10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10010-MPLS
21-MPLS-TE-STD-MIB
21-MPLS-TE-STD-MIB 256.35 KB
MPLS-TE-STD-MIB
About this MIB
MPLS-TE-STD-MIB is a standard MIB based on RFC 3812.
Network congestion can degrade the network backbone performance. It might occur when network resources are inadequate or when load distribution is unbalanced. Traffic engineering (TE) is intended to avoid the latter situation where partial congestion might occur because of improper resource allocation.
TE can make the best use of network resources and avoid uneven load distribution by using the following functionalities:
·     Real-time monitoring of traffic and traffic load on network elements.
·     Dynamic tuning of traffic management attributes, routing parameters, and resources constraints.
MPLS TE combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution.
With MPLS TE, a service provider can deploy traffic engineering on the existing MPLS backbone to provide various services and optimize network resources management.
MIB file name
rfc3812-mpls-te-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
mplsTunnelConfigured
Object (OID)
Access
Value range
Implementation
mplsTunnelConfigured (1.3.6.1.2.1.10.166.3.1.1)
read-only
Integer32
Integer32
(0..4294967295)
Number of configured tunnels.
As per the MIB.
mplsTunnelActive
Object (OID)
Access
Value range
Implementation
mplsTunnelActive (1.3.6.1.2.1.10.166.3.1.2)
read-only
Unsigned32
Unsigned32
(0..4294967295)
Number of active tunnels.
As per the MIB.
mplsTunnelTEDistProto
Object (OID)
Access
Value range
Implementation
mplsTunnelTEDistProto (1.3.6.1.2.1.10.166.3.1.3)
read-only
BITS
other(0)
ospf(1)
isis(2)
IGP used to advertise link information.
As per the MIB.
mplsTunnelMaxHops
Object (OID)
Access
Value range
Implementation
mplsTunnelMaxHops (1.3.6.1.2.1.10.166.3.1.4)
read-only
Unsigned32
Unsigned32
(255)
Maximum number of hops allowed by a tunnel.
As per the MIB.
mplsTunnelNotificationMaxRate
Object (OID)
Access
Value range
Implementation
mplsTunnelNotificationMaxRate (1.3.6.1.2.1.10.166.3.1.5)
read-write
Unsigned32
Unsigned32
(0..4294967295)
Tunnel advertisement frequency.
Supports only the read operation.
mplsTunnelIndexNext
Object (OID)
Access
Value range
Implementation
mplsTunnelIndexNext (1.3.6.1.2.1.10.166.3.2.1)
read-only
Unsigned32
Unsigned32
(0..65535)
Next tunnel index.
As per the MIB.
mplsTunnelHopListIndexNext
Object (OID)
Access
Value range
Implementation
mplsTunnelHopListIndexNext (1.3.6.1.2.1.10.166.3.2.3)
read-only
Unsigned32
Unsigned32
(0..4294967295)
Appropriate value to be used for mplsTunnelHopListIndex when creating entries in the mplsTunnelHopTable.
As per the MIB.
mplsTunnelResourceIndexNext
Object (OID)
Access
Value range
Implementation
mplsTunnelResourceIndexNext (1.3.6.1.2.1.10.166.3.2.5)
read-only
Unsigned32
Unsigned32
(0..2147483647
Next resource table index.
As per the MIB.
mplsTunnelNotificationEnable
Object (OID)
Access
Value range
Implementation
mplsTunnelNotificationEnable (1.3.6.1.2.1.10.166.3.2.11)
read-write
TruthValue
true(1),
false(2)
Whether MPLS TE notification is enabled.
As per the MIB.
Tabular objects
mplsTunnelTable
About this table
This table allows you to create new MPLS tunnels between an LSR and a remote endpoint and delete existing tunnels.
Support for operations
Create
Edit/Modify
Delete
Read
You can create only tunnel interfaces. To create a tunnel interface, configure mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, and mplsTunnelEgressLSRId, and use the default settings for other objects. The value of the mplsTunnelInstance object must be 0.
