合 |
1-7 |
last-listener-query-interval |
组播协议 |
2-6 |
组播协议 |
1-22 |
组播协议 |
4-17 |
lcd |
文件系统管理 |
2-14 |
ldap-server |
PKI |
1-15 |
level |
1-21 |
link-aggregation group description |
链路聚合 |
1-8 |
link-aggregation group mode |
链路聚合 |
1-9 |
link-aggregation group service-type |
链路聚合 |
1-9 |
locality |
PKI |
1-16 |
local-proxy-arp enable |
ARP |
2-1 |
local-user |
1-22 |
local-user password-display-mode |
1-23 |
lock |
登录以太网交换机 |
1-14 |
logging-host |
集群管理 |
1-38 |
log-peer-change |
IPv4路由 |
3-40 |
log-peer-change |
IPv4路由 |
4-48 |
log-peer-change |
IPv4路由 |
5-37 |
log-peer-change |
IPv6路由 |
3-27 |
loopback |
端口相关配置 |
1-15 |
loopback-detection control enable |
端口相关配置 |
1-16 |
loopback-detection enable |
端口相关配置 |
1-17 |
loopback-detection interval-time |
端口相关配置 |
1-18 |
loopback-detection per-vlan enable |
端口相关配置 |
1-18 |
ls |
文件系统管理 |
2-15 |
ls |
SSH |
1-34 |
lsa-arrival-interval |
IPv4路由 |
3-41 |
lsa-generation-interval |
IPv4路由 |
3-41 |
lsdb-overflow-limit |
IPv4路由 |
3-42 |
lsp-fragments-extend |
IPv4路由 |
4-49 |
lsp-length originate |
IPv4路由 |
4-50 |
lsp-length receive |
IPv4路由 |
4-51 |
mac-address (系统视图) |
MAC地址表管理 |
1-3 |
mac-address (以太网端口视图) |
MAC地址表管理 |
1-2 |
mac-address max-mac-count |
MAC地址表管理 |
1-5 |
mac-address timer |
MAC地址表管理 |
1-5 |
3-3 |
mac-authentication domain |
3-4 |
mac-authentication timer |
3-4 |
mac-authentication user-name-format |
3-6 |
management-vlan |
集群管理 |
1-39 |
IPv4路由 |
2-13 |
IPv4路由 |
3-43 |
IPv4路由 |
4-51 |
IPv6路由 |
2-10 |
IPv6路由 |
3-28 |
maximum-routes |
IPv4路由 |
3-44 |
max-response-time |
组播协议 |
1-22 |
max-response-time |
组播协议 |
2-6 |
max-response-time |
组播协议 |
4-18 |
mdi |
端口相关配置 |
1-19 |
mirroring-group |
端口镜像 |
1-2 |
mirroring-group mirroring-port |
端口镜像 |
1-3 |
mirroring-group monitor-port |
端口镜像 |
1-4 |
mirroring-group reflector-port |
端口镜像 |
1-5 |
mirroring-group remote-probe vlan |
端口镜像 |
1-6 |
mirroring-port |
端口镜像 |
1-7 |
mirror-to interface |
QoS |
8-1 |
mkdir |
文件系统管理 |
1-7 |
mkdir |
文件系统管理 |
2-16 |
mkdir |
SSH |
1-34 |
mld-snooping |
组播协议 |
2-7 |
mld-snooping drop-unknown |
组播协议 |
2-8 |
mld-snooping enable |
组播协议 |
2-8 |
mld-snooping fast-leave |
组播协议 |
2-9 |
mld-snooping general-query source-ip |
组播协议 |
2-10 |
mld-snooping group-limit |
组播协议 |
2-11 |
mld-snooping group-policy |
组播协议 |
2-12 |
mld-snooping host-aging-time |
组播协议 |
2-13 |
mld-snooping host-join |
组播协议 |
2-13 |
mld-snooping last-listener-query-interval |
组播协议 |
2-15 |
mld-snooping max-response-time |
组播协议 |
2-15 |
mld-snooping overflow-replace |
组播协议 |
2-16 |
mld-snooping querier |
组播协议 |
2-17 |
mld-snooping query-interval |
组播协议 |
2-17 |
mld-snooping router-aging-time |
组播协议 |
2-18 |
mld-snooping special-query source-ip |
组播协议 |
2-19 |
mld-snooping static-group |
组播协议 |
2-20 |
mld-snooping static-router-port |
组播协议 |
2-21 |
mld-snooping version |
组播协议 |
2-22 |
monitor-port |
端口镜像 |
1-8 |
more |
文件系统管理 |
1-7 |
move |
文件系统管理 |
1-8 |
msdp |
组播协议 |
6-9 |
mtracert |
组播协议 |
7-9 |
mtu (Tunnel Interface view) |
IPv6配置 |
3-8 |
组播协议 |
7-11 |
multicast forwarding-table downstream-limit |
组播协议 |
7-12 |
multicast forwarding-table route-limit |
组播协议 |
7-13 |
multicast load-splitting |
组播协议 |
