- 02-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_ATM_Configuration_Examples
- 04-H3C_IGMP_Configuration_Examples
- 05-H3C_IP_Source_Guard_Configuration_Examples
- 06-H3C_Ethernet_OAM_Configuration_Examples
- 07-H3C_NQA_Configuration_Examples
- 08-H3C_QinQ_Configuration_Examples
- 09-H3C_OSPF_Configuration_Examples
- 10-H3C_MPLS_TE_Configuration_Examples
- 11-H3C_OpenFlow_Configuration_Examples
- 12-H3C_NAT_Configuration_Examples
- 13-H3C_RBAC_Configuration_Examples
- 14-H3C_IRF_Configuration_Examples
- 15-H3C_POS_Interface_Configuration_Examples
- 16-H3C_CPOS_Interface_Configuration_Examples
- 17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 18-H3C_DLDP_Configuration_Examples
- 19-H3C_IS-IS_Configuration_Examples
- 20-H3C_MPLS_L3VPN_Configuration_Examples
- 21-H3C_SSH_Configuration_Examples
- 22-H3C_Login_Management_Configuration_Examples
- 23-H3C_SNMP_Configuration_Examples
- 24-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 25-H3C_Multicast_VPN_Configuration_Examples
- 26-H3C_BGP_Configuration_Examples
- 27-H3C_HoVPN_Configuration_Examples
- 28-H3C_L2TP_Configuration_Examples
- 29-H3C_VRRP_Configuration_Examples
- 30-H3C_Traffic_Filtering_Configuration_Examples
- 31-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 32-H3C_Software_Upgrade_Examples
- 33-H3C_MPLS_L2VPN_Configuration_Examples
- 34-H3C_NetStream_Configuration_Examples
- 35-H3C_Policy-Based_Routing_Configuration_Examples
- 36-H3C_Traffic_Policing_Configuration_Examples
- 37-H3C_BFD_Configuration_Examples
- 38-H3C_OSPFv3_Configuration_Examples
- 39-H3C_VPLS_Configuration_Examples
- 40-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 41-H3C_IPv6_IS-IS_Configuration_Examples
- 42-H3C_MPLS OAM_Configuration_Examples
- 43-H3C_BGP_Route_Selection_Configuration_Examples
- 44-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 45-H3C_SRv6 Configuration Examples
- 46-H3C_Attack_Protection_Configuration_Examples
- 47-H3C_OSPF_Multi-Process_Configuration_Examples
- 48-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 49-H3C_ARP_Attack_Protection_Configuration_Examples
- 50-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 51-CE1 Interface Connection Configuration Examples
- 52-GRE Tunnel Establishment Using OSPF Configuration Examples
- 53-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 54-General QoS Configuration Examples
- 55-QoS Configuration Examples for the Financial Industry
| 12-H3C_NAT_Configuration_Examples | 88.40 KB |
Example: Configuring basic NAT
Specifying IP addresses for the interfaces
Configuring outbound NAT for internal users
Implementing load sharing among FTP servers
Specifying a NAT-capable service module to provide NAT service
Configuring a QoS policy to redirect traffic to the service module in slot 3
Introduction
This document provides NAT configuration examples.
This document is not restricted to specific software or hardware versions.
The following information is provided based on the assumption that you have basic knowledge of NAT.
NAT is available on service modules except CSPC-CP2LB.
A QoS policy is required on an interface to redirect the incoming traffic to the specified NAT-capable service module. For more information about QoS policies, see ACL and QoS Configuration Guide.
As shown in Figure 1, the internal users use the IP addresses in the range of 10.110.0.0 to 10.110.2.255. The private IP addresses of the FTP servers are from 10.110.3.1 to 10.110.3.3. These servers provide FTP services to external users. The company has three public IP addresses from 61.16.0.1 to 61.16.0.3.
Configure NAT on the device to implement the following:
· Allow the internal and external users to use the IP address 61.16.0.1 to access the FTP servers.
· Implement load sharing among the FTP servers and do not allow connections that are initiated by the FTP servers to the external network.
Analysis
· To translate IP addresses in the range of 10.110.0.0 to 10.110.2.255 into IP addresses in the range of 61.16.0.2 to 61.16.0.3, configure an ACL to identify these packets. Then configure outbound address translation on packets identified by the ACL on Ten-GigabitEthernet 3/1/2.
· To allow three FTP servers to load share services, configure NAT server group to implement load sharing.
· To allow internal hosts to access the internal FTP server by using a public IP address, enable AT hairpin on Ten-GigabitEthernet 3/1/1 of the device.
Procedures
# Specify IP addresses for Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2.
[Device] interface Ten-GigabitEthernet3/1/1
[Device-Ten-GigabitEthernet3/1/1] ip address 10.110.0.1 255.255.252.0
[Device-Ten-GigabitEthernet3/1/1] quit
[Device] interface Ten-GigabitEthernet3/1/2
[Device-Ten-GigabitEthernet3/1/2] ip address 61.16.0.1 255.255.255.0
[Device-Ten-GigabitEthernet3/1/2] quit
# Configure NAT address group 0, and add public IP address 61.16.0.2 and 61.16.0.3 to the group.
[Device-nat-address-group-0] address 61.16.0.2 61.16.0.3
[Device-nat-address-group-0] quit
# Configure ACL 2000 to identify packets only from subnet 10.110.0.0 to 10.110.2.255.
[Device-acl-ipv4-basic-2000] rule permit source 10.110.0.0 0.0.1.255
[Device-acl-ipv4-basic-2000] rule permit source 10.110.2.0 0.0.0.255
# Configure outbound dynamic NAT on Ten-GigabitEthernet 3/1/2 to translate source IP address in packets permitted by ACL 2000 into the IP addresses in NAT address group 0.
