- 06-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-EIGRP configuration
- 07-BGP configuration
- 08-Policy-based routing configuration
- 09-IPv6 static routing configuration
- 10-RIPng configuration
- 11-OSPFv3 configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
- 14-DCN configuration
| 07-BGP configuration | 4.55 MB |
Categories of BGP path attributes
BGP route processing mechanism
Settlements for problems in large-scale BGP networks
BGP route redistribution into local VPN instances
Basic BGP network configuration tasks at a glance (IPv4 unicast/IPv4 multicast)
Basic BGP network configuration tasks at a glance (IPv6 unicast/IPv6 multicast)
Configuring an IBGP peer group
Configuring an EBGP peer group
Specifying the source address of TCP connections
Controlling BGP route generation, advertisement, and reception
Redistributing routes from a non-BGP protocol
Redistributing the local network specified in the public instance or a VPN instance
Configuring BGP route summarization
Advertising optimal routes in the IP routing table
Advertising a default route to a peer or peer group
Limiting routes received from a peer or peer group
Configuring BGP IPv4 unicast route and BGP IPv4 labeled unicast route redistribution
Enabling prioritized withdrawal of the default route
Enabling prioritized withdrawal of specific routes
Configuring BGP route distribution filtering policies
Setting the BGP route sending rate
Configuring BGP route reception filtering policies
Configuring BGP route update delay
Setting the update interval and the maximum number of update messages that can be sent each time
Configuring a startup policy for BGP route updates
Configuring the link bandwidth attribute
Configuring the keepalive interval and hold time
Setting the session retry timer
Configuring the interval for sending updates for the same route
Setting the refresh route advertisement delay timer
Setting an update delay for local MPLS labels
Configuring BGP logging and notifications
Enabling logging for session state changes
Enabling logging for BGP route flapping
Configuring BGP network management
Display and maintenance commands for basic BGP network building
Basic IPv4 BGP network configuration examples
Example: Configuring basic BGP
Example: Configuring BGP and IGP route redistribution
Example: Configuring dynamic BGP peers
Example: Configuring BGP route summarization
Example: Configuring multicast BGP
Example: Separating unicast traffic and multicast traffic
Example: Configuring multiple BGP instances on one router
Basic IPv6 BGP network configuration examples
Example: Configuring IPv6 BGP basics
Example: Configuring IPv6 multicast BGP
Configuring large-scale BGP networks
Large-scale BGP network configuration tasks at a glance
Configuring BGP route dampening
Configuring BGP route reflection
Configuring a BGP route reflector
Ignoring the ORIGINATOR_ID attribute
Clearing the route reflection attributes of a route before forwarding the route
Configuring BGP confederation settings
Configuring a BGP confederation
Configuring confederation compatibility
Display and maintenance commands for large-scale BGP network configuration
Large-scale BGP network configuration examples
Example: Configuring BGP communities
Example: Configuring BGP route reflector
Example: Configuring BGP confederation
Controlling BGP path selection
BGP path selection control tasks at a glance
Setting a preferred value for received routes
Configuring the preferred value as 0 for BGP routes generated from redistributed routes
Configuring preferences for BGP routes
Configuring the default local preference
Configuring the default MED value
Enabling MED comparison for routes from different ASs
Enabling MED comparison for routes on a per-AS basis
Enabling MED comparison for routes from confederation peers
Configuring the NEXT_HOP attribute
Setting the local device IP as the next hop for routes sent to a peer or peer group
Disabling nexthop changing for routes advertised to a peer or peer group
Configuring the AS_PATH attribute
Permitting local AS number to appear in routes from a peer or peer group
Ignoring the AS_PATH attribute during optimal route selection
Advertising a fake AS number to a peer or peer group
Configuring AS number substitution
Removing/replacing private AS numbers in BGP updates
Ignoring the first AS number of EBGP route updates
Setting an AS number quantity threshold
Configuring the AIGP attribute
Preferring routes learned from a peer or peer group during optimal route selection
Preferring BGP routes of a specific next hop IP type
Ignoring IGP metrics during optimal route selection
Ignoring router IDs during optimal route selection
Configuring the next hop type selection rule for optimal route selection
About tunnel-type recursive next hops
Configuring the condition for BGP routes to participate in optimal route selection
Preferring BGP routes of a specific recursive next hop type during optimal route selection
Changing the BGP route selection rule when the device receives routes from different EBGP peers
Display and maintenance commands for BGP path selection control
BGP path selection control configuration examples
Example: Configuring BGP path selection based on the LOCAL_PREF attribute
Example: Configuring route selection based on the MED attribute
Example: Configuring route selection based on the AS_PATH attribute
Example: Changing the preference value for a BGP route
Tuning and optimizing BGP networks
BGP network tuning and optimization tasks at a glance
Configuring path MTU discovery and MSS for TCP connections
Enabling path MTU discovery for TCP connections
Setting the TCP MSS for TCP connections
Enabling BGP to establish an EBGP session over multiple hops
Enabling immediate re-establishment of direct EBGP connections upon link failure
Protecting an EBGP peer when memory usage reaches level 2 threshold
Enabling prefix-based BGP ORF capabilities negotiation
Enabling BGP ORF capabilities negotiation for a peer or peer group
Enabling nonstandard BGP ORF capabilities negotiation for a peer or peer group
Enabling 4-byte AS number suppression
Enabling BGP to negotiate the extended message capability with peers
Disabling BGP session establishment
About disabling BGP session establishment
Disabling BGP session establishment with a peer or peer group (IPv4 peers)
Disabling BGP session establishment with a peer or peer group (IPv6 peers)
Disabling BGP session establishment with all peers or peer groups
Enabling route refresh (IPv4 peers)
Enabling route refresh (IPv6 peers)
Configuring BGP soft-reset by saving route updates
Saving updates (IPv4 unicast/multicast address family)
Saving updates (IPv6 unicast/multicast address family)
Configuring manual soft-reset (IPv4 unicast/multicast address family)
Configuring manual soft-reset (IPv6 unicast/multicast address family)
Configuring BGP load balancing
Configuring the BGP Additional Paths feature
Configuring BGP optimal route selection delay
Setting the delay time for responding to recursive next hop changes
Configuring route recursion suppression
Specifying the longest match principle for next hop recursion
Recursing public-network BGP routes to tunnels
Disabling BGP from checking the next hop addresses of EBGP routes received from a peer or peer group
Configuring peer flap dampening
Setting a DSCP value for outgoing BGP packets
Flushing the suboptimal BGP route to the RIB
Enabling BGP to not flush specific routes to the routing table
Specifying a label allocation mode
Disabling optimal route selection for labeled routes without tunnel information
Converting unlabeled BGP routes into labeled routes
Disabling MPLS local IFNET tunnel establishment
Appending the local RT attribute to private routes
Enabling peer unreachability detection
Enabling the 4-byte private AS number capability
Displaying 4-byte AS numbers in dotted notation
Setting the maximum number of error UPDATE messages
Advertising user group ID information in BGP routes to a peer or peer group
Display and maintenance commands for BGP network tuning and optimization
Displaying and maintaining records about error UPDATE messages
BGP network tuning and optimization configuration examples
Example: Configuring BGP load balancing
Example: Configuring the BGP Additional Paths feature
Example: Configuring prefix-based BGP ORF
Configuring BGP security features
BGP security feature configuration tasks at a glance
Enabling MD5 authentication for BGP peers
Enabling keychain authentication for BGP peers
Configuring IPsec for IPv6 BGP
Configuring RPKI connection parameters
Applying the BGP RPKI validation state to optimal route selection
Advertising BGP RPKI validation state to a peer or peer group
Display and maintenance commands for BGP security features
Displaying BGP security features
Clearing BGP security feature information
IPv4 BGP security feature configuration examples
Example: Configuring BGP keychain authentication
IPv6 BGP security feature configuration examples
Example: Configuring IPsec for IPv6 BGP packets
Improving BGP network reliability
BGP network reliability improvement tasks at a glance
Configuring BGP FRR by using a routing policy (IPv4 unicast address family)
Configuring BGP FRR by using a routing policy (IPv6 unicast address family)
Configuring BGP FRR through PIC (IPv4 unicast address family)
Configuring BGP FRR through PIC (IPv6 unicast address family)
Configuring BFD-powered nexthop connectivity detection for BGP FRR
Configuring multi-tunnel switchover for MPLS
Allowing BGP route recursion to multiple load sharing tunnels
Allowing BGP route recursion to primary and backup tunnels
Configuring BGP maintenance features
About BGP isolation and BGP shutdown
Display and maintenance commands for BGP network reliability improvement
IPv4 BGP network reliability improvement configuration examples
Example: Configuring BFD for BGP
IPv6 BGP network reliability improvement configuration examples
Example: Configuring BFD for IPv6 BGP
Example: Configuring IPv6 BGP FRR
Configuring extended BGP features
Extended BGP feature configuration tasks at a glance
Configuring BGP policy accounting
BMP configuration tasks at a glance
Establishing a TCP connection between the BMP client and BMP server
Enabling a BMP server to monitor a peer or peer group
Sending routes to the BMP server
Configuring the BMP client to send notifications with mode flags to the BMP server
Sending statistics information to the BMP server
Applying an SSL client-policy to the TCP connection to the BMP server
Configuring BGP LS route reflection
Specifying an AS number and a router ID for BGP LS messages
Configuring the route selection rules for BGP LS routes
Performing manual soft-reset for BGP sessions of BGP LS or BGP-VPN LS address family
Configuring the BGP Additional Paths feature for 6PE
Controlling path selection for 6PE
Controlling 6PE route advertisement and reception
Configuring 6PE route reflection
Display and maintenance commands for extended BGP features
Extended IPv4 BGP feature configuration examples
Extended IPv6 BGP feature configuration examples
BGP overview
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs.
BGP characteristics
BGP has the following characteristics:
· Focuses on route control and selection rather than route discovery and calculation. In addition, it provides rich routing policies, allowing route filtering and selection.
· Uses TCP (port number 179) to enhance reliability. This is because BGP needs to handle a large volume of routing information to implement inter-AS route advertisement and selection. Devices can exchange routing information even if they are not directly connected.
· Has good scalability and can adapt to network developments. An increasing number of new technologies use BGP as their control plane protocol for information transmission.
· Measures the distance of a route by using a list of ASs that the route must travel through to reach the destination. BGP is also called a path-vector protocol.
· Supports CIDR.
· Reduces bandwidth consumption by advertising only incremental updates. BGP is very suitable to advertise large numbers of routes on the Internet.
· Eliminates routing loops by adding AS path information to BGP route updates. A device discards a route when it finds that the route contains the local AS number.
BGP application scenarios
BGP helps an increasing number of emerging technologies establish information pathways. It inserts information of the control plane into BGP routes and transmits the information across networks. BGP is used in the following scenarios:
· The control plane is deployed with BGP and works in conjunction with forwarding-plane technologies to carry services.
¡ Scenarios where different users need to unicast packets to each other across ASs in the public network.
¡ Scenarios where unicast routing information used for RPF checks and multicast topology setup requires cross-AS advertisement.
¡ Scenarios where BGP and MPLS must work together to implement BGP MPLS L3VPN or L2VPN:
- VPN routing information needs to be transmitted over the public network. For more information, see MPLS L3VPN configuration in MPLS Configuration Guide.
- Label block information needs to be transmitted. For more information, see MPLS L2VPN configuration and VPLS configuration in MPLS Configuration Guide.
¡ Scenarios where SRv6 tunnels are used to forward VPN traffic over the public network. For more information, see SRv6 VPN overview, IP L3VPN over SRv6, EVPN L3VPN over SRv6, EVPN VPWS over SRv6, EVPN VPLS over SRv6, and IP public network over SRv6 in Segment Routing Configuration Guide.
¡ Scenarios where multicast is required in VPNs. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
· The implementation of new features requires BGP extensions:
¡ Ethernet Virtual Private Network (EVPN) scenarios. For more information, see EVPN Configuration Guide.
¡ Scenarios where devices need to exchange SR-MPLS TE policy or SRv6 TE policy settings. For more information, see SR-MPLS TE policy configuration or SRv6 TE policy configuration in Segment Routing Configuration Guide.
¡ Scenarios where inter-AS paths require SIDs to support SR cross-domain forwarding. These scenarios are based on BGP Egress Peer Engineering (BGP-EPE). For more information, see SR-MPLS configuration or SRv6 configuration in Segment Routing Configuration Guide.
¡ Scenarios where QoS policy transmission is required to filter and detect illegal traffic within the network. For more information, see flowspec configuration in ACL and QoS Configuration Guide.
¡ Scenarios where intra- or inter-domain source address verification is required. For more information, see SAVNET configuration in Security Configuration Guide.
BGP speaker and BGP peer
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
Based on the AS, a BGP peer can be either of the following types:
· IBGP peer—Resides in the same AS as the local router.
· EBGP peer—Resides in different ASs from the local router.
Based on the IP version, a BGP peer can be either of the following types:
· IPv4 peer—Uses an IPv4 address to establish a peer relationship with the local router.
· IPv6 peer—Uses an IPv6 address to establish a peer relationship with the local router.
BGP message types
BGP uses the following message types:
· Open—After establishing a TCP connection, BGP sends an OPEN message to establish a session to the peer.
· Update—BGP sends UPDATE messages to exchange routing information between peers. Each UPDATE message can advertise a group of routes with reachable next hops and identical attributes. A UPDATE message can also contain multiple withdrawn routes. You can identify those routes by their destination addresses in the Network Layer Reachability Information (NLRI) of that update message.
· Keepalive—BGP sends KEEPALIVE messages between peers to maintain connectivity.
· Route-refresh—BGP sends a ROUTE-REFRESH message to request the routing information for a specific address family from a peer. The local device might send a ROUTE-REFRESH message to a peer if both of them are enabled with the ROUTE-REFRESH capability. When the BGP route reception policy changes, the local device sends a ROUTE-REFRESH message to its peers. On receipt of that message, a peer sends its route information to the local device, so the local device can update BGP routes and apply the new reception policy to them.
· Notification—BGP sends a NOTIFICATION message upon detecting an error and immediately closes the connection.
BGP message formats
A BGP message consists of message header and message content. The five BGP messages have the same message header, but the content of each message differs.
BGP message header
The format of the BGP message header is as shown in Figure 1. For more information about fields in the BGP message header, see Table 1.
Table 1 Fields in the BGP message header
Length (in bytes) |
Marker |
16 |
Synchronization state of the BGP connection. If the value of this field is not a hexadecimal string containing only Fs, the BGP connection has a synchronization error. |
Length |
2 |
Total length of the BGP message, including the message header. The length range is 19 to 4096 bytes. |
Type |
1 |
BGP message type: · 1—OPEN · 2—UPDATE · 3—NOTIFICATION · 4—KEEPALIVE · 5—ROUTE-REFRESH |
OPEN message
Figure 2 OPEN message format
OPEN messages are used for BGP connection establishment and BGP capability negotiation. The format of OPEN messages is as shown in Figure 7. For more information about fields in an OPEN message, see Table 2.
Table 2 Fields in an OPEN message
Length (in bytes) |
Version |
1 |
BGP version number. |
My Autonomous System |
2 |
AS number of the message sender. |
Hold Time |
2 |
Hold timer set by the message sender, in seconds. This timer is for peer connection maintenance purposes, and specifies the interval for sending KEEPALIVE or UPDATE messages. After both parties in a BGP session receive the hold timer set by the other, they use the smaller timer. |
BGP Identifier |
4 |
Router ID of the message sender. |
Opt Parm Len |
1 |
Total length of the Optional Parameters field, in bytes. A value of 0 indicates that they message does not contain optional parameters. |
Option Parameters |
Variable |
Optional parameters, each of which is a unit in TLV format. They are typically used to list the capabilities that the message sender can negotiate. For more information about the capabilities supported by the device, see "Tuning and optimizing BGP networks." |
UPDATE message
Figure 3 UPDATE message format
UPDATE messages are used for route advertisement. The format of UPDATE messages is as shown in Figure 3. For more information about fields in an UPDATE message, see Table 3.
Table 3 Fields in an UPDATE message
Length (in bytes) |
Withdrawn Routes Length |
2 |
Total length of the Withdrawn Routes field, in bytes. A value of 0 indicates that they message does not contain routes being withdrawn. |
Withdrawn Routes |
Variable |
List of routes being withdrawn. Each route is represented by the following fields: · Length—Length of the IP address prefix. This field is one byte long. · Prefix—IP address prefix of the route. This field is variable. |
Total Path Attribute Length |
2 |
Total length of the Path Attributes field, in bytes. |
Path Attributes |
Variable |
List of path attributes carried by routes in the message. Those attributes are list in ascending order of their type numbers and each of them are encoded in TLV format. The Type field indicates the type of a route attribute. It is two bytes long and consists of the Attr.Flag and Attr.Type Code subfields. · Attr.Flag: Type flags of the route attribute: ¡ O—Indicates whether the route attribute is a well-known attribute. If the route attribute is well-known, this flag is set to 0. If the route attribute is optional, this flag is set to 1. ¡ T—Indicates whether the route attribute is a transitive attribute. If the route attribute is transitive, this flag is set to 1. If not, this flag is set to 0. ¡ P—Indicates whether the route attribute is partially effective. If a route attribute has this flag set to 1, it takes effect only within the same AS and will not be transmitted to other ASs. This flag is set to 1 only if the route attribute is an optional transitive attribute. ¡ E—Indicates whether the Length field of the route attribute needs to be extended. If field extension is required, this flag is set to 1, and the Length field occupies two bytes. If field extension is not required, this flag is not set, and the Length field occupies only one byte. ¡ U—This flag is reserved and thus set to 0. · Attr.Type Code: Type code of the route attribute, which indicates the type of the route attribute. ¡ 1—ORIGIN ¡ 2—AS_PATH ¡ 3—NEXT_HOP ¡ 4—MED ¡ 5—LOCAL_PREF ¡ 6—ATOMIC_AGGREGATE ¡ 7—AGGREGATOR ¡ 8—COMMUNITY ¡ 9—ORIGINATOR_ID ¡ 10—CLUSTER_LIST ¡ 14—MP_REACH_NLRI ¡ 15—MP_UNREACH_NLRI ¡ 16—EXT-COMMUNITY The Length field indicates the length of the route attribute, in bytes. The Value field indicates the content of the route attribute. |
Network Layer Reachability Information (NLRI) |
Variable |
List of routes to be updated. Each route is represented by the following fields: · Length—Length of the IP address prefix. This field is one byte long. · Prefix—IP address prefix of the route. This field is variable. |
Figure 4 NOTIFICATION message format
NOTIFICATION messages are used to notify BGP session errors. The format of NOTIFICATION messages is as shown in Figure 4. For more information about fields in a NOTIFICATION message, see Table 4.
Table 4 Fields in a NOTIFICATION message
Length (in bytes) |
Error Code |
1 |
Error SubCode |
1 |
Error subcode. |
Data |
Variable |
Detailed error information. |
Table 5 introduces supported error codes and subcodes.
Table 5 Error codes and subcodes
Error code/subcode |
Reason for peer disconnection |
1/1 |
connection not synchronized |
The two ends of the connection were not synchronized. The current implementation is that the first 16 bytes of the received message's header do not contain only Fs. |
1/2 |
bad message length |
Invalid message length. |
1/3 |
bad message type |
Invalid message type. |
3/1 |
the withdrawn length is too large |
The length of routing information to be withdrawn message was too long. |
the attribute length is too large |
The attribute length was too long. |
one attribute appears more than once |
A path attribute appeared multiple times in an UPDATE message. |
the attribute length is too small |
The attribute length was less than two bytes. |
exntended length field is less than two octets |
The attribute length was extended, but it was less than two bytes. |
the length field is less than one octet |
The attribute length was not extended, but it was less than one byte. |
link-state attribute error |
The link-state attribute was in incorrect form. |
3/2 |
unrecognized well-known attribute |
Unknown well-known attribute. |
3/3 |
attribute-type attribute missed |
The attribute-type attribute was lost. The values for the attribute-type argument include: · ORIGIN · AS_PATH · LOCAL_PREF · NEXT_HOP |
3/4 |
attribute flags error |
Incorrect attribute flags. |
3/5 |
attribute-type attribute length error |
The length of the attribute-type atrrbute was invalid. The values for the attribute-type argument include: · AS_PATH · AS4_PATH · CLUSTER_LIST · AGGREGATOR · AS4_AGGREGATOR · ORIGIN · NEXT_HOP · MED · LOCAL_PREF · ATOMIC_AGGREGATE · ORIGINATOR_ID · MP_REACH_NLRI · COMMUNITIES · EXT-COMMUNITIES |
attribute length exceeds |
The attribute length crossed the limit. |
3/6 |
Invalid ORIGIN attribute. |
3/8 |
invalid NEXT_HOP attribute |
Invalid NEXT_HOP attribute. |
3/9 |
invalid nexthop length in MP_REACH_NLRI (address-family) |
The Nexthop length in the MP_REACH_NLRI attribute was invalid for the address-family address family. The values for the address-family argument include: · 4u—IPv4 unicast address family. · IPv4 Flowspec—IPv4 flowspec address family. · MPLS—MPLS address family. · VPNv4—VPNv4 address family. · 6u—IPv6 unicast address family. · VPNv6—VPNv6 address family. · L2VPN—L2VPN address family. |
the length of MP_UNREACH_NLRI is too small |
The length of the MP_UNREACH_NLRI attribute was less than three bytes. |
the MP NLRI attribute length exceeds |
The length of the MP_REACH_NLRI or MP_UNREACH_NLRI attribute crossed the limit. |
erroneous MP NLRI attribute end position |
The reachable or unreachable prefix and the path attribute ended at different positions. |
3/10 |
invalid network field |
Invalid network field. |
3/11 |
malformed AS_PATH |
The AS_PATH attribute was malformed. |
4/0 |
Keepalive last triggered time |
Most recent time when KEEPALIVE message sending was triggered. |
Keepalive last sent time |
Update last sent time |
Most recent time when an UPDATE message was sent. |
EPOLLOUT last occurred time |
Most recent time when an EPOLLOUT event occurred. |
Keepalive last received time |
Most recent time when a KEEPALIVE message was received. |
Update last received time |
Most recent time when an UPDATE message was received. |
EPOLLIN last occurred time |
Most recent time when an EPOLLIN event occurred. |
5/0 |
connection retry timer expires |
The ConnectRetry timer expired. |
TCP_CR_Acked event received |
A TCP_CR_Acked event was received. |
TCP_Connection_Confirmed event received |
A TCP_Connection_Confirmed event was received. |
5/3 |
open message received |
An OPEN message was received. |
6/0 |
manualstop event received |
A manualstop event was received. |
physical interface configuration changed |
Physical configurations changed, such as interface settings. |
session down event received from BFD |
A BFD session down event was received. |
6/1 |
maximum number of prefixes reached |
The number of route prefixes has exceeded the upper limit specified by using the peer route-limit command. |
maximum number of address-family prefixes reached |
The number of route prefixes in the address-family address family has exceeded the upper limit specified by using the peer route-limit command. The values for the address-family argument include: · IPv4 unicast—IPv4 unicast address family. · IPv6 unicast—IPv6 unicast address family. · VPNv4—VPNv4 address family. · VPNv6—VPNv6 address family. |
6/2 |
configuration of peer ignore changed |
The peer ignore command was configured. |
6/3 |
address family deleted |
An address family was deleted. |
peer disabled |
A peer was disabled. |
6/4 |
administrative reset |
The BGP session was reset because of the reset bgp command or configuration changes. |
6/5 |
connection rejected |
The connection request was rejected. |
6/6 |
other configuration change |
Other configurations changed. |
6/7 |
connection collision resolution |
A connection conflict occurred. |
two connections exist and MD5 authentication is configured for the neighbor |
Two connections existed and MD5 authentication was configured for one of them. |
6/8 |
no memory to process the attribute |
The memory was insufficient for attribute parsing. |
no memory for the route |
Failed to obtain memory resources for route or label block generation. |
no memory to generate unreachable NLRI |
Failed to obtain memory resources for MP_UNREACH_NLRI encapsulation. |
no memory to generate a message |
Failed to obtain memory resources for message encapsulation. |
can't get the VPN RD |
Failed to obtain RDs upon prefix parsing. |
can't get the VPN routing table |
Failed to obtain the VPN routing table upon prefix parsing. |
can't get the attributes |
Failed to obtain attributes upon prefix parsing. |
entered severe memory state |
A severe memory usage alarm was triggered. |
entered critical memory state |
A critical memory usage alarm was triggered. |
KEEPALIVE message
Figure 5 KEEPALIVE message format
KEEPALIVE messages are transmitted between BGP peers to maintain connectivity. The format of KEEPALIVE messages is as shown in Figure 5. For more information about fields in a KEEPALIVE message, see Table 6.
Table 6 Fields in a KEEPALIVE message
Length (in bytes) |
Marker |
16 |
This field indicates the completeness of information synchronization between BGP peers, and can be used for BGP authentication. When BGP authentication is not configured, the value for this field is a hexadecimal string containing only Fs. |
Length |
2 |
Total length of the KEEPALIVE message, in bytes. |
Type |
1 |
BGP message type. The type value is 4 for KEEPALIVE messages. |
Figure 6 ROUTE-REFRESH message format
BGP sends a ROUTE-REFRESH message to request the routing information of a specific address family from a peer. On receipt of the message, the peer re-advertises routes in the specified address family. The format of ROUTE-REFRESH messages is as shown in Figure 6. For more information about fields in a ROUTE-REFRESH message, see Table 7.
Table 7 Fields in a ROUTE-REFRESH message
Length (in bytes) |
AFI |
2 |
Identifier of the address family. |
Reserved |
1 |
Reserved field. |
SAFI |
1 |
Identifier of the subsequent address family. |
BGP finite state machine
During session establishment, the devices at the two ends transition between different BGP states, as shown in Figure 7.
Figure 7 BGP finite state machine
Idle
This state is the initial BGP state. In this state, BGP rejects any connection requests. Only upon receiving a Start event, the device assigns resources to BGP, and attempts to establish a TCP connection and transition to Connect state.
BGP transitions to Idle state from the remaining states upon a TCP disconnection error, packet error, connection closed due to configuration issues, and reception of a NOTIFICATION message.
Connect
In this state, BGP starts a Connect Retry timer and waits for TCP connection establishment to be completed.
· If TCP connection establishment succeeds before the Connect Retry timer expires, BGP closes the Connect Retry timer, sends an OPEN message to the peer, and transitions to OpenSent state.
· If TCP connection establishment fails before the Connect Retry timer expires, BGP transitions to Active state.
· If the Connect Retry timer expires, and no connection response is received, BGP resets the Connect Retry timer, tries to establish a TCP connection with the peer again, and stays in Connect state.
Active
In this state, BGP continuously attempts to establish a TCP connection.
· If TCP connection establishment succeeds, BGP closes the Connect Retry timer, sends an OPEN message to the peer, and transitions to OpenSent state.
· If TCP connection establishment fails, BGP resets the Connect Retry timer and stays in Active state.
· If the Connect Retry timer expires and no connection response is received, BGP resets the Connect Retry timer and transitions to Connect state.
OpenSent
In this state, BGP waits for an OPEN message from the peer, and checks the BGP version number and AS number in the OPEN message.
· If the OPEN message is correct, BGP sends a KEEPALIVE message to the peer, and transitions to OpenConfirm state.
· If the OPEN message is incorrect, BGP sends a NOTIFICATION message to the peer, and transitions to Idle state.
If the TCP connection is disconnected in this state, BGP resets the Connect Retry timer, transitions to Active state, and tries to establish a TCP connection again.
OpenConfirm
In this state, BGP waits for a KEEPALIVE or NOTIFICATION message.
· Upon receiving a KEEPALIVE message, BGP transitions to Established state.
· Upon receiving a NOTIFICATION message, BGP transitions to Idle state.
Established
In this state, BGP can exchange UPDATE, KEEPALIVE, ROUTE-REFRESH, and NOTIFICATION messages with the peer.
· Upon receiving a correct UPDATE or KEEPALIVE message, BGP stays in Established state.
· Upon receiving an incorrect UPDATE or KEEPALIVE message, BGP sends a NOTIFICATION message to the peer and transitions to Idle state.
· Upon receiving a ROUTE-REFRESH message, BGP does not change its state.
BGP path attributes
BGP uses the following path attributes in UPDATE messages for route filtering and selection:
BGP path attributes are a set of parameters that are advertised along with routes. They provide further description of specific routes, enabling the route receiver to filter and select routes.
BGP path attributes are categorized as follows:
· Well-known mandatory—Attributes that all BGP devices must recognize and UPDATE messages must contain. UPDATE messages lacking these attributes are invalid.
· Well-known discretionary—Attributes that all BGP devices must recognize, but UPDATE messages do not need to contain.
· Optional transitive—Attributes that BGP devices might not be able to recognize, but can receive and advertise to other BGP devices.
· Optional non-transitive—If a BGP device does not support these attributes, the device will ignore them in UPDATE messages and will not forward them to other peers.
ORIGIN
ORIGIN is a well-known mandatory attribute that specifies the origin of BGP routes. This attribute has the following types:
· IGP—Has the highest priority. Routes generated in the local AS have the IGP attribute.
· EGP—Has the second highest priority. Routes obtained through EGP have the EGP attribute.
· INCOMPLETE—Has the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
In route summarization scenarios, the ORIGIN attribute of a summary route is determined by the specific routes:
· The ORIGIN attribute of the summary route is Incomplete if the ORIGIN attribute of a specific route is Incomplete.
· The ORIGIN attribute of the summary route is EGP if no specific route has the Incomplete ORIGIN attribute and the ORIGIN attribute of a specific route is EPG.
· The ORIGIN attribute of the summary route is IGP only when all specific routes have the IGP ORIGIN attribute.
When the ORIGIN attributes of the specific routes change, the ORIGIN attribute of the summary route will also change accordingly.
AS_PATH
AS_PATH is a well-known mandatory attribute that records the ASs a route must pass through from the local network to the destination address.The route receiver can then determine the ASs required to route traffic to the destination address based on the AS_PATH attribute.
When a BGP device advertises local routes, it processes them as follows:
· Before advertising routes to EBGP peers, it appends the local AS number to the end of each route's AS_PATH list.
· When it advertises routes to IBGP peers, it does not add any AS number to the AS_PATH list of each route. The AS_PATH list of each advertised route is empty.
When a BGP device forwards routes, it processes them as follows:
· Before forwarding routes to EBGP peers, it appends the local AS number to the head of each route's AS_PATH list.
· Before forwarding routes to IBGP peers, it does not change the AS_PATH list of each route.
AS numbers in the AS_PATH attribute are arranged in one of the following methods:
· AS_SEQUENCE—Arranges AS numbers in sequence. As shown in Figure 8, the number of the AS closest to the receiver's AS is leftmost.
· AS_SET—Arranges AS numbers randomly. This method is applicable to route summarization (also called route aggregation) scenarios. After routes are summarized, the system cannot sequentially arrange the AS_PATH attributes of summarized routes. Instead, it records the AS numbers in an unordered manner. During optimal route selection, those AS numbers are treated as one AS number.
· AS_CONFED_SEQUENCE—Arranges sub-AS numbers within a confederation in sequence.
· AS_CONFED_SET—Arranges sub-AS numbers within a confederation randomly. This method is applicable to intra-confederation route summarization scenarios.
· The AS_CONFED_SEQUENCE and AS_CONFED_SET methods are used only in BGP routes forwarded inside a confederation.
Figure 8 AS_PATH attribute
BGP uses the AS_PATH attribute to implement the following functions:
· Avoid routing loops—A BGP router does not receive routes containing the local AS number to avoid routing loops.
· Affect route selection—BGP gives priority to the route with the shortest AS_PATH length if other factors are the same. As shown in Figure 8, the BGP router in AS 50 gives priority to the route passing AS 40 for sending data to the destination 8.0.0.0. In some applications, you can apply a routing policy to control BGP route selection by modifying the AS_PATH length. For more information about routing policy, see "Configuring routing policies."
· Filter routes—By using an AS path list, you can filter routes based on AS numbers contained in the AS_PATH attribute. For more information about AS path list, see "Configuring routing policies."
NEXT_HOP
NEXT_HOP is a well-known mandatory attribute that might not contain the IP address of a directly connected router. Its value is determined as follows:
· When a BGP speaker advertises a self-originated route to a BGP peer, it sets the address of the sending interface as the NEXT_HOP.
· When a BGP speaker sends a received route to an EBGP peer, it sets the address of the sending interface as the NEXT_HOP.
· When a BGP speaker sends a route received from an EBGP peer to an IBGP peer, it does not modify the NEXT_HOP attribute. If load balancing is configured, BGP modifies the NEXT_HOP attribute for the equal-cost routes. For load balancing information, see "Figure 9."
MED (MULTI_EXIT_DISC)
BGP advertises the MED attribute between two neighboring ASs, each of which does not advertise the attribute to any other AS. The MED attribute is an optional non-transitive attribute.
Similar to metrics used by IGPs, MED is used to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it selects the route with the smallest MED value as the optimal route. As shown in Figure 10, traffic from AS 10 to AS 20 travels through Router B that is selected according to MED.
Figure 10 MED attribute
Generally BGP only compares MEDs of routes received from the same AS. You can also use the compare-different-as-med command to force BGP to compare MED values of routes received from different ASs.
LOCAL_PREF
LOCAL_PREF is a well-known discretionary attribute exchanged between IBGP peers only, and is not advertised to any other AS. It indicates the priority of a BGP router.
BGP uses LOCAL_PREF to determine the optimal route for traffic leaving the local AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it selects the route with the highest LOCAL_PREF value as the optimal route. As shown in Figure 11, traffic from AS 20 to AS 10 travels through Router C that is selected according to LOCAL_PREF.
The LOCAL_PREF attribute is transmitted only between IBGP peers, and cannot be advertised to other ASs.
Figure 11 LOCAL_PREF attribute
ATOMIC_AGGREGATE
ATOMIC_AGGREGATE is a well-known discretionary attribute that identifies the aggregation status of a route. A route with the ATOMIC_AGGREGATE attribute is an aggregate route. The route receiver should be aware that the member routes of the aggregate route might be dropped during route advertisement.
AGGREGATOR
AGGREGATOR is an optional transitive attribute supplementary to the ATOMIC_AGGREGATE attribute. It contains the IP address and the AS number of the BGP device that initiated the route aggregation. When a device aggregates BGP routes, it adds both the ATOMIC_AGGREGATE and AGGREGATOR attributes to the aggregate route.
ORIGINATOR_ID
ORIGINATOR_ID is an optional non-transitive attribute that identifies the router ID of the route generator within the local AS. Only route reflectors can add this attribute to routes.
The ORIGINATOR_ID attribute prevents routing loops caused by the introduction of route reflectors. When a BGP route is reflected for the first time, the route reflector adds the ORIGINATOR_ID attribute to the route. The attribute contains the router ID of the device that sent the route to the reflector. When the route reflector receives a route carrying the ORIGINATOR_ID attribute, it does not modify the route. Upon receiving a route with the ORIGINATOR_ID attribute, a device identifies whether the router ID in the ORIGINATOR_ID attribute is the same as its own router ID. If they are the same, a routing loop exists within the current AS, and the receiver discards the route.
CLUSTER_LIST
CLUSTER_LIST is an optional non-transitive attribute that prevents routing loops by recording the route reflector clusters a route has passed through.
This attribute is generated by route reflectors. When a route reflector a route, it adds the local cluster ID to the CLUSTER_LIST attribute of that route. If the route does not carry a CLUSTER_LIST attribute, the route reflector creates one for the route. When a route reflector receives a BGP route, it identifies whether the route's CLUSTER_LIST attribute contains the local cluster ID. If the local router ID is found, the route will be discarded to prevent routing loops.
COMMUNITY
COMMUNITY is an optional transitive attribute that identifies the communities of BGP routes. A BGP community is a group of routes with the same characteristics. It has no geographical boundaries. Routes of different ASs can belong to the same community.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration, management, and maintenance.
The COMMUNITY attribute supports the following formats:
· aa:nn—Both the aa and nn arguments are in the range of 0 to 65535. The aa argument represents the AS number from which the route comes, and the nn argument represents the user-defined community value. For example, if the community value of a route from AS 100 is 999, the COMMUNITY attribute of that route is 100:999.
· Integer—An integer in the range of 0 to 4294967295.
Figure 12 shows the relationship between the above two formats.
Figure 12 Relationship between the aa:nn and integer formats
Well-known COMMUNITY attributes involve the following:
· INTERNET—By default, all routes belong to the Internet community. Routes with this attribute can be advertised to all BGP peers. The value forthis attribute is 0.
· NO_EXPORT—Routes with this attribute cannot be advertised out of the local AS or out of the local confederation, but can be advertised to other sub-ASs in the confederation. For confederation information, see "Confederation." The value forthis attribute is 4294967041.
· No_ADVERTISE—Routes with this attribute cannot be advertised to other BGP peers. The value forthis attribute is 4294967042.
· No_EXPORT_SUBCONFED—Routes with this attribute cannot be advertised out of the local AS or other sub-ASs in the local confederation. The value forthis attribute is 4294967043.
You can configure BGP community lists to filter BGP routes based on the BGP COMMUNITY attribute.
Large community
The COMMUNITY attribute can denote only two-byte AS numbers, and has only one community value.. To use the COMMUNITY attribute flexibly, BGP large community attribute is defined. This attribute is an optional non-transitive attribute whose value is 12 bytes long in Global Administration:LocalData1:LocalData2 format. Each field is four-byte long and is a integer in the range of 0 to 4294967295. You can define the meaning of each field as needed, for example, ME:ACTION:YOU or ASN:Function:Parameter.
The large community attribute contributes to flexible application of routing policies and control over route advertisement and reception because of the following advantages:
· It can denote two-byte and four-byte AS numbers entirely.
· It contains two four-byte local data attribute identifiers.
The large community attribute can be used together with the COMMUNITY attribute for better route management.
EXT_COMMUNITY
To meet new demands, BGP defines the EXT_COMMUNITY attribute, which is an optional non-transitive attribute. This attribute has the following advantages over the COMMUNITY attribute:
· Provides more attribute values by extending the attribute length to eight bytes.
· Allows for using different types of extended community attributes in different scenarios to enhance route filtering and control and simplify configuration and management.
The device supports the route target, link bandwidth, color, and Site of Origin (SoO) extended community attributes. For information about route target, see MPLS Configuration Guide. For information about the color attribute, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
The link bandwidth attribute carries the bandwidth of the interface directly connected to an EBGP peer or peer group. The link bandwidth attribute will be advertised to IBGP peers.
The SoO attribute specifies the site where the route originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
The SoO attribute has the following formats:
· 16-bit AS number in integer format:32-bit user-defined number. For example, 100:3.
· 16-bit AS number in dotted format:32-bit user-defined number. For example, 0.1:1. The AS number range is 0.1 to 0.65535.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number in integer format:16-bit user-defined number, where the minimum AS number is 65536. For example, 65536:1.
· 32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
· 32-bit AS number in dotted format:16-bit user-defined number. For example, 10.1:1. The minimum AS number is 1.0.
Community container
BGP community attributes are used to carry additional information in BGP routes to simplify routing policies. The length of the BGP community attribute is limited (4 bytes), so BGP introduces many new attributes to provide functions similar to community attributes, such as the large community attribute and extended community attribute. These attributes all have a fixed length, which still cannot meet the growing demand. These attributes have their own unique formats, and the device must be able to recognize these attributes, which increases the difficulty of network deployment.
The community container attribute can resolve this problem. The community container attribute provides a generalized solution similar to the function of the community attribute. As a container of community-like attributes, a community container attribute can carry a variety of community-like attributes through the community container common header + community-like attribute structure. A community-like attribute is called a community container in the community container attribute, and the length of a community container is variable. Different community containers can define different attribute values to implement different functions. In addition to the community containers defined in the protocol, users can also define new community containers to meet the growing demand. A device can forward community container attributes without being able to recognize community containers.
In the current software version, H3C devices cannot add community container attributes to BGP routes. They can recognize the community container attributes carried in BGP routes sent by other manufacturers' devices and forward the routes. H3C devices support only the wide community containers. The value of the wide community container can only be Download To FIB, which indicates that a flowspec route does not notify the QoS module to execute the corresponding QoS policy. It uses the destination address in the match rule as the destination address and the redirected next hop in the action as the next hop address to generate a route in the IPv4/IPv6 routing table. If no destination address match rule or next hop redirection action exists, no route will be generated. By using the Download To FIB community container, the controller can issue IP routes through flowspec routes and use the IP routes for traffic forwarding when the flowspec router cannot obtain routing information in other ways.
The routing table to which a route generated based on the Download To FIB community container belongs depends on the address family of the flowspec route. For more information, see Table 8.
Table 8 Routing table to which a route generated based on flowspec route belongs
Flowspec address family |
Routing table for the generated IP routes |
BGP IPv4 flowspec address family |
Public network IPv4 routing table |
BGP IPv6 flowspec address family |
Public network IPv6 routing table |
BGP-VPN IPv4 flowspec address family |
VPN instance IPv4 routing table |
BGP-VPN IPv6 flowspec address family |
VPN instance IPv6 routing table |
BGP VPNv4 flowspec address family |
IPv4 routing table of the VPN instance corresponding to the RD of the flowspec route |
BGP VPNv6 flowspec address family |
IPv6 routing table of the VPN instance corresponding to the RD of the flowspec route |
For more information about flowspec routes and flowspec address family, see flowspec configuration in ACL and QoS Configuration Guide.
AIGP
Accumulated Interior Gateway Protocol Metric (AIGP) is an optional non-transitive attribute that conveys and accumulates IGP metric values.
When an IGP starts running in an AS, it assigns a metric value to each link for path calculation. The path with the smallest metric value will be selected as the optimal route. As an inter-AS routing protocol, BGP cannot select optimal routes based on IGP metric values, because different ASs cannot exchange their metric information. To resolve this issue, the AIGP attribute is introduced. This attribute enables BGP to perform IGP metric-based route selection. The network administrator can integrate the ASs managed by the same department and running the same IGP protocol into an AIGP management domain. Within this domain, BGP can also select optimal routes based on IGP metrics.
NOTE: In this chapter, an AIGP-capable device refers to a device that supports sending and receiving the AIGP attribute. |
Only AIGP-capable devices can recognize the AIGP attribute in BGP routes and send routes carrying the AIGP attribute. To have a device add the AIGP attribute to routes, you must configure a routing policy for that device. As shown in Figure 13, Device B is AIGP-incapable and Device C is AIGP-capable. When Device A adds the AIGP attribute to a BGP route and sends it to Device B and Device C, the following rules apply:
· Device B ignores the AIGP attribute when it forwards the route to Device D.
· Device C forwards the route with the AIGP attribute to Device D. Device C does not modify the route's AIGP attribute unless it needs to set its IP address as the route's next hop. Device C modifies the AIGP attribute as follows:
¡ Identifies whether the BGP session between Device A and Device C is established based on IGP routes, or static or direct routes that do not require route recursion. If yes, Device C creates a new AIGP attribute by integrating the metric values of those IGP, static, or direct routes with the original AIGP attribute, and then sends it to Device D.
¡ Identifies whether the BGP session between Device A and Device C is established based on BGP or static routes that require route recursion. If yes, Device C adds the metric value of the obtained dependent route into the AIGP attribute each time BGP performs route recursion for one of those BGP or static routes. After the AIGP attribute finishes accumulating all metric values of dependent routes associated with those BGP or static routes, Device will send the new AIGP attribute to Device D.
With the above mechanism provided by the AIGP attribute, BGP can select optimal routes based on metric values similarly to IGP. Devices in the AIGP management domain can use optimal IGP paths to guide traffic forwarding. For more information about the influence of the AIGP attribute on route selection and its position in the route selection rules, see "BGP route selection."
4-byte AS numbers
In earlier BGP versions, each AS number was 2 bytes long and was in the range of 1 to 65535. However, as the network size grew, 2-byte AS numbers became insufficient. To avoid AS number exhaustion, AS numbers were lengthened to 4 bytes and their value range became 1 to 4294967295.
Before establishing a session using 4-byte AS numbers, two devices must negotiate with each other about the 4-byte AS number capability through OPEN messages. The session can be established successfully only if both devices support 4-byte AS numbers and the capability negotiation succeeds. During the capability negotiation, the format of OPEN messages is as shown in Figure 14. The My Autonomous System field does not support 4-byte AS numbers because the formats of fields in the OPEN message header are fixed. Therefore, a device using a 4-byte AS number inserts AS number 23456 into the My Autonomous System field, and places the real 4-byte AS number in the Optional Parameters field. With this approach, two peering devices can determine whether the other supports 4-byte AS numbers and obtain the other's 4-byte AS number during capability negotiation.
Figure 14 Format of OPEN messages used for 4-byte AS number capability negotiation
Figure 15 shows how BGP routes are generated, redistributed, and advertised.
Figure 15 BGP route processing mechanism
Route redistribution
BGP cannot discover routes by itself. To have BGP generate and advertise routes, you must redistribute routes from other protocols into the routing table of BGP. BGP supports the following route redistribution methods:
· Per-protocol redistribution—This method redistributes routes in bulk on a per routing protocol basis into the routing table of BGP. The routes that can be redistributed include IGP routes, direct routes, and static routes.
· Per-route redistribution—This method can identify a specific route by its prefix and redistribute it into the routing table of BGP.
Route summarization
Route summarization can summarize multiple routes into one summary route. This method can shrink the BGP routing table, because BGP only advertises summary routes rather than summarized routes to peers.
The system supports both manual and automatic route summarization.
· Automatic summarization—Summarizes routes redistributed into BGP according to natural network segments. After automatic summarization, BGP suppresses the summarized routes.
· Manual summarization—Summarizes BGP routes according to the user-defined summarization settings. This method allows you to determine the attribute of a summary route and whether to advertise the summarized routes.
BGP route selection
BGP discards routes with unreachable next hops and routes without IP-type recursive next hops. If the bestroute nexthop-resolved none command is executed, BGP does not discard routes with unreachable next hops. If the bestroute nexthop-resolved tunnel command is executed, BGP does not discard routes with only tunnel-type recursive next hops. In this situation, BGP still discards routes with next hops recursed to neither tunnels nor IP addresses.
If multiple routes to the same destination are available, BGP selects the optimal route in the following sequence:
1. The route with the highest-priority RPKI validation result if the bestroute origin-as-validation command is executed.
If the bestroute origin-as-validation command is not executed, BGP skips this route selection rule.
2. The route with the highest Preferred_value.
3. The route learned from the peer or peer group specified in the peer high-priority preferred command.
If the peer high-priority preferred command is not executed, BGP skips this route selection rule.
4. The route of the nexthop IP type specified in the bestroute nexthop-priority preferred command.
If the bestroute nexthop-priority preferred command is not executed, BGP skips this route selection rule.
5. The route of the encapsulation type specified in the bestroute encap-type preferred command.
If the bestroute encap-type preferred command is not executed, BGP skips this route selection rule.
6. The route of the nexthop type specified in the bestroute nexthop-type preferred command.
If the bestroute nexthop-type preferred command is not executed, BGP skips this route selection rule.
7. The route with the highest LOCAL_PREF.
8. The route of the encapsulation type specified in the bestroute encap-type command.
This rule does not take effect in public BGP instances.
If the bestroute encap-type command is not executed, BGP skips this route selection rule.
9. The route generated by the network command, the route redistributed by the import-route command, or the summary route in turn.
10. The route with the smallest AIGP attribute value.
11. The route with the shortest AS_PATH.
12. The IGP, EGP, or INCOMPLETE route in turn.
13. The route with the lowest MED value.
14. The route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn.
15. The route learned from the peer or peer group specified in the peer high-priority command.
If the peer high-priority command is not executed, BGP skips this route selection rule.
16. The route of the nexthop IP type specified in the bestroute nexthop-priority command.
If the bestroute nexthop-priority command is not executed, BGP skips this route selection rule.
17. The route with the smallest IGP metric to the next hop.
If the bestroute igp-metric-ignore command is executed, BGP skips this route selection rule.
18. The route with the smallest recursion depth.
19. The route of the nexthop type specified in the bestroute nexthop-type command.
If the bestroute nexthop-type command is not executed, BGP skips this route selection rule.
20. If a route received from an EBGP peer is the current optimal route, BGP does not change the optimal route when it receives routes from other EBGP peers.
If the bestroute compare-ebgp command is configured, BGP skips this route selection rule.
21. The route advertised by the router with the smallest router ID.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routers. Then, BGP selects the route with the smallest ID as the optimal route.
If the bestroute router-id-ignore command is executed, BGP skips this route selection rule.
22. The route with the shortest CLUSTER_LIST.
23. The route with an IPv6 next hop if the bestroute ipv6-nexthop command is executed.
If the bestroute ipv6-nexthop command is not executed, BGP skips this route selection rule.
24. The route with an IPv4 next hop.
25. The route advertised by the peer with the lowest IP address.
The CLUSTER_IDs of route reflectors form a CLUSTER_LIST. If a route reflector receives a route that contains its own CLUSTER ID in the CLUSTER_LIST, the router discards the route to avoid routing loops.
If load balancing is configured, the system selects available routes to implement load balancing.
For more information about the bestroute encap-type command, see SRv6 TE policy commands in Segment Routing Command Reference.
BGP route advertisement rules
BGP follows these rules for route advertisement:
· When multiple feasible routes to a destination exist, BGP advertises only the optimal route to its peers. If the advertise-rib-active command is configured, BGP advertises the optimal route in the IP routing table. If not, BGP advertises the optimal route in the BGP routing table.
· BGP advertises only routes that it uses.
· BGP advertises routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers.
· BGP advertises routes learned from an IBGP peer to EBGP peers, rather than other IBGP peers.
· After establishing a session to a new BGP peer, BGP advertises all the routes matching the above rules to the peer. After that, BGP advertises only incremental updates to the peer.
BGP load balancing
BGP load balancing is applicable between EBGP peers, between IBGP peers, and between confederations.
BGP implements load balancing through route recursion and route selection.
BGP load balancing through route recursion
The next hop of a BGP route might not be directly connected. One of the reasons is that the next hop information exchanged between IBGP peers is not modified. The BGP router must find the directly connected next hop through IGP. The matching route with the direct next hop is called the recursive route. The process of finding a recursive route is route recursion.
If multiple recursive routes to the same destination are load balanced, BGP generates the same number of next hops to forward packets.
BGP load balancing based on route recursion is always enabled in the system.
BGP load balancing through route selection
IGP routing protocols, such as RIP and OSPF, can use route metrics as criteria to load balance between routes that have the same metric. BGP cannot load balance between routes by route metrics as an IGP does, because BGP does not have a route computation algorithm.
BGP uses the following load balancing criteria to determine load balanced routes:
· The routes have the same ORIGIN, LOCAL_PREF, AIGP, and MED attributes.
· The routes meet the following requirements on the AS_PATH attribute:
¡ If the balance as-path-neglect command is configured, the routes can have different AS_PATH attributes.
¡ If only the balance as-path-relax command is configured, the routes can have different AS_PATH attributes, but the length of the AS_PATH attributes must be the same.
¡ If neither the balance as-path-neglect nor the balance as-path-relax command is configured, the routes must have the same AS_PATH attribute.
· The next hops of the routes meet the following requirements on IGP metric:
¡ If neither of the bestroute igp-metric-ignore and balance igp-metric-ignore commands is configured, the next hops of the routes must have the same IGP metric value.
¡ If the bestroute igp-metric-ignore or balance igp-metric-ignore command is configured, the next hops of the routes can have different IGP metric values.
· The routes have the same MPLS label assignment status (labeled or not labeled).
BGP does not use the route selection rules described in "BGP route selection" for load balancing.
