18-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)-6W90218-Network Management and Monitoring Configuration Guide
20-gRPC configuration
20-gRPC configuration 248.00 KB
Configuring gRPC
About gRPC
gRPC is an open source remote procedure call (RPC) system initially developed at Google. It uses HTTP 2.0 and provides network device configuration and management methods that support multiple programming languages.
gRPC protocol stack layers
Table 1 describes the gRPC protocol stack layers.
Table 1 gRPC protocol stack layers
Layer
Content layer
Defines the data of the service module.
Two peers must notify each other of the data models that they are using.
Protocol buffer encoding layer
Encodes data by using the protocol buffer code format.
gRPC layer
Defines the protocol interaction format for remote procedure calls.
HTTP 2.0 layer
Carries gRPC.
TCP layer
Provides connection-oriented reliable data links.
Network architecture
As shown in Figure 1, the gRPC network uses the client/server model. It uses HTTP 2.0 for packet transport.
Figure 1 gRPC network architecture
The gRPC network uses the following mechanism:
1.     The gRPC server listens to connection requests from clients at the gRPC service port.
2.     A user runs the gRPC client application to log in to the gRPC server, and uses methods provided in the .proto file to send requests.
3.     The gRPC server responds to requests from the gRPC client.
The device can act as the gRPC server or client.
Telemetry technology based on gRPC
Telemetry is a remote data collection technology for monitoring device performance and operating status. H3C telemetry technology uses gRPC to push data from the device to the collectors on the NMSs. As shown in Figure 2, after a gRPC connection is established between the device and NMSs, the NMSs can subscribe to data of modules on the device.
Figure 2 Telemetry technology based on gRPC
Telemetry modes
The device supports the following telemetry modes:
·     Dial-in mode—The device acts as a gRPC server and the collectors act as gRPC clients. A collector initiates a gRPC connection to the device to subscribe to device data.
·     Dial-out mode—The device acts as a gRPC client and the collectors act as gRPC servers. The device initiates a gRPC connection to the collectors and pushes subscribed device data to the collectors.
Protocols
RFC 7540, Hypertext Transfer Protocol version 2 (HTTP/2)
Restrictions and guidelines: gRPC configuration
Disabling the gRPC service deletes all gRPC settings.
Configuring the gRPC dial-in mode
gRPC dial-in mode configuration tasks at a glance
To configure the gRPC dial-in mode, perform the following tasks:
1.     (Optional.) Specifying the PKI domain for SSL communication with collectors
2.     Configuring the gRPC service
3.     Configuring a gRPC user
4.     (Optional.) Enabling gRPC logging in dial-in mode
To implement SSL communication with collectors, you must specify a PKI domain. For more information about PKI domain configuration, see PKI configuration in Security Configuration Guide.
2.     Specify the PKI domain for SSL communication with collectors.
grpc pki domain domain-name
By default, no PKI domain is specified for SSL communication with collectors.
2.     Enable the gRPC service.
grpc enable
By default, the gRPC service is disabled.
3.     (Optional.) Set the gRPC service port number.
grpc port port-number
By default, the gRPC service port number is 50051.
Changing the gRPC service port number reboots the gRPC service and terminates all gRPC sessions to the gRPC server.
4.     (Optional.) Set the gRPC session idle timeout timer.
grpc idle-timeout minutes
By default, the gRPC session idle timeout timer is 5 minutes.
For gRPC clients to establish gRPC sessions with the device, you must configure local users for the gRPC clients on the device.
2.     Add a local user with the device management right.
3.     Configure a password for the user.
By default, no password is configured for a local user. A non-password-protected user can pass authentication after providing the correct username and passing attribute checks.
4.     Assign user role network-admin to the user.
By default, a local user is assigned the network-operator role.
5.     Authorize the user to use the HTTPS service.
service-type https
By default, no service types are authorized to a local user.
For more information about the local-user, password, authorization-attribute, and service-type commands, see AAA configuration in Security Command Reference.
To identify gRPC issues, enable gRPC operations logging in dial-in mode.
This feature generates gRPC operation logs in dial-in mode and sends them to the information center.
With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
gRPC operation logging might degrade device performance if gRPC operations are frequent. As a best practice, use gRPC operation logging only when necessary and log only gRPC operations of interest if gRPC operation logging is enabled.
2.     Enable gRPC logging for RPC operations in dial-in mode.
grpc log dial-in rpc { all | { cli | get }* }
By default, gRPC logging is disabled for RPC operations in dial-in mode.
