- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
60-MVRP Configuration Examples | 116.74 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Verifying local VLAN information on all devices
Verifying VLAN information after changing the registration mode
Verifying VLAN information after changing the network topology
Introduction
This document provides MVRP configuration examples.
This document assumes that you have basic knowledge of MVRP.
Example: Configuring MVRP
As shown in Figure 1:
· Device A and Device B are core layer devices. Device C and Device D are aggregation layer devices.
· Ports on all devices allow packets from VLANs 11 through 30 to pass through.
· MSTP implements load balancing and link backup for traffic of VLANs 11 through 30 between the core layer devices and the aggregation layer devices.
Configure MVRP on all devices to synchronize and update VLAN information. When the network is stable, set the registration mode to fixed on Ten-GigabitEthernet 1/0/1 of Device B to maintain dynamic VLAN information.
Analysis
To meet the network requirements, you must perform the following tasks:
· To assign all devices to the same MST region, configure the same settings for the following parameters on all the devices:
¡ Spanning tree mode. (This example uses the default mode MSTP.)
¡ MST region name. (This example uses the region name test.)
¡ MST region revision level. (This example uses the default setting 0.)
¡ VLAN-to-instance mappings. (This example maps VLANs 11 through 20 to MSTI 1, and maps VLANs 21 through 30 to MSTI 2.)
· For MSTIs 1 and 2 to use different uplinks for backup, set Device A and Device B as the root bridges of MSTIs 1 and 2, respectively.
· Make sure each MSTI is mapped to an existing VLAN on each device in the network.
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
When you configure MVRP, follow these restrictions and guidelines:
· MVRP can work with STP, RSTP, or MSTP. Ports blocked by STP, RSTP, or MSTP can receive and send MVRP frames. MVRP cannot work with other link layer topology protocols, including service loopback, PVST, RRPP, and Smart Link.
· On a Layer 2 aggregate interface, MVRP takes effect on both the aggregate interface and all Selected member ports in the link aggregation group.
· MVRP configuration made on an aggregation group member port takes effect only after the port is removed from the aggregation group.
Procedures
Configuring Device A
# Create VLANs 11 through 30.
[DeviceA] vlan 11 to 30
# Enter MST region view.
[DeviceA] stp region-configuration
# Set the MST region name to test.
[DeviceA-mst-region] region-name test
# Map VLANs 11 through 20 to MSTI 1.
[DeviceA-mst-region] instance 1 vlan 11 to 20
# Map VLANs 21 through 30 to MSTI 2.
[DeviceA-mst-region] instance 2 vlan 21 to 30
# Activate the MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Configure Device A as the root bridge of MSTI 1.
[DeviceA] stp instance 1 root primary
# Enable the spanning tree feature globally.
[DeviceA] stp global enable
# Configure the ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 as trunk ports, assign the ports to VLANs 11 through 30, and enable MVRP on these ports.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 11 to 30
[DeviceA-if-range] mvrp enable
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
Configuring Device B
# Create VLANs 11 and 21.
[DeviceB] vlan 11
[DeviceB-vlan11] quit
[DeviceB] vlan 21
[DeviceB-vlan21] quit
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name test
[DeviceB-mst-region] instance 1 vlan 11 to 20
[DeviceB-mst-region] instance 2 vlan 21 to 30
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Configure Device B as the root bridge of MSTI 2.
[DeviceB] stp instance 2 root primary
[DeviceB] stp global enable
# Enable MVRP globally.
[DeviceB] mvrp global enable
[DeviceB] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 11 to 30
[DeviceB-if-range] mvrp enable
[DeviceB-if-range] undo shutdown
[DeviceB-if-range] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 11
[DeviceC-vlan11] quit
[DeviceC] vlan 21
[DeviceC-vlan21] quit
[DeviceC-mst-region] region-name test
[DeviceC-mst-region] instance 1 vlan 11 to 20
[DeviceC-mst-region] instance 2 vlan 21 to 30
[DeviceC-mst-region] quit
[DeviceC] stp global enable
[DeviceC] mvrp global enable
# Configure the ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, assign the ports to VLANs 11 through 30, and enable MVRP on these ports.
