09-ACL和QoS命令参考
02-QoS命令
本章节下载: 02-QoS命令  (449.35 KB)
02-QoS命令
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 primap color-map-dp
1.2.6 primap pre-defined
1.2.7 primap pre-defined color
1.2.8 redirect
1.2.9 redirect-default
1.2.10 remark dot1p
1.2.11 remark drop-precedence
1.2.12 remark dscp
1.2.13 remark ip-precedence
1.2.14 remark local-precedence
1.2.15 remark mpls-exp
1.2.16 traffic behavior
1.3 定义策略和应用策略的命令
1.3.1 classifier behavior
1.3.2 display qos policy
1.3.3 display qos policy global
1.3.4 display qos policy interface
1.3.5 display qos vlan-policy
1.3.6 qos apply policy
1.3.7 qos apply policy global
1.3.8 qos policy
1.3.9 qos vlan-policy
1.3.10 reset qos policy global
1.3.11 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 display qos map-table color
2.1.3 import
2.1.4 qos map-table
2.1.5 qos map-table color
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量整形和接口限速
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts any
3.1.3 qos gts queue
3.2 接口限速配置命令
3.2.1 display qos lr interface
3.2.2 qos lr
4 硬件实现拥塞管理
4.1 队列调度策略配置命令
4.1.1 display qos qmprofile configuration
4.1.2 display qos qmprofile interface
4.1.3 qos apply qmprofile
4.1.4 qos qmprofile
4.1.5 queue
4.2 WFQ队列配置命令
4.2.1 display qos wfq interface
4.2.2 qos bandwidth queue
4.2.3 qos wfq weight
4.3 基于类的队列配置命令
4.3.1 queue af
4.3.2 queue ef
4.3.3 queue wfq
4.3.4 wred
4.3.5 weight
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.2 WRED表配置命令
5.2.1 display qos wred table
5.2.2 qos wred table
5.2.3 queue
5.2.4 queue weighting-constant
5.2.5 qos wred apply
6 聚合CAR
6.1 聚合CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car aggregative
6.1.4 reset qos car name
7 报文统计
7.1 报文统计配置命令
7.1.1 display qos traffic-counter
7.1.2 qos traffic-counter
7.1.3 reset qos traffic-counter
8 端口队列统计
8.1 端口队列显示命令
8.1.1 display qos queue-statistics interface
9 QoS管道模式
9.1 QoS管道模式配置命令
9.1.1 qos pipe-mode
1 QoS策略
本文中的“SPC单板”指的是单板丝印以“SPC”开头(如SPC-GT48L)的单板,“SPE单板”指的是单板丝印以“SPE”开头(如SPE-1020-E-II)的单板,“MPE单板”指的是单板丝印以“MPE”开头(如MPE-1004)的单板。
1.1  定义类的命令
display traffic classifier user-defined [ classifier-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义类。
classifier-name:类名。长度为1~31个字符的字符串。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display traffic classifier命令用来显示配置的类信息。
如果未指定类名,本命令将显示所有用户定义类的信息。
# 显示配置的用户自定义的类信息。
User Defined Classifier Information:
 Classifier: USER1
  Operator: AND
  Rule(s) : If-match ip-precedence 5
 Classifier: database
  Operator: AND
  Rule(s) : If-match acl 3131
表1-1 display traffic classifier user-defined命令显示信息描述表
用户自定义类的信息
Classifier
类的名字及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule
分类规则
1.1.2  if-match
if-match match-criteria
undo if-match match-criteria
类视图
【缺省级别】
2:系统级
match-criteria:类的匹配规则,取值范围如下表所示。
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~4999,IPv6 ACL序号的取值范围是2000~3999
acl-name是ACL的名称,为1~32个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
如果QoS策略引用了匹配规则是用户自定义ACL的类,仅当该QoS策略应用在SPC单板的入方向时,用户自定义ACL才生效
customer-dot1p 8021p-list
定义匹配用户网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
对于MPE单板,本参数配置后不生效
customer-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配用户网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4093
destination-mac mac-address
定义匹配目的MAC地址的规则
对于MPE单板,本参数配置后不生效
dscp dscp-list
定义匹配DSCP的规则,dscp-list为DSCP取值的列表,最多可以输入8个DSCP取值,DSCP取值范围为0~63
forwarding-layer { bridge | route }
定义匹配转发报文的二、三层属性的规则:bridge表示只匹配二层转发报文,route表示只匹配三层转发报文
本参数仅SPC单板和MPE单板支持
ip-precedence ip-precedence-list
定义匹配IP优先级的规则,ip-precedence-list为ip-precedence的列表,最多可以输入8个ip-precedence,ip-precedence取值范围为0~7
mpls-exp exp-list
定义匹配MPLS EXP优先级的规则,exp-list为EXP的列表,最多可以输入8个EXP,EXP取值范围为0~7
mpls-label { label-value-list | label-value1 to label-value2 }
定义匹配mpls-label的规则,label-value-list为mpls-label值的列表,最多可以输入8个mpls-label值,label-value1 to label-value2表示一个mpls-label的范围,label-value1的值必须小于label-value2的值,mpls-label的取值范围为0~1048575
protocol protocol-name
定义匹配协议的规则,protocol-name取值为IP或者IPv6
second-mpls-exp exp-list
定义匹配内层MPLS EXP优先级的规则,exp-list为EXP的列表,最多可以输入8个EXP,EXP取值范围为0~7
second-mpls-label { label-value-list | label-value1 to label-value2 }
定义匹配内层mpls-label的规则,label-value-list为mpls-label值的列表,最多可以输入8个mpls-label值,label-value1 to label-value2表示一个mpls-label的范围,label-value1的值必须小于label-value2的值,mpls-label的取值范围为0~1048575
service-dot1p 8021p-list
定义匹配运营商网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
对于MPE单板,本参数配置后不生效
service-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配运营商网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4093
对于MPE单板,本参数配置后不生效
source-mac mac-address
定义匹配源MAC地址的规则
对于MPE单板,本参数配置后不生效
【描述】
if-match命令用来定义匹配指定匹配规则的所有报文的规则。undo if-match命令用来删除匹配指定匹配规则的所有报文的规则。
在定义各个规则的时候,注意事项如下:
(1)     定义匹配ACL的规则
·     如果类中引用的ACL不存在,则不能在硬件中下发。
·     如果类下的规则之间是逻辑或的关系,则该类允许通过ACL名称和序号的方式分别引用一次同一个ACL;如果类下的规则之间是逻辑与的关系,则该类允许通过ACL名称或序号的方式仅引用一次同一个ACL。
(2)     定义匹配目的MAC地址规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。
·     匹配目的MAC地址规则只对以太网类型的接口有意义。
(3)     定义匹配源MAC地址规则
·     匹配源MAC地址规则只对以太网类型的接口有意义。
(4)     定义匹配DSCP的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,dscp值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)     定义匹配二层转发或者三层转发报文的规则
·     if-match forwarding-layer bridge和 if-match forwarding-layer route 不能同时配置。
·     forwarding-layer参数不能在类中单独配置,即在配置该参数的类中必须配置有其它参数;且不论类操作符是and或or,同时配置的其它参数都不允许和forwarding-layer参数冲突。