Configuring the gRPC dial-out mode
gRPC dial-out mode configuration tasks at a glance
To configure telemetry, perform the following tasks:
2.     Enabling the gRPC service
3.     Configuring sensors
4.     Configuring collectors
5.     Configuring a subscription
6.     (Optional.) Enabling gRPC logging in dial-out mode
grpc enable
Configuring sensors
The device uses sensors to sample data. A sensor path indicates a data source.
Supported data collection types include:
·     Event-triggered collection—Sensors in a sensor group sample data when certain events occur. For sensor paths of this data collection type, see NETCONF XML API Event Reference for the module.
·     Periodic collection—Sensors in a sensor group sample data at intervals. For sensor paths of this data collection type, see the NETCONF XML API references for the module except for NETCONF XML API Event Reference.
2.     Enter telemetry view.
telemetry
3.     Create a sensor group and enter sensor group view.
sensor-group group-name
4.     Specify a sensor path.
sensor path path [ condition node node operator operator value value | depth depth ]
To specify multiple sensor paths or data push conditions, execute this command multiple times. A sensor path can have a maximum of five data push conditions. The device pushes data of a sensor path to collectors only when all relevant conditions are met.
Collectors are used to receive sampled data from network devices. For the device to communicate with collectors, you must create a destination group and add collectors to the destination group.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
To configure a collector that resides in a VPN instance, configure the VPN instance first.
telemetry
3.     Create a destination group and enter destination group view.
destination-group group-name
4.     Specify a collector.
IPv4:
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
IPv6:
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
The IPv6 address of a collector cannot be an IPv6 link-local address. For more information about IPv6 link-local addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
To specify multiple collectors, execute this command multiple times. One collector must have a different address, port, or VPN instance than the other collectors.
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
telemetry
3.     Create a subscription and enter subscription view.
subscription subscription-name
4.     (Optional.) Specify the source IP address for packets sent to collectors.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
By default, the device uses the primary IPv4 address of the output interface for the route to the collectors as the source address.
Changing the source address causes the device to reconnect to the gRPC server.
5.     (Optional.) Set the DSCP value of packets sent to collectors.
dscp dscp-value
By default, the DSCP value for packets sent to collectors is 0.
A greater DSCP value represents a higher priority.
6.     Specify a sensor group.
sensor-group group-name [ sample-interval [ msec ] interval ]
Specify the sample-interval interval option for periodic sensor paths and only for periodic sensor paths.
¡     If you specify the option for event-triggered sensor paths, the sensor paths do not take effect.
¡     If you do not specify the option for periodic sensor paths, the device does not sample or push data.
7.     Specify a destination group.
To identify gRPC issues, enable gRPC data collection logging in dial-out mode.
This feature generates gRPC data collection logs in dial-out mode and sends them to the information center.
2.     Enable gRPC logging in dial-out mode.
grpc log dial-out { all | { event | sample }* }
By default, gRPC logging is disabled in dial-out mode.
Display and maintenance commands for gRPC
Display gRPC information.
display grpc
gRPC configuration examples
These configuration examples describe only CLI configuration tasks on the device. The collectors need to run an extra application. For information about collector-side application development, see "Developing the collector-side application."
Example: Configuring the gRPC dial-in mode
As shown in Figure 3, configure the gRPC dial-in mode on the device so the device acts as the gRPC server and the gRPC client can subscribe to LLDP events on the device.
Figure 3 Network diagram
1.     Assign IP addresses to interfaces on the gRPC server and client and configure routes. Make sure the server and client can reach each other.
2.     Configure the device as the gRPC server:
# Enable the gRPC service.
[Device] grpc enable
# Create a local user named test. Set the password of the user, and assign the network-admin user role and HTTPS service to the user.
[Device] local-user test
[Device-luser-manage-test] password simple 123456TESTplat&!
[Device-luser-manage-test] authorization-attribute user-role network-admin
[Device-luser-manage-test] service-type https
[Device-luser-manage-test] quit
3.     Configure the gRPC client.
a.     Prepare a PC and install the gRPC environment on the PC. For more information, see the user guide for the gRPC environment.
b.     Obtain the H3C proto definition file and uses the protocol buffer compiler to generate code of a specific language, for example, Java, Python, C/C++, or Go.
c.     Create a client application to call the generated code.
d.     Start the application to log in to the gRPC server.
When an LLDP event occurs on the gRPC server, verify that the gRPC client receives the event.