[Device-Ten-GigabitEthernet3/1/2] nat outbound 2000 address-group 0
# Create NAT server group 0, and add servers at 10.110.3.1, 10.110.3.2, 10.110.3.3 to the group.
[Device-nat-server-group-0] inside ip 10.110.3.1 port 21
[Device-nat-server-group-0] inside ip 10.110.3.2 port 21
[Device-nat-server-group-0] inside ip 10.110.3.3 port 21
[Device-nat-server-group-0] quit
# Associate NAT server group 0 with Ten-GigabitEthernet 3/1/2 so that servers in the server group can load share FTP services.
[Device-Ten-GigabitEthernet3/1/2] nat server protocol tcp global 61.16.0.1 ftp inside server-group 0
# Enable NAT hairpin on Ten-GigabitEthernet 3/1/1.
[Device-Ten-GigabitEthernet3/1/1] nat hairpin enable
# Specify the service module in slot 3 to provide the NAT service for Ten-GigabitEthernet 3/1/1.
[Device-Ten-GigabitEthernet3/1/1] nat service slot 3
# Specify the service module in slot 3 to provide the NAT service for Ten-GigabitEthernet 3/1/2.
[Device-Ten-GigabitEthernet3/1/2] nat service slot 3
# Configure ACL 2001 to identify packets to be redirected to the NAT-capable service module. In this example, the packets are those to be translated, therefore, define the same ACL rules as those in ACL 2000.
[Device] acl basic 2001
[Device-acl-ipv4-basic-2001] rule permit source 10.110.0.0 0.0.1.255
[Device-acl-ipv4-basic-2001] rule permit source 10.110.2.0 0.0.0.255
[Device-acl-ipv4-basic-2001] quit
# Create traffic class 1 and define a match criterion for the traffic class to match ACL 2001.
[Device] traffic classifier 1 operator and
[Device-classifier-1] if-match acl 2001
[Device-classifier-1] quit
# Create traffic behavior 1 and configure redirecting traffic to the service module in slot 3 in the traffic behavior 1.
[Device] traffic behavior 1
[Device-behavior-1] redirect slot 3
[Device-behavior-1] quit
# Create QoS policy 1 and associate traffic class 1 with traffic behavior 1 in the QoS policy.
[Device] qos policy 1
[Device-qospolicy-1] classifier 1 behavior 1
[Device-qospolicy-1] quit
# Apply the QoS policy to the inbound direction of Ten-GigabitEthernet 3/1/1.
[Device-Ten-GigabitEthernet3/1/1] qos apply policy 1 inbound
# Access the WWW server from PC 1. Verify that a NAT session is created on the device.
[Device] display nat session verbose
Initiator:
Source IP/port: 10.110.1.10/1024
Destination IP/port: 200.1.1.10/80
DS-Lite tunnel peer: -
Protocol: TCP(6)
Inbound interface: Ten-GigabitEthernet3/1/1
Responder:
Source IP/port: 200.1.1.10/80
Destination IP/port: 61.16.0.2/1025
Protocol: TCP(6)
Inbound interface: Ten-GigabitEthernet3/1/2
State: TCP_CLOSE
Application: HTTP
Start time: 2014-07-08 13:30:47
Initiator->Responder: 0 packets 0 bytes
Responder->Initiator: 0 packets 0 bytes
Total sessions found: 1
# Use two external hosts at the IP address of 61.16.0.10 and 61.16.0.11 to request FTP services at the same time. On the device, verify that two NAT sessions are created, and FTP server 1 and FTP server 2 provide FTP services for the two hosts, respectively.
Initiator:
Source IP/port: 61.16.0.11/1024
Destination IP/port: 61.16.0.1/21
Protocol: TCP(6)
Responder:
Source IP/port: 10.110.3.1/21
Destination IP/port: 61.16.0.11/1024
Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: FTP
Start time: 2014-07-08 14:11:41
Initiator:
Source IP/port: 61.16.0.10/1024
Protocol: TCP(6)
Responder:
Source IP/port: 10.110.3.2/21
Destination IP/port: 61.16.0.10/1024
Protocol: TCP(6)
Application: FTP
Start time: 2014-07-08 14:12:00
Total sessions found: 2
# Access an FTP server through 61.16.0.1 from PC 1. Verify that a NAT session is created.
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
Application: FTP
Start time: 2014-07-08 14:24:15
Configuration files
if-match acl 2001
traffic behavior 1
redirect slot 3
qos policy 1
nat hairpin enable
nat service slot 3
nat server protocol tcp global 61.16.0.1 21 inside server-group 0
nat service slot 3
acl basic 2000
rule 0 permit source 10.110.0.0 0.0.1.255
rule 5 permit source 10.110.2.0 0.0.0.255
acl basic 2001
nat server-group 0
Related documentation
· H3C SR8800-F Routers NAT Configuration Guide
· H3C SR8800-F Routers NAT Command Reference
