- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
| 71-GRE with VPN Configuration Examples | 183.55 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides GRE with VPN configuration examples.
In an MPLS VPN network where a CE and a PE cannot be connected directly, you can deploy a GRE tunnel to provide a logical direct connection between them.
This document assumes that you have basic knowledge of GRE and MPLS L3VPN.
Example: Configuring GRE with VPN
As shown in Figure 1:
· Customer A and Customer B belong to VPN network vpn1.
· CE 1 and CE 2 are the edge devices of customer network vpn1.
· PE 1 and PE 2 are the edge devices of the MPLS network.
· CE 1 and PE 1 are interconnected through a VPN network named vpn2.
Configure the following settings for Customer A and Customer B to communicate with each other through the MPLS and VPN networks:
· Set up a point-to-point GRE tunnel between CE 1 and PE 1 and configure static routes for them to reach each other.
· Configure an IGP routing protocol in the MPLS network to ensure IP connectivity among the PE and P devices. In this example, OSPF is used.
· Configure LDP in the MPLS network to distribute public network labels (outer labels) of packets from VPN network vpn1.
· Configure MP-BGP and establish peer relationship between the PEs so that the PEs can advertise private network routing information and distribute private network labels (inner labels).
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
Associating an interface with a VPN instance clears the IP address configuration on the interface. As a best practice, associate the interface with the VPN instance before you configure other settings on the interface.
Procedures
Configuring OSPF in the MPLS network
1. Configure PE 1:
# Configure IP addresses for Loopback 0 and VLAN-interface 2.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] vlan 2
[PE1-vlan2] port ten-gigabitethernet 1/0/2
[PE1-vlan2] quit
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] ip address 10.1.1.1 24
[PE1-Vlan-interface2] quit
# Configure OSPF to advertise routes for the specified networks.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
2. Configure P:
# Configure IP addresses for Loopback 0, VLAN-interface 2, and VLAN-interface 5.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] port ten-gigabitethernet 1/0/2
[P-vlan2] quit
[P] vlan 5
[P-vlan5] port ten-gigabitethernet 1/0/3
[P-vlan5] quit
[P] interface vlan-interface 2
[P-Vlan-interface2] ip address 10.1.1.2 24
[P-Vlan-interface2] quit
[P] interface vlan-interface 5
[P-Vlan-interface5] ip address 10.1.4.1 24
[P-Vlan-interface5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
3. Configure PE 2:
# Configure IP addresses for Loopback 0 and VLAN-interface 5.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] vlan 5