[DeviceC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[DeviceC-if-range] port link-mode bridge
[DeviceC-if-range] port link-type trunk
[DeviceC-if-range] port trunk permit vlan 11 to 30
[DeviceC-if-range] mvrp enable
[DeviceC-if-range] undo shutdown
[DeviceC-if-range] quit
Configuring Device D
Configure Device D in the same way Device C is configured. (Details not shown.)
Verifying MSTI topologies
# Display brief spanning tree information on Device A.
[DeviceA] display stp brief
MST ID Port Role STP State Protection
1 Ten-GigabitEthernet1/0/1 DESI FORWARDING NONE
1 Ten-GigabitEthernet1/0/2 DESI FORWARDING NONE
1 Ten-GigabitEthernet1/0/3 DESI FORWARDING NONE
2 Ten-GigabitEthernet1/0/1 ROOT FORWARDING NONE
2 Ten-GigabitEthernet1/0/2 DESI FORWARDING NONE
2 Ten-GigabitEthernet1/0/3 DESI FORWARDING NONE
# Display brief spanning tree information on Device B.
[DeviceB] display stp brief
1 Ten-GigabitEthernet1/0/1 ROOT FORWARDING NONE
2 Ten-GigabitEthernet1/0/1 DESI FORWARDING NONE
# Display brief spanning tree information on Device C.
[DeviceC] display stp brief
1 Ten-GigabitEthernet1/0/1 ALTE DISCARDING NONE
1 Ten-GigabitEthernet1/0/2 ROOT FORWARDING NONE
2 Ten-GigabitEthernet1/0/2 ALTE DISCARDING NONE
# Display brief spanning tree information on Device D.
[DeviceD] display stp brief
1 Ten-GigabitEthernet1/0/2 ALTE DISCARDING NONE
2 Ten-GigabitEthernet1/0/1 ALTE DISCARDING NONE
2 Ten-GigabitEthernet1/0/2 ROOT FORWARDING NONE
Based on the output, you can get MSTI topologies, as shown in Figure 2.
# Display local VLAN information on Device A.
[DeviceA] display mvrp running-status
-------[MVRP Global Info] -------
Global Status : Enabled
Compliance-GVRP : False
----[Ten-GigabitEthernet1/0/1] ----
Config Status : Enabled
Running Status : Enabled
Join Timer : 20 (centiseconds)
Leave Timer : 60 (centiseconds)
Periodic Timer : 100 (centiseconds)
LeaveAll Timer : 1000 (centiseconds)
Registration Type : Normal
Registered VLANs :
1(default), 11, 21
Declared VLANs :
1(default), 11-30
Propagated VLANs :
1(default), 11, 21
----[Ten-GigabitEthernet1/0/2] ----
Registered VLANs :
1(default), 11
Declared VLANs :
1(default), 11-30
Propagated VLANs :
1(default), 11
----[Ten-GigabitEthernet1/0/3] ----
Registered VLANs :
1(default), 11
Declared VLANs :
1(default), 11-30
Propagated VLANs :
1(default), 11
The output shows that all ports of Device A have declared VLANs 11 through 30.
# Display local VLAN information on Device B.
[DeviceB] display mvrp running-status
Registered VLANs :
1(default), 11-30
Declared VLANs :
1(default), 11, 21
Propagated VLANs :
1(default), 11-30
Registered VLANs :
21
Declared VLANs :
1(default), 11-30
Propagated VLANs :
21
Registered VLANs :
21
Declared VLANs :
1(default), 11-30
Propagated VLANs :
21
The output shows that:
· Ten-GigabitEthernet 1/0/1 has registered and propagated VLANs 11 through 30.
· Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 have declared VLANs 11 through 30.
# Display local VLAN information on Device C.
[DeviceC] display mvrp running-status
Registered VLANs :
1(default), 11-30
Declared VLANs :
21
Propagated VLANs :
21-30
Registered VLANs :
1(default), 11-30
Declared VLANs :
1(default), 11
Propagated VLANs :
1(default), 11-20
· Ten-GigabitEthernet 1/0/1 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/1 is a blocked port in MSTI 1, the port propagated only VLANs 21 through 30.