As shown in Figure 16, Router A and Router B are IBGP peers of Router C. Router C allows a maximum number of two ECMP routes for load balancing.
Router D and Router E both advertise a route 9.0.0.0 to Router C. Router C installs the two routes to its routing table for load balancing if the routes meet the BGP load balancing criteria. After that, Router C forwards to Router A and Router B a single route whose attributes are changed as follows:
· AS_PATH attribute:
¡ If the balance as-path-neglect and balance as-path-relax commands are not configured, the AS_PATH attribute does not change.
¡ If the balance as-path-neglect or balance as-path-relax command is configured, the AS_PATH attribute is changed to the attribute of the optimal route.
· The NEXT_HOP attribute is changed to the IP address of Router C.
· Other attributes are changed to be the same as the optimal route.
Route reflector
IBGP peers must be fully meshed to maintain connectivity. If n routers exist in an AS, the number of IBGP connections is n(n-1)/2. If a large number of IBGP peers exist, large amounts of network and CPU resources are consumed to maintain sessions.
Using route reflectors can solve this issue. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
A router that is neither a route reflector nor a client is a non-client, which, as shown in Figure 17, must establish BGP sessions to the route reflector and other non-clients.
Figure 17 Network diagram for a route reflector
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the Cluster_ID. You can configure more than one route reflector in a cluster to improve availability, as shown in Figure 18. The configured route reflectors must have the same Cluster_ID to avoid routing loops.
Figure 18 Network diagram for route reflectors
When the BGP routers in an AS are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use commands to disable route reflection between clients instead of modifying the network configuration or changing the network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
Settlements for problems in large-scale BGP networks
You can use the following methods to facilitate management and improve route distribution efficiency on a large-scale BGP network.
Route dampening
Route flapping (a route comes up and disappears in the routing table frequently) causes BGP to send many routing updates. It can consume too many resources and affect other operations.
In most cases, BGP runs in complex networks where route changes are more frequent. To solve the problem caused by route flapping, you can use BGP route dampening to suppress unstable routes.
BGP route dampening uses a penalty value to judge the stability of a route. The bigger the value, the less stable the route. Each time a route state changes from reachable to unreachable, or a reachable route's attribute changes, BGP adds a penalty value of 1000 to the route. When the penalty value of the route exceeds the suppress value, the route is suppressed and cannot become the optimal route. When the penalty value reaches the upper limit, no penalty value is added.
If the suppressed route does not flap, its penalty value gradually decreases to half of the suppress value after a period of time. This period is called "Half-life." When the value decreases to the reusable threshold value, the route is usable again.
Figure 19 BGP route dampening
Peer group and dynamic peers
You can organize BGP peers with the same attributes into a group to simplify their configurations.
When a peer joins the peer group, the peer obtains the same configuration as the peer group. If the configuration of the peer group is changed, the configuration of group members is changed.
In some BGP networks, peers might change frequently and cause changes to BGP sessions. Using the regular peering method requires frequent BGP configuration adjustments, which is laborious. To resolve this issue, you can configure the neighbors of a device in the same network segment as a dynamic peer. The device accepts the peering request of a device as long as the requesting device is in the configured network segment.
Community
You can apply a community list, a large community list, or an extended community list to a routing policy for route control. For more information, see "BGP path attributes."
Route server
Some networks require the border devices in multiple ASs to establish full mesh connections, which consumes many network resources and reduces device performance.
To resolve this issue, configure a device as a route server and the border devices in different ASs as its clients as needed. The route server advertises routes to the clients without changing their AS path, next hop, and MED attributes, enabling the clients to exchange routes and traffic without establishing EBGP connections.
Figure 20 Network diagram for route server
Confederation
Confederation is another method to manage growing IBGP connections in an AS. It splits an AS into multiple sub-ASs. In each sub-AS, IBGP peers are fully meshed. As shown in Figure 21, intra-confederation EBGP connections are established between sub-ASs in AS 200.
Figure 21 Confederation network diagram
A non-confederation BGP speaker does not need to know sub-ASs in the confederation. To the BGP speaker, the confederation is one AS and the confederation ID is the AS number. In the above figure, AS 200 is the confederation ID.
Confederation has a deficiency. When you change an AS into a confederation, you must reconfigure the routers, and the topology will be changed.
In large-scale BGP networks, you can use both route reflector and confederation.
BGP update group
In large-scale BGP networks, a device needs to advertise routes to a large number of BGP peers, which requires high performance in bulk packet packaging and advertisement.
To conserve device resources, BGP can treat all peers with the same configurations as an update group. It packages a route only once and advertises that route to all peers in an update group. If the BGP update group feature is not supported, BGP must package routes on a per peer basis. For example, a route reflector has 10 clients and needs to reflect 10000 routes:
· If the route reflector does not support BGP update groups, it must package routes 100000 times.
· If the route reflector supports BGP update groups, it only needs to package routes 10000 times.
In the current software version, the BGP update group feature is supported by default.
MP-BGP
Supported address families
BGP-4 can only advertise IPv4 unicast routing information. Multiprotocol Extensions for BGP-4 (MP-BGP) can advertise routing information for the following address families:
· IPv6 unicast address family.
· IPv4 multicast and IPv6 multicast address families.
PIM uses static and dynamic unicast routes to perform RPF check before creating multicast routing entries. When the multicast and unicast topologies are different, you can use MP-BGP to advertise the routes for RPF check. MP-BGP stores the routes in the BGP multicast routing table. For more information about PIM and RPF check, see IP Multicast Configuration Guide.
· VPNv4 and VPNv6 address families.
For more information about VPNv4 and VPNv6, see MPLS Configuration Guide.
· Labeled IPv4 unicast and IPv6 unicast address families.
MP-BGP advertises IPv4 unicast/IPv6 unicast routes and MPLS labels assigned for the routes. Labeled IPv4 unicast routes apply to inter-AS Option C for MPLS L3VPN. Labeled IPv6 unicast routes apply to 6PE and inter-AS Option C for MPLS L3VPN. For more information about inter-AS Option C, see MPLS Configuration Guide.
You can perform either of the following tasks to enable BGP IPv4 labeled unicast route advertisement:
¡ Enable the capability to exchange labeled routes in BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
¡ Create the BGP IPv4 labeled unicast address family or BGP-VPN IPv4 labeled unicast address family, and perform route forwarding and advertisement in the address family.
The above two tasks are mutually exclusive. Enabling the capability to exchange labeled routes in BGP IPv4 unicast address family view is mutually exclusive with the creation of the BGP IPv4 labeled unicast address family. Enabling the capability to exchange labeled routes in BGP-VPN IPv4 unicast address family view is mutually exclusive with the creation of the BGP-VPN IPv4 labeled unicast address family.
BGP routes in the BGP IPv4 labeled unicast address family or BGP-VPN IPv4 labeled unicast address family can be added to the IP routing table only after you configure BGP IPv4 unicast route and BGP IPv4 labeled unicast route redistribution. BGP IPv4 labeled routes in BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family can be automatically added to the IP routing table.
A device can label and advertise BGP routes in the BGP IPv4 labeled unicast address family or BGP-VPN IPv4 labeled unicast address family only when the device has the MPLS label allocation capability. If the device does not have the MPLS label allocation capability, it cannot advertise BGP IPv4 labeled unicast routes to peers. For more information, see MPLS Configuration Guide.
In the current software version, you can enable a device to advertise IPv6 labeled unicast routes only by enabling the capability to exchange labeled routes for the device in BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
· L2VPN address family.
L2VPN information includes label block information and remote peer information. For more information about L2VPN and VPLS, see MPLS Configuration Guide.
· IPv4 MDT address family.
MP-BGP advertises MDT information including the PE address and default group so that multicast VPN can create a default MDT that uses the PE as the root on the public network. For more information about multicast VPN, see multicast VPN configuration in IP Multicast Configuration Guide.
· MVPN address family.
MP-BGP advertises MVPN routing information so that RSVP-TE can establish inclusive tunnels and selective tunnels. For more information about MVPN RSVP-TE, see multicast VPN configuration in IP Multicast Configuration Guide.
· EVPN address family.
MP-BGP advertises EVPN routes to implement automatic VTEP discovery, VXLAN tunnel establishment and assignment, and MAC and ARP information advertisement. For more information about EVPN, see EVPN configuration in EVPN Configuration Guide.
· IPv6 SAVNET address family.
MP-BGP advertises IPv6 SAVNET routes to help SAVNET devices generate SAVNET entries. For more information about SAVNET, see SAVNET configuration in Security Configuration Guide.
MP-BGP extended attributes
Prefixes and next hops are key routing information. BGP-4 uses UPDATE messages to carry the following information:
· Feasible route prefixes in the Network Layer Reachability Information (NLRI) field.
· Unfeasible route prefixes in the withdrawn routes field.
· Next hops in the NEXT_HOP attribute.
BGP-4 cannot carry routing information for multiple network layer protocols.
To support multiple network layer protocols, MP-BGP defines the following path attributes:
· MP_REACH_NLRI—Carries feasible route prefixes and next hops for multiple network layer protocols.
· MP_UNREACH_NLRI—Carries unfeasible route prefixes for multiple network layer protocols.
MP-BGP uses these two attributes to advertise feasible and unfeasible routes for different network layer protocols. BGP speakers not supporting MP-BGP ignore updates containing these attributes and do not forward them to its peers.
Address family
MP-BGP uses address families and subsequent address families to identify different network layer protocols for routes contained in the MP_REACH_NLRI and MP_UNREACH_NLRI attributes. For example, an Address Family Identifier (AFI) of 2 and a Subsequent Address Family Identifier (SAFI) of 1 identify IPv6 unicast routing information carried in the MP_REACH_NLRI attribute. For address family values, see RFC 1700.
Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
MP-BGP supports IPv4 route exchange between IPv6 peers and IPv6 route exchange between IPv4 peers as follows:
· When the next hop of an IPv6 route is an IPv4 address, MP-BGP maps the IPv4 address to an IPv6 address encapsulated in the NEXT_HOP attribute of update messages.
· When the next hop of an IPv4 route is an IPv6 address, BGP negotiates the extended next hop encoding capability with its peer. Then, BGP encapsulates the IPv4 NLRI in the MP_REACH_NLRI attribute of update messages.
Figure 22 Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
As shown in Figure 22, an IPv6 BGP peer relationship is established between Device A and Device B, between Device B and Device C, and between Device C and Device D. An IPv4 BGP peer relationship is established between Device A and Device B and between Device C and Device D. Device A and Device D can learn both IPv4 and IPv6 routes from each other and traffic is forwarded correctly in both IPv4 and IPv6 address families. For Device C to correctly receive IPv4 routes using the IPv6 address of Device B as the next hop, configure a routing policy on Device C. Use the routing policy to change the next hop of these routes to the IPv4 address of Device B.
BGP route redistribution into local VPN instances
In a private BGP network, BGP sessions might transmit routes that belong to different VPN instances. On receipt of those VPN routes, BGP needs to redistribute them into local VPN instances. During the route redistribution, BGP redistributes routes of non-local VPN instances or routes of another local VPN instance to the BGP routing table of a local VPN instance. Route redistribution into local VPN instances can be divided into local route redistribution and remote route redistribution based on the origins of routes:
· Local route redistribution—Redistributes the BGP routes of a local BGP-VPN instance to another local BGP-VPN instance. BGP VPN routes can be redistributed from a local VPN instance to another only if their export RTs equal the import RT of the destination VPN instance.
· Remote route redistribution—Redistributes the BGP routes received from remote peers into local VPN instances. BGP VPN routes can be redistributed into a local VPN instance only if their RTs equal the import RT of that VPN instance. If a BGP VPN route matches multiple local VPN instances, BGP will copy the route and redistribute it into those matching VPN instances separately.
In the current software version, only the following routes support route redistribution between VPN instances:
· Local route redistribution: BGP-VPN IPv4 unicast routes, BGP-VPN IPv6 unicast routes, and BGP-VPN IPv4 labeled unicast routes.
· Remote route redistribution: BGP VPNv4 routes, BGP VPNv6 routes, and BGP EVPN routes.
After BGP receives a BGP VPNv4, VPNv6, or EVPN route from a peer, it redistributes that route into local VPN instances as shown in Figure 23.
Figure 23 Remote route redistribution
BGP multi-instance
About this feature
A BGP router can run multiple BGP processes. Each BGP process corresponds to a BGP instance. BGP maintains an independent routing table for each BGP instance. Multiple BGP instances can use the same AS number, and they do not affect each other.
When you create multiple BGP instances, follow these guidelines:
· You can create multiple public address families for a BGP instance. However, each public address family (except for IPv4 unicast address family, IPv6 unicast address family, VPNv4 address family, VPNv6 address family, VPNv4 flowspec address family, VPNv6 flowspec address family, IPv4 RT-filter address family, IPv4 SR policy address family, and IPv6 SR policy address family) can belong to only one BGP instance.
· You can create multiple VPN instances for a BGP instance, and each VPN instance can have multiple address families. A VPN instance can belong to only one BGP instance.
· On the public network, a peer address can establish a session to only one BGP instance. Multiple BGP instances cannot synchronously establish sessions to the same peer address.
· The IPv4 and IPv6 multicast address families must belong to the same BGP instance.
· Different BGP instances can have the same AS number but cannot have the same name.
As shown in Figure 24, Device A, Device B, and Device C all run in AS 100. To enable Device A to communicate with Device B and Device C and implement service isolation between Device B and Device C, perform the following task on Device A:
Table 9 Create two BGP instances, for example, default and abc.
2. Use BGP instance default to establish a session to Device B.
3. Use BGP instance abc to establish a session to Device C.
After you complete this task, Device A can learn routes from Device B and Device C. However, Device B and Device C cannot learn routes from each other, because BGP instance default and abc are two independent instances.
Figure 24 Service isolation with BGP multi-instance
BGP configuration views
BGP uses different views to manage routing information for different BGP instances, address families, and VPN instances. Most BGP commands are available in all BGP views. BGP supports multiple VPN instances by establishing a separate routing table for each VPN instance.
Table 10 describes different BGP configuration views.
If a command supports only BGP instance view, the command applies to the public network and all VPN instances of that BGP instance.
If a command supports both BGP instance view and BGP-VPN instance view, the command applies to the public network and all VPN instances of that BGP instance.
· In BGP instance view, the command applies to only the public network of that BGP instance.
· In BGP-VPN instance view, the command applies to only the VPN instance associated with that BGP-VPN instance.
Table 10 BGP configuration views
View names |
Ways to enter the views |
Remarks |
BGP instance view |
You can create a BGP instance and enter its view by specifying the instance keyword in the bgp command. Configurations in this view apply to all public address families for the specified BGP instance and all VPN instances (such as confederation, GR, and logging configurations), or apply to all public address families for the specified BGP instance. |
BGP IPv4 unicast address family view |
Configurations in this view apply to public IPv4 unicast routes and peers of the specified BGP instance. |
BGP IPv6 unicast address family view |
Configurations in this view apply to public IPv6 unicast routes and peers of the specified BGP instance. |
BGP IPv4 labeled unicast address family view |
Configurations in this view apply to public IPv4 labeled unicast routes and peers of the specified BGP instance. |
BGP IPv4 multicast address family view |
Configurations in this view apply to IPv4 multicast routes and peers of the specified BGP instance. |
BGP IPv6 multicast address family view |
Configurations in this view apply to IPv6 multicast routes and peers of the specified BGP instance. |
BGP VPNv4 address family view |
Configurations in this view apply to VPNv4 routes and peers of the specified BGP instance. For more information about BGP VPNv4 address family view, see MPLS Configuration Guide. |
BGP VPNv6 address family view |
Configurations in this view apply to VPNv6 routes and peers of the specified BGP instance. For more information about BGP VPNv6 address family view, see MPLS Configuration Guide. |
BGP L2VPN address family view |
Configurations in this view apply to L2VPN information and L2VPN peers of the specified BGP instance. For more information about BGP L2VPN address family view, see MPLS Configuration Guide. |
BGP EVPN address family view |
Configurations in this view apply to EVPN routes and peers of the specified BGP instance. For more information about BGP EVPN address family view, see EVPN Configuration Guide. |
BGP-VPN instance view |
Configurations in this view apply to all address families of the specified VPN instance in the specified BGP instance. For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide. |
BGP-VPN IPv4 unicast address family view |
Configurations in this view apply to IPv4 unicast routes and peers of the specified VPN instance in the specified BGP instance. For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide. |
BGP-VPN IPv6 unicast address family view |
Configurations in this view apply to IPv6 unicast routes and peers of the specified VPN instance in the specified BGP instance. For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide. |
BGP-VPN IPv4 labeled unicast address family view |
Configurations in this view apply to IPv4 labeled unicast routes and peers of the specified VPN instance in the specified BGP instance. |
BGP-VPN VPNv4 address family view |
Configurations in this view apply to VPNv4 routes and peers of the specified VPN instance in the specified BGP instance. For more information about BGP-VPN VPNv4 address family view, see MPLS Configuration Guide. |
BGP MDT address family view |
Configurations in this view apply to MDT routes and peers of the specified BGP instance. For more information about BGP MDT address family view, see IP Multicast Configuration Guide. |
BGP IPv4 MVPN address family view |
Configurations in this view apply to MVPN routes and peers of the specified BGP instance. For more information about BGP IPv4 MVPN address family view, see IP Multicast Configuration Guide. |
BGP IPv6 MVPN address family view |
Configurations in this view apply to IPv6 MVPN routes and peers of the specified BGP instance. For more information about BGP IPv6 MVPN address family view, see IP Multicast Configuration Guide. |
BGP LS address family view |
Configurations in this view apply to public network LS messages and peers of the specified BGP instance. |
BGP-VPN LS address family view |
Configurations in this view apply to VPN LS messages and peers of the specified BGP instance. |
BGP IPv4 RT filter address family view |
Configurations in this view apply to IPv4 RT filter routes and peers of the specified BGP instance. For more information about BGP IPv4 RT filter address family view, see MPLS L3VPN Configuration Guide. |
BGP IPv4 SR policy address family view |
Configurations in this view apply to IPv4 SR policy routes and peers of the specified BGP instance. For more information about BGP IPv4 SR policy address family view, see SR-MPLS TE policy configuration in Segment Routing Configuration Guide. |
BGP IPv6 SR policy address family view |
Configurations in this view apply to IPv6 SR policy routes and peers of the specified BGP instance. For more information about BGP IPv6 SR policy address family view, see SRv6 TE policy configuration in Segment Routing Configuration Guide. |
BGP IPv6 SAVNET address family view |
Configurations in this view apply to IPv6 SAVNET routes and peers of the specified BGP instance. For more information about BGP IPv6 SAVNET address family view, see SAVNET configuration in Security Configuration Guide. |
BGP IPv4 flowspec address family view |
Configurations in this view apply to IPv4 flowspec routes and peers of the specified BGP instance. For more information about BGP IPv4 flowspec address family view, see flowspec configuration in ACL and QoS Configuration Guide. |
BGP-VPN IPv4 flowspec address family view |
Configurations in this view apply to IPv4 flowspec routes and peers of the specified VPN instance in the specified BGP instance. For more information about BGP-VPN IPv4 flowspec address family view, see flowspec configuration in ACL and QoS Configuration Guide. |
BGP IPv6 flowspec address family view |
Configurations in this view apply to IPv6 flowspec routes and peers of the specified BGP instance. For more information about BGP IPv6 flowspec address family view, see flowspec configuration in ACL and QoS Configuration Guide. |
BGP-VPN IPv6 flowspec address family view |
Configurations in this view apply to IPv6 flowspec routes and peers of the specified VPN instance in the specified BGP instance. For more information about BGP-VPN IPv6 flowspec address family view, see flowspec configuration in ACL and QoS Configuration Guide. |
BGP VPNv4 flowspec address family view |
Configurations in this view apply to VPNv4 flowspec routes and peers of the specified BGP instance. For more information about BGP VPNv4 flowspec address family view, see flowspec configuration in ACL and QoS Configuration Guide. |
BGP VPNv6 flowspec address family view |
Configurations in this view apply to VPNv6 flowspec routes and peers of the specified BGP instance. For more information about BGP VPNv6 flowspec address family view, see flowspec configuration in ACL and QoS Configuration Guide. |
Protocols and standards
· RFC 1700, ASSIGNED NUMBERS
· RFC 1997, BGP Communities Attribute
· RFC 2439, BGP Route Flap Damping
· RFC 2545, Use of BGP-4 Multiprotocol Extensions for IPv6 Inter-Domain Routing
· RFC 2918, Route Refresh Capability for BGP-4
· RFC 3107, Carrying Label Information in BGP-4
· RFC 4271, A Border Gateway Protocol 4 (BGP-4)
· RFC 4275, BGP-4 MIB Implementation Survey
· RFC 4277, Experience with the BGP-4 Protocol
· RFC 4360, BGP Extended Communities Attribute
· RFC 4364, BGP/MPLS IP Virtual Private Networks (VPNs)
· RFC 4382, MPLS/BGP Layer 3 Virtual Private Network (VPN) Management
· RFC 4451, BGP MULTI_EXIT_DISC (MED) Considerations
· RFC 4456, BGP Route Reflection: An Alternative to Full Mesh Internal BGP
· RFC 4486, Subcodes for BGP Cease Notification Message
· RFC 4659, BGP-MPLS IP Virtual Private Network (VPN) Extension for IPv6 VPN
· RFC 4684, Constrained Route Distribution for Border Gateway Protocol/MultiProtocol Label Switching (BGP/MPLS) Internet Protocol (IP) Virtual Private Networks (VPNs)
· RFC 4724, Graceful Restart Mechanism for BGP
· RFC 4760, Multiprotocol Extensions for BGP-4
· RFC 4781, Graceful Restart Mechanism for BGP with MPLS
· RFC 5004, Avoid BGP Best Path Transitions from One External to Another
· RFC 5065, Autonomous System Confederations for BGP
· RFC 5082, The Generalized TTL Security Mechanism (GTSM)
· RFC 5291, Outbound Route Filtering Capability for BGP-4
· RFC 5292, Address-Prefix-Based Outbound Route Filter for BGP-4
· RFC 5492, Capabilities Advertisement with BGP-4
· RFC 5549, Advertising IPv4 Network Layer Reachability Information with an IPv6 Next Hop
· RFC 5668, 4-Octet AS Specific BGP Extended Community
· RFC 6037, Cisco Systems' Solution for Multicast in BGP MPLS IP VPNs
· RFC 6198, Requirements for the Graceful Shutdown of BGP Sessions
· RFC 6368, Internal BGP as the Provider/Customer Edge Protocol for BGP/MPLS IP
· RFC 6513, Multicast in MPLS/BGP IP VPNs
· RFC 6514, BGP Encodings and Procedures for Multicast in MPLS/BGP IP VPNs
· RFC 6515, IPv4 and IPv6 Infrastructure Addresses in BGP Updates for Multicast VPN
· RFC 6608, Subcodes for BGP Finite State Machine Error
· RFC 6624, Layer 2 Virtual Private Networks Using BGP for Auto-Discovery and Signaling
· RFC 6793, BGP Support for Four-Octet Autonomous System (AS) Number Space
· RFC 6811, BGP Prefix Origin Validation
· RFC 7311, The Accumulated IGP Metric Attribute for BGP
· RFC 7432, BGP MPLS-Based Ethernet VPN
· RFC 7752, North-Bound Distribution of Link-State and Traffic Engineering (TE) Information Using BGP
· RFC 7854, BGP Monitoring Protocol (BMP)
· RFC 7911, Advertisement of Multiple Paths in BGP
· RFC 7947, Internet Exchange BGP Route Server
· RFC 8277, Using BGP to Bind MPLS Labels to Address Prefixes
Building basic BGP networks
Basic BGP network configuration tasks at a glance (IPv4 unicast/IPv4 multicast)
To build basic BGP networks for the IPv4 unicast or IPv4 multicast address family, perform the following tasks:
a. Enabling BGP
c. Configuring dynamic BGP peers
d. Configuring an IBGP peer group
Configure BGP peer groups on large-scale BGP networks for easy configuration and maintenance.
e. Configuring an EBGP peer group
f. (Optional.) Specifying the source address of TCP connections
2. Controlling BGP route generation, advertisement, and reception
¡ Redistributing routes from a non-BGP protocol
¡ (Optional.) Configuring BGP route summarization
¡ (Optional.) Advertising optimal routes in the IP routing table
BGP cannot advertise optimal routes in the IP routing table for IPv4 multicast address family.
¡ (Optional.) Advertising a default route to a peer or peer group
¡ (Optional.) Limiting routes received from a peer or peer group
¡ (Optional.) Configuring BGP IPv4 unicast route and BGP IPv4 labeled unicast route redistribution
¡ (Optional.) Enabling prioritized withdrawal of the default route
¡ (Optional.) Enabling prioritized withdrawal of specific routes
¡ (Optional.) Configuring BGP route distribution filtering policies
¡ (Optional.) Setting the BGP route sending rate
This feature applies only to IPv4 unicast routes.
¡ (Optional.) Configuring BGP route reception filtering policies
¡ (Optional.) Configuring BGP route update delay
¡ (Optional.) Setting the update interval and the maximum number of update messages that can be sent each time
¡ (Optional.) Configuring a startup policy for BGP route updates
¡ (Optional.) Configuring the SoO attribute
¡ (Optional.) Configuring the link bandwidth attribute
¡ Configuring the keepalive interval and hold time
¡ Setting the session retry timer
¡ Configuring the interval for sending updates for the same route
¡ Setting the refresh route advertisement delay timer
¡ Setting an update delay for local MPLS labels
4. (Optional.) Configuring BGP logging and notifications
¡ Enabling logging for session state changes
¡ Enabling logging for BGP route flapping
¡ Configuring BGP network management
Basic BGP network configuration tasks at a glance (IPv6 unicast/IPv6 multicast)
To build basic BGP networks for the IPv6 unicast or IPv6 multicast address family, perform the following tasks:
a. Enabling BGP
¡ (Optional.) Redistributing the local network specified in the public instance or a VPN instance
BGP cannot advertise optimal routes in the IP routing table for IPv6 multicast address family.
This feature applies only to IPv6 unicast routes.
Configuring basic BGP
Enabling BGP
A router ID is the unique identifier of a BGP router in an AS.
· To ensure the uniqueness of a router ID and enhance availability, specify in BGP instance view the IP address of a local loopback interface as the router ID. Different BGP instances can have the same router ID.
· If no router ID is specified in BGP instance view, the global router ID is used.
· To modify a non-zero router ID of a BGP instance , use the router-id command in BGP instance view, rather than the router id command in system view.
· If you specify a router ID in BGP instance view and then remove the interface that owns the router ID, the router does not select a new router ID. To select a new router ID, use the undo router-id command in BGP instance view.
1. Enter system view.
2. Configure a global router ID.
router id router-id
By default, no global router ID is configured.
If no global router ID is configured, the following rules apply:
¡ If loopback interfaces configured with an IP address exist, BGP uses the highest loopback interface IP address as the router ID.
¡ If no loopback interface IP address is available, BGP uses the highest physical interface IP address as the route ID regardless of the interface status.
3. Enable BGP and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4. (Optional.) Configure a router ID for the BGP instance.
router-id router-id
By default, no router ID is configured for a BGP instance, and the BGP instance uses the global router ID configured by the router-id command in system view.
5. (Optional.) Enter BGP-VPN instance view.
The specified VPN instance must have been created and have an RD.
6. (Optional.) Configure a router ID for the BGP VPN instance.
By default, no router ID is configured for a BGP VPN instance.
The BGP VPN instance uses the router ID configured in BGP instance view. If no router ID is configured in BGP instance view, the BGP VPN instance uses the global router ID configured in system view.
Configuring a BGP peer
A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
Procedure (Exchanging IPv4 unicast routes with IPv4 peers)
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Enter BGP-VPN instance view.
3. Create an IPv4 BGP peer and specify its AS number.
4. (Optional.) Configure a description for a peer.
By default, no description is configured for a peer.
5. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
6. Enable the router to exchange IPv4 unicast routing information with the specified peer.
peer ipv4-address enable
By default, the router cannot exchange IPv4 unicast routing information with the peer.
Procedure (Exchanging IPv6 unicast routes with IPv4 peers)
2. Enter BGP instance view.
4. (Optional.) Configure a description for the IPv4 peer.
By default, no description is configured for an IPv4 peer.
5. Create the BGP IPv6 unicast address family and enter its view.
6. Enable BGP to exchange IPv6 unicast routing information with the IPv4 peer.
By default, BGP cannot exchange IPv6 unicast routing information with an IPv4 peer.
7. Use a routing policy to modify the next hop of routes received from the IPv4 peer.
peer ipv4-address route-policy route-policy-name import
Procedure (Exchanging IPv6 unicast routes with IPv6 peers)
3. Create an IPv6 BGP peer and specify its AS number.
5. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
6. Enable the router to exchange IPv6 unicast routing information with the specified peer.
peer ipv6-address enable
By default, the router cannot exchange IPv6 unicast routing information with the peer.
Procedure (Exchanging IPv4 unicast routes with IPv6 peers)
4. (Optional.) Configure a description for the IPv6 peer.
By default, no description is configured for an IPv6 peer.
5. Create the BGP IPv4 unicast address family and enter its view.
6. Enable BGP to exchange IPv4 unicast routing information with the IPv6 peer.
By default, BGP cannot exchange IPv4 unicast routing information with an IPv6 peer.
7. Use a routing policy to modify the next hop of routes received from the IPv6 peer.
peer ipv6-address route-policy route-policy-name import
Procedure (Exchanging IPv4 labeled unicast routes with IPv4 peers)
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
5. Create the BGP IPv4 labeled unicast address family or BGP-VPN IPv4 labeled unicast address family, and enter its view.
address-family ipv4 labeled-unicast
6. Enable BGP to exchange IPv4 labeled unicast routing information with the IPv4 peer.
By default, BGP cannot exchange IPv4 labeled unicast routing information with an IPv4 peer.
Procedure (Exchanging IPv4 multicast routes with IPv4 peers)
4. (Optional.) Configure a description for the peer.
5. Create the BGP IPv4 multicast address family and enter its view.
address-family ipv4 multicast
6. Enable the router to exchange IPv4 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peer.
Procedure (Exchanging IPv6 multicast routes with IPv4 peers)
5. Create the BGP IPv6 multicast address family and enter its view.
address-family ipv6 multicast
6. Enable the router to exchange IPv6 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peer.
Procedure (Exchanging IPv4 multicast routes with IPv6 peers)
Procedure (Exchanging IPv6 multicast routes with IPv6 peers)
This feature enables BGP to establish dynamic BGP peer relationships with devices in a network. BGP accepts connection requests from the network but it does not initiate connection requests to the network.
After a device in the network initiates a connection request, BGP establishes a dynamic peer relationship with the device.
If multiple BGP peers reside in the same network, you can use this feature to simplify BGP peer configuration.
For a remote device to establish a peer relationship with the local device, you must specify the IP address of the local device on the remote device.
If the local device establishes a dynamic peer relationship with an IP address after network segment matching, you cannot configure a static peer relationship between the local device and that IP address. When you configure an IP address as a static peer, the IP address might be in a network segment associated with a dynamic peer. To ensure successful peer creation, create the dynamic peer only after you finish creating the static peer. For example, a dynamic peer is created with network segment 10.1.1.0/24 and the local device has established a BGP connection with 10.1.1.1 based on this configuration. In this situation, you cannot configure IP address 10.1.1.1 as a static peer for the local device. On the contrary, if you first configure IP address 10.1.1.1 as a static peer, you can continue to create a dynamic peer with network segment 10.1.1.0/24.
Procedure (Exchanging IPv4 unicast routes with dynamic IPv4 peers)
3. Specify devices in a network as dynamic BGP peers and specify an AS number for the peers.
4. (Optional.) Configure a description for dynamic BGP peers.
By default, no description is configured for dynamic BGP peers.
6. Enable BGP to exchange IPv4 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic BGP peers.
Procedure (Exchanging IPv6 unicast routes with dynamic IPv4 peers)
3. Specify devices in an IPv4 network as dynamic IPv4 BGP peers and specify an AS number for the peers.
By default, no description is configured for dynamic peers.
6. Enable BGP to exchange IPv6 unicast routing information with the dynamic IPv4 peers.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic IPv4 peers.
7. Use a routing policy to modify the next hop of routes received from the dynamic IPv4 peers.
peer ipv4-address mask-length route-policy route-policy-name import
Procedure (Exchanging IPv6 unicast routes with dynamic IPv6 peers)
6. Enable BGP to exchange IPv6 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic BGP peers.
Procedure (Exchanging IPv4 unicast routes with dynamic IPv6 peers)
3. Specify devices in an IPv6 network as dynamic IPv6 BGP peers and specify an AS number for the peers.
4. (Optional.) Configure a description for the dynamic IPv6 peers.
6. Enable BGP to exchange IPv4 unicast routing information with dynamic IPv6 peers.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic IPv6 peers.
7. Use a routing policy to modify the next hop of routes received from the dynamic IPv6 peers.
peer ipv6-address prefix-length route-policy route-policy-name import
Procedure (Exchanging IPv4 labeled unicast routes with dynamic IPv4 peers)
4. (Optional.) Configure a description for the dynamic IPv4 peers.
6. Enable BGP to exchange IPv4 labeled unicast routing information with dynamic IPv4 peers.
By default, BGP cannot exchange IPv4 labeled unicast routing information with dynamic IPv4 peers.
Procedure (Exchanging IPv4 multicast routes with dynamic IPv4 peers)
6. Enable BGP to exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers.
Procedure (Exchanging IPv6 multicast routes with dynamic IPv4 peers)
6. Enable BGP to exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers.
Procedure (Exchanging IPv4 multicast routes with dynamic IPv6 peers)
Procedure (Exchanging IPv6 multicast routes with dynamic IPv6 peers)
A peer group is an IBGP peer group if peers in it belong to the same AS as the local router.
After you create an IBGP peer group and then add a peer into it, the system creates the peer in BGP instance view and specifies the local AS number for the peer.
If you configure a BGP setting at both the peer group and the peer level, the most recent configuration takes effect on the peer.
3. Create an IBGP peer group.
group group-name [ internal ]
4. Add a peer into the IBGP peer group.
The as-number as-number option must specify the local AS number.
5. (Optional.) Configure a description for the peer group.
By default, no description is configured for the peer group.
6. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
7. Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
peer group-name enable
By default, the router cannot exchange IPv4 unicast routing information with the peers.
4. Add an IPv4 peer into the IBGP peer group.
By default, no description is configured for a peer group.
6. Create the BGP IPv6 unicast address family and enter its view.
7. Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv6 unicast routing information with peers in a peer group.
8. Use a routing policy to modify the next hop of routes received from peers in the peer group.
peer group-name route-policy route-policy-name import
bgp as-number[ instance instance-name ]
6. Create the BGP IPv4 labeled unicast address family or BGP-VPN IPv4 labeled unicast address family, and enter its view.
7. Enable BGP to exchange IPv4 labeled unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv4 labeled unicast routing information with peers in a peer group.
6. Create the BGP IPv4 multicast address family and enter its view.
7. Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the peer group.
6. Create the BGP IPv6 multicast address family and enter its view.
7. Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the peer group.
6. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
7. Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information with the peers.
4. Add an IPv6 peer into the IBGP peer group.
6. Create the BGP IPv4 unicast address family and enter its view.
7. Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv4 unicast routing information with peers in a peer group.
A peer group is an EBGP peer group if peers in it belong to different ASs.
If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group. If not, it is a mixed EBGP peer group.
Use one of the following methods to configure an EBGP peer group:
· Method 1—Create an EBGP peer group, specify its AS number, and add peers into it. All the added peers have the same AS number. All peers in the peer group have the same AS number as the peer group. You can specify an AS number for a peer before adding it into the peer group. The AS number must be the same as that of the peer group.
· Method 2—Create an EBGP peer group, specify an AS number for a peer, and add the peer into the peer group. Peers added in the group can have different AS numbers.
· Method 3—Create an EBGP peer group and add a peer with an AS number into it. Peers added in the group can have different AS numbers.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 unicast routes with IPv4 peers)
3. Create an EBGP peer group.
group group-name external
4. Specify the AS number of the group.
By default, no AS number is specified.
If a peer group contains peers, you cannot remove or change its AS number.
5. Add a peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer group-name as-number as-number command.
6. (Optional.) Configure a description for the peer group.
7. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
8. Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 unicast routes with IPv4 peers)
4. Create an IPv4 BGP peer and specify its AS number.
5. Add the peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer ipv4-address [ mask-length ] as-number as-number command.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 unicast routes with IPv4 peers)
4. Add a peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 labeled unicast routes with IPv4 peers)
7. Create the BGP IPv4 labeled unicast address family or BGP-VPN IPv4 labeled unicast address family, and enter its view.
8. Enable BGP to exchange IPv4 labeled unicast routing information with peers in the specified peer group.
By default, BGP cannot exchange IPv4 labeled unicast routing information with the peers.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 labeled unicast routes with IPv4 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 labeled unicast routes with IPv4 peers)
7. Enable BGP to exchange IPv4 labeled unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 unicast routes with IPv4 peers)
4. Specify an AS number for the peer group.
By default, no AS number is specified for a peer group.
5. Add an IPv4 peer into the EBGP peer group.
7. Create the BGP IPv6 unicast address family and enter its view.
8. Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
9. Use a routing policy to modify the next hop of routes received from peers in the peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 unicast routes with IPv4 peers)
5. Add the IPv4 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 unicast routes with IPv4 peers)
4. Add an IPv4 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 multicast routes with IPv4 peers)
5. Add an IPv4 BGP peer into the EBGP peer group.
7. Create the BGP IPv4 multicast address family and enter its view.
8. Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 multicast routes with IPv4 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 multicast routes with IPv4 peers)
4. Add an IPv4 BGP peer into the EBGP peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 multicast routes with IPv4 peers)
7. Create the BGP IPv6 multicast address family and enter its view.
8. Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 multicast routes with IPv4 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 multicast routes with IPv4 peers)
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 unicast routes with IPv6 peers)
7. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
8. Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 unicast routes with IPv6 peers)
4. Create an IPv6 BGP peer and specify its AS number.
peer ipv6-address [ prefix-length ] as-number as-number
The as-number as-number option must specify the same AS number as the peer ipv6-address [ prefix-length ] as-number as-number command.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 unicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 unicast routes with IPv6 peers)
5. Add an IPv6 peer into the EBGP peer group.
7. Create the BGP IPv4 unicast address family and enter its view.
8. Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 unicast routes with IPv6 peers)
5. Add the IPv6 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 unicast routes with IPv6 peers)
4. Add an IPv6 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 multicast routes with IPv6 peers)
5. Add an IPv6 BGP peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 multicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 multicast routes with IPv6 peers)
4. Add an IPv6 BGP peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 multicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 multicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 multicast routes with IPv6 peers)
BGP uses TCP as the transport layer protocol. Perform this task in the following scenarios to specify the source address or source interface of TCP connections to a peer or peer group:
· The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡ Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡ Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
· A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
· On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this problem, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
· You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this problem, use one of the following methods:
¡ If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡ If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
· The source address of a TCP connection is borrowed by another interface. When the status of the interface changes, the BGP session cannot respond to the changes correctly. To resolve this problem, you must use the peer connect-interface command to specify the interface that borrows the source address as the source interface of the TCP connection.
BGP immediately terminates the session to an IBGP peer or peer group when the following conditions exist:
· The source interface of TCP connections to the IBGP peer or peer group is a physical interface.
· The source interface fails and the link to the IBGP peer or peer group goes down.
Procedure (IPv4 peers)
Table 11 Enter system view.
3. Specify the source address or source interface of TCP connections to a peer or peer group.
¡ Specify the source address of TCP connections to a peer or peer group.
¡ Specify the source interface of TCP connections to a peer or peer group.
By default, BGP uses the primary IPv4 address of the output interface in the optimal route to a peer or peer group as the source address of TCP connections to the peer or peer group.
Procedure (IPv6 peers)
3. Specify the source IPv6 address or source interface of TCP connections to a peer or peer group.
¡ Specify the source IPv6 address of TCP connections to a peer or peer group.
By default, BGP uses the IPv6 address of the output interface in the optimal route to the BGP peer or peer group as the source address of TCP connections to the peer or peer group.
Injecting a local network
Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
The specified network must be available and active in the local IP routing table.
Procedure (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 labeled unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 labeled unicast address family view:
3. Configure BGP to advertise a local network.
By default, BGP does not advertise local networks.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
Perform this task to configure route redistribution from a non-BGP protocol to BGP.
By default, BGP does not redistribute default IGP routes. You can use the default-route imported command to redistribute default IGP routes into the BGP routing table.
The ORIGIN attribute of BGP routes redistributed from IGPs is INCOMPLETE.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol or display ipv6 routing-table protocol command. For more information about the commands, see Layer 3—IP Routing Command Reference.
If you execute the import-route command multiple times for an IGP process, the most recent configuration takes effect. To redistribute more routes from an IGP process without overwriting the routes redistributed before, use the import-route-append command.
When you execute both the import-route and import-route-append commands for an IGP process, the commands take effect as follows:
· A route is redistributed as long as it matches the criteria of either command.
· If a route matches the criteria of both commands, the route is redistributed, and the apply clauses in the routing policies specified in the two commands take effect as follows:
¡ If the apply clauses do not conflict, all apply clauses take effect.
¡ If conflicts occur between the apply clauses, only the apply clauses in the import-route-append command take effect.
· The MED value specified by the import-route-append command takes precedence over that specified by the import-route command.
3. Enable route redistribution from the specified IGP into BGP.
¡ Redistribute IS-IS, RIP, or OSPF routes.
¡ Redistribute direct or static routes.
import-route { direct | static | unr } [ med med-value | route-policy route-policy-name ] *
¡ Redistribute EIGRP routes.
import-route eigrp [ { eigrp-as | all-as } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
By default, BGP does not redistribute IGP routes.
4. (Optional.) Redistribute routes from an IGP without overwriting the routes redistributed by the import-route command.
import-route-append { isis | ospf | rip } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
import-route-append { direct | static | unr } [ med med-value | route-policy route-policy-name ] *
import-route-append eigrp [ { eigrp-as | all-as } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
5. (Optional.) Redistribute all routes with the same destination address.
import-route multipath
By default, BGP redistributes only the optimal routes to its routing table when multiple routes with the same destination address exist.
This command is not supported in BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
This command takes effect only on the routes redistributed by the import-route command or the import-route-append command in the same address family.
6. (Optional.) Enable default route redistribution into BGP.
By default, BGP does not redistribute default routes.
¡ Redistribute IPv6 IS-IS, RIPng, or OSPFv3 routes.
import-route-append { isisv6 | ospfv3 | ripng } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
This command is not supported in BGP IPv6 multicast address family view.
Perform this task to redistribute the local network specified in the public instance or a VPN instance to the BGP routing table, so BGP can advertise the network route. The ORIGIN attribute is IGP for routes advertised in this way.
The local network specified in the network command must exist and be active in the routing table of the public instance or VPN instance.
2. Enter public instance IPv4 address family view or VPN instance IPv4 address family view.
¡ Execute the following commands in sequence to enter public instance IPv4 address family view:
ip public-instance
address-family ipv4
¡ Execute the following commands in sequence to enter VPN instance IPv4 address family view:
address-family ipv4
3. Specify a local network in the public instance or VPN instance.
By default, no local network is specified in the public instance or VPN instance.
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
4. Execute the quit command twice to return to system view.
5. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
¡ Execute the following commands in sequence to enter BGP multicast address family view:
6. Redistribute the local network specified in the public instance or VPN instance.
import-route local-aggregate [ route-policy route-policy-name ]
By default, BGP does not redistribute the local network specified in the public instance or any VPN instances.
Route summarization can reduce the number of redistributed routes and the routing table size. IPv4 BGP supports automatic route summarization and manual route summarization. Manual summarization takes precedence over automatic summarization. IPv6 BGP supports only manual route summarization.
Automatic route summarization enables BGP to summarize IGP subnet routes redistributed by the import-route command, so BGP advertises only natural network routes.
By configuring manual route summarization, you can do the following:
· Summarize both redistributed routes and routes injected using the network command.
· Determine the mask length for a summary route.
Restrictions and guidelines for configuring BGP route summarization
The output interface of a BGP summary route is Null 0 on the originating router. Therefore, a summary route must not be an optimal route on the originating router. Otherwise, BGP will fail to forward packets matching the route. If a summarized specific route has the same mask as the summary route, but has a lower priority, the summary route becomes the optimal route. To ensure correct packet forwarding, change the priority of the summary or specific route to make the specific route the optimal route.
Configuring automatic route summarization (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
3. Configure automatic route summarization.
summary automatic
By default, automatic route summarization is not configured.
Configuring manual route summarization (IPv4 unicast/multicast address family)
3. Create a summary route in the BGP routing table.
By default, no summary routes are configured.
Configuring BGP manual route summarization (IPv6 unicast/multicast address family)
3. Create a summary route in the IPv6 BGP routing table.
By default, BGP advertises optimal routes in the BGP routing table, which may not be optimal in the IP routing table. This task allows you to advertise BGP routes that are optimal in the IP routing table.
The advertise-rib-active command does not apply to the following routes:
· Routes redistributed by the import-route command.
· Routes advertised by the network command.
· Default routes redistributed by the default-route imported command.
· VPNv4 routes.
· VPNv6 routes.
· IPv4 multicast routes.
· IPv6 multicast routes.
· Subnet routes generated for locators by using the advertise srv6 locator command.
The advertise-rib-active command takes effect only on the routes generated after you execute this command. To apply this command to existing routes, use the reset bgp command to reset BGP sessions.
The setting in BGP unicast address family view applies when it is different from that in BGP instance view.
The advertise-rib-active command is mutually exclusive with the routing-table bgp-rib-only command.
Procedure (IPv4 unicast)
3. Enable BGP to advertise optimal routes in the IP routing table.
By default, BGP advertises optimal routes in the BGP routing table.
4. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
¡ Enter BGP IPv4 unicast address family view.
5. Enable BGP to advertise optimal routes in the IP routing table of the address family in the VPN instance.
By default, the setting is the same as that in BGP instance view.
Procedure (IPv6 unicast)
3. Enable BGP to advertise optimal routes in the IPv6 routing table.
4. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡ Enter BGP IPv6 unicast address family view.
5. Enable BGP to advertise optimal routes in the IPv6 routing table of the address family in the VPN instance.
Perform this task to advertise a default BGP route with the next hop being the advertising router to a peer or peer group.
3. Advertise a default route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ] [ conditional-policy route-policy-name ]
By default, no default route is advertised.
The ipv6-address [ prefix-length ] argument is not supported in BGP IPv4 labeled unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
This feature can prevent attacks that send a large number of BGP routes to the router.
If the number of routes received from a peer or peer group exceeds the upper limit, the router takes one of the following actions based on your configuration:
· Terminates the BGP session to the peer or peer group and does not attempt to re-establish the session.
· Continues to receive routes from the peer or peer group and generates a log message.
· Retains the session to the peer or peer group, but it discards excess routes and generates a log message.
· Terminates the BGP session to the peer or peer group and, after a specific period of time, re-establishes a BGP session to the peer or peer group.
You can specify a percentage threshold for the router to generate a log message. When the ratio of the number of received routes to the maximum number reaches the percentage value, the router generates a log message.
3. Specify the maximum number of routes that a router can receive from a peer or peer group.
By default, the number of routes that a router can receive from a peer or peer group is not limited.
Perform this task to enable mutual route redistribution between the BGP IPv4 unicast address family and BGP IPv4 labeled unicast address family, between the public instance and a VPN instance, or between different VPN instances.
In the MPLS L3VPN inter-AS option C scenario, perform this task to redistribute BGP IPv4 labeled unicast routes to the BGP IPv4 unicast routing table. Then, networks of other ASs can be added to the local IP routing table of the public network, enabling PEs to establish inter-AS multi-hop MP-EBGP sessions. For more information about the inter-AS option C scenario, see MPLS L3VPN configuration in MPLS Configuration Guide.
When you filter the routes to be redistributed by using an ACL, the source IPv4 address in the ACL will be used to match the destination addresses in the routes, and the other matching rules in the ACL will not take effect. If the specified ACL does not contain a source IPv4 address matching rule, the routes will not be filtered.
Before redistributing the BGP IPv4 labeled unicast routes or BGP IPv4 unicast routes of a VPN instance to the current address family, make sure the BGP IPv4 labeled unicast address family or BGP IPv4 unicast address family has been created in the VPN instance.
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
3. Configure BGP IPv4 unicast route and BGP IPv4 labeled unicast route redistribution.
import-rib { public | vpn-instance vpn-instance-name } [ labeled-unicast ] [ valid-route ] [ route-policy route-policy-name | filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } ]
By default, the BGP IPv4 labeled unicast address family and BGP IPv4 unicast address family cannot redistribute routes from each other. The public instance and a VPN instance cannot redistribute BGP IPv4 labeled unicast routes or BGP IPv4 unicast routes from each other. Different VPN instances cannot redistribute BGP IPv4 labeled unicast routes from each other. Different VPN instances can redistribute BGP IPv4 unicast routes from each other if the VPN instances have matching route targets.
Typically a BGP router does not send withdrawal messages of the default route prior to other routes to its peers. If the peer relationship is down, the default route cannot be withdrawn first. Traffic interruption might occur. Perform this task to configure BGP to send the withdrawal messages of the default route prior to other routes. This can reduce the traffic interruption time when the peer relationship is down.
3. Enable BGP to send withdrawal messages of the default route prior to other routes.
default-route update-first
By default, BGP does not send withdrawal messages of the default route prior to other routes.
Perform this task to configure BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast route switchover and reduce the traffic interruption time.
3. Enable BGP to send withdrawal messages of routes matching the specified routing policy prior to other routes.
By default, BGP does not send withdrawal messages of specific routes prior to other routes.
To configure BGP route distribution filtering policies, use the following methods:
· Use an ACL or prefix list to filter routing information advertised to all peers.
· Use a routing policy, conditional advertisement policy (existent policy or nonexistent policy), ACL, AS path list, or prefix list to filter routing information advertised to a peer or peer group.
If you configure multiple filtering policies, apply them in the following sequence:
1. peer prefix-list export
2. peer filter-policy export
3. peer as-path-acl export
4. filter-policy export
5. peer advertise-policy exist-policy
6. peer advertise-policy non-exist-policy
7. peer route-policy export
Only routes passing all the configured policies can be advertised.
Before you configure BGP routing filtering policies, configure the following filters used for route filtering as needed:
· ACL (see ACL and QoS Configuration Guide).
· Prefix list (see "Configuring routing policies").
· Routing policy (see "Configuring routing policies").
· AS path list (see "Configuring routing policies").
When you specify an ACL, prefix list, or routing policy as a filtering policy to filter BGP routing information, follow these restrictions and guidelines:
· If the specified ACL, prefix list, or routing policy does not exist, all BGP routes can pass the filtering policy.
· When you specify an ACL or prefix list as a BGP route filtering policy (for example, use filter-policy export to specify an ACL for route filtering), the following rules apply:
¡ BGP routes can pass the filtering policy only when one of the following conditions exists:
- They match a permit rule in the specified ACL.
- They match a permit item in the specified prefix list.
When the ACL has only deny rules or the prefix list has only deny items, no BGP routes can pass the filtering policy.
¡ When the ACL match order is config, BGP routes match against rules in ascending order of rule ID. When BGP routes match against the items of the prefix list, an item with a smaller index number is matched first.
¡ In either of the match modes above, a BGP route does not match against the next ACL rule or prefix list item when it already matches the current ACL rule or prefix list item. To avoid wasting filter resources, set a small match range for each ACL rule or prefix list item when you configure multiple ACL rules or prefix list items for an ACL or prefix list.
