- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
22-OSPFv3 Configuration Examples | 100.52 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring OSPFv3 route filtering
Configuring route redistribution
Introduction
This document provides OSPFv3 route filtering configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of OSPFv3 route filtering.
As shown in Figure 1, the devices of an enterprise reside in OSPFv3 and RIPng domains.
Configure route redistribution between OSPFv3 and RIPng to interconnect the devices.
Configure route filtering on Device E, Device C, and Device D to meet the following requirements:
· The route destined for R&D department 2 is not redistributed to OSPFv3.
· Marketing department 1 cannot reach R&D department 1.
· R&D department 1 and the After-sale service department cannot reach Marketing department 2.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int100 |
1::1/64 |
Device B |
Vlan-int100 |
1::2/64 |
Vlan-int200 |
2::1/64 |
Vlan-int300 |
3::1/64 |
Vlan-int400 |
4::1/64 |
Device C |
Vlan-int200 |
2::2/64 |
Device D |
Vlan-int300 |
3::2/64 |
Loop0 |
13::1/64 |
Loop0 |
11::1/64 |
Loop1 |
12::1/64 |
Device E |
Vlan-int400 |
4::2/64 |
Device F |
Vlan-int500 |
5::2/64 |
Vlan-int500 |
5::1/64 |
Loop0 |
14::1/64 |
Loop1 |
15::1/64 |
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
When you configure OSPFv3 route filtering, follow these restrictions and guidelines:
· The filter-policy export command that filters redistributed routes takes effect only on an ASBR.
· OSPFv3 filters routes calculated using received LSAs. It does not filter LSAs.
· IP communication is bidirectional. If a router filters out a route destined for Network A, the subnets attached to the router cannot reach Network A, and Network A cannot reach the subnets.
· When you configure route filtering by referencing an ACL, configure the rule permit source any item following multiple rule deny source items to allow unmatched routes to pass.
· Specify a Router ID when you configure OSPFv3.