7-13 |
multicast longest-match |
组播协议 |
7-14 |
multicast routing-enable |
组播协议 |
7-14 |
multicast-vlan enable |
组播协议 |
3-1 |
multicast-vlan subvlan |
组播协议 |
3-2 |
nas-ip |
1-39 |
nas-ip |
1-64 |
nbns-list |
DHCP |
1-17 |
ndp enable |
集群管理 |
1-5 |
ndp timer aging |
集群管理 |
1-6 |
ndp timer hello |
集群管理 |
1-6 |
nest |
QoS |
2-9 |
netbios-type |
DHCP |
1-18 |
network |
IPv4路由 |
2-14 |
network |
IPv4路由 |
3-44 |
network |
IPv4路由 |
5-38 |
network |
IPv6路由 |
5-26 |
network |
DHCP |
1-19 |
network-entity |
IPv4路由 |
4-52 |
nm-interface vlan-interface |
集群管理 |
1-40 |
nqa |
NQA |
1-13 |
nqa-agent enable |
NQA |
1-14 |
nqa-agent max-requests |
NQA |
1-14 |
nqa-server enable |
NQA |
1-27 |
nqa-server tcpconnect |
NQA |
1-28 |
nqa-server udpecho |
NQA |
1-29 |
nssa |
IPv4路由 |
3-45 |
ntdp enable |
集群管理 |
1-12 |
ntdp explore |
集群管理 |
1-13 |
ntdp hop |
集群管理 |
1-13 |
ntdp timer |
集群管理 |
1-14 |
ntdp timer hop-delay |
集群管理 |
1-15 |
ntdp timer port-delay |
集群管理 |
1-16 |
ntp-service access |
NTP |
1-5 |
ntp-service authentication enable |
NTP |
1-6 |
ntp-service authentication-keyid |
NTP |
1-6 |
ntp-service broadcast-client |
NTP |
1-7 |
ntp-service broadcast-server |
NTP |
1-8 |
ntp-service in-interface disable |
NTP |
1-8 |
ntp-service max-dynamic-sessions |
NTP |
1-9 |
ntp-service multicast-client |
NTP |
1-9 |
ntp-service multicast-server |
NTP |
1-10 |
ntp-service reliable authentication-keyid |
NTP |
1-11 |
ntp-service source-interface |
NTP |
1-11 |
ntp-service unicast-peer |
NTP |
1-12 |
ntp-service unicast-server |
NTP |
1-13 |
oam enable |
OAM |
1-9 |
oam errored-frame period |
OAM |
1-10 |
oam errored-frame threshold |
OAM |
1-11 |
oam errored-frame-period period |
OAM |
1-12 |
oam errored-frame-period threshold |
OAM |
1-12 |
oam errored-frame-seconds period |
OAM |
1-13 |
oam errored-frame-seconds threshold |
OAM |
1-14 |
oam errored-symbol period |
OAM |
1-15 |
oam errored-symbol threshold |
OAM |
1-15 |
oam loopback |
OAM |
1-16 |
oam mode |
OAM |
1-17 |
opaque-capability enable |
IPv4路由 |
3-46 |
open |
文件系统管理 |
2-17 |
open ipv6 |
文件系统管理 |
2-17 |
option |
DHCP |
1-19 |
organization |
PKI |
1-17 |
organization-unit |
PKI |
1-17 |
originating-rp |
组播协议 |
6-9 |
ospf |
IPv4路由 |
3-47 |
ospf authentication-mode |
IPv4路由 |
3-47 |
ospf cost |
IPv4路由 |
3-49 |
ospf dr-priority |
IPv4路由 |
3-50 |
ospf mib-binding |
IPv4路由 |
3-51 |
ospf mtu-enable |
IPv4路由 |
3-51 |
ospf network-type |
IPv4路由 |
3-52 |
ospf timer dead |
IPv4路由 |
3-53 |
ospf timer hello |
IPv4路由 |
3-54 |
ospf timer poll |
IPv4路由 |
3-55 |
ospf timer retransmit |
IPv4路由 |
3-56 |
ospf trans-delay |
IPv4路由 |
3-56 |
ospfv3 |
IPv6路由 |
3-28 |
ospfv3 area |
IPv6路由 |
3-29 |
ospfv3 cost |
IPv6路由 |
3-30 |
ospfv3 dr-priority |
IPv6路由 |
3-30 |
ospfv3 mtu-ignore |
IPv6路由 |
3-31 |
ospfv3 timer dead |
IPv6路由 |
3-32 |
ospfv3 timer hello |
IPv6路由 |
3-32 |
ospfv3 timer retransmit |
IPv6路由 |
3-33 |
ospfv3 trans-delay |
IPv6路由 |
3-34 |
overflow-replace |
组播协议 |
1-23 |
overflow-replace |
组播协议 |
2-22 |
parity |
登录以太网交换机 |
1-15 |
passive |
文件系统管理 |
2-18 |
password |
1-24 |
password |
NQA |
1-16 |
peer |
IPv4路由 |
2-14 |
peer |
IPv4路由 |
3-57 |
peer advertise-community |