To create a static tunnel interface, associate it with a static CRLSP.
Not supported
Supported
Supported
Columns
The table indexes are mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, and mplsTunnelEgressLSRId.
Object (OID)
Access
Value range
Implementation
mplsTunnelIndex (1.3.6.1.2.1.10.166.3.2.2.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Tunnel index.
As per the MIB.
mplsTunnelInstance (1.3.6.1.2.1.10.166.3.2.2.1.2)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Tunnel instance ID.
As per the MIB.
mplsTunnelIngressLSRId (1.3.6.1.2.1.10.166.3.2.2.1.3)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Router ID of the ingress LSR.
As per the MIB.
mplsTunnelEgressLSRId (1.3.6.1.2.1.10.166.3.2.2.1.4)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Router ID of the egress LSR.
As per the MIB.
mplsTunnelName (1.3.6.1.2.1.10.166.3.2.2.1.5)
read-create
Octet String
Octet String
(0..255)
Tunnel name.
As per the MIB.
mplsTunnelDescr (1.3.6.1.2.1.10.166.3.2.2.1.6)
read-create
Octet String
Octet String
(0..255)
Tunnel description.
As per the MIB.
mplsTunnelIsIf (1.3.6.1.2.1.10.166.3.2.2.1.7)
read-create
TruthValue
true(1),
false(2)
Tunnel.
As per the MIB.
mplsTunnelIfIndex (1.3.6.1.2.1.10.166.3.2.2.1.8)
read-only
Integer32
Integer32
(0..2147483647
Tunnel interface index.
As per the MIB.
mplsTunnelOwner (1.3.6.1.2.1.10.166.3.2.2.1.9)
read-only
Integer
unknown(1),
other(2),
snmp(3),
ldp(4),
crldp(5),
rsvpTe(6),
policyAgent(7)
Tunnel owner.
As per the MIB.
mplsTunnelRole (1.3.6.1.2.1.10.166.3.2.2.1.10)
read-create
Integer
head(1),
transit(2),
tail(3),
headTail(4)
Role that this tunnel entry/instance represents.
The value of Set operation is head(1).
mplsTunnelXCPointer (1.3.6.1.2.1.10.166.3.2.2.1.11)
read-create
Object Identifier
Standard MIB values.
Pointer to a row in the mplsXCTable.
As per the MIB.
mplsTunnelSignallingProto (1.3.6.1.2.1.10.166.3.2.2.1.12)
read-create
Integer
none(1),
rsvp(2),
crldp(3),
other(4)
Tunnel signaling protocol.
Supports only rsvp(2) and other(4).
mplsTunnelSetupPrio (1.3.6.1.2.1.10.166.3.2.2.1.13)
read-create
Integer32
Integer32
(0..7)
Tunnel setup priority.
As per the MIB.
mplsTunnelHoldingPrio (1.3.6.1.2.1.10.166.3.2.2.1.14)
read-create
Integer32
Integer32
(0..7)
Tunnel holding priority.
As per the MIB.
mplsTunnelSessionAttributes (1.3.6.1.2.1.10.166.3.2.2.1.15)
read-create
BITS
fastReroute (0),
mergingPermitted (1),
isPersistent (2),
isPinned (3),
recordRoute(4)
Tunnel session attributes.
As per the MIB.
mplsTunnelLocalProtectInUse (1.3.6.1.2.1.10.166.3.2.2.1.16)
read-create
TruthValue
true(1),
false(2)
Whether local protection is enabled for the tunnel.
As per the MIB.
mplsTunnelResourcePointer (1.3.6.1.2.1.10.166.3.2.2.1.17)
read-create
Object Identifier
Tunnel resource pointer.
mplsTunnelPrimaryInstance (1.3.6.1.2.1.10.166.3.2.2.1.18)
read-only
Unsigned32
Unsigned32
(0..2147483647)
Primary instance of the tunnel.
