10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10010-MPLS
09-HH3C-MPLSBFD-MIB
09-HH3C-MPLSBFD-MIB 59.32 KB
HH3C-MPLSBFD-MIB
About this MIB
Use HH3C-MPLSBFD-MIB to manage MPLS and BFD capabilities and MPLS BFD sessions.
MIB file name
hh3c-mplsbfd.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsBfd(261)
Scalar objects
hh3cMplsBfdBaseInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsBfdBaseInfo (1.3.6.1.4.1.25506.2.261.1.1.1)
accessible-for-notify
OCTET STRING
OCTET STRING (1..127)
Basic information of MBFD.
As per the MIB.
hh3cMplsBfdExtInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsBfdExtInfo (1.3.6.1.4.1.25506.2.261.1.1.2)
OCTET STRING
Extended information of MBFD.
As per the MIB.
Notifications
hh3cMplsBfdTracerouteFailed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.261.0.1
BFD echo reply with invalid return code
Error
Major
N/A
OFF
Notification triggers
This notification is generated when the system receives a BFD echo reply with an invalid return code during a periodic traceroute for an LSP or MPLS TE tunnel. This notification might indicate a periodic-traceroute function issue or an LSP or MPLS TE tunnel failure.
System impact
·     If the failure reason is Malformed echo request received or One or more of the TLVs was not understood, this notification indicates a periodic-traceroute function issue, which has no negative impact on the system or services.
·     If the failure reason is other values, this notification indicates an LSP or MPLS TE tunnel failure, which might cause forwarding failure for the traffic transmitted over this LSP or TE tunnel.
Status control
ON
CLI: Use the snmp-agent trap enable mbfd-private command.
OFF
CLI: Use the undo snmp-agent trap enable mbfd-private command.
Objects
OID (object name)
Index nodes
Value range
hh3cMplsBfdBaseInfo
N/A
OCTET STRING
Standard MIB values
hh3cMplsBfdExtInfo
N/A
OCTET STRING
Standard MIB values
Recommended action
To resolve this issue:
1.     Verify that the LSP or MPLS TE tunnel configuration is correct.
2.     If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
