- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
55-SPBM Configuration Examples | 185.63 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring SPBM with tandem replication
Configuring BEB 2, BEB 3, and BEB 4
Example: Configuring SPBM with head-end replication
Example: Performing SPBM ECT migration by changing the B-VLAN
Configuration files (before ECT migration)
Introduction
This document provides examples for configuring SPBM.
This document assumes that you have basic knowledge of SPBM.
When you use SPBM in conjunction with other features, follow the restrictions and guidelines in Table 1.
Table 1 SPBM and other features compatibility
Feature |
Restrictions and guidelines |
IRF |
You must execute the irf mac-address persistent always command to prevent the IRF bridge MAC address from changing after the address owner leaves the IRF fabric. |
Spanning tree |
The spanning tree mode must be set to MSTP (the default). For SPBM neighbors to establish adjacencies, you must map all B-VLANs to MSTI 4092 and make sure their in-between links have connectivity. To forward traffic on an SPBM network, you must assign all SPBM nodes to one MST region. For more information about MST region configuration, see Layer 2—LAN Switching Configuration Guide. |
Static MAC |
If a B-MAC is the same as a static MAC in the MAC address table, remove the static MAC. The device can forward SPBM packets to the B-MAC only after the conflict is removed. |
VLAN |
ISIS-SPB protocol frames are transmitted untagged on links. To prevent SPBM-enabled interfaces from dropping these frames, assign each SPBM-enabled interface to the port VLAN (PVID) as an untagged member. You must configure the provider network ports on BEBs and BCBs as trunk or hybrid ports, and assign the ports to all B-VLANs as tagged VLAN members. |
As shown in Figure 1, deploy an SPBM network to meet the following requirements:
· Use I-SID 3001 to extend VLAN 100 across customer sites 1, 2, 3, and 4.
· Assign B-VLAN 3001 to I-SID 3001.
· Use tandem replication for multicast in the SPBM network.
NOTE: BCB 2 uses the same port numbering scheme as BCB 1. BEB 2, BEB 3, and BEB 4 use the same port numbering scheme as BEB 1. |
When you configure SPBM, follow these restrictions and guidelines:
· The following MST region parameters must be the same across all SPBM nodes:
¡ Region name.
¡ Revision level.
¡ All B-VLANs mapped to MSTI 4092.
· Multicast replication mode must be the same across all BEBs.
Hardware |
Software version |
S6800 switch series S6860 switch series |
Release 2702 |
S6861 switch series |
Not supported |
Procedures
Configuring BEB 1
# Create C-VLAN 100 and B-VLAN 3001.
<BEB1> system-view
[BEB1] vlan 100
[BEB1-vlan100] quit
[BEB1] vlan 3001
[BEB1-vlan3001] quit
# Configure MST region parameters. This example uses the default (0) for the revision level.
[BEB1] stp region-configuration
[BEB1-mst-region] region-name spb
[BEB1-mst-region] instance 4092 vlan 3001
[BEB1-mst-region] active region-configuration
[BEB1-mst-region] quit
# Enable SPBM both globally and on provider network ports. Assign the provider network ports to B-VLAN 3001.
[BEB1] spbm
[BEB1-spbm] quit
[BEB1] interface range Ten-GigabitEthernet 1/0/2 to Ten-GigabitEthernet 1/0/3
[BEB1-if-range] port link-type trunk
[BEB1-if-range] port trunk permit vlan 3001
[BEB1-if-range] spbm enable
[BEB1-if-range] quit
# Enable L2VPN.
[BEB1] l2vpn enable
# Configure an SPB VSI (I-SID 3001).
[BEB1] vsi test
[BEB1-vsi-test] spb i-sid 3001
# Assign B-VLAN 3001 to the SPB VSI.
[BEB1-vsi-test-3001] b-vlan 3001
# Enable tandem multicast replication for the SPB VSI.
[BEB1-vsi-test-3001] multicast replicate-mode tandem
[BEB1-vsi-test-3001] quit
[BEB1-vsi-test] quit
# Assign the customer network port Ten-GigabitEthernet 1/0/1 to C-VLAN 100.
[BEB1] interface Ten-GigabitEthernet1/0/1
[BEB1-Ten-GigabitEthernet1/0/1] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
