- H3C Network Adapter Datasheet-6W102
- 01-About H3C Network Adapters
- 02-PCIe network adapter specifications
- 03-FLOM network adapter specifications
- 04-mLOM network adapter specifications
- 05-sLOM network adapter specifications
- 06-OCP network adapter specifications
- 07-Appendix A Safety standards&EMC standards&Acronyms
- 08-Appendix B FAQs
| 06-OCP network adapter specifications | 1.54 MB |
OCP network adapter list
Table 1 OCP network adapters
Model |
NIC-ETH640F-3S-2P |
2-port 25-GE optical interface OCP Ethernet adapter (SFP28) |
NIC-ETH540F-3S-2P |
2-port 10-GE optical interface OCP Ethernet adapter (SFP+) |
NIC-ETH561F-3S-2P |
NIC-ETH565T-3S-2P |
2-port 10-GE electrical interface OCP Ethernet adapter (RJ-45) |
NIC-ETH360T-3S-4P |
4-port GE electrical interface OCP Ethernet adapter (RJ-45) |
NIC-ETH660F-3S-2P |
NIC-ETH330T-3S-4P |
NIC-ETH531F-3S-2P |
NIC-ETH640F-3S-2P
Figure 1 NIC-ETH640F-3S-2P
Ports and LEDs
Figure 2 NIC-ETH640F-3S-2P front panel
(1) SFP28 fiber port LINK LED |
(2) SFP28 fiber port ACT LED |
(3) 25GE SFP28 fiber ports (2 in total) |
NOTE: For information about the fiber port LEDs, see Table 23. |
Technical specifications
Table 2 NIC-ETH640F-3S-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-AE) |
Maximum power consumption |
14 W |
Bus type |
PCIe 3.0 ×8 |
Form factor |
OCP3.0 (76 × 115 mm or 2.99 × 4.53 in) |
Network properties |
Connectors |
2 × 25-GE SFP28 |
Data rate |
10/25Gbit/s |
Transmission media |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3ae, 802.3az, 802.3ap, 802.1ax, 802.1Q, 802.1p, 802.1Qaz, 802.1Qbb, 802.1Qbg |
Features
Table 3 NIC-ETH640F-3S-2P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Multiple Rx queues (RSS) |
TCP/IP stateless offloading |
TCP/IP Offload Engine (TOE) |
Wake-on-LAN |
RDMA over Converged Ethernet version 1 (RoCE v1) |
RDMA over Converged Ethernet version 2 (RoCE v2) |
Internet Wide Area RDMA Protocol (iWARP) |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
25 Gigabit Ethernet Consortium |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NOTE: · One asterisk (*) indicates that the feature is not available for VMware ESXi. · Three asterisks (***) indicate that the feature is available only for Linux and BSD. · Only one port on the network adapter supports NCSI at a time. |
NIC-ETH540F-3S-2P
Figure 3 NIC-ETH540F-3S-2P
Ports and LEDs
Figure 4 NIC-ETH540F-3S-2P front panel
(1) SFP+ fiber port LINK LED |
(2) SFP+ fiber port ACT LED |
(3) 10-GE SFP+ fiber ports (2 in total) |
Table 4 NIC-ETH540F-3S-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-XE) |
12 W |
Bus type |
PCIe 3.0 ×8 |
Form factor |
Connectors |
2 × 10-GE SFP+ |
Data rate |
10Gbit/s |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3ae, 802.3az, 802.3ap, 802.3ad, 802.1ax, 802.1Q, 802.1p, 802.1Qaz, 802.1Qbb, 802.1Qbg |
Features
Table 5 NIC-ETH540F-3S-2P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NIC-ETH561F-3S-2P
Figure 5 NIC-ETH561F-3S-2P
Ports and LEDs
Figure 6 NIC-ETH561F-3S-2P front panel
NOTE: For information about the fiber port LEDs, see Table 20. |
Table 6 NIC-ETH561F-3S-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Intel FTX710-BM2 |
12 W |
Bus type |
PCIe 3.0 ×8 |
Form factor |
Connectors |
2 × 10-GE SFP+ |
Data rate |
10Gbit/s |
Optical fiber |
Duplex mode |
Full/half duplex |
Standards |
802.3, 802.3ad, 802.1Qbg, 802.1as, 802.1Q, 802.1p, 802.1az, 802.1Qbb |
Features
Table 7 NIC-ETH561F-3S-2P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NIC-ETH565T-3S-2P
Figure 7 NIC-ETH565T-3S-2P
Ports and LEDs
Figure 8 NIC-ETH565T-3S-2P front panel
(1) RJ-45 copper port LINK LED |
(2) RJ-45 copper port ACT LED |
(3) 10-GE RJ-45 copper ports (2 in total) |
NOTE: For information about the copper port LEDs, see Table 22. |
Table 8 NIC-ETH565T-3S-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Intel X710-AT2 |
13 W |
Bus type |
PCIe 3.0 ×4 |
Form factor |
Connectors |
2 × 10-GE RJ-45 |
Data rate |
1/10Gbit/s |
STP cable |
Duplex mode |
Full/half duplex |
Standards |
802.3, 802.3ad, 802.1Qbg, 802.1as, 802.1Q, 802.1p, 802.1az, 802.1Qbb, 802.3bz, 802.3az, 802.1Qaz |
Features
Table 9 NIC-ETH565T-3S-2P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NIC-ETH360T-3S-4P
Figure 9 NIC-ETH360T-3S-4P
Ports and LEDs
Figure 10 NIC-ETH360T-3S-4P front panel
(3) GE RJ-45 copper ports 1 through 4 (from left to right) |
NOTE: For information about the copper port LEDs, see Table 19. |
