- 02-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_ATM_Configuration_Examples
- 04-H3C_IGMP_Configuration_Examples
- 05-H3C_IP_Source_Guard_Configuration_Examples
- 06-H3C_Ethernet_OAM_Configuration_Examples
- 07-H3C_NQA_Configuration_Examples
- 08-H3C_QinQ_Configuration_Examples
- 09-H3C_OSPF_Configuration_Examples
- 10-H3C_MPLS_TE_Configuration_Examples
- 11-H3C_OpenFlow_Configuration_Examples
- 12-H3C_NAT_Configuration_Examples
- 13-H3C_RBAC_Configuration_Examples
- 14-H3C_IRF_Configuration_Examples
- 15-H3C_POS_Interface_Configuration_Examples
- 16-H3C_CPOS_Interface_Configuration_Examples
- 17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 18-H3C_DLDP_Configuration_Examples
- 19-H3C_IS-IS_Configuration_Examples
- 20-H3C_MPLS_L3VPN_Configuration_Examples
- 21-H3C_SSH_Configuration_Examples
- 22-H3C_Login_Management_Configuration_Examples
- 23-H3C_SNMP_Configuration_Examples
- 24-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 25-H3C_Multicast_VPN_Configuration_Examples
- 26-H3C_BGP_Configuration_Examples
- 27-H3C_HoVPN_Configuration_Examples
- 28-H3C_L2TP_Configuration_Examples
- 29-H3C_VRRP_Configuration_Examples
- 30-H3C_Traffic_Filtering_Configuration_Examples
- 31-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 32-H3C_Software_Upgrade_Examples
- 33-H3C_MPLS_L2VPN_Configuration_Examples
- 34-H3C_NetStream_Configuration_Examples
- 35-H3C_Policy-Based_Routing_Configuration_Examples
- 36-H3C_Traffic_Policing_Configuration_Examples
- 37-H3C_BFD_Configuration_Examples
- 38-H3C_OSPFv3_Configuration_Examples
- 39-H3C_VPLS_Configuration_Examples
- 40-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 41-H3C_IPv6_IS-IS_Configuration_Examples
- 42-H3C_MPLS OAM_Configuration_Examples
- 43-H3C_BGP_Route_Selection_Configuration_Examples
- 44-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 45-H3C_SRv6 Configuration Examples
- 46-H3C_Attack_Protection_Configuration_Examples
- 47-H3C_OSPF_Multi-Process_Configuration_Examples
- 48-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 49-H3C_ARP_Attack_Protection_Configuration_Examples
- 50-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 51-CE1 Interface Connection Configuration Examples
- 52-GRE Tunnel Establishment Using OSPF Configuration Examples
- 53-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 54-General QoS Configuration Examples
- 55-QoS Configuration Examples for the Financial Industry
| 25-H3C_Multicast_VPN_Configuration_Examples | 293.55 KB |
General restrictions and guidelines
Example: Configuring intra-AS MDT-based MVPN
Assigning IP addresses to interfaces
Configuring routing and basic MPLS L3VPN
Configuring multicast routing and MDT-based MVPN
Example: Configuring inter-AS option A MDT-based MVPN
Configuring multicast routing and inter-AS option A MDT-based MVPN
Example: Configuring inter-AS option C MDT-based MVPN
Introduction
This document provides multicast VPN configuration examples.
This document assumes that you have basic knowledge of multicast VPN.
Support for multicast VPN depends on the card model. For more information, see the configuration guide of the product.
As shown in Figure 1:
· Customer A has two branches that connect to the MPLS L3VPN network of a service provider.
· PIM-SM runs within the two branches.
· The multicast source and the receiver host are in different branches.
Configure intra-AS MDT-based MVPN so that the receiver host can receive the multicast data from the source.
