- 02-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_ATM_Configuration_Examples
- 04-H3C_IGMP_Configuration_Examples
- 05-H3C_IP_Source_Guard_Configuration_Examples
- 06-H3C_Ethernet_OAM_Configuration_Examples
- 07-H3C_NQA_Configuration_Examples
- 08-H3C_QinQ_Configuration_Examples
- 09-H3C_OSPF_Configuration_Examples
- 10-H3C_MPLS_TE_Configuration_Examples
- 11-H3C_OpenFlow_Configuration_Examples
- 12-H3C_NAT_Configuration_Examples
- 13-H3C_RBAC_Configuration_Examples
- 14-H3C_IRF_Configuration_Examples
- 15-H3C_POS_Interface_Configuration_Examples
- 16-H3C_CPOS_Interface_Configuration_Examples
- 17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 18-H3C_DLDP_Configuration_Examples
- 19-H3C_IS-IS_Configuration_Examples
- 20-H3C_MPLS_L3VPN_Configuration_Examples
- 21-H3C_SSH_Configuration_Examples
- 22-H3C_Login_Management_Configuration_Examples
- 23-H3C_SNMP_Configuration_Examples
- 24-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 25-H3C_Multicast_VPN_Configuration_Examples
- 26-H3C_BGP_Configuration_Examples
- 27-H3C_HoVPN_Configuration_Examples
- 28-H3C_L2TP_Configuration_Examples
- 29-H3C_VRRP_Configuration_Examples
- 30-H3C_Traffic_Filtering_Configuration_Examples
- 31-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 32-H3C_Software_Upgrade_Examples
- 33-H3C_MPLS_L2VPN_Configuration_Examples
- 34-H3C_NetStream_Configuration_Examples
- 35-H3C_Policy-Based_Routing_Configuration_Examples
- 36-H3C_Traffic_Policing_Configuration_Examples
- 37-H3C_BFD_Configuration_Examples
- 38-H3C_OSPFv3_Configuration_Examples
- 39-H3C_VPLS_Configuration_Examples
- 40-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 41-H3C_IPv6_IS-IS_Configuration_Examples
- 42-H3C_MPLS OAM_Configuration_Examples
- 43-H3C_BGP_Route_Selection_Configuration_Examples
- 44-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 45-H3C_SRv6 Configuration Examples
- 46-H3C_Attack_Protection_Configuration_Examples
- 47-H3C_OSPF_Multi-Process_Configuration_Examples
- 48-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 49-H3C_ARP_Attack_Protection_Configuration_Examples
- 50-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 51-CE1 Interface Connection Configuration Examples
- 52-GRE Tunnel Establishment Using OSPF Configuration Examples
- 53-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 54-General QoS Configuration Examples
- 55-QoS Configuration Examples for the Financial Industry
| 04-H3C_IGMP_Configuration_Examples | 162.57 KB |
Example: Configuring basic IGMP features
Example: Configuring IGMP SSM mappings
Introduction
This document provides IGMP configuration examples.
This document assumes that you have basic knowledge of IGMP.
As shown in Figure 1:
· OSPF and PIM-DM run on the network.
· VOD streams are sent in multicast. Hosts of different organizations form stub networks N1 and N2.
IGMPv2 runs between Router A and N1, and between the other two routers and N2. Router A acts as the IGMP querier in N1. Router B acts as the IGMP querier in N2 because it has a lower IP address.
Configure basic IGMP features on the routers to meet the following requirements:
· Hosts in N1 can join any multicast groups.
· Hosts in N2 can join only multicast group 224.1.1.1.
Analysis
To limit the multicast groups that hosts can join, create an IPv4 basic ACL and specify the multicast groups that you want the hosts to join.
When you configure basic IGMP features, follow these restrictions and guidelines:
· The protocol packets of different IGMP versions are different in structures and types. For IGMP to operate correctly, you must enable the same IGMP version for all routers on the same subnet.
· You must configure the same multicast group policy for all routers on the same subnet.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 1. (Details not shown.)
2. Configure OSPF on the routers in the PIM-DM domain. (Details not shown.)
3. Configure Router A:
# Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable IGMP on the receiver-side interface Ten-GigabitEthernet 3/1/1.
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] igmp enable
[RouterA-Ten-GigabitEthernet3/1/1] quit
# Enable PIM-DM on Ten-GigabitEthernet 3/1/2.
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] pim dm
[RouterA-Ten-GigabitEthernet3/1/2] quit
4. Configure Router B:
# Create ACL 2001 to permit IGMP reports for multicast group 224.1.1.1.
<RouterB> system-view
[RouterB] acl basic 2001
[RouterB-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[RouterB-acl-ipv4-basic-2001] quit