As per the MIB.
mplsTunnelInstancePriority (1.3.6.1.2.1.10.166.3.2.2.1.19)
read-creaet
Unsigned32
Unsigned32
(0..4294967295)
Tunnel instance priority.
Not supported. The value is fixed at 1.
mplsTunnelHopTableIndex (1.3.6.1.2.1.10.166.3.2.2.1.20)
read-create
Unsigned32
Unsigned32
(0..2147483647)
Hop table index.
mplsTunnelPathInUse (1.3.6.1.2.1.10.166.3.2.2.1.21)
read-create
Unsigned32
Unsigned32
(0..2147483647)
Path used by the tunnel.
mplsTunnelARHopTableIndex (1.3.6.1.2.1.10.166.3.2.2.1.22)
read-only
Unsigned32
Unsigned32
(0..2147483647)
ARHop table index.
As per the MIB.
mplsTunnelCHopTableIndex (1.3.6.1.2.1.10.166.3.2.2.1.23)
read-only
Unsigned32
Unsigned32
(0..2147483647)
Chop table index.
As per the MIB.
mplsTunnelIncludeAnyAffinity (1.3.6.1.2.1.10.166.3.2.2.1.24)
read-create
Unsigned32
Unsigned32
(0..2147483647)
IncludeAny affinity attribute.
As per the MIB.
mplsTunnelIncludeAllAffinity (1.3.6.1.2.1.10.166.3.2.2.1.25)
read-create
Unsigned32
Unsigned32
(0..2147483647)
IncludeAll affinity attribute.
The value is fixed at 0. If set to other values, this parameter will be ignored.
This value can be obtained after the path for the MPLS TE tunnel is established.
mplsTunnelExcludeAnyAffinity (1.3.6.1.2.1.10.166.3.2.2.1.26)
read-create
Unsigned32
Unsigned32
(0..2147483647)
A link satisfies the exclude-any constraint if and only if the link contains none of the administrative groups specified in the constraint.
As per the MIB.
mplsTunnelTotalUpTime (1.3.6.1.2.1.10.166.3.2.2.1.27)
read-only
TimeTicks
Aggregate up time for all instances of this tunnel, if available.
As per the MIB.
mplsTunnelInstanceUpTime (1.3.6.1.2.1.10.166.3.2.2.1.28)
read-only
TimeTicks
Total time that the tunnel instance's operStatus has been Up(1).
As per the MIB.
mplsTunnelPrimaryUpTime (1.3.6.1.2.1.10.166.3.2.2.1.29)
read-only
TimeTicks
Total time the primary instance of the tunnel has been active.
As per the MIB.
mplsTunnelPathChanges (1.3.6.1.2.1.10.166.3.2.2.1.30)
read-only
Counter32
Number of times the actual path for the tunnel instance has changed.
As per the MIB.
mplsTunnelLastPathChange (1.3.6.1.2.1.10.166.3.2.2.1.31)
read-only
TimeTicks
Time since the last change to the actual path for the tunnel instance.
As per the MIB.
mplsTunnelCreationTime (1.3.6.1.2.1.10.166.3.2.2.1.32)
read-only
TimeTicks
Time when the tunnel was created.
As per the MIB.
mplsTunnelStateTransitions (1.3.6.1.2.1.10.166.3.2.2.1.33)
read-only
Counter32
Counter32
(0..4294967295)
Number of times the state of this tunnel instance has changed.
As per the MIB.
mplsTunnelAdminStatus (1.3.6.1.2.1.10.166.3.2.2.1.34)
read-create
Integer
up(1),
down(2),
testing(3)
Administrative state of the tunnel.
Supports only up(1).
mplsTunnelOperStatus (1.3.6.1.2.1.10.166.3.2.2.1.35)
read-only
Integer
up(1),
down(2),
testing(3),
unknown(4),
dormant(5),
notPresent(6),
lowerlayerDown(7)
Operational state of the tunnel.