¡ You can use the rule [ rule-id ] permit ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to create a rule for an advanced ACL to match specific routes. The source sour-addr sour-wildcard option represents the destination network address and the destination dest-addr dest-wildcard option represents the mask in dotted decimal notation. For example, to match route 3.3.3.0/24, the rule configuration should be rule [ rule-id ] permit ip source 3.3.3.0 0.0.0.255 destination 255.255.255.0 0.0.0.255.
· When you specify a routing policy as a BGP route filtering policy, the following rules apply:
¡ BGP routes can pass the filtering policy only when they match a permit node in the routing policy.
¡ A BGP route matches against the nodes of the routing policy in ascending order of node number. It does not match against the next node when it already matches the current node (unless a continue clause exists).
¡ If the routing policy has an ACL or prefix-list if-match clause, a BGP route can pass the filtering policy only when the following conditions exist:
- The route matches a permit rule in the ACL or a permit item in the prefix list.
- The route matches a permit node in the routing policy.
3. Configure BGP route distribution filtering policies. Choose the options to configure as needed:
¡ Reference an ACL or IP prefix list to filter advertised BGP routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } export [ direct | isis process-id | ospf process-id | rip process-id | static | unr ]
¡ Specify a routing policy as the existent policy to control route advertisement.
This command is available only in BGP IPv4 unicast address family view.
¡ Specify a routing policy as the nonexistent policy to control route advertisement.
¡ Reference a routing policy to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
¡ Reference an ACL to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } export
¡ Reference an AS path list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } export
¡ Reference an IPv4 prefix list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name export
By default, no BGP distribution filtering policy is configured.
¡ Reference an ACL or IPv6 prefix list to filter advertised BGP routes.
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-list-name } export [ direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static | unr ]
This command is available only in BGP IPv6 unicast address family view.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } export
¡ Reference an IPv6 prefix list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name export
If a device sends many new routes within a short time period, it might be unable to add the routes to the FIB before the peer device adds them. This might result in traffic forwarding failure. To avoid this problem, you can perform this task to set an appropriate route sending rate for the device.
For a device with high performance, you can set a high BGP route sending rate as needed. For a device without high performance, set a relatively low BGP route sending rate as a best practice.
As a best practice to avoid route withdrawal failures, do not set the BGP route sending rate to 0 or a small value when network flapping occurs.
This task applies only to IPv4 unicast routes and IPv6 unicast routes.
3. Set the BGP route sending rate.
route-rate-limit rate
By default, the BGP route sending rate is not limited.
You can use the following methods to configure BGP route reception filtering policies:
· Use an ACL or prefix list to filter routing information received from all peers.
· Use a routing policy, ACL, AS path list, or prefix list to filter routing information received from a peer or peer group.
1. peer filter-policy import
2. peer prefix-list import
3. peer as-path-acl import
4. filter-policy import
5. peer route-policy import
Only routes passing all the configured policies can be received.
Before you configure BGP route reception filtering policies, configure the following filters used for route filtering as needed:
When you specify an ACL, prefix list, or routing policy as a filtering policy to filter BGP routing information, follow these guidelines:
· When you specify an ACL or prefix list as a BGP route filtering policy (for example, use filter-policy import to specify an ACL for route filtering), the following rules apply:
3. Configure BGP route reception filtering policies. Choose the options to configure as needed:
¡ Reference an ACL or IP prefix list to filter BGP routes received from all peers.
¡ Reference a routing policy to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name import
¡ Reference an ACL to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } import
¡ Reference an AS path list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } import
¡ Reference an IPv4 prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name import
By default, no route reception filtering is configured.
¡ Reference ACL or IPv6 prefix list to filter BGP routes received from all peers.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } import
¡ Reference an IPv6 prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name import
Perform this task to configure BGP to delay sending route updates after the device restarts and the BGP process recovers to reduce traffic loss. With this feature enabled, BGP redistributes all routes from other neighbors after the device restarts and the BGP process recovers, selects the optimal route, and then advertises it.
You can specify a prefix list and configure BGP to immediately send route updates for routes that match the prefix list.
For BGP EVPN routes, this feature takes effect only on IP prefix routes and MAC/IP advertisement routes that carry IP routing information.
3. Configure BGP to delay sending route updates after the device restarts and the BGP process recovers.
By default, BGP sends route updates to established peers immediately after the device restarts and the BGP process recovers.
4. (Optional.) Configure BGP to immediately send route updates for routes that match a prefix list.
By default, no prefix list is specified to filter routes.
After you perform this task, the device does not send update messages to its peers within the specified update interval. You can set the update interval and the maximum number of update messages that can be sent each time together.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer advertisement-interval command takes precedence over that of the advertisement-interval command. If you do not configure the peer advertisement-interval command for the peer or peer group, the configuration of the advertisement-interval command takes effect on the peer or peer group.
Procedure (global configuration)
3. Set the interval for sending update messages and the maximum number of update messages that can be sent each time.
advertisement-interval interval count
By default, the device sends update messages to its peers immediately if it needs to update routes. The maximum number of update messages that can be sent each time is unlimited.
Procedure (configuration for a peer or peer group)
3. Set the interval for sending update messages and the maximum number of update messages that can be sent each time to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertisement-interval interval count
By default, the two parameters are not set and the configuration of the advertisement-interval command takes effect.
The configuration of this command takes precedence over that of the advertisement-interval command.
Perform this task to configure BGP to send route updates with the specified attributes within the specified period after reboot.
As shown in Figure 25, if Router B restarts and sends route updates before route convergence completes, traffic sent from Router A through Router B might be lost. This feature enables Router B to send route updates with the specified attribute values within the specified period after reboot, so that Router A can forward traffic through Router C.
3. Specify the period after reboot within which the startup policy is effective.
By default, the startup policy does not take effect.
4. Specify a MED attribute value in the startup policy.
By default, the MED attribute value in the startup policy is 4294967295.
After you configure the SoO attribute for a BGP peer or peer group, BGP adds the SoO attribute into the route updates received from the BGP peer or peer group. In addition, before advertising route updates to the peer or peer group, BGP checks the SoO attribute of the route update against the configured SoO attribute. If they are the same, BGP does not advertise the route updates to the BGP peer or peer group.
3. Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
Perform this task to add the link bandwidth extended community attribute to routes received from a directly connected EBGP peer or peer group. The link bandwidth is the bandwidth of the interface directly connected to the EBGP peer or peer group. After BGP advertises the routes received from the EBGP peer or peer group to other IBGP peers, the IBGP peers can filter routes based on the link bandwidth attribute.
This feature is applicable only to directly connected EBGP peers and peer groups.
If a directly connected EBGP peer or peer group changes to an indirectly connected one, BGP stops adding the link bandwidth attribute to routes received from the EBGP peer or peer group.
3. Enable BGP to add the link bandwidth attribute to routes received from an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from an EBGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } bandwidth
Configuring BGP timers
BGP sends KEEPALIVE messages regularly to keep the BGP session between two routers.
If a router receives no KEEPALIVE or UPDATE message from a peer within the hold time, it terminates the session.
You can configure the keepalive interval and hold time globally or for a peer or peer group. The individual settings take precedence over the global settings.
The actual keepalive interval and hold time are determined as follows:
· If the hold time settings on the local and peer routers are different, the smaller setting is used. If the hold time is 0, BGP does not send KEEPALIVE messages to its peers and never terminates the session.
· If the keepalive interval is not 0, the actual keepalive interval is the smaller one between 1/3 of the hold time and the keepalive interval.
The hold time must be a minimum of three times the keepalive interval.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer timer command takes precedence over that of the timer command. If you do not configure the peer timer command for the peer or peer group, the configuration of the timer command takes effect on the peer or peer group.
3. Configure the keepalive interval and hold time. Choose the options to configure as needed:
¡ Configure the global keepalive interval and hold time.
This command takes effect for new BGP sessions and does not affect existing sessions.
¡ Configure the keepalive interval and hold time for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } timer keepalive keepalive hold holdtime
By default, the keepalive interval is 60 seconds, and hold time is 180 seconds.
The timers configured with the timer and peer timer commands do not take effect until a session is re-established (for example, a session is reset).
peer { group-name | ipv6-address [ prefix-length ] } timer keepalive keepalive hold holdtime
To speed up session establishment to a peer or peer group and route convergence, set a small session retry timer. If the BGP session flaps, you can set a large session retry timer to reduce the impact.
The timer set by the peer timer connect-retry command takes precedence over the timer set by the timer connect-retry command.
3. Set the session retry timer.
¡ Set the session retry timer for all peers or peer groups.
¡ Set the session retry timer for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } timer connect-retry retry-time
By default, the session retry timer is 32 seconds for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } timer connect-retry retry-time
A BGP router sends an UPDATE message to its peers when a route is changed. If the route changes frequently, the BGP router keeps sending updates for the same route, resulting route flapping. To prevent this situation, perform this task to configure the interval for sending updates for the same route to a peer or peer group.
This feature does not take effect on withdrawn routes. For withdrawn routes, BGP sends the withdrawal messages immediately.
3. Configure the interval for sending updates for the same route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } route-update-interval interval
By default, the interval is 15 seconds for an IBGP peer and 30 seconds for an EBGP peer.
peer { group-name | ipv6-address [ prefix-length ] } route-update-interval interval
Setting the refresh route advertisement delay timer
BGP advertises all routes to a peer in the following scenarios:
· BGP establishes a session to the peer for the first time.
· The update group of the peer changes.
· BGP receives route-refresh messages from the peer.
Routes advertised in the above scenarios are called refresh routes.
Perform this task to set the refresh route advertisement delay timer that starts when BGP advertises refresh routes for the first time. BGP delays refresh route advertisement to all peers until the timer expires. After the timer expires, BGP advertises refresh routes to the corresponding peers by update group, which improves route advertisement efficiency and saves system resources.
3. Set the refresh route advertisement delay timer.
refresh delay delay-value
By default, the refresh route advertisement delay timer is five seconds.
Setting an update delay for local MPLS labels
BGP includes local MPLS labels in advertised VPNv4 routes, VPNv6 routes, labeled IPv4 unicast routes, and labeled IPv6 unicast routes.
When a local label is changed, BGP removes the old label and advertises the new label. Traffic interruption occurs if BGP peers use the old label to forward packets before they learn the new label. To resolve this issue, set an update delay for local MPLS labels. BGP does not remove the old label before the update delay timer expires.
1. Enter system view.
3. Set an update delay for local MPLS labels.
retain local-label retain-time
By default, the update delay is 60 seconds.
Configuring BGP logging and notifications
Enabling logging for session state changes
Perform this task to enable BGP to log BGP session establishment and disconnection events. To display the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration.
For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
3. Enable logging for session state changes globally.
log-peer-change
By default, logging for session state changes is enabled globally.
4. (Optional.) Enter BGP-VPN instance view.
5. Enable logging for session state changes for a peer or peer group.
By default, logging for session state changes is enabled for all peers and peer groups.
log-peer-change
peer { group-name | ipv6-address [ prefix-length ] } log-change
Enabling logging for BGP route flapping
This feature enables BGP to generate logs for BGP route flapping events that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
Procedure (IPv4 unicast/IPv4 multicast)
3. Enable logging for BGP route flapping.
log-route-flap monitor-time monitor-count [ route-policy route-policy-name ] [ log-count-limit ]
By default, logging for BGP route flapping is disabled.
Procedure (IPv6 unicast/IPv6 multicast)
Configuring BGP network management
After you enable SNMP notifications for BGP, the device generates a notification when a BGP session state change occurs. The notification includes the neighbor address, the error code and subcode of the most recent error, and the current neighbor state. For BGP notifications to be sent correctly, you must also configure SNMP on the device.
You can use the snmp-agent trap bgp peer-state-change extended command to enable BGP to generate SNMP notifications for BGP session state changes in extended format. Compared with the standard format, the extended format additionally carries VPN instance information, which facilitates troubleshooting.
BGP does not know the BGP instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different BGP instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
· For an SNMPv3 packet:
¡ The device selects the MIB of the default BGP instance if the packet does not carry a context and no SNMP context is configured for the default BGP instance.
¡ The device selects the MIB of a BGP instance if the packet meets the following conditions:
- Carries a context that is configured with the snmp-agent context command in system view.
- Matches the context of the BGP instance.
¡ The device does not process any MIBs in other situations.
· For an SNMPv1/v2c packet:
¡ The device selects the MIB of the default BGP instance if the following conditions are met:
- No community name-to-SNMP context mapping is configured with the snmp-agent community-map command in system view.
- No SNMP context is configured for the default BGP instance.
¡ The device selects the MIB of a BGP instance if the community name is mapped to an SNMP context and the context matches the context of the BGP instance.
For more information about SNMP contexts and community names, see SNMP configuration in Network Management and Monitoring Configuration Guide.
Table 12 Enter system view.
2. Enable SNMP notifications for BGP.
snmp-agent trap enable bgp [ instance instance-name ] [ peer-addrfamily-routeexceed | peer-addrfamily-routeexceed-clear | peer-addrfamily-routethreshold-clear | peer-addrfamily-routethreshold-exceed | peer-backward-transition | peer-established | peer-gr-status-change | peer-routeexceed | peer-routeexceed-clear | peer-routethreshold-clear | peer-routethreshold-exceed | peer-rpkisession-roaexceed | peer-rpkisession-roaexceed-clear | vrfroutenum-threshold-exceed | vrfroutenum-threshold-clear ] *
By default, SNMP notifications for BGP are enabled.
3. (Optional.) Extend the standard format of SNMP notifications for BGP session state changes.
snmp-agent trap bgp [ instance instance-name ] peer-state-change extended
By default, the system does not extend the standard format of SNMP notifications for BGP session state changes.
CAUTION: This command might disable Network Management System (NMS) from parsing SNMP notifications if NMS does not support the extended format. Make sure you have understood the potential impact before using this command. |
4. Enter BGP instance view.
5. Configure an SNMP context for the BGP instance.
By default, no SNMP context is configured for the BGP instance.
Display and maintenance commands for basic BGP network building
Displaying BGP
Displaying BGP
Task |
Command |
Display peer state information and peer statistics collected from all BGP address families. |
display bgp [ instance instance-name ] all peer summary |
Displaying BGP (IPv4 unicast address family)
Task |
Command |
Display BGP IPv4 unicast peer group information. |
display bgp [ instance instance-name ] group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display information about a peer or peer group in BGP IPv4 unicast address family. |
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 [ unicast ] vpn-instance-all [ verbose ] |
Display BGP IPv4 unicast routing information. |
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ][ longest-match ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-community-list-number | adv-large-community-list-number | large-comm-list-name } } [ whole-match ] display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] time-range min-time max-time |
Display BGP IPv4 unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display BGP peer and route summary information. |
display bgp [ instance instance-name ] ipv4 vpn-instance vpn-instance-name summary |
Display information about BGP peer relationship down events. |
display bgp [ instance instance-name ] troubleshooting [ event-count ] [ reverse ] |
Display BGP IPv4 unicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address ] display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address ] |
Display information about all BGP instances. |
display bgp instance-info |
Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command. |
display bgp [ instance instance-name ] network ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Displaying BGP (IPv6 unicast address family)
Task |
Command |
Display BGP IPv6 unicast peer group information. |
display bgp [ instance instance-name ] group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display information about a peer or peer group in BGP IPv6 unicast address family. |
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv6 [ unicast ] vpn-instance-all [ verbose ] |
Display BGP IPv6 unicast routing information. |
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv6-address prefix-length [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-comm-list-number | adv-large-comm-list-number | large-comm-list-name } } [ whole-match ] display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] time-range min-time max-time |
Display BGP IPv6 unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
display bgp [ instance instance-name ] ipv6 vpn-instance vpn-instance-name summary |
Display BGP IPv6 unicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ ipv4-address | ipv6-address ] display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address ] |
display bgp [ instance instance-name ] network ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Displaying BGP (IPv4 labeled unicast address family)
Task |
Command |
Display state and statistics information about BGP IPv4 labeled unicast peers or peer groups. |
display bgp [ instance instance-name ] peer ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 labeled-unicast vpn-instance-all [ verbose ] |
Display BGP IPv4 labeled unicast routing information. |
display bgp [ instance instance-name ] routing-table ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ][ longest-match ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] peer ipv4-address { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] time-range min-time max-time |
Display BGP IPv4 labeled unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display incoming labels of BGP IPv4 labeled unicast routes. |
display bgp [ instance instance-name ] routing-table ipv4 [ vpn-instance vpn-instance-name ] labeled-unicast inlabel |
Display outgoing labels of BGP IPv4 labeled unicast routes. |
display bgp [ instance instance-name ] routing-table ipv4 [ vpn-instance vpn-instance-name ] labeled-unicast outlabel |
Display BGP IPv4 labeled unicast peer group information. |
display bgp [ instance instance-name ] group ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display BGP IPv4 labeled unicast update group information. |
display bgp [ instance instance-name ] update-group ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address ] |
display bgp [ instance instance-name ] network ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] |
Displaying BGP (IPv4 multicast address family)
Task |
Command |
Display BGP IPv4 multicast peer group information. |
display bgp [ instance instance-name ] group ipv4 multicast [ group-name group-name ] |
Display BGP IPv4 multicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv4 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 multicast [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ] |
Display BGP IPv4 multicast routing information. |
display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ mask-length | mask ][ longest-match ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ mask-length | mask ] ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-comm-list-number | adv-large-comm-list-number | large-comm-list-name } } [ whole-match ] display bgp [ instance instance-name ] routing-table ipv4 multicast peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table ipv4 multicast time-range min-time max-time |
Display BGP IPv4 multicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display BGP path attribute information. |
display bgp [ instance instance-name ] paths [ as-regular-expression ] |
Display BGP IPv4 multicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv4 multicast [ ipv4-address ] display bgp [ instance instance-name ] update-group ipv4 multicast [ ipv6-address ] |
display bgp [ instance instance-name ] network ipv4 multicast |
Displaying BGP (IPv6 multicast address family)
Task |
Command |
Display BGP IPv6 multicast peer group information. |
display bgp [ instance instance-name ] group ipv6 multicast [ group-name group-name ] |
Display BGP IPv6 multicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv6 multicast [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] display bgp [ instance instance-name ] peer ipv6 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display BGP IPv6 multicast routing information. |
display bgp [ instance instance-name ] routing-table ipv6 multicast [ ipv6-address prefix-length [ advertise-info ] | as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv6-address prefix-length [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv6 multicast [ ipv6-address prefix-length ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-comm-list-number | adv-large-comm-list-number | large-comm-list-name } } [ whole-match ] display bgp [ instance instance-name ] routing-table ipv6 multicast peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table ipv6 multicast time-range min-time max-time |
Display BGP IPv6 multicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display BGP IPv6 multicast address family update group information. |
display bgp [ instance instance-name ] update-group ipv6 multicast [ ipv6-address ] display bgp [ instance instance-name ] update-group ipv6 multicast [ ipv4-address ] |
display bgp [ instance instance-name ] network ipv6 multicast |
Resetting BGP sessions
CAUTION: A reset operation terminates BGP sessions for a short period of time. |
Execute reset commands in user view.
Task |
Command |
Reset all BGP sessions. |
reset bgp [ instance instance-name ] all |
Reset BGP sessions for IPv4 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp ipv6-address [ mask-length ] ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for IPv6 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp ipv4-address [ mask-length ] ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for IPv4 labeled unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for IPv4 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv4 multicast |
Reset BGP sessions for IPv6 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 multicast |
Clearing BGP information
Task |
Command |
Clear flap information for BGP IPv4 unicast routes. |
reset bgp [ instance instance-name ] flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ] |
Clear flap information for BGP IPv6 unicast routes. |
reset bgp [ instance instance-name ] flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ] |
Clear flap information for BGP IPv4 labeled unicast routes. |
reset bgp [ instance instance-name ] flap-info ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ] |
Clear flap information for BGP IPv4 multicast routes. |
reset bgp [ instance instance-name ] flap-info ipv4 multicast [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer { ipv4-address [ mask-length ] | ipv6-address [ prefix -length ] } ] |
Clear flap information for BGP IPv6 multicast routes. |
reset bgp [ instance instance-name ] flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer { ipv4-address [ mask-length ] | ipv6-address [ prefix -length ] } ] |
Basic IPv4 BGP network configuration examples
Example: Configuring basic BGP
As shown in Figure 26, all routers run BGP. Run EBGP between Router A and Router B, and run IBGP between Router B and Router C to allow Router C to access network 8.1.1.0/24 connected to Router A.
Table 13 Configure IP addresses for interfaces. (Details not shown.)
Table 14 Configure IBGP:
¡ To prevent route flapping caused by port state changes, this example uses loopback interfaces to establish IBGP connections.
¡ Because loopback interfaces are virtual interfaces, you need to use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections.
¡ Enable OSPF in AS 65009 to ensure that Router B can communicate with Router C through loopback interfaces.
# Configure Router B.
<RouterB> system-view
[RouterB] bgp 65009
[RouterB-bgp-default] router-id 2.2.2.2
[RouterB-bgp-default] peer 3.3.3.3 as-number 65009
[RouterB-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 3.3.3.3 enable
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] bgp 65009
[RouterC-bgp-default] router-id 3.3.3.3
[RouterC-bgp-default] peer 2.2.2.2 as-number 65009
[RouterC-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 2.2.2.2 enable
[RouterC-bgp-default-ipv4] quit
[RouterC-bgp-default] quit
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
[RouterC] display bgp peer ipv4
BGP local router ID : 3.3.3.3
Local AS number : 65009
Total number of peers : 1 Peers in established state : 1
* - Dynamically created peer
2.2.2.2 65009 7 10 0 0 00:06:09 Established
The output shows that Router C has established an IBGP peer relationship with Router B.
Table 15 Configure EBGP:
¡ The EBGP peers, Router A and Router B (usually in different ISPs), are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so directly connected interfaces are used for establishing EBGP sessions.
¡ To enable Router C to access the network 8.1.1.0/24 connected directly to Router A, inject network 8.1.1.0/24 to the BGP routing table of Router A.
# Configure Router A.
[RouterA] bgp 65008
[RouterA-bgp-default] router-id 1.1.1.1
[RouterA-bgp-default] peer 3.1.1.1 as-number 65009
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 3.1.1.1 enable
[RouterA-bgp-default-ipv4] network 8.1.1.0 24
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
[RouterB] bgp 65009
[RouterB-bgp-default] peer 3.1.1.2 as-number 65008
[RouterB-bgp-default-ipv4] peer 3.1.1.2 enable
# Display BGP peer information on Router B.
[RouterB] display bgp peer ipv4
BGP local router ID : 2.2.2.2
Total number of peers : 2 Peers in established state : 2
3.3.3.3 65009 12 10 0 3 00:09:16 Established
3.1.1.2 65008 3 3 0 1 00:00:08 Established
The output shows that Router B has established an IBGP peer relationship with Router C and an EBGP peer relationship with Router A.
# Display the BGP routing table on Router A.
[RouterA] display bgp routing-table ipv4
Total number of routes: 1
Status codes: * - valid, > - best, d - dampened, h - history
a - additional-path
* > 8.1.1.0/24 8.1.1.1 0 32768 i
# Display the BGP routing table on Router B.
[RouterB] display bgp routing-table ipv4
a - additional-path
* >e 8.1.1.0/24 3.1.1.2 0 0 65008i
# Display the BGP routing table on Router C.
[RouterC] display bgp routing-table ipv4
a - additional-path
i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
The outputs show that Router A has no route to AS 65009, and Router C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
Table 16 Redistribute direct routes:
Configure BGP to redistribute direct routes on Router B, so Router A can obtain the route to 9.1.1.0/24, and Router C can obtain the route to 3.1.1.0/24.
[RouterB] bgp 65009
[RouterB-bgp-default-ipv4] import-route direct
Total number of routes: 4
a - additional-path
* >e 2.2.2.2/32 3.1.1.1 0 0 65009?
* >e 3.1.1.0/24 3.1.1.1 0 0 65009?
* >e 9.1.1.0/24 3.1.1.1 0 0 65009?
Two routes 2.2.2.2/32 and 9.1.1.0/24 have been added in Router A's routing table.
a - additional-path
* >i 2.2.2.2/32 2.2.2.2 0 100 0 ?
* >i 3.1.1.0/24 2.2.2.2 0 100 0 ?
* >i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
* >i 9.1.1.0/24 2.2.2.2 0 100 0 ?
The output shows that the route 8.1.1.0 has become valid and the next hop is Router A.
# Verify that Router C can ping 8.1.1.1.
[RouterC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 8.1.1.1: icmp_seq=0 ttl=255 time=5.311 ms
56 bytes from 8.1.1.1: icmp_seq=1 ttl=255 time=1.719 ms
56 bytes from 8.1.1.1: icmp_seq=2 ttl=255 time=1.502 ms
56 bytes from 8.1.1.1: icmp_seq=3 ttl=255 time=1.809 ms
56 bytes from 8.1.1.1: icmp_seq=4 ttl=255 time=1.701 ms
round-trip min/avg/max/std-dev = 1.502/2.048/5.311/1.455 ms
Example: Configuring BGP and IGP route redistribution
As shown in Figure 27, all devices of company A belong to AS 65008 and all devices of company B belong to AS 65009.
Configure BGP and IGP route redistribution to allow Router A to access network 9.1.2.0/24 in AS 65009, and Router C to access network 8.1.1.0/24 in AS 65008.
Table 17 Configure IP addresses for interfaces. (Details not shown.)
Table 18 Configure OSPF:
Enable OSPF in AS 65009, so Router B can obtain the route to 9.1.2.0/24.
[RouterB] ospf 1
[RouterC] ospf 1
[RouterC-ospf-1] import-route direct
Table 19 Configure the EBGP connection:
Configure the EBGP connection and inject network 8.1.1.0/24 to the BGP routing table of Router A, so Router B can obtain the route to 8.1.1.0/24.
[RouterA] bgp 65008
[RouterB] bgp 65009
Table 20 Configure BGP and IGP route redistribution:
¡ Configure BGP to redistribute routes from OSPF on Router B, so Router A can obtain the route to 9.1.2.0/24.
¡ Configure OSPF to redistribute routes from BGP on Router B, so that Router C can obtain the route to 8.1.1.0/24.
# Configure route redistribution between BGP and OSPF on Router B.
[RouterB-bgp-default-ipv4] import-route ospf 1
[RouterB] ospf 1
[RouterB-ospf-1] import-route bgp
Total number of routes: 3
a - additional-path
* >e 3.3.3.3/32 3.1.1.1 1 0 65009?
* >e 9.1.2.0/24 3.1.1.1 1 0 65009?
# Display the OSPF routing table on Router C.
[RouterC] display ospf routing
Routing Table
Topology base (MTID 0)
Routing for network
Destination Cost Type NextHop AdvRouter Area
9.1.1.0/24 1 Transit 9.1.1.2 3.3.3.3 0.0.0.0
2.2.2.2/32 1 Stub 9.1.1.1 2.2.2.2 0.0.0.0
Routing for ASEs
Destination Cost Type Tag NextHop AdvRouter
8.1.1.0/24 1 Type2 1 9.1.1.1 2.2.2.2
Total nets: 3
Intra area: 2 Inter Area: 0 ASE: 1 NSSA: 0
# Use ping to test connectivity.
[RouterA] ping -a 8.1.1.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL+C to break
[RouterC] ping -a 9.1.2.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL+C to break
Example: Configuring dynamic BGP peers
As shown in Figure 28, Router A needs to establish IBGP peer relationships with Router B, Router C, and Router D in network 10.1.0.0/16. Configure dynamic BGP peers to simplify the configuration.
Configure Router A as the route reflector, and configure Router B, Router C, and Router D as its clients.
Table 21 Configure IP addresses for interfaces. (Details not shown.)
Table 22 Configure IBGP peer relationships:
# Configure Router A to establish dynamic BGP peer relationships with routers in network 10.1.0.0/16.
[RouterA] bgp 200
[RouterA-bgp-default] peer 10.1.0.0 16 as-number 200
[RouterA-bgp-default-ipv4] peer 10.1.0.0 16 enable
# Configure Router B to establish an IBGP peer relationship with Router A.
[RouterB] bgp 200
[RouterB-bgp-default] peer 10.1.1.1 as-number 200
[RouterB-bgp-default-ipv4] peer 10.1.1.1 enable
# Configure Router C to establish an IBGP peer relationship with Router A.
[RouterC] bgp 200
[RouterC-bgp-default] peer 10.1.2.1 as-number 200
[RouterC-bgp-default-ipv4] peer 10.1.2.1 enable
# Configure Router D to establish an IBGP peer relationship with Router A.
<RouterD> system-view
[RouterD] bgp 200
[RouterD-bgp-default] router-id 4.4.4.4
[RouterD-bgp-default] peer 10.1.3.1 as-number 200
[RouterD-bgp-default] address-family ipv4
[RouterD-bgp-default-ipv4] peer 10.1.3.1 enable
# Display BGP peer information on Router A. The output shows that Router A has established IBGP peer relationships with Router B, Router C, and Router D.
[RouterA] display bgp peer ipv4
BGP local router ID : 1.1.1.1
Local AS number : 200
Total number of peers : 3 Peers in established state : 3
*10.1.1.2 200 7 10 0 0 00:06:09 Established
*10.1.2.2 200 7 10 0 0 00:06:09 Established
*10.1.3.2 200 7 10 0 0 00:06:09 Established
Table 23 Configure Router A as the route reflector, and configure peers in network 10.1.0.0/16 as its clients.
[RouterA-bgp-default-ipv4] peer 10.1.0.0 16 reflect-client
Table 24 Configure Router C to advertise network 9.1.1.0/24.
[RouterC-bgp-default-ipv4] network 9.1.1.0 24
# Verify that route 9.1.1.0/24 exists in the BGP routing table on Router A, Router B, Router D. This example uses Router A.
[RouterA-bgp-default] display bgp routing-table ipv4
Total Number of Routes: 1
a - additional-path
* i 9.1.1.0/24 10.1.2.2 0 100 0 ?
Example: Configuring BGP route summarization
As shown in Figure 29, run EBGP between Router C and Router D, so the internal network and external network can communicate with each other.
· In AS 65106, perform the following configurations so the devices in the internal network can communicate:
¡ Configure static routing between Router A and Router B.
¡ Configure OSPF between Router B and Router C.
¡ Configure OSPF to redistribute static routes.
· Configure route summarization on Router C so BGP advertises a summary route instead of advertising routes to the 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 networks to Router D.
Table 25 Configure IP addresses for interfaces. (Details not shown.)
Table 26 Configure static routing between Router A and Router B:
# Configure a default route with the next hop 192.168.212.1 on Router A.
[RouterA] ip route-static 0.0.0.0 0 192.168.212.1
# Configure static routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 with the same next hop 192.168.212.161 on Router B.
[RouterB] ip route-static 192.168.64.0 24 192.168.212.161
[RouterB] ip route-static 192.168.74.0 24 192.168.212.161
[RouterB] ip route-static 192.168.99.0 24 192.168.212.161
Table 27 Configure OSPF between Router B and Router C and configure OSPF on Router B to redistribute static routes:
# Configure OSPF to advertise the local network and enable OSPF to redistribute static routes on Router B.
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[RouterB-ospf-1] import-route static
# Configure OSPF to advertise local networks on Router C.
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 10.220.2.0 0.0.0.255
# Display the IP routing table on Router C.
[RouterC] display ip routing-table protocol ospf
Summary count : 5
OSPF Routing table status : <Active>
Summary count : 3
192.168.64.0/24 O_ASE2 150 1 172.17.100.1 XGE0/0/15
192.168.74.0/24 O_ASE2 150 1 172.17.100.1 XGE0/0/15
192.168.99.0/24 O_ASE2 150 1 172.17.100.1 XGE0/0/15
OSPF Routing table status : <Inactive>
Summary count : 2
10.220.2.0/24 O_INTRA 10 1 10.220.2.16 XGE0/0/16
172.17.100.0/24 O_INTRA 10 1 172.17.100.2 XGE0/0/15
The output shows that Router C has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through OSPF.
Table 28 Configure BGP between Router C and Router D and configure BGP on Router C to redistribute OSPF routes:
# On Router C, enable BGP, specify Router D as an EBGP peer, and configure BGP to redistribute OSPF routes.
[RouterC] bgp 65106
[RouterC-bgp-default] peer 10.220.2.217 as-number 64631
[RouterC-bgp-default-ipv4] peer 10.220.2.217 enable
[RouterC-bgp-default-ipv4] import-route ospf
# Enable BGP, and configure Router C as an EBGP peer on Router D.
[RouterD] bgp 64631
[RouterD-bgp-default] peer 10.220.2.16 as-number 65106
[RouterD-bgp-default] address-family ipv4 unicast
[RouterD-bgp-default-ipv4] peer 10.220.2.16 enable
[RouterD-bgp-default-ipv4] quit
[RouterD-bgp-default] quit
# Display routing table information on Router D.
[RouterD] display ip routing-table protocol bgp
Summary count : 3
BGP Routing table status : <Active>
Summary count : 3
192.168.64.0/24 BGP 255 1 10.220.2.16 XGE0/0/15
192.168.74.0/24 BGP 255 1 10.220.2.16 XGE0/0/15
192.168.99.0/24 BGP 255 1 10.220.2.16 XGE0/0/15
BGP Routing table status : <Inactive>
Summary count : 0
The output shows that Router D has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through BGP.
# Ping the hosts on networks 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 from Router D. The ping operations succeed.
Table 29 Configure route summarization on Router C to summarize 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 into a single route 192.168.64.0/18, and disable advertisement of specific routes.
[RouterC-bgp-default-ipv4] aggregate 192.168.64.0 18 detail-suppressed
# Display IP routing table information on Router C.
[RouterC] display ip routing-table | include 192.168
192.168.64.0/18 BGP 130 0 127.0.0.1 NULL0
The output shows that Router C has a summary route 192.168.64.0/18 with the output interface Null 0.
# Display the IP routing table information on Router D.
Summary count : 1
Summary count : 1
192.168.64.0/18 BGP 255 0 10.220.2.16 XGE0/0/15
Summary count : 0
The output shows that Router D has only one route 192.168.64.0/18 to AS 65106.
# Verify that Router D can ping the hosts on subnets 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24. (Details not shown.)
Example: Configuring multicast BGP
As shown in Figure 30, OSPF runs within AS 100 and AS 200 to ensure intra-AS connectivity. MBGP runs between the two ASs to exchange IPv4 unicast routes used for RPF check.
· Configure the Loopback 0 interface of Router A and Router B as the C-BSR and C-RP.
· Configure Router A and Router B to establish a Multicast Source Discovery Protocol (MSDP) peer relationship through MBGP, so that the receiver can receive multicast traffic from the source.
2. Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Source |
N/A |
10.110.1.100/24 |
Router C |
XGE0/0/15 |
10.110.2.1/24 |
Router A |
XGE0/0/15 |
10.110.1.1/24 |
XGE0/0/16 |
192.168.2.2/24 |
XGE0/0/16 |
192.168.1.1/24 |
XGE0/0/17 |
192.168.4.1/24 |
Loop0 |
1.1.1.1/32 |
Loop0 |
3.3.3.3/32 |
Router B |
XGE0/0/15 |
192.168.1.2/24 |
Router D |
XGE0/0/15 |
192.168.3.2/24 |
XGE0/0/16 |
192.168.3.1/24 |
XGE0/0/16 |
192.168.4.2/24 |
XGE0/0/17 |
192.168.2.1/24 |
Loop0 |
4.4.4.4/32 |
Loop0 |
2.2.2.2/32 |
Table 30 Configure IP addresses for interfaces and configure OSPF (this example uses OSPF process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
Table 31 Enable IP multicast routing, PIM-SM, and IGMP, and configure BSR boundaries:
# On Router A, enable multicast routing globally, and enable PIM-SM on interfaces.
[RouterA] multicast routing
[RouterA-mrib] quit
[RouterA] interface ten-gigabitethernet 0/0/15
[RouterA-Ten-GigabitEthernet0/0/15] pim sm
[RouterA-Ten-GigabitEthernet0/0/15] quit
[RouterA] interface ten-gigabitethernet 0/0/16
[RouterA-Ten-GigabitEthernet0/0/16] pim sm
[RouterA-Ten-GigabitEthernet0/0/16] quit
# Configure Router B and Router D in the same way that Router A was configured.
# On Router C, enable multicast routing globally.
[RouterC] multicast routing
[RouterC-mrib] quit
# Enable PIM-SM on interfaces, and enable IGMP on Ten-GigabitEthernet 0/0/15.
[RouterC] interface ten-gigabitethernet 0/0/16
[RouterC-Ten-GigabitEthernet0/0/16] pim sm
[RouterC-Ten-GigabitEthernet0/0/16] quit
[RouterC] interface ten-gigabitethernet 0/0/17
[RouterC-Ten-GigabitEthernet0/0/17] pim sm
[RouterC-Ten-GigabitEthernet0/0/17] quit
[RouterC] interface ten-gigabitethernet 0/0/15
[RouterC-Ten-GigabitEthernet0/0/15] pim sm
[RouterC-Ten-GigabitEthernet0/0/15] igmp enable
[RouterC-Ten-GigabitEthernet0/0/15] quit
# Configure the BSR boundary on Router A.
[RouterA-Ten-GigabitEthernet0/0/16] pim bsr-boundary
# Configure the BSR boundary on Router B.
[RouterB] interface ten-gigabitethernet 0/0/15
[RouterB-Ten-GigabitEthernet0/0/15] pim bsr-boundary
[RouterB-Ten-GigabitEthernet0/0/15] quit
Table 32 Configure Loopback 0, C-BSR, and C-RP:
# Configure the Loopback 0 interface and specify it as the C-BSR and C-RP on Router A.
[RouterA-LoopBack0] ip address 1.1.1.1 32
[RouterA-LoopBack0] pim sm
[RouterA-LoopBack0] quit
[RouterA] pim
[RouterA-pim] c-bsr 1.1.1.1
[RouterA-pim] c-rp 1.1.1.1
[RouterA-pim] quit
# Configure the Loopback 0 interface and specify it as the C-BSR and C-RP on Router B.
[RouterB-LoopBack0] ip address 2.2.2.2 32
[RouterB-LoopBack0] pim sm
[RouterB-LoopBack0] quit
[RouterB] pim
[RouterB-pim] c-bsr 2.2.2.2
[RouterB-pim] c-rp 2.2.2.2
[RouterB-pim] quit
Table 33 Configure BGP to establish BGP IPv4 multicast peers and redistribute routes:
# On Router A, establish an EBGP session to Router B.
[RouterA] bgp 100
[RouterA-bgp-default] peer 192.168.1.2 as-number 200
# Enable exchange of IPv4 unicast routes used for RPF check with Router B.
[RouterA-bgp-default] address-family ipv4 multicast
[RouterA-bgp-default-mul-ipv4] peer 192.168.1.2 enable
# Redistribute direct routes into BGP.
[RouterA-bgp-default-mul-ipv4] import-route direct
[RouterA-bgp-default-mul-ipv4] quit
# On Router B, establish an EBGP session to Router A.
[RouterB] bgp 200
[RouterB-bgp-default] peer 192.168.1.1 as-number 100
[RouterB-bgp-default] address-family ipv4 multicast
[RouterB-bgp-default-mul-ipv4] peer 192.168.1.1 enable
# Redistribute OSPF routes into BGP.
[RouterB-bgp-default-mul-ipv4] import-route ospf 1
[RouterB-bgp-default-mul-ipv4] quit
Table 34 Configure MSDP peers:
# Configure an MSDP peer on Router A.
[RouterA] msdp
[RouterA-msdp] peer 192.168.1.2 connect-interface ten-gigabitethernet 0/0/16
[RouterA-msdp] quit
# Configure an MSDP peer on Router B.
[RouterB] msdp
[RouterB-msdp] peer 192.168.1.1 connect-interface ten-gigabitethernet 0/0/15
[RouterB-msdp] quit
# Verify the BGP IPv4 multicast peer information on Router B.
[RouterB] display bgp peer ipv4 multicast
192.168.1.1 100 56 56 0 0 00:40:54 Established
# Verify the MSDP peer information on Router B.
[RouterB] display msdp brief
Configured Established Listen Connect Shutdown Disabled
1 1 0 0 0 0
Peer address State Up/Down time AS SA count Reset count
192.168.1.1 Established 00:07:17 100 1 0
Example: Separating unicast traffic and multicast traffic
Router A is located in AS 100 and is connected to a multicast source and the Internet. Router B and Router C run in AS 200 and are connected to Internet users and multicast users, respectively. Unicast traffic and multicast traffic need to be separated, which ensures that traffic from AS 100 to AS 200 is forwarded along the following paths:
· Internet traffic: Router A > Router B > Internet user
· Multicast traffic: Router A > Router C > Multicast user
Figure 31 Network diagram
1. Configure IP addresses for interfaces and configure OSPF (this example uses OSPF process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
Table 35 Establish BGP sessions.
[RouterA] bgp 100
[RouterA-bgp-default] peer 10.1.1.2 as-number 200
[RouterA-bgp-default] peer 10.2.1.2 as-number 200
[RouterA-bgp-default-mul-ipv4] peer 10.1.1.2 enable
[RouterA-bgp-default-mul-ipv4] peer 10.2.1.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.1.2 enable
[RouterA-bgp-default-ipv4] peer 10.2.1.2 enable
[RouterB] bgp 200
[RouterB-bgp-default] peer 10.1.1.1 as-number 100
[RouterB-bgp-default] peer 10.10.1.2 as-number 200
[RouterB-bgp-default-mul-ipv4] peer 10.1.1.1 enable
[RouterB-bgp-default-mul-ipv4] peer 10.10.1.2 enable
[RouterB-bgp-default-ipv4] peer 10.10.1.2 enable
[RouterC] bgp 200
[RouterC-bgp-default] peer 10.2.1.1 as-number 100
[RouterC-bgp-default] peer 10.10.1.1 as-number 200
[RouterC-bgp-default] address-family ipv4 multicast
[RouterC-bgp-default-mul-ipv4] peer 10.2.1.1 enable
[RouterC-bgp-default-mul-ipv4] peer 10.10.1.1 enable
[RouterC-bgp-default-mul-ipv4] quit
[RouterC-bgp-default-ipv4] peer 10.2.1.1 enable
[RouterC-bgp-default-ipv4] peer 10.10.1.1 enable
Table 36 Configure BGP unicast routes used for unicast traffic forwarding, and BGP unicast routes used for multicast RPF check.
[RouterB-bgp-default-mul-ipv4] network 2.2.2.2 32
[RouterB-bgp-default-mul-ipv4] network 10.10.1.0 24
[RouterB-bgp-default-ipv4] network 10.10.1.0 24
[RouterC-bgp-default-mul-ipv4] network 2.2.2.2 32
[RouterC-bgp-default-mul-ipv4] network 10.10.1.0 24
[RouterC-bgp-default-ipv4] network 10.10.1.0 24
Table 37 Configure a routing policy on Router B and Router C separately, so the two routers can modify the MED values of routes before route advertisement. This operation ensures that Router A selects the BGP unicast route from Router B for unicast traffic forwarding and selects the BGP unicast route from Router C for multicast RPF check.
[RouterB-acl-ipv4-basic-2077] rule permit source 10.10.1.0 0.0.0.255
[RouterB-acl-ipv4-basic-2077] quit
[RouterB] route-policy b2a permit node 10
[RouterB-route-policy-b2a-10] if-match ip address acl 2077
[RouterB-route-policy-b2a-10] apply cost 200
[RouterB-route-policy-b2a-10] quit
[RouterB] route-policy b2a permit node 20
[RouterB-route-policy-b2a-20] quit
[RouterB] bgp 200
[RouterB-bgp-default-mul-ipv4] peer 10.1.1.1 route-policy b2a export
[RouterC] acl basic 2077
[RouterC-acl-ipv4-basic-2077] rule permit source 10.10.1.0 0.0.0.255
[RouterC-acl-ipv4-basic-2077] quit
[RouterC] route-policy b2a permit node 10
[RouterC-route-policy-b2a-10] if-match ip address acl 2077
[RouterC-route-policy-b2a-10] apply cost 200
[RouterC-route-policy-b2a-10] quit
[RouterC] route-policy b2a permit node 20
[RouterC-route-policy-b2a-20] quit
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] peer 10.2.1.1 route-policy b2a export
Table 38 Configure IP multicast.
[RouterA-mrib] quit
[RouterA] pim
[RouterA-pim] quit
[RouterB] multicast routing
[RouterB-mrib] quit
[RouterB-Ten-GigabitEthernet0/0/15] pim sm
[RouterB] interface ten-gigabitethernet 0/0/16
[RouterB-Ten-GigabitEthernet0/0/16] pim sm
[RouterB-Ten-GigabitEthernet0/0/16] igmp enable
[RouterB-Ten-GigabitEthernet0/0/16] quit
[RouterC-mrib] quit
[RouterC-Ten-GigabitEthernet0/0/16] igmp enable
[RouterC] interface loopback 0
[RouterC-LoopBack0] pim sm
[RouterC-LoopBack0] quit
[RouterC] pim
[RouterC-pim] c-bsr 3.3.3.3
[RouterC-pim] c-rp 3.3.3.3
[RouterC-pim] quit
Table 39 Configure BSR boundaries.
[RouterA-Ten-GigabitEthernet0/0/15] pim bsr-boundary
[RouterC-Ten-GigabitEthernet0/0/15] pim bsr-boundary
Table 40 Configure MSDP peers.
[RouterA] msdp
[RouterA-msdp] peer 10.1.1.2 connect-interface ten-gigabitethernet 0/0/15
[RouterA-msdp] peer 10.2.1.2 connect-interface ten-gigabitethernet 0/0/16
[RouterA-msdp] quit
[RouterB] msdp
[RouterB-msdp] peer 10.1.1.1 connect-interface ten-gigabitethernet 0/0/15
[RouterB-msdp] quit
[RouterC] msdp
[RouterC-msdp] peer 10.2.1.1 connect-interface ten-gigabitethernet 0/0/15
[RouterC-msdp] quit
# View BGP IPv4 unicast routing information on Router A.
[RouterA] display bgp routing-table ipv4 unicast
Total number of routes: 2
a – additional-path
* >e 10.10.1.0/24 10.1.1.2 0 0 200i
* e 10.2.1.2 200 0 200i
# View BGP IPv4 multicast routing information on Router A.
[RouterA] display bgp routing-table ipv4 multicast
Total number of routes: 6
a – additional-path
* >e 2.2.2.2/32 10.1.1.2 0 0 200i
* e 10.2.1.2 0 200i
* >e 3.3.3.3/32 10.2.1.2 0 0 200i
* e 10.1.1.2 0 200i
* >e 10.10.1.0/24 10.2.1.2 0 0 200i
* e 10.1.1.2 200 0 200i
According to the above command outputs, Router A selects the BGP unicast route from Router B for unicast traffic forwarding and selects the BGP unicast route from Router C for multicast RPF check.
# On Router A, view MSDP peers.
2 2 0 0 0 0
10.1.1.2 Established 00:40:17 200 0 0
10.2.1.2 Established 00:41:17 200 0 0
According to the above command output, Router A has established an MSDP peer relationship with Router B and Router C separately.
Example: Configuring multiple BGP instances on one router
To achieve separate management and maintenance of different routers' routes, Router A uses different BGP instances to establish a BGP session to Router B and Router C separately. After Router A receive routes from Router B and Router C, it does not advertise the routes of Router B to Router C or the routes of Router C to Router B.
Figure 32 Network diagram
Table 41 Configure IP addresses for interfaces. (Details not shown.)
Table 42 Configure BGP connections.
[RouterA] bgp 100
[RouterA-bgp-default] router-id 10.1.1.1
[RouterA-bgp-default] peer 10.1.1.2 as-number 100
[RouterA] bgp 200 instance toc
[RouterA-bgp-toc] router-id 10.2.1.1
[RouterA-bgp-toc] peer 10.2.1.2 as-number 200
[RouterA-bgp-toc] address-family ipv4 unicast
[RouterA-bgp-toc-ipv4] peer 10.2.1.2 enable
[RouterA-bgp-toc-ipv4] quit
[RouterA-bgp-toc] quit
[RouterB] bgp 100
[RouterC] bgp 200
[RouterC-bgp-default] peer 10.2.1.1 as-number 200
Table 43 Configure route advertisement.
[RouterB] ip route-static 192.168.10.10 32 null 0
[RouterB] bgp 100
[RouterB-bgp-default-ipv4] import-route static
[RouterC] ip route-static 192.168.20.20 32 null 0
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] import-route static
# View the IP routing table of Router A.
Destinations : 12 Routes : 12
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE0/0/15
10.1.1.1/32 Direct 0 0 127.0.0.1 XGE0/0/15
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE0/0/15
10.2.1.0/24 Direct 0 0 10.2.1.1 XGE0/0/16
10.2.1.1/32 Direct 0 0 127.0.0.1 XGE0/0/16
10.2.1.255/32 Direct 0 0 10.2.1.1 XGE0/0/16
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.10.10/32 BGP 255 0 10.1.1.2 XGE0/0/15
192.168.20.20/32 BGP 255 0 10.2.1.2 XGE0/0/16
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# View the IP routing table of Router B.
[RouterB] display ip routing-table
Destinations : 8 Routes : 8
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE0/0/15
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE0/0/15
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE0/0/15
192.168.10.10/32 Static 60 0 0.0.0.0 NULL0
# View the IP routing table of Router C.
10.2.1.0/24 Direct 0 0 10.2.1.2 XGE0/0/15
10.2.1.2/32 Direct 0 0 127.0.0.1 XGE0/0/15
10.2.1.255/32 Direct 0 0 10.2.1.2 XGE0/0/15
192.168.20.20/32 Static 60 0 0.0.0.0 NULL0
According to the above command outputs, Router A can receive routes from Router B and Router C, but the routing table of Router B or Router C only has their own routes.
Basic IPv6 BGP network configuration examples
Example: Configuring IPv6 BGP basics
As shown in Figure 33, all routers run BGP. Run EBGP between Router A and Router B, and run IBGP between Router B and Router C to allow Router C to access network 50::/64 connected to Router A.
Table 44 Configure IP addresses for interfaces. (Details not shown.)
Table 45 Configure IBGP:
[RouterB] bgp 65009
[RouterB-bgp-default] peer 9::2 as-number 65009
[RouterB-bgp-default] address-family ipv6
[RouterB-bgp-default-ipv6] peer 9::2 enable
[RouterB-bgp-default-ipv6] quit
[RouterC] bgp 65009
[RouterC-bgp-default] peer 9::1 as-number 65009
[RouterC-bgp-default] address-family ipv6
[RouterC-bgp-default-ipv6] peer 9::1 enable
Table 46 Configure EBGP:
[RouterA] bgp 65008
[RouterA-bgp-default] peer 10::1 as-number 65009
[RouterA-bgp-default] address-family ipv6
[RouterA-bgp-default-ipv6] peer 10::1 enable
[RouterB-bgp-default] peer 10::2 as-number 65008
[RouterB-bgp-default-ipv6] peer 10::2 enable
Table 47 Inject network routes to the BGP routing table:
[RouterA-bgp-default-ipv6] network 10:: 64
[RouterA-bgp-default-ipv6] network 50:: 64
[RouterA-bgp-default-ipv6] quit
[RouterB-bgp-default-ipv6] network 10:: 64
[RouterB-bgp-default-ipv6] network 9:: 64
[RouterC-bgp-default-ipv6] network 9:: 64
[RouterC-bgp-default-ipv6] quit
# Display IPv6 BGP peer information on Router B.
[RouterB] display bgp peer ipv6
BGP local router ID: 2.2.2.2
Local AS number: 65009
Total number of peers: 2 Peers in established state: 2
9::2 65009 41 43 0 1 00:29:00 Established
10::2 65008 38 38 0 2 00:27:20 Established
The output shows that Router A and Router B have established an EBGP connection, and Router B and Router C have established an IBGP connection.