Device |
IP address |
Device |
IP address |
S 1 |
10.11.3.2/24 |
PE 2 |
XGE3/1/2 |
192.168.2.2/24 |
PE 1 |
XGE3/1/2 |
192.168.1.2/24 |
PE 2 |
XGE3/1/1 |
10.11.2.1/24 |
PE 1 |
XGE3/1/1 |
10.11.1.1/24 |
PE 2 |
Loop1 |
1.1.1.2/32 |
PE 1 |
Loop1 |
1.1.1.1/32 |
CE a1 |
XGE3/1/1 |
10.11.3.1/24 |
P |
XGE3/1/1 |
192.168.1.1/24 |
CE a1 |
XGE3/1/2 |
10.11.1.2/24 |
P |
XGE3/1/2 |
192.168.2.1/24 |
CE a1 |
Loop0 |
2.2.2.2/32 |
P |
Loop1 |
3.3.3.3/32 |
CE a2 |
XGE3/1/2 |
10.11.4.1/24 |
R 1 |
10.11.4.2/24 |
CE a2 |
XGE3/1/1 |
10.11.2.2/24 |
Analysis
To meet the network requirement, you must run PIM on the devices of the public network, and configure MDT-based MVPN on each PE. In addition, make sure the PIM protocol on the public network is independent from the PIM protocol for the VPN instance.
The MTI interfaces take effect only after the default-group and the MVPN source interface are specified and the MVPN source interface obtains the public IP address.
You must enable the same PIM mode on all interfaces that belong to the same VPN instance (including the interfaces associated with the VPN instance on the PEs).
You must specify the same default-group for the same VPN instance on different PEs.
The IP address of the MVPN source interface must be the same as the source address used for establishing BGP peer relationship. Otherwise, correct routing information cannot be obtained.
Procedures
# Assign an IP address and subnet mask to each interface on CE a1, as shown in Table 1.
<CEa1> system-view
[CEa1] interface ten-gigabitethernet 3/1/1
[CEa1-Ten-GigabitEthernet3/1/1] ip address 10.11.3.1 24
[CEa1-Ten-GigabitEthernet3/1/1] quit
[CEa1] interface loopback 0
[CEa1-LoopBack0] ip address 2.2.2.2 32
[CEa1-LoopBack0] quit
[CEa1] interface ten-gigabitethernet 3/1/2
[CEa1-Ten-GigabitEthernet3/1/2] ip address 10.11.1.2 24
[CEa1-Ten-GigabitEthernet3/1/2] quit
# Configure PE 1, P, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
# Configure a unicast routing protocol and basic MPLS VPN on all devices so that all devices are interoperable at the network layer. (Details not shown.) For more information about configuring basic MPLS VPN, see H3C SR8800-F Routers MPLS Configuration Guide.
1. Enable IP multicast routing on the public network, and enable PIM-SM on the public network interfaces (including Loopback interfaces).
# On PE 1, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
<PE1> system-view
[PE1] multicast routing
[PE1-mrib] quit
[PE1] interface ten-gigabitethernet 3/1/2
[PE1-Ten-GigabitEthernet3/1/2] pim sm
[PE1-Ten-GigabitEthernet3/1/2] quit
[PE1] interface loopback 1
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# On P, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
<P> system-view
[P] multicast routing
[P-mrib] quit
[P] interface ten-gigabitethernet 3/1/1
[P-Ten-GigabitEthernet3/1/1] pim sm
[P-Ten-GigabitEthernet3/1/1] quit
[P] interface ten-gigabitethernet 3/1/2
[P-Ten-GigabitEthernet3/1/2] pim sm
[P-Ten-GigabitEthernet3/1/2] quit
[P] interface loopback 1
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[P] pim
[P-pim] c-bsr 3.3.3.3
[P-pim] c-rp 3.3.3.3
[P-pim] quit
# On PE 2, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
<PE2> system-view
[PE2] multicast routing
[PE2-mrib] quit
[PE2] interface ten-gigabitethernet 3/1/2
[PE2-Ten-GigabitEthernet3/1/2] pim sm
[PE2-Ten-GigabitEthernet3/1/2] quit
[PE2] interface loopback 1
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
2. Enable IP multicast routing for the VPN instance, enable PIM-SM on the private network interfaces, and enable IGMP on interfaces that have receiver hosts attached.
