- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
81-Puppet Configuration Examples | 63.20 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides Puppet configuration examples.
Puppet is an open-source configuration management tool. It provides the Puppet language. You can use the Puppet language to create configuration manifests and save them to a server. You can then use the server for centralized configuration enforcement and management.
This document assumes that you have basic knowledge of Puppet.
Example: Configuring Puppet
As shown in Figure 1, Puppet agents Device A and Device B are connected to the Puppet master. Use Puppet to create VLAN 100 on each Puppet agent.
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
Procedures
Configuring the Puppet master
1. Assign an IP address to the Puppet master. (Details not shown.)
2. Install Puppet on the Puppet master.
$ sudo apt-get install puppetmaster
3. Verify that Puppet configuration file puppet.conf is created in directory /etc/puppet.
If the file does not exist, execute the following command to create the file:
$ sudo puppet master –genconfig > puppet.conf
4. Add files provided by H3C:
# Create directory costom/lib/puppet in directory /etc/puppet/modules.
$ sudo mkdir –p /etc/puppet/modules/costom/lib/puppet
# Copy the type and provider library files to directory /etc/puppet/modules/custom/lib/puppet. (Details not shown.)
# Create directory nodes in directory /etc/puppet/manifests.
$ sudo mkdir –p /etc/puppet/manifests/nodes
# Edit file puppet.master.com.pp in directory /etc/puppet/manifests/nodes/. (String puppet.master.com is the host name of the Puppet master in file hostname.)
node 'puppet.master.com' {
include custom
5. Configure file site.pp:
# Go to directory /etc/puppet/manifests/ and create file site.pp in the directory.
$ cd ..
$ sudo touch site.pp
# Edit file site.pp.
node '16.1.136.133'{
netdev_device{'device':
ensure => undo_shutdown,
username => 'test',
password => 'test',
ipaddr => '16.1.136.133',
include custom
node '16.1.136.134'{
username => 'test',
password => 'test',
ipaddr => '16.1.136.134',
include custom
6. Configure file init.pp:
# Create directory custom/manifests in directory /etc/puppet/modules to store configuration manifests.
$ sudo mkdir -p /etc/puppet/modules/custom/manifests
# Create configuration manifest init.pp in directory /etc/puppet/modules/custom/manifests.
$ sudo touch init.pp
# Edit file init.pp.
class custom{
netdev_vlan{'vlan100':
id => 100,
require => Netdev_device['device'],
Configuring Puppet agent Device A
1. Assign an IP address to Device A. (Details not shown.)
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] ip address 16.1.136.133 255.255.0.0
[DeviceA-Vlan-interface2] quit
2. Configure the device as the NETCONF over SSH server:
# Generate RSA key pairs. Leave the key pair to use the default key pair name.
[DeviceA] public-key local create rsa
# Enable NETCONF over SSH.
[DeviceA] netconf ssh server enable
# Enable scheme authentication for NETCONF over SSH users.
[DeviceA] line vty 0 63
[DeviceA-line-vty0-63] authentication-mode scheme
[DeviceA-line-vty0-63] quit
# Create device management user test. Set the password to test, and assign the SSH service and network-admin user role to the user.
[DeviceA] local-user test class manage
[DeviceA-luser-manage-test] password simple test
[DeviceA-luser-manage-test] service-type ssh
[DeviceA-luser-manage-test] authorization-attribute user-role network-admin
[DeviceA-luser-manage-test] quit
3. Configure the device as an NTP client to synchronize its system time to the system time on the Puppet master:
# Enable the NTP service
[DeviceA] ntp-service enable
# Configure the device to use NTP to obtain the UTC time.
[DeviceA] clock protocol ntp
# Configure the device to operate in NTP broadcast client mode and use VLAN-interface 2 to receive NTP broadcast packets.
[DeviceA-Vlan-interface2] ntp-service broadcast-client
4. Start Puppet on the device.
[DeviceA] third-part-process start name puppet arg agent --certname=16.1.136.133 --server=16.1.147.150
The device will act as a Puppet client to request a certificate from the Puppet master.
Configuring Puppet agent Device B
The steps are similar to the steps for Device A
Using the Puppet master to issue certificates to the Puppet clients
# Use the puppet cert list command to display devices that require a certificate. (Details not shown.)
# Sign a certificate for Device A.
$ sudo puppet cert sign 16.1.136.133
After Device A obtains a certificate, it obtains a configuration manifest from the Puppet master and run the manifest.
# Sign a certificate for Device B. (Details not shown.)
# Display device configuration information. VLAN 100 is created. (Details not shown.)
Configuration files
The type and provider library files and the puppet.master.com.pp file are provided by H3C.
· Device A
clock protocol ntp
interface Vlan-interface2
ntp-service enable
line vty 0 63
user-role network-operator
idle-timeout 0 0
password hash $h$6$x0kIJnaHZkFFa3Ga$H4yMQnG96xjHiTID+6UPyJrTLXru6RJaGqrCKpxmo2O
KUVWujeoTcDEovLt6LzKIUyN7J3i5Tq2rOQPdj2Nrww==
service-type ssh
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Network Management and Monitoring Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Network Management and Monitoring Command Reference
