19-EPON Configuration Guides
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release7639Pxx-6W10019-EPON Configuration Guides
05-EPON PoE configuration
05-EPON PoE configuration 86.53 KB
Configuring EPON PoE
EPON PoE overview
On an OLT, you can remotely configure PoE for ONUs.
As shown in Figure 1, the PoE model of the EPON system includes the following elements:
·     PSE—A power sourcing equipment (PSE) is an ONU that supplies power to PDs through UNIs.
·     PD—A powered device (PD) receives power from a PSE. PDs include IP telephones and APs.
Figure 1 EPON PoE model
Restrictions and guidelines: EPON PoE configuration
In an EPON system, support of ONUs for EPON PoE varies by ONU model and software version.
EPON features are supported only on the default MDC. For more information about MDCs, see Virtual Technologies Configuration Guide.
You can configure PoE for UNIs by using the onu poe command series and the uni poe command series. On the same ONU interface or RONU interface, the onu poe command series and the uni poe command series for configuring the same feature are mutually exclusive.
·     To configure PoE with the same parameters on all UNIs of an ONU, use the onu poe command series.
·     To configure PoE on only some UNIs of an ONU or configure PoE with different parameters on UNIs of an ONU, use the uni poe command series.
·     To switch the current commands series to the other command series, use the undo forms of the current command series to cancel the configuration first.
When the sum of power supplied to all PDs connected to UNIs of an ONU exceeds the maximum power of the ONU, the ONU might disable PoE for some UNIs to avoid power overload. As a best practice, use the alarm enable onu power-alarm command to enable the ONU to report power alarms to the OLT. For more information about the alarm enable command, see EPON Command Reference.
Configuring PoE for all UNIs of an ONU
Step
Remarks
N/A
2.     Enter ONU or RONU interface view.
·     Enter ONU interface view.
interface onu interface-number
·     Enter RONU interface view.
interface ronu interface-number
N/A
3.     Enable PoE for all UNIs of the ONU.
onu poe enable
By default, PoE is enabled for all UNIs of an ONU.
4.     Configure a power transmission mode for all UNIs of the ONU.
onu poe mode { signal | spare }
By default, the power transmission mode is power over signal cables (signal) for UNIs.
5.     (Optional.) Enable nonstandard PD detection for all UNIs of the ONU.
onu poe legacy enable
By default, nonstandard PD detection is disabled for UNIs.
6.     (Optional.) Configure the maximum PoE power for each UNI of the ONU.
onu poe max-power { class { class0 | class1 | class2 | class3 | class4 | default } | value max-power-value }
By default, the maximum power of an UNI depends on the maximum power class of the PD attached to the UNI.
Configuring PoE for an UNI of an ONU
Step
Remarks
N/A
N/A
3.     Enable PoE on a single UNI.
uni uni-number poe enable
By default, PoE is disabled for a single UNI. The default of the onu poe enable command takes effect preferentially, and PoE is enabled for all UNIs of an ONU.
4.     Configure a power transmission mode for an UNI.
uni uni-number poe mode { signal | spare }
By default, the power transmission mode is power over signal cables (signal) for an UNI.
5.     (Optional.) Enable nonstandard PD detection for an UNI.
uni uni-number poe legacy enable
By default, nonstandard PD detection is disabled for an UNI.
6.     (Optional.) Configure the maximum power of an UNI.
uni uni-number poe max-power { class { default | class0 | class1 | class2 | class3 | class4 } | value max-power-value }
7.     (Optional.) Configure the power supply priority for an UNI.
uni uni-number poe priority { critical | high | low }
By default, the PoE priority of an UNI is critical.
Display and maintenance commands for EPON PoE
Display PoE information of a UNI.
display uni uni-number poe
ONU interface view
RONU interface view