(6)     定义匹配用户网络的802.1p优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,8021p值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)     定义匹配IP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,IP优先级的值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个IP优先级值,最多可指定8个;如果指定了多个相同的IP优先级值,系统默认为一个;多个不同的IP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(8)     定义匹配用户网络和运营商网络VLAN ID的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,vlan-id值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(9)     定义匹配MPLS EXP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,MPLS EXP优先级的值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个MPLS EXP优先级值,最多可指定8个;如果指定了多个相同的MPLS EXP优先级值,系统默认为一个;多个不同的MPLS EXP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS EXP优先级的规则时,指定的所有MPLS EXP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     MPLS EXP为MPLS报文特有的参数,该匹配规则仅对MPLS报文生效。
(10)     定义匹配MPLS Label的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,MPLS Label值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个MPLS Label值,如果指定了多个相同的MPLS Label值,系统默认为一个;多个不同的MPLS Label值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS Label的规则时,指定的所有MPLS Label值必须与该规则中定义的完全相同才会删除,顺序可不一样。
相关配置可参考命令traffic classifier。
# 定义类class1的匹配规则为:匹配DSCP值为1的报文。
[Sysname-classifier-class1] if-match dscp 1
# 定义类class1的匹配规则为:匹配用户网络VLAN ID值为1的报文。
[Sysname-classifier-class1] if-match customer-vlan-id 1
【缺省级别】
2:系统级
classifier-name:类名,为1~31个字符的字符串。
operator:指定各规则之间的逻辑运算符。
【描述】
traffic classifier命令用来定义一个类并进入类视图。undo traffic classifier命令用来删除一个类。
缺省情况下为operator and,即类视图下各匹配规则之间的关系为逻辑与。
相关配置可参考命令qos policy、qos apply policy和classifier behavior。
# 定义一个名为class1的类。
1.2  定义流行为的命令
1.2.1  accounting
accounting [ byte | packet ]
undo accounting
流行为视图
【缺省级别】
2:系统级
byte:表示报文以字节为单位进行统计。
packet:表示报文以包数为单位进行统计。此参数的配置,同时会影响CAR的统计单位。
【描述】
accounting命令用来为流行为配置统计动作。undo accounting命令用来取消统计动作配置。
若用户不指明统计单位,则采用默认的统计单位进行统计,默认的统计单位为byte。
相关统计信息可以通过命令display qos policy interface、display qos vlan-policy或display qos policy global查看。
相关配置可参考命令qos policy、traffic behavior和classifier behavior。
对于丝印为SPE-1010、SPE-1020、SPE-1010-E和SPE-1020-E的单板,报文(如IPv4/IPv6单播报文、组播报文、隧道报文、L3VPN入隧道报文)进行三层转发时,accounting统计只计算报文IP首部和载荷的长度。计算方法如下(以128字节长度的三层转发报文为例):
·     当输入输出端口为以太网接口且报文不带tag时:
流量统计结果=报文个数*(128字节报文长度-4字节CRC长度-14字节二层首部长度);
·     当输入输出端口为POS接口时:
流量统计结果=报文个数*(128字节报文长度-4字节CRC长度-4字节二层首部长度)。
对于SPC单板、MPE单板和丝印为SPE-1010-II、SPE-1020-II、SPE-1010-E-II和SPE-1020-E-II的单板,报文长度按照整个报文长度来计算。
# 为流行为配置统计动作。
[Sysname-behavior-database] accounting
1.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red { discard | pass } ]
undo car
流行为视图
【缺省级别】
2:系统级
cir committed-information-rate:承诺信息速率。committed-information-rate的取值范围为64~10000000 kbps。
cbs committed-burst-size:承诺突发尺寸,缺省取值为大约500毫秒时间内以CIR速率通过的流量,单位为byte。committee-burst-size的取值范围为1875~1000000000。
ebs excess-burst-size:超出突发尺寸,缺省值为0,单位为byte。excess-burst-size的取值范围为0~1000000000。
pir peak-information-rate:峰值速率。peak-information-rate的取值范围为64~10000000 kbps。
red:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
·     discard:对数据包采取的动作,丢弃数据包。
·     pass:对数据包采取的动作,允许数据包通过。
【描述】
car命令用来为流行为配置流量监管动作。undo car命令用来取消流量监管动作配置。
接口上应用的策略中使用car时,可以应用到接口报文的接收或者发送方向。
如果多次使用该命令在同一个流行为上配置,最后一次配置生效。
对于丝印为SPE-1010、SPE-1020、SPE-1010-E和SPE-1020-E的单板,报文(如IPv4/IPv6单播报文、组播报文、隧道报文、L3VPN入隧道报文)进行三层转发时,car命令中的报文长度只计算报文IP首部和载荷的长度。car命令中配置的端口速率参数,配置的速率值与理论输出速率值对应的计算方式如下(以三层转发报文的长度为128字节,配置的速率值为10000 kbps为例):
·     当输入输出端口为以太网接口且报文不带tag时,出接口速率的理论值计算如下:
(10000 kbps)*128字节/(128字节报文长度-4字节CRC长度-14字节二层首部长度)=11636 kbps;
·     当输入输出端口为POS接口时,出接口速率的理论值计算如下:
(10000 kbps)*128字节/(128字节报文长度-4字节CRC长度-4字节二层首部长度)=10666 kbps。
对于SPC单板、MPE单板和丝印为SPE-1010-II、SPE-1020-II、SPE-1010-E-II和SPE-1020-E-II的单板,配置的速率值与理论输出速率值一致。
# 为流行为配置流量监管:报文正常流速为200kbps,承诺突发尺寸为50000bytes,不符合承诺速率时对数据包采取丢弃动作。
[Sysname-behavior-database] car cir 200 cbs 50000 red discard
display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义行为。
behavior-name:行为名,如果未指定行为名,则显示所有用户定义行为的信息。
【描述】
display traffic behavior命令用来显示配置的流行为信息。
# 显示配置的用户自定义的流行为信息。
  User Defined Behavior Information:
    Behavior: ben
      Mirror enable:
        Mirror type: vlan
        Mirror destination: 23
    Behavior: 23
      Mirror enable:
        Mirror type: vlan
        Mirror destination: 25
表1-3 display traffic behavior user-defined命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
Mirror enable
流量镜像相关信息
Mirror type
流镜像类型,目前支持VLAN、CPU、interface三种
Mirror destination
流镜像的目的,对应于VLAN的是VLAN ID,对应于interface的是接口名
1.2.4  filter
filter { deny | permit }
undo filter
流行为视图
【缺省级别】
2:系统级
deny:丢弃数据包。
permit:允许数据包通过。
【描述】
filter命令用来为流行为配置流量过滤动作。undo filter命令用来取消过滤动作配置。
# 为流行为配置丢弃数据包的过滤动作。
primap color-map-dp
undo primap color-map-dp
流行为视图
【缺省级别】
2:系统级
无
【描述】
primap color-map-dp命令用来配置流行为中的动作为根据报文颜色标记报文的丢弃优先级。undo primap color-map-dp命令用来取消上述设置。
需要注意的是,本命令需要和car结合在一起使用。
映射关系为:红色对应丢弃优先级2,黄色对应丢弃优先级1,绿色对应丢弃优先级0。此映射关系固定,不能修改。
# 根据报文的颜色标记报文的丢弃优先级。
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap color-map-dp
primap pre-defined  dscp-dscp
undo primap pre-defined dscp-dscp
流行为视图
【缺省级别】
2:系统级
pre-defined:预先定义的优先级映射表。
dscp-dscp:DSCP到DSCP映射表。
【描述】
primap命令用来配置流行为中的动作为使用相应的优先级映射表为报文获取其他的优先级参数。undo primap命令用来取消流行为中的使用相应优先级映射表为报文映射优先级的动作。
相关配置可参考命令display qos map-table。
# 使用DSCP到DSCP映射表为报文获取优先级参数。
[Sysname-behavior-behavior1] primap pre-defined dscp-dscp
primap pre-defined color { up-dot1p | up-dscp | up-exp | up-lp }
undo primap pre-defined color { up-dot1p | up-dscp | up-exp | up-lp }
流行为视图
【缺省级别】
2:系统级
color:使用带颜色优先级映射表做映射。
up-dot1p:用户优先级到802.1p优先级映射表。
up-dscp:用户优先级到DSCP映射表。
up-exp:用户优先级到EXP优先级映射表。
up-lp:用户优先级到本地优先级映射表。
【描述】
primap pre-defined color命令用来配置流行为中的动作为使用相应的带颜色优先级映射表为报文获取其他的优先级参数。undo primap pre-defined color命令用来取消流行为中的使用相应的带颜色优先级映射表为报文映射优先级的动作。
相关配置可参考命令display qos map-table color。
# 使用带颜色的用户优先级到本地优先级映射表为报文获取本地优先级参数。
[Sysname-behavior-behavior1] primap pre-defined color up-lp
1.2.8  redirect
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ interface-type interface-number ] [ track track-entry-number ] [ ipv6-add2 [ interface-type interface-number ] [ track track-entry-number ] ] } [ fail-action { discard | forward } ] | vpn-instance vpn-instance-name }
undo redirect { cpu | interface interface-type interface-number | next-hop | vpn-instance }
流行为视图