IPv4路由 |
5-39 |
IPv6路由 |
5-27 |
peer advertise-ext-community |
IPv4路由 |
5-40 |
IPv6路由 |
5-28 |
peer allow-as-loop |
IPv4路由 |
5-41 |
IPv6路由 |
5-29 |
MCE |
1-20 |
peer as-number |
IPv4路由 |
5-42 |
peer as-number |
IPv6路由 |
5-29 |
peer as-path-acl |
IPv4路由 |
5-42 |
peer as-path-acl |
IPv6路由 |
5-30 |
peer capability-advertise conventional |
IPv4路由 |
5-43 |
peer capability-advertise route-refresh |
IPv4路由 |
5-44 |
IPv6路由 |
5-31 |
peer connect-interface |
IPv4路由 |
5-45 |
IPv6路由 |
5-32 |
组播协议 |
6-10 |
peer default-route-advertise |
IPv4路由 |
5-46 |
IPv6路由 |
5-32 |
peer description |
IPv4路由 |
5-47 |
peer description |
IPv6路由 |
5-33 |
peer description |
组播协议 |
6-11 |
peer ebgp-max-hop |
IPv4路由 |
5-48 |
peer ebgp-max-hop |
IPv6路由 |
5-34 |
peer enable (BGP view) |
IPv4路由 |
5-49 |
peer fake-as |
IPv4路由 |
5-49 |
peer fake-as |
IPv6路由 |
5-35 |
peer filter-policy |
IPv4路由 |
5-50 |
IPv6路由 |
5-35 |
peer group |
IPv4路由 |
5-51 |
peer group |
IPv6路由 |
5-36 |
peer group |
MCE |
1-21 |
peer ignore |
IPv4路由 |
5-52 |
peer ignore |
IPv6路由 |
5-37 |
peer ip-prefix |
IPv4路由 |
5-53 |
peer ipv6-prefix |
IPv6路由 |
5-38 |
peer keep-all-routes |
IPv4路由 |
5-54 |
IPv6路由 |
5-38 |
peer log-change |
IPv4路由 |
5-55 |
peer log-change |
IPv6路由 |
5-39 |
peer mesh-group |
组播协议 |
6-11 |
peer minimum-ttl |
组播协议 |
6-12 |
peer next-hop-local |
IPv4路由 |
5-55 |
IPv6路由 |
5-40 |
peer password |
IPv4路由 |
5-56 |
peer preferred-value |
IPv4路由 |
5-57 |
IPv6路由 |
5-40 |
peer public-as-only |
IPv4路由 |
5-59 |
IPv6路由 |
5-41 |
peer reflect-client |
IPv4路由 |
5-59 |
IPv6路由 |
5-42 |
peer request-sa-enable |
组播协议 |
6-13 |
peer route-limit |
IPv4路由 |
5-60 |
peer route-limit |
IPv6路由 |
5-43 |
peer route-policy |
IPv4路由 |
5-61 |
peer route-policy |
IPv6路由 |
5-44 |
peer route-update-interval |
IPv4路由 |
5-62 |
IPv6路由 |
5-45 |
peer sa-cache-maximum |
组播协议 |
6-13 |
peer sa-policy |
组播协议 |
6-14 |
peer sa-request-policy |
组播协议 |
6-15 |
peer substitute-as |
IPv4路由 |
5-63 |
IPv6路由 |
5-45 |
peer timer |
IPv4路由 |
5-64 |
peer timer |
IPv6路由 |
5-46 |
peer-public-key end |
SSH |
1-8 |
pim |
组播协议 |
5-32 |
pim bsr-boundary |
组播协议 |
5-32 |
pim dm |
组播协议 |
5-33 |
pim hello-option dr-priority |
组播协议 |
5-33 |
pim hello-option holdtime |
组播协议 |
5-34 |
pim hello-option lan-delay |
组播协议 |
5-35 |
pim hello-option neighbor-tracking |
组播协议 |
5-35 |
pim hello-option override-interval |
组播协议 |
5-36 |
pim holdtime assert |
组播协议 |
5-37 |
pim holdtime join-prune |
组播协议 |
5-37 |
pim require-genid |
组播协议 |
5-38 |
pim sm |
组播协议 |
5-38 |
pim state-refresh-capable |
组播协议 |
5-39 |
pim timer graft-retry |
组播协议 |
5-40 |
pim timer hello |
组播协议 |
5-40 |
pim timer join-prune |
组播协议 |
5-41 |
pim triggered-hello-delay |
组播协议 |
5-42 |
ping |
系统维护与调试 |
2-1 |
ping ipv6 |
系统维护与调试 |
2-3 |
PKI |
1-18 |
PKI |
1-18 |
pki delete-certificate |
PKI |
1-19 |
pki domain |
PKI |
1-20 |
pki entity |
PKI |
1-20 |
pki import-certificate |
PKI |
1-21 |
pki request-certificate domain |
PKI |
1-22 |
pki retrieval-certificate |
PKI |
1-22 |
pki retrieval-crl domain |
PKI |
1-23 |
pki validate-certificate |
PKI |
1-24 |
pki-domain |
SSL-HTTPS |
1-5 |
port |
VLAN |
1-8 |
port access vlan |
VLAN |
1-9 |
port hybrid ip-subnet-vlan vlan |