# On CE a1, enable IP multicast routing, and enable PIM-SM on each interface.
<CEa1> system-view
[CEa1] multicast routing
[CEa1-mrib] quit
[CEa1-Ten-GigabitEthernet3/1/1] pim sm
[CEa1-Ten-GigabitEthernet3/1/2] pim sm
[CEa1-LoopBack0] pim sm
# Configure Loopback 0 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 2.2.2.2
[CEa1-pim] c-rp 2.2.2.2
[CEa1-pim] quit
# On CE a2, enable IP multicast routing, enable PIM-SM on Ten-GigabitEthernet 3/1/1, and enable IGMP on the receiver-side interface Ten-GigabitEthernet 3/1/2.
<CEa2> system-view
[CEa2] multicast routing
[CEa2-mrib] quit
[CEa2] interface ten-gigabitethernet 3/1/1
[CEa2-Ten-GigabitEthernet3/1/1] pim sm
[CEa2-Ten-GigabitEthernet3/1/1] quit
[CEa2] interface ten-gigabitethernet 3/1/2
[CEa2-Ten-GigabitEthernet3/1/2] igmp enable
[CEa2-Ten-GigabitEthernet3/1/2] quit
# On PE 1, create a VPN instance named customerA.
[PE1] ip vpn-instance customerA
[PE1-vpn-instance-customerA] route-distinguisher 100:1
[PE1-vpn-instance-customerA] vpn-target 111:1
[PE1-vpn-instance-customerA] quit
# Associate Ten-GigabitEthernet 3/1/1 with VPN instance customerA.
[PE1] interface ten-gigabitethernet 3/1/1
[PE1-Ten-GigabitEthernet3/1/1] ip binding vpn-instance customerA
[PE1-Ten-GigabitEthernet3/1/1] quit
# Enable IP multicast routing for VPN instance customerA.
[PE1] multicast routing vpn-instance customerA
[PE1-mrib-customerA] quit
# Enable PIM-SM on Ten-GigabitEthernet 3/1/1.
[PE1-Ten-GigabitEthernet3/1/1] pim sm
# On PE 2, create a VPN instance named customerA.
[PE2] ip vpn-instance customerA
[PE2-vpn-instance-customerA] route-distinguisher 100:1
[PE2-vpn-instance-customerA] vpn-target 111:1
[PE2-vpn-instance-customerA] quit
[PE2] interface ten-gigabitethernet 3/1/1
[PE2-Ten-GigabitEthernet3/1/1] ip binding vpn-instance customerA
[PE2-Ten-GigabitEthernet3/1/1] quit
[PE2] multicast routing vpn-instance customerA
[PE2-mrib-customerA] quit
[PE2-Ten-GigabitEthernet3/1/1] pim sm
3. Configure the MVPN for the VPN instance:
# On PE 1, create an MDT-based MVPN for VPN instance customerA.
[PE1] multicast-vpn vpn-instance customerA mode mdt
# Create an MVPN IPv4 address family for VPN instance customerA.
[PE1-mvpn-vpn-instance-customerA] address-family ipv4
# Specify the default group, MVPN source interface, and data group range for VPN instance customerA.
[PE1-mvpn-vpn-instance-customerA-ipv4] default-group 239.1.1.1
[PE1-mvpn-vpn-instance-customerA-ipv4] source loopback 1
[PE1-mvpn-vpn-instance-customerA-ipv4] data-group 225.2.2.0 28
[PE1-mvpn-vpn-instance-customerA-ipv4] quit
[PE1-mvpn-vpn-instance-customerA] quit
# On PE 2, create an MDT-based MVPN for VPN instance customerA.
[PE2] multicast-vpn vpn-instance customerA mode mdt
[PE2-mvpn-vpn-instance-customerA] address-family ipv4
[PE2-mvpn-vpn-instance-customerA-ipv4] default-group 239.1.1.1
[PE2-mvpn-vpn-instance-customerA-ipv4] source loopback 1
[PE2-mvpn-vpn-instance-customerA-ipv4] data-group 225.2.2.0 28
[PE2-mvpn-vpn-instance-customerA-ipv4] quit
[PE2-mvpn-vpn-instance-customerA] quit
# Verify the establishment of the default-MDT for the public network on PEs and P. The following example shows PIM routing table for the public network on P.