【缺省级别】
2:系统级
cpu:重定向到CPU。
interface:重定向到指定的接口(目前仅支持重定向到NAT业务接口)。
next-hop:重定向到指定的下一跳(下一跳必须直连)。
ipv4-add:下一跳IPv4地址。ipv4-add2是ipv4-add1的备份下一跳地址,如果重定向到ipv4-add1失败,则会选择重定向到ipv4-add2。
ipv6-add:下一跳IPv6地址。不支持重定向到链路本地地址;当IPv6地址为非链路本地地址时,下一跳IPv6地址不需要配置接口。ipv6-add2是ipv6-add1的备份下一跳地址,如果重定向到ipv6-add1失败,则会选择重定向到ipv6-add2。
track track-entry-number:指定下一跳关联的Track项,对于不同的IP地址需要分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测模块(如NQA模块、BFD模块)的联动,具体请参见“可靠性配置指导”中的“Track”。
fail-action { discard | forward }:当下一跳的地址不存在时,对报文采取的处理动作。discard表示丢弃此报文。forward表示转发此报文。
vpn-instance vpn-instance-name:重定向到指定的VPN实例。vpn-instance-name表示VPN实例名称,为1~31字符的字符串,区分大小写。
【描述】
redirect命令用来为流行为配置流量重定向动作。undo redirect命令用来取消流量重定向动作配置。
·     在配置重定向动作时,同一个流行为中重定向类型只能为重定向到CPU、重定向到接口、重定向到下一跳或重定向到VPN实例中的一种。
·     请不要将QoS重定向的出接口绑定NAT业务接口。
·     如果配置重定向到下一跳时不配置fail-action关键字,则下一跳不存在时缺省的处理动作是转发报文。
# 为流行为配置流量重定向动作,重定向到CPU。
[Sysname-behavior-database] redirect cpu
redirect-default next-hop ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ]
undo redirect-default next-hop
流行为视图
【缺省级别】
2:系统级
next-hop:缺省重定向到指定的下一跳。
【描述】
redirect-default命令用来为流行为配置流量缺省重定向动作。undo redirect-default命令用来取消流量缺省重定向动作配置。
# 为流行为配置流量缺省重定向动作,缺省重定向到下一条1.1.1.1。
[Sysname-behavior-database] redirect-default next-hop 1.1.1.1
1.2.10  remark dot1p
remark dot1p 8021p
undo remark dot1p
流行为视图
【缺省级别】
2:系统级
8021p:标记的802.1p优先级,取值范围为0~7。
【描述】
remark dot1p命令用来配置标记报文的802.1p优先级。undo remark dot1p命令用来取消标记报文的802.1p优先级。
# 配置标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
流行为视图
【缺省级别】
2:系统级
drop-precedence-value:标记的丢弃优先级,取值范围为0~2。
【描述】
remark drop-precedence命令用来配置标记报文的丢弃优先级。undo remark drop-precedence命令用来取消标记报文的丢弃优先级。
# 配置标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.12  remark dscp
remark dscp dscp-value
undo remark dscp
流行为视图
【缺省级别】
2:系统级
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-4所示。
表1-4 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
【描述】
remark dscp命令用来为类配置标记报文的DSCP值。undo remark dscp命令用来取消标记报文的DSCP值。
# 配置标记报文的DSCP值为6。
remark ip-precedence ip-precedence-value
undo remark ip-precedence
流行为视图
【缺省级别】
2:系统级
ip-precedence-value:标记的IP优先级,取值范围为0~7。
【描述】
remark ip-precedence命令用来配置标记报文的IP优先级。undo remark ip-precedence命令用来取消标记报文的IP优先级。
本命令执行后,同时会将报文中DSCP字段的低3位修改为0。
# 配置标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
流行为视图
【缺省级别】
2:系统级
local-precedence:标记的本地优先级,可以使用数字或关键字表示,两者对应关系:
表1-5 本地优先级参数描述表
关键字
本地优先级(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
【描述】
remark local-precedence命令用来配置标记报文的本地优先级。undo remark local-precedence命令用来取消标记报文的本地优先级。
# 配置标记报文的本地优先级值为2。
remark mpls-exp exp-value
undo remark mpls-exp
流行为视图
【缺省级别】
2:系统级
exp-value:标记的MPLS报文的EXP域的值,取值范围为0~7。
【描述】
remark mpls-exp命令用来配置标记MPLS报文的EXP域的值。undo remark mpls-exp命令用来取消标记MPLS报文的EXP域的值。
# 配置标记MPLS报文的EXP域的值为2。
[Sysname-behavior-database] remark mpls-exp 2
【缺省级别】
2:系统级
behavior-name:流行为名,为1~31个字符的字符串。
【描述】
traffic behavior命令用来定义一个流行为并进入流行为视图。undo traffic behavior命令用来删除一个流行为。
# 定义一个名为behavior1的流行为。
1.3  定义策略和应用策略的命令
classifier classifier-name behavior behavior-name
策略视图
【缺省级别】
2:系统级
classifier-name:类名。
behavior-name:流行为名。
【描述】
classifier behavior命令用来在策略中为类指定采用的流行为。undo classifier命令用来取消指定类在策略中的使用。
·     策略下每个类只能与一个动作关联。
·     如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
相关配置可参考命令qos policy。
# 在策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义策略。
policy-name:策略名,如果未指定,则显示所有用户定义策略的配置信息。
classifier-name:策略中的类名。
【描述】
display qos policy命令用来显示用户定义策略的配置信息。
# 显示用户定义策略的配置信息。
  User Defined QoS Policy Information:
  Policy: user1
   Classifier: class1
     Behavior: test
      Accounting Enable
      Committed Access Rate:
        CIR 20000 (kbps), CBS 300000 (byte), EBS 100 (byte), PIR 25000 (kbps)
        Red Action: discard
      Filter enable : permit
      Marking:
        Remark dot1p COS 2
表1-6 display qos policy user-defined命令显示信息描述表
Policy
策略名
Classifier
类名,一个策略中可以存在多个类,每个类有对应的行为,每个类的匹配规则又可以有多条,参见traffic classifier命令
Behavior
策略中一个类对应的行为,每个行为可以有多条规则,参见traffic behavior命令
Accounting
流行为配置统计
流量限速的相关信息
Red Action
对流量不符合承诺速率的报文所做的动作
Filter enable
流行为配置流量过滤动作
Marking
重标记的相关信息
display qos policy global [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:显示入方向全局QoS策略的信息。
outbound:显示出方向全局QoS策略的信息。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。
【描述】
display qos policy global命令用来显示基于全局应用QoS策略的信息。
·     如果不指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
·     如果不指定槽位号,则显示主控板上基于全局应用QoS策略的信息,不显示各单板的信息。
·     本命令仅在SPC单板和MPE单板上生效。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: 1
   Classifier: 2
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: 2
       Accounting Enable
         20864 (Bytes)
         CIR 128 (kbps), CBS 8000 (byte), EBS 0 (byte)
         Red Action: discard
         Green : 12928(Bytes)
         Yellow: 7936(Bytes)
         Red   : 43904(Bytes)
表1-7 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Mode
类和流行为的对应关系所支持的模式
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称及其内容,内容可以有多种类型
Accounting
流行为统计
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出承诺突发流量的部分,单位为byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type:接口类型。
interface-number:接口编号。
inbound:显示对接口接收到的报文应用的QoS策略信息。
outbound:显示对接口发送的报文应用的QoS策略信息。
【描述】
display qos policy interface命令用来显示指定接口或所有接口上QoS策略的配置信息和运行情况。
# 显示GigabitEthernet2/1/1接口上策略的配置信息和运行情况。
<Sysname> display qos policy interface GigabitEthernet 2/1/1
Interface: GigabitEthernet2/1/1
  Direction: Outbound
  Policy: user1
   Classifier: class1
     Operator: AND
     Rule(s) : If-match acl 2001
               If-match ip-precedence 1
     Behavior: test
      Mirror enable:
        Mirror type: cpu
      Assured Forwarding:
        Bandwidth 3000 (Kbps)
        Matched  : 3905267/429580690 (Packets/Bytes)
        Enqueued : 13384/1471580 (Packets/Bytes)
        Discarded: 3891883/428109110 (Packets/Bytes)