VLAN |
1-22 |
port hybrid protocol-vlan |
VLAN |
1-16 |
port hybrid pvid vlan |
VLAN |
1-9 |
port hybrid vlan |
VLAN |
1-10 |
port link-aggregation group |
链路聚合 |
1-10 |
port link-type |
VLAN |
1-11 |
port trunk permit vlan |
VLAN |
1-12 |
port trunk pvid vlan |
VLAN |
1-13 |
port-group |
端口相关配置 |
1-20 |
port-group aggregation |
链路聚合 |
1-11 |
port-isolate enable |
端口相关配置 |
2-2 |
port-isolate uplink-port |
端口相关配置 |
2-3 |
prefer-cipher |
SSL-HTTPS |
1-6 |
preference |
IPv4路由 |
2-15 |
preference |
IPv4路由 |
3-58 |
preference |
IPv4路由 |
4-53 |
preference |
IPv4路由 |
5-65 |
preference |
IPv6路由 |
2-10 |
preference |
IPv6路由 |
3-35 |
preference |
IPv6路由 |
5-47 |
primap |
QoS |
2-9 |
primary accounting |
1-40 |
1-65 |
primary authentication |
1-41 |
1-65 |
primary authorization |
1-66 |
probe-failtimes |
NQA |
1-17 |
probe-interval |
组播协议 |
5-42 |
protocol inbound |
登录以太网交换机 |
1-16 |
protocol-vlan |
VLAN |
1-17 |
proxy-arp enable |
ARP |
2-1 |
public-key local create |
SSH |
1-10 |
public-key local destroy |
SSH |
1-11 |
public-key local export rsa |
SSH |
1-12 |
public-key peer |
SSH |
1-13 |
public-key peer import sshkey |
SSH |
1-14 |
public-key-code begin |
SSH |
1-8 |
public-key-code end |
SSH |
1-9 |
put |
文件系统管理 |
2-19 |
put |
SSH |
1-35 |
pwd |
文件系统管理 |
1-8 |
pwd |
文件系统管理 |
2-20 |
pwd |
SSH |
1-35 |
qinq enable |
QinQ-BPDU TUNNEL |
1-2 |
qinq ethernet-type |
QinQ-BPDU TUNNEL |
1-3 |
qinq vid |
QinQ-BPDU TUNNEL |
1-4 |
qos apply policy |
QoS |
2-19 |
qos car |
QoS |
1-2 |
qos car aggregative |
QoS |
6-1 |
qos car name |
QoS |
6-2 |
qos gts |
QoS |
1-4 |
qos map-table |
QoS |
4-2 |
qos policy |
QoS |
2-19 |
qos priority |
QoS |
4-3 |
qos trust |
QoS |
4-5 |
qos vlan-policy |
QoS |
7-2 |
qos wred enable |
QoS |
5-3 |
qos wrr |
QoS |
3-2 |
quit |
文件系统管理 |
2-20 |
quit |
系统维护与调试 |
1-18 |
quit |
SSH |
1-36 |
radius client |
1-42 |
radius nas-ip |
1-42 |
radius scheme |
1-43 |
radius trap |
1-44 |
raw-vlan-id inbound |
QinQ-BPDU TUNNEL |
1-1 |
reboot |
系统维护与调试 |
3-17 |
reboot member |
集群管理 |
1-40 |
redirect |
QoS |
2-10 |
reflect between-clients |
IPv4路由 |
5-66 |
IPv6路由 |
5-48 |
reflector cluster-id |
IPv4路由 |
5-67 |
IPv6路由 |
5-49 |
refresh bgp |
IPv4路由 |
5-67 |
refresh bgp ipv6 |
IPv6路由 |
5-49 |
refresh bgp vpn-instance |
MCE |
1-21 |
region-name |
MSTP |
1-11 |
register-policy |
组播协议 |
5-43 |
register-suppression-timeout |
组播协议 |
5-43 |
register-whole-checksum |
组播协议 |
5-44 |
remark dot1p |
QoS |
2-11 |
remark drop-precedence |
QoS |
2-12 |
remark dscp |
QoS |
2-12 |
remark ip-precedence |
QoS |
2-14 |
remark service-vlan-id |
QoS |
2-15 |
remotehelp |
文件系统管理 |
2-21 |
remove |
SSH |
1-36 |
rename |
文件系统管理 |
1-9 |
rename |
SSH |
1-37 |
report-aggregation |
组播协议 |
1-24 |
组播协议 |
2-23 |
组播协议 |
4-19 |
reset acl counter |
ACL |
1-9 |
reset acl ipv6 counter |
ACL |
1-27 |
reset arp |
ARP |
1-7 |
reset bfd session statistics |
BFD-GR |
1-10 |
reset bgp |
IPv4路由 |
5-68 |
reset bgp dampening |
IPv4路由 |
5-69 |
reset bgp flap-info |
IPv4路由 |
5-69 |
reset bgp ipv4 all |
IPv4路由 |
5-70 |
reset bgp ipv6 |
IPv6路由 |
5-50 |
reset bgp ipv6 dampening |
IPv6路由 |
5-51 |
reset bgp ipv6 flap-info |
IPv6路由 |
5-51 |
