- 06-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-EIGRP configuration
- 07-BGP configuration
- 08-Policy-based routing configuration
- 09-IPv6 static routing configuration
- 10-RIPng configuration
- 11-OSPFv3 configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
- 14-DCN configuration
| 00-Preface | 110.50 KB |
Preface
This configuration guide covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Support for slots varies by device model. All slot-related descriptions in this documentation are for illustration only. It is normal that the slots in the examples differ from those on your device. On a device to which this documentation applies, the slot-number argument in a command represents the entire device and is fixed at 0. The command applies to the entire device regardless of whether the slot number is specified.
Documentation feedback
We appreciate your comments.