[P] display pim routing-table
Total 1 (*, G) entries; 2 (S, G) entries
(*, 239.1.1.1)
RP: 3.3.3.3 (local)
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Register
Upstream neighbor: NULL
RPF prime neighbor: NULL
Total number of downstreams: 2
1: Ten-GigabitEthernet3/1/1
Protocol: pim-sm, UpTime: 02:54:43, Expires: -
2: Ten-GigabitEthernet3/1/2
Protocol: pim-sm, UpTime: 02:33:57, Expires: -
(1.1.1.1, 239.1.1.1)
RP: 3.3.3.3 (local)
UpTime: 01:57:13
Upstream interface: Ten-GigabitEthernet3/1/1
Upstream neighbor: 192.168.1.2
RPF prime neighbor: 192.168.1.2
Downstream interface(s) information: None
(1.1.1.2, 239.1.1.1)
RP: 3.3.3.3 (local)
UpTime: 01:57:13
Upstream interface: Ten-GigabitEthernet3/1/2
Upstream neighbor: 192.168.2.2
RPF prime neighbor: 192.168.2.2
The output shows that an RPT for (*, 239.1.1.1), an SPT for (1.1.1.1, 239.1.1.1), and an SPT for (1.1.1.2, 239.1.1.1) have been established on the public network. The RPT and SPTs constitute the default-MDT for the public network.
Configuration files
· PE 1:
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
interface LoopBack1
ip address 1.1.1.1 255.255.255.255
pim sm
interface Ten-GigabitEthernet3/1/1
ip address 10.11.1.1 255.255.255.0
pim sm
interface Ten-GigabitEthernet3/1/2
ip address 192.168.1.2 255.255.255.0
pim sm
multicast routing
address-family ipv4
source LoopBack1
data-group 225.1.1.0 255.255.255.240
· PE 2:
interface LoopBack1
ip address 1.1.1.2 255.255.255.255
pim sm
ip address 10.11.2.1 255.255.255.0
pim sm
ip address 192.168.2.2 255.255.255.0
pim sm
multicast routing
address-family ipv4
source LoopBack1
· P:
interface LoopBack1
ip address 3.3.3.3 255.255.255.255
pim sm
pim sm
ip address 192.168.2.1 255.255.255.0
pim sm
multicast routing
pim
c-bsr 3.3.3.3
c-rp 3.3.3.3
· CE a1:
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
pim sm
ip address 10.11.3.1 255.255.255.0
pim sm
ip address 10.11.1.2 255.255.255.0
pim sm
multicast routing
pim
c-bsr 2.2.2.2
c-rp 2.2.2.2
· CE a2:
ip address 10.11.2.2 255.255.255.0
pim sm
ip address 10.11.4.1 255.255.255.0
igmp enable
multicast routing
As shown in Figure 2:
· Customer A has two branches that separately connect to AS 100 and AS 200.
· ASBR-PE 1 and ASBR-PE 2 are interconnected by using the inter-AS option A solution.
Configure inter-AS option A MDT-based MVPN so that the receiver host can receive the multicast data from the source.
Device |
IP address |
Device |
IP address |
S 1 |
10.11.3.2/24 |
R 1 |
10.11.4.2/24 |
PE 1 |
XGE3/1/1 |
192.168.1.2/24 |
ASBR-PE 2 |
XGE3/1/1 |
192.168.2.2/24 |
PE 1 |
XGE3/1/2 |
10.11.1.1/24 |
ASBR-PE 2 |
XGE3/1/2 |
192.168.3.2/24 |
PE 1 |
Loop1 |
1.1.1.1/32 |
ASBR-PE 2 |
Loop1 |
1.1.1.3/32 |
ASBR-PE 1 |
XGE3/1/1 |
192.168.1.1/24 |
ASBR-PE 2 |
Loop2 |
22.22.22.22/32 |
ASBR-PE 1 |
XGE3/1/2 |
192.168.2.1/24 |
PE 2 |
XGE3/1/1 |
192.168.3.1/24 |
ASBR-PE 1 |
Loop1 |
1.1.1.2/32 |
PE 2 |
XGE3/1/2 |
10.11.2.1/24 |
ASBR-PE 1 |
Loop2 |
11.11.11.11/32 |
PE 2 |
Loop1 |
1.1.1.4/32 |
CE a1 |
XGE3/1/1 |
10.11.3.1/24 |
CE a2 |
XGE3/1/1 |
10.11.2.2/24 |
CE a1 |
XGE3/1/2 |
10.11.1.2/24 |
CE a2 |
XGE3/1/2 |
10.11.4.1/24 |
CE a1 |
Loopback 0 |
2.2.2.2/32 |
Analysis
To meet the network requirement, you must create a separate MDT-based MVPN for each AS.
