- H3C Network Adapter Datasheet-6W102
- 01-About H3C Network Adapters
- 02-PCIe network adapter specifications
- 03-FLOM network adapter specifications
- 04-mLOM network adapter specifications
- 05-sLOM network adapter specifications
- 06-OCP network adapter specifications
- 07-Appendix A Safety standards&EMC standards&Acronyms
- 08-Appendix B FAQs
| 04-mLOM network adapter specifications | 959.52 KB |
The figures in this section are for illustration only.
mLOM network adapter list
Table 1 mLOM network adapters
Model |
Specifications |
NIC-10GE-2P-560F-L2 |
2-port 10-GE optical interface mLOM network adapter (SFP+) |
NIC-10GE-2P-560F-L2-M |
NIC-GE-4P-360T-L3 |
4-port GE electrical interface mLOM network adapter |
NIC-GE-4P-360T-L3-M |
NIC-10GE-2P-560T-L2 |
2-port 10-GE electrical interface mLOM network adapter |
NIC-10GE-2P-560T-L2-M |
NIC-10GE-2P-560F-L2
Figure 1 NIC-10GE-2P-560F-L2
Ports and LEDs
Figure 2 NIC-10GE-2P-560F-L2 front panel
(1) SFP+ fiber port LINK LED |
(2) SFP+ fiber port ACT LED |
(3) 10-GE SFP+ fiber ports (2 in total) |
NOTE: For information about the fiber port LEDs, see Table 14. |
Technical specifications
Table 2 NIC-10GE-2P-560F-L2 technical specifications
Item |
Specifications |
Basic properties |
Chip model |
MAC chip: Intel X722 PHY chip: Inphi WPCS4227C.A2 NOTE: The X722 MAC chip is on the system board and is available only for G3 servers. |
Maximum power consumption |
7 W |
Bus type |
KR ×2 |
Form factor |
mLOM |
Network properties |
Connectors |
2 × 10-GE SFP+ |
Data rate |
10 Gbit/s |
Transmission media |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3, 802.3ab, 802.3ad, 802.1q, 802.3az |
Available transceiver modules |
See "About H3C Network Adapters." |
Features
Table 3 NIC-10GE-2P-560F-L2 features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Multiple Rx Queues (RSS) |
TCP/IP Stateless Offloading |
TCP/IP Offload Engine (TOE) |
Wake-on-LAN |
RDMA over Converged Ethernet version 1 (RoCE v1) |
RDMA over Converged Ethernet version 2 (RoCE v2) |
Internet Wide Area RDMA Protocol (iWARP) |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NOTE: · One asterisk (*) indicates that the feature is not available for VMware ESXi. · Three asterisks (***) indicate that the feature is available only for Linux and BSD. · Only one port on the network adapter supports NCSI at a time. |
Figure 3 NIC-10GE-2P-560F-L2-M
Ports and LEDs
Figure 4 NIC-10GE-2P-560F-L2-M front panel
(1) 10-GE SFP+ fiber ports (2 in total) |
(2) SFP+ fiber port LINK LED |
(3) SFP+ fiber port ACT LED |
Table 4 NIC-10GE-2P-560F-L2-M technical specifications
Item |
Specifications |
Basic properties |
Chip model |
MAC chip: Intel X722 PHY chip: Inphi CS4227 NOTE: The X722 MAC chip is on the system board and is available only for G3 servers. |
15 W |
Bus type |
10G-KR ×2 |
Form factor |
LP By default, the network adapter comes with a full-height bracket installed. |
Connectors |
2 × 10-GE SFP+ |
Data rate |
10 Gbit/s |
Optical fiber |
Duplex mode |
Full duplex |
Standards |
802.3, 802.3ab, 802.3u, 802.3x, 802.3ad, 802.1q, 802.3az |
Features
Table 5 NIC-10GE-2P-560F-L2-M features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NIC-GE-4P-360T-L3
Figure 5 NIC-GE-4P-360T-L3
Ports and LEDs
Figure 6 NIC-GE-4P-360T-L3 front panel
(1) RJ-45 copper port LINK LED |
(2) RJ-45 copper port ACT LED |
(3) 1000Base-T Ethernet ports 1 through 4 (from left to right) |
NOTE: For information about the copper port LEDs, see Table 15. |
Table 6 NIC-GE-4P-360T-L3 technical specifications