Example: Configuring event-triggered telemetry in gRPC dial-out mode
As shown in Figure 4, the device acts as a gRPC client and connects to the telemetry data collector (a gRPC server). The collector receives data on port 50050.
Configure the device to operate in dial-out mode to push interface event data to the collector.
Figure 4 Network diagram
When you execute the sensor-group command in subscription view to specify a sensor group that contains event-triggered sensor paths for a subscription, do not use the sample-interval to set a data push interval.
An event-triggered sensor path typically contains a string of event in its path name.
# Configure IP addresses as required so the device and the collector can reach each other. (Details not shown.)
# Enable gRPC.
# Create a sensor group named Test, and add sensor path ifmgr/interfaceevent to it.
[Device] telemetry
[Device-telemetry] sensor-group Test
[Device-telemetry-sensor-group-Test] sensor path ifmgr/interfaceevent
[Device-telemetry-sensor-group-Test] quit
# Create a destination group named collector1 and add a collector to the group. In this example, the collector receives data on port 50050 at IPv4 address 192.168.2.1.
[Device-telemetry] destination-group collector1
[Device-telemetry-destination-group-collector1] ipv4-address 192.168.2.1 port 50050
[Device-telemetry-destination-group-collector1] quit
# Configure a subscription named B to bind sensor group Test with destination group collector1.
[Device-telemetry] subscription B
[Device-telemetry-subscription-B] sensor-group Test
[Device-telemetry-subscription-B] destination-group collector1
[Device-telemetry-subscription-B] quit
Access the collector and verify that the collector can receive the interface event data pushed by the device. (Details not shown.)
Example: Configuring periodic telemetry in gRPC dial-out mode
As shown in Figure 5, the device is connected to a collector. The collector uses port 50050.
Configure gRPC dial-out mode on the device so the device pushes the device capability information of its interface module to the collector at 10-second intervals.
Figure 5 Network diagram
# Create a sensor group named test, and add sensor path ifmgr/devicecapabilities/.
[Device] telemetry
[Device-telemetry] sensor-group test
[Device-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities/
[Device-telemetry-sensor-group-test] quit
# Create a destination group named collector1. Specify a collector that uses IPv4 address 192.168.2.1 and port number 50050.
# Configure a subscription named A to bind sensor group test with destination group collector1. Set the data collection interval to 10 seconds.
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
[Device-telemetry-subscription-A] destination-group collector1
[Device-telemetry-subscription-A] quit
# Verify that the collector receives the device capability information of the interface module from the device at 10-second intervals. (Details not shown.)
Protocol buffer code
Protocol buffer code format
Google Protocol Buffers provide a flexible mechanism for serializing structured data. Different from XML code and JSON code, the protocol buffer code is binary and provides higher performance.
Table 2 compares a protocol buffer code format example and the corresponding JSON code format example.
Table 2 Protocol buffer and JSON code format examples
Protocol buffer code format example
Corresponding JSON code format example
1:“H3C”
2:“H3C”
3:“H3C device_test”
4:“Syslog/LogBuffer”
5:"notification": {
"Syslog": {
"LogBuffer": {
"BufferSize": 512,
"BufferSizeLimit": 1024,
"DroppedLogsCount": 0,
"LogsCount": 100,
"LogsCountPerSeverity": {
"Alert": 0,
"Critical": 1,
"Debug": 0,
"Emergency": 0,
"Error": 3,
"Informational": 80,
"Notice": 15,
"Warning": 1
"OverwrittenLogsCount": 0,
"State": "enable"
"Timestamp": "1527206160022"
"producerName": "H3C",
"deviceName": "H3C",
"deviceModel": "H3C device_test",
"sensorPath": "Syslog/LogBuffer",
"jsonData": {
"notification": {
"Syslog": {
"LogBuffer": {
"BufferSize": 512,
"LogsCount": 100,
"Alert": 0,
"Critical": 1,
"Debug": 0,
"Emergency": 0,
"Error": 3,
"Notice": 15,
"Warning": 1
"State": "enable"
Proto definition files
You can define data structures in a proto definition file. Then, you can compile the file with utility protoc to generate code in a programing language such as Java and C++. Using the generated code, you can develop an application for a collector to communicate with the device.
H3C provides proto definition files for both dial-in mode and dial-out mode.
Proto definition files in dial-in mode
Public proto definition files
The grpc_service.proto file defines the public RPC methods in dial-in mode, for example, login method and logout method.
