- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-NTP-MIB
- 04-HH3C-HTTP-MIB
- 05-HH3C-INQA-MIB
- 06-HH3C-MIRRORGROUP-MIB
- 07-HH3C-NETCONF-MIB
- 08-HH3C-NETSTREAM4-MIB
- 09-HH3C-NETSTREAM6-MIB
- 10-HH3C-NQA-MIB
- 11-HH3C-PTP-MIB
- 12-HH3C-RMON-EXT2-MIB
- 13-HH3C-SNMP-EXT-MIB
- 14-HH3C-TWAMP-MIB
- 15-RMON-MIB
- 16-RMON2-MIB
- 17-SNMP-FRAMEWORK-MIB
- 18-SNMP-MPD-MIB
- 19-SNMP-NOTIFICATION-MIB
- 20-SNMP-TARGET-MIB
- 21-SNMP-USER-BASED-SM-MIB
- 22-SNMP-VIEW-BASED-ACM-MIB
- 23-SNMPv2-MIB
| 13-HH3C-SNMP-EXT-MIB | 110.55 KB |
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4)
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5)
hh3cSnmpExtTargetAddress (1.3.6.1.4.1.25506.2.104.1.12)
hh3cSnmpExtFallingThreshold (1.3.6.1.4.1.25506.2.104.1.13)
hh3cSnmpExtRisingThreshold (1.3.6.1.4.1.25506.2.104.1.14)
hh3cSnmpExtLockThresholdResume
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSnmpExt(104)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4) |
read-only |
Integer32 |
Integer32 (1..65535) |
Maximum number of SNMP contexts supported by the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5) |
read-write |
BITS |
BITS { snmpV1(0), snmpV2c(1), snmpV3(2) } |
SNMP version. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtTargetAddress (1.3.6.1.4.1.25506.2.104.1.12) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..255) |
Address of the target host that receives SNMP notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtFallingThreshold (1.3.6.1.4.1.25506.2.104.1.13) |
Integer32 |
Integer32(1..2147483647) |
Falling threshold for the number of users in the SNMPv3 user denylist. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtRisingThreshold (1.3.6.1.4.1.25506.2.104.1.14) |
Integer32 |
Rising threshold for the number of users in the SNMPv3 user denylist. |
As per the MIB. |
Tabular objects
hh3cSnmpExtCommunityTable
About this table
Use this table to configure the extended properties for SNMP communities (SNMPv1 or SNMPv2c) and SNMP users (SNMPv3).
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cSnmpExtCommunitySecurityLevel and hh3cSnmpExtCommunitySecurityName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtCommunitySecurityLevel (1.3.6.1.4.1.25506.2.104.2.1.1.1) |
not-accessible |
SnmpSecurityModel |
INTEGER (0..3) |
Security model of a community or user. |
As per the MIB. |
hh3cSnmpExtCommunitySecurityName (1.3.6.1.4.1.25506.2.104.2.1.1.2) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Security name of the community or user. |
As per the MIB. |
hh3cSnmpExtCommunityName (1.3.6.1.4.1.25506.2.104.2.1.1.3) |
read-only |
OCTET STRING |
Community name or username. |
As per the MIB. |
hh3cSnmpExtCommunityAclNum (1.3.6.1.4.1.25506.2.104.2.1.1.4) |
read-write |
Integer32 |
Integer32 (0 | 2000..3999) |
IPv4 ACL number used by the community or the user. |
As per the MIB. |
hh3cSnmpExtCommunityIPv6AclNum (1.3.6.1.4.1.25506.2.104.2.1.1.5) |
read-write |
Integer32 |
IPv6 ACL number used by the community or the user. |
As per the MIB. |
hh3cSnmpExtContextTable
About this table
Use this table to configure SNMP context extended properties.
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cSnmpExtContextName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtContextName (1.3.6.1.4.1.25506.2.104.2.3.1.1) |
not-accessible |
SnmpAdminString |
Context name. |
As per the MIB. |
hh3cSnmpExtContextRowStatus (1.3.6.1.4.1.25506.2.104.2.3.1.2) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Status of this entry. |
Supports only action, createAndGo, and destroy. |
Notifications
hh3cSnmpExtTargetHostDel
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.104.3.0.1 |
An SNMP notification target host configuration was cancelled. |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the undo snmp-agent target-host command is executed to cancel an SNMP notification target host configuration. This notification is sent only to the canceled target host.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
Standard MIB values. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.104.3.0.2 |
The number of users in the SNMPv3 user denylist exceeded the rising threshold. |
Informational |
Warning |
hh3cSnmpExtLockThresholdResume (hh3cSnmpExtLockThresholdResume) |
ON |
This notification is generated when the number of users in the SNMPv3 user denylist exceeds the rising threshold (40% of the maximum number of users in the SNMPv3 user denylist).
System impact
The device is subject to many authorized user access attacks, which can result in network management connection failure in worst cases.
Status control
ON
CLI: Use the snmp-agent trap enable command.
OFF
CLI: Use the undo snmp-agent trap enable command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Integer32 |
Recommended action
Check the users in the denylist for attack sources and filter attack sources through firewall or other means.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.104.3.0.3 |
The number of users in the SNMPv3 denylist fell below the falling threshold. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the number of users in the SNMPv3 user denylist falls below the falling threshold (10% of the maximum number of users in the SNMPv3 user denylist).
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Integer32 |
Recommended action
