- 04-Layer 3—IP Services Configuration Examples
- 01-DHCP Snooping Configuration Examples
- 02-DHCPv6 Server and DHCPv6 Prefix Client Configuration Examples
- 03-GRE with OSPF Configuration Examples
- 04-GRE with VPN Configuration Examples
- 05-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 06-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 07-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 08-IP Unnumbered Configuration Examples
- 09-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
| 06-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples | 100.79 KB |
Example: Configuring IPv6 over IPv4 manual tunneling with OSPFv3
Configuring IPv6 over IPv4 manual tunnels
Introduction
This document provides IPv6 over IPv4 manual tunneling with OSPFv3 configuration examples.
This document assumes that you have basic knowledge of HP IPv6 over IPv4 manual tunneling and OSPFv3.
As shown in Figure 1, in IPv6 networks, Device A, Device B, and Device C act as the gateways of the headquarters, Branch 1, and Branch 2, respectively.
Configure IPv6 over IPv4 manual tunnels to ensure that the headquarters can communicate with the two branches over IPv4 networks.
Configure OSPFv3 on the gateways to ensure the following:
· The gateways have routes to destination IPv6 addresses through tunnel interfaces.
· Branch 1 and Branch 2 can communicate with each other through the headquarters.
Device |
IP address |
Device A |
Vlan-int10 |
20.1.1.1/24 |
Vlan-int20 |
2001::1/64 |
Tunnel1 |
3001::1/64 |
Tunnel2 |
4001::1/64 |
Device B |
Vlan-int10 |
30.1.1.1/24 |
Vlan-int20 |
5001::1/64 |
Tunnel1 |
3001::2/64 |
Device C |
Vlan-int10 |
40.1.1.1/24 |
Vlan-int20 |
6001::1/64 |
Tunnel2 |
4001::2/64 |
Hardware |
Software version |
S12500G-AF switch series |
Release 7639P01 and later |
S10500X switch series |
S10500 switch series |
S7500E-X switch series |
S7500E switch series |
S7500X switch series |
The device cannot directly route a tunneled packet based on its destination address. The packet is sent to a tunnel-type service loopback group, which then delivers the packet to the forwarding module for Layer 3 forwarding. For the tunnel interface to forward and receive packets, you must configure a tunnel-type service loopback group on the device.
Procedures
Make sure the gateways can reach each other at IPv4.
· Configure Device A:
# Configure an IP address for VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 20.1.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[DeviceA] interface Ten-GigabitEthernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet1/0/3] quit
# Configure an IPv6 over IPv4 manual tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipv6-ipv4
# Configure an IPv6 address for Tunnel 1.
[DeviceA-Tunnel1] ipv6 address 3001::1/64
# Specify VLAN-interface 10 as the source interface of Tunnel 1.
[DeviceA-Tunnel1] source vlan-interface 10
# Specify the destination address for Tunnel 1.
[DeviceA-Tunnel1] destination 30.1.1.1
[DeviceA-Tunnel1] quit
# Configure an IPv6 over IPv4 manual tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipv6-ipv4
# Configure an IPv6 address for Tunnel 2.
[DeviceA-Tunnel2] ipv6 address 4001::1/64
# Specify VLAN-interface 10 as the source interface of Tunnel 2.
[DeviceA-Tunnel2] source Vlan-interface 10
# Specify the destination address for Tunnel 2.
[DeviceA-Tunnel2] destination 40.1.1.1
[DeviceA-Tunnel2] quit
· Configure Device B:
[DeviceB] vlan 10
[DeviceB-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 30.1.1.1 24
[DeviceB-Vlan-interface10] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface Ten-GigabitEthernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceB-Ten-GigabitEthernet1/0/3] quit
[DeviceB] interface tunnel 1 mode ipv6-ipv4
[DeviceB-Tunnel1] ipv6 address 3001::2/64
[DeviceB-Tunnel1] source vlan-interface 10
[DeviceB-Tunnel1] destination 20.1.1.1
[DeviceB-Tunnel1] quit
· Configure Device C:
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ip address 40.1.1.1 24
[DeviceC-Vlan-interface10] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface Ten-GigabitEthernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-Ten-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 2 mode ipv6-ipv4
[DeviceC-Tunnel2] ipv6 address 4001::2/64
[DeviceC-Tunnel2] source vlan-interface 10
[DeviceC-Tunnel2] destination 20.1.1.1
[DeviceC-Tunnel2] quit
Configuring OSPFv3
# Specify the router ID as 1.1.1.1.
[DeviceA] ospfv3
[DeviceA-ospfv3-1] router-id 1.1.1.1
[DeviceA-ospfv3-1] quit
# Enable OSPFv3 on Tunnel 1.
[DeviceA] interface Tunnel 1
[DeviceA-Tunnel1] ospfv3 1 area 0
# Enable OSPFv3 on Tunnel 2.
[DeviceA] interface Tunnel 2
[DeviceA-Tunnel2] ospfv3 1 area 0
# Enable OSPFv3 on VLAN-interface 20.
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ospfv3 1 area 0
[DeviceA-Vlan-interface20] quit
# Specify the router ID as 2.2.2.2.
[DeviceB] ospfv3
[DeviceB-ospfv3-1] router-id 2.2.2.2
[DeviceB-ospfv3-1] quit
[DeviceB] interface Tunnel 1
[DeviceB-Tunnel1] ospfv3 1 area 0
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ospfv3 1 area 0
[DeviceB-Vlan-interface20] quit
# Specify the router ID as 3.3.3.3.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 3.3.3.3
[DeviceC-ospfv3-1] quit
[DeviceC] interface Tunnel 2
[DeviceC-Tunnel2] ospfv3 1 area 0
[DeviceC] interface vlan-interface 20
[DeviceC-Vlan-interface20] ospfv3 1 area 0
[DeviceC-Vlan-interface20] quit
# Ping PC 1 from PC 2.
Pinging 2001::3
from 5001::3 with 32 bytes of data:
Reply from 2001::3: bytes=32 time=13ms
Reply from 2001::3: bytes=32 time=1ms
Reply from 2001::3: bytes=32 time<1ms
Ping statistics for 2001::3:
Minimum = 0ms, Maximum = 13ms, Average = 3ms
The output shows that the ping operation succeeds.
# Ping PC 3 from PC 2.
D:\>ping6 -s 5001::3 6001::3
Pinging 6001::3
from 6001::3 with 32 bytes of data:
Reply from 6001::3: bytes=32 time=13ms
Reply from 6001::3: bytes=32 time=1ms
Reply from 6001::3: bytes=32 time<1ms
Ping statistics for 6001::3:
Configuration files
· Device A:
ospfv3 1
router-id 1.1.1.1
area 0.0.0.0
vlan 10
vlan 20
interface Vlan-interface10
ip address 20.1.1.1 255.255.255.0
interface Vlan-interface20
ospfv3 1 area 0.0.0.0
ipv6 address 2001::1/64
port link-mode bridge
port access vlan 10
port access vlan 20
interface Tunnel1 mode ipv6-ipv4
source Vlan-interface10
interface Tunnel2 mode ipv6-ipv4
· Device B:
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
vlan 10
vlan 20
ip address 30.1.1.1 255.255.255.0
ipv6 address 5001::1/64
port access vlan 10
port access vlan 20
· Device C:
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
vlan 10
vlan 20
ip address 40.1.1.1 255.255.255.0
ipv6 address 6001::1/64
port access vlan 10
port access vlan 20