You must enable the same PIM mode for all interfaces that belong to the same VPN instance (including the interface associated with the VPN instance). You may enable different PIM modes for the public network in different ASs.
You must specify the same default-group for the same VPN instance in the same AS. You may specify different default-groups for the same VPN instance in different ASs.
Procedures
# Assign an IP address and subnet mask to each interface on CE a1, as shown in Table 2.
<CEa1> system-view
# Configure PE 1, ASBR-PE 1, ASBR-PE2, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
# Configure a unicast routing protocol and MPLS L3VPN inter-AS option A on all devices so that all devices in the ASs are interoperable at the network layer. (Details not shown) For more information about configuring basic MPLS VPN, see H3C SR8800-F Routers MPLS Configuration Guide.
<PE1> system-view
[PE1-mrib] quit
# On ASBR-PE 1, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
<ASBR-PE1> system-view
[ASBR-PE1] multicast routing
[ASBR-PE1-mrib] quit
[ASBR-PE1] interface ten-gigabitethernet 3/1/1
[ASBR-PE1-Ten-GigabitEthernet3/1/1] pim sm
[ASBR-PE1-Ten-GigabitEthernet3/1/1] quit
[ASBR-PE1] interface loopback 1
[ASBR-PE1-LoopBack1] pim sm
[ASBR-PE1-LoopBack1] quit
[ASBR-PE1] interface loopback 2
[ASBR-PE1-LoopBack2] pim sm
[ASBR-PE1-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and a C-RP.
[ASBR-PE1] pim
[ASBR-PE1-pim] c-bsr 11.11.11.11
[ASBR-PE1-pim] c-rp 11.11.11.11
[ASBR-PE1-pim] quit
<PE2> system-view
[PE2-mrib] quit
# On ASBR-PE 2, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
<ASBR-PE2> system-view
[ASBR-PE2] multicast routing
[ASBR-PE2-mrib] quit
[ASBR-PE2] interface ten-gigabitethernet 3/1/2
[ASBR-PE2-Ten-GigabitEthernet3/1/2] pim sm
[ASBR-PE2-Ten-GigabitEthernet3/1/2] quit
[ASBR-PE2] interface loopback 1
[ASBR-PE2-LoopBack1] pim sm
[ASBR-PE2-LoopBack1] quit
[ASBR-PE2] interface loopback 2
[ASBR-PE2-LoopBack2] pim sm
[ASBR-PE2-LoopBack2] quit
[ASBR-PE2] pim
[ASBR-PE2-pim] c-bsr 22.22.22.22
[ASBR-PE2-pim] c-rp 22.22.22.22
[ASBR-PE2-pim] quit
2. Enable IP multicast routing for the VPN instances, enable PIM-SM on the VPN instance interfaces, and enable IGMP on the interfaces that have receiver hosts attached.
NOTE: The route targets for the same VPN instance on the ASBRs and PEs within the same AS must match. Those within different ASs do not need to match. |
# On CE a1, enable IP multicast routing, enable PIM-SM on each interface.
<CEa1> system-view
[CEa1-mrib] quit
[CEa1] pim
[CEa1-pim] quit
# On CE a2, enable IP multicast routing, enable PIM-SM on Ten-GigabitEthernet 3/1/1, and enable IGMP on Ten-GigabitEthernet 3/1/2.