      Filter Enable: permit
      Marking:
        Remark DSCP cs5
表1-8 display qos policy interface命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Direction
Policy应用在接口的方向
Policy
应用到接口上的策略的名字
Classifier
策略里分类规则以及对应的配置信息
Operator
同一个类中多条分类规则的逻辑关系
Rule(s)
类的分类规则
Behavior
策略里行为的名字及配置信息,参见behavior的相关命令
Mirror enable
流量镜像相关信息
Mirror type
Assured Forwarding
确保转发(AF队列)的相关信息
Bandwidth
队列的带宽
Matched
符合分类规则的数据包数目
Enqueued
入队包数/字节数
Discarded
降级包数/字节数
Filter enable
流量过滤相关信息。过滤功能可以配置允许(permit)和阻止(deny)两种方式
Marking
重标记的相关信息
Remark
重标记的类型。可支持的类型有DSCP、IP precedence、MPLS EXP等类型,相关类型描述请参考1.2  定义流行为的命令
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
name policy-name:显示指定策略名称的VLAN策略信息。policy-name表示策略名称,取值为1~31个字符的字符串。
vlan vlan-id:显示指定VLAN上应用的基于VLAN应用QoS策略的信息。vlan-id表示应用策略的VLAN ID。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。
inbound:显示对VLAN接收到的报文应用QoS策略信息。
outbound:显示对VLAN发送的报文应用QoS策略信息。
【描述】
display qos vlan-policy命令用来显示VLAN应用QoS策略的信息。
·     如果不指定显示方向,则同时显示出入两个方向基于VLAN应用QoS策略的信息。
·     如果不指定槽位号,则显示设备上所有基于VLAN应用QoS策略的信息。
# 显示6号单板上名字为test的QoS策略信息。
<Sysname> display qos vlan-policy name test slot 6
Policy user1
    Vlan 2: inbound
表1-9 display qos vlan-policy命令显示信息描述表
Policy
QoS策略名称
Vlan
引用QoS策略的VLAN ID
Inbound
对VLAN接收到的报文应用QoS策略
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: user1
   Classifier: class1
     Operator: AND
     Behavior: test
      Accounting Enable:
        0 (Packets)
        0 (Bytes)
        CIR 2000 (kbps), CBS 30000 (byte), EBS 100 (byte), PIR 25000 (kbps)
        Red Action: discard
        Green : 0(Bytes)
        Yellow: 0(Bytes)
        Red   : 0(Bytes)
      Marking:
        Remark dot1p COS 2
表1-10 display qos vlan-policy命令显示信息描述表
Vlan
引用QoS策略的VLAN ID
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
Accounting
流行为统计
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
EBS
PIR
峰值速率
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
undo qos apply policy [ policy-name ]  { inbound | outbound }
接口视图/端口组视图
【缺省级别】
2:系统级
inbound:入方向。
outbound:出方向。
policy policy-name:策略名,为1~31个字符的字符串。
【描述】
qos apply policy命令用来在接口上应用关联的策略。undo qos apply policy命令用来删除关联的策略。
除链路层协议为X.25、LAPB协议的接口外,所有物理接口都可以应用QoS策略。
在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效;在子接口视图下执行该命令,则该配置只在当前子接口生效。
需要注意的是,在接口视图/端口组视图下应用QoS策略后,如果该QoS策略的名称为inbound、outbound、inbound的前几个字符或outbound的前几个字符(不区分大小写),取消应用该QoS策略时,无法通过带策略名方式取消,只能通过不带策略名方式取消。
# 将策略USER1应用到接口GigabitEthernet2/1/1的出方向上。
[Sysname] interface GigabitEthernet2/1/1
[Sysname-GigabitEthernet2/1/1] qos apply policy USER1 outbound
undo qos apply policy [ policy-name ] global { inbound | outbound }
【缺省级别】
2:系统级
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
【描述】
qos apply policy global命令用来全局应用QoS策略,全局应用的QoS策略对全部流量生效。undo qos apply policy global命令用来取消全局应用的QoS策略。
·     基于全局应用QoS策略仅在MPE单板(仅入方向)和SPC单板上生效。
·     当全局应用QoS策略后,如果该QoS策略的名称为global或global的前几个字符(不区分大小写),取消应用该QoS策略时,无法通过带策略名方式取消,只能通过不带策略名方式取消。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.8  qos policy
qos policy policy-name
undo qos policy policy-name
【缺省级别】
2:系统级
policy policy-name:策略名。为1~31个字符的字符串。
【描述】
qos policy命令用来定义一个策略并进入策略视图。undo qos policy命令用来删除一个策略。
如果某接口应用了该策略,则不允许删除该策略,需要先在应用的接口上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
相关配置可参考命令classifier behavior和qos apply policy。
# 定义一个名为user1的策略。
undo qos vlan-policy [ policy-name ] vlan vlan-id-list { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略名称。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4093。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
【描述】
qos vlan-policy命令用来在指定VLAN上应用QoS策略。undo qos vlan-policy命令用来取消指定VLAN上应用的QoS策略。
需要注意的是,在指定VLAN应用QoS策略后,如果该QoS策略的名称为VLAN或VLAN的前几个字符(不区分大小写),取消应用该QoS策略时,无法通过带策略名方式取消,只能通过不带策略名方式取消。
# 在VLAN 200、300、400、500、600、700、800、900的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
【缺省级别】
1:监控级
inbound:入方向。
outbound:出方向。
【描述】
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
需要注意的是,本命令仅在SPC单板和MPE单板上生效。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
【缺省级别】
1:监控级
vlan-id:VLAN的ID号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除对VLAN发送的报文应用QoS策略的统计信息。
【描述】
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table [ dscp-dscp | inbound [ up-dp | up-lp | up-up] | outbound [ up-dp | up-fc | up-lp | up-rpr ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:接收报文方向优先级映射表。
outbound:发送报文方向优先级映射表。
up-up:用户优先级到用户优先级映射表。
up-dp:用户优先级到丢弃优先级映射表。
up-rpr:用户优先级到RPR优先级映射表。
up-fc:用户优先级到转发类映射表。
【描述】
display qos map-table命令用来显示指定优先级映射表配置情况。
如不指定表的类型,本命令将显示所有映射表的配置情况。
相关配置可参考命令qos map-table。
# 显示接收报文方向的用户优先级到本地优先级映射表的配置信息。
<Sysname> display qos map-table inbound up-lp
MAP-TABLE NAME: up-lp   TYPE: pre-define   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-1 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
DIRECTION
优先级映射表的方向
IMPORT
映射表的输入值
EXPORT
映射表的输出值
display qos map-table color [ green | yellow | red ] [ up-dot1p | up-dscp | up-lp | up-exp ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
color:带颜色优先级映射表。
green:绿色报文。
yellow:黄色报文。
red:红色报文。
【描述】
display qos map-table color命令用来显示指定带颜色优先级映射表配置情况。
·     如不指定表的类型,本命令将显示所有带颜色映射表的配置情况。
·     如不指定颜色,本命令将显示所有颜色的带颜色映射表的配置情况。
相关配置可参考命令qos map-table color。
# 显示绿色报文的用户优先级到802.1p优先级映射表的配置信息。
<Sysname> display qos map-table color green up-dot1p
MAP-TABLE NAME: up-dot1p   TYPE: pre-define   COLOR: green
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table color命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
COLOR
映射表的颜色
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.3  import
优先级映射表视图
【缺省级别】
2:系统级
import-value-list:映射输入参数列表。
export-value:映射输出参数。
all:删除该映射表所有参数。
【描述】
import命令用来配置指定优先级映射表参数,定义一条或一组映射规则。undo import命令用来删除指定映射索引所对应的映射项,被删除的映射条目恢复为系统缺省值。
在配置DSCP到DSCP的优先级映射规则时,只有奇数的映射输入参数所配置的映射关系能生效,偶数输入参数所配置的映射关系不生效,其实际映射效果与比其大1的奇数输入参数配置的映射效果一致。所以如果要配置偶数输入参数的映射关系,只能通过配置比其值大1的奇数输入参数的映射关系来实现。