reset bgp vpn-instance |
MCE |
1-22 |
reset bgp vpn-instance dampening |
MCE |
1-23 |
reset bgp vpn-instance flap-info |
MCE |
1-23 |
reset counters interface |
端口相关配置 |
1-20 |
reset dhcp relay statistics |
DHCP |
2-16 |
reset dhcp server conflict |
DHCP |
1-20 |
reset dhcp server ip-in-use |
DHCP |
1-21 |
reset dhcp server statistics |
DHCP |
1-21 |
reset dhcp-snooping |
DHCP |
4-6 |
reset dldp statistics |
DLDP |
1-10 |
reset dns dynamic-host |
域名解析 |
1-7 |
reset dns ipv6 dynamic-host |
IPv6配置 |
1-35 |
reset dot1x statistics |
1-18 |
reset garp statistics |
VLAN |
3-5 |
reset hwtacacs statistics |
1-67 |
reset igmp group |
组播协议 |
4-19 |
reset igmp-snooping group |
组播协议 |
1-25 |
reset igmp-snooping statistics |
组播协议 |
1-25 |
reset ip ip-prefix |
IPv4路由 |
6-28 |
reset ip ipv6-prefix |
IPv6路由 |
6-5 |
reset ip routing-table statistics protocol |
路由概述 |
1-22 |
reset ip statistics |
IP地址-IP性能 |
2-18 |
reset ipv6 fibcache |
IPv6配置 |
1-35 |
reset ipv6 neighbors |
IPv6配置 |
1-36 |
reset ipv6 pathmtu |
IPv6配置 |
1-36 |
reset ipv6 routing-table statistics |
路由概述 |
1-23 |
reset ipv6 statistics |
IPv6配置 |
1-37 |
reset isis all |
IPv4路由 |
4-54 |
reset isis peer |
IPv4路由 |
4-54 |
reset lacp statistics |
链路聚合 |
1-11 |
reset logbuffer |
信息中心 |
1-20 |
reset mac-authentication statistics |
3-7 |
reset mld-snooping group |
组播协议 |
2-24 |
reset mld-snooping statistics |
组播协议 |
2-24 |
reset msdp peer |
组播协议 |
6-16 |
reset msdp sa-cache |
组播协议 |
6-16 |
reset msdp statistics |
组播协议 |
6-17 |
reset multicast forwarding-table |
组播协议 |
7-15 |
reset multicast routing-table |
组播协议 |
7-16 |
reset ndp statistics |
集群管理 |
1-7 |
reset oam |
OAM |
1-18 |
reset ospf counters |
IPv4路由 |
3-59 |
reset ospf process |
IPv4路由 |
3-59 |
reset ospf redistribution |
IPv4路由 |
3-60 |
reset pim control-message counters |
组播协议 |
5-45 |
reset qos car name |
QoS |
6-4 |
reset qos vlan-policy |
QoS |
7-3 |
reset radius statistics |
1-45 |
reset recycle-bin |
文件系统管理 |
1-9 |
reset rip statistics |
IPv4路由 |
2-16 |
reset rrpp statistics |
RRPP |
1-8 |
reset saved-configuration |
文件系统管理 |
1-15 |
reset stop-accounting-buffer |
1-46 |
1-68 |
reset stp |
MSTP |
1-12 |
reset tcp ipv6 statistics |
IPv6配置 |
1-37 |
reset tcp statistics |
IP地址-IP性能 |
2-19 |
reset trapbuffer |
信息中心 |
1-20 |
reset udp ipv6 statistics |
IPv6配置 |
1-38 |
reset udp statistics |
IP地址-IP性能 |
2-19 |
reset udp-helper packet |
UDP Helper |
1-1 |
reset unused porttag |
系统维护与调试 |
3-17 |
reset vrrp ipv6 statistics |
VRRP |
1-17 |
reset vrrp statistics |
VRRP |
1-5 |
restore startup-configuration |
文件系统管理 |
1-16 |
retry |
1-47 |
retry realtime-accounting |
1-47 |
retry stop-accounting |
1-49 |
1-68 |
return |
系统维护与调试 |
1-18 |
revision-level |
MSTP |
1-13 |
rfc1583 compatible |
IPv4路由 |
3-60 |
ring |
RRPP |
1-9 |
ring enable |
RRPP |
1-11 |
rip |
IPv4路由 |
2-16 |
rip authentication-mode |
IPv4路由 |
2-17 |
rip input |
IPv4路由 |
2-18 |
rip metricin |
IPv4路由 |
2-19 |
rip metricout |
IPv4路由 |
2-20 |
rip mib-binding |
IPv4路由 |
2-20 |
rip output |
IPv4路由 |
2-21 |
rip poison-reverse |
IPv4路由 |
2-22 |
rip split-horizon |
IPv4路由 |
2-22 |
rip summary-address |
IPv4路由 |
2-23 |
rip version |
IPv4路由 |