<CEa2> system-view
[CEa2-mrib] quit
[PE1-vpn-instance-customerA] vpn-target 100:1 both
# Associate Ten-GigabitEthernet 3/1/2 with VPN instance customerA.
[PE1-Ten-GigabitEthernet3/1/2] ip binding vpn-instance customerA
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on Ten-GigabitEthernet 3/1/2.
[PE2-vpn-instance-customerA] route-distinguisher 12:12
[PE2-vpn-instance-customerA] vpn-target 3:3 import-extcommunity
[PE2-vpn-instance-customerA] vpn-target 3:3 export-extcommunity
[PE2-vpn-instance] quit
[PE2-Ten-GigabitEthernet3/1/2] ip binding vpn-instance customerA
# On ASBR-PE 1, create a VPN instance named customerA.
[ASBR-PE1] ip vpn-instance customerA
[ASBR-PE1-vpn-instance-customerA] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-customerA] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-customerA] quit
[ASBR-PE1] interface ten-gigabitethernet 3/1/2
[ASBR-PE1-Ten-GigabitEthernet3/1/2] ip binding vpn-instance customerA
[ASBR-PE1-Ten-GigabitEthernet3/1/2] quit
[ASBR-PE1] multicast routing vpn-instance customerA
[ASBR-PE1-mrib-customerA] quit
[ASBR-PE1-Ten-GigabitEthernet3/1/2] pim sm
# On ASBR-PE 2, create a VPN instance named customerA.
[ASBR-PE2] ip vpn-instance customerA
[ASBR-PE2-vpn-vpn-customerA] route-distinguisher 200:1
[ASBR-PE2-vpn-vpn-customerA] vpn-target 200:1 both
[ASBR-PE2-vpn-vpn-customerA] quit
[ASBR-PE2] interface ten-gigabitethernet 3/1/1
[ASBR-PE2-Ten-GigabitEthernet3/1/1] ip binding vpn-instance customerA
[ASBR-PE2-Ten-GigabitEthernet3/1/1] quit
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on Ten-GigabitEthernet 3/1/1.
[ASBR-PE2] multicast routing vpn-instance customerA
[ASBR-PE2-mrib-customerA] quit
[ASBR-PE2-Ten-GigabitEthernet3/1/1] pim sm
3. Configure the MDT-based MVPN for the VPN instance.
# On ASBR-PE 1, create an MDT-based MVPN for VPN instance customerA.
[ASBR-PE1] multicast-vpn vpn-instance customerA mode mdt
[ASBR-PE1-mvpn-vpn-instance-customerA] address-family ipv4
[ASBR-PE1-mvpn-vpn-instance-customerA-ipv4] default-group 239.1.1.1
[ASBR-PE1-mvpn-vpn-instance-customerA-ipv4] source loopback 1
[ASBR-PE1-mvpn-vpn-instance-customerA-ipv4] data-group 225.2.2.0 28
[ASBR-PE1-mvpn-vpn-instance-customerA-ipv4] quit
[ASBR-PE1-mvpn-vpn-instance-customerA] quit
# On ASBR-PE 2, create an MDT-based MVPN for VPN instance customerA.
[ASBR-PE2] multicast-vpn vpn-instance customerA mode mdt
[ASBR-PE2-mvpn-vpn-instance-customerA] address-family ipv4
[ASBR-PE2-mvpn-vpn-instance-customerA-ipv4] default-group 239.1.1.1
[ASBR-PE2-mvpn-vpn-instance-customerA-ipv4] source loopback 1
[ASBR-PE2-mvpn-vpn-instance-customerA-ipv4] data-group 225.2.2.0 28
[ASBR-PE2-mvpn-vpn-instance-customerA-ipv4] quit
[ASBR-PE2-mvpn-vpn-instance-customerA] quit
# Verify that the default-MDT has been established on the public network in each AS on PEs and ASBR-PEs. The following example shows PIM routing table for the public network on ASBR-PE 1.