# 配置DSCP优先级到DSCP优先级映射表参数,与DSCP优先级5相对应的DSCP优先级为1。
[Sysname] qos map-table dscp-dscp
[Sysname-maptbl-dscp-dscp] import 5 export 1
2.1.4  qos map-table
qos map-table { dscp-dscp | inbound { up-dp | up-lp | up-up } | outbound { up-dp | up-fc | up-lp | up-rpr } }
【缺省级别】
2:系统级
up-fc:用户优先级到转发类映射表。
【描述】
# 进入DSCP优先级到DSCP优先级映射表视图。
qos map-table color { green | red | yellow } { up-dot1p | up-dscp | up-lp | up-exp }
【缺省级别】
2:系统级
color:带颜色优先级映射表。
green:绿色报文。
yellow:黄色报文。
red:红色报文。
【描述】
qos map-table color命令用来进入指定的带颜色优先级映射表视图。
# 进入绿色报文的用户优先级到802.1p优先级映射表视图。
[Sysname] qos map-table color green up-dot1p
[Sysname-maptbl-green-up-dot1p]
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority priority-value
undo qos priority
接口视图/端口组视图
【缺省级别】
2:系统级
priority-value:端口优先级值,取值范围为0~7。
【描述】
qos priority命令用来配置当前端口的端口优先级。undo qos priority命令用来恢复端口优先级为缺省值。
端口优先级可以通过命令display qos trust interface来查看。
缺省情况下,端口优先级为0。
·     仅SPE单板支持在子接口上配置qos priority命令。
·     对于MPE单板,仅以太网接口、POS接口和ATM接口支持配置qos priority命令。
·     对于SPC单板,在主接口视图下执行该命令,则该配置在当前主接口及其所有子接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有主接口及其子接口生效;
·     对于SPE单板,在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有接口生效;在子接口视图下执行该命令,则该配置只在当前子接口生效。
·     对于MPE单板上的以太网接口、POS接口和ATM接口,在主接口执行该命令后,主接口及其下的所有子接口均生效。
# 配置以太网端口GigabitEthernet2/1/1的端口优先级为2。
[Sysname] interface GigabitEthernet 2/1/1
[Sysname-GigabitEthernet2/1/1] qos priority 2
2.3  端口优先级信任模式配置命令
display qos trust interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:接口号。
【描述】
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
如果不指定接口,本命令将显示所有接口的端口优先级信任模式信息。
# 显示GigabitEthernet2/1/1接口当前配置的端口优先级信任模式信息。
<Sysname> display qos trust interface GigabitEthernet 2/1/1
 Port priority information
  Port priority :0
  Port priority trust type : untrust
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Port priority
端口优先级
端口优先级信任类型
2.3.2  qos trust
qos trust auto
undo qos trust
接口视图/端口组视图
【缺省级别】
2:系统级
auto:表示根据报文的类型,自动提取报文中的优先级字段进行优先级映射。
·     在SPE单板上,对于二层报文,采用802.1p优先级;对于三层报文,采用IP优先级;对于MPLS报文,采用EXP。
·     在SPC单板和MPE单板上,对于只有非IP报文,采用802.1p优先级;对于IP报文,采用IP优先级;对于MPLS报文,采用EXP。
【描述】
qos trust auto命令用来配置端口优先级信任模式为auto模式。undo qos trust命令用来取消配置端口优先级信任模式为auto模式。
报文在进入设备以后,设备会根据自身支持的情况和相应的规则给报文分配包括802.1p优先级、DSCP、本地优先级、丢弃优先级等在内的一系列参数。
其中,本地优先级和丢弃优先级的概念如下:
·     本地优先级:设备为报文分配的一种具有本地意义的优先级,对应出端口队列序号;
·     丢弃优先级:在进行报文丢弃时参考的参数,2对应红色报文、1对应黄色报文、0对应绿色报文。
·     仅SPE单板支持在子接口上配置qos trust auto命令。
·     对于MPE单板上的以太网接口、POS接口和ATM接口,在主接口执行该命令后,主接口及其下的所有子接口均生效;
·     对于MPE单板上的串口,在该接口上执行此命令后,其对应的CE1接口或CPOS接口下的所有串口均生效,如果该串口是第一个CE1接口或CPOS接口下的串口,则其对应子卡上的所有的MP-group接口均生效;
·     对于MPE单板上的MP-group接口,在该接口上执行此命令后,其对应子卡上的所有的MP-group接口以及第一个CE1接口或CPOS接口下的所有串口均生效。
# 在以太网端口GigabitEthernet2/1/1上配置优先级信任模式为auto模式。
[Sysname-GigabitEthernet2/1/1] qos trust auto
3 流量整形和接口限速
3.1  流量整形配置命令
display qos gts interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定的接口类型和接口编号。
【描述】
display qos gts interface命令用来显示某个接口或所有接口的GTS配置情况。
如不指定接口,本命令将显示所有接口的GTS配置情况和运行统计信息。
需要注意的是:在接口上开启流量整形后,接口上是否显示GTS配置情况和统计信息与接口状态(开启还是关闭)没有关系。
# 显示指定接口的GTS配置情况和统计信息。
<Sysname> display qos gts interface GigabitEthernet2/1/5
Interface: GigabitEthernet2/1/5
 Rule(s): If-match any
 CIR 160 (kbps), CBS 10240 (byte)
表3-1 display qos gts interface命令显示信息描述表
Rule(s)
匹配规则
CIR
承诺信息速率,单位为kbps
CBS
3.1.2  qos gts any
qos gts any cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts any
接口视图/端口组视图
【缺省级别】
2:系统级
any:对所有的数据包进行流量整形。
cir committed-information-rate:承诺信息速率,单位为kbps。接口类型不同,committed-information-rate的取值范围有所不同,具体如下:
·     在千兆以太网接口(即GE接口)或对应的三层以太网子接口上,取值范围为300~1000000;
·     在万兆以太网接口(即10GE接口)或对应的三层以太网子接口上,取值范围为2500~10000000;
·     在链路类型非FR的POS接口上,取值范围为300~10000000;
·     在MP-group接口或链路类型非FR的串口上,取值范围为40~1000000。
cbs committed-burst-size:承诺突发尺寸,单位为byte,其生效值为1024的整数倍。接口类型不同,committed-burst-size的取值范围和缺省情况有所不同,具体如下:
·     在以太网接口或三层以太网子接口上,取值范围为4096~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在链路类型非FR的POS接口上,取值范围为1024~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在MP-group接口或链路类型非FR的串口上,取值范围为1024~15360,缺省值为1024。
【描述】
qos gts any命令用来为接口下所有流配置流量整形。undo qos gts any命令用来取消对接口下所有流的整形设置。
缺省情况下,接口上没有配置流量整形。
·     qos lr与qos gts any命令不能在同一接口、端口组或子接口上同时配置。
·     支持qos gts any命令的子接口,目前仅包括SPE单板上的三层以太网子接口、MPE单板的接口子卡MIC-GP4L上的三层以太网子接口。
·     qos gts any命令在MFR接口、链路类型为FR的POS接口和链路类型为FR的串口上不生效。
# 为通过GigabitEthernet2/1/1接口的所有流配置流量整形,流量整形的参数为:承诺信息速率为640kbps;承诺突发尺寸为1024000bytes。
[Sysname-GigabitEthernet2/1/1] qos gts any cir 640 cbs 1024000
3.1.3  qos gts queue
qos gts queue queue cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts queue queue
接口视图/端口组视图
【缺省级别】
2:系统级
queue queue-number:对队列上的数据包进行流量整形。queue用于指定队列,可以使用数字或关键字表示,两者对应关系:
表3-2 队列参数描述表
关键字
队列号(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
·     在千兆以太网接口(即GE接口)上,取值范围为300~1000000;
·     在万兆以太网接口(即10GE接口)上,取值范围为2500~10000000;
·     在E-CPOS通道化出的串口上,取值范围为40~1000000。
·     在以太网接口上,取值范围为4096~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在E-CPOS通道化出的串口上,取值范围为1024~15360,缺省值为1024。
【描述】
qos gts queue命令用来为某一队列的流配置流量整形。undo qos gts queue命令用来取消对某一队列的整形设置。
缺省情况下,接口上没有配置流量整形。
在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
·     qos gts queue命令仅在以太网主接口和POS主接口上支持。
·     qos gts queue命令在链路类型为FR的POS接口上不生效。
# 配置在GigabitEthernet2/1/1队列af1上的报文进行流量整形,流量整形的参数为:承诺信息速率为640kbps;承诺突发尺寸为1024000bytes。
[Sysname-GigabitEthernet2/1/1] qos gts queue af1 cir 640 cbs 1024000
3.2  接口限速配置命令
display qos lr interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos lr interface命令用来显示某个或者全部接口的LR配置情况。
如不指定接口,本命令将显示所有接口的LR配置情况。
需要注意的是:在接口上开启接口限速后,接口上是否显示接口限速配置情况与接口状态(开启还是关闭)没有关系。
# 显示指定接口的接口限速配置情况。
<Sysname> display qos lr interface GigabitEthernet2/1/5
 Direction: Outbound
 CIR 300 (kbps), CBS 18750 (byte)
表3-3 display qos lr命令显示信息描述表
Direction
指明物理接口限速的方向是入接口还是出接口
CIR
承诺信息速率,单位为kbps
