- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
34-Control Plane-Based QoS Policy Configuration Examples | 57.98 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This chapter provides examples for configuring control plane-based QoS policies.
This document assumes that you have basic knowledge of QoS policies.
Example: Rate limiting ICMP packets
As shown in Figure 1, the device receives a large number of ICMP packets from the Internet. As a result, CPU usage is high, and device performance degrades.
Configure a control plane-based QoS policy to meet the following requirements:
· Rate limit ICMP packets sent to the control plane to 320 pps.
· Drop excess ICMP packets.
Analysis
To meet the network requirements, you must perform the following tasks:
· Use the if-match command to classify ICMP packets into a class.
· Use the car command to configure the rate limit value for ICMP packets and drop excess packets.
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
When you configure a control plane-based QoS policy to rate limit ICMP packets, follow these restrictions and guidelines:
· By default, the predefined QoS policy is applied to the control plane. The predefined QoS policy identifies packet types by system index and uses a default rate limit value for each packet type. To display the predefined QoS policy, use the display qos policy control-plane pre-defined command.
· You can use the if-match control-plane protocol or if-match control-plane protocol-group command to classify protocol packets.
· You can only configure the car command or a combination of the car and accounting packet commands in the behavior associated with the class.
Procedures
# Create a class named ICMP, and use the ICMP protocol as the match criterion.
[Device] traffic classifier ICMP
[Device-classifier-ICMP] if-match control-plane protocol icmp
[Device-classifier-ICMP] quit
# Create a behavior named ICMP, and configure a CAR action for ICMP packets.
[Device] traffic behavior ICMP
[Device-behavior-ICMP] car cir pps 320
[Device-behavior-ICMP] quit
# Create a QoS policy named ICMP, and associate the class ICMP with the behavior ICMP in the QoS policy.
[Device] qos policy ICMP
[Device-qospolicy-ICMP] classifier ICMP behavior ICMP
[Device-qospolicy-ICMP] quit
# Apply the QoS policy ICMP to the inbound direction of the control plane.
[Device] control-plane slot 1
[Device-cp-slot1] qos apply policy ICMP inbound
[Device-cp-slot1] quit
Verify the configuration
# Verify that the QoS policy is correctly applied to the control plane.
[Device] display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: ICMP
Classifier: ICMP
Operator: AND
Rule(s) :
If-match control-plane protocol icmp
Behavior: ICMP
Committed Access Rate:
CIR 320 (pps), CBS 20480 (Bytes), EBS 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Green packets : 0 (Packets)
Red packets : 0 (Packets)
Configuration files
traffic classifier ICMP operator and
car cir pps 320 cbs 20480 ebs 0 green pass red discard yellow pass
qos policy ICMP
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Configuration Guide