[ASBR-PE1] display pim routing-table
Total 1 (*, G) entries; 1 (S, G) entries
(*, 239.1.1.1)
RP: 11.11.11.11 (local)
UpTime: 02:54:43
UpTime: 01:57:13
The output shows that an RPT for (*, 239.1.1.1) and an SPT for (1.1.1.1, 239.1.1.1) have been established on the public network. The RPT and SPT constitute the default-MDT for the public network.
Configuration files
· PE 1:
interface LoopBack1
pim sm
pim sm
pim sm
multicast routing
address-family ipv4
source LoopBack1
· PE 2:
vpn-target 200:1 import-extcommunity
vpn-target 200:1 export-extcommunity
interface LoopBack1
ip address 1.1.1.4 255.255.255.255
pim sm
ip address 192.168.3.1 255.255.255.0
pim sm
pim sm
multicast routing
address-family ipv4
source LoopBack1
· ASBR-PE 1:
interface LoopBack1
pim sm
interface LoopBack2
ip address 11.11.11.11 255.255.255.255
pim sm
pim sm
pim sm
multicast routing
pim
c-bsr 11.11.11.11
c-rp 11.11.11.11
address-family ipv4
source LoopBack1
· ASBR-PE 2:
interface LoopBack1
ip address 1.1.1.3 255.255.255.255
pim sm
interface LoopBack2
ip address 22.22.22.22 255.255.255.255
pim sm
pim sm
ip address 192.168.3.2 255.255.255.0
pim sm
multicast routing
pim
c-bsr 22.22.22.22
c-rp 22.22.22.22
address-family ipv4
source LoopBack1
· CE a1:
interface LoopBack0
pim sm
pim sm
pim sm
multicast routing
pim
c-bsr 2.2.2.2
c-rp 2.2.2.2
· CE a2:
pim sm
igmp enable
multicast routing
As shown in Figure 3:
· ASBR-PE 1 and ASBR-PE 2 are interconnected by using the inter-AS option C solution.
Configure inter-AS option C MDT-based MVPN so that the receiver host can receive the multicast data from the source.
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
S 1 |
10.11.3.2/24 |
R 1 |
10.11.4.2/24 |
PE 1 |
XGE3/1/1 |
192.168.1.2/24 |
ASBR-PE2 |
XGE3/1/1 |
192.168.2.2/24 |
PE 1 |
XGE3/1/2 |
10.11.1.1/24 |
ASBR-PE2 |
XGE3/1/2 |
192.168.3.2/24 |
PE 1 |
Loop1 |
1.1.1.1/32 |
ASBR-PE2 |
Loop1 |
1.1.1.3/32 |
ASBR-PE1 |
XGE3/1/1 |
192.168.1.1/24 |
ASBR-PE2 |
Loop2 |
22.22.22.22/32 |
ASBR-PE1 |
XGE3/1/2 |
192.168.2.1/24 |
PE 2 |
XGE3/1/1 |
192.168.3.1/24 |
ASBR-PE1 |
Loop1 |
1.1.1.2/32 |
PE 2 |
XGE3/1/2 |
10.11.2.1/24 |
ASBR-PE1 |
Loop2 |
11.11.11.11/32 |
PE 2 |
Loop1 |
1.1.1.4/32 |
CE a1 |
XGE3/1/1 |
10.11.3.1/24 |
CE a2 |
XGE3/1/1 |
10.11.2.2/24 |
CE a1 |
XGE3/1/2 |
10.11.1.2/24 |
CE a2 |
XGE3/1/2 |
10.11.4.1/24 |
CE a1 |
Loop0 |
2.2.2.2/32 |
Analysis
To meet the network requirement, you must perform the following tasks:
· Create the same MDT-based MVPN for each AS.
· Establish MSDP peering relationships between the RPs in the ASs to share the multicast source information in different PIM-SM domains.
Procedures
# Assign an IP address and subnet mask to each interface on CE a1, as shown in Table 3.
<CEa1> system-view
# Configure PE 1, ASBR-PE 1, ASBR-PE 2, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
# Configure a unicast routing protocol and basic MPLS VPN on all devices so that all devices are interoperable at the network layer. (Details not shown) For more information about configuring basic MPLS VPN, see H3C SR8800-F Routers MPLS Configuration Guide.
