H3C Network Adapter Datasheet-6W102
HomeSupportServersNetwork AdapterProduct LiteratureCard DatasheetsH3C Network Adapter Datasheet-6W102
02-PCIe network adapter specifications
02-PCIe network adapter specifications 21.57 MB
The figures in this section are for illustration only.
PCIe network adapter list
Table 1 PCIe network adapters
Model
CNA-10GE-2P-510F-B2
2-port 10GE optical interface network adapter (SFP+)
NIC-10GE-2P-520F-B2
NIC-10GE-2P-530F-B2
CNA-10GE-2P-560F-B2
NIC-GE-4P-360T-B2
4-port GE electrical interface network adapter
CNA-560T-B2-10Gb-2P
2-port 10GE electrical interface network adapter
NIC-620F-B2-25Gb-2P
2-port 25GE optical interface network adapter (SFP28)
NIC-ETH540F-LP-2P
NIC-ETH1060F-LP-2P
2-port 100GE optical interface network adapter (QSFP28)
NIC-ETH531F-LP-2P
NIC-ETH630F-LP-2P
NIC-ETH641F-LP-2P
NIC-ETH330T-LP-4P
CNA-10GE-2P-510F-B2
Figure 1 CNA-10GE-2P-510F-B2
Ports and LEDs
Figure 2 CNA-10GE-2P-510F-B2 front panel
v6r1_001
(1) SFP+ fiber port ACT LED
(2) SFP+ fiber port LINK LED
(3) 10-GE SFP+ fiber ports (2 in total)
For information about the fiber port LEDs, see Table 28.
Technical specifications
Table 2 CNA-10GE-2P-510F-B2 technical specifications
Item
Specifications
Basic properties
Chip model
Chelsio T5
Maximum power consumption
25 W
Bus type
PCIe3.0 ×8
Form factor
LP
By default, the network adapter comes with a full-height bracket installed. You can install a half-height bracket instead.
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3ad, 802.1q, 802.3az
Available transceiver modules
See "About H3C Network Adapters."
Features
Table 3 CNA-10GE-2P-510F-B2 features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Multiple Rx Queues (RSS)
TCP/IP Stateless Offloading
TCP/IP Offload Engine (TOE)
Wake-on-LAN
RDMA over Converged Ethernet version 1 (RoCE v1)
RDMA over Converged Ethernet version 2 (RoCE v2)
Internet Wide Area RDMA Protocol (iWARP)
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     One asterisk (*) indicates that the feature is not available for VMware ESXi.
·     Two asterisks (**) indicate that the feature is not available for H3C CAS or VMware ESXi.
·     Three asterisks (***) indicate that the feature is available only for Linux and BSD.
NIC-10GE-2P-520F-B2
Figure 3 NIC-10GE-2P-520F-B2
Ports and LEDs
Figure 4 NIC-10GE-2P-520F-B2 front panel
v6r1_001
Table 4 NIC-10GE-2P-520F-B2 technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-3 Pro
10 W
Bus type
PCIe3.0 ×8
Form factor
LP
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 5 NIC-10GE-2P-520F-B2 features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA over Converged Ethernet version 2(RoCE v2)
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     iSCSI is not available for H3C CAS.