CBS
3.2.2  qos lr
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
接口视图/端口组视图
【缺省级别】
2:系统级
outbound:对接口发送的数据流进行限速。
【描述】
qos lr命令用来限制物理接口发送数据的速率。undo qos lr命令用来取消限制。
缺省情况下,接口上没有限制物理接口发送数据的速率。
·     支持本命令的子接口,目前仅包括SPE单板上的三层以太网子接口、MPE单板的接口子卡MIC-GP4L上的三层以太网子接口。
·     qos lr命令在MFR接口、链路类型为FR的POS接口和链路类型为FR的串口上不生效。
# 配置在GigabitEthernet2/1/1上发出的报文进行限速,接口限速的参数为:承诺信息速率为640kbps;承诺突发尺寸为1024000bytes。
[Sysname-GigabitEthernet2/1/1] qos lr outbound cir 640 cbs 1024000
4 硬件实现拥塞管理
4.1  队列调度策略配置命令
本章节的命令,仅MPE单板的接口子卡MIC-GP8L 和SPC单板支持。
display qos qmprofile configuration [ profile-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。
【描述】
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
如果不指定队列调度策略的名称,将显示所有队列调度策略的配置情况。
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile
 Queue ID    Type    Group    Weight
 0           SP      N/A      N/A
 1           SP      N/A      N/A
 2           SP      N/A      N/A
 3           SP      N/A      N/A
 4           SP      N/A      N/A
 5           SP      N/A      N/A
 6           WRR     1        200
 7           SP      N/A      N/A
表4-1 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)
Group
WRR优先组,N/A表示无效
Weight
调度权重,N/A表示无效
display qos qmprofile interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
如果不指定接口,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 3/0/1
Interface: GigabitEthernet3/0/1
表4-2 display qos qmprofile interface命令显示信息描述表
接口名称
队列调度策略名称
undo qos apply qmprofile
以太网接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos apply qmprofile命令用来在接口上应用队列调度策略。undo qos apply qmprofile命令用来恢复接口缺省的队列调度策略。
缺省情况下,SPC单板接口1、2、3、4队列使用加权轮询调度,0、5、6、7队列使用严格优先级调度;MPE单板的0~7队列采用严格优先级调度。
·     每个接口只能应用一个队列调度策略。
·     本命令不支持在子接口上进行配置。
# 在GigabitEthernet3/0/1接口上应用队列调度策略myprofile。
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos apply qmprofile myprofile
4.1.4  qos qmprofile
qos qmprofile profile-name
undo qos qmprofile profile-name
【缺省级别】
2:系统级
【描述】
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入队列调度策略视图。undo qos qmprofile命令用来删除用户自定义的队列调度策略。
需要注意的是,不能删除已经应用到接口的队列调度策略,必须先在应用的接口上取消对该队列调度策略的应用,然后再删除该队列调度策略。
对于刚创建的队列调度策略,缺省情况是1、2、3、4队列加入WRR组优先组1使用加权轮询调度,0、5、6、7队列使用严格优先级调度。
# 创建自定义的队列调度策略myprofile,并进入队列调度策略视图。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile]
4.1.5  queue
queue queue-number { sp | wrr group group-id weight weight-value }
undo queue queue-number
队列调度策略视图
【缺省级别】
2:系统级
queue-number:队列号,取值范围0~7。
sp:配置队列为严格优先级调度。
wrr:配置队列为加权轮询调度。
group-id:WRR优先组号,取值范围1~2。
weight-value:调度权重,取值范围1~63。
【描述】
queue命令用来配置指定队列的调度策略。undo queue命令用来删除指定队列的调度策略。
需要注意的是:每个WRR组内的队列号应该连续,否则可能出现调度不准确。
# 创建自定义的队列调度策略myprofile,并配置队列1为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 1 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为20,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 20
4.2  WFQ队列配置命令
WFQ队列的相关内容,仅SPE单板支持,SPC单板和MPE单板不支持。
display qos wfq interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wfq interface命令用来显示接口的WFQ(Weighted Fair Queuing,加权公平队列)队列配置情况。
如不指定接口,本命令将显示所有接口的WFQ队列配置情况。
相关配置可参考命令qos wfq。
# 显示接口GigabitEthernet2/1/1的WFQ队列配置情况。
<Sysname> display qos wfq interface GigabitEthernet 2/1/1
Output queue: Hardware weighted fair queue
Queue ID    Weight            Min-Bandwidth
  be        1                 NA
  af1       1                 2000
  af2       1                 NA
  af3       1                 NA
  af4       1                 NA
  ef        1                 NA
  cs6       1                 NA
  cs7       1                 NA
表4-3 display qos wfq interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Weight
调度时各个队列的权重
Min-Bandwidth
队列的最小保证带宽值,单位是kbps,NA表示没有配置此内容
qos bandwidth queue queue-number min bandwidth-value
undo qos bandwidth queue queue-number [ min bandwidth-value ]
接口视图/端口组视图
【缺省级别】
2:系统级
queue-number :端口队列序号。可以使用数字或关键字表示,两者对应关系请参见表4-4。队列0(be队列)配置bandwidth不生效。
表4-4 队列参数描述表
关键字
队列号(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
min bandwidth-value:端口流量拥塞时能够保证的最小队列带宽值,单位为kbps。
【描述】
qos bandwidth queue命令用来配置端口队列的最小保证带宽值。undo qos bandwidth queue命令用来取消端口队列配置的最小保证带宽值。
缺省情况下,接口上没有配置最小保证带宽值。
·     在ATM接口下配置本命令,会对该ATM接口下的所有PVC生效。
·     在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
·     SPC单板和MPE单板不支持本命令。
·     目前,本命令不支持在子接口上进行配置。
# 在GigabitEthernet2/1/1上配置队列1的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet2/1/1] qos bandwidth queue 1 min 100
qos wfq queue-number weight schedule-value
undo qos wfq queue-number weight
接口视图/端口组视图
【缺省级别】
2:系统级
queue-number:指定的队列,可以使用数字或关键字表示,两者对应关系请参见表4-4。
weight schedule-value:配置队列的调度权重。schedule-value的取值范围为1~63。
【描述】
qos wfq weight命令用来在接口上配置WFQ队列的队列调度权重值。undo qos wfq weight命令用来将队列调度权重值恢复为缺省情况。缺省情况下,WFQ权重值为1。
相关配置可参考命令display qos wfq interface。
·     支持本命令的子接口,目前仅包括SPE单板上的三层以太网子接口。
# 在GigabitEthernet2/1/1上配置队列3和队列4的调度权重分别为20、30。
[Sysname-GigabitEthernet2/1/1] qos wfq 3 weight 20
[Sysname-GigabitEthernet2/1/1] qos wfq 4 weight 30
4.3  基于类的队列配置命令
·     基于类的队列的相关配置命令,仅MPE单板的三层接口(除MIC-GP8L接口子卡外)和SPE单板支持,SPC单板不支持。
·     当设备作为MPLS L2VPN或VPLS的PE设备,且MPE单板的MIC-GP4L子卡上的接口作为AC侧接口时,不支持CBQ。
4.3.1  queue af
queue af bandwidth bandwidth
undo queue af
流行为视图
【缺省级别】
2:系统级
bandwidth:用户定义的需要确保转发的流量保证带宽,范围为64~10000000,单位是kbps。
【描述】
queue af bandwidth命令用来配置类进行确保转发(Assured-Forwarding),并指定可确保的带宽。undo queue af命令用来取消配置。
当在策略下将类与queue af所属行为关联时,必须满足:同一个策略下为确保转发(queue af)和加速转发(queue ef)的类指定的带宽之和必须不大于该策略所应用接口的可用带宽。
相关配置可参考命令queue ef。
# 配置af的流量保证带宽为5M。
[Sysname] traffic behavior af_behav
[Sysname-behavior-af_behav] queue af bandwidth 5000
[Sysname-behavior-af_behav] quit
4.3.2  queue ef
queue ef bandwidth bandwidth [ cbs burst ]
undo queue ef
流行为视图
【缺省级别】
2:系统级
bandwidth:用户定义的需要加速转发的流量保证带宽,范围为64~10000000,单位是kbps。
cbs burst:承诺突发尺寸,即实际平均速率在用户定义带宽以内时的突发流量,取值范围为1600~1000000000字节。缺省值为bandwidth的25倍。用户配置的承诺突发尺寸不允许小于50ms承诺信息速率的流量,以避免令牌桶突发速率太小,影响网络流量的突发特征。
【描述】