The following are the contents of the grpc_service.proto file:
syntax = "proto2";
package grpc_service;
message GetJsonReply { // Reply to the Get method
    required string result = 1;
message SubscribeReply { // Subscription result
message ConfigReply {   // Configuration result
message ReportEvent {   // Subscribed event
    required string token_id = 1;   // Login token_id
    required string stream_name = 2; // Event stream name
    required string event_name = 3;     // Event name
    required string json_text = 4;  // Subscription result, a JSON string
message GetReportRequest{ // Obtains the event subscription result
    required string token_id = 1; // Returns the token_id upon a successful login
message LoginRequest {  // Login request parameters
    required string user_name = 1; // Username
    required string password = 2; // Password
message LoginReply {  // Reply to a login request
message LogoutRequest { // Logout parameter
    required string token_id = 1; // token_id
message LogoutReply { // Reply to a logout request
    required string result = 1; // Logout result
message SubscribeRequest { // Event stream name
    required string stream_name = 1;
service GrpcService {   // gRPC methods
    rpc Login (LoginRequest) returns (LoginReply) {}    // Login method
    rpc Logout (LogoutRequest) returns (LogoutReply) {}     // Logout method
    rpc SubscribeByStreamName (SubscribeRequest) returns (SubscribeReply) {} // Event subscription method
    rpc GetEventReport (GetReportRequest) returns (stream ReportEvent) {} // Method for obtaining the subscribed event
Proto definition files for service modules
The dial-in mode supports proto definition files for the following service modules: Device, Ifmgr, IPFW, LLDP, and Syslog.
The following are the contents of the Device.proto file, which defines the RPC methods for the Device module:
syntax = "proto2";
import "grpc_service.proto";
package  device;
message DeviceBase { // Structure for obtaining basic device information
    optional string HostName = 1;   // Device name
    optional string HostOid = 2;    // sysoid
    optional uint32 MaxChassisNum = 3; //Maximum number of chassis
    optional uint32 MaxSlotNum = 4;     // Maximum number of slots
    optional string HostDescription = 5; // Device description
message DevicePhysicalEntities {    // Structure for obtaining physical entity information of the device
    message Entity {
        optional uint32 PhysicalIndex = 1; // Entity index
        optional string VendorType = 2;         // Vendor type
        optional uint32 EntityClass = 3;        // Entity class
        optional string SoftwareRev = 4;        // Software version
        optional string SerialNumber = 5;   // Serial number
        optional string Model = 6;          // Model
    repeated Entity entity = 1;
service DeviceService { // RPC methods
    rpc GetJsonDeviceBase(DeviceBase) returns (grpc_service.GetJsonReply) {} // Method for obtaining basic device information
    rpc GetJsonDevicePhysicalEntities(DevicePhysicalEntities) returns (grpc_service.GetJsonReply) {}    // Method for obtaining physical entity information of the device
Proto definition file in dial-out mode
The grpc_dialout.proto file defines the public RPC methods in dial-out mode. The following are the contents of the file:
syntax = "proto2";
package grpc_dialout;
message DeviceInfo{     // Pushed device information
    required string producerName = 1; // Vendor name
    required string deviceName = 2;      // Device name
    required string deviceModel = 3;  // Device model
    optional string deviceIpAddr = 4; //Device IP
    optional string eventType = 5; //Type of the sensor path
    optional string deviceSerialNumber = 6; //Serial number of the device
message DialoutMsg{   // Format of the pushed data
    required DeviceInfo deviceMsg = 1; // Device information described by DeviceInfo
    required string sensorPath = 2; // Sensor path, which corresponds to xpath in NETCONF
    required string jsonData = 3;  // Sampled data, a JSON string
message DialoutResponse{  // Response from the collector. Reserved. The value is not processed.
    required string response = 1;
service GRPCDialout {  // Data push method
    rpc Dialout(stream DialoutMsg) returns (DialoutResponse);
Obtaining proto definition files
Contact the technical support.
Example: Developing a gRPC collector-side application
Use a language (for example, C++) to develop a gRPC collector-side application on Linux to enable a collector to collect device data.
1.     Obtain H3C proto definition files.
¡     For dial-in mode, obtain the grpc_service.proto file and proto definition files for service modules.
¡     For dial-out mode, obtain the grpc_dialout.proto file.
2.     Obtain utility protoc from https://github.com/google/protobuf/releases.
3.     Obtain the protobuf plug-in for C++ (protobuf-cpp) from https://github.com/google/protobuf/releases.
Generating the C++ code for the proto definition files
Dial-in mode
# Copy the required proto definition files to the current directory, for example, grpc_service.proto and BufferMonitor.proto.