NIC-10GE-2P-530F-B2
Figure 5 NIC-10GE-2P-530F-B2
Ports and LEDs
Figure 6 NIC-10GE-2P-530F-B2 front panel
v6r1_001
(3) 10GE SFP+ fiber ports (2 in total)
Table 6 NIC-10GE-2P-530F-B2 technical specifications
Item
Specifications
Basic properties
Chip model
Qlogic BCM57810S
10 W
Bus type
PCIe2.0 ×8
Form factor
LP
Network properties
Connectors
2 × 1/10GE SFP/SFP+
Data rate
1/10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 7 NIC-10GE-2P-530F-B2 features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
CNA-10GE-2P-560F-B2
Figure 7 CNA-10GE-2P-560F-B2
Ports and LEDs
Figure 8 CNA-10GE-2P-560F-B2 front panel
v6r1_001
Table 8 CNA-10GE-2P-560F-B2 technical specifications
Item
Specifications
Basic properties
Chip model
Intel JL82599ES
15 W
Bus type
PCIe2.0 ×8
Form factor
LP
Network properties
Connectors
2 × 1/10GE SFP/SFP+
Data rate
1/10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 9 CNA-10GE-2P-560F-B2 features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA over Converged Ethernet version 1(RoCE v1)
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-GE-4P-360T-B2
Figure 9 NIC-GE-4P-360T-B2
Ports and LEDs
Figure 10 NIC-GE-4P-360T-B2 front panel
v6r1_002
(1) RJ-45 copper port LINK LED
(2) RJ-45 copper port ACT LED
(3) 10/100/1000Base-T autosensing Ethernet ports 1 through 4 (from left to right)
For information about the copper port LEDs, see Table 29.
Table 10 NIC-GE-4P-360T-B2 technical specifications
Item
Specifications
Basic properties
Chip model
Intel NHI350AM4
5 W
Bus type
PCIe2.0 ×4
Form factor
LP
Network properties
Connectors
4 × RJ-45
Data rate
10/100/1000 Mbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
Features
Table 11 NIC-GE-4P-360T-B2 features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
CNA-560T-B2-10Gb-2P
Figure 11 CNA-560T-B2-10Gb-2P
Ports and LEDs
Figure 12 CNA-560T-B2-10Gb-2P front panel
(3) 1/10Gbit/s autosensing Ethernet ports (2 in total)
Table 12 CNA-560T-B2-10Gb-2P technical specifications
Item
Specifications
Basic properties
Chip model
Intel ELX550AT2SLL2E
12 W
Bus type
PCIe3.0 ×4
Form factor
LP
Network properties
Connectors
2 × RJ-45
Data rate
1/10 Gbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
802.3, 802.3u, 802.3x, 802.1q, 802.3az, 802.3an, 802.3bz, 802.3ac, 802.1Qbb, 802.1Qaz, 802.1p
Features
Table 13 CNA-560T-B2-10Gb-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-620F-B2-25Gb-2P
Figure 13 NIC-620F-B2-25Gb-2P
Ports and LEDs
Figure 14 NIC-620F-B2-25Gb-2P ports and LEDs
(1) NCSI connector
(2) SFP28 fiber port ACT LED
(3) SFP28 fiber port LINK LED
(4) 25-GE SFP28 fiber ports (2 in total)
Table 14 NIC-620F-B2-25Gb-2P technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-AE)
12 W
Bus type
PCIe3.0 ×8
Form factor
LP
Network properties
Connectors
2 × 25GE SFP28 and 1 × NCSI
Data rate
1/10/25 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3ad, 802.3az, 802.3ae, 802.3ap, 802.1Q, 802.1p, 802.1Qau, 802.1Qbb, 802.1Qbg, and IEEE802.3BYY2016
Features
Table 15 NIC-620F-B2-25Gb-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     Only one port on the network adapter supports NCSI at a time.
NIC-ETH540F-LP-2P
Figure 15 NIC-ETH540F-LP-2P
Ports and LEDs
Figure 16 NIC-ETH540F-LP-2P ports and LEDs
(1) NCSI connector
(2) SFP+ fiber port ACT LED
(3) SFP+ fiber port LINK LED
(4) 10-GE SFP+ fiber ports (2 in total)
Table 16 NIC-ETH540F-LP-2P technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-XE)
12 W
Bus type
PCIe3.0 ×8
Form factor
LP
Network properties
Connectors
2 × 10-GE SFP and 1 × NCSI
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 17 NIC-ETH540F-LP-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH1060F-LP-2P
Figure 17 NIC-ETH1060F-LP-2P
Ports and LEDs
Figure 18 NIC-ETH1060F-LP-2P ports and LEDs
(1) 100-GE QSFP28 fiber ports (2 in total)
(2) QSFP28 fiber port LINK/ACT LED
For information about the fiber port LEDs, see Table 30.