# Display IPv6 BGP routing table information on Router A.
[RouterA] display bgp routing-table ipv6
a - additional-path
* >e Network : 9:: PrefixLen : 64
NextHop : 10::1 LocPrf :
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: 65009i
* > Network : 10:: PrefixLen : 64
NextHop : :: LocPrf :
MED : 0
Path/Ogn: i
* e Network : 10:: PrefixLen : 64
MED : 0
Path/Ogn: 65009i
* > Network : 50:: PrefixLen : 64
MED : 0
Path/Ogn: i
The output shows that Router A has learned routing information of AS 65009.
# Display IPv6 BGP routing table information on Router C.
[RouterC] display bgp routing-table ipv6
a - additional-path
* > Network : 9:: PrefixLen : 64
MED : 0
Path/Ogn: i
* i Network : 9:: PrefixLen : 64
NextHop : 9::1 LocPrf : 100
MED : 0
Path/Ogn: i
* >i Network : 10:: PrefixLen : 64
MED : 0
Path/Ogn: i
* >i Network : 50:: PrefixLen : 64
NextHop : 10::2 LocPrf : 100
MED : 0
Path/Ogn: 65008i
The output shows that Router C has learned the route 50::/64.
# Verify that Router C can ping hosts on network 50::/64. (Details not shown.)
Example: Configuring IPv6 multicast BGP
As shown in Figure 34, OSPFv3 runs within AS 100 and AS 200 to ensure intra-AS connectivity. IPv6 MBGP runs between the two ASs to exchange IPv6 unicast routes used for RPF check.
Enable Anycast RP on Router A and Router B.
Device |
IP address |
Device |
IP address |
Source |
N/A |
1002::100/64 |
Router B |
XGE0/0/15 |
1001::2/64 |
Router A |
XGE0/0/15 |
1002::1/64 |
XGE0/0/16 |
2002::1/64 |
XGE0/0/16 |
1001::1/64 |
XGE0/0/17 |
2001::1/64 |
Loop0 |
1:1::1/128 |
Loop0 |
1:1::1/128 |
Loop1 |
1:1::2/128 |
Loop1 |
2:2::2/128 |
Router C |
XGE0/0/15 |
3002::1/64 |
Router D |
XGE0/0/15 |
2002::2/64 |
XGE0/0/16 |
2001::2/64 |
XGE0/0/16 |
3001::2/64 |
XGE0/0/17 |
3001::1/64 |
Table 48 Configure IPv6 addresses for interfaces and configure OSPFv3 (this example uses OSPFv3 process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
Table 49 Enable IPv6 multicast routing, IPv6 PIM-SM, and MLD, and configure BSR boundaries:
# On Router A, enable IPv6 multicast routing globally, and enable IPv6 PIM-SM on interfaces.
[RouterA-mrib6] quit
[RouterA-Ten-GigabitEthernet0/0/15] ipv6 pim sm
[RouterA-Ten-GigabitEthernet0/0/16] ipv6 pim sm
[RouterA-LoopBack0] ipv6 pim sm
# On Router C, enable IPv6 multicast routing globally.
[RouterC] ipv6 multicast routing
[RouterC-mrib6] quit
# Enable IPv6 PIM-SM on interfaces, and enable MLD on Ten-GigabitEthernet 0/0/15.
[RouterC-Ten-GigabitEthernet0/0/16] ipv6 pim sm
[RouterC-Ten-GigabitEthernet0/0/17] ipv6 pim sm
[RouterC-Ten-GigabitEthernet0/0/15] ipv6 pim sm
[RouterC-Ten-GigabitEthernet0/0/15] mld enable
[RouterA-Ten-GigabitEthernet0/0/16] ipv6 pim bsr-boundary
[RouterB-Ten-GigabitEthernet0/0/15] ipv6 pim bsr-boundary
Table 50 Enable Anycast RP, and specify C-BSR and C-RP:
[RouterA] ipv6 pim
[RouterA-pim6] anycast-rp 1:1::1 1:1::2
[RouterA-pim6] anycast-rp 1:1::1 2:2::2
[RouterA-pim6] c-bsr 1:1::1
[RouterA-pim6] c-rp 1:1::1
[RouterA-pim6] quit
[RouterB] ipv6 pim
[RouterB-pim6] anycast-rp 1:1::1 1:1::2
[RouterB-pim6] anycast-rp 1:1::1 2:2::2
[RouterB-pim6] c-bsr 1:1::1
[RouterB-pim6] c-rp 1:1::1
[RouterB-pim6] quit
Table 51 Configure BGP to establish BGP IPv6 multicast peers and redistribute routes:
[RouterA] bgp 100
[RouterA-bgp-default] peer 1001::2 as-number 200
# Enable exchange of IPv6 unicast routes used for RPF check with Router B.
[RouterA-bgp-default] address-family ipv6 multicast
[RouterA-bgp-default-mul-ipv6] peer 1001::2 enable
[RouterA-bgp-default-mul-ipv6] import-route direct
[RouterA-bgp-default-mul-ipv6] quit
[RouterB] bgp 200
[RouterB-bgp-default] peer 1001::1 as-number 100
[RouterB-bgp-default] address-family ipv6 multicast
[RouterB-bgp-default-mul-ipv6] peer 1001::1 enable
# Redistribute OSPFv3 routes into BGP.
[RouterB-bgp-default-mul-ipv6] import-route ospfv3 1
[RouterB-bgp-default-mul-ipv6] quit
Table 52 Establish BGP IPv6 unicast peer relationships between Router A and Router B and redistribute routes:
# On Router A, enable BGP to exchange IPv6 unicast routes with Router B, and redistribute direct routes into BGP.
[RouterA-bgp-default] address-family ipv6 unicast
[RouterA-bgp-default-ipv6] peer 1001::2 enable
[RouterA-bgp-default-ipv6] import-route direct
# On Router B, enable BGP to exchange IPv6 unicast routes with Router A, and redistribute direct routes into BGP.
[RouterB-bgp-default] address-family ipv6 unicast
[RouterB-bgp-default-ipv6] peer 1001::1 enable
[RouterB-bgp-default-ipv6] import-route direct
# Verify the BGP IPv6 multicast peer information on Router B.
[RouterB] display bgp peer ipv6 multicast
1001::1 100 56 56 0 0 00:40:54 Established
# Verify the RPF information for the multicast source on Router B.
[RouterB] display ipv6 multicast rpf-info 1002::1
RPF information about source 1002::1:
RPF interface: XGE0/0/15, RPF neighbor: 1001::1
Referenced prefix/prefix length: 1002::/64
Referenced route type: mbgp
Troubleshooting BGP
Symptom
The display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command output shows that the state of the connection to a peer cannot become established.
Analysis
To become BGP peers, any two routers must establish a TCP connection using port 179 and exchange OPEN messages successfully.
Solution
1. To resolve the problem:
a. Use the display current-configuration command to verify the current configuration, and verify that the peer's AS number is correct.
b. Use the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command to verify that the peer's IP/IPv6 address is correct.
c. If a loopback interface is used, verify that the loopback interface is specified with the peer connect-interface command.
d. If the peer is a non-direct EBGP peer, verify that the peer ebgp-max-hop command is configured.
e. If the peer ttl-security hops command is configured, verify that the command is configured on the peer. Verify that the hop-count values configured on them are greater than the number of hops between them.
f. Verify that a valid route to the peer is available.
g. Use the ping command to verify the connectivity to the peer.
h. Use the display tcp verbose or display ipv6 tcp verbose command to verify the TCP connection.
i. Verify that no ACL rule is applied to disable TCP port 179.
2. If the problem persists, contact H3C Support.
Configuring large-scale BGP networks
Large-scale BGP network configuration tasks at a glance
To configure large-scale BGP networks, perform the following tasks:
· Configuring BGP route dampening
· Configuring BGP route reflection
· Configuring BGP confederation settings
¡ Configuring a BGP confederation
¡ (Optional.) Configuring confederation compatibility
Route dampening enables BGP to not select unstable routes as optimal routes. By default, the device records BGP route dampening log entries. You can check route dampening or recovery information by viewing these log entries.
This feature applies to EBGP routes but not to IBGP routes.
If an EBGP peer goes down after you configure this feature, routes coming from the peer are dampened but not deleted.
After an active/standby switchover, BGP route dampening processes and information will be reset. The device needs to recalculate the dampening mechanism of BGP routes.
Procedure (IPv4 unicast/multicast address family)
1. Enter system view.
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 labeled unicast address family view:
address-family ipv4 labeled-unicast
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 labeled unicast address family view:
3. Configure BGP route dampening.
By default, BGP route dampening is not configured.
4. (Optional.) Specify the maximum number of BGP route dampening log entries that can be recorded.
a. Return to BGP instance view.
- Execute the quit command twice in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
- Execute the quit command once in BGP IPv4 unicast address family view, BGP IPv4 multicast address family view, or BGP IPv4 labeled unicast address family view.
b. Specify the maximum number of BGP route dampening log entries that can be recorded.
dampening-log size size-number
By default, the device can record a maximum of 1000 BGP route dampening log entries.
To disable BGP from recording route dampening log entries, you can set the value for this argument to 0.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
3. Configure IPv6 BGP route dampening.
By default, IPv6 BGP route dampening is not configured.
- Execute the quit command twice in BGP-VPN IPv6 unicast address family view.
- Execute the quit command once in BGP IPv6 unicast address family view or BGP IPv6 multicast address family view.
Configuring BGP communities
By default, a router does not advertise the COMMUNITY, large community, or extended community attribute to its peers or peer groups. When the router receives a route carrying the COMMUNITY, large community, or extended community attribute, it removes the attribute before advertising the route to other peers or peer groups.
Perform this task to enable a router to advertise the COMMUNITY, large community, or extended community attribute to its peers for route filtering and control. You can also use a routing policy to add or modify the COMMUNITY, large community, or extended community attribute for specific routes. For more information about routing policy, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
2. Create a routing policy and a node, and enter routing policy node view.
For more information about this command, see routing policy commands in Layer 3—IP Routing Command Reference.
3. (Optional.) Configure if-match clauses as BGP route match criteria.
The routing policy can configure the COMMUNITY attribute of BGP routes only when these routes match a permit node.
For more information about if-match clauses, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
4. Configure the COMMUNITY attribute, extended community attribute, and large community attribute of BGP routes.
¡ Set the COMMUNITY attribute for BGP routes.
¡ Delete COMMUNITY attribute values from BGP routes.
By default, no COMMUNITY attribute value is deleted from BGP routes.
¡ Set the link bandwidth or RT extended community attribute for BGP routes.
apply extcommunity { bandwidth link-bandwidth-value | { rt route-target }&<1-32> } [ additive ]
¡ Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
¡ Set the SoO extended community attribute for BGP routes.
¡ Set the large community attribute for BGP routes.
apply large-community { aa:bb:cc&<1-8> [ additive ] | additive | none }
¡ Delete large community attribute values from BGP routes.
apply large-comm-list { large-comm-list-number | large-comm-list-name } delete
For more information about these commands, see routing policy commands in Layer 3—IP Routing Command Reference.
5. Return to system view.
6. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
7. Advertise the COMMUNITY attribute to a peer or peer group.
By default, the COMMUNITY attribute is not advertised.
The ipv6-address [ prefix-length ] argument is not supported in BGP IPv4 multicast address family view.
8. Advertise the extended community attribute to a peer or peer group.
By default, the extended community attribute is not advertised.
9. Advertise the large community attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-large-community
By default, the large community attribute is not advertised.
The ipv6-address [ prefix-length ] argument is not supported in BGP IPv4 labeled unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
10. Apply a routing policy to routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
By default, no routing policy is applied.
6. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
The ipv4-address [ mask-length ] argument is not supported in BGP IPv6 multicast address family view.
Configuring a BGP route reflector
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
To improve availability, you can specify multiple route reflectors for a cluster. The route reflectors in the cluster must have the same cluster ID to avoid routing loops.
When a route reflector connects to multiple clusters, you can configure different cluster IDs for different peers or peer groups.
You only need to configure BGP route reflection on the device that acts as a route reflector. Other devices do not need to know the role of the local device in route reflection.
After you configure a device as a route reflector, it advertises routes as follows:
· Advertises routes received from a non-client IBGP peer to all clients.
· Advertises routes received from an IBGP peer that acts as a client to all peers.
· Advertises routes received from an EBGP peer to all peers.
If you do not configure the peer cluster-id command for a peer or peer group, the peer or peer group uses the cluster ID configured by the reflector cluster-id command.
For a peer or peer group, the cluster ID configured by the peer cluster-id command takes precedence over the cluster ID configured by the reflector cluster-id command.
By default, the route reflector does not change the attributes of routes before route reflection to avoid routing loops. When you replan network traffic, you can perform this task to allow the route reflector to change the attributes of the routes to be reflected.
After using the reflect change-path-attribute command, you can use the peer route-policy export command to apply a routing policy that can change the attributes of the routes to be reflected. The following apply commands can define how the routing policy modifies route attributes:
· Use apply origin to change the ORIGIN attribute of routes.
· Use apply ip-address next-hop or apply ipv6 next-hop to change the NEXT_HOP attribute of routes.
· Use apply cost to change the MED attribute of routes.
· Use apply local-preference to change the local preference for routes.
· Use apply community to configure the COMMUNITY attribute of routes. For BGP to advertise the COMMUNITY attribute to a peer or peer group, use the peer advertise-community command.
· Use apply comm-list delete to delete COMMUNITY attribute values from routes.
· Use apply extcommunity to configure the link bandwidth or RT extended community attribute of routes. For BGP to advertise extended COMMUNITY attributes to a peer or peer group, use the peer advertise-ext-community command.
· Use apply extcommunity color to configure the color extended community attribute of routes.
· Use apply extcommunity soo to configure the SoO extended community attribute of routes.
· Use apply large-community to configure the large community attribute for BGP routes. For BGP to advertise the large community attribute to a peer or peer group, use the peer advertise-large-community command.
· Use apply large-comm-list delete to delete large community attribute values from routes.
· Use apply aigp to configure the AIGP attribute for BGP routes. For BGP to advertise the AIGP attribute to a peer or peer group, use the peer aigp command.
For more information about the apply commands, see routing policy commands in Layer 3—IP Routing Command Reference.
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Enter BGP-VPN instance view.
3. Configure the cluster ID of the route reflector for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } cluster-id cluster-id
By default, the cluster ID of the route reflector is not configured for a peer or peer group.
4. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
¡ Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
This command is available only in BGP instance view.
¡ Enter BGP IPv4 labeled unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
5. Configure the router as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
6. (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
7. (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
8. (Optional.) Enable the route reflector to change the attributes of routes to be reflected.
By default, the route reflector cannot change the attributes of routes to be reflected.
peer { group-name | ipv6-address [ prefix-length ] } cluster-id cluster-id
4. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view or BGP IPv6 multicast address family view.
¡ Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡ Enter BGP IPv6 multicast address family view.
Ignoring the ORIGINATOR_ID attribute
By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID. Some special networks such as firewall networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
Make sure this command does not result in a routing loop.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
Procedure (IPv4 peers)
3. Ignore the ORIGINATOR_ID attribute.
By default, BGP does not ignore the ORIGINATOR_ID attribute.
Procedure (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } ignore-originatorid
Clearing the route reflection attributes of a route before forwarding the route
In route reflection scenarios, BGP compares the CLUSTER_LIST and ORIGINATOR_ID attributes of routes to avoid routing loops. BGP discards a route if its CLUSTER_LIST attribute contains the local CLUSTER_ID or its ORIGINATOR_ID attribute is the same as the local router ID.
This feature applies when BGP forwards a route between the public network and a VPN instance or between different VPN instances. In such a scenario, the route reflection attributes carried by the route are meaningless. To avoid traffic loss, perform this task to enable BGP to clear the CLUSTER_LIST and ORIGINATOR_ID attributes of a route before forwarding the route.
· After you configure this feature, BGP re-advertises all routes to all peers and peer groups.
· This feature might cause routing loops. Before executing the command, make sure you understand the potential impact on the network.
2. Enter BGP instance view.
3. Enable BGP to clear the CLUSTER_LIST and ORIGINATOR_ID attributes of a route before forwarding the route.
advertise-between-vrf clear-reflect-attributes
By default, BGP does not clear the CLUSTER_LIST and ORIGINATOR_ID attributes of a route before forwarding the route.
Configuring a route server
Some networks require the border devices in multiple ASs to establish full mesh connections, which consumes many network resources and reduces device performance. To resolve this issue, configure a device as a route server and the border devices in different ASs as its clients as needed. The route server advertises routes to the clients without changing their AS path, next hop, and MED attributes. The clients can exchange routes without establishing EBGP connections and forward traffic to each other without the participation of the route server.
The route server does not add its AS number in the packets advertised to a peer. To avoid peer establishment failures, execute the peer ignore-first-as command on the clients.
Procedure (IPv4 unicast)
2. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
3. Configure the device as a route server and specify a peer or peer group as a client.
peer { group-name | ipv4-address [ mask-length ] } route-server-client
By default, neither the route server nor the client is configured.
Procedure (IPv6 unicast)
2. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
peer { group-name | ipv6-address [ prefix-length ] } route-server-client
About BGP confederation
BGP confederation provides another way to reduce IBGP connections in an AS.
A confederation contains sub-ASs. In each sub-AS, IBGP peers are fully meshed. Sub-ASs establish EBGP connections in between.
3. Configure a confederation ID.
confederation id as-number
By default, no confederation ID is configured.
From an outsider's perspective, the sub-ASs of the confederation is a single AS, which is identified by the confederation ID.
4. Specify confederation peer sub-ASs in the confederation.
By default, no confederation peer sub-ASs are specified.
A confederation can contain a maximum of 32 sub-ASs. The AS number of a sub-AS is effective only in the confederation.
If the router needs to establish EBGP connections to other sub-ASs, you must specify the peering sub-ASs in the confederation.
If any routers in the confederation do not comply with RFC 3065, enable confederation compatibility to allow the router to work with those routers.
3. Enable confederation compatibility.
confederation nonstandard
By default, confederation compatibility is disabled.
Display and maintenance commands for large-scale BGP network configuration
Displaying BGP (IPv4 unicast address family)
Task |
Command |
Display BGP IPv4 unicast peer group information. |
display bgp [ instance instance-name ] group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display information about a peer or peer group in BGP IPv4 unicast address family. |
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ] |
Display BGP IPv4 unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display dampened BGP IPv4 unicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Display BGP IPv4 unicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Clear BGP IPv4 unicast route dampening information and release suppressed BGP IPv4 unicast routes. |
reset bgp [ instance instance-name ] dampening ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] ] |
Displaying BGP (IPv6 unicast address family)
Task |
Command |
Display BGP IPv6 unicast peer group information. |
display bgp [ instance instance-name ] group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display information about a peer or peer group in BGP IPv6 unicast address family. |
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ] |
Display BGP IPv6 unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display dampened BGP IPv6 unicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Display BGP IPv6 unicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Clear BGP IPv6 unicast route dampening information and release suppressed BGP IPv6 unicast routes. |
reset bgp [ instance instance-name ] dampening ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ] |
Displaying BGP (IPv4 labeled unicast address family)
Task |
Command |
Display BGP IPv4 labeled unicast peer group information. |
display bgp [ instance instance-name ] group ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display state and statistics information about BGP IPv4 labeled unicast peers or peer groups. |
display bgp [ instance instance-name ] peer ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 labeled-unicast vpn-instance-all [ verbose ] |
Display BGP IPv4 labeled unicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display BGP IPv4 labeled unicast route dampening parameters. |
display bgp [ instance instance-name ] dampening parameter ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] |
Clear BGP IPv4 labeled unicast route dampening information and release suppressed BGP IPv4 labeled unicast routes. |
reset bgp [ instance instance-name ] dampening ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] ] |
Displaying BGP (IPv4 multicast address family)
Task |
Command |
Display BGP IPv4 multicast peer group information. |
display bgp [ instance instance-name ] group ipv4 multicast [ group-name group-name ] |
Display BGP IPv4 multicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv4 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] display bgp [ instance instance-name ] peer ipv4 multicast [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ] |
Display BGP IPv4 multicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display dampened BGP IPv4 multicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv4 multicast |
Display BGP IPv4 multicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv4 multicast |
Clear BGP IPv4 multicast route dampening information and release suppressed BGP IPv4 multicast routes. |
reset bgp [ instance instance-name ] dampening ipv4 multicast [ ipv4-address [ mask-length | mask ] ] |
Displaying BGP (IPv6 multicast address family)
Task |
Command |
Display BGP IPv6 multicast peer group information. |
display bgp [ instance instance-name ] group ipv6 multicast [ group-name group-name ] |
Display BGP IPv6 multicast peer or peer group information. |
display bgp [ instance instance-name ] peer ipv6 multicast [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ] display bgp [ instance instance-name ] peer ipv6 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display BGP IPv6 multicast route flapping statistics. |
display bgp [ instance instance-name ] routing-table flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display dampened BGP IPv6 multicast route information. |
display bgp [ instance instance-name ] routing-table dampened ipv6 multicast |
Display BGP IPv6 multicast route dampening parameter information. |
display bgp [ instance instance-name ] dampening parameter ipv6 multicast |
Clear BGP IPv6 multicast route dampening information and release suppressed BGP IPv6 multicast routes. |
reset bgp [ instance instance-name ] dampening ipv6 multicast [ ipv6-address prefix-length ] |
Displaying BGP route dampening log information
Task |
Command |
Display BGP route dampening log information. |
display bgp [ instance instance-name ] dampening-log [ reverse ] |
Clear BGP route dampening log information. |
reset bgp [ instance instance-name ] dampening-log |
Large-scale BGP network configuration examples
Example: Configuring BGP communities
As shown in Figure 35, Router B establishes EBGP connections to Router A and Router C. Configure NO_EXPORT community attribute on Router A so that AS 20 does not advertise routes received from AS 10 to any other AS.
Table 53 Configure IP addresses for interfaces. (Details not shown.)
Table 54 Configure EBGP connections:
[RouterA] bgp 10
[RouterA-bgp-default] peer 200.1.2.2 as-number 20
[RouterA-bgp-default-ipv4] peer 200.1.2.2 enable
[RouterA-bgp-default-ipv4] network 9.1.1.0 255.255.255.0
# Configure Router B.
<RouterB> system-view
[RouterB] bgp 20
[RouterB-bgp-default] router-id 2.2.2.2
[RouterB-bgp-default] peer 200.1.2.1 as-number 10
[RouterB-bgp-default] peer 200.1.3.2 as-number 30
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 200.1.2.1 enable
[RouterB-bgp-default-ipv4] peer 200.1.3.2 enable
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
# Configure Router C.
<RouterC> system-view
[RouterC] bgp 30
[RouterC-bgp-default] router-id 3.3.3.3
[RouterC-bgp-default] peer 200.1.3.1 as-number 20
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 200.1.3.1 enable
[RouterC-bgp-default-ipv4] quit
[RouterC-bgp-default] quit
# Display the BGP route 9.1.1.0 on Router B.
[RouterB] display bgp routing-table ipv4 9.1.1.0
Local AS number: 20
Paths: 1 available, 1 best
Rely nexthop : 200.1.2.1
Original nexthop: 200.1.2.1
Out interface : Ten-GigabitEthernet0/0/15
Route age : 01h43m31s
OutLabel : NULL
AS-path : 10
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
# Display advertisement information for the route 9.1.1.0 on Router B.
[RouterB] display bgp routing-table ipv4 9.1.1.0 advertise-info
Local AS number: 20
Paths: 1 best
200.1.3.2
The output shows that Router B can advertise the route with the destination 9.1.1.0/24 to other ASs through BGP.
Total number of routes: 1
Status codes: * - valid, > - best, d - dampened, h - history
* >e 9.1.1.0/24 200.1.3.1 0 20 10i
Router C has learned the route to the destination 9.1.1.0/24 from Router B.
Table 55 Configure the BGP COMMUNITY attribute:
# Configure a routing policy.
[RouterA] route-policy comm_policy permit node 0
[RouterA-route-policy-comm_policy-0] apply community no-export
[RouterA-route-policy-comm_policy-0] quit
# Apply the routing policy.
[RouterA] bgp 10
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 200.1.2.2 route-policy comm_policy export
[RouterA-bgp-default-ipv4] peer 200.1.2.2 advertise-community
Local AS number: 20
OutLabel : NULL
Community : No-Export
AS-path : 10
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Local AS number: 20
Paths: 1 best
# Display the BGP routing table on Router C.
[RouterC] display bgp routing-table ipv4
Total number of routes: 0
The output shows that BGP has not learned any route.
Example: Configuring BGP route reflector
As shown in Figure 36, all routers run BGP. Run EBGP between Router A and Router B, run IBGP between Router C and Router B, and between Router C and Router D.
Configure Router C as a route reflector with clients Router B and D to allow Router D to learn route 20.0.0.0/8 from Router C.
Table 56 Configure IP addresses for interfaces and configure OSPF in AS 200. (Details not shown.)
Table 57 Configure BGP connections:
# Configure Router A.
[RouterA] bgp 100
[RouterA-bgp-default] router-id 1.1.1.1
[RouterA-bgp-default] peer 192.1.1.2 as-number 200
[RouterA-bgp-default-ipv4] peer 192.1.1.2 enable
# Inject network 20.0.0.0/8 to the BGP routing table.
[RouterA-bgp-default-ipv4] network 20.0.0.0
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
[RouterB] bgp 200
[RouterB-bgp-default] peer 192.1.1.1 as-number 100
[RouterB-bgp-default] peer 193.1.1.1 as-number 200
[RouterB-bgp-default-ipv4] peer 192.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 193.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 193.1.1.1 next-hop-local
[RouterC] bgp 200
[RouterC-bgp-default] peer 193.1.1.2 as-number 200
[RouterC-bgp-default] peer 194.1.1.2 as-number 200
[RouterC-bgp-default-ipv4] peer 193.1.1.2 enable
[RouterC-bgp-default-ipv4] peer 194.1.1.2 enable
# Configure Router D.
[RouterD] bgp 200
[RouterD-bgp-default] peer 194.1.1.1 as-number 200
[RouterD-bgp-default-ipv4] peer 194.1.1.1 enable
Table 58 Configure Router C as the route reflector.
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] peer 193.1.1.2 reflect-client
[RouterC-bgp-default-ipv4] peer 194.1.1.2 reflect-client
# Display the BGP routing table on Router B.
* >e 20.0.0.0 192.1.1.1 0 0 100i
# Display the BGP routing table on Router D.
[RouterD] display bgp routing-table ipv4
* >i 20.0.0.0 193.1.1.2 0 100 0 100i
The output shows that Router D has learned the route 20.0.0.0/8 from Router C.
Example: Configuring BGP confederation
As shown in Figure 37, split AS 200 into three sub-ASs (AS 65001, AS 65002, and AS 65003) to reduce IBGP connections. Routers in AS 65001 are fully meshed.
Device |
IP address |
Device |
IP address |
Router A |
XGE0/0/15 |
10.1.2.1/24 |
Router D |
XGE0/0/15 |
10.1.5.1/24 |
XGE0/0/16 |
10.1.3.1/24 |
XGE0/0/16 |
10.1.3.2/24 |
XGE0/0/17 |
10.1.4.1/24 |
Router E |
XGE0/0/15 |
10.1.5.2/24 |
XGE0/0/18 |
200.1.1.1/24 |
XGE0/0/16 |
10.1.4.2/24 |
XGE0/0/19 |
10.1.1.1/24 |
Router F |
XGE0/0/15 |
9.1.1.1/24 |
Router B |
XGE0/0/15 |
10.1.1.2/24 |
XGE0/0/16 |
200.1.1.2/24 |
Router C |
XGE0/0/15 |
10.1.2.2/24 |
Table 59 Configure IP addresses for interfaces. (Details not shown.)
Table 60 Configure the BGP confederation:
[RouterA] bgp 65001
[RouterA-bgp-default] confederation id 200
[RouterA-bgp-default] confederation peer-as 65002 65003
[RouterA-bgp-default] peer 10.1.1.2 as-number 65002
[RouterA-bgp-default] peer 10.1.2.2 as-number 65003
[RouterA-bgp-default-ipv4] peer 10.1.2.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.1.2 next-hop-local
[RouterA-bgp-default-ipv4] peer 10.1.2.2 next-hop-local
[RouterB] bgp 65002
[RouterB-bgp-default] confederation id 200
[RouterB-bgp-default] confederation peer-as 65001 65003
[RouterB-bgp-default] peer 10.1.1.1 as-number 65001
[RouterC] bgp 65003
[RouterC-bgp-default] confederation id 200
[RouterC-bgp-default] confederation peer-as 65001 65002
[RouterC-bgp-default] peer 10.1.2.1 as-number 65001
Table 61 Configure IBGP connections in AS65001:
[RouterA] bgp 65001
[RouterA-bgp-default] peer 10.1.3.2 as-number 65001
[RouterA-bgp-default] peer 10.1.4.2 as-number 65001
[RouterA-bgp-default-ipv4] peer 10.1.3.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.4.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.3.2 next-hop-local
[RouterA-bgp-default-ipv4] peer 10.1.4.2 next-hop-local
[RouterD] bgp 65001
[RouterD-bgp-default] confederation id 200
[RouterD-bgp-default] peer 10.1.3.1 as-number 65001
[RouterD-bgp-default] peer 10.1.5.2 as-number 65001
[RouterD-bgp-default-ipv4] peer 10.1.5.2 enable
# Configure Router E.
<RouterE> system-view
[RouterE] bgp 65001
[RouterE-bgp-default] router-id 5.5.5.5
[RouterE-bgp-default] confederation id 200
[RouterE-bgp-default] peer 10.1.4.1 as-number 65001
[RouterE-bgp-default] peer 10.1.5.1 as-number 65001
[RouterE-bgp-default] address-family ipv4 unicast
[RouterE-bgp-default-ipv4] peer 10.1.4.1 enable
[RouterE-bgp-default-ipv4] peer 10.1.5.1 enable
[RouterE-bgp-default-ipv4] quit
[RouterE-bgp-default] quit
Table 62 Configure the EBGP connection between AS 100 and AS 200:
[RouterA] bgp 65001
[RouterA-bgp-default] peer 200.1.1.2 as-number 100
[RouterA-bgp-default-ipv4] peer 200.1.1.2 enable
# Configure Router F.
<RouterF> system-view
[RouterF] bgp 100
[RouterF-bgp-default] router-id 6.6.6.6
[RouterF-bgp-default] peer 200.1.1.1 as-number 200
[RouterF-bgp-default] address-family ipv4 unicast
[RouterF-bgp-default-ipv4] peer 200.1.1.1 enable
[RouterF-bgp-default-ipv4] network 9.1.1.0 255.255.255.0
[RouterF-bgp-default-ipv4] quit
[RouterF-bgp-default] quit
* >i 9.1.1.0/24 10.1.1.1 0 100 0 (65001)
100i
Local AS number: 65002
Rely nexthop : 10.1.1.1
Original nexthop: 10.1.1.1
Route age : 01h22m43s
OutLabel : NULL
AS-path : (65001) 100
Origin : igp
State : valid, external-confed, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
* >i 9.1.1.0/24 10.1.3.1 0 100 0 100i
[RouterD] display bgp routing-table ipv4 9.1.1.0
BGP local router ID: 4.4.4.4
Local AS number: 65001
Rely nexthop : 10.1.3.1
Original nexthop: 10.1.3.1
Out interface : Ten-GigabitEthernet0/0/16
Route age : 01h43m32s
OutLabel : NULL
AS-path : 100
Origin : igp
State : valid, internal-confed, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
· Router F can send route information to Router B and Router C through the confederation by establishing only an EBGP connection with Router A.
· Router B and Router D are in the same confederation, but belong to different sub-ASs. They obtain external route information from Router A and generate identical BGP route entries although they have no direct connection in between.
Controlling BGP path selection
BGP path selection control tasks at a glance
By configuring BGP path attributes, you can control BGP path selection.
To control BGP path selection, perform the following tasks:
1. Setting a preferred value for received routes
2. Configuring the preferred value as 0 for BGP routes generated from redistributed routes
3. Configuring preferences for BGP routes
4. Configuring the default local preference
5. Configuring the MED attribute
¡ Configuring the default MED value
¡ Enabling MED comparison for routes from different ASs
¡ Enabling MED comparison for routes on a per-AS basis
¡ Enabling MED comparison for routes from confederation peers
6. Configuring the NEXT_HOP attribute
¡ Setting the local device IP as the next hop for routes sent to a peer or peer group
¡ Disabling nexthop changing for routes advertised to a peer or peer group
7. Configuring the AS_PATH attribute
¡ Permitting local AS number to appear in routes from a peer or peer group
¡ Ignoring the AS_PATH attribute during optimal route selection
¡ Advertising a fake AS number to a peer or peer group
¡ Configuring AS number substitution
¡ Removing/replacing private AS numbers in BGP updates
¡ Ignoring the first AS number of EBGP route updates
¡ Setting an AS number quantity threshold
8. Configuring the AIGP attribute
9. Configuring BGP route selection specifications
To view the impact of this configuration step on BGP route selection rules, see "BGP route selection."
¡ Preferring routes learned from a peer or peer group during optimal route selection
¡ Preferring BGP routes of a specific next hop IP type
¡ Ignoring IGP metrics during optimal route selection
¡ Ignoring router IDs during optimal route selection
¡ Configuring the next hop type selection rule for optimal route selection
¡ Changing the BGP route selection rule when the device receives routes from different EBGP peers
Perform this task to set a preferred value for specific routes to control BGP path selection.
Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the optimal route.
3. Set a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
After you configure this feature, for redistributed routes with the import-route command or injected local network routes with the network command, BGP sets the preferred value for the generated BGP routes to 0.
If you enable route redistribution with the import-route command, and also configure a routing policy with the apply preferred-value clause specified, the configuration of the default preferred-value command does not apply to the generated BGP routes. Instead, the configuration of the apply preferred-value clause applies to the generated BGP routes.
3. Configure the preferred value as 0 for BGP routes generated from redistributed routes.
By default, after BGP redistributes routes from other routing protocols, it changes the preferred value to 32768 for the generated BGP routes.
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route. A smaller preference value indicates a higher preference.
You can use the preference command to modify preferences for EBGP, IBGP, and local BGP routes, or use a routing policy to set a preference for matching routes. For routes not matching the routing policy, the default preference applies.
If a device has an EBGP route and a local BGP route to reach the same destination, it does not select the EBGP route because the EBGP route has a lower preference than the local BGP route by default. You can use the network short-cut command to configure the EBGP route as a shortcut route that has the same preference as the local BGP route. The EBGP route will more likely become the optimal route.
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
3. Configure preferences for EBGP, IBGP, and local BGP routes.
By default, the preferences for EBGP, IBGP, and local BGP routes are 255, 255, and 130, respectively.
The preference command is used to configure the preferences for locally generated BGP routes. In the current software version, the command applies to only the manually summarized routes generated through the aggregate command.
4. (Optional.) Configure an EBGP route as a shortcut route.
By default, an EBGP route has a preference of 255.
The local preference is used to determine the optimal route for traffic leaving the local AS. When a BGP router obtains multiple routes with the same destination and different next hops from several IBGP peers, it preferentially selects the route with the highest local preference as the optimal route.
This task allows you to specify the default local preference for routes sent to IBGP peers.
3. Configure the default local preference.
The default local preference is 100.
About the MED attribute
BGP uses MED to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes with the same destination but with different next hops, it selects the route with the smallest MED value as the optimal route if other conditions are the same.
Configuring the default MED value (IPv4 unicast/multicast address family)
3. Configure the default MED value.
default med med-value
The default MED value is 0.
Configuring the default MED value (IPv6 unicast/multicast address family)
By default, BGP only compares the MEDs of routes from the same AS. This task enables BGP to compare the MEDs of routes from different ASs.
3. Enable MED comparison for routes from different ASs.
compare-different-as-med
By default, MED comparison for routes from different ASs is disabled.
This task enables BGP to compare the MEDs of routes from an AS.
Figure 38 Route selection based on MED (in an IPv4 network)
As shown in Figure 38, Device D establishes indirect EBGP peer relationships with Device A, Device B, and Device C, and learns addresses 1.1.1.1/32, 2.2.2.2/32, and 3.3.3.3/32 through OSPF. The following output shows the routing information on Device D.
1.1.1.1/32 O_INTRA 10 10 11.1.1.2 Interface D1
2.2.2.2/32 O_INTRA 10 20 12.1.1.2 Interface D2
3.3.3.3/32 O_INTRA 10 30 13.1.1.2 Interface D3
Device D learns network 10.0.0.0 from both Device A and Device B. Because the route learned from Device B has a smaller IGP metric, the route is optimal. The following output shows the BGP routing table on Device D.
*>e 10.0.0.0 2.2.2.2 50 0 300 400e
* e 3.3.3.3 50 0 200 400e
When Device D learns network 10.0.0.0 from Device C, it compares the route with the optimal route in its routing table. Because Device C and Device B reside in different ASs, BGP does not compare the MEDs of the two routes. The route from Device C has a smaller IGP metric than the route from Device B, so the route from Device C becomes optimal. The following output shows the BGP routing table on Device D.
*>e 10.0.0.0 1.1.1.1 60 0 200 400e
* e 10.0.0.0 2.2.2.2 50 0 300 400e
However, Device C and Device A reside in the same AS, and Device C has a greater MED, so network 10.0.0.0 learned from Device C should not be optimal.
To avoid this problem, you can configure the bestroute compare-med command to enable MED comparison for routes from the same AS on Device D. After that, Device D puts the routes received from each AS into a group, selects the route with the lowest MED from each group, and compares routes from different groups. Network 10.0.0.0 learned from Device B is the optimal route. The following output shows the BGP routing table on Device D.
* e 1.1.1.1 60 0 200 400e
3. Enable MED comparison for routes on a per-AS basis.
By default, MED comparison for routes on a per-AS basis is disabled.
This task enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
3. Enable MED comparison for routes from confederation peers.
bestroute med-confederation
By default, MED comparison for routes from confederation peers is disabled.
By default, a BGP router does not set itself as the next hop for routes advertised to an IBGP peer or peer group. In some cases, however, you must configure the advertising router as the next hop to ensure that the BGP peer can find the correct next hop.
For example, as shown in Figure 39, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. If Router C has no route destined for IP address 1.1.1.1/24, you must configure Router B to set itself 3.1.1.1/24 as the next hop for the network 2.1.1.1/24 advertised to Router C.
Figure 39 NEXT_HOP attribute configuration
If a BGP router has two peers on a broadcast network, it does not set itself as the next hop for routes sent to an EBGP peer by default. As shown in Figure 40, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. They are on the same broadcast network 1.1.1.0/24. When Router B sends EBGP routes to Router A, it does not set itself as the next hop by default. However, you can configure Router B to set it (1.1.1.2/24) as the next hop for routes sent to Router A by using the peer next-hop-local command as needed.
Figure 40 NEXT_HOP attribute configuration
If you have configured BGP load balancing, the device sets itself as the next hop for routes sent to an IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
The following commands are mutually exclusive when you execute them for the same peer or peer group:
· peer next-hop-local
· peer next-hop-invariable
By default, a device sets itself as the next hop for labeled unicast routes sent to an IBGP peer or peer group.
A route reflector can change the NEXT_HOP attribute of reflected routes only if it is configured with both of the peer next-hop-local and reflect change-path-attribute commands.
address-family ipv4 multicast
3. Specify the local device IP as the next hop for routes sent to a peer or peer group.
The default settings are as follows:
¡ When the device advertises a route to an EBGP peer, it changes the next hop of that route as follows:
- If the EBGP peer is a directly connected peer and the next hop of the route is in the same network as the directly connected interface, the device does not change the next hop of the route.
- In other scenarios, the device sets the local device IP as the next hop of the route.
¡ The device does not change the next hops of routes sent to an IBGP peer or peer group. When the device sends ECMP BGP routes to IBGP peers, it sets the local device IP as the next hop of the optimal route among these routes.
This feature is applicable to multiple-AS networks on which a device cannot change the next hop of routes advertised to a peer or peer group in a different AS. As shown in Figure 41, PE1 and PE2 are located in different ASs. They communicate with each other through the public network and exchange BGP IPv4 and IPv6 routes. To ensure service scheduling, the next hop of routes on PE1 must be PE2 and the next hop of routes on PE2 must be PE1.
Both PE1 and PE2 have established an EBGP relationship with PE3 and PE4 respectively on the backbone network to exchange routes with each other. On the receipt of routes from PE1, PE3 will forward the routes to PE4. Then, PE4 will change the next hop of the routes before forwarding them to PE2. As a result, the next hop of the routes received by PE2 is not PE1. To resolve this issue, you can use the peer next-hop-invariable command to disable PE4 from changing the next hop of routes.
Procedure (IPv4 unicast address family)
Table 63 Enter system view.
2. Enter BGP IPv4 unicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
3. Disable the device from changing the next hop of routes advertised to an EBGP peer or peer group.
By default, the device sets its IP address as the next hop for all routes advertised to an EBGP peer or peer group. It does not set its IP address as the next hop for routes advertised to an IBGP peer or peer group.
The ipv6-address [ prefix-length ] option is not supported in BGP IPv4 labeled unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
Procedure (IPv6 unicast address family)
Table 64 Enter system view.
3. Enter BGP IPv6 unicast address family view.
4. Disable the device from changing the next hop of routes advertised to an EBGP peer or peer group.
In general, BGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
In certain network environments (for example, a Hub&Spoke network in MPLS L3VPN), however, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
3. Permit the local AS number to appear in routes from a peer or peer group and set the appearance times.
By default, the local AS number is not allowed in routes from a peer or peer group.
3. Configure BGP to ignore the AS_PATH attribute during optimal route selection.
bestroute as-path-neglect
By default, BGP includes the AS_PATH attribute in optimal route selection.
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
Figure 42 Network diagram
When you configure the peer fake-as command, you can specify the following keywords:
· dual-as—Initiates session requests to a peer using the real AS number and fake AS number in turn until a session is established successfully. The first session request contains the real AS number.
When the session goes down and BGP re-initiates session requests to the peer, the first session request contains the most recent AS number before the session goes down.
· prepend-fake-as—Adds the fake AS number to the AS_PATH attribute in packets received from a peer.
· prepend-global-as—Adds the real AS number to the AS_PATH attribute in packets sent to a peer.
The prepend-fake-as and prepend-global-as keywords take effect only when BGP establishes a session to its peer using a fake AS number.
The peer fake-as command is applicable only to EBGP peers or peer groups. When you set the AS number of the specified peer as the fake AS number in the peer fake-as command, follow these restrictions and guidelines:
· If the device successfully establishes a session to the specified peer by using the fake AS number, the device considers the peer as an IBGP peer.
· If the device successfully establishes a session to the specified peer by using the actual AS number, the device considers the peer as an EBGP peer.
· Both the features supported only by IBGP peers and the features supported only by EBGP peers are configurable for the peer. However, only the features supported by the peer can take effect on the peer.
· BGP clears the configuration that takes effect on only IBGP peers for the peer if one of the following conditions exists:
¡ The value for the as-number argument in the peer fake-as command is different from that in the peer as-number command.
¡ You have executed the undo peer fake-as command.
3. Advertise a fake AS number to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } fake-as as-number [ dual-as | prepend-fake-as | prepend-global-as ] *
By default, no fake AS number is advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } fake-as as-number [ dual-as | prepend-fake-as | prepend-global-as ] *
To use EBGP between PE and CE in MPLS L3VPN, VPN sites in different geographical areas should have different AS numbers. Otherwise, BGP discards route updates containing the local AS number. If two CEs connected to different PEs use the same AS number, you must configure AS number substitution on each PE. This substitution can replace the AS number in route updates originated by the remote CE as its own AS number before advertising them to the connected CE.
Figure 43 AS number substitution configuration (in an IPv4 network)
As shown in Figure 43, CE 1 and CE 2 use the same AS number 800. To ensure bidirectional communication between the two sites, configure AS number substitution on PE 2. PE 2 replaces AS 800 with AS 100 for the BGP route update originated from CE 1 before advertising it to CE 2. Perform the same configuration on PE 1.
Do not configure AS number substitution in normal circumstances. Otherwise, routing loops might occur.
3. Configure AS number substitution for a peer or peer group.
By default, AS number substitution is not configured.
peer { group-name | ipv6-address [ prefix-length ] } substitute-as
Private AS numbers are typically used in test networks, and should not be transmitted in public networks. To prevent the transmission of private AS numbers in public networks, use this feature to replace or delete the private AS numbers in BGP updates advertised to EBGP peers.
You can use this feature to remove or replace private AS numbers with the local AS number in BGP updates as follows:
· When you execute the peer public-as-only command without specifying the force keyword or the limited keyword, the following rules apply:
¡ If the AS_PATH attribute of a BGP update carries only private AS numbers, the device removes the AS numbers before sending the update to the specified EBGP peer or peer group.
· When you execute the peer public-as-only command with the force keyword specified, this command works as Table 65 shows.
Keyword |
replace |
Whether this keyword is specified: · Specified—This command replaces all private AS numbers with the local AS number in the AS_PATH attribute. · Not specified—This command removes all private AS numbers from the AS_PATH attribute. |
include-peer-as |
Whether this keyword is specified: · Specified—This command removes or replaces the AS number of the specified peer or peer group if it is a private AS number. · Not specified—This command does not remove or replace the private AS number of the specified peer or peer group. |
keep-local-as |
The keep-local-as and replace keywords cannot be used together. Whether this keyword is specified: · Specified—This command removes all private AS numbers except for the local one from the AS_PATH attribute. · Not specified—This command removes or replaces the private AS numbers in the AS_PATH attribute based on the configuration of other keywords. |
· When you execute the peer public-as-only command with the limited keyword specified, this command works as Table 66 shows.
Keyword |
replace |
Whether this keyword is specified: · Specified—This command replaces all private AS numbers on the left of the first non-private AS number in the AS_PATH attribute. · Not specified—This command removes all private AS numbers on the left of the first non-private AS number from the AS_PATH attribute. |
include-peer-as |
Whether this keyword is specified: · Specified—This command removes or replaces the private AS number of the specified peer or peer group on the left of the first non-private AS number in the AS_PATH attribute. · Not specified—This command does not remove or replace the private AS number of the specified peer or peer group. |
By default, AS numbers in the ranges of 64512 to 65535 and 4200000000 to 4294967295 are private AS numbers. If the 4-byte private AS number capability is disabled by executing the undo private-4-byte-as enable command, only AS numbers in the range of 64512 to 65535 are private AS numbers.
This feature is applicable only to EBGP peers or peer groups.
Use this feature with caution, because changing the AS_PATH attribute might cause routing loops.
3. Configure BGP to remove or replace private AS numbers with the local AS number in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only [ force [ include-peer-as ] ] keep-local-as
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
By default, BGP checks the first AS number of a route learned from an EBGP peer. If the first AS number is not that of the EBGP peer, BGP terminates the BGP session to the peer.
Ignoring the first AS number of all EBGP route updates
3. Configure BGP to ignore the first AS number of all EBGP route updates.
ignore-first-as
By default, BGP checks the first AS number of all EBGP-learned route updates.
Ignoring the first AS number of EBGP route updates received from a peer or peer group (IPv4 peers)
3. Configure BGP to ignore the first AS number of EBGP route updates received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ignore-first-as
By default, BGP checks the first AS number of EBGP-learned route updates.
Ignoring the first AS number of EBGP route updates received from a peer or peer group (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } ignore-first-as
Perform this task to enable BGP to filter routes based on the quantity of AS numbers contained in the AS_PATH attribute. BGP will discard incoming and outgoing routes, and withdraw routes that have been advertised if they exceed the specified quantity threshold.
This feature does not take effect on routes that have been received or on local summary routes.
3. Set an AS number quantity threshold.
as-path-limit [ as-numbers ]
By default, no AS number quantity threshold is configured.
By default, BGP does not advertise the AIGP attribute to its peers or peer groups. When BGP receives a route carrying the AIGP attribute, it ignores and removes the attribute before advertising the route to other peers or peer groups. Perform this task to enable BGP to advertise the AIGP attribute to its peers or peer groups.
When the AIGP attribute of a route changes, BGP sends a route update with the new AIGP attribute.
As a best practice, do not configure the peer aigp command on border routers of an AIGP administrative domain.
When a router receives a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you configure only the peer aigp command. To enable the router to advertise the AIGP attribute, you must configure both the peer aigp and apply aigp commands. For information about the apply aigp command, see "Configuring routing policies."
Procedure (IPv4)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
3. Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attribute in routes received from the peer or peer group.
4. (Optional.) Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
Procedure (IPv6)
peer { group-name | ipv6-address [ prefix-length ] } aigp
peer { group-name | ipv6-address [ prefix-length ] } aigp send med
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
After you perform this task, routes learned from the specified peer or peer group take precedence over other routes if these routes have the same prefix. BGP will prefer routes learned from the specified peer or peer group during optimal route selection.
To view the priority of the route selection rule configured by this task among the BGP route selection rules, see "BGP route selection."
This feature takes effect only on BGP routes that are learned in the current address family. It does not take effect on BGP routes that are redistributed to other BGP routing tables.
3. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority [ preferred ]
address-family ipv6 multicast
In scenarios where multiple networks coexist, the device might simultaneously learn BGP routes with the same destination network address but different types of next hops. Supported next hop types include IPv4 and IPv6. For example, the device might be able to reach the same destination address through either an SRv6 network or the public IPv4 network. In this case, it might learn a route with an IPv6 next hop from the SRv6 network and a route with an IPv4 next hop from the public IPv4 network. By default, the device selects the route learned from the public IPv4 network as the optimal route. To have the device select the route learned from the SRv6 network as the optimal route, you need to configure other route attributes to affect the route selection result. This task enables you to specify the next hop IP type that BGP prefers during optimal route selection, thus providing more flexibility and convenience in BGP route planning.
To view the priority of the nexthop IP type-based route selection rule among the BGP route selection rules, see "BGP route selection."
Procedure (IPv4 unicast/multicast address family)
1. Enter system view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
3. Prefer BGP routes of a specific next hop IP type during optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hops during optimal route selection.
If you execute this command multiple times in the same address family, the most recent configuration takes effect.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
By default, BGP takes IGP metrics into account during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest IGP metric as the optimal route.
Perform this task to enable BGP to ignore IGP metrics during optimal route selection.
3. Configure BGP to ignore IGP metrics during optimal route selection.
bestroute igp-metric-ignore
By default, BGP compares router IDs during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest router ID as the optimal route.
Perform this task to enable BGP to ignore router IDs during optimal route selection.
3. Configure BGP to ignore router IDs during optimal route selection.
bestroute router-id-ignore
About tunnel-type recursive next hops
NOTE: In this section, a recursive next hop refers to a next hop obtained through route recursion. Recursive next hops include the following: · IP-type recursive next hops: This type of recursive next hops are IP addresses. · Tunnel-type recursive next hops: This type of recursive next hops are tunnels. |
When the next hop of a BGP route is recursed to a tunnel, the tunnel can be one of the following:
· Label switched path (LSP) or MPLS TE tunnel.
· GRE or VXLAN tunnel.
· SR-MPLS TE policy or SRv6 TE policy tunnel.
Each tunnel-type recursive next hop has a unique tunnel ID. To view the tunnel-type recursive next hops of BGP routes, see the Rely tunnel IDs field in the output of the display bgp routing-table command.
