- H3C Network Adapter Datasheet-6W102
- 01-About H3C Network Adapters
- 02-PCIe network adapter specifications
- 03-FLOM network adapter specifications
- 04-mLOM network adapter specifications
- 05-sLOM network adapter specifications
- 06-OCP network adapter specifications
- 07-Appendix A Safety standards&EMC standards&Acronyms
- 08-Appendix B FAQs
| 05-sLOM network adapter specifications | 981.82 KB |
The figures in this section are for illustration only.
sLOM network adapter list
Table 1 sLOM network adapters
Model |
Specifications |
NIC-GE-4P-360T-s2 |
4-port GE electrical interface sLOM network adapter |
NIC-10GE-2P-530F-s3 |
2-port 10-GE optical interface sLOM network adapter (SFP+) |
NIC-ETH561F-sL-2*10G |
NIC-ETH561F-sL-4*10G |
4-port 10-GE optical interface sLOM network adapter (SFP+) |
NIC-ETH640F-L-2*25G |
2-port 25-GE optical interface sLOM network adapter (SFP28) |
NIC-ETH563T-SL-2P |
2-port 10-GE electrical interface sLOM network adapter (RJ-45) |
NIC-GE-4P-360T-s2
Figure 1 NIC-GE-4P-360T-s2
Ports and LEDs
Figure 2 NIC-GE-4P-360T-s2 front panel
(1) RJ-45 copper port LINK LED |
(2) RJ-45 copper port ACT LED |
(3) 1000Base-T Ethernet ports 1 through 4 (from left to right) |
NOTE: For information about the copper port LEDs, see Table 15. |
Technical specifications
Table 2 NIC-GE-4P-360T-s2 technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Intel NHI350AM4 |
Maximum power consumption |
6 W |
Bus type |
PCIe 2.0 ×4 |
Form factor |
Embedded sLOM (128 × 78 mm or 5.04 × 3.07 in) |
Network properties |
Connectors |
4 × RJ-45 |
Data rate |
10/100/1000 Mbit/s |
Transmission media |
STP cable |
Duplex mode |
Full duplex/half duplex |
Standards |
802.3, 802.3ab, 802.3u, 802.3x, 802.3ad, 802.1q, 802.3az |
Features
Table 3 NIC-GE-4P-360T-s2 features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Multiple Rx Queues (RSS) |
TCP/IP Stateless Offloading |
TCP/IP Offload Engine (TOE) |
Wake-on-LAN |
RDMA over Converged Ethernet version 1 (RoCE v1) |
RDMA over Converged Ethernet version 2 (RoCE v2) |
Internet Wide Area RDMA Protocol (iWARP) |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NOTE: · One asterisk (*) indicates that the feature is not available for VMware ESXi. · Three asterisks (***) indicate that the feature is available only for Linux and BSD. · Only one port on the network adapter supports NCSI at a time. |
NIC-10GE-2P-530F-s3
Figure 3 NIC-10GE-2P-530F-s3
Ports and LEDs
Figure 4 NIC-10GE-2P-530F-s3 front panel
(1) SFP+ fiber port ACT LED |
(2) SFP+ fiber port LINK LED |
(3) 10-GE SFP+ fiber ports (2 in total) |
NOTE: For information about the fiber port LEDs, see Table 14. |
Table 4 NIC-10GE-2P-530F-s3 technical specifications
Item |
Specifications |
Basic properties |
Chip model |
BCM57810S |
10 W |
Bus type |
PCIe 2.0 ×8 |
Form factor |
Connectors |
2 × 10-GE SFP+ |
Data rate |
1/10 Gbit/s |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
Features
Table 5 NIC-10GE-2P-530F-s3 features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NOTE: · One asterisk (*) indicates that the feature is not available for VMware ESXi. · Only one port on the network adapter supports NCSI at a time. |
Ports and LEDs
Figure 5 NIC-ETH561F-sL-2*10G front panel
(1) SFP+ fiber port LED (one for each port) |
(2) 10-GE SFP+ fiber ports (2 in total) |