Supports only up(1) and
down(2).
mplsTunnelRowStatus (1.3.6.1.2.1.10.166.3.2.2.1.36)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4), createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
mplsTunnelStorageType (1.3.6.1.2.1.10.166.3.2.2.1.37)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
As per the MIB.
mplsTunnelHopTable
About this table
This table contains explicit path information for tunnel interfaces.
Create
Edit/Modify
Delete
Read
The mplsTunnelHopPathOptionName object must be specified.
The value range for the mplsTunnelHopPathOptionIndex object is 1 to 10 for the primary CRLSP and 101 to 110 for the backup CRLSP.
When the value of the mplsTunnelHopEntryPathComp object is dynamic(1), the value of the mplsTunnelHopIndex object must be 0.
Not supported
Supported
Supported
Columns
The table indexes are mplsTunnelHopListIndex, mplsTunnelHopPathOptionIndex, and mplsTunnelHopIndex.
Object (OID)
Access
Value range
Implementation
mplsTunnelHopListIndex (1.3.6.1.2.1.10.166.3.2.4.1.1)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
Hop table index.
As per the MIB.
mplsTunnelHopPathOptionIndex (1.3.6.1.2.1.10.166.3.2.4.1.2)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
Path option index.
As per the MIB.
mplsTunnelHopIndex (1.3.6.1.2.1.10.166.3.2.4.1.3)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
Hop index.
As per the MIB.
mplsTunnelHopAddrType (1.3.6.1.2.1.10.166.3.2.4.1.4)
read-create
TeHopAddressType
Integer
Unsigned32
(1..2147483647)
Address type.
Supports only ipv4(1).
mplsTunnelHopIpAddr (1.3.6.1.2.1.10.166.3.2.4.1.5)
read-create
TeHopAddress
OCTET STRING
(0..32)
Address.
As per the MIB.
mplsTunnelHopIpPrefixLen (1.3.6.1.2.1.10.166.3.2.4.1.6)
read-create
InetAddressPrefixLength
Unsigned32
(0..2040)
Address prefix.
As per the MIB.
mplsTunnelHopAsNumber (1.3.6.1.2.1.10.166.3.2.4.1.7)
read-create
TeHopAddressAS
OCTET STRING
(4)
自治域号
不支持.
mplsTunnelHopAddrUnnum (1.3.6.1.2.1.10.166.3.2.4.1.8)
read-create
TeHopAddressUnnum
OCTET STRING
(4)
地址借用
不支持.
mplsTunnelHopLspId (1.3.6.1.2.1.10.166.3.2.4.1.9)
read-create
MplsLSPID
OCTET STRING
(2 | 6)
Hop使用的LSPID
不支持.
mplsTunnelHopType (1.3.6.1.2.1.10.166.3.2.4.1.10)
read-create
Integer
strict(1),
loose(2)
Hop type.
As per the MIB.
mplsTunnelHopInclude (1.3.6.1.2.1.10.166.3.2.4.1.11)
read-create
TurthValue
true(1),
false(2)
Whether this hop is included in the tunnel's path.
As per the MIB.
mplsTunnelHopPathOptionName (1.3.6.1.2.1.10.166.3.2.4.1.12)
read-create
SnmpAdminString
OCTET STRING
(0..255)
Description of this series of hops as they relate to the specified path option.
As per the MIB.
mplsTunnelHopEntryPathComp (1.3.6.1.2.1.10.166.3.2.4.1.13)
read-create
Integer
dynamic(1),
explicit(2)
Features using the path.
As per the MIB.
mplsTunnelHopRowStatus (1.3.6.1.2.1.10.166.3.2.4.1.14)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
mplsTunnelHopStorageType (1.3.6.1.2.1.10.166.3.2.4.1.15)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
The value of this object is fixed at nonvolatile(3).
mplsTunnelResourceTable
About this table
This table contains tunnel resource information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Objects used by mplsXCEntry objects cannot be deleted.
