- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
| 20-BGP Configuration Examples | 106.61 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring basic BGP
Configuring IP addresses for interfaces
Configuring BGP to redistribute direct routes on Switch B
Examples: Configuring BGP and IGP route redistribution
Introduction
This document provides BGP configuration examples.
This document assumes that you have basic knowledge of BGP.
As shown in Figure 1, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C so that Switch C can access the network 8.1.1.0/24 connected to Switch A.
Analysis
To enable Switch B to communicate with Switch C through loopback interfaces, enable OSPF in AS 65009.
By default, BGP does not advertise local networks. To enable Switch C to access the network 8.1.1.0/24 connected directly to Switch A, perform the following tasks:
· Inject network 8.1.1.0/24 to the BGP routing table of Switch A.
· Inject networks 3.1.1.0/24 and 9.1.1.0/24 to the BGP routing table of Switch B.
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
When you configure basic BGP, follow these restrictions and guidelines:
· Use loopback interfaces to establish IBGP connections to prevent route flapping caused by port state changes.
· Loopback interfaces are virtual interfaces. Use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections.
· The EBGP peers, Switch A and Switch B, are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so the switches use directly connected interfaces to establish EBGP sessions.
Procedures
# Configure an IP address for VLAN-interface 100.
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 8.1.1.1 24
# Configure IP addresses for other interfaces in the same way that VLAN-interface 100 is configured. (Details not shown.)
Configuring IBGP
Configuring Switch B
[SwitchB] bgp 65009
[SwitchB-bgp-default] peer 3.3.3.3 connect-interface Loopback 0
[SwitchB-bgp-default] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] quit
Configuring Switch C
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer 2.2.2.2 as-number 65009
[SwitchC-bgp-default] peer 2.2.2.2 connect-interface Loopback 0
[SwitchC-bgp-default] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1] quit
# Display BGP peer information on Switch C.
BGP local router ID : 3.3.3.3
Local AS number : 65009
Total number of peers : 1 Peers in established state : 1
* - Dynamically created peer
2.2.2.2 65009 2 2 0 0 00:00:13 Established
The output shows that Switch C has established an IBGP peer relationship with Switch B.
Configuring EBGP
Configuring Switch A
[SwitchA] bgp 65008
[SwitchA-bgp-default] quit
[SwitchB] bgp 65009
# Display BGP peer information on Switch B.
BGP local router ID : 2.2.2.2
Total number of peers : 2 Peers in established state : 2
3.3.3.3 65009 4 4 0 0 00:02:49 Established
3.1.1.2 65008 2 2 0 0 00:00:05 Established
The output shows that Switch B has established an IBGP peer relationship with Switch C and an EBGP peer relationship with Switch A.
# Display the BGP routing table on Switch A.
Total number of routes: 1
Status codes: * - valid, > - best, d - dampened, h - history
s - suppressed, S - stale, i - internal, e – external
a - additional-path
* > 8.1.1.0/24 8.1.1.1 0 32768 i
# Display the BGP routing table on Switch B.
a - additional-path
* >e 8.1.1.0/24 3.1.1.2 0 0 65008i
# Display the BGP routing table on Switch C.
a - additional-path
i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
The outputs show that Switch A has learned no route to AS 65009, and Switch C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
# Configure Switch B.
[SwitchB] bgp 65009
[SwitchB-bgp-default-ipv4] network 3.1.1.0 24
[SwitchB-bgp-default-ipv4] network 9.1.1.0 24
Total number of routes: 3
a - additional-path
* >e 3.1.1.0/24 3.1.1.1 0 0 65009?
* >e 9.1.1.0/24 3.1.1.1 0 0 65009i
The output shows that route 9.1.1.0/24 has been added in Switch A's routing table.
a - additional-path
* >i 3.1.1.0/24 2.2.2.2 0 100 0 ?
* >i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
* >i 9.1.1.0/24 2.2.2.2 0 100 0 i
The output shows that the route 8.1.1.0 becomes valid with the next hop as Switch A.