[PE2-vlan5] port ten-gigabitethernet 1/0/1
[PE2-vlan5] quit
[PE2] interface vlan-interface 5
[PE2-Vlan-interface5] ip address 10.1.4.2 24
[PE2-Vlan-interface5] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
4. Verify that PE 1, P, and PE 2 have established OSPF neighbor relationship. This example uses PE 1 for illustration.
[PE1] display ospf peer verbose
OSPF Process 1 with Router ID 1.1.1.9
Neighbors
Area 0.0.0.0 interface 10.1.1.1(Vlan-interface2)'s neighbors
Router ID: 2.2.2.9 Address: 10.1.1.2 GR State: Normal
State: Full Mode: Nbr is Master Priority: 1
DR: 10.1.1.2 BDR: 10.1.1.1 MTU: 0
Dead timer due in 38 sec
Neighbor is up for 17:30:25
BFD status: Disabled
[PE1] display ip routing-table protocol ospf
Summary Count : 5
Summary Count : 3
2.2.2.9/32 OSPF 10 1 10.1.1.2 Vlan2
3.3.3.9/32 OSPF 10 2 10.1.1.2 Vlan2
10.1.4.0/24 OSPF 10 2 10.1.1.2 Vlan2
Summary Count : 2
1.1.1.9/32 OSPF 10 0 1.1.1.9 Loop0
10.1.1.0/24 OSPF 10 1 10.1.1.1 Vlan2
Establishing LDP LSPs in the MPLS network
1. Configure PE 1:
# Configure the LSR ID as 1.1.1.9 and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
# Enable MPLS and IPv4 LDP on VLAN-interface 2.
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
2. Configure P:
# Configure the LSR ID as 2.2.2.9 and enable LDP globally.
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Vlan-interface2] mpls enable
[P-Vlan-interface2] mpls ldp enable
# Enable MPLS and IPv4 LDP on VLAN-interface 5.
[P-Vlan-interface5] mpls enable
[P-Vlan-interface5] mpls ldp enable
3. Configure PE 2:
# Configure the LSR ID as 3.3.3.9 and enable LDP globally.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface5] mpls enable
[PE2-Vlan-interface5] mpls ldp enable
4. Verify that PE 1, P, and PE 2 have established LDP sessions. This example uses PE 1 for illustration.
[PE1] display mpls ldp peer
Total number of peers: 1
Peer LDP ID State Role GR MD5 KA Sent/Rcvd
2.2.2.9:0 Operational Passive Off Off 5/5
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup
FECs: 4 Ingress: 1 Transit: 1 Egress: 3
FEC In/Out Label Nexthop OutInterface
1.1.1.9/32 3/-
-/1151(L)
2.2.2.9/32 -/3 10.1.1.2 Vlan2
1151/3 10.1.1.2 Vlan2
3.3.3.9/32 -/1150 10.1.1.2 Vlan2
1150/1150 10.1.1.2 Vlan2
Configuring GRE and VPN instances
1. Configure VPN instance vpn1 on PE 1:
# Create VPN instance vpn1.
[PE1] ip vpn-instance vpn1
# Configure an RD for the VPN instance.
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
# Configure route targets for the VPN instance.
[PE1-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-vpn1] quit
# Associate VLAN-interface 100 with VPN instance vpn1.
[PE1] vlan 100
[PE1-vlan100] port ten-gigabitethernet 1/0/1
[PE1-vlan100] quit
[PE1] interface vlan-interface 100
[PE1-Vlan-interface100] ip binding vpn-instance vpn1
[PE1-Vlan-interface100] ip address 200.1.1.2 24
[PE1-Vlan-interface100] quit
2. Configure VPN instance vpn1 on CE 1:
[CE1] ip vpn-instance vpn1
[CE1-vpn-instance-vpn1] route-distinguisher 100:1
[CE1-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[CE1-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[CE1-vpn-instance-vpn1] quit
# Associate VLAN-interface 101 with VPN instance vpn1.
[CE1] vlan 101
[CE1-vlan101] port ten-gigabitethernet 1/0/1
[CE1-vlan101] quit
[CE1] interface vlan-interface 101
[CE1-Vlan-interface101] ip binding vpn-instance vpn1
[CE1-Vlan-interface101] ip address 100.1.1.1 24
[CE1-Vlan-interface101] quit
3. Configure GRE on CE 1:
# Create service loopback group 1, and specify its service type as Tunnel.
[CE1] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[CE1] interface ten-gigabitethernet 1/0/3
[CE1-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[CE1-Ten-GigabitEthernet1/0/3] quit