Supported
Columns
The table index is mplsTunnelResourceIndex.
Object (OID)
Access
Value range
Implementation
mplsTunnelResourceIndex (1.3.6.1.2.1.10.166.3.2.6.1.1)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
Resource table index.
As per the MIB.
mplsTunnelResourceMaxRate (1.3.6.1.2.1.10.166.3.2.6.1.2)
read-create
Unsigned32
Unsigned32
(0..4294967295)
Maximum transmission rate.
As per the MIB.
mplsTunnelResourceMeanRate (1.3.6.1.2.1.10.166.3.2.6.1.3)
read-create
Unsigned32
Unsigned32
(1..4294967295)
Minimum transmission rate.
As per the MIB.
mplsTunnelResourceMaxBurstSize (1.3.6.1.2.1.10.166.3.2.6.1.4)
read-create
Unsigned32
Unsigned32
(0..2147483647)
Maximum burst size.
As per the MIB.
mplsTunnelResourceMeanBurstSize (1.3.6.1.2.1.10.166.3.2.6.1.5)
read-create
Unsigned32
Unsigned32
(0..2147483647)
Minimum burst size.
As per the MIB.
mplsTunnelResourceExBurstSize (1.3.6.1.2.1.10.166.3.2.6.1.6)
read-create
Unsigned32
Unsigned32
(0..2147483647)
Excess burst size in bytes.
As per the MIB.
mplsTunnelResourceFrequency (1.3.6.1.2.1.10.166.3.2.6.1.7)
read-create
Integer
unspecified(1),
frequent(2),
veryFrequent(3)
Guaranteed traffic size.
Not supported.
mplsTunnelResourceWeight (1.3.6.1.2.1.10.166.3.2.6.1.8)
read-create
Unsigned32
Unsigned32
(0..255)
Weight of the excessive traffic.
Not supported.
mplsTunnelResourceRowStatus (1.3.6.1.2.1.10.166.3.2.6.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
mplsTunnelResourceStorageType (1.3.6.1.2.1.10.166.3.2.6.1.10)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
Not supported.
The value of this object is fixed at 3.
About this table
This table contains tunnel ARHop information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsTunnelARHopListIndex and mplsTunnelARHopIndex.
Object (OID)
Access
Value range
Implementation
mplsTunnelARHopListIndex (1.3.6.1.2.1.10.166.3.2.7.1.1)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
ARHop table index.
As per the MIB.
mplsTunnelARHopIndex (1.3.6.1.2.1.10.166.3.2.7.1.2)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
ARHop index.
As per the MIB.
mplsTunnelARHopAddrType (1.3.6.1.2.1.10.166.3.2.7.1.3)
read-only
TeHopAddressType
unknown(0),
ipv4(1),
ipv6(2),
asnumber(3),
unnum(4),
lspid(5)
Address type.
mplsTunnelARHopIpAddr (1.3.6.1.2.1.10.166.3.2.7.1.4)
read-only
TeHopAddress
OCTET STRING
(0..32)
IP address.
As per the MIB.
mplsTunnelARHopAddrUnnum (1.3.6.1.2.1.10.166.3.2.7.1.5)
read-only
TeHopAddressUnnum
OCTET STRING
(4)
Address borrowing.
Not supported.
mplsTunnelARHopLspId (1.3.6.1.2.1.10.166.3.2.7.1.6)
read-only
MplsLSPID
OCTET STRING
(2 | 6)
LSP ID used by hop.
Not supported.
mplsTunnelCHopTable
About this table
This table contains CHop information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsTunnelCHopListIndex and mplsTunnelCHopIndex.
