- H3C S6800 & S6860 & S6861 Switches Configuration Examples-Release 27xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-PBB Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-Multicast VPN Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-SPBM Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-GRE with VPN Configuration Examples
- 72-VXLAN Configuration Examples
- 73-DRNI Configuration Examples
- 74-IRF 3.1 Configuration Examples
- 75-DRNI and EVPN Configuration Examples
- 76-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 77-VCF Fabric Configuration Examples
- 78-PTP Configuration Examples
- 79-S-MLAG Configuration Examples
- 80-MPLS SR Configuration Examples
- 81-Puppet Configuration Examples
| 38-Traffic Filtering Configuration Examples | 94.11 KB |
H3C S6800 & S6860 & S6861 Switches |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides traffic filtering configuration examples.
This document assumes that you have basic knowledge of traffic filtering.
Example: Configuring traffic filtering
As shown in Figure 1, a company has three branches, each of which has a Marketing department and a Finance department. All Marketing departments belong to VLAN 20. All Finance departments belong to VLAN 30.
Configure traffic filtering to meet the following requirements:
· HTTP traffic from the Marketing department in each branch is denied.
· In Branch B, only Host A and Host B can access the server.
· The Marketing departments in three branches can access one another, and the Finance departments in three branches can access one another.
Analysis
To meet the network requirements, you must perform the following tasks:
· To deny HTTP traffic from the Marketing departments, use one of the following methods:
¡ Filter outgoing traffic from the subnet 192.168.4.0/24 on the interfaces that connect Device B, Device C, and Device D to Device A.
This method has poor scalability, because new branches require the same configuration on their access switches.
¡ Filter outgoing traffic from the subnet 192.168.4.0/24 on interface Ten-GigabitEthernet 1/0/4 of Device A.
This method wastes processing capabilities of Device A, because Device A must internally forward all incoming traffic to interface Ten-GigabitEthernet 1/0/4.
¡ Configure a QoS policy to deny HTTP traffic from the Marketing departments.
This method can automatically adapt to changing network topologies and also saves hardware resources by denying traffic on the incoming interface. This example uses this method.
· To allow only Host A and Host B to access the server in Branch B, perform the following tasks:
¡ Configure an ACL on Ten-GigabitEthernet 1/0/1 to allow packets from 192.168.4.10/24 and 192.168.4.15/24.
¡ Set the default packet filtering action to deny to deny packets that do not match the configured ACL.
· To allow traffic from Marketing departments and Finance departments (except HTTP traffic) to the Internet and to allow access among Marketing departments and among Finance departments, perform the following tasks:
¡ Configure Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 as trunk ports.
¡ Assign these interfaces to VLAN 20 and VLAN 30.
Hardware |
Software version |
S6800 switch series S6860 switch series S6861 switch series |
Release 2702 |
If a traffic behavior is configured with the filter deny action, all other actions in the behavior except traffic accounting do not take effect.
Procedures
Configuring Device A
# Create VLAN 20 and VLAN 30.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] vlan 30
[DeviceA-vlan30] quit
# Add Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to interface range named myport.
[DeviceA] interface range name myport interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
# Configures interfaces Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 as trunk ports, assign them to VLAN 20 and VLAN 30, and remove them from VLAN 1.
[DeviceA-if-range-myport] port link-type trunk
[DeviceA-if-range-myport] port trunk permit vlan 20 30
[DeviceA-if-range-myport] undo port trunk permit vlan 1
[DeviceA-if-range-myport] quit
# Configure advanced IPv4 ACL 3000 to match HTTP traffic from subnet 192.168.4.0/24.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule deny tcp source 192.168.4.0 0.0.0.255 source-port eq 80
[DeviceA-acl-ipv4-adv-3000] quit
# Create a class named vlan20_http, and use ACL 3000 as the match criterion.
[DeviceA] traffic classifier vlan20_http
[DeviceA-classifier-vlan20_http] if-match acl 3000
[DeviceA-classifier-vlan20_http] quit
# Create a behavior named vlan20_http, and configure traffic filtering to deny traffic of the class vlan20_http.
[DeviceA] traffic behavior vlan20_http
[DeviceA-behavior-vlan20_http] filter deny
[DeviceA-behavior-vlan20_http] quit
# Create a QoS policy named vlan20_http, and associate the class vlan20_http with the behavior vlan20_http in the QoS policy.
[DeviceA] qos policy vlan20_http
[DeviceA-qospolicy-vlan20_http] classifier vlan20_http behavior vlan20_http
[DeviceA-qospolicy-vlan20_http] quit
# Apply the QoS policy vlan20_http to the inbound direction of VLAN 20 and VLAN 30.
[DeviceA] qos vlan-policy vlan20_http vlan 20 30 inbound
Configuring Device B
# Configure basic IPv4 ACL 2000 to permit traffic from Host A and Host B.
[DeviceB] acl basic 2000
[DeviceB-acl-ipv4-basic-2000] rule permit source 192.168.4.10 0
[DeviceB-acl-ipv4-basic-2000] rule permit source 192.168.4.15 0
[DeviceB-acl-ipv4-basic-2000] quit
# Set the packet filtering default action to deny.
[DeviceB] packet-filter default deny
# Apply ACL 2000 to interface Ten-GigabitEthernet 1/0/1 to filter outgoing traffic.
[DeviceB-Ten-GigabitEthernet1/0/1] packet-filter 2000 outbound
# Verify the QoS policy applied to the inbound direction of VLAN 20 and VLAN 30.
[DeviceA]display qos vlan-policy vlan inbound
Direction: Inbound
Policy: vlan20_http
Classifier: vlan20_http
Operator: AND
Rule(s) :
If-match acl 3000
Behavior: vlan20_http
Filter enable: Deny
Vlan 30
Direction: Inbound
Policy: vlan20_http
Operator: AND
Rule(s) :
If-match acl 3000
Filter enable: Deny
# Display application details of ACLs for incoming packet filtering on Ten-GigabitEthernet 1/0/1.
[DeviceB] display packet-filter verbose interface ten-gigabitethernet 1/0/1 outbound
Outbound policy:
IPv4 ACL 2000
rule 0 permit source 192.168.4.10 0
IPv4 default action: Deny
Configuration files
· Device A:
vlan 20
vlan 30
interface range name myport interface Ten-GigabitEthernet1/0/1 to Ten-GigabitEthernet1/0/4
acl advanced 3000
rule 0 deny tcp source 192.168.4.0 0.0.0.255 source-port eq www
traffic classifier vlan20_http operator and
if-match acl 3000
filter deny
qos vlan-policy vlan20_http vlan 20 inbound
qos vlan-policy vlan20_http vlan 30 inbound
port link-mode bridge
interface Ten-GigabitEthernet1/0/4
· Device B:
acl basic 2000
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Configuration Guide