# Create tunnel interface Tunnel 0, and specify the tunnel mode as GRE/IPv4.
[CE1] interface tunnel 0 mode gre
# Specify the VPN instance to which the tunnel source belongs.
[CE1-Tunnel0] ip binding vpn-instance vpn1
# Configure an IP address for tunnel interface Tunnel 0.
[CE1-Tunnel0] ip address 20.1.1.1 255.255.255.0
# Configure the source address of tunnel interface Tunnel 0 as the IP address of VLAN-interface 101 on CE 1.
[CE1-Tunnel0] source vlan-interface 101
# Configure the destination address of the tunnel interface as the IP address of VLAN-interface 100 on PE 1.
[CE1-Tunnel0] destination 200.1.1.2
# Specify the VPN instance to which the tunnel destination belongs.
[CE1-Tunnel0] tunnel vpn-instance vpn1
[CE1-Tunnel0] quit
# Configure a static route from Customer A through tunnel interface Tunnel 0 to Customer B.
[CE1] ip route-static vpn-instance vpn1 172.2.0.0 24 tunnel 0
4. Configure GRE on PE 1:
[PE1] service-loopback group 1 type tunnel
[PE1] interface ten-gigabitethernet 1/0/3
[PE1-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[PE1-Ten-GigabitEthernet1/0/3] quit
[PE1] interface tunnel 0 mode gre
[PE1-Tunnel0] ip binding vpn-instance vpn1
[PE1-Tunnel0] ip address 20.1.1.2 255.255.255.0
# Configure the source address of tunnel interface Tunnel 0 as the IP address of VLAN-interface 100 on PE 1.
[PE1-Tunnel0] source vlan-interface 100
# Configure the destination address of the tunnel interface as the IP address of VLAN-interface 101 on CE 1.
[PE1-Tunnel0] destination 100.1.1.1
[PE1-Tunnel0] tunnel vpn-instance vpn1
[PE1-Tunnel0] quit
# Configure a static route from Customer B through tunnel interface Tunnel 0 to Customer A.
[PE1] ip route-static vpn-instance vpn1 172.1.0.0 24 Tunnel 0
5. Configure VPN instance vpn1 on PE 2:
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
# Configure route targets for the VPN instance. Make sure the import route target on PE 2 is the same as the export route target on PE 1 and the export route target on PE 2 is the same as the import route target on PE 1.
[PE2-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-vpn1] quit
[PE2] vlan 101
[PE2-vlan101] port ten-gigabitethernet 1/0/2
[PE2-vlan101] quit
[PE2] interface vlan-interface 101
[PE2-Vlan-interface101] ip binding vpn-instance vpn1
[PE2-Vlan-interface101] ip address 101.1.1.1 24
[PE2-Vlan-interface101] quit
6. Configure IP addresses for interfaces on CE 2, as shown in Figure 1. (Details not shown.)
7. Verify the configuration. This example uses PE 2 for illustration.
# Display VPN instance information.
[PE2] display ip vpn-instance
VPN-Instance Name RD Create time
vpn1 100:1 2016/06/22 13:20:08
# Verify that PE 2 can ping CE 2.
[PE2] ping -vpn-instance vpn1 101.1.1.2
Ping 10.1.4.2 (101.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 101.1.1.2: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 101.1.1.2: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 101.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 101.1.1.2: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 101.1.1.2: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
Establishing EBGP peer relationship between PEs and CEs and redistributing VPN routes
1. Configure PE 1:
# Enable BGP instance default, set the local AS number to 100, and enter BGP instance view.
[PE1] bgp 100
# Specify CE 1 as a BGP peer and set its AS number to 65410.
[PE1-bgp-default-vpn1] peer 20.1.1.1 as-number 65410
# Redistribute the direct routes of PE 1 to BGP-VPN IPv4 unicast address family.
[PE1-bgp-default-ipv4-vpn1] peer 20.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] import-route direct
[PE1-bgp-default-vpn1] quit
2. Configure PE 2:
[PE2] bgp 100
# Specify CE 2 as a BGP peer and set its AS number to 65410.
[PE2-bgp-default-vpn1] peer 101.1.1.2 as-number 65410
# Redistribute the direct routes of PE 2 to BGP-VPN IPv4 unicast address family.
[PE2-bgp-default-ipv4-vpn1] peer 101.1.1.2 enable
[PE2-bgp-default-ipv4-vpn1] import-route direct
[PE2-bgp-default-vpn1] quit
3. Configure CE 1:
# Enable BGP instance default, set the local AS number to 65410, and enter BGP instance view.
<CE1> system-view
[CE1] bgp 65410
# Specify PE 1 as a BGP peer and set its AS number to 100.
[CE1-bgp-default] peer 20.1.1.2 as-number 100
# Enter BGP IPv4 unicast address family view, and enable BGP to exchange IPv4 unicast routing information with peer 20.1.1.2.