Object (OID)
Access
Value range
Implementation
mplsTunnelCHopListIndex (1.3.6.1.2.1.10.166.3.2.8.1.1)
not-accessible
Unsinged32
Unsinged32
(1..2147483647)
CHop table index.
As per the MIB.
mplsTunnelCHopIndex (1.3.6.1.2.1.10.166.3.2.8.1.2)
not-accessible
Unsigned32
Unsigned32
(1..2147483647)
CHop index
As per the MIB.
mplsTunnelCHopAddrType (1.3.6.1.2.1.10.166.3.2.8.1.3)
read-only
TeHopAddressType
unknown(0),
ipv4(1),
ipv6(2),
asnumber(3),
unnum(4),
lspid(5)
Address type.
mplsTunnelCHopIpAddr (1.3.6.1.2.1.10.166.3.2.8.1.4)
read-only
TeHopAddress
OCTET STRING
(0..32)
IP address.
As per the MIB.
mplsTunnelCHopIpPrefixLen (1.3.6.1.2.1.10.166.3.2.8.1.5)
read-only
OCTET STRING (0..32)
Address prefix.
As per the MIB.
mplsTunnelCHopAsNumber (1.3.6.1.2.1.10.166.3.2.8.1.6)
read-only
TeHopAddressAS
OCTET STRING
(4)
Autonomous system number.
Not supported.
mplsTunnelCHopAddrUnnum (1.3.6.1.2.1.10.166.3.2.8.1.7)
read-only
OCTET STRING
OCTET STRING
(4)
Address borrowing.
Not supported.
mplsTunnelCHopLspId (1.3.6.1.2.1.10.166.3.2.8.1.8)
read-only
MplsLSPID
OCTET STRING
(2 | 6)
Used LSPID.
Not supported.
mplsTunnelCHopType (1.3.6.1.2.1.10.166.3.2.8.1.9)
read-only
Integer
strict(1),
loose(2)
CHop type.
As per the MIB.
mplsTunnelCRLDPResTable
About this table
This table is used to implement the function of querying the resource information table for tunnels established using CRLDP.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is none.
Object (OID)
Access
Value range
Implementation
mplsTunnelCRLDPResMeanBurstSize (1.3.6.1.2.1.10.166.3.2.10.1.1)
read-create
Unsigned32
Unsigned32
(0..2147483647)
CRLDP min burst traffic.
Not supported.
mplsTunnelCRLDPResExBurstSize (1.3.6.1.2.1.10.166.3.2.10.1.2)
read-create
Unsigned32
Unsigned32
(0..2147483647)
CRLDP excessive burst traffic.
Not supported.
mplsTunnelCRLDPResFrequency (1.3.6.1.2.1.10.166.3.2.10.1.3)
read-create
Integer
unspecified(1),
frequent(2),
veryFrequent(3)
CRLDP guaranteed traffic.
Not supported.
mplsTunnelCRLDPResWeight (1.3.6.1.2.1.10.166.3.2.10.1.4)
read-create
Unsigned32
Unsigned32
(0..255)
Bandwidth exceeded the predetermined value on CRLDP.
Not supported.
mplsTunnelCRLDPResFlags (1.3.6.1.2.1.10.166.3.2.10.1.5)
read-create
Unsigned32
0..63
Traffic-related identifier for CRLDP.
Not supported.
mplsTunnelCRLDPResRowStatus (1.3.6.1.2.1.10.166.3.2.10.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Not supported.
mplsTunnelCRLDPResStorageType (1.3.6.1.2.1.10.166.3.2.10.1.7)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
Not supported.
mplsTunnelPerfTable
About this table
This table contains tunnel performance parameters.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
mplsTunnelPerfPackets (1.3.6.1.2.1.10.166.3.2.9.1.1)
read-only
Counter32
Counter32
(0..4294967295)
Number of forwarded packets. This object represents the 32-bit value of the least significant part of the 64-bit value if mplsTunnelPerfHCPackets is also returned.