2-24 |
ripng |
IPv6路由 |
2-11 |
ripng default-route |
IPv6路由 |
2-12 |
ripng enable |
IPv6路由 |
2-13 |
ripng metricin |
IPv6路由 |
2-13 |
ripng metricout |
IPv6路由 |
2-14 |
ripng poison-reverse |
IPv6路由 |
2-15 |
ripng split-horizon |
IPv6路由 |
2-15 |
ripng summary-address |
IPv6路由 |
2-16 |
rmdir |
文件系统管理 |
1-10 |
rmdir |
文件系统管理 |
2-23 |
rmdir |
SSH |
1-38 |
rmon alarm |
SNMP-RMON |
2-8 |
rmon event |
SNMP-RMON |
2-10 |
rmon history |
SNMP-RMON |
2-11 |
rmon prialarm |
SNMP-RMON |
2-13 |
rmon statistics |
SNMP-RMON |
2-15 |
robust-count |
组播协议 |
4-20 |
root-certificate fingerprint |
PKI |
1-24 |
route-distinguisher |
MCE |
1-24 |
route-policy |
IPv4路由 |
6-22 |
router-aging-time |
组播协议 |
1-26 |
router-aging-time |
组播协议 |
2-25 |
router-id |
IPv4路由 |
5-70 |
router-id |
IPv6路由 |
3-35 |
router-id |
IPv6路由 |
5-52 |
routing-table limit |
MCE |
1-25 |
rrpp domain |
RRPP |
1-12 |
rrpp enable |
RRPP |
1-13 |
rule (advanced IPv4 ACL view) |
ACL |
1-12 |
rule (advanced IPv6 ACL view) |
ACL |
1-30 |
rule (basic IPv4 ACL view) |
ACL |
1-10 |
rule (basic IPv6 ACL view) |
ACL |
1-28 |
rule (Ethernet frame header ACL view) |
ACL |
1-17 |
rule (Pki Cert Acp view) |
PKI |
1-25 |
rule (user-defined ACL view) |
ACL |
1-18 |
rule comment (for IPv4) |
ACL |
1-20 |
rule comment (for IPv6) |
ACL |
1-34 |
save |
文件系统管理 |
1-17 |
schedule reboot at |
系统维护与调试 |
3-18 |
schedule reboot delay |
系统维护与调试 |
3-19 |
screen-length |
登录以太网交换机 |
1-16 |
secondary accounting |
1-49 |
1-69 |
secondary authentication |
1-50 |
1-70 |
secondary authorization |
1-71 |
security-policy-server |
1-51 |
self-service-url |
1-25 |
send |
登录以太网交换机 |
1-17 |
sendpacket passroute |
NQA |
1-18 |
send-router-alert |
组播协议 |
4-21 |
send-trap |
NQA |
1-17 |
server-type |
1-52 |
service-type |
登录以太网交换机 |
1-18 |
service-type |
1-26 |
service-type ftp |
1-26 |
session |
SSL-HTTPS |
1-7 |
set authentication password |
登录以太网交换机 |
1-19 |
set-overload |
IPv4路由 |
4-55 |
sftp |
SSH |
1-14 |
sftp client ipv6 source |
SSH |
1-15 |
SSH |
1-16 |
sftp ipv6 |
SSH |
1-16 |
sftp server enable |
SSH |
1-18 |
sftp server idle-timeout |
SSH |
1-18 |
shell |
登录以太网交换机 |
1-20 |
shutdown |
VLAN |
1-6 |
shutdown |
端口相关配置 |
1-21 |
shutdown |
组播协议 |
6-17 |
shutdown-interval |
系统维护与调试 |
3-21 |
silent-interface |
IPv4路由 |
2-25 |
silent-interface |
IPv4路由 |
3-61 |
silent-interface |
IPv6路由 |
3-36 |
snmp-agent |
SNMP-RMON |
1-10 |
登录以太网交换机 |
2-3 |
SNMP-RMON |
1-11 |
snmp-agent group |
登录以太网交换机 |
2-4 |
snmp-agent group |
SNMP-RMON |
1-12 |
SNMP-RMON |
1-13 |
snmp-agent log |
SNMP-RMON |
1-13 |
SNMP-RMON |
1-14 |
snmp-agent packet max-size |
SNMP-RMON |
1-15 |
SNMP-RMON |
1-16 |
snmp-agent target-host |
SNMP-RMON |
1-17 |
snmp-agent trap enable |
SNMP-RMON |
1-18 |
snmp-agent trap enable bfd |
BFD-GR |
1-10 |
snmp-agent trap enable ospf |
IPv4路由 |
3-62 |
snmp-agent trap if-mib link extended |
SNMP-RMON |
1-19 |
snmp-agent trap life |
SNMP-RMON |
1-20 |
snmp-agent trap queue-size |
SNMP-RMON |
1-21 |
snmp-agent trap source |
SNMP-RMON |
1-21 |
登录以太网交换机 |
2-5 |
SNMP-RMON |
1-22 |
snmp-host |
集群管理 |
1-41 |
source |
IPv6配置 |
3-8 |
source-interface |
NQA |
1-19 |
source-ip |
NQA |
1-20 |