# Configure Ethernet service instance 1 to match C-VLAN 100, and map the service instance to the SPB VSI.
[BEB1-Ten-GigabitEthernet1/0/1] service-instance 1
[BEB1-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 100
[BEB1-Ten-GigabitEthernet1/0/1-srv1] xconnect vsi test
[BEB1-Ten-GigabitEthernet1/0/1-srv1] quit
[BEB1-Ten-GigabitEthernet1/0/1] quit
# Configure the BEBs in the same way you configure BEB 1. (Details not shown.)
Configuring BCB 1
# Create B-VLAN 3001.
<BCB1> system-view
[BCB1] vlan 3001
[BCB1-vlan3001] quit
[BCB1] stp region-configuration
[BCB1-mst-region] region-name spb
[BCB1-mst-region] instance 4092 vlan 3001
[BCB1-mst-region] active region-configuration
[BCB1-mst-region] quit
[BCB1] spbm
[BCB1-spbm] quit
[BCB1] interface range Ten-GigabitEthernet 1/0/1 to Ten-GigabitEthernet 1/0/4
[BCB1-if-range] port link-type trunk
[BCB1-if-range] port trunk permit vlan 3001
[BCB1-if-range] spbm enable
[BCB1-if-range] quit
Configuring BCB 2
# Configure BCB 2 in the same way you configure BCB 1. (Details not shown.)
Verify the configuration on BEBs (for example, BEB 1):
# Verify that the BEB has ISIS-SPB adjacency with its neighbors.
[BEB1] display spbm peer
Peer information for SPBM
System ID Port Circuit ID State Holdtime
0011.2200.1501 XGE1/0/2 2 Up 29s
0011.2200.1601 XGE1/0/3 3 Up 29s
# Verify that the BEB has established tunnels to other BEBs.
[BEB1] display l2vpn vsi name test verbose
VSI Name: test
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : 4294967295 kbps
Multicast Restrain : 4294967295 kbps
Unknown Unicast Restrain: 4294967295 kbps
MAC Learning : Enabled
MAC Table Limit : -
Drop Unknown : -
SPB I-SID : 3001
Flooding : Enabled
Statistics : Disabled
VXLAN ID : -
SPB Connections:
BMAC BVLAN Link ID Type
0011-2200-1201 3001 64 Unicast
0011-2200-1301 3001 65 Unicast
0011-2200-1401 3001 66 Unicast
6380-ff00-0bb9 3001 - Multicast
ACs:
AC Link ID State Type
XGE1/0/1 srv1 0 Up Manual
Configuration files
· BEB 1, BEB 2, BEB 3, and BEB 4:
vlan 100
vlan 3001
region-name spb
spbm
l2vpn enable
vsi test
spb i-sid 3001
b-vlan 3001
port link-mode bridge
port trunk permit vlan 1 100
service-instance 1
xconnect vsi test
port trunk permit vlan 1 3001
spbm enable
spbm enable
· BCB 1 and BCB 2:
vlan 3001
region-name spb
spbm
spbm enable
spbm enable
spbm enable
interface Ten-GigabitEthernet1/0/4
spbm enable
As shown in Figure 2, deploy an SPBM network to meet the following requirements:
· Use I-SID 3001 to extend VLAN 100 across customer sites 1, 2, and 3.
· Use head-end replication for multicast in the SPBM network.
¡ Region name.
¡ Revision level.
Hardware |
Software version |
Release 2702 |
Not supported |
Procedures
Configuring BEB 1
<BEB1> system-view
[BEB1] vlan 100
[BEB1-vlan100] quit
[BEB1] vlan 3001
# Enable SPBM both globally and on the provider network port Ten-GigabitEthernet 1/0/2. Assign the provider network port to B-VLAN 3001.
[BEB1] spbm
[BEB1-spbm] quit
[BEB1] interface Ten-GigabitEthernet1/0/2
[BEB1-Ten-GigabitEthernet1/0/2] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/2] port trunk permit vlan 3001