Configuring the condition for BGP routes to participate in optimal route selection
The next hop of a BGP route can be recursed to an IP addresses and a tunnel synchronously. By default, a BGP route can participate in optimal route selection only when its next hop is recursed to an IP address. This command is applicable to the following scenarios:
· When the device acts as a route reflector, it only reflects routes to clients and does not provide traffic forwarding guidance. To ensure that the device can reflect all received routes to its clients, execute the bestroute nexthop-resolved none command. This command disables BGP from examining the reachability of next hops during optimal route selection.
· In some special networks, the next hop of a route might be a tunnel only after route recursion if its AS_PATH attribute is modified by an intermediate device. In this situation, the route cannot participate in optimal route selection though its next hop is reachable, which leads to traffic forwarding failure. To resolve this issue, use the bestroute nexthop-resolved tunnel command. This command allows BGP routes that have only tunnel-type recursive next hops to participate in optimal route selection.
Although the bestroute nexthop-resolved none command enables BGP routes with unreachable next hops to participate in optimal route selection, those routes cannot be added into the IP routing table or FIB. As a result, they are not used to direct traffic forwarding.
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
3. Configure the condition for BGP routes to participate in optimal route selection
bestroute nexthop-resolved tunnel { none | tunnel }
By default, BGP routes can participate in optimal route selection only when their next hops are recursed to IP addresses.
Preferring BGP routes of a specific recursive next hop type during optimal route selection
By default, the recursive next hops of BGP routes does not affect their priorities during optimal route selection. If the next hop of a BGP route is recursed to an IP address and that of another BGP route is recursed to a tunnel, the two routes still have the same priority during optimal route selection.
This feature enables BGP to prefer routes with IP-type or tunnel-type recursive next hops during optimal route selection.
To view the priority of the route selection rule configured by this feature during optimal route selection, see "BGP route selection."
A BGP route that does not have an IP-type recursive next hop cannot participate in optimal route selection. For BGP routes with only tunnel-type recursive next hops, they cannot participate in optimal route selection even if you have executed the bestroute nexthop-type tunnel command. To resolve this issue, execute the bestroute nexthop-resolved tunnel command.
¡ Execute the following commands in sequence to enter BGP-VPN instance view.
3. Prefer routes with IP-type or tunnel-type recursive next hops during optimal route selection.
bestroute nexthop-type { ip | tunnel } [ preferred ]
After you configure this feature, the following BGP route selection rule will no longer take effect: "If a route received from an EBGP peer is the current optimal route, BGP does not change the optimal route when it receives routes from other EBGP peers." When the device receives routes from different EBGP peers, the reselection process will not stop at this step. Instead, the reselection process will proceed with the subsequent BGP route selection rules until the optimal route is selected.
3. Change the BGP route selection rule when the device receives routes from different EBGP peers.
bestroute compare-ebgp
By default, if the device receives routes from different EBGP peers, and the current optimal EBGP route remains unchanged after the "route with the smallest recursion depth" rule is applied, BGP does not proceed with the subsequent BGP route selection rules, and does not change the optimal EBGP route.
Display and maintenance commands for BGP path selection control
Task |
Command |
Display BGP path attribute information. |
display bgp [ instance instance-name ] paths [ as-regular-expression ] |
Task |
Command |
Task |
Command |
Task |
Command |
BGP path selection control configuration examples
Example: Configuring BGP path selection based on the LOCAL_PREF attribute
As shown in Figure 44, all routers run BGP.
· EBGP runs between Router A and Router B, and between Router A and Router C.
· IBGP runs between Router B and Router D, and between Router D and Router C. OSPF is the IGP in AS 200.
Configure routing policies for LOCAL_PREF attribute adding, which makes Router D prefer route 1.0.0.0/8 learned from Router C.
2. Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
XGE0/0/15 |
1.0.0.1/8 |
Router D |
XGE0/0/15 |
195.1.1.1/24 |
XGE0/0/16 |
192.1.1.1/24 |
XGE0/0/16 |
194.1.1.1/24 |
XGE0/0/17 |
193.1.1.1/24 |
Router C |
XGE0/0/15 |
193.1.1.2/24 |
Router B |
XGE0/0/15 |
192.1.1.2/24 |
XGE0/0/16 |
195.1.1.2/24 |
XGE0/0/16 |
194.1.1.2/24 |
Table 67 Configure IP addresses for interfaces. (Details not shown.)
Table 68 Configure OSPF on Router B, Router C, and Router D:
[RouterB] ospf
[RouterB-ospf] area 0
[RouterB-ospf-1-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
[RouterC] ospf
[RouterC-ospf] area 0
[RouterC-ospf-1-area-0.0.0.0] network 193.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
<RouterD> system-view
[RouterD] ospf
[RouterD-ospf] area 0
[RouterD-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
Table 69 Configure BGP connections:
[RouterA] bgp 100
[RouterA-bgp-default] peer 193.1.1.2 as-number 200
[RouterA-bgp-default-ipv4] peer 193.1.1.2 enable
# Inject network 1.0.0.0/8 into the BGP routing table of Router A.
[RouterA-bgp-default-ipv4] network 1.0.0.0 8
[RouterB] bgp 200
[RouterB-bgp-default] peer 194.1.1.1 as-number 200
[RouterB-bgp-default-ipv4] peer 194.1.1.1 enable
[RouterC] bgp 200
[RouterC-bgp-default] peer 193.1.1.1 as-number 100
[RouterC-bgp-default] peer 195.1.1.1 as-number 200
[RouterC-bgp-default-ipv4] peer 193.1.1.1 enable
[RouterC-bgp-default-ipv4] peer 195.1.1.1 enable
[RouterD] bgp 200
[RouterD-bgp-default] peer 194.1.1.2 as-number 200
[RouterD-bgp-default] peer 195.1.1.2 as-number 200
[RouterD-bgp-default] address-family ipv4 unicast
[RouterD-bgp-default-ipv4] peer 194.1.1.2 enable
[RouterD-bgp-default-ipv4] peer 195.1.1.2 enable
[RouterD-bgp-default-ipv4] quit
[RouterD-bgp-default] quit
Table 70 Configure local preference for the route 1.0.0.0/8 to make Router D give priority to the route learned from Router C:
# Define IPv4 basic ACL 2000 to permit the route 1.0.0.0/8 on Router C.
[RouterC] acl basic 2000
[RouterC-acl-ipv4-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[RouterC-acl-ipv4-basic-2000] quit
# Define routing policy localpref on Router C to set the local preference of route 1.0.0.0/8 to 200 (the default is 100).
[RouterC] route-policy localpref permit node 10
[RouterC-route-policy-localpref-10] if-match ip address acl 2000
[RouterC-route-policy-localpref-10] apply local-preference 200
[RouterC-route-policy-localpref-10] quit
# Apply the routing policy localpref to the route from the peer 193.1.1.1 on Router C.
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] peer 193.1.1.1 route-policy localpref import
Total number of routes: 2
a - additional-path
* >i 1.0.0.0 193.1.1.1 200 0 100i
* i 192.1.1.1 100 0 100i
The route 1.0.0.0/8 learned from Router C is the optimal route.
Example: Configuring route selection based on the MED attribute
As shown in Figure 45, all devices run BGP. EBGP runs between Router A and Router B, and between Router A and Router C. IBGP runs between Router B and Router C.
For Router A, traffic destined for network segment 10.1.1.0/24 can reach AS 200 via Router B or Router. To achieve this goal, configure a routing policy that adds the MED attribute to BGP routes, so Router A can select Router C as the ingress of AS 200.
Table 71 Configure IP addresses for interfaces. (Details not shown.)
Table 72 Configuring BGP connections.
[RouterA] bgp 100
[RouterA-bgp-default] peer 192.1.2.2 as-number 200
[RouterA-bgp-default-ipv4] peer 193.1.2.2 enable
[RouterB] bgp 200
[RouterB-bgp-default-ipv4] network 10.1.1.0 24
[RouterC] bgp 200
[RouterC-bgp-default] peer 192.1.2.1 as-number 100
[RouterC-bgp-default-ipv4] peer 192.1.2.1 enable
[RouterC-bgp-default-ipv4] network 10.1.1.0 24
Table 73 Configure the MED attribute, ensuring that Router A selects the route from Router C as the optimal route.
# Configure IPv4 basic ACL 2000 on Router A. This ACL only permits route 10.1.1.0/24.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[RouterA-acl-ipv4-basic-2000] quit
# Configure routing policy med on Router A. This routing policy sets the local preference of route 10.1.1.0/24 to 100. The default MED value is 0.
[RouterA] route-policy med permit node 10
[RouterA-route-policy-med-10] if-match ip address acl 2000
[RouterA-route-policy-med-10] apply cost 100
[RouterA-route-policy-med-10] quit
# On Router A, apply routing policy med to BGP routes received from Router B.
[RouterA] bgp 100
[RouterA-bgp-default-ipv4] peer 192.1.1.2 route-policy med import
# View the BGP routing table of Router A.
[RouterA] display bgp routing-table ipv4 unicast
BGP local router ID is 192.1.2.1
a - additional-path
* >e 10.1.1.0/24 192.1.2.2 0 0 200i
* e 192.1.1.2 100 0 200i
The command output shows that Router A has selected route 10.1.1.0/24 learned from Router C as the optimal route.
Example: Configuring route selection based on the AS_PATH attribute
As shown in Figure 46, Router A, Router B, and Router C are located in different ASs. Router B communicates with the other routers through EBGP. For security purposes, Router A and Router C should not learn the routes that the other advertises to Router B. To meet this requirement, configure a BGP route filtering policy based on the AS_PATH attribute on Router B. This policy prevents Router B from advertising routes learned from Router C to Router A, and from advertising routes learned from Router A to Router C. With this route filtering policy, AS 100 and AS 300 are isolated from each other.
Table 74 Configure IP addresses for interfaces. (Details not shown.)
Table 75 Configuring BGP connections.
[RouterA] bgp 100
[RouterA-bgp-default] peer 12.1.1.2 as-number 200
[RouterA-bgp-default-ipv4] peer 12.1.1.2 enable
[RouterA-bgp-default-ipv4] network 10.8.8.0 24
[RouterB] bgp 100
[RouterB-bgp-default] peer 12.1.1.1 as-number 100
[RouterB-bgp-default] peer 12.1.2.1 as-number 300
[RouterB-bgp-default-ipv4] peer 12.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 12.1.2.1 enable
[RouterC] bgp 100
[RouterC-bgp-default] peer 12.1.2.2 as-number 200
[RouterC-bgp-default-ipv4] peer 12.1.2.2 enable
[RouterC-bgp-default-ipv4] network 10.9.9.0 24
Table 76 Configure a BGP route distribution policy based on the AS_PATH attribute on Router B.
# Create AS path list deny100 to deny BGP routes whose AS_PATH attribute contains AS 100.
[RouterB] ip as-path deny100 deny _100_
[RouterB] ip as-path deny100 permit .*
# Create AS path list deny300 to deny BGP routes whose AS_PATH attribute contains AS 300.
[RouterB] ip as-path deny300 deny _300_
[RouterB] ip as-path deny300 permit .*
# Apply AS path lists deny100 and deny300 to routes advertised to Router A and Router C, respectively.
[RouterB] bgp 100
[RouterB-bgp-default-ipv4] peer 12.1.1.1 as-path-acl deny 300 export
[RouterB-bgp-default-ipv4] peer 12.1.2.1 as-path-acl deny 100 export
Execute the display bgp routing-table ipv4 unicast command on Router A, Router B, and Router C separately. The command outputs show that:
· Router B has learned route 10.8.8.0/24 from Router A and route 10.9.9.0/24 from Router C.
· Router A has not learned route 10.9.9.0/24 from Router C, and Router C has not learned route10.8.8.0/24 from Router A. This indicates that Router B does not forward Router A's routes to Router C or forward Router C's routes to Router A.
Example: Changing the preference value for a BGP route
As shown in Figure 47, Routers A, C, and D establish IBGP peer relationships, with Router C acting as the route reflector. Routers A, B, and D establish OSPF neighbor relationships. Router D advertises IPv4 unicast route 9.9.9.9/32 through OSPF and BGP. Upon receiving OSPF route 9.9.9.9/32 and BGP route 9.9.9.9/32, Router A changes the preference value for BGP route 9.9.9.9/32, so the route can be selected as optimal route in Router A's IP routing table.
Table 77 Configure IP addresses for interfaces. (Details not shown.)
Table 78 Configure Router A.
# Configure basic OSPF settings.
[RouterA] ospf 1
[RouterA-ospf-1] area 0.0.0.0
[RouterA-ospf-1] quit
# Enable OSPF on Ten-GigabitEthernet 0/0/15.
[RouterA] interface ten-gigabitethernet 0/0/15
[RouterA-Ten-GigabitEthernet0/0/15] ospf 1 area 0.0.0.0
[RouterA-Ten-GigabitEthernet0/0/15] quit
# Configure BGP settings.
[RouterA] bgp 10
[RouterA-bgp-default] peer 13.1.1.3 as-number 10
[RouterA-bgp-default-ipv4] peer 13.1.1.3 enable
Table 79 Configure Router B.
[RouterB] ospf 1
[RouterB-ospf-1] area 0.0.0.0
# Enable OSPF on Ten-GigabitEthernet 0/0/15 and Ten-GigabitEthernet 0/0/16.
[RouterB] interface ten-gigabitethernet 0/0/15
[RouterB-Ten-GigabitEthernet0/0/15] ospf 1 area 0.0.0.0
[RouterB-Ten-GigabitEthernet0/0/15] quit
[RouterB] interface ten-gigabitethernet 0/0/16
[RouterB-Ten-GigabitEthernet0/0/16] ospf 1 area 0.0.0.0
[RouterB-Ten-GigabitEthernet0/0/16] quit
Table 80 Configure Router C:
[RouterC] bgp 10
[RouterC-bgp-default] peer 13.1.1.1 as-number 10
[RouterC-bgp-default] peer 34.1.1.4 as-number 10
[RouterC-bgp-default-ipv4] peer 13.1.1.1 enable
[RouterC-bgp-default-ipv4] peer 13.1.1.1 reflect-client
[RouterC-bgp-default-ipv4] peer 13.1.1.1 next-hop-local
[RouterC-bgp-default-ipv4] peer 34.1.1.4 enable
[RouterC-bgp-default-ipv4] peer 34.1.1.4 reflect-client
[RouterC-bgp-default-ipv4] peer 34.1.1.4 next-hop-local
[RouterC-bgp-default-ipv4] reflect change-path-attribute
Table 81 Configure Router D:
[RouterD] ospf 1
[RouterD-ospf-1] area 0.0.0.0
# Enable OSPF on Loopback 1 and Ten-GigabitEthernet 0/0/15.
[RouterD] interface LoopBack1
[RouterD-LoopBack1] ip address 9.9.9.9 255.255.255.255
[RouterD-LoopBack1] ospf 1 area 0.0.0.0
[RouterD-LoopBack1] quit
[RouterD] interface ten-gigabitethernet 0/0/15
[RouterD-Ten-GigabitEthernet0/0/15] ospf 1 area 0.0.0.0
[RouterD-Ten-GigabitEthernet0/0/15] quit
[RouterD] bgp 10
[RouterD-bgp-default] peer 34.1.1.3 as-number 10
[RouterD-bgp-default-ipv4] network 9.9.9.9 255.255.255.255
[RouterD-bgp-default-ipv4] peer 34.1.1.3 enable
Table 82 Enable Router A to change the preference value for BGP route 9.9.9.9/32.
# On Router A, view detailed information about BGP route 9.9.9.9/32 in the IP routing table.
[RouterA] displey ip routing-table 9.9.9.9 verbose
Summary count : 2
Destination: 9.9.9.9/32
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 06h34m02s
FlushedAge: 00h01m35s
Cost: 2 Preference: 10
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
OrigTblID: 0x2 OrigVrf: default-vrf
TableID: 0x2 OrigAs: 0
NibID: 0x13000002 LastAs: 0
AttrID: 0xffffffffffffffff
BkAttrID: 0xffffffffffffffff Neighbor: 0.0.0.0
Flags: 0x10041 OrigNextHop: 12.1.1.2
Label: NULL RealNextHop: 12.1.1.2
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/15
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet0/0/15
BkTunnel ID: Invalid BkIPInterface: N/A
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: 0.0.0.0 PathID: 0x0
UserID: 0xffffffff SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 Priority: Medium
MemberPort: N/A ExtFlags: 0x0
UCMIndex: 0x0 UserVLAN: 65535
UCMMTU: 0 BrasHash: 0
SessionID: 0 UserGroupID: 0
IsoGroupID: 0 BkIsoGroupID: 0
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x1 Age: 00h01m35s
FlushedAge: 06h23m44s
Cost: 0 Preference: 255
Tag: 0 State: Inactive Adv
TableID: 0x2 OrigAs: 10
NibID: 0x16000001 LastAs: 10
AttrID: 0x0
BkAttrID: 0xffffffffffffffff Neighbor: 3.3.3.3
Flags: 0x60 OrigNextHop: 4.4.4.4
Label: NULL RealNextHop: 13.1.1.3
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/16
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet0/0/16
Connector: N/A PathID: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 Priority: Low
IsoGroupID: 256 BkIsoGroupID: 256
The IP routing table has two routes destined for 9.9.9.9/32. The preference value is 10 for OSPF route 9.9.9.9/32 and is 255 for BGP route 9.9.9.9/32. Consequently, only OSPF route 9.9.9.9/32 is active.
# On Router A, configure an ACL that match routes with prefix 9.9.9.9/32, and then apply the ACL to a routing policy. Then, configure the routing policy to change the preference value to 5 for matching routes in the IP routing table.
[RouterA] acl basic 2077
[RouterA-acl-ipv4-basic-2077] rule 5 permit source 9.9.9.9 0
[RouterA-acl-ipv4-basic-2077] quit
[RouterA] route-policy change-preference permit node 10
[RouterA-route-policy-change-preference-10] if-match ip address acl 2077
[RouterA-route-policy-change-preference-10] apply preference 5
[RouterA-route-policy-change-preference-10] quit
# On Router A, apply the previous routing policy to BGP. Router A can then set the preference value to 5 for BGP route 9.9.9.9/32.
[RouterA] bgp 10
[RouterA-bgp-default-ipv4] preference route-policy change-preference
Summary count : 2
Process ID: 0
SubProtID: 0x1 Age: 00h00m08s
FlushedAge: 00h00m08s
Cost: 0 Preference: 5
AttrID: 0x0
Flags: 0x10060 OrigNextHop: 4.4.4.4
SID: N/A
BkSID: N/A
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 06h54m06s
FlushedAge: 00h21m39s
Flags: 0x41 OrigNextHop: 12.1.1.2
SID: N/A
BkSID: N/A
According to the command output, the preference value for BGP route 9.9.9.9/32 has been changed to 5. The BGP route is in active state, because its preference is higher than that of OSPF route 9.9.9.9/32.
Tuning and optimizing BGP networks
BGP network tuning and optimization tasks at a glance
To tune and optimize BGP networks, perform the following tasks:
· Configuring path MTU discovery and MSS for TCP connections
¡ Enabling path MTU discovery for TCP connections
¡ Setting the TCP MSS for TCP connections
· Establishing and resetting EBGP sessions:
¡ Enabling BGP to establish an EBGP session over multiple hops
¡ Enabling immediate re-establishment of direct EBGP connections upon link failure
¡ Protecting an EBGP peer when memory usage reaches level 2 threshold
· Enabling BGP to negotiate special capabilities
¡ Enabling prefix-based BGP ORF capabilities negotiation
¡ Enabling 4-byte AS number suppression
¡ Enabling BGP to negotiate the extended message capability with peers
· Establishing, terminating, and soft-resetting BGP sessions:
¡ Disabling BGP session establishment
· Enabling BGP to select and advertise multiple routes with the same prefix:
¡ Configuring BGP load balancing
¡ Configuring the BGP Additional Paths feature
· Configuring BGP optimal route selection delay
· Adjusting nexthop recursion settings for BGP routes
¡ Setting the delay time for responding to recursive next hop changes
¡ Configuring route recursion suppression
¡ Specifying the longest match principle for next hop recursion
¡ Recursing public-network BGP routes to tunnels
· Disabling BGP from checking the next hop addresses of EBGP routes received from a peer or peer group
· Configuring peer flap dampening
· Setting a DSCP value for outgoing BGP packets
· Configuring the rules for adding BGP routes to the IP routing table:
¡ Flushing the suboptimal BGP route to the RIB
¡ Enabling BGP to not flush specific routes to the routing table
· Adjusting labeled routes
¡ Specifying a label allocation mode
¡ Disabling optimal route selection for labeled routes without tunnel information
¡ Converting unlabeled BGP routes into labeled routes
· Disabling MPLS local IFNET tunnel establishment
· Appending the local RT attribute to private routes
· Enabling peer unreachability detection
· Enabling the 4-byte private AS number capability
· Displaying 4-byte AS numbers in dotted notation
· Setting the maximum number of error UPDATE messages
· Advertising user group ID information in BGP routes to a peer or peer group
About path MTU discovery
BGP typically establishes a multihop TCP connection with a peer. Multiple intermediate devices might fragment BGP packets due to their MTU settings. To avoid IP fragmentation by intermediate devices, enable BGP to perform path MTU discovery before establishing a TCP connection with a peer. Then, BGP uses the detected path MTU to calculate the MSS. For more information about path MTU discovery, see IP performance optimization configuration in Layer 3—IP Services Configuration Guide.
You can enable path MTU discovery globally by using the path-mtu-discovery enable command or on a per peer basis by using the peer path-mtu-discovery enable command.
The path-mtu-discovery enable command takes effect on only TCP connections established through IPv4 addresses.
You can configure the peer path-mtu-discovery enable command together with the peer path-mtu-discovery enable command. The configuration of the latter command takes precedence over that of the former.
Enabling path MTU discovery globally
2. Enter BGP instance view.
3. Enable path MTU discovery for TCP connections globally.
By default, BGP does not perform path MTU discovery before establishing a TCP connection.
Enabling path MTU discovery on a per peer basis
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
3. Enable path MTU discovery for TCP connections with a specific peer.
peer ipv4-address [ mask-length ] path-mtu-discovery enable
By default, BGP does not perform path MTU discovery for TCP connections with a specific peer.
BGP typically establishes a multihop TCP connection with a peer. Multiple intermediate devices might fragment BGP packets due to their MTU settings, resulting in frequent packet encapsulations and decapsulations that reduce forwarding efficiency.
To resolve this issue, you can perform this task to set the TCP maximum segment size (MSS) for TCP connections with a peer or peer group. TCP segments sent by the source will not be re-fragmented along the path to the destination.
During TCP connection establishment with the peer or peer group specified in the peer tcp-mss command, the minimum of the following MSSs takes effect:
· The MSS calculated according to the IPv4 MTU set by the ip mtu command on the peer-facing interface.
· The MSS set by the tcp mss command for the peer-facing interface.
· The MSS calculated according to the path MTU detected by TCP path MTU discovery (enabled with the tcp path-mtu-discovery command).
· The MSS calculated according to the path MTU detected by path MTU discovery (enabled with the path-mtu-discovery enable command or the peer path-mtu-discovery enable command).
· The MSS set by the peer tcp-mss command.
The MSS is calculated by using the following formula:
MSS = path MTU (or interface MTU) – IP header length – TCP header length
For more information about MTU and MSS, see IP performance optimization configuration in Layer 3—IP Services Configuration Guide.
This task might cause BGP session re-establishment. Make sure you understand the potential impact before performing this task.
3. Set the TCP MSS for TCP connections with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tcp-mss mss-value
By default, the TCP MSS is not set.
To establish an EBGP session, two routers must have a direct physical link and use directly connected interfaces. If no direct link is available, you must use the peer ebgp-max-hop command to enable BGP to establish an EBGP session over multiple hops and specify the maximum hops.
When the BGP GTSM feature is enabled, two peers can establish an EBGP session after passing GTSM check, regardless of whether the maximum number of hops is reached.
To ensure correct BGP route recursion, do not specify any direct EBGP peer or peer group when you configure the peer ebgp-max-hop command.
Procedure (IPv4 peers)
¡ Enter BGP-VPN instance view.
3. Enable BGP to establish an EBGP session to an indirectly connected peer or peer group and specify the maximum hop count.
peer { group-name | ipv4-address [ mask-length ] } ebgp-max-hop [ hop-count ]
By default, BGP cannot establish an EBGP session to an indirectly connected peer or peer group.
Procedure (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
With this feature disabled, when the link to a directly connected EBGP peer goes down, BGP does not re-establish a session to the peer until the hold time timer expires. This feature enables BGP to immediately discover the link failure and recreate the session in that situation. When this feature is disabled, route flapping does not affect EBGP session state.
3. Enable immediate re-establishment of direct EBGP connections upon link failure.
ebgp-interface-sensitive
By default, immediate re-establishment of direct EBGP connections is enabled.
Memory usage includes the following threshold levels: normal, level 1, level 2, and level 3. When the level 2 threshold is reached, BGP periodically terminates an EBGP session to release memory resources until the memory usage falls below the level 2 threshold. You can configure this feature to avoid terminating the EBGP session to an EBGP peer when the memory usage reaches the level 2 threshold.
For more information about memory usage thresholds, see device management configuration in Fundamentals Configuration Guide.
Table 83 Enter system view.
3. Configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold.
peer { group-name | ipv4-address [ mask-length ] } low-memory-exempt
By default, BGP periodically terminates an EBGP session to release memory resources when level 2 threshold is reached.
Table 84 Enter system view.
peer { group-name | ipv6-address [ prefix-length ] } low-memory-exempt
By default, BGP terminates an EBGP session to release memory resources periodically when level 2 threshold is reached.
About BGP ORF
Configure this feature in scenarios where the route sender is supposed to send only the desired BGP routes to the route receiver. Without BGP ORF configured, you must configure a route distribution policy on the route sender on a per receiver basis, which is complex and larborious. This feature helps you free this situaiton.
BGP Outbound Route Filtering (ORF) reduces the bandwidth usage by reducing the route updates that are sent between BGP peers.
The BGP peers negotiate the ORF capabilities through OPEN messages. After completing the negotiation process, the BGP peers can exchange ORF information (local route reception filtering policy) through ROUTE-REFRESH messages. Then, only routes that pass both the local route distribution filtering policy and the received route reception filtering policy can be advertised.
ORF information includes the local address prefix list used for selective BGP route reception. After a peer receives the local device's ORF information, it will only send BGP routes that match the address prefix list to the local device. This approach reduces the number of UPDATE messages transmitted between BGP peers, saving network resources.
You can enable the ORF information sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the ORF capabilities, make sure one end has the sending capability and the other end has the receiving capability.
After you enable BGP ORF capabilities negotiation for a peer, the local device negotiates standard ORF capabilities as defined in RFC with the peer. If the peer uses nonstandard ORF, you must also enable nonstandard ORF capabilities negotiation for the peer.
Before enabling BGP ORF capabilities negotiation for a peer, use the peer prefix-list import command to set a BGP route reception policy referencing an address prefix list. If you fail to do so, BGP does not send address prefix list information to that peer.
Enabling BGP ORF capabilities negotiation for a peer or peer group
Procedure (IPv4 unicast/IPv4 multicast)
3. Reference an address prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name import
By default, no address prefix list is referenced to filter BGP routes received from a peer or peer group.
4. Enable prefix-based BGP ORF capabilities negotiation for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
By default, BGP ORF capabilities negotiation is disabled for a peer or peer group.
Procedure (IPv6 unicast/IPv6 multicast)
Enabling nonstandard BGP ORF capabilities negotiation for a peer or peer group
3. Enable nonstandard BGP ORF capabilities negotiation for a peer or peer group.
peer { group-name | ip-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
By default, nonstandard BGP ORF capabilities negotiation is disabled for a peer or peer group.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an OPEN message to the peer device for session establishment. The OPEN message indicates that the device supports 4-byte AS numbers. If the peer device supports 2-byte AS numbers instead of 4-byte AS numbers, the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression feature. The device then sends an OPEN message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers and the peer AS number is greater than 65535, do not enable the 4-byte AS number suppression feature. Otherwise, the BGP session cannot be established.
3. Enable 4-byte AS number suppression.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise suppress-4-byte-as
By default, 4-byte AS number suppression is disabled.
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
By default, the device supports sending and receiving BGP messages with a length of up to 4096 bytes. In certain scenarios, such as SRv6 TE policy networks, the candidate paths of an SRv6 TE policy might contain a large number of SID lists. As a result, the related BGP IPv6 SR policy route update might exceed 4096 bytes and thus cannot be advertised, which affects service traffic forwarding.
To avoid the above issue, you can execute this command. The local device will negotiate the extended message capability with the specified peer or peer group through OPEN messages. After successful negotiation, the local device and the specified peer or peer group can exchange BGP messages with a length greater than 4096 bytes and up to 65535 bytes.
To ensure successful negotiation of the extended message capability in a BGP session, configure this command at both ends of the BGP session, specifying the other end. To view the negotiation result, use the display bgp peer command.
The BGP extended message capability applies to all messages except for OPEN and KEEPALIVE messages. After the local device and the specified peer or peer group successfully negotiate the extended message capability, the maximum length of OPEN and KEEPALIVE messages exchanged between them is still 4096 bytes.
When the local device is not enabled with the extended capability and receives a BGP message exceeding 4096 bytes, it returns a NOTIFICATION message to the source peer and terminates the related BGP session.
When the local device fails to negotiate the extended capability with a peer, it still can receive BGP messages exceeding 4096 bytes from that peer. However, to avoid generating incorrect route information in the local routing table, the local device will delete the routes carried by the UPDATE messages among the received messages.
Table 85 Enter system view.
3. Enable BGP to negotiate the extended message capability with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise extended-message
By default, BGP does not negotiate the extended message capability with any peer or peer group.
CAUTION: Execute this command with caution, because this operation will re-establish all existing BGP sessions. |
About disabling BGP session establishment
This task enables you to temporarily tear down BGP sessions to a peer/peer group or all peers/peer groups. You can perform network upgrade and maintenance without needing to delete and reconfigure the peers and peer groups. To recover the sessions, execute the undo peer ignore or undo ignore all-peers command.
If you specify the graceful keyword in the peer ignore command, BGP performs the following tasks:
Table 86 Starts the wait timer specified with the graceful keyword.
2. Advertises all routes to the specified peer or peer group and changes the attribute of the advertised routes to the specified value.
Advertises the routes from the specified peer or peer group to other peers and peer groups and changes the attribute of the advertised routes to the specified value.
3. Shuts down the session to the specified peer or peer group after the wait timer expires.
If you specify the graceful keyword in the ignore all-peers command, BGP performs the following tasks:
Table 87 Starts the wait timer specified with the graceful keyword.
4. Advertises all routes to all peers and peer groups and changes the attribute of the advertised routes to the specified value.
5. Shuts down all sessions to peers and peer groups after the wait timer expires.
To lower the priority of the routes advertised by BGP, you can use the peer ignore command or the ignore all-peers command to configure route attribures. BGP peers can then select other peers' routes as optimal routes, which avoids traffic interruption upon wait timer expiration or peer disconnection.
For a BGP peer or peer group, the configuration made by the peer ignore command takes precedence over the configuration made by the ignore all-peers command.
· When you use the peer ignore command, follow these guidelines:
¡ If a session has been established to a peer, executing this command for the peer terminates the session and clears all related routing information.
¡ If sessions have been established to a peer group, executing this command for the peer group terminates the sessions to all peers in the group and clears all related routing information.
· Executing the ignore all-peers command terminates all existing sessions to peers and peer groups and clears all related routing information.
Disabling BGP session establishment with a peer or peer group (IPv4 peers)
Table 88 Enter system view.
3. Disable BGP session establishment with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ignore [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
By default, BGP can establish a session to a peer or peer group.
CAUTION: · If a session has been established to a peer, executing this command for the peer terminates the session and clears all related routing information. · If sessions have been established to a peer group, executing this command for the peer group terminates the sessions to all peers in the group and clears all related routing information. |
Disabling BGP session establishment with a peer or peer group (IPv6 peers)
Table 89 Enter system view.
peer { group-name | ipv6-address [ prefix-length ] } ignore [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
Disabling BGP session establishment with all peers or peer groups
Table 90 Enter system view.
3. Disable BGP session establishment with all peers or peer groups.
ignore all-peers [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
By default, BGP can establish sessions to all peers and peer groups.
CAUTION: Executing this command terminates all existing sessions to peers and peer groups and clears all related routing information. |
Configuring BGP soft-reset
About BGP soft-reset
After you modify the route selection policy, for example, modify the preferred value, you must reset BGP sessions to apply the new policy. The reset operation terminates and re-establishes BGP sessions.
To avoid tearing down BGP sessions, you can use one of the following soft-reset methods to apply the new policy:
· Enabling route refresh—The BGP router advertises a ROUTE-REFRESH message to the specified peer, and the peer resends its routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy.
This method requires that both the local router and the peer support route refresh.
· Saving updates—Use the peer keep-all-routes command to save all route updates from the specified peer. After modifying the route selection policy, filter routing information by using the new policy.
This method does not require that the local router and the peer support route refresh but it uses more memory resources to save routes.
· Manual soft-reset—Use the refresh bgp command to enable BGP to send local routing information or advertise a ROUTE-REFRESH message to the specified peer. The peer then resends its routing information. After receiving the routing information, the router filters the routing information by using the new policy.
Enabling route refresh (IPv4 peers)
3. Enable BGP route refresh for a peer or peer group.
¡ Enable BGP route refresh for the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise route-refresh
¡ Enable the BGP route refresh, multi-protocol extension, and 4-byte AS number features for the specified peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } capability-advertise conventional
By default, the BGP route refresh, multi-protocol extension, and 4-byte AS number features are enabled.
Enabling route refresh (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv6-address [ prefix-length ] } capability-advertise conventional
Configuring BGP soft-reset by saving route updates
You can execute the keep-all-routes command in BGP instance view to save route updates from all peers and peer groups.
You can execute the peer keep-all-routes command for a peer or peer group in the corresponding address family view to save route updates from the peer or peer group.
This feature takes effect only on routes received after this feature is configured.
The keep-all-routes command applies to all peers and peer groups. You cannot disable this feature by executing the undo peer keep-all-routes command for a specific peer or peer group in the corresponding address family view. To enable the feature for only certain peers or peer groups, perform the following operations:
· Execute the peer keep-all-routes command in the associated address family view.
· Make sure the keep-all-routes command is not executed in BGP instance view.
Procedure (global configuration)
3. Save route updates from all peers and peer groups.
keep-all-routes
By default, route updates from peers and peer groups are not saved.
Saving updates (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 labeled unicast address family view:
address-family ipv4 labeled-unicast
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 labeled unicast address family view:
3. Save all route updates from the peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
The ipv6-address [ prefix-length ] argument is not supported in BGP IPv4 labeled unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
This command takes effect only for the routes received after this command is executed.
Saving updates (IPv6 unicast/multicast address family)
Configuring manual soft-reset (IPv4 unicast/multicast address family)
4. Execute the quit command twice to return to user view.
5. Perform manual soft-reset. Choose one option as needed:
¡ Perform manual soft-reset on IPv4 sessions in BGP IPv4 address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 [ multicast | [ labeled-unicast | unicast ] [ vpn-instance vpn-instance-name ] ]
¡ Perform manual soft-reset on IPv6 sessions in BGP IPv4 address family.
refresh bgp [ instance instance-name ] ipv6-address [ prefix-length ] { export | import } ipv4 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
Configuring manual soft-reset (IPv6 unicast/multicast address family)
¡ Perform manual soft-reset on IPv6 sessions in BGP IPv6 address family.
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ]]
¡ Perform manual soft-reset on IPv4 sessions in BGP IPv6 address family.
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ multicast | [ unicast ] [ vpn-instance vpn-instance-name ] ]
Perform this task to specify the maximum number of BGP ECMP routes for load balancing, increasing the link resource usage.
By default, multiple labeled unicast routes can act as ECMP routes in the BGP routing table for load balancing purposes. However, label forwarding entries associated with those routes cannot form ECMP relationships, disabling the related label switched paths (LSPs) from performing load balancing. To resolve this issue, execute the balancing-lsp command to enable load balancing for label forwarding entries associated with ECMP labeled unicast routes. Traffic that matches those entries can be forwarded along multiple LSPs in a load balancing manner.
Both the balance igp-metric-ignore and bestroute igp-metric-ignore commands can enable BGP to use routes with different IGP metrics for load balancing. The two commands are different as follows:
· The balance igp-metric-ignore command can be used only for load balancing. It does not change the rules of optimal route selection. BGP still compares the IGP metric value of each route during optimal route selection.
· The bestroute igp-metric-ignore command takes effect on optimal route selection and route selection for load balancing.
3. (Optional.) Enable BGP to ignore IGP metrics during optimal route selection.
By default, BGP compares IGP metrics during optimal route selection, and selects the route with the smallest IGP metric as the optimal route.
BGP cannot use routes with different IGP metrics to implement load balancing. To resolve this issue, you can use this command.
4. Return to system view.
¡ In BGP instance view:
¡ In BGP-VPN instance view:
5. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
address-family ipv4 multicast
6. Specify the maximum number of BGP ECMP routes for load balancing.
balance [ ebgp | eibgp | ibgp ] number
By default, load balancing is disabled.
7. (Optional.) Enable BGP to ignore the AS_PATH attribute when it implements load balancing.
balance as-path-neglect
By default, BGP does not ignore the AS_PATH attribute when it implements load balancing.
8. (Optional.) Enable BGP to perform load balancing for routes that have different AS_PATH attributes of the same length.
balance as-path-relax [ ebgp | ibgp ]
By default, BGP cannot perform load balancing for routes that have different AS_PATH attributes of the same length.
9. (Optional.) Enable BGP to use routes with different IGP metrics to the same next hop for load balancing.
By default, BGP cannot use routes with different IGP metrics to the same next hop to implement load balancing.
10. (Optional.) Enable load balancing for label forwarding entries associated with labeled unicast routes and set the maximum number of labeled unicast routes for load balancing.
balancing-lsp number
By default, label forwarding entries associated with labeled unicast routes do not perform load balancing.
This command is not supported in BGP IPv4 multicast address family.
5. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
On a large-scale network, a route reflector can receive multiple BGP routes with the same prefix. By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
To resolve this issue, configure the BGP Additional Paths (Add-Path) feature on the route reflector. This feature enables the device to advertise multiple routes with the same prefix to a peer or peer group. On receipt of these routes, the peer generates multiple links to the same destination network. You can use these links to implement load balancing with the balance command or configure backup routes. When the optimal link fails, another link can take over to forward traffic, which enhances the reliability of data transmission.
As shown in Figure 48, Device A, Device B, and Device C are located in AS 100, exchanging routing information within the domain through the RR. Both Device B and Device C establish an EBGP session to Device D and learn a route with prefix 10.1.1.0/24 from Device D.
In this situation, the RR can learn two routes destined for 10.1.1.0/24 from Device B and Device C. To have the RR advertise multiple routes with the same prefix to Device A, configure the BGP Additional Paths feature. Table 91 shows the effect of the BGP Additional Paths feature on route advertisement and route convergence upon link failure:
Table 91 Route advertisement and route convergence upon link failure
Whether the BGP Additional Paths feature is configured |
Route advertisement |
Route convergence upon failure of a single link |
Configured |
The RR selects the optimal route from the two routes destined for 10.1.1.0/24, and only advertises the optimal route to Device A. |
Device A needs to perform route convergence again. |
Not configured |
RR advertises the two routes destined for 10.1.1.0/24 to Device A. The next hops of the two routes are 12.1.1.1 and 13.1.1.1, respectively. |
· If Device A establishes an FRR relationship between the two routes and the primary path to 10.1.1.0/24 fails, Device A can quickly use the backup path for traffic forwarding. · If Device A establishes an ECMP relationship between the two routes and one of them fails, Device A switches all traffic to the other path. |
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the Additional Paths capabilities, make sure one end has the sending capability and the other end has the receiving capability.
Procedure (IPv4 unicast address family)
3. Configure the BGP Additional Paths capabilities.
By default, no BGP Additional Paths capabilities are configured.
The ipv6-address [ prefix-length ] option is not supported in BGP IPv4 labeled unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
4. Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
By default, a maximum number of one Add-Path optimal route can be advertised to a peer or peer group.
5. Set the maximum number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum number of one Add-Path optimal route can be advertised to all peers.
Procedure (IPv6 unicast address family)
2. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
Typically BGP optimal route selection is triggered in real time by the events such as attribute change, configuration change, and route recursion. To avoid packet loss upon switchover between redundant links, you can perform this task to delay optimal route selection.
As shown in Figure 49, BGP runs on all devices in the network. Device A and Device D uses the primary path for communication. When the primary path fails, Device A and Device D switch to the backup path for communication and then back to the primary path after the primary path recovers. In such case, traffic loss might occur if Device A forwards packets through Device B before Device B completes route convergence. You can configure optimal route selection delay on Device A to resolve the problem.
Follow these restrictions and guidelines when you configure this feature:
· The optimal route selection delay setting applies only when multiple effective routes with the same prefix exist after a route change occurs.
· For routes being delayed for optimal route selection, modifying the optimal route selection delay timer has the following effects:
¡ If you modify the delay timer to a non-zero value, the routes are not affected, and they still use the original delay timer.
¡ If you execute the undo form of the route-select delay command or modify the delay timer to 0, the device performs optimal route selection immediately.
· If you execute the command multiple times for an address family, the most recent configuration takes effect.
· The optimal route selection delay configuration does not apply to the following conditions:
¡ A route change is caused by execution of a command or by route withdrawal.
¡ After a route change occurs, only one route exists for a specific destination network.
¡ An active/standby process switchover occurs.
¡ A route change occurs among equal-cost routes.
¡ Only the optimal and suboptimal routes exist when FRR is configured.
¡ Optimal route selection is triggered by a redistributed route.
¡ The next hop of the optimal route changes and a route with the same prefix is waiting for the delay timer to expire.
3. Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
Next hop changes include the following types:
· Critical next hop changes—Changes that cause route unreachability and service interruption. For example, a BGP route cannot find a recursive next hop (a physical interface or tunnel interface) because of network failures.
· Noncritical next hop changes—A recursive or related route changes but the change does not cause route unreachability or service interruption. For example, the recursive next hop (a physical interface or tunnel interface) of a BGP route changes but traffic forwarding is not affected.
When recursive or related routes change frequently, configure this feature to reduce unnecessary path selection and update messages and prevent traffic loss.
To avoid traffic loss, do not configure this feature if only one route is available to a specific destination.
Set an appropriate delay time based on your network condition. A short delay time cannot reduce unnecessary path selection or update messages, and a long delay time might cause traffic loss.
3. Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
BGP performs nexthop recursion for a BGP route to obtain a route or tunnel for real traffic forwarding. When the obtained route or tunnel changes, BGP performs nexthop recursion for the BGP route again. Upon frequent network flapping, BGP also performs route recursion repeatedly, which causes high CPU usage. To resolve this issue, configure BGP route recursion suppression. BGP can obtain the nexthop recursion result of a route only after the suppression timer expires. This feature helps reduce nexthop recursion frequency and CPU usage.
After you configure the suppression timer for BGP route recursion, the process of BGP route recursion is as follows:
Figure 50 BGP route recursion suppression
BGP can obtain the nexthop recursion result of a route only after the suppression timer expires. BGP does not update the route recursion result unless the suppression timer expires. If the route recursion result of a BGP route changes later, BGP performs route recursion for that route again.
To dynamically suppress route recursion, configure the maximum suppression timer. If the route recursion results keep changing, the suppression time increases until the maximum suppression timer expires or the recursion results stop changing.
The calculation of dynamic suppression time (T) is based on the number of route recursions (N) as follows:
· When N is 1, T equals minimum-interval.
· When N is not less than 2, T equals minimum-interval + incremental-interval × [ 2 ^ ( N - 2 ) ], and T cannot exceed maximum-interval.
· When T reaches maximum-interval for three consecutive times, T equals minimum-interval and N is reset to 1 in the next recursion.
· If the recursion results remain unchanged within two times the maximum-interval, T equals minimum-interval and N is reset to 1 in the next recursion.
· You can execute the nexthop recursive-lookup restrain command multiple times with different configurations to modify the suppression timer settings. However, only the most recent configuration can take effect. The suppression timer modification does not takes effect immediately. Instead, it takes effect on the next-round route recursion.
· The view in which you should execute the nexthop recursive-lookup restrain command varies by next hop location as follows:
¡ If the next hop of a BGP route is on the public network, execute this command in BGP instance view.
¡ If the next hop of a BGP route is on a VPN instance, execute this command in the BGP-VPN instance view of that VPN instance.
To determine the location of a next hop, perform the following task:
a. Execute the display ip routing-table verbose or display ipv6 routing-table verbose command, find the target BGP route in the command output, and then check the value of the NibID field.
b. Execute the display rib nib or display ipv6 rib nib command with the NIB ID obtained above, and then check the value of the VrfNthp field. This field displays index of the VPN instance to which a next hop belongs.
For more information about the following commands, see IP routing basics commands in Layer 3—IP Routing Command Reference:
¡ display ip routing-table verbose
¡ display ipv6 routing-table verbose
¡ display rib nib
¡ display ipv6 rib nib
· If you use the following commands together, BGP must wait the sum of the suppression timer and the delay timer before using the route recursion result for traffic forwarding:
¡ nexthop recursive-lookup restrain (in BGP instance view or BGP-VPN instance view)
¡ nexthop recursive-lookup delay
· If you use the following commands together, the actual suppression timer equals the sum of the suppression timers configured in those commands:
¡ nexthop recursive-lookup restrain (in RIB IPv4 address family view or RIB IPv6 address family view)
For more information about configuring the nexthop recursive-lookup restrain command in RIB IPv4 or IPv6 address family view, see IP routing basics commands in Layer 3—IP Routing Command Reference.
· Configuring this feature can result in low route recursion efficiency and slow route convergence. As a best practice, use this feature according to the network condition and make sure the suppression timer settings are appropriate.
1. Enter system view.
3. Configure BGP route recursion suppression.
nexthop recursive-lookup restrain { maximum-interval [ minimum-interval [ incremental-interval ] ] | millisecond interval }
By default, BGP route recursion suppression is disabled.
The value for the minimum-interval or incremental-interval argument cannot be greater than that for the maximum-interval argument.
By default, BGP first looks up in its directly connected routes for a recursive route during a route recursion. If no matching routes exist, BGP will look up in routes generated by all routing protocols based on the longest match principle. The device considers the next hop of a received BGP route as directly connected when the next hop belongs to the same subnet as a direct route. As a result, packet forwarding failure will occur when the device uses this BGP route to forward matching packets.
As shown in Figure 51, Device B has established an IBGP session to Device A and Device C respectively. All devices use a loopback interface as the source port for TCP connection. On receipt of BGP route 8.0.0.0/24 from Device C, Device B reflects the route to Device A. The addresses of the interfaces that connect Device A and Device B belong to subnet 3.3.0.0/16.
If the next hop information exchanged between IBGP peers remains unchanged, the next hop of BGP route 8.0.0.0/24 is 3.3.3.3. Device A considers 3.3.3.3 as a directly connected next hop because 3.3.3.3 belongs to subnet 3.3.0.0/16 and a direct route to 3.3.0.0/16 exists. Packet forwarding failure will occur if Device A forwards packets destined for subnet 8.0.0.0/24 over 3.3.3.3.
Figure 51 Next hop recursion error
To resolve this issue, you can specify the longest match principle for next hop recursion to ensure the recursive route is reachable. BGP will directly look up in routes generated by all routing protocols and select a matching route based on the longest match principle.
Procedure (IPv4 unicast)
2. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
3. Specify the longest match principle for BGP next hop recursion.
nexthop recursive-lookup longest-match [ route-policy route-policy-name ]
This command applies to all BGP routes received from peers in one of the following scenarios:
¡ The route-policy route-policy-name option is not specified.
¡ The specified routing policy does not exist.
Procedure (IPv6 unicast)
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
To perform IP forwarding on customer packets, carrier network devices must learn a large number of routes. To reduce workload and save resources on carrier network devices, configure this feature on user access devices to enable support for recursing unlabeled public BGP routes to LSPs or recursing public-network BGP routes to SRv6 TE policies. This feature allows the carrier network devices to forward customer packets through tunnels, without the need to learn customer network routes.
By default, BGP obtains output interface information and next hop address information for unlabeled public-network BGP routes only through IP forwarding-based route recursion. Those routes cannot be recursed to LSPs. If the segment-routing ipv6 traffic-engineering command is not configured, public-network BGP routes with SRv6 SIDs will not be recursed to SRv6 TE policies.
To enable support for recursing unlabeled public-network BGP routes to LSPs, execute the unicast-route recursive-lookup tunnel command. After you execute the unicast-route recursive-lookup tunnel and sr-policy steering policy-based commands, public-network BGP routes can be recursed to SRv6 TE policies, regardless of whether they carry SRv6 SIDs. BGP performs IP forwarding-based route recursion for a route only if the route fails to be recursed to a tunnel.
To recurse unlabeled public-network IPv6 BGP routes to IPv4 LSPs, you must configure the egress node to assign a non-null label to the penultimate hop. For more information about the penultimate hop popping feature, see basic MPLS configuration in MPLS Configuration Guide.
Public-network BGP routes with SRv6 SIDs can be recursed to SRv6 TE policies in one of the following situations:
· The unicast-route recursive-lookup tunnel and sr-policy steering policy-based commands are executed.
· The segment-routing ipv6 traffic-engineering command is executed.
For more information about the segment-routing ipv6 traffic-engineering command, see SRv6 VPN commands in Segment Routing Command Reference. For more information about the sr-policy steering command, see SRv6 TE policy commands in Segment Routing Command Reference.
3. Enter BGP IPv4 unicast address family view.
4. Enable support for recursing unlabeled public-network BGP routes to LSPs or recursing public-network BGP routes to SRv6 TE policies.
unicast-route recursive-lookup tunnel [ prefix-list ipv4-prefix-list-name ] [ tunnel-policy tunnel-policy-name ]
The default settings are as follows:
¡ Unlabeled public-network BGP routes are recursed to IP next hops instead of tunnels.
¡ Public-network BGP routes with SRv6 SIDs cannot be recursed to SRv6 TE policies.
¡ Public-network BGP routes that have color community attributes rather than SRv6 SIDs can be recursed to SRv6 TE policies through color-based traffic steering.
3. Enter BGP IPv6 unicast address family view.
unicast-route recursive-lookup tunnel [ prefix-list ipv6-prefix-list-name ] [ tunnel-policy tunnel-policy-name ]
By default, BGP checks the next hop address of a route received from a directly connected EBGP peer or peer group. If the next hop address of the route does not belong to a directly connected network, BGP determines that the EBGP route is invalid and does not add it to the BGP routing table. BGP does not check the next hop addresses of routes received from indirectly EBGP peers or peer groups.
After you configure this feature, BGP will send route-refresh messages to the specified peer or peer group. After the peer or peer group resends routes to BGP, BGP will not check the next hop addresses of EBGP routes sent by the peer or peer group.
After you execute the undo peer ebgp-nexthop-check ignore command to remove the configuration of the peer ebgp-nexthop-check ignore command, BGP will check all routes received from the specified peer or peer group and remove those with invalid next hop addresses. Then, BGP will advertise the route updates to other peers and peer groups based on the route advertisement rules.
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
3. Disable BGP from checking the next hop addresses of EBGP routes received from the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } ebgp-nexthop-check ignore
By default, BGP checks the next hops of EBGP routes received from a peer or peer group.
Perform this task to dampen BGP peer flaps. Peer flap refers to the situation where the state of a peer frequently changes between up and down. After a BGP session is established between two peers, they need to exchange their entire BGP routing tables. If the BGP route tables contain a large number of routes and a peer flaps, the other peer needs to update route state information frequently, consuming a significant amount of resources. To avoid this issue, configure peer flap dampening. This feature saves CPU and bandwidth resources by reducing the number of BGP messages transmitted between peers.