source-lifetime |
组播协议 |
5-45 |
source-policy |
组播协议 |
5-46 |
source-port |
NQA |
1-21 |
speed |
登录以太网交换机 |
1-21 |
speed |
端口相关配置 |
1-22 |
spf timers |
IPv6路由 |
3-37 |
spf-schedule-interval |
IPv4路由 |
3-63 |
spf-slice-size |
IPv4路由 |
4-56 |
spt-switch-threshold |
组播协议 |
5-47 |
ssh client authentication server |
SSH |
1-19 |
ssh client first-time enable |
SSH |
1-19 |
ssh client ipv6 source |
SSH |
1-20 |
ssh client source |
SSH |
1-21 |
ssh server authentication-retries |
SSH |
1-21 |
ssh server authentication-timeout |
SSH |
1-22 |
ssh server compatible-ssh1x enable |
SSH |
1-23 |
ssh server enable |
SSH |
1-23 |
ssh server rekey-interval |
SSH |
1-24 |
ssh user |
SSH |
1-25 |
ssh2 |
SSH |
1-26 |
ssh2 ipv6 |
SSH |
1-27 |
ssl client-policy |
SSL-HTTPS |
1-8 |
ssl server-policy |
SSL-HTTPS |
1-8 |
ssm-policy |
组播协议 |
5-48 |
startup saved-configuration |
文件系统管理 |
1-18 |
state |
1-27 |
state |
1-52 |
state |
PKI |
1-26 |
state-refresh-interval |
组播协议 |
5-49 |
state-refresh-rate-limit |
组播协议 |
5-49 |
state-refresh-ttl |
组播协议 |
5-50 |
static-bind client-identifier |
DHCP |
1-22 |
static-bind ip-address |
DHCP |
1-23 |
static-bind mac-address |
DHCP |
1-24 |
static-rp |
组播协议 |
5-51 |
static-rpf-peer |
组播协议 |
6-18 |
step (for IPv4) |
ACL |
1-21 |
step (for IPv6) |
ACL |
1-35 |
stop-accounting-buffer enable |
1-54 |
1-72 |
stopbits |
登录以太网交换机 |
1-22 |
stp |
MSTP |
1-13 |
stp bpdu-protection |
MSTP |
1-15 |
stp bridge-diameter |
MSTP |
1-15 |
stp compliance |
MSTP |
1-16 |
stp config-digest-snooping |
MSTP |
1-17 |
stp cost |
MSTP |
1-18 |
stp edged-port |
MSTP |
1-19 |
stp loop-protection |
MSTP |
1-20 |
stp max-hops |
MSTP |
1-20 |
stp mcheck |
MSTP |
1-21 |
stp mode |
MSTP |
1-22 |
stp no-agreement-check |
MSTP |
1-22 |
stp pathcost-standard |
MSTP |
1-23 |
stp point-to-point |
MSTP |
1-25 |
stp port priority |
MSTP |
1-26 |
stp port-log |
MSTP |
1-26 |
stp priority |
MSTP |
1-27 |
MSTP |
1-28 |
stp root primary |
MSTP |
1-29 |
stp root secondary |
MSTP |
1-30 |
stp root-protection |
MSTP |
1-30 |
stp tc-protection |
MSTP |
1-31 |
stp tc-protection threshold |
MSTP |
1-32 |
stp timer forward-delay |
MSTP |
1-32 |
stp timer hello |
MSTP |
1-33 |
stp timer max-age |
MSTP |
1-34 |
stp timer-factor |
MSTP |
1-35 |
stp transmit-limit |
MSTP |
1-36 |
stub |
IPv4路由 |
3-64 |
stub |
IPv6路由 |
3-38 |
stub-router |
IPv4路由 |
3-65 |
summary |
IPv4路由 |
2-26 |
summary |
IPv4路由 |
4-57 |
summary automatic |
IPv4路由 |
5-71 |
super |
系统维护与调试 |
1-19 |
super password |
系统维护与调试 |
1-20 |
switch-mode |
IPv6配置 |
2-4 |
switch-mode mce |
MCE |
1-26 |
synchronization |
IPv4路由 |
5-72 |
synchronization |
IPv6路由 |
5-53 |
sysname |
系统维护与调试 |
1-21 |
system-view |
系统维护与调试 |
1-22 |
tcp anti-naptha enable |
IP地址-IP性能 |
2-20 |
tcp ipv6 timer fin-timeout |
IPv6配置 |
1-38 |
tcp ipv6 timer syn-timeout |
IPv6配置 |
1-39 |
tcp ipv6 window |
IPv6配置 |
1-39 |
tcp state |
IP地址-IP性能 |
2-20 |
tcp syn-cookie enable |
IP地址-IP性能 |
2-21 |
tcp timer check-state |
IP地址-IP性能 |
2-22 |
tcp timer fin-timeout |
IP地址-IP性能 |
2-23 |
tcp timer syn-timeout |
IP地址-IP性能 |
2-23 |
tcp window |
IP地址-IP性能 |
2-24 |
telnet |
登录以太网交换机 |
1-23 |
telnet client source |
登录以太网交换机 |