· Ten-GigabitEthernet 1/0/2 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/2 is a blocked port in MSTI 2, the port propagated only VLANs 11 through 20.
# Display local VLAN information on Device D.
[DeviceD] display mvrp running-status
Registered VLANs :
1(default), 11-30
Declared VLANs :
1(default), 11
Propagated VLANs :
1(default), 11-20
Registered VLANs :
1(default), 11-30
Declared VLANs :
21
Propagated VLANs :
21-30
· Ten-GigabitEthernet 1/0/1 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/1 is a blocked port in MSTI 2, the port propagated only VLANs 11 through 20.
· Ten-GigabitEthernet 1/0/2 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/2 is a blocked port in MSTI 1, the port propagated only VLANs 21 through 30.
When the network is stable, set the MVRP registration mode to fixed on Ten-GigabitEthernet 1/0/1 of Device B. Then, verify that dynamic VLANs on the port will not be deregistered.
# Set the MVRP registration mode to fixed on Ten-GigabitEthernet 1/0/1 of Device B.
[DeviceB-Ten-GigabitEthernet1/0/1] mvrp registration fixed
# Remove VLAN 30 from Device A.
[DeviceA] undo vlan 30
# Display local VLAN information on Ten-GigabitEthernet 1/0/1 of Device B.
[DeviceB] display mvrp running-status interface ten-gigabitethernet 1/0/1
Registration Type : Fixed
Registered VLANs :
1(default), 21-30
Declared VLANs :
1(default), 21
Propagated VLANs :
1(default), 21-30
# Create VLAN 30 on Device A.
Shut down Ten-GigabitEthernet1/0/2 of Device C to change the network topology, and then verify the VLAN information on this port.
# Display VLAN information on Ten-GigabitEthernet 1/0/2 of Device C.
[DeviceC] display interface ten-gigabitethernet 1/0/2
Current state: UP
Line protocol state: UP
Port link-type: Trunk
VLAN Passing: 1(default vlan), 11-30
VLAN permitted: 1(default vlan), 11-30
Trunk port encapsulation: IEEE 802.1q
The output shows that VLAN 1 and VLANs 11 through 30 can pass through Ten-GigabitEthernet 1/0/2.
# Shut down Ten-GigabitEthernet 1/0/2.
[DeviceC] interface ten-gigabitethernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] shutdown
[DeviceC-Ten-GigabitEthernet1/0/2] quit
0 Ten-GigabitEthernet1/0/1 ROOT FORWARDING NONE
0 Ten-GigabitEthernet1/0/2 ALTE DISCARDING NONE
Based on the output, you can get the topology of MSTI 1, as shown in Figure 3.
Figure 3 Topology of MSTI 1
# Display dynamic VLANs on Device C.
[DeviceC] display vlan dynamic
Dynamic VLANs: 18
The dynamic VLANs include:
12-20, 22-30
VLAN Passing: 1(default vlan), 11, 21
· VLANs 1, 11, and 21 can pass through Ten-GigabitEthernet 1/0/2.
· Ten-GigabitEthernet 1/0/2 failed to learn dynamic VLANs.
Configuration files
· Device A:
sysname DeviceA
mvrp global enable
vlan 1
vlan 11 to 30
region-name test
stp instance 0 to 1 root primary
stp global enable
port trunk permit vlan 1 11 to 30
mvrp enable
mvrp enable
mvrp enable
· Device B:
sysname DeviceB
mvrp global enable
vlan 1
vlan 11
vlan 21
region-name test
stp global enable
mvrp enable
mvrp enable
mvrp enable
· Device C:
sysname DeviceC
mvrp global enable
vlan 1
vlan 11
vlan 21
region-name test
stp global enable
mvrp enable
mvrp enable
· Device D:
sysname DeviceD
mvrp global enable
vlan 1
vlan 11
vlan 21
region-name test
stp global enable
mvrp enable
mvrp enable
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Command Reference