Table 10 NIC-ETH360T-3S-4P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Intel NHI350AM4 |
6 W |
Bus type |
PCIe 2.0 ×4 |
Form factor |
Connectors |
4 × 1GE RJ-45 |
Data rate |
10/100/1000 Mbps |
STP cable |
Duplex mode |
Full/half duplex |
Standards |
802.3, 802.3ab, 802.3u, 802.3x, 802.3z, 802.3as, 802.3ad, 802.1q, 802.3az, 802.3ap |
Features
Table 11 NIC-ETH360T-3S-4P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NIC-ETH660F-3S-2P
Figure 11 NIC-ETH660F-3S-2P
Ports and LEDs
Figure 12 NIC-ETH660F-3S-2P front panel
(3) 25-GE SFP28 fiber ports (2 in total) |
NOTE: For information about the fiber port LEDs, see Table 24. |
Table 12 NIC-ETH660F-3S-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
EYE810XXVAM2 |
9.2 W |
Bus type |
PCIe 4.0 ×8 |
Form factor |
Connectors |
2 × 25-GE SFP28 |
Data rate |
25Gbit/s |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3, 802.3bd, 802.3ae, 802.3an, 802.3ap, 802.3az, 802.3ba, 802.3z |
Features
Table 13 NIC-ETH660F-3S-2P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NIC-ETH330T-3S-4P
Figure 13 NIC-ETH330T-3S-4P
Ports and LEDs
Figure 14 NIC-ETH330T-3S-4P front panel
(3) 1GE RJ-45 copper ports (4 in total) |
NOTE: For information about the fiber port LEDs, see Table 21. |
Table 14 NIC-ETH330T-3S-4P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
BCM5719A1KFBG |
2.3 W |
Bus type |
PCIe2.1 ×4 |
Form factor |
Connectors |
4 × 1GE RJ-45 |
Data rate |
10/100/1000 Mbit/s |
Twisted pair cables |
Duplex mode |
Full duplex/half duplex |
Standards |
802.3, 802.3ab, 802.3u, 802.3x, 802.3ap, 802.1q, 802.3az |
Features
Table 15 NIC-ETH330T-3S-4P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
NIC-ETH531F-3S-2P
Figure 15 NIC-ETH531F-3S-2P
Ports and LEDs
Figure 16 NIC-ETH531F-3S-2P front panel
Table 16 NIC-ETH531F-3S-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
BCM57412(BCM57412B1KFSBG) |
8.32 W |
Bus type |
PCIe3.0 ×8 |
Form factor |
Connectors |
2 × 10-GE SFP+ |
Data rate |
10 Gbit/s |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3, 802.3x, 802.3ad, 802.3az, 802.3u, 802.1q, 802.1Qbb, 802.1Qaz, 802.1Qau |
Features
Table 17 NIC-ETH531F-3S-2P features
Feature |
Supported or not |
Jumbo frames |
Load balancing |
802.1Q VLANs |
Auto-negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP pass-through |
Remote boot |
PXE boot |
FCoE boot |
iSCSI boot |
LEDs
Table 18 SFP+/SFP28 port status LED description
Status |
LINK (amber) |
ACT (green) |
Steady on |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
A link is present, but the port is not sending or receiving data. |
Off |
Off |
No link is present. |
Table 19 RJ-45 port status LED description
Status |
LINK (green) |
ACT (green) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table 20 SFP+ port status LED description for NIC-ETH561F-3S-2P/NIC-ETH531F-3S-2P
Status |
LINK |
ACT |
Steady green |
Flashing green |
A 10-GE link is present, and the port is sending or receiving data. |
Steady green |
Off |
A 10-GE link is present, but not data is being sent or received. |
Steady amber |
Flashing green |
A GE link is present, and the port is sending or receiving data. |
Steady amber |
Off |
A GE link is present, but not data is being sent or received. |
Off |
Off |
Table 21 RJ-45 port status LED description for the NIC-ETH330T-3S-4P
Status |
LINK |
ACT (green) |
Steady green |
Flashing |
Steady green |
Off |
Steady amber |
Flashing |
A 10M/100M link is present, and the port is sending or receiving data. |
Steady amber |
Off |
A 10M/100M link is present, but not data is being sent or received. |
Off |
Off |
Table 22 RJ-45 port status LED description for NIC-ETH565T-3S-2P
Status |
LINK |
ACT |
Steady green |
Flashing green |
Steady green |
Off |
Steady amber |
Flashing green |
A 1G/100M link is present, and the port is sending or receiving data. |
Steady amber |
Off |
A 1G/100M link is present, but not data is being sent or received. |
Off |
Off |
Table 23 SFP+/SFP28 port status LED description for NIC-ETH540F-3S-2P and NIC-ETH640F-3S-2P
Status |
LINK (green) |
ACT (green) |
Steady |
Flashing |
A link is present, and the port is sending or receiving data. |
Steady |
Off |
Off |
Off |
Table 24 SFP28 port status LED description for NIC-ETH660F-3S-2P
Status |
LINK |
ACT |
Steady green |
Flashing green |
A 25-GE link is present, and the port is sending or receiving data. |
Steady green |
Off |
A 25-GE link is present, but not data is being sent or received. |
Steady amber |
Flashing green |
Steady amber |
Off |
Off |
Off |
