10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10010-MPLS
23-PW-MPLS-STD-MIB
23-PW-MPLS-STD-MIB 59.84 KB
PW-MPLS-STD-MIB
About this MIB
Use this MIB to configure PWs.
MIB file name
rfc5602-pw-mpls-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwMplsStdMIB(181)
Tabular objects
pwMplsTable
About this table
Use this table to configure and obtain settings of the MPLS public tunnel that carries a PW.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is pwIndex.
Object (OID)
Access
Value range
Implementation
pwMplsMplsType (1.3.6.1.2.1.181.1.1.1.1)
read-write
BITS
mplsTe(0),
mplsNonTe(1),
pwOnly(2)
Type of the public tunnel.
Supports only the read operation.
pwMplsExpBitsMode (1.3.6.1.2.1.181.1.1.1.2)
read-write
INTEGER
outerTunnel(1),
specifiedValue(2),
serviceDependant(3)
Type of the Exp field of the MPLS label.
As per the MIB.
pwMplsExpBits (1.3.6.1.2.1.181.1.1.1.3)
read-write
Unsigned32
Unsigned32 (0..7)
Value of the Exp field of the MPLS label.
As per the MIB.
pwMplsTtl (1.3.6.1.2.1.181.1.1.1.4)
read-write
Unsigned32
Unsigned32 (0..255)
TTL value of the MPLS PW.
As per the MIB.
pwMplsLocalLdpID (1.3.6.1.2.1.181.1.1.1.5)
read-write
MplsLdpIdentifier
OCTET STRING (6)
Local LDP ID.
pwMplsLocalLdpEntityIndex (1.3.6.1.2.1.181.1.1.1.6)
read-write
Unsigned32
Unsigned32 (1..2147483647)
LDP entity index of the LDP entity that creates this PW on the local node.
As per the MIB.
pwMplsPeerLdpID (1.3.6.1.2.1.181.1.1.1.7)
read-only
MplsLdpIdentifier
OCTET STRING (6)
The peer LDP identifier of the LDP session.
As per the MIB.
pwMplsStorageType (1.3.6.1.2.1.181.1.1.1.8)
read-write
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for this role.
This value is always nonVolatile(3).
pwMplsOutboundTable
About this table
Use this table to configure and obtain detailed information about the MPLS public tunnel that carries the PW traffic toward the public network.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
pwMplsOutboundLsrXcIndex (1.3.6.1.2.1.181.1.2.1.1)
read-write
MplsIndexType
OCTET STRING (1..24)
XC index of the public tunnel.
pwMplsOutboundTunnelIndex (1.3.6.1.2.1.181.1.2.1.2)
read-write
MplsIndexIndex
ID of the public tunnel.
pwMplsOutboundTunnelInstance (1.3.6.1.2.1.181.1.2.1.3)
read-only
MplsTunnelInstanceIndex
Unsigned32 (0 | 1..65535 | 65536..2147483647)
CRLSP ID of the public tunnel.
As per the MIB.
pwMplsOutboundTunnelLclLSR (1.3.6.1.2.1.181.1.2.1.4)
read-write
MplsLsrIdentifier
OCTET STRING (4)
Ingress LSR ID of the public tunnel.
pwMplsOutboundTunnelPeerLSR (1.3.6.1.2.1.181.1.2.1.5)
read-write
MplsLsrIdentifier
OCTET STRING (4)
Egress LSR ID of the public tunnel.
pwMplsOutboundIfIndex (1.3.6.1.2.1.181.1.2.1.6)
read-write
InterfaceIndexOrZero
Integer32 (0..2147483647)
Index of the outgoing interface of the public tunnel.
pwMplsOutboundTunnelTypeInUse (1.3.6.1.2.1.181.1.2.1.7)
read-only
INTEGER
notYetKnown(1),
mplsTe(2),
mplsNonTe(3),
pwOnly(4)
Type of the public tunnel that is carrying the PW traffic.
As per the MIB.
