- H3C Network Adapter Datasheet-6W102
- 01-About H3C Network Adapters
- 02-PCIe network adapter specifications
- 03-FLOM network adapter specifications
- 04-mLOM network adapter specifications
- 05-sLOM network adapter specifications
- 06-OCP network adapter specifications
- 07-Appendix A Safety standards&EMC standards&Acronyms
- 08-Appendix B FAQs
| 00-Preface | 177.14 KB |
Preface
This documentation describes the appearance, interfaces, LEDs, properties, and supported features for the H3C network adapters.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the server configuration and O&M.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