[RouterB] multicast routing
[RouterB-mrib] quit
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] igmp enable
# Configure a multicast group policy that uses ACL 2001.
[RouterB-Ten-GigabitEthernet3/1/1] igmp group-policy 2001
[RouterB-Ten-GigabitEthernet3/1/1] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] pim dm
[RouterB-Ten-GigabitEthernet3/1/2] quit
5. Configure Router C:
<RouterC> system-view
[RouterC] acl basic 2001
[RouterC-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[RouterC-acl-ipv4-basic-2001] quit
[RouterC] multicast routing
[RouterC-mrib] quit
[RouterC] interface ten-gigabitethernet 3/1/1
[RouterC-Ten-GigabitEthernet3/1/1] igmp enable
[RouterC-Ten-GigabitEthernet3/1/1] igmp group-policy 2001
[RouterC-Ten-GigabitEthernet3/1/1] quit
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] pim dm
[RouterC-Ten-GigabitEthernet3/1/2] quit
# Send IGMP reports from Host C (10.110.2.10) to join multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
# Display information about IGMP groups that hosts have dynamically joined on Router B.
[RouterB] display igmp group
IGMP groups in total: 1.
Ten-GigabitEthernet3/1/1(10.110.2.1):
IGMP groups reported in total: 1
Group address Last reporter Uptime Expires
224.1.1.1 10.110.2.10 00:02:04 00:01:15
# Display information about IGMP groups that hosts have dynamically joined on Router C.
[RouterC] display igmp group
IGMP groups in total: 1..
Ten-GigabitEthernet3/1/1(10.110.2.2):
The output shows that Router B and Router C each have IGMP membership information about only multicast group, 224.1.1.1. The multicast group policy has taken effect, and hosts in N2 can join only multicast group 224.1.1.1.
Configuration files
· Router A:
interface Ten-GigabitEthernet3/1/1
port link-mode route
igmp enable
interface Ten-GigabitEthernet3/1/2
pim dm
multicast routing
· Router B:
igmp enable
pim dm
multicast routing
acl basic 2001
rule 0 permit source 224.1.1.1 0
· Router C:
pim dm
igmp enable
multicast routing
acl basic 2001
As shown in Figure 2:
· The SSM group range for the PIM-SSM domain is 232.1.1.0/24.
· Router A and Router B in the PIM-SSM domain run IGMPv3.
· Host A in N1 and Host B in N2 run IGMPv2, and they do not support IGMPv3. The other hosts in N1 and N2 run IGMPv3.
Configure IGMP SSM mappings on Router A and Router B to meet the following requirements:
· Hosts in N1 receive multicast data only from Source 1.
· Hosts in N2 receive multicast data only from Source 2.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 2. (Details not shown.)
2. Configure OSPF on the routers in the PIM-SSM domain. (Details not shown.)
3. Enable IP multicast routing and enable PIM-SM:
# On Router A, enable IP multicast routing, and enable PIM-SM on Ten-GigabitEthernet 3/1/1.
[RouterA-mrib] quit
[RouterA-Ten-GigabitEthernet3/1/1] pim sm
# Configure Router B in the same way Router A is configured. (Details not shown.)
# On Router C, enable IP multicast routing, and enable PIM-SM on each interface.
[RouterC-mrib] quit
[RouterC-Ten-GigabitEthernet3/1/1] pim sm
[RouterC-Ten-GigabitEthernet3/1/2] pim sm
[RouterC] interface ten-gigabitethernet 3/1/3
[RouterC-Ten-GigabitEthernet3/1/3] pim sm
[RouterC-Ten-GigabitEthernet3/1/3] quit
4. Configure IGMPv3 on the receiver-side interfaces:
# On Router A, enable IGMP, and specify IGMP version 3 on Ten-GigabitEthernet 3/1/2.
[RouterA-Ten-GigabitEthernet3/1/2] igmp enable
[RouterA-Ten-GigabitEthernet3/1/2] igmp version 3
5. Configure the SSM group range:
# On Router A, configure the SSM group range as 232.1.1.0/24.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[RouterA-acl-ipv4-basic-2000] quit
[RouterA] pim
[RouterA-pim] ssm-policy 2000
[RouterA-pim] quit
# Configure Router B and Router C in the same way Router A is configured. (Details not shown.)
6. Configure IGMP SSM mappings:
# On Router A, map Source 1 to SSM group range 232.1.1.0/24 so that hosts in N1 can receive multicast data only from Source 1.
[RouterA] igmp
[RouterA-igmp] ssm-mapping 10.110.5.100 2000
[RouterA-igmp] quit
# On Router B, map Source 2 to SSM group range 232.1.1.0/24 so that hosts in N2 can receive multicast data only from Source 2.
[RouterB] igmp
[RouterB-igmp] ssm-mapping 10.110.5.101 2000
[RouterB-igmp] quit
# Send IGMPv2 reports from Host A and Host C to join multicast group 232.1.1.1. (Details not shown.)
# Send multicast data from Source 1 and Source 2 to multicast group 232.1.1.1. (Details not shown.)
# Display IGMP SSM mappings for multicast group 232.1.1.1 on Router A.
[RouterA] display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
10.110.5.100
The output shows that multicast group 232.1.1.1 is mapped to Source 1 (10.110.5.100). Router A will translate (0.0.0.0, 232.1.1.1) in IGMPv2 reports to (10.110.5.100, 232.1.1.1).