Item |
Specifications |
Basic properties |
Chip model |
MAC chip: Intel X722 PHY chip: Marvell 88E1543-A1-LKJ2C000 NOTE: The X722 MAC chip is on the system board and is available only for G3 servers. |
3 W |
Bus type |
SGMII ×4 |
Form factor |
mLOM |
Connectors |
4 × RJ-45 |
Data rate |
1000 Mbit/s |
STP cable |
Duplex mode |
Full duplex |
Standards |
Features
Table 7 NIC-GE-4P-360T-L3 features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NIC-GE-4P-360T-L3-M
Figure 7 NIC-GE-4P-360T-L3-M
Ports and LEDs
Figure 8 NIC-GE-4P-360T-L3-M front panel
(1) 1000Base-T Ethernet ports 1 through 4 (from left to right) |
(3) RJ-45 copper port LINK LED |
Table 8 NIC-GE-4P-360T-L3-M technical specifications
Item |
Specifications |
Basic properties |
Chip model |
MAC chip: Intel X722 PHY chip: Marvell 88E1543 NOTE: The X722 MAC chip is on the system board and is available only for G3 servers. |
5 W |
Bus type |
1000BASE-X ×4 |
Form factor |
Connectors |
4 × RJ-45 |
Data rate |
1000 Mbit/s |
STP cable |
Duplex mode |
Full duplex |
Standards |
Features
Table 9 NIC-GE-4P-360T-L3-M features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
NIC-10GE-2P-560T-L2
Figure 9 NIC-10GE-2P-560T-L2
Ports and LEDs
Figure 10 NIC-10GE-2P-560T-L2 front panel
(3) 1/10Gbit/s autosensing Ethernet ports (2 in total) |
NOTE: For information about the copper port LEDs, see Table 16. |
Table 10 NIC-10GE-2P-560T-L2 technical specifications
Item |
Specifications |
Basic properties |
Chip model |
MAC chip: Intel X722 PHY chip: Intel EZX557AT2 NOTE: The X722 MAC chip is on the system board and is available only for G3 servers. |
11 W |
Bus type |
KR ×2 |
Form factor |
mLOM |
Connectors |
2 × RJ-45 |
Data rate |
1/10 Gbit/s |
STP cable |
Duplex |
Full duplex |
Standards |
Features
Table 11 NIC-10GE-2P-560T-L2 features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
Figure 11 NIC-10GE-2P-560T-L2-M
Ports and LEDs
Figure 12 NIC-10GE-2P-560T-L2-M front panel
Table 12 NIC-10GE-2P-560T-L2-M technical specifications
Item |
Specifications |
Basic properties |
Chip model |
MAC chip: Intel X722 PHY chip: Intel X557-AT2 NOTE: The X722 MAC chip is on the system board and is available only for G3 servers. |
15 W |
Bus type |
10G-KR ×2 |
Form factor |
Connectors |
2 × RJ-45 |
Data rate |
1/10 Gbit/s |
STP cable |
Duplex mode |
Full duplex |
Standards |
Features
Table 13 NIC-10GE-2P-560T-L2-M features
Feature |
Supported |
Jumbo Frames |
Load Balancing |
802.1Q VLANs |
Auto-Negotiation |
FCoE |
iSCSI |
SRIOV |
VMDq |
Wake-on-LAN |
NPAR |
NCSI |
NIC bonding |
DPDK |
IPv6 |
LLDP |
LLDP Pass-through |
Remote boot |
PXE Boot |
FCoE Boot |
iSCSI Boot |
LEDs
Table 14 SFP+/SFP28 port status LED description
Status |
LINK (amber) |
ACT (green) |
Steady on |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
A link is present, but the port is not sending or receiving data. |
Off |
Off |
No link is present. |
Table 15 RJ-45 port status LED description
Status |
LINK (green) |
ACT (green) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table 16 RJ-45 port status LED description for NIC-10GE-2P-560T-L2 and NIC-10GE-2P-560T-L2-M
Status |
LINK |
ACT |
Steady amber |
Flashing green |
A 10-GE link is present, and the port is sending or receiving data. |
Steady amber |
Off |
A 10-GE link is present, but no data is being sent or received. |
Steady green |
Flashing green |
A GE link is present, and the port is sending or receiving data. |
Steady green |
Off |
A GE link is present, but no data is being sent or received. |
Off |
Off |