Procedures
Configuring IPv6 addresses
# Configure an IPv6 address for VLAN-interface 100.
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] ipv6 address 1::1 64
# Configure IPv6 addresses for other interfaces in the same way VLAN-interface 100 is configured. (Details not shown.)
Configuring OSPFv3
# Enable OSPFv3 on Device A.
[DeviceA] ospfv3
[DeviceA-ospfv3-1] router-id 6.6.6.6
[DeviceA-ospfv3-1] quit
[DeviceA-Vlan-interface100] ospfv3 1 area 0
[DeviceA-Vlan-interface100] quit
[DeviceA] interface vlan-interface 200
[DeviceA-Vlan-interface200] ospfv3 1 area 2
[DeviceA-Vlan-interface200] quit
[DeviceA] interface vlan-interface 400
[DeviceA-Vlan-interface400] ospfv3 1 area 1
[DeviceA-Vlan-interface400] quit
# Enable OSPFv3 on Device B.
[DeviceB] ospfv3
[DeviceB-ospfv3-1] router-id 5.5.5.5
[DeviceB-ospfv3-1] quit
[DeviceB] interface vlan-interface 100
[DeviceB-Vlan-interface100] ospfv3 1 area 0
[DeviceB-Vlan-interface100] quit
[DeviceB] interface vlan-interface 300
[DeviceB-Vlan-interface300] ospfv3 1 area 3
[DeviceB-Vlan-interface300] quit
# Enable OSPFv3 on Device C.
<DeviceC> system-view
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 4.4.4.4
[DeviceC-ospfv3-1] quit
[DeviceC] interface vlan-interface 200
[DeviceC-Vlan-interface200] ospfv3 1 area 2
[DeviceC-Vlan-interface200] quit
[DeviceC] interface loopback 0
[DeviceC-LoopBack0] ospfv3 1 area 2
[DeviceC-LoopBack0] quit
# Enable OSPFv3 on Device D.
<DeviceD> system-view
[DeviceD] ospfv3
[DeviceD-ospfv3-1] router-id 3.3.3.3
[DeviceD-ospfv3-1] quit
[DeviceD] interface vlan-interface 300
[DeviceD-Vlan-interface300] ospfv3 1 area 3
[DeviceD-Vlan-interface300] quit
[DeviceD] interface loopback 0
[DeviceD-LoopBack0] ospfv3 1 area 3
[DeviceD-LoopBack0] quit
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] ospfv3 1 area 3
[DeviceD-LoopBack1] quit
# Enable OSPFv3 on Device E.
<DeviceE> system-view
[DeviceE] ospfv3
[DeviceE-ospfv3-1] router-id 2.2.2.2
[DeviceE-ospfv3-1] quit
[DeviceE] interface vlan-interface 400
[DeviceE-Vlan-interface400] ospfv3 1 area 1
[DeviceE-Vlan-interface400] quit
Configure RIPng
# Enable RIPng on Device E.
[DeviceE] ripng
[DeviceE-ripng-1] quit
[DeviceE] interface vlan-interface 500
[DeviceE-Vlan-interface500] ripng 1 enable
[DeviceE-Vlan-interface500] quit
# Enable RIPng on Device F.
<DeviceF> system-view
[DeviceF] ripng
[DeviceF-ripng-1] quit
[DeviceF] interface vlan-interface 500
[DeviceF-Vlan-interface500] ripng 1 enable
[DeviceF-Vlan-interface500] quit
[DeviceF] interface loopback 0
[DeviceF-LoopBack0] ripng 1 enable
[DeviceF-LoopBack0] quit
[DeviceF] interface loopback 1
# Configure Device E to redistribute OSPFv3 and direct routes to RIPng.
[DeviceE] ripng
[DeviceE-ripng-1] import-route direct
[DeviceE-ripng-1] import-route ospfv3
# Configure Device E to redistribute RIPng and direct routes to OSPFv3.
[DeviceE] ospfv3
[DeviceE-ospfv3-1] import-route direct
[DeviceE-ospfv3-1] import-route ripng
# Verify that Device E has routes to all networks.
[DeviceE] display ipv6 routing-table
Destinations : 15 Routes : 15
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 1::/64 Protocol : OSPFv3
NextHop : FE80::2E0:FCFF:FE58:124D Preference: 10
Interface : Vlan400 Cost : 2
Destination: 2::/64 Protocol : OSPFv3
Destination: 3::/64 Protocol : OSPFv3
Interface : Vlan400 Cost : 3
Destination: 4::/64 Protocol : Direct
NextHop : :: Preference: 0
Interface : Vlan400 Cost : 0
Destination: 4::2/128 Protocol : Direct
Destination: 5::/64 Protocol : Direct
Interface : Vlan500 Cost : 0
Destination: 5::1/128 Protocol : Direct
Destination: 11::1/128 Protocol : OSPFv3
Destination: 12::1/128 Protocol : OSPFv3
Destination: 13::1/128 Protocol : OSPFv3
Destination: 14::/64 Protocol : RIPng
NextHop : FE80::2E0:FCFF:FE11:19B5 Preference: 100
Interface : Vlan500 Cost : 1
Destination: 15::/64 Protocol : RIPng
Destination: FE80::/10 Protocol : Direct
Destination: FF00::/8 Protocol : Direct
Interface : NULL0 Cost : 0
# Verify that other devices have routes to all networks. (Details not shown.)
# On Device C, configure IPv6 basic ACL 2000 to permit any subnet except 12::1/64.
[DeviceC] acl ipv6 basic 2000
[DeviceC-acl-ipv6-basic-2000] rule 0 deny source 12::1 64
[DeviceC-acl-ipv6-basic-2000] rule permit source any
[DeviceC-acl-ipv6-basic-2000] quit
# On Device C, use ACL 2000 to filter received routes.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] filter-policy 2000 import