# Display the PIM routing table on Router A.
[RouterA] display pim routing-table
Total 0 (*, G) entries; 1 (S, G) entries
Protocol: pim-ssm, Flag:
UpTime: 00:00:47
Upstream interface: Ten-GigabitEthernet3/1/1
Upstream neighbor: 192.168.1.1
RPF prime neighbor: 192.168.1.1
1: Ten-GigabitEthernet3/1/2
Protocol: igmp, UpTime: 00:00:47, Expires: -
The output shows that Router A has the (10.110.5.100, 232.1.1.1) entry.
# Display IGMP SSM mappings for multicast group 232.1.1.1 on Router B.
[RouterB] display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
10.110.5.101
The output shows that multicast group 232.1.1.1 is mapped to Source 2 (10.110.5.101). Router B will translate (0.0.0.0, 232.1.1.1) in IGMPv2 reports to (10.110.5.101, 232.1.1.1).
# Display the PIM routing table on Router B.
[RouterB] display pim routing-table
UpTime: 00:00:47
Upstream neighbor: 192.168.2.1
RPF prime neighbor: 192.168.2.1
The output shows that Router B has the (10.110.5.101, 232.1.1.1) entry.
Configuration files
· Router A:
pim sm
igmp enable
igmp version 3
multicast routing
pim
ssm-policy 2000
igmp
acl basic 2000
rule 0 permit source 232.1.1.0 0.0.0.255
· Router B:
pim sm
igmp enable
igmp version 3
multicast routing
pim
ssm-policy 2000
igmp
acl basic 2000
· Router C:
pim sm
pim sm
interface Ten-GigabitEthernet3/1/3
pim sm
multicast routing
Example: Configuring IGMP proxying
As shown in Figure 3:
· PIM-DM runs on the core network.
· Host A and Host C on the stub network receive VOD information sent to multicast group 224.1.1.1.
Configure IGMP proxying on Router A so that Router A can maintain group memberships and forward multicast traffic without running PIM-DM.
Analysis
To implement the network requirements, perform the following tasks on Router A:
· Enable IGMP proxying on the upstream interface so the upstream device regards Router A as a receiver host.
· Enable IGMP on the downstream interface so receiver hosts regard Router A as an IGMP querier.
You must enable IP multicast routing before configuring IGMP proxying.
If you enable both IGMP and IGMP proxying on an interface, only IGMP proxying takes effect. On this interface, only the igmp version command takes effect. Other IGMP commands do not take effect.
If you enable both IGMP proxying and a multicast routing protocol (such as PIM or MSDP) on a device, the multicast routing protocol does not take effect.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 3. (Details not shown.)
[RouterA-mrib] quit
# Enable IGMP proxying on Ten-GigabitEthernet 3/1/1.
[RouterA-Ten-GigabitEthernet3/1/1] igmp proxy enable
# Enable IGMP on Ten-GigabitEthernet 3/1/2 and Ten-GigabitEthernet 3/1/3.
[RouterA] interface ten-gigabitethernet 3/1/3
[RouterA-Ten-GigabitEthernet3/1/3] igmp enable
[RouterA-Ten-GigabitEthernet3/1/3] quit
[RouterB]multicast routing
[RouterB-mrib]quit
# Enable IGMP on Ten-GigabitEthernet 3/1/1.
# Send an IGMP report from Host A to join multicast group 224.1.1.1. (Details not shown.)
# Display information about IGMP multicast groups that hosts have dynamically joined on Ten-GigabitEthernet 3/1/2 of Router A.
[RouterA] display igmp group interface ten-gigabitethernet 3/1/2
Ten-GigabitEthernet3/1/2(10.110.1.1):
224.1.1.1 10.110.1.10 00:02:04 00:01:15
# Display multicast group membership information maintained by the IGMP proxy on Router A.
[RouterA] display igmp proxy group
IGMP proxy group records in total: 1
Ten-GigabitEthernet3/1/1(192.168.1.1):
Group address Member state Expires
224.1.1.1 Delay 00:00:02
The output shows that Router A creates and maintains a membership entry for multicast group 224.1.1.1 based on the IGMP report from Host A. For Host A (a receiver host), Router A acts as an IGMP querier.
# Display information about IGMP multicast groups that hosts have dynamically joined on Ten-GigabitEthernet 3/1/1 of Router B.
[RouterB] display igmp group interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1(192.168.1.2):
224.1.1.1 192.168.1.1 00:02:04 00:01:15
The output shows that Router B creates an IGMP multicast group entry for multicast group 224.1.1.1 and maintains Router A as a receiver host of this group. For Router B (the upstream IGMP querier), Router A acts as a receiver host.
Configuration files
· Router A:
igmp proxy enable
igmp enable
igmp enable
multicast routing
· Router B:
igmp enable
pim dm
multicast routing
Related documentation
· H3C SR8800-F Routers IP Multicast Command Reference
· H3C SR8800-F Routers IP Multicast Configuration Guide
