- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-NTP-MIB
- 04-HH3C-HTTP-MIB
- 05-HH3C-INQA-MIB
- 06-HH3C-MIRRORGROUP-MIB
- 07-HH3C-NETCONF-MIB
- 08-HH3C-NETSTREAM4-MIB
- 09-HH3C-NETSTREAM6-MIB
- 10-HH3C-NQA-MIB
- 11-HH3C-PTP-MIB
- 12-HH3C-RMON-EXT2-MIB
- 13-HH3C-SNMP-EXT-MIB
- 14-HH3C-TWAMP-MIB
- 15-RMON-MIB
- 16-RMON2-MIB
- 17-SNMP-FRAMEWORK-MIB
- 18-SNMP-MPD-MIB
- 19-SNMP-NOTIFICATION-MIB
- 20-SNMP-TARGET-MIB
- 21-SNMP-USER-BASED-SM-MIB
- 22-SNMP-VIEW-BASED-ACM-MIB
- 23-SNMPv2-MIB
| 22-SNMP-VIEW-BASED-ACM-MIB | 96.04 KB |
About this MIB
Use this MIB to manage SNMPv3 settings, including access control view, group, VACM security mode, and security level.
MIB file name
rfc3415-snmp-vacm.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpVacmMIB(16).vacmMIBObjects(1)
Tabular objects
vacmContextTable
About this table
This table contains locally available contexts.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is vacmContextName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vacmContextName (1.3.6.1.6.3.16.1.1.1.1) |
read-only |
SnmpAdminString |
OCTET STRING (0..32) |
A human readable name identifying a context at an SNMP entity. An empty contextName (zero length) represents the default context. |
As per the MIB. |
vacmSecurityToGroupTable
About this table
This table maps a combination of securityModel and securityName into a groupName that is used to define an access control policy for a group of principals.
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are vacmSecurityModel and vacmSecurityName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vacmSecurityModel (1.3.6.1.6.3.16.1.2.1.1) |
not-accessible |
SnmpSecurityModel |
Integer32 (1.. 2147483647) |
Security model, by which the vacmSecurityName referenced by this entry is provided. |
As per the MIB. |
vacmSecurityName (1.3.6.1.6.3.16.1.2.1.2) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Security Name. |
The value can contain only displayable characters except question marks. |
vacmGroupName (1.3.6.1.6.3.16.1.2.1.3) |
read-create |
SnmpAdminString |
Name of the group to which this entry (combination of securityModel and securityName) belongs |
vacmSecurityToGroupStorageType (1.3.6.1.6.3.16.1.2.1.4) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for this conceptual row. |
Supports only be nonVolatile(3). |
vacmSecurityToGroupStatus (1.3.6.1.6.3.16.1.2.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
vacmAccessTable
About this table
Use this table to configure access rights for groups.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are vacmGroupName, vacmAccessContextPrefix, vacmAccessSecurityModel, and vacmAccessSecurityLevel.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vacmAccessContextPrefix (1.3.6.1.6.3.16.1.4.1.1) |
not-accessible |
SnmpAdminString |
In order to gain the access rights allowed by this conceptual row, a contextName must match exactly (if the value of vacmAccessContextMatch is exact) or partially (if the value of vacmAccessContextMatch is prefix) the value of the instance of this object. |
Only the value - is effective. Other values do not take effect. |
vacmAccessSecurityModel (1.3.6.1.6.3.16.1.4.1.2) |
not-accessible |
SnmpSecurityModel |
Integer32 (0.. 2147483647) |
In order to gain the access rights allowed by this conceptual row, this securityModel must be in use. |
As per the MIB. |
vacmAccessSecurityLevel (1.3.6.1.6.3.16.1.4.1.3) |
not-accessible |
SnmpSecurityLevel |
noAuthNoPriv(1), authNoPriv(2), authPriv(3) |
Minimum level of security required to gain the access rights allowed by this conceptual row. |
As per the MIB. |
vacmAccessContextMatch (1.3.6.1.6.3.16.1.4.1.4) |
read-create |
INTEGER |
exact(1), prefix(2) |
Match type. If the value of this object is exact(1), all rows where the contextName exactly matches vacmAccessContextPrefix are selected. If the value of this object is prefix(2), all rows where the contextName whose starting octets exactly match vacmAccessContextPrefix are selected. |
The default value is exact(1). |
vacmAccessReadViewName (1.3.6.1.6.3.16.1.4.1.5) |
read-create |
SnmpAdminString |
The value of an instance of this object identifies the MIB view of the SNMP context to which this conceptual row authorizes read access. |
vacmAccessWriteViewName (1.3.6.1.6.3.16.1.4.1.6) |
read-create |
SnmpAdminString |
The value of an instance of this object identifies the MIB view of the SNMP context to which this conceptual row authorizes write access. |
vacmAccessNotifyViewName (1.3.6.1.6.3.16.1.4.1.7) |
read-create |
SnmpAdminString |
The value of an instance of this object identifies the MIB view of the SNMP context to which this conceptual row authorizes access for notifications. |
vacmAccessStorageType (1.3.6.1.6.3.16.1.4.1.8) |
read-create |
StorageType |
Supports only nonVolatile(3). |
vacmAccessStatus (1.3.6.1.6.3.16.1.4.1.9) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
vacmViewTreeFamilyTable
About this table
Use this table to save information about families of subtrees within MIB views locally.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are vacmViewTreeFamilyViewName and vacmViewTreeFamilySubtree.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
vacmViewTreeFamilyViewName (1.3.6.1.6.3.16.1.5.2.1.1) |
not-accessible |
SnmpAdminString |
Name for a family of view subtrees. |
vacmViewTreeFamilySubtree (1.3.6.1.6.3.16.1.5.2.1.2) |
not-accessible |
OBJECT IDENTIFIER |
Standard MIB values |
MIB subtree which, when combined with the corresponding instance of vacmViewTreeFamilyMask, defines a family of view subtrees. |
As per the MIB. |
vacmViewTreeFamilyMask (1.3.6.1.6.3.16.1.5.2.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..16) |
Bit mask which, in combination with the corresponding instance of vacmViewTreeFamilySubtree, defines a family of view subtrees. |
The default value is a zero-length character string. |
vacmViewTreeFamilyType (1.3.6.1.6.3.16.1.5.2.1.4) |
read-create |
INTEGER |
included(1), excluded(2)} |
Indicates whether the corresponding instances of vacmViewTreeFamilySubtree and vacmViewTreeFamilyMask define a family of view subtrees which is included in or excluded from the MIB view. |
The default value is included(1). |
vacmViewTreeFamilyStorageType (1.3.6.1.6.3.16.1.5.2.1.5) |
read-create |
StorageType |
vacmViewTreeFamilyStatus (1.3.6.1.6.3.16.1.5.2.1.6) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