If a BGP session is terminated after peer flap dampening is configured, the session that BGP re-establishes with the same peer will remain in Idle state for a period (idle time, in seconds). This mechanism avoids frequent BGP session flaps. BGP increases the idle time of the peer each time the peer session is re-established. The idle time equals 2^ [(IdleCount - 1)/3] x 32. The IdleCount argument represents the number of peer flaps (or peer disconnections). This calculation formula takes effect only if the IdleCount value is greater than 1.
NOTE: After a peer flaps for the first time, the idle time for that peer is two seconds. |
When the idle time for a peer reaches the maximum idle time specified by the peer flap-dampen command, it stops increasing. In this situation, the idle time for a peer is always the maximum idle time even if the IdleCount value keeps increasing. If the BGP session to the peer is not terminated for the period specified by using the min-established-time min-time option in the peer flap-dampen command, the idle time is reset to two seconds for the peer. In other situations, you can manually reset the idle time for a dampened peer to two seconds by using the reset bgp command.
Set a maximum idle time and a minimum established time based on your network condition, so they can achieve good peer flap dampening, ensuring successful BGP peer connections.
3. Configure flap dampening for a peer or peer group.
peer { group-name | ipv4-address | ipv6-address } flap-dampen [ max-idle-time max-time | min-established-time min-time ]*
By default, flap dampening is disabled for all peers and peer groups.
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet.
3. Set a DSCP value for outgoing BGP packets.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } dscp dscp-value
By default, the DSCP value for outgoing BGP packets is 48.
This feature flushes the suboptimal BGP route to the RIB when the following conditions are met:
· The optimal route is generated by the network command or is redistributed by the import-route command.
· The suboptimal route is received from a BGP peer.
After the suboptimal route is flushed to the RIB on a network, BGP immediately switches traffic to the suboptimal route when the optimal route fails.
For example, the device has a static route to the subnet 1.1.1.0/24 that has a higher priority than a BGP route. BGP redistributes the static route and receives a route to 1.1.1.0/24 from a peer. After the flush suboptimal-route command is executed, BGP flushes the received BGP route to the RIB as the suboptimal route. When the static route fails, BGP immediately switches traffic to the suboptimal route if inter-protocol FRR is enabled. For more information about inter-protocol FRR, see "Configuring basic IP routing."
3. Flush the suboptimal BGP route to the RIB.
By default, BGP is disabled from flushing the suboptimal BGP route to the RIB, and only the optimal route is flushed to the RIB.
Perform this task to enable BGP to not flush routes matching the specified routing policy to the routing table.
This feature applies to the following scenarios:
· In an MPLS L3VPN network, all the optimal private BGP routes will be flushed to the routing table of a PE by default. You can configure this feature to prevent unnecessary routes from being flushed to the IP routing table and improve the forwarding performance of the PE.
· In a route reflection network, configure this feature to not flush specific BGP routes to the routing table of the RR. Then, the RR only advertises and receives routes but does not forward service traffic, which saves the system resources of the RR.
3. Enable BGP to not flush routes matching the specified routing policy to the routing table.
routing-table bgp-rib-only [ route-policy route-policy-name ]
By default, BGP flushes the optimal routes to the routing table.
BGP supports the following label allocation modes:
· Per-prefix—Allocates a label to each route prefix.
· Per-next-hop—Allocates a label to each next hop. This mode is applicable when the number of labels required by the per-prefix mode exceeds the maximum number of labels supported by the device.
· Per-VPN-instance—Allocates a label to each VPN instance. This mode is applicable when the number of labels required by the per-next-hop mode exceeds the maximum number of labels supported by the device.
When you specify the per-prefix or per-next-hop label allocation mode, you can execute the vpn popgo command to specify the POPGO forwarding mode on an egress PE. The egress PE will pop the label for each packet and forward the packet out of the interface corresponding to the label.
When you specify the per-VPN instance label allocation mode, do not execute the vpn popgo command because it is mutually exclusive with the label-allocation-mode per-vrf command. The egress PE will pop the label for each packet and forward the packet through the FIB table.
The label-allocation-mode command takes effect only on BGP VPNv4, VPNv6, and EVPN routes generated from local private routes. It does not take effect when the local device forwards BGP VPNv4, VPNv6, and EVPN routes received from remote BGP peers.
3. Specify a label allocation mode.
label-allocation-mode { per-prefix | per-vrf }
By default, BGP allocates labels on a per-next-hop basis.
CAUTION: A change to the label allocation mode enables BGP to re-advertise all routes, which will cause service interruption. Use this command with caution. |
3. Disable optimal route selection for labeled routes without tunnel information.
labeled-route ignore-no-tunnel
By default, labeled routes without tunnel information can participate in optimal route selection.
As shown in Figure 52, an MPLS LSP is deployed between the PE and Device A on the public network. The PE and Device A establish an IBGP IPv4 unicast session and exchange unlabeled BGP IPv4 unicast routes with each other. Device A and Device B establish a BGP session and exchange labeled BGP IPv4 unicast routes with each other.
By default, Device A cannot forward packets destined for PE-attached users through the public-network LSP, because the public-network LSP cannot be selected as the recursive route as any unlabeled BGP IPv4 route. When Device B requires forwarding packets to PE-attached users through only labeled forwarding paths, you can configure this feature to meet the requirement.
With this feature configured, BGP can iterate unlabeled BGP IPv4 unicast routes to public-network MPLS LSPs that the local device has established. The device can convert unlabeled BGP IPv4 unicast routes into labeled routes and advertise them to its BGP peers.
As shown in Figure 52, this feature ensures that packets can be forwarded from Device B to PE-attached users through only labeled forwarding paths as follows:
2. After learning an unlabeled BGP IPv4 unicast route from the PE, Device A can perform the following operations:
¡ Iterates the route to the public-network LSP between Device A and the PE.
¡ Converts the route into a labeled route and advertises the labeled route to Device B.
3. After receiving the labeled route, Device B encapsulates labels into packets destined for PE-attached users, and then forwards the encapsulated packets to Device A through the related labeled forwarding path.
4. When Device A receives those packets, it switches their labels to the public network label, and then forwards them to the PE through the public-network LSP.
To have BGP convert unlabeled BGP IPv4 unicast routes into labeled routes after executing the unicast-route label advertise command, you must perform the following operations:
· Execute the peer label-route-capability command to enable labeled-route capabilities on both devices that need to exchange labeled routes.
· Enable the device that advertises labeled routes to assign MPLS labels to BGP routes:
a. Create a routing policy.
b. In the view of a routing policy node, execute the apply mpls-label command to enable MPLS label assignment to BGP routes.
c. In BGP IPv4 address family view, execute the peer route-policy export command to apply the routing policy.
When no public-network MPLS LSPs are found for BGP IPv4 unicast routes after next hop recursion, use the unicast-route label advertise pop-go command to ensure normal packet forwarding. As shown in Figure 52, Device A might fail to iterate BGP IPv4 unicast routes to the public-network MPLS LSP between Device A and the PE. If the pop-go keyword is specified, Device A can pop the labels of packets destined for PE-attached users and perform IP address-based forwarding for those packets. If the pop-go keyword is not specified, Device A cannot continue to forward packets destined for PE-attached users after popping the labels of those packets.
This command cannot take effect if the label-allocation-mode per-vrf command is configured.
4. Enable BGP to convert unlabeled BGP IPv4 unicast routes into labeled routes.
unicast-route label advertise [ pop-go ]
By default, BGP cannot convert unlabeled BGP IPv4 unicast routes into labeled routes.
Configuring BGP POPGO
As shown in Figure 53, Device C has two static routes 10.1.1.0/24 and 10.1.1.0/30 with Device A and Device B as the next hops, respectively. Device C redistributes only route 10.1.1.0/24 to the BGP routing table, assigns a label to the route, and then advertises the route to Device D. A BGP LSP to 10.1.1.0/24 is established between Device C and Device D.
By default, Device C performs a FIB table lookup for packets destined to 10.1.1.0 through 10.1.1.3 from Device D after popping their BGP LSP labels. Device C will forward the packets to Device B through route 10.1.1.0/30, and Device A cannot receive these packets.
To address this issue, you can configure BGP POPGO on Device C. When advertising route 10.1.1.0/24 to Device D, Device C records the mapping between the assigned label and outgoing interface of the route in the ILM table. Upon receiving packets encapsulated with a label from BGP LSPs, Device C performs the following steps:
1. Looks up the ILM table for the outgoing interface based on the label value.
2. Pops the label, and then forwards the packets through the outgoing interface.
Figure 53 Network diagram for BGP POPGO
2. Enter BGP IPv4 unicast address family view or BGP IPv4 labeled unicast address family view.
3. Enable the egress node of a BGP LSP to forward packets based on the ILM table.
apply-label per-route pop-go
By default, the egress node of a BGP LSP forwards packets based on the FIB.
An MPLS local IFNET tunnel is automatically established between MP-EBGP peers. Only directly connected MP-EBGP peers are able to forward traffic through this tunnel.
For two indirectly connected MP-EBGP peers, traffic between them is interrupted upon failover to the MPLS local IFNET tunnel. To avoid this issue, you can disable BGP from establishing MPLS local IFNET tunnels to the specified EBGP peer or peer group.
Disabling MPLS local IFNET tunnel establishment deletes the MPLS local IFNET tunnels already established to the specified EBGP peer or peer group.
Disabling BGP from establishing MPLS local IFNET tunnels to directly connected EBGP peers and peer groups will cause traffic loss. Make sure you fully understand the impact before performing the operation.
3. Disable MPLS local IFNET tunnel establishment to the specified EBGP peer or peer group.
peer { group name | ipv4-address [ mask-length ] } mpls-local-ifnet disable
By default, MPLS local IFNET tunnel establishment is enabled. Two MP-EBGP peers automatically establish an MPLS local IFNET tunnel after they exchange labeled routes and VPNv4 routes.
As shown in Figure 54, PE 2 learns private routes of the site where CE 2 resides through BGP. CE 2 adds the RT attribute to a private route before advertising it to PE 2. ASBR 1 can filter the private routes based on RT attributes. By default, PE 2 replaces the RT attribute in a received private route with the local RT attribute before advertising the route. As a result, ASBR 1 cannot filter received VPNv4 routes based on the RT attribute added by CE 2 because the routes only contain the RT attribute added by PE 2.
To resolve this issue, configure this feature on the PE. Then, the PE appends the local RT attribute to a private route received from the CE instead of replacing the original RT attribute in the route.
If you have configured a routing policy and executed the apply extcommunity rt command without the additive keyword, the RT attribute specified in the routing policy takes effect.
2. Execute the following commands in sequence to enter BGP-VPN instance view:
3. Enable BGP to append the local RT attribute to the extended community attribute list of a received private route.
extcommunity vpn-target additive
By default, BGP uses the local RT attribute to replace the original RT attribute in a received private route.
Peer unreachability detection achieves fast route convergence by enabling BGP to discover link failures in a timely manner. With this feature enabled, BGP will disconnect from the specified peer or peer group if that peer or peer group is detected unreachable.
BGP considers a peer unreachable if one of the following conditions exists:
· BGP cannot find a route to that peer in the current routing table.
· BGP finds the route to that peer in the current routing table is a blackhole route.
As shown in Figure 55, Device A, Device B, and DeviceC are IGP neighbors. Device A and Device C are BGP peers. When a link failure occurs between Devices A and B after peer unreachability detection is enabled on Device A, the IGP immediately performs route convergence. As a result, Device A cannot find the IP route destined for Device C and thus terminates its BGP session with Device C without waiting for the hold timer to expire.
If you do not set the delay time of peer disconnection, BGP disconnects from the specified peer or peer group immediately if that peer or peer group is detected unreachable.
When you set the delay time of peer disconnection, follow these guidelines to improve network stability:
· To avoid BGP session flappings caused by unstable traffic, make sure the delay time of peer disconnection is longer than the convergence time of IGP routes.
· With peer unreachability detection enabled, the GR helper can detect whether the GR restarter is reachable. To ensure successful GR, make sure the delay time of peer disconnection is longer than the GR timer plus the extra timer to wait.
For more information about the GR timer and the extra timer to wait, see "Configuring BGP GR."
3. Enable peer unreachability detection for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tracking [ delay delay-time ]
By default, peer unreachability detection is disabled.
This command does not take effect if you enter a link-local address for the ipv6-address argument.
Some of the BGP commands need to identify private AS numbers when they are functioning. The enabling status of 4-byte private AS number capability affects the identification of private AS numbers as follows:
· If this capability is enabled, the device identifies AS numbers in the ranges of 64512 to 65535 and 4200000000 to 4294967295 as private AS numbers. When private-network devices that use 4-byte AS numbers exist on the network, enable this capability as a best practice.
· If this capability is disabled, the device identifies only AS numbers in the ranges of 64512 to 65535 as private AS numbers. When excessive BGP nodes are deployed on the public network and 4-byte AS numbers are in shortage, disable this capability as a best practice.
3. Enable the 4-byte private AS number capability.
private-4-byte-as enable
By default, the 4-byte private AS number capability is enabled.
Displaying 4-byte AS numbers in dotted notation
By default, a BGP display command uses decimal integer notation to represent 4-byte AS numbers. A 4-byte AS number in decimal integer notation tends to be long and not reader-friendly. To resolve this issue, perform this task to display AS numbers in dotted notation.
The dotted notation refers to a method of representing AS numbers in X.Y format. The value ranges for arguments X and Y are both 0 to 65535 (the values for X and Y cannot be both 0), and the value range for a dotted AS number is 0.1 to 65535.65535. To convert an AS number from dotted notation to decimal integer notation, use the following formula: integer= X x 65536 + Y. For example, if a dotted AS number is 2.1, its decimal integer notation is (2 x 65536 + 1 =131073).
After you perform this task, the AS path list can match only 4-byte AS numbers in dotted notation. To avoid route filtering failure, make sure that the AS path list used in a route filtering policy is configured to match 4-byte AS numbers in dotted notation.
This task does not take effect on the 4-byte AS numbers in the system configuration file.
2. Display 4-byte AS numbers in dotted notation.
as-notation dotted [ 4-octet-only ]
By default, 4-byte AS numbers are displayed in decimal integer notation.
Setting the maximum number of error UPDATE messages
By default, the device records error UPDATE messages upon receiving them. You can use records about error UPDATE messages for fast BGP session troubleshooting. If the number of recorded error UPDATE messages exceeds the upper limit, the overflowing records will overwrite the earliest records. To avoid this issue, use this feature to set an appropriate limit.
To view records about error UPDATE messages, use the display bgp update-packet record command. The maximum value of the Total number record field in the command output depends on the configuration of the update-packet record count command.
Recording error UPDATE messages consumes system resources. To ensure system performance, use the update-packet record count command to set an appropriate limit based on the service condition.
2. Enter BGP instance view.
3. Set the maximum number of error UPDATE messages that BGP can record in an address family.
update-packet record count count
By default, BGP can record up to 100 error UPDATE messages in an address family.
To disable BGP from recording error UPDATE messages, set the value for the count argument to 0.
Advertising user group ID information in BGP routes to a peer or peer group
As shown in Figure 56, BRAS A and BRAS B are deployed at a school. BRAS A provides access services for users in the family area and BRAS B provides access services for users in the teaching area.
Figure 56 Network deployed with BRASs
For security and management purposes, it is required to disable mutual access between users in the family area and those in the teaching area. Typically, QoS policies based on source and destination IP addresses are deployed to achieve access control. However, this method does not support IP-based deployment because access users in different areas are not stable. To resolve this issue, perform QoS policy deployment on a per-user group basis as follows:
Table 92 Add all users attached to the same BRAS into a user group.
Table 93 Deploy a QoS policy on the user group for user traffic filtering.
This mechanism ensures that the deployed QoS policy remains effective regardless of access user IP changes.
To achieve user group-based QoS policy deployment, the BRAS must obtain user group information for both the local network and the remote network. The peer advertise user-group-id command enables BGP to advertise user group information through peer sessions.
To facilitate user group information management, the device identifies user groups their user group IDs. After assigning an IP address to an online user, the BRAS generates a UNR for the user. Typically, to enable communication between users from different areas, the BRAS needs to advertise UNR information generated for local users to remote BRASs. The advertised UNR information directs the forwarding of packets from remote users to local users.
Upon UNR generation for a user, the BRAS adds the group ID related with that user into the UNR. The BRAS uses the user group ID attribute to carry user group ID information and advertises the user group ID attribute in a BGP route if the following conditions exist:
Table 94 The peer advertise user-group-id command is executed on the BRAS.
Table 95 The BRAS redistributes UNRs into BGP for advertisement.
After receiving the BGP route, the specified peer can determine the user group to which the remote user belongs, which facilitates user group-based QoS policy deployment.
In this example, users attached to BRAS A are added in to user group A and the user group ID is 2. Users attached to BRAS B are added in to user group B and the user group ID is 3. When BRAS A and BRAS B exchange UNR information with each other through BGP, they also advertises their local user group IDs. After they know each other's local user group ID, you can perform user group-based QoS policy deployment to prevent mutual access between the family area and the teaching area as follows:
· Deploy a QoS policy on BRAS A to prevent the traffic of user group A from reaching user group B.
· Deploy a QoS policy on BRAS B to prevent the traffic of user group B from reaching user group A.
Since the user group ID extended community attribute is a proprietary implementation of H3C, non-H3C devices might not be able to recognize it. To have non-H3C devices support the user group ID attribute, execute the extcommunity-type usergroup-id command to set the type value for the user group ID attribute to a value that non-H3C devices can recognize.
This feature does not take effect on non-UNR redistributed routes or redistributed UNRs that do not carry user group ID information.
Table 96 Enter system view.
Table 97 Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
Table 98 Enable BGP to advertise user group ID information to a peer or peer group in BGP routes.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise user-group-id
By default, BGP does not advertise user group ID information to any peers or peer groups in BGP routes.
In BGP IPv4 labeled unicast address family view and BGP-VPN IPv4 labeled unicast address family view, the ipv6-address [ prefix-length ] parameter is not supported.
Table 99 (Optional.) Return to BGP instance view.
¡ Execute the quit command once in BGP IPv4 unicast address family view or BGP IPv4 labeled unicast address family view.
¡ Execute the quit command twice in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv4 labeled unicast address family view.
Table 100 (Optional.) Specify the type value for the user group ID extended community attribute.
extcommunity-type usergroup-id type-value
By default, the type value is 83df for the user group ID extended community attribute.
Table 101 Enter system view.
Table 102 Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
Table 103 Enable BGP to advertise user group ID information to a peer or peer group in BGP routes.
Table 104 (Optional.) Return to BGP instance view.
¡ Execute the quit command once in BGP IPv6 unicast address family view.
¡ Execute the quit command twice in BGP-VPN IPv6 unicast address family view.
Table 105 (Optional.) Specify the type value for the user group ID extended community attribute.
Display and maintenance commands for BGP network tuning and optimization
Displaying BGP
Displaying BGP (IPv4 unicast address family)
Task |
Command |
Display ORF prefix information received by a peer. |
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] ipv4-address received prefix-list display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] ipv6-address received prefix-list |
Displaying BGP (IPv6 unicast address family)
Task |
Command |
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] ipv6-address received prefix-list display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] ipv4-address received prefix-list |
Displaying BGP (IPv4 multicast address family)
Task |
Command |
display bgp [ instance instance-name ] peer ipv4 multicast { ipv4-address | ipv6-address } received prefix-list |
Displaying BGP (IPv6 multicast address family)
Task |
Command |
display bgp [ instance instance-name ] peer ipv6 multicast { ipv4-address | ipv6-address } received prefix-list |
Resetting BGP sessions
CAUTION: A reset operation terminates BGP sessions for a short period of time. |
Execute reset commands in user view.
Task |
Command |
Reset all BGP sessions. |
reset bgp [ instance instance-name ] all |
Reset BGP sessions for IPv4 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for IPv6 unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] reset bgp ipv4-address [ mask-length ] ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for IPv4 labeled unicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 labeled-unicast [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for IPv4 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv4 multicast |
Reset BGP sessions for IPv6 multicast address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 multicast |
Displaying and maintaining records about error UPDATE messages
Execute display commands in any view and execute reset commands in user view.
Task |
Command |
Display records about error UPDATE messages. |
display bgp [ instance instance-name ] update-packet record [ vpn-instance vpn-instance-name ] [ peer { ipv4-address | ipv6-address } ] |
Clear records about error UPDATE messages. |
reset bgp [ instance instance-name ] update-packet record |
BGP network tuning and optimization configuration examples
Example: Configuring BGP load balancing
As shown in Figure 57, run EBGP between Router A and Router B, and between Router A and Router C. Run IBGP between Router B and Router C.
Configure load balancing over the two EBGP links on Router A.
Table 106 Configure IP addresses for interfaces. (Details not shown.)
Table 107 Configure BGP connections:
¡ On Router A, establish EBGP connections with Router B and Router C. Configure BGP to advertise network 8.1.1.0/24 to Router B and Router C. This allows Router B and Router C can access the internal network connected to Router A.
¡ On Router B, establish an EBGP connection with Router A and an IBGP connection with Router C. Configure BGP to advertise network 9.1.1.0/24 to Router A, so that Router A can access the intranet through Router B. Configure a static route to interface loopback 0 on Router C (or use a routing protocol like OSPF) to establish the IBGP connection.
¡ On Router C, establish an EBGP connection with Router A and an IBGP connection with Router B. Configure BGP to advertise network 9.1.1.0/24 to Router A, so that Router A can access the intranet through Router C. Configure a static route to interface loopback 0 on Router B (or use another protocol like OSPF) to establish the IBGP connection.
# Configure Router A.
[RouterA] bgp 65008
[RouterA-bgp-default] router-id 1.1.1.1
[RouterA-bgp-default] peer 3.1.1.1 as-number 65009
[RouterA-bgp-default] peer 3.1.2.1 as-number 65009
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 3.1.1.1 enable
[RouterA-bgp-default-ipv4] peer 3.1.2.1 enable
[RouterA-bgp-default-ipv4] network 8.1.1.0 24
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
# Configure Router B.
<RouterB> system-view
[RouterB] bgp 65009
[RouterB-bgp-default] router-id 2.2.2.2
[RouterB-bgp-default] peer 3.1.1.2 as-number 65008
[RouterB-bgp-default] peer 3.3.3.3 as-number 65009
[RouterB-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 3.1.1.2 enable
[RouterB-bgp-default-ipv4] peer 3.3.3.3 enable
[RouterB-bgp-default-ipv4] network 9.1.1.0 24
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
[RouterB] ip route-static 3.3.3.3 32 9.1.1.2
# Configure Router C.
<RouterC> system-view
[RouterC] bgp 65009
[RouterC-bgp-default] router-id 3.3.3.3
[RouterC-bgp-default] peer 3.1.2.2 as-number 65008
[RouterC-bgp-default] peer 2.2.2.2 as-number 65009
[RouterC-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 3.1.2.2 enable
[RouterC-bgp-default-ipv4] peer 2.2.2.2 enable
[RouterC-bgp-default-ipv4] network 9.1.1.0 24
[RouterC-bgp-default-ipv4] quit
[RouterC-bgp-default] quit
[RouterC] ip route-static 2.2.2.2 32 9.1.1.1
# Display the BGP routing table on Router A.
[RouterA] display bgp routing-table ipv4
Total number of routes: 3
Status codes: * - valid, > - best, d - dampened, h - history
a - additional-path
* > 8.1.1.0/24 8.1.1.1 0 32768 i
* >e 9.1.1.0/24 3.1.1.1 0 0 65009i
* e 3.1.2.1 0 0 65009i
¡ The output shows two valid routes to destination 9.1.1.0/24. The route with next hop 3.1.1.1 is marked with a greater-than sign (>), indicating that it is the optimal route. The route with next hop 3.1.2.1 is marked with an asterisk (*), indicating that it is a valid route, but not the optimal route.
¡ By using the display ip routing-table command, you can find there is only one route to 9.1.1.0/24 with next hop 3.1.1.1 and output interface Ten-GigabitEthernet 0/0/16.
Table 108 On Router A, configure the maximum number of ECMP routes destined for AS 65009 as 2 to improve link usage.
[RouterA] bgp 65008
[RouterA-bgp-default-ipv4] balance 2
a - additional-path
* >e 3.1.2.1 0 0 65009i
· The output shows that there are two valid routes to the destination 9.1.1.0/24, and both of them are the optimal routes.
· By using the display ip routing-table command, you can find there are two routes to 9.1.1.0/24. One has next hop 3.1.1.1 and output interface Ten-GigabitEthernet 0/0/16, and the other has next hop 3.1.2.1 and output interface Ten-GigabitEthernet 0/0/17.
Example: Configuring the BGP Additional Paths feature
As shown in Figure 58, all routers run BGP. EBGP runs between Router A and Router B, and between Router A and Router C. IBGP runs between Router B and Router D, between Router C and Router D, and between Router D and Router E. Router D is a route reflector and Router E is its client.
Configure the BGP Additional Paths feature to enable Router E to learn routes with the same prefix and different next hops from Router B and Router C.
2. Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
XGE0/0/15 |
10.1.1.1/24 |
Router D |
XGE0/0/15 |
30.1.1.1/24 |
XGE0/0/16 |
20.1.1.1/24 |
XGE0/0/16 |
40.1.1.1/24 |
Router B |
XGE0/0/15 |
10.1.1.2/24 |
XGE0/0/17 |
50.1.1.1/24 |
XGE0/0/16 |
30.1.1.2/24 |
Router E |
XGE0/0/15 |
50.1.1.2/24 |
Router C |
XGE0/0/15 |
20.1.1.2/24 |
XGE0/0/16 |
40.1.1.2/24 |
Table 109 Configure IP addresses for interfaces. (Details not shown.)
Table 110 Configure BGP connections:
[RouterA] bgp 10
[RouterA-bgp-default] peer 10.1.1.2 as-number 20
[RouterA-bgp-default] peer 20.1.1.2 as-number 20
[RouterA-bgp-default-ipv4] peer 10.1.1.2 enable
[RouterA-bgp-default-ipv4] peer 20.1.1.2 enable
[RouterB] bgp 20
[RouterB-bgp-default] peer 10.1.1.1 as-number 10
[RouterB-bgp-default] peer 30.1.1.1 as-number 20
[RouterB-bgp-default-ipv4] peer 10.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 30.1.1.1 enable
[RouterC] bgp 20
[RouterC-bgp-default] peer 20.1.1.1 as-number 10
[RouterC-bgp-default] peer 40.1.1.1 as-number 20
[RouterC-bgp-default-ipv4] peer 20.1.1.1 enable
[RouterC-bgp-default-ipv4] peer 40.1.1.1 enable
# Configure Router D.
<RouterD> system-view
[RouterD] bgp 20
[RouterD-bgp-default] peer 30.1.1.2 as-number 20
[RouterD-bgp-default] peer 40.1.1.2 as-number 20
[RouterD-bgp-default] peer 50.1.1.2 as-number 20
[RouterD-bgp-default] address-family ipv4 unicast
[RouterD-bgp-default-ipv4] peer 30.1.1.2 enable
[RouterD-bgp-default-ipv4] peer 40.1.1.2 enable
[RouterD-bgp-default-ipv4] peer 50.1.1.2 enable
# Configure Router E.
<RouterE> system-view
[RouterE] bgp 20
[RouterE-bgp-default] peer 50.1.1.1 as-number 20
[RouterE-bgp-default] address-family ipv4 unicast
[RouterE-bgp-default-ipv4] peer 50.1.1.1 enable
Table 111 Configure Router A to advertise network 10.1.1.0/24.
[RouterA-bgp-default-ipv4] network 10.1.1.0 24
Table 112 Set the local router as the next hop for routes sent to a peer:
[RouterB-bgp-default-ipv4] peer 30.1.1.1 next-hop-local
[RouterC-bgp-default-ipv4] peer 40.1.1.1 next-hop-local
Table 113 Configure Router D as a route reflector.
[RouterD-bgp-default-ipv4] peer 50.1.1.2 reflect-client
Table 114 Configure the Additional Paths feature:
# Enable the additional path sending capability on Router D.
[RouterD-bgp-default-ipv4] peer 50.1.1.2 additional-paths send
# Set the maximum number to 2 for Add-Path optimal routes that can be advertised.
[RouterD-bgp-default-ipv4] additional-paths select-best 2
# Set the maximum number to 2 for Add-Path optimal routes that can be advertised to peer 50.1.1.2.
[RouterD-bgp-default-ipv4] peer 50.1.1.2 advertise additional-paths best 2
# Enable the additional path receiving capability on Router E.
[RouterE-bgp-default-ipv4] peer 50.1.1.1 additional-paths receive
# Display BGP routing information on Router E.
[Router E] display bgp routing-table ipv4
Total number of routes: 2
BGP local router ID is 50.1.1.2
a - additional-path
i 10.1.1.0/24 30.1.1.2 0 100 0 10i
i 40.1.1.2 0 100 0 10i
The output shows that Router D has learned two routes with the same prefix and different next hops.
Example: Configuring prefix-based BGP ORF
As shown in Figure 59, AS 100 and AS 200 can exchange BGP routes. To ensure network security and optimize network performance, devices in AS 100 and AS 200 need to filter routes before route advertisement. The routes required by Router A frequently change. Configure prefix-based BGP ORF on both Router A and Router C, so Router C sends only routes matching Router A's route reception policy to Router A.
Table 115 Configure IP addresses for interfaces. (Details not shown.)
Table 116 Configure BGP connections:
¡ On Router A, establish an IBGP connection with Router B and an EBGP connection with Router C.
¡ On Router C, establish an IBGP connection with Router D and Router E separately.
[RouterA] bgp 100
[RouterA-bgp-default] peer 10.1.1.2 as-number 200
[RouterA-bgp-default] peer 10.2.1.2 as-number 100
[RouterA-bgp-default-ipv4] peer 10.2.1.2 enable
[RouterA-bgp-default-ipv4] import-route direct
[RouterB] bgp 100
[RouterB-bgp-default] peer 10.2.1.1 as-number 100
[RouterB-bgp-default-ipv4] peer 10.2.1.1 enable
[RouterC] bgp 200
[RouterC-bgp-default] peer 10.1.1.1 as-number 100
[RouterC-bgp-default] peer 10.4.1.1 as-number 200
[RouterC-bgp-default] peer 10.5.1.1 as-number 200
[RouterC-bgp-default-ipv4] peer 10.1.1.1 enable
[RouterC-bgp-default-ipv4] peer 10.4.1.1 enable
[RouterC-bgp-default-ipv4] peer 10.5.1.1 enable
[RouterC-bgp-default-ipv4] import-route direct
[RouterD] bgp 200
[RouterD-bgp-default] router-id 4.4.4.4
[RouterD-bgp-default] peer 10.4.1.2 as-number 200
[RouterD-bgp-default-ipv4] peer 10.4.1.2 enable
[RouterD-bgp-default-ipv4] quit
[RouterD-bgp-default] quit
[RouterE] bgp 200
[RouterE-bgp-default] router-id 5.5.5.5
[RouterE-bgp-default] peer 10.5.1.2 as-number 200
[RouterE-bgp-default-ipv4] peer 10.5.1.2 enable
[RouterE-bgp-default-ipv4] quit
[RouterE-bgp-default] quit
Table 117 On Router A, reference an address prefix list to filter BGP routes received from Router C.
[RouterA] ip refix-list policy1 permit 10.4.1.0 24 less-equal 32
[RouterA] bgp 100
[RouterA-bgp-default-ipv4] peer 10.1.1.2 prefix-list policy1 import
# On Router C, view the routes advertised to Router A.
[RouterC] display bgp routing-table ipv4 unicast peer 10.1.1.1 advertised-routes
Total number of routes: 4
a – additional-path
Network NextHop MED LocPrf Path/Ogn
* > 3.3.3.3/32 127.0.0.1 0 200?
* > 10.1.1.0/24 10.1.1.2 0 200?
* > 10.4.1.0/24 10.4.1.2 0 200?
* > 10.5.1.0/24 10.5.1.2 0 200?
# On Router A, view the routes received to Router C.
[RouterA] display bgp routing-table ipv4 unicast peer 10.1.1.2 received-routes
Total number of routes: 1
a – additional-path
* >e 10.4.1.0/24 10.1.1.2 0 0 ?
According to the above command outputs, Router C has advertised four routes to Router A, but Router A only received one of them under the restriction of its BGP route reception policy.
Table 118 Configure prefix-based BGP ORF.
# On Router A, enable prefix-based BGP ORF capabilities negotiation for Router C.
[RouterA] bgp 100
[RouterA-bgp-default-ipv4] peer 10.1.1.2 capability-advertise orf prefix-list both
# On Router C, enable prefix-based BGP ORF capabilities negotiation for Router A.
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] peer 10.1.1.1 capability-advertise orf prefix-list both
# On Router C, view address prefix list information in the ORF information received from Router A.
[RouterC] display bgp peer ipv4 10.1.1.1 received prefix-list
ORF prefix list entries: 2
ge: greater-equal le: less-equal
Index Rule Prefix Ge Le
10 permit 10.4.1.0/24 0 32
a – additional-path
According to the above command outputs, Router C only advertised the route matching Router A's route reception policy to Router A.
Configuring BGP security features
BGP security feature configuration tasks at a glance
To configure BGP security features, perform the following tasks:
· Enabling MD5 authentication for BGP peers
· Enabling keychain authentication for BGP peers
· Configuring IPsec for IPv6 BGP
MD5 authentication provides the following benefits:
· Peer authentication ensures that only BGP peers that have the same password can establish TCP connections.
· Integrity check ensures that BGP packets exchanged between peers are intact.
Procedure (IPv4 peers)
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Enter BGP-VPN instance view.
3. Enable MD5 authentication for a BGP peer group or peer.
peer { group-name | ipv4-address [ mask-length ] } password { cipher | simple } password
By default, MD5 authentication is disabled.
Procedure (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } password { cipher | simple } password
Configuring GTSM for BGP
The Generalized TTL Security Mechanism (GTSM) protects a BGP session by comparing the TTL value in the IP header of incoming BGP packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the BGP packets sent by the device have a TTL of 255.
GTSM provides best protection for directly connected EBGP sessions, but not for multihop EBGP or IBGP sessions because the TTL of packets might be modified by intermediate devices.
When GTSM is configured, the local device can establish an EBGP session to the peer after both devices pass GTSM check, regardless of whether the maximum number of hops is reached.
To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
Editing the value for the hop-count argument clears statistics about the packets dropped by GTSM.
3. Configure GTSM for the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ttl-security hops hop-count
By default, GTSM is disabled.
peer { group-name | ipv6-address [ prefix-length ] } ttl-security hops hop-count
Keychain authentication enhances the security of BGP in the following ways:
· BGP peers can establish TCP connections only when they use the same key for keychain authentication.
· The keys used by the BGP peers at the same time must have the same ID.
· The keys with the same ID must use the same authentication algorithm and key string.
For more information about keychains, see keychain configuration in Security Configuration Guide.
Follow these restrictions and guidelines when you configure the algorithm and key ID in keychain authentication:
· BGP supports the HMAC-MD5, MD5, HMAC-SHA-256, HMAC-SM3, and SM3 algorithms. To configure an algorithm, execute the authentication-algorithm command.
· BGP supports key IDs in the range of 0 to 63. To configure a key ID, execute the key command.
3. Enable keychain authentication for a BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } keychain keychain-name
By default, keychain authentication is disabled.
peer { group-name | ipv6-address [ prefix-length ] } keychain keychain-name
Perform this task to configure IPsec for IPv6 BGP. IPsec can protect IPv6 BGP packets from data eavesdropping, tampering, and attacks caused by forged IPv6 BGP packets.
When two IPv6 BGP peers are configured with IPsec (for example, Device A and Device B), Device A encapsulates an IPv6 BGP packet with IPsec before sending it to Device B. If Device B successfully receives and de-encapsulates the packet, it establishes an IPv6 BGP peer relationship with Device A and learns IPv6 BGP routes from Device A. If Device B receives but fails to de-encapsulate the packet, or receives a packet not protected by IPsec, it discards the packet.
2. Configure an IPsec transform set and a manual IPsec profile.
For more information about this task, see Security Configuration Guide.
3. Enter BGP instance view or BGP-VPN instance view.
4. Apply the IPsec profile to an IPv6 BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } ipsec-profile profile-name
By default, no IPsec profile is configured for any IPv6 BGP peer or peer group.
This command supports only IPsec profiles in manual mode.
Configuring BGP RPKI
About BGP RPKI
About RPKI
The AS_PATH attribute identifies the ASs through which a route has passed, and the AS that originated the route is the origin AS of the route. If the origin AS number of a route is incorrect, traffic transmission failure or even network collapse might occur.
To avoid this problem, you can configure the BGP Resource Public Key Infrastructure (RPKI) feature. It enables BGP to validate the origin AS of a route and determine whether to use and advertise the route based on the validation state.
BGP RPKI can address the issue of traffic hijacking. For example, an ISP advertises a legitimate route with a prefix of 192.168.0.0/16 to its users, and an attacker advertises a route with a prefix of 192.168.10.0/24. After receiving the two routes, a user prefers route 192.168.10.0/24 during route selection, because this route is more specific. As a result, the user might send traffic to the attacker mistakenly. To avoid this issue, configure BGP RPKI.
About ROAs
Route Origin Authorization (ROA) is a digital certificate that binds a route prefix to an origin AS number. With ROAs, the device can verify the validity of a route based on its origin AS number.
As shown in Figure 60, Device A and the RPKI server are connected. The RPKI server downloads ROA information from the RPKI database and sends the downloaded ROAs to Device A. Device A then stores the received ROAs in its local ROA database. Upon receiving a route, Device A searches the local ROA database for an ROA that matches the route prefix. If such an ROA exists, Device A compares the origin AS number of the route with that of the matching ROA.
· If the two AS numbers are the same, the route is valid.
· If the two AS numbers are different, the route is invalid.
In this example, Device A determines that route 10.1.1.0/24 from Device B is valid and route 10.1.1.0/24 from Device C is invalid.
Figure 60 Route validation with ROAs
Configuring RPKI connection parameters
A router establishes a TCP connection with an RPKI server to obtain the Route Origin Authorization (ROA) information used for RPKI validation. The router checks the connection to the RPKI server at the specified interval. If the router does not receive a response from the RPKI server within the specified time period, it terminates the connection to the RPKI server.
When the connection between a router and an RPKI server goes down (except when the shutdown command is executed), the router takes the following actions:
· Attempts to reconnect to the server.
· Places the ROA information obtained from the server in aging state, and starts the aging timer for the ROA information.
If the router reconnects to the server before the aging timer expires, it releases the ROA information from the aging state. If the router fails to reconnect to the server when the aging timer expires, it deletes the ROA information obtained from the server.
You can set the maximum number of ROAs that can be received from an RPKI server to save the system resources of the device.
Follow these restrictions and guidelines when you configure RPKI connection parameters:
· As a best practice, set an ROA information aging time longer than the time to wait for the response from the RPKI server.
· To tear down the connection to an RPKI server, execute the undo port command in RPKI server view.
· If you execute the undo rpki command, all configurations in RPKI view are removed.
3. Enable BGP RPKI and enter BGP RPKI view.
rpki
4. Specify an RPKI server by its IP address and enter RPKI server view.
server [ vpn-instance vpn-instance-name ] tcp { ipv4-address | ipv6-address }
By default, no RPKI server is specified.
5. Specify the port number of the RPKI server.
port port-number
By default, the port number of the RPKI server is not specified.
To enable a router to establish a TCP connection with the RPKI server, you must configure the port number of the RPKI server on the router.
6. (Optional.) Specify the MD5 authentication password.
passwords { cipher | simple } string
By default, the RPKI server does not perform MD5 authentication.
The MD5 authentication password must be the same as the authentication password configured on the RPKI server.
MD5 authentication ensures the validity of the RPKI server and the security of BGP RPKI packets.
7. (Optional.) Set the RPKI connection check interval.
refresh-time refresh-time
By default, the RPKI connection check interval is 600 seconds.
8. (Optional.) Set the time to wait for the response from the RPKI server.
response-time response-time
By default, the time to wait for the response from the RPKI server is 30 seconds.
9. (Optional.) Set the aging time for the ROA information.
purge-time purge-time
By default, the aging time for the ROA information is 60 seconds.
10. (Optional.) Set the maximum number of ROAs that can be received from the RPKI server.
rpki-limit limit [ alert-only | discard | reconnect reconnect-time ]
By default, the number of ROAs that can be received from an RPKI server is not limited.
Enabling BGP RPKI validation
After you configure this feature, BGP validates the prefix and origin AS number of a received route. BGP determines the validation state of the route based on the following requirements:
1. A minimum of one ROA contains the prefix.
2. The mask length of the route does not exceed the longest mask length among all ROAs.
3. The AS number of an ROA is the same as the origin AS number of the route.
If the route meets all requirements, the route is in Valid state. If the route cannot meet requirement 1, the route is in Not-found state. If the route meets requirement 1, but cannot meet requirement 2 or 3, the route is in Invalid state.
If you configure this feature, BGP uses the local RPKI validation states. If you do not configure this feature, BGP uses the validation states in the received BGP routes.
3. Enter BGP RPKI view.
rpki
4. Enable BGP RPKI validation.
check-origin-validation
By default, BGP RPKI validation is disabled.
Applying the BGP RPKI validation state to optimal route selection
If multiple routes to the same destination are available, BGP first discards routes with unreachable next hops, and then selects the optimal route according to the following rules:
· Routes with a BGP RPKI validation state of Valid takes precedence over routes with a validation state of Not-found or Invalid.
· Routes with a BGP RPKI validation state of Not-found takes precedence over routes with a validation state of Invalid.
· Routes without a BGP RPKI validation state have the same priority as routes with a BGP RPKI validation state of Not-found.
· For routes that have the same BGP RPKI validation state, BGP selects the optimal route according to the rules in "BGP route selection."
You can configure a routing policy to filter routes based on the BGP RPKI validation state. For more information about routing policies, see "Configuring routing policies."
3. Apply the BGP RPKI validation state to optimal route selection.
bestroute origin-as-validation [ allow-invalid ]
By default, BGP ignores the BGP RPKI validation state during optimal route selection.
To allow routes with a validation state of Invalid to participate in optimal route selection, you must specify the allow-invalid keyword.
2. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
Advertising BGP RPKI validation state to a peer or peer group
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. To enable this feature, you must first enable BGP to advertise the extended community attribute to the peer or peer group and make sure RPKI settings are correct.
In the current software version, BGP can advertise the BGP RPKI validation state only to IBGP peers and peer groups.
3. Advertise the extended community attribute to a peer or peer group.
By default, BGP does not advertise the extended community attribute.
4. Advertise the BGP RPKI validation state to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state.
Resetting BGP RPKI sessions
Execute the command in user view.
reset bgp [ instance instance-name ] rpki server [ vpn-instance vpn-instance-name ] tcp { ipv4 address | ipv6 address }
CAUTION: After you execute this command, the device will delete and re-establish the specified BGP RPKI session and cause temporary session interruption. |
Display and maintenance commands for BGP security features
Displaying BGP security features
Displaying BGP RPKI (IPv4 unicast address family)
Task |
Command |
Display information about connections to RPKI servers. |
display bgp [ instance instance-name ] rpki server [ [ vpn-instance vpn-instance-name ] ipv4-address ] |
Display the ROA information obtained from RPKI servers. |
display bgp [ instance instance-name ] rpki table ipv4 [ ipv4-address min min-length max max-length ] |
Displaying BGP RPKI (IPv6 unicast address family)
Task |
Command |
display bgp [ instance instance-name ] rpki server [ [ vpn-instance vpn-instance-name ] ipv6-address ] |
display bgp [ instance instance-name ] rpki table ipv6 [ ipv6-address min min-length max max-length |
Displaying BGP GTSM
Task |
Command |
Display statistics information about packets discarded by GTSM. |
In standalone mode: display ttl-security statistics [ slot slot-number ] In IRF mode: display ttl-security statistics [ chassis chassis-number slot slot-number ] |
Displaying FC-BGP
Task |
Command |
Display FC-BGP information. |
display bgp [ instance instance-name ] forwarding-commitment { connection | binding-message [ ipv4-address | ipv6-address | brief ] | public-key } |
Clearing BGP security feature information
Task |
Command |
Clear statistics information about packets discarded by GTSM. |
In standalone mode: reset ttl-security statistics [ slot slot-number ] In IRF mode: reset ttl-security statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
IPv4 BGP security feature configuration examples
Example: Configuring BGP RPKI
As shown in Figure 61, all routers run BGP. Establish a TCP connection between Router A and the RPKI server, and establish an IBGP connection between Router A and Router B.
Configure Router A to advertise the BGP RPKI validation state to Router B, and configure a routing policy to filter routes based on the validation state for Router B.
Table 119 Configure IP addresses for interfaces and establish an IBGP connection between Router A and Router B. (Details not shown.)
Table 120 Configure Router A to establish a TCP connection to the RPKI server.
[RouterA] bgp 100
[RouterA-bgp-default] rpki
[RouterA-bgp-default-rpki] server tcp 1.1.1.2
[RouterA-bgp-default-rpki-server] port 1234
[RouterA-bgp-default-rpki-server] quit
Table 121 Enable BGP RPKI validation on Router A.
[RouterA-bgp-default-rpki] check-origin-validation
[RouterA-bgp-default-rpki] quit
Table 122 Apply the BGP RPKI validation state to optimal route selection.
[RouterA-bgp-default-ipv4] bestroute origin-as-validation
Table 123 Configure Router A to advertise the BGP RPKI validation state to peer 1.2.3.2.
[RouterA-bgp-default-ipv4] peer 1.2.3.2 advertise-ext-community
[RouterA-bgp-default-ipv4] peer 1.2.3.2 advertise origin-as-validation
Table 124 Configure Router B to permit routes with a BGP RPKI validation state of Valid.
# Configure a routing policy.
[RouterB] route-policy rpki_policy permit node 0
[RouterB-route-policy-rpki_policy-0] if-match rpki valid
[RouterB-route-policy-rpki_policy-0] quit
# Apply the routing policy.
[RouterB] bgp 100
[RouterB-bgp-default-ipv4] peer 1.2.3.1 route-policy rpki_policy import
# Display information about the connection between Router A and the RPKI server.
[RouterA] display bgp rpki server
Server VPN-index Port State Time ROAs(IPv4/IPv6)
1.1.1.2 0 1234 Establish 00:04:43 5/4
The output shows that Router A has established a TCP connection to the RPKI server.
# Display the ROA information on Router A.
[RouterA] display bgp rpki table ipv4
Total number of entries: 5
Status codes: S - stale, U - used
Network Mask-range Origin-AS Server Status
1.2.3.4 8-24 100 1.1.1.2 U
2.2.3.6 8-32 100 1.1.1.2 U
2.2.3.6 10-24 4294967295 1.1.1.2 U
2.2.3.9 20-24 4294967295 1.1.1.2 U
3.2.3.5 8-26 200 1.1.1.2 U
The output shows that Router A has obtained the ROA information from the RPKI server.
# Display the BGP RPKI validation state on Router A.
[RouterA] display bgp routing-table ipv4 1.2.3.0
BGP local router ID: 2.2.2.2
Local AS number: 100
Paths: 1 available, 1 best
BGP routing table information of 1.2.3.0/24:
Imported route.
Original nexthop: 0.0.0.0
Out interface : Ten-GigabitEthernet0/0/15
Route age : 01h28m30s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
Org-validation : Valid
AS-path : (null)
Origin : incomplete
Attribute value : MED 0, pref-val 32768
State : valid, local, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
The route to 1.2.3.0 matches the ROA with a prefix of 1.2.3.4, a mask length range of 8 to 24, and an origin AS number of 100. Therefore, the BGP RPKI validation state of the route to 1.2.3.0 is Valid.
# On Router B, display detailed information about the BGP IPv4 unicast route to 1.2.3.0.
[RouterB] display bgp routing-table ipv4 1.2.3.0
RR-client route.
Rely nexthop : 1.2.3.1
Original nexthop: 1.2.3.1
Route age : 01h28m33s
OutLabel : NULL
Ext-Community : <Origin Valid State: Valid >
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
State : valid, internal, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
The output displays information about the BGP IPv4 unicast route to 1.2.3.0 because Router B permits routes with a BGP RPKI validation state of Valid.
Example: Configuring BGP keychain authentication
Configure keychain authentication to better protect the BGP connection between Router A and Router B.
Table 125 Configure IP addresses for interfaces. (Details not shown.)
Table 126 Configure EBGP connections.
[RouterA] bgp 100
[RouterB] bgp 200
[RouterB-bgp-default] peer 10.1.1.1 as-number 100
Table 127 Configure basic keychain authentication settings.
[RouterA] keychain abc mode absolute
[RouterA-keychain-abc] key 1
[RouterA-keychain-abc-key-1] authentication-algorithm hmac-md5
[RouterA-keychain-abc-key-1] key-string plain pwd123
[RouterA-keychain-abc-key-1] send-lifetime utc 11:00:00 2023/01/01 to 12:00:00 2023/12/30
[RouterA-keychain-abc-key-1] accept-lifetime utc 11:00:00 2023/01/01 to 12:00:00 2023/12/30
[RouterA-keychain-abc-key-1] quit
[RouterA-keychain-abc] quit
[RouterB] keychain abc mode absolute
[RouterB-keychain-abc] key 1
[RouterB-keychain-abc-key-1] authentication-algorithm hmac-md5
[RouterB-keychain-abc-key-1] key-string plain pwd123
[RouterB-keychain-abc-key-1] send-lifetime utc 11:00:00 2023/01/01 to 12:00:00 2023/12/30
[RouterB-keychain-abc-key-1] accept-lifetime utc 11:00:00 2023/01/01 to 12:00:00 2023/12/30
[RouterB-keychain-abc-key-1] quit
[RouterB-keychain-abc] quit
Table 128 Configure BGP keychain authentication settings.
[RouterA] bgp 100
[RouterA-bgp-default] peer 10.1.1.2 keychain abc
[RouterB] bgp 200
[RouterB-bgp-default] peer 10.1.1.1 keychain abc
# View IPv4 unicast peer information on Router A.
[RouterA] display bgp peer ipv4 unicast
BGP local router ID: 10.1.1.1
Total number of peers: 1 Peers in established state: 1
* - Dynamically created peer
10.1.1.2 200 13 16 0 0 00:10:34 Established
The output shows that Router A and Router B has passed keychain authentication and established a BGP session.
Example: Configuring BGP GTSM
As shown in Figure 63, Router A is located in AS 100, and Routers B, C, and D are in AS 200. They all run BGP. Router A and Router B are EBGP peers, and Routers B, C, and D are IBGP peers. Configure BGP GTSM to protect all devices from CPU utilization-type packet attacks.
Table 129 Configure IP addresses for interfaces. (Details not shown.)
Table 130 Configure OSPF to ensure the loopback interfaces of Router B, Router C, and Router D are reachable.
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[RouterB-ospf-1] quit
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 10.3.1.0 0.0.0.255
[RouterC-ospf-1] quit
[RouterD] ospf 1
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 10.3.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
Table 131 Configure IBGP connections in a full-mesh manner.
To avoid route flaps caused by unstable port states, this example uses loopback interfaces for IBGP peer session establishment.