[BEB1-Ten-GigabitEthernet1/0/2] spbm enable
[BEB1-Ten-GigabitEthernet1/0/2] quit
# Enable L2VPN.
[BEB1] l2vpn enable
[BEB1] vsi test
Configuring BEB 2 and BEB 3
Configuring the BCB
<BCB> system-view
[BCB] vlan 3001
[BCB-vlan3001] quit
[BCB] stp region-configuration
[BCB-mst-region] region-name spb
[BCB-mst-region] instance 4092 vlan 3001
[BCB-mst-region] active region-configuration
[BCB-mst-region] quit
[BCB] spbm
[BCB-spbm] quit
[BCB] interface range Ten-GigabitEthernet 1/0/1 to Ten-GigabitEthernet 1/0/3
[BCB-if-range] port link-type trunk
[BCB-if-range] port trunk permit vlan 3001
[BCB-if-range] spbm enable
[BCB-if-range] quit
# Verify that the BEB has ISIS-SPB adjacency with its neighbor.
0000.eeee.0101 XGE1/0/2 2 Up 29s
VSI Name: test
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
SPB I-SID : 3001
Flooding : Enabled
VXLAN ID : -
SPB Connections:
0000-eeee-0141 3001 64 Unicast
0000-9999-0141 3001 65 Unicast
ACs:
Configuration files
· BEB 1, BEB 2, and BEB 3:
vlan 100
vlan 3001
region-name spb
spbm
l2vpn enable
vsi test
spb i-sid 3001
b-vlan 3001
service-instance 1
xconnect vsi test
spbm enable
· BCB:
vlan 3001
region-name spb
spbm
spbm enable
spbm enable
spbm enable
As shown in Figure 3, perform ECT migration for the SPBM network (I-SID 3001) in "Example: Configuring SPBM with tandem replication."
Move I-SID 3001 from the original ECT algorithm to ECT algorithm 9. Change the B-VLAN from 3001 to 3003 for I-SID 3001.
Analysis
To perform the ECT migration, you must perform the following tasks:
· Create B-VLAN 3003, and map B-VLAN 3003 to MSTI 4092 on all SPBM nodes.
· Map B-VLAN 3003 to ECT algorithm 9 on all SPBM nodes.
· Change the B-VLAN from 3001 to 3003 for I-SID 3001 on BEBs.
Hardware |
Software version |
Release 2702 |
Not supported |
Procedures
Adding B-VLAN 3003
Configuring BEB 1
# Create B-VLAN 3003.
<BEB1> system-view
[BEB1] vlan 3003
[BEB1-vlan3003] quit
[BEB1-mst-region] instance 4092 vlan 3003
# Assign provider network ports to B-VLAN 3003.
[BEB1-if-range] port trunk permit vlan 3003
# Map B-VLAN 3003 to ECT algorithm 9.
[BEB1] spbm
[BEB1-spbm] ect 9 b-vlan 3003
[BEB1-spbm] quit
Configuring BCB 1
<BCB1> system-view
[BCB1] vlan 3003
[BCB1-vlan3003] quit
# Configure MST region parameters. Map B-VLAN 3003 to MSTI 4092.
[BCB1-mst-region] instance 4092 vlan 3003
[BCB1-if-range] port trunk permit vlan 3003
[BCB1] spbm
[BCB1-spbm] ect 9 b-vlan 3003
[BCB1-spbm] quit
Configuring BCB 2
Performing ECT migration
Configuring BEB 1
# Change the B-VLAN to 3003 for the SPB VSI test.
[BEB1] vsi test
[BEB1-vsi-test-3001] b-vlan 3003
Before ECT migration
# Before the ECT migration, verify that I-SID 3001 uses B-VLAN 3001 to transmit customer traffic on BEBs (for example BEB 1).
[BEB1] display spbm ect-migration i-sid 3001
ECT B-VLAN T R
00-80-c2-01 3001 1 1
After ECT migration
# Approximately 2 minutes later after the ECT migration, verify that I-SID 3001 uses B-VLAN 3003 to transmit customer traffic on BEBs (for example BEB 1).
[BEB1-spbm] display spbm ect-migration i-sid 3001
ECT B-VLAN T R
00-80-c2-09 3003 1 1
vlan 100
vlan 3001
vlan 3003
region-name spb
instance 4092 vlan 3001 3003
spbm
ect 9 b-vlan 3003
l2vpn enable
vsi test
spb i-sid 3001
b-vlan 3001
service-instance 1
xconnect vsi test
port trunk permit vlan 1 3001 3003
spbm enable
spbm enable
· BCB 1 and BCB 2:
vlan 3001
vlan 3003
region-name spb
spbm
ect 9 b-vlan 3003
spbm enable
spbm enable
spbm enable
spbm enable
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series MPLS Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series MPLS Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series SPB Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series SPB Configuration Guide
