- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-NTP-MIB
- 04-HH3C-HTTP-MIB
- 05-HH3C-INQA-MIB
- 06-HH3C-MIRRORGROUP-MIB
- 07-HH3C-NETCONF-MIB
- 08-HH3C-NETSTREAM4-MIB
- 09-HH3C-NETSTREAM6-MIB
- 10-HH3C-NQA-MIB
- 11-HH3C-PTP-MIB
- 12-HH3C-RMON-EXT2-MIB
- 13-HH3C-SNMP-EXT-MIB
- 14-HH3C-TWAMP-MIB
- 15-RMON-MIB
- 16-RMON2-MIB
- 17-SNMP-FRAMEWORK-MIB
- 18-SNMP-MPD-MIB
- 19-SNMP-NOTIFICATION-MIB
- 20-SNMP-TARGET-MIB
- 21-SNMP-USER-BASED-SM-MIB
- 22-SNMP-VIEW-BASED-ACM-MIB
- 23-SNMPv2-MIB
| 05-HH3C-INQA-MIB | 119.99 KB |
hh3cInqaForwardLossRatio (1.3.6.1.4.1.25506.2.252.1.1.1)
hh3cInqaBackwardLossRatio (1.3.6.1.4.1.25506.2.252.1.1.2)
hh3cInqaInstAttrMismatchReason (1.3.6.1.4.1.25506.2.252.1.1.6)
hh3cInqaAnalyzerLossThresTable
HH3C-INQA-MIB
About this MIB
Use this MIB to configure device INQA.
MIB file name
hh3c-inqa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cInqa(252)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInqaForwardLossRatio (1.3.6.1.4.1.25506.2.252.1.1.1) |
accessible-for-notify |
OCTET STRING |
Standard MIB values. |
Packet loss rate of the forward flow. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInqaBackwardLossRatio (1.3.6.1.4.1.25506.2.252.1.1.2) |
OCTET STRING |
Packet loss rate of the backward flow. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInqaInstAttrMismatchReason (1.3.6.1.4.1.25506.2.252.1.1.6) |
INTEGER |
unspecified(0) flag(1), flow(2), interval(3) |
Reason for instance attribute inconsistency. |
As per the MIB. |
Tabular objects
hh3cInqaAnalyzerInstTable
About this table
Use this table to obtain information about the Analyzer configuration instance.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Not supported
Columns
The table index is hh3cInqaAnalyzerInstID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInqaAnalyzerInstID(1.3.6.1.4.1.25506.2.252.2.1.1.1.1) |
Unsigned32 |
Unsigned32(1.. 8355838) |
Analyzer ID. |
As per the MIB. |
hh3cInqaAnalyzerInstDesc(1.3.6.1.4.1.25506.2.252.2.1.1.1.2) |
read-only |
OCTET STRING |
OCTET STRING(1..64) |
Description of the Analyzer instance. |
As per the MIB. |
hh3cInqaAnalyzerAmsTable
About this table
Use this table to obtain the Atomic Measurement Span (AMS) information of the Analyzer.
Read:Not supported
Columns
The table index is hh3cInqaAnalyzerInstID and hh3cInqaAmsID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInqaAmsID(1.3.6.1.4.1.25506.2.252.2.1.2.1.1) |
Unsigned32 |
Unsigned32(1.. 2147483647) |
AMS ID. |
As per the MIB. |
hh3cInqaAmsFlowDir(1.3.6.1.4.1.25506.2.252.2.1.2.1.2) |
read-only |
INTEGER |
forward (1), backward (2), bidirection (3) |
Target flow direction. |
As per the MIB. |
About this table
Use this table to obtain the packet loss log parameters for the Analyzer instance.
Read:Not supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInqaLossUpperLimit (1.3.6.1.4.1.25506.2.252.2.1.3.1.1) |
read-only |
OCTET STRING |
OCTET STRING(1..10) |
Packet loss alarm threshold, in the range of 0.000001 to 100. |
As per the MIB. |
hh3cInqaLossLowerLimit(1.3.6.1.4.1.25506.2.252.2.1.3.1.2) |
read-only |
OCTET STRING |
Packet loss recovery threshold, in the range of 0.000001 to 100. |
As per the MIB. |
Notifications
hh3cInqaLossRatioExceed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.252.1.0.1 |
The packet loss rate exceeds the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.252.1.0.2 (hh3cInqaLossRatioRecover) |
OFF |
Notification triggers
When packet loss statistics collection is enabled, iNQA periodically calculates the packet loss rate. If the packet loss rate is greater than or equal to the packet loss alarm threshold for five consecutive periods, it indicates that too many packets are lost in the instance. Then, the Analyzer generates a packet loss alarm.
Possible reasons include:
Abnormal traffic causes network congestion.
The link state is unstable.
System impact
The packet loss rate is high and may be unable to meet service requirements on packet loss. Services might be affected.
Status control
ON
CLI: loss-measure alarm upper-limit upper-limit lower-limit lower-limit
OFF
CLI: undo loss-measure alarm
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.252.2.1.1.1.1 (hh3cInqaAnalyzerInstID) |
Analyzer ID. |
hh3cInqaAnalyzerInstID |
Unsigned32 |
Unsigned32 (1.. 8355838) |
1.3.6.1.4.1.25506.2.252.2.1.1.1.2 (hh3cInqaAnalyzerInstDesc) |
OCTET STRING |
1.3.6.1.4.1.25506.2.252.2.1.2.1.1 (hh3cInqaAmsID) |
AMS ID. |
hh3cInqaAnalyzerInstID hh3cInqaAmsID |
Unsigned32 |
Unsigned32 (1.. 2147483647) |
1.3.6.1.4.1.25506.2.252.2.1.2.1.2 (hh3cInqaAmsFlowDir) |
Target traffic direction. |
INTEGER |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.252.2.1.3.1.1 (hh3cInqaLossUpperLimit) |
OCTET STRING |
1.3.6.1.4.1.25506.2.252.2.1.3.1.2 (hh3cInqaLossLowerLimit) |
OCTET STRING |
Recommended action
To resolve the issue:
1.Verify if abnormal traffic exists in the network.
2.Verify if the link state is stable during the alarming periods. Troubleshoot and resolve issues that causes link instability.
3.If the issue persists, collect alarm and configuration information, and contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.252.1.0.2 |
Packet loss rate recovered. |
Recovery |
Warning |
N/A (N/A) |
OFF |
If the packet loss rate is lower than or equal to the packet loss recovery threshold for five consecutive periods, it indicates that the packet loss rate in the instance has dropped to the normal range. Then, the Analyzer generates a packet loss recovery notification.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Analyzer ID. |
Unsigned32 |
OCTET STRING |
AMS ID. |
Unsigned32 |
INTEGER |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
OCTET STRING |
OCTET STRING |
Recommended action
No action is required.
Recover
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.252.1.0.8 |
Instance attribute inconsistency recovered between the analyzer instance and the associated collector. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the instance attribute inconsistency recovers between the analyzer instance and the associated collector.
System impact
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
Analyzer ID. |
Unsigned32 |
Description of the analyzer instance. |
OCTET STRING |
1.3.6.1.4.1.25506.2.252.1.1.6 (hh3cInqaInstAttrMismatchReason) |
N/A |
INTEGER |
unspecified(0), flag(1), flow(2),, interval(3) |
Recommended action