[RouterB] bgp 200
[RouterB-bgp-default] peer 4.4.4.4 as-number 65009
[RouterB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterB-bgp-default-ipv4] peer 4.4.4.4 enable
[RouterB-bgp-default-ipv4] peer 3.3.3.3 next-hop-local
[RouterB-bgp-default-ipv4] peer 4.4.4.4 next-hop-local
[RouterC] bgp 200
[RouterC-bgp-default] peer 4.4.4.4 as-number 65009
[RouterC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[RouterC-bgp-default-ipv4] peer 4.4.4.4 enable
[RouterD] bgp 200
[RouterD-bgp-default] peer 3.3.3.3 as-number 65009
[RouterD-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[RouterD-bgp-default] peer 2.2.2.2 as-number 65009
[RouterD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[RouterD-bgp-default-ipv4] peer 3.3.3.3 enable
[RouterD-bgp-default-ipv4] peer 2.2.2.2 enable
Table 132 Configure EBGP connections.
<RouterA>
[RouterA] bgp 100
[RouterB] bgp 200
Table 133 Configure BGP GTSM.
# Configure BGP GTSM between Router A and Router B. The maximum number of hops to each other is 1 and the valid TTL range is [255,255], because the two devices are directly connected.
[RouterA] bgp 100
[RouterA-bgp-default] peer 10.1.1.2 ttl-security hops 1
[RouterB] bgp 200
[RouterB-bgp-default] peer 10.1.1.1 ttl-security hops 1
# Configure BGP GTSM between Router B and Router C. The maximum number of hops to each other is 1 and the valid TTL range is [255,255], because the two devices are directly connected.
[RouterC] bgp 200
[RouterC-bgp-default] peer 2.2.2.2 ttl-security hops 1
[RouterB-bgp-default] peer 3.3.3.3 ttl-security hops 1
# Configure BGP GTSM between Router C and Router D. The maximum number of hops to each other is 1 and the valid TTL range is [255,255], because the two devices are directly connected.
[RouterD] bgp 200
[RouterD-bgp-default] peer 3.3.3.3 ttl-security hops 1
[RouterC-bgp-default] peer 4.4.4.4 ttl-security hops 1
# Configure BGP GTSM between Router B and Router D. The maximum number of hops to each other is 2 and the valid TTL range is [254,255], because the two devices are indirectly connected via an intermediate device.
[RouterB-bgp-default] peer 4.4.4.4 ttl-security hops 2
[RouterD-bgp-default] peer 2.2.2.2 ttl-security hops 2
IPv6 BGP security feature configuration examples
Example: Configuring IPsec for IPv6 BGP packets
As shown in Figure 64, all routers run IPv6 BGP. Establish an IBGP connection between Router A and Router B, and establish an EBGP connection between Router B and Router C.
To enhance security, configure IPsec to protect IPv6 BGP packets.
Table 134 Configure IPv6 addresses for interfaces. (Details not shown.)
Table 135 Establish an IBGP connection between Router A and Router B:
[RouterA] bgp 65008
[RouterA-bgp-default] group ibgp internal
[RouterA-bgp-default] peer 1::2 group ibgp
[RouterA-bgp-default] address-family ipv6 unicast
[RouterA-bgp-default-ipv6] peer ibgp enable
[RouterA-bgp-default-ipv6] quit
[RouterB] bgp 65008
[RouterB-bgp-default] group ibgp internal
[RouterB-bgp-default] peer 1::1 group ibgp
[RouterB-bgp-default] address-family ipv6 unicast
[RouterB-bgp-default-ipv6] peer ibgp enable
[RouterB-bgp-default-ipv6] quit
Table 136 Establish an EBGP connection between Router B and Router C:
[RouterC] bgp 65009
[RouterC-bgp-default] group ebgp external
[RouterC-bgp-default] peer 3::1 as-number 65008
[RouterC-bgp-default] peer 3::1 group ebgp
[RouterC-bgp-default] address-family ipv6 unicast
[RouterC-bgp-default-ipv6] peer ebgp enable
[RouterC-bgp-default-ipv6] quit
[RouterB-bgp-default] group ebgp external
[RouterB-bgp-default] peer 3::2 as-number 65009
[RouterB-bgp-default] peer 3::2 group ebgp
[RouterB-bgp-default-ipv6] peer ebgp enable
Table 137 Configure IPsec transform sets and IPsec profiles:
# On Router A, create an IPsec transform set named tran1.
[RouterA] ipsec transform-set tran1
# Set the encapsulation mode to transport mode.
[RouterA-ipsec-transform-set-tran1] encapsulation-mode transport
# Set the security protocol to ESP, the encryption algorithm to DES, and authentication algorithm to SHA1.
[RouterA-ipsec-transform-set-tran1] esp encryption-algorithm des
[RouterA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[RouterA-ipsec-transform-set-tran1] quit
# Create an IPsec profile named policy001, and specify the manual mode for it.
[RouterA] ipsec profile policy001 manual
# Use IPsec transform set tran1.
[RouterA-ipsec-profile-policy001-manual] transform-set tran1
# Set the SPIs of the inbound and outbound SAs to 12345.
[RouterA-ipsec-profile-policy001-manual] sa spi outbound esp 12345
[RouterA-ipsec-profile-policy001-manual] sa spi inbound esp 12345
# Set the keys for the inbound and outbound SAs using ESP to abcdefg.
[RouterA-ipsec-profile-policy001-manual] sa string-key outbound esp simple abcdefg
[RouterA-ipsec-profile-policy001-manual] sa string-key inbound esp simple abcdefg
[RouterA-ipsec-profile-policy001-manual] quit
# On Router B, create an IPsec transform set named tran1.
[RouterB] ipsec transform-set tran1
[RouterB-ipsec-transform-set-tran1] encapsulation-mode transport
[RouterB-ipsec-transform-set-tran1] esp encryption-algorithm des
[RouterB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[RouterB-ipsec-transform-set-tran1] quit
# Create IPsec profile named policy001, and specify the manual mode for it.
[RouterB] ipsec profile policy001 manual
[RouterB-ipsec-profile-policy001-manual] transform-set tran1
[RouterB-ipsec-profile-policy001-manual] sa spi outbound esp 12345
[RouterB-ipsec-profile-policy001-manual] sa spi inbound esp 12345
[RouterB-ipsec-profile-policy001-manual] sa string-key outbound esp simple abcdefg
[RouterB-ipsec-profile-policy001-manual] sa string-key inbound esp simple abcdefg
[RouterB-ipsec-profile-policy001-manual] quit
# Create an IPsec transform set named tran2.
[RouterB] ipsec transform-set tran2
[RouterB-ipsec-transform-set-tran2] encapsulation-mode transport
[RouterB-ipsec-transform-set-tran2] esp encryption-algorithm des
[RouterB-ipsec-transform-set-tran2] esp authentication-algorithm sha1
[RouterB-ipsec-transform-set-tran2] quit
# Create IPsec profile named policy002, and specify the manual mode for it.
[RouterB] ipsec profile policy002 manual
# Use IPsec transform set tran2.
[RouterB-ipsec-profile-policy002-manual] transform-set tran2
# Set the SPIs of the inbound and outbound SAs to 54321.
[RouterB-ipsec-profile-policy002-manual] sa spi outbound esp 54321
[RouterB-ipsec-profile-policy002-manual] sa spi inbound esp 54321
# Set the keys for the inbound and outbound SAs using ESP to gfedcba.
[RouterB-ipsec-profile-policy002-manual] sa string-key outbound esp simple gfedcba
[RouterB-ipsec-profile-policy002-manual] sa string-key inbound esp simple gfedcba
[RouterB-ipsec-profile-policy002-manual] quit
# On Router C, create an IPsec transform set named tran2.
[RouterC] ipsec transform-set tran2
[RouterC-ipsec-transform-set-tran2] encapsulation-mode transport
[RouterC-ipsec-transform-set-tran2] esp encryption-algorithm des
[RouterC-ipsec-transform-set-tran2] esp authentication-algorithm sha1
[RouterC-ipsec-transform-set-tran2] quit
[RouterC] ipsec profile policy002 manual
[RouterC-ipsec-profile-policy002-manual] transform-set tran2
[RouterC-ipsec-profile-policy002-manual] sa spi outbound esp 54321
[RouterC-ipsec-profile-policy002-manual] sa spi inbound esp 54321
[RouterC-ipsec-profile-policy002-manual] sa string-key outbound esp simple gfedcba
[RouterC-ipsec-profile-policy002-manual] sa string-key inbound esp simple gfedcba
[RouterC-ipsec-profile-policy002-manual] quit
Table 138 Configure IPsec to protect IPv6 BGP packets between Router A and Router B:
[RouterA] bgp 65008
[RouterA-bgp-default] peer 1::2 ipsec-profile policy001
[RouterB] bgp 65008
[RouterB-bgp-default] peer 1::1 ipsec-profile policy001
Table 139 Configure IPsec to protect IPv6 BGP packets between Router B and Router C:
[RouterC] bgp 65009
[RouterC-bgp-default] peer ebgp ipsec-profile policy002
[RouterB] bgp 65008
[RouterB-bgp-default] peer ebgp ipsec-profile policy002
# Display detailed information about IPv6 BGP peers on Router B.
[RouterB] display bgp peer ipv6 verbose
Peer: 1::1 Local: 2.2.2.2
Type: IBGP link
BGP version 4, remote router ID 1.1.1.1
Update group ID: 0
BGP current state: Established, Up for 00h05m54s
BGP last state: OpenConfirm
Port: Local - 24896 Remote - 179
Configured: Active Hold Time: 180 sec Keepalive Time: 60 sec
Received : Active Hold Time: 180 sec
Negotiated: Active Hold Time: 180 sec Keepalive Time: 60 sec
Peer optional capabilities:
Peer supports BGP multi-protocol extension
Peer supports BGP route refresh capability
Peer supports BGP route AS4 capability
InQ updates: 0, OutQ updates: 0
NLRI statistics:
Rcvd: UnReach NLRI 0, Reach NLRI 0
Sent: UnReach NLRI 0, Reach NLRI 3
Message statistics:
Msg type Last rcvd time/ Current rcvd count/ History rcvd count/
Last sent time Current sent count History sent count
Open 18:59:15-2013.4.24 1 1
18:59:15-2013.4.24 1 2
Update - 0 0
18:59:16-2013.4.24 1 1
Notification - 0 0
18:59:15-2013.4.24 0 1
Keepalive 18:59:15-2013.4.24 1 1
RouteRefresh - 0 0
- 0 0
Total - 2 2
- 3 5
Threshold: 75%
Authentication type configured: None
Minimum time between advertisements is 15 seconds
Optional capabilities:
Peer preferred value: 0
IPsec profile name: policy001
Site-of-Origin: Not specified
Routing policy configured:
Peer: 3::2 Local: 2.2.2.2
Type: EBGP link
BGP version 4, remote router ID 3.3.3.3
Update group ID: 0
BGP current state: Established, Up for 00h05m00s
Port: Local - 24897 Remote - 179
NLRI statistics:
Message statistics:
Update - 0 0
Notification - 0 0
RouteRefresh - 0 0
- 0 0
Total - 2 2
- 3 5
Threshold: 75%
IPsec profile name: policy002
The output shows that IBGP and EBGP peers are established and both sent and received IPv6 BGP packets are encapsulated by IPsec.
As shown in Figure 65, all routers run IPv6 BGP. Establish a TCP connection between Router A and the RPKI server, and establish an IBGP connection between Router A and Router B.
Table 140 Configure IPv6 addresses for interfaces and establish an IBGP connection between Router A and Router B. (Details not shown.)
Table 141 Configure Router A to establish a TCP connection to the RPKI server.
[RouterA] bgp 100
[RouterA-bgp-default-rpki] server tcp 1::2
Table 142 Enable BGP RPKI validation on Router A.
Table 143 Apply the BGP RPKI validation state to optimal route selection.
[RouterA-bgp-default-ipv6] bestroute origin-as-validation
Table 144 Configure Router A to advertise the BGP RPKI validation state to peer 2001::2.
[RouterA-bgp-default-ipv6] peer 2001::2 advertise-ext-community
[RouterA-bgp-default-ipv6] peer 2001::2 advertise origin-as-validation
Table 145 Configure Router B to permit routes with a BGP RPKI validation state of Valid:
[RouterB] bgp 100
[RouterB-bgp-default-ipv6] peer 2001::1 route-policy rpki_policy import
1::2 0 1234 Establish 00:04:43 5/5
[RouterA] display bgp rpki table ipv6
2001:4860:: 32-32 100 1::2 U
2404:6800:: 32-32 100 1::2 U
2607:F8B0:: 28-28 4294967295 1::2 U
2A03:ACE0:: 40-40 4294967295 1::2 U
2001::1 64-64 200 1::2 U
[RouterA] display bgp routing-table ipv6 2001::1 64
BGP routing table information of 2001::1/64:
Imported route.
Route age : 01h13m20s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
IP precedence : N/A
QoS local ID : N/A
The route to 2001::1 matches the ROA with a prefix of 2001::1, a prefix length range of 64 to 64, and an origin AS number of 200. Therefore, the BGP RPKI validation state of the route to 2001::1 is Valid.
# On Router B, display detailed information about the BGP IPv6 unicast route to 2001::1.
[RouterB] display bgp routing-table ipv6 2001::1 64
RR-client route.
Rely nexthop : 2001::1
Original nexthop: 2001::1
Route age : 01h13m22s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
Org-validation : Invalid
AS-path : (null)
Origin : incomplete
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
The output displays information about the BGP IPv6 unicast route to 2001::1 because Router B permits routes with a BGP RPKI validation state of Valid.
Improving BGP network reliability
BGP network reliability improvement tasks at a glance
To improve the BGP network reliability, perform the following tasks:
· Configuring multi-tunnel switchover for MPLS
¡ Allowing BGP route recursion to multiple load sharing tunnels
¡ Allowing BGP route recursion to primary and backup tunnels
· Configuring BGP maintenance features
Configuring BGP GR
About BGP GR
Graceful Restart (GR) ensures forwarding continuous when a routing protocol restarts or an active/standby switchover occurs. Two routers are required to complete a GR process. The following are router roles in a GR process:
· GR restarter—Performs GR upon a BGP restart or active/standby switchover.
· GR helper—Helps the GR restarter to complete the GR process.
A device can act as a GR restarter and GR helper at the same time.
BGP GR works as follows:
Table 146 The BGP GR restarter and helper exchange OPEN messages for GR capability negotiation. If both parties have the GR capability, they establish a GR-capable session. The GR restarter sends the GR timer set by the graceful-restart timer restart command to the GR helper in an OPEN message.
2. When an active/standby switchover occurs or BGP restarts, the GR restarter does not remove existing BGP routes from Routing Information Base (RIB) and Forwarding Information Base (FIB). It still uses these routes for packet forwarding, and it starts the RIB purge timer (set by the graceful-restart timer purge-time command). The GR helper marks all routes learned from the GR restarter as stale instead of deleting them. It continues to use these routes for packet forwarding. During the GR process, packet forwarding is not interrupted.
3. After the active/standby switchover or BGP restart completes, the GR restarter re-establishes a BGP session to the GR helper. If the BGP session fails to be established after both the GR timer and the extra timer to wait expire, the GR helper removes the stale routes. To set the extra timer to wait after the restart timer expires, execute the peer graceful-restart timer restart extra command.
4. If the BGP session is established, routing information is exchanged for the GR restarter to retrieve route entries and for the GR helper to recover stale routes.
5. Both the GR restarter and the GR helper start the End-Of-RIB marker waiting timer.
The End-Of-RIB marker waiting time is set by the graceful-restart timer wait-for-rib command.
¡ If routing information exchange is completed within the waiting timer, the GR restarter and the GR helper act as follows:
- The GR restarter updates its routing table with learned BGP routes, removes the aged routes from the RIB, and quits the GR process.
- The GR helper removes the stale routes and quits the GR process.
¡ If routing information exchange is not completed within the waiting timer, the GR restarter and the GR helper act as follows:
- The GR restarter updates the RIB with the BGP routes already learned, removes the aged routes from the RIB, and quits the GR process.
The End-Of-RIB marker is an update message that does not contain any NLRI or withdrawn NLRI. After the GR restarter and the GR helper complete route exchange, they additionally send an End-Of-RIB marker to each other. The marker indicates the completion of route update.
6. The GR restarter quits the GR process if routing information exchange is not completed within the RIB purge timer. It updates the RIB with the BGP routes already learned, and removes the aged routes.
When the TCP connection goes down, the hold timer expires, or the address families supporting route exchange change, BGP terminates and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, enable BGP to reset peer sessions gracefully.
After BGP completes GR, it advertises updated routes as follows:
· If the routes rely on other protocols, for example, redistributed OSPF routes and routes with MPLS labels, BGP starts a wait timer for these protocols to complete GR. This ensures that incorrect and unreachable routes are not advertised.
¡ If the protocols complete GR and notify BGP before the wait timer expires, BGP cancels the wait timer and advertises the routes.
¡ After the wait timer expires, BGP immediately advertises the routes.
· If the routes do not rely on other protocols, BGP immediately advertises the routes.
About local GR
A BGP session is GR-capable only when both ends of the session are enabled with the GR capability. If an H3C device establishes a BGP session to a GR-incapable peer, the BGP session is also GR-incapable. When the BGP session is terminated, traffic interruption will occur, because the device needs to learn BGP routes again. To avoid the above issue, enable the local GR capability for the related peer.
If the BGP session to a peer or peer group enabled with the local GR capability is disconnected, the local device retains the routes learned from that peer or peer group for a certain period. The retain operation is performed regardless of whether the disconnected BGP session is GR-capable. During the route retention period, the local device still uses the original routes for packet forwarding to avoid traffic interruption.
NOTE: In this section, the GR timer is specified by the peer local-graceful-restart timer restart command and the End-of-RIB marker wait timer is specified by the peer local-graceful-restart timer wait-for-rib command. |
Local GR functions as follows:
Table 147 When the local device is disconnected from a peer or peer group enabled with the local GR capability, it does not delete the routes learned from that peer or peer group. Instead, it marks those routes as stale routes and still use them for packet forwarding without updating the forwarding table.
2. The local device starts the GR timer and tries to re-establish a BGP session to the peer or peer group:
¡ If the BGP session re-establishment does not succeed before the GR timer expires, the local device removes the stale routes and exits from the local GR process.
¡ If the BGP session re-establishment succeeds before the GR timer expires, the local device starts the End-of-RIB marker wait timer and exchanges routes with the peer or peer group. After route learning is completed, the local device will remove the stale marker from the related routes. The End-of-RIB marker wait timer functions as follows:
- If the local device receives an End-of-RIB marker from the peer or peer group before the wait timer expires, it removes the routes in stale state, updates the forwarding table, and exits from the local GR process.
- If the local device does not receive an End-of-RIB marker from the peer or peer group before the wait timer expires, it removes the routes in stale state, updates the forwarding table, and exits from the local GR process.
Restrictions and guidelines on BGP GR
The maximum time to wait for the End-of-RIB marker configured on the local end is not advertised to the peer. It controls the time for the local end to receive updates from the peer. Set a large value for the maximum time to wait for the End-of-RIB marker when a large number of routes need to be exchanged. When you use the peer graceful-restart timer restart extra command, you can specify the no-limit keyword. In this situation, the GR helper does not start the End-of-RIB marker waiting timer after BGP session re-establishment and keeps waiting for the End-of-RIB marker from the GR restarter.
As a best practice, perform the BGP GR configuration on both the GR restarter and GR helper.
When the following conditions exist, BGP might advertise incomplete routes after completing GR:
· The routes rely on other protocols, for example, redistributed OSPF routes.
· BGP maintains a large amount of routing information. In this case, BGP and the protocols take a long time to complete GR.
For BGP to correctly advertise the routes after BGP and the protocols complete GR, set a larger wait timer for BGP.
Restrictions and guidelines on local GR
After the local Graceful Restart (GR) capability is enabled for a peer or peer group on the local device, only the local GR process is started when the two sides re-establish a BGP session. The local device and the peer or peer group will not start a BGP GR process during BGP session re-establishment, regardless of whether they have successfully negotiated the BGP GR capability.
If the local device is already in a BGP GR process when you enable the local GR capability, enabling the local GR capability will not interrupt the BGP GR process. After the BGP GR process ends, the local device will only enter the local GR process.
When the local device is in a local GR process, enable or disable BGP GR capability on the local device with caution. This operation will interrupt the local GR process and re-establish BGP sessions.
The local GR feature does not take effect on dynamic BGP peers.
Configuring BGP GR
Table 148 Enter system view.
2. Enter BGP instance view.
3. Enable GR capability for BGP.
graceful-restart
By default, GR capability is disabled for BGP.
CAUTION: After you enable or disable GR, the device re-establishes all BGP sessions. |
4. (Optional.) Configure the GR timer.
The default setting is 150 seconds.
The time that a peer waits to re-establish a session must be less than the hold time.
5. (Optional.) Set the extra time to wait after the restart timer expires.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } graceful-restart timer restart extra { time | no-limit }
By default, the extra time to wait after the restart timer expires is 0 seconds.
6. (Optional.) Configure the maximum time to wait for the End-of-RIB marker.
The default setting is 600 seconds.
7. (Optional.) Configure the RIB purge timer.
The default setting is 480 seconds.
8. (Optional.) Configure the time that BGP must wait for other protocols to complete GR after BGP completes GR.
bgp update-delay wait-other-protocol seconds
By default, after BGP completes GR, it must wait a maximum of 300 seconds for other protocols to complete GR.
9. (Optional.) Enable BGP to reset peer sessions gracefully.
graceful-restart peer-reset [ all ]
By default, BGP does not reset peer sessions gracefully.
Configuring local GR
Table 149 Enter system view.
3. Enable the local GR capability for a peer or peer group.
peer { group-name | ipv4-address | ipv6-address } local-graceful-restart enable
By default, the local GR capability is disabled for all BGP peers.
4. (Optional.) Configure the timers for local GR processes.
¡ Configure the local GR timer.
peer { group-name | ipv4-address | ipv6-address } local-graceful-restart timer restart timer
¡ Configure the time to wait for the End-of-RIB marker.
peer { group-name | ipv4-address | ipv6-address } local-graceful-restart timer wait-for-rib timer
Configuring BFD for BGP
BGP maintains neighbor relationships based on the keepalive timer and hold timer in seconds. It requires that the hold time must be at least three times the keepalive interval. This mechanism slows down link failure detection. Once a failure occurs on a high-speed link, a large quantity of packets will be dropped before routing convergence completes. BFD for BGP can solve this problem by fast detecting link failures to reduce convergence time.
Before you enable BFD for a BGP peer or peer group, you must establish a BGP session between the local router and the peer or peer group.
For more information about BFD, see High Availability Configuration Guide.
Follow these restrictions and guidelines when you configure echo packet mode BFD:
· Echo packet mode BFD is applicable only to directly connected BGP peers.
· Echo packet mode BFD is not applicable to the BGP peers established by using loopback interfaces.
· For successful BFD session establishment, make sure a source address has been specified for echo packets by using the bfd echo-source-ip or bfd echo-source-ipv6 command.
To detect the link to a BGP peer established through link-local addresses, you must configure single-hop BFD in control packet mode.
When you enable control packet-mode BFD for a BGP peer on an H3C device (local router), follow these restrictions and guidelines:
· If the BGP peer is an H3C device, you must configure the same BFD detection mode (multi-hop or single-hop) on the local device and the BGP peer.
· If the BGP peer is a non-H3C device, make sure the local router and the BGP peer meet the following requirements:
¡ The local router and the BGP peer must use the same UDP destination port when they exchange BFD packets.
¡ If the BGP peer sends BFD packets with TTL less than 255 to the local router, the TTL must be less than 255 for the local router's BFD packets.
If the BGP peer sends BFD packets with TTL 255 to the local router, the TTL must be 255 for the local router's BFD packets.
As shown in Table 150, the UDP destination port and the TTL for BFD packets depends on the BGP session type and the configuration of the peer bfd command.
Table 150 UDP destination port and TTL
Whether the multi-hop or single-hop keyword is specified |
Whether the compatible keyword is specified |
Directly-connected IBGP peer |
Indirectly-connected IBGP peer |
Directly-connected EBGP peer |
Indirectly-connected EBGP peer |
No |
No |
· UDP destination port: 4784 · TTL: 64 |
· UDP destination port: 3784 · TTL: 255 |
No |
Yes |
· UDP destination port: 4784 · TTL: 255 |
· UDP destination port: 3784 · TTL: 64 |
The single-hop keyword is specified. |
No |
Yes |
The multi-hop keyword is specified. |
No |
Yes |
When you specify the compatible keyword, make sure other services do not share a BFD session with BGP as a best practice. Specifying the compatible keyword will interrupt the services that use the same BFD session as BGP.
If you have enabled GR, use BFD with caution because BFD might detect a failure before the system performs GR, which will result in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
When you configure BFD parameters for a BGP peer or peer group, follow these restrictions and guidelines:
· When you add a peer to a peer group, the peer will inherit the BFD settings of the peer group.
· When you configure BFD parameters for a peer group, the configuration takes effect on all peers in the peer group.
· If you configure a BFD parameter multiple times for a peer or peer group, the most recent configuration takes effect.
For a BGP peer or peer group, the most recent configuration of a BFD parameter takes effect regardless of the configuration source.
1. Enter system view.
3. Enable BFD to detect the link to an IPv4 BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bfd [ echo | [ multi-hop | single-hop ] [ compatible ] ]
By default, BFD is disabled.
4. (Optional.) Configure BFD parameters for a BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bfd parameters { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
By default, BFD parameters are not configured for a BGP peer or peer group.
3. Enable BFD to detect the link to an IPv6 BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } bfd [ echo | [ multi-hop | single-hop ] [ compatible ] ]
peer { group-name | ipv6-address [ prefix-length ] } bfd parameters { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
By default, no BFD parameters are configured for a BGP peer or peer group.
Configuring BGP FRR
About BGP FRR
When a link fails, the packets on the link are discarded, and a routing loop might occur until BGP completes routing convergence based on the new network topology.
You can enable BGP fast reroute (FRR) to resolve this issue.
Figure 66 Network diagram for BGP FRR
After you configure FRR on Router B as shown in Figure 66, BGP generates a backup next hop Router C for the primary route. BGP uses ARP (for IPv4), BFD echo packet mode (for IPv4), or ND (for IPv6) to detect the connectivity to Router D. When the link to Router D fails, BGP directs packets to the backup next hop. At the same time, BGP calculates a new optimal route, and forwards packets over the optimal route.
You can use the following methods to configure BGP FRR:
· Method 1—Execute the pic command in BGP address family view. BGP calculates a backup next hop for each BGP route in the address family if there are two or more unequal-cost routes that reach the destination.
· Method 2—Execute the fast-reroute route-policy command to use a routing policy in which a backup next hop is specified by using the command apply [ ipv6 ] fast-reroute backup-nexthop. The backup next hop calculated by BGP must be the same as the specified backup next hop. Otherwise, BGP does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
BGP supports FRR for IPv4 and IPv6 unicast routes, but not for IPv4 and IPv6 multicast routes.
Configuring BGP FRR by using a routing policy (IPv4 unicast address family)
2. Configure the source address of echo packets.
bfd echo-source-ip ipv4-address
By default, no source address is specified for echo packets.
This step is required when BFD echo packet mode is used to detect the connectivity to the next hop of the primary route.
Specify a source IP address that does not belong to any local network.
For more information about this command, see BFD commands in High Availability Command Reference.
3. Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
For more information about this command, see routing policy commands in Layer 3—IP Routing Command Reference.
4. Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ipv4-address
By default, no backup next hop is set.
5. Return to system view.
6. Enter BGP instance view.
7. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
¡ Enter BGP IPv4 unicast address family view.
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
8. Apply a routing policy to FRR for the address family.
By default, no routing policy is applied.
The apply fast-reroute backup-nexthop and apply ipv6 fast-reroute backup-nexthop commands can take effect in the applied routing policy. Other apply commands do not take effect.
Configuring BGP FRR by using a routing policy (IPv6 unicast address family)
2. Create a routing policy and enter routing policy view.
3. Set the backup next hop for FRR.
apply ipv6 fast-reroute backup-nexthop ipv6-address
4. Return to system view.
5. Enter BGP instance view or BGP-VPN instance view.
6. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
7. Apply a routing policy to FRR for the address family.
Configuring BGP FRR through PIC (IPv4 unicast address family)
This feature might result in routing loops. Use it with caution.
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 labeled unicast address family view, or BGP-VPN IPv4 labeled unicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 labeled unicast address family view:
address-family ipv4 labeled-unicast
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 labeled unicast address family view:
3. Enable BGP FRR through PIC.
pic
By default, BGP FRR is disabled.
Configuring BGP FRR through PIC (IPv6 unicast address family)
3. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
4. Enable BGP FRR through PIC.
pic
Configuring BFD-powered nexthop connectivity detection for BGP FRR
By default, BGP FRR uses ARP to detect next hop connectivity for the primary route. This method is not efficient at detecting the failure of the primary route. As a result, data loss might occur when the primary route fails, because the backup path might not take over to forward traffic in time. To resolve this issue, enable BFD-powered nexthop connectivity detection for BGP FRR. This feature enables BGP to create an IP FRR BFD session that detects next hop connectivity for the primary route. This can speed up primary and backup route switchover when the next hop of the primary route fails.
This feature takes effect and creates an IP FRR BFD session only when the primary route has a backup next hop.
BGP does not support backup next hop calculation for the routes used for load balancing. This command cannot take effect when the primary route is an equal-cost route. To enable BFD-based next hop detection for equal-cost routes, use the primary-path-detect bfd protocol-ecmp bgp command or the primary-path-detect bfd protocol-ecmp bgp4+ command. For more information about the two commands, see IP routing basics commands in Layer 3—IP Routing Command Reference.
BGP can establish a control-mode BFD session with a peer only after negotiation. To use control-mode BFD to detect the next hop of the primary link, perform one of the following tasks:
· Configure the primary-path-detect bfd command on the peer device in the primary link.
This task is applicable when both ends of the primary link are configured with FRR.
· Manually configure a static BFD session that uses the following settings on the peer device in the primary link:
¡ Source IP address: Destination IP address of the BFD session automatically created on the local device in the primary link.
¡ Destination IP address: Source IP address of the BFD session automatically created on the local device in the primary link.
¡ Remote ID: Local ID of the BFD session automatically created on the local device in the primary link.
When you configure echo-mode BFD for nexthop connectivity detection, you only need to configure this feature on the local router.
When another routing protocol (such as RIB, OSPF, or IS-IS) uses BFD to detect next hop connectivity for the primary route, it also creates a BFD session. If the detected link is the same as the link attached to the next hop of the BGP primary route, BGP reuses the BFD session created by the protocol. In this situation, BGP will not create an additional BFD session.
In BFD echo packet mode, the source addresses of BFD packets must be global unicast addresses. When the IPv6 next hop of the primary route is not a global unicast address, use BFD control packet mode to detect the connectivity to the next hop of the primary route.
3. (Optional.) Enable BFD-powered nexthop connectivity detection for BGP FRR.
primary-path-detect bfd { ctrl | echo }
By default, BGP FRR uses ARP to detect nexthop connectivity for the primary route.
As shown in Figure 67, both PE 2 and PE 3 are connected to CE 2 and advertise the private routes of CE 2 to PE 1 through BGP. PE 1 and PE 2 can reach each other along the PE 1 <> P 1 <> PE 2 or PE 1 <> P 2 <> PE 2 path. Typically, PE 1 selects the route from one peer PE as the optimal route for traffic forwarding. When multiple public tunnels exist between two PEs, PE 1 selects only one of them to forward the private traffic destined for CE 2, because each BGP route can be iterated to only one tunnel. As a result, PE 1 cannot make full use of the link resources on the public network.
Figure 67 MPLS FRR in dual-homed scenario
After you configure this feature on PE 1, a BGP route can be iterated to multiple tunnels. As shown in Figure 68, when you configure this feature in conjunction with FRR, CE 1 and CE 2 can exchange private traffic along the PE 1 <> PE 2 and PE 1 <> PE 3 paths. On PE 1, the primary route to CE 2 is iterated to public tunnels PE 1 > P 1 > PE 2 and PE 1 > P 2 > PE 2, and the backup route to CE 2 is iterated to public tunnels PE 1 > P 3 > PE 3 and PE 1 > P 4 > PE 3.
When PE 1 forwards private traffic to CE 2, it preferentially uses public tunnels PE 1 > P 1 > PE 2 and PE 1 > P 2 > PE 2 for load sharing. Public tunnels PE 1 > P 3 > PE 3 and PE 1 > P 4 > PE 3 can take over to forward private traffic to CE 2 only when both public tunnels PE 1 > P 1 > PE 2 and PE 1 > P 2 > PE 2 are unavailable.
Figure 68 Multi-tunnel-based load sharing for MPLS FRR in dual-homed scenario
To have this feature take effect, you must perform the following task:
2. Associate a tunnel selector with the tunnel policy configured with the select-seq load-balance-number command.
3. Apply the tunnel selector to BGP VPNv4 routes, BGP VPNv6 routes, or BGP EVPN routes.
These routes then can be iterated to multiple tunnels. The types of the tunnels and the number of tunnels for load sharing depend on the configuration of the select-seq load-balance-number command. For more information about this command, see tunnel policy commands in MPLS Command Reference.
If you specify SRv6 tunnel types in the select-seq load-balance-number command, the configuration does not take effect on this feature. BGP routes cannot be iterated to SRv6 tunnels.
The device still supports iterating BGP routes to multiple load-balancing tunnels when you do not configure the select-seq load-balance-number command on the device. In this situation, the device selects tunnels for load sharing according to the default tunnel selection policy of the select-seq load-balance-number command.
Configuring the PE
2. Create a tunnel policy and enter tunnel policy view.
tunnel-policy tunnel-policy-name [ default ]
3. Configure the tunnel selection order and the number of tunnels for load sharing.
select-seq [ strict ] { cr-lsp | flex-algo-lsp | gre | lsp | sr-lsp | sr-policy | srv6-policy | srv6-policy-group } * load-balance-number number
By default, the policy selects tunnels in LSP > GRE > CRLSP > SRLSP > SR-MPLS TE policy > SRv6 TE policy > SRv6 TE policy group > Flex-Algo LSP order, and the number of tunnels selected for load sharing varies by device model.
5. Enter tunnel selector view.
tunnel-selector tunnel-selector-name { deny | permit } node node-number
6. Apply a tunnel policy to the tunnel selector.
apply tunnel-policy tunnel-policy-name
By default, no tunnel policy is applied to a tunnel selector.
7. Return to system view.
8. Enter BGP instance view.
9. Enter BGP address family view. Choose one option as needed:
¡ Enter BGP VPNv4 address family view.
address-family vpnv4
¡ Enter BGP VPNv6 address family view.
address-family vpnv6
¡ Enter BGP EVPN address family view.
address-family l2vpn evpn
10. Apply a tunnel selector.
apply tunnel-selector tunnel-selector-name [ all ]
By default, no tunnel selector is applied to BGP EVPN, BGP VPNv4, or BGP VPNv6 routes.
The all keyword is not supported in BGP VPNv4 address family view or BGP VPNv6 address family view.
11. Return to BGP instance view.
12. (Optional.) Enter BGP address family view. Choose one option as needed:
¡ Enter BGP IPv6 unicast address family view.
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
13. (Optional.) Enable BGP FRR through PIC.
pic
As shown in Figure 69, CE 1 is connected to PE 1 and CE 2 is connected to PE 2. PE 1 and PE 2 exchange the private routes of CE 1 and CE 2 through BGP.
When multiple public tunnels exist between two PEs, a PE selects only one of the public tunnels to forward the private traffic destined for the remote CE. This is because each BGP route can be iterated to only one tunnel. For example, when PE 1 forwards the private traffic destined for CE 2, it selects only one of the PE 1 > P 1 > PE 2 and PE 1 > P 2 > PE 2 tunnels for traffic forwarding. If the selected tunnel fails, PE 1 can perform forwarding path switchover only after route convergence completes. This mechanism provides low service reliability.
To resolve this issue, perform this task to enable support for BGP route recursion to primary and backup tunnels. The obtained primary and backup tunnels work together to ensure traffic forwarding reliability. BGP forwards the matching traffic through the primary tunnel as long as the primary tunnel is available. When the primary tunnel fails, the backup tunnel immediately takes over to forward traffic. This mechanism avoids long-time traffic forwarding interruption.
Figure 69 Primary/backup tunnel switchover for MPLS in single-homed scenario
After you configure this feature, a BGP route can be iterated to primary and backup tunnels. These tunnels are of different types and are single tunnels without load sharing.
With this feature configured, the device determines the types of primary and backup tunnels according to the configuration of the select-seq load-balance-number command. For example, the type of primary tunnel is SRLSP and the type of backup tunnel is CRLSP for BGP IPv4 unicast routes if you perform the following task:
2. Configure the select-seq sr-lsp cr-lsp load-balance-number command in the view of a tunnel policy.
3. Apply the tunnel selector associated with the tunnel policy above to BGP IPv4 unicast routes.
For more information about the select-seq load-balance-number command and tunnel policies, see tunnel policy commands in MPLS Command Reference.
· If you specify only one tunnel type in the select-seq load-balance-number command, route recursion to primary and backup tunnels is not supported for BGP routes. In the current software version, only the cr-lsp and sr-lsp keywords of the select-seq load-balance-number command can take effect on the nexthop recursive-lookup tunnel-backup command. When a BGP route is iterated to primary and backup tunnels, these tunnels can only be CRLSP tunnels and SRLSP tunnels.
· The load-balance-number number option of the select-seq load-balance-number command does not take effect on this feature.
· When you apply the tunnel selector associated with a tunnel policy to an address family, the tunnel policy might not be configured with the select-seq load-balance-number command. In this situation, the nexthop recursive-lookup tunnel-backup command uses the default tunnel selection order of the select-seq load-balance-number command for BGP route recursion to primary and backup tunnels. The tunnel type of primary tunnel is CRLSP and the tunnel type of backup tunnel is SRLSP.
· After you configure the nexthop recursive-lookup tunnel-backup command for an address family, the routes of that address family support only route recursion to primary and backup tunnels. They cannot be iterated to load sharing tunnels.
· This feature only allows BGP route recursion to intra-AS primary and backup tunnels and does not take effect on labeled BGP routes. Therefore, this feature is not supported when the network scheme is inter-AS VPN option B or inter-AS VPN option C.
· Do not execute the sr-policy steering policy-based command after executing the nexthop recursive-lookup tunnel-backup command. If you fail to do so, the nexthop recursive-lookup tunnel-backup command cannot take effect.
For more information about the sr-policy steering command, see SR-MPLS TE policy commands in Segment Routing Command Reference.
Procedure (IPv4 unicast)
2. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
3. Allow BGP route recursion to primary and backup tunnels.
nexthop recursive-lookup tunnel-backup [ evpn ]
By default, a BGP route can be iterated to only one tunnel.
The evpn keyword is supported only in BGP-VPN IPv4 unicast address family view.
Procedure (IPv6 unicast)
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
The evpn keyword is supported only in BGP-VPN IPv6 unicast address family view.
About BGP isolation and BGP shutdown
For maintenance purposes, you can use either BGP isolation or BGP shutdown to remove the device from the network. The device will not be used for forwarding traffic from its peers after they reselect an optimal route. Both BGP isolation and BGP shutdown retain the device configuration to ease maintenance workload.
After maintenance, you can disable BGP isolation or BGP shutdown to add the device back to the network.
Configuring BGP isolation
To reduce impact on traffic forwarding, you can isolate the device from the network before upgrading it. BGP isolation works as follows:
1. BGP withdraws all routes advertised by the device except for the directly-connected routes.
2. BGP keeps all routes learned from its peers.
3. Each peer of the device reselects an optimal route and updates the FIB table. During optimal route selection, the peers can still use the routes advertised by the device to forward traffic.
4. After an optimal route is selected and the FIB table is updated, the peers stop forwarding packets except for those destined for the device to the device. The device is fully isolated from the network and you can upgrade it.
5. After the maintenance, disable BGP isolation on the device to gracefully add it back to the network. After returning to the network, the device advertises and learns routes as follows:
¡ Advertises routes to its peers.
¡ Learns routes if BGP was reset during the isolation.
To avoid isolation failure, do not use this feature when GR or NSR is enabled for the device.
3. Enable BGP isolation to gracefully remove the device from the network.
isolate enable
By default, BGP isolation is disabled.
4. Disable BGP isolation to gracefully add the device to the network.
undo isolate enable
Configuring BGP shutdown
For maintenance purposes, you can use this feature to temporarily disconnect BGP sessions from all peers and peer groups. After maintenance, you can disable this feature to restore these sessions.
With this feature enabled, the device terminates all sessions and clears all routing information.
When you configure the shutdown process command together with the peer ignore or ignore all-peers command, follow these restrictions and guidelines:
· Once BGP shutdown is enabled by the shutdown process command, the device cannot establish BGP session with all peers and peer groups.
· To disable BGP session establishment with a peer or peer group if you have disabled BGP shutdown, perform one of the following tasks:
¡ Disable BGP session establishment with that peer or peer group by using the peer ignore command.
¡ Disable BGP session establishment with all peers and peer groups by using the ignore all-peers command.
For more information about disabling BGP session establishment, see "Disabling BGP session establishment."
Table 151 Enter system view.
3. Shut down BGP sessions to all peers and peer groups.
shutdown process
By default, BGP does not shut down sessions to any peers or peer groups.
4. Restore the BGP sessions to add the device back to the network.
undo shutdown process
Display and maintenance commands for BGP network reliability improvement
Displaying BGP (IPv4 unicast address family)
Task |
Command |
Display BGP NSR status information. |
display bgp [ instance instance-name ] non-stop-routing status |
Displaying BGP (IPv6 unicast address family)
Task |
Command |
Displaying BGP (IPv4 multicast address family)
Task |
Command |
Displaying BGP (IPv6 multicast address family)
Task |
Command |
IPv4 BGP network reliability improvement configuration examples
Example: Configuring BGP GR
As shown in Figure 70, run EBGP between Router A and Router B, and run IBGP between Router B and Router C.
Configure BGP GR so that the communication between Router A and Router C is not affected when an active/standby switchover occurs on Router B.
Table 152 Configure Router A:
# Configure IP addresses for interfaces. (Details not shown.)
# Configure the EBGP connection.
[RouterA] bgp 65008
[RouterA-bgp-default] router-id 1.1.1.1
[RouterA-bgp-default] peer 200.1.1.1 as-number 65009
# Enable GR capability for BGP.
[RouterA-bgp-default] graceful-restart
# Inject network 8.0.0.0/8 to the IPv4 BGP routing table.
[RouterA-bgp-default] address-family ipv4
[RouterA-bgp-default-ipv4] network 8.0.0.0
# Enable Router A to exchange IPv4 unicast routing information with Router B.
[RouterA-bgp-default-ipv4] peer 200.1.1.1 enable
Table 153 Configure Router B:
<RouterB> system-view
[RouterB] bgp 65009
[RouterB-bgp-default] router-id 2.2.2.2
[RouterB-bgp-default] peer 200.1.1.2 as-number 65008
# Configure the IBGP connection.
[RouterB-bgp-default] peer 9.1.1.2 as-number 65009
[RouterB-bgp-default] graceful-restart
# Inject networks 200.1.1.0/24 and 9.1.1.0/24 to the IPv4 BGP routing table.
[RouterB-bgp-default] address-family ipv4
[RouterB-bgp-default-ipv4] network 200.1.1.0 24
[RouterB-bgp-default-ipv4] network 9.1.1.0 24
# Enable Router B to exchange IPv4 unicast routing information with Router A and Router C.
[RouterB-bgp-default-ipv4] peer 200.1.1.2 enable
[RouterB-bgp-default-ipv4] peer 9.1.1.2 enable
Table 154 Configure Router C:
<RouterC> system-view
[RouterC] bgp 65009
[RouterC-bgp-default] router-id 3.3.3.3
[RouterC-bgp-default] peer 9.1.1.1 as-number 65009
[RouterC-bgp-default] graceful-restart
# Enable Router C to exchange IPv4 unicast routing information with Router B.
[RouterC-bgp-default] address-family ipv4
[RouterC-bgp-default-ipv4] peer 9.1.1.1 enable
Ping Router C on Router A. Meanwhile, perform an active/standby switchover on Router B. The ping operation is successful during the whole switchover process. (Details not shown.)
Example: Configuring BFD for BGP
As shown in Figure 71, configure OSPF as the IGP in AS 200.
· Establish two IBGP connections between Router A and Router C. When both paths operate correctly, Router C uses the path Router A<—>Router B<—>Router C to communicate with network 1.1.1.0/24.
· Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to BGP. Then, the path Router A<—>Router D<—>Router C takes effect immediately.
Table 155 Configure IP addresses for interfaces. (Details not shown.)
Table 156 Configure OSPF so that Router A and Router C can reach each other. (Details not shown.)
Table 157 Configure BGP on Router A:
# Establish two IBGP connections to Router C.
[RouterA] bgp 200
[RouterA-bgp-default] peer 3.0.2.2 as-number 200
[RouterA-bgp-default] peer 2.0.2.2 as-number 200
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 3.0.2.2 enable
[RouterA-bgp-default-ipv4] peer 2.0.2.2 enable
[RouterA-bgp-default-ipv4] quit
# Create IPv4 basic ACL 2000 to permit 1.1.1.0/24 to pass.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule permit source 1.1.1.0 0.0.0.255
[RouterA-acl-ipv4-basic-2000] quit
# Create two routing policies to set the MED for route 1.1.1.0/24. The policy apply_med_50 sets the MED to 50, and the policy apply_med_100 sets the MED to 100.
[RouterA] route-policy apply_med_50 permit node 10
[RouterA-route-policy-apply_med_50-10] if-match ip address acl 2000
[RouterA-route-policy-apply_med_50-10] apply cost 50
[RouterA-route-policy-apply_med_50-10] quit
[RouterA] route-policy apply_med_100 permit node 10
[RouterA-route-policy-apply_med_100-10] if-match ip address acl 2000
[RouterA-route-policy-apply_med_100-10] apply cost 100
[RouterA-route-policy-apply_med_100-10] quit
# Apply routing policy apply_med_50 to routes outgoing to peer 3.0.2.2, and apply routing policy apply_med_100 to routes outgoing to peer 2.0.2.2.
[RouterA] bgp 200
[RouterA-bgp-default-ipv4] peer 3.0.2.2 route-policy apply_med_50 export
[RouterA-bgp-default-ipv4] peer 2.0.2.2 route-policy apply_med_100 export
# Enable BFD for peer 3.0.2.2.
[RouterA-bgp-default] peer 3.0.2.2 bfd
[RouterA-bgp-default] quit
Table 158 Configure BGP on Router C:
# Establish two IBGP connections to Router A.
[RouterC] bgp 200
[RouterC-bgp-default] peer 3.0.1.1 as-number 200
[RouterC-bgp-default] peer 2.0.1.1 as-number 200
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 3.0.1.1 enable
[RouterC-bgp-default-ipv4] peer 2.0.1.1 enable
[RouterC-bgp-default-ipv4] quit
# Enable BFD for peer 3.0.1.1.
[RouterC-bgp-default] peer 3.0.1.1 bfd
[RouterC-bgp-default] quit
# Display detailed BFD session information on Router C.
<RouterC> display bfd session verbose
Total sessions: 1 Up sessions: 1 Init mode: Active
Local discr: 513 Remote discr: 513
Source IP: 3.0.2.2 Destination IP: 3.0.1.1
Destination port: 4784 Session state: Up
Interface: N/A
Min Tx interval: 500ms Actual Tx Interval: 500ms
Min Rx interval: 500ms Detection time: 2500ms
Rx count: 135 Tx count: 135
Connect type: Indirect Up duration: 00:00:20
Hold time: 2457ms Auth mode: None
Detection mode: Async Slot: 0
Protocol: BGP
Version:1
Diag info: No Diagnostic
Hardware mode: Disable
The output shows that a BFD session has been established between Router A and Router C.
# Display BGP peer information on Router C.
<RouterC> display bgp peer ipv4
BGP local router ID: 3.3.3.3
Local AS number: 200
Total number of peers: 2 Peers in established state: 2
2.0.1.1 200 4 5 0 0 00:01:55 Established
3.0.1.1 200 4 5 0 0 00:01:52 Established
The output shows that Router C has established two BGP connections with Router A, and both connections are in Established state.
# Display route 1.1.1.0/24 on Router C.
<RouterC> display ip routing-table 1.1.1.0 24 verbose
Summary count : 1
Destination: 1.1.1.0/24
Protocol: BGP
Process ID: 0
SubProtID: 0x1 Age: 00h00m09s
FlushedAge: 12h24m47s
Cost: 50 Preference: 255
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
OrigTblID: 0x1 OrigVrf: default-vrf
TableID: 0x2 OrigAs: 0
NibID: 0x15000001 LastAs: 0
AttrID: 0x1
BkAttrID: 0xffffffff Neighbor: 3.0.1.1
Flags: 0x10060 OrigNextHop: 3.0.1.1
Label: NULL RealNextHop: 3.0.2.1
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/15
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: N/A
BkTunnel ID: Invalid BkIPInterface: N/A
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: N/A PathID: 0x0
UserID: 0x0 SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 Priority: Critical
MemberPort: N/A ExtFlags: 0x0
UCMIndex: 0x0 UserVLAN: 65535
UCMMTU: 0 BrasHash: 0
SessionID: 0 UserGroupID: 0
IsoGroupID: 0 BkIsoGroupID: 0
The output shows that Router C communicates with network 1.1.1.0/24 through the path Router C<—>Router B<—>Router A.
# Break down the link Router C<—>Router B<—>Router A and then display route 1.1.1.0/24 on Router C.
Summary count : 1
Protocol: BGP
Process ID: 0
SubProtID: 0x1 Age: 00h03m08s
FlushedAge: 12h26m45s
Cost: 100 Preference: 255
NibID: 0x15000000 LastAs: 0
AttrID: 0x0
BkAttrID: 0xffffffff Neighbor: 2.0.1.1
Flags: 0x10060 OrigNextHop: 2.0.1.1
Label: NULL RealNextHop: 2.0.2.1
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/16
SID: N/A
BkSID: N/A
The output shows that Router C communicates with network 1.1.1.0/24 through the path Router C<—>Router D<—>Router A.
Example: Configuring BGP FRR
As shown in Figure 72, configure BGP FRR so that when Link B fails, BGP uses Link A to forward traffic.
Table 159 Configure IP addresses for interfaces. (Details not shown.)
Table 160 Configure OSPF in AS 200 to ensure connectivity among Router B, Router C, and Router D. (Details not shown.)