As per the MIB.
mplsTunnelPerfHCPackets (1.3.6.1.2.1.10.166.3.2.9.1.2)
read-only
Counter64
Counter64
(0..18446744073709551615)
High capacity counter for number of packets forwarded by this tunnel.
As per the MIB.
mplsTunnelPerfErrors (1.3.6.1.2.1.10.166.3.2.9.1.3)
read-only
Counter32
Counter32
(0..4294967295)
Number of error packets.
As per the MIB.
mplsTunnelPerfBytes (1.3.6.1.2.1.10.166.3.2.9.1.4)
read-only
Counter32
Counter32
(0..4294967295)
Number of forwarded bytes. This object represents the 32-bit value of the least significant part of the 64-bit value if mplsTunnelPerfHCBytes is also returned.
As per the MIB.
mplsTunnelPerfHCBytes (1.3.6.1.2.1.10.166.3.2.9.1.5)
read-only
Counter64
Counter64
High capacity counter for number of bytes forwarded by the tunnel.
As per the MIB.
Notifications
mplsTunnelUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.3.0.1
A tunnel comes up.
Recovery
Warning
N/A
ON
Notification triggers
This notification is generated when the operational state (indicated by the mplsTunnelOperStatus object) of a tunnel changes from down to another value (except for notPresent).
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name)
Index nodes
Value range
 (mplsTunnelAdminStatus)
mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, mplsTunnelEgressLSRId
INTEGER
up(1)
down(2)
testing(3)
(mplsTunnelOperStatus)
Actual state of the tunnel.
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
No action is required.
mplsTunnelDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.3.0.2
The operation state of a tunnel becomes down.
Error
Major
N/A
ON
For all types of tunnels, possible reasons for this notification include the following:
·     The interface went Down.
·     The configuration of the tunnel was deleted.
·     The link was faulty.
·     The tunnel was manually shut down.
·     Others
For RSVP-TE tunnels, possible reasons for this notification also include the following:
·     RSVP-TE LSP resources were preempted.
·     Transmission of an RSVP message timed out.
·     RSVP Hello mechanism detected a downstream node failure.
·     CSPF failed to calculate a path.
For Segment Routing TE tunnels, possible reasons for this notification also include the following:
·     IGP calculation or verification failed.
For static TE tunnels, possible reasons for this notification also include:
·     A static CR-LSP went Down.
·     A static SR-LSP went Down.
System impact
Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
INTEGER
up(1)
down(2)
testing(3)
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
To resolve this issue:
1.     Check the current tunnel interface configuration, IGP configuration, and the whole tunnel path.
¡     If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
-     If yes, clear link faults.
-     If no, execute step 2 or 3 according to the tunnel type.
¡     If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2 or 3 according to the tunnel type.
2.     For an RSVP-TE tunnel, check whether the RSVP protocol, link bandwidth, and link affinity settings are correct.
¡     If the settings are correct but the issue persists, go to step 4.
¡     If the settings are not correct, edit the related configuration.
3.     For a static MPLS TE tunnel, check whether static CRLSP or SRLSP settings are correct.
4.     If the issue persists, collect log messages and configuration data, and then contact Technical Support for help.
mplsTunnelRerouted
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.3.0.3
A tunnel is rerouted.
Informational
Warning
N/A
ON
This notification is generated when a tunnel is rerouted because of the current path used by the tunnel is unreachable. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
INTEGER
up(1)
down(2)
testing(3)
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
mplsTunnelReoptimized
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.3.0.4
A tunnel is reoptimized.
Informational
Warning
N/A
ON
This notification is generated when the optimal path is selected successfully for a tunnel during tunnel reoptimization. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.10.166.3.2.2.1.34 (mplsTunnelAdminStatus)
INTEGER
up(1)
down(2)
testing(3)
1.3.6.1.2.1.10.166.3.2.2.1.35 (mplsTunnelOperStatus)
INTEGER
up(1)
down(2)
 testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