# On Device D, configure IPv6 basic ACL 2000 to permit any subnet except 15::1/64.
[DeviceD] acl ipv6 basic 2000
[DeviceD-acl-ipv6-basic-2000] rule 0 deny source 15::1 64
[DeviceD-acl-ipv6-basic-2000] rule permit source any
[DeviceD-acl-ipv6-basic-2000] quit
# On Device D, use ACL 2000 to filter received routes.
[DeviceD] ospfv3
[DeviceD-ospfv3-1] filter-policy 2000 import
# On Device E, configure IPv6 basic ACL 2000 to permit any subnet except 14::1/64.
[DeviceE] acl ipv6 basic 2000
[DeviceE-acl-ipv6-basic-2000] rule 0 deny source 14::1 64
[DeviceE-acl-ipv6-basic-2000] rule permit source any
[DeviceE-acl-ipv6-basic-2000] quit
# On Device E, use ACL 2000 to filter routes redistributed from RIPng.
[DeviceE] ospfv3
[DeviceE-ospfv3-1] filter-policy 2000 export ripng 1
# Verify that Device C does not have a route to 12::/64.
[DeviceC] display ipv6 routing-table
Destinations : 13 Routes : 13
NextHop : FE80::2E0:FCFF:FE58:1245 Preference: 10
Interface : Vlan200 Cost : 2
Destination: 2::/64 Protocol : Direct
Interface : Vlan200 Cost : 0
Destination: 2::2/128 Protocol : Direct
Interface : Vlan200 Cost : 3
Destination: 4::/64 Protocol : OSPFv3
Destination: 5::/64 Protocol : OSPFv3
NextHop : FE80::2E0:FCFF:FE58:1245 Preference: 150
Interface : Vlan200 Cost : 1
Destination: 13::/64 Protocol : Direct
Interface : Loop0 Cost : 0
Destination: 13::1/128 Protocol : Direct
Destination: 15::/64 Protocol : OSPFv3
# Verify that Marketing department 1 cannot reach R&D department 1.
[DeviceC] ping ipv6 -a 13::1 12::1
Ping6(56 data bytes) 13::1 --> 12::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping6 statistics for 12::1 ---
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
# Verify that Device D does not have a route to 15::/64.
[DeviceD] display ipv6 routing-table
Destinations : 14 Routes : 14
NextHop : FE80::2A0:FCFF:FE00:5815 Preference: 10
Interface : Vlan300 Cost : 2
Interface : Vlan300 Cost : 3
Destination: 3::/64 Protocol : Direct
Interface : Vlan300 Cost : 0
Destination: 3::2/128 Protocol : Direct
NextHop : FE80::2A0:FCFF:FE00:5815 Preference: 150
Interface : Vlan300 Cost : 1
Destination: 11::/64 Protocol : Direct
Destination: 11::1/128 Protocol : Direct
Destination: 12::/64 Protocol : Direct
Interface : Loop1 Cost : 0
Destination: 12::1/128 Protocol : Direct
# Verify that the After-sale service department cannot reach Marketing department 2.
[DeviceD] ping ipv6 -a 11::1 15::1
Ping6(56 data bytes) 11::1 --> 15::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping6 statistics for 15::1 ---
# Verify that R&D department 1 cannot reach Marketing department 2.
[DeviceD] ping ipv6 -a 12::1 15::1
Ping6(56 data bytes) 12::1 --> 15::1, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
The output on Device C and Device D shows that Device E has filtered out the route destined for R&D development 2.
Configuration files
· Device A:
ospfv3 1
router-id 6.6.6.6
area 0.0.0.0
area 0.0.0.1
area 0.0.0.2
vlan 100
vlan 200
vlan 400
interface Vlan-interface100
ospfv3 1 area 0.0.0.0
ipv6 address 1::1/64
interface Vlan-interface200
ospfv3 1 area 0.0.0.2
ipv6 address 2::1/64
interface Vlan-interface400
ospfv3 1 area 0.0.0.1
ipv6 address 4::1/64
· Device B:
ospfv3 1
router-id 5.5.5.5
area 0.0.0.0
area 0.0.0.3
vlan 100
vlan 300
ipv6 address 1::2/64
interface Vlan-interface300
ospfv3 1 area 0.0.0.3
ipv6 address 3::1/64
· Device C:
ospfv3 1
router-id 4.4.4.4
area 0.0.0.2
vlan 200
interface LoopBack0
ipv6 address 13::1/64
ipv6 address 2::2/64
acl ipv6 basic 2000
rule 0 deny source 12::/64
rule 5 permit
· Device D:
ospfv3 1
router-id 3.3.3.3
area 0.0.0.3
vlan 300
interface LoopBack0
ipv6 address 11::1/64
interface LoopBack1
ipv6 address 12::1/64
ipv6 address 3::2/64
acl ipv6 basic 2000
rule 0 deny source 15::/64
rule 5 permit
· Device E:
ospfv3 1
router-id 2.2.2.2
import-route direct
import-route ripng 1
area 0.0.0.1
ripng 1
import-route direct
import-route ospfv3 1
vlan 400
vlan 500
ipv6 address 4::2/64
interface Vlan-interface500
ipv6 address 5::1/64
ripng 1 enable
acl ipv6 basic 2000
rule 0 deny source 14::/64
rule 5 permit
· Device F:
ripng 1
vlan 500
interface LoopBack0
ipv6 address 14::1/64
ripng 1 enable
interface LoopBack1
ipv6 address 15::1/64
ripng 1 enable
ipv6 address 5::2/64
ripng 1 enable
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Command Reference