queue ef bandwidth命令用来配置加速转发(Expedited-forwarding)的流量保证带宽。
相关配置可参考命令queue af。
# 配置ef的流量保证带宽为30M。
[Sysname] traffic behavior ef_behav
[Sysname-behavior-ef_behav] queue ef bandwidth 30000
[Sysname-behavior-ef_behav] quit
4.3.3  queue wfq
queue wfq
undo queue wfq
流行为视图
【缺省级别】
2:系统级
无
【描述】
queue wfq命令用来为缺省类配置采用公平队列。undo queue wfq命令用来取消配置。
# 为用户配置的进入BE队列的类配置WFQ。
[Sysname] traffic behavior be_behav
[Sysname-behavior-be_behav] queue wfq
4.3.4  wred
wred [ dscp | ip-precedence ]
undo wred
流行为视图
【缺省级别】
2:系统级
dscp:表明在为一个包计算丢弃概率时使用的是DSCP值
ip-precedence:表明在为一个包计算丢弃概率时使用的是IP优先级值,作为缺省配置
【描述】
wred命令用来配置丢弃方式为加权随机早期检测。undo wred命令用来取消该配置。
该命令必须在配置了queue af或queue wfq后使用。
# 为AF队列配置WRED。
[Sysname-behavior-af_behav] wred
4.3.5  weight
weight weight-value
undo weight
流行为视图
【缺省级别】
2:系统级
weight-value:权重的值。
【描述】
weight命令用来配置队列权重值。undo weight命令用来恢复缺省情况。
缺省情况下,AF、WFQ队列的权重值都为1。
相关配置可参考命令qos policy、traffic behavior、classifier behavior、queue af和queue wfq。
·     本命令仅MPE单板支持。
·     设备提示的取值范围为1~255,但是实际能生效取值范围为1~63。
·     该命令在流行为视图下不能单独使用,必须与queue af、queue wfq两者中的一条配合使用。
# 配置流行为database1采用AF,最小可保证带宽为200kbps,权重为62。超过200kbps之外的流量和WFQ之间进行加权调度。
[Sysname] traffic behavior database1
[Sysname-behavior-database1] queue af bandwidth 200
[Sysname-behavior-database1] weight 62
5 拥塞避免
5.1  WRED配置命令
WRED的相关内容,仅MPE单板(除MIC-GP8L接口子卡外)和SPE单板支持,SPC单板不支持。
display qos wred interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wred interface命令用来显示指定接口或所有接口的WRED配置情况和统计信息。
如果不指定接口,本命令将显示所有接口的WRED配置情况和统计信息。
# 显示指定接口的WRED配置情况。
<Sysname> display qos wred interface GigabitEthernet 2/1/1
 Current WRED configuration:
 Applied WRED table name: 123
表5-1 display qos wred interface命令显示信息描述表
当前WRED的配置情况
应用的WRED表名
5.2  WRED表配置命令
display qos wred table [ table-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
table-name:要显示的WRED表的名字。
【描述】
display qos wred table命令用来显示WRED表的配置情况。
如果不指定表名字,本命令将显示所有已配置的WRED表的配置情况。
# 显示WRED表的配置情况。
<Sysname> display qos wred table 1
Table Name: 1
Table Type: Queue based WRED
QID:  gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent
 0 10224  10240   100 10224  10240   100 10224  10240   100      8
 1 10224  10240   100 10224  10240   100 10224  10240   100      8
 2 10224  10240   100 10224  10240   100 10224  10240   100      8
 3 10224  10240   100 10224  10240   100 10224  10240   100      8
 4 10224  10240   100 10224  10240   100 10224  10240   100      8
 5 10224  10240   100 10224  10240   100 10224  10240   100      8
 6 10224  10240   100 10224  10240   100 10224  10240   100      8
 7 10224  10240   100 10224  10240   100 10224  10240   100      8
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列号
gmin
绿色报文下限阈值
gmax
绿色报文上限阈值
gprob
绿色报文最大丢弃概率
ymin
黄色报文下限阈值
ymax
黄色报文上限阈值
yprob
黄色报文最大丢弃概率
rmin
红色报文下限阈值
rmax
红色报文上限阈值
rprob
红色报文最大丢弃概率
exponent
计算平均队列长度指数
undo qos wred table table-name
【缺省级别】
2:系统级
queue:基于队列的表,拥塞时根据报文所在队列进行随机丢弃。
table table-name:指定表的名字,为1~32个字符的字符串。
【描述】
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。undo qos wred table命令用来删除全局WRED表。
缺省情况下,没有全局WRED表存在。
设备不允许删除正在使用的表。
相关配置可参考命令display qos wred table和display qos wred interface。
# 创建WRED表exp-table1。
[Sysname] qos wred queue table exp-table1
[Sysname-wred-table-exp-table1]
5.2.3  queue
queue queue-number [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-number | all }
WRED表视图
【缺省级别】
2:系统级
queue-number:队列编号。
drop-level drop-level:丢弃级别,如果没有指定,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:优先级的WRED下限,low-limit的缺省值为10224。
high-limit high-limit:优先级的WRED上限,high-limit的缺省值为10240。
discard-probability discard-prob:丢弃概率的分母,每一个丢弃级别都有自己独立的丢弃概率分母,discard-prob的缺省值为100。
【描述】
queue命令用来编辑基于queue的WRED表的内容。undo queue命令用来恢复WRED表的内容为缺省值。
缺省情况下,基于队列的WRED全局表有一套可用的缺省参数。
相关配置可参考命令qos wred table。
# 修改基于queue的全局WRED表queue-table1的队列1的丢弃级别为1的数据包的丢弃参数。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue queue-number weighting-constant exponent
undo queue queue-number weighting-constant
WRED表视图
【缺省级别】
2:系统级
queue-number:队列编号。
weighting-constant exponent:计算平均队列长度的指数,取值范围为0~21。缺省情况下,该指数取值为8。需要注意的是,MPE单板支持的取值范围为0~15。
【描述】
queue weighting-constant命令用来配置基于queue的WRED表的平均队列长度的指数,undo queue weighting-constant命令用来恢复基于queue的WRED表平均队列长度指数为缺省值。
# 配置基于queue的WRED表的平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
qos wred apply table-name
undo qos wred apply
接口视图/端口组视图
【缺省级别】
2:系统级
table-name:WRED全局表的名字。
【描述】
qos wred apply命令用来在接口上应用WRED全局表。undo qos wred apply命令用来恢复端口缺省的尾丢弃模式,它同时取消WRED表的应用。
缺省情况下,端口采用尾丢弃。
在接口视图下执行该命令,则该配置只在当前端口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效;在子接口视图下执行该命令,则该配置只在当前子接口生效。
相关配置可参考命令display qos wred interface、display qos wred table和qos wred table。
需要注意的是,支持本命令的子接口,目前仅包括SPE单板上的三层以太网子接口、MPE单板的接口子卡MIC-GP4L上的三层以太网子接口。
# 在接口GigabitEthernet2/1/1上应用基于队列的表queue-table1。
[Sysname-GigabitEthernet2/1/1] qos wred apply queue-table1
6 聚合CAR
6.1  聚合CAR配置命令
6.1.1  car name
car name car-name
undo car
流行为视图
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
car name命令用来配置流行为的聚合CAR动作。undo car用来删除流行为的流量监管动作。
# 配置流行为be1的聚合CAR动作为aggcar-1。
display qos car name [ car-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
car-name:聚合CAR的名称。
【描述】
display qos car name命令用来显示聚合CAR的配置和统计信息。
·     如果输入car-name参数,将显示指定聚合CAR的配置和统计信息。
·     如果不输入car-name参数,将显示所有聚合CAR的配置和统计信息。
# 显示聚合CAR aggcar-1的配置信息。
<Sysname> display qos car name aggcar-1
  Mode: aggregative
 CIR 200(kbps)  CBS: 2000(byte)  EBS: 40000(byte)  PIR: 2000(kbps)
  Red Action: discard
  Green packet 2000(Bytes)
  Yellow packet 400(Bytes)
  Red packet 6000(Bytes)
表6-1 display qos car name命令显示信息描述表
Name
流量监管的名称
Mode
流量监管的类型
CIR  CBS  EBS  PIR
流量监管流量的参数配置
Red Action
对红色报文的动作
Green packet
绿色报文的流量统计
Yellow packet
黄色报文的流量统计
Red packet
红色报文的流量统计
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ red { discard | pass } ]
undo qos car car-name
【缺省级别】
2:系统级
car-name:聚合CAR的名称,取值为1~31个字符的字符串。