1. Enable IP multicast routing on the public network in each AS, enable PIM-SM on the public network interfaces (including Loopback interfaces), and configure PIM-SM domain boarders.
<PE1> system-view
[PE1-mrib] quit
[ASBR-PE1] pim
[ASBR-PE1] pim
[ASBR-PE1-pim] quit
# Configure Ten-GigabitEthernet 3/1/2 as a PIM-SM domain boarder.
[ASBR-PE1-Ten-GigabitEthernet3/1/2] pim bsr-boundary
<PE2> system-view
[PE2-mrib] quit
[ASBR-PE2] pim
[ASBR-PE2-pim] quit
# Configure Ten-GigabitEthernet 3/1/1 as a PIM-SM domain boarder.
[ASBR-PE2-Ten-GigabitEthernet3/1/1] pim bsr-boundary
2. Establish MSDP peering relationships between the RPs on the public network in the ASs:
# On ASBR-PE 1, specify an MSDP peer.
[ASBR-PE1] msdp
[ASBR-PE1-msdp] encap-data-enable
[ASBR-PE1-msdp] peer 192.168.2.2 connect-interface ten-gigabitethernet 3/1/2
# On ASBR-PE 2, specify an MSDP peer.
[ASBR-PE2] msdp
[ASBR-PE2-msdp] encap-data-enable
[ASBR-PE2-msdp] peer 192.168.2.1 connect-interface ten-gigabitethernet 3/1/1
3. Enable IP multicast routing for the VPN instance, enable PIM-SM on the private network interfaces, and enable IGMP on the interfaces that have receiver hosts attached:
<CEa1> system-view
[CEa1-mrib] quit
[CEa1] pim
[CEa1-pim] quit
<CEa2> system-view
[CEa2-mrib] quit
[PE1-vpn-instance-customerA] route-distinguisher 11:11
[PE1-vpn-instance-customerA] vpn-target 3:3 import-extcommunity
[PE1-vpn-instance-customerA] vpn-target 3:3 export-extcommunity
4. Create the same MDT-based MVPN for the ASs, and specify the default-group, MVPN source interface, and data-group for the MVPN:
(*, 239.1.1.1)
RP: 3.3.3.3 (local)
UpTime: 02:54:43
RP: 3.3.3.3 (local)
UpTime: 01:57:13
(1.1.1.4, 239.1.1.1)
RP: 3.3.3.3 (local)
UpTime: 01:57:13
The output shows that an RPT for (*, 239.1.1.1), an SPT for (1.1.1.1, 239.1.1.1), and an SPT for (1.1.1.4, 239.1.1.1) have been established on the public network. The RPT and SPTs constitute the default-MDT for the public network.
Configuration files
· PE 1:
interface LoopBack1
pim sm
pim sm
pim sm
multicast routing
address-family ipv4
source LoopBack1
· PE 2:
interface LoopBack1
pim sm
pim sm
pim sm
multicast routing
address-family ipv4
source LoopBack1
· ASBR-PE 1:
interface LoopBack1
pim sm
interface LoopBack2
pim sm
pim sm
pim sm
pim bsr-boundary
multicast routing
pim
c-bsr 11.11.11.11
c-rp 11.11.11.11
msdp
encap-data-enable
peer 192.168.2.2 connect-interface Ten-GigabitEthernet3/1/2
· ASBR-PE 2:
interface LoopBack1
pim sm
interface LoopBack2
pim sm
pim sm
pim bsr-boundary
pim sm
multicast routing
pim
c-bsr 22.22.22.22
c-rp 22.22.22.22
msdp
encap-data-enable
peer 192.168.2.1 connect-interface Ten-GigabitEthernet3/1/1
· CE a1:
interface LoopBack0
pim sm
pim sm
pim sm
multicast routing
pim
c-bsr 2.2.2.2
c-rp 2.2.2.2
· CE a2:
pim sm
igmp enable
multicast routing
Related documentation
· H3C SR8800-F Routers IP Multicast Command Reference
· H3C SR8800-F Routers IP Multicast Configuration Guide
