20-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
06-HH3C-MIRRORGROUP-MIB
06-HH3C-MIRRORGROUP-MIB 100.63 KB
About this MIB
Use this MIB to configure the source port, monitor port, reflector port, remote probe VLAN, and more.
MIB file name
hh3c-mirrorgroup.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMirrGroup(68)
Tabular objects
hh3cMGTable
About this table
This table creates, deletes, or obtains a mirroring group.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is h3cMGID.
Object (OID)
Access
Value range
Implementation
hh3cMGID (1.3.6.1.4.1.25506.2.68.1.1.1.1.1)
not-accessible
Integer32
0..2147483647
Mirroring group ID.
Implementation varies by product.
hh3cMGType (1.3.6.1.4.1.25506.2.68.1.1.1.1.2)
read-create
INTEGER
local(1)
remote-source(2)
remote-destination(3)
Mirroring group type.
hh3cMGStatus (1.3.6.1.4.1.25506.2.68.1.1.1.1.3)
read-only
INTEGER
active(1)
inactive(2)
Mirroring group state.
As per the MIB.
hh3cMGRowStatus (1.3.6.1.4.1.25506.2.68.1.1.1.1.4)
read-create
RowStatus
Standard MIB values.
Row status.
Supports only the following values:
active(1).
createAndGo(4).
destroy(6).
hh3cMGMirrorIfTable
About this table
This table creates, deletes, or obtains a source port in a mirroring group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cMGID, h3cMGMirrorIfIndex, and h3cMGMirrorDirection.
Object (OID)
Access
Value range
Implementation
hh3cMGMirrorIfIndex (1.3.6.1.4.1.25506.2.68.1.2.1.1.1)
not-accessible
Integer32
Source port index.
As per the MIB.
hh3cMGMirrorDirection (1.3.6.1.4.1.25506.2.68.1.2.1.1.2)
not-accessible
INTEGER
inbound(1)
outbound(2)
both(3)
Mirroring direction.
As per the MIB.
hh3cMGMirrorRowStatus (1.3.6.1.4.1.25506.2.68.1.2.1.1.3)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cMGMonitorIfTable
About this table
This table creates, deletes, or obtains a monitor port in a mirroring group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cMGID and h3cMGMonitorIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cMGMonitorIfIndex (1.3.6.1.4.1.25506.2.68.1.3.1.1.1)
not-accessible
Integer32
Monitor port index.
As per the MIB.
hh3cMGMonitorRowStatus (1.3.6.1.4.1.25506.2.68.1.3.1.1.2)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cMGReflectorIfTable
About this table
This table creates, deletes, or obtains a reflector port in a mirroring group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cMGID and h3cMGReflectorIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cMGReflectorIfIndex (1.3.6.1.4.1.25506.2.68.1.4.1.1.1)
not-accessible
Integer32
Reflector port index.
As per the MIB.
hh3cMGReflectorRowStatus (1.3.6.1.4.1.25506.2.68.1.4.1.1.2)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cMGRprobeVlanTable
About this table
This table creates, deletes, or obtains a remote probe VLAN in a mirroring group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cMGID and h3cMGRprobeVlanID.
Object (OID)
Access
Value range
Implementation
hh3cMGRprobeVlanID (1.3.6.1.4.1.25506.2.68.1.5.1.1.1)
not-accessible
Integer32
1..4094
Remote probe VLAN ID.
As per the MIB.
hh3cMGRprobeVlanRowStatus (1.3.6.1.4.1.25506.2.68.1.5.1.1.2)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cMGEgressIfTable
About this table
This table creates, deletes, or obtains an egress port in a mirroring group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cMGID and h3cMGEgressIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cMGEgressIfIndex (1.3.6.1.4.1.25506.2.68.1.6.1.1.1)
not-accessible
Integer32
0..2147483647
Egress port index.
As per the MIB.
hh3cMGEgressRowStatus (1.3.6.1.4.1.25506.2.68.1.6.1.1.2)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cMGMirrorCpuTable
About this table
This table creates, deletes, or obtains a source CPU in a mirroring group.
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cMGID, h3cMGMirrorCpuChassis, and h3cMGMirrorCpuSlot.
Object (OID)
Access
Value range
Implementation
hh3cMGMirrorCpuChassis (1.3.6.1.4.1.25506.2.68.1.8.1.1.1)
not-accessible
Unsigned32
Chassis number for the source CPU.
As per the MIB.
hh3cMGMirrorCpuSlot (1.3.6.1.4.1.25506.2.68.1.8.1.1.2)
not-accessible
Unsigned32
Slot number for the source CPU.
As per the MIB.
hh3cMGMirrorCpuDirection (1.3.6.1.4.1.25506.2.68.1.8.1.1.3)
read-create
INTEGER
inbound(1),
outbound(2),
both(3)
As per the MIB.
hh3cMGMirrorCpuRowStatus (1.3.6.1.4.1.25506.2.68.1.8.1.1.4)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