Table 161 Configure BGP connections:
# Configure Router A to establish EBGP sessions to Router B and Router C, and advertise network 1.1.1.1/32.
[RouterA] bgp 100
[RouterA-bgp-default] peer 10.1.1.2 as-number 200
[RouterA-bgp-default] peer 30.1.1.3 as-number 200
[RouterA-bgp-default-ipv4] peer 10.1.1.2 enable
[RouterA-bgp-default-ipv4] peer 30.1.1.3 enable
[RouterA-bgp-default-ipv4] network 1.1.1.1 32
# Configure Router B to establish an EBGP session to Router A, and an IBGP session to Router D.
[RouterB] bgp 200
[RouterB-bgp-default] peer 4.4.4.4 as-number 200
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 10.1.1.1 enable
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
# Configure Router C to establish an EBGP session to Router A, and an IBGP session to Router D.
[RouterC] bgp 200
[RouterC-bgp-default] peer 30.1.1.1 as-number 100
[RouterC-bgp-default] peer 4.4.4.4 as-number 200
[RouterC-bgp-default-ipv4] peer 30.1.1.1 enable
[RouterC-bgp-default-ipv4] peer 4.4.4.4 next-hop-local
# Configure Router D to establish IBGP sessions to Router B and Router C, and advertise network 4.4.4.4/32.
<RouterD> system-view
[RouterD] bgp 200
[RouterD-bgp-default] router-id 4.4.4.4
[RouterD-bgp-default] peer 2.2.2.2 as-number 200
[RouterD-bgp-default] peer 3.3.3.3 as-number 200
[RouterD-bgp-default] address-family ipv4 unicast
[RouterD-bgp-default-ipv4] network 4.4.4.4 32
Table 162 Configure preferred values so Link B is used to forward traffic between Router A and Router D:
# Configure Router A to set the preferred value to 100 for routes received from Router B.
[RouterA-bgp-default-ipv4] peer 10.1.1.2 preferred-value 100
# Configure Router D to set the preferred value to 100 for routes received from Router B.
[RouterD-bgp-default-ipv4] peer 2.2.2.2 preferred-value 100
[RouterD-bgp-default-ipv4] quit
[RouterD-bgp-default] quit
Table 163 Configure BGP FRR:
# On Router A, configure the source address of BFD echo packets as 11.1.1.1.
[RouterA] bfd echo-source-ip 11.1.1.1
# Create routing policy frr to set a backup next hop 30.1.1.3 (Router C) for the route destined for 4.4.4.4/32.
[RouterA] ip prefix-list abc index 10 permit 4.4.4.4 32
[RouterA] route-policy frr permit node 10
[RouterA-route-policy] if-match ip address prefix-list abc
[RouterA-route-policy] apply fast-reroute backup-nexthop 30.1.1.3
[RouterA-route-policy] quit
# Use BFD echo packet mode to detect the connectivity to Router D.
[RouterA] bgp 100
[RouterA-bgp-default] primary-path-detect bfd echo
# Apply the routing policy to BGP FRR for BGP IPv4 unicast address family.
[RouterA-bgp-default-ipv4] fast-reroute route-policy frr
# On Router D, set the source address of BFD echo packets to 44.1.1.1.
[RouterD] bfd echo-source-ip 44.1.1.1
# Create routing policy frr to set a backup next hop 3.3.3.3 (Router C) for the route destined for 1.1.1.1/32.
[RouterD] ip prefix-list abc index 10 permit 1.1.1.1 32
[RouterD] route-policy frr permit node 10
[RouterD-route-policy] if-match ip address prefix-list abc
[RouterD-route-policy] apply fast-reroute backup-nexthop 3.3.3.3
[RouterD-route-policy] quit
# Use BFD echo packet mode to detect the connectivity to Router A.
[RouterD] bgp 200
[RouterD-bgp-default] primary-path-detect bfd echo
[RouterD-bgp-default-ipv4] fast-reroute route-policy frr
# Display detailed information about the route to 4.4.4.4/32 on Router A. The output shows the backup next hop for the route.
[RouterA] display ip routing-table 4.4.4.4 32 verbose
Summary count : 1
Destination: 4.4.4.4/32
Protocol: BGP Process ID: 0
SubProtID: 0x2 Age: 00h01m52s
FlushedAge: 13h26m47s
Cost: 0 Preference: 255
TableID: 0x2 OrigAs: 200
NibID: 0x15000003 LastAs: 200
AttrID: 0x5
BkAttrID: 0x6 Neighbor: 10.1.1.2
Flags: 0x10060 OrigNextHop: 10.1.1.2
Label: NULL RealNextHop: 10.1.1.2
BkLabel: NULL BkNextHop: 30.1.1.3
BkSRLabel: NULL BkInterface: Ten-GigabitEthernet0/0/16
Tunnel ID: Invalid IPInterface: InLoopBack0
SID: N/A
BkSID: N/A
# Display detailed information about the route to 1.1.1.1/32 on Router D. The output shows the backup next hop for the route.
[RouterD] display ip routing-table 1.1.1.1 32 verbose
Summary count : 1
Destination: 1.1.1.1/32
SubProtID: 0x1 Age: 00h00m36s
FlushedAge: 13h28m49s
TableID: 0x2 OrigAs: 100
NibID: 0x15000003 LastAs: 100
AttrID: 0x1
BkAttrID: 0x3 Neighbor: 2.2.2.2
Flags: 0x10060 OrigNextHop: 2.2.2.2
Label: NULL RealNextHop: 20.1.1.2
BkLabel: NULL BkNextHop: 40.1.1.3
SID: N/A
BkSID: N/A
IPv6 BGP network reliability improvement configuration examples
Example: Configuring BFD for IPv6 BGP
As shown in Figure 73, configure OSPFv3 as the IGP in AS 200.
· Establish two IBGP connections between Router A and Router C. When both paths operate correctly, Router C uses the path Router A<—>Router B<—>Router C to exchange packets with network 1200::0/64.
· Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to IPv6 BGP. Then, the path Router A<—>Router D<—>Router C takes effect immediately.
Table 164 Configure IPv6 addresses for interfaces. (Details not shown.)
Table 165 Configure OSPFv3 so that Router A and Router C can reach each other. (Details not shown.)
Table 166 Configure IPv6 BGP on Router A:
[RouterA] bgp 200
[RouterA-bgp-default] peer 2002::2 as-number 200
[RouterA-bgp-default] peer 3002::2 as-number 200
[RouterA-bgp-default-ipv6] peer 2002::2 enable
[RouterA-bgp-default-ipv6] peer 3002::2 enable
# Create IPv6 basic ACL 2000 to permit 1200::0/64 to pass.
[RouterA] acl ipv6 basic 2000
[RouterA-acl-ipv6-basic-2000] rule permit source 1200:: 64
[RouterA-acl-ipv6-basic-2000] quit
# Create two routing policies to set the MED for route 1200::0/64. The policy apply_med_50 sets the MED to 50, and the policy apply_med_100 sets the MED to 100.
[RouterA-route-policy-apply_med_50-10] if-match ipv6 address acl 2000
[RouterA-route-policy-apply_med_100-10] if-match ipv6 address acl 2000
# Apply routing policy apply_med_50 to routes outgoing to peer 3002::2, and apply routing policy apply_med_100 to routes outgoing to peer 2002::2.
[RouterA] bgp 200
[RouterA-bgp-default-ipv6] peer 3002::2 route-policy apply_med_50 export
[RouterA-bgp-default-ipv6] peer 2002::2 route-policy apply_med_100 export
# Enable BFD for peer 3002::2.
[RouterA-bgp-default] peer 3002::2 bfd
Table 167 Configure IPv6 BGP on Router C:
[RouterC] bgp 200
[RouterC-bgp-default] peer 3001::1 as-number 200
[RouterC-bgp-default] peer 2001::1 as-number 200
[RouterC-bgp-default-ipv6] peer 3001::1 enable
[RouterC-bgp-default-ipv6] peer 2001::1 enable
# Enable BFD for peer 3001::1.
[RouterC-bgp-default] peer 3001::1 bfd
IPv6 session working in control packet mode:
Source IP: 3002::2 Destination IP: 3001::1
Interface: N/A
Min Tx interval: 500ms Actual Tx interval: 500ms
Rx count: 13 Tx count: 14
Connection type: Indirect Up duration: 00:00:05
Hold time: 2243ms Auth mode: None
Protocol: BGP4+
Version: 1
<RouterC> display bgp peer ipv6
* - Dynamically created peer
2001::1 200 8 8 0 0 00:04:45 Established
3001::1 200 5 4 0 0 00:01:53 Established
# Display route 1200::0/64 on Router C.
<RouterC> display ipv6 routing-table 1200::0 64 verbose
Summary count : 1
Destination: 1200::/64
Protocol: BGP4+
Process ID: 0
SubProtID: 0x1 Age: 00h01m07s
FlushedAge: 14h22m43s
TableID: 0xa OrigAs: 0
NibID: 0x25000001 LastAs: 0
AttrID: 0x1
BkAttrID: 0xffffffff Neighbor: 3001::1
Flags: 0x10060 OrigNextHop: 3001::1
Label: NULL RealNextHop: FE80::20C:29FF:FE4A:3873
SID: N/A
BkSID: N/A
The output shows that Router C communicates with network 1200::0/64 through the path Router C<—>Router B<—>Router A.
# Break down the path Router C<—>Router B<—>Router A and then display route 1200::0/64 on Router C.
Summary count : 1
Protocol: BGP4+
Process ID: 0
SubProtID: 0x1 Age: 00h00m57s
FlushedAge: 14h26m44s
NibID: 0x25000000 LastAs: 0
AttrID: 0x0
BkAttrID: 0xffffffff Neighbor: 2001::1
Flags: 0x10060 OrigNextHop: 2001::1
Label: NULL RealNextHop: FE80::20C:29FF:FE40:715
SID: N/A
BkSID: N/A
The output shows that Router C communicates with network 1200::0/64 through the path Router C<—>Router D<—>Router A.
Example: Configuring IPv6 BGP FRR
As shown in Figure 74, configure BGP FRR so that when Link B fails, BGP uses Link A to forward traffic.
Table 168 Configure IPv6 addresses for interfaces. (Details not shown.)
Table 169 Configure OSPFv3 in AS 200 to ensure connectivity among Router B, Router C, and Router D. (Details not shown.)
Table 170 Configure BGP connections:
# Configure Router A to establish EBGP sessions to Router B and Router C, and advertise network 1::/64.
[RouterA] bgp 100
[RouterA] router-id 1.1.1.1
[RouterA-bgp-default] peer 3001::2 as-number 200
[RouterA-bgp-default] peer 2001::2 as-number 200
[RouterA-bgp-default] address-family ipv6 unicast
[RouterA-bgp-default-ipv6] peer 3001::2 enable
[RouterA-bgp-default-ipv6] peer 2001::2 enable
[RouterA-bgp-default-ipv6] network 1:: 64
[RouterA-bgp-default-ipv6] quit
[RouterB] bgp 200
[RouterB] router-id 2.2.2.2
[RouterB-bgp-default] peer 3001::1 as-number 100
[RouterB-bgp-default] peer 3002::2 as-number 200
[RouterB-bgp-default] address-family ipv6 unicast
[RouterB-bgp-default-ipv6] peer 3001::1 enable
[RouterB-bgp-default-ipv6] peer 3002::2 enable
[RouterB-bgp-default-ipv6] peer 3002::2 next-hop-local
[RouterB-bgp-default-ipv6] quit
[RouterC] bgp 200
[RouterC] router-id 3.3.3.3
[RouterC-bgp-default] peer 2001::1 as-number 100
[RouterC-bgp-default] peer 2002::2 as-number 200
[RouterC-bgp-default] address-family ipv6 unicast
[RouterC-bgp-default-ipv6] peer 2002::2 enable
[RouterC-bgp-default-ipv6] peer 2002::2 next-hop-local
[RouterC-bgp-default-ipv6] quit
# Configure Router D to establish IBGP sessions to Router B and Router C, and advertise network 4::/64.
[RouterD] bgp 200
[RouterD-bgp-default] peer 3002::1 as-number 200
[RouterD-bgp-default] peer 2002::1 as-number 200
[RouterD-bgp-default] address-family ipv6 unicast
[RouterD-bgp-default-ipv6] peer 3002::1 enable
[RouterD-bgp-default-ipv6] peer 2002::1 enable
[RouterD-bgp-default-ipv6] network 4:: 64
[RouterD-bgp-default-ipv6] quit
Table 171 Configure preferred values so Link B is used to forward traffic between Router A and Router D:
[RouterA-bgp-default-ipv6] peer 3001::2 preferred-value 100
[RouterD-bgp-default-ipv6] peer 3002::1 preferred-value 100
Table 172 Configure BGP FRR:
# On Router A, create routing policy frr to set a backup next hop 2001::2 (Router C) for the route destined for 4::/64.
[RouterA] ipv6 prefix-list abc index 10 permit 4:: 64
[RouterA-route-policy] if-match ipv6 address prefix-list abc
[RouterA-route-policy] apply ipv6 fast-reroute backup-nexthop 2001::2
# Apply the routing policy to BGP FRR for BGP IPv6 unicast address family.
[RouterA] bgp 100
[RouterA-bgp-default-ipv6] fast-reroute route-policy frr
# On Router D, create routing policy frr to set a backup next hop 2002::1 (Router C) for the route destined for 1::/64.
[RouterD] ipv6 prefix-list abc index 10 permit 1:: 64
[RouterD-route-policy] if-match ipv6 address prefix-list abc
[RouterD-route-policy] apply ipv6 fast-reroute backup-nexthop 2002::1
[RouterD] bgp 200
[RouterD-bgp-default-ipv6] fast-reroute route-policy frr
# Display detailed information about the route to 4::/64 on Router A. The output shows the backup next hop for the route.
[RouterA] display ipv6 routing-table 4:: 64 verbose
Summary count : 1
Destination: 4::/64
Protocol: BGP4+ Process ID: 0
SubProtID: 0x2 Age: 00h00m58s
FlushedAge: 13h22m44s
TableID: 0xa OrigAs: 200
NibID: 0x25000003 LastAs: 200
AttrID: 0x3
BkAttrID: 0x4 Neighbor: 3001::2
Flags: 0x10060 OrigNextHop: 3001::2
Label: NULL RealNextHop: 3001::2
BkLabel: NULL BkNextHop: 2001::2
SID: N/A
BkSID: N/A
# Display detailed information about the route to 1::/64 on Router D. The output shows the backup next hop for the route.
[RouterD] display ipv6 routing-table 1:: 64 verbose
Summary count : 1
Destination: 1::/64
SubProtID: 0x1 Age: 00h03m24s
FlushedAge: 13h26m33s
TableID: 0xa OrigAs: 100
NibID: 0x25000003 LastAs: 100
AttrID: 0x4
BkAttrID: 0x5 Neighbor: 3002::1
Flags: 0x10060 OrigNextHop: 3002::1
Label: NULL RealNextHop: 3002::1
BkLabel: NULL BkNextHop: 2002::1
SID: N/A
BkSID: N/A
Configuring extended BGP features
Extended BGP feature configuration tasks at a glance
To configure extended BGP features, perform the following tasks:
· Configuring BGP policy accounting
¡ (Optional.) Configuring BGP LS route reflection
¡ (Optional.) Specifying an AS number and a router ID for BGP LS messages
¡ (Optional.) Configuring the route selection rules for BGP LS routes
¡ (Optional.) Performing manual soft-reset for BGP sessions of BGP LS or BGP-VPN LS address family
¡ (Optional.) Configuring the BGP Additional Paths feature for 6PE
¡ (Optional.) Controlling path selection for 6PE
¡ (Optional.) Controlling 6PE route advertisement and reception
¡ (Optional.) Tuning and optimizing 6PE
¡ (Optional.) Configuring 6PE route reflection
¡ (Optional.) Resetting 6PE connections
BGP policy accounting provides the following functionalities:
· Classifies IP traffic by BGP path attributes such as NEXT HOP, COMMUNITY, and AS_PATH.
· Assigns an index to each class of traffic.
· Collects statistics based on indexes.
BGP policy accounting supports the following traffic classification policies:
· Source IP address-based policy—Used to collect statistics for traffic from a specific source.
BGP searches routes to the source address, obtains the traffic index for the routes, and collects statistics for the traffic identified by the index.
· Destination IP address-based policy—Used to collect statistics for traffic destined to a specific address.
BGP searches routes to the destination address, obtains the traffic index for the routes, and collects statistics for the traffic identified by the index.
This feature is incompatible with fast forwarding as follows:
· When the source IP address-based policy is applied, fast forwarding does not work.
· When the destination IP address-based policy is applied, fast forwarding does not process traffic with a traffic index.
The IP traffic classification rule configured for BGP policy accounting takes effect if you perform the following tasks on the same device:
· Enable BGP policy accounting with the source keyword specified.
· Enable the QPPB feature with the destination keyword specified.
Table 173 Enter system view.
Table 174 Set a traffic index:
a. Configure a routing policy, and assign an index to the matching BGP routes by using the apply traffic-index command. For more information about the apply traffic-index command, see Layer 3—IP Routing Command Reference.
b. Configure BGP to use the routing policy. The network, import-route, aggregate, peer route-policy, and peer default-route-advertise commands can use a routing policy.
Table 175 Enter interface view.
Table 176 Enable BGP policy accounting on the interface.
bgp-policy accounting { input | output } * [ source ]
By default, BGP policy accounting is disabled.
If you do not specify the source keyword, the destination IP address-based policy applies.
Configuring BMP
BGP monitors only the real-time states of BGP sessions and BGP routes. It cannot directly monitor session state change and route update processes. To resolve this issue, configure the BGP monitoring protocol (BMP) feature. BMP enables a BGP router (BMP client) to send session state information of the specified peers to BMP servers for monitoring. The session status information includes peer relationship establishment and termination as well as routing information.
BMP benefits
· BMP uses TCP as its transmission layer protocol, which ensures the transmission reliability.
· As an extended feature of BGP, BMP collects the required information through a simple work mechanism.
· All BMP settings are configured on the BMP client, which simplifies the configuration and management.
· To implement BMP, the BMP client only needs to send BMP packets to the BMP server. It does not require any BMP packets from the BMP server, which barely affects the current network.
BMP components
BMP contains the following components:
· Client—Device configured with the BMP feature. You must specify the IP address and port number of the BMP server on the BMP client to enable them to establish a TCP connection. A BMP client can connect to multiple BMP servers.
· Server— Monitoring server.
· Monitored peer—Device being monitored. It must be a peer of the BMP client.
As shown in Figure 75, Device A, Device B, and Device C have established a BGP session with one another. You can configure BMP on Device B (BMP client) to enable the BMP server to monitor the running state changes and route updates of Device A and Device C (monitored peers).
BMP messages
BMP defines the following messages:
· Initiation—After establishing a TCP connection to the BMP server, the BMP client sends an initiation message to the BMP server to report its software version and vendor.
· Termination—Reports TCP connection down causes to the BMP server. After sending a termination message to the BMP server, the BMP client terminates the TCP connection and stops sending messages to the BMP server through the TCP connection.
· Peer Up Notification—Reports information about BGP sessions between the BMP client and monitored peers to the BMP server. A peer up notification contains information in the open messages exchanged with a monitored peer and TCP connection information. The BMP client will send a peer up notification for each BGP session in established state.
· Peer Down Notification—Reports BGP session down events and causes to the BMP server. The BMP client sends a peer down notification when the state of a monitored peer changes from Established to another value.
· Stats Reports—Reports BGP running statistics information to the BMP server. The statistics information includes number of routes discarded because of duplicated AS path attributes, number of routes received from peers, and number of duplicated up messages.
· Route Monitoring—Reports BGP routes (including initial, updated, and withdrawal routes) exchanged between the BMP client and monitored peers to the BMP server.
BMP mechanism
BMP works as follows:
Table 177 The BMP client establishes a TCP connection with the BMP server.
2. The BMP client sends an initiation message to the BMP server to advertise its information.
3. The BMP client sends a peer up notification and a route monitoring message to the BMP server to advertise the initial state and routing information of the monitored peer.
4. The BMP client sends peer up notifications, peer down notifications, route monitoring messages, and stats reports to the BMP server to report state changes and route updates of the monitored peers.
5. The BMP client sends a termination message to the BMP server and terminates the TCP connection to terminate the monitoring.
BMP configuration tasks at a glance
To configure BMP, perform the following tasks on the BMP client:
· Establishing a TCP connection between the BMP client and BMP server
· Enabling a BMP server to monitor a peer or peer group
· Sending routes to the BMP server
· Sending statistics information to the BMP server
2. Create a BMP server and enter BMP server view.
bmp server server-number
3. Configure an IP address and port number for the BMP server.
server address { ipv4-address | ipv6-address } port port-number
By default, no IP address and port number are configured for the BMP server.
4. (Optional.) Specify a VPN instance for the BMP server.
server vpn-instance vpn-instance-name
By default, no VPN instance is specified for a BMP server. A BMP server belongs to the public network.
5. (Optional.) Specify the source interface of TCP connections to the BMP server.
server connect-interface interface-type interface-number
By default, BGP uses the primary IPv4 or IPv6 address of the output interface in the optimal route to the BMP server as the source address of TCP connections to the BMP server.
For a BMP server, this command does not take effect if the VPN instance of the specified interface is different from that specified by the server vpn-instance command.
6. (Optional.) Specify the source address of TCP connections to the BMP server.
server source-address { ipv4-address | ipv6-address }
If you execute both this command and the server connect-interface command for a BMP server, the configuration of this command takes effect.
7. (Optional.) Specify the authentication mode and key for the local device to establish TCP connections to the BMP server.
server password { keychain keychain-name | md5 { cipher | simple } string }
By default, the local device establishes TCP connections to the BMP server without authentication.
You can execute any of the following commands to enable a BMP server to monitor BGP peers:
· Execute the peer bmp server command to enable the specified BMP server to monitor the specified peer or peer group.
· Execute the bmp server monitor current-instance command to enable the specified BMP server to monitor all peers in the current instance.
· Execute the bmp server monitor all-vpn-instance command to enable the specified BMP server to monitor all peers in all BGP-VPN instances.
For a peer, the following rules apply:
· The BMP server specified by the peer bmp server command takes precedence over that specified by the bmp server monitor current-instance command.
· The BMP server specified by the bmp server monitor current-instance command takes precedence over that specified by the bmp server monitor all-vpn-instance command.
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
3. Enable a BMP server to monitor a peer or peer group. Choose the options to configure as needed:
¡ Enable the specified BMP server to monitor the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bmp server server-number-list
By default, a BMP server cannot monitor a peer or peer group.
¡ Enable the specified BMP server to monitor all peers in the current instance.
bmp server server-number monitor current-instance
By default, a BMP server cannot monitor the peers in the current instance.
¡ Enable the specified BMP server to monitor all peers in all BGP-VPN instances.
bmp server server-number monitor all-vpn-instance
By default, a BMP server cannot monitor the peers in a BGP-VPN instance.
This command is not supported in BGP-VPN instance view.
For a peer or peer group, the following rules apply when BGP determines the type of routes to send to the BMP server:
· The route type specified by the peer route-mode command takes precedence over that specified by the bmp server monitor current-instance route-mode command.
· The route type specified by the bmp server monitor current-instance route-mode command takes precedence over that specified by the bmp server monitor all-vpn-instance route-mode command.
· The route type specified by the bmp server monitor all-vpn-instance route-mode command takes precedence over that specified by the route-mode adj-rib-in or route-mode adj-rib-out command.
You can execute the route-mode loc-rib command to configure BGP to send the optimal routes in the routing table to the BMP server.
After establishing a TCP connection to a BMP server, a BMP client reports BGP route information the BMP server. If the BMP client establishes TCP connections to a large number of BMP servers, it repeatedly sends BGP route information to those BMP servers, continuously consuming system resources.
To help the BMP client save system resources, execute the bmp server notify delay command to delay the BMP client in reporting BGP route information to BMP servers. When the device establishes a TCP connection to the first BMP server, its starts the specified delay timer.
· Before the delay timer expires, the BMP client does not send BGP route information to any BMP servers, regardless of the quantity of established BMP server connections.
· After the delay timer expires, the BMP client sends BGP route information to all connected BMP servers.
In networks with many BMP servers, use the bmp server notify delay command to increase the delay time in reporting BGP route information for BMP clients. A larger delay timer helps a BMP client bulk report BGP route information to all connected BMP servers only once, thus minimizing system resource consumption.
When BGP sends the routes received from monitored peers and peer groups to the BMP server without route filtering, route information integrity cannot be ensured. To ensure that BGP sends complete route information to the BMP server, perform one of the operations:
· Execute the peer keep-all-routes command for those monitored peers and peer groups.
· Execute the keep-all-routes command in BGP instance view.
2. Enter BMP server view.
3. (Optional.) Enable BGP to send routes to the BMP server globally. Choose the following options to configure as needed:
¡ Enable BGP to send routes advertised to all the monitored peers and peer groups to the BMP server.
route-mode adj-rib-out [ pre-policy | post-policy | both ]
By default, BGP does not send routes advertised to a monitored peer or peer group to the BMP server.
¡ Enable BGP to send routes received from all the monitored peers and peer groups to the BMP server.
route-mode adj-rib-in [ pre-policy | post-policy | both ]
By default, BGP does not send routes received from a monitored peer or peer group to the BMP server.
¡ Configure BGP to send the optimal routes in the routing table to the BMP server.
route-mode loc-rib [ additional-paths ]
route-mode loc-rib { vpn-instance-all | vpn-insatance vpn-instance-name } { ipv4 [ labeled-unicast | unicast ] | ipv6 [ unicast ] } [ additional-paths ]
route-mode loc-rib { ipv4 [ labeled-unicast | unicast ] | ipv6 [ unicast ] | vpnv4 | vpnv6 | evpn } [ additional-paths ]
By default, BGP does not send the optimal routes in the routing table to the BMP server.
With this feature configured, BGP sends all routes to the BMP server first. If routes update later, BGP sends only the optimal routes to the server.
6. Enable BGP to send routes exchanged with a monitored peer or peer group to the BMP server. Choose the following options to configure as needed:
¡ Enable BGP to send routes exchanged with the specified monitored peer or peer group to the BMP server.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } *
¡ Enable BGP to send routes exchanged with all the monitored peers and peer groups in the current instance to the BMP server.
bmp server server-number monitor current-instance route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } *
¡ Enable BGP to send routes exchanged with all the monitored peers and peer groups in all BGP-VPN instances to the BMP server.
bmp server server-number monitor all-vpn-instance route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } *
By default, BGP determines whether to send routes exchanged with a peer or peer group to the BMP server based on the following configurations:
¡ Configuration of the route-mode adj-rib-in command in BMP server view.
¡ Configuration of the route-mode adj-rib-out command in BMP server view.
7. (Optional.) Send route trace information to the BMP server.
bmp-route-trace { ip-prefix-list ipv4-prefix-list-name | ipv6-prefix-list ipv6-prefix-list-name } [ rd-list rd-list-number ]
By default, the device does not send route trace information to the BMP server.
¡ The feature can be configured only in BGP instance view.
8. (Optional.) Set the delay time for reporting BGP route information to BMP servers.
bmp server notify delay delay-value
By default, a BMP client waits 15 seconds before reporting BGP route information to BMP servers.
Configuring the BMP client to send notifications with mode flags to the BMP server
Perform this task to configure the BMP client to send peer up/down notifications with the following flags:
· Adj-RIB-In—The BMP client sends routes received from monitored peers to the BMP server.
· Adj-RIB-Out—The BMP client sends routes advertised to monitored peers to the BMP server.
· pre-policy—The BMP client sends routes to the BMP server without filtering.
· post-policy—The BMP client sends routes to the BMP server after filtering.
By default, the BMP client sends peer up/down notifications with the Adj-RIB-In and pre-policy flags to the BMP server after you configure this feature.
· After you add a route sending mode by executing the route-mode adj-rib-in, route-mode adj-rib-out, or peer route-mode command, the BMP client will send peer up notifications with the new mode flag to the BMP server.
· After you delete the route sending mode by executing the route-mode adj-rib-in, route-mode adj-rib-out, or peer route-mode command, the BMP client will send peer down notifications with the new mode flag to the BMP server.
For example, if you execute the route-mode adj-rib-out post-policy command after executing the route-mode adj-rib-out pre-policy command, the BMP client sends routes to the BMP server after filtering. The BMP client will send both peer up and peer down notifications with the new mode flags to the BMP server.
3. Configure the BMP client to send notifications with mode flags to the BMP server. Choose a minimum of one task.
¡ Configure the BMP client to send peer up notifications with mode flags to the BMP server.
pu-monitor-mode enable
¡ Configure the BMP client to send peer down notifications with mode flags to the BMP server.
pd-monitor-mode enable
By default, the BMP client sends peer up/down notifications without mode flags to the BMP server.
The BMP client uses stats reports to report statistics information to the BMP server. Perform this task to set the interval at which the BMP client sends stats reports to the BMP server.
To ensure that BGP sends correct route statistics information to the BMP server after this feature is configured, perform one of the operations:
· Execute the peer keep-all-routes command for all monitored peers and peer groups.
3. Set the interval at which the BMP client sends statistics information to the BMP server.
statistics-interval value
By default, the BMP client does not send statistics information to the BMP server.
Applying an SSL client-policy to the TCP connection to the BMP server
This feature secures the TCP connection to a BMP server by using SSL to protect BMP packets.
When you configure this feature in the view of a BMP server, make sure the BMP server is SSL-capable. With this feature configured, the device encrypts the BMP packets sent to the BMP server. If the BMP server does not support SSL, it cannot decrypt the packets.
1. Enter system view.
3. Apply an SSL client policy to the TCP connection to the BMP server.
ssl client-policy policy-name
By default, no SSL policy is applied to the TCP connection to a BMP server.
Configuring BGP LS
About BGP LS
Traditional BGP focuses on the propagation of routing information and lacks detailed understanding of network topology and link conditions. BGP Link State (LS) is a feature that collects and reports network topology information and link state information to the controller. This feature helps network administrators better understand and manage network links. Although IGPs can report network topology information and link state information to the controller, they have the following disadvantages:
· The controllers need to support those IGPs and their algorithms, which requires higher compute performance.
· IGPs cannot collect information across different domains.
· Different IGPs report information to the controller separately. It is complex for the controller to process the reported information.
With BGP LS configured, BGP can report the link state and topology information collected by IGPs to the controller, regardless of the IGP capabilities of the controller. In addition, BGP supports cross-domain deployment. All BGP LS-enabled devices can maintain a complete link state database with the route advertisement mechanism of BGP. The topology information reported to the controller will also be complete.
The link state and topology information collected through BGP LS helps achieve the following purposes:
· Topology maintenance and calculation: This information can be used for calculating the shortest paths and building network maps.
· Path selection optimization: Network administrators can optimize path selection results based on this information.
· Link quality detection: Network administrators can quickly detect link failures by using this information.
· Support for advanced applications: This information provides support for multiple tasks, such as traffic engineering, network planning, and resource allocation.
BGP LS extensions
BGP places network topology and link state information in a series of NLRIs, and adds those NLRIs into the MP_REACH_NLRI and MP_UNREACH_NLRI attributes of BGP UPDATE messages. This approach allows BGP LS peers to exchange topology and link state information.
The BGP LS address family and the BGP-VPN LS address family must belong to the same BGP instance.
Configuring basic BGP LS
3. Specify an AS number for an LS peer or peer group.
peer { { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } | group-name } as-number as-number
By default, no AS number is specified.
4. Create and enter BGP LS address family view or BGP-VPN LS address family view.
¡ Enter BGP LS address family view.
address-family link-state
¡ Enter BGP-VPN LS address family view.
address-family link-state vpn
5. Enable the device to exchange LS information with the peer or peer group.
By default, the device cannot exchange LS information with the peer or peer group.
6. (Optional.) Set the maximum number of routes that can be received from the specified peer or peer group.
By default, no limit is set for the number of routes that can be received from a peer or peer group.
7. (Optional.) Set the optimal route selection delay timer for BGP LS routes.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
8. (Optional.) Set the delay timer for responding to next hop recursion result changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to next hop recursion result changes immediately.
9. (Optional.) Reference a routing policy to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
10. (Optional.) Reference a routing policy to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name import
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
3. Enter BGP LS address family view or BGP-VPN LS address family view.
4. Configure BGP LS route reflection.
¡ Configure the device as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
¡ (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
This command can reduce the number of IBGP connections in an AS.
¡ (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
The following issues might occur during LS information collection:
· When two devices in the same AS send the same LS information to the controller, the controller determines the information as different because the LS messages from the two devices have different router IDs. As a result, the controller cannot use the information for unified path calculation.
· After two devices in different ASs complete LS information collection, the controller must perform traffic scheduling based on the network topologies of the two ASs. Because the AS numbers in the LS information sent by the two devices are different, the controller cannot use the information for unified path calculation.
To resolve these issues, perform this task to specify an AS number and a router ID for BGP LS messages.
After you configure this feature in BGP LS address family view, the feature takes effect in both the BGP LS and BGP-VPN LS address families.
3. Enter BGP LS address family view.
4. Specify an AS number and a router ID for BGP LS messages.
domain-distinguisher as-number:router-id
By default, the AS number and router ID of the current BGP process are used.
Preferring routes learned from the specified peer or peer group during optimal route selection
3.
4. Enter BGP LS address family view or BGP-VPN LS address family view.
5. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
By default, routes learned from a peer or peer group do not take precedence over routes learned from other peers or peer groups.
Preferring BGP routes of a specific next hop IP type
4. Prefer BGP routes of a specific next hop IP type during optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hops during optimal route selection.
3. Enable BGP route refresh.
¡ Enable BGP route refresh for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
¡ Enable the BGP route refresh, multi-protocol extension, and 4-byte AS number features for a peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
By default, the BGP route refresh, multi-protocol extension, and 4-byte AS number features are enabled.
4. Perform manual soft-reset for BGP sessions of BGP LS or BGP-VPN LS address family:
a. Return to system view.
b. Return to user view.
c. Perform manual soft-reset for BGP sessions of BGP LS address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state [ vpn-instance vpn-instance-name ]
d. Perform manual soft-reset for sessions of BGP-VPN LS address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state vpn [ vpn-instance vpn-instance-name ]
Configuring 6PE
About 6PE
IPv6 provider edge (6PE) is a transition technology that uses MPLS to connect sparsely populated IPv6 networks through an existing IPv4 backbone network. It is an efficient solution for ISP IPv4/MPLS networks to provide IPv6 traffic switching capability.
Figure 76 Network diagram for 6PE
6PE mainly performs the following operations:
· 6PE assigns a label to IPv6 routing information received from a CE router, and sends the labeled IPv6 routing information to the peer 6PE device through an MP-BGP session. The peer 6PE device then forwards the IPv6 routing information to the attached customer site.
· 6PE provides tunnels over the IPv4 backbone so the IPv4 backbone can forward packets for IPv6 networks. The tunnels can be GRE tunnels, MPLS LSPs, or MPLS TE tunnels.
· Upon receiving an IPv6 packet, 6PE adds an inner tag (corresponding to the IPv6 packet) and then an outer tag (corresponding to the public network tunnel) to the IPv6 packet. Devices in the IPv4 backbone network forwards the packet based on the outer tag. When the peer 6PE device receives the packet, it removes the outer and inner tags and forwards the original IPv6 packet to the attached customer site.
To implement exchange of IPv6 routing information, you can configure IPv6 static routing, an IPv6 IGP, or IPv6 BGP between CE and 6PE devices.
For more information about MPLS, MPLS TE, CE, and P, see MPLS Configuration Guide. For more information about GRE, see Layer 3—IP Services Configuration Guide.
Before you configure 6PE, perform the following tasks:
· Establish tunnels in the IPv4 backbone network (see Layer 3—IP Services Configuration Guide).
· Configure basic MPLS on 6PE devices (see MPLS Configuration Guide).
· Configure BGP on 6PE devices so that they can advertise tagged IPv6 routing information through BGP sessions. The following tasks describe only BGP configurations on 6PE devices.
Configuring basic 6PE
2. Enter BGP instance view.
3. Specify a 6PE peer or peer group and its AS number.
By default, no 6PE peer is specified.
4. Enter BGP IPv6 unicast address family view.
5. Enable BGP to exchange IPv6 unicast routing information with the 6PE peer or peer group.
By default, BGP cannot exchange IPv6 unicast routing information with a 6PE peer or peer group.
6. Enable BGP to exchange labeled IPv6 routes with the 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
By default, BGP cannot exchange labeled IPv6 routes with a 6PE peer or peer group.
3. Enter BGP IPv6 unicast address family view.
4. Configure the BGP Additional Paths capabilities for a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP Additional Paths capabilities are configured for a 6PE peer or peer group.
5. Set the maximum number of Add-Path optimal routes that can be advertised to a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, BGP does not advertise Add-Path optimal routes to a 6PE peer or peer group.
4. Advertise COMMUNITY attribute to a 6PE peer or peer group.
By default, the COMMUNITY attribute is not advertised.
5. Advertise extended community attribute to a 6PE peer or peer group.
By default, the extended community attribute is not advertised.
6. Advertise large community attribute to a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise-large-community
By default, the large community attribute is not advertised.
7. Remove or replace private AS numbers in BGP updates sent to a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ force [ include-peer-as ] ] keep-local-as
By default, BGP updates sent to a 6PE peer or peer group can carry both public and private AS numbers.
8. Specify a preferred value for routes received from a 6PE peer or peer group.
By default, the preferred value for routes received from a 6PE peer or peer group is 0.
9. Prefer routes learned from the specified 6PE peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] } high-priority [ preferred ]
10. Enable BGP to add the link bandwidth attribute to routes received from a 6PE peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from a 6PE peer or peer group.
11. Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group.
12. Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
4. Advertise a default route to a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise [ route-policy route-policy-name ] [ conditional-policy route-policy-name ]
By default, no default route is advertised to a 6PE peer or peer group.
5. Configure route filtering policies.
¡ Specify an AS path list to filter routes advertised to or received from a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
By default, no AS path list is specified.
¡ Specify an IPv6 ACL to filter routes advertised to or received from a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } { export | import }
By default, no IPv6 ACL is specified.
¡ Specify an IPv6 prefix list to filter routes advertised to or received from a 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } prefix-list ipv6-prefix-list-name { export | import }
By default, no IPv6 prefix list is specified.
¡ Specify a routing policy to filter routes advertised to or received from a 6PE peer or peer group.
By default, no routing policy is specified.
6. Save all routes from a 6PE peer or peer group.
By default, routes from a 6PE peer or peer group are not saved.
7. Set the maximum number of routes that BGP can receive from a 6PE peer or peer group.
By default, the number of routes that BGP can receive from a 6PE peer or peer group is not limited.
8. Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
4. Allow the local AS number to appear in routes from a 6PE peer or peer group and specify the repeat times.
By default, the local AS number is not allowed to appear in routes from a 6PE peer or peer group.
4. Configure the device as a route reflector and a 6PE peer or peer group as a client.
To reset 6PE connections, execute one of the following commands in user view:
· Soft-reset a BGP 6PE connection.
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ]
· Reset a BGP 6PE connection.
reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ]
CAUTION: A reset operation terminates BGP sessions for a short period of time. |
Display and maintenance commands for extended BGP features
Displaying BGP
Task |
Command |
Display BGP policy accounting information for IPv4 traffic. |
display bgp-policy ip statistics { input | output } [ interface interface-type interface-number ] |
Display BMP server information. |
display bgp [ instance instance-name ] bmp server server-number |
Display information about BGP peers monitored by the specified BMP server for the specified BGP instance. |
display bgp [ instance instance-name ] bmp server server-number monitor-peer all display bgp [ instance instance-name ] bmp server server-number monitor-peer [ vpn-instance vpn-instance-name ] ipv4 { ipv4-address | ipv6-address } |
Display BGP route trace information. |
display bgp [ instance instance-name ] route-trace { ipv4-address { mask-length | mask } | ipv6-address prefix-length } [ route-distinguisher route-distinguisher ] |
Task |
Command |
Display BGP policy accounting information for IPv6 traffic. |
display bgp-policy ipv6 statistics { input | output } [ interface interface-type interface-number ] |
Display BGP peer or peer group information. |
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ] |
Display BGP IPv6 unicast routing information. |
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] |
display bgp [ instance instance-name ] bmp server server-number monitor-peer all display bgp [ instance instance-name ] bmp server server-number monitor-peer [ vpn-instance vpn-instance-name ] ipv6 { ipv4-address | ipv6-address } |
Display incoming labels for BGP IPv6 unicast routes. |
display bgp routing-table ipv6 unicast inlabel |
Display outgoing labels for BGP IPv6 unicast routes. |
display bgp routing-table ipv6 unicast outlabel |
Task |
Command |
Displaying BGP (LS address family)
Task |
Command |
Display BGP LS peer group information. |
display bgp [ instance instance-name ] group link-state [ vpn ] [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display BGP LS information. |
display bgp [ instance instance-name ] link-state [ vpn [ route-distinguisher route-distinguisher ] ] [ vpn-instance vpn-instance-name ] ls-prefix [ advertise-info ] display bgp [ instance instance-name ] link-state [ vpn [ route-distinguisher route-distinguisher ] ] [ vpn-instance vpn-instance-name ] [ peer { ipv4-address | ipv6-address } { advertised | received } ] [ statistics ] [ type { node | link | ipv4-prefix | ipv6-prefix | te-policy | srv6-sid } ] display bgp [ instance instance-name ] link-state[ vpn [ route-distinguisher route-distinguisher ] ] [ vpn-instance vpn-instance-name ] [ ls-prefix [ advertise-info ] | peer { ipv4-address | ipv6-address } { advertised | received } [ statistics ] | statistics ] display bgp [ instance instance-name ] link-state [ vpn-instance vpn-instance-name ] [ color color-value end-point { ipv4 ipv4-address | ipv6 ipv6-address } ] display bgp [ instance instance-name ] link-state time-range min-time max-time |
Display BGP LS peer or peer group information. |
display bgp [ instance instance-name ] peer link-state [ vpn ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ] |
Display BGP LS address family update group information. |
display bgp [ instance instance-name ] update-group[ vpn ] [ vpn-instance vpn-instance-name ] link-state [ ipv4-address | ipv6-address ] |
Display SR-MPLS prefix SID information about the BGP LS routes that describe IPv4 reachable prefixes. |
display bgp [ instance instance-name ] link-state [ vpn [ route-distinguisher route-distinguisher ] ] [ vpn-instance vpn-instance-name ] [ peer { ipv4-address | ipv6-address } { advertised | received } ] ls-prefix prefix-sid |
Display SID list information about the BGP LS routes that describe SR-MPLS TE policy/SRv6 TE policy information. |
display bgp [ instance instance-name ] link-state [ vpn-instance vpn-instance-name ] [ peer { ipv4-address | ipv6-address } { received | advertised } ] ls-prefix segment-list |
Display algorithm information about the BGP LS routes that describe LS node information. |
display bgp [ instance instance-name ] link-state [ vpn [ route-distinguisher route-distinguisher ] ] [ vpn-instance vpn-instance-name ] [ peer { ipv4-address | ipv6-address } { received | advertised } ] ls-prefix sr-algorithm |
Display flexible algorithm information about the BGP LS routes that describe LS node information. |
display bgp [ instance instance-name ] link-state [ vpn [ route-distinguisher route-distinguisher ] ] [ vpn-instance vpn-instance-name ] [ peer { ipv4-address | ipv6-address } { received | advertised } ] ls-prefix flexible-algorithm-definition |
Displaying BGP (VPNv4 address family)
Task |
Command |
display bgp [ instance instance-name ] bmp server server-number monitor-peer all display bgp [ instance instance-name ] server server-number monitor-peer vpnv4 { ipv4-address | ipv6-address } display bgp [ instance instance-name ] bmp server server-number monitor-peer vpn-instance vpn-instance-name vpnv4 ipv4-address |
Displaying BGP (VPNv6 address family)
Task |
Command |
display bgp [ instance instance-name ] bmp server server-number monitor-peer all display bgp [ instance instance-name ] bmp server server-number monitor-peer vpnv6 { ipv4-address | ipv6-address } |
Displaying BGP (EVPN address family)
Task |
Command |
display bgp [ instance instance-name ] bmp server server-number monitor-peer all display bgp [ instance instance-name ] bmp server server-number monitor-peer l2vpn evpn { ipv4-address | ipv6-address } |
Resetting BGP sessions
Execute reset commands in user view.
Task |
Command |
Reset BGP sessions for LS address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } link-state [ vpn ] |
Clearing BGP information
Task |
Command |
Reset the BMP server connection and clear statistics information. |
reset bgp [ instance instance-name ] bmp server { server-number | all } |
Clear BMP server statistics. |
reset bgp [ instance instance-name ] bmp server server-number statistics |
Clear BGP policy accounting information. |
reset bgp-policy { ip | ipv6 } statistics [ input | output ] [ interface interface-type interface-number ] |
Extended IPv4 BGP feature configuration examples
Example: Configuring BGP LS
As shown in Figure 77, all routers run BGP. Run IBGP between Router A and Router B, between Router B and Router C, and between Router B and Router D.
Configure Router B as a route reflector with client Router A to allow Router A to learn LS information advertised by Router C and Router D.
Table 178 Configure IP addresses for interfaces and configure OSPF on Router C and Router D. (Details not shown.)
Table 179 Configure BGP connections:
# Configure Router A.
[RouterA] bgp 100
[RouterA-bgp-default] peer 192.1.1.2 as-number 100
[RouterA-bgp-default] address-family link-state
[RouterA-bgp-default-ls] peer 192.1.1.2 enable
[RouterA-bgp-default-ls] quit
# Configure Router B.
<RouterB> system-view
[RouterB] bgp 100
[RouterB-bgp-default] peer 192.1.1.1 as-number 100
[RouterB-bgp-default] peer 193.1.1.1 as-number 100
[RouterB-bgp-default] peer 194.1.1.1 as-number 100
[RouterB-bgp-default] address-family link-state
[RouterB-bgp-default-ls] peer 192.1.1.1 enable
[RouterB-bgp-default-ls] peer 193.1.1.1 enable
[RouterB-bgp-default-ls] peer 194.1.1.1 enable
[RouterB-bgp-default-ls] quit
# Configure Router C.
<RouterC> system-view
[RouterC] bgp 100
[RouterC-bgp-default] peer 193.1.1.2 as-number 100
[RouterC-bgp-default] address-family link-state
[RouterC-bgp-default-ls] peer 193.1.1.2 enable
[RouterC-bgp-default-ls] quit
[RouterC] ospf
[RouterC-ospf-1] distribute bgp-ls
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 0.0.0.0 0.0.0.0
[RouterC-ospf-1] quit
# Configure Router D.
[RouterD] bgp 100
[RouterD-bgp-default] peer 194.1.1.2 as-number 100
[RouterD-bgp-default] address-family link-state
[RouterD-bgp-default-ls] peer 194.1.1.2 enable
[RouterD-bgp-default-ls] quit
[RouterD] ospf
[RouterD-ospf-1] distribute bgp-ls
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 0.0.0.0 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
Table 180 Configure Router B as the route reflector.
[RouterB] bgp 100
[RouterB-bgp-default-ls] peer 192.1.1.1 reflect-client
# Verify that Router A has learned LS information advertised by Router C and Router D.
[RouterA] display bgp link-state
Total number of routes: 4
BGP local router ID is 192.1.1.1
a - additional-path
Prefix codes: E link, V node, T4 IPv4 route, T6 IPv6 route, SD SRv6 SID desc
u/U unknown,
I Identifier, N local node, R remote node, L link, P prefix,
L1/L2 ISIS level-1/level-2, O OSPF, O3 OSPFv3,
D direct, S static, B BGP, SS SRv6 SID,
a area-ID, l link-ID, t topology-ID, s ISO-ID,
c confed-ID/ASN, b bgp-identifier, r router-ID,
i if-address, n peer-address, o OSPF Route-type, p IP-prefix
d designated router address/interface, ID Link Descriptor Identifer
i Network : [V][O][I0x0][N[c100][b193.1.1.1][a0.0.0.0][r193.1.1.1]]/376
NextHop : 193.1.1.1 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED :
Path/Ogn: i
i Network : [V][O][I0x0][N[c100][b194.1.1.1][a0.0.0.0][r194.1.1.1]]/376
NextHop : 194.1.1.1 LocPrf : 100
MED :
Path/Ogn: i
i Network : [T4][O][I0x0][N[c100][b193.1.1.1][a0.0.0.0][r193.1.1.1]][P[o0x1][p193.1.1.0/24]]/480
MED :
Path/Ogn: i
i Network : [T4][O][I0x0][N[c100][b194.1.1.1][a0.0.0.0][r194.1.1.1]][P[o0x1][p194.1.1.0/24]]/480
MED :
Path/Ogn: i
Extended IPv6 BGP feature configuration examples
Example: Configuring 6PE
Use 6PE to connect two isolated IPv6 networks over an IPv4/MPLS network.
· The ISP uses OSPF as the IGP.
· PE 1 and PE 2 are edge devices of the ISP, and establish an IPv4 IBGP connection between them.
· CE 1 and CE 2 are edge devices of the IPv6 networks, and they connect the IPv6 networks to the ISP.
· A CE and a PE exchange IPv6 packets through IPv6 static routing.
Figure 78 Network diagram
Table 181 Configure IPv6 addresses and IPv4 addresses for interfaces. (Details not shown.)
Table 182 Configure PE 1:
# Enable LDP globally, and configure the LSP generation policy.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] lsp-trigger all
[PE1-ldp] quit
# Enable MPLS and LDP on Ten-GigabitEthernet 0/0/16.
[PE1] interface ten-gigabitethernet 0/0/16
[PE1-Ten-GigabitEthernet0/0/16] mpls enable
[PE1-Ten-GigabitEthernet0/0/16] mpls ldp enable
[PE1-Ten-GigabitEthernet0/0/16] quit
# Configure IBGP, enable the peer's 6PE capabilities, and redistribute IPv6 direct and static routes.
[PE1] bgp 65100
[PE1-bgp-default] router-id 2.2.2.2
[PE1-bgp-default] peer 3.3.3.3 as-number 65100
[PE1-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[PE1-bgp-default] address-family ipv6
[PE1-bgp-default-ipv6] import-route direct
[PE1-bgp-default-ipv6] import-route static
[PE1-bgp-default-ipv6] peer 3.3.3.3 enable
[PE1-bgp-default-ipv6] peer 3.3.3.3 label-route-capability
[PE1-bgp-default-ipv6] quit
[PE1-bgp-default] quit
# Configure the static route to CE 1.
[PE1] ipv6 route-static 1::1 128 10::1
# Configure OSPF for the ISP.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE1-ospf-1] quit
Table 183 Configure PE 2:
<PE2> system-view
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-mpls-ldp] lsp-trigger all
[PE2-mpls-ldp] quit
[PE2] interface ten-gigabitethernet 0/0/16
[PE2-Ten-GigabitEthernet0/0/16] mpls enable
[PE2-Ten-GigabitEthernet0/0/16] mpls ldp enable
[PE2-Ten-GigabitEthernet0/0/16] quit
[PE2] bgp 65100
[PE2-bgp-default] router-id 3.3.3.3
[PE2-bgp-default] peer 2.2.2.2 as-number 65100
[PE2-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE2-bgp-default] address-family ipv6
[PE2-bgp-default-ipv6] import-route direct
[PE2-bgp-default-ipv6] import-route static
[PE2-bgp-default-ipv6] peer 2.2.2.2 enable
[PE2-bgp-default-ipv6] peer 2.2.2.2 label-route-capability
[PE2-bgp-default-ipv6] quit
[PE2-bgp-default] quit
# Configure the static route to CE 2.
[PE2] ipv6 route-static 4::4 128 20::1
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE2-ospf-1] quit
Table 184 Configure a static route, with PE 1 as the default next hop.
<CE1> system-view
[CE1] ipv6 route-static :: 0 10::2
Table 185 Configure a static route on CE 2, with PE 2 as the default next hop.
<CE2> system-view
[CE2] ipv6 route-static :: 0 20::2
# Display the IPv6 BGP routing tables on PE 1 and PE 2. The output shows that each of them has two IPv6 network routes. The following shows the output on PE 1:
[PE1] display bgp routing-table ipv6
Total number of routes: 5
a - additional-path
* > Network : 1::1 PrefixLen : 128
NextHop : 10::1 LocPrf :
MED : 0
Path/Ogn: ?
* >i Network : 4::4 PrefixLen : 128
NextHop : ::FFFF:3.3.3.3 LocPrf : 100
PrefVal : 0 OutLabel : 1279
MED : 0
Path/Ogn: ?
* > Network : 10:: PrefixLen : 64
NextHop : :: LocPrf :
MED : 0
Path/Ogn: ?
* > Network : 10::2 PrefixLen : 128
NextHop : ::1 LocPrf :
MED : 0
Path/Ogn: ?
* >i Network : 20:: PrefixLen : 64
PrefVal : 0 OutLabel : 1278
MED : 0
Path/Ogn: ?
# Verify that CE 1 can ping the IPv6 address 4::4 (loopback interface address) of CE 2. (Details not shown.)