1-24 |
telnet ipv6 |
登录以太网交换机 |
1-24 |
telnet server enable |
登录以太网交换机 |
1-25 |
temperature-limit |
系统维护与调试 |
3-22 |
terminal debugging |
信息中心 |
1-21 |
terminal logging |
信息中心 |
1-21 |
terminal monitor |
信息中心 |
1-22 |
terminal trapping |
信息中心 |
1-23 |
terminal type |
登录以太网交换机 |
1-26 |
test-enable |
NQA |
1-22 |
test-failtimes |
NQA |
1-23 |
test-type |
NQA |
1-21 |
tftp |
文件系统管理 |
3-2 |
tftp client source |
文件系统管理 |
3-4 |
tftp ipv6 |
文件系统管理 |
3-5 |
tftp-server |
集群管理 |
1-42 |
tftp-server acl |
文件系统管理 |
3-1 |
tftp-server domain-name |
DHCP |
1-25 |
tftp-server ip-address |
DHCP |
1-25 |
timeout |
NQA |
1-24 |
timer |
IPv4路由 |
5-73 |
timer |
IPv6路由 |
5-54 |
timer |
集群管理 |
1-42 |
timer |
RRPP |
1-13 |
timer hello |
组播协议 |
5-52 |
timer join-prune |
组播协议 |
5-52 |
timer lsp-generation |
IPv4路由 |
4-58 |
timer lsp-max-age |
IPv4路由 |
4-59 |
timer lsp-refresh |
IPv4路由 |
4-60 |
组播协议 |
4-22 |
timer query |
组播协议 |
4-23 |
timer quiet |
1-54 |
timer quiet |
1-72 |
timer realtime-accounting |
1-55 |
1-73 |
timer response-timeout |
1-56 |
1-74 |
timer retry |
组播协议 |
6-19 |
timer spf |
IPv4路由 |
4-61 |
time-range |
ACL |
1-2 |
timers |
IPv4路由 |
2-26 |
timers |
IPv6路由 |
2-17 |
topology accept |
集群管理 |
1-43 |
topology restore-from |
集群管理 |
1-44 |
topology save-to |
集群管理 |
1-45 |
tos |
NQA |
1-24 |
tracert |
系统维护与调试 |
2-4 |
tracert ipv6 |
系统维护与调试 |
2-5 |
traffic behavior |
QoS |
2-15 |
QoS |
2-4 |
ttl |
NQA |
1-25 |
tunnel-protocol |
IPv6配置 |
3-9 |
udp-helper enable |
UDP Helper |
1-2 |
udp-helper port |
UDP Helper |
1-3 |
udp-helper server |
UDP Helper |
1-4 |
undelete |
文件系统管理 |
1-11 |
user |
文件系统管理 |
2-23 |
user privilege level |
登录以太网交换机 |
1-27 |
user-bind |
IP Source Guard |
1-4 |
user-interface |
登录以太网交换机 |
1-26 |
username |
NQA |
1-25 |
user-name-format |
1-57 |
user-name-format |
1-75 |
validate-source-address |
IPv4路由 |
2-28 |
verbose |
文件系统管理 |
2-24 |
version |
IPv4路由 |
2-28 |
version |
组播协议 |
4-23 |
version |
SSL-HTTPS |
1-9 |
virtual-cable-test |
端口相关配置 |
1-23 |
virtual-system |
IPv4路由 |
4-62 |
vlan |
VLAN |
1-7 |
vlan-mapping modulo |
MSTP |
1-37 |
vlink-peer |
IPv4路由 |
3-66 |
vlink-peer |
IPv6路由 |
3-39 |
voice vlan |
VLAN |
2-3 |
voice vlan aging |
VLAN |
2-4 |
voice vlan enable |
VLAN |
2-4 |
voice vlan mac-address |
VLAN |
2-5 |
voice vlan mode auto |
VLAN |
2-7 |
voice vlan security enable |
VLAN |
2-7 |
voice-config |
DHCP |
1-26 |
vpninstance |
NQA |
1-26 |
vpn-instance-capability simple |
MCE |
1-26 |
vpn-target |
MCE |
1-27 |
vrrp ipv6 method |
VRRP |
1-18 |
vrrp ipv6 ping-enable |
VRRP |
1-19 |
vrrp ipv6 vrid authentication-mode |
VRRP |
1-18 |
vrrp ipv6 vrid preempt-mode |
VRRP |
1-20 |
vrrp ipv6 vrid priority |
VRRP |
1-21 |
vrrp ipv6 vrid timer advertise |
VRRP |
1-21 |
vrrp ipv6 vrid track |
VRRP |
1-22 |
vrrp ipv6 vrid virtual-ip |
VRRP |
1-23 |
vrrp method |
VRRP |
1-7 |
vrrp ping-enable |
VRRP |
1-7 |
vrrp un-check ttl |
VRRP |
1-8 |
vrrp vrid authentication-mode |
VRRP |
1-6 |
vrrp vrid preempt-mode |
VRRP |
1-8 |
vrrp vrid priority |
VRRP |
1-9 |
vrrp vrid timer advertise |
VRRP |
1-10 |
vrrp vrid track |
VRRP |
1-11 |
vrrp vrid virtual-ip |
VRRP |
1-12 |
work-directory |
1-28 |