[CE1-bgp-default-ipv4] peer 20.1.1.2 enable
# Redistribute direct routes to BGP IPv4 unicast address family.
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
4. Configure CE 2:
<CE2> system-view
[CE2] bgp 65410
# Specify PE 2 as a BGP peer and set its AS number to 100.
[CE2-bgp-default] peer 101.1.1.1 as-number 100
# Enter BGP IPv4 unicast address family view, and enable BGP to exchange IPv4 unicast routing information with peer 101.1.1.1.
[CE2-bgp-default-ipv4] peer 101.1.1.1 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
5. On PE 2, verify that PE 2 and CE 2 have established BGP peer relationship.
[PE2] display bgp peer ipv4 vpn-instance vpn1
BGP local router ID: 3.3.3.9
Local AS number: 100
Total number of peers: 1 Peers in established state: 1
101.1.1.2 65410 4 4 0 2 13:35:25 Established
Establishing MP-IBGP peer relationship between PEs
1. Configure PE 1:
# Specify PE 2 as a BGP peer and specify Loopback 0 as the source interface for TCP connections to the peer.
[PE1] bgp 100
# Enter BGP VPNv4 address family view and specify PE 2 as a BGP peer.
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
2. Configure PE 2:
# Specify PE 1 as a BGP peer and specify Loopback 0 as the source interface for TCP connections to the peer.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
# Enter BGP VPNv4 address family view and specify PE 1 as a BGP peer.
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
3. Verify that the PEs have established BGP peer relationship.
[PE1] display bgp peer vpnv4
BGP local router ID: 1.1.1.9
3.3.3.9 100 8 8 0 0 00:00:08 Established
# Display routing table information on the PEs. Verify that they have routes to reach the CEs. In this example, the routing table of VPN instance vpn1 on PE 1 is displayed.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 13 Routes : 13
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
20.1.1.0/24 Direct 0 0 20.1.1.2 Tun0
20.1.1.0/32 Direct 0 0 20.1.1.2 Tun0
20.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
200.1.1.0/24 Direct 0 0 200.1.1.2 Vlan100
200.1.1.0/32 Direct 0 0 200.1.1.2 Vlan100
200.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
200.1.1.255/32 Direct 0 0 100.1.1.2 Vlan100
101.1.1.0/24 BGP 255 0 3.3.3.9 Vlan2
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
Configuration files
· PE 1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
vlan 2
vlan 100
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Vlan-interface2
mpls enable
mpls ldp enable
interface Vlan-interface100
ip address 200.1.1.2 255.255.255.0
port link-mode bridge
port access vlan 100
port access vlan 2
interface Tunnel0 mode gre
source Vlan-interface100
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
import-route direct
ip route-static vpn-instance vpn1 172.1.0.0 24 Tunnel0
· P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
vlan 2
vlan 5
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
mpls enable
mpls ldp enable
interface Vlan-interface5
ip address 10.1.4.1 255.255.255.0
mpls enable
mpls ldp enable
port access vlan 2
port access vlan 5
· PE 2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
lldp global enable
vlan 5
vlan 101
mpls ldp
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 10.1.4.2 255.255.255.0
mpls enable
mpls ldp enable
interface Vlan-interface101
ip address 101.1.1.1 255.255.255.0
port access vlan 5
port access vlan 101
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
import-route direct
· CE 1:
vlan 101
ip address 100.1.1.1 255.255.255.0
source Vlan-interface101
bgp 65410
import-route direct
ip route-static vpn-instance vpn1 172.2.0.0 24 Tunnel0
· CE 2:
vlan 101
ip address 101.1.1.2 255.255.255.0
bgp 65410
import-route direct
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Services Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Services Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Command Reference