aggregative:标明该全局CAR为聚合模式,目前只支持聚合CAR。
cir committed-information-rate:承诺信息速率,committed-information-rate的取值范围为64~10000000,单位为kbps。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,committed-burst-size的取值范围为1875~1000000000字节。缺省值为大约500ms内承诺信息速率的流量。用户配置的承诺突发尺寸不允许小于50ms承诺信息速率的流量,以避免令牌桶突发速率太小,影响网络流量的突发特征。
ebs excess-burst-size:超出突发尺寸,excess-burst-size的取值范围为0~1000000000字节。
pir peak-information-rate:峰值速率,peak-information-rate的取值范围为64~10000000 kbps。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
【描述】
qos car aggregative命令用来配置聚合CAR。undo qos car命令用来取消聚合CAR的配置。
聚合CAR配置需要在策略中引用后才能生效。
对于丝印为SPE-1010、SPE-1020、SPE-1010-E和SPE-1020-E的单板,报文(如IPv4/IPv6单播报文、组播报文、隧道报文、L3VPN入隧道报文)进行三层转发时,qos car aggregative命令中的报文长度只计算报文IP首部和载荷的长度。qos car aggregative命令中配置的端口速率参数,配置的速率值与理论输出速率值对应的计算方式如下(以三层转发报文的长度为128字节,配置的速率值为10000 kbps为例):
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
reset qos car name命令用来清除聚合CAR的统计信息。
·     如果输入car-name参数,将清除指定聚合CAR的统计信息。
·     如果不输入car-name参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的配置信息。
<Sysname> reset qos car name aggcar-1
7 报文统计
7.1  报文统计配置命令
报文统计的配置命令,仅SPC单板和MPE单板且单板上的端口工作在二层模式时才支持,SPE单板不支持。
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:入方向的报文统计计数器。
outbound:出方向的报文统计计数器。
counter0:计数器0。
counter1:计数器1。
slot-number:显示指定单板计数器统计的流量信息,slot-number表示单板槽位号。
【描述】
display qos traffic-counter命令用来显示计数器统计的流量信息,同时显示该组计数器的配置信息。
# 显示4号槽位单板出方向上的报文统计信息。
<Sysname> display qos traffic-counter outbound counter0 slot 4
Slot 4 outbound counter0 mode:
 Interface: all
 VLAN: all
 Local precedence: all
 Drop priority: all
Traffic-counter summary:
 Unicast: 0 packets
 Multicast: 0 packets
 Broadcast: 0 packets
 Control packets: 2 packets
 Bridge egress filtered packets: 0 packets
 Tail drop packets: 0 packets
 Multicast Tail drop packets: 6 packets
 Forward restrictions packets: 0 packets
表7-1 display qos traffic-counter outbound命令显示信息描述表
4槽位单板上计数器0统计出方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
Local precedence
本计数器所统计的本地优先级
Drop priority
本计数器所统计的丢弃优先级
本计数器统计信息汇总
Unicast
单播报文数
Multicast
多播报文数
Broadcast
广播报文数
Control packets
控制报文和镜像报文统计
出方向桥(二层)过滤报文统计(包括VLAN过滤和STP Block报文)
Tail drop packets
单播报文拥塞尾丢弃统计
组播、广播报文拥塞尾丢弃统计
转发的限制报文数(目前,该项暂不支持)
# 显示1号槽位单板入方向上的报文统计信息。
<Sysname> display qos traffic-counter inbound counter0 slot 1
Slot 1 inbound counter0 mode:
 Interface: all
 VLAN: all
 Bridge in frames: 5490000 packets
 Bridge local discarded: 0 packets
 Bridge vlan ingress filter discarded: 0 packets
 Bridge security filter discarded: 0 packets
表7-2 display qos traffic-counter inbound命令显示信息描述表
1槽位单板上计数器0统计入方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
本计数器统计信息汇总
Bridge in frames
桥(二层)接收到的报文个数
桥(二层)丢弃报文个数(除了桥安全过滤和VLAN入方向过滤外的其他原因丢弃的报文数)
VLAN入方向过滤报文数
桥(二层)安全过滤报文数
qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ interface interface-type interface-number ] [ vlan vlan-id ] [ local-precedence lp-value ] [ drop-priority dp-value ]
undo qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
【缺省级别】
2:系统级
counter0:计数器0。
counter1:计数器1。
slot-number:单板槽位号。
interface-type interface-number:指定绑定的接口类型和接口编号。
vlan-id:VLAN的编号,取值范围为1~4093。
local-precedence:本地优先级,取值范围为0~7。
drop-priority:丢弃优先级,取值范围为0~2。
【描述】
qos traffic-counter命令用来使能报文统计功能。undo qos traffic-counter命令用来关闭报文统计功能。
缺省情况下,报文统计功能处于关闭状态。
一块单板提供两个计数器用于统计单板流量,监控的对象可以是指定端口、VLAN、本地优先级和丢弃优先级的报文。
·     当不指定端口时,则监控单板上所有端口的流量。
·     当不指定VLAN时,则监控单板上所有VLAN的流量。
·     当不指定本地优先级时,则监控单板上所有本地优先级的流量。
·     当不指定丢弃优先级时,则监控单板上所有丢弃优先级的流量。
使用qos traffic-counter命令重新设置某单板的监控对象后,计数器的值会自动清零。
# 使能4号槽位的计数器0的报文统计功能,统计GigabitEthernet4/0/1端口的出方向流量。
[Sysname] qos traffic-counter outbound counter0 slot 4 interface gigabitethernet 4/0/1
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
【缺省级别】
2:系统级
counter0:计数器0。
counter1:计数器1。
slot-number:单板槽位号。
【描述】
reset qos traffic-counter命令用来清除报文统计计数器的统计值。
# 清除4号槽位的出方向报文统计计数器的统计值。
<Sysname> reset qos traffic-counter outbound counter0 slot 4
8 端口队列统计
8.1  端口队列显示命令
display qos queue-statistics interface [ interface-type interface-number ] [ pvc { pvc-name [ vpi/vci ] | vpi/vci } ] [ dlci dlci-number ] [ outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定接口类型和编号。
pvc:只用于ATM接口,即显示ATM接口上的指定PVC的信息。
pvc-name:PVC名。
vpi/vci:VPI/VCI值。
dlci dlci-number:为帧中继接口分配的虚电路号。dlci-number取值范围为16~1007。当指定接口封装的链路层协议为帧中继时,才支持此参数。
outbound:显示出方向上的端口队列统计信息。
【描述】
display qos queue-statistics interface命令用来显示端口队列统计信息。
·     如果不指定接口,将显示所有接口的队列统计信息。
·     统计信息可通过reset counters interface命令清除,关于此命令的介绍请参见“接口管理命令参考”中的“以太网接口”。
·     如果接口上配置了HQoS,则本命令无法显示该接口上的队列统计信息。
·     对于MPE单板,如果在除以太网主接口外的其他类型接口上配置了CBQ,则本命令无法显示该接口上的队列统计信息。
# 显示接口GigabitEthernet2/1/3的出方向队列统计信息。
<Sysname>display qos queue-statistics interface GigabitEthernet 2/1/3
Interface: GigabitEthernet2/1/3
Direction: Outbound
    Pass: 0 packets, 0 bytes
    Drop: 0 packets, 0 bytes
  Data Flow:
    Queue 0:
      Total queue length  : 4096 packets
      Current queue length: 0 packets, 0% use ratio
    Queue 1:
      Total queue length  : 2048 packets
    Queue 2:
    Queue 3:
    Queue 4:
    Queue 5:
      Total queue length  : 512 packets
    Queue 6:
    Queue 7:
      Total queue length  : 8192 packets
表8-1 display qos queue-statistics interface命令显示信息描述表
统计的接口
Direction
端口队列统计的方向
Pass
转发的数据包数和字节数
Drop
丢弃的数据包数和字节数
Data Flow
数据流统计信息
Queue
队列编号
Total queue length
队列总长度
当前队列长度
use ratio
队列使用率
9 QoS管道模式
9.1  QoS管道模式配置命令
9.1.1  qos pipe-mode
qos pipe-mode
undo qos pipe-mode
【缺省级别】
2:系统级
无
【描述】
qos pipe-mode命令用来配置QoS管道模式。undo qos pipe-mode命令用来取消QoS管道模式。
缺省情况下,设备未配置QoS管道模式。
配置QoS管道模式后,可以确保报文在经过以下任意一种网络后:
·     在MPLS L2VPN网络;
·     在MPLS L3VPN网络;
·     在VPLS网络;
所携带的DSCP优先级字段不会被改变,从而不影响下游设备对该IP报文的转发调度。关于此功能的详细介绍请参见配置指导中的“QoS”。
·     本命令仅在SPC单板和MPE单板上支持。
·     QoS管道模式配置后,在SPC单板和MPE单板上配置的优先级配置命令(包括qos priority、qos trust)不生效。
# 配置QoS管道模式。
[Sysname] qos pipe-mode