Table 18 NIC-ETH1060F-LP-2P technical specifications
Item
Specifications
Basic properties
Chip model
E810-CAM2
25 W
Bus type
PCIe4.0 x16
Form factor
LP
Network properties
Connectors
2 × 100GE QSFP28 and 1 × NCSI
Data rate
100 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex in active/standby mode
Standards
802.3, 802.3bd, 802.3ae, 802.3an, 802.3ap, 802.3az, 802.3ba, 802.3z
Features
Table 19 NIC-ETH1060F-LP-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH531F-LP-2P
Figure 19 NIC-ETH531F-LP-2P
Ports and LEDs
Figure 20 NIC-ETH531F-LP-2P ports and LEDs
(1) Network adapter NCSI connector
Table 20 NIC-ETH531F-LP-2P technical specifications
Item
Specifications
Basic properties
Chip model
BCM57412
10 W
Bus type
PCIe3.0 x8
Form factor
LP
Network properties
Connectors
2 × 10GE SFP+ and 1 × NCSI
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Standards
802.3, 802.3x, 802.3ad, 802.3az, 802.3u, 802.1q, 802.1Qbb, 802.1Qaz, 802.1Qau
Features
Table 21 NIC-ETH531F-LP-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH630F-LP-2P
Figure 21 NIC-ETH630F-LP-2P
Ports and LEDs
Figure 22 NIC-ETH630F-LP-2P ports and LEDs
Table 22 NIC-ETH630F-LP-2P technical specifications
Item
Specifications
Basic properties
Chip model
BCM57414
13 W
Bus type
PCIe3.0 x8
Form factor
LP
Network properties
Connectors
Data rate
25 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 23 NIC-ETH630F-LP-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH641F-LP-2P
Figure 23 NIC-ETH641F-LP-2P
Ports and LEDs
Figure 24 NIC-ETH641F-LP-2P ports and LEDs
Table 24 NIC-ETH641F-LP-2P technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-6 Lx (MT28942A0-NCCF-AE)
13 W
Bus type
PCIe4.0 x8
Form factor
LP
Network properties
Connectors
Data rate
25 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 25 NIC-ETH641F-LP-2P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH330T-LP-4P
Figure 25 NIC-ETH330T-LP-4P
Ports and LEDs
Figure 26 NIC-ETH330T-LP-4P ports and LEDs
v6r1_002
(3) 10/100/1000Base-T autosensing Ethernet ports (4 in total)
Table 26 UN-NIC-ETH330T-LP-4P technical specifications
Item
Specifications
Basic properties
Chip model
BCM5719A1KFBG
8 W
Bus type
PCIe2.0 x4
Form factor
LP
Network properties
Connectors
4 × RJ-45
Data rate
10/100/1000 Mbit/s
Transmission media
Twisted pair cables
Duplex mode
Full duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3ap, 802.1q, 802.3az
Features
Table 27 NIC-ETH330T-LP-4P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
LEDs
Table 28 SFP+/SFP28 port status LED description
Status
LINK (amber)
ACT (green)
Steady on
Flashing
The port is sending or receiving data.
Steady on
Off
A link is present, but the port is not sending or receiving data.
Off
Off
No link is present.
Table 29 RJ-45 port status LED description
Status
LINK (green)
ACT (green)
Steady on
Flashing
Steady on
Off
Off
Off
No link is present.
Table 30 QSFP28 port status LED description for NIC-ETH1060F-LP-2P
Status
Steady green
A 100-GE link is present, but no data is being sent or received
Flashing green
A 100-GE link is present, and the port is sending or receiving data.
Off
No link is present.