# Verify that Switch C can ping 8.1.1.1.
[SwitchC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL_C to break
Configuration files
· Switch A:
vlan 100
vlan 200
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface100
ip address 8.1.1.1 255.255.255.0
interface Vlan-interface200
ip address 3.1.1.2 255.255.255.0
bgp 65008
router-id 1.1.1.1
network 8.1.1.0 255.255.255.0
peer 3.1.1.1 enable
· Switch B:
vlan 200
vlan 300
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 3.1.1.1 255.255.255.0
interface Vlan-interface300
ip address 9.1.1.1 255.255.255.0
bgp 65009
router-id 2.2.2.2
peer 3.3.3.3 connect-interface Loopback0
network 3.1.1.0 255.255.255.0
network 9.1.1.0 255.255.255.0
peer 3.1.1.2 enable
peer 3.3.3.3 enable
ospf 1
area 0.0.0.0
· Switch C:
vlan 300
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 9.1.1.2 255.255.255.0
bgp 65009
router-id 3.3.3.3
peer 2.2.2.2 connect-interface Loopback0
peer 2.2.2.2 enable
ospf 1
area 0.0.0.0
As shown in Figure 2, all devices of company A belong to AS 65008 and all devices of company B belong to AS 65009. Run EBGP between Switch A and Switch B, and run OSPF between Switch B and Switch C to allow communication only between networks 9.1.2.0/24 and 8.1.1.0/24.
Analysis
To enable Switch A to obtain the route to 9.1.2.0/24, configure BGP to redistribute routes from OSPF on Switch B. To enable Switch C to obtain the route to 8.1.1.0/24, configure OSPF to redistribute routes from BGP on Switch B.
Hardware |
Software version |
Release 2702 |
When you configure BGP and IGP route redistribution, follow these restrictions and guidelines:
· The EBGP peers, Switch A and Switch B, are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so the switches directly connected interfaces to establish EBGP sessions.
Procedures
Enabling OSPF
Enable OSPF in AS 65009.
[SwitchB] ospf 1
[SwitchC] ospf 1
[SwitchC-ospf-1-area-0.0.0.0] network 9.1.2.0 0.0.0.255
Configuring EBGP connection
Configure the EBGP connection and inject network 8.1.1.0/24 to the BGP routing table of Switch A.
[SwitchA] bgp 65008
[SwitchB] bgp 65009
# Configure route redistribution between BGP and OSPF on Switch B.
[SwitchB] ospf 1
a - additional-path
* >e 9.1.2.0/24 3.1.1.1 1 0 65009?
The output shows that Switch A has obtained the route to 9.1.2.0/24.
# Display the OSPF routing table on Switch C.
Routing Table
Topology base (MTID 0)
Routing for network
Destination Cost Type NextHop AdvRouter Area
9.1.1.0/24 1 Transit 9.1.1.2 3.3.3.3 0.0.0.0
9.1.2.0/24 1 Stub 9.1.2.1 192.168.0.63 0.0.0.0
2.2.2.2/32 1 Stub 9.1.1.1 2.2.2.2 0.0.0.0
Routing for ASEs
Destination Cost Type Tag NextHop AdvRouter
8.1.1.0/24 1 Type2 1 9.1.1.1 2.2.2.2
Total nets: 3
Intra area: 2 Inter area: 0 ASE: 1 NSSA: 0
The output shows that Switch C has obtained the route to 8.1.1.0/24.
# Ping 9.1.2.1 from 8.1.1.1 on Switch A. The ping operation succeeds.
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL_C to break
# Ping 8.1.1.1 from 9.1.2.1 on Switch C. The ping operation succeeds.
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL_C to break
# Ping 9.1.2.1 and 9.1.3.1 from 8.1.2.1 on Switch A. The ping operations fail.
[SwitchA] ping –a 8.1.2.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
[SwitchA] ping –a 8.1.2.1 9.1.3.1
Ping 9.1.3.1 (9.1.3.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 9.1.3.1 ---
# Ping 8.1.1.1 and 8.1.2.1 from 9.1.3.1 on Switch C. The ping operations fail.
[SwitchC] ping –a 9.1.3.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
[SwitchC] ping –a 9.1.3.1 8.1.2.1
Ping 8.1.2.1 (8.1.2.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 8.1.2.1 ---
Configuration files
· Switch A:
vlan 100
vlan 200
vlan 600
interface Loopback0
interface Vlan-interface600
ip address 8.1.2.1 255.255.255.0
bgp 65008
router-id 1.1.1.1
peer 3.1.1.1 enable
· Switch B:
vlan 200
vlan 300
vlan 500
interface Loopback0
bgp 65009
router-id 2.2.2.2
import-route ospf 1
peer 3.1.1.2 enable
ospf 1
import-route bgp
area 0.0.0.0
· Switch C:
vlan 300
vlan 400
interface Loopback0
interface Vlan-interface400
ip address 9.1.2.1 255.255.255.0
interface Vlan-interface500
ip address 9.1.3.1 255.255.255.0
ospf 1
area 0.0.0.0
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Command Reference