$protoc --plugin=./grpc_cpp_plugin  --grpc_out=. --cpp_out=. *.proto
Dial-out mode
# Copy proto definition file grpc_dialout.proto to the current directory.
$ protoc --plugin=./grpc_cpp_plugin  --grpc_out=.  --cpp_out=. *.proto
Dial-in mode
In dial-in mode, the application needs to provide the code to be run on the gRPC client.
The C++ code generated from the proto definition files already encapsulates the service classes, which are GrpcService and BufferMonitorService in this example. For the gRPC client to initiate RPC requests, you only need to call the RPC method in the application.
The application performs the following operations:
·     Log in to obtain the token_id.
·     Prepare parameters for the RPC method, use the service classes generated from the proto definition files to call the RPC method, and resolve the returned result.
·     Log out.
To develop the collector-side application in dial-in mode:
1.     Create a GrpcServiceTest class.
# In the class, use the GrpcService::Stub class generated from grpc_service.proto. Implement login and logout with the Login and Logout methods generated from grpc_service.proto.
class GrpcServiceTest
public:
    /* Constructor functions */
   GrpcServiceTest(std::shared_ptr<Channel> channel): GrpcServiceStub(GrpcService::NewStub(channel))  {}
    /* Member functions */
    int Login(const std::string& username, const std::string& password);
   void Logout();
   void listen();
    /* Member variable */
   std::string token;
private:
   std::unique_ptr<GrpcService::Stub> GrpcServiceStub;  // Use the GrpcService::Stub class generated from grpc_service.proto.
2.     Customize the Login method.
# Call the Login method of the GrpcService::Stub class to allow a user who provides the correct the username and password to log in.
int GrpcServiceTest::Login(const std::string& username, const std::string& password)
    LoginRequest request;   // Username and password.
    request.set_user_name(username);
    request.set_password(password);
LoginReply reply;
ClientContext context;
   // Call the Login method.
   Status status = GrpcServiceStub->Login(&context, request, &reply);
   if (status.ok())
       std::cout << "login ok!" << std::endl;
        std::cout <<"token id is :" << reply.token_id() << std::endl;
       token = reply.token_id();  // The login succeeds. The token is obtained.
        return 0;
    else{
       std::cout << status.error_code() << ": " << status.error_message()
                   << ". Login failed!" << std::endl;
        return -1;
3.     Initiate an RPC request to the device. In this example, the application subscribes to interface packet drop events.
rpc SubscribePortQueDropEvent(PortQueDropEvent) returns (grpc_service.SubscribeReply) {}
4.     Create the BufMon_GrpcClient class to encapsulate the RPC method.
# Use the BufferMonitorService::Stub class generated from BufferMonitor.proto to call the RPC method.
class BufMon_GrpcClient
public:
    BufMon_GrpcClient(std::shared_ptr<Channel> channel): mStub(BufferMonitorService::NewStub(channel))
    std::string BufMon_Sub_AllEvent(std::string token);
    std::string BufMon_Sub_BoardEvent(std::string token);
    std::string BufMon_Sub_PortOverrunEvent(std::string token);
    std::string BufMon_Sub_PortDropEvent(std::string token);
    /* Get entries */
    std::string BufMon_Sub_GetStatistics(std::string token);
    std::string BufMon_Sub_GetGlobalCfg(std::string token);
    std::string BufMon_Sub_GetBoardCfg(std::string token);
    std::string BufMon_Sub_GetNodeQueCfg(std::string token);
    std::string BufMon_Sub_GetPortQueCfg(std::string token);
private:
   std::unique_ptr<BufferMonitorService::Stub> mStub; // Use the class generated from BufferMonitor.proto.
5.     Use std::string BufMon_Sub_PortDropEvent(std::string token) to implement interface packet drop event subscription.
std::string BufMon_GrpcClient::BufMon_Sub_PortDropEvent(std::string token)
    std::cout << "-------BufMon_Sub_PortDropEvent-------- " << std::endl;
   PortQueDropEvent stNodeEvent;
   PortQueDropEvent_PortQueDrop* pstParam = stNodeEvent.add_portquedrop();
    UINT uiIfIndex = 0;
    UINT uiQueIdx = 0;
    UINT uiAlarmType = 0;
    std::cout<<"Please input interface queue info : ifIndex queIdx alarmtype " << std::endl;
    cout<<"alarmtype : 1 for ingress; 2 for egress; 3 for port headroom"<<endl;
    std::cin>>uiIfIndex>>uiQueIdx>>uiAlarmType; // Set the subscription parameters and interface index.