NOTE: For information about the fiber port LED, see Table 16. |
Table 6 NIC-ETH561F-sL-2*10G technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Intel X710-BM2 |
10 W |
Bus type |
PCIe 3.0 ×8 |
Form factor |
Connectors |
2 × 10-GE SFP+ |
Data rate |
10 Gbit/s |
Optical fiber |
Duplex mode |
Standards |
802.3, 802.3ad, 802.1Qbg, 802.1as, 802.1Q, 802.1p |
Features
Table 7 NIC-ETH561F-sL-2*10G features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NOTE: · One asterisk (*) indicates that the feature is not available for VMware ESXi. · Three asterisks (***) indicate that the feature is available only for Linux and BSD. · Only one port on the network adapter supports NCSI at a time. · A pound sign (#) indicates that the feature is available only in UEFI mode. |
Figure 6 NIC-ETH561F-sL-4*10G
Ports and LEDs
Figure 7 NIC-ETH561F-sL-4*10G front panel
(2) 10-GE SFP+ fiber ports 1 through 4 (from left to right) |
Table 8 NIC-ETH561F-sL-4*10G
Item |
Specifications |
Basic properties |
Chip model |
Intel XL710-BM1 |
13 W |
Bus type |
PCIe 3.0 ×8 |
Form factor |
Connectors |
4 × 10-GE SFP+ |
Data rate |
10 Gbit/s |
Optical fiber |
Duplex mode |
Standards |
Features
Table 9 NIC-ETH561F-sL-4*10G features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NIC-ETH640F-L-2*25G
Figure 8 NIC-ETH640F-L-2*25G
Ports and LEDs
Figure 9 NIC-ETH640F-L-2*25G front panel
(1) SFP28 fiber port ACT LED |
(2) SFP28 fiber port LINK LED |
(3) SFP28 fiber port (2 in total) |
Table 10 NIC-ETH640F-L-2*25G technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-AE) |
9.2 W |
Bus type |
PCIe3.0 ×8 |
Form factor |
Connectors |
2 × 25-GE SFP28 |
Data rate |
10/25 Gbit/s |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3, 802.3ad, 802.3az, 802.3ae, 802.3ap, 802.1Q, 802.1p, 802.1Qau, 802.1Qbb, 802.1Qbg, and IEEE802.3BYY2016 |
Available transceiver modules |
See "About H3C Network Adapters." |
Features
Table 11 NIC-ETH640F-L-2*25G features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NIC-ETH563T-sL-2P
Figure 10 NIC-ETH563T-sL-2P
Ports and LEDs
(3) RJ-45 copper ports (2 in total) |
Table 12 NIC-ETH563T-sL-2P technical specifications
Item |
Specifications |
Basic properties |
Chip model |
Intel ELX550AT2SLL2E |
16.2 W |
Bus type |
PCIE3.0 ×4 |
Form factor |
Connectors |
2 × 10-GE RJ-45 |
Data rate |
1/10 Gbit/s |
STP cable |
Duplex mode |
Full duplex |
Standards |
802.3, 802.3ab, 802.3ad, 802.1q, 802.3az |
Features
Table 13 NIC-ETH563T-sL-2P features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
LEDs
Table 14 SFP+/SFP28 port status LED description
Status |
LINK (amber) |
ACT (green) |
Steady on |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
A link is present, but the port is not sending or receiving data. |
Off |
Off |
No link is present. |
Table 15 RJ-45 port status LED description
Status |
LINK (green) |
ACT (green) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table 16 SFP+ port status LED description for NIC-ETH561F-sL-2*10G and NIC-ETH561F-sL-4*10G
Status |
Steady green |
A 10-GE link is present, but no data is being sent or received. |
Flashing green |
A 10-GE link is present, and the port is sending or receiving data. |
Steady amber |
A GE link is present, but no data is being sent or received. |
Flashing amber |
A GE link is present, and the port is sending or receiving data. |
Off |