   pstParam->set_ifindex(uiIfIndex);
    pstParam->set_queindex(uiQueIdx);
    pstParam->set_alarmtype(uiAlarmType);
   /* Token needs to be added to context */ // Set the token_id to be returned after a successful login
   std::string key = "token_id";
   std::string value = token;
   context.AddMetadata(key, value);
   SubscribeReply reply;
   Status status = mStub->SubscribePortQueDropEvent(&context,stNodeEvent,&reply); // Call the RPC method.
   return reply.result();
6.     Use a loop to listen to event reports.
# Implement this method in the GrpcServiceTest class.
void GrpcServiceTest::listen()
    GetReportRequest reportRequest;
    ReportEvent reportedEvent;
   /* Add the token to the request */
   reportRequest.set_token_id(token);
    std::unique_ptr< ClientReader< ReportEvent>> reader(GrpcServiceStub->GetEventReport(&context, reportRequest)); // Use GetEventReport (which is generated from grpc_service.proto) to obtain event information.
    std::string streamName;
    std::string eventName;
    std::string jsonText;
   std::string token;
    JsonFormatTool jsonTool;
   std::cout << "Listen to server for Event" << std::endl;
    while(reader->Read(&reportedEvent) ) // Read the received event report.
        streamName = reportedEvent.stream_name();
        eventName = reportedEvent.event_name();
       jsonText = reportedEvent.json_text();
       token = reportedEvent.token_id();
       std::cout << "/**********************EVENT COME************************/" << std::endl;
       std::cout << "TOKEN: " << token << std::endl;
       std::cout << "StreamName: "<< streamName << std::endl;
       std::cout << "EventName: " << eventName << std::endl;
       std::cout << "JsonText without format: " << std::endl << jsonText << std::endl;
        std::cout << std::endl;
       std::cout << "JsonText Formated: " << jsonTool.formatJson(jsonText) << std::endl;
    Status status = reader->Finish();
    std::cout << "Status Message:" << status.error_message() << "ERROR code :" << status.error_code();
}  // Login and RPC request finished.
7.     To log out, call the Logout method. (Details not shown.)
Dial-out mode
In dial-out mode, the application needs to provide the gRPC server code so the collector can receive and resolve data obtained from the device.
·     Inherit the automatically generated GRPCDialout::Service class, overload the automatically generated RPC Dialout service, and resolve the fields.
·     Register the RPC service with the specified listening port.
To develop the collector-side application in dial-out mode:
1.     Inherit and overload RPC service Dialout.
# Create class DialoutTest and inherit GRPCDialout::Service.
class DialoutTest final : public GRPCDialout::Service { // Overload the automatically generated abstract class.
    Status Dialout(ServerContext* context, ServerReader< DialoutMsg>* reader, DialoutResponse* response) override; // Implement RPC method Dialout.
2.     Register the DialoutTest service as a gRPC service and specify the listening port.
using grpc::Server;
using grpc::ServerBuilder;
std::string server_address("0.0.0.0:60057"); // Specify the address and port to listen to.
DialoutTest dialout_test; // Define the object declared in step 1.
ServerBuilder builder;
builder.AddListeningPort(server_address, grpc::InsecureServerCredentials());// Add the listening port.
builder.RegisterService(&dialout_test); // Register the service.
std::unique_ptr<Server> server(builder.BuildAndStart()); // Start the service.
server->Wait();
3.     Implement the Dialout method and data resolution.
Status DialoutTest::Dialout(ServerContext* context, ServerReader< DialoutMsg>* reader, DialoutResponse* response)
        DialoutMsg msg;
        while( reader->Read(&msg))
            const DeviceInfo &device_msg = msg.devicemsg();
            std::cout<< "Producer-Name: " << device_msg.producername() << std::endl;
            std::cout<< "Device-Name: " << device_msg.devicename() << std::endl;
            std::cout<< "Device-Model: " << device_msg.devicemodel() << std::endl;
            std::cout<<"Sensor-Path: " << msg.sensorpath()<<std::endl;
            std::cout<<"Json-Data: " << msg.jsondata()<<std::endl;
            std::cout<<std::endl;
        response->set_response("test");
        return Status::OK;
4.     After obtaining the DialoutMsg object (generated from the proto definition file) through the Read method, you can call the method to obtain the field values.
